commit f537da685c35a81a75f6067751bddb902c8adb68 upstream.
Obviously, {} is needed in the branch of
"else if (hcd->driver->flags & HCD_LOCAL_MEM)"
for handling of setup packet mapping.
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 9d1ac34ec3a67713308ae0883c3359c557f14d17 upstream.
In kernel Bugzilla #15825 (2 users), in a wireless mailing list thread
(http://lists.infradead.org/pipermail/b43-dev/2010-May/000124.html), and on a
netbook owned by John Linville
(http://marc.info/?l=linux-wireless&m=127230751408818&w=4), there are reports
of ssb failing to detect an SPROM at the normal location. After studying the
MMIO trace dump for the Broadcom wl driver, it was determined that the affected
boxes had a relocated SPROM.
This patch fixes all systems that have reported this problem.
Cc: Ben Hutchings <ben@decadent.org.uk>
commit da1fdb02d9200ff28b6f3a380d21930335fe5429 upstream.
Ethernet driver b44 does register ssb by it's pcihost_wrapper
and doesn't set ssb_chipcommon. A check on this value
introduced with commit d53cdbb94a52a920d5420ed64d986c3523a56743
and ea2db495f92ad2cf3301623e60cb95b4062bc484 triggers:
BUG: unable to handle kernel NULL pointer dereference at 00000010
IP: [<c1266c36>] ssb_is_sprom_available+0x16/0x30
Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
commit ea2db495f92ad2cf3301623e60cb95b4062bc484 upstream.
Our offset handling becomes even a little more hackish now. For some reason I
do not understand all offsets as inrelative. It assumes base offset is 0x1000
but it will work for now as we make offsets relative anyway by removing base
0x1000. Should be cleaner however.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
commit d53cdbb94a52a920d5420ed64d986c3523a56743 upstream.
Attempting to read registers that don't exist on the SSB bus can cause
hangs on some boxes. At least some b43 devices are 'in the wild' that
don't have SPROMs at all. When the SSB bus support loads, it attempts
to read these (non-existant) SPROMs and causes hard hangs on the box --
no console output, etc.
This patch adds some intelligence to determine whether or not the SPROM
is present before attempting to read it. This avoids those hard hangs
on those devices with no SPROM attached to their SSB bus. The
SSB-attached devices (e.g. b43, et al.) won't work, but at least the box
will survive to test further patches. :-)
Cc: Michael Buesch <mb@bu3sch.de>
Turns out this isn't the best way to resolve this issue. The
individual patches will be applied instead.
commit a1efd14a99483a4fb9308902397ed86b69454c99 upstream.
Apparently i830 and i845 cannot handle any stride that is not a multiple
of 256, unlike their brethren which do support 64 byte aligned strides.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Eric Anholt <eric@anholt.net>
commit 812d046915f48236657f02c06d7dc47140e9ceda upstream.
Use of HDP_*_COHERENCY_FLUSH_CNTL can cause a hang in certain
situations. Add workaround.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
commit 1297c05a8dfb568c689f057d51a65eebe5ddc86f upstream.
New evergreen and r7xx ids.
commit 4c70b2eae371ebe83019ac47de6088b78124ab36 upstream.
Intel variants don't support it.
commit 8a22b9996b001c88f2bfb54c6de6a05fc39e177a upstream.
xen_sched_clock only counts unstolen time. In principle this should
be useful to the Linux scheduler so that it knows how much time a process
actually consumed. But in practice this doesn't work very well as the
scheduler expects the sched_clock time to be synchronized between
cpus. It also uses sched_clock to measure the time a task spends
sleeping, in which case "unstolen time" isn't meaningful.
So just use plain xen_clocksource_read to return wallclock nanoseconds
for sched_clock.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
(cherry picked from commit 91546356d0e550fa23abf7f4b04a903c2855761f)
After remove a rmap, we should flush all vcpu's tlb
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit 728a756b8fcd22d80e2dbba8117a8a3aafd3f203 upstream.
This patch fixes a kernel Oops in the GFS2 rename code.
The problem was in the way the gfs2 directory code was trying
to re-use sentinel directory entries.
In the failing case, gfs2's rename function was renaming a
file to another name that had the same non-trivial length.
The file being renamed happened to be the first directory
entry on the leaf block.
First, the rename code (gfs2_rename in ops_inode.c) found the
original directory entry and decided it could do its job by
simply replacing the directory entry with another. Therefore
it determined correctly that no block allocations were needed.
Next, the rename code deleted the old directory entry prior to
replacing it with the new name. Therefore, the soon-to-be
replaced directory entry was temporarily made into a directory
entry "sentinel" or a place holder at the start of a leaf block.
Lastly, it went to re-add the replacement directory entry in
that leaf block. However, when gfs2_dirent_find_space was
looking for space in the leaf block, it used the wrong value
for the sentinel. That threw off its calculations so later
it decides it can't really re-use the sentinel and therefore
must allocate a new leaf block. But because it previously decided
to re-use the directory entry, it didn't waste the time to
grab a new block allocation for the inode. Therefore, the
inode's i_alloc pointer was still NULL and it crashes trying to
reference it.
In the case of sentinel directory entries, the entire dirent is
reused, not just the "free space" portion of it, and therefore
the function gfs2_dirent_find_space should use the value 0
rather than GFS2_DIRENT_SIZE(0) for the actual dirent size.
Fixing this calculation enables the reproducer programs to work
properly.
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
commit a91c1be21704113b023919826c6d531da46656ef upstream.
we also need to clean up and free the cdev.
Reported-by: Jani Nikula <ext-jani.1.nikula@nokia.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
commit c937019761a758f2749b1f3a032b7a91fb044753 upstream.
While mesh_rx_plink_frame holds sta->lock...
mesh_rx_plink_frame ->
mesh_plink_inc_estab_count ->
ieee80211_bss_info_change_notify
...but ieee80211_bss_info_change_notify is allowed to sleep. A driver
taking advantage of that allowance can cause a scheduling while
atomic bug. Similar paths exist for mesh_plink_dec_estab_count,
so work around those as well.
http://bugzilla.kernel.org/show_bug.cgi?id=16099
Also, correct a minor kerneldoc comment error (mismatched function names).
commit ccb6c1360f8dd43303c659db718e7e0b24175db5 upstream.
When kernel-internal users use cfg80211_get_bss()
to get a reference to a BSS struct, they may end
up getting one that would have been removed from
the list if there had been any userspace access
to the list. This leads to inconsistencies and
problems.
Fix it by making cfg80211_get_bss() ignore BSSes
that cfg80211_bss_expire() would remove.
Fixes http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2180
Reported-by: Jiajia Zheng <jiajia.zheng@intel.com>
Tested-by: Jiajia Zheng <jiajia.zheng@intel.com>
commit 643f82e32f14faf0d0944c804203a6681b6b0a1e upstream.
Ever since mac80211/drivers are no longer
fully in charge of keeping track of the
auth status, trying to make them do so will
fail. Instead of warning and reporting the
deauthentication to userspace, cfg80211 must
simply ignore it so that spurious
deauthentications, e.g. before starting
authentication, aren't seen by userspace as
actual deauthentications.
Reported-by: Paul Stewart <pstew@google.com>
commit d28232b461b8d54b09e59325dbac8b0913ce2049 upstream.
Fix possible double priv->mutex lock introduced by commit
a69b03e941abae00380fc6bc1877fb797a1b31e6
"iwlwifi: cancel scan watchdog in iwl_bg_abort_scan" .
We can not call cancel_delayed_work_sync(&priv->scan_check) with
priv->mutex locked because workqueue function iwl_bg_scan_check()
take that lock internally.
We do not need to synchronize when canceling priv->scan_check work.
We can avoid races (sending double abort command or send no
command at all) using STATUS_SCAN_ABORT bit. Moreover
current iwl_bg_scan_check() code seems to be broken, as
we should not send abort commands when currently aborting.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit 4cee78614cfa046a26c4fbf313d5bbacb3ad8efc upstream.
When an aggregation session is being cleaned up, while the tx status
for some frames is being processed, the TID is flushed and its buffers
are sent out.
Unfortunately that left the pending un-acked frames unprocessed, thus
leaking buffers. Fix this by reordering the code so that those frames
are processed first, before the TID is flushed.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
commit f860d526eb2939a1c37128900b5af2b6f3ff7f20 upstream.
When issuing a reset, the TSF value is lost in the hardware because of
the 913x specific cold reset. As with some AR9280 cards, the TSF needs
to be preserved in software here.
Additionally, there's an issue that frequently prevents a successful
TSF write directly after the chip reset. In this case, repeating the
TSF write after the initval-writes usually works.
This patch detects failed TSF writes and recovers from them, taking
into account the delay caused by the initval writes.
Reported-by: Björn Smedman <bjorn.smedman@venatech.se>
commit 03b4776c408d2f4bf3a5d204e223724d154716d1 upstream.
PDADC values were only generated for values surrounding the target
index, however not for the target index itself, leading to a minor
error in the generated curve.
commit 2b40994cabd2f545d5c11d3a65dcee6f6f9155f8 upstream.
It looks like it might be possible for a TID to be paused, while still
holding some queued buffers, however ath_tx_node_cleanup currently only
iterates over active TIDs.
Fix this by always checking every allocated TID for the STA that is being
cleaned up.
commit 4c85ab11ca56da1aa59b58c80cc6a356515cc645 upstream.
https://bugzilla.kernel.org/show_bug.cgi?id=16476
Acked-by: Luis R. Rodriguez <lrodriguez@atheros.com>
commit 5fa8517f038d51d571981fb495206cc30ed91b06 upstream.
The 82576 expects the second rx queue in any pool to receive L2 switch
loop back packets sent from the second tx queue in another pool. The
82576 VF driver does not enable the second rx queue so if the PF driver
sends packets destined to a VF from its second tx queue then the VF
driver will never see them. In SR-IOV mode limit the number of tx queues
used by the PF driver to one. This patch fixes a bug reported in which
the PF cannot communciate with the VF and should be considered for 2.6.34
stable.
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
commit 5c4bfa17f3ec46becec4b23d12323f7605ebd696 upstream.
This is an off by one bug because strlen() doesn't count the NULL
terminator. We strcpy() addr into a fixed length array of size
UNIX_PATH_MAX later on.
The addr variable is the name of the device being mounted.
commit ff847ac2d3e90edd94674c28bade25ae1e6a2e49 upstream.
The MAC-PHY interconnect on 82577/82578 uses a power management feature
(called K1) which must be disabled when in 1Gbps due to a hardware issue on
these parts. The #define bit setting used to enable/disable K1 is
incorrect and can cause PHY register accesses to stop working altogether
until the next device reset. This patch sets the register correctly.
This issue is present in kernels since 2.6.32.
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com>
commit 36f2407fe52c55566221f8c68c8fb808abffd2f5 upstream.
Should e1000_test_msi() fail to see an msi interrupt, it attempts to
fallback to legacy INTx interrupts. But an error in the code may prevent
this from happening correctly.
Before calling e1000_test_msi_interrupt(), e1000_test_msi() disables SERR
by clearing the SERR bit from the just read PCI_COMMAND bits as it writes
them back out.
Upon return from calling e1000_test_msi_interrupt(), it re-enables SERR
by writing out the version of PCI_COMMAND it had previously read.
The problem with this is that e1000_test_msi_interrupt() calls
pci_disable_msi(), which eventually ends up in pci_intx(). And because
pci_intx() was called with enable set to 1, the INTX_DISABLE bit gets
cleared from PCI_COMMAND, which is what we want. But when we get back to
e1000_test_msi(), the INTX_DISABLE bit gets inadvertently re-set because
of the attempt by e1000_test_msi() to re-enable SERR.
The solution is to have e1000_test_msi() re-read the PCI_COMMAND bits as
part of its attempt to re-enable SERR.
During debugging/testing of this issue I found that not all the systems
I ran on had the SERR bit set to begin with. And on some of the systems
the same could be said for the INTX_DISABLE bit. Needless to say these
latter systems didn't have a problem falling back to legacy INTx
interrupts with the code as is.
Signed-off-by: Dean Nelson <dnelson@redhat.com>
Tested-by: Emil Tantilov <emil.s.tantilov@intel.com>
commit 962b70a1eb22c467b95756a290c694e73da17f41 upstream.
The bitwise AND is of higher precedence, make that explicit.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
commit bc57117856cf1e581135810b37d3b75f9d1749f5 upstream.
Exit early when setting scrub rate on unknown/unsupported families.
Acked-by: Doug Thompson <dougthompson@xmission.com>
commit 9975a5f22a4fcc8d08035c65439900a983f891ad upstream.
The correct check is to verify whether in high range we're below 4GB
and not to extract the DctSelBaseAddr again. See "2.8.5 Routing DRAM
Requests" in the F10h BKDG.
commit d9b68e5e88248bb24fd4e455588bea1d56108fd6 upstream.
The firmware handles '\t' internally, so stop trying to emulate it
(which, incidentally, had a bug in it.)
Fixes a really weird hang at bootup in rcu_bootup_announce, which,
as far as I can tell, is the first printk in the core kernel to use
a tab as the first character.
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
commit 14cb0deb66fcfca8fdbef75da8c84b5405a8c767 upstream.
The GPIO registers need protection from concurrent access for operations that
are not atomic.
Cc: Juergen Beisert <j.beisert@pengutronix.de>
Cc: Daniel Mack <daniel@caiaq.de>
Reported-by: rpkamiak@rockwellcollins.com
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
commit 4b4fd27c0b5ec638a1f06ced9226fd95229dbbf0 upstream.
avoid potential stack overflow by correctly checking count parameter
Reported-by: Ilja <ilja@netric.org>
Signed-off-by: Helge Deller <deller@gmx.de>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
(Note: upstream comedi configuration has been overhauled, so this patch
does not apply there.)
Several comedi drivers call subdev_8255_init() (declared in
"drivers/staging/comedi/drivers/8255.h") to set up one or more DIO
subdevices. This should be provided by the 8255.ko module, but unless
the CONFIG_COMEDI_8255 or CONFIG_COMEDI_8255_MODULE macro is defined,
the 8255.h header uses a dummy inline version of the function instead.
This means the comedi devices end up with an "unused" subdevice with 0
channels instead of a "DIO" subdevice with 24 channels!
This patch provides a non-interactive COMEDI_8255 option and selects it
whenever the COMEDI_PCI_DRIVERS or COMEDI_PCMCIA_DRIVERS options are
selected.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
commit 77a63f3d1e0a3e7ede8d10f569e8481b13ff47c5 upstream.
nfs_commit_inode() needs to be defined irrespectively of whether or not
we are supporting NFSv3 and NFSv4.
Allow the compiler to optimise away code in the NFSv2-only case by
converting it into an inlined stub function.
Reported-and-tested-by: Ingo Molnar <mingo@elte.hu>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit b608b283a962caaa280756bc8563016a71712acf upstream.
See https://bugzilla.kernel.org/show_bug.cgi?id=16056
If other processes are blocked waiting for kswapd to free up some memory so
that they can make progress, then we cannot allow kswapd to block on those
processes.
commit de51257aa301652876ab6e8f13ea4eadbe4a3846 upstream.
Debian's ia64 autobuilders have been seeing kernel freeze or reboot
when running the gdb testsuite (Debian bug 588574): dannf bisected to
2.6.32 62eede62dafb4a6633eae7ffbeb34c60dba5e7b1 "mm: ZERO_PAGE without
PTE_SPECIAL"; and reproduced it with gdb's gcore on a simple target.
I'd missed updating the gate_vma handling in __get_user_pages(): that
happens to use vm_normal_page() (nowadays failing on the zero page),
yet reported success even when it failed to get a page - boom when
access_process_vm() tried to copy that to its intermediate buffer.
Fix this, resisting cleanups: in particular, leave it for now reporting
success when not asked to get any pages - very probably safe to change,
but let's not risk it without testing exposure.
Why did ia64 crash with 16kB pages, but succeed with 64kB pages?
Because setup_gate() pads each 64kB of its gate area with zero pages.
Reported-by: Andreas Barth <aba@not.so.argh.org>
Bisected-by: dann frazier <dannf@debian.org>
Tested-by: dann frazier <dannf@dannf.org>
commit 7926c09dea682be6f3b2e42f16c50d8554c6bbdc upstream.
Signed-off-by: Jan III Sobieski <jan3sobi3ski@gmail.com>
commit 5620ae29f1eabe655f44335231b580a78c8364ea upstream.
Fix error from the last pull request. Making sure we shut the panel off
is more correct and saves power.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 9934c132989d5c488d2e15188220ce240960ce96 upstream.
When enabling the eDP port, we need to make sure the panel is turned on
after training the link. If we don't, it likely won't come back after
suspend or may not come up at all.
For unknown reasons, unlocking the panel regs before initiating a power
on sequence is necessary. There are known bugs in the PCH panel
sequencing logic, apparently this is one possible workaround.
Fixes https://bugs.freedesktop.org/show_bug.cgi?id=28739.
Tested-by: "Paulo J. S. Silva" <pjssilva@gmail.com>
commit 4a655f043160eeae447efd3be297b6b4c397a640 upstream.
In some cases, unlocking the panel regs is safe and can help us avoid a
flickery, full mode set sequence. So define the unlock key and use it.
commit 38faddb1afdd37218c196ac3db1cb5fbe7fc9c75 upstream.
The behavior of Nvidia HDMI codec regarding the pin-detection unsol events
is based on the old HD-audio spec, i.e. PD bit indicates only the update
and doesn't show the current state. Since the current code assumes the
new behavior, the pin-detection doesn't work relialby with these h/w.
This patch adds a flag for indicating the old spec, and fixes the issue
by checking the pin-detection explicitly for such hardware.
Tested-by: Wei Ni <wni@nvidia.com>
commit 856b185dd23da39e562983fbf28860f54e661b41 upstream.
The commit 5d554a7bb06 (ACPI: processor: add internal
processor_physically_present()) is broken on uniprocessor (UP)
configurations, as acpi_get_cpuid() will always return -1.
We use the value of num_possible_cpus() to tell us whether we got
an invalid cpuid from acpi_get_cpuid() in the SMP case, or if
instead, we are UP, in which case num_possible_cpus() is #defined
as 1.
We use num_possible_cpus() instead of num_online_cpus() to
protect ourselves against the scenario of CPU hotplug, and we've
taken down all the CPUs except one.
Thanks to Jan Pogadl for initial report and analysis and Chen
Gong for review.
https://bugzilla.kernel.org/show_bug.cgi?id=16357
Reported-by: Jan Pogadl <pogadl.jan@googlemail.com>:
Reviewed-by: Chen Gong <gong.chen@linux.intel.com>
Signed-off-by: Alex Chiang <achiang@canonical.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Cc: Thomas Renninger <trenn@suse.de>
commit a78f9f4668949a6588b8872f162e86685c63d023 upstream.
The old ocfs2_xattr_extent_allocation is too optimistic about
the clusters we can get. So actually if the file system is
too fragmented, ocfs2_add_clusters_in_btree will return us
with EGAIN and we need to allocate clusters once again.
So this patch change it to a while loop so that we can allocate
clusters until we reach clusters_to_add.
Signed-off-by: Tao Ma <tao.ma@oracle.com>
Signed-off-by: Joel Becker <joel.becker@oracle.com>
commit 2e65a2075cc740b485ab203430bdf3459d5551b6 upstream.
Commit 3fea60261e73 ("Input: twl40300-keypad - fix handling of "all
ground" rows") broke compilation as I managed to use non-existent
keycodes.
Reported-by: Arjan van de Ven <arjan@infradead.org>
commit b6855772f4a22c4fbdd4fcaceff5c8a527035123 upstream.
ath5k assumes ah_current_channel is always a valid pointer in
several places, but a newly created interface may not have a
channel. To avoid null pointer dereferences, set it up to point
to the first available channel until later reconfigured.
This fixes the following oops:
$ rmmod ath5k
$ insmod ath5k
$ iw phy0 set distance 11000
BUG: unable to handle kernel NULL pointer dereference at 00000006
IP: [<d0a1ff24>] ath5k_hw_set_coverage_class+0x74/0x1b0 [ath5k]
*pde = 00000000
Oops: 0000 [#1]
last sysfs file: /sys/devices/pci0000:00/0000:00:0e.0/ieee80211/phy0/index
Modules linked in: usbhid option usb_storage usbserial usblp evdev lm90
scx200_acb i2c_algo_bit i2c_dev i2c_core via_rhine ohci_hcd ne2k_pci
8390 leds_alix2 xt_IMQ imq nf_nat_tftp nf_conntrack_tftp nf_nat_irc nf_cc
Pid: 1597, comm: iw Not tainted (2.6.32.14 #8)
EIP: 0060:[<d0a1ff24>] EFLAGS: 00010296 CPU: 0
EIP is at ath5k_hw_set_coverage_class+0x74/0x1b0 [ath5k]
EAX: 000000c2 EBX: 00000000 ECX: ffffffff EDX: c12d2080
ESI: 00000019 EDI: cf8c0000 EBP: d0a30edc ESP: cfa09bf4
DS: 007b ES: 007b FS: 0000 GS: 0000 SS: 0068
Process iw (pid: 1597, ti=cfa09000 task=cf88a000 task.ti=cfa09000)
Stack:
d0a34f35 d0a353f8 d0a30edc 000000fe cf8c0000 00000000 1900063d cfa8c9e0
<0> cfa8c9e8 cfa8c0c0 cfa8c000 d0a27f0c 199d84b4 cfa8c200 00000010 d09bfdc7
<0> 00000000 00000000 ffffffff d08e0d28 cf9263c0 00000001 cfa09cc4 00000000
Call Trace:
[<d0a27f0c>] ? ath5k_hw_attach+0xc8c/0x3c10 [ath5k]
[<d09bfdc7>] ? __ieee80211_request_smps+0x1347/0x1580 [mac80211]
[<d08e0d28>] ? nl80211_send_scan_start+0x7b8/0x4520 [cfg80211]
[<c10f5db9>] ? nla_parse+0x59/0xc0
[<c11ca8d9>] ? genl_rcv_msg+0x169/0x1a0
[<c11ca770>] ? genl_rcv_msg+0x0/0x1a0
[<c11c7e68>] ? netlink_rcv_skb+0x38/0x90
[<c11c9649>] ? genl_rcv+0x19/0x30
[<c11c7c03>] ? netlink_unicast+0x1b3/0x220
[<c11c893e>] ? netlink_sendmsg+0x26e/0x290
[<c11a409e>] ? sock_sendmsg+0xbe/0xf0
[<c1032780>] ? autoremove_wake_function+0x0/0x50
[<c104d846>] ? __alloc_pages_nodemask+0x106/0x530
[<c1074933>] ? do_lookup+0x53/0x1b0
[<c10766f9>] ? __link_path_walk+0x9b9/0x9e0
[<c11acab0>] ? verify_iovec+0x50/0x90
[<c11a42b1>] ? sys_sendmsg+0x1e1/0x270
[<c1048e50>] ? find_get_page+0x10/0x50
[<c104a96f>] ? filemap_fault+0x5f/0x370
[<c1059159>] ? __do_fault+0x319/0x370
[<c11a55b4>] ? sys_socketcall+0x244/0x290
[<c101962c>] ? do_page_fault+0x1ec/0x270
[<c1019440>] ? do_page_fault+0x0/0x270
[<c1002ae5>] ? syscall_call+0x7/0xb
Code: 00 b8 fe 00 00 00 b9 f8 53 a3 d0 89 5c 24 14 89 7c 24 10 89 44 24
0c 89 6c 24 08 89 4c 24 04 c7 04 24 35 4f a3 d0 e8 7c 30 60 f0 <0f> b7
43 06 ba 06 00 00 00 a8 10 75 0e 83 e0 20 83 f8 01 19 d2
EIP: [<d0a1ff24>] ath5k_hw_set_coverage_class+0x74/0x1b0 [ath5k] SS:ESP
0068:cfa09bf4
CR2: 0000000000000006
---[ end trace 54f73d6b10ceb87b ]---
Reported-by: Steve Brown <sbrown@cortland.com>
Signed-off-by: Bob Copeland <me@bobcopeland.com>
commit 3d61510f4ecacfe47c75c0eb51c0659dfa77fb1b upstream.
This patch (as1365) enables remote wakeup by default for USB keyboard
devices. Keyboards in general are supposed to be wakeup devices, but
the correct place to enable it depends on the device's bus; no single
approach will work for all keyboard devices. In particular, this
covers only USB keyboards (and then only those supporting the boot
protocol).
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
commit 98a0f86a54bb195c28ae1ccb5a5f5cda12cf7121 upstream.
This patch fixes a regression introduced by commit "MIPS: Alchemy: MTX-1:
Use linux gpio api." (bb706b28bbd647c2fd7f22d6bf03a18b9552be05) which broke
PCI bus operation. The problem is caused by alchemy_gpio2_enable() which
resets the GPIO2 block. Two PCI signals (PCI_SERR and PCI_RST) are connected
to GPIO2 and they obviously do not to like the reset. Since GPIO2 is
correctly initialized by the boot monitor (YAMON) it is not necessary to
call this function, so just remove it.
Also replace gpio_set_value() with alchemy_gpio_set_value() to avoid
problems in case gpiolib gets initialized after PCI. And since alchemy
gpio_set_value() calls au_sync() we don't have to au_sync() again later.
Signed-off-by: Bruno Randolf <br1@einfach.org>
To: linux-mips@linux-mips.org
To: manuel.lauss@googlemail.com
Patchwork: https://patchwork.linux-mips.org/patch/1448/
Tested-by: Florian Fainelli <florian@openwrt.org>
