commit 39aa3cb3e8250db9188a6f1e3fb62ffa1a717678 upstream.
So it can be used by all that need to check for that.
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
commit 9aea5a65aa7a1af9a4236dfaeb0088f1624f9919 upstream.
An execve with a very large total of argument/environment strings
can take a really long time in the execve system call. It runs
uninterruptibly to count and copy all the strings. This change
makes it abort the exec quickly if sent a SIGKILL.
Note that this is the conservative change, to interrupt only for
SIGKILL, by using fatal_signal_pending(). It would be perfectly
correct semantics to let any signal interrupt the string-copying in
execve, i.e. use signal_pending() instead of fatal_signal_pending().
We'll save that change for later, since it could have user-visible
consequences, such as having a timer set too quickly make it so that
an execve can never complete, though it always happened to work before.
Signed-off-by: Roland McGrath <roland@redhat.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
commit 7993bc1f4663c0db67bb8f0d98e6678145b387cd upstream.
This adds a preemption point during the copying of the argument and
environment strings for execve, in copy_strings(). There is already
a preemption point in the count() loop, so this doesn't add any new
points in the abstract sense.
When the total argument+environment strings are very large, the time
spent copying them can be much more than a normal user time slice.
So this change improves the interactivity of the rest of the system
when one process is doing an execve with very large arguments.
commit 1b528181b2ffa14721fb28ad1bd539fe1732c583 upstream.
The CONFIG_STACK_GROWSDOWN variant of setup_arg_pages() does not
check the size of the argument/environment area on the stack.
When it is unworkably large, shift_arg_pages() hits its BUG_ON.
This is exploitable with a very large RLIMIT_STACK limit, to
create a crash pretty easily.
Check that the initial stack is not too large to make it possible
to map in any executable. We're not checking that the actual
executable (or intepreter, for binfmt_elf) will fit. So those
mappings might clobber part of the initial stack mapping. But
that is just userland lossage that userland made happen, not a
kernel problem.
commit b7d460897739e02f186425b7276e3fdb1595cea7 upstream.
rc2 kernel crashes when booting second cpu on this CONFIG_VMSPLIT_2G_OPT
laptop: whereas cloning from kernel to low mappings pgd range does need
to limit by both KERNEL_PGD_PTRS and KERNEL_PGD_BOUNDARY, cloning kernel
pgd range itself must not be limited by the smaller KERNEL_PGD_BOUNDARY.
LKML-Reference: <alpine.LSU.2.00.1008242235120.2515@sister.anvils>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
commit 8848a91068c018bc91f597038a0f41462a0f88a4 upstream.
Fix dummy inline stubs for trampoline-related functions when no
trampolines exist (until we get rid of the no-trampoline case
entirely.)
Cc: Joerg Roedel <joerg.roedel@amd.com>
Cc: Borislav Petkov <borislav.petkov@amd.com>
LKML-Reference: <4C6C294D.3030404@zytor.com>
commit fd89a137924e0710078c3ae855e7cec1c43cb845 upstream.
This patch fixes machine crashes which occur when heavily exercising the
CPU hotplug codepaths on a 32-bit kernel. These crashes are caused by
AMD Erratum 383 and result in a fatal machine check exception. Here's
the scenario:
1. On 32-bit, the swapper_pg_dir page table is used as the initial page
table for booting a secondary CPU.
2. To make this work, swapper_pg_dir needs a direct mapping of physical
memory in it (the low mappings). By adding those low, large page (2M)
mappings (PAE kernel), we create the necessary conditions for Erratum
383 to occur.
3. Other CPUs which do not participate in the off- and onlining game may
use swapper_pg_dir while the low mappings are present (when leave_mm is
called). For all steps below, the CPU referred to is a CPU that is using
swapper_pg_dir, and not the CPU which is being onlined.
4. The presence of the low mappings in swapper_pg_dir can result
in TLB entries for addresses below __PAGE_OFFSET to be established
speculatively. These TLB entries are marked global and large.
5. When the CPU with such TLB entry switches to another page table, this
TLB entry remains because it is global.
6. The process then generates an access to an address covered by the
above TLB entry but there is a permission mismatch - the TLB entry
covers a large global page not accessible to userspace.
7. Due to this permission mismatch a new 4kb, user TLB entry gets
established. Further, Erratum 383 provides for a small window of time
where both TLB entries are present. This results in an uncorrectable
machine check exception signalling a TLB multimatch which panics the
machine.
There are two ways to fix this issue:
1. Always do a global TLB flush when a new cr3 is loaded and the
old page table was swapper_pg_dir. I consider this a hack hard
to understand and with performance implications
2. Do not use swapper_pg_dir to boot secondary CPUs like 64-bit
does.
This patch implements solution 2. It introduces a trampoline_pg_dir
which has the same layout as swapper_pg_dir with low_mappings. This page
table is used as the initial page table of the booting CPU. Later in the
bringup process, it switches to swapper_pg_dir and does a global TLB
flush. This fixes the crashes in our test cases.
-v2: switch to swapper_pg_dir right after entering start_secondary() so
that we are able to access percpu data which might not be mapped in the
trampoline page table.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
LKML-Reference: <20100816123833.GB28147@aftab>
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
commit f8f235e5bbf4e61f3e0886a44afb1dc4cfe8f337 upstream.
Sandybridge GTT has new cache control bits in PTE, which controls
graphics page cache in LLC or LLC/MLC, so we need to extend the mask
function to respect the new bits.
And set cache control to always LLC only by default on Gen6.
Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com>
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
commit 1dedefd1a066a795a87afca9c0236e1a94de9bf6 upstream.
Some extra CPU features such as ARAT is needed in early boot so
that x86_init function pointers can be set up properly.
http://lkml.org/lkml/2010/5/18/519
At start_kernel() level, this patch moves init_scattered_cpuid_features()
from check_bugs() to setup_arch() -> early_cpu_init() which is earlier than
platform specific x86_init layer setup. Suggested by HPA.
Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com>
LKML-Reference: <1274295685-6774-2-git-send-email-jacob.jun.pan@linux.intel.com>
commit 539986482b0db07b7164ab086d167ab99b4d3061 upstream.
Commit 2a6b69765ad794389f2fc3e14a0afa1a995221c2 (ACPI: Store NVS
state even when entering suspend to RAM) changed the ACPI suspend
to RAM code so that the NVS memory area is always unconditionally
saved during suspend and restored during resume, since some systems
evidently need that for the suspend-resume to work on them. However,
it turned out that this change broke suspend-resume on a few systems,
so commit 72ad5d77fb981963edae15eee8196c80238f5ed0 (ACPI / Sleep:
Allow the NVS saving to be skipped during suspend to RAM) introduced
the acpi_sleep=nonvs command line switch to allow their users to
work around this issue. To keep track of the systems that require
this workaround and to make the life of their users slightly easier
blacklist them in acpisleep_dmi_table[].
https://bugzilla.kernel.org/show_bug.cgi?id=16396
Signed-off-by: Len Brown <len.brown@intel.com>
commit 337279ce3aa85d81d34c0f837d1c204df105103b upstream.
Disable the Windows Vista (SP1) compatibility for Toshiba P305D.
http://bugzilla.kernel.org/show_bug.cgi?id=14736
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
commit 64a32307b710c100beb101e9c78f8022f0e8ba61 upstream.
per comments in the bug report, this entry
seems to hurt at much as it helps.
https://bugzilla.kernel.org/show_bug.cgi?id=10807
commit 7a1d602f5fc35d14907b7da98d5627acb69589d1 upstream.
https://bugzilla.kernel.org/show_bug.cgi?id=12641
commit 4731fdcf6f7bdab3e369a3f844d4ea4d4017284d upstream.
When the Lenovo Ideapad S10-3 is booted with HT enabled,
it hits a boot hang in the intel_idle driver.
This occurs when entering ATM-C4 for the first time,
unless BM_STS is first cleared.
acpi_idle doesn't see this because it first checks
and clears BM_STS, but it would hit the same hang
if that check were disabled.
http://bugs.meego.com/show_bug.cgi?id=7093
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/634702
commit 573b638158029898caf9470c8214b7ddd29751e3 upstream.
Section 4.7.3.1.1 (PM1 Status Registers) of version 4.0 of
the ACPI spec concerning PCIEXP_WAKE_STS points out in
in the final note field in table 4-11 that if this bit is
set to 1 and the system is put into a sleeping state then
the system will not automatically wake.
This bit gets set by hardware to indicate that the system
woke up due to a PCI Express wakeup event, so clear it during
acpi_hw_clear_acpi_status() calls to enable subsequent
resumes to work.
BugLink: http://bugs.launchpad.net/bugs/613381
commit f7154de220f14073ef0d76638f85e254ad2e202f upstream.
Lenovo IdeaPad Y430 has an additional subwoofer connected at pin 0x1b,
which isn't muted when headphone is plugged in. This adds additional
support to the extra subwoofer via new ideapad model.
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
Cc: David Henningsson <david.henningsson@canonical.com>
commit bcf64aa379fcadd074449cbf0c049da70071b06f upstream.
For carrier detection to work properly when binding the driver with a cable
unplugged, netif_carrier_off() should be called after register_netdev(),
not before.
Signed-off-by: Paul Fertser <fercerpav@gmail.com>
commit 54a834043314c257210db2a9d59f8cc605571639 upstream.
In f761622e59433130bc33ad086ce219feee9eb961 we changed
early_setup_secondary so it's called using the proper kernel stack
rather than the emergency one.
Unfortunately, this stack pointer can't be used when translation is off
on PHYP as this stack pointer might be outside the RMO. This results in
the following on all non zero cpus:
cpu 0x1: Vector: 300 (Data Access) at [c00000001639fd10]
pc: 000000000001c50c
lr: 000000000000821c
sp: c00000001639ff90
msr: 8000000000001000
dar: c00000001639ffa0
dsisr: 42000000
current = 0xc000000016393540
paca = 0xc000000006e00200
pid = 0, comm = swapper
The original patch was only tested on bare metal system, so it never
caught this problem.
This changes __secondary_start so that we calculate the new stack
pointer but only start using it after we've called early_setup_secondary.
With this patch, the above problem goes away.
Signed-off-by: Michael Neuling <mikey@neuling.org>
commit f761622e59433130bc33ad086ce219feee9eb961 upstream.
As early setup calls down to slb_initialize(), we must have kstack
initialised before checking "should we add a bolted SLB entry for our kstack?"
Failing to do so means stack access requires an SLB miss exception to refill
an entry dynamically, if the stack isn't accessible via SLB(0) (kernel text
& static data). It's not always allowable to take such a miss, and
intermittent crashes will result.
Primary CPUs don't have this issue; an SLB entry is not bolted for their
stack anyway (as that lives within SLB(0)). This patch therefore only
affects the init of secondaries.
Signed-off-by: Matt Evans <matt@ozlabs.org>
commit c1e0ddbf0a97e1704d7f13b4934f9acca002402d upstream.
After
| commit d8191fa4a33fdc817277da4f2b7f771ff605a41c
| Author: Alex Chiang <achiang@hp.com>
| Date: Mon Feb 22 12:11:39 2010 -0700
| ACPI: processor: driver doesn't need to evaluate _PDC
| Now that the early _PDC evaluation path knows how to correctly
| evaluate _PDC on only physically present processors, there's no
| need for the processor driver to evaluate it later when it loads.
| To cover the hotplug case, push _PDC evaluation down into the
| hotplug paths.
only cpu with Processor Statement get processed with _PDC
If bios is using Device object instead of Processor statement.
SSDTs for Pstate/Cstate/Tstate can not be loaded dynamically.
Need to try to scan ACPI0007 in addition to Processor.
That commit is between 2.6.34-rc1 and 2.6.34-rc2, so stable tree for 2.6.34+
need this patch.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Reviewed-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
commit 531295e63be8c2b8b909d7400739e8b8df60d61f upstream.
If the host is slow in reading data or doesn't read data at all,
blocking write calls not only blocked the program that called write()
but the entire guest itself.
To overcome this, let's not block till the host signals it has given
back the virtio ring element we passed it. Instead, send the buffer to
the host and return to userspace. This operation then becomes similar
to how non-blocking writes work, so let's use the existing code for this
path as well.
This code change also ensures blocking write calls do get blocked if
there's not enough room in the virtio ring as well as they don't return
-EAGAIN to userspace.
Signed-off-by: Amit Shah <amit.shah@redhat.com>
Acked-by: Hans de Goede <hdegoede@redhat.com>
commit 16d3ea26f82271fef9b1c4523b5e1ea31fa39eec upstream.
Fix two bugs in the VPD page wrapper:
- Don't return failure if the user asked for page 0
- The end of buffer check failed to account for the page header size
and consequently didn't work
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
commit 478971600e47cb83ff2d3c63c5c24f2b04b0d6a1 upstream.
bsg incorrectly returns sg's masked_status value for device_status.
[jejb: fix up expression logic]
Reported-by: Douglas Gilbert <dgilbert@interlog.com>
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
commit ca242ac9960dc61530e25a2c190e4e13fd5f1ecb upstream.
When we reboot, we disable vmx extensions or otherwise INIT gets blocked.
If a task on another cpu hits a vmx instruction, it will fault if vmx is
disabled. We trap that to avoid a nasty oops and spin until the reboot
completes.
Problem is, we sleep with interrupts disabled. This blocks smp_send_stop()
from running, and the reboot process halts.
Fix by enabling interrupts before spinning.
Signed-off-by: Avi Kivity <avi@redhat.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit 6bbfb2653177a00f70e57e53625502d43804fed0 upstream.
I think I see the following (theoretical) race:
During irqfd assign, we drop irqfds lock before we
schedule inject work. Therefore, deassign running
on another CPU could cause shutdown and flush to run
before inject, causing user after free in inject.
A simple fix it to schedule inject under the lock.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Gregory Haskins <ghaskins@novell.com>
commit 47008cd887c1836bcadda123ba73e1863de7a6c4 upstream.
The VMCB is reset whenever we receive a startup IPI, so Linux is setting
TSC back to zero happens very late in the boot process and destabilizing
the TSC. Instead, just set TSC to zero once at VCPU creation time.
Why the separate patch? So git-bisect is your friend.
Signed-off-by: Zachary Amsden <zamsden@redhat.com>
commit 58877679fd393d3ef71aa383031ac7817561463d upstream.
On reset, VMCB TSC should be set to zero. Instead, code was setting
tsc_offset to zero, which passes through the underlying TSC.
commit eebb5f31b8d9a2620dcf32297096f8ce1240b179 upstream.
Top of kvm_kpic_state structure should have the same memory layout as
kvm_pic_state since it is copied by memcpy.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
commit aeb19f6052b5e5c8a24aa444fbff73b84341beac upstream.
We have fedora bug report where driver fail to initialize after
suspend/resume because of memory allocation errors:
https://bugzilla.redhat.com/show_bug.cgi?id=629158
To fix use GFP_KERNEL allocation where possible.
Tested-by: Neal Becker <ndbecker2@gmail.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit 392bd0cb000d4aac9e88e4f50823db85e7220688 upstream.
Skge devices installed on some Gigabyte motherboards are not able to
perform 64 dma correctly due to board PCI implementation, so limit
DMA to 32bit if such boards are detected.
Bug was reported here:
https://bugzilla.redhat.com/show_bug.cgi?id=447489
Tested-by: Luya Tshimbalanga <luya@fedoraproject.org>
commit 081003fff467ea0e727f66d5d435b4f473a789b3 upstream.
When marking an inode reclaimable, a per-AG counter is increased, the
inode is tagged reclaimable in its per-AG tree, and, when this is the
first reclaimable inode in the AG, the AG entry in the per-mount tree
is also tagged.
When an inode is finally reclaimed, however, it is only deleted from
the per-AG tree. Neither the counter is decreased, nor is the parent
tree's AG entry untagged properly.
Since the tags in the per-mount tree are not cleared, the inode
shrinker iterates over all AGs that have had reclaimable inodes at one
point in time.
The counters on the other hand signal an increasing amount of slab
objects to reclaim. Since "70e60ce xfs: convert inode shrinker to
per-filesystem context" this is not a real issue anymore because the
shrinker bails out after one iteration.
But the problem was observable on a machine running v2.6.34, where the
reclaimable work increased and each process going into direct reclaim
eventually got stuck on the xfs inode shrinking path, trying to scan
several million objects.
Fix this by properly unwinding the reclaimable-state tracking of an
inode when it is reclaimed.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Alex Elder <aelder@sgi.com>
commit 90e12cec707204930934acdb5efce5f94a163a5f upstream.
To improve performance on DiB7770-devices enabling the current mirror
is needed.
This patch adds an option to the dib7000p-driver to do that and it
creates a separate device-entry in dib0700-device to use those changes
on hardware which is using the DiB7770.
Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr>
Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr>
commit 1c8cf9c997a4a6b36e907c7ede5f048aeaab1644 upstream.
Fix SDIO suspend/resume regression introduced by 4c2ef25fe0b "mmc: fix
all hangs related to mmc/sd card insert/removal during suspend/resume":
PM: Syncing filesystems ... done.
Freezing user space processes ... (elapsed 0.01 seconds) done.
Freezing remaining freezable tasks ... (elapsed 0.01 seconds) done.
Suspending console(s) (use no_console_suspend to debug)
pm_op(): platform_pm_suspend+0x0/0x5c returns -38
PM: Device pxa2xx-mci.0 failed to suspend: error -38
PM: Some devices failed to suspend
4c2ef25fe0b moved the card removal/insertion mechanism out of MMC's
suspend/resume path and into pm notifiers (mmc_pm_notify), and that
broke SDIO's expectation that mmc_suspend_host() will remove the card,
and squash the error, in case -ENOSYS is returned from the bus suspend
handler (mmc_sdio_suspend() in this case).
mmc_sdio_suspend() is using this whenever at least one of the card's SDIO
function drivers does not have suspend/resume handlers - in that case
it is agreed to force removal of the entire card.
This patch fixes this regression by trivially bringing back that part of
mmc_suspend_host(), which was removed by 4c2ef25fe0b.
Reported-and-tested-by: Sven Neumann <s.neumann@raumfeld.com>
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
Cc: Maxim Levitsky <maximlevitsky@gmail.com>
Acked-by: Nicolas Pitre <nico@fluxnic.net>
Signed-off-by: Chris Ball <cjb@laptop.org>
commit f36fce0f49ed40f3e843d45fa53d476d63444b58 upstream.
Board has no digital connectors
Reported-by: Andy Walls <awalls@md.metrocast.net>
Tested-by: Andy Walls <awalls@md.metrocast.net>
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
commit e488459a0e131acc9e14df093cfee740bc431953 upstream.
radeon_gem_wait_idle_ioctl can apparently get called prior to
the vram page being set up or even if accel if false, so make
sure it's valid before using it.
Should fix:
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=597636
https://bugs.freedesktop.org/show_bug.cgi?id=29834
commit 73758a5d51280ca0613b8380fc07351f4d64f9c8 upstream.
encoder info was not printed properly on boards using the
DFP6 id.
Not upstream in Linus's tree as it was fixed by a much more intrusive
patch in a different manner, commit c919b371cb734f42b11
2.6.35 and 2.6.36 do not contain blit support for evergreen
asics so if they use unmappable vram, you can end up with an
unreachable buffer address. This should not be applied to drm-next
as that tree already contains evergreen blit support. This should
only be applied to the 2.6.35 and 2.6.36 stable trees.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=30188
Acked-by: Dave Airlie <airlied@redhat.com>
commit f459ffbdfd04edb4a8ce6eea33170eb057a5e695 upstream.
fixes https://bugzilla.kernel.org/show_bug.cgi?id=19012
commit 39b4d07aa3583ceefe73622841303a0a3e942ca1 upstream.
In order to be fully threadsafe we need to check that the drm_gem_object
refcount is still 0 after acquiring the mutex in order to call the free
function. Otherwise, we may encounter scenarios like:
Thread A: Thread B:
drm_gem_close
unreference_unlocked
kref_put mutex_lock
... i915_gem_evict
... kref_get -> BUG
... i915_gem_unbind
... kref_put
... i915_gem_object_free
... mutex_unlock
mutex_lock
i915_gem_object_free -> BUG
i915_gem_object_unbind
kfree
mutex_unlock
Note that no driver is currently using the free_unlocked vfunc and it is
scheduled for removal, hasten that process.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=30454
Reported-and-Tested-by: Magnus Kessler <Magnus.Kessler@gmx.net>
commit 31dfbc93923c0aaa0440b809f80ff2830c6a531a upstream.
Hook the GEM vm open/close ops into the generic drm vm open/close so
that the private vma entries are created and destroy appropriately.
Fixes the leak of the drm_vma_entries during the lifetime of the filp.
Reported-by: Matt Mackall <mpm@selenic.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit d270ae34eb77c58dea60e5b1e300a698d2ce39ac upstream.
The IPS driver needs to know the current power consumption of the GMCH
in order to make decisions about when to increase or decrease the CPU
and/or GPU power envelope. So fix up the divisions to save the results
so the numbers are actually correct (contrary to some earlier comments
and code, these functions do not modify the first argument and use it
for the result).
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit ce9d419dbecc292cc3e06e8b1d6d123d3fa813a4 upstream.
Move the access control up from the fast paths, which are no longer
universally taken first, up into the caller. This then duplicates some
sanity checking along the slow paths, but is much simpler.
Tracked as CVE-2010-2962.
Reported-by: Kees Cook <kees@ubuntu.com>
commit 6939a5aca7cfada279a24c307e772f33104fca20 upstream.
The i915 driver has quite a few module unload bugs, the known ones at
least have fixes that are targeting 2.6.37. However, in order to
maintain a stable kernel, we should prevent this known random memory
corruption following driver unload. This should have very low impact on
normal users who are unlikely to need to unload the i915 driver.
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit aa0170fff3c26bf2b42159af2dd9cf86444c292a upstream.
Revert commit 54672386ccf36ffa21d1de8e75624af83f9b0eeb
"firewire: ohci: fix up configuration of TI chips".
It caused massive slow-down and data corruption with a TSB82AA2 based
StarTech EC1394B2 ExpressCard and FireWire 800 harddisks.
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/657081
http://thread.gmane.org/gmane.linux.kernel.firewire.user/4013
The fact that some card EEPROMs do not program these enhancements may be
related to TSB81BA3 phy chip errata, if not to bugs of TSB82AA2 itself.
We could re-add these configuration steps, but only conditional on a
whitelist of cards on which these enhancements bring a proven positive
effect.
Reported-and-tested-by: Eric Shattow <lucent@gmail.com>
Cc: Clemens Ladisch <clemens@ladisch.de>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
commit 799c10559d60f159ab2232203f222f18fa3c4a5f upstream.
Don't try to "optimize" rds_page_copy_user() by using kmap_atomic() and
the unsafe atomic user mode accessor functions. It's actually slower
than the straightforward code on any reasonable modern CPU.
Back when the code was written (although probably not by the time it was
actually merged, though), 32-bit x86 may have been the dominant
architecture. And there kmap_atomic() can be a lot faster than kmap()
(unless you have very good locality, in which case the virtual address
caching by kmap() can overcome all the downsides).
But these days, x86-64 may not be more populous, but it's getting there
(and if you care about performance, it's definitely already there -
you'd have upgraded your CPU's already in the last few years). And on
x86-64, the non-kmap_atomic() version is faster, simply because the code
is simpler and doesn't have the "re-try page fault" case.
People with old hardware are not likely to care about RDS anyway, and
the optimization for the 32-bit case is simply buggy, since it doesn't
verify the user addresses properly.
Reported-by: Dan Rosenberg <drosenberg@vsecurity.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
commit 6dcbfe4f0b4e17e289d56fa534b7ce5a6b7f63a3 upstream.
This fixes possible cases of not collecting valid error info in
the MCE error thresholding groups on F10h hardware.
The current code contains a subtle problem of checking only the
Valid bit of MSR0000_0413 (which is MC4_MISC0 - DRAM
thresholding group) in its first iteration and breaking out if
the bit is cleared.
But (!), this MSR contains an offset value, BlkPtr[31:24], which
points to the remaining MSRs in this thresholding group which
might contain valid information too. But if we bail out only
after we checked the valid bit in the first MSR and not the
block pointer too, we miss that other information.
The thing is, MC4_MISC0[BlkPtr] is not predicated on
MCi_STATUS[MiscV] or MC4_MISC0[Valid] and should be checked
prior to iterating over the MCI_MISCj thresholding group,
irrespective of the MC4_MISC0[Valid] setting.
commit 73cf624d029d776a33d0a80c695485b3f9b36231 upstream.
Russ reported SGI UV is broken recently. He said:
| The SRAT table shows that memory range is spread over two nodes.
| SRAT: Node 0 PXM 0 100000000-800000000
| SRAT: Node 1 PXM 1 800000000-1000000000
| SRAT: Node 0 PXM 0 1000000000-1080000000
|Previously, the kernel early_node_map[] would show three entries
|with the proper node.
|[ 0.000000] 0: 0x00100000 -> 0x00800000
|[ 0.000000] 1: 0x00800000 -> 0x01000000
|[ 0.000000] 0: 0x01000000 -> 0x01080000
|The problem is recent community kernel early_node_map[] shows
|only two entries with the node 0 entry overlapping the node 1
|entry.
| 0: 0x00100000 -> 0x01080000
After looking at the changelog, Found out that it has been broken for a while by
following commit
|commit 8716273caef7f55f39fe4fc6c69c5f9f197f41f1
|Author: David Rientjes <rientjes@google.com>
|Date: Fri Sep 25 15:20:04 2009 -0700
| x86: Export srat physical topology
Before that commit, register_active_regions() is called for every SRAT memory
entry right away.
Use nodememblk_range[] instead of nodes[] in order to make sure we
capture the actual memory blocks registered with each node. nodes[]
contains an extended range which spans all memory regions associated
with a node, but that does not mean that all the memory in between are
included.
Reported-by: Russ Anderson <rja@sgi.com>
Tested-by: Russ Anderson <rja@sgi.com>
LKML-Reference: <4CB27BDF.5000800@kernel.org>
Acked-by: David Rientjes <rientjes@google.com>
commit ec5a32f67c603b11d68eb283d94eb89a4f6cfce1 upstream.
adapter->cmb.cmb is initialized when the device is opened and freed when
it's closed. Accessing it unconditionally during resume results either
in a crash (NULL pointer dereference, when the interface has not been
opened yet) or data corruption (when the interface has been used and
brought down adapter->cmb.cmb points to a deallocated memory area).
Signed-off-by: Luca Tettamanti <kronos.it@gmail.com>
Acked-by: Chris Snook <chris.snook@gmail.com>
commit df6d02300f7c2fbd0fbe626d819c8e5237d72c62 upstream.
When a driver doesn't fill the entire buffer, old
heap contents may remain, and if it also doesn't
update the length properly, this old heap content
will be copied back to userspace.
It is very unlikely that this happens in any of
the drivers using private ioctls since it would
show up as junk being reported by iwpriv, but it
seems better to be safe here, so use kzalloc.
Reported-by: Jeff Mahoney <jeffm@suse.com>
