Due to the recent change for multiple mics assignment, we need to handle
the index of each Mic Boost control respectively. Otherwise the driver
gets the control element conflicts, and gives the unsable state.
Reference: kernel bug 25002
https://bugzilla.kernel.org/show_bug.cgi?id=25002
Reported-and-tested-by: Adam Williamson <awilliam@redhat.com>
As PControl G20 is a carrier board for the Stamp9G20 SoM, some code can
be shared. Therefore board-stamp9g20.c is refactored to allow reusing the
SoM initialization and board-pcontrol-g20.c is modified to use it.
Signed-off-by: Christian Glindkamp <christian.glindkamp@taskit.de>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
The uhpck clock should be divided from the utmi clock, not its parent
(main). This change is mostly cosmetic as the uhpck rate value is not
used anywhere except for the debugfs clock output.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
Fix interrupt priority level handling on SH-Mobile ARM.
SH-Mobile ARM platforms using multiple interrupt priority
levels need this patch to fix a potential dead lock that
may occur if multiple interrupts with different levels
are pending simultaneously.
The default INTC configuration is to use the same priority
level for all interrupts, so this issue does not trigger by
default. It is however common for board code to override the
interrupt priority for certain interrupt sources depending
on the application. Without this fix such boards may lock up.
In detail, this patch updates the INTC code in entry-macro.S
to make sure that the INTLVLA register gets set as expected.
To trigger this bug modify the board specific code to adjust
the interrupt priority level for the ethernet chip. After
changing the priority level simply use flood ping to drown
the board with interrupts.
This patch applies to INTCA-based processors such as sh7372,
sh7377 and sh7372. GIC-based processors are not affected.
Suitable for v2.6.37-rc and stable from v2.6.34 to v2.6.36.
Cc: stable@kernel.org
Signed-off-by: Magnus Damm <damm@opensource.se>
Tested-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Turn down the warning noise from the compiler,
basically a SH-Mobile specific version of the
patch located in the RMK patch tracker:
6484/1: "fix compile warning in mm/init.c",
Without this patch the following warning triggers:
CC arch/arm/kernel/sys_arm.o
arch/arm/mm/init.c: In function 'mem_init':
arch/arm/mm/init.c:606: warning: format '%08lx' expects type 'long unsigned int', but argument 12 has type 'unsigned int'
CC arch/arm/kernel/traps.o
There are control flow that sh_cmt_set_next() does double
spin-lock. The callers sh_cmt_{start,stop}() already have
lock. But another callers sh_cmt_clock_event_{start,next}()
does not.
Now sh_cmt_set_next() does not lock by itself. All the
callers should hold spin-lock before calling it.
[damm@opensource.se: use __sh_cmt_set_next() to simplify code]
[damm@opensource.se: added stable, suitable for v2.6.35 + v2.6.36]
Signed-off-by: Takashi YOSHII <takashi.yoshii.zj@renesas.com>
If you delete a logical drive, and then run BLKRRPART (e.g. via fdisk)
on a logical drive which is "after" the deleted logical drive in the h->drv[]
array, then cciss_revalidate panics because it will access the null pointer
h->drv[x] when x hits the deleted drive.
Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Implement blk_limits_max_hw_sectors() and make
blk_queue_max_hw_sectors() a wrapper around it.
DM needs this to avoid setting queue_limits' max_hw_sectors and
max_sectors directly. dm_set_device_limits() now leverages
blk_limits_max_hw_sectors() logic to establish the appropriate
max_hw_sectors minimum (PAGE_SIZE). Fixes issue where DM was
incorrectly setting max_sectors rather than max_hw_sectors (which
caused dm_merge_bvec()'s max_hw_sectors check to be ineffective).
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
When stacking devices, a request_queue is not always available. This
forced us to have a no_cluster flag in the queue_limits that could be
used as a carrier until the request_queue had been set up for a
metadevice.
There were several problems with that approach. First of all it was up
to the stacking device to remember to set queue flag after stacking had
completed. Also, the queue flag and the queue limits had to be kept in
sync at all times. We got that wrong, which could lead to us issuing
commands that went beyond the max scatterlist limit set by the driver.
The proper fix is to avoid having two flags for tracking the same thing.
We deprecate QUEUE_FLAG_CLUSTER and use the queue limit directly in the
block layer merging functions. The queue_limit 'no_cluster' is turned
into 'cluster' to avoid double negatives and to ease stacking.
Clustering defaults to being enabled as before. The queue flag logic is
removed from the stacking function, and explicitly setting the cluster
flag is no longer necessary in DM and MD.
Reported-by: Ed Lin <ed.lin@promise.com>
Acked-by: Mike Snitzer <snitzer@redhat.com>
This patch adds new entries required by the new version of MAX8998
driver. Without them, the driver fails to init. See commit 50f19a4596
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
S3C2416 PM code uses low-level sleep routines from S3C2412 code,
but these routines are compiled only for S3C2412 SoC.
Split S3C2412_PM to two parts: S3C2412_PM, S3C2412_PM_SLEEP and
select last in S3C2416's Kconfig.
Signed-off-by: Yauhen Kharuzhy <jekhor@gmail.com>
Should be CONFIG_S3C_DEV_NAND instead of CONFIG_S3C_DEVICE_NAND.
Cc: Ben Dooks <ben-linux@fluff.org>
A relocatable kernel can be anywhere in lowmem -- and in the case of a
kdump kernel, is likely to be fairly high. Since the early page
tables map everything from address zero up we need to make sure we
allocate enough brk that we can map all of lowmem if we need to.
Reported-by: Stanislaw Gruszka <sgruszka@redhat.com>
Tested-by: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <4D0AD3ED.8070607@kernel.org>
This reverts commit 1ab83238740ff1e1773d5c13ecac43c60cf4aec4.
Turns out this doesn't allow for the device ids to be overridden
properly, so we need to revert the thing.
Reported-by: Jef Driesen <jefdriesen@telenet.be>
Cc: Robert Lukassen <Robert.Lukassen@tomtom.com>
Cc: stable <stable@kernel.org>
* 'for-linus' of git://git.infradead.org/users/eparis/notify:
fanotify: fill in the metadata_len field on struct fanotify_event_metadata
fanotify: split version into version and metadata_len
fanotify: Dont try to open a file descriptor for the overflow event
fanotify: Introduce FAN_NOFD
fanotify: do not leak user reference on allocation failure
inotify: stop kernel memory leak on file creation failure
fanotify: on group destroy allow all waiters to bypass permission check
fanotify: Dont allow a mask of 0 if setting or removing a mark
fanotify: correct broken ref counting in case adding a mark failed
fanotify: if set by user unset FMODE_NONOTIFY before fsnotify_perm() is called
fanotify: remove packed from access response message
fanotify: deny permissions when no event was sent
Fabio Battaglia report that he has another cable that works with this
driver, so this patch adds its vendor/product ID.
Signed-off-by: Thomas Sailer <t.sailer@alumni.ethz.ch>
Add an unusual_devs entry for the Samsung YP-CP3 MP4 player.
User was getting the following errors in dmesg:
usb 2-6: reset high speed USB device using ehci_hcd and address 2
usb 2-6: USB disconnect, address 2
sd 3:0:0:0: [sdb] Assuming drive cache: write through
sdb:<2>ldm_validate_partition_table(): Disk read failed.
Dev sdb: unable to read RDB block 0
unable to read partition table
Signed-off-by: Vitaly Kuznetsov <vitty@altlinux.ru>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
CC: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
CC: stable@kernel.org
cdev struct is accessed in suspended sysfs show function. So
remove sysfs file before freeing the cdev in composite_unbind.
Signed-off-by: Pavankumar Kondeti <pkondeti@codeaurora.org>
bd6882 commit (usb: gadget: fix Kconfig warning) removes
the duplicate USB_OTG config from gadget/Kconfig. But
does not copy the input prompt and help text to the original
config defined in core/Kconfig. Add them now.
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (28 commits)
MIPS: Add a CONFIG_FORCE_MAX_ZONEORDER Kconfig option.
MIPS: LD/SD o32 macro GAS fix update
MIPS: Alchemy: fix build with SERIAL_8250=n
MIPS: Rename mips_dma_cache_sync back to dma_cache_sync
MIPS: MT: Fix typo in comment.
SSB: Fix nvram_get on BCM47xx platform
MIPS: BCM47xx: Swap serial console if ttyS1 was specified.
MIPS: BCM47xx: Use sscanf for parsing mac address
MIPS: BCM47xx: Fill values for b43 into SSB sprom
MIPS: BCM47xx: Do not read config from CFE
MIPS: FDT size is a be32
MIPS: Fix CP0 COUNTER clockevent race
MIPS: Fix regression on BCM4710 processor detection
MIPS: JZ4740: Fix pcm device name
MIPS: Separate two consecutive loads in memset.S
MIPS: Send proper signal and siginfo on FP emulator faults.
MIPS: AR7: Fix loops per jiffies on TNETD7200 devices
MIPS: AR7: Fix double ar7_gpio_init declaration
MIPS: Rework GENERIC_HARDIRQS Kconfig.
MIPS: Alchemy: Add return value check for strict_strtoul()
I wrote this quirk awhile ago to properly setup MCP55 chips on hypertransport
busses so that interrupts reached whatever cpu happend to boot the kdump kernel.
while that works well, it was recently shown to me that a a non-hypertransport
variant of the MCP55 exists, and on those system the register that this quirk
manipulates causes hangs if you write to it. Since the quirk was only meant to
handle errors found on MCP55 chips that have a HT interface, this patch adds a
filter to make sure the chip is an HT capable before making the needed register
adjustment. This lets the broken MCP55s work with kdump while not breaking the
non-HT variants.
Resolves https://bugzilla.kernel.org/show_bug.cgi?id=23952
Tested successfully by the reporter and myself.
Reported-by: Mathieu Bérard <mathieu@mberard.eu>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
gsm_data_alloc buffer allocation could fail and it is not being checked.
Add check for allocated buffer and return if the buffer allocation
fails.
Signed-off-by: Ken Mills <ken.k.mills@intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Fix message length handling when building header
When the message length is greater than 127, the length field in the header
is built incorrectly. According to the spec, when the length is less than 128
the length field is a single byte formatted as: bbbbbbb1. When it is greater
than 127 then the field is two bytes of the format: bbbbbbb0 bbbbbbbb.
For huge page support with base page size of 16K or 32K, we have to
increase the MAX_ORDER so that huge pages can be allocated.
[Ralf: I don't think a user should have to configure obscure constants like
this but for the time being this will have to suffice.]
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
To: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/1685/
I am about to commit:
http://sourceware.org/ml/binutils/2010-10/msg00033.html
that fixes a problem with the LD/SD macro currently implemented by GAS for
the o32 ABI in an inconsistent way. This is best illustrated with a
simple program, which I'm copying here from the message above for easier
reference:
$ cat ld.s
ld $5,32767($4)
ld $5,32768($4)
This gets assebled into the following output:
$ mips-linux-as -32 -mips3 -o ld.o ld.s
$ mips-linux-objdump -d ld.o
ld.o: file format elf32-tradbigmips
Disassembly of section .text:
00000000 <.text>:
0: dc857fff ld a1,32767(a0)
4: 3c010001 lui at,0x1
8: 00810821 addu at,a0,at
c: 8c258000 lw a1,-32768(at)
10: 8c268004 lw a2,-32764(at)
Oops!
The GAS fix makes the macro behave in a consistent way and pairs of LW/SW
instructions to be output as appropriate regardless of the size of the
offset associated with the address used. The machine instruction is still
available, but to reach it macros have to be disabled first. This has a
side effect of requiring the use of a machine-addressable memory operand.
As some platforms require 64-bit operations for accesses to some I/O
registers LD/SD instructions are used in a couple of places in Linux
regardless of the ABI selected. Here's a fix for some pieces of code
affected I've been able to track down. The fix should be backwards
compatible with all supported binutils releases in existence and can be
used as a reference for any other places or off-tree code. The use of the
"R" constraint guarantees a machine-addressable operand.
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/1680/
In commit 7d172bfe ("Alchemy: Add UART PM methods") I introduced
platform PM methods which call a function of the 8250 driver;
this patch works around link failures when the kernel is built
without 8250 support.
Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com>
To: Linux-MIPS <linux-mips@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/1737/
This fixes IP22 and IP28 build errors.
The nvram_get function was never in the mainline kernel, it only existed in
an external OpenWrt patch. Use nvram_getenv function, which is in mainline
and use an include instead of an extra function declaration. et0macaddr
contains the mac address in text from like 00:11:22:33:44:55. We have to
parse it before adding it into macaddr.
nvram_parse_macaddr will be merged into asm/mach-bcm47xx/nvram.h through
the MIPS git tree and will be available soon. It will not build now without
nvram_parse_macaddr, but it hasn't before either.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Cc: mb@bu3sch.de
Cc: netdev@vger.kernel.org
Cc: Hauke Mehrtens <hauke@hauke-m.de>
Acked-by: Michael Buesch <mb@bu3sch.de>
Patchwork: https://patchwork.linux-mips.org/patch/1849/
Some devices like the Netgear WGT634U are using ttyS1 for default console
output. We should switch to that console if it was given in the kernel_args
parameters.
Patchwork: https://patchwork.linux-mips.org/patch/1848/
Instead of writing own function for parsing the mac address we now
use sscanf.
Patchwork: https://patchwork.linux-mips.org/patch/1847/
Fill the sprom with all available values from the nvram. Most of these
new values are needed for the b43 or b43legacy driver.
Parts of this patch have been in OpenWRT for a long time and were written
by Michael Buesch.
Patchwork: https://patchwork.linux-mips.org/patch/1846/
The config options read out here are not stored in CFE but only in NVRAM on
the devices. Remove reading from CFE and only access the NVRAM. Reading out
CFE does not harm but is useless here.
Patchwork: https://patchwork.linux-mips.org/patch/1845/
The totalsize field was be32. And the reserve bootmem would cause failure.
To: devicetree-discuss@lists.ozlabs.org
Cc: grant.likely@secretlab.ca
Cc: David Daney <ddaney@caviumnetworks.com>
Cc: Dezhong Diao <dediao@cisco.com>
Patchwork: https://patchwork.linux-mips.org/patch/1838/
Consider the following test case:
write_c0_compare(read_c0_count());
Even if the counter doesn't increment during execution, this might not
generate an interrupt until the counter wraps around. The CPU may
perform the comparison each time CP0 COUNT increments, not when CP0
COMPARE is written.
If mips_next_event() is called with a very small delta, and CP0 COUNT
increments during the calculation of "cnt += delta", it is possible
that CP0 COMPARE will be written with the current value of CP0 COUNT.
If this is detected, the function should return -ETIME, to indicate
that the interrupt might not have actually gotten scheduled.
Signed-off-by: Kevin Cernekee <cernekee@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/1836/
BCM4710 uses the BMIPS32 core (like BCM6345), not the MIPS 4Kc core as
was previously believed.
Tested-by: Alexandros C. Couloumbis <alex@ozo.com>
Patchwork: https://patchwork.linux-mips.org/patch/1837/
As part the ASoC multi-component patch (commit f0fba2ad) the jz4740 pcm
driver was renamed to 'jz4740-pcm-audio'. Adjust the device name
accordingly.
Patchwork: https://patchwork.linux-mips.org/patch/1770/
partial_fixup is used in noreorder block.
Separating two consecutive loads can save one cycle on processors with
GPR intrelock and can fix load-use on processors that need a load delay slot.
Also do so for fwd_fixup.
[Ralf: Only R2000/R3000 class processors are lacking the the load-user
interlock and even some of those got it retrofitted. With R2000/R3000
being fairly uncommon these days the impact of this bug should be minor.]
Signed-off-by: Tony Wu <tung7970@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/1768/
We were unconditionally sending SIGBUS with an empty siginfo on FP
emulator faults. This differs from what happens when real floating
point hardware would get a fault.
For most faults we need to send SIGSEGV with the faulting address
filled in in the struct siginfo.
Reported-by: Camm Maguire <camm@maguirefamily.org>
Cc: Camm Maguire <camm@maguirefamily.org>
Patchwork: https://patchwork.linux-mips.org/patch/1727/
TNETD7200 run their CPU clock faster than the default CPU clock we assume.
In order to have the correct loops per jiffies settings, initialize clocks right
before setting mips_hpt_frequency. As a side effect, we can no longer use
msleep in clocks.c which requires other parts of the kernel to be initialized,
so replace these with mdelay.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
Patchwork: https://patchwork.linux-mips.org/patch/1749/
Patchwork: https://patchwork.linux-mips.org/patch/1748/
Recent changes to CONFIG_GENERIC_HARDIRQS have caused us to start getting:
warning: (SMP && SYS_SUPPORTS_SMP) selects IRQ_PER_CPU which has unmet direct dependencies (HAVE_GENERIC_HARDIRQS)
Rearranging our Kconfig quiets the message.
Patchwork: https://patchwork.linux-mips.org/patch/1757/
arch/mips/alchemy/devboards/prom.c: In function 'prom_init':
arch/mips/alchemy/devboards/prom.c:60: error: ignoring return value of
'strict_strtoul', declared with attribute warn_unused_result
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org>
Cc: linux-mips <linux-mips@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/1761/
cc1: warnings being treated as errors
arch/mips/loongson/common/env.c: In function 'prom_init_env':
arch/mips/loongson/common/env.c:49: error: ignoring return value of 'strict_strtol', declared with attribute warn_unused_result
arch/mips/loongson/common/env.c:50: error: ignoring return value of 'strict_strtol', declared with attribute warn_unused_result
arch/mips/loongson/common/env.c:51: error: ignoring return value of 'strict_strtol', declared with attribute warn_unused_result
arch/mips/loongson/common/env.c:52: error: ignoring return value of 'strict_strtol', declared with attribute warn_unused_result
Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/1762/
The return value of the vmalloc() call in arch/mips/kernel/vpe.c::vpe_open()
is not checked, so we potentially store a null pointer in v->pbuffer. Add
a check for a null return and then return -ENOMEM in that case.
[Ralf: The check added by Jesper's original patch is where it logically
should be. Adding it eleminated the need for the checks in a few other
places, so I removed them. There still is a zillion of other things that
need to be fixed in this file / API.]
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Patchwork: https://patchwork.linux-mips.org/patch/1747/
If PER_LINUX32 has been set on a 32-bit kernel, only twiddle with the
low-order personality bits, let the upper bits pass through.
Patchwork: https://patchwork.linux-mips.org/patch/1751/
The high bits of current->personality carry settings that we don't want to
clobber on each exec. Only clobber them if the lower bits that indicate
either PER_LINUX or PER_LINUX32 are invalid.
The clobbering prevents us from using useful bits like ADDR_NO_RANDOMIZE.
Patchwork: https://patchwork.linux-mips.org/patch/1750/
This patch fixes the following section mismatch:
WARNING: arch/mips/built-in.o(.text+0xc): Section mismatch in reference from the
function jz4740_init_cmdline() to the variable .init.data:arcs_cmdline
While were at it, make jz4740_init_cmdline static as well.
Patchwork: https://patchwork.linux-mips.org/patch/1755/
This patch fixes the gpio number for the 6th row of the keyboard matrix.
(And fixes a typo in my name...)
Signed-off-by: https://patchwork.linux-mips.org/patch/1754/
We never needed that (->regs[2] is overwritten on return from syscall paths
with return value of syscall, so storing it there early made no sense) and
with new restart logics since d27240bf7e61d2656de18e158ec910a902030847 it
has become really bad - we lose the original syscall number before the
place where we decide that we might need a syscall restart.
Note that for child we do need the assignment to regs[2] - it won't go
through the normal return from syscall path.
[Ralf: Issue found and reported by Lluís; initial investigations by me;
bug finally found and patch by Al; testing by me and Lluís.]
Tested-by: Lluís Batlle i Rossell <viriketo@gmail.com>
