commit 6dfbd87a20a737641ef228230c77f4262434fa24 upstream
ip6ip6: autoload ip6 tunnel
Add necessary alias to autoload ip6ip6 tunnel module.
commit e192a7cf0effe7680264a5bc35c0ad1bdcdc921c upstream.
This patch adds the pid filtering for the dib7000M demod. It also
corrects the pid filtering for the dib7700 based board. It should
prevent an oops, when using dib7700p based board.
References: https://bugzilla.novell.com/show_bug.cgi?id=644807
Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr>
Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr>
Tested-by: Pavel SKARKA <paul.sp@seznam.cz>
commit 1e6406b8f0dc1ae7d7c39c9e1ac6ca78e016ebfb upstream.
Fix the probing of cx2583x chips, because two controls were clustered
that are not created for these chips.
This regression was introduced in 2.6.36.
Signed-off-by: Sven Barth <pascaldragon@googlemail.com>
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
commit 67914b5c400d6c213f9e56d7547a2038ab5c06f4 upstream.
This reverts commit 44835f197bf1e3f57464f23dfb239fef06cf89be.
With the CX23885 hardware I2C master, checking for I2C slave ACK/NAK
is not valid when the I2C_EXTEND or I2C_NOSTOP bits are set.
Revert the commit that checks for I2C slave ACK/NAK on all transactions,
so that XC5000 tuners work with the CX23885 again.
Thanks go to Mark Zimmerman for reporting and bisecting this problem.
Bisected-by: Mark Zimmerman <markzimm@frii.com>
Reported-by: Mark Zimmerman <markzimm@frii.com>
commit d213ad08362909ab50fbd6568fcc9fd568268d29 upstream.
After upgrading the kernel from stock Ubuntu 7.10 to
10.04, with no hardware changes, I started getting the dreaded DMA
TIMEOUT errors, followed by inability to encode until the machine was
rebooted.
I came across a post from Andy in March
(http://www.gossamer-threads.com/lists/ivtv/users/40943#40943) where he
speculates that perhaps the corrective actions being taken after a DMA
ERROR are not sufficient to recover the situation. After some testing
I suspect that this is indeed the case, and that in fact the corrective
action may be what hangs the card's DMA engine, rather than the
original error.
Specifically these DMA ERROR IRQs seem to present with two different
values in the IVTV_REG_DMASTATUS register: 0x11 and 0x13. The current
corrective action is to clear that status register back to 0x01 or
0x03, and then issue the next DMA request. In the case of a 0x13 this
seems to result in a minor glitch in the encoded stream due to the
failed transfer that was not retried, but otherwise things continue OK.
In the case of a 0x11 the card's DMA write engine is never heard from
again, and a DMA TIMEOUT follows shortly after. 0x11 is the killer.
I suspect that the two cases need to be handled differently. The
difference is in bit 1 (0x02), which is set when the error is about to
be successfully recovered, and clear when things are about to go bad.
Bit 1 of DMASTATUS is described differently in different places either
as a positive "write finished", or an inverted "write busy". If we
take the first definition, then when an error arises with state 0x11,
it means that the write did not complete. It makes sense to start a
new transfer, as in the current code. But if we take the second
definition, then 0x11 means "an error but the write engine is still
busy". Trying to feed it a new transfer in this situation might not be
a good idea.
As an experiment, I added code to ignore the DMA ERROR IRQ if DMASTATUS
is 0x11. I.e., don't start a new transfer, don't clear our flags, etc.
The hope was that the card would complete the transfer and issue a ENC
DMA COMPLETE, either successfully or with an error condition there.
However the card still hung.
The only remaining corrective action being taken with a 0x11 status was
then the write back to the status register to clear the error, i.e.
DMASTATUS = DMASTATUS & ~3. This would have the effect of clearing the
error bit 4, while leaving the lower bits indicating DMA write busy.
Strangely enough, removing this write to the status register solved the
problem! If the DMA ERROR IRQ with DMASTATUS=0x11 is completely
ignored, with no corrective action at all, then the card will complete
the transfer and issue a new IRQ. If the status register is written to
when it has the value 0x11, then the DMA engine hangs. Perhaps it's
illegal to write to
DMASTATUS while the read or write busy bit is set? At any rate, it
appears that the current corrective action is indeed making things
worse rather than better.
I put together a patch that modifies ivtv_irq_dma_err to do the
following:
- Don't write back to IVTV_REG_DMASTATUS.
- If write-busy is asserted, leave the card alone. Just extend the
timeout slightly.
- If write-busy is de-asserted, retry the current transfer.
This has completely fixed my DMA TIMEOUT woes. DMA ERR events still
occur, but now they seem to be correctly handled. 0x11 events no
longer hang the card, and 0x13 events no longer result in a glitch in
the stream, as the failed transfer is retried. I'm happy.
I've inlined the patch below in case it is of interest. As described
above, I have a theory about why it works (based on a different
interpretation of bit 1 of DMASTATUS), but I can't guarantee that my
theory is correct. There may be another explanation, or it may be a
fluke. Maybe ignoring that IRQ entirely would be equally effective?
Maybe the status register read/writeback sequence is race condition if
the card changes it in the mean time? Also as I am using a PVR-150
only, I have not been able to test it on other cards, which may be
especially relevant for 350s that support concurrent decoding.
Hopefully the patch does not break the DMA READ path.
Mike
[awalls@md.metrocast.net: Modified patch to add a verbose comment, make minor
brace reformats, and clear the error flags in the IVTV_REG_DMASTATUS iff both
read and write DMA were not in progress. Mike's conjecture about a race
condition with the writeback is correct; it can confuse the DMA engine.]
[Comment and analysis from the ML post by Michael <mike@rsy.com>]
commit 0c3b9168017cbad2c4af3dd65ec93fe646eeaa62 upstream.
The current sched rt code is broken when it comes to hierarchical
scheduling, this patch fixes two problems
1. It adds redundant enqueuing (harmless) when it finds a queue
has tasks enqueued, but it has no run time and it is not
throttled.
2. The most important change is in sched_rt_rq_enqueue/dequeue.
The code just picks the rt_rq belonging to the current cpu
on which the period timer runs, the patch fixes it, so that
the correct rt_se is enqueued/dequeued.
Tested with a simple hierarchy
/c/d, c and d assigned similar runtimes of 50,000 and a while
1 loop runs within "d". Both c and d get throttled, without
the patch, the task just stops running and never runs (depends
on where the sched_rt b/w timer runs). With the patch, the
task is throttled and runs as expected.
[ bharata, suggestions on how to pick the rt_se belong to the
rt_rq and correct cpu ]
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Acked-by: Bharata B Rao <bharata@linux.vnet.ibm.com>
LKML-Reference: <20110303113435.GA2868@balbir.in.ibm.com>
commit 0d672e9f8ac320c6d1ea9103db6df7f99ea20361 upstream.
Without calling of netif_carrier_off at the end of the probe the operstate
is unknown when the device is initially opened. By default the carrier is
on so when the device is opened and netif_carrier_on is called the link
watch event is not fired and operstate remains zero (unknown).
This patch fixes this behavior in forcedeth and r8169.
Signed-off-by: Ivan Vecera <ivecera@redhat.com>
Acked-by: Francois Romieu <romieu@fr.zoreil.com>
commit f60ac8e7ab7cbb413a0131d5665b053f9f386526 upstream.
While the RxFIFO interruption is masked for most 8168, nothing prevents
it to appear in the irq status word. This is no excuse to crash.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Cc: Ivan Vecera <ivecera@redhat.com>
Cc: Hayes <hayeswang@realtek.com>
commit 1519e57fe81c14bb8fa4855579f19264d1ef63b4 upstream.
Some experiment-based action to prevent my 8168 chipsets locking-up hard
in the irq handler under load (pktgen ~1Mpps). Apparently a reset is not
always mandatory (is it at all ?).
- RTL_GIGA_MAC_VER_12
- RTL_GIGA_MAC_VER_25
Missed ~55% packets. Note:
- this is an old SiS 965L motherboard
- the 8168 chipset emits (lots of) control frames towards the sender
- RTL_GIGA_MAC_VER_26
The chipset does not go into a frenzy of mac control pause when it
crashes yet but it can still be crashed. It needs more work.
commit b5ba6d12bdac21bc0620a5089e0f24e362645efd upstream.
I found that one of the 8168c chipsets (concretely XID 1c4000c0) starts
generating RxFIFO overflow errors. The result is an infinite loop in
interrupt handler as the RxFIFOOver is handled only for ...MAC_VER_11.
With the workaround everything goes fine.
commit 9d0db8b6b1da9e3d4c696ef29449700c58d589db upstream.
In 135367b "netfilter: xtables: change xt_target.checkentry return type",
the type returned by checkentry was changed from boolean to int, but the
return values where not adjusted.
arptables: Input/output error
This broke arptables with the mangle target since it returns true
under success, which is interpreted by xtables as >0, thus
returning EIO.
commit 8909c9ad8ff03611c9c96c9a92656213e4bb495b upstream.
Since a8f80e8ff94ecba629542d9b4b5f5a8ee3eb565c any process with
CAP_NET_ADMIN may load any module from /lib/modules/. This doesn't mean
that CAP_NET_ADMIN is a superset of CAP_SYS_MODULE as modules are
limited to /lib/modules/**. However, CAP_NET_ADMIN capability shouldn't
allow anybody load any module not related to networking.
This patch restricts an ability of autoloading modules to netdev modules
with explicit aliases. This fixes CVE-2011-1019.
Arnd Bergmann suggested to leave untouched the old pre-v2.6.32 behavior
of loading netdev modules by name (without any prefix) for processes
with CAP_SYS_MODULE to maintain the compatibility with network scripts
that use autoloading netdev modules by aliases like "eth0", "wlan0".
Currently there are only three users of the feature in the upstream
kernel: ipip, ip_gre and sit.
root@albatros:~# capsh --drop=$(seq -s, 0 11),$(seq -s, 13 34) --
root@albatros:~# grep Cap /proc/$$/status
CapInh: 0000000000000000
CapPrm: fffffff800001000
CapEff: fffffff800001000
CapBnd: fffffff800001000
root@albatros:~# modprobe xfs
FATAL: Error inserting xfs
(/lib/modules/2.6.38-rc6-00001-g2bf4ca3/kernel/fs/xfs/xfs.ko): Operation not permitted
root@albatros:~# lsmod | grep xfs
root@albatros:~# ifconfig xfs
xfs: error fetching interface information: Device not found
root@albatros:~# lsmod | grep sit
root@albatros:~# ifconfig sit
sit: error fetching interface information: Device not found
root@albatros:~# ifconfig sit0
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
sit 10457 0
tunnel4 2957 1 sit
For CAP_SYS_MODULE module loading is still relaxed:
CapPrm: ffffffffffffffff
CapEff: ffffffffffffffff
CapBnd: ffffffffffffffff
xfs 745319 0
Reference: https://lkml.org/lkml/2011/2/24/203
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Signed-off-by: Michael Tokarev <mjt@tls.msk.ru>
Acked-by: Kees Cook <kees.cook@canonical.com>
Signed-off-by: James Morris <jmorris@namei.org>
commit ff75f40f44ae9b79d520bf32a05d35af74a805c0 upstream.
Fix dst_lock usage in __ip_vs_update_dest. We need
_bh locking because destination is updated in user context.
Can cause lockups on frequent destination updates.
Problem reported by Simon Kirby. Bug was introduced
in 2.6.37 from the "ipvs: changes for local real server"
change.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Hans Schillstrom <hans@schillstrom.com>
Signed-off-by: Simon Horman <horms@verge.net.au>
Cc: Simon Kirby <sim@hostway.ca>
commit d1205f87bbb8040c1408bbd9e0a720310b2b0b9b upstream.
On recent 2.6.38-rc kernels, connectathon basic test 6 fails on
NFSv4 mounts of OpenSolaris with something like:
> ./test6: readdir
> ./test6: (/mnt/klimt/matisse.test) didn't read expected 'file.12' dir entry, pass 0
> ./test6: (/mnt/klimt/matisse.test) didn't read expected 'file.82' dir entry, pass 0
> ./test6: (/mnt/klimt/matisse.test) didn't read expected 'file.164' dir entry, pass 0
> ./test6: (/mnt/klimt/matisse.test) Test failed with 3 errors
> basic tests failed
> Tests failed, leaving /mnt/klimt mounted
> [cel@matisse cthon04]$
I narrowed the problem down to nfs4_decode_dirent() reporting that the
decode buffer had overflowed while decoding the entries for those
missing files.
verify_attr_len() assumes both it's pointer arguments reside on the
same page. When these arguments point to locations on two different
pages, verify_attr_len() can report false errors. This can happen now
that a large NFSv4 readdir result can span pages.
We have reasonably good checking in nfs4_decode_dirent() anyway, so
it should be safe to simply remove the extra checking.
At a guess, this was introduced by commit 6650239a, "NFS: Don't use
vm_map_ram() in readdir".
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit ad6d42670279da8f33f633f8a96a67cd7ef3b1da upstream.
This commit allows the device to be recognized as a touchscreen, and not a
touchpad by xf86-input-evdev.
The device has 2 modes. The first one is an emulation of a touchscreen by
sending left and right button, and the second mode is the one used in
dual-touch (sending trackingID, touch and else).
That's why there is a hid report containing left and right buttons
(9000001 and 9000002). The point is that xorg relies on these fields to
determine if it's a touchpad or a touchscreen.
Clearing the report (return -1) makes xorg detecting it out of the box
as a quite pleasant (dual)touchscreen.
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr>
Acked-by: Chase Douglas <chase.douglas@canonical.com>
Cc: James Sharam <james.sharam@googlemail.com>
commit 3ec07aa9522e3d5e9d5ede7bef946756e623a0a0 upstream.
Index i was already used in the outer loop
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 1f858ef2fbabdc5e645644010a31a40c32e397c9 upstream.
Return 0 on failure. This will cause the initialization of the driver
to fail and prevent the driver from loading if the BIOS cannot handle
the PCC interface command to "get frequency". Otherwise, the driver
will load and display a very high value like "4294967274" (which is
actually -EINVAL) for frequency:
# cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
4294967274
Signed-off-by: Naga Chumbalkar <nagananda.chumbalkar@hp.com>
Signed-off-by: Dave Jones <davej@redhat.com>
commit 9ef0298a8e5730d9a46d640014c727f3b4152870 upstream.
Like many other places, we have to check that the array index is
within allowed limits, or otherwise, a kernel oops and other nastiness
can ensue when we access memory beyond the end of the array.
[ 5954.115381] BUG: unable to handle kernel paging request at 0000004000000000
[ 5954.120014] IP: __find_logger+0x6f/0xa0
[ 5954.123979] nf_log_bind_pf+0x2b/0x70
[ 5954.123979] nfulnl_recv_config+0xc0/0x4a0 [nfnetlink_log]
[ 5954.123979] nfnetlink_rcv_msg+0x12c/0x1b0 [nfnetlink]
The problem goes back to v2.6.30-rc1~1372~1342~31 where nf_log_bind
was decoupled from nf_log_register.
Reported-by: Miguel Di Ciurcio Filho <miguel.filho@gmail.com>,
via irc.freenode.net/#netfilter
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
commit a3e8cc643d22d2c8ed36b9be7d9c9ca21efcf7f7 upstream.
Robert Swiecki reported a BUG_ON(page_mapped) from a fuzzer, punching
a hole with madvise(,, MADV_REMOVE). That path is under mutex, and
cannot be explained by lack of serialization in unmap_mapping_range().
Reviewing the code, I found one place where vm_truncate_count handling
should have been updated, when I switched at the last minute from one
way of managing the restart_addr to another: mremap move changes the
virtual addresses, so it ought to adjust the restart_addr.
But rather than exporting the notion of restart_addr from memory.c, or
converting to restart_pgoff throughout, simply reset vm_truncate_count
to 0 to force a rescan if mremap move races with preempted truncation.
We have no confirmation that this fixes Robert's BUG,
but it is a fix that's worth making anyway.
Cc: Kerin Millar <kerframil@gmail.com>
commit a124339ad28389093ed15eca990d39c51c5736cc upstream.
We have found a hardware erratum on 82599 hardware that can lead to
unpredictable behavior when Header Splitting mode is enabled. So
we are no longer enabling this feature on affected hardware.
Please see the 82599 Specification Update for more information.
Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com>
Tested-by: Stephen Ko <stephen.s.ko@intel.com>
This is a backport of upstream commit 0f5cd45960173ba5b36727decbb4a241cbd35ef9.
The DMA latency issue is observed only in Intel pinetrail platforms
but in the driver we had a default PM-QOS value of 55. This caused
unnecessary power consumption and battery drain in other platforms.
Remove the pm-qos thing in the driver code and address the throughput
issue in Intel pinetrail platfroms in user space using any one of
the scripts in below links:
http://www.kernel.org/pub/linux/kernel/people/mcgrof/scripts/cpudmalatency.c
http://johannes.sipsolutions.net/files/netlatency.c.txt
More details can be found in the following bugzilla link:
https://bugzilla.kernel.org/show_bug.cgi?id=27532
Signed-off-by: Thomas Bächler <thomas@archlinux.org>
Acked-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com>
commit f009918a1c1bbf8607b8aab3959876913a30193a upstream.
commit 339412841d7 (RxRPC: Allow key payloads to be passed in XDR form)
broke klog for me. I notice the v1 key struct had a kif_version field
added:
-struct rxkad_key {
- u16 security_index; /* RxRPC header security index */
- u16 ticket_len; /* length of ticket[] */
- u32 expiry; /* time at which expires */
- u32 kvno; /* key version number */
- u8 session_key[8]; /* DES session key */
- u8 ticket[0]; /* the encrypted ticket */
+struct rxrpc_key_data_v1 {
+ u32 kif_version; /* 1 */
+ u16 security_index;
+ u16 ticket_length;
+ u32 expiry; /* time_t */
+ u32 kvno;
+ u8 session_key[8];
+ u8 ticket[0];
However the code in rxrpc_instantiate strips it away:
data += sizeof(kver);
datalen -= sizeof(kver);
Removing kif_version fixes my problem.
commit e9e3d724e2145f5039b423c290ce2b2c3d8f94bc upstream.
The "bad_page()" page allocator sanity check was reported recently (call
chain as follows):
bad_page+0x69/0x91
free_hot_cold_page+0x81/0x144
skb_release_data+0x5f/0x98
__kfree_skb+0x11/0x1a
tcp_ack+0x6a3/0x1868
tcp_rcv_established+0x7a6/0x8b9
tcp_v4_do_rcv+0x2a/0x2fa
tcp_v4_rcv+0x9a2/0x9f6
do_timer+0x2df/0x52c
ip_local_deliver+0x19d/0x263
ip_rcv+0x539/0x57c
netif_receive_skb+0x470/0x49f
:virtio_net:virtnet_poll+0x46b/0x5c5
net_rx_action+0xac/0x1b3
__do_softirq+0x89/0x133
call_softirq+0x1c/0x28
do_softirq+0x2c/0x7d
do_IRQ+0xec/0xf5
default_idle+0x0/0x50
ret_from_intr+0x0/0xa
default_idle+0x29/0x50
cpu_idle+0x95/0xb8
start_kernel+0x220/0x225
_sinittext+0x22f/0x236
It occurs because an skb with a fraglist was freed from the tcp
retransmit queue when it was acked, but a page on that fraglist had
PG_Slab set (indicating it was allocated from the Slab allocator (which
means the free path above can't safely free it via put_page.
We tracked this back to an nfsv4 setacl operation, in which the nfs code
attempted to fill convert the passed in buffer to an array of pages in
__nfs4_proc_set_acl, which gets used by the skb->frags list in
xs_sendpages. __nfs4_proc_set_acl just converts each page in the buffer
to a page struct via virt_to_page, but the vfs allocates the buffer via
kmalloc, meaning the PG_slab bit is set. We can't create a buffer with
kmalloc and free it later in the tcp ack path with put_page, so we need
to either:
1) ensure that when we create the list of pages, no page struct has
PG_Slab set
or
2) not use a page list to send this data
Given that these buffers can be multiple pages and arbitrarily sized, I
think (1) is the right way to go. I've written the below patch to
allocate a page from the buddy allocator directly and copy the data over
to it. This ensures that we have a put_page free-able page for every
entry that winds up on an skb frag list, so it can be safely freed when
the frame is acked. We do a put page on each entry after the
rpc_call_sync call so as to drop our own reference count to the page,
leaving only the ref count taken by tcp_sendpages. This way the data
will be properly freed when the ack comes in
Successfully tested by myself to solve the above oops.
Note, as this is the result of a setacl operation that exceeded a page
of data, I think this amounts to a local DOS triggerable by an
uprivlidged user, so I'm CCing security on this as well.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Trond Myklebust <Trond.Myklebust@netapp.com>
CC: Jeff Layton <jlayton@redhat.com>
commit 97e419a082461f8a3a0818834eb88ad41219a1da upstream.
The device table is required to load modules based on modaliases.
Cc: Shubhrajyoti D <shubhrajyoti@ti.com>
Cc: Christoph Mair <christoph.mair@gmail.com>
Cc: Jonathan Cameron <jic23@cam.ac.uk>
commit 38c07641905c0db58e800ea974cd9158717c6610 upstream.
The errata init verbs for CS42xx codecs contain the verbs to set
the power-state of SPDIF nodes to D3, which seem to break the SPDIF
output on some MacBooks. Since this is executed during the power-up
initialization, we shouldn't turn them down there.
Reported-by: Arun Raghavan <arun.raghavan@collabora.co.uk>
commit f0ce27996217d06207c8bfda1b1bbec2fbab48c6 upstream.
This patch fixes an error in the jack detection reporting,
causing the jack detection sometimes not to be reported
correctly to the input subsystem. It should apply to several
Realtek codecs.
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit 3ee845acba58549578d03a46ed307c0a56c7f777 upstream.
It went AWOL in the multi-component conversion.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
commit b652277b09d3d030cb074cc6a98ba80b34244c03 upstream.
The "ct" variable should be an unsigned int. Both struct kbdiacrs
->kb_cnt and struct kbd_data ->accent_table_size are unsigned ints.
Making it signed causes a problem in KBDIACRUC because the user could
set the signed bit and cause a buffer overflow.
commit d7a62cd0332115d4c7c4689abea0d889a30d8349 upstream.
If a virtio-console device gets unplugged while a port is open, a
subsequent close() call on the port accesses vqs to free up buffers.
This can lead to a crash.
The buffers are already freed up as a result of the call to
unplug_ports() from virtcons_remove(). The fix is to simply not access
vq information if port->portdev is NULL.
Reported-by: juzhang <juzhang@redhat.com>
Signed-off-by: Amit Shah <amit.shah@redhat.com>
commit b75f38d659e6fc747eda64cb72f3920e29dd44a4 upstream.
Don't forget to release cgroup_mutex if alloc_trial_cpuset() fails.
[akpm@linux-foundation.org: avoid multiple return points]
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: Paul Menage <menage@google.com>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Miao Xie <miaox@cn.fujitsu.com>
commit d11327ad6695db8117c78d70611e71102ceec2ac upstream.
NETDEV_NOTIFY_PEER is an explicit request by the driver to send a link
notification while NETDEV_UP/NETDEV_CHANGEADDR generate link
notifications as a sort of side effect.
In the later cases the sysctl option is present because link
notification events can have undesired effects e.g. if the link is
flapping. I don't think this applies in the case of an explicit
request from a driver.
This patch makes NETDEV_NOTIFY_PEER unconditional, if preferred we
could add a new sysctl for this case which defaults to on.
This change causes Xen post-migration ARP notifications (which cause
switches to relearn their MAC tables etc) to be sent by default.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
[reported to solve hyperv live migration problem - gkh]
Cc: Haiyang Zhang <haiyangz@microsoft.com>
Cc: Mike Surcouf <mike@surcouf.co.uk>
Cc: Hank Janssen <hjanssen@microsoft.com>
commit 1362fa078dae16776cd439791c6605b224ea6171 upstream.
When a DNS resolver key is instantiated with an error indication, attempts to
read that key will result in an oops because user_read() is expecting there to
be a payload - and there isn't one [CVE-2011-1076].
Give the DNS resolver key its own read handler that returns the error cached in
key->type_data.x[0] as an error rather than crashing.
Also make the kenter() at the beginning of dns_resolver_instantiate() limit the
amount of data it prints, since the data is not necessarily NUL-terminated.
The buggy code was added in:
commit 4a2d789267e00b5a1175ecd2ddefcc78b83fbf09
Author: Wang Lei <wang840925@gmail.com>
Date: Wed Aug 11 09:37:58 2010 +0100
Subject: DNS: If the DNS server returns an error, allow that to be cached [ver #2]
This can trivially be reproduced by any user with the following program
compiled with -lkeyutils:
#include <stdlib.h>
#include <keyutils.h>
#include <err.h>
static char payload[] = "#dnserror=6";
int main()
key_serial_t key;
key = add_key("dns_resolver", "a", payload, sizeof(payload),
KEY_SPEC_SESSION_KEYRING);
if (key == -1)
err(1, "add_key");
if (keyctl_read(key, NULL, 0) == -1)
err(1, "read_key");
return 0;
What should happen is that keyctl_read() reports error 6 (ENXIO) to the user:
dns-break: read_key: No such device or address
but instead the kernel oopses.
This cannot be reproduced with the 'keyutils add' or 'keyutils padd' commands
as both of those cut the data down below the NUL termination that must be
included in the data. Without this dns_resolver_instantiate() will return
-EINVAL and the key will not be instantiated such that it can be read.
The oops looks like:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000010
IP: [<ffffffff811b99f7>] user_read+0x4f/0x8f
PGD 3bdf8067 PUD 385b9067 PMD 0
Oops: 0000 [#1] SMP
last sysfs file: /sys/devices/pci0000:00/0000:00:19.0/irq
CPU 0
Modules linked in:
Pid: 2150, comm: dns-break Not tainted 2.6.38-rc7-cachefs+ #468 /DG965RY
RIP: 0010:[<ffffffff811b99f7>] [<ffffffff811b99f7>] user_read+0x4f/0x8f
RSP: 0018:ffff88003bf47f08 EFLAGS: 00010246
RAX: 0000000000000001 RBX: ffff88003b5ea378 RCX: ffffffff81972368
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff88003b5ea378
RBP: ffff88003bf47f28 R08: ffff88003be56620 R09: 0000000000000000
R10: 0000000000000395 R11: 0000000000000002 R12: 0000000000000000
R13: 0000000000000000 R14: 0000000000000000 R15: ffffffffffffffa1
FS: 00007feab5751700(0000) GS:ffff88003e000000(0000) knlGS:0000000000000000
CR2: 0000000000000010 CR3: 000000003de40000 CR4: 00000000000006f0
Process dns-break (pid: 2150, threadinfo ffff88003bf46000, task ffff88003be56090)
Stack:
ffff88003b5ea378 ffff88003b5ea3a0 0000000000000000 0000000000000000
ffff88003bf47f68 ffffffff811b708e ffff88003c442bc8 0000000000000000
00000000004005a0 00007fffba368060 0000000000000000 0000000000000000
Call Trace:
[<ffffffff811b708e>] keyctl_read_key+0xac/0xcf
[<ffffffff811b7c07>] sys_keyctl+0x75/0xb6
[<ffffffff81001f7b>] system_call_fastpath+0x16/0x1b
Code: 75 1f 48 83 7b 28 00 75 18 c6 05 58 2b fb 00 01 be bb 00 00 00 48 c7 c7 76 1c 75 81 e8 13 c2 e9 ff 4c 8b b3 e0 00 00 00 4d 85 ed <41> 0f b7 5e 10 74 2d 4d 85 e4 74 28 e8 98 79 ee ff 49 39 dd 48
RIP [<ffffffff811b99f7>] user_read+0x4f/0x8f
RSP <ffff88003bf47f08>
Acked-by: Jeff Layton <jlayton@redhat.com>
cc: Wang Lei <wang840925@gmail.com>
commit 4def99bbfd46e05c5e03b5b282cb4ee30e27ff19 upstream.
When support for 82577/82578 was added[1] in 2.6.31, PHY wakeup was in-
advertently enabled (even though it does not function properly) on ICH10
LOMs. This patch makes it so that the ICH10 LOMs use MAC wakeup instead
as was done with the initial support for those devices (i.e. 82567LM-3,
82567LF-3 and 82567V-4).
[1] commit a4f58f5455ba0efda36fb33c37074922d1527a10
Reported-by: Aurelien Jarno <aurelien@aurel32.net>
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com>
commit 720dc34bbbe9493c7bd48b2243058b4e447a929d upstream.
This fixes a bug in the order of dccp_rcv_state_process() that still permitted
reception even after closing the socket. A Reset after close thus causes a NULL
pointer dereference by not preventing operations on an already torn-down socket.
dccp_v4_do_rcv()
| state other than OPEN
v
| DCCP_PKT_RESET
v
dccp_rcv_reset()
v
dccp_time_wait()
WARNING: at net/ipv4/inet_timewait_sock.c:141 __inet_twsk_hashdance+0x48/0x128()
Modules linked in: arc4 ecb carl9170 rt2870sta(C) mac80211 r8712u(C) crc_ccitt ah
[<c0038850>] (unwind_backtrace+0x0/0xec) from [<c0055364>] (warn_slowpath_common)
[<c0055364>] (warn_slowpath_common+0x4c/0x64) from [<c0055398>] (warn_slowpath_n)
[<c0055398>] (warn_slowpath_null+0x1c/0x24) from [<c02b72d0>] (__inet_twsk_hashd)
[<c02b72d0>] (__inet_twsk_hashdance+0x48/0x128) from [<c031caa0>] (dccp_time_wai)
[<c031caa0>] (dccp_time_wait+0x40/0xc8) from [<c031c15c>] (dccp_rcv_state_proces)
[<c031c15c>] (dccp_rcv_state_process+0x120/0x538) from [<c032609c>] (dccp_v4_do_)
[<c032609c>] (dccp_v4_do_rcv+0x11c/0x14c) from [<c0286594>] (release_sock+0xac/0)
[<c0286594>] (release_sock+0xac/0x110) from [<c031fd34>] (dccp_close+0x28c/0x380)
[<c031fd34>] (dccp_close+0x28c/0x380) from [<c02d9a78>] (inet_release+0x64/0x70)
The fix is by testing the socket state first. Receiving a packet in Closed state
now also produces the required "No connection" Reset reply of RFC 4340, 8.3.1.
Reported-and-tested-by: Johan Hovold <jhovold@gmail.com>
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
commit ba04c7c93bbcb48ce880cf75b6e9dffcd79d4c7b upstream.
For some time is known that ASPM is causing troubles on r8169, i.e. make
device randomly stop working without any errors in dmesg.
Currently Tomi Leppikangas reports that system with r8169 device hangs
with MCE errors when ASPM is enabled:
https://bugzilla.redhat.com/show_bug.cgi?id=642861#c4
Lets disable ASPM for r8169 devices at all, to avoid problems with
r8169 PCIe devices at least for some users.
Reported-by: Tomi Leppikangas <tomi.leppikangas@gmail.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit c86664e5a285af1afa06416e450e7c4af04daa7c upstream.
"AirLive X.USB now works perfectly under a Linux
environment!"
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
commit 72746ac643928f6c3113b5aa783d8ea1b13949d2 upstream.
According to the report from Jiro SEKIBA titled "regression in
2.6.37?" (Message-Id: <8739n8vs1f.wl%jir@sekiba.com>), on 2.6.37 and
later kernels, lscp command no longer displays "i" flag on checkpoints
that snapshot operations or garbage collection created.
This is a regression of nilfs2 checkpointing function, and it's
critical since it broke behavior of a part of nilfs2 applications.
For instance, snapshot manager of TimeBrowse gets to create
meaningless snapshots continuously; snapshot creation triggers another
checkpoint, but applications cannot distinguish whether the new
checkpoint contains meaningful changes or not without the i-flag.
This patch fixes the regression and brings that application behavior
back to normal.
Reported-by: Jiro SEKIBA <jir@unicus.jp>
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Tested-by: Jiro SEKIBA <jir@unicus.jp>
commit 2b799a6b25bb9f9fbc478782cd9503e8066ab618 upstream.
Reported-by: Mark Davis
commit 2c27392dc4d4f5ee8a3967a520b8f6cac0418031 upstream.
The stream length/tag fields have to be in little endian
format. Fixing this makes the driver work on big-endian
platforms.
Tested-by: raghunathan.kailasanathan@wipro.com
Signed-off-by: Sujith Manoharan <Sujith.Manoharan@atheros.com>
commit fd51469fb68b987032e46297e0a4fe9020063c20 upstream.
Following steps lead to deadlock in kernel:
dd if=/dev/zero of=img bs=512 count=1000
losetup -f img
mkfs.ext2 /dev/loop0
mount -t ext2 -o loop /dev/loop0 mnt
umount mnt/
Stacktrace:
[<c102ec04>] irq_exit+0x36/0x59
[<c101502c>] smp_apic_timer_interrupt+0x6b/0x75
[<c127f639>] apic_timer_interrupt+0x31/0x38
[<c101df88>] mutex_spin_on_owner+0x54/0x5b
[<fe2250e9>] lo_release+0x12/0x67 [loop]
[<c10c4eae>] __blkdev_put+0x7c/0x10c
[<c10a4da5>] fput+0xd5/0x1aa
[<fe2250cf>] loop_clr_fd+0x1a9/0x1b1 [loop]
[<fe225110>] lo_release+0x39/0x67 [loop]
[<c10a59d9>] deactivate_locked_super+0x17/0x36
[<c10b6f37>] sys_umount+0x27e/0x2a5
[<c10b6f69>] sys_oldumount+0xb/0xe
[<c1002897>] sysenter_do_call+0x12/0x26
[<ffffffff>] 0xffffffff
Regression since 2a48fc0ab24241755dc9, which introduced the private
loop_mutex as part of the BKL removal process.
As per [1], the mutex can be safely removed.
[1] http://www.gossamer-threads.com/lists/linux/kernel/1341930
Addresses: https://bugzilla.novell.com/show_bug.cgi?id=669394
Addresses: https://bugzilla.kernel.org/show_bug.cgi?id=29172
Signed-off-by: Petr Uzel <petr.uzel@suse.cz>
Reviewed-by: Nikanth Karthikesan <knikanth@suse.de>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit 255bb490c8c27eed484d538efe6ef6a7473bd3f6 upstream.
blk-flush decomposes a flush into sequence of multiple requests. On
completion of a request, the next one is queued; however, block layer
must not implicitly call into q->request_fn() directly from completion
path. This makes the queue behave unexpectedly when seen from the
drivers and violates the assumption that q->request_fn() is called
with process context + queue_lock.
This patch makes blk-flush the following two changes to make sure
q->request_fn() is not called directly from request completion path.
- blk_flush_complete_seq_end_io() now asks __blk_run_queue() to always
use kblockd instead of calling directly into q->request_fn().
- queue_next_fseq() uses ELEVATOR_INSERT_REQUEUE instead of
ELEVATOR_INSERT_FRONT so that elv_insert() doesn't try to unplug the
request queue directly.
Reported by Jan in the following threads.
http://thread.gmane.org/gmane.linux.ide/48778
http://thread.gmane.org/gmane.linux.ide/48786
stable: applicable to v2.6.37.
Reported-by: Jan Beulich <JBeulich@novell.com>
commit 1654e7411a1ad4999fe7890ef51d2a2bbb1fcf76 upstream.
__blk_run_queue() automatically either calls q->request_fn() directly
or schedules kblockd depending on whether the function is recursed.
blk-flush implementation needs to be able to explicitly choose
kblockd. Add @force_kblockd.
All the current users are converted to specify %false for the
parameter and this patch doesn't introduce any behavior change.
stable: This is prerequisite for fixing ide oops caused by the new
blk-flush implementation.
Cc: Jan Beulich <JBeulich@novell.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
commit 450adcbe518ab3a3953d8475309525d22de77cba upstream.
o Dominik Klein reported a system hang issue while doing some blkio
throttling testing.
https://lkml.org/lkml/2011/2/24/173
o Some tracing revealed that CFQ was not dispatching any more jobs as
queue unplug was not happening. And queue unplug was not happening
because unplug work was not being called as there was one throttling
work on same cpu which as not finished yet. And throttling work had not
finished as it was tyring to dispatch a bio to CFQ but all the request
descriptors were consume to it was put to sleep.
o So basically it is a cyclic dependecny between CFQ unplug work and
throtl dispatch work. Tejun suggested that use separate workqueue for
such cases.
o This patch uses a separate workqueue for throttle related work and
does not rely on kblockd workqueue anymore.
Reported-by: Dominik Klein <dk@in-telegence.net>
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Acked-by: Tejun Heo <tj@kernel.org>
commit 6927faf30920b8c03dfa007e732642a1f1f20089 upstream.
On a Thinkpad x61s, I noticed some memory corruption when
plugging/unplugging the external VGA connection. The symptoms are that
4 bytes at the beginning of a page get overwritten by zeroes.
The address of the corruption varies when rebooting the machine, but
stays constant while it's running (so it's possible to repeatedly write
some data and then corrupt it again by plugging the cable).
Further investigation revealed that the corrupted address is
(dev_priv->status_page_dmah->busaddr & 0xffffffff), ie. the beginning of
the hardware status page of the i965 graphics card, cut to 32 bits.
So it seems that for some memory access, the hardware uses only 32 bit
addressing. If the hardware status page is located >4GB, this
corrupts unrelated memory.
Signed-off-by: Jan Niehusmann <jan@gondor.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
commit ed199facd070f8e551dc16a2ae1baa01d8d28ed4 upstream.
If management firmware is present and the device is down, the firmware
will assume control of the phy. If a phy access were allowed from the
host, it will collide with firmware phy accesses, resulting in
unpredictable behavior. This patch fixes the problem by disallowing phy
accesses during the problematic condition.
Signed-off-by: Matt Carlson <mcarlson@broadcom.com>
Reviewed-by: Michael Chan <mchan@broadcom.com>
commit 4f919a3bc54da01db829c520ce4b1fabfde1c3f7 upstream.
I previously managed to reproduce a hang while scanning wireless
channels (reproducible with airodump-ng hopping channels); subsequent
lockdep instrumentation revealed a lock ordering issue.
Without knowing the design intent, it looks like the locks should be
taken in reverse order; please comment.
[ INFO: possible circular locking dependency detected ]
2.6.38-rc5-341cd #4
airodump-ng/15445 is trying to acquire lock:
(&rdev->devlist_mtx){+.+.+.}, at: [<ffffffff816b1266>]
cfg80211_wext_siwfreq+0xc6/0x100
but task is already holding lock:
(&wdev->mtx){+.+.+.}, at: [<ffffffff816b125c>] cfg80211_wext_siwfreq+0xbc/0x100
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&wdev->mtx){+.+.+.}:
[<ffffffff810a79d6>] lock_acquire+0xc6/0x280
[<ffffffff816d6bce>] mutex_lock_nested+0x6e/0x4b0
[<ffffffff81696080>] cfg80211_netdev_notifier_call+0x430/0x5f0
[<ffffffff8109351b>] notifier_call_chain+0x8b/0x100
[<ffffffff810935b1>] raw_notifier_call_chain+0x11/0x20
[<ffffffff81576d92>] call_netdevice_notifiers+0x32/0x60
[<ffffffff815771a4>] __dev_notify_flags+0x34/0x80
[<ffffffff81577230>] dev_change_flags+0x40/0x70
[<ffffffff8158587c>] do_setlink+0x1fc/0x8d0
[<ffffffff81586042>] rtnl_setlink+0xf2/0x140
[<ffffffff81586923>] rtnetlink_rcv_msg+0x163/0x270
[<ffffffff8159d741>] netlink_rcv_skb+0xa1/0xd0
[<ffffffff815867b0>] rtnetlink_rcv+0x20/0x30
[<ffffffff8159d39a>] netlink_unicast+0x2ba/0x300
[<ffffffff8159dd57>] netlink_sendmsg+0x267/0x3e0
[<ffffffff8155e364>] sock_sendmsg+0xe4/0x110
[<ffffffff8155f3a3>] sys_sendmsg+0x253/0x3b0
[<ffffffff81003192>] system_call_fastpath+0x16/0x1b
-> #0 (&rdev->devlist_mtx){+.+.+.}:
[<ffffffff810a7222>] __lock_acquire+0x1622/0x1d10
[<ffffffff816b1266>] cfg80211_wext_siwfreq+0xc6/0x100
[<ffffffff816b2fad>] ioctl_standard_call+0x5d/0xd0
[<ffffffff816b3223>] T.808+0x163/0x170
[<ffffffff816b326a>] wext_handle_ioctl+0x3a/0x90
[<ffffffff815798d2>] dev_ioctl+0x6f2/0x830
[<ffffffff8155cf3d>] sock_ioctl+0xfd/0x290
[<ffffffff8117dffd>] do_vfs_ioctl+0x9d/0x590
[<ffffffff8117e53a>] sys_ioctl+0x4a/0x80
2 locks held by airodump-ng/15445:
#0: (rtnl_mutex){+.+.+.}, at: [<ffffffff81586782>] rtnl_lock+0x12/0x20
#1: (&wdev->mtx){+.+.+.}, at: [<ffffffff816b125c>]
stack backtrace:
Pid: 15445, comm: airodump-ng Not tainted 2.6.38-rc5-341cd #4
Call Trace:
[<ffffffff810a3f0a>] ? print_circular_bug+0xfa/0x100
[<ffffffff810a7222>] ? __lock_acquire+0x1622/0x1d10
[<ffffffff810a1f99>] ? trace_hardirqs_off_caller+0x29/0xc0
[<ffffffff810a79d6>] ? lock_acquire+0xc6/0x280
[<ffffffff816b1266>] ? cfg80211_wext_siwfreq+0xc6/0x100
[<ffffffff810a31d7>] ? mark_held_locks+0x67/0x90
[<ffffffff816d6bce>] ? mutex_lock_nested+0x6e/0x4b0
[<ffffffff816b2fad>] ? ioctl_standard_call+0x5d/0xd0
[<ffffffff8157818b>] ? __dev_get_by_name+0x9b/0xc0
[<ffffffff816b2f50>] ? ioctl_standard_call+0x0/0xd0
[<ffffffff816b3223>] ? T.808+0x163/0x170
[<ffffffff8112ddf2>] ? might_fault+0x72/0xd0
[<ffffffff816b326a>] ? wext_handle_ioctl+0x3a/0x90
[<ffffffff8112de3b>] ? might_fault+0xbb/0xd0
[<ffffffff815798d2>] ? dev_ioctl+0x6f2/0x830
[<ffffffff810a1bae>] ? put_lock_stats+0xe/0x40
[<ffffffff810a1c8c>] ? lock_release_holdtime+0xac/0x150
[<ffffffff8155cf3d>] ? sock_ioctl+0xfd/0x290
[<ffffffff8117dffd>] ? do_vfs_ioctl+0x9d/0x590
[<ffffffff8116c8ff>] ? fget_light+0x1df/0x3c0
[<ffffffff8117e53a>] ? sys_ioctl+0x4a/0x80
[<ffffffff81003192>] ? system_call_fastpath+0x16/0x1b
Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
commit 3c323c01b6bd5fd01be21a8f0cdc11e55997aa06 upstream.
As mentioned by W. Trevor King on the devel@linuxdriverproject.org list
on "Thu, 27 Jan 2011 18:52:15 -0500", "Message-ID:
<20110127235214.GA5107@thialfi.dhcp.drexel.edu>", the ni_pcimio module
is missing module metadata, including a license.
This patch adds module metadata to all the NI comedi driver modules. It
also removes a duplicate MODULE_LICENSE("GPL") line from the "mite"
module.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
Cc: W. Trevor King <wking@drexel.edu>
commit 664dc878ed6f0476b875547547a49e06f7a4e73b upstream.
During init, reading the 2 PHY ID registers back-to-back in the default
fast mode could return invalid data (all F's) and in slow mode could
return data to the second read the data from the first read. To resolve
the issue in fast mode, set to slow mode before any PHY accesses; to
resolve the issue in slow mode, put in a delay for every 82579 PHY access.
Since this PHY is currently only paired with the pch2lan MAC and the PHY
type is not known before the first PHY access which can fail this way,
check for this based on MAC-type.
Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
Acked-by: Brandon Philips <bphilips@suse.de>
