commit 926317de33998c112c5510301868ea9aa34097e2 upstream.
This patch addresses a bug where a local EXTENDED_COPY WRITE or READ
backend I/O request would always return SAM_STAT_CHECK_CONDITION,
even if underlying xcopy_pt_cmd->se_cmd generated a different
SCSI status code.
ESX host environments expect to hit SAM_STAT_RESERVATION_CONFLICT
for certain scenarios, and SAM_STAT_CHECK_CONDITION results in
non-retriable status for these cases.
Tested on v4.1.y with ESX v5.5u2+ with local IBLOCK backend copy.
Reported-by: Nixon Vincent <nixon.vincent@calsoftinc.com>
Tested-by: Nixon Vincent <nixon.vincent@calsoftinc.com>
Cc: Nixon Vincent <nixon.vincent@calsoftinc.com>
Tested-by: Dinesh Israni <ddi@datera.io>
Signed-off-by: Dinesh Israni <ddi@datera.io>
Cc: Dinesh Israni <ddi@datera.io>
commit 449a137846c84829a328757cd21fd9ca65c08519 upstream.
This patch addresses a bug where EXTENDED_COPY across multiple LUNs
results in a CHECK_CONDITION when the source + destination are not
located on the same physical node.
ESX Host environments expect sense COPY_ABORTED w/ COPY TARGET DEVICE
NOT REACHABLE to be returned when this occurs, in order to signal
fallback to local copy method.
As described in section 6.3.3 of spc4r22:
"If it is not possible to complete processing of a segment because the
copy manager is unable to establish communications with a copy target
device, because the copy target device does not respond to INQUIRY,
or because the data returned in response to INQUIRY indicates
an unsupported logical unit, then the EXTENDED COPY command shall be
terminated with CHECK CONDITION status, with the sense key set to
COPY ABORTED, and the additional sense code set to COPY TARGET DEVICE
NOT REACHABLE."
Tested on v4.1.y with ESX v5.5u2+ with BlockCopy across multiple nodes.
commit 527268df31e57cf2b6d417198717c6d6afdb1e3e upstream.
This patch fixes a regression in >= v4.1.y code where the original
SCF_ACK_KREF assignment in target_get_sess_cmd() was dropped upstream
in commit 054922bb, but the series for addressing TMR ABORT_TASK +
LUN_RESET with fabric session reinstatement in commit febe562c20 still
depends on this code in transport_cmd_finish_abort().
The regression manifests itself as a se_cmd->cmd_kref +1 leak, where
ABORT_TASK + LUN_RESET can hang indefinately for a specific I_T session
for drivers using SCF_ACK_KREF, resulting in hung kthreads.
This patch has been verified with v4.1.y code.
Reported-by: Vaibhav Tandon <vst@datera.io>
Tested-by: Vaibhav Tandon <vst@datera.io>
Cc: Vaibhav Tandon <vst@datera.io>
commit 843741c5778398ea67055067f4cc65ae6c80ca0e upstream.
When the operation fails we also have to undo the changes
we made to ->xattr_names. Otherwise listxattr() will report
wrong lengths.
Signed-off-by: Richard Weinberger <richard@nod.at>
commit 559cce698eaf4ccecb2213b2519ea3a0413e5155 upstream.
When 'jh->b_transaction == transaction' (asserted by below)
J_ASSERT_JH(jh, (jh->b_transaction == transaction || ...
'journal->j_list_lock' will be incorrectly unlocked, since
the the lock is aquired only at the end of if / else-if
statements (missing the else case).
Signed-off-by: Taesoo Kim <tsgatesv@gmail.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
Fixes: 6e4862a5bb9d12be87e4ea5d9a60836ebed71d28
commit c4704a4fbe834eee4109ca064131d440941f6235 upstream.
The sysfs file /sys/fs/ext4/features/encryption was present on kernels
compiled with CONFIG_EXT4_FS_ENCRYPTION=n. This was misleading because
such kernels do not actually support ext4 encryption. Therefore, only
provide this file on kernels compiled with CONFIG_EXT4_FS_ENCRYPTION=y.
Note: since the ext4 feature files are all hardcoded to have a contents
of "supported", it really is the presence or absence of the file that is
significant, not the contents (and this change reflects that).
commit 4f48aa7a11bfed9502a7c85a5b68cd40ea827f73 upstream.
Accesses of the rtsx sdmmc's parent device, which is the rtsx usb device,
must be done when it's runtime resumed. Currently this isn't case when
changing the led, so let's fix this by adding a pm_runtime_get_sync() and
a pm_runtime_put() around those operations.
Reported-by: Ritesh Raj Sarraf <rrs@researchut.com>
Tested-by: Ritesh Raj Sarraf <rrs@researchut.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit 31cf742f515c275d22843c4c756e048d2b6d716c upstream.
The rtsx_usb_sdmmc driver may bail out in its ->set_ios() callback when no
SD card is inserted. This is wrong, as it could cause the device to remain
runtime resumed when it's unused. Fix this behaviour.
commit 3f2d26643595973e835e8356ea90c7c15cb1b0f1 upstream.
Commit f68381a70bb2 (mmc: block: fix packed command header endianness)
correctly fixed endianness handling of packed_cmd_hdr in
mmc_blk_packed_hdr_wrq_prep.
But now, sparse complains about incorrect types:
drivers/mmc/card/block.c:1613:27: sparse: incorrect type in assignment (different base types)
drivers/mmc/card/block.c:1613:27: expected unsigned int [unsigned] [usertype] <noident>
drivers/mmc/card/block.c:1613:27: got restricted __le32 [usertype] <noident>
So annotate cmd_hdr properly using __le32 to make everyone happy.
Fixes: f68381a70bb2 (mmc: block: fix packed command header endianness)
commit d2cf909cda5f8c5609cb7ed6cda816c3e15528c7 upstream.
If a cxl adapter faults on an invalid address for a kernel context, we
may enter copro_calculate_slb() with a NULL mm pointer (kernel
context) and an effective address which looks like a user
address. Which will cause a crash when dereferencing mm. It is clearly
an AFU bug, but there's no reason to crash either. So return an error,
so that cxl can ack the interrupt with an address error.
Fixes: 73d16a6e0e51 ("powerpc/cell: Move data segment faulting code out of cell platform")
Signed-off-by: Frederic Barrat <fbarrat@linux.vnet.ibm.com>
Acked-by: Ian Munsie <imunsie@au1.ibm.com>
commit 0d7718f666be181fda1ba2d08f137d87c1419347 upstream.
In case __ceph_do_getattr returns an error and the retry_op in
ceph_read_iter is not READ_INLINE, then it's possible to invoke
__free_page on a page which is NULL, this naturally leads to a crash.
This can happen when, for example, a process waiting on a MDS reply
receives sigterm.
Fix this by explicitly checking whether the page is set or not.
Signed-off-by: Nikolay Borisov <kernel@kyup.com>
Reviewed-by: Yan, Zheng <zyan@redhat.com>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
commit 850540351bb1a4fa5f192e5ce55b89928cc57f42 upstream.
Commit f436b2ac90a0 ("arm64: kernel: fix architected PMU registers
unconditional access") made sure we wouldn't access unimplemented
PMU registers, but also left MDCR_EL2 uninitialized in that case,
leading to trap bits being potentially left set.
Make sure we always write something in that register.
Fixes: f436b2ac90a0 ("arm64: kernel: fix architected PMU registers unconditional access")
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
commit 1e6e57d9b34a9075d5f9e2048ea7b09756590d11 upstream.
Writing the outer loop of an LL/SC sequence using do {...} while
constructs potentially allows the compiler to hoist memory accesses
between the STXR and the branch back to the LDXR. On CPUs that do not
guarantee forward progress of LL/SC loops when faced with memory
accesses to the same ERG (up to 2k) between the failed STXR and the
branch back, we may end up livelocking.
This patch avoids this issue in our percpu atomics by rewriting the
outer loop as part of the LL/SC inline assembly block.
Fixes: f97fc810798c ("arm64: percpu: Implement this_cpu operations")
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
Tested-by: Mark Rutland <mark.rutland@arm.com>
commit 9158cb29e7c2f10dd325eb1589f0fe745a271257 upstream.
Accesses to the rtsx usb device, which is the parent of the rtsx memstick
device, must not be done unless it's runtime resumed. This is currently not
the case and it could trigger various errors.
Fix this by properly deal with runtime PM in this regards. This means
making sure the device is runtime resumed, when serving requests via the
->request() callback or changing settings via the ->set_param() callbacks.
Cc: Ritesh Raj Sarraf <rrs@researchut.com>
commit 796aa46adf1d90eab36ae06a42e6d3f10b28a75c upstream.
Therefore when the rtsx_usb_ms driver polls for inserted memstick cards,
let's add pm_runtime_get|put*() to make sure accesses is done when the
rtsx usb device is runtime resumed.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
commit a2ed0b391dd9c3ef1d64c7c3e370f4a5ffcd324a upstream.
When isofs_mount() is called to mount a device read-write, it returns
EACCES even before it checks that the device actually contains an isofs
filesystem. This may confuse mount(8) which then tries to mount all
subsequent filesystem types in read-only mode.
Fix the problem by returning EACCES only once we verify that the device
indeed contains an iso9660 filesystem.
Fixes: 17b7f7cf58926844e1dd40f5eb5348d481deca6a
Reported-by: Kent Overstreet <kent.overstreet@gmail.com>
Reported-by: Karel Zak <kzak@redhat.com>
commit 9224eb77e63f70f16c0b6b7a20ca7d395f3bc077 upstream.
Entry Size in GITS_BASER<n> occupies 5 bits [52:48], but we mask out 8
bits.
Fixes: cc2d3216f53c ("irqchip: GICv3: ITS command queue")
Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com>
commit f045402984404ddc11016358411e445192919047 upstream.
__tlb_flush_asce() should never be used if multiple asce belong to a mm.
As this function changes mm logic determining if local or global tlb
flushes will be neded, we might end up flushing only the gmap asce on all
CPUs and a follow up mm asce flushes will only flush on the local CPU,
although that asce ran on multiple CPUs.
The missing tlb flushes will provoke strange faults in user space and even
low address protections in user space, crashing the kernel.
Fixes: 1b948d6caec4 ("s390/mm,tlb: optimize TLB flushing for zEC12")
Cc: stable@vger.kernel.org # 3.15+
Reported-by: Sascha Silbe <silbe@linux.vnet.ibm.com>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
commit 21f54ddae449f4bdd9f1498124901d67202243d9 upstream.
That just generally kills the machine, and makes debugging only much
harder, since the traces may long be gone.
Debugging by assert() is a disease. Don't do it. If you can continue,
you're much better off doing so with a live machine where you have a
much higher chance that the report actually makes it to the system logs,
rather than result in a machine that is just completely dead.
The only valid situation for BUG_ON() is when continuing is not an
option, because there is massive corruption. But if you are just
verifying that something is true, you warn about your broken assumptions
(preferably just once), and limp on.
Fixes: 22f2ac51b6d6 ("mm: workingset: fix crash in shadow node shrinker caused by replace_page_cache_page()")
Cc: Miklos Szeredi <miklos@szeredi.hu>
Signed-off-by: Michal Hocko <mhocko@suse.com>
commit 3ddf40e8c31964b744ff10abb48c8e36a83ec6e7 upstream.
Commit 22f2ac51b6d6 ("mm: workingset: fix crash in shadow node shrinker
caused by replace_page_cache_page()") switched replace_page_cache() from
raw radix tree operations to page_cache_tree_insert() but didn't take
into account that the latter function, unlike the raw radix tree op,
handles mapping->nrpages. As a result, that counter is bumped for each
page replacement rather than balanced out even.
The mapping->nrpages counter is used to skip needless radix tree walks
when invalidating, truncating, syncing inodes without pages, as well as
statistics for userspace. Since the error is positive, we'll do more
page cache tree walks than necessary; we won't miss a necessary one.
And we'll report more buffer pages to userspace than there are. The
error is limited to fuse inodes.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
commit 22f2ac51b6d643666f4db093f13144f773ff3f3a upstream.
Antonio reports the following crash when using fuse under memory pressure:
kernel BUG at /build/linux-a2WvEb/linux-4.4.0/mm/workingset.c:346!
invalid opcode: 0000 [#1] SMP
Modules linked in: all of them
CPU: 2 PID: 63 Comm: kswapd0 Not tainted 4.4.0-36-generic #55-Ubuntu
Hardware name: System manufacturer System Product Name/P8H67-M PRO, BIOS 3904 04/27/2013
task: ffff88040cae6040 ti: ffff880407488000 task.ti: ffff880407488000
RIP: shadow_lru_isolate+0x181/0x190
Call Trace:
__list_lru_walk_one.isra.3+0x8f/0x130
list_lru_walk_one+0x23/0x30
scan_shadow_nodes+0x34/0x50
shrink_slab.part.40+0x1ed/0x3d0
shrink_zone+0x2ca/0x2e0
kswapd+0x51e/0x990
kthread+0xd8/0xf0
ret_from_fork+0x3f/0x70
which corresponds to the following sanity check in the shadow node
tracking:
BUG_ON(node->count & RADIX_TREE_COUNT_MASK);
The workingset code tracks radix tree nodes that exclusively contain
shadow entries of evicted pages in them, and this (somewhat obscure)
line checks whether there are real pages left that would interfere with
reclaim of the radix tree node under memory pressure.
While discussing ways how fuse might sneak pages into the radix tree
past the workingset code, Miklos pointed to replace_page_cache_page(),
and indeed there is a problem there: it properly accounts for the old
page being removed - __delete_from_page_cache() does that - but then
does a raw raw radix_tree_insert(), not accounting for the replacement
page. Eventually the page count bits in node->count underflow while
leaving the node incorrectly linked to the shadow node LRU.
To address this, make sure replace_page_cache_page() uses the tracked
page insertion code, page_cache_tree_insert(). This fixes the page
accounting and makes sure page-containing nodes are properly unlinked
from the shadow node LRU again.
Also, make the sanity checks a bit less obscure by using the helpers for
checking the number of pages and shadows in a radix tree node.
[mhocko@suse.com: backport for 4.4]
Fixes: 449dd6984d0e ("mm: keep page cache radix tree nodes in check")
Link: http://lkml.kernel.org/r/20160919155822.29498-1-hannes@cmpxchg.org
Reported-by: Antonio SJ Musumeci <trapexit@spawn.link>
Debugged-by: Miklos Szeredi <miklos@szeredi.hu>
commit c09f12186d6b03b798832d95289af76495990192 upstream.
Commit 209851649dc4 "acpi: nfit: Add support for hot-add" added
support for _FIT notifications, but it neglected to verify the
notification event code matches the one in the ACPI spec for
"NFIT Update". Currently there is only one code in the spec, but
once additional codes are added, older kernels (without this fix)
will misbehave by assuming all event notifications are for an
NFIT Update.
Fixes: 209851649dc4 ("acpi: nfit: Add support for hot-add")
Cc: <stable@vger.kernel.org>
Cc: <linux-acpi@vger.kernel.org>
Cc: Dan Williams <dan.j.williams@intel.com>
Reported-by: Linda Knippers <linda.knippers@hpe.com>
Signed-off-by: Vishal Verma <vishal.l.verma@intel.com>
commit 6e5224224faa50ec4c8949dcefadf895e565f0d1 upstream.
The VF administrative mac addresses (stored in the PF driver) are
initialized to zero when the PF driver starts up.
These addresses may be modified in the PF driver through ndo calls
initiated by iproute2 or libvirt.
While we allow the PF/host to change the VF admin mac address from zero
to a valid unicast mac, we do not allow restoring the VF admin mac to
zero. We currently only allow changing this mac to a different unicast mac.
This leads to problems when libvirt scripts are used to deal with
VF mac addresses, and libvirt attempts to revoke the mac so this
host will not use it anymore.
Fix this by allowing resetting a VF administrative MAC back to zero.
Fixes: 8f7ba3ca12f6 ('net/mlx4: Add set VF mac address support')
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Reported-by: Moshe Levi <moshele@mellanox.com>
Signed-off-by: Juerg Haefliger <juerg.haefliger@hpe.com>
commit 1e6bb1a3540fec3ef112b9a89dda88e684c3ff59 upstream.
Not all adapters have FC-NPIV configured. If bnx2fc is used with such an
adapter, driver would read irrelevant data from the the nvram and log
"FC-NPIV table with bad length..." In system logs.
Simply accept that reading '0' as the feature offset in nvram indicates
the feature isn't there and return.
Reported-by: Andrew Patterson <andrew.patterson@hpe.com>
Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com>
commit 7ee7014d0eb6bcac679c0bd5fe9ce65bc4325648 upstream.
Dave Young reported:
> Hi,
> I saw the warning "Missing required AuthAttr" when testing kexec,
> known issue? Idea about how to fix it?
> The kernel is latest linus tree plus sevral patches from Toshi to
> cleanup io resource structure.
> in function pkcs7_sig_note_set_of_authattrs():
> if (!test_bit(sinfo_has_content_type, &sinfo->aa_set) ||
> !test_bit(sinfo_has_message_digest, &sinfo->aa_set) ||
> (ctx->msg->data_type == OID_msIndirectData &&
> !test_bit(sinfo_has_ms_opus_info, &sinfo->aa_set))) {
> pr_warn("Missing required AuthAttr\n");
> return -EBADMSG;
> The third condition below is true:
> I signed the kernel with redhat test key like below:
> pesign -c 'Red Hat Test Certificate' -i arch/x86/boot/bzImage -o /boot/vmlinuz-4.4.0-rc8+ -s --force
And right he is! The Authenticode specification is a paragon amongst
technical documents, and has this pearl of wisdom to offer:
Authenticode-Specific SignerInfo UnauthenticatedAttributes Structures
The following Authenticode-specific data structures are present in
SignerInfo authenticated attributes.
SpcSpOpusInfo
SpcSpOpusInfo is identified by SPC_SP_OPUS_INFO_OBJID
(1.3.6.1.4.1.311.2.1.12) and is defined as follows:
SpcSpOpusInfo ::= SEQUENCE {
programName [0] EXPLICIT SpcString OPTIONAL,
moreInfo [1] EXPLICIT SpcLink OPTIONAL,
} --#public--
SpcSpOpusInfo has two fields:
programName
This field contains the program description:
If publisher chooses not to specify a description, the SpcString
structure contains a zero-length program name.
If the publisher chooses to specify a
description, the SpcString structure contains a Unicode string.
moreInfo
This field is set to an SPCLink structure that contains a URL for
a Web site with more information about the signer. The URL is an
ASCII string.
Which is to say that this is an optional *unauthenticated* field which
may be present in the Authenticated Attribute list. This is not how
pkcs7 is supposed to work, so when David implemented this, he didn't
appreciate the subtlety the original spec author was working with, and
missed the part of the sublime prose that says this Authenticated
Attribute is an Unauthenticated Attribute. As a result, the code in
question simply takes as given that the Authenticated Attributes should
be authenticated.
But this one should not, individually. Because it says it's not
authenticated.
It still has to hash right so the TBS digest is correct. So it is both
authenticated and unauthenticated, all at once. Truly, a wonder of
technical accomplishment.
Additionally, pesign's implementation has always attempted to be
compatible with the signatures emitted from contemporary versions of
Microsoft's signtool.exe. During the initial implementation, Microsoft
signatures always produced the same values for SpcSpOpusInfo -
{U"Microsoft Windows", "http://www.microsoft.com"} - without regard to
who the signer was.
Sometime between Windows 8 and Windows 8.1 they stopped including the
field in their signatures altogether, and as such pesign stopped
producing them in commits c0c4da6 and d79cb0c, sometime around June of
2012. The theory here is that anything that breaks with
pesign signatures would also be breaking with signtool.exe sigs as well,
and that'll be a more noticed problem for firmwares parsing it, so it'll
get fixed. The fact that we've done exactly this bug in Linux code is
first class, grade A irony.
So anyway, we should not be checking this field for presence or any
particular value: if the field exists, it should be at the right place,
but aside from that, as long as the hash matches the field is good.
Signed-off-by: Peter Jones <pjones@redhat.com>
Tested-by: Dave Young <dyoung@redhat.com>
commit 64ce60cab24603ac0fcd59c9fbc3be78f4c4d229 upstream.
The SA controller spins down RAID drive spares.
A REGNEWD event causes an inquiry to be sent to all physical
drives. This causes the SA controller to spin up the spare.
The controller suspends all I/O to a logical volume until
the spare is spun up. The spin-up can take over 50 seconds.
This can result in one or both of the following:
- SML sends down aborts and resets to the logical volume
and can cause the logical volume to be off-lined.
- a negative impact on the logical volume's I/O performance
each time a REGNEWD is triggered.
Reviewed-by: Scott Teel <scott.teel@microsemi.com>
Reviewed-by: Kevin Barnett <kevin.barnett@microsemi.com>
Signed-off-by: Don Brace <don.brace@microsemi.com>
commit 6b7e9cde49691e04314342b7dce90c67ad567fcc upstream.
For historic reasons, io_opt is in bytes and max_sectors in block layer
sectors. This interface inconsistency is error prone and should be
fixed. But for 4.4--4.7 let's make the unit difference explicit via a
wrapper function.
Fixes: d0eb20a863ba ("sd: Optimal I/O size is in bytes, not sectors")
Reported-by: Fam Zheng <famz@redhat.com>
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Tested-by: Andrew Patterson <andrew.patterson@hpe.com>
commit d102eb5c1ac5e6743b1c6d145c06a25d98ad1375 upstream.
The timeout loop terminates when the loop count is zero, but the decrement
of the count variable is post check. So count is -1 when we check for the
timeout and therefor the error message is supressed.
Change it to predecrement, so the error message is emitted.
[ tglx: Massaged changelog ]
Fixes: a2c225101234 ("irqchip: gic-v3: Refactor gic_enable_redist to support both enabling and disabling")
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: kernel-janitors@vger.kernel.org
Cc: Jason Cooper <jason@lakedaemon.net>
Link: http://lkml.kernel.org/r/20161014072534.GA15168@mwanda
commit 8678654e3c7ad7b0f4beb03fa89691279cba71f9 upstream.
gcc 7 warns:
arch/x86/kvm/ioapic.c: In function 'kvm_ioapic_reset':
arch/x86/kvm/ioapic.c:597:2: warning: 'memset' used with length equal to number of elements without multiplication by element size [-Wmemset-elt-size]
And it is right. Memset whole array using sizeof operator.
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: x86@kernel.org
Cc: kvm@vger.kernel.org
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
[Added x86 subject tag]
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit 23446cb66c073b827779e5eb3dec301623299b32 upstream.
Commit:
917db484dc6a ("x86/boot: Fix kdump, cleanup aborted E820_PRAM max_pfn manipulation")
... fixed up the broken manipulations of max_pfn in the presence of
E820_PRAM ranges.
However, it also broke the sanitize_e820_map() support for not merging
E820_PRAM ranges.
Re-introduce the enabling to keep resource boundaries between
consecutive defined ranges. Otherwise, for example, an environment that
boots with memmap=2G!8G,2G!10G will end up with a single 4G /dev/pmem0
device instead of a /dev/pmem0 and /dev/pmem1 device 2G in size.
Reported-by: Dave Chinner <david@fromorbit.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Zhang Yi <yizhan@redhat.com>
Cc: linux-nvdimm@lists.01.org
Fixes: 917db484dc6a ("x86/boot: Fix kdump, cleanup aborted E820_PRAM max_pfn manipulation")
Link: http://lkml.kernel.org/r/147629530854.10618.10383744751594021268.stgit@dwillia2-desk3.amr.corp.intel.com
commit bbb427e342495df1cda10051d0566388697499c0 upstream.
Unlocking a mutex twice is wrong. Hence modify blkcg_policy_register()
such that blkcg_pol_mutex is unlocked once if cpd == NULL. This patch
avoids that smatch reports the following error:
block/blk-cgroup.c:1378: blkcg_policy_register() error: double unlock 'mutex:&blkcg_pol_mutex'
Fixes: 06b285bd1125 ("blkcg: fix blkcg_policy_data allocation bug")
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Cc: Tejun Heo <tj@kernel.org>
commit d171356ff11ab1825e456dfb979755e01b3c54a1 upstream.
Patch a6b5058 results in -EREMOTE returned by is_path_accessible() in
cifs_mount() to be ignored which breaks DFS mounting.
Signed-off-by: Sachin Prabhu <sprabhu@redhat.com>
Reviewed-by: Aurelien Aptel <aaptel@suse.com>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 24df1483c272c99ed88b0cba135d0e1dfdee3930 upstream.
Cleanup some missing mem frees on some cifs ioctls, and
clarify others to make more obvious that no data is returned.
Acked-by: Sachin Prabhu <sprabhu@redhat.com>
commit 18dd8e1a65ddae2351d0f0d6dd4a334f441fc5fa upstream.
[CIFS] We had cases where we sent a SMB2/SMB3 setinfo request with all
timestamp (and DOS attribute) fields marked as 0 (ie do not change)
e.g. on chmod or chown.
Signed-off-by: Steve French <steve.french@primarydata.com>
commit fa70b87cc6641978b20e12cc5d517e9ffc0086d4 upstream.
GUIDs although random, and 16 bytes, need to be generated as
proper uuids.
Reported-by: David Goebels <davidgoe@microsoft.com>
commit c2afb8147e69819885493edf3a7c1ce03aaf2d4e upstream.
Reported-by: David Goebel <davidgoe@microsoft.com>
commit 9742805d6b1bfb45d7f267648c34fb5bcd347397 upstream.
In debugging smb3, it is useful to display the number
of credits available, so we can see when the server has not granted
sufficient operations for the client to make progress, or alternatively
the client has requested too many credits (as we saw in a recent bug)
so we can compare with the number of credits the server thinks
we have.
Add a /proc/fs/cifs/DebugData line to display the client view
on how many credits are available.
Reported-by: Germano Percossi <germano.percossi@citrix.com>
commit 3afca265b5f53a0b15b79531c13858049505582d upstream.
Remove the global file_list_lock to simplify cifs/smb3 locking and
have spinlocks that more closely match the information they are
protecting.
Add new tcon->open_file_lock and file->file_info_lock spinlocks.
Locks continue to follow a heirachy,
cifs_socket --> cifs_ses --> cifs_tcon --> cifs_file
where global tcp_ses_lock still protects socket and cifs_ses, while the
the newer locks protect the lower level structure's information
(tcon and cifs_file respectively).
Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com>
Reviewed-by: Germano Percossi <germano.percossi@citrix.com>
commit 94f873717571c759b7928399cbbddfa3d569bd01 upstream.
When we open a durable handle we give a Globally Unique
Identifier (GUID) to the server which we must keep for later reference
e.g. when reopening persistent handles on reconnection.
Without this the GUID generated for a new persistent handle was lost and
16 zero bytes were used instead on re-opening.
Signed-off-by: Aurelien Aptel <aaptel@suse.com>
commit 7d414f396c91a3382e51cf628c1cf0709ad0188b upstream.
The kernel client requests 2 credits for many operations even though
they only use 1 credit (presumably to build up a buffer of credit).
Some servers seem to give the client as much credit as is requested. In
this case, the amount of credit the client has continues increasing to
the point where (server->credits * MAX_BUFFER_SIZE) overflows in
smb2_wait_mtu_credits().
Fix this by throttling the credit requests if an set limit is reached.
For async requests where the credit charge may be > 1, request as much
credit as what is charged.
The limit is chosen somewhat arbitrarily. The Windows client
defaults to 128 credits, the Windows server allows clients up to
512 credits (or 8192 for Windows 2016), and the NetApp server
(and at least one other) does not limit clients at all.
Choose a high enough value such that the client shouldn't limit
performance.
This behavior was seen with a NetApp filer (NetApp Release 9.0RC2).
Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com>
commit 89f39af129382a40d7cd1f6914617282cfeee28e upstream.
Change thaw_super() to check frozen != SB_FREEZE_COMPLETE rather than
frozen == SB_UNFROZEN, otherwise it can race with freeze_super() which
drops sb->s_umount after SB_FREEZE_WRITE to preserve the lock ordering.
In this case thaw_super() will wrongly call s_op->unfreeze_fs() before
it was actually frozen, and call sb_freeze_unlock() which leads to the
unbalanced percpu_up_write(). Unfortunately lockdep can't detect this,
so this triggers misc BUG_ON()'s in kernel/rcu/sync.c.
Reported-and-tested-by: Nikolay Borisov <kernel@kyup.com>
commit 7798bf2140ebcc36eafec6a4194fffd8d585d471 upstream.
On faulting sigreturn we do get SIGSEGV, all right, but anything
we'd put into pt_regs could end up in the coredump. And since
__copy_from_user() never zeroed on arc, we'd better bugger off
on its failure without copying random uninitialized bits of
kernel stack into pt_regs...
commit a7fd9a4f3e8179bab31e4637236ebb0e0b7867c6 upstream.
null_blk defines an empty version of this ops structure if CONFIG_NVM
isn't set, but it doesn't know the type. Move those bits out of the
protection of CONFIG_NVM in the main lightnvm include.
Signed-off-by: Jens Axboe <axboe@fb.com>
[pebolle: backport to v4.4]
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
commit 5864a2fd3088db73d47942370d0f7210a807b9bc upstream.
Commit 6d07b68ce16a ("ipc/sem.c: optimize sem_lock()") introduced a
race:
sem_lock has a fast path that allows parallel simple operations.
There are two reasons why a simple operation cannot run in parallel:
- a non-simple operations is ongoing (sma->sem_perm.lock held)
- a complex operation is sleeping (sma->complex_count != 0)
As both facts are stored independently, a thread can bypass the current
checks by sleeping in the right positions. See below for more details
(or kernel bugzilla 105651).
The patch fixes that by creating one variable (complex_mode)
that tracks both reasons why parallel operations are not possible.
The patch also updates stale documentation regarding the locking.
With regards to stable kernels:
The patch is required for all kernels that include the
commit 6d07b68ce16a ("ipc/sem.c: optimize sem_lock()") (3.10?)
The alternative is to revert the patch that introduced the race.
The patch is safe for backporting, i.e. it makes no assumptions
about memory barriers in spin_unlock_wait().
Background:
Here is the race of the current implementation:
Thread A: (simple op)
- does the first "sma->complex_count == 0" test
Thread B: (complex op)
- does sem_lock(): This includes an array scan. But the scan can't
find Thread A, because Thread A does not own sem->lock yet.
- the thread does the operation, increases complex_count,
drops sem_lock, sleeps
Thread A:
- spin_lock(&sem->lock), spin_is_locked(sma->sem_perm.lock)
- sleeps before the complex_count test
Thread C: (complex op)
- does sem_lock (no array scan, complex_count==1)
- wakes up Thread B.
- decrements complex_count
Thread A:
- does the complex_count test
Bug:
Now both thread A and thread C operate on the same array, without
any synchronization.
Fixes: 6d07b68ce16a ("ipc/sem.c: optimize sem_lock()")
Link: http://lkml.kernel.org/r/1469123695-5661-1-git-send-email-manfred@colorfullife.com
Reported-by: <felixh@informatik.uni-bremen.de>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: <1vier1@web.de>
commit d3798ae8c6f3767c726403c2ca6ecc317752c9dd upstream.
When the underflow checks were added to workingset_node_shadow_dec(),
they triggered immediately:
kernel BUG at ./include/linux/swap.h:276!
Modules linked in: isofs usb_storage fuse xt_CHECKSUM ipt_MASQUERADE nf_nat_masquerade_ipv4 tun nf_conntrack_netbios_ns nf_conntrack_broadcast ip6t_REJECT nf_reject_ipv6
soundcore wmi acpi_als pinctrl_sunrisepoint kfifo_buf tpm_tis industrialio acpi_pad pinctrl_intel tpm_tis_core tpm nfsd auth_rpcgss nfs_acl lockd grace sunrpc dm_crypt
CPU: 0 PID: 20929 Comm: blkid Not tainted 4.8.0-rc8-00087-gbe67d60ba944 #1
Hardware name: System manufacturer System Product Name/Z170-K, BIOS 1803 05/06/2016
task: ffff8faa93ecd940 task.stack: ffff8faa7f478000
RIP: page_cache_tree_insert+0xf1/0x100
Call Trace:
__add_to_page_cache_locked+0x12e/0x270
add_to_page_cache_lru+0x4e/0xe0
mpage_readpages+0x112/0x1d0
blkdev_readpages+0x1d/0x20
__do_page_cache_readahead+0x1ad/0x290
force_page_cache_readahead+0xaa/0x100
page_cache_sync_readahead+0x3f/0x50
generic_file_read_iter+0x5af/0x740
blkdev_read_iter+0x35/0x40
__vfs_read+0xe1/0x130
vfs_read+0x96/0x130
SyS_read+0x55/0xc0
entry_SYSCALL_64_fastpath+0x13/0x8f
Code: 03 00 48 8b 5d d8 65 48 33 1c 25 28 00 00 00 44 89 e8 75 19 48 83 c4 18 5b 41 5c 41 5d 41 5e 5d c3 0f 0b 41 bd ef ff ff ff eb d7 <0f> 0b e8 88 68 ef ff 0f 1f 84 00
RIP page_cache_tree_insert+0xf1/0x100
This is a long-standing bug in the way shadow entries are accounted in
the radix tree nodes. The shrinker needs to know when radix tree nodes
contain only shadow entries, no pages, so node->count is split in half
to count shadows in the upper bits and pages in the lower bits.
Unfortunately, the radix tree implementation doesn't know of this and
assumes all entries are in node->count. When there is a shadow entry
directly in root->rnode and the tree is later extended, the radix tree
implementation will copy that entry into the new node and and bump its
node->count, i.e. increases the page count bits. Once the shadow gets
removed and we subtract from the upper counter, node->count underflows
and triggers the warning. Afterwards, without node->count reaching 0
again, the radix tree node is leaked.
Limit shadow entries to when we have actual radix tree nodes and can
count them properly. That means we lose the ability to detect refaults
from files that had only the first page faulted in at eviction time.
Reported-and-tested-by: Linus Torvalds <torvalds@linux-foundation.org>
commit 35d04077ad96ed33ceea2501f5a4f1eacda77218 upstream.
The definition of atomic_dec_if_positive() assumes that
atomic_sub_if_positive() exists, which is only the case if
metag specific atomics are used. This results in the following
build error when trying to build metag1_defconfig.
kernel/ucount.c: In function 'dec_ucount':
kernel/ucount.c:211: error:
implicit declaration of function 'atomic_sub_if_positive'
Moving the definition of atomic_dec_if_positive() into the metag
conditional code fixes the problem.
Fixes: 6006c0d8ce94 ("metag: Atomics, locks and bitops")
Signed-off-by: James Hogan <james.hogan@imgtec.com>
commit bcd8f2e94808fcddf6ef3af5f060a36820dcc432 upstream.
This patch fixes one use-after-free report[1] by KASAN.
In __scsi_scan_target(), when a type 31 device is probed,
SCSI_SCAN_TARGET_PRESENT is returned and the target will be scanned
again.
Inside the following scsi_report_lun_scan(), one new scsi_device
instance is allocated, and scsi_probe_and_add_lun() is called again to
probe the target and still see type 31 device, finally
__scsi_remove_device() is called to remove & free the device at the end
of scsi_probe_and_add_lun(), so cause use-after-free in
scsi_report_lun_scan().
And the following SCSI log can be observed:
scsi 0:0:2:0: scsi scan: INQUIRY pass 1 length 36
scsi 0:0:2:0: scsi scan: INQUIRY successful with code 0x0
scsi 0:0:2:0: scsi scan: peripheral device type of 31, no device added
scsi 0:0:2:0: scsi scan: Sending REPORT LUNS to (try 0)
scsi 0:0:2:0: scsi scan: REPORT LUNS successful (try 0) result 0x0
scsi 0:0:2:0: scsi scan: REPORT LUN scan
BUG: KASAN: use-after-free in __scsi_scan_target+0xbf8/0xe40 at addr ffff88007b44a104
This patch fixes the issue by moving the putting reference at
the end of scsi_report_lun_scan().
[1] KASAN report
[ 3.274597] PM: Adding info for serio:serio1
[ 3.275127] BUG: KASAN: use-after-free in __scsi_scan_target+0xd87/0xdf0 at addr ffff880254d8c304
[ 3.275653] Read of size 4 by task kworker/u10:0/27
[ 3.275903] CPU: 3 PID: 27 Comm: kworker/u10:0 Not tainted 4.8.0 #2121
[ 3.276258] Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 3.276797] Workqueue: events_unbound async_run_entry_fn
[ 3.277083] ffff880254d8c380 ffff880259a37870 ffffffff94bbc6c1 ffff880078402d80
[ 3.277532] ffff880254d8bb80 ffff880259a37898 ffffffff9459fec1 ffff880259a37930
[ 3.277989] ffff880254d8bb80 ffff880078402d80 ffff880259a37920 ffffffff945a0165
[ 3.278436] Call Trace:
[ 3.278528] [<ffffffff94bbc6c1>] dump_stack+0x65/0x84
[ 3.278797] [<ffffffff9459fec1>] kasan_object_err+0x21/0x70
[ 3.279063] device: 'psaux': device_add
[ 3.279616] [<ffffffff945a0165>] kasan_report_error+0x205/0x500
[ 3.279651] PM: Adding info for No Bus:psaux
[ 3.280202] [<ffffffff944ecd22>] ? kfree_const+0x22/0x30
[ 3.280486] [<ffffffff94bc2dc9>] ? kobject_release+0x119/0x370
[ 3.280805] [<ffffffff945a0543>] __asan_report_load4_noabort+0x43/0x50
[ 3.281170] [<ffffffff9507e1f7>] ? __scsi_scan_target+0xd87/0xdf0
[ 3.281506] [<ffffffff9507e1f7>] __scsi_scan_target+0xd87/0xdf0
[ 3.281848] [<ffffffff9507d470>] ? scsi_add_device+0x30/0x30
[ 3.282156] [<ffffffff94f7f660>] ? pm_runtime_autosuspend_expiration+0x60/0x60
[ 3.282570] [<ffffffff956ddb07>] ? _raw_spin_lock+0x17/0x40
[ 3.282880] [<ffffffff9507e505>] scsi_scan_channel+0x105/0x160
[ 3.283200] [<ffffffff9507e8a2>] scsi_scan_host_selected+0x212/0x2f0
[ 3.283563] [<ffffffff9507eb3c>] do_scsi_scan_host+0x1bc/0x250
[ 3.283882] [<ffffffff9507efc1>] do_scan_async+0x41/0x450
[ 3.284173] [<ffffffff941c1fee>] async_run_entry_fn+0xfe/0x610
[ 3.284492] [<ffffffff941a8954>] ? pwq_dec_nr_in_flight+0x124/0x2a0
[ 3.284876] [<ffffffff941d1770>] ? preempt_count_add+0x130/0x160
[ 3.285207] [<ffffffff941a9a84>] process_one_work+0x544/0x12d0
[ 3.285526] [<ffffffff941aa8e9>] worker_thread+0xd9/0x12f0
[ 3.285844] [<ffffffff941aa810>] ? process_one_work+0x12d0/0x12d0
[ 3.286182] [<ffffffff941bb365>] kthread+0x1c5/0x260
[ 3.286443] [<ffffffff940855cd>] ? __switch_to+0x88d/0x1430
[ 3.286745] [<ffffffff941bb1a0>] ? kthread_worker_fn+0x5a0/0x5a0
[ 3.287085] [<ffffffff956dde9f>] ret_from_fork+0x1f/0x40
[ 3.287368] [<ffffffff941bb1a0>] ? kthread_worker_fn+0x5a0/0x5a0
[ 3.287697] Object at ffff880254d8bb80, in cache kmalloc-2048 size: 2048
[ 3.288064] Allocated:
[ 3.288147] PID = 27
[ 3.288218] [<ffffffff940b27ab>] save_stack_trace+0x2b/0x50
[ 3.288531] [<ffffffff9459f246>] save_stack+0x46/0xd0
[ 3.288806] [<ffffffff9459f4bd>] kasan_kmalloc+0xad/0xe0
[ 3.289098] [<ffffffff9459c07e>] __kmalloc+0x13e/0x250
[ 3.289378] [<ffffffff95078e5a>] scsi_alloc_sdev+0xea/0xcf0
[ 3.289701] [<ffffffff9507de76>] __scsi_scan_target+0xa06/0xdf0
[ 3.290034] [<ffffffff9507e505>] scsi_scan_channel+0x105/0x160
[ 3.290362] [<ffffffff9507e8a2>] scsi_scan_host_selected+0x212/0x2f0
[ 3.290724] [<ffffffff9507eb3c>] do_scsi_scan_host+0x1bc/0x250
[ 3.291055] [<ffffffff9507efc1>] do_scan_async+0x41/0x450
[ 3.291354] [<ffffffff941c1fee>] async_run_entry_fn+0xfe/0x610
[ 3.291695] [<ffffffff941a9a84>] process_one_work+0x544/0x12d0
[ 3.292022] [<ffffffff941aa8e9>] worker_thread+0xd9/0x12f0
[ 3.292325] [<ffffffff941bb365>] kthread+0x1c5/0x260
[ 3.292594] [<ffffffff956dde9f>] ret_from_fork+0x1f/0x40
[ 3.292886] Freed:
[ 3.292945] PID = 27
[ 3.293016] [<ffffffff940b27ab>] save_stack_trace+0x2b/0x50
[ 3.293327] [<ffffffff9459f246>] save_stack+0x46/0xd0
[ 3.293600] [<ffffffff9459fa61>] kasan_slab_free+0x71/0xb0
[ 3.293916] [<ffffffff9459bac2>] kfree+0xa2/0x1f0
[ 3.294168] [<ffffffff9508158a>] scsi_device_dev_release_usercontext+0x50a/0x730
[ 3.294598] [<ffffffff941ace9a>] execute_in_process_context+0xda/0x130
[ 3.294974] [<ffffffff9508107c>] scsi_device_dev_release+0x1c/0x20
[ 3.295322] [<ffffffff94f566f6>] device_release+0x76/0x1e0
[ 3.295626] [<ffffffff94bc2db7>] kobject_release+0x107/0x370
[ 3.295942] [<ffffffff94bc29ce>] kobject_put+0x4e/0xa0
[ 3.296222] [<ffffffff94f56e17>] put_device+0x17/0x20
[ 3.296497] [<ffffffff9505201c>] scsi_device_put+0x7c/0xa0
[ 3.296801] [<ffffffff9507e1bc>] __scsi_scan_target+0xd4c/0xdf0
[ 3.297132] [<ffffffff9507e505>] scsi_scan_channel+0x105/0x160
[ 3.297458] [<ffffffff9507e8a2>] scsi_scan_host_selected+0x212/0x2f0
[ 3.297829] [<ffffffff9507eb3c>] do_scsi_scan_host+0x1bc/0x250
[ 3.298156] [<ffffffff9507efc1>] do_scan_async+0x41/0x450
[ 3.298453] [<ffffffff941c1fee>] async_run_entry_fn+0xfe/0x610
[ 3.298777] [<ffffffff941a9a84>] process_one_work+0x544/0x12d0
[ 3.299105] [<ffffffff941aa8e9>] worker_thread+0xd9/0x12f0
[ 3.299408] [<ffffffff941bb365>] kthread+0x1c5/0x260
[ 3.299676] [<ffffffff956dde9f>] ret_from_fork+0x1f/0x40
[ 3.299967] Memory state around the buggy address:
[ 3.300209] ffff880254d8c200: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 3.300608] ffff880254d8c280: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 3.300986] >ffff880254d8c300: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 3.301408] ^
[ 3.301550] ffff880254d8c380: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 3.301987] ffff880254d8c400: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 3.302396]
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
commit 3f807e5ae5597bd65a6fff684083e8eaa21f3fa7 upstream.
The caller of rpc_run_task also gets a reference that must be put.
Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
commit 304020fe48c6c7fff8b5a38f382b54404f0f79d3 upstream.
If the file permissions change on the server, then we may not be able to
recover open state. If so, we need to ensure that we mark the file
descriptor appropriately.
Tested-by: Oleg Drokin <green@linuxhacker.ru>
