2013-02-03Linux 3.0.62v3.0.62Greg Kroah-Hartman
2013-02-03x86/Sandy Bridge: Sandy Bridge workaround depends on CONFIG_PCIH. Peter Anvin
commit e43b3cec711a61edf047adf6204d542f3a659ef8 upstream. early_pci_allowed() and read_pci_config_16() are only available if CONFIG_PCI is defined. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com>
2013-02-03efi, x86: Pass a proper identity mapping in efi_call_phys_prelogNathan Zimmer
commit b8f2c21db390273c3eaf0e5308faeaeb1e233840 upstream. Update efi_call_phys_prelog to install an identity mapping of all available memory. This corrects a bug on very large systems with more then 512 GB in which bios would not be able to access addresses above not in the mapping. The result is a crash that looks much like this. BUG: unable to handle kernel paging request at 000000effd870020 IP: [<0000000078bce331>] 0x78bce330 PGD 0 Oops: 0000 [#1] SMP Modules linked in: CPU 0 Pid: 0, comm: swapper/0 Tainted: G W 3.8.0-rc1-next-20121224-medusa_ntz+ #2 Intel Corp. Stoutland Platform RIP: 0010:[<0000000078bce331>] [<0000000078bce331>] 0x78bce330 RSP: 0000:ffffffff81601d28 EFLAGS: 00010006 RAX: 0000000078b80e18 RBX: 0000000000000004 RCX: 0000000000000004 RDX: 0000000078bcf958 RSI: 0000000000002400 RDI: 8000000000000000 RBP: 0000000078bcf760 R08: 000000effd870000 R09: 0000000000000000 R10: 0000000000000000 R11: 00000000000000c3 R12: 0000000000000030 R13: 000000effd870000 R14: 0000000000000000 R15: ffff88effd870000 FS: 0000000000000000(0000) GS:ffff88effe400000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 000000effd870020 CR3: 000000000160c000 CR4: 00000000000006b0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process swapper/0 (pid: 0, threadinfo ffffffff81600000, task ffffffff81614400) Stack: 0000000078b80d18 0000000000000004 0000000078bced7b ffff880078b81fff 0000000000000000 0000000000000082 0000000078bce3a8 0000000000002400 0000000060000202 0000000078b80da0 0000000078bce45d ffffffff8107cb5a Call Trace: [<ffffffff8107cb5a>] ? on_each_cpu+0x77/0x83 [<ffffffff8102f4eb>] ? change_page_attr_set_clr+0x32f/0x3ed [<ffffffff81035946>] ? efi_call4+0x46/0x80 [<ffffffff816c5abb>] ? efi_enter_virtual_mode+0x1f5/0x305 [<ffffffff816aeb24>] ? start_kernel+0x34a/0x3d2 [<ffffffff816ae5ed>] ? repair_env_string+0x60/0x60 [<ffffffff816ae2be>] ? x86_64_start_reservations+0xba/0xc1 [<ffffffff816ae120>] ? early_idt_handlers+0x120/0x120 [<ffffffff816ae419>] ? x86_64_start_kernel+0x154/0x163 Code: Bad RIP value. RIP [<0000000078bce331>] 0x78bce330 RSP <ffffffff81601d28> CR2: 000000effd870020 ---[ end trace ead828934fef5eab ]--- Signed-off-by: Nathan Zimmer <nzimmer@sgi.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03x86/msr: Add capabilities checkAlan Cox
commit c903f0456bc69176912dee6dd25c6a66ee1aed00 upstream. At the moment the MSR driver only relies upon file system checks. This means that anything as root with any capability set can write to MSRs. Historically that wasn't very interesting but on modern processors the MSRs are such that writing to them provides several ways to execute arbitary code in kernel space. Sample code and documentation on doing this is circulating and MSR attacks are used on Windows 64bit rootkits already. In the Linux case you still need to be able to open the device file so the impact is fairly limited and reduces the security of some capability and security model based systems down towards that of a generic "root owns the box" setup. Therefore they should require CAP_SYS_RAWIO to prevent an elevation of capabilities. The impact of this is fairly minimal on most setups because they don't have heavy use of capabilities. Those using SELinux, SMACK or AppArmor rules might want to consider if their rulesets on the MSR driver could be tighter. Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03smp: Fix SMP function call empty cpu mask raceWang YanQing
commit f44310b98ddb7f0d06550d73ed67df5865e3eda5 upstream. I get the following warning every day with v3.7, once or twice a day: [ 2235.186027] WARNING: at /mnt/sda7/kernel/linux/arch/x86/kernel/apic/ipi.c:109 default_send_IPI_mask_logical+0x2f/0xb8() As explained by Linus as well: | | Once we've done the "list_add_rcu()" to add it to the | queue, we can have (another) IPI to the target CPU that can | now see it and clear the mask. | | So by the time we get to actually send the IPI, the mask might | have been cleared by another IPI. | This patch also fixes a system hang problem, if the data->cpumask gets cleared after passing this point: if (WARN_ONCE(!mask, "empty IPI mask")) return; then the problem in commit 83d349f35e1a ("x86: don't send an IPI to the empty set of CPU's") will happen again. Signed-off-by: Wang YanQing <udknight@gmail.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Jan Beulich <jbeulich@suse.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: peterz@infradead.org Cc: mina86@mina86.org Cc: srivatsa.bhat@linux.vnet.ibm.com Link: http://lkml.kernel.org/r/20130126075357.GA3205@udknight [ Tidied up the changelog and the comment in the code. ] Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03Bluetooth: Fix incorrect strncpy() in hidp_setup_hid()Anderson Lizardo
commit 0a9ab9bdb3e891762553f667066190c1d22ad62b upstream. The length parameter should be sizeof(req->name) - 1 because there is no guarantee that string provided by userspace will contain the trailing '\0'. Can be easily reproduced by manually setting req->name to 128 non-zero bytes prior to ioctl(HIDPCONNADD) and checking the device name setup on input subsystem: $ cat /sys/devices/pnp0/00\:04/tty/ttyS0/hci0/hci0\:1/input8/name AAAAAA[...]AAAAAAAAf0:af:f0:af:f0:af ("f0:af:f0:af:f0:af" is the device bluetooth address, taken from "phys" field in struct hid_device due to overflow.) Signed-off-by: Anderson Lizardo <anderson.lizardo@openbossa.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03EDAC: Test correct variable in ->store functionDan Carpenter
commit 8024c4c0b1057d1cd811fc9c3f88f81de9729fcd upstream. We're testing for ->show but calling ->store(). Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03ALSA: usb-audio: fix invalid length check for RME and other UAC 2 devicesClemens Ladisch
commit d56268fb108c7c21e19933588ca4d94652585183 upstream. Commit 23caaf19b11e (ALSA: usb-mixer: Add support for Audio Class v2.0) forgot to adjust the length check for UAC 2.0 feature unit descriptors. This would make the code abort on encountering a feature unit without per-channel controls, and thus prevented the driver to work with any device having such a unit, such as the RME Babyface or Fireface UCX. Reported-by: Florian Hanisch <fhanisch@uni-potsdam.de> Tested-by: Matthew Robbetts <wingfeathera@gmail.com> Tested-by: Michael Beer <beerml@sigma6audio.de> Cc: Daniel Mack <daniel@caiaq.de> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03ath9k: fix double-free bug on beacon generate failureFelix Fietkau
commit 1adb2e2b5f85023d17eb4f95386a57029df27c88 upstream. When the next beacon is sent, the ath_buf from the previous run is reused. If getting a new beacon from mac80211 fails, bf->bf_mpdu is not reset, yet the skb is freed, leading to a double-free on the next beacon tx attempt, resulting in a system crash. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03ath9k_htc: Fix memory leakSujith Manoharan
commit 0981c3b24ef664f5611008a6e6d0622fac6d892b upstream. SKBs that are allocated in the HTC layer do not have callbacks registered and hence ended up not being freed, Fix this by freeing them properly in the TX completion routine. Reported-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Sujith Manoharan <c_manoha@qca.qualcomm.com> Tested-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03Bluetooth: Fix sending HCI commands after resetSzymon Janc
commit dbccd791a3fbbdac12c33834b73beff3984988e9 upstream. After sending reset command wait for its command complete event before sending next command. Some chips sends CC event for command received before reset if reset was send before chip replied with CC. This is also required by specification that host shall not send additional HCI commands before receiving CC for reset. < HCI Command: Reset (0x03|0x0003) plen 0 [hci0] 18.404612 > HCI Event: Command Complete (0x0e) plen 4 [hci0] 18.405850 Write Extended Inquiry Response (0x03|0x0052) ncmd 1 Status: Success (0x00) < HCI Command: Read Local Supported Features (0x04|0x0003) plen 0 [hci0] 18.406079 > HCI Event: Command Complete (0x0e) plen 4 [hci0] 18.407864 Reset (0x03|0x0003) ncmd 1 Status: Success (0x00) < HCI Command: Read Local Supported Features (0x04|0x0003) plen 0 [hci0] 18.408062 > HCI Event: Command Complete (0x0e) plen 12 [hci0] 18.408835 Signed-off-by: Szymon Janc <szymon.janc@tieto.com> Acked-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03ARM: DMA: Fix struct page iterator in dma_cache_maint() to work with sparsememRussell King
commit 15653371c67c3fbe359ae37b720639dd4c7b42c5 upstream. Subhash Jadavani reported this partial backtrace: Now consider this call stack from MMC block driver (this is on the ARMv7 based board): [<c001b50c>] (v7_dma_inv_range+0x30/0x48) from [<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c) [<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c) from [<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c) [<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c) from [<c0017ff8>] (dma_map_sg+0x3c/0x114) This is caused by incrementing the struct page pointer, and running off the end of the sparsemem page array. Fix this by incrementing by pfn instead, and convert the pfn to a struct page. Suggested-by: James Bottomley <JBottomley@Parallels.com> Tested-by: Subhash Jadavani <subhashj@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03fs/cifs/cifs_dfs_ref.c: fix potential memory leakageCong Ding
commit 10b8c7dff5d3633b69e77f57d404dab54ead3787 upstream. When it goes to error through line 144, the memory allocated to *devname is not freed, and the caller doesn't free it either in line 250. So we free the memroy of *devname in function cifs_compose_mount_options() when it goes to error. Signed-off-by: Cong Ding <dinggnu@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03can: pch_can: fix invalid error codesOlivier Sobrie
commit ee50e135aeb048b90fab662e661c58b67341830b upstream. Errors in CAN protocol (location) are reported in data[3] of the can frame instead of data[2]. Signed-off-by: Olivier Sobrie <olivier@sobrie.be> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03can: ti_hecc: fix invalid error codesOlivier Sobrie
commit 71088c4bd9b8f8cbffb0e66f2abc14297e4b2ca8 upstream. Errors in CAN protocol (location) are reported in data[3] of the can frame instead of data[2]. Signed-off-by: Olivier Sobrie <olivier@sobrie.be> Cc: Anant Gole <anantgole@ti.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03can: c_can: fix invalid error codesOlivier Sobrie
commit 6ea45886865c1abb01bb861f7f6bdd5d0f398cb3 upstream. Errors in CAN protocol (location) are reported in data[3] of the can frame instead of data[2]. Signed-off-by: Olivier Sobrie <olivier@sobrie.be> Cc: Bhupesh Sharma <bhupesh.sharma@st.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27Linux 3.0.61v3.0.61Greg Kroah-Hartman
2013-01-27ioat: Fix DMA memory sync direction correct flagShuah Khan
commit ac4989874af56435c308bdde9ad9c837a26f8b23 upstream. ioat does DMA memory sync with DMA_TO_DEVICE direction on a buffer allocated for DMA_FROM_DEVICE dma, resulting in the following warning from dma debug. Fixed the dma_sync_single_for_device() call to use the correct direction. [ 226.288947] WARNING: at lib/dma-debug.c:990 check_sync+0x132/0x550() [ 226.288948] Hardware name: ProLiant DL380p Gen8 [ 226.288951] ioatdma 0000:00:04.0: DMA-API: device driver syncs DMA memory with different direction [device address=0x00000000ffff7000] [size=4096 bytes] [mapped with DMA_FROM_DEVICE] [synced with DMA_TO_DEVICE] [ 226.288953] Modules linked in: iTCO_wdt(+) sb_edac(+) ioatdma(+) microcode serio_raw pcspkr edac_core hpwdt(+) iTCO_vendor_support hpilo(+) dca acpi_power_meter ata_generic pata_acpi sd_mod crc_t10dif ata_piix libata hpsa tg3 netxen_nic(+) sunrpc dm_mirror dm_region_hash dm_log dm_mod [ 226.288967] Pid: 1055, comm: work_for_cpu Tainted: G W 3.3.0-0.20.el7.x86_64 #1 [ 226.288968] Call Trace: [ 226.288974] [<ffffffff810644cf>] warn_slowpath_common+0x7f/0xc0 [ 226.288977] [<ffffffff810645c6>] warn_slowpath_fmt+0x46/0x50 [ 226.288980] [<ffffffff81345502>] check_sync+0x132/0x550 [ 226.288983] [<ffffffff81345c9f>] debug_dma_sync_single_for_device+0x3f/0x50 [ 226.288988] [<ffffffff81661002>] ? wait_for_common+0x72/0x180 [ 226.288995] [<ffffffffa019590f>] ioat_xor_val_self_test+0x3e5/0x832 [ioatdma] [ 226.288999] [<ffffffff811a5739>] ? kfree+0x259/0x270 [ 226.289004] [<ffffffffa0195d77>] ioat3_dma_self_test+0x1b/0x20 [ioatdma] [ 226.289008] [<ffffffffa01952c3>] ioat_probe+0x2f8/0x348 [ioatdma] [ 226.289011] [<ffffffffa0195f51>] ioat3_dma_probe+0x1d5/0x2aa [ioatdma] [ 226.289016] [<ffffffffa0194d12>] ioat_pci_probe+0x139/0x17c [ioatdma] [ 226.289020] [<ffffffff81354b8c>] local_pci_probe+0x5c/0xd0 [ 226.289023] [<ffffffff81083e50>] ? destroy_work_on_stack+0x20/0x20 [ 226.289025] [<ffffffff81083e68>] do_work_for_cpu+0x18/0x30 [ 226.289029] [<ffffffff8108d997>] kthread+0xb7/0xc0 [ 226.289033] [<ffffffff8166cef4>] kernel_thread_helper+0x4/0x10 [ 226.289036] [<ffffffff81662d20>] ? _raw_spin_unlock_irq+0x30/0x50 [ 226.289038] [<ffffffff81663234>] ? retint_restore_args+0x13/0x13 [ 226.289041] [<ffffffff8108d8e0>] ? kthread_worker_fn+0x1a0/0x1a0 [ 226.289044] [<ffffffff8166cef0>] ? gs_change+0x13/0x13 [ 226.289045] ---[ end trace e1618afc7a606089 ]--- [ 226.289047] Mapped at: [ 226.289048] [<ffffffff81345307>] debug_dma_map_page+0x87/0x150 [ 226.289050] [<ffffffffa019653c>] dma_map_page.constprop.18+0x70/0xb34 [ioatdma] [ 226.289054] [<ffffffffa0195702>] ioat_xor_val_self_test+0x1d8/0x832 [ioatdma] [ 226.289058] [<ffffffffa0195d77>] ioat3_dma_self_test+0x1b/0x20 [ioatdma] [ 226.289061] [<ffffffffa01952c3>] ioat_probe+0x2f8/0x348 [ioatdma] Signed-off-by: Shuah Khan <shuah.khan@hp.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27ACPI / cpuidle: Fix NULL pointer issues when cpuidle is disabledKonrad Rzeszutek Wilk
commit b88a634a903d9670aa5f2f785aa890628ce0dece upstream. If cpuidle is disabled, that means that: per_cpu(acpi_cpuidle_device, pr->id) is set to NULL as the acpi_processor_power_init ends up failing at retval = cpuidle_register_driver(&acpi_idle_driver) (in acpi_processor_power_init) and never sets the per_cpu idle device. So when acpi_processor_hotplug on CPU online notification tries to reference said device it crashes: cpu 3 spinlock event irq 62 BUG: unable to handle kernel NULL pointer dereference at 0000000000000004 IP: [<ffffffff81381013>] acpi_processor_setup_cpuidle_cx+0x3f/0x105 PGD a259b067 PUD ab38b067 PMD 0 Oops: 0002 [#1] SMP odules linked in: dm_multipath dm_mod xen_evtchn iscsi_boot_sysfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi libcrc32c crc32c nouveau mxm_wmi wmi radeon ttm sg sr_mod sd_mod cdrom ata_generic ata_piix libata crc32c_intel scsi_mod atl1c i915 fbcon tileblit font bitblit softcursor drm_kms_helper video xen_blkfront xen_netfront fb_sys_fops sysimgblt sysfillrect syscopyarea xenfs xen_privcmd mperf CPU 1 Pid: 3047, comm: bash Not tainted 3.8.0-rc3upstream-00250-g165c029 #1 MSI MS-7680/H61M-P23 (MS-7680) RIP: e030:[<ffffffff81381013>] [<ffffffff81381013>] acpi_processor_setup_cpuidle_cx+0x3f/0x105 RSP: e02b:ffff88001742dca8 EFLAGS: 00010202 RAX: 0000000000010be9 RBX: ffff8800a0a61800 RCX: ffff880105380000 RDX: 0000000000000003 RSI: 0000000000000200 RDI: ffff8800a0a61800 RBP: ffff88001742dce8 R08: ffffffff81812360 R09: 0000000000000200 R10: aaaaaaaaaaaaaaaa R11: 0000000000000001 R12: ffff8800a0a61800 R13: 00000000ffffff01 R14: 0000000000000000 R15: ffffffff81a907a0 FS: 00007fd6942f7700(0000) GS:ffff880105280000(0000) knlGS:0000000000000000 CS: e033 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000004 CR3: 00000000a6773000 CR4: 0000000000042660 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process bash (pid: 3047, threadinfo ffff88001742c000, task ffff880017944000) Stack: 0000000000000150 ffff880100f59e00 ffff88001742dcd8 ffff8800a0a61800 0000000000000000 00000000ffffff01 0000000000000000 ffffffff81a907a0 ffff88001742dd18 ffffffff813815b1 ffff88001742dd08 ffffffff810ae336 Call Trace: [<ffffffff813815b1>] acpi_processor_hotplug+0x7c/0x9f [<ffffffff810ae336>] ? schedule_delayed_work_on+0x16/0x20 [<ffffffff8137ee8f>] acpi_cpu_soft_notify+0x90/0xca [<ffffffff8166023d>] notifier_call_chain+0x4d/0x70 [<ffffffff810bc369>] __raw_notifier_call_chain+0x9/0x10 [<ffffffff81094a4b>] __cpu_notify+0x1b/0x30 [<ffffffff81652cf7>] _cpu_up+0x103/0x14b [<ffffffff81652e18>] cpu_up+0xd9/0xec [<ffffffff8164a254>] store_online+0x94/0xd0 [<ffffffff814122fb>] dev_attr_store+0x1b/0x20 [<ffffffff81216404>] sysfs_write_file+0xf4/0x170 This patch fixes it. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27SGI-XP: handle non-fatal trapsRobin Holt
commit 891348ca0f66206f1dc0e30d63757e3df1ae2d15 upstream. We found a user code which was raising a divide-by-zero trap. That trap would lead to XPC connections between system-partitions being torn down due to the die_chain notifier callouts it received. This also revealed a different issue where multiple callers into xpc_die_deactivate() would all attempt to do the disconnect in parallel which would sometimes lock up but often overwhelm the console on very large machines as each would print at least one line of output at the end of the deactivate. I reviewed all the users of the die_chain notifier and changed the code to ignore the notifier callouts for reasons which will not actually lead to a system to continue on to call die(). [akpm@linux-foundation.org: fix ia64] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27x86: Use enum instead of literals for trap values [PARTIAL]Kees Cook
[Based on commit c94082656dac74257f63e91f78d5d458ac781fa5 upstream, only taking the traps.h portion.] The traps are referred to by their numbers and it can be difficult to understand them while reading the code without context. This patch adds enumeration of the trap numbers and replaces the numbers with the correct enum for x86. Signed-off-by: Kees Cook <keescook@chromium.org> Link: http://lkml.kernel.org/r/20120310000710.GA32667@www.outflux.net Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27ahci: Add identifiers for ASM106x devicesAlan Cox
commit 7b4f6ecacb14f384adc1a5a67ad95eb082c02bd1 upstream. They don't always appear as AHCI class devices but instead as IDE class. Based on an initial patch by Hiroaki Nito Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=42804 Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27drm/i915: Implement WaDisableHiZPlanesWhenMSAAEnabledDaniel Vetter
commit 4283908ef7f11a72c3b80dd4cf026f1a86429f82 upstream. Quoting from Bspec, 3D_CHICKEN1, bit 10 This bit needs to be set always to "1", Project: DevSNB " Reviewed-by: Rodrigo Vivi <rodrigo.vivi@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27staging: usbip: changed function return type to voidBart Westgeest
commit ac2b41acfa3efe4650102067a99251587a806d70 upstream. The function usbip_pad_iso never returns anything but 0 (success). Signed-off-by: Bart Westgeest <bart@elbrys.com> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27serial: 8250, increase PASS_LIMITJiri Slaby
commit e7328ae1848966181a7ac47e8ae6cddbd2cf55f3 upstream. With virtual machines like qemu, it's pretty common to see "too much work for irq4" messages nowadays. This happens when a bunch of output is printed on the emulated serial console. This is caused by too low PASS_LIMIT. When ISR loops more than the limit, it spits the message. I've been using a kernel with doubled the limit and I couldn't see no problems. Maybe it's time to get rid of the message now? Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Ram Gupta <ram.gupta5@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27drivers/firmware/dmi_scan.c: fetch dmi version from SMBIOS if it existsZhenzhong Duan
commit 9f9c9cbb60576a1518d0bf93fb8e499cffccf377 upstream. The right dmi version is in SMBIOS if it's zero in DMI region This issue was originally found from an oracle bug. One customer noticed system UUID doesn't match between dmidecode & uek2. - HP ProLiant BL460c G6 : # cat /sys/devices/virtual/dmi/id/product_uuid 00000000-0000-4C48-3031-4D5030333531 # dmidecode | grep -i uuid UUID: 00000000-0000-484C-3031-4D5030333531 From SMBIOS 2.6 on, spec use little-endian encoding for UUID other than network byte order. So we need to get dmi version to distinguish. If version is 0.0, the real version is taken from the SMBIOS version. This is part of original kernel comment in code. [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Zhenzhong Duan <zhenzhong.duan@oracle.com> Cc: Feng Jin <joe.jin@oracle.com> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27drivers/firmware/dmi_scan.c: check dmi version when get system uuidZhenzhong Duan
commit f1d8e614d74b09531b9a85e812485340f3df7b1c upstream. As of version 2.6 of the SMBIOS specification, the first 3 fields of the UUID are supposed to be little-endian encoded. Also a minor fix to match variable meaning and mute checkpatch.pl [akpm@linux-foundation.org: tweak code comment] Signed-off-by: Zhenzhong Duan <zhenzhong.duan@oracle.com> Cc: Feng Jin <joe.jin@oracle.com> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27SCSI: sd: Reshuffle init_sd to avoid crashJoel D. Diaz
commit afd5e34b2bb34881d3a789e62486814a49b47faa upstream. scsi_register_driver will register a prep_fn() function, which in turn migh need to use the sd_cdp_pool for DIF. Which hasn't been initialised at this point, leading to a crash. So reshuffle the init_sd() and exit_sd() paths to have the driver registered last. Signed-off-by: Joel D. Diaz <joeldiaz@us.ibm.com> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Cc: CAI Qian <caiqian@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27USB: UHCI: fix IRQ race during initializationAlan Stern
commit 0f815a0a700bc10547449bde6c106051a035a1b9 upstream. This patch (as1644) fixes a race that occurs during startup in uhci-hcd. If the IRQ line is shared with other devices, it's possible for the handler routine to be called before the data structures are fully initialized. The problem is fixed by adding a check to the IRQ handler routine. If the initialization hasn't finished yet, the routine will return immediately. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Don Zickus <dzickus@redhat.com> Tested-by: "Huang, Adrian (ISS Linux TW)" <adrian.huang@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27PCI: Allow pcie_aspm=force even when FADT indicates it is unsupportedColin Ian King
commit 9e16721498b0c3d3ebfa0b503c63d35c0a4c0642 upstream. Right now using pcie_aspm=force will not enable ASPM if the FADT indicates ASPM is unsupported. However, the semantics of force should probably allow for this, especially as they did before 3c076351c4 ("PCI: Rework ASPM disable code") This patch just skips the clearing of any ASPM setup that the firmware has carried out on this bus if pcie_aspm=force is being used. Reference: http://bugs.launchpad.net/bugs/962038 Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27ftrace: Be first to run code modification on modulesSteven Rostedt
commit c1bf08ac26e92122faab9f6c32ea8aba94612dae upstream. If some other kernel subsystem has a module notifier, and adds a kprobe to a ftrace mcount point (now that kprobes work on ftrace points), when the ftrace notifier runs it will fail and disable ftrace, as well as kprobes that are attached to ftrace points. Here's the error: WARNING: at kernel/trace/ftrace.c:1618 ftrace_bug+0x239/0x280() Hardware name: Bochs Modules linked in: fat(+) stap_56d28a51b3fe546293ca0700b10bcb29__8059(F) nfsv4 auth_rpcgss nfs dns_resolver fscache xt_nat iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack lockd sunrpc ppdev parport_pc parport microcode virtio_net i2c_piix4 drm_kms_helper ttm drm i2c_core [last unloaded: bid_shared] Pid: 8068, comm: modprobe Tainted: GF 3.7.0-0.rc8.git0.1.fc19.x86_64 #1 Call Trace: [<ffffffff8105e70f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff81134106>] ? __probe_kernel_read+0x46/0x70 [<ffffffffa0180000>] ? 0xffffffffa017ffff [<ffffffffa0180000>] ? 0xffffffffa017ffff [<ffffffff8105e76a>] warn_slowpath_null+0x1a/0x20 [<ffffffff810fd189>] ftrace_bug+0x239/0x280 [<ffffffff810fd626>] ftrace_process_locs+0x376/0x520 [<ffffffff810fefb7>] ftrace_module_notify+0x47/0x50 [<ffffffff8163912d>] notifier_call_chain+0x4d/0x70 [<ffffffff810882f8>] __blocking_notifier_call_chain+0x58/0x80 [<ffffffff81088336>] blocking_notifier_call_chain+0x16/0x20 [<ffffffff810c2a23>] sys_init_module+0x73/0x220 [<ffffffff8163d719>] system_call_fastpath+0x16/0x1b ---[ end trace 9ef46351e53bbf80 ]--- ftrace failed to modify [<ffffffffa0180000>] init_once+0x0/0x20 [fat] actual: cc:bb:d2:4b:e1 A kprobe was added to the init_once() function in the fat module on load. But this happened before ftrace could have touched the code. As ftrace didn't run yet, the kprobe system had no idea it was a ftrace point and simply added a breakpoint to the code (0xcc in the cc:bb:d2:4b:e1). Then when ftrace went to modify the location from a call to mcount/fentry into a nop, it didn't see a call op, but instead it saw the breakpoint op and not knowing what to do with it, ftrace shut itself down. The solution is to simply give the ftrace module notifier the max priority. This should have been done regardless, as the core code ftrace modification also happens very early on in boot up. This makes the module modification closer to core modification. Link: http://lkml.kernel.org/r/20130107140333.593683061@goodmis.org Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Reported-by: Frank Ch. Eigler <fche@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-01-27drm/i915: Invalidate the relocation presumed_offsets along the slow pathChris Wilson
commit 262b6d363fcff16359c93bd58c297f961f6e6273 upstream. In the slow path, we are forced to copy the relocations prior to acquiring the struct mutex in order to handle pagefaults. We forgo copying the new offsets back into the relocation entries in order to prevent a recursive locking bug should we trigger a pagefault whilst holding the mutex for the reservations of the execbuffer. Therefore, we need to reset the presumed_offsets just in case the objects are rebound back into their old locations after relocating for this exexbuffer - if that were to happen we would assume the relocations were valid and leave the actual pointers to the kernels dangling, instant hang. Fixes regression from commit bcf50e2775bbc3101932d8e4ab8c7902aa4163b4 Author: Chris Wilson <chris@chris-wilson.co.uk> Date: Sun Nov 21 22:07:12 2010 +0000 drm/i915: Handle pagefaults in execbuffer user relocations Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=55984 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Daniel Vetter <daniel.vetter@fwll.ch> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-01-21Linux 3.0.60v3.0.60Greg Kroah-Hartman
2013-01-21staging: vt6656: Fix inconsistent structure packingBen Hutchings
commit 1ee4c55fc9620451b2a825d793042a7e0775391b upstream. vt6656 has several headers that use the #pragma pack(1) directive to enable structure packing, but never disable it. The layout of structures defined in other headers can then depend on which order the various headers are included in, breaking the One Definition Rule. In practice this resulted in crashes on x86_64 until the order of header inclusion was changed for some files in commit 11d404cb56ecd ('staging: vt6656: fix headers and add cfg80211.'). But we need a proper fix that won't be affected by future changes to the order of inclusion. This removes the #pragma pack(1) directives and adds __packed to the structure definitions for which packing appears to have been intended. Reported-and-tested-by: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21serial:ifx6x60:Delete SPI timer when shut down portchao bi
commit 014b9b4ce84281ccb3d723c792bed19815f3571a upstream. When shut down SPI port, it's possible that MRDY has been asserted and a SPI timer was activated waiting for SRDY assert, in the case, it needs to delete this timer. Signed-off-by: Chen Jun <jun.d.chen@intel.com> Signed-off-by: channing <chao.bi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21USB: option: blacklist network interface on ONDA MT8205 4G LTEBjørn Mork
Signed-off-by: Bjørn Mork <bjorn@mork.no> commit 2291dff02e5f8c708a46a7c4c888f2c467e26642 upstream. The driver description files gives these names to the vendor specific functions on this modem: Diag VID_19D2&PID_0265&MI_00 NMEA VID_19D2&PID_0265&MI_01 AT cmd VID_19D2&PID_0265&MI_02 Modem VID_19D2&PID_0265&MI_03 Net VID_19D2&PID_0265&MI_04 Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21USB: option: add TP-LINK HSUPA Modem MA180Bjørn Mork
commit 99beb2e9687ffd61c92a9875141eabe6f57a71b9 upstream. The driver description files gives these names to the vendor specific functions on this modem: Diagnostics VID_2357&PID_0201&MI_00 NMEA VID_2357&PID_0201&MI_01 Modem VID_2357&PID_0201&MI_03 Networkcard VID_2357&PID_0201&MI_04 Reported-by: Thomas Schäfer <tschaefer@t-online.de> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21xen: Fix stack corruption in xen_failsafe_callback for 32bit PVOPS guests.Frediano Ziglio
commit 9174adbee4a9a49d0139f5d71969852b36720809 upstream. This fixes CVE-2013-0190 / XSA-40 There has been an error on the xen_failsafe_callback path for failed iret, which causes the stack pointer to be wrong when entering the iret_exc error path. This can result in the kernel crashing. In the classic kernel case, the relevant code looked a little like: popl %eax # Error code from hypervisor jz 5f addl $16,%esp jmp iret_exc # Hypervisor said iret fault 5: addl $16,%esp # Hypervisor said segment selector fault Here, there are two identical addls on either option of a branch which appears to have been optimised by hoisting it above the jz, and converting it to an lea, which leaves the flags register unaffected. In the PVOPS case, the code looks like: popl_cfi %eax # Error from the hypervisor lea 16(%esp),%esp # Add $16 before choosing fault path CFI_ADJUST_CFA_OFFSET -16 jz 5f addl $16,%esp # Incorrectly adjust %esp again jmp iret_exc It is possible unprivileged userspace applications to cause this behaviour, for example by loading an LDT code selector, then changing the code selector to be not-present. At this point, there is a race condition where it is possible for the hypervisor to return back to userspace from an interrupt, fault on its own iret, and inject a failsafe_callback into the kernel. This bug has been present since the introduction of Xen PVOPS support in commit 5ead97c84 (xen: Core Xen implementation), in 2.6.23. Signed-off-by: Frediano Ziglio <frediano.ziglio@citrix.com> Signed-off-by: Andrew Cooper <andrew.cooper3@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21xhci: fix null-pointer dereference when destroying half-built segment ringsJulius Werner
commit 68e5254adb88bede68285f11fb442a4d34fb550c upstream. xhci_alloc_segments_for_ring() builds a list of xhci_segments and links the tail to head at the end (forming a ring). When it bails out for OOM reasons half-way through, it tries to destroy its half-built list with xhci_free_segments_for_ring(), even though it is not a ring yet. This causes a null-pointer dereference upon hitting the last element. Furthermore, one of its callers (xhci_ring_alloc()) mistakenly believes the output parameters to be valid upon this kind of OOM failure, and calls xhci_ring_free() on them. Since the (incomplete) list/ring should already be destroyed in that case, this would lead to a use after free. This patch fixes those issues by having xhci_alloc_segments_for_ring() destroy its half-built, non-circular list manually and destroying the invalid struct xhci_ring in xhci_ring_alloc() with a plain kfree(). This patch should be backported to kernels as old as 2.6.31, that contains the commit 0ebbab37422315a5d0cb29792271085bafdf38c0 "USB: xhci: Ring allocation and initialization." A separate patch will need to be developed for kernels older than 3.4, since the ring allocation code was refactored in that kernel. Signed-off-by: Julius Werner <jwerner@chromium.org> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Julius Werner <jwerner@chromium.org> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> [bwh: Backported to 3.2: - Adjust context - Since segment allocation is done directly in xhci_ring_alloc(), walk the list starting from ring->first_seg when freeing] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: CAI Qian <caiqian@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21drbd: add missing part_round_stats to _drbd_start_io_acctPhilipp Reisner
commit 72585d2428fa3a0daab02ebad1f41e5ef517dbaa upstream. Without this, iostat frequently sees bogus svctime and >= 100% "utilization". Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com> Cc: Raoul Bhatia <raoul@bhatia.at> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21intel-iommu: Prevent devices with RMRRs from being placed into SI DomainTom Mingarelli
commit ea2447f700cab264019b52e2b417d689e052dcfd upstream. This patch is to prevent non-USB devices that have RMRRs associated with them from being placed into the SI Domain during init. This fixes the issue where the RMRR info for devices being placed in and out of the SI Domain gets lost. Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Tested-by: Shuah Khan <shuah.khan@hp.com> Reviewed-by: Donald Dutile <ddutile@redhat.com> Reviewed-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Joerg Roedel <joro@8bytes.org> Signed-off-by: CAI Qian <caiqian@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21USB: fix endpoint-disabling for failed config changesAlan Stern
commit 36caff5d795429c572443894e8789c2150dd796b upstream. This patch (as1631) fixes a bug that shows up when a config change fails for a device under an xHCI controller. The controller needs to be told to disable the endpoints that have been enabled for the new config. The existing code does this, but before storing the information about which endpoints were enabled! As a result, any second attempt to install the new config is doomed to fail because xhci-hcd will refuse to enable an endpoint that is already enabled. The patch optimistically initializes the new endpoints' device structures before asking the device to switch to the new config. If the request fails then the endpoint information is already stored, so we can use usb_hcd_alloc_bandwidth() to disable the endpoints with no trouble. The rest of the error path is slightly more complex now; we have to disable the new interfaces and call put_device() rather than simply deallocating them. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-and-tested-by: Matthias Schniedermeyer <ms@citd.de> CC: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: CAI Qian <caiqian@redhat.com>
2013-01-21powerpc: fix wii_memory_fixups() compile error on 3.0.y treeShuah Khan
[not upstream as the code involved was removed in the 3.3.0 release] Fix wii_memory_fixups() the following compile error on 3.0.y tree with wii_defconfig on 3.0.y tree. CC arch/powerpc/platforms/embedded6xx/wii.o arch/powerpc/platforms/embedded6xx/wii.c: In function ‘wii_memory_fixups’: arch/powerpc/platforms/embedded6xx/wii.c:88:2: error: format ‘%llx’ expects argument of type ‘long long unsigned int’, but argument 2 has type ‘phys_addr_t’ [-Werror=format] arch/powerpc/platforms/embedded6xx/wii.c:88:2: error: format ‘%llx’ expects argument of type ‘long long unsigned int’, but argument 3 has type ‘phys_addr_t’ [-Werror=format] arch/powerpc/platforms/embedded6xx/wii.c:90:2: error: format ‘%llx’ expects argument of type ‘long long unsigned int’, but argument 2 has type ‘phys_addr_t’ [-Werror=format] arch/powerpc/platforms/embedded6xx/wii.c:90:2: error: format ‘%llx’ expects argument of type ‘long long unsigned int’, but argument 3 has type ‘phys_addr_t’ [-Werror=format] cc1: all warnings being treated as errors make[2]: *** [arch/powerpc/platforms/embedded6xx/wii.o] Error 1 make[1]: *** [arch/powerpc/platforms/embedded6xx] Error 2 make: *** [arch/powerpc/platforms] Error 2 Signed-off-by: Shuah Khan <shuah.khan@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21ext4: init pagevec in ext4_da_block_invalidatepagesEric Sandeen
commit 66bea92c69477a75a5d37b9bfed5773c92a3c4b4 upstream. ext4_da_block_invalidatepages is missing a pagevec_init(), which means that pvec->cold contains random garbage. This affects whether the page goes to the front or back of the LRU when ->cold makes it to free_hot_cold_page() Reviewed-by: Lukas Czerner <lczerner@redhat.com> Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com> Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: CAI Qian <caiqian@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21x86/Sandy Bridge: reserve pages when integrated graphics is presentJesse Barnes
commit a9acc5365dbda29f7be2884efb63771dc24bd815 upstream. SNB graphics devices have a bug that prevent them from accessing certain memory ranges, namely anything below 1M and in the pages listed in the table. So reserve those at boot if set detect a SNB gfx device on the CPU to avoid GPU hangs. Stephane Marchesin had a similar patch to the page allocator awhile back, but rather than reserving pages up front, it leaked them at allocation time. [ hpa: made a number of stylistic changes, marked arrays as static const, and made less verbose; use "memblock=debug" for full verbosity. ] Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: CAI Qian <caiqian@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21s390/time: fix sched_clock() overflowHeiko Carstens
commit ed4f20943cd4c7b55105c04daedf8d63ab6d499c upstream. Converting a 64 Bit TOD format value to nanoseconds means that the value must be divided by 4.096. In order to achieve that we multiply with 125 and divide by 512. When used within sched_clock() this triggers an overflow after appr. 417 days. Resulting in a sched_clock() return value that is much smaller than previously and therefore may cause all sort of weird things in subsystems that rely on a monotonic sched_clock() behaviour. To fix this implement a tod_to_ns() helper function which converts TOD values without overflow and call this function from both places that open coded the conversion: sched_clock() and kvm_s390_handle_wait(). Reviewed-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21tcm_fc: Do not report target role when target is not definedMark Rustad
commit edec8dfefa1f372b2dd8197da555352e76a10c03 upstream. Clear the target role when no target is provided for the node performing a PRLI. Signed-off-by: Mark Rustad <mark.d.rustad@intel.com> Reviewed-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Acked by Robert Love <robert.w.love@intel.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21tcm_fc: Do not indicate retry capability to initiatorsMark Rustad
commit f2eeba214bcd0215b7f558cab6420e5fd153042b upstream. When generating a PRLI response to an initiator, clear the FCP_SPPF_RETRY bit in the response. Signed-off-by: Mark Rustad <mark.d.rustad@intel.com> Reviewed-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Acked by Robert Love <robert.w.love@intel.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21sh: Fix FDPIC binary loaderThomas Schwinge
commit 4a71997a3279a339e7336ea5d0cd27282e2dea44 upstream. Ensure that the aux table is properly initialized, even when optional features are missing. Without this, the FDPIC loader did not work. This was meant to be included in commit d5ab780305bb6d60a7b5a74f18cf84eb6ad153b1. Signed-off-by: Thomas Schwinge <thomas@codesourcery.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17Linux 3.0.59v3.0.59Greg Kroah-Hartman
