2013-02-11Linux 3.0.63v3.0.63Greg Kroah-Hartman
2013-02-11USB: XHCI: fix memory leak of URB-private dataAlan Stern
commit 48c3375c5f69b1c2ef3d1051a0009cb9bce0ce24 upstream. This patch (as1640) fixes a memory leak in xhci-hcd. The urb_priv data structure isn't always deallocated in the handle_tx_event() routine for non-control transfers. The patch adds a kfree() call so that all paths end up freeing the memory properly. This patch should be backported to kernels as old as 2.6.36, that contain the commit 8e51adccd4c4b9ffcd509d7f2afce0a906139f75 "USB: xHCI: Introduce urb_priv structure" Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Reported-and-tested-by: Martin Mokrejs <mmokrejs@fold.natur.cuni.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11xhci: Fix isoc TD encoding.Sarah Sharp
commit 760973d2a74b93eb1697981f7448f0e62767cfc4 upstream. An isochronous TD is comprised of one isochronous TRB chained to zero or more normal TRBs. Only the isoc TRB has the TBC and TLBPC fields. The normal TRBs must set those fields to zeroes. The code was setting the TBC and TLBPC fields for both isoc and normal TRBs. Fix this. This should be backported to stable kernels as old as 3.0, that contain the commit b61d378f2da41c748aba6ca19d77e1e1c02bcea5 " xhci 1.0: Set transfer burst last packet count field." Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: storage: optimize to match the Huawei USB storage devices and support ↵fangxiaozhi
new switch command commit 200e0d994d9d1919b28c87f1a5fb99a8e13b8a0f upstream. 1. Optimize the match rules with new macro for Huawei USB storage devices, to avoid to load USB storage driver for the modem interface with Huawei devices. 2. Add to support new switch command for new Huawei USB dongles. Signed-off-by: fangxiaozhi <huananhu@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: storage: Define a new macro for USB storage match rulesfangxiaozhi
commit 07c7be3d87e5cdaf5f94c271c516456364ef286c upstream. 1. Define a new macro for USB storage match rules: matching with Vendor ID and interface descriptors. Signed-off-by: fangxiaozhi <huananhu@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: EHCI: fix bug in scheduling periodic split transfersAlan Stern
commit 3e619d04159be54b3daa0b7036b0ce9e067f4b5d upstream. This patch (as1654) fixes a very old bug in ehci-hcd, connected with scheduling of periodic split transfers. The calculations for full/low-speed bus usage are all carried out after the correction for bit-stuffing has been applied, but the values in the max_tt_usecs array assume it hasn't been. The array should allow for allocation of up to 90% of the bus capacity, which is 900 us, not 780 us. The symptom caused by this bug is that any isochronous transfer to a full-speed device with a maxpacket size larger than about 980 bytes is always rejected with a -ENOSPC error. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: qcserial: add Telit Gobi QDL deviceDaniele Palmas
commit 78796ae17eacedcdcaaeb03ba73d2e532a4c8f83 upstream. Add VID and PID for Telit Gobi QDL device Signed-off-by: Daniele Palmas <dnlplm@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: option: add Changhong CH690Bjørn Mork
commit d4fa681541aa7bf8570d03426dd7ba663a71c467 upstream. New device with 3 serial interfaces: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend) Sub=ff Prot=ff If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend) Sub=ff Prot=ff If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend) Sub=ff Prot=ff If#= 3 Alt= 0 #EPs= 2 Cls=08(stor) Sub=06 Prot=50 Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: option: add support for Telit LE920Daniele Palmas
commit 03eb466f276ceef9dcf023dc5474db02af68aad9 upstream. Add PID and special handling for Telit LE920 Signed-off-by: Daniele Palmas <dnlplm@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: ftdi_sio: add PID/VID entries for ELV WS 300 PC IISven Killig
commit c249f911406efcc7456cb4af79396726bf7b8c57 upstream. Add PID/VID entries for ELV WS 300 PC II weather station Signed-off-by: Sven Killig <sven@killig.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: ftdi_sio: add Zolix FTDI PIDPetr Kubánek
commit 0ba3b2ccc72b3df5c305d61f59d93ab0f0e87991 upstream. Add support for Zolix Omni 1509 monochromator custom USB-RS232 converter. Signed-off-by: Petr Kubánek <petr@kubanek.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11drivers/rtc/rtc-isl1208.c: call rtc_update_irq() from the alarm irq handlerJan Luebbe
commit 72fca4a4b32dc778b5b885c3498700e42b610d49 upstream. Previously the alarm event was not propagated into the RTC subsystem. By adding a call to rtc_update_irq, this fixes a timeout problem with the hwclock utility. Signed-off-by: Jan Luebbe <jlu@pengutronix.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11nilfs2: fix fix very long mount time issueVyacheslav Dubeyko
commit a9bae189542e71f91e61a4428adf6e5a7dfe8063 upstream. There exists a situation when GC can work in background alone without any other filesystem activity during significant time. The nilfs_clean_segments() method calls nilfs_segctor_construct() that updates superblocks in the case of NILFS_SC_SUPER_ROOT and THE_NILFS_DISCONTINUED flags are set. But when GC is working alone the nilfs_clean_segments() is called with unset THE_NILFS_DISCONTINUED flag. As a result, the update of superblocks doesn't occurred all this time and in the case of SPOR superblocks keep very old values of last super root placement. SYMPTOMS: Trying to mount a NILFS2 volume after SPOR in such environment ends with very long mounting time (it can achieve about several hours in some cases). REPRODUCING PATH: 1. It needs to use external USB HDD, disable automount and doesn't make any additional filesystem activity on the NILFS2 volume. 2. Generate temporary file with size about 100 - 500 GB (for example, dd if=/dev/zero of=<file_name> bs=1073741824 count=200). The size of file defines duration of GC working. 3. Then it needs to delete file. 4. Start GC manually by means of command "nilfs-clean -p 0". When you start GC by means of such way then, at the end, superblocks is updated by once. So, for simulation of SPOR, it needs to wait sometime (15 - 40 minutes) and simply switch off USB HDD manually. 5. Switch on USB HDD again and try to mount NILFS2 volume. As a result, NILFS2 volume will mount during very long time. REPRODUCIBILITY: 100% FIX: This patch adds checking that superblocks need to update and set THE_NILFS_DISCONTINUED flag before nilfs_clean_segments() call. Reported-by: Sergey Alexandrov <splavgm@gmail.com> Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Tested-by: Vyacheslav Dubeyko <slava@dubeyko.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11x86-64: Replace left over sti/cli in ia32 audit exit codeJan Beulich
commit 40a1ef95da85843696fc3ebe5fce39b0db32669f upstream. For some reason they didn't get replaced so far by their paravirt equivalents, resulting in code to be run with interrupts disabled that doesn't expect so (causing, in the observed case, a BUG_ON() to trigger) when syscall auditing is enabled. David (Cc-ed) came up with an identical fix, so likely this can be taken to count as an ack from him. Reported-by: Peter Moody <pmoody@google.com> Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Link: http://lkml.kernel.org/r/5108E01902000078000BA9C5@nat28.tlf.novell.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: David Vrabel <david.vrabel@citrix.com> Tested-by: Peter Moody <pmoody@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11drm/radeon: Calling object_unrefer() when creating fb failureliu chuansheng
commit f2d68cf4daa4de97d400d94836b907e35228e54f upstream. When kzalloc() failed in radeon_user_framebuffer_create(), need to call object_unreference() to match the object_reference(). Signed-off-by: liu chuansheng <chuansheng.liu@intel.com> Signed-off-by: xueminsu <xuemin.su@intel.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11drm/radeon: add quirk for RV100 boardAlex Deucher
commit 9200ee4941a6e5d1ec5df88982243686882dff3f upstream. vbios says external TMDS while the board is actually internal TMDS. fixes: https://bugs.freedesktop.org/show_bug.cgi?id=60037 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11drm/radeon/evergreen+: wait for the MC to settle after MC blackoutAlex Deucher
commit ed39fadd6df01095378e499fac3674883f16b853 upstream. Some chips seem to need a little delay after blacking out the MC before the requests actually stop. May fix: https://bugs.freedesktop.org/show_bug.cgi?id=56139 https://bugs.freedesktop.org/show_bug.cgi?id=57567 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03Linux 3.0.62v3.0.62Greg Kroah-Hartman
2013-02-03x86/Sandy Bridge: Sandy Bridge workaround depends on CONFIG_PCIH. Peter Anvin
commit e43b3cec711a61edf047adf6204d542f3a659ef8 upstream. early_pci_allowed() and read_pci_config_16() are only available if CONFIG_PCI is defined. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com>
2013-02-03efi, x86: Pass a proper identity mapping in efi_call_phys_prelogNathan Zimmer
commit b8f2c21db390273c3eaf0e5308faeaeb1e233840 upstream. Update efi_call_phys_prelog to install an identity mapping of all available memory. This corrects a bug on very large systems with more then 512 GB in which bios would not be able to access addresses above not in the mapping. The result is a crash that looks much like this. BUG: unable to handle kernel paging request at 000000effd870020 IP: [<0000000078bce331>] 0x78bce330 PGD 0 Oops: 0000 [#1] SMP Modules linked in: CPU 0 Pid: 0, comm: swapper/0 Tainted: G W 3.8.0-rc1-next-20121224-medusa_ntz+ #2 Intel Corp. Stoutland Platform RIP: 0010:[<0000000078bce331>] [<0000000078bce331>] 0x78bce330 RSP: 0000:ffffffff81601d28 EFLAGS: 00010006 RAX: 0000000078b80e18 RBX: 0000000000000004 RCX: 0000000000000004 RDX: 0000000078bcf958 RSI: 0000000000002400 RDI: 8000000000000000 RBP: 0000000078bcf760 R08: 000000effd870000 R09: 0000000000000000 R10: 0000000000000000 R11: 00000000000000c3 R12: 0000000000000030 R13: 000000effd870000 R14: 0000000000000000 R15: ffff88effd870000 FS: 0000000000000000(0000) GS:ffff88effe400000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 000000effd870020 CR3: 000000000160c000 CR4: 00000000000006b0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process swapper/0 (pid: 0, threadinfo ffffffff81600000, task ffffffff81614400) Stack: 0000000078b80d18 0000000000000004 0000000078bced7b ffff880078b81fff 0000000000000000 0000000000000082 0000000078bce3a8 0000000000002400 0000000060000202 0000000078b80da0 0000000078bce45d ffffffff8107cb5a Call Trace: [<ffffffff8107cb5a>] ? on_each_cpu+0x77/0x83 [<ffffffff8102f4eb>] ? change_page_attr_set_clr+0x32f/0x3ed [<ffffffff81035946>] ? efi_call4+0x46/0x80 [<ffffffff816c5abb>] ? efi_enter_virtual_mode+0x1f5/0x305 [<ffffffff816aeb24>] ? start_kernel+0x34a/0x3d2 [<ffffffff816ae5ed>] ? repair_env_string+0x60/0x60 [<ffffffff816ae2be>] ? x86_64_start_reservations+0xba/0xc1 [<ffffffff816ae120>] ? early_idt_handlers+0x120/0x120 [<ffffffff816ae419>] ? x86_64_start_kernel+0x154/0x163 Code: Bad RIP value. RIP [<0000000078bce331>] 0x78bce330 RSP <ffffffff81601d28> CR2: 000000effd870020 ---[ end trace ead828934fef5eab ]--- Signed-off-by: Nathan Zimmer <nzimmer@sgi.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03x86/msr: Add capabilities checkAlan Cox
commit c903f0456bc69176912dee6dd25c6a66ee1aed00 upstream. At the moment the MSR driver only relies upon file system checks. This means that anything as root with any capability set can write to MSRs. Historically that wasn't very interesting but on modern processors the MSRs are such that writing to them provides several ways to execute arbitary code in kernel space. Sample code and documentation on doing this is circulating and MSR attacks are used on Windows 64bit rootkits already. In the Linux case you still need to be able to open the device file so the impact is fairly limited and reduces the security of some capability and security model based systems down towards that of a generic "root owns the box" setup. Therefore they should require CAP_SYS_RAWIO to prevent an elevation of capabilities. The impact of this is fairly minimal on most setups because they don't have heavy use of capabilities. Those using SELinux, SMACK or AppArmor rules might want to consider if their rulesets on the MSR driver could be tighter. Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03smp: Fix SMP function call empty cpu mask raceWang YanQing
commit f44310b98ddb7f0d06550d73ed67df5865e3eda5 upstream. I get the following warning every day with v3.7, once or twice a day: [ 2235.186027] WARNING: at /mnt/sda7/kernel/linux/arch/x86/kernel/apic/ipi.c:109 default_send_IPI_mask_logical+0x2f/0xb8() As explained by Linus as well: | | Once we've done the "list_add_rcu()" to add it to the | queue, we can have (another) IPI to the target CPU that can | now see it and clear the mask. | | So by the time we get to actually send the IPI, the mask might | have been cleared by another IPI. | This patch also fixes a system hang problem, if the data->cpumask gets cleared after passing this point: if (WARN_ONCE(!mask, "empty IPI mask")) return; then the problem in commit 83d349f35e1a ("x86: don't send an IPI to the empty set of CPU's") will happen again. Signed-off-by: Wang YanQing <udknight@gmail.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Jan Beulich <jbeulich@suse.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: peterz@infradead.org Cc: mina86@mina86.org Cc: srivatsa.bhat@linux.vnet.ibm.com Link: http://lkml.kernel.org/r/20130126075357.GA3205@udknight [ Tidied up the changelog and the comment in the code. ] Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03Bluetooth: Fix incorrect strncpy() in hidp_setup_hid()Anderson Lizardo
commit 0a9ab9bdb3e891762553f667066190c1d22ad62b upstream. The length parameter should be sizeof(req->name) - 1 because there is no guarantee that string provided by userspace will contain the trailing '\0'. Can be easily reproduced by manually setting req->name to 128 non-zero bytes prior to ioctl(HIDPCONNADD) and checking the device name setup on input subsystem: $ cat /sys/devices/pnp0/00\:04/tty/ttyS0/hci0/hci0\:1/input8/name AAAAAA[...]AAAAAAAAf0:af:f0:af:f0:af ("f0:af:f0:af:f0:af" is the device bluetooth address, taken from "phys" field in struct hid_device due to overflow.) Signed-off-by: Anderson Lizardo <anderson.lizardo@openbossa.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03EDAC: Test correct variable in ->store functionDan Carpenter
commit 8024c4c0b1057d1cd811fc9c3f88f81de9729fcd upstream. We're testing for ->show but calling ->store(). Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03ALSA: usb-audio: fix invalid length check for RME and other UAC 2 devicesClemens Ladisch
commit d56268fb108c7c21e19933588ca4d94652585183 upstream. Commit 23caaf19b11e (ALSA: usb-mixer: Add support for Audio Class v2.0) forgot to adjust the length check for UAC 2.0 feature unit descriptors. This would make the code abort on encountering a feature unit without per-channel controls, and thus prevented the driver to work with any device having such a unit, such as the RME Babyface or Fireface UCX. Reported-by: Florian Hanisch <fhanisch@uni-potsdam.de> Tested-by: Matthew Robbetts <wingfeathera@gmail.com> Tested-by: Michael Beer <beerml@sigma6audio.de> Cc: Daniel Mack <daniel@caiaq.de> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03ath9k: fix double-free bug on beacon generate failureFelix Fietkau
commit 1adb2e2b5f85023d17eb4f95386a57029df27c88 upstream. When the next beacon is sent, the ath_buf from the previous run is reused. If getting a new beacon from mac80211 fails, bf->bf_mpdu is not reset, yet the skb is freed, leading to a double-free on the next beacon tx attempt, resulting in a system crash. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03ath9k_htc: Fix memory leakSujith Manoharan
commit 0981c3b24ef664f5611008a6e6d0622fac6d892b upstream. SKBs that are allocated in the HTC layer do not have callbacks registered and hence ended up not being freed, Fix this by freeing them properly in the TX completion routine. Reported-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Sujith Manoharan <c_manoha@qca.qualcomm.com> Tested-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03Bluetooth: Fix sending HCI commands after resetSzymon Janc
commit dbccd791a3fbbdac12c33834b73beff3984988e9 upstream. After sending reset command wait for its command complete event before sending next command. Some chips sends CC event for command received before reset if reset was send before chip replied with CC. This is also required by specification that host shall not send additional HCI commands before receiving CC for reset. < HCI Command: Reset (0x03|0x0003) plen 0 [hci0] 18.404612 > HCI Event: Command Complete (0x0e) plen 4 [hci0] 18.405850 Write Extended Inquiry Response (0x03|0x0052) ncmd 1 Status: Success (0x00) < HCI Command: Read Local Supported Features (0x04|0x0003) plen 0 [hci0] 18.406079 > HCI Event: Command Complete (0x0e) plen 4 [hci0] 18.407864 Reset (0x03|0x0003) ncmd 1 Status: Success (0x00) < HCI Command: Read Local Supported Features (0x04|0x0003) plen 0 [hci0] 18.408062 > HCI Event: Command Complete (0x0e) plen 12 [hci0] 18.408835 Signed-off-by: Szymon Janc <szymon.janc@tieto.com> Acked-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03ARM: DMA: Fix struct page iterator in dma_cache_maint() to work with sparsememRussell King
commit 15653371c67c3fbe359ae37b720639dd4c7b42c5 upstream. Subhash Jadavani reported this partial backtrace: Now consider this call stack from MMC block driver (this is on the ARMv7 based board): [<c001b50c>] (v7_dma_inv_range+0x30/0x48) from [<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c) [<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c) from [<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c) [<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c) from [<c0017ff8>] (dma_map_sg+0x3c/0x114) This is caused by incrementing the struct page pointer, and running off the end of the sparsemem page array. Fix this by incrementing by pfn instead, and convert the pfn to a struct page. Suggested-by: James Bottomley <JBottomley@Parallels.com> Tested-by: Subhash Jadavani <subhashj@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03fs/cifs/cifs_dfs_ref.c: fix potential memory leakageCong Ding
commit 10b8c7dff5d3633b69e77f57d404dab54ead3787 upstream. When it goes to error through line 144, the memory allocated to *devname is not freed, and the caller doesn't free it either in line 250. So we free the memroy of *devname in function cifs_compose_mount_options() when it goes to error. Signed-off-by: Cong Ding <dinggnu@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03can: pch_can: fix invalid error codesOlivier Sobrie
commit ee50e135aeb048b90fab662e661c58b67341830b upstream. Errors in CAN protocol (location) are reported in data[3] of the can frame instead of data[2]. Signed-off-by: Olivier Sobrie <olivier@sobrie.be> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03can: ti_hecc: fix invalid error codesOlivier Sobrie
commit 71088c4bd9b8f8cbffb0e66f2abc14297e4b2ca8 upstream. Errors in CAN protocol (location) are reported in data[3] of the can frame instead of data[2]. Signed-off-by: Olivier Sobrie <olivier@sobrie.be> Cc: Anant Gole <anantgole@ti.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03can: c_can: fix invalid error codesOlivier Sobrie
commit 6ea45886865c1abb01bb861f7f6bdd5d0f398cb3 upstream. Errors in CAN protocol (location) are reported in data[3] of the can frame instead of data[2]. Signed-off-by: Olivier Sobrie <olivier@sobrie.be> Cc: Bhupesh Sharma <bhupesh.sharma@st.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27Linux 3.0.61v3.0.61Greg Kroah-Hartman
2013-01-27ioat: Fix DMA memory sync direction correct flagShuah Khan
commit ac4989874af56435c308bdde9ad9c837a26f8b23 upstream. ioat does DMA memory sync with DMA_TO_DEVICE direction on a buffer allocated for DMA_FROM_DEVICE dma, resulting in the following warning from dma debug. Fixed the dma_sync_single_for_device() call to use the correct direction. [ 226.288947] WARNING: at lib/dma-debug.c:990 check_sync+0x132/0x550() [ 226.288948] Hardware name: ProLiant DL380p Gen8 [ 226.288951] ioatdma 0000:00:04.0: DMA-API: device driver syncs DMA memory with different direction [device address=0x00000000ffff7000] [size=4096 bytes] [mapped with DMA_FROM_DEVICE] [synced with DMA_TO_DEVICE] [ 226.288953] Modules linked in: iTCO_wdt(+) sb_edac(+) ioatdma(+) microcode serio_raw pcspkr edac_core hpwdt(+) iTCO_vendor_support hpilo(+) dca acpi_power_meter ata_generic pata_acpi sd_mod crc_t10dif ata_piix libata hpsa tg3 netxen_nic(+) sunrpc dm_mirror dm_region_hash dm_log dm_mod [ 226.288967] Pid: 1055, comm: work_for_cpu Tainted: G W 3.3.0-0.20.el7.x86_64 #1 [ 226.288968] Call Trace: [ 226.288974] [<ffffffff810644cf>] warn_slowpath_common+0x7f/0xc0 [ 226.288977] [<ffffffff810645c6>] warn_slowpath_fmt+0x46/0x50 [ 226.288980] [<ffffffff81345502>] check_sync+0x132/0x550 [ 226.288983] [<ffffffff81345c9f>] debug_dma_sync_single_for_device+0x3f/0x50 [ 226.288988] [<ffffffff81661002>] ? wait_for_common+0x72/0x180 [ 226.288995] [<ffffffffa019590f>] ioat_xor_val_self_test+0x3e5/0x832 [ioatdma] [ 226.288999] [<ffffffff811a5739>] ? kfree+0x259/0x270 [ 226.289004] [<ffffffffa0195d77>] ioat3_dma_self_test+0x1b/0x20 [ioatdma] [ 226.289008] [<ffffffffa01952c3>] ioat_probe+0x2f8/0x348 [ioatdma] [ 226.289011] [<ffffffffa0195f51>] ioat3_dma_probe+0x1d5/0x2aa [ioatdma] [ 226.289016] [<ffffffffa0194d12>] ioat_pci_probe+0x139/0x17c [ioatdma] [ 226.289020] [<ffffffff81354b8c>] local_pci_probe+0x5c/0xd0 [ 226.289023] [<ffffffff81083e50>] ? destroy_work_on_stack+0x20/0x20 [ 226.289025] [<ffffffff81083e68>] do_work_for_cpu+0x18/0x30 [ 226.289029] [<ffffffff8108d997>] kthread+0xb7/0xc0 [ 226.289033] [<ffffffff8166cef4>] kernel_thread_helper+0x4/0x10 [ 226.289036] [<ffffffff81662d20>] ? _raw_spin_unlock_irq+0x30/0x50 [ 226.289038] [<ffffffff81663234>] ? retint_restore_args+0x13/0x13 [ 226.289041] [<ffffffff8108d8e0>] ? kthread_worker_fn+0x1a0/0x1a0 [ 226.289044] [<ffffffff8166cef0>] ? gs_change+0x13/0x13 [ 226.289045] ---[ end trace e1618afc7a606089 ]--- [ 226.289047] Mapped at: [ 226.289048] [<ffffffff81345307>] debug_dma_map_page+0x87/0x150 [ 226.289050] [<ffffffffa019653c>] dma_map_page.constprop.18+0x70/0xb34 [ioatdma] [ 226.289054] [<ffffffffa0195702>] ioat_xor_val_self_test+0x1d8/0x832 [ioatdma] [ 226.289058] [<ffffffffa0195d77>] ioat3_dma_self_test+0x1b/0x20 [ioatdma] [ 226.289061] [<ffffffffa01952c3>] ioat_probe+0x2f8/0x348 [ioatdma] Signed-off-by: Shuah Khan <shuah.khan@hp.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27ACPI / cpuidle: Fix NULL pointer issues when cpuidle is disabledKonrad Rzeszutek Wilk
commit b88a634a903d9670aa5f2f785aa890628ce0dece upstream. If cpuidle is disabled, that means that: per_cpu(acpi_cpuidle_device, pr->id) is set to NULL as the acpi_processor_power_init ends up failing at retval = cpuidle_register_driver(&acpi_idle_driver) (in acpi_processor_power_init) and never sets the per_cpu idle device. So when acpi_processor_hotplug on CPU online notification tries to reference said device it crashes: cpu 3 spinlock event irq 62 BUG: unable to handle kernel NULL pointer dereference at 0000000000000004 IP: [<ffffffff81381013>] acpi_processor_setup_cpuidle_cx+0x3f/0x105 PGD a259b067 PUD ab38b067 PMD 0 Oops: 0002 [#1] SMP odules linked in: dm_multipath dm_mod xen_evtchn iscsi_boot_sysfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi libcrc32c crc32c nouveau mxm_wmi wmi radeon ttm sg sr_mod sd_mod cdrom ata_generic ata_piix libata crc32c_intel scsi_mod atl1c i915 fbcon tileblit font bitblit softcursor drm_kms_helper video xen_blkfront xen_netfront fb_sys_fops sysimgblt sysfillrect syscopyarea xenfs xen_privcmd mperf CPU 1 Pid: 3047, comm: bash Not tainted 3.8.0-rc3upstream-00250-g165c029 #1 MSI MS-7680/H61M-P23 (MS-7680) RIP: e030:[<ffffffff81381013>] [<ffffffff81381013>] acpi_processor_setup_cpuidle_cx+0x3f/0x105 RSP: e02b:ffff88001742dca8 EFLAGS: 00010202 RAX: 0000000000010be9 RBX: ffff8800a0a61800 RCX: ffff880105380000 RDX: 0000000000000003 RSI: 0000000000000200 RDI: ffff8800a0a61800 RBP: ffff88001742dce8 R08: ffffffff81812360 R09: 0000000000000200 R10: aaaaaaaaaaaaaaaa R11: 0000000000000001 R12: ffff8800a0a61800 R13: 00000000ffffff01 R14: 0000000000000000 R15: ffffffff81a907a0 FS: 00007fd6942f7700(0000) GS:ffff880105280000(0000) knlGS:0000000000000000 CS: e033 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000004 CR3: 00000000a6773000 CR4: 0000000000042660 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process bash (pid: 3047, threadinfo ffff88001742c000, task ffff880017944000) Stack: 0000000000000150 ffff880100f59e00 ffff88001742dcd8 ffff8800a0a61800 0000000000000000 00000000ffffff01 0000000000000000 ffffffff81a907a0 ffff88001742dd18 ffffffff813815b1 ffff88001742dd08 ffffffff810ae336 Call Trace: [<ffffffff813815b1>] acpi_processor_hotplug+0x7c/0x9f [<ffffffff810ae336>] ? schedule_delayed_work_on+0x16/0x20 [<ffffffff8137ee8f>] acpi_cpu_soft_notify+0x90/0xca [<ffffffff8166023d>] notifier_call_chain+0x4d/0x70 [<ffffffff810bc369>] __raw_notifier_call_chain+0x9/0x10 [<ffffffff81094a4b>] __cpu_notify+0x1b/0x30 [<ffffffff81652cf7>] _cpu_up+0x103/0x14b [<ffffffff81652e18>] cpu_up+0xd9/0xec [<ffffffff8164a254>] store_online+0x94/0xd0 [<ffffffff814122fb>] dev_attr_store+0x1b/0x20 [<ffffffff81216404>] sysfs_write_file+0xf4/0x170 This patch fixes it. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27SGI-XP: handle non-fatal trapsRobin Holt
commit 891348ca0f66206f1dc0e30d63757e3df1ae2d15 upstream. We found a user code which was raising a divide-by-zero trap. That trap would lead to XPC connections between system-partitions being torn down due to the die_chain notifier callouts it received. This also revealed a different issue where multiple callers into xpc_die_deactivate() would all attempt to do the disconnect in parallel which would sometimes lock up but often overwhelm the console on very large machines as each would print at least one line of output at the end of the deactivate. I reviewed all the users of the die_chain notifier and changed the code to ignore the notifier callouts for reasons which will not actually lead to a system to continue on to call die(). [akpm@linux-foundation.org: fix ia64] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27x86: Use enum instead of literals for trap values [PARTIAL]Kees Cook
[Based on commit c94082656dac74257f63e91f78d5d458ac781fa5 upstream, only taking the traps.h portion.] The traps are referred to by their numbers and it can be difficult to understand them while reading the code without context. This patch adds enumeration of the trap numbers and replaces the numbers with the correct enum for x86. Signed-off-by: Kees Cook <keescook@chromium.org> Link: http://lkml.kernel.org/r/20120310000710.GA32667@www.outflux.net Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27ahci: Add identifiers for ASM106x devicesAlan Cox
commit 7b4f6ecacb14f384adc1a5a67ad95eb082c02bd1 upstream. They don't always appear as AHCI class devices but instead as IDE class. Based on an initial patch by Hiroaki Nito Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=42804 Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27drm/i915: Implement WaDisableHiZPlanesWhenMSAAEnabledDaniel Vetter
commit 4283908ef7f11a72c3b80dd4cf026f1a86429f82 upstream. Quoting from Bspec, 3D_CHICKEN1, bit 10 This bit needs to be set always to "1", Project: DevSNB " Reviewed-by: Rodrigo Vivi <rodrigo.vivi@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27staging: usbip: changed function return type to voidBart Westgeest
commit ac2b41acfa3efe4650102067a99251587a806d70 upstream. The function usbip_pad_iso never returns anything but 0 (success). Signed-off-by: Bart Westgeest <bart@elbrys.com> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27serial: 8250, increase PASS_LIMITJiri Slaby
commit e7328ae1848966181a7ac47e8ae6cddbd2cf55f3 upstream. With virtual machines like qemu, it's pretty common to see "too much work for irq4" messages nowadays. This happens when a bunch of output is printed on the emulated serial console. This is caused by too low PASS_LIMIT. When ISR loops more than the limit, it spits the message. I've been using a kernel with doubled the limit and I couldn't see no problems. Maybe it's time to get rid of the message now? Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Ram Gupta <ram.gupta5@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27drivers/firmware/dmi_scan.c: fetch dmi version from SMBIOS if it existsZhenzhong Duan
commit 9f9c9cbb60576a1518d0bf93fb8e499cffccf377 upstream. The right dmi version is in SMBIOS if it's zero in DMI region This issue was originally found from an oracle bug. One customer noticed system UUID doesn't match between dmidecode & uek2. - HP ProLiant BL460c G6 : # cat /sys/devices/virtual/dmi/id/product_uuid 00000000-0000-4C48-3031-4D5030333531 # dmidecode | grep -i uuid UUID: 00000000-0000-484C-3031-4D5030333531 From SMBIOS 2.6 on, spec use little-endian encoding for UUID other than network byte order. So we need to get dmi version to distinguish. If version is 0.0, the real version is taken from the SMBIOS version. This is part of original kernel comment in code. [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Zhenzhong Duan <zhenzhong.duan@oracle.com> Cc: Feng Jin <joe.jin@oracle.com> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27drivers/firmware/dmi_scan.c: check dmi version when get system uuidZhenzhong Duan
commit f1d8e614d74b09531b9a85e812485340f3df7b1c upstream. As of version 2.6 of the SMBIOS specification, the first 3 fields of the UUID are supposed to be little-endian encoded. Also a minor fix to match variable meaning and mute checkpatch.pl [akpm@linux-foundation.org: tweak code comment] Signed-off-by: Zhenzhong Duan <zhenzhong.duan@oracle.com> Cc: Feng Jin <joe.jin@oracle.com> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27SCSI: sd: Reshuffle init_sd to avoid crashJoel D. Diaz
commit afd5e34b2bb34881d3a789e62486814a49b47faa upstream. scsi_register_driver will register a prep_fn() function, which in turn migh need to use the sd_cdp_pool for DIF. Which hasn't been initialised at this point, leading to a crash. So reshuffle the init_sd() and exit_sd() paths to have the driver registered last. Signed-off-by: Joel D. Diaz <joeldiaz@us.ibm.com> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Cc: CAI Qian <caiqian@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27USB: UHCI: fix IRQ race during initializationAlan Stern
commit 0f815a0a700bc10547449bde6c106051a035a1b9 upstream. This patch (as1644) fixes a race that occurs during startup in uhci-hcd. If the IRQ line is shared with other devices, it's possible for the handler routine to be called before the data structures are fully initialized. The problem is fixed by adding a check to the IRQ handler routine. If the initialization hasn't finished yet, the routine will return immediately. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Don Zickus <dzickus@redhat.com> Tested-by: "Huang, Adrian (ISS Linux TW)" <adrian.huang@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27PCI: Allow pcie_aspm=force even when FADT indicates it is unsupportedColin Ian King
commit 9e16721498b0c3d3ebfa0b503c63d35c0a4c0642 upstream. Right now using pcie_aspm=force will not enable ASPM if the FADT indicates ASPM is unsupported. However, the semantics of force should probably allow for this, especially as they did before 3c076351c4 ("PCI: Rework ASPM disable code") This patch just skips the clearing of any ASPM setup that the firmware has carried out on this bus if pcie_aspm=force is being used. Reference: http://bugs.launchpad.net/bugs/962038 Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27ftrace: Be first to run code modification on modulesSteven Rostedt
commit c1bf08ac26e92122faab9f6c32ea8aba94612dae upstream. If some other kernel subsystem has a module notifier, and adds a kprobe to a ftrace mcount point (now that kprobes work on ftrace points), when the ftrace notifier runs it will fail and disable ftrace, as well as kprobes that are attached to ftrace points. Here's the error: WARNING: at kernel/trace/ftrace.c:1618 ftrace_bug+0x239/0x280() Hardware name: Bochs Modules linked in: fat(+) stap_56d28a51b3fe546293ca0700b10bcb29__8059(F) nfsv4 auth_rpcgss nfs dns_resolver fscache xt_nat iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack lockd sunrpc ppdev parport_pc parport microcode virtio_net i2c_piix4 drm_kms_helper ttm drm i2c_core [last unloaded: bid_shared] Pid: 8068, comm: modprobe Tainted: GF 3.7.0-0.rc8.git0.1.fc19.x86_64 #1 Call Trace: [<ffffffff8105e70f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff81134106>] ? __probe_kernel_read+0x46/0x70 [<ffffffffa0180000>] ? 0xffffffffa017ffff [<ffffffffa0180000>] ? 0xffffffffa017ffff [<ffffffff8105e76a>] warn_slowpath_null+0x1a/0x20 [<ffffffff810fd189>] ftrace_bug+0x239/0x280 [<ffffffff810fd626>] ftrace_process_locs+0x376/0x520 [<ffffffff810fefb7>] ftrace_module_notify+0x47/0x50 [<ffffffff8163912d>] notifier_call_chain+0x4d/0x70 [<ffffffff810882f8>] __blocking_notifier_call_chain+0x58/0x80 [<ffffffff81088336>] blocking_notifier_call_chain+0x16/0x20 [<ffffffff810c2a23>] sys_init_module+0x73/0x220 [<ffffffff8163d719>] system_call_fastpath+0x16/0x1b ---[ end trace 9ef46351e53bbf80 ]--- ftrace failed to modify [<ffffffffa0180000>] init_once+0x0/0x20 [fat] actual: cc:bb:d2:4b:e1 A kprobe was added to the init_once() function in the fat module on load. But this happened before ftrace could have touched the code. As ftrace didn't run yet, the kprobe system had no idea it was a ftrace point and simply added a breakpoint to the code (0xcc in the cc:bb:d2:4b:e1). Then when ftrace went to modify the location from a call to mcount/fentry into a nop, it didn't see a call op, but instead it saw the breakpoint op and not knowing what to do with it, ftrace shut itself down. The solution is to simply give the ftrace module notifier the max priority. This should have been done regardless, as the core code ftrace modification also happens very early on in boot up. This makes the module modification closer to core modification. Link: http://lkml.kernel.org/r/20130107140333.593683061@goodmis.org Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Reported-by: Frank Ch. Eigler <fche@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-01-27drm/i915: Invalidate the relocation presumed_offsets along the slow pathChris Wilson
commit 262b6d363fcff16359c93bd58c297f961f6e6273 upstream. In the slow path, we are forced to copy the relocations prior to acquiring the struct mutex in order to handle pagefaults. We forgo copying the new offsets back into the relocation entries in order to prevent a recursive locking bug should we trigger a pagefault whilst holding the mutex for the reservations of the execbuffer. Therefore, we need to reset the presumed_offsets just in case the objects are rebound back into their old locations after relocating for this exexbuffer - if that were to happen we would assume the relocations were valid and leave the actual pointers to the kernels dangling, instant hang. Fixes regression from commit bcf50e2775bbc3101932d8e4ab8c7902aa4163b4 Author: Chris Wilson <chris@chris-wilson.co.uk> Date: Sun Nov 21 22:07:12 2010 +0000 drm/i915: Handle pagefaults in execbuffer user relocations Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=55984 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Daniel Vetter <daniel.vetter@fwll.ch> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-01-21Linux 3.0.60v3.0.60Greg Kroah-Hartman
