commit 72a0c5571351f5184195754d23db3e14495b2080 upstream.
On cris arch, the functions below aren't defined:
drivers/media/platform/sh_veu.c: In function 'sh_veu_reg_read':
drivers/media/platform/sh_veu.c:228:2: error: implicit declaration of function 'ioread32' [-Werror=implicit-function-declaration]
drivers/media/platform/sh_veu.c: In function 'sh_veu_reg_write':
drivers/media/platform/sh_veu.c:234:2: error: implicit declaration of function 'iowrite32' [-Werror=implicit-function-declaration]
drivers/media/platform/vsp1/vsp1.h: In function 'vsp1_read':
drivers/media/platform/vsp1/vsp1.h:66:2: error: implicit declaration of function 'ioread32' [-Werror=implicit-function-declaration]
drivers/media/platform/vsp1/vsp1.h: In function 'vsp1_write':
drivers/media/platform/vsp1/vsp1.h:71:2: error: implicit declaration of function 'iowrite32' [-Werror=implicit-function-declaration]
drivers/media/platform/soc_camera/rcar_vin.c: In function 'rcar_vin_setup':
drivers/media/platform/soc_camera/rcar_vin.c:284:3: error: implicit declaration of function 'iowrite32' [-Werror=implicit-function-declaration]
drivers/media/platform/soc_camera/rcar_vin.c: In function 'rcar_vin_request_capture_stop':
drivers/media/platform/soc_camera/rcar_vin.c:353:2: error: implicit declaration of function 'ioread32' [-Werror=implicit-function-declaration]
Yet, they're available, as CONFIG_GENERIC_IOMAP is defined. What happens
is that asm/io.h was not including asm-generic/iomap.h.
Suggested-by: Ben Hutchings <ben@decadent.org.uk>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
commit 5ca1db41ecdeb0358b968265fadb755213558a85 upstream.
We need to dput() the result of d_splice_alias(), unless it is passed to
finish_no_open().
Edited by Steven Whitehouse in order to make it apply to the current
GFS2 git tree, and taking account of a prerequisite patch which hasn't
been applied.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
commit 0d0d110720d7960b77c03c9f2597faaff4b484ae upstream.
unless it was given an IS_ERR(inode), which isn't the case here. So clean
up the unnecessary error handling in gfs2_create_inode().
This paves the way for real fixes (hence the stable Cc).
commit 76ae281f6307331aa063288edb6422ae99f435f0 upstream.
A race window in configfs, it starts from one dentry is UNHASHED and end
before configfs_d_iput is called. In this window, if a lookup happen,
since the original dentry was UNHASHED, so a new dentry will be
allocated, and then in configfs_attach_attr(), sd->s_dentry will be
updated to the new dentry. Then in configfs_d_iput(),
BUG_ON(sd->s_dentry != dentry) will be triggered and system panic.
sys_open: sys_close:
... fput
dput
dentry_kill
__d_drop <--- dentry unhashed here,
but sd->dentry still point
to this dentry.
lookup_real
configfs_lookup
configfs_attach_attr---> update sd->s_dentry
to new allocated dentry here.
d_kill
configfs_d_iput <--- BUG_ON(sd->s_dentry != dentry)
triggered here.
To fix it, change configfs_d_iput to not update sd->s_dentry if
sd->s_count > 2, that means there are another dentry is using the sd
beside the one that is going to be put. Use configfs_dirent_lock in
configfs_attach_attr to sync with configfs_d_iput.
With the following steps, you can reproduce the bug.
1. enable ocfs2, this will mount configfs at /sys/kernel/config and
fill configure in it.
2. run the following script.
while [ 1 ]; do cat /sys/kernel/config/cluster/$your_cluster_name/idle_timeout_ms > /dev/null; done &
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
commit 4560e7c3317c7a2b370e36dadd3a3bac2ed70818 upstream.
Use the ACCESS_ONCE macro for both accesses to idle->sequence in the
loops to calculate the idle time. If only one access uses the macro,
the compiler is free to cache the value for the second access which
can cause endless loops.
commit 7ab64a85e1a009046f97413a573e83fd85f7804d upstream.
The get_tod_clock_ext inline assembly does not specify its output
operands correctly. This can cause incorrect code to be generated.
commit 0d2dd7eaed1dac07b266ca2c662ff4a184a3060f upstream.
The patch fixes two issues in the error path cleanup:
- in MUSB_PORT_MODE_DUAL_ROLE mode, if musb_gadget_setup() fails we
never cleanup the host struct earlier allocated.
- if musb_init_debugfs() or sysfs_create_group() fails, then we never
free the host part initialization, only device part.
Cc: Daniel Mack <zonque@gmail.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 0f901c980110cd69b63670096465b35377e73b1c upstream.
According to the comments, we rely on the OTG timer because the core
does not expose some important OTG details. So far this is all I
know. After playing with OTG I stumbled over a problem:
musb is recognized as a B-device without a problem. Whenever a cable is
plugged, the VBUS rises, musb recognizes this as a starting session,
sets the MUSB_DEVCTL_SESSION bit by itself and a RESET interrupt occurs,
the session starts. Good.
After a disconnect, the timer is started and re-starts itself because
it remains in B_IDLE with the BDEVICE set. I didn't figure the the
reason or the need for it. Nothing changes here except for OTG state
from B to A device if the BDEVICE bit disappears. This doesn't make much
sense to me because nothing happens after this. _IF_ we receive an
interrupt before the state change then we may act on wrong condition.
Plugging a B-device (and letting MUSB act as host) doesn't work here.
The reason seems to be that the MUSB tries to start a session, it fails
and then it removes the bit. So we never start as a host.
This patch sets the MUSB_DEVCTL_SESSION bit in the IDLE state so musb
can try to establish a session as host. After the bit is set, musb tries
to start a session and if it fails it clears the bit. Therefore it will
try over and over again until a session either as host or as device is
established.
The readout of the MUSB_DEVCTL register after the removal the
MUSB_DEVCTL_SESSION (in A_WAIT_BCON) has been removed because it did not
contain the BDEVICE bit set (in the second read) leading to A_IDLE. After
plugging a host musb assumed that it is also a host and complained about
a missing reset. However a third read of the register has has the BDEVICE
bit set so it seems that it is not stable.
This mostly what da8xx.c is doing except that we set the timer also
after A_WAIT_BCON so the session bit can be triggered.
Whit this change I was able to keep am335x-evm in OTG mode and plug in
either a HOST or a DEVICE and in a random order and the device was
recognized.
commit 8b9fcce2d88586b9a120ff3e039d8f42413f0bb0 upstream.
The timer is initialized right after musb is probed. There is actually
no need to have this timer running because _nothing_ will happen until
we have the gadget loaded. Also we need this timer only if we run in OTG
mode _and_ we need it also after the gadget has been replaced with
another one.
I've been looking at am35x.c, da8xx.c, omap2430.c, tusb6010.c. da8xx
seem to have the same problem as dsps and doing mostly the same thing.
tusb6010 seem to do something different and do some actual "idle / power
saving" work so I am not too comfortable to remove
musb_platform_try_idle() from musb_gadget_setup().
Therefore this patch does not start the timer if there is no gadget
active (which is at musb_gadget_setup() at time). In order to have the
timer active after the gadget is loaded it will be triggered from
dsps_musb_enable().
commit ae44df2e21b50f9fff28ac75c57e399c04df812c upstream.
In commit 001dd84 ("usb: musb: start musb on the udc side, too") it was
ensured that the state engine is started also in OTG mode after a
removal / insertion of the gadget.
Unfortunately this change also introduced a bug: If the device is
configured as OTG and it connected with a remote host _without_ loading
a gadget then we bug() later (because musb->otg->gadget is not
initialized).
Initially I assumed it might be nice to have the host part of musb in
OTG mode working without having a gadget loaded. This bug and fact that
it wasn't working like this before the host/gadget split made me realize
that this was a silly idea.
This patch now introduces back the old behavior where in OTG mode the
host mode is only working after the gadget has been loaded.
commit c5340bd14336b902604ab95212a8877de109d9ae upstream.
So I captured this:
|WARNING: CPU: 0 PID: 2078 at /home/bigeasy/work/new/TI/linux/lib/debugobjects.c:260 debug_print_object+0x94/0xc4()
|ODEBUG: free active (active state 0) object type: work_struct hint: musb_irq_work+0x0/0x38 [musb_hdrc]
|CPU: 0 PID: 2078 Comm: rmmod Not tainted 3.12.0-rc4+ #338
|[<c0014d38>] (unwind_backtrace+0x0/0xf4) from [<c001249c>] (show_stack+0x14/0x1c)
|[<c001249c>] (show_stack+0x14/0x1c) from [<c0037720>] (warn_slowpath_common+0x64/0x84)
|[<c0037720>] (warn_slowpath_common+0x64/0x84) from [<c00377d4>] (warn_slowpath_fmt+0x30/0x40)
|[<c00377d4>] (warn_slowpath_fmt+0x30/0x40) from [<c022ae90>] (debug_print_object+0x94/0xc4)
|[<c022ae90>] (debug_print_object+0x94/0xc4) from [<c022b7e0>] (debug_check_no_obj_freed+0x1c0/0x228)
|[<c022b7e0>] (debug_check_no_obj_freed+0x1c0/0x228) from [<c00f1f38>] (kfree+0xf8/0x228)
|[<c00f1f38>] (kfree+0xf8/0x228) from [<c02921c4>] (release_nodes+0x1a8/0x248)
|[<c02921c4>] (release_nodes+0x1a8/0x248) from [<c028f70c>] (__device_release_driver+0x98/0xf0)
|[<c028f70c>] (__device_release_driver+0x98/0xf0) from [<c028f840>] (device_release_driver+0x24/0x34)
|[<c028f840>] (device_release_driver+0x24/0x34) from [<c028ebe8>] (bus_remove_device+0x148/0x15c)
|[<c028ebe8>] (bus_remove_device+0x148/0x15c) from [<c028d120>] (device_del+0x104/0x1c0)
|[<c028d120>] (device_del+0x104/0x1c0) from [<c02911e4>] (platform_device_del+0x18/0xac)
|[<c02911e4>] (platform_device_del+0x18/0xac) from [<c029179c>] (platform_device_unregister+0xc/0x18)
|[<c029179c>] (platform_device_unregister+0xc/0x18) from [<bf1902fc>] (dsps_remove+0x20/0x4c [musb_dsps])
|[<bf1902fc>] (dsps_remove+0x20/0x4c [musb_dsps]) from [<c0290d7c>] (platform_drv_remove+0x1c/0x24)
|[<c0290d7c>] (platform_drv_remove+0x1c/0x24) from [<c028f704>] (__device_release_driver+0x90/0xf0)
|[<c028f704>] (__device_release_driver+0x90/0xf0) from [<c028f818>] (driver_detach+0xb4/0xb8)
|[<c028f818>] (driver_detach+0xb4/0xb8) from [<c028e6e8>] (bus_remove_driver+0x98/0xec)
|[<c028e6e8>] (bus_remove_driver+0x98/0xec) from [<c008fc70>] (SyS_delete_module+0x1e0/0x24c)
|[<c008fc70>] (SyS_delete_module+0x1e0/0x24c) from [<c000e680>] (ret_fast_syscall+0x0/0x48)
|---[ end trace d79045419a3e51ec ]---
The workqueue is only scheduled from the ep0 and never canceled in case
the musb is removed before the work has a chance to run.
commit 36165fd5b00bf8163f89c21bb16a3e9834555b10 upstream.
Polling TX statuses too frequently has two negative effects. First is
randomly peek CPU usage, causing overall system functioning delays.
Second bad effect is that device is not able to fill TX statuses in
H/W register on some workloads and we get lot of timeouts like below:
ieee80211 phy4: rt2800usb_entry_txstatus_timeout: Warning - TX status timeout for entry 7 in queue 2
ieee80211 phy4: rt2800usb_txdone: Warning - Got TX status for an empty queue 2, dropping
This not only cause flood of messages in dmesg, but also bad throughput,
since rate scaling algorithm can not work optimally.
In the future, we should probably make polling interval be adjusted
automatically, but for now just increase values, this make mentioned
problems gone.
Resolve:
https://bugzilla.kernel.org/show_bug.cgi?id=62781
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit 7b6bc07ab554e929c85d51b3d5b26cf7f12c6a3b upstream.
For isochronous endpoints, set the RPIPE wMaxPacketSize value using
wOverTheAirPacketSize from the endpoint companion descriptor instead of
wMaxPacketSize from the normal endpoint descriptor.
Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com>
commit e92aee330837e4911553761490a8fb843f2053a6 upstream.
This patch adds the Port Reset Change flag to the set of bits that are
preemptively cleared on init/resume of a hub. In theory this bit should
never be set unexpectedly... in practice it can still happen if BIOS,
SMM or ACPI code plays around with USB devices without cleaning up
correctly. This is especially dangerous for XHCI root hubs, which don't
generate any more Port Status Change Events until all change bits are
cleared, so this is a good precaution to have (similar to how it's
already done for the Warm Port Reset Change flag).
Signed-off-by: Julius Werner <jwerner@chromium.org>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit dcc01c0864823f91c3bf3ffca6613e2351702b87 upstream.
Before the USB core resets a device, we need to disable the L1 timeout
for the roothub, if USB 2.0 Link PM is enabled. Otherwise the port may
transition into L1 in between descriptor fetches, before we know if the
USB device descriptors changed. LPM will be re-enabled after the
full device descriptors are fetched, and we can confirm the device still
supports USB 2.0 LPM after the reset.
We don't need to wait for the USB device to exit L1 before resetting the
device, since the xHCI roothub port diagrams show a transition to the
Reset state from any of the Ux states (see Figure 34 in the 2012-08-14
xHCI specification update).
This patch should be backported to kernels as old as 3.2, that contain
the commit 65580b4321eb36f16ae8b5987bfa1bb948fc5112 "xHCI: set USB2
hardware LPM". That was the first commit to enable USB 2.0
hardware-driven Link Power Management.
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 58e21f73975ec927119370635bf68b9023831c56 upstream.
To enable USB 2.0 Link Power Management (LPM), the xHCI host controller
needs the device slot ID to generate the device address used in L1 entry
tokens. That information is set in the L1 device slot ID field of the
USB 2.0 LPM registers.
Currently, the L1 device slot ID is overwritten when the xHCI driver
initiates the software test of USB 2.0 Link PM in
xhci_usb2_software_lpm_test. It is never cleared when USB 2.0 Link PM
is disabled for the device. That should be harmless, because the
Hardware LPM Enable (HLE) bit is cleared when USB 2.0 Link PM is
disabled, so the host should not pay attention to the slot ID.
This patch should have no effect on host behavior, but since
xhci_usb2_software_lpm_test is going away in an upcoming bug fix patch,
we need to move that code to the function that enables and disables USB
2.0 Link PM.
This patch should be backported to kernels as old as 3.11, that contain
the commit a558ccdcc71c7770c5e80c926a31cfe8a3892a09 "usb: xhci: add USB2
Link power management BESL support". The upcoming bug fix patch is also
marked for that stable kernel.
commit 890dae88672175f1d39f6105444d9bdc71c89258 upstream.
Some usb3 devices falsely claim they support usb2 hardware Link PM
when connected to a usb2 port. We only trust hardwired devices
or devices with the later BESL LPM support to be LPM enabled as default.
[Note: Sarah re-worked the original patch to move the code into the USB
core, and updated it to check whether the USB device supports BESL,
instead of checking if the xHCI port it's connected to supports BESL
encoding.]
contain the commit a558ccdcc71c7770c5e80c926a31cfe8a3892a09 "usb: xhci:
add USB2 Link power management BESL support". Without this fix, some
USB 3.0 devices will not enumerate or work properly under USB 2.0 ports
on Haswell-ULT systems.
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit de68bab4fa96014cfaa6fcbcdb9750e32969fb86 upstream.
How it's supposed to work:
USB 2.0 Link PM is a lower power state that some newer USB 2.0 devices
support. USB 3.0 devices certified by the USB-IF are required to
support it if they are plugged into a USB 2.0 only port, or a USB 2.0
cable is used. USB 2.0 Link PM requires both a USB device and a host
controller that supports USB 2.0 hardware-enabled LPM.
USB 2.0 Link PM is designed to be enabled once by software, and the host
hardware handles transitions to the L1 state automatically. The premise
of USB 2.0 Link PM is to be able to put the device into a lower power
link state when the bus is idle or the device NAKs USB IN transfers for
a specified amount of time.
...but hardware is broken:
It turns out many USB 3.0 devices claim to support USB 2.0 Link PM (by
setting the LPM bit in their USB 2.0 BOS descriptor), but they don't
actually implement it correctly. This manifests as the USB device
refusing to respond to transfers when it is plugged into a USB 2.0 only
port under the Haswell-ULT/Lynx Point LP xHCI host.
These devices pass the xHCI driver's simple test to enable USB 2.0 Link
PM, wait for the port to enter L1, and then bring it back into L0. They
only start to break when L1 entry is interleaved with transfers.
Some devices then fail to respond to the next control transfer (usually
a Set Configuration). This results in devices never enumerating.
Other mass storage devices (such as a later model Western Digital My
Passport USB 3.0 hard drive) respond fine to going into L1 between
control transfers. They ACK the entry, come out of L1 when the host
needs to send a control transfer, and respond properly to those control
transfers. However, when the first READ10 SCSI command is sent, the
device NAKs the data phase while it's reading from the spinning disk.
Eventually, the host requests to put the link into L1, and the device
ACKs that request. Then it never responds to the data phase of the
READ10 command. This results in not being able to read from the drive.
Some mass storage devices (like the Corsair Survivor USB 3.0 flash
drive) are well behaved. They ACK the entry into L1 during control
transfers, and when SCSI commands start coming in, they NAK the requests
to go into L1, because they need to be at full power.
Not all USB 3.0 devices advertise USB 2.0 link PM support. My Point
Grey USB 3.0 webcam advertises itself as a USB 2.1 device, but doesn't
have a USB 2.0 BOS descriptor, so we don't enable USB 2.0 Link PM. I
suspect that means the device isn't certified.
What do we do about it?
There's really no good way for the kernel to test these devices.
Therefore, the kernel needs to disable USB 2.0 Link PM by default, and
distros will have to enable it by writing 1 to the sysfs file
/sys/bus/usb/devices/../power/usb2_hardware_lpm. Rip out the xHCI Link
PM test, since it's not sufficient to detect these buggy devices, and
don't automatically enable LPM after the device is addressed.
commit 4bff7208f332b2b1d7cf1338e50527441283a198 upstream.
The flow may reach the err label without freeing cl and cl_info
cl and cl_info weren't assigned to ndev->cl and cl_info
so they weren't freed in mei_nfc_free called on error path
Cc: Samuel Ortiz <sameo@linux.intel.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
commit d07ba8422f1e58be94cc98a1f475946dc1b89f1b upstream.
In cases where an rpc client has a parent hierarchy, then
rpc_free_client may end up calling rpc_release_client() on the
parent, thus recursing back into rpc_free_client. If the hierarchy
is deep enough, then we can get into situations where the stack
simply overflows.
The fix is to have rpc_release_client() loop so that it can take
care of the parent rpc client hierarchy without needing to
recurse.
Reported-by: Jeff Layton <jlayton@redhat.com>
Reported-by: Weston Andros Adamson <dros@netapp.com>
Reported-by: Bruce Fields <bfields@fieldses.org>
Link: http://lkml.kernel.org/r/2C73011F-0939-434C-9E4D-13A1EB1403D7@netapp.com
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit a6b31d18b02ff9d7915c5898c9b5ca41a798cd73 upstream.
The following scenario can cause silent data corruption when doing
NFS writes. It has mainly been observed when doing database writes
using O_DIRECT.
1) The RPC client uses sendpage() to do zero-copy of the page data.
2) Due to networking issues, the reply from the server is delayed,
and so the RPC client times out.
3) The client issues a second sendpage of the page data as part of
an RPC call retransmission.
4) The reply to the first transmission arrives from the server
_before_ the client hardware has emptied the TCP socket send
buffer.
5) After processing the reply, the RPC state machine rules that
the call to be done, and triggers the completion callbacks.
6) The application notices the RPC call is done, and reuses the
pages to store something else (e.g. a new write).
7) The client NIC drains the TCP socket send buffer. Since the
page data has now changed, it reads a corrupted version of the
initial RPC call, and puts it on the wire.
This patch fixes the problem in the following manner:
The ordering guarantees of TCP ensure that when the server sends a
reply, then we know that the _first_ transmission has completed. Using
zero-copy in that situation is therefore safe.
If a time out occurs, we then send the retransmission using sendmsg()
(i.e. no zero-copy), We then know that the socket contains a full copy of
the data, and so it will retransmit a faithful reproduction even if the
RPC call completes, and the application reuses the O_DIRECT buffer in
the meantime.
commit 5fccc5b52ee07d07a74ce53c6f174bff81e26a16 upstream.
Add the missing 'break' to ensure that we don't corrupt a legacy 'v0' type
message by appending the 'v1'.
Cc: Bruce Fields <bfields@fieldses.org>
commit c6f58d9b362b45c52afebe4342c9137d0dabe47f upstream.
Andreas Herrmann writes:
When I've used slub_debug kernel option (e.g.
"slub_debug=,skbuff_fclone_cache" or similar) on a debug session I've
seen a panic like:
Highbank #setenv bootargs console=ttyAMA0 root=/dev/sda2 kgdboc.kgdboc=ttyAMA0,115200 slub_debug=,kmalloc-4096 earlyprintk=ttyAMA0
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c0004000
[00000000] *pgd=00000000
Internal error: Oops: 5 [#1] SMP ARM
Modules linked in:
CPU: 0 PID: 0 Comm: swapper Tainted: G W 3.12.0-00048-gbe408cd #314
task: c0898360 ti: c088a000 task.ti: c088a000
PC is at strncmp+0x1c/0x84
LR is at kmem_cache_flags.isra.46.part.47+0x44/0x60
pc : [<c02c6da0>] lr : [<c0110a3c>] psr: 200001d3
sp : c088bea8 ip : c088beb8 fp : c088beb4
r10: 00000000 r9 : 413fc090 r8 : 00000001
r7 : 00000000 r6 : c2984a08 r5 : c0966e78 r4 : 00000000
r3 : 0000006b r2 : 0000000c r1 : 00000000 r0 : c2984a08
Flags: nzCv IRQs off FIQs off Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387d Table: 0000404a DAC: 00000015
Process swapper (pid: 0, stack limit = 0xc088a248)
Stack: (0xc088bea8 to 0xc088c000)
bea0: c088bed4 c088beb8 c0110a3c c02c6d90 c0966e78 00000040
bec0: ef001f00 00000040 c088bf14 c088bed8 c0112070 c0110a04 00000005 c010fac8
bee0: c088bf5c c088bef0 c010fac8 ef001f00 00000040 00000000 00000040 00000001
bf00: 413fc090 00000000 c088bf34 c088bf18 c0839190 c0112040 00000000 ef001f00
bf20: 00000000 00000000 c088bf54 c088bf38 c0839200 c083914c 00000006 c0961c4c
bf40: c0961c28 00000000 c088bf7c c088bf58 c08392ac c08391c0 c08a2ed8 c0966e78
bf60: c086b874 c08a3f50 c0961c28 00000001 c088bfb4 c088bf80 c083b258 c0839248
bf80: 2f800000 0f000000 c08935b4 ffffffff c08cd400 ffffffff c08cd400 c0868408
bfa0: c29849c0 00000000 c088bff4 c088bfb8 c0824974 c083b1e4 ffffffff ffffffff
bfc0: c08245c0 00000000 00000000 c0868408 00000000 10c5387d c0892bcc c0868404
bfe0: c0899440 0000406a 00000000 c088bff8 00008074 c0824824 00000000 00000000
[<c02c6da0>] (strncmp+0x1c/0x84) from [<c0110a3c>] (kmem_cache_flags.isra.46.part.47+0x44/0x60)
[<c0110a3c>] (kmem_cache_flags.isra.46.part.47+0x44/0x60) from [<c0112070>] (__kmem_cache_create+0x3c/0x410)
[<c0112070>] (__kmem_cache_create+0x3c/0x410) from [<c0839190>] (create_boot_cache+0x50/0x74)
[<c0839190>] (create_boot_cache+0x50/0x74) from [<c0839200>] (create_kmalloc_cache+0x4c/0x88)
[<c0839200>] (create_kmalloc_cache+0x4c/0x88) from [<c08392ac>] (create_kmalloc_caches+0x70/0x114)
[<c08392ac>] (create_kmalloc_caches+0x70/0x114) from [<c083b258>] (kmem_cache_init+0x80/0xe0)
[<c083b258>] (kmem_cache_init+0x80/0xe0) from [<c0824974>] (start_kernel+0x15c/0x318)
[<c0824974>] (start_kernel+0x15c/0x318) from [<00008074>] (0x8074)
Code: e3520000 01a00002 089da800 e5d03000 (e5d1c000)
---[ end trace 1b75b31a2719ed1d ]---
Kernel panic - not syncing: Fatal exception
Problem is that slub_debug option is not parsed before
create_boot_cache is called. Solve this by changing slub_debug to
early_param.
Kernels 3.11, 3.10 are also affected. I am not sure about older
kernels.
Christoph Lameter explains:
kmem_cache_flags may be called with NULL parameter during early boot.
Skip the test in that case.
Reported-by: Andreas Herrmann <andreas.herrmann@calxeda.com>
Signed-off-by: Christoph Lameter <cl@linux.com>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
commit 84b073868b9d9e754ae48b828337633d1b386482 upstream.
When reading from the dispatch trace log (dtl) userspace interface, I
sometimes see duplicate entries. One example:
# hexdump -C dtl.out
00000000 07 04 00 0c 00 00 48 44 00 00 00 00 00 00 00 00
00000010 00 0c a0 b4 16 83 6d 68 00 00 00 00 00 00 00 00
00000020 00 00 00 00 10 00 13 50 80 00 00 00 00 00 d0 32
00000030 07 04 00 0c 00 00 48 44 00 00 00 00 00 00 00 00
00000040 00 0c a0 b4 16 83 6d 68 00 00 00 00 00 00 00 00
00000050 00 00 00 00 10 00 13 50 80 00 00 00 00 00 d0 32
The problem is in scan_dispatch_log() where we call dtl_consumer()
but bail out before incrementing the index.
To fix this I moved dtl_consumer() after the timebase comparison.
commit bf898ec5cbd33be11147743bee27b66b10cb2f85 upstream.
On PHB3, we will fail to fetch IODA tables without PCI_COMMAND_MASTER
on PCI bridges. According to one experiment I had, the MSIx interrupts
didn't raise from the adapter without the bit applied to all upstream
PCI bridges including root port of the adapter. The patch forces to
have that bit enabled accordingly.
Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com>
commit c13f20ac48328b05cd3b8c19e31ed6c132b44b42 upstream.
The VSX MSR bit in the user context indicates if the context contains VSX
state. Currently we set this when the process has touched VSX at any stage.
Unfortunately, if the user has not provided enough space to save the VSX state,
we can't save it but we currently still set the MSR VSX bit.
This patch changes this to clear the MSR VSX bit when the user doesn't provide
enough space. This indicates that there is no valid VSX state in the user
context.
This is needed to support get/set/make/swapcontext for applications that use
VSX but only provide a small context. For example, getcontext in glibc
provides a smaller context since the VSX registers don't need to be saved over
the glibc function call. But since the program calling getcontext may have
used VSX, the kernel currently says the VSX state is valid when it's not. If
the returned context is then used in setcontext (ie. a small context without
VSX but with MSR VSX set), the kernel will refuse the context. This situation
has been reported by the glibc community.
Based on patch from Carlos O'Donell.
Tested-by: Haren Myneni <haren@linux.vnet.ibm.com>
Signed-off-by: Michael Neuling <mikey@neuling.org>
commit 95f715b08fa4a953771398d20cbe35a6803ea41d upstream.
__get_user_pages_fast() may be called with interrupts disabled (see e.g.
get_futex_key() in kernel/futex.c) and therefore should use local_irq_save()
and local_irq_restore() instead of local_irq_disable()/enable().
commit 5a049f14902982c26538250bdc8d54156d357252 upstream.
Commit fba2369e6ceb (mm: use vm_unmapped_area() on powerpc architecture)
has a bug in slice_scan_available() where we compare an unsigned long
(high_slices) against a shifted int. As a result, comparisons against
the top 32 bits of high_slices (representing the top 32TB) always
returns 0 and the top of our mmap region is clamped at 32TB
This also breaks mmap randomisation since the randomised address is
always up near the top of the address space and it gets clamped down
to 32TB.
Acked-by: Michel Lespinasse <walken@google.com>
commit 631ad691b5818291d89af9be607d2fe40be0886e upstream.
We need add PE to its own PELTV. Otherwise, the errors originated
from the PE might contribute to other PEs. In the result, we can't
clear up the error successfully even we're checking and clearing
errors during access to PCI config space.
Reported-by: kalshett@in.ibm.com
commit 411cabf79e684171669ad29a0628c400b4431e95 upstream.
Commit e82b89a6f19bae73fb064d1b3dd91fcefbb478f4 used strcat instead of
strcpy which can result in an overflow of newlines on the buffer.
Signed-off-by: Prarit Bhargava
Cc: benh@kernel.crashing.org
Cc: ben@decadent.org.uk
commit 45d20e8348969a165c53cfb91f445e7cc599a9f0 upstream.
a disabled Kconfig option results in a reference to a not implemented
routine when the IS_ENABLED() macro is used for both conditional
implementation of the routine as well as a C language source code test
at the call site -- the "if (0) func();" construct only gets eliminated
later by the optimizer, while the compiler already has emitted its
warning about "func()" being undeclared
provide an empty implementation for the mpc512x_setup_diu() and
mpc512x_init_diu() routines in case of the disabled option, to avoid the
compiler warning which is considered fatal and breaks compilation
the bug appeared with commit 2abbbb63c90ab55ca3f054772c2e5ba7df810c48
"powerpc/mpc512x: move common code to shared.c file", how to reproduce:
make mpc512x_defconfig
echo CONFIG_FB_FSL_DIU=n >> .config && make olddefconfig
make
CC arch/powerpc/platforms/512x/mpc512x_shared.o
.../arch/powerpc/platforms/512x/mpc512x_shared.c: In function 'mpc512x_init_early':
.../arch/powerpc/platforms/512x/mpc512x_shared.c:456:3: error: implicit declaration of function 'mpc512x_init_diu' [-Werror=implicit-function-declaration]
.../arch/powerpc/platforms/512x/mpc512x_shared.c: In function 'mpc512x_setup_arch':
.../arch/powerpc/platforms/512x/mpc512x_shared.c:469:3: error: implicit declaration of function 'mpc512x_setup_diu' [-Werror=implicit-function-declaration]
cc1: all warnings being treated as errors
make[4]: *** [arch/powerpc/platforms/512x/mpc512x_shared.o] Error 1
Signed-off-by: Gerhard Sittig <gsi@denx.de>
commit 2bf75084f6d9f9a91ba6e30a501ff070d8a1acf6 upstream.
The MPC5200 LPBFIFO driver requires the bestcomm module to be
enabled, otherwise building will fail. Fix it.
Reported-by: Wolfgang Denk <wd@denx.de>
commit d82ae52e68892338068e7559a0c0657193341ce4 upstream.
Without this patch all DM devices will default to BLK_MAX_SEGMENT_SIZE
(65536) even if the underlying device(s) have a larger value -- this is
due to blk_stack_limits() using min_not_zero() when stacking the
max_segment_size limit.
1073741824
before patch:
65536
after patch:
1073741824
Reported-by: Lukasz Flis <l.flis@cyfronet.pl>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit a207f5937630dd35bd2550620bef416937a1365e upstream.
The probe function is supposed to return NULL on failure (as we can see in
kobj_lookup: kobj = probe(dev, index, data); ... if (kobj) return kobj;
However, in loop and brd, it returns negative error from ERR_PTR.
This causes a crash if we simulate disk allocation failure and run
less -f /dev/loop0 because the negative number is interpreted as a pointer:
BUG: unable to handle kernel NULL pointer dereference at 00000000000002b4
IP: [<ffffffff8118b188>] __blkdev_get+0x28/0x450
PGD 23c677067 PUD 23d6d1067 PMD 0
Oops: 0000 [#1] PREEMPT SMP
Modules linked in: loop hpfs nvidia(PO) ip6table_filter ip6_tables uvesafb cfbcopyarea cfbimgblt cfbfillrect fbcon font bitblit fbcon_rotate fbcon_cw fbcon_ud fbcon_ccw softcursor fb fbdev msr ipt_MASQUERADE iptable_nat nf_nat_ipv4 nf_conntrack_ipv4 nf_defrag_ipv4 xt_state ipt_REJECT xt_tcpudp iptable_filter ip_tables x_tables bridge stp llc tun ipv6 cpufreq_stats cpufreq_ondemand cpufreq_userspace cpufreq_powersave cpufreq_conservative hid_generic spadfs usbhid hid fuse raid0 snd_usb_audio snd_pcm_oss snd_mixer_oss md_mod snd_pcm snd_timer snd_page_alloc snd_hwdep snd_usbmidi_lib dmi_sysfs snd_rawmidi nf_nat_ftp nf_nat nf_conntrack_ftp nf_conntrack snd soundcore lm85 hwmon_vid ohci_hcd ehci_pci ehci_hcd serverworks sata_svw libata acpi_cpufreq freq_table mperf ide_core usbcore kvm_amd kvm tg3 i2c_piix4 libphy microcode e100 usb_common ptp skge i2c_core pcspkr k10temp evdev floppy hwmon pps_core mii rtc_cmos button processor unix [last unloaded: nvidia]
CPU: 1 PID: 6831 Comm: less Tainted: P W O 3.10.15-devel #18
Hardware name: empty empty/S3992-E, BIOS 'V1.06 ' 06/09/2009
task: ffff880203cc6bc0 ti: ffff88023e47c000 task.ti: ffff88023e47c000
RIP: 0010:[<ffffffff8118b188>] [<ffffffff8118b188>] __blkdev_get+0x28/0x450
RSP: 0018:ffff88023e47dbd8 EFLAGS: 00010286
RAX: ffffffffffffff74 RBX: ffffffffffffff74 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000001
RBP: ffff88023e47dc18 R08: 0000000000000002 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff88023f519658
R13: ffffffff8118c300 R14: 0000000000000000 R15: ffff88023f519640
FS: 00007f2070bf7700(0000) GS:ffff880247400000(0000) knlGS:0000000000000000
CR2: 00000000000002b4 CR3: 000000023da1d000 CR4: 00000000000007e0
Stack:
0000000000000002 0000001d00000000 000000003e47dc50 ffff88023f519640
ffff88043d5bb668 ffffffff8118c300 ffff88023d683550 ffff88023e47de60
ffff88023e47dc98 ffffffff8118c10d 0000001d81605698 0000000000000292
Call Trace:
[<ffffffff8118c300>] ? blkdev_get_by_dev+0x60/0x60
[<ffffffff8118c10d>] blkdev_get+0x1dd/0x370
[<ffffffff813cea6c>] ? _raw_spin_unlock+0x2c/0x50
[<ffffffff8118c365>] blkdev_open+0x65/0x80
[<ffffffff8114d12e>] do_dentry_open.isra.18+0x23e/0x2f0
[<ffffffff8114d214>] finish_open+0x34/0x50
[<ffffffff8115e122>] do_last.isra.62+0x2d2/0xc50
[<ffffffff8115eb58>] path_openat.isra.63+0xb8/0x4d0
[<ffffffff81115a8e>] ? might_fault+0x4e/0xa0
[<ffffffff8115f4f0>] do_filp_open+0x40/0x90
[<ffffffff8116db85>] ? __alloc_fd+0xa5/0x1f0
[<ffffffff8114e45f>] do_sys_open+0xef/0x1d0
[<ffffffff8114e559>] SyS_open+0x19/0x20
[<ffffffff813cff16>] system_call_fastpath+0x1a/0x1f
Code: 44 00 00 55 48 89 e5 41 57 49 89 ff 41 56 41 89 d6 41 55 41 54 4c 8d 67 18 53 48 83 ec 18 89 75 cc e9 f2 00 00 00 0f 1f 44 00 00 <48> 8b 80 40 03 00 00 48 89 df 4c 8b 68 58 e8 d5
a4 07 00 44 89
RIP [<ffffffff8118b188>] __blkdev_get+0x28/0x450
RSP <ffff88023e47dbd8>
---[ end trace bb7f32dbf02398dc ]---
The brd change should be backported to stable kernels starting with 2.6.25.
The loop change should be backported to stable kernels starting with 2.6.22.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Acked-by: Tejun Heo <tj@kernel.org>
commit 4912aa6c11e6a5d910264deedbec2075c6f1bb73 upstream.
crocode i2c_i801 i2c_core iTCO_wdt iTCO_vendor_support shpchp ioatdma dca be2net sg ses enclosure ext4 mbcache jbd2 sd_mod crc_t10dif ahci megaraid_sas(U) dm_mirror dm_region_hash dm_log dm_mod [last unloaded: scsi_wait_scan]
Pid: 491, comm: scsi_eh_0 Tainted: G W ---------------- 2.6.32-220.13.1.el6.x86_64 #1 IBM -[8722PAX]-/00D1461
RIP: 0010:[<ffffffff8124e424>] [<ffffffff8124e424>] blk_requeue_request+0x94/0xa0
RSP: 0018:ffff881057eefd60 EFLAGS: 00010012
RAX: ffff881d99e3e8a8 RBX: ffff881d99e3e780 RCX: ffff881d99e3e8a8
RDX: ffff881d99e3e8a8 RSI: ffff881d99e3e780 RDI: ffff881d99e3e780
RBP: ffff881057eefd80 R08: ffff881057eefe90 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff881057f92338
R13: 0000000000000000 R14: ffff881057f92338 R15: ffff883058188000
FS: 0000000000000000(0000) GS:ffff880040200000(0000) knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 00000000006d3ec0 CR3: 000000302cd7d000 CR4: 00000000000406b0
Process scsi_eh_0 (pid: 491, threadinfo ffff881057eee000, task ffff881057e29540)
Stack:
0000000000001057 0000000000000286 ffff8810275efdc0 ffff881057f16000
<0> ffff881057eefdd0 ffffffff81362323 ffff881057eefe20 ffffffff8135f393
<0> ffff881057e29af8 ffff8810275efdc0 ffff881057eefe78 ffff881057eefe90
Call Trace:
[<ffffffff81362323>] __scsi_queue_insert+0xa3/0x150
[<ffffffff8135f393>] ? scsi_eh_ready_devs+0x5e3/0x850
[<ffffffff81362a23>] scsi_queue_insert+0x13/0x20
[<ffffffff8135e4d4>] scsi_eh_flush_done_q+0x104/0x160
[<ffffffff8135fb6b>] scsi_error_handler+0x35b/0x660
[<ffffffff8135f810>] ? scsi_error_handler+0x0/0x660
[<ffffffff810908c6>] kthread+0x96/0xa0
[<ffffffff8100c14a>] child_rip+0xa/0x20
[<ffffffff81090830>] ? kthread+0x0/0xa0
[<ffffffff8100c140>] ? child_rip+0x0/0x20
Code: 00 00 eb d1 4c 8b 2d 3c 8f 97 00 4d 85 ed 74 bf 49 8b 45 00 49 83 c5 08 48 89 de 4c 89 e7 ff d0 49 8b 45 00 48 85 c0 75 eb eb a4 <0f> 0b eb fe 0f 1f 84 00 00 00 00 00 55 48 89 e5 0f 1f 44 00 00
RIP [<ffffffff8124e424>] blk_requeue_request+0x94/0xa0
RSP <ffff881057eefd60>
The RIP is this line:
BUG_ON(blk_queued_rq(rq));
After digging through the code, I think there may be a race between the
request completion and the timer handler running.
A timer is started for each request put on the device's queue (see
blk_start_request->blk_add_timer). If the request does not complete
before the timer expires, the timer handler (blk_rq_timed_out_timer)
will mark the request complete atomically:
static inline int blk_mark_rq_complete(struct request *rq)
return test_and_set_bit(REQ_ATOM_COMPLETE, &rq->atomic_flags);
and then call blk_rq_timed_out. The latter function will call
scsi_times_out, which will return one of BLK_EH_HANDLED,
BLK_EH_RESET_TIMER or BLK_EH_NOT_HANDLED. If BLK_EH_RESET_TIMER is
returned, blk_clear_rq_complete is called, and blk_add_timer is again
called to simply wait longer for the request to complete.
Now, if the request happens to complete while this is going on, what
happens? Given that we know the completion handler will bail if it
finds the REQ_ATOM_COMPLETE bit set, we need to focus on the completion
handler running after that bit is cleared. So, from the above
paragraph, after the call to blk_clear_rq_complete. If the completion
sets REQ_ATOM_COMPLETE before the BUG_ON in blk_add_timer, we go boom
there (I haven't seen this in the cores). Next, if we get the
completion before the call to list_add_tail, then the timer will
eventually fire for an old req, which may either be freed or reallocated
(there is evidence that this might be the case). Finally, if the
completion comes in *after* the addition to the timeout list, I think
it's harmless. The request will be removed from the timeout list,
req_atom_complete will be set, and all will be well.
This will only actually explain the coredumps *IF* the request
structure was freed, reallocated *and* queued before the error handler
thread had a chance to process it. That is possible, but it may make
sense to keep digging for another race. I think that if this is what
was happening, we would see other instances of this problem showing up
as null pointer or garbage pointer dereferences, for example when the
request structure was not re-used. It looks like we actually do run
into that situation in other reports.
This patch moves the BUG_ON(test_bit(REQ_ATOM_COMPLETE,
&req->atomic_flags)); from blk_add_timer to the only caller that could
trip over it (blk_start_request). It then inverts the calls to
blk_clear_rq_complete and blk_add_timer in blk_rq_timed_out to address
the race. I've boot tested this patch, but nothing more.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Acked-by: Hannes Reinecke <hare@suse.de>
commit a0e5a12fd18d47aa87a7a8c60ca5bc422b136564 upstream.
In h_msb_read_page() in ms_block.c, flow never reaches case
MSB_RP_RECIVE_STATUS_REG. This causes error when MEMSTICK_INT_ERR is
encountered and status error bits are going to be examined, but the status
will never be copied back.
Fix it by transitioning to MSB_RP_RECIVE_STATUS_REG right after
MSB_RP_SEND_READ_STATUS_REG.
Signed-off-by: Roger Tseng <rogerable@realtek.com>
Acked-by: Maxim Levitsky <maximlevitsky@gmail.com>
commit e41fae2b1ed8c78283d73651cd65be0228c0dd1c upstream.
Bit 2 of status register 2 on MAX6696 (external diode 2 open)
sets ALERT; the bit thus has to be listed in alert_alarms.
Also display a message in the alert handler if the condition
is encountered.
Even though not all overtemperature conditions cause ALERT
to be set, we should not ignore them in the alert handler.
Display messages for all out-of-range conditions.
Reported-by: Jean Delvare <khali@linux-fr.org>
commit 40c2729bab48e2832b17c1fa8af9db60e776131b upstream.
Using virt_to_phys on percpu mappings is horribly wrong as it may be
backed by vmalloc. Introduce kvm_kaddr_to_phys which translates both
types of valid kernel addresses to the corresponding physical address.
At the same time resolves a typing issue where we were storing the
physical address as a 32 bit unsigned long (on arm), truncating the
physical address for addresses above the 4GB limit. This caused
breakage on Keystone.
Reported-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
commit 27ef63c7e97d1e5dddd85051c03f8d44cc887f34 upstream.
When determining the page size we could use to map with the IOMMU, the
page size should also be aligned with the hva, not just the gfn. The
gfn may not reflect the real alignment within the hugetlbfs file.
Most of the time, this works fine. However, if the hugetlbfs file is
backed by non-contiguous huge pages, a multi-huge page memslot starts at
an unaligned offset within the hugetlbfs file, and the gfn is aligned
with respect to the huge page size, kvm_host_page_size() will return the
huge page size and we will use that to map with the IOMMU.
When we later unpin that same memslot, the IOMMU returns the unmap size
as the huge page size, and we happily unpin that many pfns in
monotonically increasing order, not realizing we are spanning
non-contiguous huge pages and partially unpin the wrong huge page.
Ensure the IOMMU mapping page size is aligned with the hva corresponding
to the gfn, which does reflect the alignment within the hugetlbfs file.
Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Greg Edwards <gedwards@ddn.com>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
commit ab4ead02ec235d706d0611d8741964628291237e upstream.
In commit 8a4d0a687a59 "ftrace: Use breakpoint method to update ftrace
caller", we choose to use breakpoint method to update the ftrace
caller. But we also need to skip over the breakpoint in function
ftrace_int3_handler() for them. Otherwise weird things would happen.
Signed-off-by: Kevin Hao <haokexin@gmail.com>
commit daf727225b8abfdfe424716abac3d15a3ac5626a upstream.
When I was looking at RHEL5.9's failure to start with
unrestricted_guest=0/emulate_invalid_guest_state=1, I got it working with a
slightly older tree than kvm.git. I now debugged the remaining failure,
which was introduced by commit 660696d1 (KVM: X86 emulator: fix
source operand decoding for 8bit mov[zs]x instructions, 2013-04-24)
introduced a similar mis-emulation to the one in commit 8acb4207 (KVM:
fix sil/dil/bpl/spl in the mod/rm fields, 2013-05-30). The incorrect
decoding occurs in 8-bit movzx/movsx instructions whose 8-bit operand
is sil/dil/bpl/spl.
Needless to say, "movzbl %bpl, %eax" does occur in RHEL5.9's decompression
prolog, just a handful of instructions before finally giving control to
the decompressed vmlinux and getting out of the invalid guest state.
Because OpMem8 bypasses decode_modrm, the same handling of the REX prefix
must be applied to OpMem8.
Reported-by: Michele Baldessari <michele@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
as an error
commit 11f918d3e2d3861b6931e97b3aa778e4984935aa upstream.
Do it the same way as done in microcode_intel.c: use pr_debug()
for missing firmware files.
There seem to be CPUs out there for which no microcode update
has been submitted to kernel-firmware repo yet resulting in
scary sounding error messages in dmesg:
microcode: failed to load file amd-ucode/microcode_amd_fam16h.bin
Signed-off-by: Thomas Renninger <trenn@suse.de>
Acked-by: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/1384274383-43510-1-git-send-email-trenn@suse.de
commit 522e66464467543c0d88d023336eec4df03ad40b upstream.
In reboot and crash path, when we shut down the local APIC, the I/O APIC is
still active. This may cause issues because external interrupts
can still come in and disturb the local APIC during shutdown process.
To quiet external interrupts, disable I/O APIC before shutdown local APIC.
Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
Link: http://lkml.kernel.org/r/1382578212-4677-1-git-send-email-fenghua.yu@intel.com
[ I suppose the 'issue' is a hang during shutdown. It's a fine change nevertheless. ]
commit 365da4adebb1c012febf81019ad3dc5bb52e2a13 upstream.
This fixes a regression from 247500820ebd02ad87525db5d9b199e5b66f6636
"nfsd4: fix decoding of compounds across page boundaries". The previous
code was correct: argp->pagelist is initialized in
nfs4svc_deocde_compoundargs to rqstp->rq_arg.pages, and is therefore a
pointer to the page *after* the page we are currently decoding.
The reason that patch nevertheless fixed a problem with decoding
compounds containing write was a bug in the write decoding introduced by
5a80a54d21c96590d013378d8c5f65f879451ab4 "nfsd4: reorganize write
decoding", after which write decoding no longer adhered to the rule that
argp->pagelist point to the next page.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 987da4791052fa298b7cfcde4dea9f6f2bbc786b upstream.
Use a straight goto error label style in nfsd_setattr to make sure
we always do the put_write_access call after we got it earlier.
Note that the we have been failing to do that in the case
nfsd_break_lease() returns an error, a bug introduced into 2.6.38 with
6a76bebefe15d9a08864f824d7f8d5beaf37c997 "nfsd4: break lease on nfsd
setattr".
commit 818e5a22e907fbae75e9c1fd78233baec9fa64b6 upstream.
Split out two helpers to make the code more readable and easier to verify
for correctness.
commit 6d769f1e1420179d1f83cf1a9cdc585b46c28545 upstream.
Currently, when we try to mount and get back NFS4ERR_CLID_IN_USE or
NFS4ERR_WRONGSEC, we create a new rpc_clnt and then try the call again.
There is no guarantee that doing so will work however, so we can end up
retrying the call in an infinite loop.
Worse yet, we create the new client using rpc_clone_client_set_auth,
which creates the new client as a child of the old one. Thus, we can end
up with a *very* long lineage of rpc_clnts. When we go to put all of the
references to them, we can end up with a long call chain that can smash
the stack as each rpc_free_client() call can recurse back into itself.
This patch fixes this by simply ensuring that the SETCLIENTID call will
only be retried in this situation if the last attempt did not use
RPC_AUTH_UNIX.
Note too that with this change, we don't need the (i > 2) check in the
-EACCES case since we now have a more reliable test as to whether we
should reattempt.
Cc: Chuck Lever <chuck.lever@oracle.com>
Tested-by/Acked-by: Weston Andros Adamson <dros@netapp.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
commit 3378b7f40d79930f0f447a164c7e8fcbe4480e40 upstream.
Security labels in setattr calls are currently ignored because we forget
to set label->len.
commit 427d6c6646d868fbd3094e7e2e1644d480cd9204 upstream.
Someone noticed exportfs happily accepted exports that would later be
rejected when mountd tried to give them to the kernel. Fix this.
This is a regression from 4c1e1b34d5c800ad3ac9a7e2805b0bea70ad2278
"nfsd: Store ex_anon_uid and ex_anon_gid as kuids and kgids".
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Reported-by: Yin.JianHong <jiyin@redhat.com>
