commit 98fb2cc115b4ef1ea0a2d87a170c183bd395dd6c upstream.
This patch fixes system hang when resuming from S3 state
and lower rate sens failure issue.
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
commit c30bc94758ae2a38a5eb31767c1985c0aae0950b upstream.
L2TP for example uses NLA_MSECS like this:
policy:
[L2TP_ATTR_RECV_TIMEOUT] = { .type = NLA_MSECS, },
code:
if (info->attrs[L2TP_ATTR_RECV_TIMEOUT])
cfg.reorder_timeout = nla_get_msecs(info->attrs[L2TP_ATTR_RECV_TIMEOUT]);
As nla_get_msecs() is essentially nla_get_u64() plus the
conversion to a HZ-based value, this will not properly
reject attributes from userspace that aren't long enough
and might overrun the message.
Add NLA_MSECS to the attribute minlen array to check the
size properly.
Cc: Thomas Graf <tgraf@suug.ch>
commit c1056b42a87b59375f8f81a92ef029165f44fcce upstream.
Recently the ACPI ops structs were constified but the inline version
of register_hotplug_dock_device() was overlooked (see also commit
9c8b04b, June 25 2011). Update the inline function
register_hotplug_dock_device() that is enabled with
CONFIG_ACPI_DOCK=n too. This patch fixes at least the following
compiler warnings:
drivers/ata/libata-acpi.c: In function .ata_acpi_associate.:
drivers/ata/libata-acpi.c:266:11: warning: passing argument 2 of .register_hotplug_dock_device. discards qualifiers from pointer target type
include/acpi/acpi_drivers.h:146:19: note: expected .struct acpi_dock_ops *. but argument is of type .const struct acpi_dock_ops *.
drivers/ata/libata-acpi.c:275:11: warning: passing argument 2 of .register_hotplug_dock_device. discards qualifiers from pointer target type
Signed-off-by: Len Brown <len.brown@intel.com>
commit 3bf3f8b19d2bfccc40f13c456bf339fd8f535ebc upstream.
Callers to __acpi_ioremap_fast() pass the bit_width that they found in the
acpi_generic_address structure. Convert from bits to bytes when passing to
__acpi_find_iomap() - as it wants to see bytes, not bits.
Signed-off-by: Tony Luck <tony.luck@intel.com>
commit 8bdafa39a47265bc029838b35cc6585f69224afa upstream.
The icswx code introduced an A-B B-A deadlock:
CPU0 CPU1
lock(&anon_vma->mutex);
lock(&mm->mmap_sem);
Instead of using the mmap_sem to keep mm_users constant, take the
page table spinlock.
commit 8feaa43494cee5e938fd5a57b9e9bf1c827e6ccd upstream.
Since commit 188917e183cf9ad0374b571006d0fc6d48a7f447, /proc/ppc64 is a
symlink to /proc/powerpc/. That means that creating /proc/ppc64/eeh will
end up with a unaccessible file, that is not listed under /proc/powerpc/
and, then, not listed under /proc/ppc64/.
Creating /proc/powerpc/eeh fixes that problem and maintain the
compatibility intended with the ppc64 symlink.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
commit 9c740025c51a26ab00192cfc464064d4ccbfe3fc upstream.
During hotplug CPU add we get the following error:
Unexpected Error (0) returned from configure-connector
ibm,configure-connector returns 0 for configuration complete, so
catch this and avoid the error.
commit a11940978bd598e65996b4f807cf4904793f7025 upstream.
If we echo an address the hypervisor doesn't like to
/sys/devices/system/memory/probe we oops the box:
# echo 0x10000000000 > /sys/devices/system/memory/probe
kernel BUG at arch/powerpc/mm/hash_utils_64.c:541!
The backtrace is:
create_section_mapping
arch_add_memory
add_memory
memory_probe_store
sysdev_class_store
sysfs_write_file
vfs_write
SyS_write
In create_section_mapping we BUG if htab_bolt_mapping returned
an error. A better approach is to return an error which will
propagate back to userspace.
Rerunning the test with this patch applied:
-bash: echo: write error: Invalid argument
commit 6083184269fd723affca4f6340e491950267622a upstream.
During memory hotplug testing, I got the following warning:
ERROR: Bad of_node_put() on /memory@0
of_node_release
kref_put
of_node_put
of_find_node_by_type
hot_add_node_scn_to_nid
hot_add_scn_to_nid
memory_add_physaddr_to_nid
of_find_node_by_type() loop does the of_node_put for us so we only
need the handle the case where we terminate the loop early.
As suggested by Stephen Rothwell we can do the of_node_put
unconditionally outside of the loop since of_node_put handles a
NULL argument fine.
commit 6eb40b2af4908e9aee71e43e7a384243128c56dd upstream.
This patch fixes another bug from LUN_RESET re-org fallout in
core_tmr_drain_tmr_list() that was adding the wrong se_tmr_req
into the local drain_tmr_list to be walked + released.
Signed-off-by: Joern Engel <joern@logfs.org>
Cc: Joern Engel <joern@logfs.org>
Reviewed-by: Roland Dreier <roland@purestorage.com>
Cc: Roland Dreier <roland@purestorage.com>
commit 80ccbc8e00f7001d79dd503c2781487906b98611 upstream.
This patch fixes a bug in core_tmr_drain_tmr_list() where drain_tmr_list
was using the wrong se_tmr_req for cmd assignment due to a typo during the
LUN_RESET re-org. This was resulting in general protection faults while
using the leftover bogus *tmr_p pointer from list_for_each_entry_safe().
commit a3fbbde70a0cec017f2431e8f8de208708c76acc upstream.
Mountpoint crossing is similar to following procfs symlinks - we do
not get ->d_revalidate() called for dentry we have arrived at, with
unpleasant consequences for NFS4.
Simple way to reproduce the problem in mainline:
cat >/tmp/a.c <<'EOF'
#include <unistd.h>
#include <fcntl.h>
#include <stdio.h>
main()
struct flock fl = {.l_type = F_RDLCK, .l_whence = SEEK_SET, .l_len = 1};
if (fcntl(0, F_SETLK, &fl))
perror("setlk");
EOF
cc /tmp/a.c -o /tmp/test
then on nfs4:
mount --bind file1 file2
/tmp/test < file1 # ok
/tmp/test < file2 # spews "setlk: No locks available"...
What happens is the missing call of ->d_revalidate() after mountpoint
crossing and that's where NFS4 would issue OPEN request to server.
The fix is simple - treat mountpoint crossing the same way we deal with
following procfs-style symlinks. I.e. set LOOKUP_JUMPED...
commit e67b77c791ca2778198c9e7088f3266ed2da7a55 upstream.
A dm-multipath user reported[1] a problem when trying to boot
a kernel with commit 4853abaae7e4a2af938115ce9071ef8684fb7af4
(block: fix flush machinery for stacking drivers with differring
flush flags) applied. It turns out that an empty flush request
can be sent into blk_insert_flush. When the BUG_ON was fixed
to allow for this, I/O on the underlying device would stall. The
reason is that blk_insert_cloned_request does not kick the queue.
In the aforementioned commit, I had added a special case to
kick the queue if data was sent down but the queue flags did
not require a flush. A better solution is to push the queue
kick up into blk_insert_cloned_request.
This patch, along with a follow-on which fixes the BUG_ON, fixes
the issue reported.
[1] http://www.redhat.com/archives/dm-devel/2011-September/msg00154.html
Reported-by: Christophe Saout <christophe@saout.de>
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Acked-by: Tejun Heo <tj@kernel.org>
commit 834f9f61a525d2f6d3d0c93894e26326c8d3ceed upstream.
A user reported a regression due to commit
4853abaae7e4a2af938115ce9071ef8684fb7af4 (block: fix flush
machinery for stacking drivers with differring flush flags).
Part of the problem is that blk_insert_flush required a
single bio be attached to the request. In reality, having
no attached bio is also a valid case, as can be observed with
an empty flush.
commit c4853efec665134b2e6fc9c13447323240980351 upstream.
The P600 requires a small delay when changing states. Otherwise we may think
the board did not reset and we bail. This for kdump only and is particular
to the P600.
Signed-off-by: Mike Miller <mike.miller@hp.com>
commit 5c8a0fbba543d9428a486f0d1282bbcf3cf1d95a upstream.
No one in their right mind would expect statfs() to not work on a
automounter managed mount point. Fix it.
[ I'm not sure about the "no one in their right mind" part. It's not
mounted, and you didn't ask for it to be mounted. But nobody will
really care, and this probably makes it match previous semantics, so..
- Linus ]
This mirrors the fix made to the quota code in 815d405ceff0d69646.
Signed-off-by: Dan McGee <dpmcgee@gmail.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 5c62cb48602dba95159c81ffeca179d3852e25be upstream.
We did not increment the amount of sectors written to disk
b/c we tested for the == WRITE which is incorrect - as the
operations are more of WRITE_FLUSH, WRITE_ODIRECT. This patch
fixes it by doing a & WRITE check.
Reported-by: Andy Burns <xen.lists@burns.me.uk>
Suggested-by: Ian Campbell <Ian.Campbell@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit f992ae801a7dec34a4ed99a6598bbbbfb82af4fb upstream.
The following command sequence triggers an oops.
# mount /dev/sdb1 /mnt
# echo 1 > /sys/class/scsi_device/0\:0\:1\:0/device/delete
# umount /mnt
general protection fault: 0000 [#1] PREEMPT SMP
CPU 2
Modules linked in:
Pid: 791, comm: umount Not tainted 3.1.0-rc3-work+ #8 Bochs Bochs
RIP: 0010:[<ffffffff810d0879>] [<ffffffff810d0879>] __lock_acquire+0x389/0x1d60
Call Trace:
[<ffffffff810d2845>] lock_acquire+0x95/0x140
[<ffffffff81aed87b>] _raw_spin_lock+0x3b/0x50
[<ffffffff811573bc>] bdi_lock_two+0x5c/0x70
[<ffffffff811c2f6c>] bdev_inode_switch_bdi+0x4c/0xf0
[<ffffffff811c3fcb>] __blkdev_put+0x11b/0x1d0
[<ffffffff811c4010>] __blkdev_put+0x160/0x1d0
[<ffffffff811c40df>] blkdev_put+0x5f/0x190
[<ffffffff8118f18d>] kill_block_super+0x4d/0x80
[<ffffffff8118f4a5>] deactivate_locked_super+0x45/0x70
[<ffffffff8119003a>] deactivate_super+0x4a/0x70
[<ffffffff811ac4ad>] mntput_no_expire+0xed/0x130
[<ffffffff811acf2e>] sys_umount+0x7e/0x3a0
[<ffffffff81aeeeab>] system_call_fastpath+0x16/0x1b
This is because bdev holds on to disk but disk doesn't pin the
associated queue. If a SCSI device is removed while the device is
still open, the sdev puts the base reference to the queue on release.
When the bdev is finally released, the associated queue is already
gone along with the bdi and bdev_inode_switch_bdi() ends up
dereferencing already freed bdi.
Even if it were not for this bug, disk not holding onto the associated
queue is very unusual and error-prone.
Fix it by making add_disk() take an extra reference to its queue and
put it on disk_release() and ensuring that disk and its fops owner are
put in that order after all accesses to the disk and queue are
complete.
commit dc6f55e9f8dac4b6479be67c5c9128ad37bb491f upstream.
The sunrpc layer keeps a cache of recently used credentials and
'unx_match' is used to find the credential which matches the current
process.
However unx_match allows a match when the cached credential has extra
groups at the end of uc_gids list which are not in the process group list.
So if a process with a list of (say) 4 group accesses a file and gains
access because of the last group in the list, then another process
with the same uid and gid, and a gid list being the first tree of the
gids of the original process tries to access the file, it will be
granted access even though it shouldn't as the wrong rpc credential
will be used.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 0b7dd6ad92b6cace35dc5d06d6e236c2751c85dc upstream.
commit 2af8de8c39cf58e5a5e40a9d5d71332da98e6ba7 upstream.
Since there is no current software control for these they would otherwise
be left enabled, consuming power.
commit 4f4488abc97c1c27ff029f887944e6a6da1f5733 upstream.
The WM8962 has a separate software reset for the PLL registers. Ensure that
these are reset also on startup.
commit 5a7c5f26df3c0122814dfa1c13ef6dfbdbffdb86 upstream.
Set `invert' bit for Capture Switch. Otherwise analogue is muted when
Capture Switch is ON.
Signed-off-by: Hong Xu <hong.xu@atmel.com>
commit d558cfc30064a97c2c65dbd2b3a4f5a1dea7ec1b upstream.
Current implementation in wm8711_set_dai_fmt always clear BIT[3:2]
(the Input Audio Data Bit Length Select) of WM8711_IFACE(07h) register.
Input Audio Data Bit Length Select bits are set by wm8711_hw_params,
we should leave BIT[3:2] untouched in wm8711_set_dai_fmt.
commit 04c57163c8edfbc50e022737014069998ba4fc5f upstream.
The Input Audio Data Bit Length Select is controlled by BIT[3:2] of
Current code incorrectly masks BIT[1:0] which is for Audio Data Format Select.
commit 0167ac67ff6f35bf2364f7672c8012b0cd40277f upstream.
Fix for issue : While discovery is in progress, hot unplug and hot plug of
enclosure connected to the controller card is causing system to hang.
When a device is in the process of being detected at driver load time then
if it is removed, the device that is no longer present will not be added
to the list. So the code in _scsih_probe_sas() is rearranged as such so
the devices that failed to be detected are not added to the list.
Signed-off-by: Nagalakshmi Nandigama <nagalakshmi.nandigama@lsi.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit f7c9c6bb14f3104608a3a83cadea10a6943d2804 upstream.
When looking at memory consumption issues I noticed quite a
lot of memory in the kmalloc-2048 bucket:
OBJS ACTIVE USE OBJ SIZE SLABS OBJ/SLAB CACHE SIZE NAME
6561 6471 98% 2.30K 243 27 15552K kmalloc-2048
Over 15MB. slub debug shows that cfq is responsible for almost
all of it:
# sort -nr /sys/kernel/slab/kmalloc-2048/alloc_calls
6402 .cfq_init_queue+0xec/0x460 age=43423/43564/43655 pid=1 cpus=4,11,13
In scsi_alloc_sdev we do scsi_alloc_queue but if slave_alloc
fails we don't free it with scsi_free_queue.
The patch below fixes the issue:
135 72 53% 2.30K 5 27 320K kmalloc-2048
# cat /sys/kernel/slab/kmalloc-2048/alloc_calls
3 .cfq_init_queue+0xec/0x460 age=3811/3876/3925 pid=1 cpus=4,11,13
commit 3308511c93e6ad0d3c58984ecd6e5e57f96b12c8 upstream.
Make sure that SCSI device removal via scsi_remove_host() does finish
all pending SCSI commands. Currently that's not the case and hence
removal of a SCSI host during I/O can cause a deadlock. See also
"blkdev_issue_discard() hangs forever if underlying storage device is
removed" (http://bugzilla.kernel.org/show_bug.cgi?id=40472). See also
http://lkml.org/lkml/2011/8/27/6.
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
commit a18a920c70d48a8e4a2b750d8a183b3c1a4be514 upstream.
This patch validates sdev pointer in scsi_dh_activate before proceeding further.
Without this check we might see the panic as below. I have seen this
panic multiple times..
Call trace:
#0 [ffff88007d647b50] machine_kexec at ffffffff81020902
#1 [ffff88007d647ba0] crash_kexec at ffffffff810875b0
#2 [ffff88007d647c70] oops_end at ffffffff8139c650
#3 [ffff88007d647c90] __bad_area_nosemaphore at ffffffff8102dd15
#4 [ffff88007d647d50] page_fault at ffffffff8139b8cf
[exception RIP: scsi_dh_activate+0x82]
RIP: ffffffffa0041922 RSP: ffff88007d647e00 RFLAGS: 00010046
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 00000000000093c5
RDX: 00000000000093c5 RSI: ffffffffa02e6640 RDI: ffff88007cc88988
RBP: 000000000000000f R8: ffff88007d646000 R9: 0000000000000000
R10: ffff880082293790 R11: 00000000ffffffff R12: ffff88007cc88988
R13: 0000000000000000 R14: 0000000000000286 R15: ffff880037b845e0
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0000
#5 [ffff88007d647e38] run_workqueue at ffffffff81060268
#6 [ffff88007d647e78] worker_thread at ffffffff81060386
#7 [ffff88007d647ee8] kthread at ffffffff81064436
#8 [ffff88007d647f48] kernel_thread at ffffffff81003fba
Signed-off-by: Babu Moger <babu.moger@netapp.com>
commit c68bf8eeaa57c852e74adcf597237be149eef830 upstream.
The call to complete() in st_scsi_execute_end() wakes up sleeping thread
in write_behind_check(), which frees the st_request, thus invalidating
the pointer to the associated bio structure, which is then passed to the
blk_rq_unmap_user(). Fix by storing pointer to bio structure into
temporary local variable.
This bug is present since at least linux-2.6.32.
Signed-off-by: Petr Uzel <petr.uzel@suse.cz>
Reported-by: Juergen Groß <juergen.gross@ts.fujitsu.com>
Acked-by: Kai Mäkisara <kai.makisara@kolumbus.fi>
commit 5a4c8666c6d576f076a7c6824589cdbb984c0f84 upstream.
This patch addresses two issues with non immediate TMR handling in
iscsit_handle_task_mgt_cmd(). The first involves breakage due to
v3.1-rc conversion of iscsit_sequence_cmd(), which upon good status
would hit the iscsit_add_reject_from_cmd() block of code. This patch
adds an explict check for CMDSN_ERROR_CANNOT_RECOVER.
The second adds a check to return when non immediate TMR operation is
detected after iscsit_ack_from_expstatsn(), as iscsit_sequence_cmd()
-> iscsit_execute_cmd() will have called transport_generic_handle_tmr()
for the non immediate TMR case already.
Cc: Andy Grover <agrover@redhat.com>
commit 7e32da55e26b80d57961681e53aa67938268db3f upstream.
This patch adds a missing CMDSN_LOWER_THAN_EXP return check for
iscsit_sequence_cmd() in iscsit_handle_scsi_cmd() that was incorrectly
dropped during the v3.1-rc cleanups to use iscsit_sequence_cmd().
commit 8cd79f24350826b81e16990d9e12bc878e67d385 upstream.
This patch addresses an issue with buggy userspace code sending I/O
via scsi-generic that does not explictly clear their associated read
buffers. It adds an explict memset of the first SGL entry within
tcm_loop_new_cmd_map() for SCF_SCSI_CONTROL_SG_IO_CDB payloads that
are currently guaranteed to be a single SGL by target-core code.
This issue is a side effect of the v3.1-rc1 merge to remove the
extra memcpy between certain control CDB types using a contigious
+ cleared buffer in target-core, and performing a memcpy into the
SGL list within tcm_loop.
It was originally mainfesting itself by udev + scsi_id + scsi-generic
not properly setting up the expected /dev/disk/by-id/ symlinks because
the INQUIRY payload was containing extra bogus data preventing the
proper NAA IEEE WWN from being parsed by userspace.
commit bfa02b0da66965caf46e441270af87edda4fea14 upstream.
Commit 2265cef2 (hwmon: (w83627ehf) Properly report PECI and AMD-SI
sensor types) results in kernel panic if data->temp_label was not
initialized.
The problem was found with chip W83627DHG-P.
Add check if data->temp->label was set before use.
Based on incomplete patch by Alexander Beregalov.
Reported-by: Alexander Beregalov <a.beregalov@gmail.com>
Tested-by: Alexander Beregalov <a.beregalov@gmail.com>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit 2265cef2751b3441df91f85e0107f9f549e5b711 upstream.
When temperature sources are PECI or AMD-SI agents, it makes no sense
to report their type as diode or thermistor. Instead we must report
their digital nature.
Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit 2aba6cac2a84f3b80e11a680c34d55e7739b474d upstream.
The definition of TO_ATTR_NO in the non-SMP case is wrong. As the SMP
definition resolves to the correct value, just use this for both
cases.
Without this fix the temperature attributes are named temp0_* instead
of temp2_*, so libsensors won't pick them. Broken since kernel 3.0.
Tested-by: Phil Sutter <phil@nwl.cc>
Acked-by: Durgadoss R <Durgadoss.r@intel.com>
commit ab5dbebe33e0c353e8545f09c34553ac3351dad6 upstream.
to the P600.
commit b2c0a863e14676fa5760c6d828fd373288e2f64a upstream.
Originally, the runtime PM core would send an idle notification
whenever a suspend attempt failed. The idle callback routine could
then schedule a delayed suspend for some time later.
However this behavior was changed by commit
f71648d73c1650b8b4aceb3856bebbde6daa3b86 (PM / Runtime: Remove idle
notification after failing suspend). No notifications were sent, and
there was no clear mechanism to retry failed suspends.
This caused problems for the usbhid driver, because it fails
autosuspend attempts as long as a key is being held down. A companion
patch changes the PM core's behavior, but we also need to change the
USB core. In particular, this patch (as1493) updates the device's
last_busy time when an autosuspend fails, so that the PM core will
retry the autosuspend in the future when the delay time expires
again.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Henrik Rydberg <rydberg@euromail.se>
commit 886486b792e4f6f96d4fbe8ec5bf20811cab7d6a upstream.
autosuspend attempts as long as a key is being held down. Therefore
this patch (as1492) adds a mechanism for retrying failed
autosuspends. If the callback routine updates the last_busy field so
that the next autosuspend expiration time is in the future, the
autosuspend will automatically be rescheduled.
commit 3f198dfee49d2e9c30583c62b0c79286c78c7b44 upstream.
Help text under choice menu is never displayed because it does not have
symbol name associated with it, however many kconfigs have help text
under choice, assuming that it will be displayed when user selects help.
for example in Kconfig if we have:
choice
prompt "Choice"
---help---
HELP TEXT ...
config A
bool "A"
config B
bool "B"
endchoice
Without this patch "HELP TEXT" is not displayed when user selects help
option when "Choice" is highlighted from menuconfig or xconfig or
gconfig.
This patch changes the logic in menu_get_ext_help to display help for
cases which dont have symbol names like choice.
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Reviewed-by: Stuart Menefy <stuart.menefy@st.com>
Reviewed-by: Arnaud Lacombe <lacombar@gmail.com>
commit 64912e997f0fe13512e4c7b90e4f7c11cb922ab5 upstream.
Polarity needs to be set accordingly to connector status (connected
or disconnected). Set it up in hpd_init() so first hotplug works
reliably no matter what is the initial set of connector. hpd_init()
also covers resume so HPD will work correctly after resume as well.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Cc: Jerome Glisse <j.glisse@gmail.com>
commit a18cee15ed4c8b6a35f96b7b26a46bac32e04bd9 upstream.
Allow the user to override whether MSIs are enabled
or not on supported ASICs. MSIs are disabled by default
on IGP chips as they tend not to work. However certain
IGP chips only seem to work with MSIs enabled.
I suspect this is a chipset or bios issue, but I'm not sure
what the proper fix is. This will at least make diagnosing
and working around the problem much easier.
See:
https://bugs.freedesktop.org/show_bug.cgi?id=37679
commit 01e718ec194e30b3e8eb3858c742c13649757efc upstream.
Some Dell laptops only seem to work with MSIs. This
looks like a platform/bios bug.
Fixes:
commit 00dfb8df5bf8c3afe4c0bb8361133156b06b7a2c upstream.
This should make eDP more reliable.
commit 8ab250d4484b72ccc78e34276c5ffa84c1d41303 upstream.
or disconnected). Set it up at module init so first hotplug works
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
commit b362105f7f5223fa4d2e03ceeea0e51da754ccc6 upstream.
Some HP laptops only seem to work with MSIs. This
Fixes:
commit 8f6c25c59b0c895c68cae59d1b34e9a7b36971bc upstream.
This makes it easier to add quirks for certain systems.
commit 340764465aa4a586ca332e61ae64883e5ad6f183 upstream.
Since force handling rework of d0d0a225e6ad43314c9aa7ea081f76adc5098ad4
we could end up bouncing connector status btw disconnected and unknown.
When connector status change a call to output_poll_changed happen which
in turn ask again for detect but with force set.
So set the load detect flags whenever we report the connector as
connected or unknown this avoid bouncing btw disconnected and unknown.
Reviewed-by: Alex Deucher <alexdeucher@gmail.com>
Cc: Stefan Lippers-Hollmann <s.L-H@gmx.de>
commit 69f9ba9b0cad67bc03f0a096f7f274de795ca844 upstream.
The regression-fix in 3.1 for the check of DMA-position validity caused
yet another regression for CA0110. As usual, this hardware seems working
only with LPIB properly. Adding the appropriate driver-caps bit to force
LPIB fixes the problem.
Reported-and-tested-by: Andres Freund <andres@anarazel.de>
commit 43dea228a3ba5463392281535dfb3d3fe56f4c2c upstream.
The 3.1 kernel has a regression for ALC861 codec where no sound output
is heard with the default setup. It's because the amps in DACs aren't
properly unmuted while the output mixers are assigned only to pins.
This patch fixes the missing initialization of DACs when no mixer is
assigned to them.
Tested-by: Andrea Iob <andrea_iob@yahoo.it>
