commit 1376b0a2160319125c3a2822e8c09bd283cd8141 upstream.
There is a '>' vs '<' typo so this loop is a no-op.
Fixes: d35dcc89fc93 ("staging: comedi: quatech_daqp_cs: fix daqp_ao_insn_write()")
Reviewed-by: Ian Abbott <abbotti@mev.co.uk>
commit ce00bf07cc95a57cd20b208e02b3c2604e532ae8 upstream.
The old code would indefinitely block other users of nf_log_mutex if
a userspace access in proc_dostring() blocked e.g. due to a userfaultfd
region. Fix it by moving proc_dostring() out of the locked region.
This is a followup to commit 266d07cb1c9a ("netfilter: nf_log: fix
sleeping function called from invalid context"), which changed this code
from using rcu_read_lock() to taking nf_log_mutex.
Fixes: 266d07cb1c9a ("netfilter: nf_log: fix sleeping function calle[...]")
Signed-off-by: Jann Horn <jannh@google.com>
commit 79ca484b613041ca223f74b34608bb6f5221724b upstream.
Currently the functions use to check both chip ready and good.
But the chip ready is not enough to check the operation status.
So change this to check the chip good instead of this.
About the retry functions to make sure the error handling remain it.
Signed-off-by: Tokunori Ikegami <ikegami@allied-telesis.co.jp>
Reviewed-by: Joakim Tjernlund <Joakim.Tjernlund@infinera.com>
Cc: Chris Packham <chris.packham@alliedtelesis.co.nz>
Cc: Brian Norris <computersforpeace@gmail.com>
Cc: Boris Brezillon <boris.brezillon@free-electrons.com>
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Cyrille Pitchen <cyrille.pitchen@wedev4u.fr>
Cc: linux-mtd@lists.infradead.org
Cc: stable@vger.kernel.org
Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com>
commit 45f75b8a919a4255f52df454f1ffdee0e42443b2 upstream.
For the word write functions it is retried for error.
But it is not implemented to retry for the erase functions.
To make sure for the erase functions change to retry as same.
This is needed to prevent the flash erase error caused only once.
It was caused by the error case of chip_good() in the do_erase_oneblock().
Also it was confirmed on the MACRONIX flash device MX29GL512FHT2I-11G.
But the error issue behavior is not able to reproduce at this moment.
The flash controller is parallel Flash interface integrated on BCM53003.
commit 85a82e28b023de9b259a86824afbd6ba07bd6475 upstream.
The definition can be used for other program and erase operations also.
So change the naming to MAX_RETRIES from MAX_WORD_RETRIES.
commit d12067f428c037b4575aaeb2be00847fc214c24a upstream.
dm_bufio_shrink_count() is called from do_shrink_slab to find out how many
freeable objects are there. The reported value doesn't have to be precise,
so we don't need to take the dm-bufio lock.
Suggested-by: David Rientjes <rientjes@google.com>
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 3f77f244d8ec28e3a0a81240ffac7d626390060c upstream.
The v21 version of the NAND flash controller contains a Spare Area Size
Register (SPAS) at offset 0x10. Its setting defaults to the maximum
spare area size of 218 bytes. The size that is set in this register is
used by the controller when it calculates the ECC bytes internally in
hardware.
Usually, this register is updated from settings in the IIM fuses when
the system is booting from NAND flash. For other boot media, however,
the SPAS register remains at the default setting, which may not work for
the particular flash chip on the board. The same goes for flash chips
whose configuration cannot be set in the IIM fuses (e.g. chips with 2k
sector size and 128 bytes spare area size can't be configured in the IIM
fuses on imx25 systems).
Set the SPAS register explicitly during the preset operation. Derive the
register value from mtd->oobsize that was detected during probe by
decoding the flash chip's ID bytes.
While at it, rename the define for the spare area register's offset to
NFC_V21_RSLTSPARE_AREA. The register at offset 0x10 on v1 controllers is
different from the register on v21 controllers.
Fixes: d484018 ("mtd: mxc_nand: set NFC registers after reset")
Signed-off-by: Martin Kaiser <martin@kaiser.cx>
Reviewed-by: Sascha Hauer <s.hauer@pengutronix.de>
Reviewed-by: Miquel Raynal <miquel.raynal@bootlin.com>
commit 41c73a49df31151f4ff868f28fe4f129f113fa2c upstream.
If the first allocation attempt using GFP_NOWAIT fails, drop the lock
and retry using GFP_NOIO allocation (lock is dropped because the
allocation can take some time).
Note that we won't do GFP_NOIO allocation when we loop for the second
time, because the lock shouldn't be dropped between __wait_for_free_buffer
and __get_unclaimed_buffer.
commit 9ea61cac0b1ad0c09022f39fd97e9b99a2cfc2dc upstream.
We've seen in-field reports showing _lots_ (18 in one case, 41 in
another) of tasks all sitting there blocked on:
mutex_lock+0x4c/0x68
dm_bufio_shrink_count+0x38/0x78
shrink_slab.part.54.constprop.65+0x100/0x464
shrink_zone+0xa8/0x198
In the two cases analyzed, we see one task that looks like this:
Workqueue: kverityd verity_prefetch_io
__switch_to+0x9c/0xa8
__schedule+0x440/0x6d8
schedule+0x94/0xb4
schedule_timeout+0x204/0x27c
schedule_timeout_uninterruptible+0x44/0x50
wait_iff_congested+0x9c/0x1f0
shrink_inactive_list+0x3a0/0x4cc
shrink_lruvec+0x418/0x5cc
shrink_zone+0x88/0x198
try_to_free_pages+0x51c/0x588
__alloc_pages_nodemask+0x648/0xa88
__get_free_pages+0x34/0x7c
alloc_buffer+0xa4/0x144
__bufio_new+0x84/0x278
dm_bufio_prefetch+0x9c/0x154
verity_prefetch_io+0xe8/0x10c
process_one_work+0x240/0x424
worker_thread+0x2fc/0x424
kthread+0x10c/0x114
...and that looks to be the one holding the mutex.
The problem has been reproduced on fairly easily:
0. Be running Chrome OS w/ verity enabled on the root filesystem
1. Pick test patch: http://crosreview.com/412360
2. Install launchBalloons.sh and balloon.arm from
http://crbug.com/468342
...that's just a memory stress test app.
3. On a 4GB rk3399 machine, run
nice ./launchBalloons.sh 4 900 100000
...that tries to eat 4 * 900 MB of memory and keep accessing.
4. Login to the Chrome web browser and restore many tabs
With that, I've seen printouts like:
DOUG: long bufio 90758 ms
...and stack trace always show's we're in dm_bufio_prefetch().
The problem is that we try to allocate memory with GFP_NOIO while
we're holding the dm_bufio lock. Instead we should be using
GFP_NOWAIT. Using GFP_NOIO can cause us to sleep while holding the
lock and that causes the above problems.
The current behavior explained by David Rientjes:
It will still try reclaim initially because __GFP_WAIT (or
__GFP_KSWAPD_RECLAIM) is set by GFP_NOIO. This is the cause of
contention on dm_bufio_lock() that the thread holds. You want to
pass GFP_NOWAIT instead of GFP_NOIO to alloc_buffer() when holding a
mutex that can be contended by a concurrent slab shrinker (if
count_objects didn't use a trylock, this pattern would trivially
deadlock).
This change significantly increases responsiveness of the system while
in this state. It makes a real difference because it unblocks kswapd.
In the bug report analyzed, kswapd was hung:
kswapd0 D ffffffc000204fd8 0 72 2 0x00000000
Call trace:
[<ffffffc000204fd8>] __switch_to+0x9c/0xa8
[<ffffffc00090b794>] __schedule+0x440/0x6d8
[<ffffffc00090bac0>] schedule+0x94/0xb4
[<ffffffc00090be44>] schedule_preempt_disabled+0x28/0x44
[<ffffffc00090d900>] __mutex_lock_slowpath+0x120/0x1ac
[<ffffffc00090d9d8>] mutex_lock+0x4c/0x68
[<ffffffc000708e7c>] dm_bufio_shrink_count+0x38/0x78
[<ffffffc00030b268>] shrink_slab.part.54.constprop.65+0x100/0x464
[<ffffffc00030dbd8>] shrink_zone+0xa8/0x198
[<ffffffc00030e578>] balance_pgdat+0x328/0x508
[<ffffffc00030eb7c>] kswapd+0x424/0x51c
[<ffffffc00023f06c>] kthread+0x10c/0x114
[<ffffffc000203dd0>] ret_from_fork+0x10/0x40
By unblocking kswapd memory pressure should be reduced.
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Douglas Anderson <dianders@chromium.org>
commit 7810e6781e0fcbca78b91cf65053f895bf59e85f upstream.
In __alloc_pages_slowpath() we reset zonelist and preferred_zoneref for
allocations that can ignore memory policies. The zonelist is obtained
from current CPU's node. This is a problem for __GFP_THISNODE
allocations that want to allocate on a different node, e.g. because the
allocating thread has been migrated to a different CPU.
This has been observed to break SLAB in our 4.4-based kernel, because
there it relies on __GFP_THISNODE working as intended. If a slab page
is put on wrong node's list, then further list manipulations may corrupt
the list because page_to_nid() is used to determine which node's
list_lock should be locked and thus we may take a wrong lock and race.
Current SLAB implementation seems to be immune by luck thanks to commit
511e3a058812 ("mm/slab: make cache_grow() handle the page allocated on
arbitrary node") but there may be others assuming that __GFP_THISNODE
works as promised.
We can fix it by simply removing the zonelist reset completely. There
is actually no reason to reset it, because memory policies and cpusets
don't affect the zonelist choice in the first place. This was different
when commit 183f6371aac2 ("mm: ignore mempolicies when using
ALLOC_NO_WATERMARK") introduced the code, as mempolicies provided their
own restricted zonelists.
We might consider this for 4.17 although I don't know if there's
anything currently broken.
SLAB is currently not affected, but in kernels older than 4.7 that don't
yet have 511e3a058812 ("mm/slab: make cache_grow() handle the page
allocated on arbitrary node") it is. That's at least 4.4 LTS. Older
ones I'll have to check.
So stable backports should be more important, but will have to be
reviewed carefully, as the code went through many changes. BTW I think
that also the ac->preferred_zoneref reset is currently useless if we
don't also reset ac->nodemask from a mempolicy to NULL first (which we
probably should for the OOM victims etc?), but I would leave that for a
separate patch.
Link: http://lkml.kernel.org/r/20180525130853.13915-1-vbabka@suse.cz
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Fixes: 183f6371aac2 ("mm: ignore mempolicies when using ALLOC_NO_WATERMARK")
Acked-by: Mel Gorman <mgorman@techsingularity.net>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: <stable@vger.kernel.org>
commit 3ee9bc12342cf546313d300808ff47d7dbb8e7db upstream.
The cx25840 driver currently configures 885, 887, and 888 using
default divisors for each chip. This check to see if the cx23885
driver has passed the cx25840 a non-default clock rate for a
specific chip. If a cx23885 board has left clk_freq at 0, the
clock default values will be used to configure the PLLs.
This patch only has effect on 888 boards who set clk_freq to 25M.
Signed-off-by: Brad Love <brad@nextdimension.cc>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 40c36e2741d7fe1e66d6ec55477ba5fd19c9c5d2 upstream.
Some injection testing resulted in the following console log:
mce: [Hardware Error]: CPU 22: Machine Check Exception: f Bank 1: bd80000000100134
mce: [Hardware Error]: RIP 10:<ffffffffc05292dd> {pmem_do_bvec+0x11d/0x330 [nd_pmem]}
mce: [Hardware Error]: TSC c51a63035d52 ADDR 3234bc4000 MISC 88
mce: [Hardware Error]: PROCESSOR 0:50654 TIME 1526502199 SOCKET 0 APIC 38 microcode 2000043
mce: [Hardware Error]: Run the above through 'mcelog --ascii'
Kernel panic - not syncing: Machine check from unknown source
This confused everybody because the first line quite clearly shows
that we found a logged error in "Bank 1", while the last line says
"unknown source".
The problem is that the Linux code doesn't do the right thing
for a local machine check that results in a fatal error.
It turns out that we know very early in the handler whether the
machine check is fatal. The call to mce_no_way_out() has checked
all the banks for the CPU that took the local machine check. If
it says we must crash, we can do so right away with the right
messages.
We do scan all the banks again. This means that we might initially
not see a problem, but during the second scan find something fatal.
If this happens we print a slightly different message (so I can
see if it actually every happens).
[ bp: Remove unneeded severity assignment. ]
Signed-off-by: Tony Luck <tony.luck@intel.com>
Cc: Ashok Raj <ashok.raj@intel.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Qiuxu Zhuo <qiuxu.zhuo@intel.com>
Cc: linux-edac <linux-edac@vger.kernel.org>
Cc: stable@vger.kernel.org # 4.2
Link: http://lkml.kernel.org/r/52e049a497e86fd0b71c529651def8871c804df0.1527283897.git.tony.luck@intel.com
commit fead35c68926682c90c995f22b48f1c8d78865c1 upstream.
Check the MCG_STATUS_LMCES bit on Intel to verify that current MCE is
local. It is always local on AMD.
Signed-off-by: Yazen Ghannam <Yazen.Ghannam@amd.com>
[ Massaged it a bit. Reflowed comments. Shut up -Wmaybe-uninitialized. ]
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/1462019637-16474-8-git-send-email-bp@alien8.de
commit 717adfdaf14704fd3ec7fa2c04520c0723247eac upstream.
If our length is greater than the size of the buffer, we
overflow the buffer
Signed-off-by: Daniel Rosenberg <drosen@google.com>
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit 4f65245f2d178b9cba48350620d76faa4a098841 upstream.
uref->field_index, uref->usage_index, finfo.field_index and cinfo.index can be
indirectly controlled by user-space, hence leading to a potential exploitation
of the Spectre variant 1 vulnerability.
This issue was detected with the help of Smatch:
drivers/hid/usbhid/hiddev.c:473 hiddev_ioctl_usage() warn: potential spectre issue 'report->field' (local cap)
drivers/hid/usbhid/hiddev.c:477 hiddev_ioctl_usage() warn: potential spectre issue 'field->usage' (local cap)
drivers/hid/usbhid/hiddev.c:757 hiddev_ioctl() warn: potential spectre issue 'report->field' (local cap)
drivers/hid/usbhid/hiddev.c:801 hiddev_ioctl() warn: potential spectre issue 'hid->collection' (local cap)
Fix this by sanitizing such structure fields before using them to index
report->field, field->usage and hid->collection
Notice that given that speculation windows are large, the policy is
to kill the speculation on the first load and not worry if it can be
completed with a dependent load/store [1].
[1] https://marc.info/?l=linux-kernel&m=152449131114778&w=2
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
commit ef6eaf27274c0351f7059163918f3795da13199c upstream.
Commit ac75a041048b ("HID: i2c-hid: fix size check and type usage") started
writing messages when the ret_size is <= 2 from i2c_master_recv. However, my
device i2c-DLL07D1 returns 2 for a short period of time (~0.5s) after I stop
moving the pointing stick or touchpad. It varies, but you get ~50 messages
each time which spams the log hard.
[ 95.925055] i2c_hid i2c-DLL07D1:01: i2c_hid_get_input: incomplete report (83/2)
This has also been observed with a i2c-ALP0017.
[ 1781.266353] i2c_hid i2c-ALP0017:00: i2c_hid_get_input: incomplete report (30/2)
Only print the message when ret_size is totally invalid and less than 2 to cut
down on the log spam.
Fixes: ac75a041048b ("HID: i2c-hid: fix size check and type usage")
Reported-by: John Smith <john-s-84@gmx.net>
Signed-off-by: Jason Andryuk <jandryuk@gmail.com>
commit a17712c8e4be4fa5404d20e9cd3b2b21eae7bc56 upstream.
This patch attempts to close a hole leading to a BUG seen with hot
removals during writes [1].
A block device (NVME namespace in this test case) is formatted to EXT4
without partitions. It's mounted and write I/O is run to a file, then
the device is hot removed from the slot. The superblock attempts to be
written to the drive which is no longer present.
The typical chain of events leading to the BUG:
ext4_commit_super()
__sync_dirty_buffer()
submit_bh()
submit_bh_wbc()
BUG_ON(!buffer_mapped(bh));
This fix checks for the superblock's buffer head being mapped prior to
syncing.
[1] https://www.spinics.net/lists/linux-ext4/msg56527.html
Signed-off-by: Jon Derrick <jonathan.derrick@intel.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Cc: stable@kernel.org
commit bfe0a5f47ada40d7984de67e59a7d3390b9b9ecc upstream.
The kernel's ext4 mount-time checks were more permissive than
e2fsprogs's libext2fs checks when opening a file system. The
superblock is considered too insane for debugfs or e2fsck to operate
on it, the kernel has no business trying to mount it.
This will make file system fuzzing tools work harder, but the failure
cases that they find will be more useful and be easier to evaluate.
commit c37e9e013469521d9adb932d17a1795c139b36db upstream.
If there is a directory entry pointing to a system inode (such as a
journal inode), complain and declare the file system to be corrupted.
Also, if the superblock's first inode number field is too small,
refuse to mount the file system.
This addresses CVE-2018-10882.
https://bugzilla.kernel.org/show_bug.cgi?id=200069
commit 6e8ab72a812396996035a37e5ca4b3b99b5d214b upstream.
When converting from an inode from storing the data in-line to a data
block, ext4_destroy_inline_data_nolock() was only clearing the on-disk
copy of the i_blocks[] array. It was not clearing copy of the
i_blocks[] in ext4_inode_info, in i_data[], which is the copy actually
used by ext4_map_blocks().
This didn't matter much if we are using extents, since the extents
header would be invalid and thus the extents could would re-initialize
the extents tree. But if we are using indirect blocks, the previous
contents of the i_blocks array will be treated as block numbers, with
potentially catastrophic results to the file system integrity and/or
user data.
This gets worse if the file system is using a 1k block size and
s_first_data is zero, but even without this, the file system can get
quite badly corrupted.
This addresses CVE-2018-10881.
https://bugzilla.kernel.org/show_bug.cgi?id=200015
commit bdbd6ce01a70f02e9373a584d0ae9538dcf0a121 upstream.
commit bc890a60247171294acc0bd67d211fa4b88d40ba upstream.
If there is a corupted file system where the claimed depth of the
extent tree is -1, this can cause a massive buffer overrun leading to
sadness.
This addresses CVE-2018-10877.
https://bugzilla.kernel.org/show_bug.cgi?id=199417
commit 8844618d8aa7a9973e7b527d038a2a589665002c upstream.
The bg_flags field in the block group descripts is only valid if the
uninit_bg or metadata_csum feature is enabled. We were not
consistently looking at this field; fix this.
Also block group #0 must never have uninitialized allocation bitmaps,
or need to be zeroed, since that's where the root inode, and other
special inodes are set up. Check for these conditions and mark the
file system as corrupted if they are detected.
This addresses CVE-2018-10876.
https://bugzilla.kernel.org/show_bug.cgi?id=199403
commit 819b23f1c501b17b9694325471789e6b5cc2d0d2 upstream.
Regardless of whether the flex_bg feature is set, we should always
check to make sure the bits we are setting in the block bitmap are
within the block group bounds.
https://bugzilla.kernel.org/show_bug.cgi?id=199865
commit 77260807d1170a8cf35dbb06e07461a655f67eee upstream.
It's really bad when the allocation bitmaps and the inode table
overlap with the block group descriptors, since it causes random
corruption of the bg descriptors. So we really want to head those off
at the pass.
commit e09463f220ca9a1a1ecfda84fcda658f99a1f12a upstream.
Do not set the b_modified flag in block's journal head should not
until after we're sure that jbd2_journal_dirty_metadat() will not
abort with an error due to there not being enough space reserved in
the jbd2 handle.
Otherwise, future attempts to modify the buffer may lead a large
number of spurious errors and warnings.
This addresses CVE-2018-10883.
https://bugzilla.kernel.org/show_bug.cgi?id=200071
commit 7ffbe65578b44fafdef577a360eb0583929f7c6e upstream.
For every request we send, whether it is SMB1 or SMB2+, we attempt to
reconnect tcon (cifs_reconnect_tcon or smb2_reconnect) before carrying
out the request.
So, while server->tcpStatus != CifsNeedReconnect, we wait for the
reconnection to succeed on wait_event_interruptible_timeout(). If it
returns, that means that either the condition was evaluated to true, or
timeout elapsed, or it was interrupted by a signal.
Since we're not handling the case where the process woke up due to a
received signal (-ERESTARTSYS), the next call to
wait_event_interruptible_timeout() will _always_ fail and we end up
looping forever inside either cifs_reconnect_tcon() or smb2_reconnect().
Here's an example of how to trigger that:
$ mount.cifs //foo/share /mnt/test -o
username=foo,password=foo,vers=1.0,hard
(break connection to server before executing bellow cmd)
$ stat -f /mnt/test & sleep 140
[1] 2511
$ ps -aux -q 2511
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 2511 0.0 0.0 12892 1008 pts/0 S 12:24 0:00 stat -f
/mnt/test
$ kill -9 2511
(wait for a while; process is stuck in the kernel)
$ ps -aux -q 2511
root 2511 83.2 0.0 12892 1008 pts/0 R 12:24 30:01 stat -f
/mnt/test
By using 'hard' mount point means that cifs.ko will keep retrying
indefinitely, however we must allow the process to be killed otherwise
it would hang the system.
Signed-off-by: Paulo Alcantara <palcantara@suse.de>
Reviewed-by: Aurelien Aptel <aaptel@suse.com>
Signed-off-by: Steve French <stfrench@microsoft.com>
commit 64dafbc9530c10300acffc57fae3269d95fa8f93 upstream.
We have
struct drbd_requests { ... struct bio *private_bio; ... }
to hold a bio clone for local submission.
On local IO completion, we put that bio, and in case we want to use the
result later, we overload that member to hold the ERR_PTR() of the
completion result,
Which, before v4.3, used to be the passed in "int error",
so we could first bio_put(), then assign.
v4.3-rc1~100^2~21 4246a0b63bd8 block: add a bi_error field to struct bio
changed that:
bio_put(req->private_bio);
- req->private_bio = ERR_PTR(error);
+ req->private_bio = ERR_PTR(bio->bi_error);
Which introduces an access after free,
because it was non obvious that req->private_bio == bio.
Impact of that was mostly unnoticable, because we only use that value
in a multiple-failure case, and even then map any "unexpected" error
code to EIO, so worst case we could potentially mask a more specific
error with EIO in a multiple failure case.
Unless the pointed to memory region was unmapped, as is the case with
CONFIG_DEBUG_PAGEALLOC, in which case this results in
BUG: unable to handle kernel paging request
v4.13-rc1~70^2~75 4e4cbee93d56 block: switch bios to blk_status_t
changes it further to
req->private_bio = ERR_PTR(blk_status_to_errno(bio->bi_status));
And blk_status_to_errno() now contains a WARN_ON_ONCE() for unexpected
values, which catches this "sometimes", if the memory has been reused
quickly enough for other things.
Should also go into stable since 4.3, with the trivial change around 4.13.
Fixes: 4246a0b63bd8 block: add a bi_error field to struct bio
Reported-by: Sarah Newman <srn@prgmr.com>
Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
commit 891f6a726cacbb87e5b06076693ffab53bd378d7 upstream.
In the critical section cleanup we must not mess with r1. For march=z9
or older, larl + ex (instead of exrl) are used with r1 as a temporary
register. This can clobber r1 in several interrupt handlers. Fix this by
using r11 as a temp register. r11 is being saved by all callers of
cleanup_critical.
Fixes: 6dd85fbb87 ("s390: move expoline assembler macros to a header")
Cc: stable@vger.kernel.org #v4.16
Reported-by: Oliver Kurz <okurz@suse.com>
Reported-by: Petr Tesařík <ptesarik@suse.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Reviewed-by: Hendrik Brueckner <brueckner@linux.ibm.com>
commit 26b5b874aff5659a7e26e5b1997e3df2c41fa7fd upstream.
As Al Viro noted in commit 128394eff343 ("sg_write()/bsg_write() is not fit
to be called under KERNEL_DS"), sg improperly accesses userspace memory
outside the provided buffer, permitting kernel memory corruption via
splice(). But it doesn't just do it on ->write(), also on ->read().
As a band-aid, make sure that the ->read() and ->write() handlers can not
be called in weird contexts (kernel context or credentials different from
file opener), like for ib_safe_file_access().
If someone needs to use these interfaces from different security contexts,
a new interface should be written that goes through the ->ioctl() handler.
I've mostly copypasted ib_safe_file_access() over as sg_safe_file_access()
because I couldn't find a good common header - please tell me if you know a
better way.
[mkp: s/_safe_/_check_/]
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Acked-by: Douglas Gilbert <dgilbert@interlog.com>
commit 1fe4293f4b8de75824935f8d8e9a99c7fc6873da upstream.
The function_graph tracer does not show the interrupt return marker for the
leaf entry. On leaf entries, we see an unbalanced interrupt marker (the
interrupt was entered, but nevern left).
Before:
1) | SyS_write() {
1) | __fdget_pos() {
1) 0.061 us | __fget_light();
1) 0.289 us | }
1) | vfs_write() {
1) 0.049 us | rw_verify_area();
1) + 15.424 us | __vfs_write();
1) ==========> |
1) 6.003 us | smp_apic_timer_interrupt();
1) 0.055 us | __fsnotify_parent();
1) 0.073 us | fsnotify();
1) + 23.665 us | }
1) + 24.501 us | }
After:
0) | SyS_write() {
0) | __fdget_pos() {
0) 0.052 us | __fget_light();
0) 0.328 us | }
0) | vfs_write() {
0) 0.057 us | rw_verify_area();
0) | __vfs_write() {
0) ==========> |
0) 8.548 us | smp_apic_timer_interrupt();
0) <========== |
0) + 36.507 us | } /* __vfs_write */
0) 0.049 us | __fsnotify_parent();
0) 0.066 us | fsnotify();
0) + 50.064 us | }
0) + 50.952 us | }
Link: http://lkml.kernel.org/r/1517413729-20411-1-git-send-email-changbin.du@intel.com
Fixes: f8b755ac8e0cc ("tracing/function-graph-tracer: Output arrows signal on hardirq call/return")
Signed-off-by: Changbin Du <changbin.du@intel.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 520495fe96d74e05db585fc748351e0504d8f40d upstream.
When booting with very large numbers of gigantic (i.e. 1G) pages, the
operations in the loop of gather_bootmem_prealloc, and specifically
prep_compound_gigantic_page, takes a very long time, and can cause a
softlockup if enough pages are requested at boot.
For example booting with 3844 1G pages requires prepping
(set_compound_head, init the count) over 1 billion 4K tail pages, which
takes considerable time.
Add a cond_resched() to the outer loop in gather_bootmem_prealloc() to
prevent this lockup.
Tested: Booted with softlockup_panic=1 hugepagesz=1G hugepages=3844 and
no softlockup is reported, and the hugepages are reported as
successfully setup.
Link: http://lkml.kernel.org/r/20180627214447.260804-1-cannonmatthews@google.com
Signed-off-by: Cannon Matthews <cannonmatthews@google.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Andres Lagar-Cavilla <andreslc@google.com>
Cc: Peter Feiner <pfeiner@google.com>
commit 781932375ffc6411713ee0926ccae8596ed0261c upstream.
Fastmap cannot track the LEB unmap operation, therefore it can
happen that after an interrupted erasure the mapping still looks
good from Fastmap's point of view, while reading from the PEB will
cause an ECC error and confuses the upper layer.
Instead of teaching users of UBI how to deal with that, we read back
the VID header and check for errors. If the PEB is empty or shows ECC
errors we fixup the mapping and schedule the PEB for erasure.
Fixes: dbb7d2a88d2a ("UBI: Add fastmap core")
Reported-by: martin bayern <Martinbayern@outlook.com>
Signed-off-by: Richard Weinberger <richard@nod.at>
commit df07101e1c4a29e820df02f9989a066988b160e6 upstream.
According to the reference manual the shp_2_mcu / mcu_2_shp
scripts must be used for devices connected through the SPBA.
This fixes an issue we saw with DMA transfers.
Sometimes the SPI controller RX FIFO was not empty after a DMA
transfer and the driver got stuck in the next PIO transfer when
it read one word more than expected.
commit dd4b487b32a35 ("ARM: dts: imx6: Use correct SDMA script
for SPI cores") is fixing the same issue but only for SPI1 - 4.
Fixes: 677940258dd8e ("ARM: dts: imx6q: enable dma for ecspi5")
Signed-off-by: Sean Nyekjaer <sean.nyekjaer@prevas.dk>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
commit adc972c5b88829d38ede08b1069718661c7330ae upstream.
When depth of chain is bigger than NFT_JUMP_STACK_SIZE, the nft_do_chain
crashes. But there is no need to crash hard here.
Suggested-by: Florian Westphal <fw@strlen.de>
Signed-off-by: Taehee Yoo <ap420073@gmail.com>
Acked-by: Florian Westphal <fw@strlen.de>
commit 161b8be2bd6abad250d4b3f674bdd5480f15beeb upstream.
A spurious interrupt before the nvme driver has initialized the completion
queue may inadvertently cause the driver to believe it has a completion
to process. This may result in a NULL dereference since the nvmeq's tags
are not set at this point.
The patch initializes the host's CQ memory so that a spurious interrupt
isn't mistaken for a real completion.
Signed-off-by: Keith Busch <keith.busch@intel.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
[bwh: Backported to 4.4: adjust context]
commit 804dec5bda9b4fcdab5f67fe61db4a0498af5221 upstream.
Do not modify singlestep execution buffer (kprobe.ainsn.insn)
while resuming from single-stepping, instead, modifies
the buffer to add a jump back instruction at preparing
buffer.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Cc: David S . Miller <davem@davemloft.net>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Ye Xiaolong <xiaolong.ye@intel.com>
Link: http://lkml.kernel.org/r/149076361560.22469.1610155860343077495.stgit@devbox
Reviewed-by: "Steven Rostedt (VMware)" <rostedt@goodmis.org>
Signed-off-by: Alexey Makhalov <amakhalov@vmware.com>
The validation code modified by commit 5b5e7a0de2bb ("net: metrics:
add proper netlink validation") is organised differently in older
kernel versions. The fib_convert_metrics() function that is modified
in the backports to 4.4 and 4.9 needs to returns an error code, not a
success flag.
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit ae481cc139658e89eb3ea671dd00b67bd87f01a3 upstream.
Resume failed because of uninitialized registers. Instead of adding a
resume callback, we simply initialize registers before every transfer.
This lightweight change is more robust and will keep us safe if we ever
need support for power domains or dynamic frequency changes.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit 2f38c3c01de945234d23dd163e3528ccb413066d upstream.
Chipset from QCA99X0 onwards (QCA99X0, QCA9984, QCA4019 & future)
rx_hdr_status is not padded to align in 4-byte boundary. Define a
new hw_params field to handle different alignment behaviour between
different hw. This patch fixes improper retrieval of rfc1042 header
with QCA4019. This patch along with "ath10k: Properly remove padding
from the start of rx payload" will fix traffic failure in ethernet
decap mode for QCA4019.
Signed-off-by: Vasanthakumar Thiagarajan <vthiagar@qti.qualcomm.com>
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
[bwh: This just adds the part that was left out of the previous backport,
commit b88fb9ea475a.]
commit 02afeaae9843733a39cd9b11053748b2d1dc5ae7 upstream.
The x86 early command line parsing in cmdline_find_option_bool() is
buggy. If it matches a specified 'option' all the way to the end of the
command-line, it will consider it a match.
For instance,
cmdline = "foo";
cmdline_find_option_bool(cmdline, "fool");
will return 1. This is particularly annoying since we have actual FPU
options like "noxsave" and "noxsaves" So, command-line "foo bar noxsave"
will match *BOTH* a "noxsave" and "noxsaves". (This turns out not to be
an actual problem because "noxsave" implies "noxsaves", but it's still
confusing.)
To fix this, we simplify the code and stop tracking 'len'. 'len'
was trying to indicate either the NULL terminator *OR* the end of a
non-NULL-terminated command line at 'COMMAND_LINE_SIZE'. But, each of the
three states is *already* checking 'cmdline' for a NULL terminator.
We _only_ need to check if we have overrun 'COMMAND_LINE_SIZE', and that
we can do without keeping 'len' around.
Also add some commends to clarify what is going on.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: fenghua.yu@intel.com
Cc: yu-cheng.yu@intel.com
Link: http://lkml.kernel.org/r/20151222225238.9AEB560C@viggo.jf.intel.com
commit ebec3f8f5271139df618ebdf8427e24ba102ba94 upstream.
syzbot is reporting stalls at __process_echoes() [1]. This is because
since ldata->echo_commit < ldata->echo_tail becomes true for some reason,
the discard loop is serving as almost infinite loop. This patch tries to
avoid falling into ldata->echo_commit < ldata->echo_tail situation by
making access to echo_* variables more carefully.
Since reset_buffer_flags() is called without output_lock held, it should
not touch echo_* variables. And omit a call to reset_buffer_flags() from
n_tty_open() by using vzalloc().
Since add_echo_byte() is called without output_lock held, it needs memory
barrier between storing into echo_buf[] and incrementing echo_head counter.
echo_buf() needs corresponding memory barrier before reading echo_buf[].
Lack of handling the possibility of not-yet-stored multi-byte operation
might be the reason of falling into ldata->echo_commit < ldata->echo_tail
situation, for if I do WARN_ON(ldata->echo_commit == tail + 1) prior to
echo_buf(ldata, tail + 1), the WARN_ON() fires.
Also, explicitly masking with buffer for the former "while" loop, and
use ldata->echo_commit > tail for the latter "while" loop.
[1] https://syzkaller.appspot.com/bug?id=17f23b094cd80df750e5b0f8982c521ee6bcbf40
Reported-by: syzbot <syzbot+108696293d7a21ab688f@syzkaller.appspotmail.com>
Cc: Peter Hurley <peter@hurleysoftware.com>
Cc: stable <stable@vger.kernel.org>
commit 0a2bc00341dcfcc793c0dbf4f8d43adf60458b05 upstream.
The expected return value from ion_map_kernel is an ERR_PTR. The error
path for a vmalloc failure currently just returns NULL, triggering
a warning in ion_buffer_kmap_get. Encode the vmalloc failure as an ERR_PTR.
Reported-by: syzbot+55b1d9f811650de944c6@syzkaller.appspotmail.com
Signed-off-by: Laura Abbott <labbott@redhat.com>
commit 3d63b7e4ae0dc5e02d28ddd2fa1f945defc68d81 upstream.
syzbot is reporting stalls at n_tty_receive_char_special() [1]. This is
because comparison is not working as expected since ldata->read_head can
change at any moment. Mitigate this by explicitly masking with buffer size
when checking condition for "while" loops.
[1] https://syzkaller.appspot.com/bug?id=3d7481a346958d9469bebbeb0537d5f056bdd6e8
Reported-by: syzbot <syzbot+18df353d7540aa6b5467@syzkaller.appspotmail.com>
Fixes: bc5a5e3f45d04784 ("n_tty: Don't wrap input buffer indices at buffer size")
commit 2f839823382748664b643daa73f41ee0cc01ced6 upstream.
Silicon Labs defines alternative VID/PID pairs for some chips that when
used will automatically install drivers for Windows users without manual
intervention. Unfortunately, these IDs are not recognized by the Linux
module, so using these IDs improves user experience on one platform but
degrades it on Linux. This patch addresses this problem.
Signed-off-by: Karoly Pados <pados@pados.hu>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 24160628a34af962ac99f2f58e547ac3c4cbd26f upstream.
Add device ids for CESINEL products.
Reported-by: Carlos Barcala Lara <cabl@cesinel.com>
commit 4a762569a2722b8a48066c7bacf0e1dc67d17fa1 upstream.
Uniden UBC125 radio scanner has USB interface which fails to work
with cdc_acm driver:
usb 1-1.5: new full-speed USB device number 4 using xhci_hcd
cdc_acm 1-1.5:1.0: Zero length descriptor references
cdc_acm: probe of 1-1.5:1.0 failed with error -22
Adding the NO_UNION_NORMAL quirk for the device fixes the issue:
usb 1-4: new full-speed USB device number 15 using xhci_hcd
usb 1-4: New USB device found, idVendor=1965, idProduct=0018
usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-4: Product: UBC125XLT
usb 1-4: Manufacturer: Uniden Corp.
usb 1-4: SerialNumber: 0001
cdc_acm 1-4:1.0: ttyACM0: USB ACM device
`lsusb -v` of the device:
Bus 001 Device 015: ID 1965:0018 Uniden Corporation
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 2 Communications
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x1965 Uniden Corporation
idProduct 0x0018
bcdDevice 0.01
iManufacturer 1 Uniden Corp.
iProduct 2 UBC125XLT
iSerial 3 0001
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 48
bNumInterfaces 2
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 2 Communications
bInterfaceSubClass 2 Abstract (modem)
bInterfaceProtocol 0 None
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x87 EP 7 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 10
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 10 CDC Data
bInterfaceSubClass 0 Unused
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Status: 0x0000
(Bus Powered)
Signed-off-by: Houston Yaroschoff <hstn@4ever3.net>
Acked-by: Oliver Neukum <oneukum@suse.com>
commit 082f2300cfa1a3d9d5221c38c5eba85d4ab98bd8 upstream.
Local random address needs to be updated before creating connection if
RPA from LE Direct Advertising Report was resolved in host. Otherwise
remote device might ignore connection request due to address mismatch.
This was affecting following qualification test cases:
GAP/CONN/SCEP/BV-03-C, GAP/CONN/GCEP/BV-05-C, GAP/CONN/DCEP/BV-05-C
Before patch:
< HCI Command: LE Set Random Address (0x08|0x0005) plen 6 #11350 [hci0] 84680.231216
Address: 56:BC:E8:24:11:68 (Resolvable)
Identity type: Random (0x01)
Identity: F2:F1:06:3D:9C:42 (Static)
> HCI Event: Command Complete (0x0e) plen 4 #11351 [hci0] 84680.246022
LE Set Random Address (0x08|0x0005) ncmd 1
Status: Success (0x00)
< HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7 #11352 [hci0] 84680.246417
Type: Passive (0x00)
Interval: 60.000 msec (0x0060)
Window: 30.000 msec (0x0030)
Own address type: Random (0x01)
Filter policy: Accept all advertisement, inc. directed unresolved RPA (0x02)
> HCI Event: Command Complete (0x0e) plen 4 #11353 [hci0] 84680.248854
LE Set Scan Parameters (0x08|0x000b) ncmd 1
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2 #11354 [hci0] 84680.249466
Scanning: Enabled (0x01)
Filter duplicates: Enabled (0x01)
> HCI Event: Command Complete (0x0e) plen 4 #11355 [hci0] 84680.253222
LE Set Scan Enable (0x08|0x000c) ncmd 1
> HCI Event: LE Meta Event (0x3e) plen 18 #11356 [hci0] 84680.458387
LE Direct Advertising Report (0x0b)
Num reports: 1
Event type: Connectable directed - ADV_DIRECT_IND (0x01)
Address type: Random (0x01)
Address: 53:38:DA:46:8C:45 (Resolvable)
Identity type: Public (0x00)
Identity: 11:22:33:44:55:66 (OUI 11-22-33)
Direct address type: Random (0x01)
Direct address: 7C:D6:76:8C:DF:82 (Resolvable)
RSSI: -74 dBm (0xb6)
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2 #11357 [hci0] 84680.458737
Scanning: Disabled (0x00)
Filter duplicates: Disabled (0x00)
> HCI Event: Command Complete (0x0e) plen 4 #11358 [hci0] 84680.469982
< HCI Command: LE Create Connection (0x08|0x000d) plen 25 #11359 [hci0] 84680.470444
Scan interval: 60.000 msec (0x0060)
Scan window: 60.000 msec (0x0060)
Filter policy: White list is not used (0x00)
Peer address type: Random (0x01)
Peer address: 53:38:DA:46:8C:45 (Resolvable)
Min connection interval: 30.00 msec (0x0018)
Max connection interval: 50.00 msec (0x0028)
Connection latency: 0 (0x0000)
Supervision timeout: 420 msec (0x002a)
Min connection length: 0.000 msec (0x0000)
Max connection length: 0.000 msec (0x0000)
> HCI Event: Command Status (0x0f) plen 4 #11360 [hci0] 84680.474971
LE Create Connection (0x08|0x000d) ncmd 1
< HCI Command: LE Create Connection Cancel (0x08|0x000e) plen 0 #11361 [hci0] 84682.545385
> HCI Event: Command Complete (0x0e) plen 4 #11362 [hci0] 84682.551014
LE Create Connection Cancel (0x08|0x000e) ncmd 1
> HCI Event: LE Meta Event (0x3e) plen 19 #11363 [hci0] 84682.551074
LE Connection Complete (0x01)
Status: Unknown Connection Identifier (0x02)
Handle: 0
Role: Master (0x00)
Peer address type: Public (0x00)
Peer address: 00:00:00:00:00:00 (OUI 00-00-00)
Connection interval: 0.00 msec (0x0000)
Supervision timeout: 0 msec (0x0000)
Master clock accuracy: 0x00
After patch:
< HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7 #210 [hci0] 667.152459
> HCI Event: Command Complete (0x0e) plen 4 #211 [hci0] 667.153613
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2 #212 [hci0] 667.153704
> HCI Event: Command Complete (0x0e) plen 4 #213 [hci0] 667.154584
> HCI Event: LE Meta Event (0x3e) plen 18 #214 [hci0] 667.182619
Num reports: 1
Address: 50:52:D9:A6:48:A0 (Resolvable)
Direct address: 7C:C1:57:A5:B7:A8 (Resolvable)
Identity: F4:28:73:5D:38:B0 (Static)
RSSI: -70 dBm (0xba)
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2 #215 [hci0] 667.182704
> HCI Event: Command Complete (0x0e) plen 4 #216 [hci0] 667.183599
< HCI Command: LE Set Random Address (0x08|0x0005) plen 6 #217 [hci0] 667.183645
Address: 7C:C1:57:A5:B7:A8 (Resolvable)
> HCI Event: Command Complete (0x0e) plen 4 #218 [hci0] 667.184590
< HCI Command: LE Create Connection (0x08|0x000d) plen 25 #219 [hci0] 667.184613
Peer address: 50:52:D9:A6:48:A0 (Resolvable)
> HCI Event: Command Status (0x0f) plen 4 #220 [hci0] 667.186558
> HCI Event: LE Meta Event (0x3e) plen 19 #221 [hci0] 667.485824
Handle: 0
Role: Master (0x00)
Connection interval: 50.00 msec (0x0028)
Master clock accuracy: 0x07
@ MGMT Event: Device Connected (0x000b) plen 13 {0x0002} [hci0] 667.485996
LE Address: 11:22:33:44:55:66 (OUI 11-22-33)
Flags: 0x00000000
Data length: 0
Signed-off-by: Szymon Janc <szymon.janc@codecoup.pl>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
