commit 403dff4e2c94f275e24fd85f40b2732ffec268a1 upstream.
We need to check that we have both a valid data and control inteface for both
types of headers (union and not union.)
References: https://bugzilla.kernel.org/show_bug.cgi?id=83551
Reported-by: Simon Schubert <2+kernel@0x2c.org>
commit c507de88f6a336bd7296c9ec0073b2d4af8b4f5e upstream.
stac_store_hints() does utterly wrong for masking the values for
gpio_dir and gpio_data, likely due to copy&paste errors. Fortunately,
this feature is used very rarely, so the impact must be really small.
Reported-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
commit 69eba10e606a80665f8573221fec589430d9d1cb upstream.
In olden times the snd_hda_param_read() function always set "*start_id"
but in 2007 we introduced a new return and it causes uninitialized data
bugs in a couple of the callers: print_codec_info() and
hdmi_parse_codec().
Fixes: e8a7f136f5ed ('[ALSA] hda-intel - Improve HD-audio codec probing robustness')
commit d70a1b9893f820fdbcdffac408c909c50f2e6b43 upstream.
The Arcam rPAC seems to have the same problem - whenever anything
(alsamixer, udevd, 3.9+ kernel from 60af3d037eb8c, ..) attempts to
access mixer / control interface of the card, the firmware "locks up"
the entire device, resulting in
SNDRV_PCM_IOCTL_HW_PARAMS failed (-5): Input/output error
from alsa-lib.
Other operating systems can somehow read the mixer (there seems to be
playback volume/mute), but any manipulation is ignored by the device
(which has hardware volume controls).
Signed-off-by: Jiri Jaburek <jjaburek@redhat.com>
commit bb34cb6bbd287b57e955bc5cfd42fcde6aaca279 upstream.
bus_find_device_by_name() acquires a device reference which is never
released. This results in an object leak, which on older kernels
results in failure to release all resources of PCI devices. libvirt
uses drivers_probe to re-attach devices to the host after assignment
and is therefore a common trigger for this leak.
Example:
# cd /sys/bus/pci/
# dmesg -C
# echo 1 > devices/0000\:01\:00.0/sriov_numvfs
# echo 0 > devices/0000\:01\:00.0/sriov_numvfs
# dmesg | grep 01:10
pci 0000:01:10.0: [8086:10ca] type 00 class 0x020000
kobject: '0000:01:10.0' (ffff8801d79cd0a8): kobject_add_internal: parent: '0000:00:01.0', set: 'devices'
kobject: '0000:01:10.0' (ffff8801d79cd0a8): kobject_uevent_env
kobject: '0000:01:10.0' (ffff8801d79cd0a8): fill_kobj_path: path = '/devices/pci0000:00/0000:00:01.0/0000:01:10.0'
kobject: '0000:01:10.0' (ffff8801d79cd0a8): kobject_cleanup, parent (null)
kobject: '0000:01:10.0' (ffff8801d79cd0a8): calling ktype release
kobject: '0000:01:10.0': free name
[kobject freed as expected]
# dmesg -C
# echo 0000:01:10.0 > drivers_probe
kobject: '0000:01:10.0' (ffff8801d79ce0a8): kobject_add_internal: parent: '0000:00:01.0', set: 'devices'
kobject: '0000:01:10.0' (ffff8801d79ce0a8): kobject_uevent_env
kobject: '0000:01:10.0' (ffff8801d79ce0a8): fill_kobj_path: path = '/devices/pci0000:00/0000:00:01.0/0000:01:10.0'
[no free]
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
commit 1ddf0b1b11aa8a90cef6706e935fc31c75c406ba upstream.
In Linux 3.18 and below, GCC hoists the lsl instructions in the
pvclock code all the way to the beginning of __vdso_clock_gettime,
slowing the non-paravirt case significantly. For unknown reasons,
presumably related to the removal of a branch, the performance issue
is gone as of
e76b027e6408 x86,vdso: Use LSL unconditionally for vgetcpu
but I don't trust GCC enough to expect the problem to stay fixed.
There should be no correctness issue, because the __getcpu calls in
__vdso_vlock_gettime were never necessary in the first place.
Note to stable maintainers: In 3.18 and below, depending on
configuration, gcc 4.9.2 generates code like this:
9c3: 44 0f 03 e8 lsl %ax,%r13d
9c7: 45 89 eb mov %r13d,%r11d
9ca: 0f 03 d8 lsl %ax,%ebx
This patch won't apply as is to any released kernel, but I'll send a
trivial backported version if needed.
Backported by Andy Lutomirski. Should apply to all affected
versions. This fixes a functionality bug as well as a performance
bug: buggy kernels can infinite loop in __vdso_clock_gettime on
affected compilers. See, for exammple:
https://bugzilla.redhat.com/show_bug.cgi?id=1178975
Fixes: 51c19b4f5927 x86: vdso: pvclock gettime support
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
commit 394f56fe480140877304d342dec46d50dc823d46 upstream.
The theory behind vdso randomization is that it's mapped at a random
offset above the top of the stack. To avoid wasting a page of
memory for an extra page table, the vdso isn't supposed to extend
past the lowest PMD into which it can fit. Other than that, the
address should be a uniformly distributed address that meets all of
the alignment requirements.
The current algorithm is buggy: the vdso has about a 50% probability
of being at the very end of a PMD. The current algorithm also has a
decent chance of failing outright due to incorrect handling of the
case where the top of the stack is near the top of its PMD.
This fixes the implementation. The paxtest estimate of vdso
"randomisation" improves from 11 bits to 18 bits. (Disclaimer: I
don't know what the paxtest code is actually calculating.)
It's worth noting that this algorithm is inherently biased: the vdso
is more likely to end up near the end of its PMD than near the
beginning. Ideally we would either nix the PMD sharing requirement
or jointly randomize the vdso and the stack to reduce the bias.
In the mean time, this is a considerable improvement with basically
no risk of compatibility issues, since the allowed outputs of the
algorithm are unchanged.
As an easy test, doing this:
for i in `seq 10000`
do grep -P vdso /proc/self/maps |cut -d- -f1
done |sort |uniq -d
used to produce lots of output (1445 lines on my most recent run).
A tiny subset looks like this:
7fffdfffe000
7fffe01fe000
7fffe05fe000
7fffe07fe000
7fffe09fe000
7fffe0bfe000
7fffe0dfe000
Note the suspicious fe000 endings. With the fix, I get a much more
palatable 76 repeated addresses.
commit 2bacedada682d5485424f5227f27a3d5d6eb551c upstream.
New Genius MousePen i608X devices have a new id 0x501a instead of the
old 0x5011 so add a new #define with "_2" appended and change required
places.
The remaining two checkpatch warnings about line length
being over 80 characters are present in the original files too and this
patch was made in the same style (no line break).
Just adding a new id and changing the required places should make the
new device work without any issues according to the bug report in the
following url.
This patch was made according to and fixes:
https://bugzilla.kernel.org/show_bug.cgi?id=67111
Signed-off-by: Giedrius Statkevičius <giedrius.statkevicius@gmail.com>
commit da940db41dcf8c04166f711646df2f35376010aa upstream.
Apple bluetooth wireless keyboard (sold in UK) has always reported zero
for battery strength no matter what condition the batteries are actually
in. With this patch applied (applying same quirk as other Apple
keyboards), the battery strength is now correctly reported.
Signed-off-by: Karl Relton <karllinuxtest.relton@ntlworld.com>
commit 606185b20caf4c57d7e41e5a5ea4aff460aef2ab upstream.
This is a static checker fix. We write some binary settings to the
sysfs file. One of the settings is the "->startup_profile". There
isn't any checking to make sure it fits into the
pyra->profile_settings[] array in the profile_activated() function.
I added a check to pyra_sysfs_write_settings() in both places because
I wasn't positive that the other callers were correct.
commit d1c7e29e8d276c669e8790bb8be9f505ddc48888 upstream.
Before ->start() is called, bufsize size is set to HID_MIN_BUFFER_SIZE,
64 bytes. While processing the IRQ, we were asking to receive up to
wMaxInputLength bytes, which can be bigger than 64 bytes.
Later, when ->start is run, a proper bufsize will be calculated.
Given wMaxInputLength is said to be unreliable in other part of the
code, set to receive only what we can even if it results in truncated
reports.
Signed-off-by: Gwendal Grignou <gwendal@chromium.org>
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit 6296f4a8eb86f9abcc370fb7a1a116b8441c17fd upstream.
Current driver uses a common buffer for reading reports either
synchronously in i2c_hid_get_raw_report() and asynchronously in
the interrupt handler.
There is race condition if an interrupt arrives immediately after
the report is received in i2c_hid_get_raw_report(); the common
buffer is modified by the interrupt handler with the new report
and then i2c_hid_get_raw_report() proceed using wrong data.
Fix it by using a separate buffers for synchronous reports.
Signed-off-by: Jean-Baptiste Maneyrol <jmaneyrol@invensense.com>
[Antonio Borneo: cleanup, rebase to v3.17, submit mainline]
Signed-off-by: Antonio Borneo <borneo.antonio@gmail.com>
commit cc4f14aa170d895c9a43bdb56f62070c8a6da908 upstream.
There's an off-by-one bug in function __domain_mapping(), which may
trigger the BUG_ON(nr_pages < lvl_pages) when
(nr_pages + 1) & superpage_mask == 0
The issue was introduced by commit 9051aa0268dc "intel-iommu: Combine
domain_pfn_mapping() and domain_sg_mapping()", which sets sg_res to
"nr_pages + 1" to avoid some of the 'sg_res==0' code paths.
It's safe to remove extra "+1" because sg_res is only used to calculate
page size now.
Reported-And-Tested-by: Sudeep Dutt <sudeep.dutt@intel.com>
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
Acked-By: David Woodhouse <David.Woodhouse@intel.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
commit aa5ad3b6eb8feb2399a5d26c8fb0060561bb9534 upstream.
If the erase worker is unable to erase a PEB it will
free the ubi_wl_entry itself.
The failing ubi_wl_entry must not free()'d again after
do_sync_erase() returns.
Signed-off-by: Richard Weinberger <richard@nod.at>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
commit f38aed975c0c3645bbdfc5ebe35726e64caaf588 upstream.
The logic of vfree()'ing vol->upd_buf is tied to vol->updating.
In ubi_start_update() vol->updating is set long before vmalloc()'ing
vol->upd_buf. If we encounter a write failure in ubi_start_update()
before vmalloc() the UBI device release function will try to vfree()
vol->upd_buf because vol->updating is set.
Fix this by allocating vol->upd_buf directly after setting vol->updating.
Fixes:
[ 31.559338] UBI warning: vol_cdev_release: update of volume 2 not finished, volume is damaged
[ 31.559340] ------------[ cut here ]------------
[ 31.559343] WARNING: CPU: 1 PID: 2747 at mm/vmalloc.c:1446 __vunmap+0xe3/0x110()
[ 31.559344] Trying to vfree() nonexistent vm area (ffffc90001f2b000)
[ 31.559345] Modules linked in:
[ 31.565620] 0000000000000bba ffff88002a0cbdb0 ffffffff818f0497 ffff88003b9ba148
[ 31.566347] ffff88002a0cbde0 ffffffff8156f515 ffff88003b9ba148 0000000000000bba
[ 31.567073] 0000000000000000 0000000000000000 ffff88002a0cbe88 ffffffff8156c10a
[ 31.567793] Call Trace:
[ 31.568034] [<ffffffff818f0497>] dump_stack+0x4e/0x7a
[ 31.568510] [<ffffffff8156f515>] ubi_io_write_vid_hdr+0x155/0x160
[ 31.569084] [<ffffffff8156c10a>] ubi_eba_write_leb+0x23a/0x870
[ 31.569628] [<ffffffff81569b36>] vol_cdev_write+0x226/0x380
[ 31.570155] [<ffffffff81179265>] vfs_write+0xb5/0x1f0
[ 31.570627] [<ffffffff81179f8a>] SyS_pwrite64+0x6a/0xa0
[ 31.571123] [<ffffffff818fde12>] system_call_fastpath+0x16/0x1b
commit 027bc8b08242c59e19356b4b2c189f2d849ab660 upstream.
On some ARMs the memory can be mapped pgprot_noncached() and still
be working for atomic operations. As pointed out by Colin Cross
<ccross@android.com>, in some cases you do want to use
pgprot_noncached() if the SoC supports it to see a debug printk
just before a write hanging the system.
On ARMs, the atomic operations on strongly ordered memory are
implementation defined. So let's provide an optional kernel parameter
for configuring pgprot_noncached(), and use pgprot_writecombine() by
default.
Cc: Rob Herring <robherring2@gmail.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Anton Vorontsov <anton@enomsg.org>
Cc: Colin Cross <ccross@android.com>
Cc: Olof Johansson <olof@lixom.net>
Signed-off-by: Tony Luck <tony.luck@intel.com>
commit 7ae9cb81933515dc7db1aa3c47ef7653717e3090 upstream.
Currently trying to use pstore on at least ARMs can hang as we're
mapping the peristent RAM with pgprot_noncached().
On ARMs, pgprot_noncached() will actually make the memory strongly
ordered, and as the atomic operations pstore uses are implementation
defined for strongly ordered memory, they may not work. So basically
atomic operations have undefined behavior on ARM for device or strongly
ordered memory types.
Let's fix the issue by using write-combine variants for mappings. This
corresponds to normal, non-cacheable memory on ARM. For many other
architectures, this change does not change the mapping type as by
default we have:
#define pgprot_writecombine pgprot_noncached
The reason why pgprot_noncached() was originaly used for pstore
is because Colin Cross <ccross@android.com> had observed lost
debug prints right before a device hanging write operation on some
systems. For the platforms supporting pgprot_noncached(), we can
add a an optional configuration option to support that. But let's
get pstore working first before adding new features.
Cc: Anton Vorontsov <cbouatmailru@gmail.com>
[tony@atomide.com: updated description]
commit 36e8164882ca6d3c41cb91e6f09a3ed236841f80 upstream.
Commit 6ac665c63dca ("PCI: rewrite PCI BAR reading code") masked off
low-order bits from 'l', but not from 'sz'. Both are passed to pci_size(),
which compares 'base == maxbase' to check for read-only BARs. The masking
of 'l' means that comparison will never be 'true', so the check for
read-only BARs no longer works.
Resolve this by also masking off the low-order bits of 'sz' before passing
it into pci_size() as 'maxbase'. With this change, pci_size() will once
again catch the problems that have been encountered to date:
- AGP aperture BAR of AMD-7xx host bridges: if the AGP window is
disabled, this BAR is read-only and read as 0x00000008 [1]
- BARs 0-4 of ALi IDE controllers can be non-zero and read-only [1]
- Intel Sandy Bridge - Thermal Management Controller [8086:0103];
BAR 0 returning 0xfed98004 [2]
- Intel Xeon E5 v3/Core i7 Power Control Unit [8086:2fc0];
Bar 0 returning 0x00001a [3]
Link: [1] https://git.kernel.org/cgit/linux/kernel/git/tglx/history.git/commit/drivers/pci/probe.c?id=1307ef6621991f1c4bc3cec1b5a4ebd6fd3d66b9 ("PCI: probing read-only BARs" (pre-git))
Link: [2] https://bugzilla.kernel.org/show_bug.cgi?id=43331
Link: [3] https://bugzilla.kernel.org/show_bug.cgi?id=85991
Reported-by: William Unruh <unruh@physics.ubc.ca>
Reported-by: Martin Lucina <martin@lucina.net>
Signed-off-by: Myron Stowe <myron.stowe@redhat.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
CC: Matthew Wilcox <willy@linux.intel.com>
commit 3475c3d034d7f276a474c8bd53f44b48c8bf669d upstream.
Flush the FIFOs when the stream is prepared for use. This avoids
an inadvertent swapping of the left/right channels if the FIFOs are
not empty at startup.
Signed-off-by: Andrew Jackson <Andrew.Jackson@arm.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit 48826ee590da03e9882922edf96d8d27bdfe9552 upstream.
Commit 5fe5b767dc6f ("ASoC: dapm: Do not pretend to support controls for non
mixer/mux widgets") revealed ill-defined control in a route between
"STENL Mux" and DACs in max98090.c:
max98090 i2c-193C9890:00: Control not supported for path STENL Mux -> [NULL] -> DACL
max98090 i2c-193C9890:00: ASoC: no dapm match for STENL Mux --> NULL --> DACL
max98090 i2c-193C9890:00: ASoC: Failed to add route STENL Mux -> NULL -> DACL
max98090 i2c-193C9890:00: Control not supported for path STENL Mux -> [NULL] -> DACR
max98090 i2c-193C9890:00: ASoC: no dapm match for STENL Mux --> NULL --> DACR
max98090 i2c-193C9890:00: ASoC: Failed to add route STENL Mux -> NULL -> DACR
Since there is no control between "STENL Mux" and DACs the control name must
be NULL not "NULL".
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
commit 50c0f21b42dd4cd02b51f82274f66912d9a7fa32 upstream.
Make sure to check the version field of the firmware header to make sure to
not accidentally try to parse a firmware file with a different layout.
Trying to do so can result in loading invalid firmware code to the device.
commit 9e4982f6a51a2442f1bb588fee42521b44b4531c upstream.
Like with ath9k, ath5k queues also need to be ordered by priority.
queue_info->tqi_subtype already contains the correct index, so use it
instead of relying on the order of ath5k_hw_setup_tx_queue calls.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
commit 2c3fc8d26dd09b9d7069687eead849ee81c78e46 upstream.
Need to pass the pointer within the swiotlb internal buffer to the
swiotlb library, that in the case of xen_unmap_single is dev_addr, not
paddr.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit dc50ddcd4c58a5a0226038307d6ef884bec9f8c2 upstream.
This patchs fixes a misplaced call to memset() that fills the request
buffer with 0. The problem was with sending PCAN_USBPRO_REQ_FCT
requests, the content set by the caller was thus lost.
With this patch, the memory area is zeroed only when requesting info
from the device.
Signed-off-by: Stephane Grosjean <s.grosjean@peak-system.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit af35d0f1cce7a990286e2b94c260a2c2d2a0e4b0 upstream.
This patch sets the correct reverse sequence order to the instructions
set to run, when any failure occurs during the initialization steps.
It also adds the missing unregistration call of the can device if the
failure appears after having been registered.
commit 78063d81d353e10cbdd279c490593113b8fdae1c upstream.
Hardware queues are ordered by priority. Use queue index 0 for BK, which
has lower priority than BE.
commit ad8fdccf9c197a89e2d2fa78c453283dcc2c343f upstream.
The driver passes the desired hardware queue index for a WMM data queue
in qinfo->tqi_subtype. This was ignored in ath9k_hw_setuptxqueue, which
instead relied on the order in which the function is called.
Reported-by: Hubert Feurstein <h.feurstein@gmail.com>
commit 136f49b9171074872f2a14ad0ab10486d1ba13ca upstream.
For buffer write, page lock will be got in write_begin and released in
write_end, in ocfs2_write_end_nolock(), before it unlock the page in
ocfs2_free_write_ctxt(), it calls ocfs2_run_deallocs(), this will ask
for the read lock of journal->j_trans_barrier. Holding page lock and
ask for journal->j_trans_barrier breaks the locking order.
This will cause a deadlock with journal commit threads, ocfs2cmt will
get write lock of journal->j_trans_barrier first, then it wakes up
kjournald2 to do the commit work, at last it waits until done. To
commit journal, kjournald2 needs flushing data first, it needs get the
cache page lock.
Since some ocfs2 cluster locks are holding by write process, this
deadlock may hung the whole cluster.
unlock pages before ocfs2_run_deallocs() can fix the locking order, also
put unlock before ocfs2_commit_trans() to make page lock is unlocked
before j_trans_barrier to preserve unlocking order.
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Reviewed-by: Wengang Wang <wen.gang.wang@oracle.com>
Reviewed-by: Mark Fasheh <mfasheh@suse.de>
commit 678886bdc6378c1cbd5072da2c5a3035000214e3 upstream.
When we abort a transaction we iterate over all the ranges marked as dirty
in fs_info->freed_extents[0] and fs_info->freed_extents[1], clear them
from those trees, add them back (unpin) to the free space caches and, if
the fs was mounted with "-o discard", perform a discard on those regions.
Also, after adding the regions to the free space caches, a fitrim ioctl call
can see those ranges in a block group's free space cache and perform a discard
on the ranges, so the same issue can happen without "-o discard" as well.
This causes corruption, affecting one or multiple btree nodes (in the worst
case leaving the fs unmountable) because some of those ranges (the ones in
the fs_info->pinned_extents tree) correspond to btree nodes/leafs that are
referred by the last committed super block - breaking the rule that anything
that was committed by a transaction is untouched until the next transaction
commits successfully.
I ran into this while running in a loop (for several hours) the fstest that
I recently submitted:
[PATCH] fstests: add btrfs test to stress chunk allocation/removal and fstrim
The corruption always happened when a transaction aborted and then fsck complained
like this:
_check_btrfs_filesystem: filesystem on /dev/sdc is inconsistent
*** fsck.btrfs output ***
Check tree block failed, want=94945280, have=0
read block failed check_tree_block
Couldn't open file system
In this case 94945280 corresponded to the root of a tree.
Using frace what I observed was the following sequence of steps happened:
1) transaction N started, fs_info->pinned_extents pointed to
fs_info->freed_extents[0];
2) node/eb 94945280 is created;
3) eb is persisted to disk;
4) transaction N commit starts, fs_info->pinned_extents now points to
fs_info->freed_extents[1], and transaction N completes;
5) transaction N + 1 starts;
6) eb is COWed, and btrfs_free_tree_block() called for this eb;
7) eb range (94945280 to 94945280 + 16Kb) is added to
fs_info->pinned_extents (fs_info->freed_extents[1]);
8) Something goes wrong in transaction N + 1, like hitting ENOSPC
for example, and the transaction is aborted, turning the fs into
readonly mode. The stack trace I got for example:
[112065.253935] [<ffffffff8140c7b6>] dump_stack+0x4d/0x66
[112065.254271] [<ffffffff81042984>] warn_slowpath_common+0x7f/0x98
[112065.254567] [<ffffffffa0325990>] ? __btrfs_abort_transaction+0x50/0x10b [btrfs]
[112065.261674] [<ffffffff810429e5>] warn_slowpath_fmt+0x48/0x50
[112065.261922] [<ffffffffa032949e>] ? btrfs_free_path+0x26/0x29 [btrfs]
[112065.262211] [<ffffffffa0325990>] __btrfs_abort_transaction+0x50/0x10b [btrfs]
[112065.262545] [<ffffffffa036b1d6>] btrfs_remove_chunk+0x537/0x58b [btrfs]
[112065.262771] [<ffffffffa033840f>] btrfs_delete_unused_bgs+0x1de/0x21b [btrfs]
[112065.263105] [<ffffffffa0343106>] cleaner_kthread+0x100/0x12f [btrfs]
[112065.264493] ---[ end trace dd7903a975a31a08 ]---
[112065.264673] BTRFS: error (device sdc) in btrfs_remove_chunk:2625: errno=-28 No space left
[112065.264997] BTRFS info (device sdc): forced readonly
9) The clear kthread sees that the BTRFS_FS_STATE_ERROR bit is set in
fs_info->fs_state and calls btrfs_cleanup_transaction(), which in
turn calls btrfs_destroy_pinned_extent();
10) Then btrfs_destroy_pinned_extent() iterates over all the ranges
marked as dirty in fs_info->freed_extents[], and for each one
it calls discard, if the fs was mounted with "-o discard", and
adds the range to the free space cache of the respective block
group;
11) btrfs_trim_block_group(), invoked from the fitrim ioctl code path,
sees the free space entries and performs a discard;
12) After an umount and mount (or fsck), our eb's location on disk was full
of zeroes, and it should have been untouched, because it was marked as
dirty in the fs_info->pinned_extents tree, and therefore used by the
trees that the last committed superblock points to.
Fix this by not performing a discard and not adding the ranges to the free space
caches - it's useless from this point since the fs is now in readonly mode and
we won't write free space caches to disk anymore (otherwise we would leak space)
nor any new superblock. By not adding the ranges to the free space caches, it
prevents other code paths from allocating that space and write to it as well,
therefore being safer and simpler.
This isn't a new problem, as it's been present since 2011 (git commit
acce952b0263825da32cf10489413dec78053347).
Signed-off-by: Filipe Manana <fdmanana@suse.com>
Signed-off-by: Chris Mason <clm@fb.com>
commit a28046956c71985046474283fa3bcd256915fb72 upstream.
We use the modified list to keep track of which extents have been modified so we
know which ones are candidates for logging at fsync() time. Newly modified
extents are added to the list at modification time, around the same time the
ordered extent is created. We do this so that we don't have to wait for ordered
extents to complete before we know what we need to log. The problem is when
something like this happens
log extent 0-4k on inode 1
copy csum for 0-4k from ordered extent into log
sync log
commit transaction
log some other extent on inode 1
ordered extent for 0-4k completes and adds itself onto modified list again
log changed extents
see ordered extent for 0-4k has already been logged
at this point we assume the csum has been copied
sync log
crash
On replay we will see the extent 0-4k in the log, drop the original 0-4k extent
which is the same one that we are replaying which also drops the csum, and then
we won't find the csum in the log for that bytenr. This of course causes us to
have errors about not having csums for certain ranges of our inode. So remove
the modified list manipulation in unpin_extent_cache, any modified extents
should have been added well before now, and we don't want them re-logged. This
fixes my test that I could reliably reproduce this problem with. Thanks,
Signed-off-by: Josef Bacik <jbacik@fb.com>
commit 942080643bce061c3dd9d5718d3b745dcb39a8bc upstream.
Dmitry Chernenkov used KASAN to discover that eCryptfs writes past the
end of the allocated buffer during encrypted filename decoding. This
fix corrects the issue by getting rid of the unnecessary 0 write when
the current bit offset is 2.
Signed-off-by: Michael Halcrow <mhalcrow@google.com>
Reported-by: Dmitry Chernenkov <dmitryc@google.com>
Suggested-by: Kees Cook <keescook@chromium.org>
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
commit 332b122d39c9cbff8b799007a825d94b2e7c12f2 upstream.
The ecryptfs_encrypted_view mount option greatly changes the
functionality of an eCryptfs mount. Instead of encrypting and decrypting
lower files, it provides a unified view of the encrypted files in the
lower filesystem. The presence of the ecryptfs_encrypted_view mount
option is intended to force a read-only mount and modifying files is not
supported when the feature is in use. See the following commit for more
information:
e77a56d [PATCH] eCryptfs: Encrypted passthrough
This patch forces the mount to be read-only when the
ecryptfs_encrypted_view mount option is specified by setting the
MS_RDONLY flag on the superblock. Additionally, this patch removes some
broken logic in ecryptfs_open() that attempted to prevent modifications
of files when the encrypted view feature was in use. The check in
ecryptfs_open() was not sufficient to prevent file modifications using
system calls that do not operate on a file descriptor.
Reported-by: Priya Bansal <p.bansal@samsung.com>
commit a1d47b262952a45aae62bd49cfaf33dd76c11a2c upstream.
UDF specification allows arbitrarily large symlinks. However we support
only symlinks at most one block large. Check the length of the symlink
so that we don't access memory beyond end of the symlink block.
Reported-by: Carl Henrik Lunde <chlunde@gmail.com>
commit 24c037ebf5723d4d9ab0996433cee4f96c292a4d upstream.
alloc_pid() does get_pid_ns() beforehand but forgets to put_pid_ns() if it
fails because disable_pid_allocation() was called by the exiting
child_reaper.
We could simply move get_pid_ns() down to successful return, but this fix
tries to be as trivial as possible.
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Aaron Tomlin <atomlin@redhat.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Serge Hallyn <serge.hallyn@ubuntu.com>
Cc: Sterling Alexander <stalexan@redhat.com>
commit a682e9c28cac152e6e54c39efcf046e0c8cfcf63 upstream.
If some error happens in NCP_IOC_SETROOT ioctl, the appropriate error
return value is then (in most cases) just overwritten before we return.
This can result in reporting success to userspace although error happened.
This bug was introduced by commit 2e54eb96e2c8 ("BKL: Remove BKL from
ncpfs"). Propagate the errors correctly.
Coverity id: 1226925.
Fixes: 2e54eb96e2c80 ("BKL: Remove BKL from ncpfs")
Cc: Petr Vandrovec <petr@vandrovec.name>
commit 7e77bdebff5cb1e9876c561f69710b9ab8fa1f7e upstream.
If a request is backlogged, it's complete() handler will get called
twice: once with -EINPROGRESS, and once with the final error code.
af_alg's complete handler, unlike other users, does not handle the
-EINPROGRESS but instead always completes the completion that recvmsg()
is waiting on. This can lead to a return to user space while the
request is still pending in the driver. If userspace closes the sockets
before the requests are handled by the driver, this will lead to
use-after-frees (and potential crashes) in the kernel due to the tfm
having been freed.
The crashes can be easily reproduced (for example) by reducing the max
queue length in cryptod.c and running the following (from
http://www.chronox.de/libkcapi.html) on AES-NI capable hardware:
$ while true; do kcapi -x 1 -e -c '__ecb-aes-aesni' \
-k 00000000000000000000000000000000 \
-p 00000000000000000000000000000000 >/dev/null & done
Signed-off-by: Rabin Vincent <rabin.vincent@axis.com>
commit db86da7cb76f797a1a8b445166a15cb922c6ff85 upstream.
A security fix in caused the way the unprivileged remount tests were
using user namespaces to break. Tweak the way user namespaces are
being used so the test works again.
commit 66d2f338ee4c449396b6f99f5e75cd18eb6df272 upstream.
Now that setgroups can be disabled and not reenabled, setting gid_map
without privielge can now be enabled when setgroups is disabled.
This restores most of the functionality that was lost when unprivileged
setting of gid_map was removed. Applications that use this functionality
will need to check to see if they use setgroups or init_groups, and if they
don't they can be fixed by simply disabling setgroups before writing to
gid_map.
Reviewed-by: Andy Lutomirski <luto@amacapital.net>
commit 9cc46516ddf497ea16e8d7cb986ae03a0f6b92f8 upstream.
- Expose the knob to user space through a proc file /proc/<pid>/setgroups
A value of "deny" means the setgroups system call is disabled in the
current processes user namespace and can not be enabled in the
future in this user namespace.
A value of "allow" means the segtoups system call is enabled.
- Descendant user namespaces inherit the value of setgroups from
their parents.
- A proc file is used (instead of a sysctl) as sysctls currently do
not allow checking the permissions at open time.
- Writing to the proc file is restricted to before the gid_map
for the user namespace is set.
This ensures that disabling setgroups at a user namespace
level will never remove the ability to call setgroups
from a process that already has that ability.
A process may opt in to the setgroups disable for itself by
creating, entering and configuring a user namespace or by calling
setns on an existing user namespace with setgroups disabled.
Processes without privileges already can not call setgroups so this
is a noop. Prodcess with privilege become processes without
privilege when entering a user namespace and as with any other path
to dropping privilege they would not have the ability to call
setgroups. So this remains within the bounds of what is possible
without a knob to disable setgroups permanently in a user namespace.
commit f0d62aec931e4ae3333c797d346dc4f188f454ba upstream.
Generalize id_map_mutex so it can be used for more state of a user namespace.
commit f95d7918bd1e724675de4940039f2865e5eec5fe upstream.
If you did not create the user namespace and are allowed
to write to uid_map or gid_map you should already have the necessary
privilege in the parent user namespace to establish any mapping
you want so this will not affect userspace in practice.
Limiting unprivileged uid mapping establishment to the creator of the
user namespace makes it easier to verify all credentials obtained with
the uid mapping can be obtained without the uid mapping without
privilege.
Limiting unprivileged gid mapping establishment (which is temporarily
absent) to the creator of the user namespace also ensures that the
combination of uid and gid can already be obtained without privilege.
This is part of the fix for CVE-2014-8989.
commit 80dd00a23784b384ccea049bfb3f259d3f973b9d upstream.
setresuid allows the euid to be set to any of uid, euid, suid, and
fsuid. Therefor it is safe to allow an unprivileged user to map
their euid and use CAP_SETUID privileged with exactly that uid,
as no new credentials can be obtained.
I can not find a combination of existing system calls that allows setting
uid, euid, suid, and fsuid from the fsuid making the previous use
of fsuid for allowing unprivileged mappings a bug.
This is part of a fix for CVE-2014-8989.
commit be7c6dba2332cef0677fbabb606e279ae76652c3 upstream.
As any gid mapping will allow and must allow for backwards
compatibility dropping groups don't allow any gid mappings to be
established without CAP_SETGID in the parent user namespace.
For a small class of applications this change breaks userspace
and removes useful functionality. This small class of applications
includes tools/testing/selftests/mount/unprivilged-remount-test.c
Most of the removed functionality will be added back with the addition
of a one way knob to disable setgroups. Once setgroups is disabled
setting the gid_map becomes as safe as setting the uid_map.
For more common applications that set the uid_map and the gid_map
with privilege this change will have no affect.
commit 273d2c67c3e179adb1e74f403d1e9a06e3f841b5 upstream.
setgroups is unique in not needing a valid mapping before it can be called,
in the case of setgroups(0, NULL) which drops all supplemental groups.
The design of the user namespace assumes that CAP_SETGID can not actually
be used until a gid mapping is established. Therefore add a helper function
to see if the user namespace gid mapping has been established and call
that function in the setgroups permission check.
This is part of the fix for CVE-2014-8989, being able to drop groups
without privilege using user namespaces.
commit 0542f17bf2c1f2430d368f44c8fcf2f82ec9e53e upstream.
The rule is simple. Don't allow anything that wouldn't be allowed
without unprivileged mappings.
It was previously overlooked that establishing gid mappings would
allow dropping groups and potentially gaining permission to files and
directories that had lesser permissions for a specific group than for
all other users.
This is the rule needed to fix CVE-2014-8989 and prevent any other
security issues with new_idmap_permitted.
The reason for this rule is that the unix permission model is old and
there are programs out there somewhere that take advantage of every
little corner of it. So allowing a uid or gid mapping to be
established without privielge that would allow anything that would not
be allowed without that mapping will result in expectations from some
code somewhere being violated. Violated expectations about the
behavior of the OS is a long way to say a security issue.
commit 7ff4d90b4c24a03666f296c3d4878cd39001e81e upstream.
Today there are 3 instances of setgroups and due to an oversight their
permission checking has diverged. Add a common function so that
they may all share the same permission checking code.
This corrects the current oversight in the current permission checks
and adds a helper to avoid this in the future.
A user namespace security fix will update this new helper, shortly.
commit b2f5d4dc38e034eecb7987e513255265ff9aa1cf upstream.
Forced unmount affects not just the mount namespace but the underlying
superblock as well. Restrict forced unmount to the global root user
for now. Otherwise it becomes possible a user in a less privileged
mount namespace to force the shutdown of a superblock of a filesystem
in a more privileged mount namespace, allowing a DOS attack on root.
commit 4a44a19b470a886997d6647a77bb3e38dcbfa8c5 upstream.
- MNT_NODEV should be irrelevant except when reading back mount flags,
no longer specify MNT_NODEV on remount.
- Test MNT_NODEV on devpts where it is meaningful even for unprivileged mounts.
- Add a test to verify that remount of a prexisting mount with the same flags
is allowed and does not change those flags.
- Cleanup up the definitions of MS_REC, MS_RELATIME, MS_STRICTATIME that are used
when the code is built in an environment without them.
- Correct the test error messages when tests fail. There were not 5 tests
that tested MS_RELATIME.
commit 3e1866410f11356a9fd869beb3e95983dc79c067 upstream.
Now that remount is properly enforcing the rule that you can't remove
nodev at least sandstorm.io is breaking when performing a remount.
It turns out that there is an easy intuitive solution implicitly
add nodev on remount when nodev was implicitly added on mount.
Tested-by: Cedric Bosdonnat <cbosdonnat@suse.com>
Tested-by: Richard Weinberger <richard@nod.at>
