commit 889b77f7fd2bcc922493d73a4c51d8a851505815 upstream.
Flooding the Kvaser CAN to USB dongle with multiple reads and
writes in very high frequency (*), closing the CAN channel while
all the transmissions are on (#), opening the device again (@),
then sending a small number of packets would make the driver
enter an almost infinite loop of:
[15959.853988] kvaser_usb 4-3:1.0 can0: cannot find free context
[15959.853990] kvaser_usb 4-3:1.0 can0: cannot find free context
[15959.853991] kvaser_usb 4-3:1.0 can0: cannot find free context
[15959.853993] kvaser_usb 4-3:1.0 can0: cannot find free context
[15959.853994] kvaser_usb 4-3:1.0 can0: cannot find free context
[15959.853995] kvaser_usb 4-3:1.0 can0: cannot find free context
_dragging the whole system down_ in the process due to the
excessive logging output.
Initially, this has caused random panics in the kernel due to a
buggy error recovery path. That got fixed in an earlier commit.(%)
This patch aims at solving the root cause. -->
16 tx URBs and contexts are allocated per CAN channel per USB
device. Such URBs are protected by:
a) A simple atomic counter, up to a value of MAX_TX_URBS (16)
b) A flag in each URB context, stating if it's free
c) The fact that ndo_start_xmit calls are themselves protected
by the networking layers higher above
After grabbing one of the tx URBs, if the driver noticed that all
of them are now taken, it stops the netif transmission queue.
Such queue is worken up again only if an acknowedgment was received
from the firmware on one of our earlier-sent frames.
Meanwhile, upon channel close (#), the driver sends a CMD_STOP_CHIP
to the firmware, effectively closing all further communication. In
the high traffic case, the atomic counter remains at MAX_TX_URBS,
and all the URB contexts remain marked as active. While opening
the channel again (@), it cannot send any further frames since no
more free tx URB contexts are available.
Reset all tx URB contexts upon CAN channel close.
(*) 50 parallel instances of `cangen0 -g 0 -ix`
(#) `ifconfig can0 down`
(@) `ifconfig can0 up`
(%) "can: kvaser_usb: Don't free packets when tight on URBs"
Signed-off-by: Ahmed S. Darwish <ahmed.darwish@valeo.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit b442723fcec445fb0ae1104888dd22cd285e0a91 upstream.
writes in high frequency caused seemingly-random panics in the
kernel.
On further inspection, it seems the driver erroneously freed the
to-be-transmitted packet upon getting tight on URBs and returning
NETDEV_TX_BUSY, leading to invalid memory writes and double frees
at a later point in time.
Note:
Finding no more URBs/transmit-contexts and returning NETDEV_TX_BUSY
is a driver bug in and out of itself: it means that our start/stop
queue flow control is broken.
This patch only fixes the (buggy) error handling code; the root
cause shall be fixed in a later commit.
Acked-by: Olivier Sobrie <olivier@sobrie.be>
commit b5122236bba8d7ef62153da5b55cc65d0944c61e upstream.
Fix null-pointer dereference during probe if the interface-status
completion handler is called before the individual ports have been set
up.
Fixes: f79b2d0fe81e ("USB: keyspan: fix NULL-pointer dereferences and
memory leaks")
Reported-by: Richard <richjunk@pacbell.net>
Tested-by: Richard <richjunk@pacbell.net>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 1ae78a4870989a354028cb17dabf819b595e70e3 upstream.
Added virtual com port VID/PID entries for CEL USB sticks and MeshWorks
devices.
Signed-off-by: David Peterson <david.peterson@cel.com>
commit 90441b4dbe90ba0c38111ea89fa093a8c9627801 upstream.
Fixing typo for MeshConnect IDs. The original PID (0x8875) is not in
production and is not needed. Instead it has been changed to the
official production PID (0x8857).
Signed-off-by: Preston Fick <pffick@gmail.com>
commit 39e60635a01520e8c8ed3946a28c2b98e6a46f79 upstream.
DWC3 gadget sets up a pool of 32 TRBs for each EP during initialization. This
means, the max TRBs that can be submitted for an EP is fixed to 32. Since the
request queue for an EP is a linked list, any number of requests can be queued
to it by the gadget layer. However, the dwc3 driver must not submit TRBs more
than the pool it has created for. This limit wasn't respected when SG was used
resulting in submitting more than the max TRBs, eventually leading to
non-transfer of the TRBs submitted over the max limit.
Root cause:
When SG is used, there are two loops iterating to prepare TRBs:
- Outer loop over the request_list
- Inner loop over the SG list
The code was missing break to get out of the outer loop.
Fixes: eeb720fb21d6 (usb: dwc3: gadget: add support for SG lists)
Signed-off-by: Amit Virdi <amit.virdi@st.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit ec512fb8e5611fed1df2895f90317ce6797d6b32 upstream.
When scatter gather (SG) is used, multiple TRBs are prepared from one DWC3
request (dwc3_request). So while preparing TRBs, the 'last' flag should be set
only when it is the last TRB being prepared from the last dwc3_request entry.
The current implementation uses list_is_last to check if the dwc3_request is the
last entry from the request_list. However, list_is_last returns false for the
last entry too. This is because, while preparing the first TRB from a request,
the function dwc3_prepare_one_trb modifies the request's next and prev pointers
while moving the URB to req_queued. Hence, list_is_last always returns false no
matter what.
The correct way is not to access the modified pointers of dwc3_request but to
use list_empty macro instead.
Fixes: e5ba5ec833aa (usb: dwc3: gadget: fix scatter gather implementation)
commit 56abcab833fafcfaeb2f5b25e0364c1dec45f53e upstream.
Commit 8dccddbc2368 ("OHCI: final fix for NVIDIA problems (I hope)")
introduced into 3.1.9 broke boot on e.g. Freescale P2020DS development
board. The code path that was previously specific to NVIDIA controllers
had then become taken for all chips.
However, the M5237 installed on the board wedges solid when accessing
its base+OHCI_FMINTERVAL register, making it impossible to boot any
kernel newer than 3.1.8 on this particular and apparently other similar
machines.
Don't readl() and writel() base+OHCI_FMINTERVAL on PCI ID 10b9:5237.
The patch is suitable for the -next tree as well as all maintained
kernels up to 3.2 inclusive.
Signed-off-by: Arseny Solokha <asolokha@kb.kras.ru>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 7b8792bbdffdff3abda704f89c6a45ea97afdc62 upstream.
of_get_named_gpiod_flags fails with -EPROBE_DEFER in cases
where the gpio chip is available and the GPIO translation fails.
This causes drivers to be re-probed erroneusly, and hides the
real problem(i.e. the GPIO number being out of range).
Signed-off-by: Hans Holmberg <hans.holmberg@intel.com>
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
commit 1fc0703af3143914a389bfa081c7acb09502ed5d upstream.
Currently, our trunking code will check for session trunking, but will
fail to detect client id trunking. This is a problem, because it means
that the client will fail to recognise that the two connections represent
shared state, even if they do not permit a shared session.
By removing the check for the server minor id, and only checking the
major id, we will end up doing the right thing in both cases: we close
down the new nfs_client and fall back to using the existing one.
Fixes: 05f4c350ee02e ("NFS: Discover NFSv4 server trunking when mounting")
Cc: Chuck Lever <chuck.lever@oracle.com>
Tested-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 237d28db036e411f22c03cfd5b0f6dc2aa9bf3bc upstream.
If the function graph tracer traces a jprobe callback, the system will
crash. This can easily be demonstrated by compiling the jprobe
sample module that is in the kernel tree, loading it and running the
function graph tracer.
# modprobe jprobe_example.ko
# echo function_graph > /sys/kernel/debug/tracing/current_tracer
# ls
The first two commands end up in a nice crash after the first fork.
(do_fork has a jprobe attached to it, so "ls" just triggers that fork)
The problem is caused by the jprobe_return() that all jprobe callbacks
must end with. The way jprobes works is that the function a jprobe
is attached to has a breakpoint placed at the start of it (or it uses
ftrace if fentry is supported). The breakpoint handler (or ftrace callback)
will copy the stack frame and change the ip address to return to the
jprobe handler instead of the function. The jprobe handler must end
with jprobe_return() which swaps the stack and does an int3 (breakpoint).
This breakpoint handler will then put back the saved stack frame,
simulate the instruction at the beginning of the function it added
a breakpoint to, and then continue on.
For function tracing to work, it hijakes the return address from the
stack frame, and replaces it with a hook function that will trace
the end of the call. This hook function will restore the return
address of the function call.
If the function tracer traces the jprobe handler, the hook function
for that handler will not be called, and its saved return address
will be used for the next function. This will result in a kernel crash.
To solve this, pause function tracing before the jprobe handler is called
and unpause it before it returns back to the function it probed.
Some other updates:
Used a variable "saved_sp" to hold kcb->jprobe_saved_sp. This makes the
code look a bit cleaner and easier to understand (various tries to fix
this bug required this change).
Note, if fentry is being used, jprobes will change the ip address before
the function graph tracer runs and it will not be able to trace the
function that the jprobe is probing.
Link: http://lkml.kernel.org/r/20150114154329.552437962@goodmis.org
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
commit 7c2e211f3c95b91912a92a8c6736343690042e2e upstream.
Current vfio-pci just supports normal pci device, so vfio_pci_probe() will
return if the pci device is not a normal device. While current code makes a
mistake. PCI_HEADER_TYPE is the offset in configuration space of the device
type, but we use this value to mask the type value.
This patch fixs this by do the check directly on the pci_dev->hdr_type.
Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
commit 2228d80dd05a4fc5a410fde847677b8fb3eb23d7 upstream.
We've got a bug report at disconnecting a Webcam, where the kernel
spews warnings like below:
WARNING: CPU: 0 PID: 8385 at ../fs/sysfs/group.c:219 sysfs_remove_group+0x87/0x90()
sysfs group c0b2350c not found for kobject 'event3'
CPU: 0 PID: 8385 Comm: queue2:src Not tainted 3.16.2-1.gdcee397-default #1
Hardware name: ASUSTeK Computer INC. A7N8X-E/A7N8X-E, BIOS ASUS A7N8X-E Deluxe ACPI BIOS Rev 1013 11/12/2004
c08d0705 ddc75cbc c0718c5b ddc75ccc c024b654 c08c6d44 ddc75ce8 000020c1
c08d0705 000000db c03d1ec7 c03d1ec7 00000009 00000000 c0b2350c d62c9064
ddc75cd4 c024b6a3 00000009 ddc75ccc c08c6d44 ddc75ce8 ddc75cfc c03d1ec7
Call Trace:
[<c0205ba6>] try_stack_unwind+0x156/0x170
[<c02046f3>] dump_trace+0x53/0x180
[<c0205c06>] show_trace_log_lvl+0x46/0x50
[<c0204871>] show_stack_log_lvl+0x51/0xe0
[<c0205c67>] show_stack+0x27/0x50
[<c0718c5b>] dump_stack+0x3e/0x4e
[<c024b654>] warn_slowpath_common+0x84/0xa0
[<c024b6a3>] warn_slowpath_fmt+0x33/0x40
[<c03d1ec7>] sysfs_remove_group+0x87/0x90
[<c05a2c54>] device_del+0x34/0x180
[<c05e3989>] evdev_disconnect+0x19/0x50
[<c05e06fa>] __input_unregister_device+0x9a/0x140
[<c05e0845>] input_unregister_device+0x45/0x80
[<f854b1d6>] uvc_delete+0x26/0x110 [uvcvideo]
[<f84d66f8>] v4l2_device_release+0x98/0xc0 [videodev]
[<c05a25bb>] device_release+0x2b/0x90
[<c04ad8bf>] kobject_cleanup+0x6f/0x1a0
[<f84d5453>] v4l2_release+0x43/0x70 [videodev]
[<c0372f31>] __fput+0xb1/0x1b0
[<c02650c1>] task_work_run+0x91/0xb0
[<c024d845>] do_exit+0x265/0x910
[<c024df64>] do_group_exit+0x34/0xa0
[<c025a76f>] get_signal_to_deliver+0x17f/0x590
[<c0201b6a>] do_signal+0x3a/0x960
[<c02024f7>] do_notify_resume+0x67/0x90
[<c071ebb5>] work_notifysig+0x30/0x3b
[<b7739e60>] 0xb7739e5f
---[ end trace b1e56095a485b631 ]---
The cause is that uvc_status_cleanup() is called after usb_put_*() in
uvc_delete(). usb_put_*() removes the sysfs parent and eventually
removes the children recursively, so the later device_del() can't find
its sysfs. The fix is simply rearrange the call orders in
uvc_delete() so that the child is removed before the parent.
Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=897736
Reported-and-tested-by: Martin Pluskal <mpluskal@suse.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit f85698cd296f08218a7750f321e94607da128600 upstream.
The mutex does not serialise anything in this case but avoids a lockdep
warning from the control framework.
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
commit 2279948735609d0d17d7384e776b674619f792ef upstream.
This patches fixes an ancient bug in the dvb_usb_af9005 driver, which
has been reported at least in the following threads:
https://lkml.org/lkml/2009/2/4/350
https://lkml.org/lkml/2014/9/18/558
If the driver is compiled in without any IR support (neither
DVB_USB_AF9005_REMOTE nor custom symbols), the symbol_request calls in
af9005_usb_module_init() return pointers != NULL although the IR
symbols are not available.
This leads to the following oops:
[ 8.529751] usbcore: registered new interface driver dvb_usb_af9005
[ 8.531584] BUG: unable to handle kernel paging request at 02e00000
[ 8.533385] IP: [<7d9d67c6>] af9005_usb_module_init+0x6b/0x9d
[ 8.535613] *pde = 00000000
[ 8.536416] Oops: 0000 [#1] PREEMPT PREEMPT DEBUG_PAGEALLOCDEBUG_PAGEALLOC
[ 8.537863] CPU: 0 PID: 1 Comm: swapper Not tainted 3.15.0-rc6-00151-ga5c075c #1
[ 8.539827] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014
[ 8.541519] task: 89c9a670 ti: 89c9c000 task.ti: 89c9c000
[ 8.541519] EIP: 0060:[<7d9d67c6>] EFLAGS: 00010206 CPU: 0
[ 8.541519] EIP is at af9005_usb_module_init+0x6b/0x9d
[ 8.541519] EAX: 02e00000 EBX: 00000000 ECX: 00000006 EDX: 00000000
[ 8.541519] ESI: 00000000 EDI: 7da33ec8 EBP: 89c9df30 ESP: 89c9df2c
[ 8.541519] DS: 007b ES: 007b FS: 0000 GS: 00e0 SS: 0068
[ 8.541519] CR0: 8005003b CR2: 02e00000 CR3: 05a54000 CR4: 00000690
[ 8.541519] Stack:
[ 8.541519] 7d9d675b 89c9df90 7d992a49 7d7d5914 89c9df4c 7be3a800 7d08c58c 8a4c3968
[ 8.541519] 89c9df80 7be3a966 00000192 00000006 00000006 7d7d3ff4 8a4c397a 00000200
[ 8.541519] 7d6b1280 8a4c3979 00000006 000009a6 7da32db8 b13eec81 00000006 000009a6
[ 8.541519] Call Trace:
[ 8.541519] [<7d9d675b>] ? ttusb2_driver_init+0x16/0x16
[ 8.541519] [<7d992a49>] do_one_initcall+0x77/0x106
[ 8.541519] [<7be3a800>] ? parameqn+0x2/0x35
[ 8.541519] [<7be3a966>] ? parse_args+0x113/0x25c
[ 8.541519] [<7d992bc2>] kernel_init_freeable+0xea/0x167
[ 8.541519] [<7cf01070>] kernel_init+0x8/0xb8
[ 8.541519] [<7cf27ec0>] ret_from_kernel_thread+0x20/0x30
[ 8.541519] [<7cf01068>] ? rest_init+0x10c/0x10c
[ 8.541519] Code: 08 c2 c7 05 44 ed f9 7d 00 00 e0 02 c7 05 40 ed f9 7d 00 00 e0 02 c7 05 3c ed f9 7d 00 00 e0 02 75 1f b8 00 00 e0 02 85 c0 74 16 <a1> 00 00 e0 02 c7 05 54 84 8e 7d 00 00 e0 02 a3 58 84 8e 7d eb
[ 8.541519] EIP: [<7d9d67c6>] af9005_usb_module_init+0x6b/0x9d SS:ESP 0068:89c9df2c
[ 8.541519] CR2: 0000000002e00000
[ 8.541519] ---[ end trace 768b6faf51370fc7 ]---
The prefered fix would be to convert the whole IR code to use the kernel IR
infrastructure (which wasn't available at the time this driver had been created).
Until anyone who still has this old hardware steps up an does the conversion,
fix it by not calling the symbol_request calls if the driver is compiled in
without the default IR symbols (CONFIG_DVB_USB_AF9005_REMOTE).
Due to the IR related pointers beeing NULL by default, IR support will then be disabled.
The downside of this solution is, that it will no longer be possible to
compile custom IR symbols (not using CONFIG_DVB_USB_AF9005_REMOTE) in.
Please note that this patch has NOT been tested with all possible cases.
I don't have the hardware and could only verify that it fixes the reported
bug.
Reported-by: Fengguag Wu <fengguang.wu@intel.com>
Signed-off-by: Frank Schäfer <fschaefer.oss@googlemail.com>
Acked-by: Luca Olivetti <luca@ventoso.org>
commit bc47150ab93988714d1fab7bc82fe5f505a107ad upstream.
The PLL flags were not used correctly.
commit 92b004d1aa9f367c372511ca0330f58216b25703 upstream.
If the probe of an fb driver has been deferred due to missing
dependencies, and the probe is later ran when a module is loaded, the
fbdev framework will try to find a logo to use.
However, the logos are __initdata, and have already been freed. This
causes sometimes page faults, if the logo memory is not mapped,
sometimes other random crashes as the logo data is invalid, and
sometimes nothing, if the fbdev decides to reject the logo (e.g. the
random value depicting the logo's height is too big).
This patch adds a late_initcall function to mark the logos as freed. In
reality the logos are freed later, and fbdev probe may be ran between
this late_initcall and the freeing of the logos. In that case we will
miss drawing the logo, even if it would be possible.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
commit e86fb5e8ab95f10ec5f2e9430119d5d35020c951 upstream.
When ring buffer returns an error indicating retry, storvsc may not
return a proper error code to SCSI when bounce buffer is not used.
This has introduced I/O freeze on RAID running atop storvsc devices.
This patch fixes it by always returning a proper error code.
Signed-off-by: Long Li <longli@microsoft.com>
Reviewed-by: K. Y. Srinivasan <kys@microsoft.com>
commit 6bf6ca7515c1df06f5c03737537f5e0eb191e29e upstream.
This patch changes iscsit_do_tx_data() to fail on short writes
when kernel_sendmsg() returns a value different than requested
transfer length, returning -EPIPE and thus causing a connection
reset to occur.
This avoids a potential bug in the original code where a short
write would result in kernel_sendmsg() being called again with
the original iovec base + length.
In practice this has not been an issue because iscsit_do_tx_data()
is only used for transferring 48 byte headers + 4 byte digests,
along with seldom used control payloads from NOPIN + TEXT_RSP +
REJECT with less than 32k of data.
So following Al's audit of iovec consumers, go ahead and fail
the connection on short writes for now, and remove the bogus
logic ahead of his proper upstream fix.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
commit 6583659e0f92e38079a8dd081e0a1181a0f37747 upstream.
HP ZBook 15 laptop needs a non-standard mapping (x_inverted).
BugLink: http://bugzilla.opensuse.org/show_bug.cgi?id=905329
Signed-off-by: Dominique Leuenberger <dimstar@opensuse.org>
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
commit 08f6f147773b23b765b94633a8eaa82e7defcf4c upstream.
The VHT supported channel width field is a two bit integer, not a
bitfield. cfg80211_chandef_usable() was interpreting it incorrectly and
ended up rejecting 160 MHz channel width if the driver indicated support
for both 160 and 80+80 MHz channels.
Fixes: 3d9d1d6656a73 ("nl80211/cfg80211: support VHT channel configuration")
(however, no real drivers had 160 MHz support it until 3.16)
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
commit e8ef060b37c2d3cc5fd0c0edbe4e42ec1cb9768b upstream.
This allows the sdplite/Zebu images to run on OSCI simulation platform
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
commit add284a3a2481e759d6bec35f6444c32c8ddc383 upstream.
In order to act as a full command barrier by itself, we need to tell the
pipecontrol to actually stall the command streamer while the flush runs.
We require the full command barrier before operations like
MI_SET_CONTEXT, which currently rely on a prior invalidate flush.
References: https://bugs.freedesktop.org/show_bug.cgi?id=83677
Cc: Simon Farnsworth <simon@farnz.org.uk>
Cc: Daniel Vetter <daniel@ffwll.ch>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
commit 148b83d0815a3778c8949e6a97cb798cbaa0efb3 upstream.
In the gen7 pipe control there is an extra bit to flush the media
caches, so let's set it during cache invalidation flushes.
v2: Rename to MEDIA_STATE_CLEAR to be more inline with spec.
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 410cce2a6b82299b46ff316c6384e789ce275ecb upstream.
The check was already in place in the dp mode_valid check, but
radeon_dp_get_dp_link_clock() never returned the high clock
mode_valid was checking for because that function clipped the
clock based on the hw capabilities. Add an explicit check
in the mode_valid function.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=87172
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 5e5c21cac1001089007260c48b0c89ebaace0e71 upstream.
Check the that ring we are using for copies is functional
rather than the GFX ring. On newer asics we use the DMA
ring for bo moves.
Reviewed-by: Christian König <christian.koenig@amd.com>
commit 89669e7a7f96be3ee8d9a22a071d7c0d3b4428fc upstream.
The commit "vmwgfx: Rework fence event action" introduced a number of bugs
that are fixed with this commit:
a) A forgotten return stateemnt.
b) An if statement with identical branches.
Reported-by: Rob Clark <robdclark@gmail.com>
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
Reviewed-by: Sinclair Yeh <syeh@vmware.com>
[ Upstream commit 17e96834fd35997ca7cdfbf15413bcd5a36ad448 ]
Hardware always provides compliment of IP pseudo checksum. Stack expects
whole packet checksum without pseudo checksum if CHECKSUM_COMPLETE is set.
This causes checksum error in nf & ovs.
kernel: qg-19546f09-f2: hw csum failure
kernel: CPU: 9 PID: 0 Comm: swapper/9 Tainted: GF O-------------- 3.10.0-123.8.1.el7.x86_64 #1
kernel: Hardware name: Cisco Systems Inc UCSB-B200-M3/UCSB-B200-M3, BIOS B200M3.2.2.3.0.080820141339 08/08/2014
kernel: ffff881218f40000 df68243feb35e3a8 ffff881237a43ab8 ffffffff815e237b
kernel: ffff881237a43ad0 ffffffff814cd4ca ffff8829ec71eb00 ffff881237a43af0
kernel: ffffffff814c6232 0000000000000286 ffff8829ec71eb00 ffff881237a43b00
kernel: Call Trace:
kernel: <IRQ> [<ffffffff815e237b>] dump_stack+0x19/0x1b
kernel: [<ffffffff814cd4ca>] netdev_rx_csum_fault+0x3a/0x40
kernel: [<ffffffff814c6232>] __skb_checksum_complete_head+0x62/0x70
kernel: [<ffffffff814c6251>] __skb_checksum_complete+0x11/0x20
kernel: [<ffffffff8155a20c>] nf_ip_checksum+0xcc/0x100
kernel: [<ffffffffa049edc7>] icmp_error+0x1f7/0x35c [nf_conntrack_ipv4]
kernel: [<ffffffff814cf419>] ? netif_rx+0xb9/0x1d0
kernel: [<ffffffffa040eb7b>] ? internal_dev_recv+0xdb/0x130 [openvswitch]
kernel: [<ffffffffa04c8330>] nf_conntrack_in+0xf0/0xa80 [nf_conntrack]
kernel: [<ffffffff81509380>] ? inet_del_offload+0x40/0x40
kernel: [<ffffffffa049e302>] ipv4_conntrack_in+0x22/0x30 [nf_conntrack_ipv4]
kernel: [<ffffffff815005ca>] nf_iterate+0xaa/0xc0
kernel: [<ffffffff81500664>] nf_hook_slow+0x84/0x140
kernel: [<ffffffff81509dd4>] ip_rcv+0x344/0x380
Hardware verifies IP & tcp/udp header checksum but does not provide payload
checksum, use CHECKSUM_UNNECESSARY. Set it only if its valid IP tcp/udp packet.
Cc: Jiri Benc <jbenc@redhat.com>
Cc: Stefan Assmann <sassmann@redhat.com>
Reported-by: Sunil Choudhary <schoudha@redhat.com>
Signed-off-by: Govindarajulu Varadarajan <_govind@gmx.com>
Reviewed-by: Jiri Benc <jbenc@redhat.com>
[ Upstream commit 7a05dc64e2e4c611d89007b125b20c0d2a4d31a5 ]
Commit d75b1ade567f ("net: less interrupt masking in NAPI") uncovered
wrong alx_poll() behavior.
A NAPI poll() handler is supposed to return exactly the budget when/if
napi_complete() has not been called.
It is also supposed to return number of frames that were received, so
that netdev_budget can have a meaning.
Also, in case of TX pressure, we still have to dequeue received
packets : alx_clean_rx_irq() has to be called even if
alx_clean_tx_irq(alx) returns false, otherwise device is half duplex.
Fixes: d75b1ade567f ("net: less interrupt masking in NAPI")
Reported-by: Oded Gabbay <oded.gabbay@amd.com>
Bisected-by: Oded Gabbay <oded.gabbay@amd.com>
Tested-by: Oded Gabbay <oded.gabbay@amd.com>
[ Upstream commit 843925f33fcc293d80acf2c5c8a78adf3344d49b ]
Thomas Jarosch reported IPsec TCP stalls when a PMTU event occurs.
In fact the problem was completely unrelated to IPsec. The bug is
also reproducible if you just disable TSO/GSO.
The problem is that when the MSS goes down, existing queued packet
on the TX queue that have not been transmitted yet all look like
TSO packets and get treated as such.
This then triggers a bug where tcp_mss_split_point tells us to
generate a zero-sized packet on the TX queue. Once that happens
we're screwed because the zero-sized packet can never be removed
by ACKs.
Fixes: 1485348d242 ("tcp: Apply device TSO segment limit earlier")
Reported-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
Cheers,
[ Upstream commit 05b0aa579397b734f127af58e401a30784a1e315 ]
During driver load in tg3_init_one, if the driver detects DMA activity before
intializing the chip tg3_halt is called. As part of tg3_halt interrupts are
disabled using routine tg3_disable_ints. This routine was using mailbox value
which was not initialized (default value is 0). As a result driver was writing
0x00000001 to pci config space register 0, which is the vendor id / device id.
This driver bug was exposed because of the commit a7877b17a667 (PCI: Check only
the Vendor ID to identify Configuration Request Retry). Also this issue is only
seen in older generation chipsets like 5722 because config space write to offset
0 from driver is possible. The newer generation chips ignore writes to offset 0.
Also without commit a7877b17a667, for these older chips when a GRC reset is
issued the Bootcode would reprogram the vendor id/device id, which is the reason
this bug was masked earlier.
Fixed by initializing the interrupt mailbox registers before calling tg3_halt.
Please queue for -stable.
Reported-by: Nils Holland <nholland@tisys.org>
Reported-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Signed-off-by: Prashant Sreedharan <prashant@broadcom.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
available
[ Upstream commit a18e6a186f53af06937a2c268c72443336f4ab56 ]
Each mmap Netlink frame contains a status field which indicates
whether the frame is unused, reserved, contains data or needs to
be skipped. Both loads and stores may not be reordeded and must
complete before the status field is changed and another CPU might
pick up the frame for use. Use an smp_mb() to cover needs of both
types of callers to netlink_set_status(), callers which have been
reading data frame from the frame, and callers which have been
filling or releasing and thus writing to the frame.
- Example code path requiring a smp_rmb():
memcpy(skb->data, (void *)hdr + NL_MMAP_HDRLEN, hdr->nm_len);
netlink_set_status(hdr, NL_MMAP_STATUS_UNUSED);
- Example code path requiring a smp_wmb():
hdr->nm_uid = from_kuid(sk_user_ns(sk), NETLINK_CB(skb).creds.uid);
hdr->nm_gid = from_kgid(sk_user_ns(sk), NETLINK_CB(skb).creds.gid);
netlink_frame_flush_dcache(hdr);
netlink_set_status(hdr, NL_MMAP_STATUS_VALID);
Fixes: f9c228 ("netlink: implement memory mapped recvmsg()")
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Thomas Graf <tgraf@suug.ch>
[ Upstream commit 4682a0358639b29cf69437ed909c6221f8c89847 ]
Checking the file f_count and the nlk->mapped count is not completely
sufficient to prevent the mmap'd area contents from changing from
under us during netlink mmap sendmsg() operations.
Be careful to sample the header's length field only once, because this
could change from under us as well.
Fixes: 5fd96123ee19 ("netlink: implement memory mapped sendmsg()")
Acked-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Thomas Graf <tgraf@suug.ch>
commit 690eac53daff34169a4d74fc7bfbd388c4896abb upstream.
Commit fee7e49d4514 ("mm: propagate error from stack expansion even for
guard page") made sure that we return the error properly for stack
growth conditions. It also theorized that counting the guard page
towards the stack limit might break something, but also said "Let's see
if anybody notices".
Somebody did notice. Apparently android-x86 sets the stack limit very
close to the limit indeed, and including the guard page in the rlimit
check causes the android 'zygote' process problems.
So this adds the (fairly trivial) code to make the stack rlimit check be
against the actual real stack size, rather than the size of the vma that
includes the guard page.
Reported-and-tested-by: Chih-Wei Huang <cwhuang@android-x86.org>
Cc: Jay Foad <jay.foad@gmail.com>
commit fee7e49d45149fba60156f5b59014f764d3e3728 upstream.
Jay Foad reports that the address sanitizer test (asan) sometimes gets
confused by a stack pointer that ends up being outside the stack vma
that is reported by /proc/maps.
This happens due to an interaction between RLIMIT_STACK and the guard
page: when we do the guard page check, we ignore the potential error
from the stack expansion, which effectively results in a missing guard
page, since the expected stack expansion won't have been done.
And since /proc/maps explicitly ignores the guard page (commit
d7824370e263: "mm: fix up some user-visible effects of the stack guard
page"), the stack pointer ends up being outside the reported stack area.
This is the minimal patch: it just propagates the error. It also
effectively makes the guard page part of the stack limit, which in turn
measn that the actual real stack is one page less than the stack limit.
Let's see if anybody notices. We could teach acct_stack_growth() to
allow an extra page for a grow-up/grow-down stack in the rlimit test,
but I don't want to add more complexity if it isn't needed.
Reported-and-tested-by: Jay Foad <jay.foad@gmail.com>
being killed
commit 9e5e3661727eaf960d3480213f8e87c8d67b6956 upstream.
Charles Shirron and Paul Cassella from Cray Inc have reported kswapd
stuck in a busy loop with nothing left to balance, but
kswapd_try_to_sleep() failing to sleep. Their analysis found the cause
to be a combination of several factors:
1. A process is waiting in throttle_direct_reclaim() on pgdat->pfmemalloc_wait
2. The process has been killed (by OOM in this case), but has not yet been
scheduled to remove itself from the waitqueue and die.
3. kswapd checks for throttled processes in prepare_kswapd_sleep():
if (waitqueue_active(&pgdat->pfmemalloc_wait)) {
wake_up(&pgdat->pfmemalloc_wait);
return false; // kswapd will not go to sleep
However, for a process that was already killed, wake_up() does not remove
the process from the waitqueue, since try_to_wake_up() checks its state
first and returns false when the process is no longer waiting.
4. kswapd is running on the same CPU as the only CPU that the process is
allowed to run on (through cpus_allowed, or possibly single-cpu system).
5. CONFIG_PREEMPT_NONE=y kernel is used. If there's nothing to balance, kswapd
encounters no voluntary preemption points and repeatedly fails
prepare_kswapd_sleep(), blocking the process from running and removing
itself from the waitqueue, which would let kswapd sleep.
So, the source of the problem is that we prevent kswapd from going to
sleep until there are processes waiting on the pfmemalloc_wait queue,
and a process waiting on a queue is guaranteed to be removed from the
queue only when it gets scheduled. This was done to make sure that no
process is left sleeping on pfmemalloc_wait when kswapd itself goes to
sleep.
However, it isn't necessary to postpone kswapd sleep until the
pfmemalloc_wait queue actually empties. To prevent processes from being
left sleeping, it's actually enough to guarantee that all processes
waiting on pfmemalloc_wait queue have been woken up by the time we put
kswapd to sleep.
This patch therefore fixes this issue by substituting 'wake_up' with
'wake_up_all' and removing 'return false' in the code snippet from
prepare_kswapd_sleep() above. Note that if any process puts itself in
the queue after this waitqueue_active() check, or after the wake up
itself, it means that the process will also wake up kswapd - and since
we are under prepare_to_wait(), the wake up won't be missed. Also we
update the comment prepare_kswapd_sleep() to hopefully more clearly
describe the races it is preventing.
Fixes: 5515061d22f0 ("mm: throttle direct reclaimers if PF_MEMALLOC reserves are low and swap is backed by network storage")
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
commit f61ff6c06dc8f32c7036013ad802c899ec590607 upstream.
Linus reported perf report command being interrupted due to processing
of 'out of order' event, with following error:
Timestamp below last timeslice flush
0x5733a8 [0x28]: failed to process type: 3
I could reproduce the issue and in my case it was caused by one CPU
(mmap) being behind during record and userspace mmap reader seeing the
data after other CPUs data were already stored.
This is expected under some circumstances because we need to limit the
number of events that we queue for reordering when we receive a
PERF_RECORD_FINISHED_ROUND or when we force flush due to memory
pressure.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Matt Fleming <matt.fleming@intel.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1417016371-30249-1-git-send-email-jolsa@kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[zhangzhiqiang: backport to 3.10:
- adjust context
- commit f61ff6c06d struct events_stats was defined in tools/perf/util/event.h
while 3.10 stable defined in tools/perf/util/hist.h.
- 3.10 stable there is no pr_oe_time() which used for debug.
- After the above adjustments, becomes same to the original patch:
https://github.com/torvalds/linux/commit/f61ff6c06dc8f32c7036013ad802c899ec590607
Signed-off-by: Zhiqiang Zhang <zhangzhiqiang.zhang@huawei.com>
commit 9fc81d87420d0d3fd62d5e5529972c0ad9eab9cc upstream.
We allow PMU driver to change the cpu on which the event
should be installed to. This happened in patch:
e2d37cd213dc ("perf: Allow the PMU driver to choose the CPU on which to install events")
This patch also forces all the group members to follow
the currently opened events cpu if the group happened
to be moved.
This and the change of event->cpu in perf_install_in_context()
function introduced in:
0cda4c023132 ("perf: Introduce perf_pmu_migrate_context()")
forces group members to change their event->cpu,
if the currently-opened-event's PMU changed the cpu
and there is a group move.
Above behaviour causes problem for breakpoint events,
which uses event->cpu to touch cpu specific data for
breakpoints accounting. By changing event->cpu, some
breakpoints slots were wrongly accounted for given
cpu.
Vinces's perf fuzzer hit this issue and caused following
WARN on my setup:
WARNING: CPU: 0 PID: 20214 at arch/x86/kernel/hw_breakpoint.c:119 arch_install_hw_breakpoint+0x142/0x150()
Can't find any breakpoint slot
This patch changes the group moving code to keep the event's
original cpu.
Reported-by: Vince Weaver <vince@deater.net>
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Vince Weaver <vince@deater.net>
Cc: Yan, Zheng <zheng.z.yan@intel.com>
Link: http://lkml.kernel.org/r/1418243031-20367-3-git-send-email-jolsa@kernel.org
commit af91568e762d04931dcbdd6bef4655433d8b9418 upstream.
The uncore_collect_events functions assumes that event group
might contain only uncore events which is wrong, because it
might contain any type of events.
This bug leads to uncore framework touching 'not' uncore events,
which could end up all sorts of bugs.
One was triggered by Vince's perf fuzzer, when the uncore code
touched breakpoint event private event space as if it was uncore
event and caused BUG:
BUG: unable to handle kernel paging request at ffffffff82822068
IP: [<ffffffff81020338>] uncore_assign_events+0x188/0x250
The code in uncore_assign_events() function was looking for
event->hw.idx data while the event was initialized as a
breakpoint with different members in event->hw union.
This patch forces uncore_collect_events() to collect only uncore
events.
Link: http://lkml.kernel.org/r/1418243031-20367-2-git-send-email-jolsa@kernel.org
commit 6f8960541b1eb6054a642da48daae2320fddba93 upstream.
Commit 1d52c78afbb (Btrfs: try not to ENOSPC on log replay) added a
check to skip delayed inode updates during log replay because it
confuses the enospc code. But the delayed processing will end up
ignoring delayed refs from log replay because the inode itself wasn't
put through the delayed code.
This can end up triggering a warning at commit time:
WARNING: CPU: 2 PID: 778 at fs/btrfs/delayed-inode.c:1410 btrfs_assert_delayed_root_empty+0x32/0x34()
Which is repeated for each commit because we never process the delayed
inode ref update.
The fix used here is to change btrfs_delayed_delete_inode_ref to return
an error if we're currently in log replay. The caller will do the ref
deletion immediately and everything will work properly.
Signed-off-by: Chris Mason <clm@fb.com>
commit e55355453600a33bb5ca4f71f2d7214875f3b061 upstream.
Enabling the hardware I/O coherency on Armada 370, Armada 375, Armada
38x and Armada XP requires a certain number of conditions:
- On Armada 370, the cache policy must be set to write-allocate.
- On Armada 375, 38x and XP, the cache policy must be set to
write-allocate, the pages must be mapped with the shareable
attribute, and the SMP bit must be set
Currently, on Armada XP, when CONFIG_SMP is enabled, those conditions
are met. However, when Armada XP is used in a !CONFIG_SMP kernel, none
of these conditions are met. With Armada 370, the situation is worse:
since the processor is single core, regardless of whether CONFIG_SMP
or !CONFIG_SMP is used, the cache policy will be set to write-back by
the kernel and not write-allocate.
Since solving this problem turns out to be quite complicated, and we
don't want to let users with a mainline kernel known to have
infrequent but existing data corruptions, this commit proposes to
simply disable hardware I/O coherency in situations where it is known
not to work.
And basically, the is_smp() function of the kernel tells us whether it
is OK to enable hardware I/O coherency or not, so this commit slightly
refactors the coherency_type() function to return
COHERENCY_FABRIC_TYPE_NONE when is_smp() is false, or the appropriate
type of the coherency fabric in the other case.
Thanks to this, the I/O coherency fabric will no longer be used at all
in !CONFIG_SMP configurations. It will continue to be used in
CONFIG_SMP configurations on Armada XP, Armada 375 and Armada 38x
(which are multiple cores processors), but will no longer be used on
Armada 370 (which is a single core processor).
In the process, it simplifies the implementation of the
coherency_type() function, and adds a missing call to of_node_put().
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Fixes: e60304f8cb7bb545e79fe62d9b9762460c254ec2 ("arm: mvebu: Add hardware I/O Coherency support")
Cc: <stable@vger.kernel.org> # v3.8+
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Link: https://lkml.kernel.org/r/1415871540-20302-3-git-send-email-thomas.petazzoni@free-electrons.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
commit 7b990789a4c3420fa57596b368733158e432d444 upstream.
The change from \d+ to .+ inside __aligned() means that the following
structure:
struct test {
u8 a __aligned(2);
u8 b __aligned(2);
essentially gets modified to
struct test {
u8 a;
for purposes of kernel-doc, thus dropping a struct member, which in
turns causes warnings and invalid kernel-doc generation.
Fix this by replacing the catch-all (".") with anything that's not a
semicolon ("[^;]").
Fixes: 9dc30918b23f ("scripts/kernel-doc: handle struct member __aligned without numbers")
Cc: Nishanth Menon <nm@ti.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Michal Marek <mmarek@suse.cz>
commit 705304a863cc41585508c0f476f6d3ec28cf7e00 upstream.
Same story as in commit 41080b5a2401 ("nfsd race fixes: ext2") (similar
ext2 fix) except that nilfs2 needs to use insert_inode_locked4() instead
of insert_inode_locked() and a bug of a check for dead inodes needs to
be fixed.
If nilfs_iget() is called from nfsd after nilfs_new_inode() calls
insert_inode_locked4(), nilfs_iget() will wait for unlock_new_inode() at
the end of nilfs_mkdir()/nilfs_create()/etc to unlock the inode.
If nilfs_iget() is called before nilfs_new_inode() calls
insert_inode_locked4(), it will create an in-core inode and read its
data from the on-disk inode. But, nilfs_iget() will find i_nlink equals
zero and fail at nilfs_read_inode_common(), which will lead it to call
iget_failed() and cleanly fail.
However, this sanity check doesn't work as expected for reused on-disk
inodes because they leave a non-zero value in i_mode field and it
hinders the test of i_nlink. This patch also fixes the issue by
removing the test on i_mode that nilfs2 doesn't need.
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit 5a64e56976f1ba98743e1678c0029a98e9034c81 upstream.
Fix a bug where nfsd4_encode_components_esc() includes the esc_end char as
an additional string encoding.
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
Fixes: e7a0444aef4a "nfsd: add IPv6 addr escaping to fs_location hosts"
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit ef17af2a817db97d42dd2ec0a425231748e23dbc upstream.
Bugs similar to the one in acbbe6fbb240 (kcmp: fix standard comparison
bug) are in rich supply.
In this variant, the problem is that struct xdr_netobj::len has type
unsigned int, so the expression o1->len - o2->len _also_ has type
unsigned int; it has completely well-defined semantics, and the result
is some non-negative integer, which is always representable in a long
long. But this means that if the conditional triggers, we are
guaranteed to return a positive value from compare_blob.
In this case it could be fixed by
- res = o1->len - o2->len;
+ res = (long long)o1->len - (long long)o2->len;
but I'd rather eliminate the usually broken 'return a - b;' idiom.
Reviewed-by: Jeff Layton <jlayton@primarydata.com>
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
commit 1ff383a4c3eda8893ec61b02831826e1b1f46b41 upstream.
This patch adds waiting until transmit buffer and shifter will be empty
before clock disabling.
Without this fix it's possible to have clock disabled while data was
not transmited yet, which causes unproper state of TX line and problems
in following data transfers.
Signed-off-by: Robert Baldyga <r.baldyga@samsung.com>
commit 9c6ac78eb3521c5937b2dd8a7d1b300f41092f45 upstream.
After invoking ->dirty_inode(), __mark_inode_dirty() does smp_mb() and
tests inode->i_state locklessly to see whether it already has all the
necessary I_DIRTY bits set. The comment above the barrier doesn't
contain any useful information - memory barriers can't ensure "changes
are seen by all cpus" by itself.
And it sure enough was broken. Please consider the following
scenario.
CPU 0 CPU 1
enters __writeback_single_inode()
grabs inode->i_lock
tests PAGECACHE_TAG_DIRTY which is clear
enters __set_page_dirty()
grabs mapping->tree_lock
sets PAGECACHE_TAG_DIRTY
releases mapping->tree_lock
leaves __set_page_dirty()
enters __mark_inode_dirty()
smp_mb()
sees I_DIRTY_PAGES set
leaves __mark_inode_dirty()
clears I_DIRTY_PAGES
releases inode->i_lock
Now @inode has dirty pages w/ I_DIRTY_PAGES clear. This doesn't seem
to lead to an immediately critical problem because requeue_inode()
later checks PAGECACHE_TAG_DIRTY instead of I_DIRTY_PAGES when
deciding whether the inode needs to be requeued for IO and there are
enough unintentional memory barriers inbetween, so while the inode
ends up with inconsistent I_DIRTY_PAGES flag, it doesn't fall off the
IO list.
The lack of explicit barrier may also theoretically affect the other
I_DIRTY bits which deal with metadata dirtiness. There is no
guarantee that a strong enough barrier exists between
I_DIRTY_[DATA]SYNC clearing and write_inode() writing out the dirtied
inode. Filesystem inode writeout path likely has enough stuff which
can behave as full barrier but it's theoretically possible that the
writeout may not see all the updates from ->dirty_inode().
Fix it by adding an explicit smp_mb() after I_DIRTY clearing. Note
that I_DIRTY_PAGES needs a special treatment as it always needs to be
cleared to be interlocked with the lockless test on
__mark_inode_dirty() side. It's cleared unconditionally and
reinstated after smp_mb() if the mapping still has dirty pages.
Also add comments explaining how and why the barriers are paired.
Lightly tested.
Cc: Jan Kara <jack@suse.cz>
Cc: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit d908f8478a8d18e66c80a12adb27764920c1f1ca upstream.
If probe() fails not only the attributes need to be removed
but also the memory freed.
Reported-by: Ahmed Tamrawi <ahmedtamrawi@gmail.com>
Signed-off-by: Oliver Neukum <oneukum@suse.de>
commit 5fabcb4c33fe11c7e3afdf805fde26c1a54d0953 upstream.
We can get here from blkdev_ioctl() -> blkpg_ioctl() -> add_partition()
with a user passed in partno value. If we pass in 0x7fffffff, the
new target in disk_expand_part_tbl() overflows the 'int' and we
access beyond the end of ptbl->part[] and even write to it when we
do the rcu_assign_pointer() to assign the new partition.
Reported-by: David Ramos <daramos@stanford.edu>
