commit 108cef3aa41669610e1836fe638812dd067d72de upstream.
It is critical that fetch_block() and handle_stripe_dirtying()
are consistent in their analysis of what needs to be loaded.
Otherwise raid5 can wait forever for a block that won't be loaded.
Currently when writing to a RAID5 that is resyncing, to a location
beyond the resync offset, handle_stripe_dirtying chooses a
reconstruct-write cycle, but fetch_block() assumes a
read-modify-write, and a lockup can happen.
So treat that case just like RAID6, just as we do in
handle_stripe_dirtying. RAID6 always does reconstruct-write.
This bug was introduced when the behaviour of handle_stripe_dirtying
was changed in 3.7, so the patch is suitable for any kernel since,
though it will need careful merging for some versions.
Cc: stable@vger.kernel.org (v3.7+)
Fixes: a7854487cd7128a30a7f4f5259de9f67d5efb95f
Reported-by: Henry Cai <henryplusplus@gmail.com>
Signed-off-by: NeilBrown <neilb@suse.de>
commit 7d7345322d60edb0fa49a64a89b31360f01d09cb upstream.
reaim workfile.dbase test easily triggers warning in
ext4_da_update_reserve_space():
EXT4-fs warning (device ram0): ext4_da_update_reserve_space:365:
ino 12, allocated 1 with only 0 reserved metadata blocks (releasing 1
blocks with reserved 9 data blocks)
The problem is that (one of) tests creates file and then randomly writes
to it with O_SYNC. That results in writing back pages of the file in
random order so we create extents for written blocks say 0, 2, 4, 6, 8
- this last allocation also allocates new block for extents. Then we
writeout block 1 so we have extents 0-2, 4, 6, 8 and we release
indirect extent block because extents fit in the inode again. Then we
writeout block 10 and we need to allocate indirect extent block again
which triggers the warning because we don't have the reservation
anymore.
Fix the problem by giving back freed metadata blocks resulting from
extent merging into inode's reservation pool.
Cc: Josh Hunt <johunt@akamai.com>
commit 1c8924eb106c1ac755d5d35ce9b3ff42e89e2511 upstream.
ext4 needs to convert allocated (metadata) blocks back into blocks
reserved for delayed allocation. Add functions into quota code for
supporting such operation.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 3e14dcf7cb80b34a1f38b55bc96f02d23fdaaaaf upstream.
Commit 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"")
changed the automatic module loading when requesting crypto algorithms
to prefix all module requests with "crypto-". This requires all crypto
modules to have a crypto specific module alias even if their file name
would otherwise match the requested crypto algorithm.
Even though commit 5d26a105b5a7 added those aliases for a vast amount of
modules, it was missing a few. Add the required MODULE_ALIAS_CRYPTO
annotations to those files to make them get loaded automatically, again.
This fixes, e.g., requesting 'ecb(blowfish-generic)', which used to work
with kernels v3.18 and below.
Also change MODULE_ALIAS() lines to MODULE_ALIAS_CRYPTO(). The former
won't work for crypto modules any more.
Fixes: 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"")
Signed-off-by: Mathias Krause <minipli@googlemail.com>
commit 4943ba16bbc2db05115707b3ff7b4874e9e3c560 upstream.
This adds the module loading prefix "crypto-" to the template lookup
as well.
For example, attempting to load 'vfat(blowfish)' via AF_ALG now correctly
includes the "crypto-" prefix at every level, correctly rejecting "vfat":
net-pf-38
algif-hash
crypto-vfat(blowfish)
crypto-vfat(blowfish)-all
crypto-vfat
Reported-by: Mathias Krause <minipli@googlemail.com>
Acked-by: Mathias Krause <minipli@googlemail.com>
commit 5d26a105b5a73e5635eae0629b42fa0a90e07b7b upstream.
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
commit 3b9d35d744bb5139f9fed57f38c019bb8c7d351c upstream.
This was not noticed for many years. Affects operation if
md raid is used a backing device for DRBD.
CC: stable@kernel.org # v3.2+
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com>
Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit dbdd74763f1faf799fbb9ed30423182e92919378 upstream.
This reverts commit 2c3fc8d26dd09b9d7069687eead849ee81c78e46.
This commit broke on x86 PV because entries in the generic SWIOTLB are
indexed using (pseudo-)physical address not DMA address and these are
not the same in a x86 PV guest.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
commit 3b05ac3824ed9648c0d9c02d51d9b54e4e7e874f upstream.
The app_tcp_pkt_out() function expects "*diff" to be set and ends up
using uninitialized data if CONFIG_IP_VS_IPV6 is turned on.
The same issue is there in app_tcp_pkt_in(). Thanks to Julian Anastasov
for noticing that.
Acked-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
commit a3a8784454692dd72e5d5d34dcdab17b4420e74c upstream.
When a key is being garbage collected, it's key->user would get put before
the ->destroy() callback is called, where the key is removed from it's
respective tracking structures.
This leaves a key hanging in a semi-invalid state which leaves a window open
for a different task to try an access key->user. An example is
find_keyring_by_name() which would dereference key->user for a key that is
in the process of being garbage collected (where key->user was freed but
->destroy() wasn't called yet - so it's still present in the linked list).
This would cause either a panic, or corrupt memory.
Fixes CVE-2014-9529.
commit 4aaa71873ddb9faf4b0c4826579e2f6d18ff9ab4 upstream.
DMA mapped IO should be unmapped on the error path in probe() and
unconditionally on remove().
Fixes: 62936009f35a ([libata] Add 460EX on-chip SATA driver, sata_dwc_460ex)
commit 7ddc6a2199f1da405a2fb68c40db8899b1a8cd87 upstream.
These functions can be executed on the int3 stack, so kprobes
are dangerous. Tracing is probably a bad idea, too.
Fixes: b645af2d5905 ("x86_64, traps: Rework bad_iret")
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Link: http://lkml.kernel.org/r/50e33d26adca60816f3ba968875801652507d0c4.1416870125.git.luto@amacapital.net
[bwh: Backported to 3.10:
- Use __kprobes instead of NOKPROBE_SYMBOL()
- Adjust context]
commit 3669ef9fa7d35f573ec9c0e0341b29251c2734a7 upstream.
The Witcher 2 did something like this to allocate a TLS segment index:
struct user_desc u_info;
bzero(&u_info, sizeof(u_info));
u_info.entry_number = (uint32_t)-1;
syscall(SYS_set_thread_area, &u_info);
Strictly speaking, this code was never correct. It should have set
read_exec_only and seg_not_present to 1 to indicate that it wanted
to find a free slot without putting anything there, or it should
have put something sensible in the TLS slot if it wanted to allocate
a TLS entry for real. The actual effect of this code was to
allocate a bogus segment that could be used to exploit espfix.
The set_thread_area hardening patches changed the behavior, causing
set_thread_area to return -EINVAL and crashing the game.
This changes set_thread_area to interpret this as a request to find
a free slot and to leave it empty, which isn't *quite* what the game
expects but should be close enough to keep it working. In
particular, using the code above to allocate two segments will
allocate the same segment both times.
According to FrostbittenKing on Github, this fixes The Witcher 2.
If this somehow still causes problems, we could instead allocate
a limit==0 32-bit data segment, but that seems rather ugly to me.
Fixes: 41bdc78544b8 x86/tls: Validate TLS entries to protect espfix
Cc: torvalds@linux-foundation.org
Link: http://lkml.kernel.org/r/0cb251abe1ff0958b8e468a9a9a905b80ae3a746.1421954363.git.luto@amacapital.net
commit e30ab185c490e9a9381385529e0fd32f0a399495 upstream.
32-bit programs don't have an lm bit in their ABI, so they can't
reliably cause LDT_empty to return true without resorting to memset.
They shouldn't need to do this.
This should fix a longstanding, if minor, issue in all 64-bit kernels
as well as a potential regression in the TLS hardening code.
Link: http://lkml.kernel.org/r/72a059de55e86ad5e2935c80aa91880ddf19d07c.1421954363.git.luto@amacapital.net
commit 520452172e6b318f3a8bd9d4fe1e25066393de25 upstream.
Many users see this message when booting without knowning that it is
of no importance and that TSC calibration may have succeeded by
another way.
As explained by Paul Bolle in
http://lkml.kernel.org/r/1348488259.1436.22.camel@x61.thuisdomein
"Fast TSC calibration failed" should not be considered as an error
since other calibration methods are being tried afterward. At most,
those send a warning if they fail (not an error). So let's change
the message from error to warning.
[ tglx: Make if pr_info. It's really not important at all ]
Fixes: c767a54ba065 x86/debug: Add KERN_<LEVEL> to bare printks, convert printks to pr_<level>
Signed-off-by: Alexandre Demers <alexandre.f.demers@gmail.com>
Link: http://lkml.kernel.org/r/1418106470-6906-1-git-send-email-alexandre.f.demers@gmail.com
commit 32c6590d126836a062b3140ed52d898507987017 upstream.
The Hyper-V clocksource is continuous; mark it accordingly.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Acked-by: jasowang@redhat.com
Cc: gregkh@linuxfoundation.org
Cc: devel@linuxdriverproject.org
Cc: olaf@aepfle.de
Cc: apw@canonical.com
Link: http://lkml.kernel.org/r/1421108762-3331-1-git-send-email-kys@microsoft.com
commit 8c38d28ba8da98f7102c31d35359b4dbe9d1f329 upstream.
EXYNOS4_MCT_L_MASK is defined as 0xffffff00, so applying this bitmask
produces a number outside the range 0x00 to 0xff, which always results
in execution of the default switch statement.
Obviously this is wrong and git history shows that the bitmask inversion
was incorrectly set during a refactoring of the MCT code.
Fix this by putting the inversion at the correct position again.
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Reported-by: GP Orcullo <kinsamanka@gmail.com>
Reviewed-by: Doug Anderson <dianders@chromium.org>
Signed-off-by: Tobias Jakobi <tjakobi@math.uni-bielefeld.de>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
commit 9b1087aa5e86448fe6ad40a58964e35f3ba423d5 upstream.
When changing flags in the CAN drivers ctrlmode the provided new content has to
be checked whether the bits are allowed to be changed. The bits that are to be
changed are given as a bitfield in cm->mask. Therefore checking against
cm->flags is wrong as the content can hold any kind of values.
The iproute2 tool sets the bits in cm->mask and cm->flags depending on the
detected command line options. To be robust against bogus user space
applications additionally sanitize the provided flags with the provided mask.
Cc: Wolfgang Grandegger <wg@grandegger.com>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 38bdf45f4aa5cb6186d50a29e6cbbd9d486a1519 upstream.
On Armada XP, 375 and 38x the MBus window 13 has the remap capability,
like windows 0 to 7. However, the mvebu-mbus driver isn't currently
taking into account this special case, which means that when window 13
is actually used, the remap registers are left to 0, making the device
using this MBus window unavailable.
As a minimal fix for stable, don't use window 13. A full fix will
follow later.
Fixes: fddddb52a6c ("bus: introduce an Marvell EBU MBus driver")
Reviewed-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
commit 7ecd0bde5bfea524a843ad8fa8cb66ccbce68779 upstream.
Currently PWM functionality is broken on mx25 due to the wrong assignment of the
PWM "per" clock.
According to Documentation/devicetree/bindings/clock/imx25-clock.txt:
pwm_ipg_per 52
,so update the pwm "per" to use 'pwm_ipg_per' instead of 'per10' clock.
With this change PWM can work fine on mx25.
Reported-by: Carlos Soto <csotoalonso@gmail.com>
commit 5e5aeb4367b450a28f447f6d5ab57d8f2ab16a5f upstream.
Verify that the frequency value from userspace is valid and makes sense.
Unverified values can cause overflows later on.
[jstultz: Fix up bug for negative values and drop redunent cap check]
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit 6ada1fc0e1c4775de0e043e1bd3ae9d065491aa5 upstream.
An unvalidated user input is multiplied by a constant, which can result in
an undefined behaviour for large values. While this is validated later,
we should avoid triggering undefined behaviour.
[jstultz: include trivial milisecond->microsecond correction noticed
by Andy]
commit 9b1cc9f251affdd27f29fe46d0989ba76c33faf6 upstream.
If a DM table is reloaded with an inactive table when the device is not
suspended (normal procedure for LVM2), then there will be two dm-bufio
objects that can diverge. This can lead to a situation where the
inactive table uses bufio to read metadata at the same time the active
table writes metadata -- resulting in the inactive table having stale
metadata buffers once it is promoted to the active table slot.
Fix this by using reference counting and a global list of cache metadata
objects to ensure there is only one metadata object per metadata device.
Signed-off-by: Joe Thornber <ejt@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 6cdb08172bc89f0a39e1643c5e7eab362692fd1b upstream.
Fixes a race condition in abort handling that was injected
when multiple interrupt support was added. When only a single
interrupt is present, the adapter guarantees it will send
responses for aborted commands prior to the response for the
abort command itself. With multiple interrupts, these responses
generally come back on different interrupts, so we need to
ensure the abort thread waits until the aborted command is
complete so we don't perform a double completion. This race
condition was being hit frequently in environments which
were triggering command timeouts, which was resulting in
a double completion causing a kernel oops.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Reviewed-by: Wendy Xiong <wenxiong@linux.vnet.ibm.com>
Tested-by: Wendy Xiong <wenxiong@linux.vnet.ibm.com>
commit 226e5ae9e5f9108beb0bde4ac69f68fe6210fed9 upstream.
If CONFIG_DEBUG_MUTEXES is set, the mutex->owner field is only cleared
if the mutex debugging is enabled which introduces a race in our
mutex_is_locked_by() - i.e. we may inspect the old owner value before it
is acquired by the new task.
This is the root cause of this error:
# diff --git a/kernel/locking/mutex-debug.c b/kernel/locking/mutex-debug.c
# index 5cf6731..3ef3736 100644
# --- a/kernel/locking/mutex-debug.c
# +++ b/kernel/locking/mutex-debug.c
# @@ -80,13 +80,13 @@ void debug_mutex_unlock(struct mutex *lock)
# DEBUG_LOCKS_WARN_ON(lock->owner != current);
# DEBUG_LOCKS_WARN_ON(!lock->wait_list.prev && !lock->wait_list.next);
# - mutex_clear_owner(lock);
# * __mutex_slowpath_needs_to_unlock() is explicitly 0 for debug
# * mutexes so that we can do it here after we've verified state.
# + mutex_clear_owner(lock);
# atomic_set(&lock->count, 1);
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=87955
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
commit 1caf6aaaa47471831d77c75f094d4e00ad1ec808 upstream.
Compiling SH with gcc-4.8 fails due to the -m32 option not being
supported.
From http://buildd.debian-ports.org/status/fetch.php?pkg=linux&arch=sh4&ver=3.16.7-ckt4-1&stamp=1421425783
CC init/main.o
gcc-4.8: error: unrecognized command line option '-m32'
ld: cannot find init/.tmp_mc_main.o: No such file or directory
objcopy: 'init/.tmp_mx_main.o': No such file
rm: cannot remove 'init/.tmp_mx_main.o': No such file or directory
rm: cannot remove 'init/.tmp_mc_main.o': No such file or directory
Link: http://lkml.kernel.org/r/1421537778-29001-1-git-send-email-kernel@mkarcher.dialup.fu-berlin.de
Link: http://lkml.kernel.org/r/54BCBDD4.10102@physik.fu-berlin.de
Cc: Matt Fleming <matt@console-pimps.org>
Reported-by: John Paul Adrian Glaubitz <glaubitz@physik.fu-berlin.de>
Signed-off-by: Michael Karcher <kernel@mkarcher.dialup.fu-berlin.de>
commit 6455931186bff407493135e74c5f32efd30860e2 upstream.
Signed-off-by: Jason Lee Cragg <jcragg@gmail.com>
commit ce7514526742c0898b837d4395f515b79dfb5a12 upstream.
It is possible for ata_sff_flush_pio_task() to set ap->hsm_task_state to
HSM_ST_IDLE in between the time __ata_sff_port_intr() checks for HSM_ST_IDLE
and before it calls ata_sff_hsm_move() causing ata_sff_hsm_move() to BUG().
This problem is hard to reproduce making this patch hard to verify, but this
fix will prevent the race.
I have not been able to reproduce the problem, but here is a crash dump from
a 2.6.32 kernel.
On examining the ata port's state, its hsm_task_state field has a value of HSM_ST_IDLE:
crash> struct ata_port.hsm_task_state ffff881c1121c000
hsm_task_state = 0
Normally, this should not be possible as ata_sff_hsm_move() was called from ata_sff_host_intr(),
which checks hsm_task_state and won't call ata_sff_hsm_move() if it has a HSM_ST_IDLE value.
PID: 11053 TASK: ffff8816e846cae0 CPU: 0 COMMAND: "sshd"
#0 [ffff88008ba03960] machine_kexec at ffffffff81038f3b
#1 [ffff88008ba039c0] crash_kexec at ffffffff810c5d92
#2 [ffff88008ba03a90] oops_end at ffffffff8152b510
#3 [ffff88008ba03ac0] die at ffffffff81010e0b
#4 [ffff88008ba03af0] do_trap at ffffffff8152ad74
#5 [ffff88008ba03b50] do_invalid_op at ffffffff8100cf95
#6 [ffff88008ba03bf0] invalid_op at ffffffff8100bf9b
[exception RIP: ata_sff_hsm_move+317]
RIP: ffffffff813a77ad RSP: ffff88008ba03ca0 RFLAGS: 00010097
RAX: 0000000000000000 RBX: ffff881c1121dc60 RCX: 0000000000000000
RDX: ffff881c1121dd10 RSI: ffff881c1121dc60 RDI: ffff881c1121c000
RBP: ffff88008ba03d00 R8: 0000000000000000 R9: 000000000000002e
R10: 000000000001003f R11: 000000000000009b R12: ffff881c1121c000
R13: 0000000000000000 R14: 0000000000000050 R15: ffff881c1121dd78
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018
#7 [ffff88008ba03d08] ata_sff_host_intr at ffffffff813a7fbd
#8 [ffff88008ba03d38] ata_sff_interrupt at ffffffff813a821e
#9 [ffff88008ba03d78] handle_IRQ_event at ffffffff810e6ec0
commit db93facfb0ef542aa5d8079e47580b3e669a4d82 upstream.
This patch is to fix two deadlock cases.
Deadlock 1:
CPU #1
pinctrl_register-> pinctrl_get ->
create_pinctrl
(Holding lock pinctrl_maps_mutex)
-> get_pinctrl_dev_from_devname
(Trying to acquire lock pinctrldev_list_mutex)
CPU #0
pinctrl_unregister
(Holding lock pinctrldev_list_mutex)
-> pinctrl_put ->> pinctrl_free ->
pinctrl_dt_free_maps -> pinctrl_unregister_map
(Trying to acquire lock pinctrl_maps_mutex)
Simply to say
CPU#1 is holding lock A and trying to acquire lock B,
CPU#0 is holding lock B and trying to acquire lock A.
Deadlock 2:
CPU #3
create_pinctrl
CPU #2
pinctrl_unregister
(Holding lock pctldev->mutex)
CPU #0
tegra_gpio_request
-> pinctrl_get_device_gpio_range
(Trying to acquire lock pctldev->mutex)
Simply to say
CPU#3 is holding lock A and trying to acquire lock D,
CPU#2 is holding lock B and trying to acquire lock A,
CPU#0 is holding lock D and trying to acquire lock B.
Signed-off-by: Jim Lin <jilin@nvidia.com>
commit 0915e6feb38de8d3601819992a5bd050201a56fa upstream.
The gpio device attributes were never destroyed when the gpio was
unexported (or on export failures).
Use device_create_with_groups() to create the default device attributes
of the gpio class device. Note that this also fixes the
attribute-creation race with userspace for these attributes.
Remove contingent attributes in export error path and on unexport.
Fixes: d8f388d8dc8d ("gpio: sysfs interface")
Cc: stable <stable@vger.kernel.org> # v2.6.27+
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 121b6a79955a3a3fd7bbb9b8cb88d5b9dad6283d upstream.
The gpio-chip device attributes were never destroyed when the device was
removed.
Fix by using device_create_with_groups() to create the device attributes
of the chip class device.
Note that this also fixes the attribute-creation race with userspace.
commit e512d56c799517f33b301d81e9a5e0ebf30c2d1e upstream.
git commit 37f81fa1f63ad38e16125526bb2769ae0ea8d332
"n_tty: do O_ONLCR translation as a single write"
surfaced a bug in the 3215 device driver. In combination this
broke tab expansion for tty ouput.
The cause is an asymmetry in the behaviour of tty3215_ops->write
vs tty3215_ops->put_char. The put_char function scans for '\t'
but the write function does not.
As the driver has logic for the '\t' expansion remove XTABS
from c_oflag of the initial termios as well.
Reported-by: Stephen Powell <zlinuxman@wowway.com>
commit 26d766c60f4ea08cd14f0f3435a6db3d6cc2ae96 upstream.
The ccw_device_start in raw3215_start_io can fail. raw3215_try_io
does not check if the request could be started and removes any
pending timer. This can leave the system in a hanging state.
Check for pending request after raw3215_start_io and start a
timer if necessary.
commit 6424babfd68dd8a83d9c60a5242d27038856599f upstream.
During file system stress testing on 3.10 and 3.12 based kernels, the
umount command occasionally hung in fsnotify_unmount_inodes in the
section of code:
spin_lock(&inode->i_lock);
if (inode->i_state & (I_FREEING|I_WILL_FREE|I_NEW)) {
spin_unlock(&inode->i_lock);
continue;
As this section of code holds the global inode_sb_list_lock, eventually
the system hangs trying to acquire the lock.
Multiple crash dumps showed:
The inode->i_state == 0x60 and i_count == 0 and i_sb_list would point
back at itself. As this is not the value of list upon entry to the
function, the kernel never exits the loop.
To help narrow down problem, the call to list_del_init in
inode_sb_list_del was changed to list_del. This poisons the pointers in
the i_sb_list and causes a kernel to panic if it transverse a freed
inode.
Subsequent stress testing paniced in fsnotify_unmount_inodes at the
bottom of the list_for_each_entry_safe loop showing next_i had become
free.
We believe the root cause of the problem is that next_i is being freed
during the window of time that the list_for_each_entry_safe loop
temporarily releases inode_sb_list_lock to call fsnotify and
fsnotify_inode_delete.
The code in fsnotify_unmount_inodes attempts to prevent the freeing of
inode and next_i by calling __iget. However, the code doesn't do the
__iget call on next_i
if i_count == 0 or
if i_state & (I_FREEING | I_WILL_FREE)
The patch addresses this issue by advancing next_i in the above two cases
until we either find a next_i which we can __iget or we reach the end of
the list. This makes the handling of next_i more closely match the
handling of the variable "inode."
The time to reproduce the hang is highly variable (from hours to days.) We
ran the stress test on a 3.10 kernel with the proposed patch for a week
without failure.
During list_for_each_entry_safe, next_i is becoming free causing
the loop to never terminate. Advance next_i in those cases where
__iget is not done.
Signed-off-by: Jerry Hoemann <jerry.hoemann@hp.com>
Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
Cc: Ken Helias <kenhelias@firemail.de>
Cc: Jan Kara <jack@suse.cz>
commit 2196937e12b1b4ba139806d132647e1651d655df upstream.
We could be reading 8 bytes into a 4 byte buffer here. It seems
harmless but adding a check is the right thing to do and it silences a
static checker warning.
Acked-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
commit 2836766a9d0bd02c66073f8dd44796e6cc23848d upstream.
Sleep in atomic context happened on Trats2 board after inserting or
removing SD card because mmc_gpio_get_cd() was called under spin lock.
Fix this by moving card detection earlier, before acquiring spin lock.
The mmc_gpio_get_cd() call does not have to be protected by spin lock
because it does not access any sdhci internal data.
The sdhci_do_get_cd() call access host flags (SDHCI_DEVICE_DEAD). After
moving it out side of spin lock it could theoretically race with driver
removal but still there is no actual protection against manual card
eject.
Dmesg after inserting SD card:
[ 41.663414] BUG: sleeping function called from invalid context at drivers/gpio/gpiolib.c:1511
[ 41.670469] in_atomic(): 1, irqs_disabled(): 128, pid: 30, name: kworker/u8:1
[ 41.677580] INFO: lockdep is turned off.
[ 41.681486] irq event stamp: 61972
[ 41.684872] hardirqs last enabled at (61971): [<c0490ee0>] _raw_spin_unlock_irq+0x24/0x5c
[ 41.693118] hardirqs last disabled at (61972): [<c04907ac>] _raw_spin_lock_irq+0x18/0x54
[ 41.701190] softirqs last enabled at (61648): [<c0026fd4>] __do_softirq+0x234/0x2c8
[ 41.708914] softirqs last disabled at (61631): [<c00273a0>] irq_exit+0xd0/0x114
[ 41.716206] Preemption disabled at:[< (null)>] (null)
[ 41.721500]
[ 41.722985] CPU: 3 PID: 30 Comm: kworker/u8:1 Tainted: G W 3.18.0-rc5-next-20141121 #883
[ 41.732111] Workqueue: kmmcd mmc_rescan
[ 41.735945] [<c0014d2c>] (unwind_backtrace) from [<c0011c80>] (show_stack+0x10/0x14)
[ 41.743661] [<c0011c80>] (show_stack) from [<c0489d14>] (dump_stack+0x70/0xbc)
[ 41.750867] [<c0489d14>] (dump_stack) from [<c0228b74>] (gpiod_get_raw_value_cansleep+0x18/0x30)
[ 41.759628] [<c0228b74>] (gpiod_get_raw_value_cansleep) from [<c03646e8>] (mmc_gpio_get_cd+0x38/0x58)
[ 41.768821] [<c03646e8>] (mmc_gpio_get_cd) from [<c036d378>] (sdhci_request+0x50/0x1a4)
[ 41.776808] [<c036d378>] (sdhci_request) from [<c0357934>] (mmc_start_request+0x138/0x268)
[ 41.785051] [<c0357934>] (mmc_start_request) from [<c0357cc8>] (mmc_wait_for_req+0x58/0x1a0)
[ 41.793469] [<c0357cc8>] (mmc_wait_for_req) from [<c0357e68>] (mmc_wait_for_cmd+0x58/0x78)
[ 41.801714] [<c0357e68>] (mmc_wait_for_cmd) from [<c0361c00>] (mmc_io_rw_direct_host+0x98/0x124)
[ 41.810480] [<c0361c00>] (mmc_io_rw_direct_host) from [<c03620f8>] (sdio_reset+0x2c/0x64)
[ 41.818641] [<c03620f8>] (sdio_reset) from [<c035a3d8>] (mmc_rescan+0x254/0x2e4)
[ 41.826028] [<c035a3d8>] (mmc_rescan) from [<c003a0e0>] (process_one_work+0x180/0x3f4)
[ 41.833920] [<c003a0e0>] (process_one_work) from [<c003a3bc>] (worker_thread+0x34/0x4b0)
[ 41.841991] [<c003a3bc>] (worker_thread) from [<c003fed8>] (kthread+0xe4/0x104)
[ 41.849285] [<c003fed8>] (kthread) from [<c000f268>] (ret_from_fork+0x14/0x2c)
[ 42.038276] mmc0: new high speed SDHC card at address 1234
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Fixes: 94144a465dd0 ("mmc: sdhci: add get_cd() implementation")
Cc: <stable@vger.kernel.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit 06bed7d18c2c07b3e3eeadf4bd357f6e806618cc upstream.
This commit fixes a race whereby nlmclnt_init() first starts the lockd
daemon, and then calls nlm_bind_host() with the expectation that
nlmsvc_timeout has already been initialised. Unfortunately, there is no
no synchronisation between lockd() and lockd_up() to guarantee that this
is the case.
Fix is to move the initialisation of nlmsvc_timeout into lockd_create_svc
Fixes: 9a1b6bf818e74 ("LOCKD: Don't call utsname()->nodename...")
Cc: Bruce Fields <bfields@fieldses.org>
Cc: stable@vger.kernel.org # 3.10.x
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit b485342bd79af363c77ef1a421c4a0aef2de9812 upstream.
Commit a074335a370e ("x86, um: Mark system call tables readonly") was
supposed to mark the sys_call_table in UML as RO by adding the const,
but it doesn't have the desired effect as it's nevertheless being placed
into the data section since __cacheline_aligned enforces sys_call_table
being placed into .data..cacheline_aligned instead. We need to use
the ____cacheline_aligned version instead to fix this issue.
Before:
$ nm -v arch/x86/um/sys_call_table_64.o | grep -1 "sys_call_table"
U sys_writev
0000000000000000 D sys_call_table
0000000000000000 D syscall_table_size
After:
U sys_writev
0000000000000000 R sys_call_table
Fixes: a074335a370e ("x86, um: Mark system call tables readonly")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Richard Weinberger <richard@nod.at>
commit f911d731054ab3d82ee72a16b889e17ca3a2332a upstream.
futex_atomic_cmpxchg_inatomic() does not work on UML because
it triggers a copy_from_user() in kernel context.
On UML copy_from_user() can only be used if the kernel was called
by a real user space process such that UML can use ptrace()
to fetch the value.
Reported-by: Miklos Szeredi <miklos@szeredi.hu>
Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Tested-by: Daniel Walter <d.walter@0x90.at>
commit b5c8afe5be51078a979d86ae5ae78c4ac948063d upstream.
"origPtr" is used as an offset into the bd->dbuf[] array. That array is
allocated in start_bunzip() and has "bd->dbufSize" number of elements so
the test here should be >= instead of >.
Later we check "origPtr" again before using it as an offset so I don't
know if this bug can be triggered in real life.
Fixes: bc22c17e12c1 ('bzip2/lzma: library support for gzip, bzip2 and lzma decompression')
Cc: Alain Knaff <alain@knaff.lu>
Cc: Yinghai Lu <yinghai@kernel.org>
commit b0ddb319db3d7a1943445f0de0a45c07a7f3457a upstream.
The sh73a0 INTC can't mask interrupts properly most likely due to a
hardware bug. Set the .control_parent flag to delegate masking to the
parent interrupt controller, like was already done for irqpin1.
Without this, accessing the three-axis digital accelerometer ADXL345
on kzm9g through /dev/input/event1 causes an interrupt storm, which
requires a power-cycle to recover from.
This was inspired by a patch for arch/arm/boot/dts/sh73a0.dtsi from
Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Fixes: 341eb5465f67437a ("ARM: shmobile: INTC External IRQ pin driver on sh73a0")
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
commit 572b24e6d85d98cdc552f07e9fb9870d9460d81b upstream.
The switch statement of the possible list of SYSCLK1 frequencies is
missing a 0 in 4 out of the 7 frequencies.
Fixes: fa6d79d27614 ("ARM: OMAP: Add initialisation for the real-time counter")
Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Acked-by: Nishanth Menon <nm@ti.com>
commit 81ef447950bf0955aca46f4a7617d8ce435cf0ce upstream.
The post dividers do not work on i.MX6Q rev T0 1.0 so they must be fixed
to 1. As the table index was wrong, a divider a of 4 could still be
requested which implied the clock not to be set properly. This is the
root cause of the HDMI not working at high resolution on rev T0 1.0 of
the SoC.
Signed-off-by: Gary Bisson <bisson.gary@gmail.com>
commit d2a10a1727b3948019128e83162f22c65859f1fd upstream.
Drop unnecessary semicolon after closing curly bracket.
Signed-off-by: Dmitry Voytik <voytikd@gmail.com>
commit 7a87e9cbc3a2f0ff0955815335e08c9862359130 upstream.
From Documentation/devicetree/bindings/clock/imx25-clock.txt:
cspi1_ipg 78
cspi2_ipg 79
cspi3_ipg 80
, so fix the SPI1 clocks accordingly to avoid a kernel hang when trying to
access SPI1.
commit 9333caeaeae4f831054e0e127a6ed3948b604d3e upstream.
When KBC is in active multiplexing mode the touchpad on this laptop does
not work.
Reported-by: Bilal Koc <koc.bilo@googlemail.com>
commit 148e9a711e034e06310a8c36b64957934ebe30f2 upstream.
On some laptops, keyboard needs to be reset in order to successfully detect
touchpad (e.g., some Gigabyte laptop models with Elantech touchpads).
Without resettin keyboard touchpad pretends to be completely dead.
Based on the original patch by Mateusz Jończyk this version has been
expanded to include DMI based detection & application of the fix
automatically on the affected models of laptops. This has been confirmed to
fix problem by three users already on three different models of laptops.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=81331
Signed-off-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com>
Acked-by: Mateusz Jończyk <mat.jonczyk@o2.pl>
Tested-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com>
Tested by: Zakariya Dehlawi <zdehlawi@gmail.com>
Tested-by: Guillaum Bouchard <guillaum.bouchard@gmail.com>
commit 5e7e6e0c9b47a45576c38b4a72d67927a5e049f7 upstream.
Recent Leaf firmware versions (>= 3.1.557) do not allow to send
commands for non-existing channels. If a command is sent for a
non-existing channel, the firmware crashes.
Reported-by: Christopher Storah <Christopher.Storah@invetech.com.au>
Signed-off-by: Olivier Sobrie <olivier@sobrie.be>
Signed-off-by: Ahmed S. Darwish <ahmed.darwish@valeo.com>
