2015-05-13Linux 3.10.78v3.10.78Greg Kroah-Hartman
2015-05-13ARC: signal handling robustifyVineet Gupta
commit e4140819dadc3624accac8294881bca8a3cba4ed upstream. A malicious signal handler / restorer can DOS the system by fudging the user regs saved on stack, causing weird things such as sigreturn returning to user mode PC but cpu state still being kernel mode.... Ensure that in sigreturn path status32 always has U bit; any other bogosity (gargbage PC etc) will be taken care of by normal user mode exceptions mechanisms. Reproducer signal handler: void handle_sig(int signo, siginfo_t *info, void *context) { ucontext_t *uc = context; struct user_regs_struct *regs = &(uc->uc_mcontext.regs); regs->scratch.status32 = 0; } Before the fix, kernel would go off to weeds like below: --------->8----------- [ARCLinux]$ ./signal-test Path: /signal-test CPU: 0 PID: 61 Comm: signal-test Not tainted 4.0.0-rc5+ #65 task: 8f177880 ti: 5ffe6000 task.ti: 8f15c000 [ECR ]: 0x00220200 => Invalid Write @ 0x00000010 by insn @ 0x00010698 [EFA ]: 0x00000010 [BLINK ]: 0x2007c1ee [ERET ]: 0x10698 [STAT32]: 0x00000000 : <-------- BTA: 0x00010680 SP: 0x5ffe7e48 FP: 0x00000000 LPS: 0x20003c6c LPE: 0x20003c70 LPC: 0x00000000 ... --------->8----------- Reported-by: Alexey Brodkin <abrodkin@synopsys.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13UBI: fix soft lockup in ubi_check_volume()hujianyang
commit 9aa272b492e7551a9ee0e2c83c720ea013698485 upstream. Running mtd-utils/tests/ubi-tests/io_basic.c could cause soft lockup or watchdog reset. It is because *updatevol* will perform ubi_check_volume() after updating finish and this function will full scan the updated lebs if the volume is initialized as STATIC_VOLUME. This patch adds *cond_resched()* in the loop of lebs scan to avoid soft lockup. Helped by Richard Weinberger <richard@nod.at> [ 2158.067096] INFO: rcu_sched self-detected stall on CPU { 1} (t=2101 jiffies g=1606 c=1605 q=56) [ 2158.172867] CPU: 1 PID: 2073 Comm: io_basic Tainted: G O 3.10.53 #21 [ 2158.172898] [<c000f624>] (unwind_backtrace+0x0/0x120) from [<c000c294>] (show_stack+0x10/0x14) [ 2158.172918] [<c000c294>] (show_stack+0x10/0x14) from [<c008ac3c>] (rcu_check_callbacks+0x1c0/0x660) [ 2158.172936] [<c008ac3c>] (rcu_check_callbacks+0x1c0/0x660) from [<c002b480>] (update_process_times+0x38/0x64) [ 2158.172953] [<c002b480>] (update_process_times+0x38/0x64) from [<c005ff38>] (tick_sched_handle+0x54/0x60) [ 2158.172966] [<c005ff38>] (tick_sched_handle+0x54/0x60) from [<c00601ac>] (tick_sched_timer+0x44/0x74) [ 2158.172978] [<c00601ac>] (tick_sched_timer+0x44/0x74) from [<c003f348>] (__run_hrtimer+0xc8/0x1b8) [ 2158.172992] [<c003f348>] (__run_hrtimer+0xc8/0x1b8) from [<c003fd9c>] (hrtimer_interrupt+0x128/0x2a4) [ 2158.173007] [<c003fd9c>] (hrtimer_interrupt+0x128/0x2a4) from [<c0246f1c>] (arch_timer_handler_virt+0x28/0x30) [ 2158.173022] [<c0246f1c>] (arch_timer_handler_virt+0x28/0x30) from [<c0086214>] (handle_percpu_devid_irq+0x9c/0x124) [ 2158.173036] [<c0086214>] (handle_percpu_devid_irq+0x9c/0x124) from [<c0082bd8>] (generic_handle_irq+0x20/0x30) [ 2158.173049] [<c0082bd8>] (generic_handle_irq+0x20/0x30) from [<c000969c>] (handle_IRQ+0x64/0x8c) [ 2158.173060] [<c000969c>] (handle_IRQ+0x64/0x8c) from [<c0008544>] (gic_handle_irq+0x3c/0x60) [ 2158.173074] [<c0008544>] (gic_handle_irq+0x3c/0x60) from [<c02f0f80>] (__irq_svc+0x40/0x50) [ 2158.173083] Exception stack(0xc4043c98 to 0xc4043ce0) [ 2158.173092] 3c80: c4043ce4 00000019 [ 2158.173102] 3ca0: 1f8a865f c050ad10 1f8a864c 00000031 c04b5970 0003ebce 00000000 f3550000 [ 2158.173113] 3cc0: bf00bc68 00000800 0003ebce c4043ce0 c0186d14 c0186cb8 80000013 ffffffff [ 2158.173130] [<c02f0f80>] (__irq_svc+0x40/0x50) from [<c0186cb8>] (read_current_timer+0x4/0x38) [ 2158.173145] [<c0186cb8>] (read_current_timer+0x4/0x38) from [<1f8a865f>] (0x1f8a865f) [ 2183.927097] BUG: soft lockup - CPU#1 stuck for 22s! [io_basic:2073] [ 2184.002229] Modules linked in: nandflash(O) [last unloaded: nandflash] Signed-off-by: Wang Kai <morgan.wang@huawei.com> Signed-off-by: hujianyang <hujianyang@huawei.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13Drivers: hv: vmbus: Don't wait after requesting offersK. Y. Srinivasan
commit 73cffdb65e679b98893f484063462c045adcf212 upstream. Don't wait after sending request for offers to the host. This wait is unnecessary and simply adds 5 seconds to the boot time. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Cc: <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ARM: dts: dove: Fix uart[23] reg propertySebastian Hesselbarth
commit a74cd13b807029397f7232449df929bac11fb228 upstream. Fix Dove's register addresses of uart2 and uart3 nodes that seem to be broken since ages due to a copy-and-paste error. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13staging: panel: fix lcd typeSudip Mukherjee
commit 2c20d92dad5db6440cfa88d811b69fd605240ce4 upstream. the lcd type as defined in the Kconfig is not matching in the code. as a result the rs, rw and en pins were getting interchanged. Kconfig defines the value of PANEL_LCD to be 1 if we select custom configuration but in the code LCD_TYPE_CUSTOM is defined as 5. my hardware is LCD_TYPE_CUSTOM, but the pins were assigned to it as pins of LCD_TYPE_OLD, and it was not working. Now values are corrected with referenece to the values defined in Kconfig and it is working. checked on JHD204A lcd with LCD_TYPE_CUSTOM configuration. Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org> Acked-by: Willy Tarreau <w@1wt.eu> [wt: backport to 3.10 and 3.14] Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13usb: gadget: printer: enqueue printer's response for setup requestAndrzej Pietrasiewicz
commit eb132ccbdec5df46e29c9814adf76075ce83576b upstream. Function-specific setup requests should be handled in such a way, that apart from filling in the data buffer, the requests are also actually enqueued: if function-specific setup is called from composte_setup(), the "usb_ep_queue()" block of code in composite_setup() is skipped. The printer function lacks this part and it results in e.g. get device id requests failing: the host expects some response, the device prepares it but does not equeue it for sending to the host, so the host finally asserts timeout. This patch adds enqueueing the prepared responses. Fixes: 2e87edf49227: "usb: gadget: make g_printer use composite" Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com> [ported to stable 3.10 and 3.14] Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13usb: host: oxu210hp: use new USB_RESUME_TIMEOUTFelipe Balbi
commit 84c0d178eb9f3a3ae4d63dc97a440266cf17f7f5 upstream. Make sure we're using the new macro, so our resume signaling will always pass certification. Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-133w-sas: fix command completion raceChristoph Hellwig
commit 579d69bc1fd56d5af5761969aa529d1d1c188300 upstream. The 3w-sas driver needs to tear down the dma mappings before returning the command to the midlayer, as there is no guarantee the sglist and count are valid after that point. Also remove the dma mapping helpers which have another inherent race due to the request_id index. Signed-off-by: Christoph Hellwig <hch@lst.de> Reported-by: Torsten Luettgert <ml-lkml@enda.eu> Tested-by: Bernd Kardatzki <Bernd.Kardatzki@med.uni-tuebingen.de> Acked-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <JBottomley@Odin.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-133w-9xxx: fix command completion raceChristoph Hellwig
commit 118c855b5623f3e2e6204f02623d88c09e0c34de upstream. The 3w-9xxx driver needs to tear down the dma mappings before returning the command to the midlayer, as there is no guarantee the sglist and count are valid after that point. Also remove the dma mapping helpers which have another inherent race due to the request_id index. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <JBottomley@Odin.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-133w-xxxx: fix command completion raceChristoph Hellwig
commit 9cd9554615cba14f0877cc9972a6537ad2bdde61 upstream. The 3w-xxxx driver needs to tear down the dma mappings before returning the command to the midlayer, as there is no guarantee the sglist and count are valid after that point. Also remove the dma mapping helpers which have another inherent race due to the request_id index. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <JBottomley@Odin.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ext4: fix data corruption caused by unwritten and delayed extentsLukas Czerner
commit d2dc317d564a46dfc683978a2e5a4f91434e9711 upstream. Currently it is possible to lose whole file system block worth of data when we hit the specific interaction with unwritten and delayed extents in status extent tree. The problem is that when we insert delayed extent into extent status tree the only way to get rid of it is when we write out delayed buffer. However there is a limitation in the extent status tree implementation so that when inserting unwritten extent should there be even a single delayed block the whole unwritten extent would be marked as delayed. At this point, there is no way to get rid of the delayed extents, because there are no delayed buffers to write out. So when a we write into said unwritten extent we will convert it to written, but it still remains delayed. When we try to write into that block later ext4_da_map_blocks() will set the buffer new and delayed and map it to invalid block which causes the rest of the block to be zeroed loosing already written data. For now we can fix this by simply not allowing to set delayed status on written extent in the extent status tree. Also add WARN_ON() to make sure that we notice if this happens in the future. This problem can be easily reproduced by running the following xfs_io. xfs_io -f -c "pwrite -S 0xaa 4096 2048" \ -c "falloc 0 131072" \ -c "pwrite -S 0xbb 65536 2048" \ -c "fsync" /mnt/test/fff echo 3 > /proc/sys/vm/drop_caches xfs_io -c "pwrite -S 0xdd 67584 2048" /mnt/test/fff This can be theoretically also reproduced by at random by running fsx, but it's not very reliable, though on machines with bigger page size (like ppc) this can be seen more often (especially xfstest generic/127) Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13rbd: end I/O the entire obj_request on errorIlya Dryomov
commit 082a75dad84d79d1c15ea9e50f31cb4bb4fa7fd6 upstream. When we end I/O struct request with error, we need to pass obj_request->length as @nr_bytes so that the entire obj_request worth of bytes is completed. Otherwise block layer ends up confused and we trip on rbd_assert(more ^ (which == img_request->obj_request_count)); in rbd_img_obj_callback() due to more being true no matter what. We already do it in most cases but we are missing some, in particular those where we don't even get a chance to submit any obj_requests, due to an early -ENOMEM for example. A number of obj_request->xferred assignments seem to be redundant but I haven't touched any of obj_request->xferred stuff to keep this small and isolated. Cc: Alex Elder <elder@linaro.org> Reported-by: Shawn Edwards <lesser.evil@gmail.com> Reviewed-by: Sage Weil <sage@redhat.com> Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13serial: of-serial: Remove device_type = "serial" registrationMichal Simek
commit 6befa9d883385c580369a2cc9e53fbf329771f6d upstream. Do not probe all serial drivers by of_serial.c which are using device_type = "serial"; property. Only drivers which have valid compatible strings listed in the driver should be probed. When PORT_UNKNOWN is setup probe will fail anyway. Arnd quotation about driver historical background: "when I wrote that driver initially, the idea was that it would get used as a stub to hook up all other serial drivers but after that, the common code learned to create platform devices from DT" This patch fix the problem with on the system with xilinx_uartps and 16550a where of_serial failed to register for xilinx_uartps and because of irq_dispose_mapping() removed irq_desc. Then when xilinx_uartps was asking for irq with request_irq() EINVAL is returned. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ALSA: hda - Fix mute-LED fixed modeTakashi Iwai
commit ee52e56e7b12834476cd0031c5986254ba1b6317 upstream. The mute-LED mode control has the fixed on/off states that are supposed to remain on/off regardless of the master switch. However, this doesn't work actually because the vmaster hook is called in the vmaster code itself. This patch fixes it by calling the hook indirectly after checking the mute LED mode. Reported-and-tested-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ALSA: emu10k1: Emu10k2 32 bit DMA modePeter Zubaj
commit 7241ea558c6715501e777396b5fc312c372e11d9 upstream. Looks like audigy emu10k2 (probably emu10k1 - sb live too) support two modes for DMA. Second mode is useful for 64 bit os with more then 2 GB of ram (fixes problems with big soundfont loading) 1) 32MB from 2 GB address space using 8192 pages (used now as default) 2) 16MB from 4 GB address space using 4096 pages Mode is set using HCFG_EXPANDED_MEM flag in HCFG register. Also format of emu10k2 page table is then different. Signed-off-by: Peter Zubaj <pzubaj@marticonet.sk> Tested-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ALSA: emu10k1: Fix card shortname string buffer overflowTakashi Iwai
commit d02260824e2cad626fb2a9d62e27006d34b6dedc upstream. Some models provide too long string for the shortname that has 32bytes including the terminator, and it results in a non-terminated string exposed to the user-space. This isn't too critical, though, as the string is stopped at the succeeding longname string. This patch fixes such entries by dropping "SB" prefix (it's enough to fit within 32 bytes, so far). Meanwhile, it also changes strcpy() with strlcpy() to make sure that this kind of problem won't happen in future, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ALSA: emux: Fix mutex deadlock in OSS emulationTakashi Iwai
commit 1c94e65c668f44d2c69ae7e7fc268ab3268fba3e upstream. The OSS emulation in synth-emux helper has a potential AB/BA deadlock at the simultaneous closing and opening: close -> snd_seq_release() -> sne_seq_free_client() -> snd_seq_delete_all_ports(): takes client->ports_mutex -> port_delete() -> snd_emux_unuse(): takes emux->register_mutex open -> snd_seq_oss_open() -> snd_emux_open_seq_oss(): takes emux->register_mutex -> snd_seq_event_port_attach() -> snd_seq_create_port(): takes client->ports_mutex This patch addresses the deadlock by reducing the rance taking emux->register_mutex in snd_emux_open_seq_oss(). The lock is needed for the refcount handling, so move it locally. The calls in emux_seq.c are already with the mutex, thus they are replaced with the version without mutex lock/unlock. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ALSA: emux: Fix mutex deadlock at unloadingTakashi Iwai
commit 07b0e5d49d227e3950cb13a3e8caf248ef2a310e upstream. The emux-synth driver has a possible AB/BA mutex deadlock at unloading the emu10k1 driver: snd_emux_free() -> snd_emux_detach_seq(): mutex_lock(&emu->register_mutex) -> snd_seq_delete_kernel_client() -> snd_seq_free_client(): mutex_lock(&register_mutex) snd_seq_release() -> snd_seq_free_client(): mutex_lock(&register_mutex) -> snd_seq_delete_all_ports() -> snd_emux_unuse(): mutex_lock(&emu->register_mutex) Basically snd_emux_detach_seq() doesn't need a protection of emu->register_mutex as it's already being unregistered. So, we can get rid of this for avoiding the deadlock. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ipv4: Missing sk_nulls_node_init() in ping_unhash().David S. Miller
[ Upstream commit a134f083e79fb4c3d0a925691e732c56911b4326 ] If we don't do that, then the poison value is left in the ->pprev backlink. This can cause crashes if we do a disconnect, followed by a connect(). Tested-by: Linus Torvalds <torvalds@linux-foundation.org> Reported-by: Wen Xu <hotdog3645@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06Linux 3.10.77v3.10.77Greg Kroah-Hartman
2015-05-06s390: Fix build errorGuenter Roeck
s390 images fail to build in 3.10 with arch/s390/kernel/suspend.c: In function 'pfn_is_nosave': arch/s390/kernel/suspend.c:147:10: error: 'ipl_info' undeclared arch/s390/kernel/suspend.c:147:27: error: 'IPL_TYPE_NSS' undeclared due to a missing include file. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06nosave: consolidate __nosave_{begin,end} in <asm/sections.h>Geert Uytterhoeven
commit 7f8998c7aef3ac9c5f3f2943e083dfa6302e90d0 upstream. The different architectures used their own (and different) declarations: extern __visible const void __nosave_begin, __nosave_end; extern const void __nosave_begin, __nosave_end; extern long __nosave_begin, __nosave_end; Consolidate them using the first variant in <asm/sections.h>. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06memstick: mspro_block: add missing curly bracesDan Carpenter
commit 13f6b191aaa11c7fd718d35a0c565f3c16bc1d99 upstream. Using the indenting we can see the curly braces were obviously intended. This is a static checker fix, but my guess is that we don't read enough bytes, because we don't calculate "t_len" correctly. Fixes: f1d82698029b ('memstick: use fully asynchronous request processing') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06C6x: time: Ensure consistency in __initNishanth Menon
commit f4831605f2dacd12730fe73961c77253cc2ea425 upstream. time_init invokes timer64_init (which is __init annotation) since all of these are invoked at init time, lets maintain consistency by ensuring time_init is marked appropriately as well. This fixes the following warning with CONFIG_DEBUG_SECTION_MISMATCH=y WARNING: vmlinux.o(.text+0x3bfc): Section mismatch in reference from the function time_init() to the function .init.text:timer64_init() The function time_init() references the function __init timer64_init(). This is often because time_init lacks a __init annotation or the annotation of timer64_init is wrong. Fixes: 546a39546c64 ("C6X: time management") Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06wl18xx: show rx_frames_per_rates as an array as it really isNicolas Iooss
commit a3fa71c40f1853d0c27e8f5bc01a722a705d9682 upstream. In struct wl18xx_acx_rx_rate_stat, rx_frames_per_rates field is an array, not a number. This means WL18XX_DEBUGFS_FWSTATS_FILE can't be used to display this field in debugfs (it would display a pointer, not the actual data). Use WL18XX_DEBUGFS_FWSTATS_FILE_ARRAY instead. This bug has been found by adding a __printf attribute to wl1271_format_buffer. gcc complained about "format '%u' expects argument of type 'unsigned int', but argument 5 has type 'u32 *'". Fixes: c5d94169e818 ("wl18xx: use new fw stats structures") Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org> Signed-off-by: Kalle Valo <kvalo@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06lib: memzero_explicit: use barrier instead of OPTIMIZER_HIDE_VARmancha security
commit 0b053c9518292705736329a8fe20ef4686ffc8e9 upstream. OPTIMIZER_HIDE_VAR(), as defined when using gcc, is insufficient to ensure protection from dead store optimization. For the random driver and crypto drivers, calls are emitted ... $ gdb vmlinux (gdb) disassemble memzero_explicit Dump of assembler code for function memzero_explicit: 0xffffffff813a18b0 <+0>: push %rbp 0xffffffff813a18b1 <+1>: mov %rsi,%rdx 0xffffffff813a18b4 <+4>: xor %esi,%esi 0xffffffff813a18b6 <+6>: mov %rsp,%rbp 0xffffffff813a18b9 <+9>: callq 0xffffffff813a7120 <memset> 0xffffffff813a18be <+14>: pop %rbp 0xffffffff813a18bf <+15>: retq End of assembler dump. (gdb) disassemble extract_entropy [...] 0xffffffff814a5009 <+313>: mov %r12,%rdi 0xffffffff814a500c <+316>: mov $0xa,%esi 0xffffffff814a5011 <+321>: callq 0xffffffff813a18b0 <memzero_explicit> 0xffffffff814a5016 <+326>: mov -0x48(%rbp),%rax [...] ... but in case in future we might use facilities such as LTO, then OPTIMIZER_HIDE_VAR() is not sufficient to protect gcc from a possible eviction of the memset(). We have to use a compiler barrier instead. Minimal test example when we assume memzero_explicit() would *not* be a call, but would have been *inlined* instead: static inline void memzero_explicit(void *s, size_t count) { memset(s, 0, count); <foo> } int main(void) { char buff[20]; snprintf(buff, sizeof(buff) - 1, "test"); printf("%s", buff); memzero_explicit(buff, sizeof(buff)); return 0; } With <foo> := OPTIMIZER_HIDE_VAR(): (gdb) disassemble main Dump of assembler code for function main: [...] 0x0000000000400464 <+36>: callq 0x400410 <printf@plt> 0x0000000000400469 <+41>: xor %eax,%eax 0x000000000040046b <+43>: add $0x28,%rsp 0x000000000040046f <+47>: retq End of assembler dump. With <foo> := barrier(): (gdb) disassemble main Dump of assembler code for function main: [...] 0x0000000000400464 <+36>: callq 0x400410 <printf@plt> 0x0000000000400469 <+41>: movq $0x0,(%rsp) 0x0000000000400471 <+49>: movq $0x0,0x8(%rsp) 0x000000000040047a <+58>: movl $0x0,0x10(%rsp) 0x0000000000400482 <+66>: xor %eax,%eax 0x0000000000400484 <+68>: add $0x28,%rsp 0x0000000000400488 <+72>: retq End of assembler dump. As can be seen, movq, movq, movl are being emitted inlined via memset(). Reference: http://thread.gmane.org/gmane.linux.kernel.cryptoapi/13764/ Fixes: d4c5efdb9777 ("random: add and use memzero_explicit() for clearing data") Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: mancha security <mancha1@zoho.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06e1000: add dummy allocator to fix race condition between mtu change and netpollSabrina Dubroca
commit 08e8331654d1d7b2c58045e549005bc356aa7810 upstream. There is a race condition between e1000_change_mtu's cleanups and netpoll, when we change the MTU across jumbo size: Changing MTU frees all the rx buffers: e1000_change_mtu -> e1000_down -> e1000_clean_all_rx_rings -> e1000_clean_rx_ring Then, close to the end of e1000_change_mtu: pr_info -> ... -> netpoll_poll_dev -> e1000_clean -> e1000_clean_rx_irq -> e1000_alloc_rx_buffers -> e1000_alloc_frag And when we come back to do the rest of the MTU change: e1000_up -> e1000_configure -> e1000_configure_rx -> e1000_alloc_jumbo_rx_buffers alloc_jumbo finds the buffers already != NULL, since data (shared with page in e1000_rx_buffer->rxbuf) has been re-alloc'd, but it's garbage, or at least not what is expected when in jumbo state. This results in an unusable adapter (packets don't get through), and a NULL pointer dereference on the next call to e1000_clean_rx_ring (other mtu change, link down, shutdown): BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff81194d6e>] put_compound_page+0x7e/0x330 [...] Call Trace: [<ffffffff81195445>] put_page+0x55/0x60 [<ffffffff815d9f44>] e1000_clean_rx_ring+0x134/0x200 [<ffffffff815da055>] e1000_clean_all_rx_rings+0x45/0x60 [<ffffffff815df5e0>] e1000_down+0x1c0/0x1d0 [<ffffffff811e2260>] ? deactivate_slab+0x7f0/0x840 [<ffffffff815e21bc>] e1000_change_mtu+0xdc/0x170 [<ffffffff81647050>] dev_set_mtu+0xa0/0x140 [<ffffffff81664218>] do_setlink+0x218/0xac0 [<ffffffff814459e9>] ? nla_parse+0xb9/0x120 [<ffffffff816652d0>] rtnl_newlink+0x6d0/0x890 [<ffffffff8104f000>] ? kvm_clock_read+0x20/0x40 [<ffffffff810a2068>] ? sched_clock_cpu+0xa8/0x100 [<ffffffff81663802>] rtnetlink_rcv_msg+0x92/0x260 By setting the allocator to a dummy version, netpoll can't mess up our rx buffers. The allocator is set back to a sane value in e1000_configure_rx. Fixes: edbbb3ca1077 ("e1000: implement jumbo receive with partial descriptors") Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06ksoftirqd: Enable IRQs and call cond_resched() before poking RCUCalvin Owens
commit 28423ad283d5348793b0c45cc9b1af058e776fd6 upstream. While debugging an issue with excessive softirq usage, I encountered the following note in commit 3e339b5dae24a706 ("softirq: Use hotplug thread infrastructure"): [ paulmck: Call rcu_note_context_switch() with interrupts enabled. ] ...but despite this note, the patch still calls RCU with IRQs disabled. This seemingly innocuous change caused a significant regression in softirq CPU usage on the sending side of a large TCP transfer (~1 GB/s): when introducing 0.01% packet loss, the softirq usage would jump to around 25%, spiking as high as 50%. Before the change, the usage would never exceed 5%. Moving the call to rcu_note_context_switch() after the cond_sched() call, as it was originally before the hotplug patch, completely eliminated this problem. Signed-off-by: Calvin Owens <calvinowens@fb.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Mike Galbraith <mgalbraith@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06RCU pathwalk breakage when running into a symlink overmounting somethingAl Viro
commit 3cab989afd8d8d1bc3d99fef0e7ed87c31e7b647 upstream. Calling unlazy_walk() in walk_component() and do_last() when we find a symlink that needs to be followed doesn't acquire a reference to vfsmount. That's fine when the symlink is on the same vfsmount as the parent directory (which is almost always the case), but it's not always true - one _can_ manage to bind a symlink on top of something. And in such cases we end up with excessive mntput(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06drm/i915: cope with large i2c transfersDmitry Torokhov
commit 9535c4757b881e06fae72a857485ad57c422b8d2 upstream. The hardware, according to the specs, is limited to 256 byte transfers, and current driver has no protections in case users attempt to do larger transfers. The code will just stomp over status register and mayhem ensues. Let's split larger transfers into digestable chunks. Doing this allows Atmel MXT driver on Pixel 1 function properly (it hasn't since commit 9d8dc3e529a19e427fd379118acd132520935c5d "Input: atmel_mxt_ts - implement T44 message handling" which tries to consume multiple touchscreen/touchpad reports in a single transaction). Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06drm/radeon: fix doublescan modes (v2)Alex Deucher
commit fd99a0943ffaa0320ea4f69d09ed188f950c0432 upstream. Use the correct flags for atom. v2: handle DRM_MODE_FLAG_DBLCLK Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06i2c: core: Export bus recovery functionsMark Brown
commit c1c21f4e60ed4523292f1a89ff45a208bddd3849 upstream. Current -next fails to link an ARM allmodconfig because drivers that use the core recovery functions can be built as modules but those functions are not exported: ERROR: "i2c_generic_gpio_recovery" [drivers/i2c/busses/i2c-davinci.ko] undefined! ERROR: "i2c_generic_scl_recovery" [drivers/i2c/busses/i2c-davinci.ko] undefined! ERROR: "i2c_recover_bus" [drivers/i2c/busses/i2c-davinci.ko] undefined! Add exports to fix this. Fixes: 5f9296ba21b3c (i2c: Add bus recovery infrastructure) Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06IB/mlx4: Fix WQE LSO segment calculationErez Shitrit
commit ca9b590caa17bcbbea119594992666e96cde9c2f upstream. The current code decreases from the mss size (which is the gso_size from the kernel skb) the size of the packet headers. It shouldn't do that because the mss that comes from the stack (e.g IPoIB) includes only the tcp payload without the headers. The result is indication to the HW that each packet that the HW sends is smaller than what it could be, and too many packets will be sent for big messages. An easy way to demonstrate one more aspect of the problem is by configuring the ipoib mtu to be less than 2*hlen (2*56) and then run app sending big TCP messages. This will tell the HW to send packets with giant (negative value which under unsigned arithmetics becomes a huge positive one) length and the QP moves to SQE state. Fixes: b832be1e4007 ('IB/mlx4: Add IPoIB LSO support') Reported-by: Matthew Finlay <matt@mellanox.com> Signed-off-by: Erez Shitrit <erezsh@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06IB/core: don't disallow registering region starting at 0x0Yann Droneaud
commit 66578b0b2f69659f00b6169e6fe7377c4b100d18 upstream. In a call to ib_umem_get(), if address is 0x0 and size is already page aligned, check added in commit 8494057ab5e4 ("IB/uverbs: Prevent integer overflow in ib_umem_get address arithmetic") will refuse to register a memory region that could otherwise be valid (provided vm.mmap_min_addr sysctl and mmap_low_allowed SELinux knobs allow userspace to map something at address 0x0). This patch allows back such registration: ib_umem_get() should probably don't care of the base address provided it can be pinned with get_user_pages(). There's two possible overflows, in (addr + size) and in PAGE_ALIGN(addr + size), this patch keep ensuring none of them happen while allowing to pin memory at address 0x0. Anyway, the case of size equal 0 is no more (partially) handled as 0-length memory region are disallowed by an earlier check. Link: http://mid.gmane.org/cover.1428929103.git.ydroneaud@opteya.com Cc: Shachar Raindel <raindel@mellanox.com> Cc: Jack Morgenstein <jackm@mellanox.com> Cc: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Yann Droneaud <ydroneaud@opteya.com> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Reviewed-by: Haggai Eran <haggaie@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06IB/core: disallow registering 0-sized memory regionYann Droneaud
commit 8abaae62f3fdead8f4ce0ab46b4ab93dee39bab2 upstream. If ib_umem_get() is called with a size equal to 0 and an non-page aligned address, one page will be pinned and a 0-sized umem will be returned to the caller. This should not be allowed: it's not expected for a memory region to have a size equal to 0. This patch adds a check to explicitly refuse to register a 0-sized region. Link: http://mid.gmane.org/cover.1428929103.git.ydroneaud@opteya.com Cc: Shachar Raindel <raindel@mellanox.com> Cc: Jack Morgenstein <jackm@mellanox.com> Cc: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Yann Droneaud <ydroneaud@opteya.com> Signed-off-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06stk1160: Make sure current buffer is releasedEzequiel Garcia
commit aeff09276748b66072f2db2e668cec955cf41959 upstream. The available (i.e. not used) buffers are returned by stk1160_clear_queue(), on the stop_streaming() path. However, this is insufficient and the current buffer must be released as well. Fix it. Signed-off-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06mvsas: fix panic on expander attached SATA devicesJames Bottomley
commit 56cbd0ccc1b508de19561211d7ab9e1c77e6b384 upstream. mvsas is giving a General protection fault when it encounters an expander attached ATA device. Analysis of mvs_task_prep_ata() shows that the driver is assuming all ATA devices are locally attached and obtaining the phy mask by indexing the local phy table (in the HBA structure) with the phy id. Since expanders have many more phys than the HBA, this is causing the index into the HBA phy table to overflow and returning rubbish as the pointer. mvs_task_prep_ssp() instead does the phy mask using the port properties. Mirror this in mvs_task_prep_ata() to fix the panic. Reported-by: Adam Talbot <ajtalbot1@gmail.com> Tested-by: Adam Talbot <ajtalbot1@gmail.com> Signed-off-by: James Bottomley <JBottomley@Odin.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06Drivers: hv: vmbus: Fix a bug in the error path in vmbus_open()K. Y. Srinivasan
commit 40384e4bbeb9f2651fe9bffc0062d9f31ef625bf upstream. Correctly rollback state if the failure occurs after we have handed over the ownership of the buffer to the host. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06xtensa: provide __NR_sync_file_range2 instead of __NR_sync_file_rangeMax Filippov
commit 01e84c70fe40c8111f960987bcf7f931842e6d07 upstream. xtensa actually uses sync_file_range2 implementation, so it should define __NR_sync_file_range2 as other architectures that use that function. That fixes userspace interface (that apparently never worked) and avoids special-casing xtensa in libc implementations. See the thread ending at http://lists.busybox.net/pipermail/uclibc/2015-February/048833.html for more details. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06xtensa: xtfpga: fix hardware lockup caused by LCD driverMax Filippov
commit 4949009eb8d40a441dcddcd96e101e77d31cf1b2 upstream. LCD driver is always built for the XTFPGA platform, but its base address is not configurable, and is wrong for ML605/KC705. Its initialization locks up KC705 board hardware. Make the whole driver optional, and its base address and bus width configurable. Implement 4-bit bus access method. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06ACPICA: Utilities: split IO address types from data type models.Lv Zheng
commit 2b8760100e1de69b6ff004c986328a82947db4ad upstream. ACPICA commit aacf863cfffd46338e268b7415f7435cae93b451 It is reported that on a physically 64-bit addressed machine, 32-bit kernel can trigger crashes in accessing the memory regions that are beyond the 32-bit boundary. The region field's start address should still be 32-bit compliant, but after a calculation (adding some offsets), it may exceed the 32-bit boundary. This case is rare and buggy, but there are real BIOSes leaked with such issues (see References below). This patch fixes this gap by always defining IO addresses as 64-bit, and allows OSPMs to optimize it for a real 32-bit machine to reduce the size of the internal objects. Internal acpi_physical_address usages in the structures that can be fixed by this change include: 1. struct acpi_object_region: acpi_physical_address address; 2. struct acpi_address_range: acpi_physical_address start_address; acpi_physical_address end_address; 3. struct acpi_mem_space_context; acpi_physical_address address; 4. struct acpi_table_desc acpi_physical_address address; See known issues 1 for other usages. Note that acpi_io_address which is used for ACPI_PROCESSOR may also suffer from same problem, so this patch changes it accordingly. For iasl, it will enforce acpi_physical_address as 32-bit to generate 32-bit OSPM compatible tables on 32-bit platforms, we need to define ACPI_32BIT_PHYSICAL_ADDRESS for it in acenv.h. Known issues: 1. Cleanup of mapped virtual address In struct acpi_mem_space_context, acpi_physical_address is used as a virtual address: acpi_physical_address mapped_physical_address; It is better to introduce acpi_virtual_address or use acpi_size instead. This patch doesn't make such a change. Because this should be done along with a change to acpi_os_map_memory()/acpi_os_unmap_memory(). There should be no functional problem to leave this unchanged except that only this structure is enlarged unexpectedly. Link: https://github.com/acpica/acpica/commit/aacf863c Reference: https://bugzilla.kernel.org/show_bug.cgi?id=87971 Reference: https://bugzilla.kernel.org/show_bug.cgi?id=79501 Reported-and-tested-by: Paul Menzel <paulepanter@users.sourceforge.net> Reported-and-tested-by: Sial Nije <sialnije@gmail.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06drivers: parport: Kconfig: exclude arm64 for PARPORT_PCGuenter Roeck
Fix build problem seen with arm64:allmodconfig. drivers/parport/parport_pc.c:67:25: fatal error: asm/parport.h: No such file or directory arm64 does not support PARPORT_PC. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06scsi: storvsc: Fix a bug in copy_from_bounce_buffer()K. Y. Srinivasan
commit 8de580742fee8bc34d116f57a20b22b9a5f08403 upstream. We may exit this function without properly freeing up the maapings we may have acquired. Fix the bug. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Long Li <longli@microsoft.com> Signed-off-by: James Bottomley <JBottomley@Odin.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06UBI: fix check for "too many bytes"Brian Norris
commit 299d0c5b27346a77a0777c993372bf8777d4f2e5 upstream. The comparison from the previous line seems to have been erroneously (partially) copied-and-pasted onto the next. The second line should be checking req.bytes, not req.lnum. Coverity CID #139400 Signed-off-by: Brian Norris <computersforpeace@gmail.com> [rw: Fixed comparison] Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06UBI: initialize LEB number variableBrian Norris
commit f16db8071ce18819fbd705ddcc91c6f392fb61f8 upstream. In some of the 'out_not_moved' error paths, lnum may be used uninitialized. Don't ignore the warning; let's fix it. This uninitialized variable doesn't have much visible effect in the end, since we just schedule the PEB for erasure, and its LEB number doesn't really matter (it just gets printed in debug messages). But let's get it straight anyway. Coverity CID #113449 Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06UBI: fix out of bounds writeBrian Norris
commit d74adbdb9abf0d2506a6c4afa534d894f28b763f upstream. If aeb->len >= vol->reserved_pebs, we should not be writing aeb into the PEB->LEB mapping. Caught by Coverity, CID #711212. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06UBI: account for bitflips in both the VID header and dataBrian Norris
commit 8eef7d70f7c6772c3490f410ee2bceab3b543fa1 upstream. We are completely discarding the earlier value of 'bitflips', which could reflect a bitflip found in ubi_io_read_vid_hdr(). Let's use the bitwise OR of header and data 'bitflip' statuses instead. Coverity CID #1226856 Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06tools/power turbostat: Use $(CURDIR) instead of $(PWD) and add support for ↵Thomas D
O= option in Makefile commit f82263c6989c31ae9b94cecddffb29dcbec38710 upstream. Since commit ee0778a30153 ("tools/power: turbostat: make Makefile a bit more capable") turbostat's Makefile is using [...] BUILD_OUTPUT := $(PWD) [...] which obviously causes trouble when building "turbostat" with make -C /usr/src/linux/tools/power/x86/turbostat ARCH=x86 turbostat because GNU make does not update nor guarantee that $PWD is set. This patch changes the Makefile to use $CURDIR instead, which GNU make guarantees to set and update (i.e. when using "make -C ...") and also adds support for the O= option (see "make help" in your root of your kernel source tree for more details). Link: https://bugs.gentoo.org/show_bug.cgi?id=533918 Fixes: ee0778a30153 ("tools/power: turbostat: make Makefile a bit more capable") Signed-off-by: Thomas D. <whissi@whissi.de> Cc: Mark Asselstine <mark.asselstine@windriver.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06powerpc/perf: Cap 64bit userspace backtraces to PERF_MAX_STACK_DEPTHAnton Blanchard
commit 9a5cbce421a283e6aea3c4007f141735bf9da8c3 upstream. We cap 32bit userspace backtraces to PERF_MAX_STACK_DEPTH (currently 127), but we forgot to do the same for 64bit backtraces. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
