Export the interface to be used within modules.
Signed-off-by: Matias Bjorling <m@bjorling.me>
Acked-by: Tejun Heo <tj@kernel.org>
Buffer allocation has a very crude indefinite loop around waking the
flusher threads and performing global NOFS direct reclaim because it can
not handle allocation failures.
The most immediate problem with this is that the allocation may fail due
to a memory cgroup limit, where flushers + direct reclaim might not make
any progress towards resolving the situation at all. Because unlike the
global case, a memory cgroup may not have any cache at all, only
anonymous pages but no swap. This situation will lead to a reclaim
livelock with insane IO from waking the flushers and thrashing unrelated
filesystem cache in a tight loop.
Use __GFP_NOFAIL allocations for buffers for now. This makes sure that
any looping happens in the page allocator, which knows how to
orchestrate kswapd, direct reclaim, and the flushers sensibly. It also
allows memory cgroups to detect allocations that can't handle failure
and will allow them to ultimately bypass the limit if reclaim can not
make progress.
Reported-by: azurIt <azurit@pobox.sk>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: <stable@kernel.org>
Commit 3812c8c8f395 ("mm: memcg: do not trap chargers with full
callstack on OOM") assumed that only a few places that can trigger a
memcg OOM situation do not return VM_FAULT_OOM, like optional page cache
readahead. But there are many more and it's impractical to annotate
them all.
First of all, we don't want to invoke the OOM killer when the failed
allocation is gracefully handled, so defer the actual kill to the end of
the fault handling as well. This simplifies the code quite a bit for
added bonus.
Second, since a failed allocation might not be the abrupt end of the
fault, the memcg OOM handler needs to be re-entrant until the fault
finishes for subsequent allocation attempts. If an allocation is
attempted after the task already OOMed, allow it to bypass the limit so
that it can quickly finish the fault and invoke the OOM killer.
The err variable is intended to receive the timer_create() return before
checking it
Signed-off-by: Felipe Pena <felipensp@gmail.com>
In commit 27a7c642174e ("partitions/efi: account for pmbr size in lba")
we started treating bad sizes in lba field of the partition that has the
0xEE (GPT protective) as errors.
However, we may run into these "bad sizes" in the real world if someone
uses dd to copy an image from a smaller disk to a bigger disk. Since
this case used to work (even without using force_gpt), keep it working
and treat the size mismatch as a warning instead of an error.
Reported-by: Josh Triplett <josh@joshtriplett.org>
Reported-by: Sean Paul <seanpaul@chromium.org>
Signed-off-by: Doug Anderson <dianders@chromium.org>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Acked-by: Davidlohr Bueso <davidlohr@hp.com>
Tested-by: Artem Bityutskiy <dedekind1@gmail.com>
Commit 11feeb498086 ("kvm: optimize away THP checks in
kvm_is_mmio_pfn()") introduced a memory leak when KVM is run on gigantic
compound pages.
That commit depends on the assumption that PG_reserved is identical for
all head and tail pages of a compound page. So that if get_user_pages
returns a tail page, we don't need to check the head page in order to
know if we deal with a reserved page that requires different
refcounting.
The assumption that PG_reserved is the same for head and tail pages is
certainly correct for THP and regular hugepages, but gigantic hugepages
allocated through bootmem don't clear the PG_reserved on the tail pages
(the clearing of PG_reserved is done later only if the gigantic hugepage
is freed).
This patch corrects the gigantic compound page initialization so that we
can retain the optimization in 11feeb498086. The cacheline was already
modified in order to set PG_tail so this won't affect the boot time of
large memory systems.
[akpm@linux-foundation.org: tweak comment layout and grammar]
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Reported-by: andy123 <ajs124.ajs124@gmail.com>
Cc: Gleb Natapov <gleb@redhat.com>
Acked-by: Rafael Aquini <aquini@redhat.com>
zswap_tree is not freed when swapoff, and it got re-kmalloced in swapon,
so a memory leak occurs.
Free the memory of zswap_tree in zswap_frontswap_invalidate_area().
Signed-off-by: Weijie Yang <weijie.yang@samsung.com>
Reviewed-by: Bob Liu <bob.liu@oracle.com>
Cc: Minchan Kim <minchan@kernel.org>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Cc: <stable@vger.kernel.org>
Subject: mm/zswap: bugfix: memory leak when invalidate and reclaim occur concurrently
Consider the following scenario:
thread 0: reclaim entry x (get refcount, but not call zswap_get_swap_cache_page)
thread 1: call zswap_frontswap_invalidate_page to invalidate entry x.
finished, entry x and its zbud is not freed as its refcount != 0
now, the swap_map[x] = 0
thread 0: now call zswap_get_swap_cache_page
swapcache_prepare return -ENOENT because entry x is not used any more
zswap_get_swap_cache_page return ZSWAP_SWAPCACHE_NOMEM
zswap_writeback_entry do nothing except put refcount
Now, the memory of zswap_entry x and its zpage leak.
Modify:
- check the refcount in fail path, free memory if it is not referenced.
- use ZSWAP_SWAPCACHE_FAIL instead of ZSWAP_SWAPCACHE_NOMEM as the fail path
can be not only caused by nomem but also by invalidate.
Acked-by: Seth Jennings <sjenning@linux.vnet.ibm.com>
If a page we are inspecting is in swap we may occasionally report it as
having soft dirty bit (even if it is clean). The pte_soft_dirty helper
should be called on present pte only.
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
If page migration is turned on in config and the page is migrating, we
may lose the soft dirty bit. If fork and mprotect are called on
migrating pages (once migration is complete) pages do not obtain the
soft dirty bit in the correspond pte entries. Fix it adding an
appropriate test on swap entries.
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
We should clear the page's private flag when returing the page to the
hugepage pool. Otherwise, marked hugepage can be allocated to the user
who tries to allocate the non-reserved hugepage. If this user fail to
map this hugepage, he would try to return the page to the hugepage pool.
Since this page has a private flag, resv_huge_pages would mistakenly
increase. This patch fixes this situation.
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Davidlohr Bueso <davidlohr.bueso@hp.com>
Cc: David Gibson <david@gibson.dropbear.id.au>
Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Cc: Hillf Danton <dhillf@gmail.com>
This leak was added by commit 1d3d4437eae1 ("vmscan: per-node deferred
work").
unreferenced object 0xffff88006ada3bd0 (size 8):
comm "criu", pid 14781, jiffies 4295238251 (age 105.641s)
hex dump (first 8 bytes):
00 00 00 00 00 00 00 00 ........
backtrace:
[<ffffffff8170caee>] kmemleak_alloc+0x5e/0xc0
[<ffffffff811c0527>] __kmalloc+0x247/0x310
[<ffffffff8117848c>] register_shrinker+0x3c/0xa0
[<ffffffff811e115b>] sget+0x5ab/0x670
[<ffffffff812532f4>] proc_mount+0x54/0x170
[<ffffffff811e1893>] mount_fs+0x43/0x1b0
[<ffffffff81202dd2>] vfs_kern_mount+0x72/0x110
[<ffffffff81202e89>] kern_mount_data+0x19/0x30
[<ffffffff812530a0>] pid_ns_prepare_proc+0x20/0x40
[<ffffffff81083c56>] alloc_pid+0x466/0x4a0
[<ffffffff8105aeda>] copy_process+0xc6a/0x1860
[<ffffffff8105beab>] do_fork+0x8b/0x370
[<ffffffff8105c1a6>] SyS_clone+0x16/0x20
[<ffffffff8171f739>] stub_clone+0x69/0x90
[<ffffffffffffffff>] 0xffffffffffffffff
Signed-off-by: Andrew Vagin <avagin@openvz.org>
Cc: Glauber Costa <glommer@openvz.org>
Cc: Chuck Lever <chuck.lever@oracle.com>
After acquiring the semlock spinlock, operations must test that the
array is still valid.
- semctl() and exit_sem() would walk stale linked lists (ugly, but
should be ok: all lists are empty)
- semtimedop() would sleep forever - and if woken up due to a signal -
access memory after free.
The patch also:
- standardizes the tests for .deleted, so that all tests in one
function leave the function with the same approach.
- unconditionally tests for .deleted immediately after every call to
sem_lock - even it it means that for semctl(GETALL), .deleted will be
tested twice.
Both changes make the review simpler: After every sem_lock, there must
be a test of .deleted, followed by a goto to the cleanup code (if the
function uses "goto cleanup").
The only exception is semctl_down(): If sem_ids().rwsem is locked, then
the presence in ids->ipcs_idr is equivalent to !.deleted, thus no
additional test is required.
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
The initial documentation was a bit incomplete, update accordingly.
[akpm@linux-foundation.org: make it more readable in 80 columns]
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Acked-by: Manfred Spraul <manfred@colorfullife.com>
for_each_online_cpu() needs the protection of {get,put}_online_cpus() so
cpu_online_mask doesn't change during the iteration.
cpu_hotplug.lock is held while a cpu is going down, it's a coarse lock
that is used kernel-wide to synchronize cpu hotplug activity. Memcg has
a cpu hotplug notifier, called while there may not be any cpu hotplug
refcounts, which drains per-cpu event counts to memcg->nocpu_base.events
to maintain a cumulative event count as cpus disappear. Without
get_online_cpus() in mem_cgroup_read_events(), it's possible to account
for the event count on a dying cpu twice, and this value may be
significantly large.
In fact, all memcg->pcp_counter_lock use should be nested by
{get,put}_online_cpus().
This fixes that issue and ensures the reported statistics are not vastly
over-reported during cpu hotplug.
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Pull device tree fixes and reverts from Grant Likely:
"One bug fix and three reverts. The reverts back out the slightly
controversial feeding the entire device tree into the random pool and
the reserved-memory binding which isn't fully baked yet. Expect the
reserved-memory patches at least to resurface for v3.13.
The bug fixes removes a scary but harmless warning on SPARC that was
introduced in the v3.12 merge window. v3.13 will contain a proper fix
that makes the new code work on SPARC.
On the plus side, the diffstat looks *awesome*. I love removing lines
of code"
* tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux:
Revert "drivers: of: add initialization code for dma reserved memory"
Revert "ARM: init: add support for reserved memory defined by device tree"
Revert "of: Feed entire flattened device tree into the random pool"
of: fix unnecessary warning on missing /cpus node
git://git.linaro.org/people/mszyprowski/linux-dma-mapping
Pull DMA-mapping fix from Marek Szyprowski:
"A bugfix for the IOMMU-based implementation of dma-mapping subsystem
for ARM architecture"
* 'fixes-for-v3.12' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping:
ARM: dma-mapping: Always pass proper prot flags to iommu_map()
Pull kvm fix from Gleb Natapov.
* git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: Enable pvspinlock after jump_label_init() to avoid VM hang
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull Xen fixes from Stefano Stabellini:
"A small fix for Xen on x86_32 and a build fix for xen-tpmfront on
arm64"
* tag 'stable/for-linus-3.12-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen: Fix possible user space selector corruption
tpm: xen-tpmfront: fix missing declaration of xen_domain
We use jump label to enable pv-spinlock. With the changes in (442e0973e927
Merge branch 'x86/jumplabel'), the jump label behaviour has changed
that would result in eventual hang of the VM since we would end up in a
situation where slow path locks would halt the vcpus but we will not be
able to wakeup the vcpu by lock releaser using unlock kick.
Similar problem in Xen and more detailed description is available in
a945928ea270 (xen: Do not enable spinlocks before jump_label_init()
has executed)
This patch splits kvm_spinlock_init to separate jump label changes with
pvops patching and also make jump label enabling after jump_label_init().
Signed-off-by: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
This reverts commit 9d8eab7af79cb4ce2de5de39f82c455b1f796963. There is
still no consensus on the bindings for the reserved memory and various
drawbacks of the proposed solution has been shown, so the best now is to
revert it completely and start again from scratch later.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
This reverts commit 10bcdfb8ba24760f715f0a700c3812747eddddf5. There is
no consensus on the bindings for the reserved memory, so the code for
handing it will be reverted.
Pull vfio fix from Alex Williamson:
"Fix an incorrect break out of nested loop in iommu mapping code"
* tag 'vfio-v3.12-rc5' of git://github.com/awilliam/linux-vfio:
VFIO: vfio_iommu_type1: fix bug caused by break in nested loop
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull infiniband updates from Roland Dreier:
"Last batch of IB changes for 3.12: many mlx5 hardware driver fixes
plus one trivial semicolon cleanup"
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
IB: Remove unnecessary semicolons
IB/mlx5: Ensure proper synchronization accessing memory
IB/mlx5: Fix alignment of reg umr gather buffers
IB/mlx5: Fix eq names to display nicely in /proc/interrupts
mlx5: Fix error code translation from firmware to driver
IB/mlx5: Fix opt param mask according to firmware spec
mlx5: Fix opt param mask for sq err to rts transition
IB/mlx5: Disable atomic operations
mlx5: Fix layout of struct mlx5_init_seg
mlx5: Keep polling to reclaim pages while any returned
IB/mlx5: Avoid async events on invalid port number
IB/mlx5: Decrease memory consumption of mr caches
mlx5: Remove checksum on command interface commands
IB/mlx5: Fix memory leak in mlx5_ib_create_srq
IB/mlx5: Flush cache workqueue before destroying it
IB/mlx5: Fix send work queue size calculation
These aren't necessary after switch blocks.
Signed-off-by: Roland Dreier <roland@purestorage.com>
Pull ARM fixes from Russell King:
"Some more ARM fixes, nothing particularly major here. The biggest
change is to fix the SMP_ON_UP code so that it works with TI's Aegis
cores"
* 'fixes' of git://git.linaro.org/people/rmk/linux-arm:
ARM: 7851/1: check for number of arguments in syscall_get/set_arguments()
ARM: 7846/1: Update SMP_ON_UP code to detect A9MPCore with 1 CPU devices
ARM: 7845/1: sharpsl_param.c: fix invalid memory access for pxa devices
ARM: 7843/1: drop asm/types.h from generic-y
ARM: 7842/1: MCPM: don't explode if invoked without being initialized first
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux
Pull SLAB fix from Pekka Enberg:
"A regression fix for overly eager slab cache name checks"
* 'slab/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux:
slab_common: Do not check for duplicate slab names
Pull ACPI and power management fixes from Rafael Wysocki:
"These fix two recent bugs in ACPIPHP (ACPI-based PCI hotplug) and
update a bunch of web links and e-mail addresses in MAINTAINERS, docs
and Kconfig that either are stale or will expire soon.
Specifics:
- The WARN_ON() in acpiphp_enumerate_slots() triggers as a false
positive in some cases, so drop it.
- Add a missing pci_dev_put() to an error code path in
acpiphp_enumerate_slots().
- Replace my old e-mail address that's going to expire with a new
one.
- Update ACPI web links and git tree information in MAINTAINERS.
- Update links to the Linux-ACPI project's page in MAINTAINERS.
- Update some stale links and e-mail addresses under Documentation
and in the ACPI Kconfig file"
* tag 'pm+acpi-3.12-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / hotplug / PCI: Drop WARN_ON() from acpiphp_enumerate_slots()
ACPI / hotplug / PCI: Fix error code path in acpiphp_enumerate_slots()
ACPI / PM / Documentation: Replace outdated project links and addresses
MAINTAINERS / ACPI: Update links to the Linux-ACPI project web page
MAINTAINERS / ACPI: Update links and git tree information
MAINTAINERS / Documentation: Update Rafael's e-mail address
This reverts commit 109b6236294b53d8eaa50be7d9e9ad37079f5f7e.
Tim Bird expressed concern that this will have a bad effect on boot
time, and while simple tests have shown it to be okay with simple tree,
a device tree blob can potentially be quite large and
add_device_randomness() is not a fast function. Rather than do this for
all platforms unconditionally, I'm reverting this patch and would like
to see it revisited. Instead of feeding the entire tree into the random
pool, it would probably be appropriate to hash the tree and feed the
hash result into the pool. There really isn't a lot of randomness in a
device tree anyway. In the majority of cases only a handful of
properties are going to be different between machines with the same
baseboard.
Not all DT platforms have all the cpus collected under a /cpus node.
That just happens to be a details of FDT, ePAPR and PowerPC platforms.
Sparc does something different, but unfortunately the current code
complains with a warning if /cpus isn't there. This became a problem
with commit f86e4718, "driver/core cpu: initialize of_node in cpu's
device structure", which caused the function to get called for all
architectures.
This commit is a temporary fix to fail silently if the cpus node isn't
present. A proper fix will come later to allow arch code to provide a
custom mechanism for decoding the CPU hwid if the 'reg' property isn't
appropriate.
Cc: Sudeep KarkadaNagesha <Sudeep.KarkadaNagesha@arm.com>
Cc: Rob Herring <rob.herring@calxeda.com>
Pull watchdog fixes from Wim Van Sebroeck:
"This will fix a deadlock on the ts72xx_wdt driver, fix bitmasks in the
kempld_wdt driver and fix a section mismatch in the sunxi_wdt driver"
* git://www.linux-watchdog.org/linux-watchdog:
watchdog: sunxi: Fix section mismatch
watchdog: kempld_wdt: Fix bit mask definition
watchdog: ts72xx_wdt: locking bug in ioctl
This driver has a section mismatch, for probe and remove functions,
leading to the following warning during the compilation.
WARNING: drivers/watchdog/built-in.o(.data+0x24): Section mismatch in
reference from the variable sunxi_wdt_driver to the function
.init.text:sunxi_wdt_probe()
The variable sunxi_wdt_driver references
the function __init sunxi_wdt_probe()
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
STAGE_CFG bits are defined as [5:4] bits. However, '(((x) & 0x30) << 4)'
handles [9:8] bits. Thus, it should be fixed in order to handle
[5:4] bits.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Calling the WDIOC_GETSTATUS & WDIOC_GETBOOTSTATUS and twice will cause a
interruptible deadlock.
In ftrace_syscall_enter(),
syscall_get_arguments(..., 0, n, ...)
if (i == 0) { <handle ORIG_r0> ...; n--;}
memcpy(..., n * sizeof(args[0]));
If 'number of arguments(n)' is zero and 'argument index(i)' is also zero in
syscall_get_arguments(), none of arguments should be copied by memcpy().
Otherwise 'n--' can be a big positive number and unexpected amount of data
will be copied. Tracing system calls which take no argument, say sync(void),
may hit this case and eventually make the system corrupted.
This patch fixes the issue both in syscall_get_arguments() and
syscall_set_arguments().
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Pull ARM SoC fixes from Olof Johansson:
"A small batch of fixes this week, mostly OMAP related. Nothing stands
out as particularly controversial.
Also a fix for a 3.12-rc1 timer regression for Exynos platforms,
including the Chromebooks"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: exynos: dts: Update 5250 arch timer node with clock frequency
ARM: OMAP2: RX-51: Add missing max_current to rx51_lp5523_led_config
ARM: mach-omap2: board-generic: fix undefined symbol
ARM: dts: Fix pinctrl mask for omap3
ARM: OMAP3: Fix hardware detection for omap3630 when booted with device tree
ARM: OMAP2: gpmc-onenand: fix sync mode setup with DT
Without the "clock-frequency" property in arch timer node, could able
to see the below crash dump.
[<c0014e28>] (unwind_backtrace+0x0/0xf4) from [<c0011808>] (show_stack+0x10/0x14)
[<c0011808>] (show_stack+0x10/0x14) from [<c036ac1c>] (dump_stack+0x7c/0xb0)
[<c036ac1c>] (dump_stack+0x7c/0xb0) from [<c01ab760>] (Ldiv0_64+0x8/0x18)
[<c01ab760>] (Ldiv0_64+0x8/0x18) from [<c0062f60>] (clockevents_config.part.2+0x1c/0x74)
[<c0062f60>] (clockevents_config.part.2+0x1c/0x74) from [<c0062fd8>] (clockevents_config_and_register+0x20/0x2c)
[<c0062fd8>] (clockevents_config_and_register+0x20/0x2c) from [<c02b8e8c>] (arch_timer_setup+0xa8/0x134)
[<c02b8e8c>] (arch_timer_setup+0xa8/0x134) from [<c04b47b4>] (arch_timer_init+0x1f4/0x24c)
[<c04b47b4>] (arch_timer_init+0x1f4/0x24c) from [<c04b40d8>] (clocksource_of_init+0x34/0x58)
[<c04b40d8>] (clocksource_of_init+0x34/0x58) from [<c049ed8c>] (time_init+0x20/0x2c)
[<c049ed8c>] (time_init+0x20/0x2c) from [<c049b95c>] (start_kernel+0x1e0/0x39c)
THis is because the Exynos u-boot, for example on the Chromebooks, doesn't set
up the CNTFRQ register as expected by arch_timer. Instead, we have to specify
the frequency in the device tree like this.
Signed-off-by: Yuvaraj Kumar C D <yuvaraj.cd@samsung.com>
[olof: Changed subject, added comment, elaborated on commit message]
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
From Tony Lindgren:
Few fixes for omap3 related hangs and errors that people have
noticed now that people are actually using the device tree
based booting for omap3.
Also one regression fix for timer compile for dra7xx when
omap5 is not selected, and a LED regression fix for n900.
* tag 'fixes-against-v3.12-rc3-take2' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux
Pull parisc fixes from Helge Deller:
"This patchset includes a bugfix to prevent a kernel crash when memory
in page zero is accessed by the kernel itself, e.g. via
probe_kernel_read().
Furthermore we now export flush_cache_page() which is needed
(indirectly) by the lustre filesystem. The other patches remove
unused functions and optimizes the page fault handler to only evaluate
variables if needed, which again protects against possible kernel
crashes"
* 'parisc-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux:
parisc: let probe_kernel_read() capture access to page zero
parisc: optimize variable initialization in do_page_fault
parisc: fix interruption handler to respect pagefault_disable()
parisc: mark parisc_terminate() noreturn and cold.
parisc: remove unused syscall_ipi() function.
parisc: kill SMP single function call interrupt
parisc: Export flush_cache_page() (needed by lustre)
Pull slave-dmaengine fixes from Vinod Koul:
"Another week, time to send another fixes request taking time out of
extended weekend for the festivities in this part of the world.
We have two fixes from Sergei for rcar driver and one fixing memory
leak of edma driver by Geyslan"
* 'fixes' of git://git.infradead.org/users/vkoul/slave-dma:
dma: edma.c: remove edma_desc leakage
rcar-hpbdma: add parameter to set_slave() method
rcar-hpbdma: remove shdma_free_irq() calls
Signed-off-by: Helge Deller <deller@gmx.de>
The attached change defers the initialization of the variables tsk, mm
and flags until they are needed. As a result, the code won't crash if a
kernel probe is done with a corrupt context and the code will be better
optimized.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Running an "echo t > /proc/sysrq-trigger" crashes the parisc kernel. The
problem is, that in print_worker_info() we try to read the workqueue info via
the probe_kernel_read() functions which use pagefault_disable() to avoid
crashes like this:
probe_kernel_read(&pwq, &worker->current_pwq, sizeof(pwq));
probe_kernel_read(&wq, &pwq->wq, sizeof(wq));
probe_kernel_read(name, wq->name, sizeof(name) - 1);
The problem here is, that the first probe_kernel_read(&pwq) might return zero
in pwq and as such the following probe_kernel_reads() try to access contents of
the page zero which is read protected and generate a kernel segfault.
With this patch we fix the interruption handler to call parisc_terminate()
directly only if pagefault_disable() was not called (in which case
preempt_count()==0). Otherwise we hand over to the pagefault handler which
will try to look up the faulting address in the fixup tables.
Cc: <stable@vger.kernel.org> # v3.0+
Commit 9a46ad6d6df3b54 "smp: make smp_call_function_many() use logic
similar to smp_call_function_single()" has unified the way to handle
single and multiple cross-CPU function calls. Now only one interrupt
is needed for architecture specific code to support generic SMP function
call interfaces, so kill the redundant single function call interrupt.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: Jiang Liu <liuj97@gmail.com>
ERROR: "flush_cache_page" [drivers/staging/lustre/lustre/libcfs/libcfs.ko] undefined!
Olga reported that file descriptors opened with O_PATH do not work with
fstatfs(), found during further development of ksh93's thread support.
There is no reason to not allow O_PATH file descriptors here (fstatfs is
very much a path operation), so use "fdget_raw()". See commit
55815f70147d ("vfs: make O_PATH file descriptors usable for 'fstat()'")
for a very similar issue reported for fstat() by the same team.
Reported-and-tested-by: ольга крыжановская <olga.kryzhanovska@gmail.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: stable@kernel.org # O_PATH introduced in 3.0+
