2014-04-20Linux 3.15-rc2v3.15-rc2Linus Torvalds
2014-04-20Merge branch 'fixes' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine fixes from Vinod Koul: "Back from long weekend here in India and now the time to send fixes for slave dmaengine. - Dan's fix of sirf xlate code - Jean's fix for timberland - edma fixes by Sekhar for SG handling and Yuan for changing init call" * 'fixes' of git://git.infradead.org/users/vkoul/slave-dma: dma: fix eDMA driver as a subsys_initcall dmaengine: sirf: off by one in of_dma_sirfsoc_xlate() platform: Fix timberdale dependencies dma: edma: fix incorrect SG list handling
2014-04-20Merge tag 'iommu-fixes-v3.15-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull iommu fixes from Joerg Roedel: "Fixes for regressions: - fix wrong IOMMU enumeration causing some SCSI device drivers initialization failures - ARM-SMMU fixes for a panic condition and a wrong return value" * tag 'iommu-fixes-v3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: iommu/arm-smmu: fix panic in arm_smmu_alloc_init_pte iommu/arm-smmu: Return 0 on unmap failure iommu/vt-d: fix bug in matching PCI devices with DRHD/RMRR descriptors iommu/vt-d: Fix get_domain_for_dev() handling of upstream PCIe bridges iommu/vt-d: fix memory leakage caused by commit ea8ea46
2014-04-20Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf tooling fixes from Ingo Molnar: "Three small tooling fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf tools: Improve error reporting perf tools: Adjust symbols in VDSO perf kvm: Fix 'Min time' counting in report command
2014-04-20Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/jolsa/perf into perf/urgent Pull perf/urgent fixes from Jiri Olsa: User visible changes: * Adjust symbols in VDSO to properly resolve its function names (Vladimir Nikulichev) * Improve error reporting for record session failure (Adrien BAK) * Fix 'Min time' counting in report command (Alexander Yarygin) Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-20perf tools: Improve error reportingAdrien BAK
In the current version, when using perf record, if something goes wrong in tools/perf/builtin-record.c:375 session = perf_session__new(file, false, NULL); The error message: "Not enough memory for reading per file header" is issued. This error message seems to be outdated and is not very helpful. This patch proposes to replace this error message by "Perf session creation failed" I believe this issue has been brought to lkml: https://lkml.org/lkml/2014/2/24/458 although this patch only tackles a (small) part of the issue. Additionnaly, this patch improves error reporting in tools/perf/util/data.c open_file_write. Currently, if the call to open fails, the user is unaware of it. This patch logs the error, before returning the error code to the caller. Reported-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Adrien BAK <adrien.bak@metascale.org> Link: http://lkml.kernel.org/r/1397786443.3093.4.camel@beast [ Reorganize the changelog into paragraphs ] [ Added empty line after fd declaration in open_file_write ] Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-20perf tools: Adjust symbols in VDSOVladimir Nikulichev
pert-report doesn't resolve function names in VDSO: $ perf report --stdio -g flat,0.0,15,callee --sort pid ... 8.76% 0x7fff6b1fe861 __gettimeofday ACE_OS::gettimeofday() ... In this case symbol values should be adjusted the same way as for executables, relocatable objects and prelinked libraries. After fix: $ perf report --stdio -g flat,0.0,15,callee --sort pid ... 8.76% __vdso_gettimeofday __gettimeofday ACE_OS::gettimeofday() Signed-off-by: Vladimir Nikulichev <nvs@tbricks.com> Tested-by: Namhyung Kim <namhyung@kernel.org> Reviewed-by: Adrian Hunter <adrian.hunter@intel.com> Link: http://lkml.kernel.org/r/969812.163009436-sendEmail@nvs Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-20perf kvm: Fix 'Min time' counting in report commandAlexander Yarygin
Every event in the perf-kvm has a 'stats' structure, which contains max/min/average/etc times of handling this event. The problem is that the 'perf-kvm stat report' command always shows that 'min time' is 0us for every event. Example: # perf kvm stat report Analyze events for all VCPUs: VM-EXIT Samples Samples% Time% Min Time Max Time Avg time [..] 0xB2 MSCH 12 0.07% 0.00% 0us 8us 7.31us ( +- 2.11% ) 0xB2 CHSC 12 0.07% 0.00% 0us 18us 9.39us ( +- 9.49% ) 0xB2 STPX 8 0.05% 0.00% 0us 2us 1.88us ( +- 7.18% ) 0xB2 STSI 7 0.04% 0.00% 0us 44us 16.49us ( +- 38.20% ) [..] This happens because the 'stats' structure is not initialized and stats->min equals to 0. Lets initialize the structure for every event after its allocation using init_stats() function. This initializes stats->min to -1 and makes 'Min time' statistics counting work: # perf kvm stat report Analyze events for all VCPUs: VM-EXIT Samples Samples% Time% Min Time Max Time Avg time [..] 0xB2 MSCH 12 0.07% 0.00% 6us 8us 7.31us ( +- 2.11% ) 0xB2 CHSC 12 0.07% 0.00% 7us 18us 9.39us ( +- 9.49% ) 0xB2 STPX 8 0.05% 0.00% 1us 2us 1.88us ( +- 7.18% ) 0xB2 STSI 7 0.04% 0.00% 1us 44us 16.49us ( +- 38.20% ) [..] Signed-off-by: Alexander Yarygin <yarygin@linux.vnet.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Reviewed-by: David Ahern <dsahern@gmail.com> Link: http://lkml.kernel.org/r/1397053319-2130-3-git-send-email-borntraeger@de.ibm.com [ Fixing the perf examples changelog output ] Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-19coredump: fix va_list corruptionEric Dumazet
A va_list needs to be copied in case it needs to be used twice. Thanks to Hugh for debugging this issue, leading to various panics. Tested: lpq84:~# echo "|/foobar12345 %h %h %h %h %h %h %h %h %h %h %h %h %h %h %h %h %h %h %h %h" >/proc/sys/kernel/core_pattern 'produce_core' is simply : main() { *(int *)0 = 1;} lpq84:~# ./produce_core Segmentation fault (core dumped) lpq84:~# dmesg | tail -1 [ 614.352947] Core dump to |/foobar12345 lpq84 lpq84 lpq84 lpq84 lpq84 lpq84 lpq84 lpq84 lpq84 lpq84 lpq84 lpq84 lpq84 lpq84 lpq84 lpq84 lpq84 lpq84 lpq84 (null) pipe failed Notice the last argument was replaced by a NULL (we were lucky enough to not crash, but do not try this on your production machine !) After fix : lpq83:~# echo "|/foobar12345 %h %h %h %h %h %h %h %h %h %h %h %h %h %h %h %h %h %h %h %h" >/proc/sys/kernel/core_pattern lpq83:~# ./produce_core Segmentation fault lpq83:~# dmesg | tail -1 [ 740.800441] Core dump to |/foobar12345 lpq83 lpq83 lpq83 lpq83 lpq83 lpq83 lpq83 lpq83 lpq83 lpq83 lpq83 lpq83 lpq83 lpq83 lpq83 lpq83 lpq83 lpq83 lpq83 lpq83 pipe failed Fixes: 5fe9d8ca21cc ("coredump: cn_vprintf() has no reason to call vsnprintf() twice") Signed-off-by: Eric Dumazet <edumazet@google.com> Diagnosed-by: Hugh Dickins <hughd@google.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: stable@vger.kernel.org # 3.11+ Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-19Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fix from Ingo Molnar: "This fixes the preemption-count imbalance crash reported by Owen Kibel" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/mce: Fix CMCI preemption bugs
2014-04-19Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Two fixes: - a SCHED_DEADLINE task selection fix - a sched/numa related lockdep splat fix" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: Check for stop task appearance when balancing happens sched/numa: Fix task_numa_free() lockdep splat
2014-04-19Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Two kernel side fixes: - an Intel uncore PMU driver potential crash fix - a kprobes/perf-call-graph interaction fix" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86/intel: Use rdmsrl_safe() when initializing RAPL PMU kprobes/x86: Fix page-fault handling logic
2014-04-19Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Unfortunately this contains no easter eggs, its a bit larger than I'd like, but I included a patch that just moves code from one file to another and I'd like to avoid merge conflicts with that later, so it makes it seem worse than it is, Otherwise: - radeon: fixes to use new microcode to stabilise some cards, use some common displayport code, some runtime pm fixes, pll regression fixes - i915: fix for some context oopses, a warn in a used path, backlight fixes - nouveau: regression fix - omap: a bunch of fixes" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (51 commits) drm: bochs: drop unused struct fields drm: bochs: add power management support drm: cirrus: add power management support drm: Split out drm_probe_helper.c from drm_crtc_helper.c drm/plane-helper: Don't fake-implement primary plane disabling drm/ast: fix value check in cbr_scan2 drm/nouveau/bios: fix a bit shift error introduced by 457e77b drm/radeon/ci: make sure mc ucode is loaded before checking the size drm/radeon/si: make sure mc ucode is loaded before checking the size drm/radeon: improve PLL params if we don't match exactly v2 drm/radeon: memory leak on bo reservation failure. v2 drm/radeon: fix VCE fence command drm/radeon: re-enable mclk dpm on R7 260X asics drm/radeon: add support for newer mc ucode on CI (v2) drm/radeon: add support for newer mc ucode on SI (v2) drm/radeon: apply more strict limits for PLL params v2 drm/radeon: update CI DPM powertune settings drm/radeon: fix runpm handling on APUs (v4) drm/radeon: disable mclk dpm on R7 260X drm/tegra: Remove gratuitous pad field ...
2014-04-19Merge branch 'drm-next-3.15-wip' of ↵Dave Airlie
git://people.freedesktop.org/~deathsimple/linux into drm-next Some i2c fixes over DisplayPort. * 'drm-next-3.15-wip' of git://people.freedesktop.org/~deathsimple/linux: drm/radeon: Improve vramlimit module param documentation drm/radeon: fix audio pin counts for DCE6+ (v2) drm/radeon/dp: switch to the common i2c over aux code drm/dp/i2c: Update comments about common i2c over dp assumptions (v3) drm/dp/i2c: send bare addresses to properly reset i2c connections (v4) drm/radeon/dp: handle zero sized i2c over aux transactions (v2) drm/i915: support address only i2c-over-aux transactions drm/tegra: dp: Support address-only I2C-over-AUX transactions
2014-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull more networking fixes from David Miller: 1) Fix mlx4_en_netpoll implementation, it needs to schedule a NAPI context, not synchronize it. From Chris Mason. 2) Ipv4 flow input interface should never be zero, it should be LOOPBACK_IFINDEX instead. From Cong Wang and Julian Anastasov. 3) Properly configure MAC to PHY connection in mvneta devices, from Thomas Petazzoni. 4) sys_recv should use SYSCALL_DEFINE. From Jan Glauber. 5) Tunnel driver ioctls do not use the correct namespace, fix from Nicolas Dichtel. 6) Fix memory leak on seccomp filter attach, from Kees Cook. 7) Fix lockdep warning for nested vlans, from Ding Tianhong. 8) Crashes can happen in SCTP due to how the auth_enable value is managed, fix from Vlad Yasevich. 9) Wireless fixes from John W Linville and co. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (45 commits) net: sctp: cache auth_enable per endpoint tg3: update rx_jumbo_pending ring param only when jumbo frames are enabled vlan: Fix lockdep warning when vlan dev handle notification seccomp: fix memory leak on filter attach isdn: icn: buffer overflow in icn_command() ip6_tunnel: use the right netns in ioctl handler sit: use the right netns in ioctl handler ip_tunnel: use the right netns in ioctl handler net: use SYSCALL_DEFINEx for sys_recv net: mdio-gpio: Add support for separate MDI and MDO gpio pins net: mdio-gpio: Add support for active low gpio pins net: mdio-gpio: Use devm_ functions where possible ipv4, route: pass 0 instead of LOOPBACK_IFINDEX to fib_validate_source() ipv4, fib: pass LOOPBACK_IFINDEX instead of 0 to flowi4_iif mlx4_en: don't use napi_synchronize inside mlx4_en_netpoll net: mvneta: properly configure the MAC <-> PHY connection in all situations net: phy: add minimal support for QSGMII PHY sfc:On MCDI timeout, issue an FLR (and mark MCDI to fail-fast) mwifiex: fix hung task on command timeout mwifiex: process event before command response ...
2014-04-18Merge branch 'for-next' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull cifs fixes from Steve French: "A set of 5 small cifs fixes" * 'for-next' of git://git.samba.org/sfrench/cifs-2.6: cif: fix dead code cifs: fix error handling cifs_user_readv fs: cifs: remove unused variable. Return correct error on query of xattr on file with empty xattrs cifs: Wait for writebacks to complete before attempting write.
2014-04-18Merge tag 'char-misc-3.15-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver fixes from Greg KH: "Here are a few driver fixes for char/misc drivers that resolve reported issues. All have been in linux-next successfully for a few days" * tag 'char-misc-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: Drivers: hv: vmbus: Negotiate version 3.0 when running on ws2012r2 hosts Tools: hv: Handle the case when the target file exists correctly vme_tsi148: Utilize to_pci_dev() macro vme_tsi148: Fix PCI address mapping assumption vme_tsi148: Fix typo in tsi148_slave_get() w1: avoid recursive device_add w1: fix netlink refcnt leak on error path misc: Grammar s/addition/additional/ drivers: mcb: fix memory leak in chameleon_parse_cells() error path mei: ignore client writing state during cb completion mei: me: do not load the driver if the FW doesn't support MEI interface GenWQE: Increase driver version number GenWQE: Fix multithreading problems GenWQE: Ensure rc is not returning an uninitialized value GenWQE: Add wmb before DDCB is started GenWQE: Enable access to VPD flash area
2014-04-18Merge tag 'driver-core-3.15-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core fixes from Greg KH: "Here are some driver core fixes for 3.15-rc2. Also in here are some documentation updates, as well as an API removal that had to wait for after -rc1 due to the cleanups coming into you from multiple developer trees (this one and the PPC tree.) All have been in linux next successfully" * tag 'driver-core-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: drivers/base/dd.c incorrect pr_debug() parameters Documentation: Update stable address in Chinese and Japanese translations topology: Fix compilation warning when not in SMP Chinese: add translation of io_ordering.txt stable_kernel_rules: spelling/word usage sysfs, driver-core: remove unused {sysfs|device}_schedule_callback_owner() kernfs: protect lazy kernfs_iattrs allocation with mutex fs: Don't return 0 from get_anon_bdev
2014-04-18Merge tag 'staging-3.15-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging driver fixes from Greg KH: "Here are a few staging driver fixes for issues that have been reported for 3.15-rc2. Also dominating the diffstat for the pull request is the removal of the rtl8187se driver. It's no longer needed in staging as a "real" driver for this hardware is now merged in the tree in the "correct" location in drivers/net/ All of these patches have been tested in linux-next" * tag 'staging-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging: r8188eu: Fix case where ethtype was never obtained and always be checked against 0 staging: r8712u: Fix case where ethtype was never obtained and always be checked against 0 staging: r8188eu: Calling rtw_get_stainfo() with a NULL sta_addr will return NULL staging: comedi: fix circular locking dependency in comedi_mmap() staging: r8723au: Add missing initialization of change_inx in sort algorithm Staging: unisys: use after free in list_for_each() staging: unisys: use after free in error messages staging: speakup: fix misuse of kstrtol() in handle_goto() staging: goldfish: Call free_irq in error path staging: delete rtl8187se wireless driver staging: rtl8723au: Fix buffer overflow in rtw_get_wfd_ie() staging: gs_fpgaboot: remove __TIMESTAMP__ macro staging: vme: fix memory leak in vme_user_probe() staging: fpgaboot: clean up Makefile staging/usbip: fix store_attach() sscanf return value check staging/usbip: userspace - fix usbipd SIGSEGV from refresh_exported_devices() staging: rtl8188eu: remove spaces, correct counts to unbreak P2P ioctls staging/rtl8821ae: Fix OOM handling in _rtl_init_deferred_work()
2014-04-18Merge tag 'tty-3.15-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial driver fixes from Greg KH: "Here are a number of small tty/serial driver fixes for 3.15-rc2. Also in here are some Documentation file removals for drivers that we removed a long time ago, no need to keep it around any longer. All of these have been in linux-next for a bit" * tag 'tty-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: Revert "serial: 8250, disable "too much work" messages" serial: amba-pl011: fix regression, causing an Oops on rmmod tty: Fix help text of SYNCLINK_CS tty: fix memleak in alloc_pid ttyprintk: Allow built as a module ttyprintk: Fix wrong tty_unregister_driver() call in the error path serial: 8250, disable "too much work" messages Documentation/serial: Delete obsolete driver documentation serial: omap: Fix missing pm_runtime_resume handling by simplifying code serial_core: Fix pm imbalance on unbind serial: pl011: change Rx burst size to half of trigger level serial: timberdale: Depend on X86_32 serial: st-asc: Fix SysRq char handling Revert "serial: clps711x: Give a chance to perform useful tasks during wait loop" serial_core: Fix conditional start_tx on ring buffer not empty serial: efm32: use $vendor,$device scheme for compatible string serial: omap: free the wakeup settings in remove
2014-04-18Merge tag 'usb-3.15-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg KH: "Here are a number of tiny USB fixes and new device ids for 3.15-rc2. Nothing major, just issues some people have reported. All of these have been in linux-next" * tag 'usb-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: uas: fix deadlocky memory allocations uas: fix error handling during scsi_scan() uas: fix GFP_NOIO under spinlock uwb: adds missing error handling USB: cdc-acm: Remove Motorola/Telit H24 serial interfaces from ACM driver USB: ohci-jz4740: FEAT_POWER is a port feature, not a hub feature USB: ohci-jz4740: Fix uninitialized variable warning USB: EHCI: tegra: set txfill_tuning usb: ehci-platform: Return immediately from suspend if ehci_suspend fails usb: ehci-exynos: Return immediately from suspend if ehci_suspend fails USB: fix crash during hotplug of PCI USB controller card USB: cdc-acm: fix double usb_autopm_put_interface() in acm_port_activate() usb: usb-common: fix typo for usb_state_string USB: usb_wwan: fix handling of missing bulk endpoints USB: pl2303: add ids for Hewlett-Packard HP POS pole displays USB: cp210x: Add 8281 (Nanotec Plug & Drive) usb: option driver, add support for Telit UE910v2 Revert "USB: serial: add usbid for dell wwan card to sierra.c" USB: serial: ftdi_sio: add id for Brainboxes serial cards
2014-04-18Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: "13 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: thp: close race between split and zap huge pages mm: fix new kernel-doc warning in filemap.c mm: fix CONFIG_DEBUG_VM_RB description mm: use paravirt friendly ops for NUMA hinting ptes mips: export flush_icache_range mm/hugetlb.c: add cond_resched_lock() in return_unused_surplus_pages() wait: explain the shadowing and type inconsistencies Shiraz has moved Documentation/vm/numa_memory_policy.txt: fix wrong document in numa_memory_policy.txt powerpc/mm: fix ".__node_distance" undefined kernel/watchdog.c:touch_softlockup_watchdog(): use raw_cpu_write() init/Kconfig: move the trusted keyring config option to general setup vmscan: reclaim_clean_pages_from_list() must use mod_zone_page_state()
2014-04-18thp: close race between split and zap huge pagesKirill A. Shutemov
Sasha Levin has reported two THP BUGs[1][2]. I believe both of them have the same root cause. Let's look to them one by one. The first bug[1] is "kernel BUG at mm/huge_memory.c:1829!". It's BUG_ON(mapcount != page_mapcount(page)) in __split_huge_page(). From my testing I see that page_mapcount() is higher than mapcount here. I think it happens due to race between zap_huge_pmd() and page_check_address_pmd(). page_check_address_pmd() misses PMD which is under zap: CPU0 CPU1 zap_huge_pmd() pmdp_get_and_clear() __split_huge_page() anon_vma_interval_tree_foreach() __split_huge_page_splitting() page_check_address_pmd() mm_find_pmd() /* * We check if PMD present without taking ptl: no * serialization against zap_huge_pmd(). We miss this PMD, * it's not accounted to 'mapcount' in __split_huge_page(). */ pmd_present(pmd) == 0 BUG_ON(mapcount != page_mapcount(page)) // CRASH!!! page_remove_rmap(page) atomic_add_negative(-1, &page->_mapcount) The second bug[2] is "kernel BUG at mm/huge_memory.c:1371!". It's VM_BUG_ON_PAGE(!PageHead(page), page) in zap_huge_pmd(). This happens in similar way: CPU0 CPU1 zap_huge_pmd() pmdp_get_and_clear() page_remove_rmap(page) atomic_add_negative(-1, &page->_mapcount) __split_huge_page() anon_vma_interval_tree_foreach() __split_huge_page_splitting() page_check_address_pmd() mm_find_pmd() pmd_present(pmd) == 0 /* The same comment as above */ /* * No crash this time since we already decremented page->_mapcount in * zap_huge_pmd(). */ BUG_ON(mapcount != page_mapcount(page)) /* * We split the compound page here into small pages without * serialization against zap_huge_pmd() */ __split_huge_page_refcount() VM_BUG_ON_PAGE(!PageHead(page), page); // CRASH!!! So my understanding the problem is pmd_present() check in mm_find_pmd() without taking page table lock. The bug was introduced by me commit with commit 117b0791ac42. Sorry for that. :( Let's open code mm_find_pmd() in page_check_address_pmd() and do the check under page table lock. Note that __page_check_address() does the same for PTE entires if sync != 0. I've stress tested split and zap code paths for 36+ hours by now and don't see crashes with the patch applied. Before it took <20 min to trigger the first bug and few hours for second one (if we ignore first). [1] https://lkml.kernel.org/g/<53440991.9090001@oracle.com> [2] https://lkml.kernel.org/g/<5310C56C.60709@oracle.com> Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Tested-by: Sasha Levin <sasha.levin@oracle.com> Cc: Bob Liu <lliubbo@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michel Lespinasse <walken@google.com> Cc: Dave Jones <davej@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: <stable@vger.kernel.org> [3.13+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-18mm: fix new kernel-doc warning in filemap.cRandy Dunlap
Fix new kernel-doc warning in mm/filemap.c: Warning(mm/filemap.c:2600): Excess function parameter 'ppos' description in '__generic_file_aio_write' Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-18mm: fix CONFIG_DEBUG_VM_RB descriptionDavidlohr Bueso
This appears to be a copy/paste error. Update the description to reflect extra rbtree debug and checks for the config option instead of duplicating CONFIG_DEBUG_VM. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Cc: Aswin Chandramouleeswaran <aswin@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-18mm: use paravirt friendly ops for NUMA hinting ptesMel Gorman
David Vrabel identified a regression when using automatic NUMA balancing under Xen whereby page table entries were getting corrupted due to the use of native PTE operations. Quoting him Xen PV guest page tables require that their entries use machine addresses if the preset bit (_PAGE_PRESENT) is set, and (for successful migration) non-present PTEs must use pseudo-physical addresses. This is because on migration MFNs in present PTEs are translated to PFNs (canonicalised) so they may be translated back to the new MFN in the destination domain (uncanonicalised). pte_mknonnuma(), pmd_mknonnuma(), pte_mknuma() and pmd_mknuma() set and clear the _PAGE_PRESENT bit using pte_set_flags(), pte_clear_flags(), etc. In a Xen PV guest, these functions must translate MFNs to PFNs when clearing _PAGE_PRESENT and translate PFNs to MFNs when setting _PAGE_PRESENT. His suggested fix converted p[te|md]_[set|clear]_flags to using paravirt-friendly ops but this is overkill. He suggested an alternative of using p[te|md]_modify in the NUMA page table operations but this is does more work than necessary and would require looking up a VMA for protections. This patch modifies the NUMA page table operations to use paravirt friendly operations to set/clear the flags of interest. Unfortunately this will take a performance hit when updating the PTEs on CONFIG_PARAVIRT but I do not see a way around it that does not break Xen. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: David Vrabel <david.vrabel@citrix.com> Tested-by: David Vrabel <david.vrabel@citrix.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Anvin <hpa@zytor.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Steven Noonan <steven@uplinklabs.net> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-18mips: export flush_icache_rangeKees Cook
The lkdtm module performs tests against executable memory ranges, so it needs to flush the icache for proper behaviors. Other architectures already export this, so do the same for MIPS. [akpm@linux-foundation.org: relocate export sites] Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Sanjay Lal <sanjayl@kymasys.com> Cc: John Crispin <blogic@openwrt.org> Cc: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-18mm/hugetlb.c: add cond_resched_lock() in return_unused_surplus_pages()Mizuma, Masayoshi
soft lockup in freeing gigantic hugepage fixed in commit 55f67141a892 "mm: hugetlb: fix softlockup when a large number of hugepages are freed." can happen in return_unused_surplus_pages(), so let's fix it. Signed-off-by: Masayoshi Mizuma <m.mizuma@jp.fujitsu.com> Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-18wait: explain the shadowing and type inconsistenciesPeter Zijlstra
Stick in a comment before someone else tries to fix the sparse warning this generates. Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-o2ro6f3vkxklni0bc8f7m68s@git.kernel.org Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-18Shiraz has movedViresh Kumar
shiraz.hashim@st.com email-id doesn't exist anymore as he has left the company. Replace ST's id with shiraz.linux.kernel@gmail.com. It also updates .mailmap file to fix address for 'git shortlog'. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: Shiraz Hashim <shiraz.linux.kernel@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-18Documentation/vm/numa_memory_policy.txt: fix wrong document in ↵Tang Chen
numa_memory_policy.txt In document numa_memory_policy.txt, the following examples for flag MPOL_F_RELATIVE_NODES are incorrect. For example, consider a task that is attached to a cpuset with mems 2-5 that sets an Interleave policy over the same set with MPOL_F_RELATIVE_NODES. If the cpuset's mems change to 3-7, the interleave now occurs over nodes 3,5-6. If the cpuset's mems then change to 0,2-3,5, then the interleave occurs over nodes 0,3,5. According to the comment of the patch adding flag MPOL_F_RELATIVE_NODES, the nodemasks the user specifies should be considered relative to the current task's mems_allowed. (https://lkml.org/lkml/2008/2/29/428) And according to numa_memory_policy.txt, if the user's nodemask includes nodes that are outside the range of the new set of allowed nodes, then the remap wraps around to the beginning of the nodemask and, if not already set, sets the node in the mempolicy nodemask. So in the example, if the user specifies 2-5, for a task whose mems_allowed is 3-7, the nodemasks should be remapped the third, fourth, fifth, sixth node in mems_allowed. like the following: mems_allowed: 3 4 5 6 7 relative index: 0 1 2 3 4 5 So the nodemasks should be remapped to 3,5-7, but not 3,5-6. And for a task whose mems_allowed is 0,2-3,5, the nodemasks should be remapped to 0,2-3,5, but not 0,3,5. mems_allowed: 0 2 3 5 relative index: 0 1 2 3 4 5 Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Cc: Randy Dunlap <rdunlap@infradead.org> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-18powerpc/mm: fix ".__node_distance" undefinedMike Qiu
CHK include/config/kernel.release CHK include/generated/uapi/linux/version.h CHK include/generated/utsrelease.h ... Building modules, stage 2. WARNING: 1 bad relocations c0000000013d6a30 R_PPC64_ADDR64 uprobes_fetch_type_table WRAP arch/powerpc/boot/zImage.pseries WRAP arch/powerpc/boot/zImage.epapr MODPOST 1849 modules ERROR: ".__node_distance" [drivers/block/nvme.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 make: *** Waiting for unfinished jobs.... The reason is symbol "__node_distance" not been exported in powerpc. Signed-off-by: Mike Qiu <qiudayu@linux.vnet.ibm.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Nathan Fontenot <nfont@linux.vnet.ibm.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Jesse Larrew <jlarrew@linux.vnet.ibm.com> Cc: Robert Jennings <rcj@linux.vnet.ibm.com> Cc: Alistair Popple <alistair@popple.id.au> Cc: Mike Qiu <qiudayu@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-18kernel/watchdog.c:touch_softlockup_watchdog(): use raw_cpu_write()Andrew Morton
Fix: BUG: using __this_cpu_write() in preemptible [00000000] code: systemd-udevd/497 caller is __this_cpu_preempt_check+0x13/0x20 CPU: 3 PID: 497 Comm: systemd-udevd Tainted: G W 3.15.0-rc1 #9 Hardware name: Hewlett-Packard HP EliteBook 8470p/179B, BIOS 68ICF Ver. F.02 04/27/2012 Call Trace: check_preemption_disabled+0xe1/0xf0 __this_cpu_preempt_check+0x13/0x20 touch_nmi_watchdog+0x28/0x40 Reported-by: Luis Henriques <luis.henriques@canonical.com> Tested-by: Luis Henriques <luis.henriques@canonical.com> Cc: Eric Piel <eric.piel@tremplin-utc.net> Cc: Robert Moore <robert.moore@intel.com> Cc: Lv Zheng <lv.zheng@intel.com> Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-18init/Kconfig: move the trusted keyring config option to general setupPeter Foley
The SYSTEM_TRUSTED_KEYRING config option is not in any menu, causing it to show up in the toplevel of the kernel configuration. Fix this by moving it under the General Setup menu. Signed-off-by: Peter Foley <pefoley2@pefoley.com> Cc: David Howells <dhowells@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-18vmscan: reclaim_clean_pages_from_list() must use mod_zone_page_state()Christoph Lameter
Seems to be called with preemption enabled. Therefore it must use mod_zone_page_state instead. Signed-off-by: Christoph Lameter <cl@linux.com> Reported-by: Grygorii Strashko <grygorii.strashko@ti.com> Tested-by: Grygorii Strashko <grygorii.strashko@ti.com> Cc: Tejun Heo <tj@kernel.org> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-18net: sctp: cache auth_enable per endpointVlad Yasevich
Currently, it is possible to create an SCTP socket, then switch auth_enable via sysctl setting to 1 and crash the system on connect: Oops[#1]: CPU: 0 PID: 0 Comm: swapper Not tainted 3.14.1-mipsgit-20140415 #1 task: ffffffff8056ce80 ti: ffffffff8055c000 task.ti: ffffffff8055c000 [...] Call Trace: [<ffffffff8043c4e8>] sctp_auth_asoc_set_default_hmac+0x68/0x80 [<ffffffff8042b300>] sctp_process_init+0x5e0/0x8a4 [<ffffffff8042188c>] sctp_sf_do_5_1B_init+0x234/0x34c [<ffffffff804228c8>] sctp_do_sm+0xb4/0x1e8 [<ffffffff80425a08>] sctp_endpoint_bh_rcv+0x1c4/0x214 [<ffffffff8043af68>] sctp_rcv+0x588/0x630 [<ffffffff8043e8e8>] sctp6_rcv+0x10/0x24 [<ffffffff803acb50>] ip6_input+0x2c0/0x440 [<ffffffff8030fc00>] __netif_receive_skb_core+0x4a8/0x564 [<ffffffff80310650>] process_backlog+0xb4/0x18c [<ffffffff80313cbc>] net_rx_action+0x12c/0x210 [<ffffffff80034254>] __do_softirq+0x17c/0x2ac [<ffffffff800345e0>] irq_exit+0x54/0xb0 [<ffffffff800075a4>] ret_from_irq+0x0/0x4 [<ffffffff800090ec>] rm7k_wait_irqoff+0x24/0x48 [<ffffffff8005e388>] cpu_startup_entry+0xc0/0x148 [<ffffffff805a88b0>] start_kernel+0x37c/0x398 Code: dd0900b8 000330f8 0126302d <dcc60000> 50c0fff1 0047182a a48306a0 03e00008 00000000 ---[ end trace b530b0551467f2fd ]--- Kernel panic - not syncing: Fatal exception in interrupt What happens while auth_enable=0 in that case is, that ep->auth_hmacs is initialized to NULL in sctp_auth_init_hmacs() when endpoint is being created. After that point, if an admin switches over to auth_enable=1, the machine can crash due to NULL pointer dereference during reception of an INIT chunk. When we enter sctp_process_init() via sctp_sf_do_5_1B_init() in order to respond to an INIT chunk, the INIT verification succeeds and while we walk and process all INIT params via sctp_process_param() we find that net->sctp.auth_enable is set, therefore do not fall through, but invoke sctp_auth_asoc_set_default_hmac() instead, and thus, dereference what we have set to NULL during endpoint initialization phase. The fix is to make auth_enable immutable by caching its value during endpoint initialization, so that its original value is being carried along until destruction. The bug seems to originate from the very first days. Fix in joint work with Daniel Borkmann. Reported-by: Joshua Kinard <kumba@gentoo.org> Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Tested-by: Joshua Kinard <kumba@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-18Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless John W. Linville says: ==================== pull request: wireless 2014-04-17 Please pull this batch of fixes intended for the 3.15 stream... For the mac80211 bits, Johannes says: "We have a fix from Chun-Yeow to not look at management frame bitrates that are typically really low, two fixes from Felix for AP_VLAN interfaces, a fix from Ido to disable SMPS settings when a monitor interface is enabled, a radar detection fix from Michał and a fix from myself for a very old remain-on-channel bug." For the iwlwifi bits, Emmanuel says: "I have new device IDs and a new firmware API. These are the trivial ones. The less trivial ones are Johannes's fix that delays the enablement of an interrupt coalescing hardware until after association - this fixes a few connection problems seen in the field. Eyal has a bunch of rate control fixes. I decided to add these for 3.15 because they fix some disconnection and packet loss scenarios which were reported by the field. I also have a fix for a memory leak that happens only with a very new NIC." Along with those... Amitkumar Karwar fixes a couple of problems relating to driver/firmware interactions in mwifiex. Christian Engelmayer avoids a couple of potential memory leaks in the new rsi driver. Eliad Peller provides a wl18xx mailbox alignment fix for problems when using new firmware. Frederic Danis adds a couple of missing debugging strings to the cw1200 driver. Geert Uytterhoeven adds a variable initialization inside of the rsi driver. Luciano Coelho patches the wlcore code to ignore dummy packet events in PLT mode in order to work around a firmware bug. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-18tg3: update rx_jumbo_pending ring param only when jumbo frames are enabledIvan Vecera
The patch fixes a problem with dropped jumbo frames after usage of 'ethtool -G ... rx'. Scenario: 1. ip link set eth0 up 2. ethtool -G eth0 rx N # <- This zeroes rx-jumbo 3. ip link set mtu 9000 dev eth0 The ethtool command set rx_jumbo_pending to zero so any received jumbo packets are dropped and you need to use 'ethtool -G eth0 rx-jumbo N' to workaround the issue. The patch changes the logic so rx_jumbo_pending value is changed only if jumbo frames are enabled (MTU > 1500). Signed-off-by: Ivan Vecera <ivecera@redhat.com> Acked-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-18vlan: Fix lockdep warning when vlan dev handle notificationdingtianhong
When I open the LOCKDEP config and run these steps: modprobe 8021q vconfig add eth2 20 vconfig add eth2.20 30 ifconfig eth2 xx.xx.xx.xx then the Call Trace happened: [32524.386288] ============================================= [32524.386293] [ INFO: possible recursive locking detected ] [32524.386298] 3.14.0-rc2-0.7-default+ #35 Tainted: G O [32524.386302] --------------------------------------------- [32524.386306] ifconfig/3103 is trying to acquire lock: [32524.386310] (&vlan_netdev_addr_lock_key/1){+.....}, at: [<ffffffff814275f4>] dev_mc_sync+0x64/0xb0 [32524.386326] [32524.386326] but task is already holding lock: [32524.386330] (&vlan_netdev_addr_lock_key/1){+.....}, at: [<ffffffff8141af83>] dev_set_rx_mode+0x23/0x40 [32524.386341] [32524.386341] other info that might help us debug this: [32524.386345] Possible unsafe locking scenario: [32524.386345] [32524.386350] CPU0 [32524.386352] ---- [32524.386354] lock(&vlan_netdev_addr_lock_key/1); [32524.386359] lock(&vlan_netdev_addr_lock_key/1); [32524.386364] [32524.386364] *** DEADLOCK *** [32524.386364] [32524.386368] May be due to missing lock nesting notation [32524.386368] [32524.386373] 2 locks held by ifconfig/3103: [32524.386376] #0: (rtnl_mutex){+.+.+.}, at: [<ffffffff81431d42>] rtnl_lock+0x12/0x20 [32524.386387] #1: (&vlan_netdev_addr_lock_key/1){+.....}, at: [<ffffffff8141af83>] dev_set_rx_mode+0x23/0x40 [32524.386398] [32524.386398] stack backtrace: [32524.386403] CPU: 1 PID: 3103 Comm: ifconfig Tainted: G O 3.14.0-rc2-0.7-default+ #35 [32524.386409] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007 [32524.386414] ffffffff81ffae40 ffff8800d9625ae8 ffffffff814f68a2 ffff8800d9625bc8 [32524.386421] ffffffff810a35fb ffff8800d8a8d9d0 00000000d9625b28 ffff8800d8a8e5d0 [32524.386428] 000003cc00000000 0000000000000002 ffff8800d8a8e5f8 0000000000000000 [32524.386435] Call Trace: [32524.386441] [<ffffffff814f68a2>] dump_stack+0x6a/0x78 [32524.386448] [<ffffffff810a35fb>] __lock_acquire+0x7ab/0x1940 [32524.386454] [<ffffffff810a323a>] ? __lock_acquire+0x3ea/0x1940 [32524.386459] [<ffffffff810a4874>] lock_acquire+0xe4/0x110 [32524.386464] [<ffffffff814275f4>] ? dev_mc_sync+0x64/0xb0 [32524.386471] [<ffffffff814fc07a>] _raw_spin_lock_nested+0x2a/0x40 [32524.386476] [<ffffffff814275f4>] ? dev_mc_sync+0x64/0xb0 [32524.386481] [<ffffffff814275f4>] dev_mc_sync+0x64/0xb0 [32524.386489] [<ffffffffa0500cab>] vlan_dev_set_rx_mode+0x2b/0x50 [8021q] [32524.386495] [<ffffffff8141addf>] __dev_set_rx_mode+0x5f/0xb0 [32524.386500] [<ffffffff8141af8b>] dev_set_rx_mode+0x2b/0x40 [32524.386506] [<ffffffff8141b3cf>] __dev_open+0xef/0x150 [32524.386511] [<ffffffff8141b177>] __dev_change_flags+0xa7/0x190 [32524.386516] [<ffffffff8141b292>] dev_change_flags+0x32/0x80 [32524.386524] [<ffffffff8149ca56>] devinet_ioctl+0x7d6/0x830 [32524.386532] [<ffffffff81437b0b>] ? dev_ioctl+0x34b/0x660 [32524.386540] [<ffffffff814a05b0>] inet_ioctl+0x80/0xa0 [32524.386550] [<ffffffff8140199d>] sock_do_ioctl+0x2d/0x60 [32524.386558] [<ffffffff81401a52>] sock_ioctl+0x82/0x2a0 [32524.386568] [<ffffffff811a7123>] do_vfs_ioctl+0x93/0x590 [32524.386578] [<ffffffff811b2705>] ? rcu_read_lock_held+0x45/0x50 [32524.386586] [<ffffffff811b39e5>] ? __fget_light+0x105/0x110 [32524.386594] [<ffffffff811a76b1>] SyS_ioctl+0x91/0xb0 [32524.386604] [<ffffffff815057e2>] system_call_fastpath+0x16/0x1b ======================================================================== The reason is that all of the addr_lock_key for vlan dev have the same class, so if we change the status for vlan dev, the vlan dev and its real dev will hold the same class of addr_lock_key together, so the warning happened. we should distinguish the lock depth for vlan dev and its real dev. v1->v2: Convert the vlan_netdev_addr_lock_key to an array of eight elements, which could support to add 8 vlan id on a same vlan dev, I think it is enough for current scene, because a netdev's name is limited to IFNAMSIZ which could not hold 8 vlan id, and the vlan dev would not meet the same class key with its real dev. The new function vlan_dev_get_lockdep_subkey() will return the subkey and make the vlan dev could get a suitable class key. v2->v3: According David's suggestion, I use the subclass to distinguish the lock key for vlan dev and its real dev, but it make no sense, because the difference for subclass in the lock_class_key doesn't mean that the difference class for lock_key, so I use lock_depth to distinguish the different depth for every vlan dev, the same depth of the vlan dev could have the same lock_class_key, I import the MAX_LOCK_DEPTH from the include/linux/sched.h, I think it is enough here, the lockdep should never exceed that value. v3->v4: Add a huge array of locking keys will waste static kernel memory and is not a appropriate method, we could use _nested() variants to fix the problem, calculate the depth for every vlan dev, and use the depth as the subclass for addr_lock_key. Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-18Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull infiniband/rdma updates from Roland Dreier: - mostly cxgb4 fixes unblocked by the merge of some prerequisites via the net tree - drop deprecated MSI-X API use. - a couple other miscellaneous things. * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: RDMA/cxgb4: Fix over-dereference when terminating RDMA/cxgb4: Use uninitialized_var() RDMA/cxgb4: Add missing debug stats RDMA/cxgb4: Initialize reserved fields in a FW work request RDMA/cxgb4: Use pr_warn_ratelimited RDMA/cxgb4: Max fastreg depth depends on DSGL support RDMA/cxgb4: SQ flush fix RDMA/cxgb4: rmb() after reading valid gen bit RDMA/cxgb4: Endpoint timeout fixes RDMA/cxgb4: Use the BAR2/WC path for kernel QPs and T5 devices IB/mlx5: Add block multicast loopback support IB/mthca: Use pci_enable_msix_exact() instead of pci_enable_msix() IB/qib: Use pci_enable_msix_range() instead of pci_enable_msix()
2014-04-18ARC: Delete stale barrier.hVineet Gupta
Commit 93ea02bb8435 ("arch: Clean up asm/barrier.h implementations") wired generic barrier.h for ARC, but failed to delete the existing file. In 3.15, due to rcupdate.h updates, this causes a build breakage on ARC: CC arch/arc/kernel/asm-offsets.s In file included from include/linux/sched.h:45:0, from arch/arc/kernel/asm-offsets.c:9: include/linux/rculist.h: In function __list_add_rcu: include/linux/rculist.h:54:2: error: implicit declaration of function smp_store_release [-Werror=implicit-function-declaration] rcu_assign_pointer(list_next_rcu(prev), new); ^ Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-18Merge tag 'pci-v3.15-fixes-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "These are fixes for a powerpc NULL pointer dereference, an OF interrupt mapping issue on some of the new host bridges, and a DesignWare iATU issue. Host bridge drivers - Fix OF interrupt mapping for DesignWare, R-Car, Tegra (Lucas Stach) - Fix DesignWare iATU programming (Mohit Kumar) Miscellaneous - Fix powerpc NULL dereference from list_for_each_entry() update (Mike Qiu)" * tag 'pci-v3.15-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI: tegra: Use new OF interrupt mapping when possible PCI: rcar: Use new OF interrupt mapping when possible PCI: designware: Use new OF interrupt mapping when possible PCI: designware: Fix iATU programming for cfg1, io and mem viewport PCI: designware: Fix comment for setting number of lanes powerpc/PCI: Fix NULL dereference in sys_pciconfig_iobase() list traversal
2014-04-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID fixes from Jiri Kosina: - fix for merge window mismerge in hid-sony, from Frank Praznik - fix for Surface Type/Touch Cover 2 device, from Benjamin Tissoires - quirk for ThinkPad Helix sensor hub from Stephen Chandler Paul * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: core: do not scan constant input report Revert "HID: microsoft: Add ID's for Surface Type/Touch Cover 2" HID: sensor-hub: add sensor hub quirk for ThinkPad Helix HID: sony: Fix cancel_work_sync mismerge
2014-04-18Merge tag 'sound-3.15-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Just a copule of HD-audio device/codec-specific quirks, and a trivial replacement of udelay() with mdelay() in the old es18xx driver code. All should be safe to apply" * tag 'sound-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda/realtek - Add headset Mic support for Dell machine ALSA: hda - add headset mic detect quirk for a Dell laptop ALSA: es18xx driver should use udelay error ALSA: hda/realtek - Add support of ALC288 codec
2014-04-18Merge tag 'dt-fixes-for-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree fixes from Rob Herring: - fix error handling in of_update_property - fix section mismatch warnings in __reserved_mem_check_root - add empty of_find_node_by_path for !OF builds - add various missing binding documentation * tag 'dt-fixes-for-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: of: add empty of_find_node_by_path() for !OF of: Clean up of_update_property DT: add vendor prefix for EBV Elektronik of: Fix the section mismatch warnings. of: Add vendor prefix for Digi International Inc. DT: I2C: Add trivial bindings used by kirkwood boards DT: Vendor: Add prefixes used by Kirkwood devices DT: bindings: add missing Marvell Kirkwood SoC documentation dt-bindings: add vendor-prefix for Newhaven Display of: add vendor prefix for I2SE GmbH of: add vendor prefix for ISEE 2007 S.L.
2014-04-18Merge tag 'xfs-for-linus-3.15-rc2' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull xfs bug fixes from Dave Chinner: "The fixes are for data corruption issues, memory corruption and regressions for changes merged in -rc1. Data corruption fixes: - fix a bunch of delayed allocation state mismatches - fix collapse/zero range bugs - fix a direct IO block mapping bug @ EOF Other fixes: - fix a use after free on metadata IO error - fix a use after free on IO error during unmount - fix an incorrect error sign on direct IO write errors - add missing O_TMPFILE inode security context initialisation" * tag 'xfs-for-linus-3.15-rc2' of git://oss.sgi.com/xfs/xfs: xfs: fix tmpfile/selinux deadlock and initialize security xfs: fix buffer use after free on IO error xfs: wrong error sign conversion during failed DIO writes xfs: unmount does not wait for shutdown during unmount xfs: collapse range is delalloc challenged xfs: don't map ranges that span EOF for direct IO xfs: zeroing space needs to punch delalloc blocks xfs: xfs_vm_write_end truncates too much on failure xfs: write failure beyond EOF truncates too much data xfs: kill buffers over failed write ranges properly
2014-04-18Merge tag 'trace-fixes-v3.15-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing fixes from Steven Rostedt: "This contains two fixes. The first is to remove a duplication of creating debugfs files that already exist and causes an error report to be printed due to the failure of the second creation. The second is a memory leak fix that was introduced in 3.14" * tag 'trace-fixes-v3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing/uprobes: Fix uprobe_cpu_buffer memory leak tracing: Do not try to recreated toplevel set_ftrace_* files
2014-04-18of: add empty of_find_node_by_path() for !OFdt-fixes-for-3.15Alexander Shiyan
Add an empty version of of_find_node_by_path(). This fixes following build error for asoc tree: sound/soc/fsl/fsl_ssi.c: In function 'fsl_ssi_probe': sound/soc/fsl/fsl_ssi.c:1471:2: error: implicit declaration of function 'of_find_node_by_path' [-Werror=implicit-function-declaration] sprop = of_get_property(of_find_node_by_path("/"), "compatible", NULL); Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Rob Herring <robh@kernel.org>
2014-04-18perf/x86/intel: Use rdmsrl_safe() when initializing RAPL PMUVenkatesh Srinivas
CPUs which should support the RAPL counters according to Family/Model/Stepping may still issue #GP when attempting to access the RAPL MSRs. This may happen when Linux is running under KVM and we are passing-through host F/M/S data, for example. Use rdmsrl_safe to first access the RAPL_POWER_UNIT MSR; if this fails, do not attempt to use this PMU. Signed-off-by: Venkatesh Srinivas <venkateshs@google.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1394739386-22260-1-git-send-email-venkateshs@google.com Cc: zheng.z.yan@intel.com Cc: eranian@google.com Cc: ak@linux.intel.com Cc: linux-kernel@vger.kernel.org [ The patch also silently fixes another bug: rapl_pmu_init() didn't handle the memory alloc failure case previously. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-18drm: bochs: drop unused struct fieldsGerd Hoffmann
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
