2014-06-01Linux 3.15-rc8v3.15-rc8Linus Torvalds
2014-06-01Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc fix from Ben Herrenschmidt: "Here's just one trivial patch to wire up sys_renameat2 which I seem to have completely missed so far. (My test build scripts fwd me warnings but miss the ones generated for missing syscalls)" * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: Wire renameat2() syscall
2014-06-01Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS fixes from Ralf Baechle: "A fair number of fixes across the field. Nothing terribly complicated; the one liners in below changelog should be fairly descriptive. Noteworthy is the SB1 change which the result of changes to binutils resulting in one big gas warning for most files being assembled as well as the asid_cache and branch emulation fixes which fix corruption or possible uninteded behaviour of kernel or application code. The remainder of fixes are more platforms or subsystem specific" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: R46000: Fix Micro-assembler field overflow for R4600 V2 MIPS: ptrace: Avoid smp_processor_id() in preemptible code MIPS: Lemote 2F: cs5536: mfgpt: use raw locks MIPS: SB1: Fix excessive kernel warnings. MIPS: RC32434: fix broken PCI resource initialization MIPS: malta: memory.c: Initialize the 'memsize' variable MIPS: Fix typo when reporting cache and ftlb errors for ImgTec cores MIPS: Fix inconsistancy of __NR_Linux_syscalls value MIPS: Fix branch emulation of branch likely instructions. MIPS: Fix a typo error in AUDIT_ARCH definition MIPS: Change type of asid_cache to unsigned long
2014-06-01Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Various fixlets, mostly related to the (root-only) SCHED_DEADLINE policy, but also a hotplug bug fix and a fix for a NR_CPUS related overallocation bug causing a suspend/resume regression" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: Fix hotplug vs. set_cpus_allowed_ptr() sched/cpupri: Replace NR_CPUS arrays sched/deadline: Replace NR_CPUS arrays sched/deadline: Restrict user params max value to 2^63 ns sched/deadline: Change sched_getparam() behaviour vs SCHED_DEADLINE sched: Disallow sched_attr::sched_policy < 0 sched: Make sched_setattr() correctly return -EFBIG
2014-06-02powerpc: Wire renameat2() syscallBenjamin Herrenschmidt
2014-05-31Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core futex/rtmutex fixes from Thomas Gleixner: "Three fixlets for long standing issues in the futex/rtmutex code unearthed by Dave Jones syscall fuzzer: - Add missing early deadlock detection checks in the futex code - Prevent user space from attaching a futex to kernel threads - Make the deadlock detector of rtmutex work again Looks large, but is more comments than code change" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: rtmutex: Fix deadlock detector for real futex: Prevent attaching to kernel threads futex: Add another early deadlock detection check
2014-05-31Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Mostly quiet now: i915: fixing userspace visiblie issues, all stable marked radeon: one more pll fix, two crashers, one suspend/resume regression" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/radeon: Resume fbcon last drm/radeon: only allocate necessary size for vm bo list drm/radeon: don't allow RADEON_GEM_DOMAIN_CPU for command submission drm/radeon: avoid crash if VM command submission isn't available drm/radeon: lower the ref * post PLL maximum once more drm/i915: Prevent negative relocation deltas from wrapping drm/i915: Only copy back the modified fields to userspace from execbuffer drm/i915: Fix dynamic allocation of physical handles
2014-05-31dcache: add missing lockdep annotationLinus Torvalds
lock_parent() very much on purpose does nested locking of dentries, and is careful to maintain the right order (lock parent first). But because it didn't annotate the nested locking order, lockdep thought it might be a deadlock on d_lock, and complained. Add the proper annotation for the inner locking of the child dentry to make lockdep happy. Introduced by commit 046b961b45f9 ("shrink_dentry_list(): take parent's ->d_lock earlier"). Reported-and-tested-by: Josh Boyer <jwboyer@fedoraproject.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-31drm/radeon: Resume fbcon lastDaniel Vetter
So a few people complained that commit 177cf92de4aa97ec1435987e91696ed8b5023130 Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Tue Apr 1 22:14:59 2014 +0200 drm/crtc-helpers: fix dpms on logic which was merged into 3.15-rc1, broke resume on radeons. Strangely git bisect lead everyone to commit 25f397a429dfa43f22c278d0119a60a343aa568f Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Fri Jul 19 18:57:11 2013 +0200 drm/crtc-helper: explicit DPMS on after modeset which was merged long ago and actually part of 3.14. Digging deeper I've noticed (again) that the call to drm_helper_resume_force_mode in the radeon resume handlers was a no-op previously because everything gets shut down on suspend. radeon does this with explicit calls to drm_helper_connector_dpms with DPMS_OFF. But with 177c we now force the dpms state to ON, so suddenly resume_force_mode actually forced the crtcs back on. This is the intention of the change after all, the problem is that radeon resumes the fbdev console layer _before_ restoring the display, through calling fb_set_suspend. And fbcon does an immediate ->set_par, which in turn causes the same forced mode restore to happen. Two concurrent modeset operations didn't lead to happiness. Fix this by delaying the fbcon resume until the end of the readeon resum functions. v2: Fix up a bit of the spelling fail. References: https://lkml.org/lkml/2014/5/29/1043 References: https://lkml.org/lkml/2014/5/2/388 Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=74751 Tested-by: Ken Moffat <zarniwhoop@ntlworld.com> Cc: Alex Deucher <alexdeucher@gmail.com> Cc: Ken Moffat <zarniwhoop@ntlworld.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@gmail.com>
2014-05-31Merge branch 'drm-fixes-3.15' of ↵Dave Airlie
git://people.freedesktop.org/~deathsimple/linux into drm-fixes this is the next pull request for stashed up radeon fixes for 3.15. This is finally calming down with only four patches in this pull request. * 'drm-fixes-3.15' of git://people.freedesktop.org/~deathsimple/linux: drm/radeon: only allocate necessary size for vm bo list drm/radeon: don't allow RADEON_GEM_DOMAIN_CPU for command submission drm/radeon: avoid crash if VM command submission isn't available drm/radeon: lower the ref * post PLL maximum once more
2014-05-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input subsystem fixes from Dmitry Torokhov: "A couple of driver/build fixups and also redone quirk for Synaptics touchpads on Lenovo boxes (now using PNP IDs instead of DMI data to limit number of quirks)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: synaptics - change min/max quirk table to pnp-id matching Input: synaptics - add a matches_pnp_id helper function Input: synaptics - T540p - unify with other LEN0034 models Input: synaptics - add min/max quirk for the ThinkPad W540 Input: ambakmi - request a shared interrupt for AMBA KMI devices Input: pxa27x-keypad - fix generating scancode Input: atmel-wm97xx - only build for AVR32 Input: fix ps2/serio module dependency
2014-05-30Merge tag 'firewire-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 Pull firewire fix from Stefan Richter: "A regression fix for the IEEE 1394 subsystem: re-enable IRQ-based asynchronous request reception at addresses below 128 TB" * tag 'firewire-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: firewire: revert to 4 GB RDMA, fix protocols using Memory Space
2014-05-30Merge tag 'dm-3.15-fixes-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm Pull device-mapper fixes from Mike Snitzer: "A dm-cache stable fix to split discards on cache block boundaries because dm-cache cannot yet handle discards that span cache blocks. Really fix a dm-mpath LOCKDEP warning that was introduced in -rc1. Add a 'no_space_timeout' control to dm-thinp to restore the ability to queue IO indefinitely when no data space is available. This fixes a change in behavior that was introduced in -rc6 where the timeout couldn't be disabled" * tag 'dm-3.15-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: dm mpath: really fix lockdep warning dm cache: always split discards on cache block boundaries dm thin: add 'no_space_timeout' dm-thin-pool module param
2014-05-30x86_64: expand kernel stack to 16KMinchan Kim
While I play inhouse patches with much memory pressure on qemu-kvm, 3.14 kernel was randomly crashed. The reason was kernel stack overflow. When I investigated the problem, the callstack was a little bit deeper by involve with reclaim functions but not direct reclaim path. I tried to diet stack size of some functions related with alloc/reclaim so did a hundred of byte but overflow was't disappeard so that I encounter overflow by another deeper callstack on reclaim/allocator path. Of course, we might sweep every sites we have found for reducing stack usage but I'm not sure how long it saves the world(surely, lots of developer start to add nice features which will use stack agains) and if we consider another more complex feature in I/O layer and/or reclaim path, it might be better to increase stack size( meanwhile, stack usage on 64bit machine was doubled compared to 32bit while it have sticked to 8K. Hmm, it's not a fair to me and arm64 already expaned to 16K. ) So, my stupid idea is just let's expand stack size and keep an eye toward stack consumption on each kernel functions via stacktrace of ftrace. For example, we can have a bar like that each funcion shouldn't exceed 200K and emit the warning when some function consumes more in runtime. Of course, it could make false positive but at least, it could make a chance to think over it. I guess this topic was discussed several time so there might be strong reason not to increase kernel stack size on x86_64, for me not knowing so Ccing x86_64 maintainers, other MM guys and virtio maintainers. Here's an example call trace using up the kernel stack: Depth Size Location (51 entries) ----- ---- -------- 0) 7696 16 lookup_address 1) 7680 16 _lookup_address_cpa.isra.3 2) 7664 24 __change_page_attr_set_clr 3) 7640 392 kernel_map_pages 4) 7248 256 get_page_from_freelist 5) 6992 352 __alloc_pages_nodemask 6) 6640 8 alloc_pages_current 7) 6632 168 new_slab 8) 6464 8 __slab_alloc 9) 6456 80 __kmalloc 10) 6376 376 vring_add_indirect 11) 6000 144 virtqueue_add_sgs 12) 5856 288 __virtblk_add_req 13) 5568 96 virtio_queue_rq 14) 5472 128 __blk_mq_run_hw_queue 15) 5344 16 blk_mq_run_hw_queue 16) 5328 96 blk_mq_insert_requests 17) 5232 112 blk_mq_flush_plug_list 18) 5120 112 blk_flush_plug_list 19) 5008 64 io_schedule_timeout 20) 4944 128 mempool_alloc 21) 4816 96 bio_alloc_bioset 22) 4720 48 get_swap_bio 23) 4672 160 __swap_writepage 24) 4512 32 swap_writepage 25) 4480 320 shrink_page_list 26) 4160 208 shrink_inactive_list 27) 3952 304 shrink_lruvec 28) 3648 80 shrink_zone 29) 3568 128 do_try_to_free_pages 30) 3440 208 try_to_free_pages 31) 3232 352 __alloc_pages_nodemask 32) 2880 8 alloc_pages_current 33) 2872 200 __page_cache_alloc 34) 2672 80 find_or_create_page 35) 2592 80 ext4_mb_load_buddy 36) 2512 176 ext4_mb_regular_allocator 37) 2336 128 ext4_mb_new_blocks 38) 2208 256 ext4_ext_map_blocks 39) 1952 160 ext4_map_blocks 40) 1792 384 ext4_writepages 41) 1408 16 do_writepages 42) 1392 96 __writeback_single_inode 43) 1296 176 writeback_sb_inodes 44) 1120 80 __writeback_inodes_wb 45) 1040 160 wb_writeback 46) 880 208 bdi_writeback_workfn 47) 672 144 process_one_work 48) 528 112 worker_thread 49) 416 240 kthread 50) 176 176 ret_from_fork [ Note: the problem is exacerbated by certain gcc versions that seem to generate much bigger stack frames due to apparently bad coalescing of temporaries and generating too many spills. Rusty saw gcc-4.6.4 using 35% more stack on the virtio path than 4.8.2 does, for example. Minchan not only uses such a bad gcc version (4.6.3 in his case), but some of the stack use is due to debugging (CONFIG_DEBUG_PAGEALLOC is what causes that kernel_map_pages() frame, for example). But we're clearly getting too close. The VM code also seems to have excessive stack frames partly for the same compiler reason, triggered by excessive inlining and lots of function arguments. We need to improve on our stack use, but in the meantime let's do this simple stack increase too. Unlike most earlier reports, there is nothing simple that stands out as being really horribly wrong here, apart from the fact that the stack frames are just bigger than they should need to be. - Linus ] Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Peter Anvin <hpa@zytor.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Dave Jones <davej@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Michael S Tsirkin <mst@redhat.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: PJ Waskiewicz <pjwaskiewicz@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-30Merge branch 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs dcache livelock fix from Al Viro: "Fixes for livelocks in shrink_dentry_list() introduced by fixes to shrink list corruption; the root cause was that trylock of parent's ->d_lock could be disrupted by d_walk() happening on other CPUs, resulting in shrink_dentry_list() making no progress *and* the same d_walk() being called again and again for as long as shrink_dentry_list() doesn't get past that mess. The solution is to have shrink_dentry_list() treat that trylock failure not as 'try to do the same thing again', but 'lock them in the right order'" * 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: dentry_kill() doesn't need the second argument now dealing with the rest of shrink_dentry_list() livelock shrink_dentry_list(): take parent's ->d_lock earlier expand dentry_kill(dentry, 0) in shrink_dentry_list() split dentry_kill() lift the "already marked killed" case into shrink_dentry_list()
2014-05-30dentry_kill() doesn't need the second argument nowAl Viro
it's 1 in the only remaining caller. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-30dealing with the rest of shrink_dentry_list() livelockAl Viro
We have the same problem with ->d_lock order in the inner loop, where we are dropping references to ancestors. Same solution, basically - instead of using dentry_kill() we use lock_parent() (introduced in the previous commit) to get that lock in a safe way, recheck ->d_count (in case if lock_parent() has ended up dropping and retaking ->d_lock and somebody managed to grab a reference during that window), trylock the inode->i_lock and use __dentry_kill() to do the rest. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-30shrink_dentry_list(): take parent's ->d_lock earlierAl Viro
The cause of livelocks there is that we are taking ->d_lock on dentry and its parent in the wrong order, forcing us to use trylock on the parent's one. d_walk() takes them in the right order, and unfortunately it's not hard to create a situation when shrink_dentry_list() can't make progress since trylock keeps failing, and shrink_dcache_parent() or check_submounts_and_drop() keeps calling d_walk() disrupting the very shrink_dentry_list() it's waiting for. Solution is straightforward - if that trylock fails, let's unlock the dentry itself and take locks in the right order. We need to stabilize ->d_parent without holding ->d_lock, but that's doable using RCU. And we'd better do that in the very beginning of the loop in shrink_dentry_list(), since the checks on refcount, etc. would need to be redone anyway. That deals with a half of the problem - killing dentries on the shrink list itself. Another one (dropping their parents) is in the next commit. locking parent is interesting - it would be easy to do rcu_read_lock(), lock whatever we think is a parent, lock dentry itself and check if the parent is still the right one. Except that we need to check that *before* locking the dentry, or we are risking taking ->d_lock out of order. Fortunately, once the D1 is locked, we can check if D2->d_parent is equal to D1 without the need to lock D2; D2->d_parent can start or stop pointing to D1 only under D1->d_lock, so taking D1->d_lock is enough. In other words, the right solution is rcu_read_lock/lock what looks like parent right now/check if it's still our parent/rcu_read_unlock/lock the child. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-30drm/radeon: only allocate necessary size for vm bo listChristian König
No need to always allocate the theoretical maximum here. Signed-off-by: Christian König <christian.koenig@amd.com>
2014-05-30drm/radeon: don't allow RADEON_GEM_DOMAIN_CPU for command submissionMarek Olšák
It hangs the hardware. Signed-off-by: Marek Olšák <marek.olsak@amd.com> Reviewed-by: Christian König <christian.koenig@amd.com> Cc: stable@vger.kernel.org
2014-05-30drm/radeon: avoid crash if VM command submission isn't availableChristian König
Signed-off-by: Christian König <christian.koenig@amd.com> CC: stable@vger.kernel.org
2014-05-30drm/radeon: lower the ref * post PLL maximum once moreChristian König
Let's be conservative and use 100 here until we find something better. Bugs: https://bugzilla.kernel.org/show_bug.cgi?id=75241 Signed-off-by: Christian König <christian.koenig@amd.com>
2014-05-29Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "The usual random collection of relatively small ARM fixes" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: 8063/1: bL_switcher: fix individual online status reporting of removed CPUs ARM: 8064/1: fix v7-M signal return ARM: 8057/1: amba: Add Qualcomm vendor ID. ARM: 8052/1: unwind: Fix handling of "Pop r4-r[4+nnn],r14" opcode ARM: 8051/1: put_user: fix possible data corruption in put_user ARM: 8048/1: fix v7-M setup stack location
2014-05-29Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fix from Will Deacon: "Fix CoW regression for transparent hugepages by routing set_pmd_at to set_pte_at, which correctly handles PTE_WRITE and will mark the resulting table entry as read-only where appropriate" * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: arm64: mm: fix pmd_write CoW brokenness
2014-05-29Merge tag 'pm+acpi-3.15-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: "These are three stable-candidate fixes, one for the ACPI thermal driver and two for cpufreq drivers. Specifics: - A workqueue is destroyed too early during the ACPI thermal driver module unload which leads to a NULL pointer dereference in the driver's remove callback. Fix from Aaron Lu. - A wrong argument is passed to devm_regulator_get_optional() in the probe routine of the cpu0 cpufreq driver which leads to resource leaks if the driver is unbound from the cpufreq platform device. Fix from Lucas Stach. - A lock is missing in cpufreq_governor_dbs() which leads to memory corruption and NULL pointer dereferences during system suspend/resume, for example. Fix from Bibek Basu" * tag 'pm+acpi-3.15-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / thermal: fix workqueue destroy order cpufreq: cpu0: drop wrong devm usage cpufreq: remove race while accessing cur_policy
2014-05-29Merge tag 'clk-fixes-for-linus' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull clock fixes from Mike Turquette: "Small number of user-visible regression fixes for clock drivers. There is a memory leak fix for an ST platform, an infinite Loop Of Doom fix for the recent changes to the basic clock divider (hopefully the last fix for those recent changes) and some Tegra PLL changes which keep PCI from being hosed on that platform" * tag 'clk-fixes-for-linus' of git://git.linaro.org/people/mike.turquette/linux: clk: st: Fix memory leak clk: divider: Fix table round up function clk: tegra: Fix enabling of PLLE clk: tegra: Introduce divider mask and shift helpers clk: tegra: Fix PLLE programming
2014-05-29firewire: revert to 4 GB RDMA, fix protocols using Memory SpaceStefan Richter
Undo a feature introduced in v3.14 by commit fcd46b34425d "firewire: Enable remote DMA above 4 GB". That change raised the minimum address at which protocol drivers and user programs can register for request reception from 0x0001'0000'0000 to 0x8000'0000'0000. It turned out that at least one vendor-specific protocol exists which uses lower addresses: https://bugzilla.kernel.org/show_bug.cgi?id=76921 For the time being, revert most of commit fcd46b34425d so that affected protocols work like with kernel v3.13 and before. Just keep the valid documentation parts from the regressing commit, and the ability to identify controllers which could be programmed to accept >32 bit physical DMA addresses. The rest of fcd46b34425d should probably be brought back as an optional instead of default feature. Reported-by: Fabien Spindler <fabien.spindler@inria.fr> Cc: <stable@vger.kernel.org> # 3.14+ Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2014-05-29expand dentry_kill(dentry, 0) in shrink_dentry_list()Al Viro
Result will be massaged to saner shape in the next commits. It is ugly, no questions - the point of that one is to be a provably equivalent transformation (and it might be worth splitting a bit more). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-29split dentry_kill()Al Viro
... into trylocks and everything else. The latter (actual killing) is __dentry_kill(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-29arm64: mm: fix pmd_write CoW brokennessWill Deacon
Commit 9c7e535fcc17 ("arm64: mm: Route pmd thp functions through pte equivalents") changed the pmd manipulator and accessor functions to convert the target pmd to a pte, process it with the pte functions, then convert it back. Along the way, we gained support for PTE_WRITE, however this is completely ignored by set_pmd_at, and so we fail to set the PMD_SECT_RDONLY for PMDs, resulting in all sorts of lovely failures (like CoW not working). Partially reverting the offending commit (by making use of PMD_SECT_RDONLY explicitly for pmd_{write,wrprotect,mkwrite} functions) leads to further issues because pmd_write can then return potentially incorrect values for page table entries marked as RDONLY, leading to BUG_ON(pmd_write(entry)) tripping under some THP workloads. This patch fixes the issue by routing set_pmd_at through set_pte_at, which correctly takes the PTE_WRITE flag into account. Given that THP mappings are always anonymous, the additional cache-flushing code in __sync_icache_dcache won't impose any significant overhead as the flush will be skipped. Cc: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Steve Capper <steve.capper@arm.com> Tested-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-05-28Merge tag 'sound-3.15-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Just two small stable fixes: an HD-audio fix for the new Intel chipsets and a PM handling fix in PCM dmaengine core" * tag 'sound-3.15-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Fix onboard audio on Intel H97/Z97 chipsets ALSA: pcm_dmaengine: Add check during device suspend
2014-05-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fix from Al Viro: "Oh, well... Still nothing useful on that livelock (I had something that looked kinda-sorta like a non-invasive solution, but it deadlocks), so it's just Miklos' vmsplice fix for now" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: vfs: fix vmplice_to_user()
2014-05-28ARM: 8063/1: bL_switcher: fix individual online status reporting of removed CPUsNicolas Pitre
The content of /sys/devices/system/cpu/cpu*/online is still 1 for those CPUs that the switcher has removed even though the global state in /sys/devices/system/cpu/online is updated correctly. It turns out that commit 0902a9044f ("Driver core: Use generic offline/online for CPU offline/online") has changed the way those files retrieve their content by relying on on the generic attribute handling code. The switcher, by calling cpu_down() directly, bypasses this handling and the attribute value doesn't get updated. Fix this by calling device_offline()/device_online() instead. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-05-28rtmutex: Fix deadlock detector for realThomas Gleixner
The current deadlock detection logic does not work reliably due to the following early exit path: /* * Drop out, when the task has no waiters. Note, * top_waiter can be NULL, when we are in the deboosting * mode! */ if (top_waiter && (!task_has_pi_waiters(task) || top_waiter != task_top_pi_waiter(task))) goto out_unlock_pi; So this not only exits when the task has no waiters, it also exits unconditionally when the current waiter is not the top priority waiter of the task. So in a nested locking scenario, it might abort the lock chain walk and therefor miss a potential deadlock. Simple fix: Continue the chain walk, when deadlock detection is enabled. We also avoid the whole enqueue, if we detect the deadlock right away (A-A). It's an optimization, but also prevents that another waiter who comes in after the detection and before the task has undone the damage observes the situation and detects the deadlock and returns -EDEADLOCK, which is wrong as the other task is not in a deadlock situation. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/20140522031949.725272460@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-05-28Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm fixes from Paolo Bonzini: "Small fixes for x86, slightly larger fixes for PPC, and a forgotten s390 patch. The PPC fixes are important because they fix breakage that is new in 3.15" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: s390: announce irqfd capability KVM: x86: disable master clock if TSC is reset during suspend KVM: vmx: disable APIC virtualization in nested guests KVM guest: Make pv trampoline code executable KVM: PPC: Book3S: ifdef on CONFIG_KVM_BOOK3S_32_HANDLER for 32bit KVM: PPC: Book3S HV: Add missing code for transaction reclaim on guest exit KVM: PPC: Book3S: HV: make _PAGE_NUMA take effect
2014-05-28Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull two powerpc fixes from Ben Herrenschmidt: "Here's a pair of powerpc fixes for 3.15 which are also going to stable. One's a fix for building with newer binutils (the problem currently only affects the BookE kernels but the affected macro might come back into use on BookS platforms at any time). Unfortunately, the binutils maintainer did a backward incompatible change to a construct that we use so we have to add Makefile check. The other one is a fix for CPUs getting stuck in kexec when running single threaded. Since we routinely use kexec on power (including in our newer bootloaders), I deemed that important enough" * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc, kexec: Fix "Processor X is stuck" issue during kexec from ST mode powerpc: Fix 64 bit builds with binutils 2.24
2014-05-28lift the "already marked killed" case into shrink_dentry_list()Al Viro
It can happen only when dentry_kill() is called with unlock_on_failure equal to 0 - other callers had dentry pinned until the moment they've got ->d_lock and DCACHE_DENTRY_KILLED is set only after lockref_mark_dead(). IOW, only one of three call sites of dentry_kill() might end up reaching that code. Just move it there. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-28MIPS: R46000: Fix Micro-assembler field overflow for R4600 V2Thomas Bogendoerfer
Fix uasm warning, which triggered because of workaround for R4600 V2 CPUs. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/6716/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-28MIPS: ptrace: Avoid smp_processor_id() in preemptible codeAlex Smith
ptrace_{get,set}_watch_regs access current_cpu_data to get the watch register count/masks, which calls smp_processor_id(). However they are run in preemptible context and therefore trigger warnings like so: [ 6340.092000] BUG: using smp_processor_id() in preemptible [00000000] code: gdb/367 [ 6340.092000] caller is ptrace_get_watch_regs+0x44/0x220 Since the watch register count/masks should be the same across all CPUs, use boot_cpu_data instead. Note that this may need to change in future should a heterogenous system be supported where the count/masks are not the same across all CPUs (the current code is also incorrect for this scenario - current_cpu_data here would not necessarily be correct for the CPU that the target task will execute on). Signed-off-by: Alex Smith <alex.smith@imgtec.com> Reviewed-by: Paul Burton <paul.burton@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/6879/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-28MIPS: Lemote 2F: cs5536: mfgpt: use raw locksSebastian Andrzej Siewior
The lock is taken in the raw irq path and therefore a rawlock should be used instead of a normal spinlock. While here I drop the export symbol on that variable since there are no other users. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: linux-mips@linux-mips.org Cc: Hua Yan <yanh@lemote.com> Cc: Huacai Chen <chenhc@lemote.com> Cc: Alex Smith <alex.smith@imgtec.com> Cc: Hongliang Tao <taohl@lemote.com> Cc: Wu Zhangjin <wuzhangjin@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/6936/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-28MIPS: SB1: Fix excessive kernel warnings.Ralf Baechle
A kernel build with binutils 2.24 is going to emit warnings like CC kernel/sys.o {standard input}: Assembler messages: {standard input}:701: Warning: the 32-bit MIPS architecture does not support the `mdmx' extension {standard input}:701: Warning: the `mdmx' extension requires 64-bit FPRs {standard input}:701: Warning: the `mips3d' extension requires MIPS32 revision 2 or greater {standard input}:701: Warning: the `mips3d' extension requires 64-bit FPRs for almost every file. This is caused by changes to gas' interpretation of .set semantics. Fixed by explicitly disabling MIPS3D and MDMX for Sibyte builds. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-28vfs: fix vmplice_to_user()Miklos Szeredi
Commit 6130f5315ee8 "switch vmsplice_to_user() to copy_page_to_iter()" in v3.15-rc1 broke vmsplice(2). This patch fixes two bugs: - count is not initialized to a proper value, which resulted in no data being copied - if rw_copy_check_uvector() returns negative then the iov might be leaked. Tested OK. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-27Merge tag 'clk-tegra-fixes-3.15' of ↵Mike Turquette
git://nv-tegra.nvidia.com/user/pdeschrijver/linux into clk-fixes PLLE fixes for 3.15
2014-05-28powerpc, kexec: Fix "Processor X is stuck" issue during kexec from ST modeSrivatsa S. Bhat
If we try to perform a kexec when the machine is in ST (Single-Threaded) mode (ppc64_cpu --smt=off), the kexec operation doesn't succeed properly, and we get the following messages during boot: [ 0.089866] POWER8 performance monitor hardware support registered [ 0.089985] power8-pmu: PMAO restore workaround active. [ 5.095419] Processor 1 is stuck. [ 10.097933] Processor 2 is stuck. [ 15.100480] Processor 3 is stuck. [ 20.102982] Processor 4 is stuck. [ 25.105489] Processor 5 is stuck. [ 30.108005] Processor 6 is stuck. [ 35.110518] Processor 7 is stuck. [ 40.113369] Processor 9 is stuck. [ 45.115879] Processor 10 is stuck. [ 50.118389] Processor 11 is stuck. [ 55.120904] Processor 12 is stuck. [ 60.123425] Processor 13 is stuck. [ 65.125970] Processor 14 is stuck. [ 70.128495] Processor 15 is stuck. [ 75.131316] Processor 17 is stuck. Note that only the sibling threads are stuck, while the primary threads (0, 8, 16 etc) boot just fine. Looking closer at the previous step of kexec, we observe that kexec tries to wakeup (bring online) the sibling threads of all the cores, before performing kexec: [ 9464.131231] Starting new kernel [ 9464.148507] kexec: Waking offline cpu 1. [ 9464.148552] kexec: Waking offline cpu 2. [ 9464.148600] kexec: Waking offline cpu 3. [ 9464.148636] kexec: Waking offline cpu 4. [ 9464.148671] kexec: Waking offline cpu 5. [ 9464.148708] kexec: Waking offline cpu 6. [ 9464.148743] kexec: Waking offline cpu 7. [ 9464.148779] kexec: Waking offline cpu 9. [ 9464.148815] kexec: Waking offline cpu 10. [ 9464.148851] kexec: Waking offline cpu 11. [ 9464.148887] kexec: Waking offline cpu 12. [ 9464.148922] kexec: Waking offline cpu 13. [ 9464.148958] kexec: Waking offline cpu 14. [ 9464.148994] kexec: Waking offline cpu 15. [ 9464.149030] kexec: Waking offline cpu 17. Instrumenting this piece of code revealed that the cpu_up() operation actually fails with -EBUSY. Thus, only the primary threads of all the cores are online during kexec, and hence this is a sure-shot receipe for disaster, as explained in commit e8e5c2155b (powerpc/kexec: Fix orphaned offline CPUs across kexec), as well as in the comment above wake_offline_cpus(). It turns out that cpu_up() was returning -EBUSY because the variable 'cpu_hotplug_disabled' was set to 1; and this disabling of CPU hotplug was done by migrate_to_reboot_cpu() inside kernel_kexec(). Now, migrate_to_reboot_cpu() was originally written with the assumption that any further code will not need to perform CPU hotplug, since we are anyway in the reboot path. However, kexec is clearly not such a case, since we depend on onlining CPUs, atleast on powerpc. So re-enable cpu-hotplug after returning from migrate_to_reboot_cpu() in the kexec path, to fix this regression in kexec on powerpc. Also, wrap the cpu_up() in powerpc kexec code within a WARN_ON(), so that we can catch such issues more easily in the future. Fixes: c97102ba963 (kexec: migrate to reboot cpu) Cc: stable@vger.kernel.org Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-05-28powerpc: Fix 64 bit builds with binutils 2.24Guenter Roeck
With binutils 2.24, various 64 bit builds fail with relocation errors such as arch/powerpc/kernel/built-in.o: In function `exc_debug_crit_book3e': (.text+0x165ee): relocation truncated to fit: R_PPC64_ADDR16_HI against symbol `interrupt_base_book3e' defined in .text section in arch/powerpc/kernel/built-in.o arch/powerpc/kernel/built-in.o: In function `exc_debug_crit_book3e': (.text+0x16602): relocation truncated to fit: R_PPC64_ADDR16_HI against symbol `interrupt_end_book3e' defined in .text section in arch/powerpc/kernel/built-in.o The assembler maintainer says: I changed the ABI, something that had to be done but unfortunately happens to break the booke kernel code. When building up a 64-bit value with lis, ori, shl, oris, ori or similar sequences, you now should use @high and @higha in place of @h and @ha. @h and @ha (and their associated relocs R_PPC64_ADDR16_HI and R_PPC64_ADDR16_HA) now report overflow if the value is out of 32-bit signed range. ie. @h and @ha assume you're building a 32-bit value. This is needed to report out-of-range -mcmodel=medium toc pointer offsets in @toc@h and @toc@ha expressions, and for consistency I did the same for all other @h and @ha relocs. Replacing @h with @high in one strategic location fixes the relocation errors. This has to be done conditionally since the assembler either supports @h or @high but not both. Cc: <stable@vger.kernel.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-05-28Merge tag 'drm-intel-fixes-2014-05-27' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-fixes Fixes from Chris, all cc: stable. * tag 'drm-intel-fixes-2014-05-27' of git://anongit.freedesktop.org/drm-intel: drm/i915: Prevent negative relocation deltas from wrapping drm/i915: Only copy back the modified fields to userspace from execbuffer drm/i915: Fix dynamic allocation of physical handles
2014-05-27Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull virtio_blk fix from Jens Axboe: "There's a start/stop queue race in virtio_blk, which causes stalls and erratic behaviour for some. I've had this queued up for 3.16 for a while, but I think we should push it into the current series as well. So I cherry picked the commit and added a stable marker as well, so it can propagate down" * 'for-linus' of git://git.kernel.dk/linux-block: virtio_blk: fix race between start and stop queue
2014-05-27Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull two timer fixes from Thomas Gleixner: "Two small fixlets for ARM SoC clocksource drivers: - avoid calling functions which might sleep from interrupt [disabled] context in tcb_clksrc used on Atmel SoCs - use irq_force_affinity() to pin the per cpu timer interrupt on a not yet online cpu in the SiRFprimaII driver" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: clocksource: tcb_clksrc: Make tc_mode interrupt safe clocksource: marco: Fix the affinity set for local timer of CPU1
2014-05-27Merge tag 'fixes-for-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A slightly larger set of fixes than we'd like at this point in the release. Hopefully our very last batch before 3.15: OMAP: - Fix boot regression with CPU_IDLE enabled - Fixes for audio playback on OMAP5 - Clock rate setting fix for OMAP3 - Misc idle/PM fixes Exynos: - Removal of a couple of power domains to work around issues with access when they are powered down - Enabling missing highspeed-i2c driver to make MMC regulators work - Secondary CPU spin-up fix for 4212 - Remove MDMA1 engine to avoid conflicts on secure mode platforms - A few other DT fixes Marvell: - PCI-e fixes for clocks and resource allocation plus a few other smaller fixes, add a MAINTAINERS entry for reset drivers, etc" * tag 'fixes-for-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (21 commits) MAINTAINERS: Add reset controller framework entry ARM: trusted_foundations: fix compile error on non-SMP ARM: at91: sam9260: fix compilation issues ARM: mvebu: fix definitions of PCIe interfaces on Armada 38x ARM: imx: fix error handling in ipu device registration ARM: OMAP4: Fix the boot regression with CPU_IDLE enabled ARM: dts: Keep LDO4 always ON for exynos5250-arndale board ARM: dts: Fix SPI interrupt numbers for exynos5420 ARM: dts: fix incorrect ak8975 compatible for exynos4412-trats2 board ARM: OMAP2+: Fix DMA hang after off-idle ARM: OMAP2+: nand: Fix NAND on OMAP2 and OMAP3 boards ARM: dts: Remove g2d_pd node for exynos5420 ARM: dts: Remove mau_pd node for exynos5420 ARM: exynos_defconfig: enable HS-I2C to fix for mmc partition mount ARM: dts: disable MDMA1 node for exynos5420 ARM: EXYNOS: fix the secondary CPU boot of exynos4212 ARM: omap5: hwmod_data: Correct IDLEMODE for McPDM ARM: mvebu: mvebu-soc-id: keep clock enabled if PCIe unit is enabled ARM: mvebu: mvebu-soc-id: add missing clk_put() call ARM: at91/dt: sam9260: correct external trigger value ...
2014-05-27Merge tag 'pinctrl-v3.15-4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pinctrl fix from Linus Walleij: "A single last pinctrl fix for the v3.15 series: the vt8500 driver was failing to update the output value when the combined set direction output and set value was executed" * tag 'pinctrl-v3.15-4' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: pinctrl: vt8500: Ensure value reg is updated when setting direction
