commit eed4d839b0cdf9d84b0a9bc63de90fd5e1e886fb upstream.
Use dst_entry held by sk_dst_get() to retrieve tunnel's PMTU.
The dst_mtu(__sk_dst_get(tunnel->sock)) call was racy. __sk_dst_get()
could return NULL if tunnel->sock->sk_dst_cache was reset just before the
call, thus making dst_mtu() dereference a NULL pointer:
[ 1937.661598] BUG: unable to handle kernel NULL pointer dereference at 0000000000000020
[ 1937.664005] IP: [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp]
[ 1937.664005] PGD daf0c067 PUD d9f93067 PMD 0
[ 1937.664005] Oops: 0000 [#1] SMP
[ 1937.664005] Modules linked in: l2tp_ppp l2tp_netlink l2tp_core ip6table_filter ip6_tables iptable_filter ip_tables ebtable_nat ebtables x_tables udp_tunnel pppoe pppox ppp_generic slhc deflate ctr twofish_generic twofish_x86_64_3way xts lrw gf128mul glue_helper twofish_x86_64 twofish_common blowfish_generic blowfish_x86_64 blowfish_common des_generic cbc xcbc rmd160 sha512_generic hmac crypto_null af_key xfrm_algo 8021q garp bridge stp llc tun atmtcp clip atm ext3 mbcache jbd iTCO_wdt coretemp kvm_intel iTCO_vendor_support kvm pcspkr evdev ehci_pci lpc_ich mfd_core i5400_edac edac_core i5k_amb shpchp button processor thermal_sys xfs crc32c_generic libcrc32c dm_mod usbhid sg hid sr_mod sd_mod cdrom crc_t10dif crct10dif_common ata_generic ahci ata_piix tg3 libahci libata uhci_hcd ptp ehci_hcd pps_core usbcore scsi_mod libphy usb_common [last unloaded: l2tp_core]
[ 1937.664005] CPU: 0 PID: 10022 Comm: l2tpstress Tainted: G O 3.17.0-rc1 #1
[ 1937.664005] Hardware name: HP ProLiant DL160 G5, BIOS O12 08/22/2008
[ 1937.664005] task: ffff8800d8fda790 ti: ffff8800c43c4000 task.ti: ffff8800c43c4000
[ 1937.664005] RIP: 0010:[<ffffffffa049db88>] [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp]
[ 1937.664005] RSP: 0018:ffff8800c43c7de8 EFLAGS: 00010282
[ 1937.664005] RAX: ffff8800da8a7240 RBX: ffff8800d8c64600 RCX: 000001c325a137b5
[ 1937.664005] RDX: 8c6318c6318c6320 RSI: 000000000000010c RDI: 0000000000000000
[ 1937.664005] RBP: ffff8800c43c7ea8 R08: 0000000000000000 R09: 0000000000000000
[ 1937.664005] R10: ffffffffa048e2c0 R11: ffff8800d8c64600 R12: ffff8800ca7a5000
[ 1937.664005] R13: ffff8800c439bf40 R14: 000000000000000c R15: 0000000000000009
[ 1937.664005] FS: 00007fd7f610f700(0000) GS:ffff88011a600000(0000) knlGS:0000000000000000
[ 1937.664005] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 1937.664005] CR2: 0000000000000020 CR3: 00000000d9d75000 CR4: 00000000000027e0
[ 1937.664005] Stack:
[ 1937.664005] ffffffffa049da80 ffff8800d8fda790 000000000000005b ffff880000000009
[ 1937.664005] ffff8800daf3f200 0000000000000003 ffff8800c43c7e48 ffffffff81109b57
[ 1937.664005] ffffffff81109b0e ffffffff8114c566 0000000000000000 0000000000000000
[ 1937.664005] Call Trace:
[ 1937.664005] [<ffffffffa049da80>] ? pppol2tp_connect+0x235/0x41e [l2tp_ppp]
[ 1937.664005] [<ffffffff81109b57>] ? might_fault+0x9e/0xa5
[ 1937.664005] [<ffffffff81109b0e>] ? might_fault+0x55/0xa5
[ 1937.664005] [<ffffffff8114c566>] ? rcu_read_unlock+0x1c/0x26
[ 1937.664005] [<ffffffff81309196>] SYSC_connect+0x87/0xb1
[ 1937.664005] [<ffffffff813e56f7>] ? sysret_check+0x1b/0x56
[ 1937.664005] [<ffffffff8107590d>] ? trace_hardirqs_on_caller+0x145/0x1a1
[ 1937.664005] [<ffffffff81213dee>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[ 1937.664005] [<ffffffff8114c262>] ? spin_lock+0x9/0xb
[ 1937.664005] [<ffffffff813092b4>] SyS_connect+0x9/0xb
[ 1937.664005] [<ffffffff813e56d2>] system_call_fastpath+0x16/0x1b
[ 1937.664005] Code: 10 2a 84 81 e8 65 76 bd e0 65 ff 0c 25 10 bb 00 00 4d 85 ed 74 37 48 8b 85 60 ff ff ff 48 8b 80 88 01 00 00 48 8b b8 10 02 00 00 <48> 8b 47 20 ff 50 20 85 c0 74 0f 83 e8 28 89 83 10 01 00 00 89
[ 1937.664005] RIP [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp]
[ 1937.664005] RSP <ffff8800c43c7de8>
[ 1939.559375] ---[ end trace 82d44500f28f8708 ]---
Fixes: f34c4a35d879 ("l2tp: take PMTU from tunnel UDP socket")
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
commit 7e46dddd6f6cd5dbf3c7bd04a7e75d19475ac9f2 upstream.
Commit d1442d85cc30 ("KVM: x86: Handle errors when RIP is set during far
jumps") introduced a bug that caused the fix to be incomplete. Due to
incorrect evaluation, far jump to segment with L bit cleared (i.e., 32-bit
segment) and RIP with any of the high bits set (i.e, RIP[63:32] != 0) set may
not trigger #GP. As we know, this imposes a security problem.
In addition, the condition for two warnings was incorrect.
Fixes: d1442d85cc30ea75f7d399474ca738e0bc96f715
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Nadav Amit <namit@cs.technion.ac.il>
[Add #ifdef CONFIG_X86_64 to avoid complaints of undefined behavior. - Paolo]
commit 46f341ffcfb5d8530f7d1e60f3be06cce6661b62 upstream.
Commit 2da78092 changed the locking from a mutex to a spinlock,
so we now longer sleep in this context. But there was a leftover
might_sleep() in there, which now triggers since we do the final
free from an RCU callback. Get rid of it.
Reported-by: Pontus Fuchs <pontus.fuchs@gmail.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit 24607f114fd14f2f37e3e0cb3d47bce96e81e848 upstream.
Commit 651e22f2701b "ring-buffer: Always reset iterator to reader page"
fixed one bug but in the process caused another one. The reset is to
update the header page, but that fix also changed the way the cached
reads were updated. The cache reads are used to test if an iterator
needs to be updated or not.
A ring buffer iterator, when created, disables writes to the ring buffer
but does not stop other readers or consuming reads from happening.
Although all readers are synchronized via a lock, they are only
synchronized when in the ring buffer functions. Those functions may
be called by any number of readers. The iterator continues down when
its not interrupted by a consuming reader. If a consuming read
occurs, the iterator starts from the beginning of the buffer.
The way the iterator sees that a consuming read has happened since
its last read is by checking the reader "cache". The cache holds the
last counts of the read and the reader page itself.
Commit 651e22f2701b changed what was saved by the cache_read when
the rb_iter_reset() occurred, making the iterator never match the cache.
Then if the iterator calls rb_iter_reset(), it will go into an
infinite loop by checking if the cache doesn't match, doing the reset
and retrying, just to see that the cache still doesn't match! Which
should never happen as the reset is suppose to set the cache to the
current value and there's locks that keep a consuming reader from
having access to the data.
Fixes: 651e22f2701b "ring-buffer: Always reset iterator to reader page"
commit 2627b7e15c5064ddd5e578e4efd948d48d531a3f upstream.
commit 8f4e0a18682d91 ("IPVS netns exit causes crash in conntrack")
added second ip_vs_conn_drop_conntrack call instead of just adding
the needed check. As result, the first call still can cause
crash on netns exit. Remove it.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Hans Schillstrom <hans@schillstrom.com>
Signed-off-by: Simon Horman <horms@verge.net.au>
BugLink: http://bugs.launchpad.net/bugs/1348670
Fix regression introduced in pre-3.14 kernels by cherry-picking
aa07c713ecfc0522916f3cd57ac628ea6127c0ec
(NFSD: Call ->set_acl with a NULL ACL structure if no entries).
The affected code was removed in 3.14 by commit
4ac7249ea5a0ceef9f8269f63f33cc873c3fac61
(nfsd: use get_acl and ->set_acl).
The ->set_acl methods are already able to cope with a NULL argument.
Signed-off-by: Sergio Gelato <Sergio.Gelato@astro.su.se>
[bwh: Rewrite the subject]
commit 7ba3ec5749ddb61f79f7be17b5fd7720eebc52de upstream.
Commit 8e3dffc651cb "Ext2: mark inode dirty after the function
dquot_free_block_nodirty is called" unveiled a bug in __ext2_get_block()
called from ext2_get_xip_mem(). That function called ext2_get_block()
mistakenly asking it to map 0 blocks while 1 was intended. Before the
above mentioned commit things worked out fine by luck but after that commit
we started returning that we allocated 0 blocks while we in fact
allocated 1 block and thus allocation was looping until all blocks in
the filesystem were exhausted.
Fix the problem by properly asking for one block and also add assertion
in ext2_get_blocks() to catch similar problems.
Reported-and-tested-by: Andiry Xu <andiry.xu@gmail.com>
commit d49ec52ff6ddcda178fc2476a109cf1bd1fa19ed upstream.
The DM crypt target accesses memory beyond allocated space resulting in
a crash on 32 bit x86 systems.
This bug is very old (it dates back to 2.6.25 commit 3a7f6c990ad04 "dm
crypt: use async crypto"). However, this bug was masked by the fact
that kmalloc rounds the size up to the next power of two. This bug
wasn't exposed until 3.17-rc1 commit 298a9fa08a ("dm crypt: use per-bio
data"). By switching to using per-bio data there was no longer any
padding beyond the end of a dm-crypt allocated memory block.
To minimize allocation overhead dm-crypt puts several structures into one
block allocated with kmalloc. The block holds struct ablkcipher_request,
cipher-specific scratch pad (crypto_ablkcipher_reqsize(any_tfm(cc))),
struct dm_crypt_request and an initialization vector.
The variable dmreq_start is set to offset of struct dm_crypt_request
within this memory block. dm-crypt allocates the block with this size:
cc->dmreq_start + sizeof(struct dm_crypt_request) + cc->iv_size.
When accessing the initialization vector, dm-crypt uses the function
iv_of_dmreq, which performs this calculation: ALIGN((unsigned long)(dmreq
+ 1), crypto_ablkcipher_alignmask(any_tfm(cc)) + 1).
dm-crypt allocated "cc->iv_size" bytes beyond the end of dm_crypt_request
structure. However, when dm-crypt accesses the initialization vector, it
takes a pointer to the end of dm_crypt_request, aligns it, and then uses
it as the initialization vector. If the end of dm_crypt_request is not
aligned on a crypto_ablkcipher_alignmask(any_tfm(cc)) boundary the
alignment causes the initialization vector to point beyond the allocated
space.
Fix this bug by calculating the variable iv_size_padding and adding it
to the allocated size.
Also correct the alignment of dm_crypt_request. struct dm_crypt_request
is specific to dm-crypt (it isn't used by the crypto subsystem at all),
so it is aligned on __alignof__(struct dm_crypt_request).
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
commit d974baa398f34393db76be45f7d4d04fbdbb4a0a upstream.
CR4 isn't constant; at least the TSD and PCE bits can vary.
TBH, treating CR0 and CR3 as constant scares me a bit, too, but it looks
like it's correct.
This adds a branch and a read from cr4 to each vm entry. Because it is
extremely likely that consecutive entries into the same vcpu will have
the same host cr4 value, this fixes up the vmcs instead of restoring cr4
after the fact. A subsequent patch will add a kernel-wide cr4 shadow,
reducing the overhead in the common case to just two memory reads and a
branch.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
Cc: stable@vger.kernel.org
Cc: Petr Matousek <pmatouse@redhat.com>
Cc: Gleb Natapov <gleb@kernel.org>
[bwh: Backported to 3.2:
- Adjust context
- Add struct vcpu_vmx *vmx parameter to vmx_set_constant_host_state(), done
upstream in commit a547c6db4d2f ("KVM: VMX: Enable acknowledge interupt
on vmexit")]
commit 26b87c7881006311828bb0ab271a551a62dcceb4 upstream.
This scenario is not limited to ASCONF, just taken as one
example triggering the issue. When receiving ASCONF probes
in the form of ...
-------------- INIT[ASCONF; ASCONF_ACK] ------------->
<----------- INIT-ACK[ASCONF; ASCONF_ACK] ------------
-------------------- COOKIE-ECHO -------------------->
<-------------------- COOKIE-ACK ---------------------
---- ASCONF_a; [ASCONF_b; ...; ASCONF_n;] JUNK ------>
---- ASCONF_m; [ASCONF_o; ...; ASCONF_z;] JUNK ------>
... where ASCONF_a, ASCONF_b, ..., ASCONF_z are good-formed
ASCONFs and have increasing serial numbers, we process such
ASCONF chunk(s) marked with !end_of_packet and !singleton,
since we have not yet reached the SCTP packet end. SCTP does
only do verification on a chunk by chunk basis, as an SCTP
packet is nothing more than just a container of a stream of
chunks which it eats up one by one.
We could run into the case that we receive a packet with a
malformed tail, above marked as trailing JUNK. All previous
chunks are here goodformed, so the stack will eat up all
previous chunks up to this point. In case JUNK does not fit
into a chunk header and there are no more other chunks in
the input queue, or in case JUNK contains a garbage chunk
header, but the encoded chunk length would exceed the skb
tail, or we came here from an entirely different scenario
and the chunk has pdiscard=1 mark (without having had a flush
point), it will happen, that we will excessively queue up
the association's output queue (a correct final chunk may
then turn it into a response flood when flushing the
queue ;)): I ran a simple script with incremental ASCONF
serial numbers and could see the server side consuming
excessive amount of RAM [before/after: up to 2GB and more].
The issue at heart is that the chunk train basically ends
with !end_of_packet and !singleton markers and since commit
2e3216cd54b1 ("sctp: Follow security requirement of responding
with 1 packet") therefore preventing an output queue flush
point in sctp_do_sm() -> sctp_cmd_interpreter() on the input
chunk (chunk = event_arg) even though local_cork is set,
but its precedence has changed since then. In the normal
case, the last chunk with end_of_packet=1 would trigger the
queue flush to accommodate possible outgoing bundling.
In the input queue, sctp_inq_pop() seems to do the right thing
in terms of discarding invalid chunks. So, above JUNK will
not enter the state machine and instead be released and exit
the sctp_assoc_bh_rcv() chunk processing loop. It's simply
the flush point being missing at loop exit. Adding a try-flush
approach on the output queue might not work as the underlying
infrastructure might be long gone at this point due to the
side-effect interpreter run.
One possibility, albeit a bit of a kludge, would be to defer
invalid chunk freeing into the state machine in order to
possibly trigger packet discards and thus indirectly a queue
flush on error. It would surely be better to discard chunks
as in the current, perhaps better controlled environment, but
going back and forth, it's simply architecturally not possible.
I tried various trailing JUNK attack cases and it seems to
look good now.
Joint work with Vlad Yasevich.
Fixes: 2e3216cd54b1 ("sctp: Follow security requirement of responding with 1 packet")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Vlad Yasevich <vyasevich@gmail.com>
commit b69040d8e39f20d5215a03502a8e8b4c6ab78395 upstream.
When receiving a e.g. semi-good formed connection scan in the
form of ...
---------------- ASCONF_a; ASCONF_b ----------------->
... where ASCONF_a equals ASCONF_b chunk (at least both serials
need to be equal), we panic an SCTP server!
The problem is that good-formed ASCONF chunks that we reply with
ASCONF_ACK chunks are cached per serial. Thus, when we receive a
same ASCONF chunk twice (e.g. through a lost ASCONF_ACK), we do
not need to process them again on the server side (that was the
idea, also proposed in the RFC). Instead, we know it was cached
and we just resend the cached chunk instead. So far, so good.
Where things get nasty is in SCTP's side effect interpreter, that
is, sctp_cmd_interpreter():
While incoming ASCONF_a (chunk = event_arg) is being marked
!end_of_packet and !singleton, and we have an association context,
we do not flush the outqueue the first time after processing the
ASCONF_ACK singleton chunk via SCTP_CMD_REPLY. Instead, we keep it
queued up, although we set local_cork to 1. Commit 2e3216cd54b1
changed the precedence, so that as long as we get bundled, incoming
chunks we try possible bundling on outgoing queue as well. Before
this commit, we would just flush the output queue.
Now, while ASCONF_a's ASCONF_ACK sits in the corked outq, we
continue to process the same ASCONF_b chunk from the packet. As
we have cached the previous ASCONF_ACK, we find it, grab it and
do another SCTP_CMD_REPLY command on it. So, effectively, we rip
the chunk->list pointers and requeue the same ASCONF_ACK chunk
another time. Since we process ASCONF_b, it's correctly marked
with end_of_packet and we enforce an uncork, and thus flush, thus
crashing the kernel.
Fix it by testing if the ASCONF_ACK is currently pending and if
that is the case, do not requeue it. When flushing the output
queue we may relink the chunk for preparing an outgoing packet,
but eventually unlink it when it's copied into the skb right
before transmission.
commit 9de7922bc709eee2f609cd01d98aaedc4cf5ea74 upstream.
Commit 6f4c618ddb0 ("SCTP : Add paramters validity check for
ASCONF chunk") added basic verification of ASCONF chunks, however,
it is still possible to remotely crash a server by sending a
special crafted ASCONF chunk, even up to pre 2.6.12 kernels:
skb_over_panic: text:ffffffffa01ea1c3 len:31056 put:30768
head:ffff88011bd81800 data:ffff88011bd81800 tail:0x7950
end:0x440 dev:<NULL>
kernel BUG at net/core/skbuff.c:129!
Call Trace:
<IRQ>
[<ffffffff8144fb1c>] skb_put+0x5c/0x70
[<ffffffffa01ea1c3>] sctp_addto_chunk+0x63/0xd0 [sctp]
[<ffffffffa01eadaf>] sctp_process_asconf+0x1af/0x540 [sctp]
[<ffffffff8152d025>] ? _read_unlock_bh+0x15/0x20
[<ffffffffa01e0038>] sctp_sf_do_asconf+0x168/0x240 [sctp]
[<ffffffffa01e3751>] sctp_do_sm+0x71/0x1210 [sctp]
[<ffffffff8147645d>] ? fib_rules_lookup+0xad/0xf0
[<ffffffffa01e6b22>] ? sctp_cmp_addr_exact+0x32/0x40 [sctp]
[<ffffffffa01e8393>] sctp_assoc_bh_rcv+0xd3/0x180 [sctp]
[<ffffffffa01ee986>] sctp_inq_push+0x56/0x80 [sctp]
[<ffffffffa01fcc42>] sctp_rcv+0x982/0xa10 [sctp]
[<ffffffffa01d5123>] ? ipt_local_in_hook+0x23/0x28 [iptable_filter]
[<ffffffff8148bdc9>] ? nf_iterate+0x69/0xb0
[<ffffffff81496d10>] ? ip_local_deliver_finish+0x0/0x2d0
[<ffffffff8148bf86>] ? nf_hook_slow+0x76/0x120
[<ffffffff81496ded>] ip_local_deliver_finish+0xdd/0x2d0
[<ffffffff81497078>] ip_local_deliver+0x98/0xa0
[<ffffffff8149653d>] ip_rcv_finish+0x12d/0x440
[<ffffffff81496ac5>] ip_rcv+0x275/0x350
[<ffffffff8145c88b>] __netif_receive_skb+0x4ab/0x750
[<ffffffff81460588>] netif_receive_skb+0x58/0x60
This can be triggered e.g., through a simple scripted nmap
connection scan injecting the chunk after the handshake, for
example, ...
------------------ ASCONF; UNKNOWN ------------------>
... where ASCONF chunk of length 280 contains 2 parameters ...
1) Add IP address parameter (param length: 16)
2) Add/del IP address parameter (param length: 255)
... followed by an UNKNOWN chunk of e.g. 4 bytes. Here, the
Address Parameter in the ASCONF chunk is even missing, too.
This is just an example and similarly-crafted ASCONF chunks
could be used just as well.
The ASCONF chunk passes through sctp_verify_asconf() as all
parameters passed sanity checks, and after walking, we ended
up successfully at the chunk end boundary, and thus may invoke
sctp_process_asconf(). Parameter walking is done with
WORD_ROUND() to take padding into account.
In sctp_process_asconf()'s TLV processing, we may fail in
sctp_process_asconf_param() e.g., due to removal of the IP
address that is also the source address of the packet containing
the ASCONF chunk, and thus we need to add all TLVs after the
failure to our ASCONF response to remote via helper function
sctp_add_asconf_response(), which basically invokes a
sctp_addto_chunk() adding the error parameters to the given
skb.
When walking to the next parameter this time, we proceed
with ...
length = ntohs(asconf_param->param_hdr.length);
asconf_param = (void *)asconf_param + length;
... instead of the WORD_ROUND()'ed length, thus resulting here
in an off-by-one that leads to reading the follow-up garbage
parameter length of 12336, and thus throwing an skb_over_panic
for the reply when trying to sctp_addto_chunk() next time,
which implicitly calls the skb_put() with that length.
Fix it by using sctp_walk_params() [ which is also used in
INIT parameter processing ] macro in the verification *and*
in ASCONF processing: it will make sure we don't spill over,
that we walk parameters WORD_ROUND()'ed. Moreover, we're being
more defensive and guard against unknown parameter types and
missized addresses.
Fixes: b896b82be4ae ("[SCTP] ADDIP: Support for processing incoming ASCONF_ACK chunks.")
- Adjust context
- sctp_sf_violation_paramlen() doesn't take a struct net * parameter]
commit d1442d85cc30ea75f7d399474ca738e0bc96f715 upstream.
Far jmp/call/ret may fault while loading a new RIP. Currently KVM does not
handle this case, and may result in failed vm-entry once the assignment is
done. The tricky part of doing so is that loading the new CS affects the
VMCS/VMCB state, so if we fail during loading the new RIP, we are left in
unconsistent state. Therefore, this patch saves on 64-bit the old CS
descriptor and restores it if loading RIP failed.
This fixes CVE-2014-3647.
- Adjust context
- __load_segment_descriptor() does not take an in_task_switch parameter]
commit 2356aaeb2f58f491679dc0c38bc3f6dbe54e7ded upstream.
During task switch, all of CS.DPL, CS.RPL, SS.DPL must match (in addition
to all the other requirements) and will be the new CPL. So far this
worked by carefully setting the CS selector and flag before doing the
task switch; setting CS.selector will already change the CPL.
However, this will not work once we get the CPL from SS.DPL, because
then you will have to set the full segment descriptor cache to change
the CPL. ctxt->ops->cpl(ctxt) will then return the old CPL during the
task switch, and the check that SS.DPL == CPL will fail.
Temporarily assume that the CPL comes from CS.RPL during task switch
to a protected-mode task. This is the same approach used in QEMU's
emulation code, which (until version 2.0) manually tracks the CPL.
- Adjust context
- load_state_from_tss32() does not support VM86 mode]
commit 234f3ce485d54017f15cf5e0699cff4100121601 upstream.
Before changing rip (during jmp, call, ret, etc.) the target should be asserted
to be canonical one, as real CPUs do. During sysret, both target rsp and rip
should be canonical. If any of these values is noncanonical, a #GP exception
should occur. The exception to this rule are syscall and sysenter instructions
in which the assigned rip is checked during the assignment to the relevant
MSRs.
This patch fixes the emulator to behave as real CPUs do for near branches.
Far branches are handled by the next patch.
- Adjust context
- Use ctxt->regs[] instead of reg_read(), reg_write(), reg_rmw()]
commit 05c83ec9b73c8124555b706f6af777b10adf0862 upstream.
Relative jumps and calls do the masking according to the operand size, and not
according to the address size as the KVM emulator does today.
This patch fixes KVM behavior.
commit d4ddafcdf2201326ec9717172767cfad0ede1472 upstream.
CALL: E8
Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
[bwh: Backported to 3.2: adjust context]
commit a642fc305053cc1c6e47e4f4df327895747ab485 upstream.
On systems with invvpid instruction support (corresponding bit in
IA32_VMX_EPT_VPID_CAP MSR is set) guest invocation of invvpid
causes vm exit, which is currently not handled and results in
propagation of unknown exit to userspace.
Fix this by installing an invvpid vm exit handler.
This is CVE-2014-3646.
Signed-off-by: Petr Matousek <pmatouse@redhat.com>
- Adjust filename
- Drop inapplicable change to exit reason string array]
commit bfd0a56b90005f8c8a004baf407ad90045c2b11e upstream.
If we let L1 use EPT, we should probably also support the INVEPT instruction.
In our current nested EPT implementation, when L1 changes its EPT table
for L2 (i.e., EPT12), L0 modifies the shadow EPT table (EPT02), and in
the course of this modification already calls INVEPT. But if last level
of shadow page is unsync not all L1's changes to EPT12 are intercepted,
which means roots need to be synced when L1 calls INVEPT. Global INVEPT
should not be different since roots are synced by kvm_mmu_load() each
time EPTP02 changes.
Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Signed-off-by: Nadav Har'El <nyh@il.ibm.com>
Signed-off-by: Jun Nakajima <jun.nakajima@intel.com>
Signed-off-by: Xinhao Xu <xinhao.xu@intel.com>
Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
- Adjust context, filename
- Simplify handle_invept() as recommended by Paolo - nEPT is not
supported so we always raise #UD]
commit 2febc839133280d5a5e8e1179c94ea674489dae2 upstream.
There's a race condition in the PIT emulation code in KVM. In
__kvm_migrate_pit_timer the pit_timer object is accessed without
synchronization. If the race condition occurs at the wrong time this
can crash the host kernel.
This fixes CVE-2014-3611.
Signed-off-by: Andrew Honig <ahonig@google.com>
commit 854e8bb1aa06c578c2c9145fa6bfe3680ef63b23 upstream.
Upon WRMSR, the CPU should inject #GP if a non-canonical value (address) is
written to certain MSRs. The behavior is "almost" identical for AMD and Intel
(ignoring MSRs that are not implemented in either architecture since they would
anyhow #GP). However, IA32_SYSENTER_ESP and IA32_SYSENTER_EIP cause #GP if
non-canonical address is written on Intel but not on AMD (which ignores the top
32-bits).
Accordingly, this patch injects a #GP on the MSRs which behave identically on
Intel and AMD. To eliminate the differences between the architecutres, the
value which is written to IA32_SYSENTER_ESP and IA32_SYSENTER_EIP is turned to
canonical value before writing instead of injecting a #GP.
Some references from Intel and AMD manuals:
According to Intel SDM description of WRMSR instruction #GP is expected on
WRMSR "If the source register contains a non-canonical address and ECX
specifies one of the following MSRs: IA32_DS_AREA, IA32_FS_BASE, IA32_GS_BASE,
IA32_KERNEL_GS_BASE, IA32_LSTAR, IA32_SYSENTER_EIP, IA32_SYSENTER_ESP."
According to AMD manual instruction manual:
LSTAR/CSTAR (SYSCALL): "The WRMSR instruction loads the target RIP into the
LSTAR and CSTAR registers. If an RIP written by WRMSR is not in canonical
form, a general-protection exception (#GP) occurs."
IA32_GS_BASE and IA32_FS_BASE (WRFSBASE/WRGSBASE): "The address written to the
base field must be in canonical form or a #GP fault will occur."
IA32_KERNEL_GS_BASE (SWAPGS): "The address stored in the KernelGSbase MSR must
be in canonical form."
This patch fixes CVE-2014-3610.
- The various set_msr() functions all separate msr_index and data parameters]
commit 916e4cf46d0204806c062c8c6c4d1f633852c5b6 upstream.
Currently we generate a new fragmentation id on UFO segmentation. It
is pretty hairy to identify the correct net namespace and dst there.
Especially tunnels use IFF_XMIT_DST_RELEASE and thus have no skb_dst
available at all.
This causes unreliable or very predictable ipv6 fragmentation id
generation while segmentation.
Luckily we already have pregenerated the ip6_frag_id in
ip6_ufo_append_data and can use it here.
[bwh: Backported to 3.2: adjust filename, indentation]
commit c99d1e6e83b06744c75d9f5e491ed495a7086b7b upstream.
If we suffer a block allocation failure (for example due to a memory
allocation failure), it's possible that we will call
ext4_discard_allocated_blocks() before we've actually allocated any
blocks. In that case, fe_len and fe_start in ac->ac_f_ex will still
be zero, and this will result in mb_free_blocks(inode, e4b, 0, 0)
triggering the BUG_ON on mb_free_blocks():
BUG_ON(last >= (sb->s_blocksize << 3));
Fix this by bailing out of ext4_discard_allocated_blocks() if fs_len
is zero.
Also fix a missing ext4_mb_unload_buddy() call in
ext4_discard_allocated_blocks().
Google-Bug-Id: 16844242
Fixes: 86f0afd463215fc3e58020493482faa4ac3a4d69
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
It fix the bug 67951 on bugzilla
https://bugzilla.kernel.org/show_bug.cgi?id=67951
The patch can't be applied directly, as it' used the function introduced
by "commit 94e187c0" ip6_rt_put(), that patch can't be applied directly
either.
commit 33d99113b1102c2d2f8603b9ba72d89d915c13f5 upstream.
This commit don't have a stable tag, but it fix the bug
no reply after loopback down-up.It's very worthy to be
applied to stable 3.4 kernels.
The bug is 67951 on bugzilla
CC: Sabrina Dubroca <sd@queasysnail.net>
CC: Hannes Frederic Sowa <hannes@stressinduktion.org>
Reported-by: Weilong Chen <chenweilong@huawei.com>
Signed-off-by: Weilong Chen <chenweilong@huawei.com>
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[weilong: s/ip6_rt_put/dst_release]
Signed-off-by: Chen Weilong <chenweilong@huawei.com>
Further tests revealed that after moving the garbage collector to a work
queue and protecting it with a spinlock may leave the system prone to
soft lockups if bottom half gets very busy.
It was reproced with a set of firewall rules that REJECTed packets. If
the NIC bottom half handler ends up running on the same CPU that is
running the garbage collector on a very large cache, the garbage
collector will not be able to do its job due to the amount of work
needed for handling the REJECTs and also won't reschedule.
The fix is to disable bottom half during the garbage collecting, as it
already was in the first place (most calls to it came from softirqs).
Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
When rt_intern_hash() has to deal with neighbour cache overflowing,
it triggers the route cache garbage collector in an attempt to free
some references on neighbour entries.
Such call cannot be done async but should also not run in parallel with
an already-running one, so that they don't collapse fighting over the
hash lock entries.
This patch thus blocks parallel executions with spinlocks:
- A call from worker and from rt_intern_hash() are not the same, and
cannot be merged, thus they will wait each other on rt_gc_lock.
- Calls to gc from rt_intern_hash() may happen in parallel but we must
wait for it to finish in order to try again. This dedup and
synchrinozation is then performed by the locking just before calling
__do_rt_garbage_collect().
Currently the route garbage collector gets called by dst_alloc() if it
have more entries than the threshold. But it's an expensive call, that
don't really need to be done by then.
Another issue with current way is that it allows running the garbage
collector with the same start parameters on multiple CPUs at once, which
is not optimal. A system may even soft lockup if the cache is big enough
as the garbage collectors will be fighting over the hash lock entries.
This patch thus moves the garbage collector to run asynchronously on a
work queue, much similar to how rt_expire_check runs.
There is one condition left that allows multiple executions, which is
commit 5596b0b245fb9d2cefb5023b11061050351c1398 upstream.
[ 1.904000] BUG: scheduling while atomic: swapper/1/0x00000002
[ 1.908000] Modules linked in:
[ 1.916000] CPU: 0 PID: 1 Comm: swapper Not tainted 3.12.0-rc2-lemote-los.git-5318619-dirty #1
[ 1.920000] Stack : 0000000031aac000 ffffffff810d0000 0000000000000052 ffffffff802730a4
0000000000000000 0000000000000001 ffffffff810cdf90 ffffffff810d0000
ffffffff8068b968 ffffffff806f5537 ffffffff810cdf90 980000009f0782e8
0000000000000001 ffffffff80720000 ffffffff806b0000 980000009f078000
980000009f290000 ffffffff805f312c 980000009f05b5d8 ffffffff80233518
980000009f05b5e8 ffffffff80274b7c 980000009f078000 ffffffff8068b968
0000000000000000 0000000000000000 0000000000000000 0000000000000000
0000000000000000 980000009f05b520 0000000000000000 ffffffff805f2f6c
0000000000000000 ffffffff80700000 ffffffff80700000 ffffffff806fc758
ffffffff80700000 ffffffff8020be98 ffffffff806fceb0 ffffffff805f2f6c
[ 2.028000] Call Trace:
[ 2.032000] [<ffffffff8020be98>] show_stack+0x80/0x98
[ 2.036000] [<ffffffff805f2f6c>] __schedule_bug+0x44/0x6c
[ 2.040000] [<ffffffff805fac58>] __schedule+0x518/0x5b0
[ 2.044000] [<ffffffff805f8a58>] schedule_timeout+0x128/0x1f0
[ 2.048000] [<ffffffff80240314>] msleep+0x3c/0x60
[ 2.052000] [<ffffffff80495400>] do_probe+0x238/0x3a8
[ 2.056000] [<ffffffff804958b0>] ide_probe_port+0x340/0x7e8
[ 2.060000] [<ffffffff80496028>] ide_host_register+0x2d0/0x7a8
[ 2.064000] [<ffffffff8049c65c>] ide_pci_init_two+0x4e4/0x790
[ 2.068000] [<ffffffff8049f9b8>] amd74xx_probe+0x148/0x2c8
[ 2.072000] [<ffffffff803f571c>] pci_device_probe+0xc4/0x130
[ 2.076000] [<ffffffff80478f60>] driver_probe_device+0x98/0x270
[ 2.080000] [<ffffffff80479298>] __driver_attach+0xe0/0xe8
[ 2.084000] [<ffffffff80476ab0>] bus_for_each_dev+0x78/0xe0
[ 2.088000] [<ffffffff80478468>] bus_add_driver+0x230/0x310
[ 2.092000] [<ffffffff80479b44>] driver_register+0x84/0x158
[ 2.096000] [<ffffffff80200504>] do_one_initcall+0x104/0x160
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org>
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: linux-mips@linux-mips.org
Cc: Linux Kernel Mailing List <linux-kernel@vger.kernel.org>
Patchwork: https://patchwork.linux-mips.org/patch/5941/
commit 361e9dfbaae84b0b246ed18d1ab7c82a1a41b53e upstream.
The buffers sized by CONFIG_LOG_BUF_SHIFT and
CONFIG_LOG_CPU_MAX_BUF_SHIFT do not exist if CONFIG_PRINTK=n, so don't
ask about their size at all.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
[bwh: Backported to 3.2: drop change to CONFIG_LOG_CPU_MAX_BUF_SHIFT]
commit 6c72e3501d0d62fc064d3680e5234f3463ec5a86 upstream.
Oleg noticed that a cleanup by Sylvain actually uncovered a bug; by
calling perf_event_free_task() when failing sched_fork() we will not yet
have done the memset() on ->perf_event_ctxp[] and will therefore try and
'free' the inherited contexts, which are still in use by the parent
process. This is bad..
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Reported-by: Oleg Nesterov <oleg@redhat.com>
Reported-by: Sylvain 'ythier' Hitier <sylvain.hitier@gmail.com>
commit d3cb8bf6081b8b7a2dabb1264fe968fd870fa595 upstream.
A migration entry is marked as write if pte_write was true at the time the
entry was created. The VMA protections are not double checked when migration
entries are being removed as mprotect marks write-migration-entries as
read. It means that potentially we take a spurious fault to mark PTEs write
again but it's straight-forward. However, there is a race between write
migrations being marked read and migrations finishing. This potentially
allows a PTE to be write that should have been read. Close this race by
double checking the VMA permissions using maybe_mkwrite when migration
completes.
[torvalds@linux-foundation.org: use maybe_mkwrite]
commit b928095b0a7cff7fb9fcf4c706348ceb8ab2c295 upstream.
If overwriting an empty directory with rename, then need to drop the extra
nlink.
Test prog:
#include <stdio.h>
#include <fcntl.h>
#include <err.h>
#include <sys/stat.h>
int main(void)
const char *test_dir1 = "test-dir1";
const char *test_dir2 = "test-dir2";
int res;
int fd;
struct stat statbuf;
res = mkdir(test_dir1, 0777);
if (res == -1)
err(1, "mkdir(\"%s\")", test_dir1);
res = mkdir(test_dir2, 0777);
if (res == -1)
err(1, "mkdir(\"%s\")", test_dir2);
fd = open(test_dir2, O_RDONLY);
if (fd == -1)
err(1, "open(\"%s\")", test_dir2);
res = rename(test_dir1, test_dir2);
if (res == -1)
err(1, "rename(\"%s\", \"%s\")", test_dir1, test_dir2);
res = fstat(fd, &statbuf);
if (res == -1)
err(1, "fstat(%i)", fd);
if (statbuf.st_nlink != 0) {
fprintf(stderr, "nlink is %lu, should be 0\n", statbuf.st_nlink);
return 1;
return 0;
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit 5760a97c7143c208fa3a8f8cad0ed7dd672ebd28 upstream.
There is a deadlock case which reported by Guozhonghua:
https://oss.oracle.com/pipermail/ocfs2-devel/2014-September/010079.html
This case is caused by &res->spinlock and &dlm->master_lock
misordering in different threads.
It was introduced by commit 8d400b81cc83 ("ocfs2/dlm: Clean up refmap
helpers"). Since lockres is new, it doesn't not require the
&res->spinlock. So remove it.
Fixes: 8d400b81cc83 ("ocfs2/dlm: Clean up refmap helpers")
Signed-off-by: Joseph Qi <joseph.qi@huawei.com>
Reviewed-by: joyce.xue <xuejiufei@huawei.com>
Reported-by: Guozhonghua <guozhonghua@h3c.com>
Cc: Mark Fasheh <mfasheh@suse.com>
commit 56d7acc792c0d98f38f22058671ee715ff197023 upstream.
This bug leads to reproducible silent data loss, despite the use of
msync(), sync() and a clean unmount of the file system. It is easily
reproducible with the following script:
----------------[BEGIN SCRIPT]--------------------
mkfs.nilfs2 -f /dev/sdb
mount /dev/sdb /mnt
dd if=/dev/zero bs=1M count=30 of=/mnt/testfile
umount /mnt
mount /dev/sdb /mnt
CHECKSUM_BEFORE="$(md5sum /mnt/testfile)"
/root/mmaptest/mmaptest /mnt/testfile 30 10 5
sync
CHECKSUM_AFTER="$(md5sum /mnt/testfile)"
umount /mnt
mount /dev/sdb /mnt
CHECKSUM_AFTER_REMOUNT="$(md5sum /mnt/testfile)"
umount /mnt
echo "BEFORE MMAP:\t$CHECKSUM_BEFORE"
echo "AFTER MMAP:\t$CHECKSUM_AFTER"
echo "AFTER REMOUNT:\t$CHECKSUM_AFTER_REMOUNT"
----------------[END SCRIPT]--------------------
The mmaptest tool looks something like this (very simplified, with
error checking removed):
----------------[BEGIN mmaptest]--------------------
data = mmap(NULL, file_size - file_offset, PROT_READ | PROT_WRITE,
MAP_SHARED, fd, file_offset);
for (i = 0; i < write_count; ++i) {
memcpy(data + i * 4096, buf, sizeof(buf));
msync(data, file_size - file_offset, MS_SYNC))
----------------[END mmaptest]--------------------
The output of the script looks something like this:
BEFORE MMAP: 281ed1d5ae50e8419f9b978aab16de83 /mnt/testfile
AFTER MMAP: 6604a1c31f10780331a6850371b3a313 /mnt/testfile
AFTER REMOUNT: 281ed1d5ae50e8419f9b978aab16de83 /mnt/testfile
So it is clear, that the changes done using mmap() do not survive a
remount. This can be reproduced a 100% of the time. The problem was
introduced in commit 136e8770cd5d ("nilfs2: fix issue of
nilfs_set_page_dirty() for page at EOF boundary").
If the page was read with mpage_readpage() or mpage_readpages() for
example, then it has no buffers attached to it. In that case
page_has_buffers(page) in nilfs_set_page_dirty() will be false.
Therefore nilfs_set_file_dirty() is never called and the pages are never
collected and never written to disk.
This patch fixes the problem by also calling nilfs_set_file_dirty() if the
page has no buffers attached to it.
[akpm@linux-foundation.org: s/PAGE_SHIFT/PAGE_CACHE_SHIFT/]
Signed-off-by: Andreas Rohner <andreas.rohner@gmx.net>
Tested-by: Andreas Rohner <andreas.rohner@gmx.net>
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit 8a574cfa2652545eb95595d38ac2a0bb501af0ae upstream.
Every mcount() call in the MIPS 32-bit kernel is done as follows:
move at, ra
jal _mcount
addiu sp, sp, -8
but upon returning from the mcount() function, the stack pointer
is not adjusted properly. This is explained in details in 58b69401c797
(MIPS: Function tracer: Fix broken function tracing).
Commit ad8c396936e3 ("MIPS: Unbreak function tracer for 64-bit kernel.)
fixed the stack manipulation for 64-bit but it didn't fix it completely
for MIPS32.
Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/7792/
commit 5ca918e5e3f9df4634077c06585c42bc6a8d699a upstream.
The alignment fixup incorrectly decodes faulting ARM VLDn/VSTn
instructions (where the optional alignment hint is given but incorrect)
as LDR/STR, leading to register corruption. Detect these and correctly
treat them as unhandled, so that userspace gets the fault it expects.
Reported-by: Simon Hosie <simon.hosie@arm.com>
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
commit 03bd4e1f7265548832a76e7919a81f3137c44fd1 upstream.
The following bug can be triggered by hot adding and removing a large number of
xen domain0's vcpus repeatedly:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000004 IP: [..] find_busiest_group
PGD 5a9d5067 PUD 13067 PMD 0
Oops: 0000 [#3] SMP
Call Trace:
load_balance
? _raw_spin_unlock_irqrestore
idle_balance
__schedule
schedule
schedule_timeout
? lock_timer_base
schedule_timeout_uninterruptible
msleep
lock_device_hotplug_sysfs
online_store
dev_attr_store
sysfs_write_file
vfs_write
SyS_write
Last level cache shared mask is built during CPU up and the
build_sched_domain() routine takes advantage of it to setup
the sched domain CPU topology.
However, llc_shared_mask is not released during CPU disable,
which leads to an invalid sched domainCPU topology.
This patch fix it by releasing the llc_shared_mask correctly
during CPU disable.
Yasuaki also reported that this can happen on real hardware:
https://lkml.org/lkml/2014/7/22/1018
His case is here:
Here is an example on my system.
My system has 4 sockets and each socket has 15 cores and HT is
enabled. In this case, each core of sockes is numbered as
follows:
| CPU#
Socket#0 | 0-14 , 60-74
Socket#1 | 15-29, 75-89
Socket#2 | 30-44, 90-104
Socket#3 | 45-59, 105-119
Then llc_shared_mask of CPU#30 has 0x3fff80000001fffc0000000.
It means that last level cache of Socket#2 is shared with
CPU#30-44 and 90-104.
When hot-removing socket#2 and #3, each core of sockets is
numbered as follows:
| CPU#
But llc_shared_mask is not cleared. So llc_shared_mask of CPU#30
remains having 0x3fff80000001fffc0000000.
After that, when hot-adding socket#2 and #3, each core of
sockets is numbered as follows:
| CPU#
Socket#2 | 30-59
Socket#3 | 90-119
Then llc_shared_mask of CPU#30 becomes
0x3fff8000fffffffc0000000. It means that last level cache of
Socket#2 is shared with CPU#30-59 and 90-104. So the mask has
the wrong value.
Signed-off-by: Wanpeng Li <wanpeng.li@linux.intel.com>
Tested-by: Linn Crosetto <linn@hp.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Reviewed-by: Toshi Kani <toshi.kani@hp.com>
Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Steven Rostedt <srostedt@redhat.com>
Link: http://lkml.kernel.org/r/1411547885-48165-1-git-send-email-wanpeng.li@linux.intel.com
commit d26a7730b5874a5fa6779c62f4ad7c5065a94723 upstream.
In spite of what the GCC manual says, the -mfast-indirect-calls has
never been supported in the 64-bit parisc compiler. Indirect calls have
always been done using function descriptors irrespective of the
-mfast-indirect-calls option.
Recently, it was noticed that a function descriptor was always requested
when the -mfast-indirect-calls option was specified. This caused
problems when the option was used in application code and doesn't make
any sense because the whole point of the option is to avoid using a
function descriptor for indirect calls.
Fixing this broke 64-bit kernel builds.
I will fix GCC but for now we need the attached change. This results in
the same kernel code as before.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Signed-off-by: Helge Deller <deller@gmx.de>
commit f2d5a94436cc7cc0221b9a81bba2276a25187dd3 upstream.
On 32-bit architectures, the legacy buffer_head functions are not always
handling the sector number with the proper 64-bit types, and will thus
fail on 4TB+ disks.
Any code that uses __getblk() (and thus bread(), breadahead(),
sb_bread(), sb_breadahead(), sb_getblk()), and calls it using a 64-bit
block on a 32-bit arch (where "long" is 32-bit) causes an inifinite loop
in __getblk_slow() with an infinite stream of errors logged to dmesg
like this:
__find_get_block_slow() failed. block=6740375944, b_blocknr=2445408648
b_state=0x00000020, b_size=512
device sda1 blocksize: 512
Note how in hex block is 0x191C1F988 and b_blocknr is 0x91C1F988 i.e. the
top 32-bits are missing (in this case the 0x1 at the top).
This is because grow_dev_page() is broken and has a 32-bit overflow due
to shifting the page index value (a pgoff_t - which is just 32 bits on
32-bit architectures) left-shifted as the block number. But the top
bits to get lost as the pgoff_t is not type cast to sector_t / 64-bit
before the shift.
This patch fixes this issue by type casting "index" to sector_t before
doing the left shift.
Note this is not a theoretical bug but has been seen in the field on a
4TiB hard drive with logical sector size 512 bytes.
This patch has been verified to fix the infinite loop problem on 3.17-rc5
kernel using a 4TB disk image mounted using "-o loop". Without this patch
doing a "find /nt" where /nt is an NTFS volume causes the inifinite loop
100% reproducibly whilst with the patch it works fine as expected.
Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
commit a9960e6a293e6fc3ed414643bb4e4106272e4d0a upstream.
The calculated frame size was wrong because snd_pcm_format_physical_width()
actually returns the number of bits, not bytes.
Use snd_pcm_format_size() instead, which not only returns bytes, but also
simplifies the calculation.
Fixes: 8bea869c5e56 ("ALSA: PCM midlevel: improve fifo_size handling")
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit e77980e50bc2850599d4d9c0192b67a9ffd6daac upstream.
In order to make the driver work with the common clock framework, this patch
converts the clk_enable()/clk_disable() to
clk_prepare_enable()/clk_disable_unprepare(). While there, add the missing
error handling.
Signed-off-by: David Dueck <davidcdueck@googlemail.com>
Signed-off-by: Anthony Harivel <anthony.harivel@emtrion.de>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit de5944883ebbedbf5adc8497659772f5da7b7d72 upstream.
After sending a RTR frame the TX mailbox becomes a RX_EMPTY mailbox. To avoid
side effects when the RX-FIFO is full, this patch puts the TX mailbox into
TX_INACTIVE mode in the transmission complete interrupt handler. This, of
course, leaves a race window between the actual completion of the transmission
and the handling of tx-complete interrupt. However this is the best we can do
without busy polling the tx complete interrupt.
commit 25e924450fcb23c11c07c95ea8964dd9f174652e upstream.
This patch implements the workaround mentioned in ERR005829:
ERR005829: FlexCAN: FlexCAN does not transmit a message that is enabled to
be transmitted in a specific moment during the arbitration process.
Workaround: The workaround consists of two extra steps after setting up a
message for transmission:
Step 8: Reserve the first valid mailbox as an inactive mailbox (CODE=0b1000).
If RX FIFO is disabled, this mailbox must be message buffer 0. Otherwise, the
first valid mailbox can be found using the "RX FIFO filters" table in the
FlexCAN chapter of the chip reference manual.
Step 9: Write twice INACTIVE code (0b1000) into the first valid mailbox.
Signed-off-by: David Jander <david@protonic.nl>
commit fc05b884a31dbf259cc73cc856e634ec3acbebb6 upstream.
Apparently mailboxes may contain random data at startup, causing some of them
being prepared for message reception. This causes overruns being missed or even
confusing the IRQ check for trasmitted messages, increasing the transmit
counter instead of the error counter.
This patch initializes all mailboxes after the FIFO as RX_INACTIVE.
commit c32fe4ad3e4861b2bfa1f44114c564935a123dda upstream.
This patch fixes the initialization of the TX mailbox. It is now correctly
initialized as TX_INACTIVE not RX_EMPTY.
commit bd8c78e78d5011d8111bc2533ee73b13a3bd6c42 upstream.
In testmode and vendor command reply/event SKBs we use the
skb cb data to store nl80211 parameters between allocation
and sending. This causes the code for CONFIG_NETLINK_MMAP
to get confused, because it takes ownership of the skb cb
data when the SKB is handed off to netlink, and it doesn't
explicitly clear it.
Clear the skb cb explicitly when we're done and before it
gets passed to netlink to avoid this issue.
Reported-by: Assaf Azulay <assaf.azulay@intel.com>
Reported-by: David Spinadel <david.spinadel@intel.com>
commit c80b4495c61636edc58fe1ce300f09f24db28e10 upstream.
This patch adds quirks for Entrega Technologies (later Xircom PortGear) USB-
SCSI converters. They use Shuttle Technology EUSB-01/EUSB-S1 chips. The
US_FL_SCM_MULT_TARG quirk is needed to allow multiple devices on the SCSI
chain to be accessed. Without it only the (single) device with SCSI ID 0
can be used.
The standalone converter sold by Entrega had model number U1-SC25. Xircom
acquired Entrega and re-branded the product line PortGear. The PortGear USB
to SCSI Converter (model PGSCSI) is internally identical to the Entrega
product, but later models may use a different USB ID. The Entrega-branded
units have USB ID 1645:0007, as does my Xircom PGSCSI, but the Windows and
Macintosh drivers also support 085A:0028.
Entrega also sold the "Mac USB Dock", which provides two USB ports, a Mac
(8-pin mini-DIN) serial port and a SCSI port. It appears to the computer as
a four-port hub, USB-serial, and USB-SCSI converters. The USB-SCSI part may
have initially used the same ID as the standalone U1-SC25 (1645:0007), but
later production used 085A:0026.
My Xircom PortGear PGSCSI has bcdDevice=0x0100. Units with bcdDevice=0x0133
probably also exist.
This patch adds quirks for 1645:0007, 085A:0026 and 085A:0028. The Windows
driver INF file also mentions 085A:0032 "PortStation SCSI Module", but I
couldn't find any mention of that actually existing in the wild; perhaps it
was cancelled before release?
Signed-off-by: Mark Knibbs <markk@clara.co.uk>
commit b6a3ed677991558ce09046397a7c4d70530d15b3 upstream.
The Ariston Technologies iConnect 025 and iConnect 050 (also known as e.g.
iSCSI-50) are SCSI-USB converters which use Shuttle Technology/SCM
Microsystems chips. Only the connectors differ; both have the same USB ID.
The US_FL_SCM_MULT_TARG quirk is required to use SCSI devices with ID other
than 0.
I don't have one of these, but based on the other entries for Shuttle/
SCM-based converters this patch is very likely correct. I used 0x0000 and
0x9999 for bcdDeviceMin and bcdDeviceMax because I'm not sure which
bcdDevice value the products use.
commit 67d365a57a51fb9dece6a5ceb504aa381cae1e5b upstream.
The Adaptec USBConnect 2000 is another SCSI-USB converter which uses
Shuttle Technology/SCM Microsystems chips. The US_FL_SCM_MULT_TARG quirk is
required to use SCSI devices with ID other than 0.
I don't have a USBConnect 2000, but based on the other entries for Shuttle/
bcdDevice value the product uses.
