commit f2ea0f5f04c97b48c88edccba52b0682fbe45087 upstream.
Use standard ror64() instead of hand-written.
There is no standard ror64, so create it.
The difference is shift value being "unsigned int" instead of uint64_t
(for which there is no reason). gcc starts to emit native ROR instructions
which it doesn't do for some reason currently. This should make the code
faster.
Patch survives in-tree crypto test and ping flood with hmac(sha512) on.
commit 207d543f472c1ac9552df79838dc807cbcaa9740 upstream.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit f9c2a0dc42a6938ff2a80e55ca2bbd1d5581c72e upstream.
Current PIO mode makes a kernel crash with CONFIG_HIGHMEM.
Highmem pages have a NULL from sg_virt(sg).
This patch fixes the following problem.
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c0004000
[00000000] *pgd=00000000
Internal error: Oops: 817 [#1] PREEMPT SMP
Modules linked in:
CPU: 0 Not tainted (3.0.15-01423-gdbf465f #589)
PC is at dw_mci_pull_data32+0x4c/0x9c
LR is at dw_mci_read_data_pio+0x54/0x1f0
pc : [<c0358824>] lr : [<c035988c>] psr: 20000193
sp : c0619d48 ip : c0619d70 fp : c0619d6c
r10: 00000000 r9 : 00000002 r8 : 00001000
r7 : 00000200 r6 : 00000000 r5 : e1dd3100 r4 : 00000000
r3 : 65622023 r2 : 0000007f r1 : eeb96000 r0 : e1dd3100
Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment
xkernel
Control: 10c5387d Table: 61e2004a DAC: 00000015
Process swapper (pid: 0, stack limit = 0xc06182f0)
Stack: (0xc0619d48 to 0xc061a000)
9d40: e1dd3100 e1a4f000 00000000 e1dd3100 e1a4f000 00000200
9d60: c0619da4 c0619d70 c035988c c03587e4 c0619d9c e18158f4 e1dd3100 e1dd3100
9d80: 00000020 00000000 00000000 00000020 c06e8a84 00000000 c0619e04 c0619da8
9da0: c0359b24 c0359844 e18158f4 e1dd3164 e1dd3168 e1dd3150 3d02fc79 e1dd3154
9dc0: e1dd3178 00000000 00000020 00000000 e1dd3150 00000000 c10dd7e8 e1a84900
9de0: c061e7cc 00000000 00000000 0000008d c06e8a84 c061e780 c0619e4c c0619e08
9e00: c00c4738 c0359a34 3d02fc79 00000000 c0619e4c c05a1698 c05a1670 c05a165c
9e20: c04de8b0 c061e780 c061e7cc e1a84900 ffffed68 0000008d c0618000 00000000
9e40: c0619e6c c0619e50 c00c48b4 c00c46c8 c061e780 c00423ac c061e7cc ffffed68
9e60: c0619e8c c0619e70 c00c7358 c00c487c 0000008d ffffee38 c0618000 ffffed68
9e80: c0619ea4 c0619e90 c00c4258 c00c72b0 c00423ac ffffee38 c0619ecc c0619ea8
9ea0: c004241c c00c4234 ffffffff f8810000 0000006d 00000002 00000001 7fffffff
9ec0: c0619f44 c0619ed0 c0048bc0 c00423c4 220ae7a9 00000000 386f0d30 0005d3a4
9ee0: c00423ac c10dd0b8 c06f2cd8 c0618000 c0594778 c003a674 7fffffff c0619f44
9f00: 386f0d30 c0619f18 c00a6f94 c005be3c 80000013 ffffffff 386f0d30 0005d3a4
9f20: 386f0d30 0005d2d1 c10dd0a8 c10dd0b8 c06f2cd8 c0618000 c0619f74 c0619f48
9f40: c0345858 c005be00 c00a2440 c0618000 c0618000 c00410d8 c06c1944 c00410fc
9f60: c0594778 c003a674 c0619f9c c0619f78 c004a7e8 c03457b4 c0618000 c06c18f8
9f80: 00000000 c0039c70 c06c18d4 c003a674 c0619fb4 c0619fa0 c04ceafc c004a714
9fa0: c06287b4 c06c18f8 c0619ff4 c0619fb8 c0008b68 c04cea68 c0008578 00000000
9fc0: 00000000 c003a674 00000000 10c5387d c0628658 c003aa78 c062f1c4 4000406a
9fe0: 413fc090 00000000 00000000 c0619ff8 40008044 c0008858 00000000 00000000
Backtrace:
[<c03587d8>] (dw_mci_pull_data32+0x0/0x9c) from [<c035988c>] (dw_mci_read_data_pio+0x54/0x1f0)
r6:00000200 r5:e1a4f000 r4:e1dd3100
[<c0359838>] (dw_mci_read_data_pio+0x0/0x1f0) from [<c0359b24>] (dw_mci_interrupt+0xfc/0x4a4)
[<c0359a28>] (dw_mci_interrupt+0x0/0x4a4) from [<c00c4738>] (handle_irq_event_percpu+0x7c/0x1b4)
[<c00c46bc>] (handle_irq_event_percpu+0x0/0x1b4) from [<c00c48b4>] (handle_irq_event+0x44/0x64)
[<c00c4870>] (handle_irq_event+0x0/0x64) from [<c00c7358>] (handle_fasteoi_irq+0xb4/0x124)
r7:ffffed68 r6:c061e7cc r5:c00423ac r4:c061e780
[<c00c72a4>] (handle_fasteoi_irq+0x0/0x124) from [<c00c4258>] (generic_handle_irq+0x30/0x38)
r7:ffffed68 r6:c0618000 r5:ffffee38 r4:0000008d
[<c00c4228>] (generic_handle_irq+0x0/0x38) from [<c004241c>] (asm_do_IRQ+0x64/0xe0)
r5:ffffee38 r4:c00423ac
[<c00423b8>] (asm_do_IRQ+0x0/0xe0) from [<c0048bc0>] (__irq_svc+0x80/0x14c)
Exception stack(0xc0619ed0 to 0xc0619f18)
Signed-off-by: Seungwon Jeon <tgih.jun@samsung.com>
Acked-by: Will Newton <will.newton@imgtec.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
commit 18ee684b8ab666329e0a0a72d8b70f16fb0e2243 upstream.
Sometimes a software reset is needed. Then some registers are saved and
restored but the interrupt mask register is missing. It causes issues
with sdio devices whose interrupts are masked after reset.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit 02a237b24d57e2e2d5402c92549e9e792aa24359 upstream.
Since 3.2 kernel, the driver starts trying to assign the multi-io DACs
before the speaker, thus it assigns DAC2/3 for multi-io and DAC4 for
the speaker for a standard laptop setup like a HP, a speaker, a mic-in
and a line-in. However, on Acer Aspire 6935, it seems that the
speaker pin 0x14 must be connected with either DAC1 or 2; otherwise it
results in silence by some reason, although the codec itself allows
the routing to DAC3/4.
As a workaround, the connection list of each pin is reduced to be
mapped to either only DAC1/2 or DAC3/4, so that the compatible
assignment as in kernel 3.1 is achieved.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42740
commit fc1156c0b0f7ad45ec03d919866349eeca2bf18c upstream.
VT1705 codec has two ADCs where the secondary ADC has no MUX but only
a fixed connection to the mic pin. This confused the driver and it
tries always overriding the input-source selection by assumption of
the existing MUX for the secondary ADC, resulted in resetting the
input-source at each time PM (including power-saving) occurs.
The fix is simply to check the existence of MUX for secondary ADCs in
the initialization code.
Tested-by: Anisse Astier <anisse@astier.eu>
commit 27c3afe6e1cf129faac90405121203962da08ff4 upstream.
BugLink: https://bugs.launchpad.net/bugs/930842
The reporter states that audio is inaudible by default without muting
'External Amplifier'. Add a quirk to handle his SSID so that changing
the control is not necessary.
Reported-and-tested-by: Benjamin Carlson <elderbubba0810@gmail.com>
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
commit 2673b4cf5d59c3ee5e0c12f6d734d38770324dc4 upstream.
While 7a401a972df8e18 ("backing-dev: ensure wakeup_timer is deleted")
addressed the problem of the bdi being freed with a queued wakeup
timer, there are other races that could happen if the wakeup timer
expires after/during bdi_unregister(), before bdi_destroy() is called.
wakeup_timer_fn() could attempt to wakeup a task which has already has
been freed, or could access a NULL bdi->dev via the wake_forker_thread
tracepoint.
Reported-by: Chanho Min <chanho.min@lge.com>
Reviewed-by: Namjae Jeon <linkinjeon@gmail.com>
Signed-off-by: Rabin Vincent <rabin@rab.in>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
commit 3a92d687c8015860a19213e3c102cad6b722f83c upstream.
Unfortunately in reducing W from 80 to 16 we ended up unrolling
the loop twice. As gcc has issues dealing with 64-bit ops on
i386 this means that we end up using even more stack space (>1K).
This patch solves the W reduction by moving LOAD_OP/BLEND_OP
into the loop itself, thus avoiding the need to duplicate it.
While the stack space still isn't great (>0.5K) it is at least
in the same ball park as the amount of stack used for our C sha1
implementation.
Note that this patch basically reverts to the original code so
the diff looks bigger than it really is.
commit 58d7d18b5268febb8b1391c6dffc8e2aaa751fcd upstream.
The previous patch used the modulus operator over a power of 2
unnecessarily which may produce suboptimal binary code. This
patch changes changes them to binary ands instead.
commit ff4fa4a25a33f92b5653bb43add0c63bea98d464 upstream.
standard_receive3 will check the validity of the response from the
server (via checkSMB). It'll pass the result of that check to handle_mid
which will dequeue it and mark it with a status of
MID_RESPONSE_MALFORMED if checkSMB returned an error. At that point,
standard_receive3 will also return an error, which will make the
demultiplex thread skip doing the callback for the mid.
This is wrong -- if we were able to identify the request and the
response is marked malformed, then we want the demultiplex thread to do
the callback. Fix this by making standard_receive3 return 0 in this
situation.
Reported-and-Tested-by: Mark Moseley <moseleymark@gmail.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 8b0192a5f478da1c1ae906bf3ffff53f26204f56 upstream.
Currently, it's always set to 0 (no oplock requested).
commit 09e87e5c4f9af656af2a8a3afc03487c5d9287c3 upstream.
In order to enable temperature mode aka automatic mode for the F75373 and
F75375 chips, the two FANx_MODE bits in the fan configuration register
need be set to 01, not 10.
Signed-off-by: Nikolaus Schulz <mail@microschulz.de>
commit 977b7e3a52a7421ad33a393a38ece59f3d41c2fa upstream.
When a SD card is hot removed without umount, del_gendisk() will call
bdi_unregister() without destroying/freeing it. This leaves the bdi in
the bdi->dev = NULL, bdi->wb.task = NULL, bdi->bdi_list removed state.
When sync(2) gets the bdi before bdi_unregister() and calls
bdi_queue_work() after the unregister, trace_writeback_queue will be
dereferencing the NULL bdi->dev. Fix it with a simple test for NULL.
LKML-reference: http://lkml.org/lkml/2012/1/18/346
Reported-by: Rabin Vincent <rabin@rab.in>
Tested-by: Namjae Jeon <linkinjeon@gmail.com>
commit 15eb77a07c714ac80201abd0a9568888bcee6276 upstream.
bdi_prune_sb() resets sb->s_bdi to default_backing_dev_info when the
tearing down the original bdi. Fix trace_writeback_single_inode to
use sb->s_bdi=default_backing_dev_info rather than bdi->dev=NULL for a
teared down bdi.
Tested-by: Rabin Vincent <rabin@rab.in>
commit 07ae2dfcf4f7143ce191c6436da1c33f179af0d6 upstream.
The current code checks for stored_mpdu_num > 1, causing
the reorder_timer to be triggered indefinitely, but the
frame is never timed-out (until the next packet is received)
Signed-off-by: Eliad Peller <eliad@wizery.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
commit f6302f1bcd75a042df69866d98b8d775a668f8f1 upstream.
"subbuf_size" and "n_subbufs" come from the user and they need to be
capped to prevent an integer overflow.
commit 3310225dfc71a35a2cc9340c15c0e08b14b3c754 upstream.
PROP_MAX_SHIFT should be set to <=32 on 64-bit box. This fixes two bugs
in the below lines of bdi_dirty_limit():
bdi_dirty *= numerator;
do_div(bdi_dirty, denominator);
1) divide error: do_div() only uses the lower 32 bit of the denominator,
which may trimmed to be 0 when PROP_MAX_SHIFT > 32.
2) overflow: (bdi_dirty * numerator) could easily overflow if numerator
used up to 48 bits, leaving only 16 bits to bdi_dirty
Reported-by: Ilya Tumaykin <librarian_rus@yahoo.com>
Tested-by: Ilya Tumaykin <librarian_rus@yahoo.com>
commit a1728800bed3b93b231d99e97c756f622b9991c2 upstream.
8<----------------------------------------------------------------------
Date: Wed, 16 Nov 2011 09:33:50 +0100
Subject: net: enable TC35815 for MIPS again
TX493[8,9] MIPS SoCs support 2 Ethernet channels of type TC35815
which are connected to the internal PCI controller.
And JMR3927 MIPS board has a TC35815 chip on board.
These dependencies were lost on movement to drivers/net/ethernet/toshiba.
Signed-off-by: Ralf Roesch <ralf.roesch@rw-gmbh.de>
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
commit eb2f255b2d360df3f500042a2258dcf2fcbe89a2 upstream.
In order to extract the high byte of the 16-bit word, shift the word to
the right, not to the left.
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit 55a2bb4a6d5e8c7b324d003e130fd9aaf33be4e6 upstream.
commit adb5066 "ath9k_hw: do not apply the 2.4 ghz ack timeout
workaround to cts" reduced the hardware CTS timeout to the normal
values specified by the standard, but it turns out while it doesn't
need the same extra time that it needs for the ACK timeout, it
does need more than the value specified in the standard, but only
for 2.4 GHz.
This patch brings the CTS timeout value in sync with the initialization
values, while still allowing adjustment for bigger distances.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Reported-by: Seth Forshee <seth.forshee@canonical.com>
Reported-by: Marek Lindner <lindner_marek@yahoo.de>
commit f88373fa47f3ce6590fdfaa742d0ddacc2ae017f upstream.
commit b4a82a0 "ath9k_hw: fix interpretation of the rx KeyMiss flag"
fixed the interpretation of the KeyMiss flag for keycache based lookups,
however WEP encryption uses a static index, so KeyMiss is always asserted
for it, even though frames are decrypted properly.
Fix this by clearing the ATH9K_RXERR_KEYMISS flag if no keycache based
lookup was performed.
Reported-by: Laurent Bonnans <bonnans.l@gmail.com>
Reported-by: Jurica Vukadin <u.ra604@googlemail.com>
commit 07445f688218a48bde72316aed9de4fdcc173131 upstream.
all works need to be initialized before ieee80211_register_hw
to prevent mac80211 call backs such as drv_start, drv_config
getting started. otherwise we would queue/cancel works before
initializing them and it leads to kernel panic.
this issue can be recreated with the following script
in Chrome laptops with AR928X cards, with background scan
running (or) Network manager is running
while true
do
sudo modprobe -v ath9k
sleep 3
sudo modprobe -r ath9k
sleep 3
done
EIP: [<81040a47>] __cancel_work_timer+0xb8/0xe1 SS:ESP 0068:f6be9d70
---[ end trace 4f86d6139a9900ef ]---
Registered led device: ath9k-phy0
ieee80211 phy0: Atheros AR9280 Rev:2 mem=0xf88a0000,
irq=16
Kernel panic - not syncing: Fatal exception
Pid: 456, comm: wpa_supplicant Tainted: G D
3.0.13 #1
Call Trace:
[<81379e21>] panic+0x53/0x14a
[<81004a30>] oops_end+0x73/0x81
[<81004b53>] die+0x4c/0x55
[<81002710>] do_trap+0x7c/0x83
[<81002855>] ? do_bounds+0x58/0x58
[<810028cc>] do_invalid_op+0x77/0x81
[<81040a47>] ? __cancel_work_timer+0xb8/0xe1
[<810489ec>] ? sched_clock_cpu+0x81/0x11f
[<8103f809>] ? wait_on_work+0xe2/0xf7
[<8137f807>] error_code+0x67/0x6c
[<810300d8>] ? wait_consider_task+0x4ba/0x84c
[<810380c9>] ? try_to_del_timer_sync+0x5f/0x67
[<81040a91>] cancel_work_sync+0xf/0x11
[<f88d7b7c>] ath_set_channel+0x62/0x25c [ath9k]
[<f88d67d1>] ? ath9k_tx_last_beacon+0x26a/0x85c [ath9k]
[<f88d8899>] ath_radio_disable+0x3f1/0x68e [ath9k]
[<f90d0edb>] ieee80211_hw_config+0x111/0x116 [mac80211]
[<f90dd95c>] __ieee80211_recalc_idle+0x919/0xa37 [mac80211]
[<f90dda76>] __ieee80211_recalc_idle+0xa33/0xa37 [mac80211]
[<812dbed8>] __dev_open+0x82/0xab
Cc: Gary Morain <gmorain@google.com>
Cc: Paul Stewart <pstew@google.com>
Cc: Vasanthakumar Thiagarajan <vthiagar@qca.qualcomm.com>
Tested-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com>
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
Signed-off-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com>
commit e57b6886f555ab57f40a01713304e2053efe51ec upstream.
According to a bug report, it doesn't have one.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=44263
Acked-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Keith Packard <keithp@keithp.com>
commit c898261c0dad617f0f1080bedc02d507a2fcfb92 upstream.
It is never correct to use intel_crtc->bpp in intel_dp_link_required,
so instead pass an explicit bpp in to this function. This patch
only supports 18bpp and 24bpp modes, which means that 10bpc modes will
be computed incorrectly. Fixing that will require more extensive
changes, and so must be addressed separately from this bugfix.
intel_dp_link_required is called from intel_dp_mode_valid and
intel_dp_mode_fixup.
* intel_dp_mode_valid is called to list supported modes; in this case,
the current crtc values cannot be relevant as the modes in question
may never be selected. Thus, using intel_crtc->bpp is never right.
* intel_dp_mode_fixup is called during mode setting, but it is run
well before ironlake_crtc_mode_set is called to set intel_crtc->bpp,
so using intel_crtc-bpp in this path can only ever get a stale
value.
Cc: Lubos Kolouch <lubos.kolouch@gmail.com>
Cc: Adam Jackson <ajax@redhat.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=42263
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=44881
Tested-by: Dave Airlie <airlied@redhat.com>
Tested-by: camalot@picnicpark.org (Dell Latitude 6510)
Tested-by: Roland Dreier <roland@digitalvampire.org>
commit 7a0153ee15575a4d07b5da8c96b79e0b0fd41a12 upstream.
By adding following objects:
bench/mem-memcpy-x86-64-asm.o
the x86_64 perf binary ended up with executable stack.
The reason was that above object are assembler sourced and is missing the
GNU-stack note section. In such case the linker assumes that the final binary
should not be restricted at all and mark the stack as RWX.
Adding section ".note.GNU-stack" definition to mentioned object, with all
flags disabled, thus omiting this object from linker stack flags decision.
Problem introduced in:
$ git describe ea7872b
v2.6.37-rc2-19-gea7872b
Reported-at: https://bugzilla.redhat.com/show_bug.cgi?id=783570
Reported-by: Clark Williams <williams@redhat.com>
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1328100848-5630-1-git-send-email-jolsa@redhat.com
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
[ committer note: Backported fix to perf/urgent (3.3-rc2+) ]
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit a4a03fc7ef89020baca4f19174e6a43767c6d78a upstream.
This patch fixes an issue where perf report shows nan% for certain
perf.data files. The below is from a report for a do_fork probe:
-nan% sshd [kernel.kallsyms] [k] do_fork
-nan% packagekitd [kernel.kallsyms] [k] do_fork
-nan% dbus-daemon [kernel.kallsyms] [k] do_fork
-nan% bash [kernel.kallsyms] [k] do_fork
A git bisect shows commit f3bda2c as the cause. However, looking back
through the git history, I saw commit 640c03c which seems to have
removed the required initialization for perf_sample->period. The problem
only started showing after commit f3bda2c. The below patch re-introduces
the initialization and it fixes the problem for me.
With the below patch, for the same perf.data:
73.08% bash [kernel.kallsyms] [k] do_fork
8.97% 11-dhclient [kernel.kallsyms] [k] do_fork
6.41% sshd [kernel.kallsyms] [k] do_fork
3.85% 20-chrony [kernel.kallsyms] [k] do_fork
2.56% sendmail [kernel.kallsyms] [k] do_fork
This patch applies over current linux-tip commit 9949284.
$ git describe 640c03c
v2.6.37-rc3-83-g640c03c
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20120203170113.5190.25558.stgit@localhost6.localdomain6
Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
commit 0629292117572a60465f38cdedde2f8164c3df0b upstream.
Recent addition of code to find already allocated VFs failed to take
account that systems with 2 or more multi-port SR-IOV capable controllers
might have already enabled VFs. Make sure that the VFs the function is
finding are actually subordinate to the particular instance of the adapter
that is looking for them and not subordinate to some device that has
previously enabled SR-IOV.
This is applicable to 3.2+ kernels.
Reported-by: David Ahern <daahern@cisco.com>
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
Tested-by: Robert E Garrett <robertX.e.garrett@intel.com>
commit a4b08329c74985e5cc3a44b6d2b2c59444ed8079 upstream.
This bug exists in 3.2 stable as well as 3.3 release candidates.
Disable stuff which is known to have issues on RT
We can't deal with the cpumask allocations which happen in atomic
context (see arch/x86/kernel/apic/io_apic.c) on RT right now.
wait_queue is a swiss army knife and in most of the cases the
complexity is not needed. For RT waitqueues are a constant source of
trouble as we can't convert the head lock to a raw spinlock due to
fancy and long lasting callbacks.
Provide a slim version, which allows RT to replace wait queues. This
should go mainline as well, as it lowers memory consumption and
runtime overhead.
Use the BUG_ON_NORT variant for the irq_disabled() checks. RT has
interrupts legitimately enabled here as we cant deadlock against the
irq thread due to the "sleeping spinlocks" conversion.
Reported-by: Luis Claudio R. Goncalves <lclaudio@uudg.org>
Cc: stable-rt@vger.kernel.org
Restrict the preempt disabled regions to the actual floating point
operations and enable preemption for the administrative actions.
This is necessary on RT to avoid that kfree and other operations are
called with preemption disabled.
Reported-and-tested-by: Carsten Emde <cbe@osadl.org>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Add a CONFIG option to allow the output from Magic SysRq to be output
immediately, even if this causes large latencies.
If PREEMPT_RT_FULL, printk() will not try to acquire the console lock
when interrupts or preemption are disabled. If the console lock is
not acquired the printk() output will be buffered, but will not be
output immediately. Some drivers call into the Magic SysRq code
with interrupts or preemption disabled, so the output of Magic SysRq
will be buffered instead of printing immediately if this option is
not selected.
Even with this option selected, Magic SysRq output will be delayed
if the attempt to acquire the console lock fails.
Signed-off-by: Frank Rowand <frank.rowand@am.sony.com>
Link: http://lkml.kernel.org/r/4E7CEF60.5020508@am.sony.com
Current sysv sems have a weird ass wakeup scheme that involves keeping
preemption disabled over a potential O(n^2) loop and busy waiting on
that on other CPUs.
Kill this and simply wake the task directly from under the sem_lock.
This was discovered by a migrate_disable() debug feature that
disallows:
spin_lock();
preempt_disable();
spin_unlock()
preempt_enable();
Cc: Manfred Spraul <manfred@colorfullife.com>
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Reported-by: Mike Galbraith <efault@gmx.de>
Link: http://lkml.kernel.org/r/1315994224.5040.1.camel@twins
In fact, with migrate_disable() existing one could play games with
kmap_atomic. You could save/restore the kmap_atomic slots on context
switch (if there are any in use of course), this should be esp easy now
that we have a kmap_atomic stack.
Something like the below.. it wants replacing all the preempt_disable()
stuff with pagefault_disable() && migrate_disable() of course, but then
you can flip kmaps around like below.
[dvhart@linux.intel.com: build fix]
Link: http://lkml.kernel.org/r/1311842631.5890.208.camel@twins
Add a /sys/kernel entry to indicate that the kernel is a
realtime kernel.
Clark says that he needs this for udev rules, udev needs to evaluate
if its a PREEMPT_RT kernel a few thousand times and parsing uname
output is too slow or so.
Are there better solutions? Should it exist and return 0 on !-rt?
Signed-off-by: Clark Williams <williams@redhat.com>
On 07/27/2011 04:37 PM, Thomas Gleixner wrote:
> - KGDB (not yet disabled) is reportedly unusable on -rt right now due
> to missing hacks in the console locking which I dropped on purpose.
To work around this in the short term you can use this patch, in
addition to the clocksource watchdog patch that Thomas brewed up.
Comments are welcome of course. Ultimately the right solution is to
change separation between the console and the HW to have a polled mode
+ work queue so as not to introduce any kind of latency.
Thanks,
Jason.
There are (probably rare) situations when a system crashed and the system
console becomes unresponsive but the network icmp layer still is alive.
Wouldn't it be wonderful, if we then could submit a sysreq command via ping?
This patch provides this facility. Please consult the updated documentation
Documentation/sysrq.txt for details.
Signed-off-by: Carsten Emde <C.Emde@osadl.org>
qdisc_lock is taken w/o disabling interrupts or bottom halfs. So code
holding a qdisc_lock() can be interrupted and softirqs can run on the
return of interrupt in !RT.
The spin_trylock() in net_tx_action() makes sure, that the softirq
does not deadlock. When the lock can't be acquired q is requeued and
the NET_TX softirq is raised. That causes the softirq to run over and
over.
That works in mainline as do_softirq() has a retry loop limit and
leaves the softirq processing in the interrupt return path and
schedules ksoftirqd. The task which holds qdisc_lock cannot be
preempted, so the lock is released and either ksoftirqd or the next
softirq in the return from interrupt path can proceed. Though it's a
bit strange to actually run MAX_SOFTIRQ_RESTART (10) loops before it
decides to bail out even if it's clear in the first iteration :)
On RT all softirq processing is done in a FIFO thread and we don't
have a loop limit, so ksoftirqd preempts the lock holder forever and
unqueues and requeues until the reset button is hit.
Due to the forced threading of ksoftirqd on RT we actually cannot
deadlock on qdisc_lock because it's a "sleeping lock". So it's safe to
replace the spin_trylock() with a spin_lock(). When contended,
ksoftirqd is scheduled out and the lock holder can proceed.
[ tglx: Massaged changelog and code comments ]
Solved-by: Thomas Gleixner <tglx@linuxtronix.de>
Tested-by: Carsten Emde <cbe@osadl.org>
Cc: Clark Williams <williams@redhat.com>
Cc: John Kacur <jkacur@redhat.com>
Cc: Luis Claudio R. Goncalves <lclaudio@redhat.com>
RT is not too happy about the shared timer interrupt in AT91
devices. Default to tclib timer for RT.
