call_console_drivers
This patch corrects a buffer overflow in kernels from 3.0 to 3.4 when calling
log_prefix() function from call_console_drivers().
This bug existed in previous releases but has been revealed with commit
162a7e7500f9664636e649ba59defe541b7c2c60 (2.6.39 => 3.0) that made changes
about how to allocate memory for early printk buffer (use of memblock_alloc).
It disappears with commit 7ff9554bb578ba02166071d2d487b7fc7d860d62 (3.4 => 3.5)
that does a refactoring of printk buffer management.
In log_prefix(), the access to "p[0]", "p[1]", "p[2]" or
"simple_strtoul(&p[1], &endp, 10)" may cause a buffer overflow as this
function is called from call_console_drivers by passing "&LOG_BUF(cur_index)"
where the index must be masked to do not exceed the buffer's boundary.
The trick is to prepare in call_console_drivers() a buffer with the necessary
data (PRI field of syslog message) to be safely evaluated in log_prefix().
This patch can be applied to stable kernel branches 3.0.y, 3.2.y and 3.4.y.
Without this patch, one can freeze a server running this loop from shell :
$ export DUMMY=`cat /dev/urandom | tr -dc '12345AZERTYUIOPQSDFGHJKLMWXCVBNazertyuiopqsdfghjklmwxcvbn' | head -c255`
$ while true do ; echo $DUMMY > /dev/kmsg ; done
The "server freeze" depends on where memblock_alloc does allocate printk buffer :
if the buffer overflow is inside another kernel allocation the problem may not
be revealed, else the server may hangs up.
Signed-off-by: Alexandre SIMON <Alexandre.Simon@univ-lorraine.fr>
commit ae1c07a6b7ced6c0c94c99e3b53f4e7856fa8bff upstream.
For some reason the reading of the RQDPC register was being artificially
limited to 4K. Instead of limiting the value we should read the value and
add the full amount. Otherwise this can lead to a misleading number of
dropped packets when the actual value is in fact much higher.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
Cc: Vinson Lee <vlee@twitter.com>
commit 1de63d60cd5b0d33a812efa455d5933bf1564a51 upstream.
There was a serious problem in samsung-laptop that its platform driver is
designed to run under BIOS and running under EFI can cause the machine to
become bricked or can cause Machine Check Exceptions.
Discussion about this problem:
https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557
https://bugzilla.kernel.org/show_bug.cgi?id=47121
The patches to fix this problem:
efi: Make 'efi_enabled' a function to query EFI facilities
83e68189745ad931c2afd45d8ee3303929233e7f
samsung-laptop: Disable on EFI hardware
e0094244e41c4d0c7ad69920681972fc45d8ce34
Unfortunately this problem comes back again if users specify "noefi" option.
This parameter clears EFI_BOOT and that driver continues to run even if running
under EFI. Refer to the document, this parameter should clear
EFI_RUNTIME_SERVICES instead.
Documentation/kernel-parameters.txt:
noefi [X86] Disable EFI runtime services support.
Documentation/x86/x86_64/uefi.txt:
- If some or all EFI runtime services don't work, you can try following
kernel command line parameters to turn off some or all EFI runtime
services.
noefi turn off all EFI runtime services
Signed-off-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com>
Link: http://lkml.kernel.org/r/511C2C04.2070108@jp.fujitsu.com
Cc: Matt Fleming <matt.fleming@intel.com>
commit 249bfb83cf8ba658955f0245ac3981d941f746ee upstream.
Devices are added to pci_pme_list when drivers use pci_enable_wake()
or pci_wake_from_d3(), but they aren't removed from the list unless
the driver explicitly disables wakeup. Many drivers never disable
wakeup, so their devices remain on the list even after they are
removed, e.g., via hotplug. A subsequent PME poll will oops when
it tries to touch the device.
This patch disables PME# on a device before removing it, which removes
the device from pci_pme_list. This is safe even if the device never
had PME# enabled.
This oops can be triggered by unplugging a Thunderbolt ethernet adapter
on a Macbook Pro, as reported by Daniel below.
[bhelgaas: changelog]
Reference: http://lkml.kernel.org/r/CAMVG2svG21yiM1wkH4_2pen2n+cr2-Zv7TbH3Gj+8MwevZjDbw@mail.gmail.com
Reported-and-tested-by: Daniel J Blueman <daniel@quora.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit 13d2b4d11d69a92574a55bfd985cfb0ca77aebdc upstream.
This fixes CVE-2013-0228 / XSA-42
Drew Jones while working on CVE-2013-0190 found that that unprivileged guest user
in 32bit PV guest can use to crash the > guest with the panic like this:
general protection fault: 0000 [#1] SMP
last sysfs file: /sys/devices/vbd-51712/block/xvda/dev
Modules linked in: sunrpc ipt_REJECT nf_conntrack_ipv4 nf_defrag_ipv4
iptable_filter ip_tables ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6
xt_state nf_conntrack ip6table_filter ip6_tables ipv6 xen_netfront ext4
mbcache jbd2 xen_blkfront dm_mirror dm_region_hash dm_log dm_mod [last
unloaded: scsi_wait_scan]
Pid: 1250, comm: r Not tainted 2.6.32-356.el6.i686 #1
EIP: 0061:[<c0407462>] EFLAGS: 00010086 CPU: 0
EIP is at xen_iret+0x12/0x2b
EAX: eb8d0000 EBX: 00000001 ECX: 08049860 EDX: 00000010
ESI: 00000000 EDI: 003d0f00 EBP: b77f8388 ESP: eb8d1fe0
DS: 0000 ES: 007b FS: 0000 GS: 00e0 SS: 0069
Process r (pid: 1250, ti=eb8d0000 task=c2953550 task.ti=eb8d0000)
Stack:
00000000 0027f416 00000073 00000206 b77f8364 0000007b 00000000 00000000
Call Trace:
Code: c3 8b 44 24 18 81 4c 24 38 00 02 00 00 8d 64 24 30 e9 03 00 00 00
8d 76 00 f7 44 24 08 00 00 02 80 75 33 50 b8 00 e0 ff ff 21 e0 <8b> 40
10 8b 04 85 a0 f6 ab c0 8b 80 0c b0 b3 c0 f6 44 24 0d 02
EIP: [<c0407462>] xen_iret+0x12/0x2b SS:ESP 0069:eb8d1fe0
general protection fault: 0000 [#2]
---[ end trace ab0d29a492dcd330 ]---
Kernel panic - not syncing: Fatal exception
Pid: 1250, comm: r Tainted: G D ---------------
Call Trace:
[<c08476df>] ? panic+0x6e/0x122
[<c084b63c>] ? oops_end+0xbc/0xd0
[<c084b260>] ? do_general_protection+0x0/0x210
[<c084a9b7>] ? error_code+0x73/
Petr says: "
I've analysed the bug and I think that xen_iret() cannot cope with
mangled DS, in this case zeroed out (null selector/descriptor) by either
xen_failsafe_callback() or RESTORE_REGS because the corresponding LDT
entry was invalidated by the reproducer. "
Jan took a look at the preliminary patch and came up a fix that solves
this problem:
"This code gets called after all registers other than those handled by
IRET got already restored, hence a null selector in %ds or a non-null
one that got loaded from a code or read-only data descriptor would
cause a kernel mode fault (with the potential of crashing the kernel
as a whole, if panic_on_oops is set)."
The way to fix this is to realize that the we can only relay on the
registers that IRET restores. The two that are guaranteed are the
%cs and %ss as they are always fixed GDT selectors. Also they are
inaccessible from user mode - so they cannot be altered. This is
the approach taken in this patch.
Another alternative option suggested by Jan would be to relay on
the subtle realization that using the %ebp or %esp relative references uses
the %ss segment. In which case we could switch from using %eax to %ebp and
would not need the %ss over-rides. That would also require one extra
instruction to compensate for the one place where the register is used
as scaled index. However Andrew pointed out that is too subtle and if
further work was to be done in this code-path it could escape folks attention
and lead to accidents.
Reviewed-by: Petr Matousek <pmatouse@redhat.com>
Reported-by: Petr Matousek <pmatouse@redhat.com>
Reviewed-by: Andrew Cooper <andrew.cooper3@citrix.com>
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 0ee364eb316348ddf3e0dfcd986f5f13f528f821 upstream.
A user reported the following oops when a backup process reads
/proc/kcore:
BUG: unable to handle kernel paging request at ffffbb00ff33b000
IP: [<ffffffff8103157e>] kern_addr_valid+0xbe/0x110
Call Trace:
[<ffffffff811b8aaa>] read_kcore+0x17a/0x370
[<ffffffff811ad847>] proc_reg_read+0x77/0xc0
[<ffffffff81151687>] vfs_read+0xc7/0x130
[<ffffffff811517f3>] sys_read+0x53/0xa0
[<ffffffff81449692>] system_call_fastpath+0x16/0x1b
Investigation determined that the bug triggered when reading
system RAM at the 4G mark. On this system, that was the first
address using 1G pages for the virt->phys direct mapping so the
PUD is pointing to a physical address, not a PMD page.
The problem is that the page table walker in kern_addr_valid() is
not checking pud_large() and treats the physical address as if
it was a PMD. If it happens to look like pmd_none then it'll
silently fail, probably returning zeros instead of real data. If
the data happens to look like a present PMD though, it will be
walked resulting in the oops above.
This patch adds the necessary pud_large() check.
Unfortunately the problem was not readily reproducible and now
they are running the backup program without accessing
/proc/kcore so the patch has not been validated but I think it
makes sense.
Reviewed-by: Rik van Riel <riel@redhat.coM>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/20130211145236.GX21389@suse.de
commit cb214ede7657db458fd0b2a25ea0b28dbf900ebc upstream.
When a HP ProLiant DL980 G7 Server boots a regular kernel,
there will be intermittent lost interrupts which could
result in a hang or (in extreme cases) data loss.
The reason is that this system only supports x2apic physical
mode, while the kernel boots with a logical-cluster default
setting.
This bug can be worked around by specifying the "x2apic_phys" or
"nox2apic" boot option, but we want to handle this system
without requiring manual workarounds.
The BIOS sets ACPI_FADT_APIC_PHYSICAL in FADT table.
As all apicids are smaller than 255, BIOS need to pass the
control to the OS with xapic mode, according to x2apic-spec,
chapter 2.9.
Current code handle x2apic when BIOS pass with xapic mode
enabled:
When user specifies x2apic_phys, or FADT indicates PHYSICAL:
1. During madt oem check, apic driver is set with xapic logical
or xapic phys driver at first.
2. enable_IR_x2apic() will enable x2apic_mode.
3. if user specifies x2apic_phys on the boot line, x2apic_phys_probe()
will install the correct x2apic phys driver and use x2apic phys mode.
Otherwise it will skip the driver will let x2apic_cluster_probe to
take over to install x2apic cluster driver (wrong one) even though FADT
indicates PHYSICAL, because x2apic_phys_probe does not check
FADT PHYSICAL.
Add checking x2apic_fadt_phys in x2apic_phys_probe() to fix the
problem.
Signed-off-by: Stoney Wang <song-bo.wang@hp.com>
[ updated the changelog and simplified the code ]
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Link: http://lkml.kernel.org/r/1360263182-16226-1-git-send-email-yinghai@kernel.org
commit e575a86fdc50d013bf3ad3aa81d9100e8e6cc60d upstream.
Without this patch, it is trivial to determine kernel page
mappings by examining the error code reported to dmesg[1].
Instead, declare the entire kernel memory space as a violation
of a present page.
Additionally, since show_unhandled_signals is enabled by
default, switch branch hinting to the more realistic
expectation, and unobfuscate the setting of the PF_PROT bit to
improve readability.
[1] http://vulnfactory.org/blog/2013/02/06/a-linux-memory-trick/
Reported-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
Suggested-by: Brad Spengler <spender@grsecurity.net>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Link: http://lkml.kernel.org/r/20130207174413.GA12485@www.outflux.net
commit d911e03d097bdc01363df5d81c43f69432eb785c upstream.
Since ed4f209 "s390/time: fix sched_clock() overflow" a new helper function
is used to avoid overflows when converting TOD format values to nanosecond
values.
The kvm interrupt code formerly however only worked by accident because of
an overflow. It tried to program a timer that would expire in more than ~29
years. Because of the old TOD-to-nanoseconds overflow bug the real expiry
value however was much smaller, but now it isn't anymore.
This however triggers yet another bug in the function that programs the clock
comparator s390_next_ktime(): if the absolute "expires" value is after 2042
this will result in an overflow and the programmed value is lower than the
current TOD value which immediatly triggers a clock comparator (= timer)
interrupt.
Since the timer isn't expired it will be programmed immediately again and so
on... the result is a dead system.
To fix this simply program the maximum possible value if an overflow is
detected.
Reported-by: Christian Borntraeger <borntraeger@de.ibm.com>
Tested-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit 93040ae5cc8dcc893eca4a4366dc8415af278edf upstream.
Fixed spelling error in a comment as pointed out by DaveM.
Also refactored existing code a bit to provide placeholders for another ASIC
Bug workaround that will be checked-in soon after this.
Signed-off-by: Somnath Kotur <somnath.kotur@emulex.com>
Cc: Jacek Luczak <difrost.kernel@gmail.com>
[ Upstream commit daf3ec688e057f6060fb9bb0819feac7a8bbf45c ]
TG3_PHY_AUXCTL_SMDSP_ENABLE/DISABLE macros do a blind write to the phy
auxiliary control register and overwrite the EXT_PKT_LEN (bit 14) resulting
in intermittent crc errors on jumbo frames with some link partners. Change
the code to do a read/modify/write.
Signed-off-by: Nithin Nayak Sujir <nsujir@broadcom.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
[ Upstream commit 9c13cb8bb477a83b9a3c9e5a5478a4e21294a760 ]
When netconsole is enabled, logging messages generated during tg3_open
can result in a null pointer dereference for the uninitialized tg3
status block. Use the irq_sync flag to disable polling in the early
stages. irq_sync is cleared when the driver is enabling interrupts after
all initialization is completed.
[ Upstream commit 6caab7b0544e83e6c160b5e80f5a4a7dd69545c7 ]
If lower layer driver leaves the ip header in the skb fragment, it needs to
be first pulled into skb->data before inspecting ip header length or ip version
number.
Signed-off-by: Sarveshwar Bandi <sarveshwar.bandi@emulex.com>
[ Upstream commit 6731d2095bd4aef18027c72ef845ab1087c3ba63 ]
There are transients during normal FRTO procedure during which
the packets_in_flight can go to zero between write_queue state
updates and firing the resulting segments out. As FRTO processing
occurs during that window the check must be more precise to
not match "spuriously" :-). More specificly, e.g., when
packets_in_flight is zero but FLAG_DATA_ACKED is true the problematic
branch that set cwnd into zero would not be taken and new segments
might be sent out later.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Tested-by: Eric Dumazet <edumazet@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 2e5f421211ff76c17130b4597bc06df4eeead24f ]
Commit 9dc274151a548 (tcp: fix ABC in tcp_slow_start())
uncovered a bug in FRTO code :
tcp_process_frto() is setting snd_cwnd to 0 if the number
of in flight packets is 0.
As Neal pointed out, if no packet is in flight we lost our
chance to disambiguate whether a loss timeout was spurious.
We should assume it was a proper loss.
Reported-by: Pasi Kärkkäinen <pasik@iki.fi>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Cc: Yuchung Cheng <ycheng@google.com>
[ Upstream commit b9149729ebdcfce63f853aa54a404c6a8f6ebbf3 ]
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Acked-by: Jan Beulich <JBeulich@suse.com>
[ Upstream commit 4cc7c1cb7b11b6f3515bd9075527576a1eecc4aa ]
[ Upstream commit 7d5145d8eb2b9791533ffe4dc003b129b9696c48 ]
Signed-off-by: Matthew Daley <mattjd@gmail.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
[ Upstream commit 48856286b64e4b66ec62b94e504d0b29c1ade664 ]
A buggy or malicious frontend should not be able to confuse netback.
If we spot anything which is not as it should be then shutdown the
device and don't try to continue with the ring in a potentially
hostile state. Well behaved and non-hostile frontends will not be
penalised.
As well as making the existing checks for such errors fatal also add a
new check that ensures that there isn't an insane number of requests
on the ring (i.e. more than would fit in the ring). If the ring
contains garbage then previously is was possible to loop over this
insane number, getting an error each time and therefore not generating
any more pending requests and therefore not exiting the loop in
xen_netbk_tx_build_gops for an externded period.
Also turn various netdev_dbg calls which no precipitate a fatal error
into netdev_err, they are rate limited because the device is shutdown
afterwards.
This fixes at least one known DoS/softlockup of the backend domain.
[ Upstream commit b5c37fe6e24eec194bb29d22fdd55d73bcc709bf ]
On sctp_endpoint_destroy, previously used sensitive keying material
should be zeroed out before the memory is returned, as we already do
with e.g. auth keys when released.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Vlad Yasevich <vyasevic@redhat.com>
[ Upstream commit 6ba542a291a5e558603ac51cda9bded347ce7627 ]
In sctp_setsockopt_auth_key, we create a temporary copy of the user
passed shared auth key for the endpoint or association and after
internal setup, we free it right away. Since it's sensitive data, we
should zero out the key before returning the memory back to the
allocator. Thus, use kzfree instead of kfree, just as we do in
sctp_auth_key_put().
[ Upstream commit 2f94aabd9f6c925d77aecb3ff020f1cc12ed8f86 ]
Jamie Parsons reported a problem recently, in which the re-initalization of an
association (The duplicate init case), resulted in a loss of receive window
space. He tracked down the root cause to sctp_outq_teardown, which discarded
all the data on an outq during a re-initalization of the corresponding
association, but never reset the outq->outstanding_data field to zero. I wrote,
and he tested this fix, which does a proper full re-initalization of the outq,
fixing this problem, and hopefully future proofing us from simmilar issues down
the road.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: Jamie Parsons <Jamie.Parsons@metaswitch.com>
Tested-by: Jamie Parsons <Jamie.Parsons@metaswitch.com>
CC: Jamie Parsons <Jamie.Parsons@metaswitch.com>
CC: Vlad Yasevich <vyasevich@gmail.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: netdev@vger.kernel.org
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit ab54ee80aa7585f9666ff4dd665441d7ce41f1e8 ]
We have conflicting type qualifiers for "freg_t" in s390's ptrace.h and the
iphase atm device driver, which causes the compile error below.
Unfortunately the s390 typedef can't be renamed, since it's a user visible api,
nor can I change the include order in s390 code to avoid the conflict.
So simply rename the iphase typedef to a new name. Fixes this compile error:
In file included from drivers/atm/iphase.c:66:0:
drivers/atm/iphase.h:639:25: error: conflicting type qualifiers for 'freg_t'
In file included from next/arch/s390/include/asm/ptrace.h:9:0,
from next/arch/s390/include/asm/lowcore.h:12,
from next/arch/s390/include/asm/thread_info.h:30,
from include/linux/thread_info.h:54,
from include/linux/preempt.h:9,
from include/linux/spinlock.h:50,
from include/linux/seqlock.h:29,
from include/linux/time.h:5,
from include/linux/stat.h:18,
from include/linux/module.h:10,
from drivers/atm/iphase.c:43:
next/arch/s390/include/uapi/asm/ptrace.h:197:3: note: previous declaration of 'freg_t' was here
Acked-by: chas williams - CONTRACTOR <chas@cmf.nrl.navy.mil>
[ Upstream commit 9665d5d62487e8e7b1f546c00e11107155384b9a ]
When releasing a packet socket, the routine packet_set_ring() is reused
to free rings instead of allocating them. But when calling it for the
first time, it fills req->tp_block_nr with the value of rb->pg_vec_len
which in the second invocation makes it bail out since req->tp_block_nr
is greater zero but req->tp_block_size is zero.
This patch solves the problem by passing a zeroed auto-variable to
packet_set_ring() upon each invocation from packet_release().
As far as I can tell, this issue exists even since 69e3c75 (net: TX_RING
and packet mmap), i.e. the original inclusion of TX ring support into
af_packet, but applies only to sockets with both RX and TX ring
allocated, which is probably why this was unnoticed all the time.
Signed-off-by: Phil Sutter <phil.sutter@viprinet.com>
Cc: Johann Baudy <johann.baudy@gnu-log.net>
Cc: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Daniel Borkmann <dborkman@redhat.com>
[ Upstream commit 559bcac35facfed49ab4f408e162971612dcfdf3 ]
1) rhine_tx() should use dev_kfree_skb() not dev_kfree_skb_irq()
2) rhine_slow_event_task's NAPI triggering logic is racey, it
should just hit the interrupt mask register. This is the
same as commit 7dbb491878a2c51d372a8890fa45a8ff80358af1
("r8169: avoid NAPI scheduling delay.") made to fix the same
problem in the r8169 driver. From Francois Romieu.
Reported-by: Jamie Gloudon <jamie.gloudon@gmail.com>
Tested-by: Jamie Gloudon <jamie.gloudon@gmail.com>
[ Upstream commit bd30e947207e2ea0ff2c08f5b4a03025ddce48d3 ]
They will be created at output, if ever needed. This avoids creating
empty neighbor entries when TPROXYing/Forwarding packets for addresses
that are not even directly reachable.
Note that IPv4 already handles it this way. No neighbor entries are
created for local input.
Tested by myself and customer.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
[ Upstream commit 604dfd6efc9b79bce432f2394791708d8e8f6efc ]
The return value of pktgen_add_device() is not checked, so
even if we fail to add some device, for example, non-exist one,
we still see "OK:...". This patch fixes it.
After this patch, I got:
# echo "add_device non-exist" > /proc/net/pktgen/kpktgend_0
-bash: echo: write error: No such device
# cat /proc/net/pktgen/kpktgend_0
Running:
Stopped:
Result: ERROR: can not add device non-exist
# echo "add_device eth0" > /proc/net/pktgen/kpktgend_0
Running:
Stopped: eth0
Result: OK: add_device=eth0
(Candidate for -stable)
Signed-off-by: Cong Wang <amwang@redhat.com>
[ Upstream commit 794ed393b707f01858f5ebe2ae5eabaf89d00022 ]
Ben Greear reported crashes in ip_rcv_finish() on a stress
test involving many macvlans.
We tracked the bug to a dst use after free. ip_rcv_finish()
was calling dst->input() and got garbage for dst->input value.
It appears the bug is in loopback driver, lacking
a skb_dst_force() before calling netif_rx().
As a result, a non refcounted dst, normally protected by a
RCU read_lock section, was escaping this section and could
be freed before the packet being processed.
[<ffffffff813a3c4d>] loopback_xmit+0x64/0x83
[<ffffffff81477364>] dev_hard_start_xmit+0x26c/0x35e
[<ffffffff8147771a>] dev_queue_xmit+0x2c4/0x37c
[<ffffffff81477456>] ? dev_hard_start_xmit+0x35e/0x35e
[<ffffffff8148cfa6>] ? eth_header+0x28/0xb6
[<ffffffff81480f09>] neigh_resolve_output+0x176/0x1a7
[<ffffffff814ad835>] ip_finish_output2+0x297/0x30d
[<ffffffff814ad6d5>] ? ip_finish_output2+0x137/0x30d
[<ffffffff814ad90e>] ip_finish_output+0x63/0x68
[<ffffffff814ae412>] ip_output+0x61/0x67
[<ffffffff814ab904>] dst_output+0x17/0x1b
[<ffffffff814adb6d>] ip_local_out+0x1e/0x23
[<ffffffff814ae1c4>] ip_queue_xmit+0x315/0x353
[<ffffffff814adeaf>] ? ip_send_unicast_reply+0x2cc/0x2cc
[<ffffffff814c018f>] tcp_transmit_skb+0x7ca/0x80b
[<ffffffff814c3571>] tcp_connect+0x53c/0x587
[<ffffffff810c2f0c>] ? getnstimeofday+0x44/0x7d
[<ffffffff810c2f56>] ? ktime_get_real+0x11/0x3e
[<ffffffff814c6f9b>] tcp_v4_connect+0x3c2/0x431
[<ffffffff814d6913>] __inet_stream_connect+0x84/0x287
[<ffffffff814d6b38>] ? inet_stream_connect+0x22/0x49
[<ffffffff8108d695>] ? _local_bh_enable_ip+0x84/0x9f
[<ffffffff8108d6c8>] ? local_bh_enable+0xd/0x11
[<ffffffff8146763c>] ? lock_sock_nested+0x6e/0x79
[<ffffffff814d6b49>] inet_stream_connect+0x33/0x49
[<ffffffff814632c6>] sys_connect+0x75/0x98
This bug was introduced in linux-2.6.35, in commit
7fee226ad2397b (net: add a noref bit on skb dst)
skb_dst_force() is enforced in dev_queue_xmit() for devices having a
qdisc.
Reported-by: Ben Greear <greearb@candelatech.com>
Tested-by: Ben Greear <greearb@candelatech.com>
[ Upstream commit 5d0feaff230c0abfe4a112e6f09f096ed99e0b2d ]
This was introduced in commit 6dccd16 "r8169: merge with version
6.001.00 of Realtek's r8169 driver". I did not find the version
6.001.00 online, but in 6.002.00 or any later r8169 from Realtek
this hunk is no longer present.
Also commit 05af214 "r8169: fix Ethernet Hangup for RTL8110SC
rev d" claims to have fixed this issue otherwise.
The magic compare mask of 0xfffe000 is dubious as it masks
parts of the Reserved part, and parts of the VLAN tag. But this
does not make much sense as the VLAN tag parts are perfectly
valid there. In matter of fact this seems to be triggered with
any VLAN tagged packet as RxVlanTag bit is matched. I would
suspect 0xfffe0000 was intended to test reserved part only.
Finally, this hunk is evil as it can cause more packets to be
handled than what was NAPI quota causing net/core/dev.c:
net_rx_action(): WARN_ON_ONCE(work > weight) to trigger, and
mess up the NAPI state causing device to hang.
As result, any system using VLANs and having high receive
traffic (so that NAPI poll budget limits rtl_rx) would result
in device hang.
Signed-off-by: Timo Teräs <timo.teras@iki.fi>
Acked-by: Francois Romieu <romieu@fr.zoreil.com>
[ Upstream commit a05948f296ce103989b28a2606e47d2e287c3c89 ]
Christoph Paasch found netxen could trigger a BUG in its dismantle
phase, in netxen_release_tx_buffer(), using full size TSO packets.
cmd_buf->frag_count includes the skb->data part, so the loop must
start at index 1 instead of 0, or else we can make an out
of bound access to cmd_buff->frag_array[MAX_SKB_FRAGS + 2]
Christoph provided the fixes in netxen_map_tx_skb() function.
In case of a dma mapping error, its better to clear the dma fields
so that we don't try to unmap them again in netxen_release_tx_buffer()
Reported-by: Christoph Paasch <christoph.paasch@uclouvain.be>
Tested-by: Christoph Paasch <christoph.paasch@uclouvain.be>
Cc: Sony Chacko <sony.chacko@qlogic.com>
Cc: Rajesh Borundia <rajesh.borundia@qlogic.com>
Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be>
[ Upstream commit d721a1752ba544df8d7d36959038b26bc92bdf80 ]
If subtracting 12 from l leaves zero we'd do a zero size allocation,
leading to an oops later when we try to set the NUL terminator.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Tilman Schmidt <tilman@imap.cc>
[ Upstream commit ca4c7b35f75492de7fbf5ee95be07481c348caee ]
The lines
if (mlx4_is_mfunc(dev)) {
nreq = 2;
} else {
which hard code the number of requested msi-x vectors under multi-function
mode to two can be removed completely, since the firmware sets num_eqs and
reserved_eqs appropriately Thus, the code line:
nreq = min_t(int, dev->caps.num_eqs - dev->caps.reserved_eqs, nreq);
is by itself sufficient and correct for all cases. Currently, for mfunc
mode num_eqs = 32 and reserved_eqs = 28, hence four vectors will be enabled.
This triples (one vector is used for the async events and commands EQ) the
horse power provided for processing of incoming packets on netdev RSS scheme,
IO initiators/targets commands processing flows, etc.
Reviewed-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Amir Vadai <amirv@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
[ Upstream commit 213815a1e6ae70b9648483b110bc5081795f99e8 ]
Commit 5b4c4d36860e "mlx4_en: Allow communication between functions on
same host" introduced a regression under which a bridge acting as vSwitch
whose uplink is an mlx4 Ethernet device become non-operative in native
(non sriov) mode. This happens since broadcast ARP requests sent by VMs
were loopback-ed by the HW and hence the bridge learned VM source MACs
on both the VM and the uplink ports.
The fix is to place the DMAC in the send WQE only under SRIOV/eSwitch
configuration or when the device is in selftest.
Reviewed-by: Or Gerlitz <ogerlitz@mellanox.com>
Signed-off-by: Yan Burman <yanb@mellanox.com>
[ Upstream commit d6fb3be544b46a7611a3373fcaa62b5b0be01888 ]
The xgmac driver assumes 1 frame per descriptor. If a frame larger than
the descriptor's buffer size is received, the frame will spill over into
the next descriptor. So check for received frames that span more than one
descriptor and discard them. This prevents a crash if we receive erroneous
large packets.
Cc: netdev@vger.kernel.org
[ Upstream commit 7efdba5bd9a2f3e2059beeb45c9fa55eefe1bced ]
Commit 299b0767 (ipv6: Fix IPsec slowpath fragmentation problem)
has introduced a error in the header length calculation that
provokes corrupted packets when non-fragmentable extensions
headers (Destination Option or Routing Header Type 2) are used.
rt->rt6i_nfheader_len is the length of the non-fragmentable
extension header, and it should be substracted to
rt->dst.header_len, and not to exthdrlen, as it was done before
commit 299b0767.
This patch reverts to the original and correct behavior. It has
been successfully tested with and without IPsec on packets
that include non-fragmentable extensions headers.
Signed-off-by: Romain Kuntz <r.kuntz@ipflavors.com>
Acked-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit adbbf69d1a54abf424e91875746a610dcc80017d ]
I changed my email because the vyatta.com mail server is now
redirected to brocade.com; and the Brocade mail system
is not friendly to Linux desktop users.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
[ Upstream commit 85da53bf1c336bb07ac038fb951403ab0478d2c5 ]
The tests on the flags in addrconf_get_prefix_route() does no make
much sense: the 'noflags' parameter contains the set of flags that
must not match with the route flags, so the test must be done
against 'noflags', and not against 'flags'.
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
[ Upstream commit c9be4a5c49cf51cc70a993f004c5bb30067a65ce ]
A regression is introduced by the following commit:
commit 4d52cfbef6266092d535237ba5a4b981458ab171
Author: Eric Dumazet <eric.dumazet@gmail.com>
Date: Tue Jun 2 00:42:16 2009 -0700
net: ipv4/ip_sockglue.c cleanups
Pure cleanups
but it is not a pure cleanup...
- if (val != -1 && (val < 1 || val>255))
+ if (val != -1 && (val < 0 || val > 255))
Since there is no reason provided to allow ttl=0, change it back.
Reported-by: nitin padalia <padalia.nitin@gmail.com>
Cc: nitin padalia <padalia.nitin@gmail.com>
commit e0094244e41c4d0c7ad69920681972fc45d8ce34 upstream.
It has been reported that running this driver on some Samsung laptops
with EFI can cause those machines to become bricked as detailed in the
following report,
There have also been reports of this driver causing Machine Check
Exceptions on recent EFI-enabled Samsung laptops,
So disable it if booting from EFI since this driver relies on
grovelling around in the BIOS memory map which isn't going to work.
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Cc: Corentin Chary <corentincj@iksaif.net>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Colin Ian King <colin.king@canonical.com>
Cc: Steve Langasek <steve.langasek@canonical.com>
commit 83e68189745ad931c2afd45d8ee3303929233e7f upstream.
Originally 'efi_enabled' indicated whether a kernel was booted from
EFI firmware. Over time its semantics have changed, and it now
indicates whether or not we are booted on an EFI machine with
bit-native firmware, e.g. 64-bit kernel with 64-bit firmware.
The immediate motivation for this patch is the bug report at,
which details how running a platform driver on an EFI machine that is
designed to run under BIOS can cause the machine to become
bricked. Also, the following report,
details how running said driver can also cause Machine Check
Exceptions. Drivers need a new means of detecting whether they're
running on an EFI machine, as sadly the expression,
if (!efi_enabled)
hasn't been a sufficient condition for quite some time.
Users actually want to query 'efi_enabled' for different reasons -
what they really want access to is the list of available EFI
facilities.
For instance, the x86 reboot code needs to know whether it can invoke
the ResetSystem() function provided by the EFI runtime services, while
the ACPI OSL code wants to know whether the EFI config tables were
mapped successfully. There are also checks in some of the platform
driver code to simply see if they're running on an EFI machine (which
would make it a bad idea to do BIOS-y things).
This patch is a prereq for the samsung-laptop fix patch.
Cc: David Airlie <airlied@linux.ie>
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Olof Johansson <olof@lixom.net>
Cc: Peter Jones <pjones@redhat.com>
Cc: Konrad Rzeszutek Wilk <konrad@kernel.org>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
commit 8cf9fa1240229cbdd888236c0c43fcbad680cf00 upstream.
The conn->smp_chan pointer can be NULL if SMP PDUs arrive at unexpected
moments. To avoid NULL pointer dereferences the code should be checking
for this and disconnect if an unexpected SMP PDU arrives. This patch
fixes the issue by adding a check for conn->smp_chan for all other PDUs
except pairing request and security request (which are are the first
PDUs to come to initialize the SMP context).
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit 4965f5667f36a95b41cda6638875bc992bd7d18b upstream.
Using a recursive call add a non-conflicting region in
__reserve_region_with_split() could result in a stack overflow in the case
that the recursive calls are too deep. Convert the recursive calls to an
iterative loop to avoid the problem.
Tested on a machine containing 135 regions. The kernel no longer panicked
with stack overflow.
Also tested with code arbitrarily adding regions with no conflict,
embedding two consecutive conflicts and embedding two non-consecutive
conflicts.
Signed-off-by: T Makphaibulchoke <tmac@hp.com>
Reviewed-by: Ram Pai <linuxram@us.ibm.com>
Cc: Paul Gortmaker <paul.gortmaker@gmail.com>
Cc: Wei Yang <weiyang@linux.vnet.ibm.com>
Cc: Jiri Slaby <jslaby@suse.cz>
commit aded024a12b32fc1ed9a80639681daae2d07ec25 upstream.
Don't access uninitialized work-queue when removing device.
The work queue is initialized only if the device multi-queue.
So don't call cancel_work unless this is a multi-queue device.
This fixes the following panic:
Kernel panic - not syncing: BUG!
Call Trace:
62031b28: [<6026085d>] panic+0x16b/0x2d3
62031b30: [<6004ef5e>] flush_work+0x0/0x1d7
62031b60: [<602606f2>] panic+0x0/0x2d3
62031b68: [<600333b0>] memcpy+0x0/0x140
62031b80: [<6002d58a>] unblock_signals+0x0/0x84
62031ba0: [<602609c5>] printk+0x0/0xa0
62031bd8: [<60264e51>] __mutex_unlock_slowpath+0x13d/0x148
62031c10: [<6004ef5e>] flush_work+0x0/0x1d7
62031c18: [<60050234>] try_to_grab_pending+0x0/0x17e
62031c38: [<6004e984>] get_work_gcwq+0x71/0x8f
62031c48: [<60050539>] __cancel_work_timer+0x5b/0x115
62031c78: [<628acc85>] unplug_port+0x0/0x191 [virtio_console]
62031c98: [<6005061c>] cancel_work_sync+0x12/0x14
62031ca8: [<628ace96>] virtcons_remove+0x80/0x15c [virtio_console]
62031ce8: [<628191de>] virtio_dev_remove+0x1e/0x7e [virtio]
62031d08: [<601cf242>] __device_release_driver+0x75/0xe4
62031d28: [<601cf2dd>] device_release_driver+0x2c/0x40
62031d48: [<601ce0dd>] driver_unbind+0x7d/0xc6
62031d88: [<601cd5d9>] drv_attr_store+0x27/0x29
62031d98: [<60115f61>] sysfs_write_file+0x100/0x14d
62031df8: [<600b737d>] vfs_write+0xcb/0x184
62031e08: [<600b58b8>] filp_close+0x88/0x94
62031e38: [<600b7686>] sys_write+0x59/0x88
62031e88: [<6001ced1>] handle_syscall+0x5d/0x80
62031ea8: [<60030a74>] userspace+0x405/0x531
62031f08: [<600d32cc>] sys_dup+0x0/0x5e
62031f28: [<601b11d6>] strcpy+0x0/0x18
62031f38: [<600be46c>] do_execve+0x10/0x12
62031f48: [<600184c7>] run_init_process+0x43/0x45
62031fd8: [<60019a91>] new_thread_handler+0xba/0xbc
Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com>
commit a5ffbe0a1993a27072742ef7db6cf9839956fce9 upstream.
Kernel commits 41affd5 and 6539306 changed the locking in rtl_lps_leave()
from a spinlock to a mutex by doing the calls indirectly from a work queue
to reduce the time that interrupts were disabled. This change was fine for
most systems; however a scheduling while atomic bug was reported in
https://bugzilla.redhat.com/show_bug.cgi?id=903881. The backtrace indicates
that routine rtl_is_special(), which calls rtl_lps_leave() in three places
was entered in atomic context. These direct calls are replaced by putting a
request on the appropriate work queue.
Reported-and-tested-by: Nathaniel Doherty <ntdoherty@gmail.com>
Cc: Nathaniel Doherty <ntdoherty@gmail.com>
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
commit 0a06ad8e3a1cb5311b7dbafde45410aa1bce9d40 upstream.
In routine _rtl_rx_pre_process(), skb_dequeue() is called to get an skb;
however, the wrong variable name is used in subsequent calls.
Reported-by: Guenter Roeck <linux@roeck-us.net>
commit 58b2939b4d5a030eaec469d29812ab8477ee7e76 upstream.
When the xHCI driver is not available, actively switch the ports to EHCI
mode since some BIOSes leave them in xHCI mode where they would
otherwise appear dead. This was discovered on a Dell Optiplex 7010,
but it's possible other systems could be affected.
This should be backported to kernels as old as 3.0, that contain the
commit 69e848c2090aebba5698a1620604c7dccb448684 "Intel xhci: Support
EHCI/xHCI port switching."
Signed-off-by: David Moore <david.moore@gmail.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
