2013-10-05Linux 3.4.65v3.4.65Greg Kroah-Hartman
2013-10-05HID: LG: validate HID output report detailsKees Cook
commit 0fb6bd06e06792469acc15bbe427361b56ada528 upstream. A HID device could send a malicious output report that would cause the lg, lg3, and lg4 HID drivers to write beyond the output report allocation during an event, causing a heap overflow: [ 325.245240] usb 1-1: New USB device found, idVendor=046d, idProduct=c287 ... [ 414.518960] BUG kmalloc-4096 (Not tainted): Redzone overwritten Additionally, while lg2 did correctly validate the report details, it was cleaned up and shortened. CVE-2013-2893 Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05mm, memcg: give exiting processes access to memory reservesDavid Rientjes
commit 465adcf1ea7b2e49b2e0899366624f5532b64012 A memcg may livelock when oom if the process that grabs the hierarchy's oom lock is never the first process with PF_EXITING set in the memcg's task iteration. The oom killer, both global and memcg, will defer if it finds an eligible process that is in the process of exiting and it is not being ptraced. The idea is to allow it to exit without using memory reserves before needlessly killing another process. This normally works fine except in the memcg case with a large number of threads attached to the oom memcg. In this case, the memcg oom killer only gets called for the process that grabs the hierarchy's oom lock; all others end up blocked on the memcg's oom waitqueue. Thus, if the process that grabs the hierarchy's oom lock is never the first PF_EXITING process in the memcg's task iteration, the oom killer is constantly deferred without anything making progress. The fix is to give PF_EXITING processes access to memory reserves so that we've marked them as oom killed without any iteration. This allows __mem_cgroup_try_charge() to succeed so that the process may exit. This makes the memcg oom killer exemption for TIF_MEMDIE tasks, now immediately granted for processes with pending SIGKILLs and those in the exit path, to be equivalent to what is done for the global oom killer. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [Qiang: backported to 3.4: - move the changes from memcontrol.c to oom_kill.c] Signed-off-by: Qiang Huang <h.huangqiang@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05ALSA: compress: Fix compress device unregister.Liam Girdwood
commit 4028b6c4c03f213260e9290ff3a6b5439aad07ce upstream. snd_unregister_device() should return the device type and not stream direction. Signed-off-by: Liam Girdwood <liam.r.girdwood@linux.intel.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Tested-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05hwmon: (applesmc) Check key count before proceedingHenrik Rydberg
commit 5f4513864304672e6ea9eac60583eeac32e679f2 upstream. After reports from Chris and Josh Boyer of a rare crash in applesmc, Guenter pointed at the initialization problem fixed below. The patch has not been verified to fix the crash, but should be applied regardless. Reported-by: <jwboyer@fedoraproject.org> Suggested-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05drm/radeon: disable tests/benchmarks if accel is disabledAlex Deucher
commit 4a1132a023eb48cf10522d84c5908d43b612c041 upstream. The tests are only usable if the acceleration engines have been successfully initialized. Based on an initial patch from: Alex Ivanov <gnidorah@p0n4ik.tk> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05drm/i915/dp: increase i2c-over-aux retry interval on AUX DEFERJani Nikula
commit 8d16f258217f2f583af1fd57c5144aa4bbe73e48 upstream. There is no clear cut rules or specs for the retry interval, as there are many factors that affect overall response time. Increase the interval, and even more so on branch devices which may have limited i2c bit rates. Signed-off-by: Jani Nikula <jani.nikula@intel.com> Reference: https://bugs.freedesktop.org/show_bug.cgi?id=60263 Tested-by: Nicolas Suzor <nic@suzor.com> Reviewed-by: Todd Previte <tprevite@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05dm-snapshot: fix performance degradation due to small hash sizeMikulas Patocka
commit 60e356f381954d79088d0455e357db48cfdd6857 upstream. LVM2, since version 2.02.96, creates origin with zero size, then loads the snapshot driver and then loads the origin. Consequently, the snapshot driver sees the origin size zero and sets the hash size to the lower bound 64. Such small hash table causes performance degradation. This patch changes it so that the hash size is determined by the size of snapshot volume, not minimum of origin and snapshot size. It doesn't make sense to set the snapshot size significantly larger than the origin size, so we do not need to take origin size into account when calculating the hash size. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05dm snapshot: workaround for a false positive lockdep warningMikulas Patocka
commit 5ea330a75bd86b2b2a01d7b85c516983238306fb upstream. The kernel reports a lockdep warning if a snapshot is invalidated because it runs out of space. The lockdep warning was triggered by commit 0976dfc1d0cd80a4e9dfaf87bd87 ("workqueue: Catch more locking problems with flush_work()") in v3.5. The warning is false positive. The real cause for the warning is that the lockdep engine treats different instances of md->lock as a single lock. This patch is a workaround - we use flush_workqueue instead of flush_work. This code path is not performance sensitive (it is called only on initialization or invalidation), thus it doesn't matter that we flush the whole workqueue. The real fix for the problem would be to teach the lockdep engine to treat different instances of md->lock as separate locks. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Acked-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05usb/core/devio.c: Don't reject control message to endpoint with wrong ↵Kurt Garloff
direction bit commit 831abf76643555a99b80a3b54adfa7e4fa0a3259 upstream. Trying to read data from the Pegasus Technologies NoteTaker (0e20:0101) [1] with the Windows App (EasyNote) works natively but fails when Windows is running under KVM (and the USB device handed to KVM). The reason is a USB control message usb 4-2.2: control urb: bRequestType=22 bRequest=09 wValue=0200 wIndex=0001 wLength=0008 This goes to endpoint address 0x01 (wIndex); however, endpoint address 0x01 does not exist. There is an endpoint 0x81 though (same number, but other direction); the app may have meant that endpoint instead. The kernel thus rejects the IO and thus we see the failure. Apparently, Linux is more strict here than Windows ... we can't change the Win app easily, so that's a problem. It seems that the Win app/driver is buggy here and the driver does not behave fully according to the USB HID class spec that it claims to belong to. The device seems to happily deal with that though (and seems to not really care about this value much). So the question is whether the Linux kernel should filter here. Rejecting has the risk that somewhat non-compliant userspace apps/ drivers (most likely in a virtual machine) are prevented from working. Not rejecting has the risk of confusing an overly sensitive device with such a transfer. Given the fact that Windows does not filter it makes this risk rather small though. The patch makes the kernel more tolerant: If the endpoint address in wIndex does not exist, but an endpoint with toggled direction bit does, it will let the transfer through. (It does NOT change the message.) With attached patch, the app in Windows in KVM works. usb 4-2.2: check_ctrlrecip: process 13073 (qemu-kvm) requesting ep 01 but needs 81 I suspect this will mostly affect apps in virtual environments; as on Linux the apps would have been adapted to the stricter handling of the kernel. I have done that for mine[2]. [1] http://www.pegatech.com/ [2] https://sourceforge.net/projects/notetakerpen/ Signed-off-by: Kurt Garloff <kurt@garloff.de> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05xhci: Fix race between ep halt and URB cancellationFlorian Wolter
commit 526867c3ca0caa2e3e846cb993b0f961c33c2abb upstream. The halted state of a endpoint cannot be cleared over CLEAR_HALT from a user process, because the stopped_td variable was overwritten in the handle_stopped_endpoint() function. So the xhci_endpoint_reset() function will refuse the reset and communication with device can not run over this endpoint. https://bugzilla.kernel.org/show_bug.cgi?id=60699 Signed-off-by: Florian Wolter <wolly84@web.de> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05xhci: Fix oops happening after address device timeoutMathias Nyman
commit 284d20552461466b04d6bfeafeb1c47a8891b591 upstream. When a command times out, the command ring is first aborted, and then stopped. If the command ring is empty when it is stopped the stop event will point to next command which is not yet set. xHCI tries to handle this next event often causing an oops. Don't handle command completion events on stopped cmd ring if ring is empty. This patch should be backported to kernels as old as 3.7, that contain the commit b92cc66c047ff7cf587b318fe377061a353c120f "xHCI: add aborting command ring function" Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Reported-by: Giovanni <giovanni.nervi@yahoo.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05xhci: Ensure a command structure points to the correct trb on the command ringMathias Nyman
commit ec7e43e2d98173483866fe2e4e690143626b659c upstream. If a command on the command ring needs to be cancelled before it is handled it can be turned to a no-op operation when the ring is stopped. We want to store the command ring enqueue pointer in the command structure when the command in enqueued for the cancellation case. Some commands used to store the command ring dequeue pointers instead of enqueue (these often worked because enqueue happends to equal dequeue quite often) Other commands correctly used the enqueue pointer but did not check if it pointed to a valid trb or a link trb, this caused for example stop endpoint command to timeout in xhci_stop_device() in about 2% of suspend/resume cases. This should also solve some weird behavior happening in command cancellation cases. This patch is based on a patch submitted by Sarah Sharp to linux-usb, but then forgotten: http://marc.info/?l=linux-usb&m=136269803207465&w=2 This patch should be backported to kernels as old as 3.7, that contain the commit b92cc66c047ff7cf587b318fe377061a353c120f "xHCI: add aborting command ring function" Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05staging: vt6656: [BUG] main_usb.c oops on device_close move flag earlier.Malcolm Priestley
commit e3eb270fab7734427dd8171a93e4946fe28674bc upstream. The vt6656 is prone to resetting on the usb bus. It seems there is a race condition and wpa supplicant is trying to open the device via iw_handlers before its actually closed at a stage that the buffers are being removed. The device is longer considered open when the buffers are being removed. So move ~DEVICE_FLAGS_OPENED flag to before freeing the device buffers. Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05x86, efi: Don't map Boot Services on i386Josh Boyer
commit 700870119f49084da004ab588ea2b799689efaf7 upstream. Add patch to fix 32bit EFI service mapping (rhbz 726701) Multiple people are reporting hitting the following WARNING on i386, WARNING: at arch/x86/mm/ioremap.c:102 __ioremap_caller+0x3d3/0x440() Modules linked in: Pid: 0, comm: swapper Not tainted 3.9.0-rc7+ #95 Call Trace: [<c102b6af>] warn_slowpath_common+0x5f/0x80 [<c1023fb3>] ? __ioremap_caller+0x3d3/0x440 [<c1023fb3>] ? __ioremap_caller+0x3d3/0x440 [<c102b6ed>] warn_slowpath_null+0x1d/0x20 [<c1023fb3>] __ioremap_caller+0x3d3/0x440 [<c106007b>] ? get_usage_chars+0xfb/0x110 [<c102d937>] ? vprintk_emit+0x147/0x480 [<c1418593>] ? efi_enter_virtual_mode+0x1e4/0x3de [<c102406a>] ioremap_cache+0x1a/0x20 [<c1418593>] ? efi_enter_virtual_mode+0x1e4/0x3de [<c1418593>] efi_enter_virtual_mode+0x1e4/0x3de [<c1407984>] start_kernel+0x286/0x2f4 [<c1407535>] ? repair_env_string+0x51/0x51 [<c1407362>] i386_start_kernel+0x12c/0x12f Due to the workaround described in commit 916f676f8 ("x86, efi: Retain boot service code until after switching to virtual mode") EFI Boot Service regions are mapped for a period during boot. Unfortunately, with the limited size of the i386 direct kernel map it's possible that some of the Boot Service regions will not be directly accessible, which causes them to be ioremap()'d, triggering the above warning as the regions are marked as E820_RAM in the e820 memmap. There are currently only two situations where we need to map EFI Boot Service regions, 1. To workaround the firmware bug described in 916f676f8 2. To access the ACPI BGRT image but since we haven't seen an i386 implementation that requires either, this simple fix should suffice for now. [ Added to changelog - Matt ] Reported-by: Bryan O'Donoghue <bryan.odonoghue.lkml@nexus-software.ie> Acked-by: Tom Zanussi <tom.zanussi@intel.com> Acked-by: Darren Hart <dvhart@linux.intel.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05x86/reboot: Add quirk to make Dell C6100 use reboot=pci automaticallyMasoud Sharbiani
commit 4f0acd31c31f03ba42494c8baf6c0465150e2621 upstream. Dell PowerEdge C6100 machines fail to completely reboot about 20% of the time. Signed-off-by: Masoud Sharbiani <msharbiani@twitter.com> Signed-off-by: Vinson Lee <vlee@twitter.com> Cc: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Link: http://lkml.kernel.org/r/1379717947-18042-1-git-send-email-vlee@freedesktop.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01Linux 3.4.64v3.4.64Greg Kroah-Hartman
2013-10-01kernel-doc: bugfix - multi-line macrosDaniel Santos
commit 654784284430bf2739985914b65e09c7c35a7273 upstream. Prior to this patch the following code breaks: /** * multiline_example - this breaks kernel-doc */ #define multiline_example( \ myparam) Producing this error: Error(somefile.h:983): cannot understand prototype: 'multiline_example( \ ' This patch fixes the issue by appending all lines ending in a blackslash (optionally followed by whitespace), removing the backslash and any whitespace after it prior to appending (just like the C pre-processor would). This fixes a break in kerel-doc introduced by the additions to rbtree.h. Signed-off-by: Daniel Santos <daniel.santos@pobox.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01sfc: Fix efx_rx_buf_offset() for recycled pagesBen Hutchings
This bug fix is only for stable branches older than 3.10. The bug was fixed upstream by commit 2768935a4660 ('sfc: reuse pages to avoid DMA mapping/unmapping costs'), but that change is totally unsuitable for stable. Commit b590ace09d51 ('sfc: Fix efx_rx_buf_offset() in the presence of swiotlb') added an explicit page_offset member to struct efx_rx_buffer, which must be set consistently with the u.page and dma_addr fields. However, it failed to add the necessary assignment in efx_resurrect_rx_buffer(). It also did not correct the calculation of efx_rx_buffer::dma_addr in efx_resurrect_rx_buffer(), which assumes that DMA-mapping a page will result in a page-aligned DMA address (exactly what swiotlb violates). Add the assignment of efx_rx_buffer::page_offset and change the calculation of dma_addr to make use of it. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01perf tools: Handle JITed code in shared memoryAndi Kleen
commit 89365e6c9ad4c0e090e4c6a4b67a3ce319381d89 upstream. Need to check for /dev/zero. Most likely more strings are missing too. Signed-off-by: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1366848182-30449-1-git-send-email-andi@firstfloor.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Vinson Lee <vlee@freedesktop.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01fanotify: dont merge permission eventsLino Sanfilippo
commit 03a1cec1f17ac1a6041996b3e40f96b5a2f90e1b upstream. Boyd Yang reported a problem for the case that multiple threads of the same thread group are waiting for a reponse for a permission event. In this case it is possible that some of the threads are never woken up, even if the response for the event has been received (see http://marc.info/?l=linux-kernel&m=131822913806350&w=2). The reason is that we are currently merging permission events if they belong to the same thread group. But we are not prepared to wake up more than one waiter for each event. We do wait_event(group->fanotify_data.access_waitq, event->response || atomic_read(&group->fanotify_data.bypass_perm)); and after that event->response = 0; which is the reason that even if we woke up all waiters for the same event some of them may see event->response being already set 0 again, then go back to sleep and block forever. With this patch we avoid that more than one thread is waiting for a response by not merging permission events for the same thread group any more. Reported-by: Boyd Yang <boyd.yang@gmail.com> Signed-off-by: Lino Sanfilippo <LinoSanfilipp@gmx.de> Signed-off-by: Eric Paris <eparis@redhat.com> Cc: Mihai Donțu <mihai.dontu@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01perf: Fix perf_cgroup_switch for sw-eventsPeter Zijlstra
commit 95cf59ea72331d0093010543b8951bb43f262cac upstream. Jiri reported that he could trigger the WARN_ON_ONCE() in perf_cgroup_switch() using sw-events. This is because sw-events share a cpuctx with multiple PMUs. Use the ->unique_pmu pointer to limit the pmu iteration to unique cpuctx instances. Reported-and-Tested-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-so7wi2zf3jjzrwcutm2mkz0j@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01perf: Clarify perf_cpu_context::active_pmu usage by renaming it to ::unique_pmuPeter Zijlstra
commit 3f1f33206c16c7b3839d71372bc2ac3f305aa802 upstream. Stephane thought the perf_cpu_context::active_pmu name confusing and suggested using 'unique_pmu' instead. This pointer is a pointer to a 'random' pmu sharing the cpuctx instance, therefore limiting a for_each_pmu loop to those where cpuctx->unique_pmu matches the pmu we get a loop over unique cpuctx instances. Suggested-by: Stephane Eranian <eranian@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-kxyjqpfj2fn9gt7kwu5ag9ks@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01cgroup: fail if monitored file and event_control are in different cgroupLi Zefan
commit f169007b2773f285e098cb84c74aac0154d65ff7 upstream. If we pass fd of memory.usage_in_bytes of cgroup A to cgroup.event_control of cgroup B, then we won't get memory usage notification from A but B! What's worse, if A and B are in different mount hierarchy, we'll end up accessing NULL pointer! Disallow this kind of invalid usage. Signed-off-by: Li Zefan <lizefan@huawei.com> Acked-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Weng Meiling <wengmeiling.weng@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01drm/radeon/atom: workaround vbios bug in transmitter table on rs880 (v2)Alex Deucher
commit 91f3a6aaf280294b07c05dfe606e6c27b7ba3c72 upstream. The OUTPUT_ENABLE action jumps past the point in the coder where the data_offset is set on certain rs780 cards. This worked previously because the OUTPUT_ENABLE action is always called immediately after the ENABLE action so the data_offset remained set. In 6f8bbaf568c7f2c497558bfd04654c0b9841ad57 (drm/radeon/atom: initialize more atom interpretor elements to 0), we explictly reset data_offset to 0 between atom calls which then caused this to fail. The fix is to just skip calling the OUTPUT_ENABLE action on the problematic chipsets. The ENABLE action does the same thing and more. Ultimately, we could probably drop the OUTPUT_ENABLE action all together on DCE3 asics. fixes: https://bugzilla.kernel.org/show_bug.cgi?id=60791 v2: only rs880 seems to be affected Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01drm/radeon: fix handling of variable sized arrays for router objectsAlex Deucher
commit fb93df1c2d8b3b1fb16d6ee9e32554e0c038815d upstream. The table has the following format: typedef struct _ATOM_SRC_DST_TABLE_FOR_ONE_OBJECT //usSrcDstTableOffset pointing to this structure { UCHAR ucNumberOfSrc; USHORT usSrcObjectID[1]; UCHAR ucNumberOfDst; USHORT usDstObjectID[1]; }ATOM_SRC_DST_TABLE_FOR_ONE_OBJECT; usSrcObjectID[] and usDstObjectID[] are variably sized, so we can't access them directly. Use pointers and update the offset appropriately when accessing the Dst members. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01drm/radeon: fix resume on some rs4xx boards (v2)Alex Deucher
commit acf88deb8ddbb73acd1c3fa32fde51af9153227f upstream. Setting MC_MISC_CNTL.GART_INDEX_REG_EN causes hangs on some boards on resume. The systems seem to work fine without touching this bit so leave it as is. v2: read-modify-write the GART_INDEX_REG_EN bit. I suspect the problem is that we are losing the other settings in the register. fixes: https://bugs.freedesktop.org/show_bug.cgi?id=52952 Reported-by: Ondrej Zary <linux@rainbow-software.org> Tested-by: Daniel Tobias <dan.g.tob@gmail.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01drm/radeon: update line buffer allocation for dce6Alex Deucher
commit 290d24576ccf1aa0373d2185cedfe262d0d4952a upstream. We need to allocate line buffer to each display when setting up the watermarks. Failure to do so can lead to a blank screen. This fixes blank screen problems on dce6 asics. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=64850 Based on an initial fix from: Jay Cornwall <jay.cornwall@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01drm/radeon: update line buffer allocation for dce4.1/5Alex Deucher
commit 0b31e02363b0db4e7931561bc6c141436e729d9f upstream. We need to allocate line buffer to each display when setting up the watermarks. Failure to do so can lead to a blank screen. This fixes blank screen problems on dce4.1/5 asics. Based on an initial fix from: Jay Cornwall <jay.cornwall@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01drm/radeon: fix endian bugs in hw i2c atom routinesAlex Deucher
commit 4543eda52113d1e2cc0e9bf416f79597e6ef1ec7 upstream. Need to swap the data fetched over i2c properly. This is the same fix as the endian fix for aux channel transactions. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01drm/radeon: fix LCD record parsingAlex Deucher
commit 95663948ba22a4be8b99acd67fbf83e86ddffba4 upstream. If the LCD table contains an EDID record, properly account for the edid size when walking through the records. This should fix error messages about unknown LCD records. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01drm/ttm: fix the tt_populated check in ttm_tt_destroy()Ben Skeggs
commit 182b17c8dc4e83aab000ce86587b6810e515da87 upstream. After a vmalloc failure in ttm_dma_tt_alloc_page_directory(), ttm_dma_tt_init() will call ttm_tt_destroy() to cleanup, and end up inside the driver's unpopulate() hook when populate() has never yet been called. On nouveau, the first issue to be hit because of this is that dma_address[] may be a NULL pointer. After working around this, ttm_pool_unpopulate() may potentially hit the same issue with the pages[] array. It seems to make more sense to avoid calling unpopulate on already unpopulated TTMs than to add checks to all the implementations. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com> Cc: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01HID: logitech-dj: validate output report detailsKees Cook
commit 297502abb32e225fb23801fcdb0e4f6f8e17099a upstream. A HID device could send a malicious output report that would cause the logitech-dj HID driver to leak kernel memory contents to the device, or trigger a NULL dereference during initialization: [ 304.424553] usb 1-1: New USB device found, idVendor=046d, idProduct=c52b ... [ 304.780467] BUG: unable to handle kernel NULL pointer dereference at 0000000000000028 [ 304.781409] IP: [<ffffffff815d50aa>] logi_dj_recv_send_report.isra.11+0x1a/0x90 CVE-2013-2895 Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01HID: zeroplus: validate output report detailsKees Cook
commit 78214e81a1bf43740ce89bb5efda78eac2f8ef83 upstream. The zeroplus HID driver was not checking the size of allocated values in fields it used. A HID device could send a malicious output report that would cause the driver to write beyond the output report allocation during initialization, causing a heap overflow: [ 1442.728680] usb 1-1: New USB device found, idVendor=0c12, idProduct=0005 ... [ 1466.243173] BUG kmalloc-192 (Tainted: G W ): Redzone overwritten CVE-2013-2889 Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01HID: provide a helper for validating hid reportsKees Cook
commit 331415ff16a12147d57d5c953f3a961b7ede348b upstream. Many drivers need to validate the characteristics of their HID report during initialization to avoid misusing the reports. This adds a common helper to perform validation of the report exisitng, the field existing, and the expected number of values within the field. Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01sched/fair: Fix small race where child->se.parent,cfs_rq might point to ↵Daisuke Nishimura
invalid ones commit 6c9a27f5da9609fca46cb2b183724531b48f71ad upstream. There is a small race between copy_process() and cgroup_attach_task() where child->se.parent,cfs_rq points to invalid (old) ones. parent doing fork() | someone moving the parent to another cgroup -------------------------------+--------------------------------------------- copy_process() + dup_task_struct() -> parent->se is copied to child->se. se.parent,cfs_rq of them point to old ones. cgroup_attach_task() + cgroup_task_migrate() -> parent->cgroup is updated. + cpu_cgroup_attach() + sched_move_task() + task_move_group_fair() +- set_task_rq() -> se.parent,cfs_rq of parent are updated. + cgroup_fork() -> parent->cgroup is copied to child->cgroup. (*1) + sched_fork() + task_fork_fair() -> se.parent,cfs_rq of child are accessed while they point to old ones. (*2) In the worst case, this bug can lead to "use-after-free" and cause a panic, because it's new cgroup's refcount that is incremented at (*1), so the old cgroup(and related data) can be freed before (*2). In fact, a panic caused by this bug was originally caught in RHEL6.4. BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff81051e3e>] sched_slice+0x6e/0xa0 [...] Call Trace: [<ffffffff81051f25>] place_entity+0x75/0xa0 [<ffffffff81056a3a>] task_fork_fair+0xaa/0x160 [<ffffffff81063c0b>] sched_fork+0x6b/0x140 [<ffffffff8106c3c2>] copy_process+0x5b2/0x1450 [<ffffffff81063b49>] ? wake_up_new_task+0xd9/0x130 [<ffffffff8106d2f4>] do_fork+0x94/0x460 [<ffffffff81072a9e>] ? sys_wait4+0xae/0x100 [<ffffffff81009598>] sys_clone+0x28/0x30 [<ffffffff8100b393>] stub_clone+0x13/0x20 [<ffffffff8100b072>] ? system_call_fastpath+0x16/0x1b Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/039601ceae06$733d3130$59b79390$@mxp.nes.nec.co.jp Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01rt2800: fix wrong TX power compensationStanislaw Gruszka
commit 6e956da2027c767859128b9bfef085cf2a8e233b upstream. We should not do temperature compensation on devices without EXTERNAL_TX_ALC bit set (called DynamicTxAgcControl on vendor driver). Such devices can have totally bogus TSSI parameters on the EEPROM, but still threaded by us as valid and result doing wrong TX power calculations. This fix inability to connect to AP on slightly longer distance on some Ralink chips/devices. Reported-and-tested-by: Fabien ADAM <id2ndr@crocobox.org> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01net: usb: cdc_ether: Use wwan interface for Telit modulesFabio Porcedda
commit 0092820407901a0b2c4e343e85f96bb7abfcded1 upstream. Signed-off-by: Fabio Porcedda <fabio.porcedda@gmail.com> Acked-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01Revert "sctp: fix call to SCTP_CMD_PROCESS_SACK in sctp_cmd_interpreter()"Greg Kroah-Hartman
This reverts commit c2f5b7507ac5d808f29287d77ee6148358d7fbfe which is commit f6e80abeab928b7c47cc1fbf53df13b4398a2bec. Michal writes: Mainline commit f6e80abe was introduced in v3.7-rc2 as a follow-up fix to commit edfee033 sctp: check src addr when processing SACK to update transport state (from v3.7-rc1) which changed the interpretation of third argument to sctp_cmd_process_sack() and sctp_outq_sack(). But as commit edfee033 has never been backported to stable branches, backport of commit f6e80abe actually breaks the code rather than fixing it. Reported-by: Michal Kubecek <mkubecek@suse.cz> Cc: Zijie Pan <zijie.pan@6wind.com> Cc: Nicolas Dichtel <nicolas.dichtel@6wind.com> Cc: Vlad Yasevich <vyasevich@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26Linux 3.4.63v3.4.63Greg Kroah-Hartman
2013-09-26fuse: invalidate inode attributes on xattr modificationAnand Avati
commit d331a415aef98717393dda0be69b7947da08eba3 upstream. Calls like setxattr and removexattr result in updation of ctime. Therefore invalidate inode attributes to force a refresh. Signed-off-by: Anand Avati <avati@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26fuse: postpone end_page_writeback() in fuse_writepage_locked()Maxim Patlasov
commit 4a4ac4eba1010ef9a804569058ab29e3450c0315 upstream. The patch fixes a race between ftruncate(2), mmap-ed write and write(2): 1) An user makes a page dirty via mmap-ed write. 2) The user performs shrinking truncate(2) intended to purge the page. 3) Before fuse_do_setattr calls truncate_pagecache, the page goes to writeback. fuse_writepage_locked fills FUSE_WRITE request and releases the original page by end_page_writeback. 4) fuse_do_setattr() completes and successfully returns. Since now, i_mutex is free. 5) Ordinary write(2) extends i_size back to cover the page. Note that fuse_send_write_pages do wait for fuse writeback, but for another page->index. 6) fuse_writepage_locked proceeds by queueing FUSE_WRITE request. fuse_send_writepage is supposed to crop inarg->size of the request, but it doesn't because i_size has already been extended back. Moving end_page_writeback to the end of fuse_writepage_locked fixes the race because now the fact that truncate_pagecache is successfully returned infers that fuse_writepage_locked has already called end_page_writeback. And this, in turn, infers that fuse_flush_writepages has already called fuse_send_writepage, and the latter used valid (shrunk) i_size. write(2) could not extend it because of i_mutex held by ftruncate(2). Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26of: Fix missing memory initialization on FDT unflatteningGrant Likely
commit 0640332e073be9207f0784df43595c0c39716e42 upstream. Any calls to dt_alloc() need to be zeroed. This is a temporary fix, but the allocation function itself needs to zero memory before returning it. This is a follow up to patch 9e4012752, "of: fdt: fix memory initialization for expanded DT" which fixed one call site but missed another. Signed-off-by: Grant Likely <grant.likely@linaro.org> Acked-by: Wladislav Wiebe <wladislav.kw@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26mmc: tmio_mmc_dma: fix PIO fallback on SDHISergei Shtylyov
commit f936f9b67b7f8c2eae01dd303a0e90bd777c4679 upstream. I'm testing SH-Mobile SDHI driver in DMA mode with a new DMA controller using 'bonnie++' and getting DMA error after which the tmio_mmc_dma.c code falls back to PIO but all commands time out after that. It turned out that the fallback code calls tmio_mmc_enable_dma() with RX/TX channels already freed and pointers to them cleared, so that the function bails out early instead of clearing the DMA bit in the CTL_DMA_ENABLE register. The regression was introduced by commit 162f43e31c5a376ec16336e5d0ac973373d54c89 (mmc: tmio: fix a deadlock). Moving tmio_mmc_enable_dma() calls to the top of the PIO fallback code in tmio_mmc_start_dma_{rx|tx}() helps. Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26drm/edid: add quirk for Medion MD30217PGAlex Deucher
commit 118bdbd86b39dbb843155054021d2c59058f1e05 upstream. This LCD monitor (1280x1024 native) has a completely bogus detailed timing (640x350@70hz). User reports that 1280x1024@60 has waves so prefer 1280x1024@75. Manufacturer: MED Model: 7b8 Serial#: 99188 Year: 2005 Week: 5 EDID Version: 1.3 Analog Display Input, Input Voltage Level: 0.700/0.700 V Sync: Separate Max Image Size [cm]: horiz.: 34 vert.: 27 Gamma: 2.50 DPMS capabilities: Off; RGB/Color Display First detailed timing is preferred mode redX: 0.645 redY: 0.348 greenX: 0.280 greenY: 0.605 blueX: 0.142 blueY: 0.071 whiteX: 0.313 whiteY: 0.329 Supported established timings: 720x400@70Hz 640x480@60Hz 640x480@72Hz 640x480@75Hz 800x600@56Hz 800x600@60Hz 800x600@72Hz 800x600@75Hz 1024x768@60Hz 1024x768@70Hz 1024x768@75Hz 1280x1024@75Hz Manufacturer's mask: 0 Supported standard timings: Supported detailed timing: clock: 25.2 MHz Image Size: 337 x 270 mm h_active: 640 h_sync: 688 h_sync_end 784 h_blank_end 800 h_border: 0 v_active: 350 v_sync: 350 v_sync_end 352 v_blanking: 449 v_border: 0 Monitor name: MD30217PG Ranges: V min: 56 V max: 76 Hz, H min: 30 H max: 83 kHz, PixClock max 145 MHz Serial No: 501099188 EDID (in hex): 00ffffffffffff0034a4b80774830100 050f010368221b962a0c55a559479b24 125054afcf00310a0101010101018180 000000000000d60980a0205e63103060 0200510e1100001e000000fc004d4433 3032313750470a202020000000fd0038 4c1e530e000a202020202020000000ff 003530313039393138380a2020200078 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reported-by: friedrich@mailstation.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26isofs: Refuse RW mount of the filesystem instead of making it ROJan Kara
commit 17b7f7cf58926844e1dd40f5eb5348d481deca6a upstream. Refuse RW mount of isofs filesystem. So far we just silently changed it to RO mount but when the media is writeable, block layer won't notice this change and thus will think device is used RW and will block eject button of the drive. That is unexpected by users because for non-writeable media eject button works just fine. Userspace mount(8) command handles this just fine and retries mounting with MS_RDONLY set so userspace shouldn't see any regression. Plus any tool mounting isofs is likely confronted with the case of read-only media where block layer already refuses to mount the filesystem without MS_RDONLY set so our behavior shouldn't be anything new for it. Reported-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26mm/huge_memory.c: fix potential NULL pointer dereferenceLibin
commit a8f531ebc33052642b4bd7b812eedf397108ce64 upstream. In collapse_huge_page() there is a race window between releasing the mmap_sem read lock and taking the mmap_sem write lock, so find_vma() may return NULL. So check the return value to avoid NULL pointer dereference. collapse_huge_page khugepaged_alloc_page up_read(&mm->mmap_sem) down_write(&mm->mmap_sem) vma = find_vma(mm, address) Signed-off-by: Libin <huawei.libin@huawei.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26memcg: fix multiple large threshold notificationsGreg Thelen
commit 2bff24a3707093c435ab3241c47dcdb5f16e432b upstream. A memory cgroup with (1) multiple threshold notifications and (2) at least one threshold >=2G was not reliable. Specifically the notifications would either not fire or would not fire in the proper order. The __mem_cgroup_threshold() signaling logic depends on keeping 64 bit thresholds in sorted order. mem_cgroup_usage_register_event() sorts them with compare_thresholds(), which returns the difference of two 64 bit thresholds as an int. If the difference is positive but has bit[31] set, then sort() treats the difference as negative and breaks sort order. This fix compares the two arbitrary 64 bit thresholds returning the classic -1, 0, 1 result. The test below sets two notifications (at 0x1000 and 0x81001000): cd /sys/fs/cgroup/memory mkdir x for x in 4096 2164264960; do cgroup_event_listener x/memory.usage_in_bytes $x | sed "s/^/$x listener:/" & done echo $$ > x/cgroup.procs anon_leaker 500M v3.11-rc7 fails to signal the 4096 event listener: Leaking... Done leaking pages. Patched v3.11-rc7 properly notifies: Leaking... 4096 listener:2013:8:31:14:13:36 Done leaking pages. The fixed bug is old. It appears to date back to the introduction of memcg threshold notifications in v2.6.34-rc1-116-g2e72b6347c94 "memcg: implement memory thresholds" Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26ocfs2: fix the end cluster offset of FIEMAPJie Liu
commit 28e8be31803b19d0d8f76216cb11b480b8a98bec upstream. Call fiemap ioctl(2) with given start offset as well as an desired mapping range should show extents if possible. However, we somehow figure out the end offset of mapping via 'mapping_end -= cpos' before iterating the extent records which would cause problems if the given fiemap length is too small to a cluster size, e.g, Cluster size 4096: debugfs.ocfs2 1.6.3 Block Size Bits: 12 Cluster Size Bits: 12 The extended fiemap test utility From David: https://gist.github.com/anonymous/6172331 # dd if=/dev/urandom of=/ocfs2/test_file bs=1M count=1000 # ./fiemap /ocfs2/test_file 4096 10 start: 4096, length: 10 File /ocfs2/test_file has 0 extents: # Logical Physical Length Flags ^^^^^ <-- No extent is shown In this case, at ocfs2_fiemap(): cpos == mapping_end == 1. Hence the loop of searching extent records was not executed at all. This patch remove the in question 'mapping_end -= cpos', and loops until the cpos is larger than the mapping_end as usual. # ./fiemap /ocfs2/test_file 4096 10 start: 4096, length: 10 File /ocfs2/test_file has 1 extents: # Logical Physical Length Flags 0: 0000000000000000 0000000056a01000 0000000006a00000 0000 Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reported-by: David Weber <wb@munzinger.de> Tested-by: David Weber <wb@munzinger.de> Cc: Sunil Mushran <sunil.mushran@gmail.com> Cc: Mark Fashen <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26intel-iommu: Fix leaks in pagetable freeingAlex Williamson
commit 3269ee0bd6686baf86630300d528500ac5b516d7 upstream. At best the current code only seems to free the leaf pagetables and the root. If you're unlucky enough to have a large gap (like any QEMU guest with more than 3G of memory), only the first chunk of leaf pagetables are freed (plus the root). This is a massive memory leak. This patch re-writes the pagetable freeing function to use a recursive algorithm and manages to not only free all the pagetables, but does it without any apparent performance loss versus the current broken version. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Joerg Roedel <joro@8bytes.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
