[ Upstream commit 9a0620133ccce9dd35c00a96405c8d80938c2cc0 ]
This changes the message_age_timer calculation to use the BPDU's max age as
opposed to the local bridge's max age. This is in accordance with section
8.6.2.3.2 Step 2 of the 802.1D-1998 sprecification.
With the current implementation, when running with very large bridge
diameters, convergance will not always occur even if a root bridge is
configured to have a longer max age.
Tested successfully on bridge diameters of ~200.
Signed-off-by: Chris Healy <cphealy@gmail.com>
[ Upstream commit 95ee62083cb6453e056562d91f597552021e6ae7 ]
Alan Chester reported an issue with IPv6 on SCTP that IPsec traffic is not
being encrypted, whereas on IPv4 it is. Setting up an AH + ESP transport
does not seem to have the desired effect:
SCTP + IPv4:
22:14:20.809645 IP (tos 0x2,ECT(0), ttl 64, id 0, offset 0, flags [DF], proto AH (51), length 116)
192.168.0.2 > 192.168.0.5: AH(spi=0x00000042,sumlen=16,seq=0x1): ESP(spi=0x00000044,seq=0x1), length 72
22:14:20.813270 IP (tos 0x2,ECT(0), ttl 64, id 0, offset 0, flags [DF], proto AH (51), length 340)
192.168.0.5 > 192.168.0.2: AH(spi=0x00000043,sumlen=16,seq=0x1):
SCTP + IPv6:
22:31:19.215029 IP6 (class 0x02, hlim 64, next-header SCTP (132) payload length: 364)
fe80::222:15ff:fe87:7fc.3333 > fe80::92e6:baff:fe0d:5a54.36767: sctp
1) [INIT ACK] [init tag: 747759530] [rwnd: 62464] [OS: 10] [MIS: 10]
Moreover, Alan says:
This problem was seen with both Racoon and Racoon2. Other people have seen
this with OpenSwan. When IPsec is configured to encrypt all upper layer
protocols the SCTP connection does not initialize. After using Wireshark to
follow packets, this is because the SCTP packet leaves Box A unencrypted and
Box B believes all upper layer protocols are to be encrypted so it drops
this packet, causing the SCTP connection to fail to initialize. When IPsec
is configured to encrypt just SCTP, the SCTP packets are observed unencrypted.
In fact, using `socat sctp6-listen:3333 -` on one end and transferring "plaintext"
string on the other end, results in cleartext on the wire where SCTP eventually
does not report any errors, thus in the latter case that Alan reports, the
non-paranoid user might think he's communicating over an encrypted transport on
SCTP although he's not (tcpdump ... -X):
0x0030: 5d70 8e1a 0003 001a 177d eb6c 0000 0000 ]p.......}.l....
0x0040: 0000 0000 706c 6169 6e74 6578 740a 0000 ....plaintext...
Only in /proc/net/xfrm_stat we can see XfrmInTmplMismatch increasing on the
receiver side. Initial follow-up analysis from Alan's bug report was done by
Alexey Dobriyan. Also thanks to Vlad Yasevich for feedback on this.
SCTP has its own implementation of sctp_v6_xmit() not calling inet6_csk_xmit().
This has the implication that it probably never really got updated along with
changes in inet6_csk_xmit() and therefore does not seem to invoke xfrm handlers.
SCTP's IPv4 xmit however, properly calls ip_queue_xmit() to do the work. Since
a call to inet6_csk_xmit() would solve this problem, but result in unecessary
route lookups, let us just use the cached flowi6 instead that we got through
sctp_v6_get_dst(). Since all SCTP packets are being sent through sctp_packet_transmit(),
we do the route lookup / flow caching in sctp_transport_route(), hold it in
tp->dst and skb_dst_set() right after that. If we would alter fl6->daddr in
sctp_v6_xmit() to np->opt->srcrt, we possibly could run into the same effect
of not having xfrm layer pick it up, hence, use fl6_update_dst() in sctp_v6_get_dst()
instead to get the correct source routed dst entry, which we assign to the skb.
Also source address routing example from 625034113 ("sctp: fix sctp to work with
ipv6 source address routing") still works with this patch! Nevertheless, in RFC5095
it is actually 'recommended' to not use that anyway due to traffic amplification [1].
So it seems we're not supposed to do that anyway in sctp_v6_xmit(). Moreover, if
we overwrite the flow destination here, the lower IPv6 layer will be unable to
put the correct destination address into IP header, as routing header is added in
ipv6_push_nfrag_opts() but then probably with wrong final destination. Things aside,
result of this patch is that we do not have any XfrmInTmplMismatch increase plus on
the wire with this patch it now looks like:
SCTP + IPv6:
08:17:47.074080 IP6 2620:52:0:102f:7a2b:cbff:fe27:1b0a > 2620:52:0:102f:213:72ff:fe32:7eba:
AH(spi=0x00005fb4,seq=0x1): ESP(spi=0x00005fb5,seq=0x1), length 72
08:17:47.074264 IP6 2620:52:0:102f:213:72ff:fe32:7eba > 2620:52:0:102f:7a2b:cbff:fe27:1b0a:
AH(spi=0x00003d54,seq=0x1): ESP(spi=0x00003d55,seq=0x1), length 296
This fixes Kernel Bugzilla 24412. This security issue seems to be present since
2.6.18 kernels. Lets just hope some big passive adversary in the wild didn't have
its fun with that. lksctp-tools IPv6 regression test suite passes as well with
this patch.
[1] http://www.secdev.org/conf/IPv6_RH_security-csw07.pdf
Reported-by: Alan Chester <alan.chester@tekelec.com>
Reported-by: Alexey Dobriyan <adobriyan@gmail.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit d0fe8c888b1fd1a2f84b9962cabcb98a70988aec ]
I've been hitting a NULL ptr deref while using netconsole because the
np->dev check and the pointer manipulation in netpoll_cleanup are done
without rtnl and the following sequence happens when having a netconsole
over a vlan and we remove the vlan while disabling the netconsole:
CPU 1 CPU2
removes vlan and calls the notifier
enters store_enabled(), calls
netdev_cleanup which checks np->dev
and then waits for rtnl
executes the netconsole netdev
release notifier making np->dev
== NULL and releases rtnl
continues to dereference a member of
np->dev which at this point is == NULL
Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com>
[ Upstream commit b86783587b3d1d552326d955acee37eac48800f1 ]
In commit 8ed781668dd49 ("flow_keys: include thoff into flow_keys for
later usage"), we missed that existing code was using nhoff as a
temporary variable that could not always contain transport header
offset.
This is not a problem for TCP/UDP because port offset (@poff)
is 0 for these protocols.
Cc: Daniel Borkmann <dborkman@redhat.com>
Cc: Nikolay Aleksandrov <nikolay@redhat.com>
Acked-by: Nikolay Aleksandrov <nikolay@redhat.com>
Acked-by: Daniel Borkmann <dborkman@redhat.com>
[ Upstream commit 88362ad8f9a6cea787420b57cc27ccacef000dbe ]
This was originally reported in [1] and posted by Neil Horman [2], he said:
Fix up a missed null pointer check in the asconf code. If we don't find
a local address, but we pass in an address length of more than 1, we may
dereference a NULL laddr pointer. Currently this can't happen, as the only
users of the function pass in the value 1 as the addrcnt parameter, but
its not hot path, and it doesn't hurt to check for NULL should that ever
be the case.
The callpath from sctp_asconf_mgmt() looks okay. But this could be triggered
from sctp_setsockopt_bindx() call with SCTP_BINDX_REM_ADDR and addrcnt > 1
while passing all possible addresses from the bind list to SCTP_BINDX_REM_ADDR
so that we do *not* find a single address in the association's bind address
list that is not in the packed array of addresses. If this happens when we
have an established association with ASCONF-capable peers, then we could get
a NULL pointer dereference as we only check for laddr == NULL && addrcnt == 1
and call later sctp_make_asconf_update_ip() with NULL laddr.
BUT: this actually won't happen as sctp_bindx_rem() will catch such a case
and return with an error earlier. As this is incredably unintuitive and error
prone, add a check to catch at least future bugs here. As Neil says, its not
hot path. Introduced by 8a07eb0a5 ("sctp: Add ASCONF operation on the
single-homed host").
[1] http://www.spinics.net/lists/linux-sctp/msg02132.html
[2] http://www.spinics.net/lists/linux-sctp/msg02133.html
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Cc: Michio Honda <micchie@sfc.wide.ad.jp>
Acked-By: Neil Horman <nhorman@tuxdriver.com>
[ Upstream commit 0c1db731bfcf3a9fd6c58132134f8b0f423552f0 ]
The indentation here implies this was meant to be a multi-line if.
Introduced several years back in commit c85c2951d4da1236e32f1858db418221e624aba5
("caif: Handle dev_queue_xmit errors.")
Signed-off-by: Dave Jones <davej@fedoraproject.org>
commit b98b8babd6e3370fadb7c6eaacb00eb2f6344a6c upstream.
This is primarily to address transmission timeout occurrences, when
multiple H/W Tx queues are being used concurrently. Because in
the priority scheduling mode the controller does not service the
Tx queues equally (but in ascending index order), Tx timeouts are
being triggered rightaway for a basic test with multiple simultaneous
connections like:
iperf -c <server_ip> -n 100M -P 8
resulting in kernel trace:
NETDEV WATCHDOG: eth1 (fsl-gianfar): transmit queue <X> timed out
WARNING: at net/sched/sch_generic.c:255
and controller reset during intense traffic, and possibly further
complications.
This patch changes the default H/W Tx scheduling setting (TXSCHED)
for multi-queue devices, from priority scheduling mode to a weighted
round robin mode with equal weights for all H/W Tx queues, and
addresses the issue above.
Signed-off-by: Claudiu Manoil <claudiu.manoil@freescale.com>
commit 58f09e00ae095e46ef9edfcf3a5fd9ccdfad065e upstream.
The arg64 struct has a hole after ->buf_size which isn't cleared. Or if
any of the calls to copy_from_user() fail then that would cause an
information leak as well.
This was assigned CVE-2013-2147.
Acked-by: Mike Miller <mike.miller@hp.com>
commit 627aad1c01da6f881e7f98d71fd928ca0c316b1a upstream.
The pciinfo struct has a two byte hole after ->dev_fn so stack
information could be leaked to the user.
commit 0fb6bd06e06792469acc15bbe427361b56ada528 upstream.
A HID device could send a malicious output report that would cause the
lg, lg3, and lg4 HID drivers to write beyond the output report allocation
during an event, causing a heap overflow:
[ 325.245240] usb 1-1: New USB device found, idVendor=046d, idProduct=c287
[ 414.518960] BUG kmalloc-4096 (Not tainted): Redzone overwritten
Additionally, while lg2 did correctly validate the report details, it was
cleaned up and shortened.
CVE-2013-2893
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit 465adcf1ea7b2e49b2e0899366624f5532b64012
A memcg may livelock when oom if the process that grabs the hierarchy's
oom lock is never the first process with PF_EXITING set in the memcg's
task iteration.
The oom killer, both global and memcg, will defer if it finds an
eligible process that is in the process of exiting and it is not being
ptraced. The idea is to allow it to exit without using memory reserves
before needlessly killing another process.
This normally works fine except in the memcg case with a large number of
threads attached to the oom memcg. In this case, the memcg oom killer
only gets called for the process that grabs the hierarchy's oom lock;
all others end up blocked on the memcg's oom waitqueue. Thus, if the
process that grabs the hierarchy's oom lock is never the first
PF_EXITING process in the memcg's task iteration, the oom killer is
constantly deferred without anything making progress.
The fix is to give PF_EXITING processes access to memory reserves so
that we've marked them as oom killed without any iteration. This allows
__mem_cgroup_try_charge() to succeed so that the process may exit. This
makes the memcg oom killer exemption for TIF_MEMDIE tasks, now
immediately granted for processes with pending SIGKILLs and those in the
exit path, to be equivalent to what is done for the global oom killer.
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
[Qiang: backported to 3.4:
- move the changes from memcontrol.c to oom_kill.c]
Signed-off-by: Qiang Huang <h.huangqiang@huawei.com>
commit 4028b6c4c03f213260e9290ff3a6b5439aad07ce upstream.
snd_unregister_device() should return the device type and not stream
direction.
Signed-off-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Acked-by: Vinod Koul <vinod.koul@intel.com>
Tested-by: Vinod Koul <vinod.koul@intel.com>
commit 5f4513864304672e6ea9eac60583eeac32e679f2 upstream.
After reports from Chris and Josh Boyer of a rare crash in applesmc,
Guenter pointed at the initialization problem fixed below. The patch
has not been verified to fix the crash, but should be applied
regardless.
Reported-by: <jwboyer@fedoraproject.org>
Suggested-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
commit 4a1132a023eb48cf10522d84c5908d43b612c041 upstream.
The tests are only usable if the acceleration engines have
been successfully initialized.
Based on an initial patch from: Alex Ivanov <gnidorah@p0n4ik.tk>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 8d16f258217f2f583af1fd57c5144aa4bbe73e48 upstream.
There is no clear cut rules or specs for the retry interval, as there
are many factors that affect overall response time. Increase the
interval, and even more so on branch devices which may have limited i2c
bit rates.
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Reference: https://bugs.freedesktop.org/show_bug.cgi?id=60263
Tested-by: Nicolas Suzor <nic@suzor.com>
Reviewed-by: Todd Previte <tprevite@gmail.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 60e356f381954d79088d0455e357db48cfdd6857 upstream.
LVM2, since version 2.02.96, creates origin with zero size, then loads
the snapshot driver and then loads the origin. Consequently, the
snapshot driver sees the origin size zero and sets the hash size to the
lower bound 64. Such small hash table causes performance degradation.
This patch changes it so that the hash size is determined by the size of
snapshot volume, not minimum of origin and snapshot size. It doesn't
make sense to set the snapshot size significantly larger than the origin
size, so we do not need to take origin size into account when
calculating the hash size.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 5ea330a75bd86b2b2a01d7b85c516983238306fb upstream.
The kernel reports a lockdep warning if a snapshot is invalidated because
it runs out of space.
The lockdep warning was triggered by commit 0976dfc1d0cd80a4e9dfaf87bd87
("workqueue: Catch more locking problems with flush_work()") in v3.5.
The warning is false positive. The real cause for the warning is that
the lockdep engine treats different instances of md->lock as a single
lock.
This patch is a workaround - we use flush_workqueue instead of flush_work.
This code path is not performance sensitive (it is called only on
initialization or invalidation), thus it doesn't matter that we flush the
whole workqueue.
The real fix for the problem would be to teach the lockdep engine to treat
different instances of md->lock as separate locks.
Acked-by: Alasdair G Kergon <agk@redhat.com>
direction bit
commit 831abf76643555a99b80a3b54adfa7e4fa0a3259 upstream.
Trying to read data from the Pegasus Technologies NoteTaker (0e20:0101)
[1] with the Windows App (EasyNote) works natively but fails when
Windows is running under KVM (and the USB device handed to KVM).
The reason is a USB control message
usb 4-2.2: control urb: bRequestType=22 bRequest=09 wValue=0200 wIndex=0001 wLength=0008
This goes to endpoint address 0x01 (wIndex); however, endpoint address
0x01 does not exist. There is an endpoint 0x81 though (same number,
but other direction); the app may have meant that endpoint instead.
The kernel thus rejects the IO and thus we see the failure.
Apparently, Linux is more strict here than Windows ... we can't change
the Win app easily, so that's a problem.
It seems that the Win app/driver is buggy here and the driver does not
behave fully according to the USB HID class spec that it claims to
belong to. The device seems to happily deal with that though (and
seems to not really care about this value much).
So the question is whether the Linux kernel should filter here.
Rejecting has the risk that somewhat non-compliant userspace apps/
drivers (most likely in a virtual machine) are prevented from working.
Not rejecting has the risk of confusing an overly sensitive device with
such a transfer. Given the fact that Windows does not filter it makes
this risk rather small though.
The patch makes the kernel more tolerant: If the endpoint address in
wIndex does not exist, but an endpoint with toggled direction bit does,
it will let the transfer through. (It does NOT change the message.)
With attached patch, the app in Windows in KVM works.
usb 4-2.2: check_ctrlrecip: process 13073 (qemu-kvm) requesting ep 01 but needs 81
I suspect this will mostly affect apps in virtual environments; as on
Linux the apps would have been adapted to the stricter handling of the
kernel. I have done that for mine[2].
[1] http://www.pegatech.com/
[2] https://sourceforge.net/projects/notetakerpen/
Signed-off-by: Kurt Garloff <kurt@garloff.de>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 526867c3ca0caa2e3e846cb993b0f961c33c2abb upstream.
The halted state of a endpoint cannot be cleared over CLEAR_HALT from a
user process, because the stopped_td variable was overwritten in the
handle_stopped_endpoint() function. So the xhci_endpoint_reset() function will
refuse the reset and communication with device can not run over this endpoint.
https://bugzilla.kernel.org/show_bug.cgi?id=60699
Signed-off-by: Florian Wolter <wolly84@web.de>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Jonghwan Choi <jhbird.choi@samsung.com>
commit 284d20552461466b04d6bfeafeb1c47a8891b591 upstream.
When a command times out, the command ring is first aborted,
and then stopped. If the command ring is empty when it is stopped
the stop event will point to next command which is not yet set.
xHCI tries to handle this next event often causing an oops.
Don't handle command completion events on stopped cmd ring if ring is
empty.
This patch should be backported to kernels as old as 3.7, that contain
the commit b92cc66c047ff7cf587b318fe377061a353c120f "xHCI: add aborting
command ring function"
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
Reported-by: Giovanni <giovanni.nervi@yahoo.com>
commit ec7e43e2d98173483866fe2e4e690143626b659c upstream.
If a command on the command ring needs to be cancelled before it is handled
it can be turned to a no-op operation when the ring is stopped.
We want to store the command ring enqueue pointer in the command structure
when the command in enqueued for the cancellation case.
Some commands used to store the command ring dequeue pointers instead of enqueue
(these often worked because enqueue happends to equal dequeue quite often)
Other commands correctly used the enqueue pointer but did not check if it pointed
to a valid trb or a link trb, this caused for example stop endpoint command to timeout in
xhci_stop_device() in about 2% of suspend/resume cases.
This should also solve some weird behavior happening in command cancellation cases.
This patch is based on a patch submitted by Sarah Sharp to linux-usb, but
then forgotten:
http://marc.info/?l=linux-usb&m=136269803207465&w=2
commit e3eb270fab7734427dd8171a93e4946fe28674bc upstream.
The vt6656 is prone to resetting on the usb bus.
It seems there is a race condition and wpa supplicant is
trying to open the device via iw_handlers before its actually
closed at a stage that the buffers are being removed.
The device is longer considered open when the
buffers are being removed. So move ~DEVICE_FLAGS_OPENED
flag to before freeing the device buffers.
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
commit 700870119f49084da004ab588ea2b799689efaf7 upstream.
Add patch to fix 32bit EFI service mapping (rhbz 726701)
Multiple people are reporting hitting the following WARNING on i386,
WARNING: at arch/x86/mm/ioremap.c:102 __ioremap_caller+0x3d3/0x440()
Modules linked in:
Pid: 0, comm: swapper Not tainted 3.9.0-rc7+ #95
Call Trace:
[<c102b6af>] warn_slowpath_common+0x5f/0x80
[<c1023fb3>] ? __ioremap_caller+0x3d3/0x440
[<c102b6ed>] warn_slowpath_null+0x1d/0x20
[<c1023fb3>] __ioremap_caller+0x3d3/0x440
[<c106007b>] ? get_usage_chars+0xfb/0x110
[<c102d937>] ? vprintk_emit+0x147/0x480
[<c1418593>] ? efi_enter_virtual_mode+0x1e4/0x3de
[<c102406a>] ioremap_cache+0x1a/0x20
[<c1418593>] efi_enter_virtual_mode+0x1e4/0x3de
[<c1407984>] start_kernel+0x286/0x2f4
[<c1407535>] ? repair_env_string+0x51/0x51
[<c1407362>] i386_start_kernel+0x12c/0x12f
Due to the workaround described in commit 916f676f8 ("x86, efi: Retain
boot service code until after switching to virtual mode") EFI Boot
Service regions are mapped for a period during boot. Unfortunately, with
the limited size of the i386 direct kernel map it's possible that some
of the Boot Service regions will not be directly accessible, which
causes them to be ioremap()'d, triggering the above warning as the
regions are marked as E820_RAM in the e820 memmap.
There are currently only two situations where we need to map EFI Boot
Service regions,
1. To workaround the firmware bug described in 916f676f8
2. To access the ACPI BGRT image
but since we haven't seen an i386 implementation that requires either,
this simple fix should suffice for now.
[ Added to changelog - Matt ]
Reported-by: Bryan O'Donoghue <bryan.odonoghue.lkml@nexus-software.ie>
Acked-by: Tom Zanussi <tom.zanussi@intel.com>
Acked-by: Darren Hart <dvhart@linux.intel.com>
Cc: Josh Triplett <josh@joshtriplett.org>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
commit 4f0acd31c31f03ba42494c8baf6c0465150e2621 upstream.
Dell PowerEdge C6100 machines fail to completely reboot about 20% of the time.
Signed-off-by: Masoud Sharbiani <msharbiani@twitter.com>
Signed-off-by: Vinson Lee <vlee@twitter.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Link: http://lkml.kernel.org/r/1379717947-18042-1-git-send-email-vlee@freedesktop.org
commit 654784284430bf2739985914b65e09c7c35a7273 upstream.
Prior to this patch the following code breaks:
* multiline_example - this breaks kernel-doc
#define multiline_example( \
myparam)
Producing this error:
Error(somefile.h:983): cannot understand prototype: 'multiline_example( \ '
This patch fixes the issue by appending all lines ending in a blackslash
(optionally followed by whitespace), removing the backslash and any
whitespace after it prior to appending (just like the C pre-processor
would).
This fixes a break in kerel-doc introduced by the additions to rbtree.h.
Signed-off-by: Daniel Santos <daniel.santos@pobox.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Michal Marek <mmarek@suse.cz>
Cc: Ben Hutchings <ben@decadent.org.uk>
This bug fix is only for stable branches older than 3.10. The bug was
fixed upstream by commit 2768935a4660 ('sfc: reuse pages to avoid DMA
mapping/unmapping costs'), but that change is totally unsuitable for
stable.
Commit b590ace09d51 ('sfc: Fix efx_rx_buf_offset() in the presence of
swiotlb') added an explicit page_offset member to struct
efx_rx_buffer, which must be set consistently with the u.page and
dma_addr fields. However, it failed to add the necessary assignment
in efx_resurrect_rx_buffer(). It also did not correct the calculation
of efx_rx_buffer::dma_addr in efx_resurrect_rx_buffer(), which assumes
that DMA-mapping a page will result in a page-aligned DMA address
(exactly what swiotlb violates).
Add the assignment of efx_rx_buffer::page_offset and change the
calculation of dma_addr to make use of it.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Acked-by: David Miller <davem@davemloft.net>
commit 89365e6c9ad4c0e090e4c6a4b67a3ce319381d89 upstream.
Need to check for /dev/zero.
Most likely more strings are missing too.
Link: http://lkml.kernel.org/r/1366848182-30449-1-git-send-email-andi@firstfloor.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Vinson Lee <vlee@freedesktop.org>
commit 03a1cec1f17ac1a6041996b3e40f96b5a2f90e1b upstream.
Boyd Yang reported a problem for the case that multiple threads of the same
thread group are waiting for a reponse for a permission event.
In this case it is possible that some of the threads are never woken up, even
if the response for the event has been received
(see http://marc.info/?l=linux-kernel&m=131822913806350&w=2).
The reason is that we are currently merging permission events if they belong to
the same thread group. But we are not prepared to wake up more than one waiter
for each event. We do
wait_event(group->fanotify_data.access_waitq, event->response ||
atomic_read(&group->fanotify_data.bypass_perm));
and after that
event->response = 0;
which is the reason that even if we woke up all waiters for the same event
some of them may see event->response being already set 0 again, then go back to
sleep and block forever.
With this patch we avoid that more than one thread is waiting for a response
by not merging permission events for the same thread group any more.
Reported-by: Boyd Yang <boyd.yang@gmail.com>
Signed-off-by: Lino Sanfilippo <LinoSanfilipp@gmx.de>
Signed-off-by: Eric Paris <eparis@redhat.com>
Cc: Mihai Donțu <mihai.dontu@gmail.com>
commit 95cf59ea72331d0093010543b8951bb43f262cac upstream.
Jiri reported that he could trigger the WARN_ON_ONCE() in
perf_cgroup_switch() using sw-events. This is because sw-events share
a cpuctx with multiple PMUs.
Use the ->unique_pmu pointer to limit the pmu iteration to unique
cpuctx instances.
Reported-and-Tested-by: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/n/tip-so7wi2zf3jjzrwcutm2mkz0j@git.kernel.org
Cc: Li Zefan <lizefan@huawei.com>
commit 3f1f33206c16c7b3839d71372bc2ac3f305aa802 upstream.
Stephane thought the perf_cpu_context::active_pmu name confusing and
suggested using 'unique_pmu' instead.
This pointer is a pointer to a 'random' pmu sharing the cpuctx
instance, therefore limiting a for_each_pmu loop to those where
cpuctx->unique_pmu matches the pmu we get a loop over unique cpuctx
instances.
Suggested-by: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/n/tip-kxyjqpfj2fn9gt7kwu5ag9ks@git.kernel.org
commit f169007b2773f285e098cb84c74aac0154d65ff7 upstream.
If we pass fd of memory.usage_in_bytes of cgroup A to cgroup.event_control
of cgroup B, then we won't get memory usage notification from A but B!
What's worse, if A and B are in different mount hierarchy, we'll end up
accessing NULL pointer!
Disallow this kind of invalid usage.
Signed-off-by: Li Zefan <lizefan@huawei.com>
Acked-by: Kirill A. Shutemov <kirill@shutemov.name>
Cc: Weng Meiling <wengmeiling.weng@huawei.com>
commit 91f3a6aaf280294b07c05dfe606e6c27b7ba3c72 upstream.
The OUTPUT_ENABLE action jumps past the point in the coder where
the data_offset is set on certain rs780 cards. This worked
previously because the OUTPUT_ENABLE action is always called
immediately after the ENABLE action so the data_offset remained
set. In 6f8bbaf568c7f2c497558bfd04654c0b9841ad57
(drm/radeon/atom: initialize more atom interpretor elements to 0),
we explictly reset data_offset to 0 between atom calls which then
caused this to fail. The fix is to just skip calling the
OUTPUT_ENABLE action on the problematic chipsets. The ENABLE
action does the same thing and more. Ultimately, we could
probably drop the OUTPUT_ENABLE action all together on DCE3
asics.
fixes:
https://bugzilla.kernel.org/show_bug.cgi?id=60791
v2: only rs880 seems to be affected
commit fb93df1c2d8b3b1fb16d6ee9e32554e0c038815d upstream.
The table has the following format:
typedef struct _ATOM_SRC_DST_TABLE_FOR_ONE_OBJECT //usSrcDstTableOffset pointing to this structure
UCHAR ucNumberOfSrc;
USHORT usSrcObjectID[1];
UCHAR ucNumberOfDst;
USHORT usDstObjectID[1];
}ATOM_SRC_DST_TABLE_FOR_ONE_OBJECT;
usSrcObjectID[] and usDstObjectID[] are variably sized, so we
can't access them directly. Use pointers and update the offset
appropriately when accessing the Dst members.
commit acf88deb8ddbb73acd1c3fa32fde51af9153227f upstream.
Setting MC_MISC_CNTL.GART_INDEX_REG_EN causes hangs on
some boards on resume. The systems seem to work fine
without touching this bit so leave it as is.
v2: read-modify-write the GART_INDEX_REG_EN bit.
I suspect the problem is that we are losing the other
settings in the register.
fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=52952
Reported-by: Ondrej Zary <linux@rainbow-software.org>
Tested-by: Daniel Tobias <dan.g.tob@gmail.com>
commit 290d24576ccf1aa0373d2185cedfe262d0d4952a upstream.
We need to allocate line buffer to each display when
setting up the watermarks. Failure to do so can lead
to a blank screen. This fixes blank screen problems
on dce6 asics.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=64850
Based on an initial fix from:
Jay Cornwall <jay.cornwall@amd.com>
commit 0b31e02363b0db4e7931561bc6c141436e729d9f upstream.
on dce4.1/5 asics.
commit 4543eda52113d1e2cc0e9bf416f79597e6ef1ec7 upstream.
Need to swap the data fetched over i2c properly. This
is the same fix as the endian fix for aux channel
transactions.
commit 95663948ba22a4be8b99acd67fbf83e86ddffba4 upstream.
If the LCD table contains an EDID record, properly account
for the edid size when walking through the records.
This should fix error messages about unknown LCD records.
commit 182b17c8dc4e83aab000ce86587b6810e515da87 upstream.
After a vmalloc failure in ttm_dma_tt_alloc_page_directory(),
ttm_dma_tt_init() will call ttm_tt_destroy() to cleanup, and end up
inside the driver's unpopulate() hook when populate() has never yet
been called.
On nouveau, the first issue to be hit because of this is that
dma_address[] may be a NULL pointer. After working around this,
ttm_pool_unpopulate() may potentially hit the same issue with
the pages[] array.
It seems to make more sense to avoid calling unpopulate on already
unpopulated TTMs than to add checks to all the implementations.
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
Cc: Jerome Glisse <jglisse@redhat.com>
commit 297502abb32e225fb23801fcdb0e4f6f8e17099a upstream.
logitech-dj HID driver to leak kernel memory contents to the device, or
trigger a NULL dereference during initialization:
[ 304.424553] usb 1-1: New USB device found, idVendor=046d, idProduct=c52b
[ 304.780467] BUG: unable to handle kernel NULL pointer dereference at 0000000000000028
[ 304.781409] IP: [<ffffffff815d50aa>] logi_dj_recv_send_report.isra.11+0x1a/0x90
CVE-2013-2895
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com>
commit 78214e81a1bf43740ce89bb5efda78eac2f8ef83 upstream.
The zeroplus HID driver was not checking the size of allocated values
in fields it used. A HID device could send a malicious output report
that would cause the driver to write beyond the output report allocation
during initialization, causing a heap overflow:
[ 1442.728680] usb 1-1: New USB device found, idVendor=0c12, idProduct=0005
[ 1466.243173] BUG kmalloc-192 (Tainted: G W ): Redzone overwritten
CVE-2013-2889
commit 331415ff16a12147d57d5c953f3a961b7ede348b upstream.
Many drivers need to validate the characteristics of their HID report
during initialization to avoid misusing the reports. This adds a common
helper to perform validation of the report exisitng, the field existing,
and the expected number of values within the field.
invalid ones
commit 6c9a27f5da9609fca46cb2b183724531b48f71ad upstream.
There is a small race between copy_process() and cgroup_attach_task()
where child->se.parent,cfs_rq points to invalid (old) ones.
parent doing fork() | someone moving the parent to another cgroup
copy_process()
+ dup_task_struct()
-> parent->se is copied to child->se.
se.parent,cfs_rq of them point to old ones.
+ cgroup_task_migrate()
-> parent->cgroup is updated.
+ cpu_cgroup_attach()
+ sched_move_task()
+ task_move_group_fair()
+- set_task_rq()
-> se.parent,cfs_rq of parent
are updated.
+ cgroup_fork()
-> parent->cgroup is copied to child->cgroup. (*1)
+ sched_fork()
+ task_fork_fair()
-> se.parent,cfs_rq of child are accessed
while they point to old ones. (*2)
In the worst case, this bug can lead to "use-after-free" and cause a panic,
because it's new cgroup's refcount that is incremented at (*1),
so the old cgroup(and related data) can be freed before (*2).
In fact, a panic caused by this bug was originally caught in RHEL6.4.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff81051e3e>] sched_slice+0x6e/0xa0
Call Trace:
[<ffffffff81051f25>] place_entity+0x75/0xa0
[<ffffffff81056a3a>] task_fork_fair+0xaa/0x160
[<ffffffff81063c0b>] sched_fork+0x6b/0x140
[<ffffffff8106c3c2>] copy_process+0x5b2/0x1450
[<ffffffff81063b49>] ? wake_up_new_task+0xd9/0x130
[<ffffffff8106d2f4>] do_fork+0x94/0x460
[<ffffffff81072a9e>] ? sys_wait4+0xae/0x100
[<ffffffff81009598>] sys_clone+0x28/0x30
[<ffffffff8100b393>] stub_clone+0x13/0x20
[<ffffffff8100b072>] ? system_call_fastpath+0x16/0x1b
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/039601ceae06$733d3130$59b79390$@mxp.nes.nec.co.jp
commit 6e956da2027c767859128b9bfef085cf2a8e233b upstream.
We should not do temperature compensation on devices without
EXTERNAL_TX_ALC bit set (called DynamicTxAgcControl on vendor driver).
Such devices can have totally bogus TSSI parameters on the EEPROM,
but still threaded by us as valid and result doing wrong TX power
calculations.
This fix inability to connect to AP on slightly longer distance on
some Ralink chips/devices.
Reported-and-tested-by: Fabien ADAM <id2ndr@crocobox.org>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit 0092820407901a0b2c4e343e85f96bb7abfcded1 upstream.
Signed-off-by: Fabio Porcedda <fabio.porcedda@gmail.com>
Acked-by: Oliver Neukum <oliver@neukum.org>
This reverts commit c2f5b7507ac5d808f29287d77ee6148358d7fbfe which is
commit f6e80abeab928b7c47cc1fbf53df13b4398a2bec.
Michal writes:
Mainline commit f6e80abe was introduced in v3.7-rc2 as a
follow-up fix to commit
edfee033 sctp: check src addr when processing SACK to update transport state
(from v3.7-rc1) which changed the interpretation of third
argument to sctp_cmd_process_sack() and sctp_outq_sack(). But as
commit edfee033 has never been backported to stable branches,
backport of commit f6e80abe actually breaks the code rather than
fixing it.
Reported-by: Michal Kubecek <mkubecek@suse.cz>
Cc: Zijie Pan <zijie.pan@6wind.com>
Cc: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Cc: Vlad Yasevich <vyasevich@gmail.com>
commit d331a415aef98717393dda0be69b7947da08eba3 upstream.
Calls like setxattr and removexattr result in updation of ctime.
Therefore invalidate inode attributes to force a refresh.
Signed-off-by: Anand Avati <avati@redhat.com>
Reviewed-by: Brian Foster <bfoster@redhat.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
