2013-11-13Linux 3.4.69v3.4.69Greg Kroah-Hartman
2013-11-13drm/radeon/atom: workaround vbios bug in transmitter table on rs780Alex Deucher
commit c23632d4e57c0dd20bf50eca08fa0eb8ad3ff680 upstream. Some rs780 asics seem to be affected as well. See: http://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit/?id=91f3a6aaf280294b07c05dfe606e6c27b7ba3c72 Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=60791 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13drm: Prevent overwriting from userspace underallocating core ioctl structsChris Wilson
commit b062672e305ce071f21eb9e18b102c2a430e0999 upstream. Apply the protections from commit 1b2f1489633888d4a06028315dc19d65768a1c05 Author: Dave Airlie <airlied@redhat.com> Date: Sat Aug 14 20:20:34 2010 +1000 drm: block userspace under allocating buffer and having drivers overwrite it (v2) to the core ioctl structs as well, for we found one instance where there is a 32-/64-bit size mismatch and were guilty of writing beyond the end of the user's buffer. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Dave Airlie <airlied@redhat.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Cc: dri-devel@lists.freedesktop.org Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13mm: fix aio performance regression for database caused by THPKhalid Aziz
commit 7cb2ef56e6a8b7b368b2e883a0a47d02fed66911 upstream. I am working with a tool that simulates oracle database I/O workload. This tool (orion to be specific - <http://docs.oracle.com/cd/E11882_01/server.112/e16638/iodesign.htm#autoId24>) allocates hugetlbfs pages using shmget() with SHM_HUGETLB flag. It then does aio into these pages from flash disks using various common block sizes used by database. I am looking at performance with two of the most common block sizes - 1M and 64K. aio performance with these two block sizes plunged after Transparent HugePages was introduced in the kernel. Here are performance numbers: pre-THP 2.6.39 3.11-rc5 1M read 8384 MB/s 5629 MB/s 6501 MB/s 64K read 7867 MB/s 4576 MB/s 4251 MB/s I have narrowed the performance impact down to the overheads introduced by THP in __get_page_tail() and put_compound_page() routines. perf top shows >40% of cycles being spent in these two routines. Every time direct I/O to hugetlbfs pages starts, kernel calls get_page() to grab a reference to the pages and calls put_page() when I/O completes to put the reference away. THP introduced significant amount of locking overhead to get_page() and put_page() when dealing with compound pages because hugepages can be split underneath get_page() and put_page(). It added this overhead irrespective of whether it is dealing with hugetlbfs pages or transparent hugepages. This resulted in 20%-45% drop in aio performance when using hugetlbfs pages. Since hugetlbfs pages can not be split, there is no reason to go through all the locking overhead for these pages from what I can see. I added code to __get_page_tail() and put_compound_page() to bypass all the locking code when working with hugetlbfs pages. This improved performance significantly. Performance numbers with this patch: pre-THP 3.11-rc5 3.11-rc5 + Patch 1M read 8384 MB/s 6501 MB/s 8371 MB/s 64K read 7867 MB/s 4251 MB/s 6510 MB/s Performance with 64K read is still lower than what it was before THP, but still a 53% improvement. It does mean there is more work to be done but I will take a 53% improvement for now. Please take a look at the following patch and let me know if it looks reasonable. [akpm@linux-foundation.org: tweak comments] Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com> Cc: Pravin B Shelar <pshelar@nicira.com> Cc: Christoph Lameter <cl@linux.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13aacraid: missing capable() check in compat ioctlDan Carpenter
commit f856567b930dfcdbc3323261bf77240ccdde01f5 upstream. In commit d496f94d22d1 ('[SCSI] aacraid: fix security weakness') we added a check on CAP_SYS_RAWIO to the ioctl. The compat ioctls need the check as well. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13lib/scatterlist.c: don't flush_kernel_dcache_page on slab pageMing Lei
commit 3d77b50c5874b7e923be946ba793644f82336b75 upstream. Commit b1adaf65ba03 ("[SCSI] block: add sg buffer copy helper functions") introduces two sg buffer copy helpers, and calls flush_kernel_dcache_page() on pages in SG list after these pages are written to. Unfortunately, the commit may introduce a potential bug: - Before sending some SCSI commands, kmalloc() buffer may be passed to block layper, so flush_kernel_dcache_page() can see a slab page finally - According to cachetlb.txt, flush_kernel_dcache_page() is only called on "a user page", which surely can't be a slab page. - ARCH's implementation of flush_kernel_dcache_page() may use page mapping information to do optimization so page_mapping() will see the slab page, then VM_BUG_ON() is triggered. Aaro Koskinen reported the bug on ARM/kirkwood when DEBUG_VM is enabled, and this patch fixes the bug by adding test of '!PageSlab(miter->page)' before calling flush_kernel_dcache_page(). Signed-off-by: Ming Lei <ming.lei@canonical.com> Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi> Tested-by: Simon Baatz <gmbnomis@gmail.com> Cc: Russell King - ARM Linux <linux@arm.linux.org.uk> Cc: Will Deacon <will.deacon@arm.com> Cc: Aaro Koskinen <aaro.koskinen@iki.fi> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Tejun Heo <tj@kernel.org> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13xtensa: don't use alternate signal stack on threadsBaruch Siach
commit cba9a90053e3b7973eff4f1946f33032e98eeed5 upstream. According to create_thread(3): "The new thread does not inherit the creating thread's alternate signal stack". Since commit f9a3879a (Fix sigaltstack corruption among cloned threads), current->sas_ss_size is set to 0 for cloned processes sharing VM with their parent. Don't use the (nonexistent) alternate signal stack in this case. This has been broken since commit 29c4dfd9 ([XTENSA] Remove non-rt signal handling). Fixes the SA_ONSTACK part of the nptl/tst-cancel20 test from uClibc. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13uml: check length in exitcode_proc_write()Dan Carpenter
commit 201f99f170df14ba52ea4c52847779042b7a623b upstream. We don't cap the size of buffer from the user so we could write past the end of the array here. Only root can write to this file. Reported-by: Nico Golde <nico@ngolde.de> Reported-by: Fabian Yamaguchi <fabs@goesec.de> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13Staging: bcm: info leak in ioctlDan Carpenter
commit 8d1e72250c847fa96498ec029891de4dc638a5ba upstream. The DevInfo.u32Reserved[] array isn't initialized so it leaks kernel information to user space. Reported-by: Nico Golde <nico@ngolde.de> Reported-by: Fabian Yamaguchi <fabs@goesec.de> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13staging: ozwpan: prevent overflow in oz_cdev_write()Dan Carpenter
commit c2c65cd2e14ada6de44cb527e7f1990bede24e15 upstream. We need to check "count" so we don't overflow the ei->data buffer. Reported-by: Nico Golde <nico@ngolde.de> Reported-by: Fabian Yamaguchi <fabs@goesec.de> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13ASoC: dapm: Fix source list debugfs outputsTakashi Iwai
commit ff18620c2157671a8ee21ebb8e6a3520ea209b1f upstream. ... due to a copy & paste error. Spotted by coverity CID 710923. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13ASoC: wm_hubs: Add missing break in hp_supply_event()Takashi Iwai
commit 268ff14525edba31da29a12a9dd693cdd6a7872e upstream. Spotted by coverity CID 115170. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13ALSA: fix oops in snd_pcm_info() caused by ASoC DPCMRussell King
commit a4461f41b94cb52e0141af717dcf4ef6558c8e2e upstream. Unable to handle kernel NULL pointer dereference at virtual address 00000008 pgd = d5300000 [00000008] *pgd=0d265831, *pte=00000000, *ppte=00000000 Internal error: Oops: 17 [#1] PREEMPT ARM CPU: 0 PID: 2295 Comm: vlc Not tainted 3.11.0+ #755 task: dee74800 ti: e213c000 task.ti: e213c000 PC is at snd_pcm_info+0xc8/0xd8 LR is at 0x30232065 pc : [<c031b52c>] lr : [<30232065>] psr: a0070013 sp : e213dea8 ip : d81cb0d0 fp : c05f7678 r10: c05f7770 r9 : fffffdfd r8 : 00000000 r7 : d8a968a8 r6 : d8a96800 r5 : d8a96200 r4 : d81cb000 r3 : 00000000 r2 : d81cb000 r1 : 00000001 r0 : d8a96200 Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user Control: 10c5387d Table: 15300019 DAC: 00000015 Process vlc (pid: 2295, stack limit = 0xe213c248) [<c031b52c>] (snd_pcm_info) from [<c031b570>] (snd_pcm_info_user+0x34/0x9c) [<c031b570>] (snd_pcm_info_user) from [<c03164a4>] (snd_pcm_control_ioctl+0x274/0x280) [<c03164a4>] (snd_pcm_control_ioctl) from [<c0311458>] (snd_ctl_ioctl+0xc0/0x55c) [<c0311458>] (snd_ctl_ioctl) from [<c00eca84>] (do_vfs_ioctl+0x80/0x31c) [<c00eca84>] (do_vfs_ioctl) from [<c00ecd5c>] (SyS_ioctl+0x3c/0x60) [<c00ecd5c>] (SyS_ioctl) from [<c000e500>] (ret_fast_syscall+0x0/0x48) Code: e1a00005 e59530dc e3a01001 e1a02004 (e5933008) ---[ end trace cb3d9bdb8dfefb3c ]--- This is provoked when the ASoC front end is open along with its backend, (which causes the backend to have a runtime assigned to it) and then the SNDRV_CTL_IOCTL_PCM_INFO is requested for the (visible) backend device. Resolve this by ensuring that ASoC internal backend devices are not visible to userspace, just as the commentry for snd_pcm_new_internal() says it should be. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Mark Brown <broonie@linaro.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13ALSA: hda - Add a fixup for ASUS N76VZTakashi Iwai
commit 6fc16e58adf50c0f1e4478538983fb5ff6f453d4 upstream. ASUS N76VZ needs the same fixup as N56VZ for supporting the boost speaker. Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=846529 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13parisc: Do not crash 64bit SMP kernels on machines with >= 4GB RAMHelge Deller
commit 54e181e073fc1415e41917d725ebdbd7de956455 upstream. Since the beginning of the parisc-linux port, sometimes 64bit SMP kernels were not able to bring up other CPUs than the monarch CPU and instead crashed the kernel. The reason was unclear, esp. since it involved various machines (e.g. J5600, J6750 and SuperDome). Testing showed, that those crashes didn't happened when less than 4GB were installed, or if a 32bit Linux kernel was booted. In the end, the fix for those SMP problems is trivial: During the early phase of the initialization of the CPUs, including the monarch CPU, the PDC_PSW firmware function to enable WIDE (=64bit) mode is called. It's documented that this firmware function may clobber various registers, and one one of those possibly clobbered registers is %cr30 which holds the task thread info pointer. Now, if %cr30 would always have been clobbered, then this bug would have been detected much earlier. But lots of testing finally showed, that - at least for %cr30 - on some machines only the upper 32bits of the 64bit register suddenly turned zero after the firmware call. So, after finding the root cause, the explanation for the various crashes became clear: - On 32bit SMP Linux kernels all upper 32bit were zero, so we didn't faced this problem. - Monarch CPUs in 64bit mode always booted sucessfully, because the inital task thread info pointer was below 4GB. - Secondary CPUs booted sucessfully on machines with less than 4GB RAM because the upper 32bit were zero anyay. - Secondary CPus failed to boot if we had more than 4GB RAM and the task thread info pointer was located above the 4GB boundary. Finally, the patch to fix this problem is trivial by saving the %cr30 register before the firmware call and restoring it afterwards. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13clockevents: Sanitize ticks to nsec conversionThomas Gleixner
commit 97b9410643475d6557d2517c2aff9fd2221141a9 upstream. Marc Kleine-Budde pointed out, that commit 77cc982 "clocksource: use clockevents_config_and_register() where possible" caused a regression for some of the converted subarchs. The reason is, that the clockevents core code converts the minimal hardware tick delta to a nanosecond value for core internal usage. This conversion is affected by integer math rounding loss, so the backwards conversion to hardware ticks will likely result in a value which is less than the configured hardware limitation. The affected subarchs used their own workaround (SIGH!) which got lost in the conversion. The solution for the issue at hand is simple: adding evt->mult - 1 to the shifted value before the integer divison in the core conversion function takes care of it. But this only works for the case where for the scaled math mult/shift pair "mult <= 1 << shift" is true. For the case where "mult > 1 << shift" we can apply the rounding add only for the minimum delta value to make sure that the backward conversion is not less than the given hardware limit. For the upper bound we need to omit the rounding add, because the backwards conversion is always larger than the original latch value. That would violate the upper bound of the hardware device. Though looking closer at the details of that function reveals another bogosity: The upper bounds check is broken as well. Checking for a resulting "clc" value greater than KTIME_MAX after the conversion is pointless. The conversion does: u64 clc = (latch << evt->shift) / evt->mult; So there is no sanity check for (latch << evt->shift) exceeding the 64bit boundary. The latch argument is "unsigned long", so on a 64bit arch the handed in argument could easily lead to an unnoticed shift overflow. With the above rounding fix applied the calculation before the divison is: u64 clc = (latch << evt->shift) + evt->mult - 1; So we need to make sure, that neither the shift nor the rounding add is overflowing the u64 boundary. [ukl: move assignment to rnd after eventually changing mult, fix build issue and correct comment with the right math] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King - ARM Linux <linux@arm.linux.org.uk> Cc: Marc Kleine-Budde <mkl@pengutronix.de> Cc: nicolas.ferre@atmel.com Cc: Marc Pignat <marc.pignat@hevs.ch> Cc: john.stultz@linaro.org Cc: kernel@pengutronix.de Cc: Ronald Wahl <ronald.wahl@raritan.com> Cc: LAK <linux-arm-kernel@lists.infradead.org> Cc: Ludovic Desroches <ludovic.desroches@atmel.com> Link: http://lkml.kernel.org/r/1380052223-24139-1-git-send-email-u.kleine-koenig@pengutronix.de Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13md: Fix skipping recovery for read-only arrays.Lukasz Dorau
commit 61e4947c99c4494336254ec540c50186d186150b upstream. Since: commit 7ceb17e87bde79d285a8b988cfed9eaeebe60b86 md: Allow devices to be re-added to a read-only array. spares are activated on a read-only array. In case of raid1 and raid10 personalities it causes that not-in-sync devices are marked in-sync without checking if recovery has been finished. If a read-only array is degraded and one of its devices is not in-sync (because the array has been only partially recovered) recovery will be skipped. This patch adds checking if recovery has been finished before marking a device in-sync for raid1 and raid10 personalities. In case of raid5 personality such condition is already present (at raid5.c:6029). Bug was introduced in 3.10 and causes data corruption. Signed-off-by: Pawel Baldysiak <pawel.baldysiak@intel.com> Signed-off-by: Lukasz Dorau <lukasz.dorau@intel.com> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13libata: make ata_eh_qc_retry() bump scmd->allowed on bogus failuresGwendal Grignou
commit f13e220161e738c2710b9904dcb3cf8bb0bcce61 upstream. libata EH decrements scmd->retries when the command failed for reasons unrelated to the command itself so that, for example, commands aborted due to suspend / resume cycle don't get penalized; however, decrementing scmd->retries isn't enough for ATA passthrough commands. Without this fix, ATA passthrough commands are not resend to the drive, and no error is signalled to the caller because: - allowed retry count is 1 - ata_eh_qc_complete fill the sense data, so result is valid - sense data is filled with untouched ATA registers. Signed-off-by: Gwendal Grignou <gwendal@google.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13can: flexcan: flexcan_chip_start: fix regression, mark one MB for TX and ↵Marc Kleine-Budde
abort pending TX commit d5a7b406c529e4595ce03dc8f6dcf7fa36f106fa upstream. In patch 0d1862e can: flexcan: fix flexcan_chip_start() on imx6 the loop in flexcan_chip_start() that iterates over all mailboxes after the soft reset of the CAN core was removed. This loop put all mailboxes (even the ones marked as reserved 1...7) into EMPTY/INACTIVE mode. On mailboxes 8...63, this aborts any pending TX messages. After a cold boot there is random garbage in the mailboxes, which leads to spontaneous transmit of CAN frames during first activation. Further if the interface was disabled with a pending message (usually due to an error condition on the CAN bus), this message is retransmitted after enabling the interface again. This patch fixes the regression by: 1) Limiting the maximum number of used mailboxes to 8, 0...7 are used by the RX FIFO, 8 is used by TX. 2) Marking the TX mailbox as EMPTY/INACTIVE, so that any pending TX of that mailbox is aborted. Cc: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13jfs: fix error path in iallocDave Kleikamp
commit 8660998608cfa1077e560034db81885af8e1e885 upstream. If insert_inode_locked() fails, we shouldn't be calling unlock_new_inode(). Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Tested-by: Michael L. Semon <mlsemon35@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13rtlwifi: rtl8192cu: Fix error in pointer arithmeticMark Cave-Ayland
commit 9473ca6e920a3b9ca902753ce52833657f9221cc upstream. An error in calculating the offset in an skb causes the driver to read essential device info from the wrong locations. The main effect is that automatic gain calculations are nonsense. Signed-off-by: Mark Cave-Ayland <mark.cave-ayland@ilande.co.uk> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13mac80211: update sta->last_rx on acked tx framesFelix Fietkau
commit 0c5b93290b2f3c7a376567c03ae8d385b0e99851 upstream. When clients are idle for too long, hostapd sends nullfunc frames for probing. When those are acked by the client, the idle time needs to be updated. To make this work (and to avoid unnecessary probing), update sta->last_rx whenever an ACK was received for a tx packet. Only do this if the flag IEEE80211_HW_REPORTS_TX_ACK_STATUS is set. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13mac80211: correctly close cancelled scansEmmanuel Grumbach
commit a754055a1296fcbe6f32de3a5eaca6efb2fd1865 upstream. __ieee80211_scan_completed is called from a worker. This means that the following flow is possible. * driver calls ieee80211_scan_completed * mac80211 cancels the scan (that is already complete) * __ieee80211_scan_completed runs When scan_work will finally run, it will see that the scan hasn't been aborted and might even trigger another scan on another band. This leads to a situation where cfg80211's scan is not done and no further scan can be issued. Fix this by setting a new flag when a HW scan is being cancelled so that no other scan will be triggered. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13USB: serial: ftdi_sio: add id for Z3X Box deviceАлексей Крамаренко
commit e1466ad5b1aeda303f9282463d55798d2eda218c upstream. Custom VID/PID for Z3X Box device, popular tool for cellphone flashing. Signed-off-by: Alexey E. Kramarenko <alexeyk13@yandex.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13USB: quirks: add touchscreen that is dazzeled by remote wakeupOliver Neukum
commit 614ced91fc6fbb5a1cdd12f0f1b6c9197d9f1350 upstream. The device descriptors are messed up after remote wakeup Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13USB: quirks.c: add one device that cannot deal with suspensionOliver Neukum
commit 4294bca7b423d1a5aa24307e3d112a04075e3763 upstream. The device is not responsive when resumed, unless it is reset. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13USB: support new huawei devices in option.cFangxiaozhi (Franko)
commit d544db293a44a2a3b09feab7dbd59668b692de71 upstream. Add new supporting declarations to option.c, to support Huawei new devices with new bInterfaceSubClass value. Signed-off-by: fangxiaozhi <huananhu@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04Linux 3.4.68v3.4.68Greg Kroah-Hartman
2013-11-04usb: serial: option: blacklist Olivetti Olicard200Enrico Mioso
commit fd8573f5828873343903215f203f14dc82de397c upstream. Interface 6 of this device speaks QMI as per tests done by us. Credits go to Antonella for providing the hardware. Signed-off-by: Enrico Mioso <mrkiko.rs@gmail.com> Signed-off-by: Antonella Pellizzari <anto.pellizzari83@gmail.com> Tested-by: Dan Williams <dcbw@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04USB: serial: option: add support for Inovia SEW858 deviceGreg Kroah-Hartman
commit f4c19b8e165cff1a6607c21f8809441d61cab7ec upstream. This patch adds the device id for the Inovia SEW858 device to the option driver. Reported-by: Pavel Parkhomenko <ra85551@gmail.com> Tested-by: Pavel Parkhomenko <ra85551@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04USB: serial: ti_usb_3410_5052: add Abbott strip port ID to combined table as ↵Diego Elio Pettenò
well. commit c9d09dc7ad106492c17c587b6eeb99fe3f43e522 upstream. Without this change, the USB cable for Freestyle Option and compatible glucometers will not be detected by the driver. Signed-off-by: Diego Elio Pettenò <flameeyes@flameeyes.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04wireless: radiotap: fix parsing buffer overrunJohannes Berg
commit f5563318ff1bde15b10e736e97ffce13be08bc1a upstream. When parsing an invalid radiotap header, the parser can overrun the buffer that is passed in because it doesn't correctly check 1) the minimum radiotap header size 2) the space for extended bitmaps The first issue doesn't affect any in-kernel user as they all check the minimum size before calling the radiotap function. The second issue could potentially affect the kernel if an skb is passed in that consists only of the radiotap header with a lot of extended bitmaps that extend past the SKB. In that case a read-only buffer overrun by at most 4 bytes is possible. Fix this by adding the appropriate checks to the parser. Reported-by: Evan Huus <eapache@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04writeback: fix negative bdi max pauseFengguang Wu
commit e3b6c655b91e01a1dade056cfa358581b47a5351 upstream. Toralf runs trinity on UML/i386. After some time it hangs and the last message line is BUG: soft lockup - CPU#0 stuck for 22s! [trinity-child0:1521] It's found that pages_dirtied becomes very large. More than 1000000000 pages in this case: period = HZ * pages_dirtied / task_ratelimit; BUG_ON(pages_dirtied > 2000000000); BUG_ON(pages_dirtied > 1000000000); <--------- UML debug printf shows that we got negative pause here: ick: pause : -984 ick: pages_dirtied : 0 ick: task_ratelimit: 0 pause: + if (pause < 0) { + extern int printf(char *, ...); + printf("ick : pause : %li\n", pause); + printf("ick: pages_dirtied : %lu\n", pages_dirtied); + printf("ick: task_ratelimit: %lu\n", task_ratelimit); + BUG_ON(1); + } trace_balance_dirty_pages(bdi, Since pause is bounded by [min_pause, max_pause] where min_pause is also bounded by max_pause. It's suspected and demonstrated that the max_pause calculation goes wrong: ick: pause : -717 ick: min_pause : -177 ick: max_pause : -717 ick: pages_dirtied : 14 ick: task_ratelimit: 0 The problem lies in the two "long = unsigned long" assignments in bdi_max_pause() which might go negative if the highest bit is 1, and the min_t(long, ...) check failed to protect it falling under 0. Fix all of them by using "unsigned long" throughout the function. Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Reported-by: Toralf Förster <toralf.foerster@gmx.de> Tested-by: Toralf Förster <toralf.foerster@gmx.de> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Richard Weinberger <richard@nod.at> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04dm snapshot: fix data corruptionMikulas Patocka
commit e9c6a182649f4259db704ae15a91ac820e63b0ca upstream. This patch fixes a particular type of data corruption that has been encountered when loading a snapshot's metadata from disk. When we allocate a new chunk in persistent_prepare, we increment ps->next_free and we make sure that it doesn't point to a metadata area by further incrementing it if necessary. When we load metadata from disk on device activation, ps->next_free is positioned after the last used data chunk. However, if this last used data chunk is followed by a metadata area, ps->next_free is positioned erroneously to the metadata area. A newly-allocated chunk is placed at the same location as the metadata area, resulting in data or metadata corruption. This patch changes the code so that ps->next_free skips the metadata area when metadata are loaded in function read_exceptions. The patch also moves a piece of code from persistent_prepare_exception to a separate function skip_metadata to avoid code duplication. CVE-2013-4299 Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04ext3: return 32/64-bit dir name hash according to usage typeEric Sandeen
commit d7dab39b6e16d5eea78ed3c705d2a2d0772b4f06 upstream. This is based on commit d1f5273e9adb40724a85272f248f210dc4ce919a ext4: return 32/64-bit dir name hash according to usage type by Fan Yong <yong.fan@whamcloud.com> Traditionally ext2/3/4 has returned a 32-bit hash value from llseek() to appease NFSv2, which can only handle a 32-bit cookie for seekdir() and telldir(). However, this causes problems if there are 32-bit hash collisions, since the NFSv2 server can get stuck resending the same entries from the directory repeatedly. Allow ext3 to return a full 64-bit hash (both major and minor) for telldir to decrease the chance of hash collisions. This patch does implement a new ext3_dir_llseek op, because with 64-bit hashes, nfs will attempt to seek to a hash "offset" which is much larger than ext3's s_maxbytes. So for dx dirs, we call generic_file_llseek_size() with the appropriate max hash value as the maximum seekable size. Otherwise we just pass through to generic_file_llseek(). Patch-updated-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de> Patch-updated-by: Eric Sandeen <sandeen@redhat.com> (blame us if something is not correct) Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz> Cc: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04davinci_emac.c: Fix IFF_ALLMULTI setupMariusz Ceier
[ Upstream commit d69e0f7ea95fef8059251325a79c004bac01f018 ] When IFF_ALLMULTI flag is set on interface and IFF_PROMISC isn't, emac_dev_mcast_set should only enable RX of multicasts and reset MACHASH registers. It does this, but afterwards it either sets up multicast MACs filtering or disables RX of multicasts and resets MACHASH registers again, rendering IFF_ALLMULTI flag useless. This patch fixes emac_dev_mcast_set, so that multicast MACs filtering and disabling of RX of multicasts are skipped when IFF_ALLMULTI flag is set. Tested with kernel 2.6.37. Signed-off-by: Mariusz Ceier <mceier+kernel@gmail.com> Acked-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04inet: fix possible memory corruption with UDP_CORK and UFOHannes Frederic Sowa
[ This is a simplified -stable version of a set of upstream commits. ] This is a replacement patch only for stable which does fix the problems handled by the following two commits in -net: "ip_output: do skb ufo init for peeked non ufo skb as well" (e93b7d748be887cd7639b113ba7d7ef792a7efb9) "ip6_output: do skb ufo init for peeked non ufo skb as well" (c547dbf55d5f8cf615ccc0e7265e98db27d3fb8b) Three frames are written on a corked udp socket for which the output netdevice has UFO enabled. If the first and third frame are smaller than the mtu and the second one is bigger, we enqueue the second frame with skb_append_datato_frags without initializing the gso fields. This leads to the third frame appended regulary and thus constructing an invalid skb. This fixes the problem by always using skb_append_datato_frags as soon as the first frag got enqueued to the skb without marking the packet as SKB_GSO_UDP. The problem with only two frames for ipv6 was fixed by "ipv6: udp packets following an UFO enqueued packet need also be handled by UFO" (2811ebac2521ceac84f2bdae402455baa6a7fb47). Cc: Jiri Pirko <jiri@resnulli.us> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04net: fix cipso packet validation when !NETLABELSeif Mazareeb
[ Upstream commit f2e5ddcc0d12f9c4c7b254358ad245c9dddce13b ] When CONFIG_NETLABEL is disabled, the cipso_v4_validate() function could loop forever in the main loop if opt[opt_iter +1] == 0, this will causing a kernel crash in an SMP system, since the CPU executing this function will stall /not respond to IPIs. This problem can be reproduced by running the IP Stack Integrity Checker (http://isic.sourceforge.net) using the following command on a Linux machine connected to DUT: "icmpsic -s rand -d <DUT IP address> -r 123456" wait (1-2 min) Signed-off-by: Seif Mazareeb <seif@marvell.com> Acked-by: Paul Moore <paul@paul-moore.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04net: unix: inherit SOCK_PASS{CRED, SEC} flags from socket to fix raceDaniel Borkmann
[ Upstream commit 90c6bd34f884cd9cee21f1d152baf6c18bcac949 ] In the case of credentials passing in unix stream sockets (dgram sockets seem not affected), we get a rather sparse race after commit 16e5726 ("af_unix: dont send SCM_CREDENTIALS by default"). We have a stream server on receiver side that requests credential passing from senders (e.g. nc -U). Since we need to set SO_PASSCRED on each spawned/accepted socket on server side to 1 first (as it's not inherited), it can happen that in the time between accept() and setsockopt() we get interrupted, the sender is being scheduled and continues with passing data to our receiver. At that time SO_PASSCRED is neither set on sender nor receiver side, hence in cmsg's SCM_CREDENTIALS we get eventually pid:0, uid:65534, gid:65534 (== overflow{u,g}id) instead of what we actually would like to see. On the sender side, here nc -U, the tests in maybe_add_creds() invoked through unix_stream_sendmsg() would fail, as at that exact time, as mentioned, the sender has neither SO_PASSCRED on his side nor sees it on the server side, and we have a valid 'other' socket in place. Thus, sender believes it would just look like a normal connection, not needing/requesting SO_PASSCRED at that time. As reverting 16e5726 would not be an option due to the significant performance regression reported when having creds always passed, one way/trade-off to prevent that would be to set SO_PASSCRED on the listener socket and allow inheriting these flags to the spawned socket on server side in accept(). It seems also logical to do so if we'd tell the listener socket to pass those flags onwards, and would fix the race. Before, strace: recvmsg(4, {msg_name(0)=NULL, msg_iov(1)=[{"blub\n", 4096}], msg_controllen=32, {cmsg_len=28, cmsg_level=SOL_SOCKET, cmsg_type=SCM_CREDENTIALS{pid=0, uid=65534, gid=65534}}, msg_flags=0}, 0) = 5 After, strace: recvmsg(4, {msg_name(0)=NULL, msg_iov(1)=[{"blub\n", 4096}], msg_controllen=32, {cmsg_len=28, cmsg_level=SOL_SOCKET, cmsg_type=SCM_CREDENTIALS{pid=11580, uid=1000, gid=1000}}, msg_flags=0}, 0) = 5 Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Eric Dumazet <edumazet@google.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04wanxl: fix info leak in ioctlSalva Peiró
[ Upstream commit 2b13d06c9584b4eb773f1e80bbaedab9a1c344e1 ] The wanxl_ioctl() code fails to initialize the two padding bytes of struct sync_serial_settings after the ->loopback member. Add an explicit memset(0) before filling the structure to avoid the info leak. Signed-off-by: Salva Peiró <speiro@ai2.upv.es> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04sctp: Perform software checksum if packet has to be fragmented.Vlad Yasevich
[ Upstream commit d2dbbba77e95dff4b4f901fee236fef6d9552072 ] IP/IPv6 fragmentation knows how to compute only TCP/UDP checksum. This causes problems if SCTP packets has to be fragmented and ipsummed has been set to PARTIAL due to checksum offload support. This condition can happen when retransmitting after MTU discover, or when INIT or other control chunks are larger then MTU. Check for the rare fragmentation condition in SCTP and use software checksum calculation in this case. CC: Fan Du <fan.du@windriver.com> Signed-off-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04sctp: Use software crc32 checksum when xfrm transform will happen.Fan Du
[ Upstream commit 27127a82561a2a3ed955ce207048e1b066a80a2a ] igb/ixgbe have hardware sctp checksum support, when this feature is enabled and also IPsec is armed to protect sctp traffic, ugly things happened as xfrm_output checks CHECKSUM_PARTIAL to do checksum operation(sum every thing up and pack the 16bits result in the checksum field). The result is fail establishment of sctp communication. Signed-off-by: Fan Du <fan.du@windriver.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04net: dst: provide accessor function to dst->xfrmVlad Yasevich
[ Upstream commit e87b3998d795123b4139bc3f25490dd236f68212 ] dst->xfrm is conditionally defined. Provide accessor funtion that is always available. Signed-off-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04bnx2x: record rx queue for LRO packetsEric Dumazet
[ Upstream commit 60e66fee56b2256dcb1dc2ea1b2ddcb6e273857d ] RPS support is kind of broken on bnx2x, because only non LRO packets get proper rx queue information. This triggers reorders, as it seems bnx2x like to generate a non LRO packet for segment including TCP PUSH flag : (this might be pure coincidence, but all the reorders I've seen involve segments with a PUSH) 11:13:34.335847 IP A > B: . 415808:447136(31328) ack 1 win 457 <nop,nop,timestamp 3789336 3985797> 11:13:34.335992 IP A > B: . 447136:448560(1424) ack 1 win 457 <nop,nop,timestamp 3789336 3985797> 11:13:34.336391 IP A > B: . 448560:479888(31328) ack 1 win 457 <nop,nop,timestamp 3789337 3985797> 11:13:34.336425 IP A > B: P 511216:512640(1424) ack 1 win 457 <nop,nop,timestamp 3789337 3985798> 11:13:34.336423 IP A > B: . 479888:511216(31328) ack 1 win 457 <nop,nop,timestamp 3789337 3985798> 11:13:34.336924 IP A > B: . 512640:543968(31328) ack 1 win 457 <nop,nop,timestamp 3789337 3985798> 11:13:34.336963 IP A > B: . 543968:575296(31328) ack 1 win 457 <nop,nop,timestamp 3789337 3985798> We must call skb_record_rx_queue() to properly give to RPS (and more generally for TX queue selection on forward path) the receive queue information. Similar fix is needed for skb_mark_napi_id(), but will be handled in a separate patch to ease stable backports. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Willem de Bruijn <willemb@google.com> Cc: Eilon Greenstein <eilong@broadcom.com> Acked-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04connector: use nlmsg_len() to check message lengthMathias Krause
[ Upstream commit 162b2bedc084d2d908a04c93383ba02348b648b0 ] The current code tests the length of the whole netlink message to be at least as long to fit a cn_msg. This is wrong as nlmsg_len includes the length of the netlink message header. Use nlmsg_len() instead to fix this "off-by-NLMSG_HDRLEN" size check. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04unix_diag: fix info leakMathias Krause
[ Upstream commit 6865d1e834be84ddd5808d93d5035b492346c64a ] When filling the netlink message we miss to wipe the pad field, therefore leak one byte of heap memory to userland. Fix this by setting pad to 0. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04farsync: fix info leak in ioctlSalva Peiró
[ Upstream commit 96b340406724d87e4621284ebac5e059d67b2194 ] The fst_get_iface() code fails to initialize the two padding bytes of struct sync_serial_settings after the ->loopback member. Add an explicit memset(0) before filling the structure to avoid the info leak. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04l2tp: must disable bh before calling l2tp_xmit_skb()Eric Dumazet
[ Upstream commit 455cc32bf128e114455d11ad919321ab89a2c312 ] François Cachereul made a very nice bug report and suspected the bh_lock_sock() / bh_unlok_sock() pair used in l2tp_xmit_skb() from process context was not good. This problem was added by commit 6af88da14ee284aaad6e4326da09a89191ab6165 ("l2tp: Fix locking in l2tp_core.c"). l2tp_eth_dev_xmit() runs from BH context, so we must disable BH from other l2tp_xmit_skb() users. [ 452.060011] BUG: soft lockup - CPU#1 stuck for 23s! [accel-pppd:6662] [ 452.061757] Modules linked in: l2tp_ppp l2tp_netlink l2tp_core pppoe pppox ppp_generic slhc ipv6 ext3 mbcache jbd virtio_balloon xfs exportfs dm_mod virtio_blk ata_generic virtio_net floppy ata_piix libata virtio_pci virtio_ring virtio [last unloaded: scsi_wait_scan] [ 452.064012] CPU 1 [ 452.080015] BUG: soft lockup - CPU#2 stuck for 23s! [accel-pppd:6643] [ 452.080015] CPU 2 [ 452.080015] [ 452.080015] Pid: 6643, comm: accel-pppd Not tainted 3.2.46.mini #1 Bochs Bochs [ 452.080015] RIP: 0010:[<ffffffff81059f6c>] [<ffffffff81059f6c>] do_raw_spin_lock+0x17/0x1f [ 452.080015] RSP: 0018:ffff88007125fc18 EFLAGS: 00000293 [ 452.080015] RAX: 000000000000aba9 RBX: ffffffff811d0703 RCX: 0000000000000000 [ 452.080015] RDX: 00000000000000ab RSI: ffff8800711f6896 RDI: ffff8800745c8110 [ 452.080015] RBP: ffff88007125fc18 R08: 0000000000000020 R09: 0000000000000000 [ 452.080015] R10: 0000000000000000 R11: 0000000000000280 R12: 0000000000000286 [ 452.080015] R13: 0000000000000020 R14: 0000000000000240 R15: 0000000000000000 [ 452.080015] FS: 00007fdc0cc24700(0000) GS:ffff8800b6f00000(0000) knlGS:0000000000000000 [ 452.080015] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 452.080015] CR2: 00007fdb054899b8 CR3: 0000000074404000 CR4: 00000000000006a0 [ 452.080015] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 452.080015] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 452.080015] Process accel-pppd (pid: 6643, threadinfo ffff88007125e000, task ffff8800b27e6dd0) [ 452.080015] Stack: [ 452.080015] ffff88007125fc28 ffffffff81256559 ffff88007125fc98 ffffffffa01b2bd1 [ 452.080015] ffff88007125fc58 000000000000000c 00000000029490d0 0000009c71dbe25e [ 452.080015] 000000000000005c 000000080000000e 0000000000000000 ffff880071170600 [ 452.080015] Call Trace: [ 452.080015] [<ffffffff81256559>] _raw_spin_lock+0xe/0x10 [ 452.080015] [<ffffffffa01b2bd1>] l2tp_xmit_skb+0x189/0x4ac [l2tp_core] [ 452.080015] [<ffffffffa01c2d36>] pppol2tp_sendmsg+0x15e/0x19c [l2tp_ppp] [ 452.080015] [<ffffffff811c7872>] __sock_sendmsg_nosec+0x22/0x24 [ 452.080015] [<ffffffff811c83bd>] sock_sendmsg+0xa1/0xb6 [ 452.080015] [<ffffffff81254e88>] ? __schedule+0x5c1/0x616 [ 452.080015] [<ffffffff8103c7c6>] ? __dequeue_signal+0xb7/0x10c [ 452.080015] [<ffffffff810bbd21>] ? fget_light+0x75/0x89 [ 452.080015] [<ffffffff811c8444>] ? sockfd_lookup_light+0x20/0x56 [ 452.080015] [<ffffffff811c9b34>] sys_sendto+0x10c/0x13b [ 452.080015] [<ffffffff8125cac2>] system_call_fastpath+0x16/0x1b [ 452.080015] Code: 81 48 89 e5 72 0c 31 c0 48 81 ff 45 66 25 81 0f 92 c0 5d c3 55 b8 00 01 00 00 48 89 e5 f0 66 0f c1 07 0f b6 d4 38 d0 74 06 f3 90 <8a> 07 eb f6 5d c3 90 90 55 48 89 e5 9c 58 0f 1f 44 00 00 5d c3 [ 452.080015] Call Trace: [ 452.080015] [<ffffffff81256559>] _raw_spin_lock+0xe/0x10 [ 452.080015] [<ffffffffa01b2bd1>] l2tp_xmit_skb+0x189/0x4ac [l2tp_core] [ 452.080015] [<ffffffffa01c2d36>] pppol2tp_sendmsg+0x15e/0x19c [l2tp_ppp] [ 452.080015] [<ffffffff811c7872>] __sock_sendmsg_nosec+0x22/0x24 [ 452.080015] [<ffffffff811c83bd>] sock_sendmsg+0xa1/0xb6 [ 452.080015] [<ffffffff81254e88>] ? __schedule+0x5c1/0x616 [ 452.080015] [<ffffffff8103c7c6>] ? __dequeue_signal+0xb7/0x10c [ 452.080015] [<ffffffff810bbd21>] ? fget_light+0x75/0x89 [ 452.080015] [<ffffffff811c8444>] ? sockfd_lookup_light+0x20/0x56 [ 452.080015] [<ffffffff811c9b34>] sys_sendto+0x10c/0x13b [ 452.080015] [<ffffffff8125cac2>] system_call_fastpath+0x16/0x1b [ 452.064012] [ 452.064012] Pid: 6662, comm: accel-pppd Not tainted 3.2.46.mini #1 Bochs Bochs [ 452.064012] RIP: 0010:[<ffffffff81059f6e>] [<ffffffff81059f6e>] do_raw_spin_lock+0x19/0x1f [ 452.064012] RSP: 0018:ffff8800b6e83ba0 EFLAGS: 00000297 [ 452.064012] RAX: 000000000000aaa9 RBX: ffff8800b6e83b40 RCX: 0000000000000002 [ 452.064012] RDX: 00000000000000aa RSI: 000000000000000a RDI: ffff8800745c8110 [ 452.064012] RBP: ffff8800b6e83ba0 R08: 000000000000c802 R09: 000000000000001c [ 452.064012] R10: ffff880071096c4e R11: 0000000000000006 R12: ffff8800b6e83b18 [ 452.064012] R13: ffffffff8125d51e R14: ffff8800b6e83ba0 R15: ffff880072a589c0 [ 452.064012] FS: 00007fdc0b81e700(0000) GS:ffff8800b6e80000(0000) knlGS:0000000000000000 [ 452.064012] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 452.064012] CR2: 0000000000625208 CR3: 0000000074404000 CR4: 00000000000006a0 [ 452.064012] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 452.064012] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 452.064012] Process accel-pppd (pid: 6662, threadinfo ffff88007129a000, task ffff8800744f7410) [ 452.064012] Stack: [ 452.064012] ffff8800b6e83bb0 ffffffff81256559 ffff8800b6e83bc0 ffffffff8121c64a [ 452.064012] ffff8800b6e83bf0 ffffffff8121ec7a ffff880072a589c0 ffff880071096c62 [ 452.064012] 0000000000000011 ffffffff81430024 ffff8800b6e83c80 ffffffff8121f276 [ 452.064012] Call Trace: [ 452.064012] <IRQ> [ 452.064012] [<ffffffff81256559>] _raw_spin_lock+0xe/0x10 [ 452.064012] [<ffffffff8121c64a>] spin_lock+0x9/0xb [ 452.064012] [<ffffffff8121ec7a>] udp_queue_rcv_skb+0x186/0x269 [ 452.064012] [<ffffffff8121f276>] __udp4_lib_rcv+0x297/0x4ae [ 452.064012] [<ffffffff8121c178>] ? raw_rcv+0xe9/0xf0 [ 452.064012] [<ffffffff8121f4a7>] udp_rcv+0x1a/0x1c [ 452.064012] [<ffffffff811fe385>] ip_local_deliver_finish+0x12b/0x1a5 [ 452.064012] [<ffffffff811fe54e>] ip_local_deliver+0x53/0x84 [ 452.064012] [<ffffffff811fe1d0>] ip_rcv_finish+0x2bc/0x2f3 [ 452.064012] [<ffffffff811fe78f>] ip_rcv+0x210/0x269 [ 452.064012] [<ffffffff8101911e>] ? kvm_clock_get_cycles+0x9/0xb [ 452.064012] [<ffffffff811d88cd>] __netif_receive_skb+0x3a5/0x3f7 [ 452.064012] [<ffffffff811d8eba>] netif_receive_skb+0x57/0x5e [ 452.064012] [<ffffffff811cf30f>] ? __netdev_alloc_skb+0x1f/0x3b [ 452.064012] [<ffffffffa0049126>] virtnet_poll+0x4ba/0x5a4 [virtio_net] [ 452.064012] [<ffffffff811d9417>] net_rx_action+0x73/0x184 [ 452.064012] [<ffffffffa01b2cc2>] ? l2tp_xmit_skb+0x27a/0x4ac [l2tp_core] [ 452.064012] [<ffffffff810343b9>] __do_softirq+0xc3/0x1a8 [ 452.064012] [<ffffffff81013b56>] ? ack_APIC_irq+0x10/0x12 [ 452.064012] [<ffffffff81256559>] ? _raw_spin_lock+0xe/0x10 [ 452.064012] [<ffffffff8125e0ac>] call_softirq+0x1c/0x26 [ 452.064012] [<ffffffff81003587>] do_softirq+0x45/0x82 [ 452.064012] [<ffffffff81034667>] irq_exit+0x42/0x9c [ 452.064012] [<ffffffff8125e146>] do_IRQ+0x8e/0xa5 [ 452.064012] [<ffffffff8125676e>] common_interrupt+0x6e/0x6e [ 452.064012] <EOI> [ 452.064012] [<ffffffff810b82a1>] ? kfree+0x8a/0xa3 [ 452.064012] [<ffffffffa01b2cc2>] ? l2tp_xmit_skb+0x27a/0x4ac [l2tp_core] [ 452.064012] [<ffffffffa01b2c25>] ? l2tp_xmit_skb+0x1dd/0x4ac [l2tp_core] [ 452.064012] [<ffffffffa01c2d36>] pppol2tp_sendmsg+0x15e/0x19c [l2tp_ppp] [ 452.064012] [<ffffffff811c7872>] __sock_sendmsg_nosec+0x22/0x24 [ 452.064012] [<ffffffff811c83bd>] sock_sendmsg+0xa1/0xb6 [ 452.064012] [<ffffffff81254e88>] ? __schedule+0x5c1/0x616 [ 452.064012] [<ffffffff8103c7c6>] ? __dequeue_signal+0xb7/0x10c [ 452.064012] [<ffffffff810bbd21>] ? fget_light+0x75/0x89 [ 452.064012] [<ffffffff811c8444>] ? sockfd_lookup_light+0x20/0x56 [ 452.064012] [<ffffffff811c9b34>] sys_sendto+0x10c/0x13b [ 452.064012] [<ffffffff8125cac2>] system_call_fastpath+0x16/0x1b [ 452.064012] Code: 89 e5 72 0c 31 c0 48 81 ff 45 66 25 81 0f 92 c0 5d c3 55 b8 00 01 00 00 48 89 e5 f0 66 0f c1 07 0f b6 d4 38 d0 74 06 f3 90 8a 07 <eb> f6 5d c3 90 90 55 48 89 e5 9c 58 0f 1f 44 00 00 5d c3 55 48 [ 452.064012] Call Trace: [ 452.064012] <IRQ> [<ffffffff81256559>] _raw_spin_lock+0xe/0x10 [ 452.064012] [<ffffffff8121c64a>] spin_lock+0x9/0xb [ 452.064012] [<ffffffff8121ec7a>] udp_queue_rcv_skb+0x186/0x269 [ 452.064012] [<ffffffff8121f276>] __udp4_lib_rcv+0x297/0x4ae [ 452.064012] [<ffffffff8121c178>] ? raw_rcv+0xe9/0xf0 [ 452.064012] [<ffffffff8121f4a7>] udp_rcv+0x1a/0x1c [ 452.064012] [<ffffffff811fe385>] ip_local_deliver_finish+0x12b/0x1a5 [ 452.064012] [<ffffffff811fe54e>] ip_local_deliver+0x53/0x84 [ 452.064012] [<ffffffff811fe1d0>] ip_rcv_finish+0x2bc/0x2f3 [ 452.064012] [<ffffffff811fe78f>] ip_rcv+0x210/0x269 [ 452.064012] [<ffffffff8101911e>] ? kvm_clock_get_cycles+0x9/0xb [ 452.064012] [<ffffffff811d88cd>] __netif_receive_skb+0x3a5/0x3f7 [ 452.064012] [<ffffffff811d8eba>] netif_receive_skb+0x57/0x5e [ 452.064012] [<ffffffff811cf30f>] ? __netdev_alloc_skb+0x1f/0x3b [ 452.064012] [<ffffffffa0049126>] virtnet_poll+0x4ba/0x5a4 [virtio_net] [ 452.064012] [<ffffffff811d9417>] net_rx_action+0x73/0x184 [ 452.064012] [<ffffffffa01b2cc2>] ? l2tp_xmit_skb+0x27a/0x4ac [l2tp_core] [ 452.064012] [<ffffffff810343b9>] __do_softirq+0xc3/0x1a8 [ 452.064012] [<ffffffff81013b56>] ? ack_APIC_irq+0x10/0x12 [ 452.064012] [<ffffffff81256559>] ? _raw_spin_lock+0xe/0x10 [ 452.064012] [<ffffffff8125e0ac>] call_softirq+0x1c/0x26 [ 452.064012] [<ffffffff81003587>] do_softirq+0x45/0x82 [ 452.064012] [<ffffffff81034667>] irq_exit+0x42/0x9c [ 452.064012] [<ffffffff8125e146>] do_IRQ+0x8e/0xa5 [ 452.064012] [<ffffffff8125676e>] common_interrupt+0x6e/0x6e [ 452.064012] <EOI> [<ffffffff810b82a1>] ? kfree+0x8a/0xa3 [ 452.064012] [<ffffffffa01b2cc2>] ? l2tp_xmit_skb+0x27a/0x4ac [l2tp_core] [ 452.064012] [<ffffffffa01b2c25>] ? l2tp_xmit_skb+0x1dd/0x4ac [l2tp_core] [ 452.064012] [<ffffffffa01c2d36>] pppol2tp_sendmsg+0x15e/0x19c [l2tp_ppp] [ 452.064012] [<ffffffff811c7872>] __sock_sendmsg_nosec+0x22/0x24 [ 452.064012] [<ffffffff811c83bd>] sock_sendmsg+0xa1/0xb6 [ 452.064012] [<ffffffff81254e88>] ? __schedule+0x5c1/0x616 [ 452.064012] [<ffffffff8103c7c6>] ? __dequeue_signal+0xb7/0x10c [ 452.064012] [<ffffffff810bbd21>] ? fget_light+0x75/0x89 [ 452.064012] [<ffffffff811c8444>] ? sockfd_lookup_light+0x20/0x56 [ 452.064012] [<ffffffff811c9b34>] sys_sendto+0x10c/0x13b [ 452.064012] [<ffffffff8125cac2>] system_call_fastpath+0x16/0x1b Reported-by: François Cachereul <f.cachereul@alphalink.fr> Tested-by: François Cachereul <f.cachereul@alphalink.fr> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04net: vlan: fix nlmsg size calculation in vlan_get_size()Marc Kleine-Budde
[ Upstream commit c33a39c575068c2ea9bffb22fd6de2df19c74b89 ] This patch fixes the calculation of the nlmsg size, by adding the missing nla_total_size(). Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04bridge: Correctly clamp MAX forward_delay when enabling STPVlad Yasevich
[ Upstream commit 4b6c7879d84ad06a2ac5b964808ed599187a188d ] Commit be4f154d5ef0ca147ab6bcd38857a774133f5450 bridge: Clamp forward_delay when enabling STP had a typo when attempting to clamp maximum forward delay. It is possible to set bridge_forward_delay to be higher then permitted maximum when STP is off. When turning STP on, the higher then allowed delay has to be clamed down to max value. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> CC: Herbert Xu <herbert@gondor.apana.org.au> CC: Stephen Hemminger <shemminger@vyatta.com> Reviewed-by: Veaceslav Falico <vfalico@redhat.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
