commit d05f0cdcbe6388723f1900c549b4850360545201 upstream.
In v2.6.34 commit 9d8cebd4bcd7 ("mm: fix mbind vma merge problem")
introduced vma merging to mbind(), but it should have also changed the
convention of passing start vma from queue_pages_range() (formerly
check_range()) to new_vma_page(): vma merging may have already freed
that structure, resulting in BUG at mm/mempolicy.c:1738 and probably
worse crashes.
Fixes: 9d8cebd4bcd7 ("mm: fix mbind vma merge problem")
Reported-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Tested-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Christoph Lameter <cl@linux.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
commit 4a705fef986231a3e7a6b1a6d3c37025f021f49f upstream.
There's a race between fork() and hugepage migration, as a result we try
to "dereference" a swap entry as a normal pte, causing kernel panic.
The cause of the problem is that copy_hugetlb_page_range() can't handle
"swap entry" family (migration entry and hwpoisoned entry) so let's fix
it.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: <stable@vger.kernel.org> [2.6.37+]
commit d1211af3049f4c9c1d8d4eb8f8098cc4f4f0d0c7 upstream.
arch/powerpc/kernel/sysfs.c exports PURR with write permission.
This may be valid for kernel in phyp mode. But writing to
the file in guest mode causes crash due to a priviledge violation
Signed-off-by: Madhavan Srinivasan <maddy@linux.vnet.ibm.com>
[Backported to 3.4: adjust context]
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
commit 771d09b3c4c45d4d534a83a68e6331b97fd82e15 upstream.
On a HP Pavilion dm4 laptop the BIOS sets minimum backlight on boot,
completely dimming the screen. Ignore this initial value for this
machine.
Signed-off-by: Gustavo Maciel Dias Vieira <gustavo@sagui.org>
[wyj: Backported to 3.4: adjust context]
commit 84b073868b9d9e754ae48b828337633d1b386482 upstream.
When reading from the dispatch trace log (dtl) userspace interface, I
sometimes see duplicate entries. One example:
# hexdump -C dtl.out
00000000 07 04 00 0c 00 00 48 44 00 00 00 00 00 00 00 00
00000010 00 0c a0 b4 16 83 6d 68 00 00 00 00 00 00 00 00
00000020 00 00 00 00 10 00 13 50 80 00 00 00 00 00 d0 32
00000030 07 04 00 0c 00 00 48 44 00 00 00 00 00 00 00 00
00000040 00 0c a0 b4 16 83 6d 68 00 00 00 00 00 00 00 00
00000050 00 00 00 00 10 00 13 50 80 00 00 00 00 00 d0 32
The problem is in scan_dispatch_log() where we call dtl_consumer()
but bail out before incrementing the index.
To fix this I moved dtl_consumer() after the timebase comparison.
[bwh: Backported to 3.2: adjust context]
Cc: Yijing Wang <wangyijing@huawei.com>
commit 5676005acf26ab7e924a8438ea4746e47d405762 upstream.
need set '\0' for 'local_buffer'.
SPLPAR_MAXLENGTH is 1026, RTAS_DATA_BUF_SIZE is 4096. so the contents of
rtas_data_buf may truncated in memcpy.
if contents are really truncated.
the splpar_strlen is more than 1026. the next while loop checking will
not find the end of buffer. that will cause memory access violation.
Signed-off-by: Chen Gang <gang.chen@asianux.com>
commit 8f21bd0090052e740944f9397e2be5ac7957ded7 upstream.
The csum_partial_copy_generic() function saves the PowerPC non-volatile
r14, r15, and r16 registers for the main checksum-and-copy loop.
Unfortunately, it fails to restore them upon error exit from this loop,
which results in silent corruption of these registers in the presumably
rare event of an access exception within that loop.
This commit therefore restores these register on error exit from the loop.
[bwh: Backported to 3.2: register name macros use lower-case 'r']
commit f5f6cbb61610b7bf9d9d96db9c3979d62a424bab upstream.
/proc/powerpc/lparcfg is an ancient facility (though still actively used)
which allows access to some informations relative to the partition when
running underneath a PAPR compliant hypervisor.
It makes no sense on non-pseries machines. However, currently, not only
can it be created on these if the kernel has pseries support, but accessing
it on such a machine will crash due to trying to do hypervisor calls.
In fact, it should also not do HV calls on older pseries that didn't have
an hypervisor either.
Finally, it has the plumbing to be a module but is a "bool" Kconfig option.
This fixes the whole lot by turning it into a machine_device_initcall
that is only created on pseries, and adding the necessary hypervisor
check before calling the H_GET_EM_PARMS hypercall
[bwh: Backported to 3.2: lparcfg_cleanup() was a bit different]
spinning_secondaries
commit 8246aca7058f3f2c2ae503081777965cd8df7b90 upstream.
the smp_release_cpus is a normal funciton and called in normal environments,
but it calls the __initdata spinning_secondaries.
need modify spinning_secondaries to match smp_release_cpus.
the related warning:
(the linker report boot_paca.33377, but it should be spinning_secondaries)
WARNING: arch/powerpc/kernel/built-in.o(.text+0x23176): Section mismatch in reference from the function .smp_release_cpus() to the variable .init.data:boot_paca.33377
The function .smp_release_cpus() references
the variable __initdata boot_paca.33377.
This is often because .smp_release_cpus lacks a __initdata
annotation or the annotation of boot_paca.33377 is wrong.
WARNING: arch/powerpc/kernel/built-in.o(.text+0x231fe): Section mismatch in reference from the function .smp_release_cpus() to the variable .init.data:boot_paca.33377
commit bf593907f7236e95698a76b7c7a2bbf8b1165327 upstream.
Normally, the kernel emulates a few instructions that are unimplemented
on some processors (e.g. the old dcba instruction), or privileged (e.g.
mfpvr). The emulation of unimplemented instructions is currently not
working on the PowerNV platform. The reason is that on these machines,
unimplemented and illegal instructions cause a hypervisor emulation
assist interrupt, rather than a program interrupt as on older CPUs.
Our vector for the emulation assist interrupt just calls
program_check_exception() directly, without setting the bit in SRR1
that indicates an illegal instruction interrupt. This fixes it by
making the emulation assist interrupt set that bit before calling
program_check_interrupt(). With this, old programs that use no-longer
implemented instructions such as dcba now work again.
commit 4f29ef050848245f7c180b95ccf67dfcd76b1fd8 upstream.
This patch adds two new products and modifies
the device id table to include them. In addition,
product of 0xbccd - BCM_USB_PRODUCT_ID_SM250 is
removed because Beceem, ZTE, Sprint use this id
for block devices.
Reported-by: Muhammad Minhazul Haque <mdminhazulhaque@gmail.com>
Signed-off-by: Kevin McKinney <klmckinney1@gmail.com>
commit e66fc1fba248738d32f3b64508f9ef1176d9e767 upstream.
This patch create and initalizes a new device
id of 0x172 as reported by Rinat Camalov
<richman1000000d@gmail.com>. In addition, a
comment is added to the potential invalid
existing device id.
Reported-by: Rinat Camalov <richman1000000d@gmail.com>
commit b5e2f339865fb443107e5b10603e53bbc92dc054 upstream.
We need to check the length parameter before doing the memcpy(). I've
actually changed it to strlcpy() as well so that it's NUL terminated.
You need CAP_NET_ADMIN to trigger these so it's not the end of the
world.
Reported-by: Nico Golde <nico@ngolde.de>
Reported-by: Fabian Yamaguchi <fabs@goesec.de>
commit 4b18f08be01a7b3c7b6df497137b6e3cb28adaa3 upstream.
`do_cmd_ioctl()` is called with the comedi device's mutex locked to
process the `COMEDI_CMD` ioctl to set up comedi's asynchronous command
handling on a comedi subdevice. `comedi_read()` and `comedi_write()`
are the `read` and `write` handlers for the comedi device, but do not
lock the mutex (for performance reasons, as some things can hold the
mutex for quite a long time).
There is a race condition if `comedi_read()` or `comedi_write()` is
running at the same time and for the same file object and comedi
subdevice as `do_cmd_ioctl()`. `do_cmd_ioctl()` sets the subdevice's
`busy` pointer to the file object way before it sets the `SRF_RUNNING` flag
in the subdevice's `runflags` member. `comedi_read() and
`comedi_write()` check the subdevice's `busy` pointer is pointing to the
current file object, then if the `SRF_RUNNING` flag is not set, will call
`do_become_nonbusy()` to shut down the asyncronous command. Bad things
can happen if the asynchronous command is being shutdown and set up at
the same time.
To prevent the race, don't set the `busy` pointer until
after the `SRF_RUNNING` flag has been set. Also, make sure the mutex is
held in `comedi_read()` and `comedi_write()` while calling
`do_become_nonbusy()` in order to avoid moving the race condition to a
point within that function.
Change some error handling `goto cleanup` statements in `do_cmd_ioctl()`
to simple `return -ERRFOO` statements as a result of changing when the
`busy` pointer is set.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
commit e6391a182865efc896cb2a8d79e07b7ac2f45b48 upstream.
The element of `das08_boards[]` for the 'das08jr-16-ao' board has the
`ai_encoding` member set to `das08_encode12`. It should be set to
`das08_encode16` same as the 'das08jr/16' board. After all, this board
has 16-bit AI resolution.
The description of the A/D LSB register at offset 0 seems incorrect in
the user manual "cio-das08jr-16-ao.pdf" as it implies that the AI
resolution is only 12 bits. The diagrams of the A/D LSB and MSB
registers show 15 data bits and a sign bit, which matches what the
software expects for the `das08_encode16` AI encoding method.
[bwh: Backported to 3.2: adjust indentation]
commit 4ef366c583d6180b1c951147869ee5a3038834f2 upstream.
On HP 1000 lapops, BIOS reports minimum backlight on boot and
causes backlight to dim completely. This ignores the initial backlight
values and set to max brightness.
References:: https://bugs.launchpad.net/bugs/1167760
Signed-off-by: Alex Hung <alex.hung@canonical.com>
commit c8f6d8351ba8c89d5cd4c562552ec7ec29274e31 upstream.
Like on UL30VT, the ACPI video driver can't control backlight correctly on
Asus UL30A. Vendor driver (asus-laptop) can work. This patch is to
add "Asus UL30A" to ACPI video detect blacklist in order to use
asus-laptop for video control on the "Asus UL30A" rather than ACPI
video driver.
Signed-off-by: Bastian Triller <bastian.triller@gmail.com>
commit d0c2ce16bec0afa6013b4c5220ca4c9c67210215 upstream.
The ACPI video driver can't control backlight correctly on
Asus UL30VT. Vendor driver (asus-laptop) can work. This patch is to
add "Asus UL30VT" to ACPI video detect blacklist in order to use
asus-laptop for video control on the "Asus UL30VT" rather than ACPI
video driver.
References: https://bugzilla.kernel.org/show_bug.cgi?id=32592
Reported-by: Alex Williamson <alex.williamson@redhat.com>
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
commit 084940d5b101e9ca91a689eb5048151b14076839 upstream.
On Samsung X360, the BIOS will set a flag (VDRV) if the generic
ACPI backlight device is used. This flag will definitively break
the backlight interface (even the vendor interface) untill next
reboot. It's why we should prevent video.ko from being used here
and we can't rely on a later call to acpi_video_unregister().
Signed-off-by: Corentin Chary <corentin.chary@gmail.com>
commit fd1232b214af43a973443aec6a2808f16ee5bf70 upstream.
This patch fixes I/O errors with the sym53c8xx_2 driver when the disk
returns QUEUE FULL status.
When the controller encounters an error (including QUEUE FULL or BUSY
status), it aborts all not yet submitted requests in the function
sym_dequeue_from_squeue.
This function aborts them with DID_SOFT_ERROR.
If the disk has full tag queue, the request that caused the overflow is
aborted with QUEUE FULL status (and the scsi midlayer properly retries
it until it is accepted by the disk), but the sym53c8xx_2 driver aborts
the following requests with DID_SOFT_ERROR --- for them, the midlayer
does just a few retries and then signals the error up to sd.
The result is that disk returning QUEUE FULL causes request failures.
The error was reproduced on 53c895 with COMPAQ BD03685A24 disk
(rebranded ST336607LC) with command queue 48 or 64 tags. The disk has
64 tags, but under some access patterns it return QUEUE FULL when there
are less than 64 pending tags. The SCSI specification allows returning
QUEUE FULL anytime and it is up to the host to retry.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: James Bottomley <JBottomley@Parallels.com>
commit 133d4527eab8d199a62eee6bd433f0776842df2e upstream.
When we write to a degraded array which has a bitmap, we
make sure the relevant bit in the bitmap remains set when
the write completes (so a 're-add' can quickly rebuilt a
temporarily-missing device).
If, immediately after such a write starts, we incorporate a spare,
commence recovery, and skip over the region where the write is
happening (because the 'needs recovery' flag isn't set yet),
then that write will not get to the new device.
Once the recovery finishes the new device will be trusted, but will
have incorrect data, leading to possible corruption.
We cannot set the 'needs recovery' flag when we start the write as we
do not know easily if the write will be "degraded" or not. That
depends on details of the particular raid level and particular write
request.
This patch fixes a corruption issue of long standing and so it
suitable for any -stable kernel. It applied correctly to 3.0 at
least and will minor editing to earlier kernels.
Reported-by: Bill <billstuff2001@sbcglobal.net>
Tested-by: Bill <billstuff2001@sbcglobal.net>
Link: http://lkml.kernel.org/r/53A518BB.60709@sbcglobal.net
Signed-off-by: NeilBrown <neilb@suse.de>
commit f35f71244da6e51db4e1f2c7e318581f498ececf upstream.
It appears that no one ever run ffs-test on a big-endian machine,
since it used cpu-endianess for fs_count and hs_count fields which
should be in little-endian format. Fix by wrapping the numbers in
cpu_to_le32.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 76f47128f9b33af1e96819746550d789054c9664 upstream.
An NFS operation that creates a new symlink includes the symlink data,
which is xdr-encoded as a length followed by the data plus 0 to 3 bytes
of zero-padding as required to reach a 4-byte boundary.
The vfs, on the other hand, wants null-terminated data.
The simple way to handle this would be by copying the data into a newly
allocated buffer with space for the final null.
The current nfsd_symlink code tries to be more clever by skipping that
step in the (likely) case where the byte following the string is already
0.
But that assumes that the byte following the string is ours to look at.
In fact, it might be the first byte of a page that we can't read, or of
some object that another task might modify.
Worse, the NFSv4 code tries to fix the problem by actually writing to
that byte.
In the NFSv2/v3 cases this actually appears to be safe:
- nfs3svc_decode_symlinkargs explicitly null-terminates the data
(after first checking its length and copying it to a new
page).
- NFSv2 limits symlinks to 1k. The buffer holding the rpc
request is always at least a page, and the link data (and
previous fields) have maximum lengths that prevent the request
from reaching the end of a page.
In the NFSv4 case the CREATE op is potentially just one part of a long
compound so can end up on the end of a page if you're unlucky.
The minimal fix here is to copy and null-terminate in the NFSv4 case.
The nfsd_symlink() interface here seems too fragile, though. It should
really either do the copy itself every time or just require a
null-terminated string.
Reported-by: Jeff Layton <jlayton@primarydata.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 7cb060a91c0efc5ff94f83c6df3ed705e143cdb9 upstream.
KVM does not really do much with the PAT, so this went unnoticed for a
long time. It is exposed however if you try to do rdmsr on the PAT
register.
Reported-by: Valentine Sinitsyn <valentine.sinitsyn@gmail.com>
commit 682367c494869008eb89ef733f196e99415ae862 upstream.
Recent Intel CPUs have 10 variable range MTRRs. Since operating systems
sometime make assumptions on CPUs while they ignore capability MSRs, it is
better for KVM to be consistent with recent CPUs. Reporting more MTRRs than
actually supported has no functional implications.
Signed-off-by: Nadav Amit <namit@cs.technion.ac.il>
option
commit ce36d9ab3bab06b7b5522f5c8b68fac231b76ffb upstream.
When we SMB3 mounted with mapchars (to allow reserved characters : \ / > < * ?
via the Unicode Windows to POSIX remap range) empty paths
(eg when we open "" to query the root of the SMB3 directory on mount) were not
null terminated so we sent garbarge as a path name on empty paths which caused
SMB2/SMB2.1/SMB3 mounts to fail when mapchars was specified. mapchars is
particularly important since Unix Extensions for SMB3 are not supported (yet)
Signed-off-by: Steve French <smfrench@gmail.com>
Reviewed-by: David Disseldorp <ddiss@suse.de>
commit 2fc68eb122c7ea6cd5be1fe7d6650c0beb2f4f40 upstream.
Support for firmware rev 508+ was added years ago, but we never noticed
it reports channel in a different way for G-PHY devices. Instead of
offset from 2400 MHz it simply passes channel id (AKA hw_value).
So far it was (most probably) affecting monitor mode users only, but
the following recent commit made it noticeable for quite everybody:
commit 3afc2167f60a327a2c1e1e2600ef209a3c2b75b7
Author: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Date: Tue Mar 4 16:50:13 2014 +0200
cfg80211/mac80211: ignore signal if the frame was heard on wrong channel
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
commit c021f241f4fab2bb4fc4120a38a828a03dd3f970 upstream.
Fix a parser-bug in the omap2 muxing code where muxtable-entries will be
wrongly selected if the requested muxname is a *prefix* of their
m0-entry and they have a matching mN-entry. Fix by additionally checking
that the length of the m0_entry is equal.
For example muxing of "dss_data2.dss_data2" on omap32xx will fail
because the prefix "dss_data2" will match the mux-entries "dss_data2" as
well as "dss_data20", with the suffix "dss_data2" matching m0 (for
dss_data2) and m4 (for dss_data20). Thus both are recognized as signal
path candidates:
Relevant muxentries from mux34xx.c:
_OMAP3_MUXENTRY(DSS_DATA20, 90,
"dss_data20", NULL, "mcspi3_somi", "dss_data2",
"gpio_90", NULL, NULL, "safe_mode"),
_OMAP3_MUXENTRY(DSS_DATA2, 72,
"dss_data2", NULL, NULL, NULL,
"gpio_72", NULL, NULL, "safe_mode"),
This will result in a failure to mux the pin at all:
_omap_mux_get_by_name: Multiple signal paths (2) for dss_data2.dss_data2
Patch should apply to linus' latest master down to rather old linux-2.6
trees.
Signed-off-by: David R. Piegdon <lkml@p23q.org>
Cc: stable@vger.kernel.org
[tony@atomide.com: updated description to include full description]
commit 923eaf367206e01f22c97aee22300e332d071916 upstream.
Doing so will lead to an oops for a p2p-dev interface, since it has
no netdev.
Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit e10b9969f217c948c5523045f44eba4d3a758ff0 upstream.
In this API, we were using sizeof operator for an array
given as function argument, which is invalid.
However this API is not used anywhere.
Signed-off-by: Syam Sidhardhan <s.syam@samsung.com>
Signed-off-by: Gustavo Padovan <gustavo@padovan.org>
commit ba15a58b179ed76a7e887177f2b06de12c58ec8f upstream.
From the Bluetooth Core Specification 4.1 page 1958:
"if both devices have set the Authentication_Requirements parameter to
one of the MITM Protection Not Required options, authentication stage 1
shall function as if both devices set their IO capabilities to
DisplayOnly (e.g., Numeric comparison with automatic confirmation on
both devices)"
So far our implementation has done user confirmation for all just-works
cases regardless of the MITM requirements, however following the
specification to the word means that we should not be doing confirmation
when neither side has the MITM flag set.
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
Tested-by: Szymon Janc <szymon.janc@tieto.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 4e578080ed3262ed2c3985868539bc66218d25c0 upstream.
Commit "drm/vmwgfx: correct fb_fix_screeninfo.line_length", while fixing a
vmwgfx fbdev bug, also writes the pitch to a supposedly read-only register:
SVGA_REG_BYTES_PER_LINE, while it should be (and also in fact is) written to
SVGA_REG_PITCHLOCK.
This patch is Cc'd stable because of the unknown effects writing to this
register might have, particularly on older device versions.
v2: Updated log message.
Cc: Christopher Friedt <chrisfriedt@gmail.com>
Tested-by: Christopher Friedt <chrisfriedt@gmail.com>
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
commit 642528355c694f5ed68f6bff9ff520326a249f99 upstream.
We need to specify the encoder mode as LVDS for eDP
when using the Crtc_Source atom table in order to properly
set up the FMT hardware.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=73911
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit af5d36539dfe043f1cf0f8b7334d6bb12cd14e75 upstream.
We were checking the ext clock rather than the display clock.
Noticed by ArtForz on IRC.
commit 7d5ab3009a8ca777174f6f469277b3922d56fd4b upstream.
May fix display issues with non-HDMI displays.
commit b7e460624f0f3c31150f3b09e75b0d009e22ba5f upstream.
The pxa3xx_nand driver currently uses __raw_writel() and __raw_readl()
to access I/O registers. However, those functions do not do any
endianness swapping, which means that they won't work when the CPU
runs in big-endian but the I/O registers are little endian, which is
the common situation for ARM systems running big endian.
Since __raw_writel() and __raw_readl() do not include any memory
barriers and the pxa3xx_nand driver can only be compiled for ARM
platforms, the closest I/o accessors functions that do endianess
swapping are writel_relaxed() and readl_relaxed().
This patch has been verified to work on Armada XP GP: without the
patch, the NAND is not detected when the kernel runs big endian while
it is properly detected when the kernel runs little endian. With the
patch applied, the NAND is properly detected in both situations
(little and big endian).
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
commit 616a8394b5df8c88f4dd416f4527439a4e365034 upstream.
As reported by Niels, starting rfkill polling during device probe
(commit e2bc7c5, generally sane change) broke rfkill on rt2500pci
device. I considered that bug as some initalization issue, which
should be fixed on rt2500pci specific code. But after several
attempts (see bug report for details) we fail to find working solution.
Hence I decided to revert to old behaviour on rt2500pci to fix
regression.
Additionally patch also unregister rfkill on device remove instead
of ifconfig down, what was another issue introduced by bad commit.
Bug report:
https://bugzilla.kernel.org/show_bug.cgi?id=73821
Fixes: e2bc7c5f3cb8 ("rt2x00: Fix rfkill_polling register function.")
Bisected-by: Niels <nille0386@googlemail.com>
Reported-and-tested-by: Niels <nille0386@googlemail.com>
Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
commit 8edcb0ba0d56f5914eef11eda6db8bfe74eb9ca8 upstream.
On USB we can not get atomically TKIP key. We have to disable support
for TKIP acceleration on USB hardware to avoid bug as showed bellow.
[ 860.827243] BUG: scheduling while atomic: hostapd/3397/0x00000002
<snip>
[ 860.827280] Call Trace:
[ 860.827282] [<ffffffff81682ea6>] dump_stack+0x4d/0x66
[ 860.827284] [<ffffffff8167eb9b>] __schedule_bug+0x47/0x55
[ 860.827285] [<ffffffff81685bb3>] __schedule+0x733/0x7b0
[ 860.827287] [<ffffffff81685c59>] schedule+0x29/0x70
[ 860.827289] [<ffffffff81684f8a>] schedule_timeout+0x15a/0x2b0
[ 860.827291] [<ffffffff8105ac50>] ? ftrace_raw_event_tick_stop+0xc0/0xc0
[ 860.827294] [<ffffffff810c13c2>] ? __module_text_address+0x12/0x70
[ 860.827296] [<ffffffff81686823>] wait_for_completion_timeout+0xb3/0x140
[ 860.827298] [<ffffffff81080fc0>] ? wake_up_state+0x20/0x20
[ 860.827301] [<ffffffff814d5b3d>] usb_start_wait_urb+0x7d/0x150
[ 860.827303] [<ffffffff814d5cd5>] usb_control_msg+0xc5/0x110
[ 860.827305] [<ffffffffa02fb0c6>] rt2x00usb_vendor_request+0xc6/0x160 [rt2x00usb]
[ 860.827307] [<ffffffffa02fb215>] rt2x00usb_vendor_req_buff_lock+0x75/0x150 [rt2x00usb]
[ 860.827309] [<ffffffffa02fb393>] rt2x00usb_vendor_request_buff+0xa3/0xe0 [rt2x00usb]
[ 860.827311] [<ffffffffa023d1a3>] rt2x00usb_register_multiread+0x33/0x40 [rt2800usb]
[ 860.827314] [<ffffffffa05805f9>] rt2800_get_tkip_seq+0x39/0x50 [rt2800lib]
[ 860.827321] [<ffffffffa0480f88>] ieee80211_get_key+0x218/0x2a0 [mac80211]
[ 860.827322] [<ffffffff815cc68c>] ? __nlmsg_put+0x6c/0x80
[ 860.827329] [<ffffffffa051b02e>] nl80211_get_key+0x22e/0x360 [cfg80211]
Reported-and-tested-by: Peter Wu <lekensteyn@gmail.com>
Reported-and-tested-by: Pontus Fuchs <pontus.fuchs@gmail.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit f0688c8b81d2ea239c3fb0b848f623b579238d99 upstream.
If the descriptors do not need any strings and user space sends empty
set of strings, the ffs->stringtabs field remains NULL. Thus
*ffs->stringtabs in functionfs_bind leads to a NULL pointer
dereferenece.
The bug was introduced by commit [fd7c9a007f: “use usb_string_ids_n()”].
While at it, remove double initialisation of lang local variable in
that function.
ffs->strings_count does not need to be checked in any way since in
the above scenario it will remain zero and usb_string_ids_n() is
a no-operation when colled with 0 argument.
commit aea1ae8760314e072bf1b773521e9de5d5dda10d upstream.
Fix NULL-pointer dereference when probing an interface with no
endpoints.
These devices have two bulk endpoints per interface, but this avoids
crashing the kernel if a user forces a non-FTDI device to be probed.
Note that the iterator variable was made unsigned in order to avoid
a maybe-uninitialized compiler warning for ep_desc after the loop.
Fixes: 895f28badce9 ("USB: ftdi_sio: fix hi-speed device packet size
calculation")
Reported-by: Mike Remski <mremski@mutualink.net>
Tested-by: Mike Remski <mremski@mutualink.net>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit b0ebef36e93703e59003ad6a1a20227e47714417 upstream.
Adding a couple of Olivetti modems and blacklisting the net
function on a couple which are already supported.
Reported-by: Lars Melin <larsm17@gmail.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit 1cab4c68e339086cdaff7535848e878e8f261fca upstream.
Reported by Alif Mubarak Ahmad:
This device vendor and product id is 1c9e:9800
It is working as serial interface with generic usbserial driver.
I thought it is more suitable to use usbserial option driver, which has
better capability distinguishing between modem serial interface and
micro sd storage interface.
[ johan: style changes ]
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Tested-by: Alif Mubarak Ahmad <alive4ever@live.com>
commit 17b72feb2be14e6d37023267dc0e199e8e0e3fdc upstream.
Matching on device and interface class with with unspecified
subclass and protocol is sometimes useful. This is slightly
different from USB_DEVICE_AND_INTERFACE_INFO which requires
the full interface class/subclass/protocol triplet.
commit d6236f6d1d885aa19d1cd7317346fe795227a3cc upstream.
The system suspend flow as following:
1, Freeze all user processes and kenrel threads.
2, Try to suspend all devices.
2.1, If pci device is in RPM suspended state, then pci driver will try
to resume it to RPM active state in the prepare stage.
2.2, xhci_resume function calls usb_hcd_resume_root_hub to queue two
workqueue items to resume usb2&usb3 roothub devices.
2.3, Call suspend callbacks of devices.
2.3.1, All suspend callbacks of all hcd's children, including
roothub devices are called.
2.3.2, Finally, hcd_pci_suspend callback is called.
Due to workqueue threads were already frozen in step 1, the workqueue
items can't be scheduled, and the roothub devices can't be resumed in
this flow. The HCD_FLAG_WAKEUP_PENDING flag which is set in
usb_hcd_resume_root_hub won't be cleared. Finally,
hcd_pci_suspend will return -EBUSY, and system suspend fails.
The reason why this issue doesn't show up very often is due to that
choose_wakeup will be called in step 2.3.1. In step 2.3.1, if
udev->do_remote_wakeup is not equal to device_may_wakeup(&udev->dev), then
udev will resume to RPM active for changing the wakeup settings. This
has been a lucky hit which hides this issue.
For some special xHCI controllers which have no USB2 port, then roothub
will not match hub driver due to probe failed. Then its
do_remote_wakeup will be set to zero, and we won't be as lucky.
xhci driver doesn't need to resume roothub devices everytime like in
the above case. It's only needed when there are pending event TRBs.
This patch should be back-ported to kernels as old as 3.2, that
contains the commit f69e3120df82391a0ee8118e0a156239a06b2afb
"USB: XHCI: resume root hubs when the controller resumes"
Signed-off-by: Wang, Yu <yu.y.wang@intel.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
[use readl() instead of removed xhci_readl(), reword commit message -Mathias]
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 3213b151387df0b95f4eada104f68eb1c1409cb3 upstream.
The transfer burst count (TBC) field in xhci 1.0 hosts should be set
to the number of bursts needed to transfer all packets in a isoc TD.
Supported values are 0-2 (1 to 3 bursts per service interval).
Formula for TBC calculation is given in xhci spec section 4.11.2.3:
TBC = roundup( Transfer Descriptor Packet Count / Max Burst Size +1 ) - 1
This patch should be applied to stable kernels since 3.0 that contain
the commit 5cd43e33b9519143f06f507dd7cbee6b7a621885
"xhci 1.0: Set transfer burst count field."
Suggested-by: ShiChun Ma <masc2008@qq.com>
commit 9ee755974bea2f9880e517ec985dc9dede1b3a36 upstream.
If a CRQ reset is triggered for some reason while in the middle
of performing VSCSI adapter initialization, we don't want to
call the done function for the initialization MAD commands as
this will only result in two threads attempting initialization
at the same time, resulting in failures.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Acked-by: Nathan Fontenot <nfont@linux.vnet.ibm.com>
commit 4af4206be2bd1933cae20c2b6fb2058dbc887f7c upstream.
syscall_regfunc() and syscall_unregfunc() should set/clear
TIF_SYSCALL_TRACEPOINT system-wide, but do_each_thread() can race
with copy_process() and miss the new child which was not added to
the process/thread lists yet.
Change copy_process() to update the child's TIF_SYSCALL_TRACEPOINT
under tasklist.
Link: http://lkml.kernel.org/p/20140413185854.GB20668@redhat.com
Fixes: a871bd33a6c0 "tracing: Add syscall tracepoints"
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
commit b9cd18de4db3c9ffa7e17b0dc0ca99ed5aa4d43a upstream.
The 'sysret' fastpath does not correctly restore even all regular
registers, much less any segment registers or reflags values. That is
very much part of why it's faster than 'iret'.
Normally that isn't a problem, because the normal ptrace() interface
catches the process using the signal handler infrastructure, which
always returns with an iret.
However, some paths can get caught using ptrace_event() instead of the
signal path, and for those we need to make sure that we aren't going to
return to user space using 'sysret'. Otherwise the modifications that
may have been done to the register set by the tracer wouldn't
necessarily take effect.
Fix it by forcing IRET path by setting TIF_NOTIFY_RESUME from
arch_ptrace_stop_needed() which is invoked from ptrace_stop().
Reported-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
