- Add some new compute regs
- Add new dispatch packets for evergreen/cayman
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
. and some comments to make it easier to understand.
Ackedby: Randy Dunlap <randy.dunlap@oracle.com>
[v2: Added some more updates from Randy Dunlap]
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
No need to assign the same copy callback for both
copy blit and dma.
Nouveau is going to use these hooks to map/unmap objects from a client's
private GPU address space.
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
0xff01 is not an actual voltage value, but a flag
for the driver. If the power state as that value,
skip setting the voltage.
this printk isn't really useful, just drop it for now.
git://anongit.freedesktop.org/git/nouveau/linux-2.6 into drm-fixes
* 'drm-nouveau-fixes' of git://anongit.freedesktop.org/git/nouveau/linux-2.6:
drm/nouveau: fix assumption that semaphore dmaobj is valid in x-chan sync
drm/nv50/disp: fix gamma with page flipping overlay turned on
drm/nouveau/pm: Prevent overflow in nouveau_perf_init()
drm/nouveau: fix big-endian switch
Since we were calling the wptr function before checking if the IH was
even enabled, or the GPU wasn't shutdown, we'd get spam in the logs when
the GPU readback 0xffffffff. This reorders things so we return early
in the no IH and GPU shutdown cases.
Reported-and-tested-by: ManDay on #radeon
Reviewed-by: Alex Deucher <alexdeucher@gmail.com>
This is used during phy init to set up the phy for DP. This may
fix DP problems on DCE3.2 cards.
Certain revisions of the vbios on DCE3.2 cards have a bug
in the transmitter control table which prevents duallink from
being enabled properly on some cards. The action switch statement
jumps to the wrong offset for the OUTPUT_ENABLE action. The fix
is to use the ENABLE action rather than the OUTPUT_ENABLE action
on the affected cards. In fixed version of the vbios, both
actions jump to the same offset, so the change should be safe.
Reported-and-tested-by: Dave Airlie <airlied@redhat.com>
Cc: stable@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging:
hwmon: (s3c) Initialize sysfs attributes
hwmon: (ibmpex) Initialize sysfs attributes
hwmon: (ibmaem) Initialize sysfs attributes
hwmon: (asus_atk0110) Consolidate sysfs attribute initialization
hwmon: (coretemp) Drop unused struct members
In isofs_fill_super(), when an iso_primary_descriptor is found, it is
kept in pri_bh. The error cases don't properly release it. Fix it.
Reported-and-tested-by: 김원석 <stanley.will.kim@gmail.com>
Initialize dynamically allocated sysfs attributes before device_create_file()
call to suppress lockdep_init_map() warning if lockdep debugging is enabled.
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
Cc: stable@kernel.org # 2.6.34+
Call sysfs_attr_init() from atk_init_attribute() to handle sysfs attribute
initialization in a single function.
Cc: Luca Tettamanti <kronos.it@gmail.com>
pdev_entry.cpu and pdev_entry.cpu_core_id aren't used anywhere in the
driver code so we can drop these struct members.
Cc: Guenter Roeck <guenter.roeck@ericsson.com>
Cc: Durgadoss R <durgadoss.r@intel.com>
The DDX modifies DMA_SEMAPHORE on nv50 in order to implement sync-to-vblank,
things will go very wrong for cross-channel sync after this.
While parsing the perf table, there is no check if
the num of entries read from the vbios is less than
the currently allocated number.
In case of a buggy vbios this will cause overwriting
of kernel memory, causing aditional problems.
Add a simple check in order to prevent the case
Signed-off-by: Emil Velikov <emil.l.velikov@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/i915: Fix gen6 (SNB) missed BLT ring interrupts.
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq:
[CPUFREQ] powernow-k8: Don't try to transition if the pstate is incorrect
[CPUFREQ] powernow-k8: Don't notify of successful transition if we failed (vid case).
[CPUFREQ] Don't set stat->last_index to -1 if the pol->cur has incorrect value.
* anon_vma-locking:
mm: avoid anon_vma_chain allocation under anon_vma lock
mm: avoid repeated anon_vma lock/unlock sequences in unlink_anon_vmas()
mm: avoid repeated anon_vma lock/unlock sequences in anon_vma_clone()
Hugh Dickins points out that lockdep (correctly) spots a potential
deadlock on the anon_vma lock, because we now do a GFP_KERNEL allocation
of anon_vma_chain while doing anon_vma_clone(). The problem is that
page reclaim will want to take the anon_vma lock of any anonymous pages
that it will try to reclaim.
So re-organize the code in anon_vma_clone() slightly: first do just a
GFP_NOWAIT allocation, which will usually work fine. But if that fails,
let's just drop the lock and re-do the allocation, now with GFP_KERNEL.
End result: not only do we avoid the locking problem, this also ends up
getting better concurrency in case the allocation does need to block.
Tim Chen reports that with all these anon_vma locking tweaks, we're now
almost back up to the spinlock performance.
Reported-and-tested-by: Hugh Dickins <hughd@google.com>
Tested-by: Tim Chen <tim.c.chen@linux.intel.com>
This matches the anon_vma_clone() case, and uses the same lock helper
functions. Because of the need to potentially release the anon_vma's,
it's a bit more complex, though.
We traverse the 'vma->anon_vma_chain' in two phases: the first loop gets
the anon_vma lock (with the helper function that only takes the lock
once for the whole loop), and removes any entries that don't need any
more processing.
The second phase just traverses the remaining list entries (without
holding the anon_vma lock), and does any actual freeing of the
anon_vma's that is required.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Tested-by: Hugh Dickins <hughd@google.com>
In anon_vma_clone() we traverse the vma->anon_vma_chain of the source
vma, locking the anon_vma for each entry.
But they are all going to have the same root entry, which means that
we're locking and unlocking the same lock over and over again. Which is
expensive in locked operations, but can get _really_ expensive when that
root entry sees any kind of lock contention.
In fact, Tim Chen reports a big performance regression due to this: when
we switched to use a mutex instead of a spinlock, the contention case
gets much worse.
So to alleviate this all, this commit creates a small helper function
(lock_anon_vma_root()) that can be used to take the lock just once
rather than taking and releasing it over and over again.
We still have the same "take the lock and release" it behavior in the
exit path (in unlink_anon_vmas()), but that one is a bit harder to fix
since we're actually freeing the anon_vma entries as we go, and that
will touch the lock too.
Reported-and-tested-by: Tim Chen <tim.c.chen@linux.intel.com>
The failure appeared in dmesg as:
[drm:i915_hangcheck_ring_idle] *ERROR* Hangcheck timer elapsed... blt
ring idle [waiting on 35064155, at 35064155], missed IRQ?
This works around that problem on by making the blitter command
streamer write interrupt state to the Hardware Status Page when a
MI_USER_INTERRUPT command is decoded, which appears to force the seqno
out to memory before the interrupt happens.
v1->v2: Moved to prior interrupt handler installation and RMW flags as
per feedback.
v2->v3: Removed RMW of flags (by anholt)
Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com>
Signed-off-by: Eric Anholt <eric@anholt.net>
Tested-by: Chris Wilson <chris@chris-wilson.co.uk> [v1]
Tested-by: Eric Anholt <eric@anholt.net> [v1,v3]
(incidence of the bug with a testcase went from avg 2/1000 to
0/12651 in the latest test run (plus more for v1))
Tested-by: Kenneth Graunke <kenneth@whitecape.org> [v1]
Tested-by: Robert Hooker <robert.hooker@canonical.com> [v1]
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=33394
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: hda - Fix no NID error with VIA codecs
ALSA: isight: adjust for new queueing API
ALSA: 6fire - Fix signedness bug
ALSA: lola - Fix section mismatch
ALSA: hda - Fix missing static inline to beep dummy function
ALSA: 6fire: Fix double-free bug in usb6fire_fw_ezusb_upload()
ALSA: hda - Fix beep_device compilation warnings
ALSA: hda - Fix wrong auto-mute type for Acer Aspire-one
ALSA: emu10k1: Add details for E-mu 0404 PCIe version
ALSA: hdspm - Add firmware revision ID for RME MADI PCI version
ALSA: hdspm - Fix jumping external wordclock frequency in AutoSync mode
ALSA: hdspm - Fix locking in snd_hdspm_midi_input_read
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: make log devices with write back caches work
xfs: fix ->mknod() return value on xfs_get_acl() failure
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid:
Revert "HID: magicmouse: ignore 'ivalid report id' while switching modes"
HID: hid-multitouch: fix broken eGalax
HID: MAINTAINERS: Update USB HID/HIDBP DRIVERS pattern
HID: hid-multitouch: add support for Chunghwa multi-touch panel
HID: hiddev: fix use after free in hiddev_release
HID: add quirk for HyperPen 10000U
HID: hiddev: fix potential use-after-free
git://git.secretlab.ca/git/linux-2.6
* 'gpio/merge' of git://git.secretlab.ca/git/linux-2.6:
gpio: add GPIOF_ values regardless on kconfig settings
gpio: include linux/gpio.h where needed
gpio/omap4: Fix missing interrupts during device wakeup due to IOPAD.
* 'spi/merge' of git://git.secretlab.ca/git/linux-2.6:
spi/bfin_spi: fix handling of default bits per word setting
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6:
OMAP1: PM: register notifiers with generic clock ops even when !PM_RUNTIME
omap: pandora: fix NAND support
OMAP: PM: omap_device: fix device power domain callbacks
OMAP: PM debug: fix section mismatch warnings
____call_usermodehelper() now erases any credentials set by the
subprocess_inf::init() function. The problem is that commit
17f60a7da150 ("capabilites: allow the application of capability limits
to usermode helpers") creates and commits new credentials with
prepare_kernel_cred() after the call to the init() function. This wipes
all keyrings after umh_keys_init() is called.
The best way to deal with this is to put the init() call just prior to
the commit_creds() call, and pass the cred pointer to init(). That
means that umh_keys_init() and suchlike can modify the credentials
_before_ they are published and potentially in use by the rest of the
system.
This prevents request_key() from working as it is prevented from passing
the session keyring it set up with the authorisation token to
/sbin/request-key, and so the latter can't assume the authority to
instantiate the key. This causes the in-kernel DNS resolver to fail
with ENOKEY unconditionally.
Acked-by: Eric Paris <eparis@redhat.com>
Tested-by: Jeff Layton <jlayton@redhat.com>
The default bits per word setting should be 8 bits, but since most of our
devices have been explicitly setting this up, we didn't notice when the
default stopped working.
At the moment, any default transfers without an explicit bit size setting
error out with:
bfin-spi bfin-spi.0: transfer: unsupported bits_per_word
So in the transfer logic, have a bits_per_word setting of 0 fall into the
8 bit transfer logic.
The via driver spews warnigs like
hda-codec: no NID for mapping control Independent HP:0:0
with some codecs because snd_hda_add_nid() is called with nid=0.
This patch fixes it by skipping the call when no corresponding widget
is found.
Since commit 13882a82ee16 (optimize iso queueing by setting
wake only after the last packet), drivers are required to call
fw_iso_context_queue_flush() after queueing a batch of packets.
The missing call would have an effect only if the controller
queue underruns, but then the DMA would stop completely.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
drm/radeon/kms: use helper functions for fence read/write
drm/radeon/kms: set DP link config properly for DP bridges
drm/radeon/kms/atom: AdjustPixelClock fixes for DP bridges
drm/radeon/kms: fix handling of DP to LVDS bridges
drm/radeon/kms: issue blank/unblank commands for ext encoders
drm/radeon/kms: fix support for DDC on dp bridges
drm/radeon/kms: add support for load detection on dp bridges
drm/radeon/kms: add missing external encoder action
drm/radeon/kms: rework atombios_get_encoder_mode()
drm/radeon/kms: fix num crtcs for Cedar and Caicos
Revert "drm/i915: Enable GMBUS for post-gen2 chipsets"
drivers/gpu/drm: use printk_ratelimited instead of printk_ratelimit
drm/radeon: workaround a hw bug on some radeon chipsets with all-0 EDIDs.
drm: make debug levels match in edid failure code.
drm/radeon/kms: clear wb memory by default
drm/radeon/kms: be more pedantic about the g5 quirk (v2)
drm/radeon/kms: signed fix for evergreen thermal
drm: populate irq_by_busid-member for pci
The existing code assumed scratch registers in a number
of places while in most cases we are be using writeback
and events rather than scratch registers.
DP clock and lanes were not set properly for DP bridges.
Need to set the external transmitter type properly in
AdjustPixelClock to get the properly output.
They need to be treated like eDP rather than DP.
May fix:
https://bugzilla.kernel.org/show_bug.cgi?id=34822
Required for DPMS on some systems.
Need to set up the bridge for DDC prior to the
i2c over aux transaction.
dp to vga bridges for example.
required for ddc.
This should give us more reliable results if the table
is called before an active device is set.
Only support 4 rather than 6.
Revert commit 8f9a3f9b63b8cd3f03be9dc53533f90bd4120e5f. This fixes a
hang when loading the eeprom driver (see bug #35572.) GMBUS will be
re-enabled later, differently.
Reported-by: Marek Otahal <markotahal@gmail.com>
Tested-by: Yermandu Patapitafious <yermandu.dev@gmail.com>
Tested-by: Andrew Lutomirski <luto@mit.edu>
Acked-by: Chris Wilson <chris@chris-wilson.co.uk>
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/linux-2.6-nsfd:
proc: Fix Oops on stat of /proc/<zombie pid>/ns/net
