git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux:
cpuidle: Single/Global registration of idle states
cpuidle: Split cpuidle_state structure and move per-cpu statistics fields
cpuidle: Remove CPUIDLE_FLAG_IGNORE and dev->prepare()
cpuidle: Move dev->last_residency update to driver enter routine; remove dev->last_state
ACPI: Fix CONFIG_ACPI_DOCK=n compiler warning
ACPI: Export FADT pm_profile integer value to userspace
thermal: Prevent polling from happening during system suspend
ACPI: Drop ACPI_NO_HARDWARE_INIT
ACPI atomicio: Convert width in bits to bytes in __acpi_ioremap_fast()
PNPACPI: Simplify disabled resource registration
ACPI: Fix possible recursive locking in hwregs.c
ACPI: use kstrdup()
mrst pmu: update comment
tools/power turbostat: less verbose debugging
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (40 commits)
vmwgfx: Snoop DMA transfers with non-covering sizes
vmwgfx: Move the prefered mode first in the list
vmwgfx: Unreference surface on cursor error path
vmwgfx: Free prefered mode on error path
vmwgfx: Use pointer return error codes
vmwgfx: Fix hw cursor position
vmwgfx: Infrastructure for explicit placement
vmwgfx: Make the preferred autofit mode have a 60Hz vrefresh
vmwgfx: Remove screen object active list
vmwgfx: Screen object cleanups
drm/radeon/kms: consolidate GART code, fix segfault after GPU lockup V2
drm/radeon/kms: don't poll forever if MC GDDR link training fails
drm/radeon/kms: fix DP setup on TRAVIS bridges
drm/radeon/kms: set HPD polarity in hpd_init()
drm/radeon/kms: add MSI module parameter
drm/radeon/kms: Add MSI quirk for Dell RS690
drm/radeon/kms: Add MSI quirk for HP RS690
drm/radeon/kms: split MSI check into a separate function
vmwgfx: Reinstate the update_layout ioctl
drm/radeon/kms: always do extended edid probe
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux
* 'urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux:
writeback: fix uninitialized task_ratelimit
* git://git.samba.org/sfrench/cifs-2.6:
CIFS: Cleanup byte-range locking code style
CIFS: Simplify setlk error handling for mandatory locking
* git://git.infradead.org/mtd-2.6: (226 commits)
mtd: tests: annotate as DANGEROUS in Kconfig
mtd: tests: don't use mtd0 as a default
mtd: clean up usage of MTD_DOCPROBE_ADDRESS
jffs2: add compr=lzo and compr=zlib options
jffs2: implement mount option parsing and compression overriding
mtd: nand: initialize ops.mode
mtd: provide an alias for the redboot module name
mtd: m25p80: don't probe device which has status of 'disabled'
mtd: nand_h1900 never worked
mtd: Add DiskOnChip G3 support
mtd: m25p80: add EON flash EN25Q32B into spi flash id table
mtd: mark block device queue as non-rotational
mtd: r852: make r852_pm_ops static
mtd: m25p80: add support for at25df321a spi data flash
mtd: mxc_nand: preset_v1_v2: unlock all NAND flash blocks
mtd: nand: switch `check_pattern()' to standard `memcmp()'
mtd: nand: invalidate cache on unaligned reads
mtd: nand: do not scan bad blocks with NAND_BBT_NO_OOB set
mtd: nand: wait to set BBT version
mtd: nand: scrub BBT on ECC errors
Fix up trivial conflicts:
- arch/arm/mach-at91/board-usb-a9260.c
Merged into board-usb-a926x.c
- drivers/mtd/maps/lantiq-flash.c
add_mtd_partitions -> mtd_device_register vs changed to use
mtd_device_parse_register.
* 'linux-next' of git://git.infradead.org/ubifs-2.6:
UBIFS: fix the dark space calculation
UBIFS: introduce a helper to dump scanning info
Enough to get cursors working under Wayland.
Signed-off-by: Jakob Bornecrantz <jakob@vmware.com>
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
Make it possible to use explicit placement
(although not hooked up with a user-space interface yet)
and relax the single framebuffer limit to only apply to implicit placement.
It isn't used for anything. Replace with an active bool.
Also make a couple of functions return void instead of int
since their return value wasn't checked anyway.
Reviewed-by: Jakbo Bornecrantz <jakob@vmware.com>
Remove unused member.
No need to pin / unpin fb.
In balance_dirty_pages() task_ratelimit may be not initialized
(initialization skiped by goto pause), and then used when calling
tracing hook.
Fix it by moving the task_ratelimit assignment before goto pause.
Reported-by: Witold Baryluk <baryluk@smp.if.uj.edu.pl>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
This reverts commit 361162459f62dc0826b82c9690a741a940f457f0.
It causes an infinite loop when booting Linux under Xen, as so:
[ 2.382984] console [hvc0] enabled
as reported by Konrad Rzeszutek Wilk. And Rusty reports the same for
lguest. He goes on to say:
"This is not a concurrency problem: the issue seems to be that
calling register_console() twice on the same struct console is a bad
idea."
and Greg says he'll fix it up properly at some point later. Revert for now.
Reported-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reported-by: Rusty Russell <rusty@ozlabs.org>
Requested-by: Stephen Rothwell <sfr@canb.auug.org.au>
Cc: Miche Baker-Harvey <miche@google.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Fix building following build error:
drivers/tty/hvc/hvc_opal.c:244:12: error: 'THIS_MODULE' undeclared here (not in a function)
Signed-off-by: Michael Neuling <mikey@neuling.org>
[ New file from powerpc tree not following the new rules from the
module.h split, both of which were merged today. - Linus ]
docs-move
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen
* 'upstream/jump-label-noearly' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen:
jump-label: initialize jump-label subsystem much earlier
x86/jump_label: add arch_jump_label_transform_static()
s390/jump-label: add arch_jump_label_transform_static()
jump_label: add arch_jump_label_transform_static() to optimise non-live code updates
sparc/jump_label: drop arch_jump_label_text_poke_early()
x86/jump_label: drop arch_jump_label_text_poke_early()
jump_label: if a key has already been initialized, don't nop it out
stop_machine: make stop_machine safe and efficient to call early
jump_label: use proper atomic_t initializer
- arch/x86/kernel/jump_label.c
Added __init_or_module to arch_jump_label_text_poke_early vs
removal of that function entirely
- kernel/stop_machine.c
same patch ("stop_machine: make stop_machine safe and efficient
to call early") merged twice, with whitespace fix in one version
* 'upstream/xen-settime' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen:
xen/dom0: set wallclock time in Xen
xen: add dom0_op hypercall
xen/acpi: Domain0 acpi parser related platform hypercall
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
* 'stable/cleanups-3.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen: use static initializers in xen-balloon.c
Xen: fix braces and tabs coding style issue in xenbus_probe.c
Xen: fix braces coding style issue in xenbus_probe.h
Xen: fix whitespaces,tabs coding style issue in drivers/xen/pci.c
Xen: fix braces coding style issue in gntdev.c and grant-table.c
Xen: fix whitespaces,tabs coding style issue in drivers/xen/events.c
Xen: fix whitespaces,tabs coding style issue in drivers/xen/balloon.c
Fix up trivial whitespace-conflicts in
drivers/xen/{balloon.c,pci.c,xenbus/xenbus_probe.c}
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (114 commits)
Btrfs: check for a null fs root when writing to the backup root log
Btrfs: fix race during transaction joins
Btrfs: fix a potential btrfs_bio leak on scrub fixups
Btrfs: rename btrfs_bio multi -> bbio for consistency
Btrfs: stop leaking btrfs_bios on readahead
Btrfs: stop the readahead threads on failed mount
Btrfs: fix extent_buffer leak in the metadata IO error handling
Btrfs: fix the new inspection ioctls for 32 bit compat
Btrfs: fix delayed insertion reservation
Btrfs: ClearPageError during writepage and clean_tree_block
Btrfs: be smarter about committing the transaction in reserve_metadata_bytes
Btrfs: make a delayed_block_rsv for the delayed item insertion
Btrfs: add a log of past tree roots
btrfs: separate superblock items out of fs_info
Btrfs: use the global reserve when truncating the free space cache inode
Btrfs: release metadata from global reserve if we have to fallback for unlink
Btrfs: make sure to flush queued bios if write_cache_pages waits
Btrfs: fix extent pinning bugs in the tree log
Btrfs: make sure btrfs_remove_free_space doesn't leak EAGAIN
Btrfs: don't wait as long for more batches during SSD log commit
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
'pnp-cleanup' into acpi
* 'writeback-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux:
writeback: Add a 'reason' to wb_writeback_work
writeback: send work item to queue_io, move_expired_inodes
writeback: trace event balance_dirty_pages
writeback: trace event bdi_dirty_ratelimit
writeback: fix ppc compile warnings on do_div(long long, unsigned long)
writeback: per-bdi background threshold
writeback: dirty position control - bdi reserve area
writeback: control dirty pause time
writeback: limit max dirty pause time
writeback: IO-less balance_dirty_pages()
writeback: per task dirty rate limit
writeback: stabilize bdi->dirty_ratelimit
writeback: dirty rate control
writeback: add bg_threshold parameter to __bdi_update_bandwidth()
writeback: account per-bdi accumulated dirtied pages
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
target: use ->exectute_task for all CDB emulation
target: remove SCF_EMULATE_CDB_ASYNC
target: refactor transport_emulate_control_cdb
target: pass the se_task to the CDB emulation callback
target: split core_scsi3_emulate_pr
target: split core_scsi2_emulate_crh
target: Add generic active I/O shutdown logic
target: add back error handling in transport_complete_task
target/pscsi: blk_make_request() returns an ERR_PTR()
target: Remove core TRANSPORT_FREE_CMD_INTR usage
target: Make TFO->check_stop_free return free status
iscsi-target: Fix non-immediate TMR handling
iscsi-target: Add missing CMDSN_LOWER_THAN_EXP check in iscsit_handle_scsi_cmd
target: Avoid double list_del for aborted se_tmr_req
target: Minor cleanups to core_tmr_drain_tmr_list
target: Fix wrong se_tmr being added to drain_tmr_list
target: Fix incorrect se_cmd assignment in core_tmr_drain_tmr_list
target: Check -ENOMEM to signal QUEUE_FULL from fabric callbacks
tcm_loop: Add explict read buffer memset for SCF_SCSI_CONTROL_SG_IO_CDB
target: Fix compile warning w/ missing module.h include
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
* 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
scsi: drop unused Kconfig symbol
pci: drop unused Kconfig symbol
stmmac: drop unused Kconfig symbol
x86: drop unused Kconfig symbol
powerpc: drop unused Kconfig symbols
powerpc: 40x: drop unused Kconfig symbol
mips: drop unused Kconfig symbols
openrisc: drop unused Kconfig symbols
arm: at91: drop unused Kconfig symbol
samples: drop unused Kconfig symbol
m32r: drop unused Kconfig symbol
score: drop unused Kconfig symbols
sh: drop unused Kconfig symbol
um: drop unused Kconfig symbol
sparc: drop unused Kconfig symbol
alpha: drop unused Kconfig symbol
Fix up trivial conflict in drivers/net/ethernet/stmicro/stmmac/Kconfig
as per Michal: the STMMAC_DUAL_MAC config variable is still unused and
should be deleted.
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
script/checkpatch.pl: warn about deprecated use of EXTRA_{A,C,CPP,LD}FLAGS
tags, powerpc: Update tags.sh to support _GLOBAL symbols
scripts: add extract-vmlinux
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
scripts/kconfig/nconf: add KEY_HOME / KEY_END for dialog_inputbox
scripts/kconfig/nconf: fix editing long strings
scripts/kconfig/nconf: dynamically alloc dialog_input_result
scripts/kconfig/nconf: fix memmove's length arg
scripts/kconfig/nconf: fix typo: unknow => unknown
kconfig: fix set but not used variables
kconfig: handle SIGINT in menuconfig
kconfig: fix __enabled_ macros definition for invisible and un-selected symbols
kconfig: factor code in menu_get_ext_help()
kbuild: Fix help text not displayed in choice option.
kconfig/nconf: nuke unreferenced `nohelp_text'
kconfig/streamline_config.pl: merge local{mod,yes}config
kconfig/streamline_config.pl: use options to determine operating mode
kconfig/streamline_config.pl: directly access LSMOD from the environment
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
Kbuild: append missing-syscalls to the default target list
genksyms: Regenerate lexer and parser
genksyms: Do not expand internal types
genksyms: Minor parser cleanup
Makefile: remove a duplicated line
fixdep: fix extraneous dependencies
scripts/Makefile.build: do not reference EXTRA_CFLAGS as CFLAGS replacement
kbuild: prevent make from deleting _shipped files
kbuild: Do not delete empty files in make distclean
This removes the use of the special "macbookair_fn_keys" keyboard
translation table for the MacBookAir4,x models (ie the 2011 refresh).
They use the standard apple_fn_keys[] translation. Apparently only the
old MacBook Air's need a different translation table.
This mirrors the change that commit da617c7cb915 ("HID: consolidate
MacbookAir 4,1 mappings") did for the WELLSPRING6A ones, but does it for
the WELLSPRING6 model used on the MacBookAir4,2.
Reported-and-tested-by: Dirk Hohndel <hohndel@infradead.org>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Joshua V Dillon <jvdillon@gmail.com>
Cc: Chase Douglas <chase.douglas@canonical.com>
* 'stable/vmalloc-3.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
net: xen-netback: use API provided by xenbus module to map rings
block: xen-blkback: use API provided by xenbus module to map rings
xen: use generic functions instead of xen_{alloc, free}_vm_area()
This patch makes the cpuidle_states structure global (single copy)
instead of per-cpu. The statistics needed on per-cpu basis
by the governor are kept per-cpu. This simplifies the cpuidle
subsystem as state registration is done by single cpu only.
Having single copy of cpuidle_states saves memory. Rare case
of asymmetric C-states can be handled within the cpuidle driver
and architectures such as POWER do not have asymmetric C-states.
Having single/global registration of all the idle states,
dynamic C-state transitions on x86 are handled by
the boot cpu. Here, the boot cpu would disable all the devices,
re-populate the states and later enable all the devices,
irrespective of the cpu that would receive the notification first.
Reference:
https://lkml.org/lkml/2011/4/25/83
Signed-off-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Signed-off-by: Trinabh Gupta <g.trinabh@gmail.com>
Tested-by: Jean Pihet <j-pihet@ti.com>
Reviewed-by: Kevin Hilman <khilman@ti.com>
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Kevin Hilman <khilman@ti.com>
Signed-off-by: Len Brown <len.brown@intel.com>
This is the first step towards global registration of cpuidle
states. The statistics used primarily by the governor are per-cpu
and have to be split from rest of the fields inside cpuidle_state,
which would be made global i.e. single copy. The driver_data field
is also per-cpu and moved.
The cpuidle_device->prepare() mechanism causes updates to the
cpuidle_state[].flags, setting and clearing CPUIDLE_FLAG_IGNORE
to tell the governor not to chose a state on a per-cpu basis at
run-time. State demotion is now handled by the driver and it returns
the actual state entered. Hence, this mechanism is not required.
Also this removes per-cpu flags from cpuidle_state enabling
it to be made global.
Reference:
https://lkml.org/lkml/2011/3/25/52
Signed-off-by: Deepthi Dharwar <deepthi@linux.vnet.ibm>
dev->last_state
Cpuidle governor only suggests the state to enter using the
governor->select() interface, but allows the low level driver to
override the recommended state. The actual entered state
may be different because of software or hardware demotion. Software
demotion is done by the back-end cpuidle driver and can be accounted
correctly. Current cpuidle code uses last_state field to capture the
actual state entered and based on that updates the statistics for the
state entered.
Ideally the driver enter routine should update the counters,
and it should return the state actually entered rather than the time
spent there. The generic cpuidle code should simply handle where
the counters live in the sysfs namespace, not updating the counters.
Reference:
Recently the ACPI ops structs were constified but the inline version
of register_hotplug_dock_device() was overlooked (see also commit
9c8b04b, June 25 2011). Update the inline function
register_hotplug_dock_device() that is enabled with
CONFIG_ACPI_DOCK=n too. This patch fixes at least the following
compiler warnings:
drivers/ata/libata-acpi.c: In function .ata_acpi_associate.:
drivers/ata/libata-acpi.c:266:11: warning: passing argument 2 of .register_hotplug_dock_device. discards qualifiers from pointer target type
include/acpi/acpi_drivers.h:146:19: note: expected .struct acpi_dock_ops *. but argument is of type .const struct acpi_dock_ops *.
drivers/ata/libata-acpi.c:275:11: warning: passing argument 2 of .register_hotplug_dock_device. discards qualifiers from pointer target type
Cc: stable@vger.kernel.org
There are a lot userspace approaches to detect the usage of the
platform (laptop, workstation, server, ...) and adjust kernel tunables
accordingly (io/process scheduler, power management, ...).
These approaches need constant maintaining and are ugly to implement
(detect PCMCIA controller -> laptop,
does not work on recent systems anymore, ...)
On ACPI systems there is an easy and reliable way (if implemented
in BIOS and most recent platforms have this value set).
-> export it to userspace.
Signed-off-by: Thomas Renninger <trenn@suse.de>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
The thermal driver should use a freezable workqueue to schedule
polling to prevent thermal_zone_device_update() from being run
during system suspend, when the devices it relies on may be inactive.
Make it use the system freezable workqueue for this purpose.
ACPI_NO_HARDWARE_INIT is only used by acpi_early_init() and
acpi_bus_init() when calling acpi_enable_subsystem(), but
acpi_enable_subsystem() doesn't check that flag, so it can be
dropped.
Callers to __acpi_ioremap_fast() pass the bit_width that they found in the
acpi_generic_address structure. Convert from bits to bytes when passing to
__acpi_find_iomap() - as it wants to see bytes, not bits.
cc: stable@kernel.org
Signed-off-by: Tony Luck <tony.luck@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
ceph/super.c: quiet sparse noise
ceph/mds_client.c: quiet sparse noise
ceph: use new D_COMPLETE dentry flag
ceph: clear parent D_COMPLETE flag when on dentry prune
* git://github.com/rustyrussell/linux:
module,bug: Add TAINT_OOT_MODULE flag for modules not built in-tree
module: Enable dynamic debugging regardless of taint
* 'rmobile-latest' of git://github.com/pmundt/linux-sh: (21 commits)
ARM: mach-shmobile: ag5evm needs CONFIG_I2C
ARM: mach-shmobile: sh73a0 and AG5EVM PINT support
ARM: mach-shmobile: Add support for PINT though INTC macros
ARM: mach-shmobile: SDHI0 GPIO hotplug for AG5EVM
ARM: mach-shmobile: Use common INTC IRQ code on sh73a0
ARM: mach-shmobile: Use common INTC IRQ code on sh7372
ARM: mach-shmobile: Use common INTC IRQ code on sh7377
ARM: mach-shmobile: Use common INTC IRQ code on sh7367
ARM: mach-shmobile: sh73a0 GPIO IRQ support
ARM: sh7372 ap4evb NOR Flash USB boot fix
ARM: mach-shmobile: sh7372 Mackerel NOR Flash USB boot fix
sh: intc: Allow triggering on both edges for ARM SoCs
ARM: mach-shmobile: Break out INTC IRQ code
ARM: mach-shmobile: Kota2 SDHI0 and SDHI1 support
ARM: mach-shmobile: Kota2 SCIFA4 and SCIFB support
ARM: mach-shmobile: Kota2 MMCIF support
ARM: mach-shmobile: Kota2 GPIO LEDs support
ARM: mach-shmobile: Kota2 GPIO Keys support
ARM: mach-shmobile: Kota2 KEYSC support
ARM: mach-shmobile: Kota2 SCIFA2 and SMSC911X support
The attached patch simplifies 29df8d8f8702f0f53c1375015f09f04bc8d023c1. As
the "pnp_xxx" structs are not designed to cope with IORESOURCE_DISABLED, and
hence no code can test for this value, setting this value is actually a "no op"
and can be skipped altogether. It is sufficient to remove the checks for
"empty" resources and continue processing.
The patch is applied against 3.1.
Signed-off-by: Witold Szczeponik <Witold.Szczeponik@gmx.net>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (106 commits)
powerpc/p3060qds: Add support for P3060QDS board
powerpc/83xx: Add shutdown request support to MCU handling on MPC8349 MITX
powerpc/85xx: Make kexec to interate over online cpus
powerpc/fsl_booke: Fix comment in head_fsl_booke.S
powerpc/85xx: issue 15 EOI after core reset for FSL CoreNet devices
powerpc/8xxx: Fix interrupt handling in MPC8xxx GPIO driver
powerpc/85xx: Add 'fsl,pq3-gpio' compatiable for GPIO driver
powerpc/86xx: Correct Gianfar support for GE boards
powerpc/cpm: Clear muram before it is in use.
drivers/virt: add ioctl for 32-bit compat on 64-bit to fsl-hv-manager
powerpc/fsl_msi: add support for "msi-address-64" property
powerpc/85xx: Setup secondary cores PIR with hard SMP id
powerpc/fsl-booke: Fix settlbcam for 64-bit
powerpc/85xx: Adding DCSR node to dtsi device trees
powerpc/85xx: clean up FPGA device tree nodes for Freecsale QorIQ boards
powerpc/85xx: fix PHYS_64BIT selection for P1022DS
powerpc/fsl-booke: Fix setup_initial_memory_limit to not blindly map
powerpc: respect mem= setting for early memory limit setup
powerpc: Update corenet64_smp_defconfig
powerpc: Update mpc85xx/corenet 32-bit defconfigs
Fix up trivial conflicts in:
- arch/powerpc/configs/40x/hcu4_defconfig
removed stale file, edited elsewhere
- arch/powerpc/include/asm/udbg.h, arch/powerpc/kernel/udbg.c:
added opal and gelic drivers vs added ePAPR driver
- drivers/tty/serial/8250.c
moved UPIO_TSI to powerpc vs removed UPIO_DWAPB support
Calling pm-suspend might trigger a recursive lock in it's code path.
In function acpi_hw_clear_acpi_status, acpi_os_acquire_lock holds
the lock acpi_gbl_hardware_lock before calling acpi_hw_register_write(),
then without releasing acpi_gbl_hardware_lock, this function calls
acpi_ev_walk_gpe_list, which tries to hold acpi_gbl_gpe_lock.
Both acpi_gbl_hardware_lock and acpi_gbl_gpe_lock are at same
lock-class and which might cause lock recursion deadlock.
Following patch fixes this scenario by just releasing
acpi_gbl_hardware_lock before calling acpi_ev_walk_gpe_list.
Changes since v0(https://lkml.org/lkml/2011/9/21/355):
- Fix changelog, thanks to Lin Ming.
Changes since v1 (https://lkml.org/lkml/2011/11/3/89):
- Update changelog and rename goto label, courtesy Srivatsa S. Bhat.
Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com>
Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
