Simplify the way the return value is set a number of times (mostly on
error).
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Merge list_del() + list_add_tail() to list_move_tail().
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
This commit changed an internal radeon structure, that meant a new driver
in -next had to be fixed up, merge in the commit and fix up the driver.
Also fixes a trivial nouveau merge.
drivers/gpu/drm/nouveau/nouveau_mem.c
Usually EDID retrieval is fine. However, sometimes, especially when the
machine is loaded, it fails, but succeeds after a few retries.
Based on a patch by Michael Buesch.
Reported-by: Michael Buesch <mb@bu3sch.de>
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Alex Deucher <alexdeucher@gmail.com>
Typo in the aspect scale setup.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
Cc: stable@kernel.org
As detect will use hw registers and may modify structures, it needs to be
serialised by use of the dev->mode_config.mutex. Make it so.
Otherwise, we may cause random crashes as the sysfs file is queried
whilst a concurrent hotplug poll is being run. For example:
[ 1189.189626] BUG: unable to handle kernel NULL pointer dereference at 00000100
[ 1189.189821] IP: [<e0c22019>] intel_tv_detect_type+0xa2/0x203 [i915]
[ 1189.190020] *pde = 00000000
[ 1189.190104] Oops: 0000 [#1] SMP
[ 1189.190209] last sysfs file: /sys/devices/pci0000:00/0000:00:02.0/drm/card0/card0-SVIDEO-1/status
[ 1189.190412] Modules linked in: mperf cpufreq_conservative cpufreq_userspace cpufreq_powersave cpufreq_stats decnet uinput fuse loop joydev snd_hd a_codec_realtek snd_hda_intel snd_hda_codec snd_hwdep snd_pcm_oss snd_mixer_oss snd_pcm i915 snd_seq_midi snd_rawmidi snd_seq_midi_event snd_seq drm_kms_helper snd_timer uvcvideo d rm snd_seq_device eeepc_laptop tpm_tis usbhid videodev i2c_algo_bit v4l1_compat snd sparse_keymap i2c_core hid serio_raw tpm psmouse evdev tpm_bios rfkill shpchp ac processor rng_c ore battery video power_supply soundcore pci_hotplug button output snd_page_alloc usb_storage uas ext3 jbd mbcache sd_mod crc_t10dif ata_generic ahci libahci ata_piix libata uhci_h cd ehci_hcd scsi_mod usbcore thermal atl2 thermal_sys nls_base [last unloaded: scsi_wait_scan]
[ 1189.192007]
[ 1189.192007] Pid: 1464, comm: upowerd Not tainted 2.6.37-2-686 #1 ASUSTeK Computer INC. 701/701
[ 1189.192007] EIP: 0060:[<e0c22019>] EFLAGS: 00010246 CPU: 0
[ 1189.192007] EIP is at intel_tv_detect_type+0xa2/0x203 [i915]
[ 1189.192007] EAX: 00000000 EBX: dca74000 ECX: e0f68004 EDX: 00068004
[ 1189.192007] ESI: dd110c00 EDI: 400c0c37 EBP: dca7429c ESP: de365e2c
[ 1189.192007] DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
[ 1189.192007] Process upowerd (pid: 1464, ti=de364000 task=dcc8acb0 task.ti=de364000)
[ 1189.192007] Stack: Mar 15 03:43:23 hostname kernel: [ 1189.192007] e0c2cda4 70000000 400c0c30 00000000 dd111000 de365e54 de365f24 dd110c00
[ 1189.192007] e0c22203 01000000 00000003 00000000 00000000 00000000 00000000 4353544e
[ 1189.192007] 30383420 00000069 00000000 00000000 00000000 00000000 00000000 00000000
[ 1189.192007] Call Trace: Mar 15 03:43:23 hostname kernel: [ 1189.192007] [<e0c22203>] ? intel_tv_detect+0x89/0x12d [i915]
[ 1189.192007] [<e0a9dcef>] ? status_show+0x0/0x2f [drm]
[ 1189.192007] [<e0a9dd03>] ? status_show+0x14/0x2f [drm]
[Digression: what is upowerd doing reading those power hungry files?]
Reported-by: Paul Menzel <paulepanter@users.sourceforge.net>
drm-core-next
* 'nouveau/drm-nouveau-next' of ../drm-nouveau-next:
drm/nouveau: fix __nouveau_fence_wait performance
drm/nv40: attempt to reserve just enough vram for all 32 channels
drm/nv50: check for vm traps on every gr irq
drm/nv50: decode vm faults some more
drm/nouveau: add nouveau_enum_find() util function
drm/nouveau: properly handle pushbuffer check failures
drm/nvc0: remove vm hack forcing large/small pages to not share a PDE
Commit 21e86c1c8a844bf978f8fc431a59c9f5a578812d ("drm/nouveau: remove
cpu_writers lock") turned on lazy waits. Unfortunately
__nouveau_fence_wait was not optimized for this case and on HZ=100
kernel wasted up to 10 ms per call.
Depending on application, it led to 10-30% FPS regression.
Fix it.
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Signed-off-by: Francisco Jerez <currojerez@riseup.net>
This also makes the fact we're giving 512MiB of GART space to all PCIE
boards explicit, although the vast majority (if not all) of them will
now have a ramin_rsvd_vram larger than 2MiB anyway.
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
When "buffer in list" check does not pass, don't free validation lists - they were
not initialized yet.
Fixes this oops:
[drm] nouveau 0000:02:00.0: push 105 buffer not in list
BUG: unable to handle kernel NULL pointer dereference at 000000000000057c
IP: [<ffffffff81236aa4>] do_raw_spin_lock+0x14/0x13c
PGD 1ac6cb067 PUD 1aaa52067 PMD 0
CPU 0
Modules linked in: nouveau ttm drm_kms_helper snd_hda_codec_realtek snd_hda_intel snd_hda_codec
Pid: 6265, comm: OilRush_x86 Not tainted 2.6.38-rc6-nv+ #632 System manufacturer System Product Name/P6T SE
RIP: 0010:[<ffffffff81236aa4>] [<ffffffff81236aa4>] do_raw_spin_lock+0x14/0x13c
Process OilRush_x86 (pid: 6265, threadinfo ffff8801a6aee000, task ffff8801a26c0000)
0000000000000000 ffff8801ac74c618 0000000000000000 0000000000000578
0000000000000000 ffff8801ac74c618 0000000000000000 ffff8801bd9d0000
[<ffffffff81417f78>] _raw_spin_lock+0x1e/0x22
[<ffffffffa00a2746>] nouveau_bo_fence+0x2e/0x60 [nouveau]
[<ffffffffa00a540b>] validate_fini_list+0x35/0xeb [nouveau]
[<ffffffffa00a54d3>] validate_fini+0x12/0x31 [nouveau]
[<ffffffffa00a6386>] nouveau_gem_ioctl_pushbuf+0xe94/0xf6b [nouveau]
[<ffffffff8141ac56>] ? sub_preempt_count+0x9e/0xb2
[<ffffffff81417e94>] ? _raw_spin_unlock_irqrestore+0x30/0x4d
[<ffffffff8105dea2>] ? __wake_up+0x3f/0x48
[<ffffffff812aebb4>] drm_ioctl+0x289/0x361
[<ffffffffa00a54f2>] ? nouveau_gem_ioctl_pushbuf+0x0/0xf6b [nouveau]
[<ffffffffa010caa2>] nouveau_compat_ioctl+0x16/0x1c [nouveau]
[<ffffffff81142c0d>] compat_sys_ioctl+0x1c8/0x12d7
[<ffffffff814179ca>] ? trace_hardirqs_off_thunk+0x3a/0x6c
[<ffffffff81058099>] sysenter_dispatch+0x7/0x30
[<ffffffff8141798e>] ? trace_hardirqs_on_thunk+0x3a/0x3c
RIP [<ffffffff81236aa4>] do_raw_spin_lock+0x14/0x13c
RSP <ffff8801a6aefb88>
---[ end trace 0014d5d93e6147e1 ]---
Additionally, don't call validate_fini twice in case of validation failure.
Signed-off-by: Maarten Maathuis <madman2003@gmail.com>
Appears to be fixed with commit:
"drm/nv50-nvc0: make sure vma is definitely unmapped when destroying bo"
At least on my HP 2540p this is wrong at bootup, fine
at any other time once a lid event has occured. This is due to
_REG vs _INI ordering in the ACPI tables.
* 'intel/drm-intel-next' of ../drm-next: (755 commits)
drm/i915: Only wait on a pending flip if we intend to write to the buffer
drm/i915/dp: Sanity check eDP existence
drm/i915: Rebind the buffer if its alignment constraints changes with tiling
drm/i915: Disable GPU semaphores by default
drm/i915: Do not overflow the MMADDR write FIFO
Revert "drm/i915: fix corruptions on i8xx due to relaxed fencing"
drm/i915: Don't save/restore hardware status page address register
drm/i915: don't store the reg value for HWS_PGA
drm/i915: fix memory corruption with GM965 and >4GB RAM
Linux 2.6.38-rc7
Revert "TPM: Long default timeout fix"
drm/i915: Re-enable GPU semaphores for SandyBridge mobile
drm/i915: Replace vblank PM QoS with "Interrupt-Based AGPBUSY#"
Revert "drm/i915: Use PM QoS to prevent C-State starvation of gen3 GPU"
drm/i915: Allow relocation deltas outside of target bo
drm/i915: Silence an innocuous compiler warning for an unused variable
fs/block_dev.c: fix new kernel-doc warning
ACPI: Fix build for CONFIG_NET unset
mm: <asm-generic/pgtable.h> must include <linux/mm_types.h>
x86: Use u32 instead of long to set reset vector back to 0
drivers/gpu/drm/i915/i915_gem.c
So we used to use lpfn directly to restrict VRAM when we couldn't
access the unmappable area, however this was removed in
93225b0d7bc030f4a93165347a65893685822d70 as it also restricted
the gtt placements. However it was only later noticed that this
broke on some hw.
This removes the active_vram_size, and just explicitly sets it
when it changes, TTM/drm_mm will always use the real_vram_size,
and the active vram size will change the TTM size used for lpfn
setting.
We should re-work the fpfn/lpfn to per-placement at some point
I suspect, but that is too late for this kernel.
Hopefully this addresses:
https://bugs.freedesktop.org/show_bug.cgi?id=35254
v2: fix reported useful VRAM size to userspace to be correct.
We've been getting reports of complete system lockups with rv3xx hw on
AGP and PCIE when running gnome-shell or kwin with compositing.
It appears the hw really doesn't like setting these registers while
stuff is running, this moves the setting of the registers into the modeset
since they aren't required to be changed anywhere else.
fixes: https://bugs.freedesktop.org/show_bug.cgi?id=35183
Reported-and-tested-by: Álmos <aaalmosss@gmail.com
Looks like these got passed over with both being merged at the same
time but not quite meeting in the middle.
should fix: https://bugs.freedesktop.org/show_bug.cgi?id=34137
along with Michael's phoronix article.
Reported-by: Chi-Thanh Christopher Nguyen
Article-written-by: Michael Larabel @ phoronix
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'media_fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6:
[media] mantis_pci: remove asm/pgtable.h include
[media] tda829x: fix regression in probe functions
[media] mceusb: don't claim multifunction device non-IR parts
[media] nuvoton-cir: fix wake from suspend
[media] cx18: Add support for Hauppauge HVR-1600 models with s5h1411
[media] ivtv: Fix corrective action taken upon DMA ERR interrupt to avoid hang
[media] cx25840: fix probing of cx2583x chips
[media] cx23885: Remove unused 'err:' labels to quiet compiler warning
[media] cx23885: Revert "Check for slave nack on all transactions"
[media] DiB7000M: add pid filtering
[media] Fix sysfs rc protocol lookup for rc-5-sz
[media] au0828: fix VBI handling when in V4L2 streaming mode
[media] ir-raw: Properly initialize the IR event (BZ#27202)
[media] s2255drv: firmware re-loading changes
[media] Fix double free of video_device in mem2mem_testdev
[media] DM04/QQBOX memcpy to const char fix
This patch fixes an issue in OpenIPMI module where sometimes an ABORT command
is sent after sending an IPMI request to BMC causing the IPMI request to fail.
Signed-off-by: YiCheng Doe <yicheng.doe@hp.com>
Signed-off-by: Corey Minyard <cminyard@mvista.com>
Acked-by: Tom Mingarelli <thomas.mingarelli@hp.com>
Tested-by: Andy Cress <andy.cress@us.kontron.com>
Tested-by: Mika Lansirine <Mika.Lansirinne@stonesoft.com>
Tested-by: Brian De Wolf <bldewolf@csupomona.edu>
Cc: Jean Michel Audet <Jean-Michel.Audet@ca.Kontron.com>
Cc: Jozef Sudelsky <jozef.sudolsky@elbiahosting.sk>
Acked-by: Matthew Garrett <mjg@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
fs/dcache: allow d_obtain_alias() to return unhashed dentries
Check for immutable/append flag in fallocate path
sysctl: the include of rcupdate.h is only needed in the kernel
fat: fix d_revalidate oopsen on NFS exports
jfs: fix d_revalidate oopsen on NFS exports
ocfs2: fix d_revalidate oopsen on NFS exports
gfs2: fix d_revalidate oopsen on NFS exports
fuse: fix d_revalidate oopsen on NFS exports
ceph: fix d_revalidate oopsen on NFS exports
reiserfs xattr ->d_revalidate() shouldn't care about RCU
/proc/self is never going to be invalidated...
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, UV: Initialize the broadcast assist unit base destination node id properly
x86, numa: Fix numa_emulation code with memory-less node0
x86, build: Make sure mkpiggy fails on read error
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: Fix sched rt group scheduling when hierachy is enabled
* 'perf/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf symbols: Avoid resolving [kernel.kallsyms] to real path for buildid cache
perf symbols: Fix vmlinux path when not using --symfs
This reverts commit 951f3512dba5bd44cda3e5ee22b4b522e4bb09fb
drm/i915: Do not handle backlight combination mode specially
since this commit introduced other regressions due to untouched LBPC
register, e.g. the backlight dimmed after resume.
In addition to the revert, this patch includes a fix for the original
issue (weird backlight levels) by removing the wrong bit shift for
computing the current backlight level.
Also, including typo fixes (lpbc -> lbpc).
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=34524
Acked-by: Indan Zupancic <indan@nul.nu>
Reviewed-by: Keith Packard <keithp@keithp.com>
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: <stable@kernel.org>
Without this patch, inodes are not promptly freed on last close of an
unlinked file by an nfs client:
client$ mount -tnfs4 server:/export/ /mnt/
client$ tail -f /mnt/FOO
server$ df -i /export
server$ rm /export/FOO
(^C the tail -f)
server$ echo 2 >/proc/sys/vm/drop_caches
the df's will show that the inode is not freed on the filesystem until
the last step, when it could have been freed after killing the client's
tail -f. On-disk data won't be deallocated either, leading to possible
spurious ENOSPC.
This occurs because when the client does the close, it arrives in a
compound with a putfh and a close, processed like:
- putfh: look up the filehandle. The only alias found for the
inode will be DCACHE_UNHASHED alias referenced by the filp
this, so it creates a new DCACHE_DISCONECTED dentry and
returns that instead.
- close: closes the existing filp, which is destroyed
immediately by dput() since it's DCACHE_UNHASHED.
- end of the compound: release the reference
to the current filehandle, and dput() the new
DCACHE_DISCONECTED dentry, which gets put on the
unused list instead of being destroyed immediately.
Nick Piggin suggested fixing this by allowing d_obtain_alias to return
the unhashed dentry that is referenced by the filp, instead of making it
create a new dentry.
Leave __d_find_alias() alone to avoid changing behavior of other
callers.
Also nfsd doesn't need all the checks of __d_find_alias(); any dentry,
hashed or unhashed, disconnected or not, should work.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
In the fallocate path the kernel doesn't check for the immutable/append
flag. It's possible to have a race condition in this scenario: an
application open a file in read/write and it does something, meanwhile
root set the immutable flag on the file, the application at that point
can call fallocate with success. In addition, we don't allow to do any
unreserve operation on an append only file but only the reserve one.
Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com>
Fixes this built error:
include/linux/sysctl.h:28: included file 'linux/rcupdate.h' is not exported
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
can't blindly check nd->flags in ->d_revalidate()
... it returns an error unconditionally
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc/pseries: Disable VPNH feature
powerpc/iseries: Fix early init access to lppaca
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6:
net: don't allow CAP_NET_ADMIN to load non-netdev kernel modules
Fixes this build-check error:
Since a8f80e8ff94ecba629542d9b4b5f5a8ee3eb565c any process with
CAP_NET_ADMIN may load any module from /lib/modules/. This doesn't mean
that CAP_NET_ADMIN is a superset of CAP_SYS_MODULE as modules are
limited to /lib/modules/**. However, CAP_NET_ADMIN capability shouldn't
allow anybody load any module not related to networking.
This patch restricts an ability of autoloading modules to netdev modules
with explicit aliases. This fixes CVE-2011-1019.
Arnd Bergmann suggested to leave untouched the old pre-v2.6.32 behavior
of loading netdev modules by name (without any prefix) for processes
with CAP_SYS_MODULE to maintain the compatibility with network scripts
that use autoloading netdev modules by aliases like "eth0", "wlan0".
Currently there are only three users of the feature in the upstream
kernel: ipip, ip_gre and sit.
root@albatros:~# capsh --drop=$(seq -s, 0 11),$(seq -s, 13 34) --
root@albatros:~# grep Cap /proc/$$/status
CapInh: 0000000000000000
CapPrm: fffffff800001000
CapEff: fffffff800001000
CapBnd: fffffff800001000
root@albatros:~# modprobe xfs
FATAL: Error inserting xfs
(/lib/modules/2.6.38-rc6-00001-g2bf4ca3/kernel/fs/xfs/xfs.ko): Operation not permitted
root@albatros:~# lsmod | grep xfs
root@albatros:~# ifconfig xfs
xfs: error fetching interface information: Device not found
root@albatros:~# lsmod | grep sit
root@albatros:~# ifconfig sit
sit: error fetching interface information: Device not found
root@albatros:~# ifconfig sit0
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
sit 10457 0
tunnel4 2957 1 sit
For CAP_SYS_MODULE module loading is still relaxed:
CapPrm: ffffffffffffffff
CapEff: ffffffffffffffff
CapBnd: ffffffffffffffff
xfs 745319 0
Reference: https://lkml.org/lkml/2011/2/24/203
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Signed-off-by: Michael Tokarev <mjt@tls.msk.ru>
Acked-by: Kees Cook <kees.cook@canonical.com>
Signed-off-by: James Morris <jmorris@namei.org>
This feature triggers nasty races in the scheduler between the
rebuilding of the topology and the load balancing code, causing
the machine to hang.
Disable it for now until the races are fixed.
The combination of commit
8154c5d22d91cd16bd9985b0638c8957e4688d0e and
93c22703efa72c7527dbd586d1951c1f4a85fd70
Broke boot on iSeries.
The problem is that iSeries very early boot code, which generates
the device-tree and runs before our normal early initializations
does need access the lppaca's very early, before the PACA array is
initialized, and in fact even before the boot PACA has been
initialized (it contains all 0's at this stage).
However, the first patch above makes that code use the new
llpaca_of(cpu) accessor, which itself is changed by the second patch to
use the PACA array.
We fix that by reverting iSeries to directly dereferencing the array. In
addition, we fix all iterators in the iSeries code to always skip CPU
whose number is above 63 which is the maximum size of that array and
the maximum number of supported CPUs on these machines.
Additionally, we make sure the boot_paca is properly initialized
in our early startup code.
* 'for-2.6.38' of git://linux-nfs.org/~bfields/linux:
nfsd: wrong index used in inner loop
nfsd4: fix bad pointer on failure to find delegation
NFSD: fix decode_cb_sequence4resok
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog:
watchdog: sbc_fitpc2_wdt, fix crash on systems without DMI_BOARD_NAME
* 'for-2639-rc7/i2c-fixes' of git://git.fluff.org/bjdooks/linux:
i2c-eg20t: include slab.h for memory allocations
i2c-ocores: Fix pointer type mismatch error
i2c-omap: Program I2C_WE on OMAP4 to enable i2c wakeup
Signed-off-by: Matt Turner <mattst88@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq:
[CPUFREQ] pcc-cpufreq: don't load driver if get_freq fails during init.
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc:
mmc: fix CONFIG_MMC_UNSAFE_RESUME regression
nd->inode is not set on the second attempt in path_walk()
unfuck proc_sysctl ->d_compare()
minimal fix for do_filp_open() race
