commit cc0ee9873c6afafb387379ca1df25da78a08c603 upstream.
ACPI part of the driver accidentally used sizeof(*ssp) instead of the
correct sizeof(*pdata). This leads to nasty memory corruptions like the one
below:
BUG: unable to handle kernel paging request at 0000000749fd30b8
IP: [<ffffffff813fe8a1>] __list_del_entry+0x31/0xd0
PGD 0
Oops: 0000 [#1] PREEMPT SMP
Modules linked in:
CPU: 0 PID: 30 Comm: kworker/0:1 Not tainted 3.10.0-rc6v3.10-rc6_sdhci_modprobe+ #443
task: ffff8801483a0940 ti: ffff88014839e000 task.ti: ffff88014839e000
RIP: 0010:[<ffffffff813fe8a1>] [<ffffffff813fe8a1>] __list_del_entry+0x31/0xd0
RSP: 0000:ffff88014839fde8 EFLAGS: 00010046
RAX: ffff880149fd30b0 RBX: ffff880149fd3040 RCX: dead000000200200
RDX: 0000000749fd30b0 RSI: ffff880149fd3058 RDI: ffff88014834d640
RBP: ffff88014839fde8 R08: ffff88014834d640 R09: 0000000000000001
R10: ffff8801483a0940 R11: 0000000000000001 R12: ffff880149fd3040
R13: ffffffff810e0b30 R14: ffff8801483a0940 R15: ffff88014834d640
FS: 0000000000000000(0000) GS:ffff880149e00000(0000) knlGS:0000000000000000
CR2: 0000000000000168 CR3: 0000000001e0b000 CR4: 00000000001407f0
Stack:
ffff88014839fe48 ffffffff810e0baf ffffffff81120abd ffff88014839fe20
ffff8801483a0940 ffff8801483a0940 ffff8801483a0940 ffff8801486b1c90
ffff88014834d640 ffffffff810e0b30 0000000000000000 0000000000000000
Call Trace:
[<ffffffff810e0baf>] worker_thread+0x7f/0x390
[<ffffffff81120abd>] ? trace_hardirqs_on+0xd/0x10
[<ffffffff810e0b30>] ? manage_workers.isra.22+0x2b0/0x2b0
[<ffffffff810e6c09>] kthread+0xd9/0xe0
[<ffffffff810f93df>] ? local_clock+0x3f/0x50
[<ffffffff810e6b30>] ? kthread_create_on_node+0x110/0x110
[<ffffffff818c5dec>] ret_from_fork+0x7c/0xb0
Fix this by using the right structure size in devm_kzalloc().
Reported-by: Jerome Blin <jerome.blin@intel.com>
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
commit 5548f98c46538d1da04eff179a52e50537d11465 upstream.
pxa2xx_spi_map_dma_buffer() gets called in tasklet context so we can't
sleep when we allocate a new sg table. Use GFP_ATOMIC here instead.
commit 5ed0505c713805f89473cdc0bbfb5110dfd840cb upstream.
Until recently uio_get_minor() returned 0 for success and
a negative value on failure. This became non-negative for suceess and
negative for failure. Restore the original return value spec so that we can
successfully initialize UIO devices with a non-zero minor device
number.
Signed-off-by: Damian Hobson-Garcia <dhobsong@igel.co.jp>
Cc: "Hans J. Koch" <hjk@hansjkoch.de>
commit 9bb5d40cd93c9dd4be74834b1dcb1ba03629716b upstream.
Vince's fuzzer once again found holes. This time it spotted a leak in
the locked page accounting.
When an event had redirected output and its close() was the last
reference to the buffer we didn't have a vm context to undo accounting.
Change the code to destroy the buffer on the last munmap() and detach
all redirected events at that time. This provides us the right context
to undo the vm accounting.
Reported-and-tested-by: Vince Weaver <vincent.weaver@maine.edu>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/20130604084421.GI8923@twins.programming.kicks-ass.net
commit 26cb63ad11e04047a64309362674bcbbd6a6f246 upstream.
Vince reported a problem found by his perf specific trinity
fuzzer.
Al noticed 2 problems with perf's mmap():
- it has issues against fork() since we use vma->vm_mm for accounting.
- it has an rb refcount leak on double mmap().
We fix the issues against fork() by using VM_DONTCOPY; I don't
think there's code out there that uses this; we didn't hear
about weird accounting problems/crashes. If we do need this to
work, the previously proposed VM_PINNED could make this work.
Aside from the rb reference leak spotted by Al, Vince's example
prog was indeed doing a double mmap() through the use of
perf_event_set_output().
This exposes another problem, since we now have 2 events with
one buffer, the accounting gets screwy because we account per
event. Fix this by making the buffer responsible for its own
accounting.
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/20130528085548.GA12193@twins.programming.kicks-ass.net
commit 3a96d5cd7bdce45d5dded75c3a62d4fb98050280 upstream.
[Backported for 3.9-stable.
'kmalloc(MAX_OBJ_NAME_SIZE + 1, GFP_NOIO)' was changed as
'kmem_cache_alloc(rbd_segment_name_cache, GFP_NOIO)' in 78c2a44
since 3.10-rc1, and 78c2a44 is relied on a big patchset, so restore
it as 3.9 did.]
Format 2 objects use 16 characters for the object name suffix to be
able to express the full 64-bit range of object numbers. Format 1
images only use 12 characters for this. Using 12-character names for
format 2 caused userspace and kernel rbd clients to read differently
named objects, which made an image written by one client look empty to
the other client.
Reported-by: Chris Dunlop <chris@onthe.net.au>
Signed-off-by: Josh Durgin <josh.durgin@inktank.com>
Reviewed-by: Sage Weil <sage@inktank.com>
Reviewed-by: Lingzhu Xiang <lxiang@redhat.com>
Signed-off-by: Zhouping Liu <zliu@redhat.com>
commit 574780fd5e6ec52bd43e0bdb777a19e4c4c6aa9c upstream.
Here is a fun one. Bug seems to have been introduced by commit 140854cb,
almost two years ago. I have no idea why we only started seeing it now,
but we did.
Rough callgraph:
core_tpg_set_initiator_node_queue_depth()
`-> spin_lock_irqsave(&tpg->session_lock, flags);
`-> lio_tpg_shutdown_session()
`-> iscsit_stop_time2retain_timer()
`-> spin_unlock_bh(&se_tpg->session_lock);
`-> spin_lock_bh(&se_tpg->session_lock);
`-> spin_unlock_irqrestore(&tpg->session_lock, flags);
core_tpg_set_initiator_node_queue_depth() used to call spin_lock_bh(),
but 140854cb changed that to spin_lock_irqsave(). However,
lio_tpg_shutdown_session() still claims to be called with spin_lock_bh()
held, as does iscsit_stop_time2retain_timer():
* Called with spin_lock_bh(&struct se_portal_group->session_lock) held
Stale documentation is mostly annoying, but in this case the dropping
the lock with the _bh variant is plain wrong. It is also wrong to drop
locks two functions below the lock-holder, but I will ignore that bit
for now.
After some more locking and unlocking we eventually hit this backtrace:
WARNING: at kernel/softirq.c:159 local_bh_enable_ip+0xe8/0x100()
Pid: 24645, comm: lio_helper.py Tainted: G O 3.6.11+
Call Trace:
[<ffffffff8103e5ff>] warn_slowpath_common+0x7f/0xc0
[<ffffffffa040ae37>] ? iscsit_inc_conn_usage_count+0x37/0x50 [iscsi_target_mod]
[<ffffffff8103e65a>] warn_slowpath_null+0x1a/0x20
[<ffffffff810472f8>] local_bh_enable_ip+0xe8/0x100
[<ffffffff815b8365>] _raw_spin_unlock_bh+0x15/0x20
[<ffffffffa040ae37>] iscsit_inc_conn_usage_count+0x37/0x50 [iscsi_target_mod]
[<ffffffffa041149a>] iscsit_stop_session+0xfa/0x1c0 [iscsi_target_mod]
[<ffffffffa0417fab>] lio_tpg_shutdown_session+0x7b/0x90 [iscsi_target_mod]
[<ffffffffa033ede4>] core_tpg_set_initiator_node_queue_depth+0xe4/0x290 [target_core_mod]
[<ffffffffa0409032>] iscsit_tpg_set_initiator_node_queue_depth+0x12/0x20 [iscsi_target_mod]
[<ffffffffa0415c29>] lio_target_nacl_store_cmdsn_depth+0xa9/0x180 [iscsi_target_mod]
[<ffffffffa0331b49>] target_fabric_nacl_base_attr_store+0x39/0x40 [target_core_mod]
[<ffffffff811b857d>] configfs_write_file+0xbd/0x120
[<ffffffff81148f36>] vfs_write+0xc6/0x180
[<ffffffff81149251>] sys_write+0x51/0x90
[<ffffffff815c0969>] system_call_fastpath+0x16/0x1b
---[ end trace 3747632b9b164652 ]---
As a pure band-aid, this patch drops the _bh.
Signed-off-by: Joern Engel <joern@logfs.org>
commit 7c61c3d8f44d5d822f758754287af644307b4af9 upstream.
Commit 699390354da6c258b65bf8fa79cfd5feaede50b6
('pty: Ignore slave pty close() if never successfully opened')
introduced a bug with ptys whereby a write() in parallel with an
open() on an existing pty could mistakenly indicate an I/O error.
Only indicate an I/O error if the condition on open() actually exists.
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Tested-by: Mikael Pettersson <mikpe@it.uu.se>
commit b5aff3d2747bea08b386edd070941a45611ffe51 upstream.
Suppose an initiator sends a DATA IN command with an allocation length
shorter than the FC transfer length -- we get a target message like
TARGET_CORE[qla2xxx]: Expected Transfer Length: 256 does not match SCSI CDB Length: 0 for SAM Opcode: 0x12
In that case, the target core adjusts the data_length and sets
se_cmd->residual_count for the underrun. But now suppose that command
fails and we end up in tcm_qla2xxx_queue_status() -- that function
unconditionally overwrites residual_count with the already adjusted
data_length, and the initiator will burp with a message like
qla2xxx [0000:00:06.0]-301d:0: Dropped frame(s) detected (0x100 of 0x100 bytes).
Fix this by adding on to the existing underflow residual count instead.
Signed-off-by: Roland Dreier <roland@purestorage.com>
Cc: Giridhar Malavali <giridhar.malavali@qlogic.com>
Cc: Chad Dupuis <chad.dupuis@qlogic.com>
commit 875979368eb4cfecff9f0e97625b90cc6009269d upstream.
fw_priv->buf is accessed in both request_firmware_load() and
writing to sysfs file of 'loading' context, but not protected
by 'fw_lock' entirely. The patch makes sure that access on
'fw_priv->buf' is protected by the lock.
So fixes the double abort problem reported by nirinA raseliarison:
http://lkml.org/lkml/2013/6/14/188
Reported-and-tested-by: nirinA raseliarison <nirina.raseliarison@gmail.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Ming Lei <ming.lei@canonical.com>
commit 35a2fbc941accd0e9f1bfadd669311786118d874 upstream.
Add product id for Abbott strip port cable for Precision meter which
uses the TI 3410 chip.
Signed-off-by: Anders Hammarquist <iko@iko.pp.se>
commit be66227151c0cd4da536098c3ee07809101c6faa upstream.
Added MAP_TRIGGERS_TO_BUTTONS for Mad Catz Street Fighter IV FightPad
device. This controller model was already supported by the xpad
driver, but none of the buttons work correctly without this change.
Tested on kernel version 3.9.5.
Signed-off-by: Shawn Joseph <jms.576@gmail.com>
commit 150e5928d6063b273a80d9d6722417ac3c93ff82 upstream.
Several drivers don't build on s390 with CONFIG_PCI disabled as
they require MMIO functions.
commit d2983cdb480157f637df07723f28aaa657b1080d upstream.
memcpy param is wrong because of offset in bl_cmd, this may corrupt the
stack which may cause a crash.
Tested-by: Ferruh Yigit <fery@cypress.com> on TMA300-DVK
Signed-off-by: Ferruh Yigit <fery@cypress.com>
Acked-by: Javier Martinez Canillas <javier@dowhile0.org>
[ Upstream commit 15e5a030716468dce4032fa0f398d840fa2756f6 ]
gso_segs were reset to zero when kernel receive packets from untrusted
source. But we use this zero value to estimate precise packet len which is
wrong. So this patch tries to estimate the correct gso_segs value before using
it in qdisc_pkt_len_init().
Signed-off-by: Jason Wang <jasowang@redhat.com>
Cc: Eric Dumazet <edumazet@google.com>
[ Upstream commit f9ca8f74399f9195fd8e01f67a8424a8d33efa55 ]
Currently, for the packets receives from netback, before doing header check,
kernel just reset the transport header in netif_receive_skb() which pretends non
l4 header. This is suboptimal for precise packet length estimation (introduced
in 1def9238: net_sched: more precise pkt_len computation) which needs correct l4
header for gso packets.
The patch just reuse the header probed by netback for partial checksum packets
and tries to use skb_flow_dissect() for other cases, if both fail, just pretend
no l4 header.
Cc: Ian Campbell <ian.campbell@citrix.com>
[ Upstream commit c1aad275b0293d2b1905ec95a945422262470684 ]
Set the transport header for 1) some drivers (e.g ixgbe needs l4 header to do
atr) 2) precise packet length estimation (introduced in 1def9238) needs l4
header to compute header length.
So this patch first tries to get l4 header for packet socket through
skb_flow_dissect(), and pretend no l4 header if skb_flow_dissect() fails.
[ Upstream commit 38502af77e07b5d6650b9ff99a0b482d86366592 ]
Currently, for the packets receives from tuntap, before doing header check,
in 1def9238) which needs correct l4 header for gso packets.
So this patch set the transport header to csum_start for partial checksum
packets, otherwise it first try skb_flow_dissect(), if it fails, just reset the
transport header.
[ Upstream commit 9b4d669bc06c215d64f56f1eb0d4eb96e14d689d ]
Set the transport header for 1) some drivers (e.g ixgbe) needs l4 header 2)
precise packet length estimation (introduced in 1def9238) needs l4 header to
For the packets with partial checksum, the patch just set the transport header
to csum_start. Otherwise tries to use skb_flow_dissect() to get l4 offset, if it
fails, just pretend no l4 header.
[ Upstream commit e8dbad66ef56074eadb41ed5998acd2320447018 ]
commit (3be8fbab tuntap: fix error return code in tun_set_iff()) breaks the
creation of multiqueue tuntap since it forbids to create more than one queues
for a multiqueue tuntap device. We need return 0 instead -EBUSY here since we
don't want to re-initialize the device when one or more queues has been already
attached. Add a comment and correct the return value to zero.
Reported-by: Jerry Chu <hkchu@google.com>
Cc: Jerry Chu <hkchu@google.com>
Cc: Wei Yongjun <weiyj.lk@gmail.com>
Acked-by: Jerry Chu <hkchu@google.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit dd019897358b815f7828dab90b51d51df4d3658d ]
This patch fixes an issue that the driver increments the "RX length error"
on every buffer in sh_eth_rx() if the R8A7740.
This patch also adds a description about the Receive Frame Status bits.
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
[ Upstream commit c5c7774d7eb4397891edca9ebdf750ba90977a69 ]
In commit 2f94aabd9f6c925d77aecb3ff020f1cc12ed8f86
(refactor sctp_outq_teardown to insure proper re-initalization)
we modified sctp_outq_teardown to use sctp_outq_init to fully re-initalize the
outq structure. Steve West recently asked me why I removed the q->error = 0
initalization from sctp_outq_teardown. I did so because I was operating under
the impression that sctp_outq_init would properly initalize that value for us,
but it doesn't. sctp_outq_init operates under the assumption that the outq
struct is all 0's (as it is when called from sctp_association_init), but using
it in __sctp_outq_teardown violates that assumption. We should do a memset in
sctp_outq_init to ensure that the entire structure is in a known state there
instead.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: "West, Steve (NSN - US/Fort Worth)" <steve.west@nsn.com>
CC: Vlad Yasevich <vyasevich@gmail.com>
CC: netdev@vger.kernel.org
CC: davem@davemloft.net
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit a6f79d0f26704214b5b702bbac525cb72997f984 ]
PPPoL2TP sockets should comply with the standard send*() return values
(i.e. return number of bytes sent instead of 0 upon success).
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit 55b92b7a11690bc377b5d373872a6b650ae88e64 ]
Copy user data after PPP framing header. This prevents erasure of the
added PPP header and avoids leaking two bytes of uninitialised memory
at the end of skb's data buffer.
[ Upstream commit 2dc85bf323515e59e15dfa858d1472bb25cad0fe ]
uaddr->sa_data is exactly of size 14, which is hard-coded here and
passed as a size argument to strncpy(). A device name can be of size
IFNAMSIZ (== 16), meaning we might leave the destination string
unterminated. Thus, use strlcpy() and also sizeof() while we're
at it. We need to memset the data area beforehand, since strlcpy
does not padd the remaining buffer with zeroes for user space, so
that we do not possibly leak anything.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
[ Upstream commit 72df935d985c1575ed44ad2c8c653b28147993fa ]
team_port_enable() adds port to port_hashlist. Reader sees port
in team_get_port_by_index_rcu() and returns it, but
team_get_first_port_txable_rcu() tries to go through port_list, where the
port is not inserted yet -> NULL pointer dereference.
Fix this by reordering port_list and port_hashlist insertion.
Panic is easily triggeable when txing packets and adding/removing port
in a loop.
Introduced by commit 3d249d4c "net: introduce ethernet teaming device"
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit 76c455decbbad31de21c727edb184a963f42b40b ]
team_get_port_by_index_rcu() might return NULL due to race between port
removal and skb tx path. Panic is easily triggeable when txing packets
and adding/removing port in a loop.
introduced by commit 3d249d4ca "net: introduce ethernet teaming device"
and commit 753f993911b "team: introduce random mode" (for random mode)
[ Upstream commit 19a6afb23e5d323e1245baa4e62755492b2f1200 ]
Commit 54f968d6efdbf7dec36faa44fc11f01b0e4d1990
(tuntap: move socket to tun_file) forgets to set SOCK_ZEROCOPY flag, which will
prevent vhost_net from doing zercopy w/ tap. This patch fixes this by setting
it during file open.
Cc: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit 1abd165ed757db1afdefaac0a4bc8a70f97d258c ]
While stress testing sctp sockets, I hit the following panic:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000020
IP: [<ffffffffa0490c4e>] sctp_endpoint_free+0xe/0x40 [sctp]
PGD 7cead067 PUD 7ce76067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in: sctp(F) libcrc32c(F) [...]
CPU: 7 PID: 2950 Comm: acc Tainted: GF 3.10.0-rc2+ #1
Hardware name: Dell Inc. PowerEdge T410/0H19HD, BIOS 1.6.3 02/01/2011
task: ffff88007ce0e0c0 ti: ffff88007b568000 task.ti: ffff88007b568000
RIP: 0010:[<ffffffffa0490c4e>] [<ffffffffa0490c4e>] sctp_endpoint_free+0xe/0x40 [sctp]
RSP: 0018:ffff88007b569e08 EFLAGS: 00010292
RAX: 0000000000000000 RBX: ffff88007db78a00 RCX: dead000000200200
RDX: ffffffffa049fdb0 RSI: ffff8800379baf38 RDI: 0000000000000000
RBP: ffff88007b569e18 R08: ffff88007c230da0 R09: 0000000000000001
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: ffff880077990d00 R14: 0000000000000084 R15: ffff88007db78a00
FS: 00007fc18ab61700(0000) GS:ffff88007fc60000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000020 CR3: 000000007cf9d000 CR4: 00000000000007e0
Stack:
ffff88007b569e38 ffff88007db78a00 ffff88007b569e38 ffffffffa049fded
ffffffff81abf0c0 ffff88007db78a00 ffff88007b569e58 ffffffff8145b60e
0000000000000000 0000000000000000 ffff88007b569eb8 ffffffff814df36e
Call Trace:
[<ffffffffa049fded>] sctp_destroy_sock+0x3d/0x80 [sctp]
[<ffffffff8145b60e>] sk_common_release+0x1e/0xf0
[<ffffffff814df36e>] inet_create+0x2ae/0x350
[<ffffffff81455a6f>] __sock_create+0x11f/0x240
[<ffffffff81455bf0>] sock_create+0x30/0x40
[<ffffffff8145696c>] SyS_socket+0x4c/0xc0
[<ffffffff815403be>] ? do_page_fault+0xe/0x10
[<ffffffff8153cb32>] ? page_fault+0x22/0x30
[<ffffffff81544e02>] system_call_fastpath+0x16/0x1b
Code: 0c c9 c3 66 2e 0f 1f 84 00 00 00 00 00 e8 fb fe ff ff c9 c3 66 0f
1f 84 00 00 00 00 00 55 48 89 e5 53 48 83 ec 08 66 66 66 66 90 <48>
8b 47 20 48 89 fb c6 47 1c 01 c6 40 12 07 e8 9e 68 01 00 48
RIP [<ffffffffa0490c4e>] sctp_endpoint_free+0xe/0x40 [sctp]
RSP <ffff88007b569e08>
---[ end trace e0d71ec1108c1dd9 ]---
I did not hit this with the lksctp-tools functional tests, but with a
small, multi-threaded test program, that heavily allocates, binds,
listens and waits in accept on sctp sockets, and then randomly kills
some of them (no need for an actual client in this case to hit this).
Then, again, allocating, binding, etc, and then killing child processes.
This panic then only occurs when ``echo 1 > /proc/sys/net/sctp/auth_enable''
is set. The cause for that is actually very simple: in sctp_endpoint_init()
we enter the path of sctp_auth_init_hmacs(). There, we try to allocate
our crypto transforms through crypto_alloc_hash(). In our scenario,
it then can happen that crypto_alloc_hash() fails with -EINTR from
crypto_larval_wait(), thus we bail out and release the socket via
sk_common_release(), sctp_destroy_sock() and hit the NULL pointer
dereference as soon as we try to access members in the endpoint during
sctp_endpoint_free(), since endpoint at that time is still NULL. Now,
if we have that case, we do not need to do any cleanup work and just
leave the destruction handler.
[ Upstream commit 4364d5f96eed7994a2c625bd9216656e55fba0cb ]
When we decide not use zero-copy, msg.control should be set to NULL otherwise
macvtap/tap may set zerocopy callbacks which may decrease the kref of ubufs
wrongly.
Bug were introduced by commit cedb9bdce099206290a2bdd02ce47a7b253b6a84
(vhost-net: skip head management if no outstanding).
This solves the following warnings:
WARNING: at include/linux/kref.h:47 handle_tx+0x477/0x4b0 [vhost_net]()
Modules linked in: vhost_net macvtap macvlan tun nfsd exportfs bridge stp llc openvswitch kvm_amd kvm bnx2 megaraid_sas [last unloaded: tun]
CPU: 5 PID: 8670 Comm: vhost-8668 Not tainted 3.10.0-rc2+ #1566
Hardware name: Dell Inc. PowerEdge R715/00XHKG, BIOS 1.5.2 04/19/2011
ffffffffa0198323 ffff88007c9ebd08 ffffffff81796b73 ffff88007c9ebd48
ffffffff8103d66b 000000007b773e20 ffff8800779f0000 ffff8800779f43f0
ffff8800779f8418 000000000000015c 0000000000000062 ffff88007c9ebd58
Call Trace:
[<ffffffff81796b73>] dump_stack+0x19/0x1e
[<ffffffff8103d66b>] warn_slowpath_common+0x6b/0xa0
[<ffffffff8103d6b5>] warn_slowpath_null+0x15/0x20
[<ffffffffa0197627>] handle_tx+0x477/0x4b0 [vhost_net]
[<ffffffffa0197690>] handle_tx_kick+0x10/0x20 [vhost_net]
[<ffffffffa019541e>] vhost_worker+0xfe/0x1a0 [vhost_net]
[<ffffffffa0195320>] ? vhost_attach_cgroups_work+0x30/0x30 [vhost_net]
[<ffffffff81061f46>] kthread+0xc6/0xd0
[<ffffffff81061e80>] ? kthread_freezable_should_stop+0x70/0x70
[<ffffffff817a1aec>] ret_from_fork+0x7c/0xb0
[ Upstream commit 5343a7f8be11951cb3095b91e8e4eb506cfacc0f ]
commit 56b765b79 ("htb: improved accuracy at high rates") added another
regression for low rates, because it mixes 1ns and 64ns time units.
So the maximum delay (mbuffer) was not 60 second, but 937 ms.
Lets convert all time fields to 1ns as 64bit arches are becoming the
norm.
Reported-by: Jesper Dangaard Brouer <brouer@redhat.com>
Tested-by: Jesper Dangaard Brouer <brouer@redhat.com>
[ Upstream commit 534c877928a16ae5f9776436a497109639bf67dc ]
Commit 25fb6ca4ed9cad72f14f61629b68dc03c0d9713f
"net IPv6 : Fix broken IPv6 routing table after loopback down-up"
forgot to assign rt6_info to the inet6_ifaddr.
When disable the net device, the rt6_info which allocated
in init_loopback will not be destroied in __ipv6_ifa_notify.
This will trigger the waring message below
[23527.916091] unregister_netdevice: waiting for tap0 to become free. Usage count = 1
Reported-by: Arkadiusz Miskiewicz <a.miskiewicz@gmail.com>
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
[ Upstream commit 01cb71d2d47b78354358e4bb938bb06323e17498 ]
broke the "overhead xxx" handling, as well as the "linklayer atm"
attribute.
tc class add ... htb rate X ceil Y linklayer atm overhead 10
This patch restores the "overhead xxx" handling, for htb, tbf
and act_police
The "linklayer atm" thing needs a separate fix.
Cc: Vimalkumar <j.vimal@gmail.com>
Cc: Jiri Pirko <jpirko@redhat.com>
[ Upstream commit c87a124a5d5e8cf8e21c4363c3372bcaf53ea190 ]
Roman Gushchin discovered that udp4_lib_lookup2() was not reloading
first item in the rcu protected list, in case the loop was restarted.
This produced soft lockups as in https://lkml.org/lkml/2013/4/16/37
rcu_dereference(X)/ACCESS_ONCE(X) seem to not work as intended if X is
ptr->field :
In some cases, gcc caches the value or ptr->field in a register.
Use a barrier() to disallow such caching, as documented in
Documentation/atomic_ops.txt line 114
Thanks a lot to Roman for providing analysis and numerous patches.
Diagnosed-by: Roman Gushchin <klamm@yandex-team.ru>
Reported-by: Boris Zhmurov <zhmurov@yandex-team.ru>
Signed-off-by: Roman Gushchin <klamm@yandex-team.ru>
[ Upstream commit 1e2bd517c108816220f262d7954b697af03b5f9c ]
udp6 over GRE tunnel does not work after to GRE tso changes. GRE
tso handler passes inner packet but keeps track of outer header
start in SKB_GSO_CB(skb)->mac_offset. udp6 fragment need to
take care of outer header, which start at the mac_offset, while
adding fragment header.
This bug is introduced by commit 68c3316311 (GRE: Add TCP
segmentation offload for GRE).
Reported-by: Dmitry Kravkov <dkravkov@gmail.com>
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
Tested-by: Dmitry Kravkov <dmitry@broadcom.com>
[ Upstream commit 8e6d91ae0917bf934ed86411148f79d904728d51 ]
We currently allow changing the mq flag (IFF_MULTI_QUEUE) for a persistent
device. This will result a mismatch between the number the queues in netdev and
tuntap. This is because we only allocate a 1q netdevice when IFF_MULTI_QUEUE was
not specified, so when we set the IFF_MULTI_QUEUE and try to attach more queues
later, netif_set_real_num_tx_queues() may fail which result a single queue
netdevice with multiple sockets attached.
Solve this by disallowing changing the mq flag for persistent device.
Bug was introduced by commit edfb6a148ce62e5e19354a1dcd9a34e00815c2a1
(tuntap: reduce memory using of queues).
Reported-by: Sriram Narasimhan <sriram.narasimhan@hp.com>
[ Upstream commit 456db6a4d495f40777da6f1f32f62f13026f52db ]
The three arrays of strings: af_family_key_strings,
af_family_slock_key_strings and af_family_clock_key_strings have not
VSOCK's string
Signed-off-by: Federico Vaga <federico.vaga@gmail.com>
[ Upstream commits 1be374a0518a288147c6a7398792583200a67261 and
a7526eb5d06b0084ef12d7b168d008fcf516caab ]
MSG_CMSG_COMPAT is (AFAIK) not intended to be part of the API --
it's a hack that steals a bit to indicate to other networking code
that a compat entry was used. So don't allow it from a non-compat
syscall.
This prevents an oops when running this code:
int main()
int s;
struct sockaddr_in addr;
struct msghdr *hdr;
char *highpage = mmap((void*)(TASK_SIZE_MAX - 4096), 4096,
PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_ANONYMOUS | MAP_FIXED, -1, 0);
if (highpage == MAP_FAILED)
err(1, "mmap");
s = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP);
if (s == -1)
err(1, "socket");
addr.sin_family = AF_INET;
addr.sin_port = htons(1);
addr.sin_addr.s_addr = htonl(INADDR_LOOPBACK);
if (connect(s, (struct sockaddr*)&addr, sizeof(addr)) != 0)
err(1, "connect");
void *evil = highpage + 4096 - COMPAT_MSGHDR_SIZE;
printf("Evil address is %p\n", evil);
if (syscall(__NR_sendmmsg, s, evil, 1, MSG_CMSG_COMPAT) < 0)
err(1, "sendmmsg");
return 0;
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
[ Upstream commit f96ef988cc603487c03a6de07807b06cbe641829 ]
Unlike ipv4_redirect() and ipv4_sk_redirect(), ip_do_redirect()
doesn't call __build_flow_key() directly but via
ip_rt_build_flow_key() wrapper. This leads to __build_flow_key()
getting pointer to IPv4 header of the ICMP redirect packet
rather than pointer to the embedded IPv4 header of the packet
initiating the redirect.
As a result, handling of ICMP redirects initiated by TCP packets
is broken. Issue was introduced by
4895c771c ("ipv4: Add FIB nexthop exceptions.")
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
[ Upstream commit 9a9c56cb34e65000d1f0a4b7553399bfcf7c5a52 ]
The phy_init_eee has to exit with an error when the
local device and its link partner both do not support EEE.
So this patch fixes a problem when verify this.
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
[ Upstream commit a622260254ee481747cceaaa8609985b29a31565 ]
Daniel Petre reported crashes in icmp_dst_unreach() with following call
graph:
Daniel found a similar problem mentioned in
http://lkml.indiana.edu/hypermail/linux/kernel/1007.0/00961.html
And indeed this is the root cause : skb->cb[] contains data fooling IP
stack.
We must clear IPCB in ip_tunnel_xmit() sooner in case dst_link_failure()
is called. Or else skb->cb[] might contain garbage from GSO segmentation
layer.
A similar fix was tested on linux-3.9, but gre code was refactored in
linux-3.10. I'll send patches for stable kernels as well.
Many thanks to Daniel for providing reports, patches and testing !
Reported-by: Daniel Petre <daniel.petre@rcs-rds.ro>
[ Upstream commit 547669d483e5783d722772af1483fa474da7caf9 ]
commit 3853b5841c01a ("xps: Improvements in TX queue selection")
introduced ooo_okay flag, but the condition to set it is slightly wrong.
In our traces, we have seen ACK packets being received out of order,
and RST packets sent in response.
We should test if we have any packets still in host queue.
Cc: Tom Herbert <therbert@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 497574c72c9922cf20c12aed15313c389f722fa0 ]
The error exit path needs err explicitly set. Otherwise it
returns success and the only caller, xfrm_output_resume(),
would oops in skb_dst(skb)->ops derefence as skb_dst(skb) is
NULL.
Bug introduced in commit bb65a9cb (xfrm: removes a superfluous
check and add a statistic).
Signed-off-by: Timo Teräs <timo.teras@iki.fi>
Cc: Li RongQing <roy.qing.li@gmail.com>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 35f079ebbc860dcd1cca70890c9c8d59c1145525 ]
This patch is a fix for a bug triggering newly_acked_sacked < 0
in tcp_ack(.).
The bug is triggered by sacked_out decreasing relative to prior_sacked,
but packets_out remaining the same as pior_packets. This is because the
snapshot of prior_packets is taken after tcp_sacktag_write_queue() while
prior_sacked is captured before tcp_sacktag_write_queue(). The problem
is: tcp_sacktag_write_queue (tcp_match_skb_to_sack() -> tcp_fragment)
adjusts the pcount for packets_out and sacked_out (MSS change or other
reason). As a result, this delta in pcount is reflected in
(prior_sacked - sacked_out) but not in (prior_packets - packets_out).
This patch does the following:
1) initializes prior_packets at the start of tcp_ack() so as to
capture the delta in packets_out created by tcp_fragment.
2) introduces a new "previous_packets_out" variable that snapshots
packets_out right before tcp_clean_rtx_queue, so pkts_acked can be
correctly computed as before.
3) Computes pkts_acked using previous_packets_out, and computes
newly_acked_sacked using prior_packets.
Signed-off-by: Nandita Dukkipati <nanditad@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
[ Upstream commit 98962baad72fd6d393bf39dbb7c2076532c363c6 ]
This patch cures transmit timeout's with DHCP observed
while running under KVM. When the transmit ring is cleaned out,
the Byte Queue Limit values need to be reset.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
[ Upstream commit b423e9ae49d78ea3f53b131c8d5a6087aed16fd6 ]
8168evl offloaded checksums are wrong since commit
e5195c1f31f399289347e043d6abf3ffa80f0005 ("r8169: fix 8168evl frame padding.")
pads small packets to 60 bytes (without ethernet checksum). Typical symptoms
appear as UDP checksums which are wrong by the count of added bytes.
It isn't worth compensating. Let the driver checksum.
Due to the skb length changes, TSO code is moved before the Tx descriptor gets
written.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Tested-by: Holger Hoffstätte <holger.hoffstaette@googlemail.com>
[ Upstream commit 6b21e1b77d1a3d58ebfd513264c885695e8a0ba5 ]
The net/netlabel/netlabel_domainhash.c:netlbl_domhsh_add() function
does not properly validate new domain hash entries resulting in
potential problems when an administrator attempts to add an invalid
entry. One such problem, as reported by Vlad Halilov, is a kernel
BUG (found in netlabel_domainhash.c:netlbl_domhsh_audit_add()) when
adding an IPv6 outbound mapping with a CIPSO configuration.
This patch corrects this problem by adding the necessary validation
code to netlbl_domhsh_add() via the newly created
netlbl_domhsh_validate() function.
Ideally this patch should also be pushed to the currently active
-stable trees.
Reported-by: Vlad Halilov <vlad.halilov@gmail.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
[ Upstream commit 284041ef21fdf2e0d216ab6b787bc9072b4eb58a ]
commit 0178b695fd6b4 ("ipv6: Copy cork options in ip6_append_data")
added some code duplication and bad error recovery, leading to potential
crash in ip6_cork_release() as kfree() could be called with garbage.
use kzalloc() to make sure this wont happen.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
[ Upstream commit 014be2c8eac3381e202f684c1f35ae184a8b152b ]
Fix some instances where vxlan fdb 'used' field is not updated after the entry
is used.
v2: rename vxlan_find_mac() as __vxlan_find_mac() and create a new vxlan_find_mac()
that also updates ->used field.
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
