commit a89652769470d12cd484ee3d3f7bde0742be8d96 upstream.
MPX setups private anonymous mapping, but uses vma->vm_ops too.
This can confuse core VM, as it relies on vm->vm_ops to
distinguish file VMAs from anonymous.
As result we will get SIGBUS, because handle_pte_fault() thinks
it's file VMA without vm_ops->fault and it doesn't know how to
handle the situation properly.
Let's fix that by not setting ->vm_ops.
We don't really need ->vm_ops here: MPX VMA can be detected with
VM_MPX flag. And vma_merge() will not merge MPX VMA with non-MPX
VMA, because ->vm_flags won't match.
The only thing left is name of VMA. I'm not sure if it's part of
ABI, or we can just drop it. The patch keep it by providing
arch_vma_name() on x86.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: dave@sr71.net
Link: http://lkml.kernel.org/r/20150720212958.305CC3E9@viggo.jf.intel.com
commit 6b7339f4c31ad69c8e9c0b2859276e22cf72176d upstream.
Reading page fault handler code I've noticed that under right
circumstances kernel would map anonymous pages into file mappings: if
the VMA doesn't have vm_ops->fault() and the VMA wasn't fully populated
on ->mmap(), kernel would handle page fault to not populated pte with
do_anonymous_page().
Let's change page fault handler to use do_anonymous_page() only on
anonymous VMA (->vm_ops == NULL) and make sure that the VMA is not
shared.
For file mappings without vm_ops->fault() or shred VMA without vm_ops,
page fault on pte_none() entry would lead to SIGBUS.
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Willy Tarreau <w@1wt.eu>
commit 6f957724b94cb19f5c1c97efd01dd4df8ced323c upstream.
The firmware class uevent function accessed the "fw_priv->buf" buffer
without the proper locking and testing for NULL. This is an old bug
(looks like it goes back to 2012 and commit 1244691c73b2: "firmware
loader: introduce firmware_buf"), but for some reason it's triggering
only now in 4.2-rc1.
Shuah Khan is trying to bisect what it is that causes this to trigger
more easily, but in the meantime let's just fix the bug since others are
hitting it too (at least Ingo reports having seen it as well).
Reported-and-tested-by: Shuah Khan <shuahkh@osg.samsung.com>
Acked-by: Ming Lei <ming.lei@canonical.com>
commit a28e4b2b18ccb90df402da3f21e1a83c9d4f8ec1 upstream.
Removing unnecessary static buffers is good.
Use the vsprintf %pV extension instead.
Signed-off-by: Mikulas Patocka <mikulas@twibright.com>
commit ce657611baf902f14ae559ce4e0787ead6712067 upstream.
There is a possibility of nothing being allocated to the new_opts in
case of memory pressure, therefore return ENOMEM for such case.
Signed-off-by: Sanidhya Kashyap <sanidhya.gatech@gmail.com>
commit 13ee9fdba96577eb1583dcd7b15767ef623fae12 upstream.
If the host toolchain is not glibc based then the arm kernel build
fails with
arch/arm/vdso/vdsomunge.c:53:19: fatal error: error.h: No such file or directory
error.h is a glibc only header (ie not available in musl, newlib and
bsd libcs). Changed the error reporting to standard conforming code
to avoid depending on specific C implementations.
Signed-off-by: Szabolcs Nagy <szabolcs.nagy@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Fixes: 8512287a8165 ("ARM: 8330/1: add VDSO user-space code")
Signed-off-by: Nathan Lynch <nathan_lynch@mentor.com>
commit 398f74569cebbf06bc6b069442bcd0e9616ca465 upstream.
John Stultz reports an RCU splat on boot with ARM ipi trace
events enabled.
[ INFO: suspicious RCU usage. ]
4.1.0-rc7-00033-gb5bed2f #153 Not tainted
include/trace/events/ipi.h:68 suspicious rcu_dereference_check() usage!
RCU used illegally from idle CPU!
rcu_scheduler_active = 1, debug_locks = 0
RCU used illegally from extended quiescent state!
no locks held by swapper/0/0.
stack backtrace:
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.1.0-rc7-00033-gb5bed2f #153
Hardware name: Qualcomm (Flattened Device Tree)
[<c0216b08>] (unwind_backtrace) from [<c02136e8>] (show_stack+0x10/0x14)
[<c02136e8>] (show_stack) from [<c075e678>] (dump_stack+0x70/0xbc)
[<c075e678>] (dump_stack) from [<c0215a80>] (handle_IPI+0x428/0x604)
[<c0215a80>] (handle_IPI) from [<c020942c>] (gic_handle_irq+0x54/0x5c)
[<c020942c>] (gic_handle_irq) from [<c0766604>] (__irq_svc+0x44/0x7c)
Exception stack(0xc09f3f48 to 0xc09f3f90)
3f40: 00000001 00000001 00000000 c09f73b8 c09f4528 c0a5de9c
3f60: c076b4f0 00000000 00000000 c09ef108 c0a5cec1 00000001 00000000 c09f3f90
3f80: c026bf60 c0210ab8 20000113 ffffffff
[<c0766604>] (__irq_svc) from [<c0210ab8>] (arch_cpu_idle+0x20/0x3c)
[<c0210ab8>] (arch_cpu_idle) from [<c02647f0>] (cpu_startup_entry+0x2c0/0x5dc)
[<c02647f0>] (cpu_startup_entry) from [<c099bc1c>] (start_kernel+0x358/0x3c4)
[<c099bc1c>] (start_kernel) from [<8020807c>] (0x8020807c)
At this point in the IPI handling path we haven't called
irq_enter() yet, so RCU doesn't know that we're about to exit
idle and properly warns that we're using RCU from an idle CPU.
Use trace_ipi_entry_rcuidle() instead of trace_ipi_entry() so
that RCU is informed about our exit from idle.
Fixes: 365ec7b17327 ("ARM: add IPI tracepoints")
Reported-by: John Stultz <john.stultz@linaro.org>
Tested-by: John Stultz <john.stultz@linaro.org>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
commit 2b42b09b88c831ba4da2d669581dde371c38c2af upstream.
With commit: e1e455f4f4d3 (perf tools: Work around lack of sched_getcpu
in glibc < 2.6), perf_bench numa mem with -c or -m option is not able to
correctly calculate convergence.
With the above commit, sched_getcpu always seems to return -1. The
intention of commit e1e455f was to add a sched_getcpu in glibc < 2.6.
Hence keep the sched_getcpu definition under an ifdef.
This regression happened occurred between v4.0 and v4.1
Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Vinson Lee <vlee@twitter.com>
Fixes: e1e455f4f4d3 ("perf tools: Work around lack of sched_getcpu in glibc < 2.6")
Link: http://lkml.kernel.org/r/20150624111004.GA5220@linux.vnet.ibm.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit fd28f5d439fca77348c129d5b73043a56f8a0296 upstream.
The current pmd_huge() and pud_huge() functions simply check if the table
bit is not set and reports the entries as huge in that case. This is
counter-intuitive as a clear pmd/pud cannot also be a huge pmd/pud, and
it is inconsistent with at least arm and x86.
To prevent others from making the same mistake as me in looking at code
that calls these functions and to fix an issue with KVM on arm64 that
causes memory corruption due to incorrect page reference counting
resulting from this mistake, let's change the behavior.
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
Reviewed-by: Steve Capper <steve.capper@linaro.org>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Fixes: 084bd29810a5 ("ARM64: mm: HugeTLB support.")
commit d63903bbc30c7ccad040851dfdb4da12d9a17bcf upstream.
Upper bits should be zeroed in endianness conversion:
- even when there's no need to change endianness (i.e., BPF_FROM_BE
on big endian or BPF_FROM_LE on little endian);
- after rev16.
This patch fixes such bugs by emitting extra instructions to clear
upper bits.
Cc: Zi Shen Lim <zlim.lnx@gmail.com>
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
Fixes: e54bcde3d69d ("arm64: eBPF JIT compiler")
Signed-off-by: Xi Wang <xi.wang@gmail.com>
commit 8eee539ddea09bccae2426f09b0ba6a18b72b691 upstream.
Problems occur when bpf_to or bpf_from has value prog->len - 1 (e.g.,
"Very long jump backwards" in test_bpf where the last instruction is a
jump): since ctx->offset has length prog->len, ctx->offset[bpf_to + 1]
or ctx->offset[bpf_from + 1] will cause an out-of-bounds read, leading
to a bogus jump offset and kernel panic.
This patch moves updating ctx->offset to after calling build_insn(),
and changes indexing to use bpf_to and bpf_from without + 1.
commit be081d9bf3e163a9ed1ca2f0f14f08424c7f9016 upstream.
John Stultz reported an RCU splat on ARM with ipi trace events
enabled. It looks like the same problem exists on ARM64.
Cc: John Stultz <john.stultz@linaro.org>
Cc: Nicolas Pitre <nicolas.pitre@linaro.org>
Fixes: 45ed695ac10a ("ARM64: add IPI tracepoints")
commit 67e808fbb0404a12d9b9830a44bbb48d447d8bc9 upstream.
Braino in "9p: switch p9_client_write() to passing it struct iov_iter *";
if response is impossible to parse and we discard the request, get the
out of the loop right there.
commit 75a15a7864c9e281c74a1670b10b69d1d7ff1c82 upstream.
Commit
debe6a623d3c ("MIPS: OCTEON: Update octeon-model.h code for new SoCs.")
renamed some SoC model helper functions, but forgot to update the EDAC
drivers resulting in build failures. Fix that.
Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com>
Acked-by: David Daney <david.daney@cavium.com>
Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Cc: linux-edac <linux-edac@vger.kernel.org>
Cc: linux-mips@linux-mips.org
Link: http://lkml.kernel.org/r/1435747132-10954-1-git-send-email-aaro.koskinen@nokia.com
commit 5d6bed2a9c8bc161bff4cc7cede00f2e0e27a7e7 upstream.
v3.18 changed handle_IRQ() to call __handle_domain_irq(), which now
rejects attempts to deliver IRQ0. Since IRQ 0 is used as the timer
interrupt (just like the PIT on x86), this causes boot to fail as the
bogomips calibration never completes.
Fix this by shuffling all interrupts up by one.
Fixes: a71b092a9c68 ("ARM: Convert handle_IRQ to use __handle_domain_irq")
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit 8b572a4200828b4e75cc22ed2f494b58d5372d65 upstream.
In needs_ilk_vtd_wa(), we pass in the GPU device but compared it against
the ids for the mobile GPU and the mobile host bridge. That latter is
impossible and so likely was just a typo for the desktop GPU device id
(which is also buggy).
Fixes commit da88a5f7f7d434e2cde1b3e19d952e6d84533662
Author: Chris Wilson <chris@chris-wilson.co.uk>
Date: Wed Feb 13 09:31:53 2013 +0000
drm/i915: Disable WC PTE updates to w/a buggy IOMMU on ILK
Reported-by: Ting-Wei Lan <lantw44@gmail.com>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=91127
References: https://bugzilla.freedesktop.org/show_bug.cgi?id=60391
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
commit 5a60e87603c4c533492c515b7f62578189b03c9c upstream.
rbd_obj_request_create() is called on the main I/O path, so we need to
use GFP_NOIO to make sure allocation doesn't blow back on us. Not all
callers need this, but I'm still hardcoding the flag inside rather than
making it a parameter because a) this is going to stable, and b) those
callers shouldn't really use rbd_obj_request_create() and will be fixed
in the future.
More memory allocation fixes will follow.
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Reviewed-by: Alex Elder <elder@linaro.org>
commit 0a73d0a204a4a04a1e110539c5a524ae51f91d6d upstream.
commit a84b69cb6e0a41e86bc593904faa6def3b957343 upstream.
If we'd already sent a request and decide to abort it, we *must*
issue TFLUSH properly and not just blindly reuse the tag, or
we'll get seriously screwed when response eventually arrives
and we confuse it for response to later request that had reused
the same tag.
commit 88de6af24f2b48b06c514d3c3d0a8f22fafe30bd upstream.
req->rq_private_buf isn't initialised when xprt_setup_backchannel calls
xprt_free_allocation.
Fixes: fb7a0b9addbdb ("nfs41: New backchannel helper routines")
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 0c8315dd56577445dd1afe6b9cfa06b7efdf2f82 upstream.
A ds can be associated with more than one mirror, but we currently skip
setting a mirror's credentials if we find that it's already set up with
a connected client.
The upshot is that we can end up sending DS writes with MDS credentials
instead of properly setting them up. Fix nfs4_ff_layout_prepare_ds to
always verify that the mirror's credentials are set up, even when we
have a DS that's already connected.
Reported-by: Tom Haynes <thomas.haynes@primarydata.com>
Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
commit a24221dca1868101c9b4b5adde4a6a5b1a3a64a7 upstream.
If we have two tasks racing to update a mirror's credentials, then they
can end up leaking one (or more) sets of credentials. The first task
will set mirror->cred and then the second task will just overwrite it.
Use a cmpxchg to ensure that the creds are only set once. If we get to
the point where we would set mirror->cred and find that they're already
set, then we just release the creds that were just found.
commit c70701131f7a8edea91fc49d11796d342cff7c62 upstream.
If a write attempt fails, and the write is queued up for resending to
the server, as opposed to being dropped, then we need to set the
appropriate flag so that nfs_file_fsync() does the right thing.
commit 764ad8ba8cd4c6f836fca9378f8c5121aece0842 upstream.
The current buffer is much too small if you have a relatively long
hostname. Bring it up to the size of the one that SETCLIENTID has.
Reported-by: Michael Skralivetsky <michael.skralivetsky@primarydata.com>
commit e8d975e73e5fa05f983fbf2723120edcf68e0b38 upstream.
Problem: When an operation like WRITE receives a BAD_STATEID, even though
recovery code clears the RECLAIM_NOGRACE recovery flag before recovering
the open state, because of clearing delegation state for the associated
inode, nfs_inode_find_state_and_recover() gets called and it makes the
same state with RECLAIM_NOGRACE flag again. As a results, when we restart
looking over the open states, we end up in the infinite loop instead of
breaking out in the next test of state flags.
Solution: unset the RECLAIM_NOGRACE set because of
calling of nfs_inode_find_state_and_recover() after returning from calling
recover_open() function.
Signed-off-by: Olga Kornievskaia <kolga@netapp.com>
commit d683cc49daf7c5afca8cd9654aaa1bf63cdf2ad9 upstream.
When encoding the NFSACL SETACL operation, reserve just the estimated
size of the ACL rather than a fixed maximum. This eliminates needless
zero padding on the wire that the server ignores.
Fixes: ee5dc7732bd5 ('NFS: Fix "kernel BUG at fs/nfs/nfs3xdr.c:1338!"')
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
commit d620876990f02788d5a663075df007ffb91bdfad upstream.
hdr->good_bytes needs to be set to the length of the request, not
zero.
commit 1ca018d28d96d07788474abf66a5f3e9594841f5 upstream.
pnfs_do_write() expects the call to pnfs_write_through_mds() to free the
pgio header and to release the layout segment before exiting. The problem
is that nfs_pgio_data_destroy() doesn't actually do this; it only frees
the memory allocated by nfs_generic_pgio().
Ditto for pnfs_do_read()...
Fix in both cases is to add a call to hdr->release(hdr).
commit 6d451367bfa16fc103604bacd258f534c65d1540 upstream.
Since the parent rate has been recalculated, pixel RCG clock
should rely on it to find the correct M/N values during set_rate,
instead of calling __clk_round_rate() to its parent again.
Signed-off-by: Hai Li <hali@codeaurora.org>
Tested-by: Archit Taneja <architt@codeaurora.org>
Fixes: 99cbd064b059 ("clk: qcom: Support display RCG clocks")
[sboyd@codeaurora.org: Silenced unused parent variable warning]
commit e0cdcda508f110b7ec190dc7c5eb2869ba73a535 upstream.
of_clk_get_from_provider() returns ERR_PTR on failure. The
dra7-atl-clock driver was not checking its return value and
immediately used it in __clk_get_hw(). __clk_get_hw()
dereferences supplied clock, if it is not NULL, so in that case
it would dereference an ERR_PTR.
Fixes: 9ac33b0ce81f ("CLK: TI: Driver for DRA7 ATL (Audio Tracking Logic)")
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
commit 7cb81136d2efe0f5ed9d965857f4756a15e6c338 upstream.
key/value pairs in a JSON object must be separated by a comma.
After adding the properties "accuracy" and "phase" the JSON output
of /sys/kernel/debug/clk/clk_dump is invalid.
So add the missing commas to fix it.
Fixes: 5279fc402ae5 ("clk: add clk accuracy retrieval support")
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
[sboyd@codeaurora.org: Added comment in function]
commit 496e7ce2a46562938edcb74f65b26068ee8895f6 upstream.
If GPIOLIB=n:
drivers/leds/leds-gpio.c: In function ‘gpio_leds_create’:
drivers/leds/leds-gpio.c:187: error: implicit declaration of function ‘devm_get_gpiod_from_child’
drivers/leds/leds-gpio.c:187: warning: assignment makes pointer from integer without a cast
Add dummies for fwnode_get_named_gpiod() and devm_get_gpiod_from_child()
for the !GPIOLIB case to fix this.
Fixes: 40b7318319281b1b ("gpio: Support for unified device properties interface")
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
Signed-off-by: Bryan Wu <cooloney@gmail.com>
commit 530c11d432727c697629ad5f9d00ee8e2864d453 upstream.
The omap watchdog has the annoying behaviour that writes to most
registers don't have any effect when the watchdog is already running.
Quoting the AM335x reference manual:
To modify the timer counter value (the WDT_WCRR register),
prescaler ratio (the WDT_WCLR[4:2] PTV bit field), delay
configuration value (the WDT_WDLY[31:0] DLY_VALUE bit field), or
the load value (the WDT_WLDR[31:0] TIMER_LOAD bit field), the
watchdog timer must be disabled by using the start/stop sequence
(the WDT_WSPR register).
Currently the timer is stopped in the .probe callback but still there
are possibilities that yield to a situation where omap_wdt_start is
entered with the timer running (e.g. when /dev/watchdog is closed
without stopping and then reopened). In such a case programming the
timeout silently fails!
To circumvent this stop the timer before reprogramming.
Assuming one of the first things the watchdog user does is setting the
timeout explicitly nothing too bad should happen because this explicit
setting works fine.
Fixes: 7768a13c252a ("[PATCH] OMAP: Add Watchdog driver support")
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
commit c8fff7bc5bba6bd59cad40441c189c4efe7190f6 upstream.
Node 0 might be offline as well as any other numa node,
in this case kernel cannot handle memory allocation and crashes.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Fixes: 0c3f061c195c ("of: implement of_node_to_nid as a weak function")
Signed-off-by: Grant Likely <grant.likely@linaro.org>
commit cdb672795876d7bc1870aed9a2d7cb59f43d1d96 upstream.
If jffs2 can deadlock on overlayfs readdir because it takes the same lock
on ->iterate() as in ->lookup().
Fix by moving whiteout checking outside iterate_dir(). Optimized by
collecting potential whiteouts (DT_CHR) in a temporary list and if
non-empty iterating throug these and checking for a 0/0 chardev.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Fixes: 49c21e1cacd7 ("ovl: check whiteout while reading directory")
Reported-by: Roman Yeryomin <leroi.lists@gmail.com>
commit b8830a4e71b15d0364ac8e6c55301eea73f211da upstream.
This commit fix kernel crash when probing for rfkill devices in dell-laptop
driver failed. Function free_page() was incorrectly used on struct page *
instead of virtual address of SMI buffer.
This commit also simplify allocating page for SMI buffer by using
__get_free_page() function instead of sequential call of functions
alloc_page() and page_address().
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
commit 294240ffe784e951dc2ef070da04fa31ef6db3a0 upstream.
When kzalloc() is called under spin_lock(), GFP_ATOMIC should be
used to avoid sleeping allocation.
The call tree is:
of_pci_range_to_resource()
--> pci_register_io_range() <-- takes spin_lock(&io_range_lock);
--> kzalloc()
Signed-off-by: Jingoo Han <jingoohan1@gmail.com>
Signed-off-by: Rob Herring <robh@kernel.org>
commit 4b200b4604bec3388426159f1656109d19fadf6e upstream.
This fixes a several year old regression that I found while trying
to get the Yoga 3 11 to work. The ideapad_rfk_set function is meant
to send a command to the embedded controller through ACPI, but
as of c1f73658ed, it sends the index of the rfkill device instead
of the command, and ignores the opcode field.
This changes it back to the original behavior, which indeed
flips the rfkill state as seen in the debugfs interface.
Fixes: c1f73658ed ("ideapad: pass ideapad_priv as argument (part 2)")
commit 4fa9dabcffc8e16601307d3d56b58c68d9716ba4 upstream.
Lenovo G30-50 does not have a hardware wireless switch and wireless
is always blocked.
BugLink: https://bugs.launchpad.net/bugs/1397021
Signed-off-by: Dmitry Tunin <hanipouspilot@gmail.com>
Signed-off-by: Philippe Coval <philippe.coval@open.eurogiciel.org>
[dvhart@linux.intel.com: Reordered dmi id per Phillippe's later version]
commit 56a94f13919c0db5958611b388e1581b4852f3c9 upstream.
Whilst testing cpu hotplug events on kernel configured with
DEBUG_PREEMPT and DEBUG_ATOMIC_SLEEP we get following BUG message,
caused by calling request_irq() and free_irq() in the context of
hotplug notification (which is in this case atomic context).
[ 40.785859] CPU1: Software reset
[ 40.786660] BUG: sleeping function called from invalid context at mm/slub.c:1241
[ 40.786668] in_atomic(): 1, irqs_disabled(): 128, pid: 0, name: swapper/1
[ 40.786678] Preemption disabled at:[< (null)>] (null)
[ 40.786681]
[ 40.786692] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 3.19.0-rc4-00024-g7dca860 #36
[ 40.786698] Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
[ 40.786728] [<c0014a00>] (unwind_backtrace) from [<c0011980>] (show_stack+0x10/0x14)
[ 40.786747] [<c0011980>] (show_stack) from [<c0449ba0>] (dump_stack+0x70/0xbc)
[ 40.786767] [<c0449ba0>] (dump_stack) from [<c00c6124>] (kmem_cache_alloc+0xd8/0x170)
[ 40.786785] [<c00c6124>] (kmem_cache_alloc) from [<c005d6f8>] (request_threaded_irq+0x64/0x128)
[ 40.786804] [<c005d6f8>] (request_threaded_irq) from [<c0350b8c>] (exynos4_local_timer_setup+0xc0/0x13c)
[ 40.786820] [<c0350b8c>] (exynos4_local_timer_setup) from [<c0350ca8>] (exynos4_mct_cpu_notify+0x30/0xa8)
[ 40.786838] [<c0350ca8>] (exynos4_mct_cpu_notify) from [<c003b330>] (notifier_call_chain+0x44/0x84)
[ 40.786857] [<c003b330>] (notifier_call_chain) from [<c0022fd4>] (__cpu_notify+0x28/0x44)
[ 40.786873] [<c0022fd4>] (__cpu_notify) from [<c0013714>] (secondary_start_kernel+0xec/0x150)
[ 40.786886] [<c0013714>] (secondary_start_kernel) from [<40008764>] (0x40008764)
Interrupts cannot be requested/freed in the CPU_STARTING/CPU_DYING
notifications which run on the hotplugged cpu with interrupts and
preemption disabled.
To avoid the issue, request the interrupts for all possible cpus in
the boot code. The interrupts are marked NO_AUTOENABLE to avoid a racy
request_irq/disable_irq() sequence. The flag prevents the
request_irq() code from enabling the interrupt immediately.
The interrupt is then enabled in the CPU_STARTING notifier of the
hotplugged cpu and again disabled with disable_irq_nosync() in the
CPU_DYING notifier.
[ tglx: Massaged changelog to match the patch ]
Fixes: 7114cd749a12 ("clocksource: exynos_mct: use (request/free)_irq calls for local timer registration")
Reported-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Tested-by: Marcin Jabrzyk <m.jabrzyk@samsung.com>
Signed-off-by: Damian Eppel <d.eppel@samsung.com>
Cc: m.szyprowski@samsung.com
Cc: kyungmin.park@samsung.com
Cc: daniel.lezcano@linaro.org
Cc: kgene@kernel.org
Link: http://lkml.kernel.org/r/1435324984-7328-1-git-send-email-d.eppel@samsung.com
Cc: <stable@vger.kernel.org>
commit 8084b86dcfbc4b4822868c1dbdb429b5c08154e2 upstream.
When the VLAN_HLEN was added to the calculation for the maximum frame size
there seems to have been a number of issues added to the driver.
The first issue is that in some cases the maximum frame size for a device
never really reached the actual maximum frame size as the VLAN header
length was not included the calculation for that value. As a result some
parts only supported a maximum frame size of either 1496 in the case of
parts that didn't support jumbo frames, and 8996 in the case of the parts
that do.
The second issue is the fact that there were several checks that weren't
updated so as a result setting an MTU of 1500 was treated as enabling jumbo
frames as the calculated value was 1522 instead of 1518. I have addressed
those by replacing ETH_FRAME_LEN with VLAN_ETH_FRAME_LEN where appropriate.
The final issue was the fact that lowering the MTU below 1500 would cause
the driver to allocate 2K buffers for the rings. This is an old issue that
was fixed several years ago in igb/ixgbe and I am addressing now by just
replacing == with a <= so that we always just round up to 1522 for anything
that isn't a jumbo frame.
Fixes: c751a3d58cf2d ("e1000e: Correctly include VLAN_HLEN when changing interface MTU")
Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
commit ab499db80fcf07c18e4053f91a619500f663e90e upstream.
There was a possible race between
ieee80211_reconfig() and
ieee80211_delayed_tailroom_dec(). This could
result in inability to transmit data if driver
crashed during roaming or rekeying and subsequent
skbs with insufficient tailroom appeared.
This race was probably never seen in the wild
because a device driver would have to crash AND
recover within 0.5s which is very unlikely.
I was able to prove this race exists after
changing the delay to 10s locally and crashing
ath10k via debugfs immediately after GTK
rekeying. In case of ath10k the counter went below
0. This was harmless but other drivers which
actually require tailroom (e.g. for WEP ICV or
MMIC) could end up with the counter at 0 instead
of >0 and introduce insufficient skb tailroom
failures because mac80211 would not resize skbs
appropriately anymore.
Fixes: 8d1f7ecd2af5 ("mac80211: defer tailroom counter manipulation when roaming")
Signed-off-by: Michal Kazior <michal.kazior@tieto.com>
commit 6cbfb1bb66e4e85da5db78e8ff429a85bd84ce64 upstream.
It was possible for mac80211 to be coerced into an
unexpected flow causing sdata union to become
corrupted. Station pointer was put into
sdata->u.vlan.sta memory location while it was
really master AP's sdata->u.ap.next_beacon. This
led to station entry being later freed as
next_beacon before __sta_info_flush() in
ieee80211_stop_ap() and a subsequent invalid
pointer dereference crash.
The problem was that ieee80211_ptr->use_4addr
wasn't cleared on interface type changes.
This could be reproduced with the following steps:
# host A and host B have just booted; no
# wpa_s/hostapd running; all vifs are down
host A> iw wlan0 set type station
host A> iw wlan0 set 4addr on
host A> printf 'interface=wlan0\nssid=4addrcrash\nchannel=1\nwds_sta=1' > /tmp/hconf
host A> hostapd -B /tmp/conf
host B> iw wlan0 set 4addr on
host B> ifconfig wlan0 up
host B> iw wlan0 connect -w hostAssid
host A> pkill hostapd
# host A crashed:
[ 127.928192] BUG: unable to handle kernel NULL pointer dereference at 00000000000006c8
[ 127.929014] IP: [<ffffffff816f4f32>] __sta_info_flush+0xac/0x158
[ 127.934578] [<ffffffff8170789e>] ieee80211_stop_ap+0x139/0x26c
[ 127.934578] [<ffffffff8100498f>] ? dump_trace+0x279/0x28a
[ 127.934578] [<ffffffff816dc661>] __cfg80211_stop_ap+0x84/0x191
[ 127.934578] [<ffffffff816dc7ad>] cfg80211_stop_ap+0x3f/0x58
[ 127.934578] [<ffffffff816c5ad6>] nl80211_stop_ap+0x1b/0x1d
[ 127.934578] [<ffffffff815e53f8>] genl_family_rcv_msg+0x259/0x2b5
Note: This isn't a revert of f8cdddb8d61d
("cfg80211: check iface combinations only when
iface is running") as far as functionality is
considered because b6a550156bc ("cfg80211/mac80211:
move more combination checks to mac80211") moved
the logic somewhere else already.
Fixes: f8cdddb8d61d ("cfg80211: check iface combinations only when iface is running")
commit c779273b37bec14c33feeab11c4d457a24bc64e0 upstream.
commit b112889c5af8124 ("iwlwifi: mvm: add Aux ROC request/response flow")
added aux ROC flow in addition to the existing ROC flow. While doing
it, it moved the ROC reference release to a common work item, which
is being called for both the ROC and aux ROC flows.
This resulted in invalid reference accounting, as no reference was
taken in case of aux ROC, while a reference was released on completion.
Fix it by adding a reference for the aux ROC as well, and release
only the relevant references on completion (according to the set bits).
While at it, convert cancel_work_sync() to flush_work(), in order
to make sure the references are being cleaned properly.
Fixes: b112889c5af8 ("iwlwifi: mvm: add Aux ROC request/response flow")
Signed-off-by: Eliad Peller <eliadx.peller@intel.com>
Reviewed-by: Johannes Berg <johannes.berg@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit 8df734e865b74d9f273216482a45a38269dc767a upstream.
The csa counter has moved from sdata to beacon/presp but
it is not updated accordingly for mesh and ibss. Fix this.
Fixes: af296bdb8da4 ("mac80211: move csa counters from sdata to beacon/presp")
Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com>
commit d194e5d666225b04c7754471df0948f645b6ab3a upstream.
The final version of commit 637241a900cb ("kmsg: honor dmesg_restrict
sysctl on /dev/kmsg") lost few hooks, as result security_syslog() are
processed incorrectly:
- open of /dev/kmsg checks syslog access permissions by using
check_syslog_permissions() where security_syslog() is not called if
dmesg_restrict is set.
- syslog syscall and /proc/kmsg calls do_syslog() where security_syslog
can be executed twice (inside check_syslog_permissions() and then
directly in do_syslog())
With this patch security_syslog() is called once only in all
syslog-related operations regardless of dmesg_restrict value.
Fixes: 637241a900cb ("kmsg: honor dmesg_restrict sysctl on /dev/kmsg")
Signed-off-by: Vasily Averin <vvs@virtuozzo.com>
Cc: Josh Boyer <jwboyer@redhat.com>
Cc: Eric Paris <eparis@redhat.com>
commit 2528a8b8f457d7432552d0e2b6f0f4046bb702f4 upstream.
bitmap_parselist("", &mask, nmaskbits) will erroneously set bit zero in
the mask. The same bug is visible in cpumask_parselist() since it is
layered on top of the bitmask code, e.g. if you boot with "isolcpus=",
you will actually end up with cpu zero isolated.
The bug was introduced in commit 4b060420a596 ("bitmap, irq: add
smp_affinity_list interface to /proc/irq") when bitmap_parselist() was
generalized to support userspace as well as kernelspace.
Fixes: 4b060420a596 ("bitmap, irq: add smp_affinity_list interface to /proc/irq")
Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
commit b86a50c3b5414eafdbee7f34af4a201a4a7817c2 upstream.
Cleanup commit 73679e508201 ("compiler-intel.h: Remove duplicate
definition") removed the double definition of __memory_barrier()
intrinsics.
However, in doing so, it also removed the preceding #undef barrier by
accident, meaning, the actual barrier() macro from compiler-gcc.h with
inline asm is still in place as __GNUC__ is provided.
Subsequently, barrier() can never be defined as __memory_barrier() from
compiler.h since it already has a definition in place and if we trust
the comment in compiler-intel.h, ecc doesn't support gcc specific asm
statements.
I don't have an ecc at hand (unsure if that's still used in the field?)
and only found this by accident during code review, a revert of that
cleanup would be simplest option.
Fixes: 73679e508201 ("compiler-intel.h: Remove duplicate definition")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Reviewed-by: Pranith Kumar <bobby.prani@gmail.com>
Cc: Pranith Kumar <bobby.prani@gmail.com>
Cc: mancha security <mancha1@zoho.com>
commit 17cd5bd5391e6e7b363d66335e1bc6760ae969b9 upstream.
A 32-bit entry point to a DMI table says how many structures the table
contains. The SMBIOS specification explicitly says that end-of-table
markers should be ignored if they are not actually at the end of the
DMI table. So only honor the end-of-table marker for tables accessed
through 64-bit entry points, as they do not specify a structure count.
Fixes: fc43026278 ("dmi: add support for SMBIOS 3.0 64-bit entry point")
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Leif Lindholm <leif.lindholm@linaro.org>
Cc: Matt Fleming <matt.fleming@intel.com>
