git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace updates from Eric Biederman:
"Long ago and far away when user namespaces where young it was realized
that allowing fresh mounts of proc and sysfs with only user namespace
permissions could violate the basic rule that only root gets to decide
if proc or sysfs should be mounted at all.
Some hacks were put in place to reduce the worst of the damage could
be done, and the common sense rule was adopted that fresh mounts of
proc and sysfs should allow no more than bind mounts of proc and
sysfs. Unfortunately that rule has not been fully enforced.
There are two kinds of gaps in that enforcement. Only filesystems
mounted on empty directories of proc and sysfs should be ignored but
the test for empty directories was insufficient. So in my tree
directories on proc, sysctl and sysfs that will always be empty are
created specially. Every other technique is imperfect as an ordinary
directory can have entries added even after a readdir returns and
shows that the directory is empty. Special creation of directories
for mount points makes the code in the kernel a smidge clearer about
it's purpose. I asked container developers from the various container
projects to help test this and no holes were found in the set of mount
points on proc and sysfs that are created specially.
This set of changes also starts enforcing the mount flags of fresh
mounts of proc and sysfs are consistent with the existing mount of
proc and sysfs. I expected this to be the boring part of the work but
unfortunately unprivileged userspace winds up mounting fresh copies of
proc and sysfs with noexec and nosuid clear when root set those flags
on the previous mount of proc and sysfs. So for now only the atime,
read-only and nodev attributes which userspace happens to keep
consistent are enforced. Dealing with the noexec and nosuid
attributes remains for another time.
This set of changes also addresses an issue with how open file
descriptors from /proc/<pid>/ns/* are displayed. Recently readlink of
/proc/<pid>/fd has been triggering a WARN_ON that has not been
meaningful since it was added (as all of the code in the kernel was
converted) and is not now actively wrong.
There is also a short list of issues that have not been fixed yet that
I will mention briefly.
It is possible to rename a directory from below to above a bind mount.
At which point any directory pointers below the renamed directory can
be walked up to the root directory of the filesystem. With user
namespaces enabled a bind mount of the bind mount can be created
allowing the user to pick a directory whose children they can rename
to outside of the bind mount. This is challenging to fix and doubly
so because all obvious solutions must touch code that is in the
performance part of pathname resolution.
As mentioned above there is also a question of how to ensure that
developers by accident or with purpose do not introduce exectuable
files on sysfs and proc and in doing so introduce security regressions
in the current userspace that will not be immediately obvious and as
such are likely to require breaking userspace in painful ways once
they are recognized"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
vfs: Remove incorrect debugging WARN in prepend_path
mnt: Update fs_fully_visible to test for permanently empty directories
sysfs: Create mountpoints with sysfs_create_mount_point
sysfs: Add support for permanently empty directories to serve as mount points.
kernfs: Add support for always empty directories.
proc: Allow creating permanently empty directories that serve as mount points
sysctl: Allow creating permanently empty directories that serve as mountpoints.
fs: Add helper functions for permanently empty directories.
vfs: Ignore unlocked mounts in fs_fully_visible
mnt: Modify fs_fully_visible to deal with locked ro nodev and atime
mnt: Refactor the logic for mounting sysfs and proc in a user namespace
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc
Pull remoteproc updates from Ohad Ben-Cohen:
- remoteproc fixes/cleanups from Suman Anna
- new remoteproc TI Wakeup M3 driver from Dave Gerlach
- remoteproc core support for TI's Wakeup M3 driver from both Dave and Suman
- tiny remoteproc build fix from myself
* tag 'remoteproc-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc:
remoteproc: fix !CONFIG_OF build breakage
remoteproc/wkup_m3: add a remoteproc driver for TI Wakeup M3
Documentation: dt: add bindings for TI Wakeup M3 processor
remoteproc: add a rproc ops for performing address translation
remoteproc: introduce rproc_get_by_phandle API
remoteproc: fix various checkpatch warnings
remoteproc/davinci: fix quoted split string checkpatch warning
remoteproc/ste: add blank lines after declarations
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/hwspinlock
Pull hwspinlock updates from Ohad Ben-Cohen:
- hwspinlock core DT support from Suman Anna
- OMAP hwspinlock DT support from Suman Anna
- QCOM hwspinlock DT support from Bjorn Andersson
- a new CSR atlas7 hwspinlock driver from Wei Chen
- CSR atlas7 hwspinlock DT binding document from Wei Chen
- a tiny QCOM hwspinlock driver fix from Bjorn Andersson
* tag 'hwspinlock-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/hwspinlock:
hwspinlock: qcom: Correct msb in regmap_field
DT: hwspinlock: add the CSR atlas7 hwspinlock bindings document
hwspinlock: add a CSR atlas7 driver
hwspinlock: qcom: Add support for Qualcomm HW Mutex block
DT: hwspinlock: Add binding documentation for Qualcomm hwmutex
hwspinlock/omap: add support for dt nodes
Documentation: dt: add the omap hwspinlock bindings document
hwspinlock/core: add device tree support
Documentation: dt: add common bindings for hwspinlock
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 fixes (and cleanups) from Catalin Marinas:
"Various arm64 fixes:
- suspicious RCU usage warning
- BPF (out of bounds array read and endianness conversion)
- perf (of_node usage after of_node_put, cpu_pmu->plat_device
assignment)
- huge pmd/pud check for value 0
- rate-limiting should only take unhandled signals into account
Clean-up:
- incorrect use of pgprot_t type
- unused header include
- __init annotation to arm_cpuidle_init
- pr_debug instead of pr_error for disabled GICC entries in
ACPI/MADT"
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
arm64: Fix show_unhandled_signal_ratelimited usage
ARM64 / SMP: Switch pr_err() to pr_debug() for disabled GICC entry
arm64: cpuidle: add __init section marker to arm_cpuidle_init
arm64: Don't report clear pmds and puds as huge
arm64: perf: fix unassigned cpu_pmu->plat_device when probing PMU PPIs
arm64: perf: Don't use of_node after putting it
arm64: fix incorrect use of pgprot_t variable
arm64/hw_breakpoint.c: remove unnecessary header
arm64: bpf: fix endianness conversion bugs
arm64: bpf: fix out-of-bounds read in bpf2a64_offset()
ARM64: smp: Fix suspicious RCU usage with ipi tracepoints
Pull nios2 update from Ley Foon Tan:
"Check number of timer instances"
* tag 'nios2-v4.2' of git://git.rocketboards.org/linux-socfpga-next:
nios2: check number of timer instances
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
Pull more hwmon updates from Jean Delvare.
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
hwmon: (w83627ehf) Use swap() in w82627ehf_swap_tempreg()
hwmon: Document which I2C addresses can be probed
hwmon: (w83792d) Additional PWM outputs support
Pull block fixes from Jens Axboe:
"Mainly sending this off now for the writeback fixes, since they fix a
real regression introduced with the cgroup writeback changes. The
NVMe fix could wait for next pull for this series, but it's simple
enough that we might as well include it.
This contains:
- two cgroup writeback fixes from Tejun, fixing a user reported issue
with luks crypt devices hanging when being closed.
- NVMe error cleanup fix from Jon Derrick, fixing a case where we'd
attempt to free an unregistered IRQ"
* 'for-linus' of git://git.kernel.dk/linux-block:
NVMe: Fix irq freeing when queue_request_irq fails
writeback: don't drain bdi_writeback_congested on bdi destruction
writeback: don't embed root bdi_writeback_congested in bdi_writeback
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux
Pull fbdev fix from Tomi Valkeinen:
"Fix display regression on TI AM4xxx boards"
* tag 'fbdev-fixes-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux:
OMAPDSS: fix probing if rfbi device is enabled
git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp
Pull EDAC fix from Borislav Petkov:
"A build fix for octeon_edac from Aaro Koskinen"
* tag 'edac_urgent_for_4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp:
EDAC, octeon: Fix broken build due to model helper renames
Added Hyper-V crash msrs values - HV_X64_MSR_CRASH*.
Signed-off-by: Andrey Smetanin <asmetanin@virtuozzo.com>
Signed-off-by: Denis V. Lunev <den@openvz.org>
Reviewed-by: Peter Hornyack <peterhornyack@google.com>
CC: Paolo Bonzini <pbonzini@redhat.com>
CC: Gleb Natapov <gleb@kernel.org>
Commit 609e36d372ad ("KVM: x86: pass host_initiated to functions that
read MSRs") modified kvm_get_msr_common function to use msr_info->data
instead of data but missed one occurrence. Replace it and remove the
unused local variable.
Fixes: 609e36d372ad ("KVM: x86: pass host_initiated to functions that
read MSRs")
Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org>
Eric noticed problems with vhost-scsi and virtio-ccw: vhost-scsi
complained about overwriting values in the config space, which
was triggered by a broken implementation of virtio-ccw's config
get/set routines. It was probably sheer luck that we did not hit
this before.
When writing a value to the config space, the WRITE_CONF ccw will
always write from the beginning of the config space up to and
including the value to be set. If the config space up to the value
has not yet been retrieved from the device, however, we'll end up
overwriting values. Keep track of the known config space and update
if needed to avoid this.
Moreover, READ_CONF will only read the number of bytes it has been
instructed to retrieve, so we must not copy more than that to the
buffer, or we might overwrite trailing values.
Reported-by: Eric Farman <farman@linux.vnet.ibm.com>
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Reviewed-by: Eric Farman <farman@linux.vnet.ibm.com>
Tested-by: Eric Farman <farman@linux.vnet.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: stable@vger.kernel.org
Memory-mapped LVT0 register already contains the new value when APICv
traps so we can't directly detect a change.
Memorize a bit we are interested in to enable legacy NMI watchdog.
Suggested-by: Yoshida Nobuo <yoshida.nb@ncos.nec.co.jp>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Legacy NMI watchdog didn't work after migration/resume, because
vapics_in_nmi_mode was left at 0.
Writes were a bit racy, but hard to turn into a bug at the same time.
(Particularly because modern Linux doesn't use this feature anymore.)
[Actually the next patch makes it much, much easier to trigger the race
so I'm including this one for stable@ as well. - Paolo]
Commit 1cde2930e154 ("sched/preempt: Add static_key() to preempt_notifiers")
had two problems. First, the preempt-notifier API needs to sleep with the
addition of the static_key, we do however need to hold off preemption
while modifying the preempt notifier list, otherwise a preemption could
observe an inconsistent list state. KVM correctly registers and
unregisters preempt notifiers with preemption disabled, so the sleep
caused dmesg splats.
Second, KVM registers and unregisters preemption notifiers very often
(in vcpu_load/vcpu_put). With a single uniprocessor guest the static key
would move between 0 and 1 continuously, hitting the slow path on every
userspace exit.
To fix this, wrap the static_key inc/dec in a new API, and call it from
KVM.
Fixes: 1cde2930e154 ("sched/preempt: Add static_key() to preempt_notifiers")
Reported-by: Pontus Fuchs <pontus.fuchs@gmail.com>
Reported-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Takashi Iwai <tiwai@suse.de>
Commit 86dca36e6ba introduced ratelimited usage for
'unhandled_signal' messages.
The commit checks the ratelimit irrespective of whether
the signal is handled or not, which is wrong and leads
to false reports like the below in dmesg :
__do_user_fault: 127 callbacks suppressed
Do the ratelimit check only if the signal is unhandled.
Fixes: 86dca36e6ba0 ("arm64: use private ratelimit state along with show_unhandled_signals")
Cc: Vladimir Murzin <Vladimir.Murzin@arm.com>
Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com>
Use kernel.h macro definition.
Thanks to Julia Lawall for Coccinelle scripting support.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Add an item to the checklist when submitting a new hwmon driver: only
some I2C addresses can be probed, others should not for safety
reasons.
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Add pwm[4-7] and the associated pwm[4-7]_mode attributes.
Signed-off-by: Roger Lucas <vt8231@hiddenengine.co.uk>
It is normal that firmware presents GICC entry or entries (processors)
with disabled flag in ACPI MADT, taking a system of 16 cpus for example,
ACPI firmware may present 8 ebabled first with another 8 cpus disabled
in MADT, the disabled cpus can be hot-added later.
Firmware may also present more cpus than the hardware actually has, but
disabled the unused ones, and easily enable it when the hardware has such
cpus to make the firmware code scalable.
So that's not an error for disabled cpus in MADT, we can switch pr_err()
to pr_debug() to make the boot a little quieter by default.
Since hwid for disabled cpus often are invalid, and we check invalid hwid
first in the code, for use case that hot add cpus later will be filtered
out and will not be counted in possible cups, so move this check before
the hwid one to prepare the code to count for disabeld cpus when cpu
hot-plug is introduced.
Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org>
Reviewed-by: Al Stone <ahs3@redhat.com>
Pull ACPICA updates from Rafael Wysocki:
"Additional ACPICA material for v4.2-rc1
This will update the ACPICA code in the kernel to upstream revision
20150619 (a bug-fix release mostly including stable-candidate fixes)
and restore an earlier ACPICA commit that had to be reverted due to a
regression introduced by it (the regression is addressed by
blacklisting the only known system affected by it to date).
The only new feature added by this update is the support for
overriding objects in the ACPI namespace and a new ACPI table that can
be used for that called the Override System Definition Table (OSDT).
That should allow us to "patch" the ACPI namespace built from
incomplete or incorrect ACPI System Definition tables (DSDT, SSDT)
during system startup without the need to provide replacements for all
of those tables in the future.
Specifics:
- Fix system resume problems related to 32-bit and 64-bit versions of
the Firmware ACPI Control Structure (FACS) in the firmare (Lv
Zheng)
- Fix double initialization of the FACS (Lv Zheng)
- Add _CLS object processing code to ACPICA (Suravee Suthikulpanit)
- Add support for the (currently missing) new GIC version field in
the Multiple APIC Description Table (MADT) (Hanjun Guo)
- Add support for overriding objects in the ACPI namespace to ACPICA
and OSDT support (Lv Zheng, Bob Moore, Zhang Rui)
- Updates related to the TCPA and TPM2 ACPI tables (Bob Moore)
- Restore the commit modifying _REV to always return "2" (as required
by ACPI 6) and add a blacklisting mechanism for systems that may be
affected by that change (Rafael J Wysocki)
- Assorted fixes and cleanups (Bob Moore, Lv Zheng, Sascha Wildner)"
* tag 'acpica-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (28 commits)
Revert 'Revert "ACPICA: Permanently set _REV to the value '2'."'
ACPI / init: Make it possible to override _REV
ACPICA: Update version to 20150619
ACPICA: Comment update, no functional change
ACPICA: Update TPM2 ACPI table
ACPICA: Update definitions for the TCPA and TPM2 ACPI tables
ACPICA: Split C library prototypes to new header
ACPICA: De-macroize calls to standard C library functions
ACPI / acpidump: Update acpidump manual
ACPICA: acpidump: Convert the default behavior to dump from /sys/firmware/acpi/tables
ACPICA: acpidump: Allow customized tables to be dumped without accessing /dev/mem
ACPICA: Cleanup output for the ASL Debug object
ACPICA: Update for acpi_install_table memory types
ACPICA: Namespace: Change namespace override to avoid node deletion
ACPICA: Namespace: Add support of OSDT table
ACPICA: Namespace: Add support to allow overriding objects
ACPICA: ACPI 6.0: Add values for MADT GIC version field
ACPICA: Utilities: Add _CLS processing
ACPICA: Add dragon_fly support to unix file mapping file
ACPICA: EFI: Add EFI interface definitions to eliminate dependency of GNU EFI
It's a bug in our Makefile rules, make it show what the changing
certificate list was, and make it a warning so that people actually see
it.
Revert commit ff284f37fc0e (Revert "ACPICA: Permanently set _REV to
the value '2'.) as the regression introduced by commit b1ef29725865
reverted by it is now addressed via a blacklist entry.
The platform firmware on some systems expects Linux to return "5" as
the supported ACPI revision which makes it expose system configuration
information in a special way.
For example, based on what ACPI exports as the supported revision,
Dell XPS 13 (2015) configures its audio device to either work in HDA
mode or in I2S mode, where the former is supposed to be used on Linux
until the latter is fully supported (in the kernel as well as in user
space).
Since ACPI 6 mandates that _REV should return "2" if ACPI 2 or later
is supported by the OS, a subsequent change will make that happen, so
make it possible to override that on systems where "5" is expected to
be returned for Linux to work correctly one them (such as the Dell
machine mentioned above).
Original-by: Dominik Brodowski <linux@dominikbrodowski.net>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild updates from Michal Marek:
"Just a few kbuild core commits this time:
- kallsyms fix for CONFIG_XIP_KERNEL
- bashisms in scripts/link-vmlinux.sh fixed
- workaround to make DEBUG_INFO_REDUCED more useful yet still space
efficient
- clang is not wrongly detected when cross-compiling"
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kbuild: include core debug info when DEBUG_INFO_REDUCED
scripts: link-vmlinux: Don't pass page offset to kallsyms if XIP Kernel
scripts: fix link-vmlinux.sh bash-ism
Makefile: Fix detection of clang when cross-compiling
Pull kconfig updates from Michal Marek:
- kconfig conditions can use usual less/greater than comparisons
- kconfig warns about stray characters in Kconfig files
- bogus expression simplification removed
- some minor fixes
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kconfig: re-generate *.c_shipped files after previous change
kconfig: allow use of relations other than (in)equality
kconfig: don't silently ignore unhandled characters
kconfig: Wrap long "make help" text lines
scripts/kconfig/Makefile: Cosmetic fixes
scripts/kconfig/Makefile: Fix spelling of Qt
Kconfig: Remove bad inference rules expr_eliminate_dups2()
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon fixes from Guenter Roeck:
"Two patches headed for stable:
- Fix broken output scaling in mcp3021 driver
- Fix attribute visibility in nct7802 driver
One regression:
- Fix name attribute in dell-smm-hwmon driver"
* tag 'hwmon-for-linus-v4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
hwmon: (mcp3021) Fix broken output scaling
hwmon: (nct7802) fix visibility of temp3
hwmon: (dell-smm-hwmon) Use a valid name attribute
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux
Pull ia64 boot noise reduction fix from Tony Luck:
"Remove some boot noise from a now-invalid check that pages are
reserved"
* tag 'please-pull-put_kernel_page' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux:
[IA64] Drop debug test/printk that some special pages are marked reserved
Pull ARM SoC late fixes and dependencies from Kevin Hilman:
"This is a collection of a few late fixes and other misc stuff that had
dependencies on things being merged from other trees.
Other than the fixes, the primary feature being added is the
conversion of some OMAP drivers to the new generic wakeirq interface"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: multi_v7_defconfig: Enable BRCMNAND driver
ARM: BCM: Do not select CONFIG_MTD_NAND_BRCMNAND
ARM: at91/dt: update udc compatible strings
ARM: at91/dt: trivial: fix USB udc compatible string
arm64: dts: Add APM X-Gene standby GPIO controller DTS entries
soc: qcom: spm: Fix idle on THUMB2 kernels
ARM: dove: fix legacy dove IRQ numbers
ARM: mvebu: fix suspend to RAM on big-endian configurations
ARM: mvebu: adjust Armada XP DT spi muxing after pinctrl function rename
serial: 8250_omap: Move wake-up interrupt to generic wakeirq
serial: omap: Switch wake-up interrupt to generic wakeirq
mmc: omap_hsmmc: Change wake-up interrupt to use generic wakeirq
Pull radeon and amdgpu fixes from Alex Deucher:
"First round of fixes for 4.2 for radeon and amdgpu. Stuff all over
the place:
- hibernation, suspend fixes for radeon and amdgpu
- radeon audio fix
- amdgpu ioctl optimzations and fixes
- amdgpu VCE cs checker improvements
- misc bug fixes"
[ Dave on vacation, pulling directly ]
* 'drm-next-4.2' of git://people.freedesktop.org/~agd5f/linux: (30 commits)
drm/radeon: only check the sink type on DP connectors
drm/amdgpu: add flag to delay VM updates
drm/amdgpu: add optional dependencies to the CS IOCTL v2
drm/amdgpu: recreate fence from user seq
gpu/drm/amdgpu: Fix build when CONFIG_DEBUG_FS is not set
Revert "drm/radeon: dont switch vt on suspend"
drm/amdgpu: disable enable_nb_ps_policy temporarily
drm/amdgpu: correct define SMU_EnabledFeatureScoreboard_SclkDpmOn
drm/amdgpu: allocate ip_block_enabled memory in common code
drm/amdgpu: remove unnecessary check before kfree
drm/amdgpu: use kzalloc for allocating one thing
drm/radeon: fix adding all VAs to the freed list on remove v2
drm/amdgpu: add chunk id validity check
drm/amdgpu: fix crash on invalid CS IOCTL
drm/amdgpu: reset wptr at cp compute resume (v2)
drm/amdgpu: check VCE feedback and bitstream index
drm/amdgpu: make VCE handle check more strict
drm/amdgpu: check VCE relocation buffer range
drm/amdgpu: silence invalid error message
drm/amdgpu: fix wrong type
git://anongit.freedesktop.org/drm-intel
Pull intel drm fixes from Jani Nikula:
"Almost all of it is regression fixes all around, with cc: stable, and
then there's Ander's fix for one of the warnings you reported. We're
still working on the rest"
[ Dave is on vacation, and Jani is heading out on vacation too ]
* tag 'drm-intel-next-fixes-2015-07-02' of git://anongit.freedesktop.org/drm-intel:
drm/i915: Clear pipe's pll hw state in hsw_dp_set_ddi_pll_sel()
drm/i915: fix backlight after resume on 855gm
agp/intel: Fix typo in needs_ilk_vtd_wa()
drm/i915/ppgtt: Break loop in gen8_ppgtt_clear_range failure path
drm/i915: Fix IPS related flicker
In commit 92923ca3aace "mm: meminit: only set page reserved in the memblock region"
we dropped setting the reserved bits for all pages. This results in some warnings
on ia64:
put_kernel_page: page at 0xe000000005588000 not in reserved memory
put_kernel_page: page at 0xe000000005580000 not in reserved memory
the two different pages match up with two objects from the loaded kernel
that get mapped by arch/ia64/mm/init.c:setup_gate()
a000000101588000 D __start_gate_section
a000000101580000 D empty_zero_page
In a discussion with Mel Gorman:
http://lkml.kernel.org/r/20150526102219.GB13750%40suse.de
he suggested that while the preferred approach might be to
set the reserved bit for these pages, it would also be OK
to just drop the test:
"as it's a debugging check that is ia-64 specific"
After hunting around a bit and failin to find a good place to mark these
pages as reserved - I decided to just delete the test.
Signed-off-by: Tony Luck <tony.luck@intel.com>
At the moment the IRQCHIP_DECLARE macro is only declared locally in
drivers/irqchip/irqchip.h. It prevents from using it directly in arch/*
directories whenever irqchip drivers only exist there, which happens in a few
cases (e.g. arc, arm, microblaze and mips).
This patch makes the macro to be globally defined, i.e. in
include/linux/irqchip.h, and thus usable for arch-specific declarations of
irqchip drivers. In this way, it is very similar to what clocksource does (ie
CLOCKSOURCE_OF_DECLARE is defined in include/linux/clocksource.h).
For now, this patch only moves the declaration of the macro
IRQCHIP_DECLARE to the global header 'include/linux/irqchip.h' and make
'drivers/irqchip/irqchip.h' include 'include/linux/irqchip.h'. Later, other
patches will get rid of 'drivers/irqchip/irqchip.h' and modify all the impacted
irqchip drivers.
Signed-off-by: Joel Porquet <joel@porquet.org>
Cc: Jason Cooper <jason@lakedaemon.net>
Link: http://lkml.kernel.org/r/1435865565-14114-1-git-send-email-joel@porquet.org
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull Ceph updates from Sage Weil:
"We have a pile of bug fixes from Ilya, including a few patches that
sync up the CRUSH code with the latest from userspace.
There is also a long series from Zheng that fixes various issues with
snapshots, inline data, and directory fsync, some simplification and
improvement in the cap release code, and a rework of the caching of
directory contents.
To top it off there are a few small fixes and cleanups from Benoit and
Hong"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (40 commits)
rbd: use GFP_NOIO in rbd_obj_request_create()
crush: fix a bug in tree bucket decode
libceph: Fix ceph_tcp_sendpage()'s more boolean usage
libceph: Remove spurious kunmap() of the zero page
rbd: queue_depth map option
rbd: store rbd_options in rbd_device
rbd: terminate rbd_opts_tokens with Opt_err
ceph: fix ceph_writepages_start()
rbd: bump queue_max_segments
ceph: rework dcache readdir
crush: sync up with userspace
crush: fix crash from invalid 'take' argument
ceph: switch some GFP_NOFS memory allocation to GFP_KERNEL
ceph: pre-allocate data structure that tracks caps flushing
ceph: re-send flushing caps (which are revoked) in reconnect stage
ceph: send TID of the oldest pending caps flush to MDS
ceph: track pending caps flushing globally
ceph: track pending caps flushing accurately
libceph: fix wrong name "Ceph filesystem for Linux"
ceph: fix directory fsync
Pull NFS client updates from Trond Myklebust:
"Highlights include:
Stable patches:
- Fix a crash in the NFSv4 file locking code.
- Fix an fsync() regression, where we were failing to retry I/O in
some circumstances.
- Fix an infinite loop in NFSv4.0 OPEN stateid recovery
- Fix a memory leak when an attempted pnfs fails.
- Fix a memory leak in the backchannel code
- Large hostnames were not supported correctly in NFSv4.1
- Fix a pNFS/flexfiles bug that was impeding error reporting on I/O.
- Fix a couple of credential issues in pNFS/flexfiles
Bugfixes + cleanups:
- Open flag sanity checks in the NFSv4 atomic open codepath
- More NFSv4 delegation related bugfixes
- Various NFSv4.1 backchannel bugfixes and cleanups
- Fix the NFS swap socket code
- Various cleanups of the NFSv4 SETCLIENTID and EXCHANGE_ID code
- Fix a UDP transport deadlock issue
Features:
- More RDMA client transport improvements
- NFSv4.2 LAYOUTSTATS functionality for pnfs flexfiles"
* tag 'nfs-for-4.2-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (87 commits)
nfs: Remove invalid tk_pid from debug message
nfs: Remove invalid NFS_ATTR_FATTR_V4_REFERRAL checking in nfs4_get_rootfh
nfs: Drop bad comment in nfs41_walk_client_list()
nfs: Remove unneeded micro checking of CONFIG_PROC_FS
nfs: Don't setting FILE_CREATED flags always
nfs: Use remove_proc_subtree() instead remove_proc_entry()
nfs: Remove unused argument in nfs_server_set_fsinfo()
nfs: Fix a memory leak when meeting an unsupported state protect
nfs: take extra reference to fl->fl_file when running a LOCKU operation
NFSv4: When returning a delegation, don't reclaim an incompatible open mode.
NFSv4.2: LAYOUTSTATS is optional to implement
NFSv4.2: Fix up a decoding error in layoutstats
pNFS/flexfiles: Fix the reset of struct pgio_header when resending
pNFS/flexfiles: Turn off layoutcommit for servers that don't need it
pnfs/flexfiles: protect ktime manipulation with mirror lock
nfs: provide pnfs_report_layoutstat when NFS42 is disabled
nfs: verify open flags before allowing open
nfs: always update creds in mirror, even when we have an already connected ds
nfs: fix potential credential leak in ff_layout_update_mirror_cred
pnfs/flexfiles: report layoutstat regularly
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull overlayfs updates from Miklos Szeredi:
"This relaxes the requirements on the lower layer filesystem: now ones
that implement .d_revalidate, such as NFS, can be used.
Upper layer filesystems still has the "no .d_revalidate" requirement.
Also a bad interaction with jffs2 locking has been fixed"
* 'overlayfs-next' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs:
ovl: lookup whiteouts outside iterate_dir()
ovl: allow distributed fs as lower layer
ovl: don't traverse automount points
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
Pull fuse updates from Miklos Szeredi:
"This is the start of improving fuse scalability.
An input queue and a processing queue is split out from the monolithic
fuse connection, each of those having their own spinlock. The end of
the patchset adds the ability to clone a fuse connection. This means,
that instead of having to read/write requests/answers on a single fuse
device fd, the fuse daemon can have multiple distinct file descriptors
open. Each of those can be used to receive requests and send answers,
currently the only constraint is that a request must be answered on
the same fd as it was read from.
This can be extended further to allow binding a device clone to a
specific CPU or NUMA node.
Based on a patchset by Srinivas Eeda and Ashish Samant. Thanks to
Ashish for the review of this series"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: (40 commits)
fuse: update MAINTAINERS entry
fuse: separate pqueue for clones
fuse: introduce per-instance fuse_dev structure
fuse: device fd clone
fuse: abort: no fc->lock needed for request ending
fuse: no fc->lock for pqueue parts
fuse: no fc->lock in request_end()
fuse: cleanup request_end()
fuse: request_end(): do once
fuse: add req flag for private list
fuse: pqueue locking
fuse: abort: group pqueue accesses
fuse: cleanup fuse_dev_do_read()
fuse: move list_del_init() from request_end() into callers
fuse: duplicate ->connected in pqueue
fuse: separate out processing queue
fuse: simplify request_wait()
fuse: no fc->lock for iqueue parts
fuse: allow interrupt queuing without fc->lock
fuse: iqueue locking
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull init.h/module.h fragility fixes from Paul Gortmaker:
"Fixup various init.h misuses that are fragile wrt code moving to
module.h
What started as a removal of no longer required include <linux/init.h>
due to the earlier __cpuinit and __devinit removal led to the
observation that some module specfic support was living in init.h
itself, thus preventing the full removal from introducing compile
regressions.
This series includes a few final fixups needed prior to the relocation
of the modular init code from <init.h> to <module.h>. These are
things that weren't easily categorized into any of the other previous
series categories already requested for pull.
That said, each fixup branch (including this one) is independent and
there are no ordering constraints. Only the final code relocation
(which is NOT in this pull) requires that all my cleanup branches be
merged first"
* tag 'module-misc-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
tile: add init.h to usb.c to avoid compile failure
arm: fix implicit #include <linux/init.h> in entry asm.
x86: replace __init_or_module with __init in non-modular vsmp_64.c
Pull module_platform_driver replacement from Paul Gortmaker:
"Replace module_platform_driver with builtin_platform driver in non
modules.
We see an increasing number of non-modular drivers using
modular_driver() type register functions. There are several downsides
to letting this continue unchecked:
- The code can appear modular to a reader of the code, and they won't
know if the code really is modular without checking the Makefile
and Kconfig to see if compilation is governed by a bool or
tristate.
- Coders of drivers may be tempted to code up an __exit function that
is never used, just in order to satisfy the required three args of
the modular registration function.
- Non-modular code ends up including the <module.h> which increases
CPP overhead that they don't need.
- It hinders us from performing better separation of the module init
code and the generic init code.
So here we introduce similar macros for builtin drivers. Then we
convert builtin drivers (controlled by a bool Kconfig) by making the
following type of mapping:
module_platform_driver() ---> builtin_platform_driver()
module_platform_driver_probe() ---> builtin_platform_driver_probe().
The set of drivers that are converted here are just the ones that
showed up as relying on an implicit include of <module.h> during a
pending header cleanup. So we convert them here vs adding an include
of <module.h> to non-modular code to avoid compile fails. Additonal
conversions can be done asynchronously at any time.
Once again, an unused module_exit function that is removed here
appears in the diffstat as an outlier wrt all the other changes"
* tag 'module-builtin_driver-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
drivers/clk: convert sunxi/clk-mod0.c to use builtin_platform_driver
drivers/power: Convert non-modular syscon-reboot to use builtin_platform_driver
drivers/soc: Convert non-modular soc-realview to use builtin_platform_driver
drivers/soc: Convert non-modular tegra/pmc to use builtin_platform_driver
drivers/cpufreq: Convert non-modular s5pv210-cpufreq.c to use builtin_platform_driver
drivers/cpuidle: Convert non-modular drivers to use builtin_platform_driver
drivers/platform: Convert non-modular pdev_bus to use builtin_platform_driver
platform_device: better support builtin boilerplate avoidance
Pull module_init replacement part two from Paul Gortmaker:
"Replace module_init with appropriate alternate initcall in non
modules.
This series converts non-modular code that is using the module_init()
call to hook itself into the system to instead use one of our
alternate priority initcalls.
Unlike the previous series that used device_initcall and hence was a
runtime no-op, these commits change to one of the alternate initcalls,
because (a) we have them and (b) it seems like the right thing to do.
For example, it would seem logical to use arch_initcall for arch
specific setup code and fs_initcall for filesystem setup code.
This does mean however, that changes in the init ordering will be
taking place, and so there is a small risk that some kind of implicit
init ordering issue may lie uncovered. But I think it is still better
to give these ones sensible priorities than to just assign them all to
device_initcall in order to exactly preserve the old ordering.
Thad said, we have already made similar changes in core kernel code in
commit c96d6660dc65 ("kernel: audit/fix non-modular users of
module_init in core code") without any regressions reported, so this
type of change isn't without precedent. It has also got the same
local testing and linux-next coverage as all the other pull requests
that I'm sending for this merge window have got.
Once again, there is an unused module_exit function removal that shows
up as an outlier upon casual inspection of the diffstat"
* tag 'module_init-alternate_initcall-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
x86: perf_event_intel_pt.c: use arch_initcall to hook in enabling
x86: perf_event_intel_bts.c: use arch_initcall to hook in enabling
mm/page_owner.c: use late_initcall to hook in enabling
lib/list_sort: use late_initcall to hook in self tests
arm: use subsys_initcall in non-modular pl320 IPC code
powerpc: don't use module_init for non-modular core hugetlb code
powerpc: use subsys_initcall for Freescale Local Bus
x86: don't use module_init for non-modular core bootflag code
netfilter: don't use module_init/exit in core IPV4 code
fs/notify: don't use module_init for non-modular inotify_user code
mm: replace module_init usages with subsys_initcall in nommu.c
Pull module_init replacement part one from Paul Gortmaker:
"Replace module_init with equivalent device_initcall in non modules.
This series of commits converts non-modular code that is using the
module_init() call to hook itself into the system to instead use
device_initcall().
The conversion is a runtime no-op, since module_init actually becomes
__initcall in the non-modular case, and that in turn gets mapped onto
device_initcall. A couple files show a larger negative diffstat,
representing ones that had a module_exit function that we remove here
vs previously relying on the linker to dispose of it.
We make this conversion now, so that we can relocate module_init from
init.h into module.h in the future.
The files changed here are just limited to those that would otherwise
have to add module.h to obviously non-modular code, in order to avoid
a compile fail, as testing has shown"
* tag 'module_init-device_initcall-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
MIPS: don't use module_init in non-modular cobalt/mtd.c file
drivers/leds: don't use module_init in non-modular leds-cobalt-raq.c
cris: don't use module_init for non-modular core eeprom.c code
tty/metag_da: Avoid module_init/module_exit in non-modular code
drivers/clk: don't use module_init in clk-nomadik.c which is non-modular
xtensa: don't use module_init for non-modular core network.c code
sh: don't use module_init in non-modular psw.c code
mn10300: don't use module_init in non-modular flash.c code
parisc64: don't use module_init for non-modular core perf code
parisc: don't use module_init for non-modular core pdc_cons code
cris: don't use module_init for non-modular core intmem.c code
ia64: don't use module_init in non-modular sim/simscsi.c code
ia64: don't use module_init for non-modular core kernel/mca.c code
arm: don't use module_init in non-modular mach-vexpress/spc.c code
powerpc: don't use module_init in non-modular 83xx suspend code
powerpc: use device_initcall for registering rtc devices
x86: don't use module_init in non-modular devicetree.c code
x86: don't use module_init in non-modular intel_mid_vrtc.c
Pull implicit module.h fixes from Paul Gortmaker:
"Fix up implicit <module.h> users that will break later.
The files changed here are simply modular source files that are
implicitly relying on <module.h> being present. We fix them up now,
so that we can decouple some of the module related init code from the
core init code in the future.
The addition of the module.h include to several files here is also a
no-op from a code generation point of view, else there would already
be compile issues with these files today.
There may be lots more implicit includes of <module.h> in tree, but
these are the ones that extensive build test coverage has shown that
must be fixed in order to avoid build breakage fallout for the pending
module.h <---> init.h code relocation we desire to complete"
* tag 'module-implicit-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
frv: add module.h to mb93090-mb00/flash.c to avoid compile fail
drivers/cpufreq: include <module.h> for modular exynos-cpufreq.c code
drivers/staging: include <module.h> for modular android tegra_ion code
crypto/asymmetric_keys: pkcs7_key_type needs module.h
sh: mach-highlander/psw.c is tristate and should use module.h
drivers/regulator: include <module.h> for modular max77802 code
drivers/pcmcia: include <module.h> for modular xxs1500_ss code
drivers/hsi: include <module.h> for modular omap_ssi code
drivers/gpu: include <module.h> for modular rockchip code
drivers/gpio: include <module.h> for modular crystalcove code
drivers/clk: include <module.h> for clk-max77xxx modular code
Pull __cpuinit removal from Paul Gortmaker:
"Remove __cpuinit macros and users.
We removed the __cpuinit stuff in 3.11-rc1 with commit 22f0a2736774
("init.h: remove __cpuinit sections from the kernel") but we left some
no-op stubs as a courtesy to unmerged code.
Here we get rid of the stubs as well, since (as can be seen in these
changes) they are enabling use cases to sneak back in, primarily from
older BSP code that has been living out of tree for some time prior to
getting mainlined. So we get rid of these "new" users 1st and then
get rid of the stubs.
Obviously, getting rid of the stubs can't happen until all the users
are gone, so I had to keep this together as a series, even though some
of these commits since got picked up into maintainers trees as well.
The nature of this change is such that it should have zero impact on
the generated runtime.
This is one of several independent cleanup branches aimed at enabling
better organization in the init.h and module.h code. They have been
getting coverage in the linux-next tree for the last month, in
addition to my local testing, which also covers approximately a half
dozen or more architectures"
* tag 'cpuinit-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
init: delete the __cpuinit related stubs
kernel/cpu.c: remove new instance of __cpuinit that crept back in
sched/core: remove __cpuinit section tag that crept back in.
mips/mm/tlbex: remove new instance of __cpuinit that crept back in
mips/c-r4k: remove legacy __cpuinit section that crept in
mips/bcm77xx: remove legacy __cpuinit sections that crept in
mips/ath25: remove legacy __cpuinit section that crept in
arm/mach-hisi: remove legacy __CPUINIT section that crept in
arm/mach-rockchip: remove legacy __cpuinit section that crept in
arm/mach-mvebu: remove legacy __cpuinit sections that crept in
arm/mach-keystone: remove legacy __cpuinit sections that crept in
It is not needed after booting, this patch moves the arm_cpuidle_init()
function to the __init section.
Signed-off-by: Jisheng Zhang <jszhang@marvell.com>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Fixes an issue when queue_reuest_irq fails in nvme_setup_io_queues. This
patch initializes all vectors to -1 and resets the vector to -1 in the
case of a failure in queue_request_irq. This avoids the free_irq in
nvme_suspend_queue if the queue did not get an irq.
Signed-off-by: Jon Derrick <jonathan.derrick@intel.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
52ebea749aae ("writeback: make backing_dev_info host cgroup-specific
bdi_writebacks") made bdi (backing_dev_info) host per-cgroup wb's
(bdi_writeback's). As the congested state needs to be per-wb and
referenced from blkcg side and multiple wbs, the patch made all
non-root cong's (bdi_writeback_congested's) reference counted and
indexed on bdi.
When a bdi is destroyed, cgwb_bdi_destroy() tries to drain all
non-root cong's; however, this can hang indefinitely because wb's can
also be referenced from blkcg_gq's which are destroyed after bdi
destruction is complete.
This patch fixes the bug by updating bdi destruction to not wait for
cong's to drain. A cong is unlinked from bdi->cgwb_congested_tree on
bdi destuction regardless of its reference count as the bdi may go
away any point after destruction. wb_congested_put() checks whether
the cong is already unlinked on release.
Reported-by: Jon Christopherson <jon@jons.org>
Link: https://bugzilla.kernel.org/show_bug.cgi?id=100681
Fixes: 52ebea749aae ("writeback: make backing_dev_info host cgroup-specific bdi_writebacks")
Tested-by: Jon Christopherson <jon@jons.org>
indexed on bdi.
To fix the bug, bdi destruction will be updated to not wait for cong's
to drain, which naturally means that cong's may outlive the associated
bdi. This is fine for non-root cong's but is problematic for the root
cong's which are embedded in their bdi's as they may end up getting
dereferenced after the containing bdi's are freed.
This patch makes root cong's behave the same as non-root cong's. They
are no longer embedded in their bdi's but allocated separately during
bdi initialization, indexed and reference counted the same way.
* As cong handling is the same for all wb's, wb->congested
initialization is moved into wb_init().
* When !CONFIG_CGROUP_WRITEBACK, there was no indexing or refcnting.
bdi->wb_congested is now a pointer pointing to the root cong
allocated during bdi init and minimal refcnting operations are
implemented.
* The above makes root wb init paths diverge depending on
CONFIG_CGROUP_WRITEBACK. root wb init is moved to cgwb_bdi_init().
This patch in itself shouldn't cause any consequential behavior
differences but prepares for the actual fix.
Added <linux/slab.h> include to backing-dev.h for kfree() definition.
This patch only moves files to their new locations, before applying the
next two patches adding the NTB Abstraction layer. Splitting this patch
from the next is intended make distinct which code is changed only due
to moving the files, versus which are substantial code changes in adding
Signed-off-by: Allen Hubbe <Allen.Hubbe@emc.com>
Signed-off-by: Jon Mason <jdmason@kudzu.us>
