commit c6cc25fda58da8685ecef3f179adc7b99c8253b2 upstream.
The adp5520 unfortunately also clears the BL_EN bit when the nSTNDBY bit is
cleared. So we need to make sure to restore it during resume if it was set
before suspend.
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
commit 7ee2b9e56495c56dcaffa2bab19b39451d9fdc8a upstream.
commit bdbc5d0c60f3e9de3eeccf1c1a18bdc11dca62cc upstream.
The driver is doing, by default, multi-block reads. When a block error
occurs, card/block.c instigates a single block read: "mmcblk0: retrying
using single block read". It leaves the sg chain intact and just changes
the length attribute for the first sg entry and the overall sg_len
parameter. When atmci_read_data_pio is called to read the single block
of data it ignores the sg_len and expects to read more than 512 bytes as
it sees there are multiple items in the sg list. No more data comes as
the controller has only been commanded to get one block.
Signed-off-by: Terry Barnaby <terry@beam.ltd.uk>
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
commit 836dc2fe89c968c10cada87e0dfae6626f8f9da3 upstream.
PARTITION_SUPPORT needs to be set before doing the compare on version
number so the bit width test does not get invalid data. Before this
patch, a Sandisk iNAND eMMC card would detect 1-bit width although
the hardware supports 4-bit.
Only affects old emmc devices - pre 4.4 devices.
Reported-by: Elad Yi <elad.yi@gmail.com>
Signed-off-by: Philip Rakity <prakity@yahoo.com>
commit f7b0e1055574ce06ab53391263b4e205bf38daf3 upstream.
With the current implementation, kstat_cpu(cpu).irqs_sum is also
increased in case of irq_mis_count increment.
So there is no need to count irq_mis_count in arch_irq_stat,
otherwise irq_mis_count will be counted twice in the sum of
/proc/stat.
Reported-by: Liu Chuansheng <chuansheng.liu@intel.com>
Signed-off-by: Li Fei <fei.li@intel.com>
Acked-by: Liu Chuansheng <chuansheng.liu@intel.com>
Cc: tomoki.sekiyama.qu@hitachi.com
Cc: joe@perches.com
Link: http://lkml.kernel.org/r/1366980611.32469.7.camel@fli24-HP-Compaq-8100-Elite-CMT-PC
commit 660696d1d16a71e15549ce1bf74953be1592bcd3 upstream.
Source operand for one byte mov[zs]x is decoded incorrectly if it is in
high byte register. Fix that.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
commit 9e6879460c8edb0cd3c24c09b83d06541b5af0dc upstream.
Give the OID registry file module information so that it doesn't taint the
kernel when compiled as a module and loaded.
Reported-by: Dros Adamson <Weston.Adamson@netapp.com>
cc: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 91cf54feecf815bec0b6a8d6d9dbd0e219f2f2cc upstream.
Fix regression introduced by commit 796211b7953 ("mmc: atmel-mci: add
pdc support and runtime capabilities detection") which removed the need
for CONFIG_MMC_ATMELMCI_DMA but kept the Kconfig-entry as well as the
compile guards around dma_release_channel() in remove(). Consequently,
DMA is always enabled (if supported), but the DMA-channel is not
released on module unload unless the DMA-config option is selected.
Remove the no longer used CONFIG_MMC_ATMELMCI_DMA option completely.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
checks")
commit 0d5cadb87e0fa764db7fa0b78d8a6f173cb475a1 upstream.
Bisected-by: Michael Leun <lkml20130126@newton.leun.net>
commit 7f3e3c7cfcec148ccca9c0dd2dbfd7b00b7ac10f upstream.
Fox the Kconfig documentation for CONFIG_EXT4_DEBUG to match the
change made by commit a0b30c1229: ext4: use module parameters instead
of debugfs for mballoc_debug
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit c5c72d814cf0f650010337c73638b25e6d14d2d4 upstream.
Commit fb0a387dcdc restricts block allocations for indirect-mapped
files to block groups less than s_blockfile_groups. However, the
online resizing code wasn't setting s_blockfile_groups, so the newly
added block groups were not available for non-extent mapped files.
Reported-by: Eric Sandeen <sandeen@redhat.com>
commit 171a7f21a76a0958c225b97c00a97a10390d40ee upstream.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
commit a75ae78f087f933ab3432e98bb4dbbf2196cf6d5 upstream.
Otherwise destroyed ext_sb_info will be part of global shinker list
and result in the following OOPS:
JBD2: corrupted journal superblock
JBD2: recovery failed
EXT4-fs (dm-2): error loading journal
general protection fault: 0000 [#1] SMP
Modules linked in: fuse acpi_cpufreq freq_table mperf coretemp kvm_intel kvm crc32c_intel microcode sg button sd_mod crc_t10dif ahci libahci pata_acpi ata_generic dm_mirror dm_region_hash dm_log dm_\
mod
CPU 1
Pid: 2758, comm: mount Not tainted 3.8.0-rc3+ #136 /DH55TC
RIP: 0010:[<ffffffff811bfb2d>] [<ffffffff811bfb2d>] unregister_shrinker+0xad/0xe0
RSP: 0000:ffff88011d5cbcd8 EFLAGS: 00010207
RAX: 6b6b6b6b6b6b6b6b RBX: 6b6b6b6b6b6b6b53 RCX: 0000000000000006
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000246
RBP: ffff88011d5cbce8 R08: 0000000000000002 R09: 0000000000000001
R10: 0000000000000001 R11: 0000000000000000 R12: ffff88011cd3f848
R13: ffff88011cd3f830 R14: ffff88011cd3f000 R15: 0000000000000000
FS: 00007f7b721dd7e0(0000) GS:ffff880121a00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00007fffa6f75038 CR3: 000000011bc1c000 CR4: 00000000000007e0
Process mount (pid: 2758, threadinfo ffff88011d5ca000, task ffff880116aacb80)
Stack:
ffff88011cd3f000 ffffffff8209b6c0 ffff88011d5cbd18 ffffffff812482f1
00000000000003f3 00000000ffffffea ffff880115f4c200 0000000000000000
ffff88011d5cbda8 ffffffff81249381 ffff8801219d8bf8 ffffffff00000000
Call Trace:
[<ffffffff812482f1>] deactivate_locked_super+0x91/0xb0
[<ffffffff81249381>] mount_bdev+0x331/0x340
[<ffffffff81376730>] ? ext4_alloc_flex_bg_array+0x180/0x180
[<ffffffff81362035>] ext4_mount+0x15/0x20
[<ffffffff8124869a>] mount_fs+0x9a/0x2e0
[<ffffffff81277e25>] vfs_kern_mount+0xc5/0x170
[<ffffffff81279c02>] do_new_mount+0x172/0x2e0
[<ffffffff8127aa56>] do_mount+0x376/0x380
[<ffffffff8127ab98>] sys_mount+0x138/0x150
[<ffffffff818ffed9>] system_call_fastpath+0x16/0x1b
Code: 8b 05 88 04 eb 00 48 3d 90 ff 06 82 48 8d 58 e8 75 19 4c 89 e7 e8 e4 d7 2c 00 48 c7 c7 00 ff 06 82 e8 58 5f ef ff 5b 41 5c c9 c3 <48> 8b 4b 18 48 8b 73 20 48 89 da 31 c0 48 c7 c7 c5 a0 e4 81 e\
8
RIP [<ffffffff811bfb2d>] unregister_shrinker+0xad/0xe0
RSP <ffff88011d5cbcd8>
commit 5d3ee20855e28169d711b394857ee608a5023094 upstream.
It is incorrect to use list_for_each_entry_safe() for journal callback
traversial because ->next may be removed by other task:
->ext4_mb_free_metadata()
->ext4_journal_callback_del()
This results in the following issue:
WARNING: at lib/list_debug.c:62 __list_del_entry+0x1c0/0x250()
Hardware name:
list_del corruption. prev->next should be ffff88019a4ec198, but was 6b6b6b6b6b6b6b6b
Modules linked in: cpufreq_ondemand acpi_cpufreq freq_table mperf coretemp kvm_intel kvm crc32c_intel ghash_clmulni_intel microcode sg xhci_hcd button sd_mod crc_t10dif aesni_intel ablk_helper cryptd lrw aes_x86_64 xts gf128mul ahci libahci pata_acpi ata_generic dm_mirror dm_region_hash dm_log dm_mod
Pid: 16400, comm: jbd2/dm-1-8 Tainted: G W 3.8.0-rc3+ #107
Call Trace:
[<ffffffff8106fb0d>] warn_slowpath_common+0xad/0xf0
[<ffffffff8106fc06>] warn_slowpath_fmt+0x46/0x50
[<ffffffff813637e9>] ? ext4_journal_commit_callback+0x99/0xc0
[<ffffffff8148cae0>] __list_del_entry+0x1c0/0x250
[<ffffffff813637bf>] ext4_journal_commit_callback+0x6f/0xc0
[<ffffffff813ca336>] jbd2_journal_commit_transaction+0x23a6/0x2570
[<ffffffff8108aa42>] ? try_to_del_timer_sync+0x82/0xa0
[<ffffffff8108b491>] ? del_timer_sync+0x91/0x1e0
[<ffffffff813d3ecf>] kjournald2+0x19f/0x6a0
[<ffffffff810ad630>] ? wake_up_bit+0x40/0x40
[<ffffffff813d3d30>] ? bit_spin_lock+0x80/0x80
[<ffffffff810ac6be>] kthread+0x10e/0x120
[<ffffffff810ac5b0>] ? __init_kthread_worker+0x70/0x70
[<ffffffff818ff6ac>] ret_from_fork+0x7c/0xb0
This patch fix the issue as follows:
- ext4_journal_commit_callback() make list truly traversial safe
simply by always starting from list_head
- fix race between two ext4_journal_callback_del() and
ext4_journal_callback_try_del()
commit 794446c6946513c684d448205fbd76fa35f38b72 upstream.
The following race is possible:
[kjournald2] other_task
jbd2_journal_commit_transaction()
j_state = T_FINISHED;
spin_unlock(&journal->j_list_lock);
->jbd2_journal_remove_checkpoint()
->jbd2_journal_free_transaction();
->kmem_cache_free(transaction)
->j_commit_callback(journal, transaction);
-> USE_AFTER_FREE
Hardware name:
Call Trace:
In order to demonstrace this issue one should mount ext4 with mount -o
discard option on SSD disk. This makes callback longer and race
window becomes wider.
In order to fix this we should mark transaction as finished only after
callbacks have completed
commit d76a3a77113db020d9bb1e894822869410450bd9 upstream.
In the case where an inode has a very stale transaction id (tid) in
i_datasync_tid or i_sync_tid, it's possible that after a very large
(2**31) number of transactions, that the tid number space might wrap,
causing tid_geq()'s calculations to fail.
Commit deeeaf13 "jbd2: fix fsync() tid wraparound bug", later modified
by commit e7b04ac0 "jbd2: don't wake kjournald unnecessarily",
attempted to fix this problem, but it only avoided kjournald spinning
forever by fixing the logic in jbd2_log_start_commit().
Unfortunately, in the codepaths in fs/ext4/fsync.c and fs/ext4/inode.c
that might call jbd2_log_start_commit() with a stale tid, those
functions will subsequently call jbd2_log_wait_commit() with the same
stale tid, and then wait for a very long time. To fix this, we
replace the calls to jbd2_log_start_commit() and
jbd2_log_wait_commit() with a call to a new function,
jbd2_complete_transaction(), which will correctly handle stale tid's.
As a bonus, jbd2_complete_transaction() will avoid locking
j_state_lock for writing unless a commit needs to be started. This
should have a small (but probably not measurable) improvement for
ext4's scalability.
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Reported-by: George Barnett <gbarnett@atlassian.com>
commit 78d77df71510a96e042de7ba6dbd7998103642cb upstream.
During early init, we would incorrectly set the NX bit even if the NX
feature was not supported. Instead, only set this bit if NX is
actually available and enabled. We already do very early detection of
the NX bit to enable it in EFER, this simply extends this detection to
the early page table mask.
Reported-by: Fernando Luis Vázquez Cao <fernando@oss.ntt.co.jp>
Link: http://lkml.kernel.org/r/1367476850.5660.2.camel@nexus
commit 73e3dd6b45c4c870fc2641eb04c24e3f12dab1e0 upstream.
The PTP Hardware Clock settime function in the e1000e driver
computes nanoseconds from a struct timespec. The code converts the
seconds field .tv_sec by multiplying it with NSEC_PER_SEC. However,
both operands are of type long, resulting in an unintended overflow.
The patch fixes the issue by using the helper function from time.h.
Signed-off-by: Richard Cochran <richardcochran@gmail.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
commit d87d830720a1446403ed38bfc2da268be0d356d1 upstream.
Previously, the ixgbe_msix_other was writing the full 32bits of the set
interrupts, instead of only the ones which the ixgbe_msix_other is
handling. This resulted in a loss of performance when the X540's PPS feature is
enabled due to sometimes clearing queue interrupts which resulted in the driver
not getting the interrupt for cleaning the q_vector rings often enough. The fix
is to simply mask the lower 16bits off so that this handler does not write them
in the EICR, which causes them to remain high and be properly handled by the
clean_rings interrupt routine as normal.
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
Tested-by: Phil Schmitt <phillip.j.schmitt@intel.com>
commit d69f3bad4675ac519d41ca2b11e1c00ca115cecd upstream.
Trying to run an application which was trying to put data into half of
memory using shmget(), we found that having a shmall value below 8EiB-8TiB
would prevent us from using anything more than 8TiB. By setting
kernel.shmall greater than 8EiB-8TiB would make the job work.
In the newseg() function, ns->shm_tot which, at 8TiB is INT_MAX.
ipc/shm.c:
458 static int newseg(struct ipc_namespace *ns, struct ipc_params *params)
459 {
465 int numpages = (size + PAGE_SIZE -1) >> PAGE_SHIFT;
474 if (ns->shm_tot + numpages > ns->shm_ctlall)
475 return -ENOSPC;
[akpm@linux-foundation.org: make ipc/shm.c:newseg()'s numpages size_t, not int]
Signed-off-by: Robin Holt <holt@sgi.com>
Reported-by: Alex Thorlton <athorlton@sgi.com>
commit 990de49f74e772b6db5208457b7aa712a5f4db86 upstream.
When a full scan 2.4 and 5 GHz scan is scheduled, but then the 2.4 GHz
part of the scan disables a 5.2 GHz channel due to, e.g. receiving
country or frequency information, that 5.2 GHz channel might already
be in the list of channels to scan next. Then, when the driver checks
if it should do a passive scan, that will return false and attempt an
active scan. This is not only wrong but can also lead to the iwlwifi
device firmware crashing since it checks regulatory as well.
Fix this by not setting the channel flags to just disabled but rather
OR'ing in the disabled flag. That way, even if the race happens, the
channel will be scanned passively which is still (mostly) correct.
commit bf8d909705e9d9bac31d9b8eac6734d2b51332a7 upstream.
The seconds field of an nfstime4 structure is 64bit, but we are assuming
that the first 32bits are zero-filled. So if the client tries to set
atime to a value before the epoch (touch -t 196001010101), then the
server will save the wrong value on disk.
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 2c44a23471d048118e49b616d08df0729cdbd9f1 upstream.
memory allocated by kmem_cache_alloc() should be freed using
kmem_cache_free(), not kfree().
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
commit b022032e195ffca83d7002d6b84297d796ed443b upstream.
we should return error status directly when nfs4_preprocess_stateid_op
return error.
Signed-off-by: fanchaoting <fanchaoting@cn.fujitsu.com>
commit 0c7c3e67ab91ec6caa44bdf1fc89a48012ceb0c5 upstream.
Don't actually close any opens until we don't need them at all.
This means being left with write access when it's not really necessary,
but that's better than putting a file that might still have posix locks
held on it, as we have been.
Reported-by: Toralf Förster <toralf.foerster@gmx.de>
commit 8b6cc4d6f841d31f72fe7478453759166d366274 upstream.
A server shouldn't normally return NFS4ERR_GRACE if the client holds a
delegation, since no conflicting lock reclaims can be granted, however
the spec does not require the server to grant the open in this
instance
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit dbb21c25a35a71baf413f5176f028ee11b88cfbc upstream.
the spec does not require the server to grant the lock in this
instance.
commit 32f9f570d04461a41bdcd5c1d93b41ebc5ce182a upstream.
In SSD/hard disk hybid storage, discard request should be ignored for hard
disk. We used to be doing this way, but the unplug path forgets it.
This is suitable for stable tree since v3.6.
Reported-and-tested-by: Markus <M4rkusXXL@web.de>
Signed-off-by: Shaohua Li <shli@fusionio.com>
Signed-off-by: NeilBrown <neilb@suse.de>
commit 486adf72ccc0c235754923d47a2270c5dcb0c98b upstream.
Maintenance of a bad-block-list currently defaults to 'enabled'
and is then disabled when it cannot be supported.
This is backwards and causes problem for dm-raid which didn't know
to disable it.
So fix the defaults, and only enabled for v1.x metadata which
explicitly has bad blocks enabled.
The problem with dm-raid has been present since badblock support was
added in v3.1, so this patch is suitable for any -stable from 3.1
onwards.
Reported-by: Jonathan Brassow <jbrassow@redhat.com>
commit 1dfd89af8697a299e7982ae740d4695ecd917eef upstream.
After a server reboot, the reclaimer thread will recover all the existing
locks. For locks that are blocked, however, it will change the value
of block->b_status to nlm_lck_denied_grace_period in order to signal that
they need to wake up and resend the original blocking lock request.
Due to a bug, however, the block->b_status never gets reset after the
blocked locks have been woken up, and so the process goes into an
infinite loop of resends until the blocked lock is satisfied.
Reported-by: Marc Eshel <eshel@us.ibm.com>
commit e56fb2874015370e3b7f8d85051f6dce26051df9 upstream.
threadgroup_lock() takes signal->cred_guard_mutex to ensure that
thread_group_leader() is stable. This doesn't look nice, the scope of
this lock in do_execve() is huge.
And as Dave pointed out this can lead to deadlock, we have the
following dependencies:
do_execve: cred_guard_mutex -> i_mutex
cgroup_mount: i_mutex -> cgroup_mutex
attach_task_by_pid: cgroup_mutex -> cred_guard_mutex
Change de_thread() to take threadgroup_change_begin() around the
switch-the-leader code and change threadgroup_lock() to avoid
->cred_guard_mutex.
Note that de_thread() can't sleep with ->group_rwsem held, this can
obviously deadlock with the exiting leader if the writer is active, so it
does threadgroup_change_end() before schedule().
Reported-by: Dave Jones <davej@redhat.com>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Li Zefan <lizefan@huawei.com>
commit 421348f1ca0bf17769dee0aed4d991845ae0536d upstream.
Call cond_resched() in shrink_dcache_parent() to maintain interactivity.
Before this patch:
void shrink_dcache_parent(struct dentry * parent)
while ((found = select_parent(parent, &dispose)) != 0)
shrink_dentry_list(&dispose);
select_parent() populates the dispose list with dentries which
shrink_dentry_list() then deletes. select_parent() carefully uses
need_resched() to avoid doing too much work at once. But neither
shrink_dcache_parent() nor its called functions call cond_resched(). So
once need_resched() is set select_parent() will return single dentry
dispose list which is then deleted by shrink_dentry_list(). This is
inefficient when there are a lot of dentry to process. This can cause
softlockup and hurts interactivity on non preemptable kernels.
This change adds cond_resched() in shrink_dcache_parent(). The benefit
of this is that need_resched() is quickly cleared so that future calls
to select_parent() are able to efficiently return a big batch of dentry.
These additional cond_resched() do not seem to impact performance, at
least for the workload below.
Here is a program which can cause soft lockup if other system activity
sets need_resched().
int main()
struct rlimit rlim;
int i;
int f[100000];
char buf[20];
struct timeval t1, t2;
double diff;
/* cleanup past run */
system("rm -rf x");
/* boost nfile rlimit */
rlim.rlim_cur = 200000;
rlim.rlim_max = 200000;
if (setrlimit(RLIMIT_NOFILE, &rlim))
err(1, "setrlimit");
/* make directory for files */
if (mkdir("x", 0700))
err(1, "mkdir");
if (gettimeofday(&t1, NULL))
err(1, "gettimeofday");
/* populate directory with open files */
for (i = 0; i < 100000; i++) {
snprintf(buf, sizeof(buf), "x/%d", i);
f[i] = open(buf, O_CREAT);
if (f[i] == -1)
err(1, "open");
/* close some of the files */
for (i = 0; i < 85000; i++)
close(f[i]);
/* unlink all files, even open ones */
system("rm -rf x");
if (gettimeofday(&t2, NULL))
diff = (((double)t2.tv_sec * 1000000 + t2.tv_usec) -
((double)t1.tv_sec * 1000000 + t1.tv_usec));
printf("done: %g elapsed\n", diff/1e6);
return 0;
Signed-off-by: Greg Thelen <gthelen@google.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
commit 04df32fa10ab9a6f0643db2949d42efc966bc844 upstream.
When we run the crackerjack testsuite, the inotify_add_watch test is
stalled.
This is caused by the invalid mask 0 - the task is waiting for the event
but it never comes. inotify_add_watch() should return -EINVAL as it did
before commit 676a0675cf92 ("inotify: remove broken mask checks causing
unmount to be EINVAL"). That commit removes the invalid mask check, but
that check is needed.
Check the mask's ALL_INOTIFY_BITS before the inotify_arg_to_mask() call.
If none are set, just return -EINVAL.
Because IN_UNMOUNT is in ALL_INOTIFY_BITS, this change will not trigger
the problem that above commit fixed.
[akpm@linux-foundation.org: fix build]
Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com>
Acked-by: Jim Somerville <Jim.Somerville@windriver.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Jerome Marchand <jmarchan@redhat.com>
Cc: Eric Paris <eparis@parisplace.org>
commit 2cc1144a31f76d4a9fb48bec5d6ba1359f980813 upstream.
mkinitrd looks at /sys/class/scsi_host/host$hostnum/proc_name to find
the module name of a disk driver. Current name is "highbank-ahci" but
the module is "sata_highbank". Rename it to match the module name.
Signed-off-by: Robert Richter <robert.richter@calxeda.com>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Alexander Graf <agraf@suse.de>
commit 6f7a05d7018de222e40ca003721037a530979974 upstream.
Vitaliy reported that a per cpu HPET timer interrupt crashes the
system during hibernation. What happens is that the per cpu HPET timer
gets shut down when the nonboot cpus are stopped. When the nonboot
cpus are onlined again the HPET code sets up the MSI interrupt which
fires before the clock event device is registered. The event handler
is still set to hrtimer_interrupt, which then crashes the machine due
to highres mode not being active.
See http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=700333
There is no real good way to avoid that in the HPET code. The HPET
code alrady has a mechanism to detect spurious interrupts when event
handler == NULL for a similar reason.
We can handle that in the clockevent/tick layer and replace the
previous functional handler with a dummy handler like we do in
tick_setup_new_device().
The original clockevents code did this in clockevents_exchange_device(),
but that got removed by commit 7c1e76897 (clockevents: prevent
clockevent event_handler ending up handler_noop) which forgot to fix
it up in tick_shutdown(). Same issue with the broadcast device.
Reported-by: Vitaliy Fillipov <vitalif@yourcmc.ru>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: 700333@bugs.debian.org
commit ced9cb1af1e3486cc14dca755a1b3fbadf06e90b upstream.
A bug was reported that caused localmodconfig to not keep all the
dependencies of ATH9K. This was caused by the kconfig file:
In drivers/net/wireless/ath/Kconfig:
commit 712317ad97f41e738e1a19aa0a6392a78a84094e upstream.
We should store file xattrs in struct cfent instead of struct cftype,
because cftype is a type while cfent is object instance of cftype.
For example each cgroup has a tasks file, and each tasks file is
associated with a uniq cfent, but all those files share the same
struct cftype.
Alexey Kodanev reported a crash, which can be reproduced:
# mount -t cgroup -o xattr /sys/fs/cgroup
# mkdir /sys/fs/cgroup/test
# setfattr -n trusted.value -v test_value /sys/fs/cgroup/tasks
# rmdir /sys/fs/cgroup/test
# umount /sys/fs/cgroup
oops!
In this case, simple_xattrs_free() will free the same struct simple_xattrs
twice.
tj: Dropped unused local variable @cft from cgroup_diput().
Reported-by: Alexey Kodanev <alexey.kodanev@oracle.com>
Signed-off-by: Li Zefan <lizefan@huawei.com>
commit 3ac1707a13a3da9cfc8f242a15b2fae6df2c5f88 upstream.
The 3rd parameter of flex_array_prealloc() is the number of elements,
not the index of the last element.
The effect of the bug is, when opening cgroup.procs, a flex array will
be allocated and all elements of the array is allocated with
GFP_KERNEL flag, but the last one is GFP_ATOMIC, and if we fail to
allocate memory for it, it'll trigger a BUG_ON().
points
commit 94a409319561ec1847fd9bf996a2d5843ad00932 upstream.
Commit 4ae46be "Thermal: Introduce thermal_zone_trip_update()"
introduced a regression causing the fan to be always on even when
the system is idle.
My original idea in that commit is that:
- when the current temperature is above the trip point,
keep the fan on, even if the temperature is dropping.
- when the current temperature is below the trip point,
turn on the fan when the temperature is raising,
turn off the fan when the temperature is dropping.
But this is what the code actually does:
the fan keeps on.
the fan is always on because thermal_get_trend()
in driver/acpi/thermal.c returns THERMAL_TREND_RAISING.
Thus the fan keeps running even if the system is idle.
Fix this in drivers/acpi/thermal.c.
[rjw: Changelog]
References: https://bugzilla.kernel.org/show_bug.cgi?id=56591
References: https://bugzilla.kernel.org/show_bug.cgi?id=56601
References: https://bugzilla.kernel.org/show_bug.cgi?id=50041#c45
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Tested-by: Matthias <morpheusxyz123@yahoo.de>
Tested-by: Ville Syrjälä <syrjala@sci.fi>
commit a6432ded299726f123b93d0132fead200551535c upstream.
Commit 53aac44 (ACPI: Store valid ACPI tables passed via early initrd
in reserved memblock areas) introduced acpi_initrd_override() that
passes a wrong value as the second argument to memblock_reserve().
Namely, the second argument of memblock_reserve() is the size of the
region, not the address of the top of it, so make
acpi_initrd_override() pass the size in there as appropriate.
[rjw: Changelog]
Signed-off-by: Wang YanQing <udknight@gmail.com>
Acked-by: Yinghai Lu <yinghai@kernel.org>
commit d66af4df0837f21bf267305dc5ccab2d29e24d86 upstream.
Since commit 30dcf76acc, ata_ap_acpi_handle will always do a namespace
walk, which requires acquiring an acpi namespace mutex. This made it
impossible to be used when calling path has held a spinlock.
For example, it can occur in the following code path for pata_acpi:
ata_scsi_queuecmd (ap->lock is acquired)
__ata_scsi_queuecmd
ata_scsi_translate
ata_qc_issue
pacpi_qc_issue
ata_acpi_stm
ata_ap_acpi_handle
acpi_get_child
acpi_walk_namespace
acpi_ut_acquire_mutex (acquire mutex while holding lock)
This caused scheduling while atomic bug, as reported in bug #56781.
Actually, ata_ap_acpi_handle doesn't have to walk the namespace every
time it is called, it can simply return the bound acpi handle on the
corresponding SCSI host. The reason previously it is not done this way
is, ata_ap_acpi_handle is used in the binding function
ata_acpi_bind_host by ata_acpi_gtm when the handle is not bound to the
SCSI host yet. Since we already have the ATA port's handle in its
binding function, we can simply use it instead of calling
ata_ap_acpi_handle there. So introduce a new function __ata_acpi_gtm,
where it will receive an acpi handle param in addition to the ATA port
which is solely used for debug statement. With this change, we can make
ata_ap_acpi_handle simply return the bound handle for SCSI host instead
of walking the acpi namespace now.
Buglink: https://bugzilla.kernel.org/show_bug.cgi?id=56781
Reported-and-tested-by: <kenzopl@o2.pl>
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
commit 3427de92ac70a064098ff843c72ac76c420bb1cb upstream.
Add missing iounmap to probe error path and remove.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit e005715efaf674660ae59af83b13822567e3a758 upstream.
There's a bug where rtc alarms are ignored after the rtc cmos suspends
but before the system finishes suspend. Since hpet emulation is
disabled and it still handles the interrupts, a wake event is never
registered which is done from the rtc layer.
This patch reverts commit d1b2efa83fbf ("rtc: disable hpet emulation on
suspend") which disabled hpet emulation. To fix the problem mentioned
in that commit, hpet_rtc_timer_init() is called directly on resume.
Signed-off-by: Derek Basehore <dbasehore@chromium.org>
Cc: Maxim Levitsky <maximlevitsky@gmail.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
commit 0cdc444a67ccdbd58bfbcba865cb17a9f17a7691 upstream.
As pointed out by Andrew Morton, the swap-over-NFS writeback is not
setting PageWriteback before it is queued for direct IO. While swap
pages do not participate in BDI or process dirty accounting and the IO
is synchronous, the writeback bit is still required and not setting it
in this case was an oversight. swapoff depends on the page writeback to
synchronoise all pending writes on a swap page before it is reused.
Swapcache freeing and reuse depend on checking the PageWriteback under
lock to ensure the page is safe to reuse.
Direct IO handlers and the direct IO handler for NFS do not deal with
PageWriteback as they are synchronous writes. In the case of NFS, it
schedules pages (or a page in the case of swap) for IO and then waits
synchronously for IO to complete in nfs_direct_write(). It is
recognised that this is a slowdown from normal swap handling which is
asynchronous and uses a completion handler. Shoving PageWriteback
handling down into direct IO handlers looks like a bad fit to handle the
swap case although it may have to be dealt with some day if swap is
converted to use direct IO in general and bmap is finally done away
with. At that point it will be necessary to refit asynchronous direct
IO with completion handlers onto the swap subsystem.
As swapcache currently depends on PageWriteback to protect against
races, this patch sets PageWriteback under the page lock before queueing
it for direct IO. It is cleared when the direct IO handler returns. IO
errors are treated similarly to the direct-to-bio case except PageError
is not set as in the case of swap-over-NFS, it is likely to be a
transient error.
It was asked what prevents such a page being reclaimed in parallel.
With this patch applied, such a page will now be skipped (most of the
time) or blocked until the writeback completes. Reclaim checks
PageWriteback under the page lock before calling try_to_free_swap and
the page lock should prevent the page being requeued for IO before it is
freed.
This and Jerome's related patch should considered for -stable as far
back as 3.6 when swap-over-NFS was introduced.
[akpm@linux-foundation.org: use pr_err_ratelimited()]
[akpm@linux-foundation.org: remove hopefully-unneeded cast in printk]
commit 2d30d31ea3c5be426ce25607b9bd1835acb85e0a upstream.
Since commit 62c230bc1790 ("mm: add support for a filesystem to activate
swap files and use direct_IO for writing swap pages"), swap_writepage()
calls direct_IO on swap files. However, in that case the page isn't
redirtied if I/O fails, and is therefore handled afterwards as if it has
been successfully written to the swap file, leading to memory corruption
when the page is eventually swapped back in.
This patch sets the page dirty when direct_IO() fails. It fixes a
memory corruption that happened while using swap-over-NFS.
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
commit 8f294b5a139ee4b75e890ad5b443c93d1e558a8b upstream.
The settimeofday01 test in the LTP testsuite effectively does
gettimeofday(current time);
settimeofday(Jan 1, 1970 + 100 seconds);
settimeofday(current time);
This test causes a stack trace to be displayed on the console during the
setting of timeofday to Jan 1, 1970 + 100 seconds:
[ 131.066751] ------------[ cut here ]------------
[ 131.096448] WARNING: at kernel/time/clockevents.c:209 clockevents_program_event+0x135/0x140()
[ 131.104935] Hardware name: Dinar
[ 131.108150] Modules linked in: sg nfsv3 nfs_acl nfsv4 auth_rpcgss nfs dns_resolver fscache lockd sunrpc nf_conntrack_netbios_ns nf_conntrack_broadcast ipt_MASQUERADE ip6table_mangle ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 iptable_nat nf_nat_ipv4 nf_nat iptable_mangle ipt_REJECT nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_conntrack ebtable_filter ebtables ip6table_filter ip6_tables iptable_filter ip_tables kvm_amd kvm sp5100_tco bnx2 i2c_piix4 crc32c_intel k10temp fam15h_power ghash_clmulni_intel amd64_edac_mod pcspkr serio_raw edac_mce_amd edac_core microcode xfs libcrc32c sr_mod sd_mod cdrom ata_generic crc_t10dif pata_acpi radeon i2c_algo_bit drm_kms_helper ttm drm ahci pata_atiixp libahci libata usb_storage i2c_core dm_mirror dm_region_hash dm_log dm_mod
[ 131.176784] Pid: 0, comm: swapper/28 Not tainted 3.8.0+ #6
[ 131.182248] Call Trace:
[ 131.184684] <IRQ> [<ffffffff810612af>] warn_slowpath_common+0x7f/0xc0
[ 131.191312] [<ffffffff8106130a>] warn_slowpath_null+0x1a/0x20
[ 131.197131] [<ffffffff810b9fd5>] clockevents_program_event+0x135/0x140
[ 131.203721] [<ffffffff810bb584>] tick_program_event+0x24/0x30
[ 131.209534] [<ffffffff81089ab1>] hrtimer_interrupt+0x131/0x230
[ 131.215437] [<ffffffff814b9600>] ? cpufreq_p4_target+0x130/0x130
[ 131.221509] [<ffffffff81619119>] smp_apic_timer_interrupt+0x69/0x99
[ 131.227839] [<ffffffff8161805d>] apic_timer_interrupt+0x6d/0x80
[ 131.233816] <EOI> [<ffffffff81099745>] ? sched_clock_cpu+0xc5/0x120
[ 131.240267] [<ffffffff814b9ff0>] ? cpuidle_wrap_enter+0x50/0xa0
[ 131.246252] [<ffffffff814b9fe9>] ? cpuidle_wrap_enter+0x49/0xa0
[ 131.252238] [<ffffffff814ba050>] cpuidle_enter_tk+0x10/0x20
[ 131.257877] [<ffffffff814b9c89>] cpuidle_idle_call+0xa9/0x260
[ 131.263692] [<ffffffff8101c42f>] cpu_idle+0xaf/0x120
[ 131.268727] [<ffffffff815f8971>] start_secondary+0x255/0x257
[ 131.274449] ---[ end trace 1151a50552231615 ]---
When we change the system time to a low value like this, the value of
timekeeper->offs_real will be a negative value.
It seems that the WARN occurs because an hrtimer has been started in the time
between the releasing of the timekeeper lock and the IPI call (via a call to
on_each_cpu) in clock_was_set() in the do_settimeofday() code. The end result
is that a REALTIME_CLOCK timer has been added with softexpires = expires =
KTIME_MAX. The hrtimer_interrupt() fires/is called and the loop at
kernel/hrtimer.c:1289 is executed. In this loop the code subtracts the
clock base's offset (which was set to timekeeper->offs_real in
do_settimeofday()) from the current hrtimer_cpu_base->expiry value (which
was KTIME_MAX):
KTIME_MAX - (a negative value) = overflow
A simple check for an overflow can resolve this problem. Using KTIME_MAX
instead of the overflow value will result in the hrtimer function being run,
and the reprogramming of the timer after that.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
[jstultz: Tweaked commit subject]
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit 51fd36f3fad8447c487137ae26b9d0b3ce77bb25 upstream.
One can trigger an overflow when using ktime_add_ns() on a 32bit
architecture not supporting CONFIG_KTIME_SCALAR.
When passing a very high value for u64 nsec, e.g. 7881299347898368000
the do_div() function converts this value to seconds (7881299347) which
is still to high to pass to the ktime_set() function as long. The result
in is a negative value.
The problem on my system occurs in the tick-sched.c,
tick_nohz_stop_sched_tick() when time_delta is set to
timekeeping_max_deferment(). The check for time_delta < KTIME_MAX is
valid, thus ktime_add_ns() is called with a too large value resulting in
a negative expire value. This leads to an endless loop in the ticker code:
time_delta: 7881299347898368000
expires = ktime_add_ns(last_update, time_delta)
expires: negative value
This fix caps the value to KTIME_MAX.
This error doesn't occurs on 64bit or architectures supporting
CONFIG_KTIME_SCALAR (e.g. ARM, x86-32).
Signed-off-by: David Engraf <david.engraf@sysgo.com>
[jstultz: Minor tweaks to commit message & header]
commit 98682063549bedd6e2d2b6b7222f150c6fbce68c upstream.
The hardware revision of the codec is based at 0x40. Subtract that
before convering to ASCII. The same as it is done for 98095.
Signed-off-by: Dylan Reid <dgreid@chromium.org>
commit 7fc7d047216aa4923d401c637be2ebc6e3d5bd9b upstream.
It's yet another ALC269-variant.
Signed-off-by: Kailang Yang <kailang@realtek.com>
