commit 4e1a720d0312fd510699032c7694a362a010170f upstream.
slub debug reported:
[ 440.648642] =============================================================================
[ 440.648649] BUG kmalloc-1024 (Tainted: G BU O ): Poison overwritten
[ 440.648651] -----------------------------------------------------------------------------
[ 440.648655] INFO: 0xe70f4bec-0xe70f4bec. First byte 0x6a instead of 0x6b
[ 440.648665] INFO: Allocated in sk_prot_alloc+0x6b/0xc6 age=33155 cpu=1 pid=1047
[ 440.648671] ___slab_alloc.constprop.24+0x1fc/0x292
[ 440.648675] __slab_alloc.isra.18.constprop.23+0x1c/0x25
[ 440.648677] __kmalloc+0xb6/0x17f
[ 440.648680] sk_prot_alloc+0x6b/0xc6
[ 440.648683] sk_alloc+0x1e/0xa1
[ 440.648700] sco_sock_alloc.constprop.6+0x26/0xaf [bluetooth]
[ 440.648716] sco_connect_cfm+0x166/0x281 [bluetooth]
[ 440.648731] hci_conn_request_evt.isra.53+0x258/0x281 [bluetooth]
[ 440.648746] hci_event_packet+0x28b/0x2326 [bluetooth]
[ 440.648759] hci_rx_work+0x161/0x291 [bluetooth]
[ 440.648764] process_one_work+0x163/0x2b2
[ 440.648767] worker_thread+0x1a9/0x25c
[ 440.648770] kthread+0xf8/0xfd
[ 440.648774] ret_from_fork+0x2e/0x38
[ 440.648779] INFO: Freed in __sk_destruct+0xd3/0xdf age=3815 cpu=1 pid=1047
[ 440.648782] __slab_free+0x4b/0x27a
[ 440.648784] kfree+0x12e/0x155
[ 440.648787] __sk_destruct+0xd3/0xdf
[ 440.648790] sk_destruct+0x27/0x29
[ 440.648793] __sk_free+0x75/0x91
[ 440.648795] sk_free+0x1c/0x1e
[ 440.648810] sco_sock_kill+0x5a/0x5f [bluetooth]
[ 440.648825] sco_conn_del+0x8e/0xba [bluetooth]
[ 440.648840] sco_disconn_cfm+0x3a/0x41 [bluetooth]
[ 440.648855] hci_event_packet+0x45e/0x2326 [bluetooth]
[ 440.648868] hci_rx_work+0x161/0x291 [bluetooth]
[ 440.648872] process_one_work+0x163/0x2b2
[ 440.648875] worker_thread+0x1a9/0x25c
[ 440.648877] kthread+0xf8/0xfd
[ 440.648880] ret_from_fork+0x2e/0x38
[ 440.648884] INFO: Slab 0xf4718580 objects=27 used=27 fp=0x (null) flags=0x40008100
[ 440.648886] INFO: Object 0xe70f4b88 @offset=19336 fp=0xe70f54f8
When KASAN was enabled, it reported:
[ 210.096613] ==================================================================
[ 210.096634] BUG: KASAN: use-after-free in ex_handler_refcount+0x5b/0x127
[ 210.096641] Write of size 4 at addr ffff880107e17160 by task kworker/u9:1/2040
[ 210.096651] CPU: 1 PID: 2040 Comm: kworker/u9:1 Tainted: G U O 4.14.47-20180606+ #2
[ 210.096654] Hardware name: , BIOS 2017.01-00087-g43e04de 08/30/2017
[ 210.096693] Workqueue: hci0 hci_rx_work [bluetooth]
[ 210.096698] Call Trace:
[ 210.096711] dump_stack+0x46/0x59
[ 210.096722] print_address_description+0x6b/0x23b
[ 210.096729] ? ex_handler_refcount+0x5b/0x127
[ 210.096736] kasan_report+0x220/0x246
[ 210.096744] ex_handler_refcount+0x5b/0x127
[ 210.096751] ? ex_handler_clear_fs+0x85/0x85
[ 210.096757] fixup_exception+0x8c/0x96
[ 210.096766] do_trap+0x66/0x2c1
[ 210.096773] do_error_trap+0x152/0x180
[ 210.096781] ? fixup_bug+0x78/0x78
[ 210.096817] ? hci_debugfs_create_conn+0x244/0x26a [bluetooth]
[ 210.096824] ? __schedule+0x113b/0x1453
[ 210.096830] ? sysctl_net_exit+0xe/0xe
[ 210.096837] ? __wake_up_common+0x343/0x343
[ 210.096843] ? insert_work+0x107/0x163
[ 210.096850] invalid_op+0x1b/0x40
[ 210.096888] RIP: 0010:hci_debugfs_create_conn+0x244/0x26a [bluetooth]
[ 210.096892] RSP: 0018:ffff880094a0f970 EFLAGS: 00010296
[ 210.096898] RAX: 0000000000000000 RBX: ffff880107e170e8 RCX: ffff880107e17160
[ 210.096902] RDX: 000000000000002f RSI: ffff88013b80ed40 RDI: ffffffffa058b940
[ 210.096906] RBP: ffff88011b2b0578 R08: 00000000852f0ec9 R09: ffffffff81cfcf9b
[ 210.096909] R10: 00000000d21bdad7 R11: 0000000000000001 R12: ffff8800967b0488
[ 210.096913] R13: ffff880107e17168 R14: 0000000000000068 R15: ffff8800949c0008
[ 210.096920] ? __sk_destruct+0x2c6/0x2d4
[ 210.096959] hci_event_packet+0xff5/0x7de2 [bluetooth]
[ 210.096969] ? __local_bh_enable_ip+0x43/0x5b
[ 210.097004] ? l2cap_sock_recv_cb+0x158/0x166 [bluetooth]
[ 210.097039] ? hci_le_meta_evt+0x2bb3/0x2bb3 [bluetooth]
[ 210.097075] ? l2cap_ertm_init+0x94e/0x94e [bluetooth]
[ 210.097093] ? xhci_urb_enqueue+0xbd8/0xcf5 [xhci_hcd]
[ 210.097102] ? __accumulate_pelt_segments+0x24/0x33
[ 210.097109] ? __accumulate_pelt_segments+0x24/0x33
[ 210.097115] ? __update_load_avg_se.isra.2+0x217/0x3a4
[ 210.097122] ? set_next_entity+0x7c3/0x12cd
[ 210.097128] ? pick_next_entity+0x25e/0x26c
[ 210.097135] ? pick_next_task_fair+0x2ca/0xc1a
[ 210.097141] ? switch_mm_irqs_off+0x346/0xb4f
[ 210.097147] ? __switch_to+0x769/0xbc4
[ 210.097153] ? compat_start_thread+0x66/0x66
[ 210.097188] ? hci_conn_check_link_mode+0x1cd/0x1cd [bluetooth]
[ 210.097195] ? finish_task_switch+0x392/0x431
[ 210.097228] ? hci_rx_work+0x154/0x487 [bluetooth]
[ 210.097260] hci_rx_work+0x154/0x487 [bluetooth]
[ 210.097269] process_one_work+0x579/0x9e9
[ 210.097277] worker_thread+0x68f/0x804
[ 210.097285] kthread+0x31c/0x32b
[ 210.097292] ? rescuer_thread+0x70c/0x70c
[ 210.097299] ? kthread_create_on_node+0xa3/0xa3
[ 210.097306] ret_from_fork+0x35/0x40
[ 210.097314] Allocated by task 2040:
[ 210.097323] kasan_kmalloc.part.1+0x51/0xc7
[ 210.097328] __kmalloc+0x17f/0x1b6
[ 210.097335] sk_prot_alloc+0xf2/0x1a3
[ 210.097340] sk_alloc+0x22/0x297
[ 210.097375] sco_sock_alloc.constprop.7+0x23/0x202 [bluetooth]
[ 210.097410] sco_connect_cfm+0x2d0/0x566 [bluetooth]
[ 210.097443] hci_conn_request_evt.isra.53+0x6d3/0x762 [bluetooth]
[ 210.097476] hci_event_packet+0x85e/0x7de2 [bluetooth]
[ 210.097507] hci_rx_work+0x154/0x487 [bluetooth]
[ 210.097512] process_one_work+0x579/0x9e9
[ 210.097517] worker_thread+0x68f/0x804
[ 210.097523] kthread+0x31c/0x32b
[ 210.097529] ret_from_fork+0x35/0x40
[ 210.097533] Freed by task 2040:
[ 210.097539] kasan_slab_free+0xb3/0x15e
[ 210.097544] kfree+0x103/0x1a9
[ 210.097549] __sk_destruct+0x2c6/0x2d4
[ 210.097584] sco_conn_del.isra.1+0xba/0x10e [bluetooth]
[ 210.097617] hci_event_packet+0xff5/0x7de2 [bluetooth]
[ 210.097648] hci_rx_work+0x154/0x487 [bluetooth]
[ 210.097653] process_one_work+0x579/0x9e9
[ 210.097658] worker_thread+0x68f/0x804
[ 210.097663] kthread+0x31c/0x32b
[ 210.097670] ret_from_fork+0x35/0x40
[ 210.097676] The buggy address belongs to the object at ffff880107e170e8
which belongs to the cache kmalloc-1024 of size 1024
[ 210.097681] The buggy address is located 120 bytes inside of
1024-byte region [ffff880107e170e8, ffff880107e174e8)
[ 210.097683] The buggy address belongs to the page:
[ 210.097689] page:ffffea00041f8400 count:1 mapcount:0 mapping: (null) index:0xffff880107e15b68 compound_mapcount: 0
[ 210.110194] flags: 0x8000000000008100(slab|head)
[ 210.115441] raw: 8000000000008100 0000000000000000 ffff880107e15b68 0000000100170016
[ 210.115448] raw: ffffea0004a47620 ffffea0004b48e20 ffff88013b80ed40 0000000000000000
[ 210.115451] page dumped because: kasan: bad access detected
[ 210.115454] Memory state around the buggy address:
[ 210.115460] ffff880107e17000: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 210.115465] ffff880107e17080: fc fc fc fc fc fc fc fc fc fc fc fc fc fb fb fb
[ 210.115469] >ffff880107e17100: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 210.115472] ^
[ 210.115477] ffff880107e17180: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 210.115481] ffff880107e17200: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 210.115483] ==================================================================
And finally when BT_DBG() and ftrace was enabled it showed:
<...>-14979 [001] .... 186.104191: sco_sock_kill <-sco_sock_close
<...>-14979 [001] .... 186.104191: sco_sock_kill <-sco_sock_release
<...>-14979 [001] .... 186.104192: sco_sock_kill: sk ef0497a0 state 9
<...>-14979 [001] .... 186.104193: bt_sock_unlink <-sco_sock_kill
kworker/u9:2-792 [001] .... 186.104246: sco_sock_kill <-sco_conn_del
kworker/u9:2-792 [001] .... 186.104248: sco_sock_kill: sk ef0497a0 state 9
kworker/u9:2-792 [001] .... 186.104249: bt_sock_unlink <-sco_sock_kill
kworker/u9:2-792 [001] .... 186.104250: sco_sock_destruct <-__sk_destruct
kworker/u9:2-792 [001] .... 186.104250: sco_sock_destruct: sk ef0497a0
kworker/u9:2-792 [001] .... 186.104860: hci_conn_del <-hci_event_packet
kworker/u9:2-792 [001] .... 186.104864: hci_conn_del: hci0 hcon ef0484c0 handle 266
Only in the failed case, sco_sock_kill() gets called with the same sock
pointer two times. Add a check for SOCK_DEAD to avoid continue killing
a socket which has already been killed.
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit fd7e315988b784509ba3f1b42f539bd0b1fca9bb upstream.
Create a pgd_pfn() macro similar to the p[4um]d_pfn() macros and then
use the p[g4um]d_pfn() macros in the p[g4um]d_page() macros instead of
duplicating the code.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: Alexander Potapenko <glider@google.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Brijesh Singh <brijesh.singh@amd.com>
Cc: Dave Young <dyoung@redhat.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Toshimitsu Kani <toshi.kani@hpe.com>
Cc: kasan-dev@googlegroups.com
Cc: kvm@vger.kernel.org
Cc: linux-doc@vger.kernel.org
Cc: linux-efi@vger.kernel.org
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/e61eb533a6d0aac941db2723d8aa63ef6b882dee.1500319216.git.thomas.lendacky@amd.com
[Backported to 4.9 stable by AK, suggested by Michael Hocko]
commit 784c29eda5b4e28c3a56aa90b3815f9a1b0cfdc1 upstream.
Add ACPI identifier HID for UART DW 8250 on Broadcom SoCs
to match the HID passed through ACPI tables to enable
UART controller.
Signed-off-by: Srinath Mannam <srinath.mannam@broadcom.com>
Reviewed-by: Vladimir Olovyannikov <vladimir.olovyannikov@broadcom.com>
Tested-by: Vladimir Olovyannikov <vladimir.olovyannikov@broadcom.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: stable <stable@vger.kernel.org>
commit dfcab6ba573445c703235ab6c83758eec12d7f28 upstream.
dw8250_set_termios() doesn't set baud rate if the arg "old ktermios" is
NULL. This happens during resume.
Call Trace:
[ 54.928108] dw8250_set_termios+0x162/0x170
[ 54.928114] serial8250_set_termios+0x17/0x20
[ 54.928117] uart_change_speed+0x64/0x160
[ 54.928119] uart_resume_port
So the baud rate is not restored after S3 and breaks the apps who use
UART, for example, console and bluetooth etc.
We address this issue by setting the baud rate irrespective of arg
"old", just like the drivers for other 8250 IPs. This is tested with
Intel Broxton platform.
Signed-off-by: Chen Hu <hu1.chen@intel.com>
Fixes: 4e26b134bd17 ("serial: 8250_dw: clock rate handling for all ACPI platforms")
Cc: Heikki Krogerus <heikki.krogerus@linux.intel.com>
commit 47ac76662ca9c5852fd353093f19de3ae85f2e66 upstream.
Revert commit ecb988a3b7985913d1f0112f66667cdd15e40711: tty: serial:
8250: 8250_core: NXP SC16C2552 workaround
The above commit causes userland application to no longer write
correctly its first write to a dumb terminal connected to /dev/ttyS0.
This commit seems to be the culprit. It's as though the TX FIFO is being
reset during that write. What should be displayed is:
PSW 80000000 INST 00000000 HALT
What is displayed is some variation of:
T 00000000 HAL//
Reverting this commit via this patch fixes my problem.
Signed-off-by: Mark Hounschell <dmarkh@cfl.rr.com>
Fixes: ecb988a3b798 ("tty: serial: 8250: 8250_core: NXP SC16C2552 workaround")
commit 231f9415001138a000cd0f881c46654b7ea3f8c5 upstream.
Every time I tried to upgrade my laptop from 3.10.x to 4.x I faced an
issue by which the fan would run at full speed upon resume. Bisecting
it showed me the issue was introduced in 3.17 by commit 821d6f0359b0
(ACPI / sleep: Do not save NVS for new machines to accelerate S3). This
code only affects machines built starting as of 2012, but this Asus
1025C laptop was made in 2012 and apparently needs the NVS data to be
saved, otherwise the CPU's thermal state is not properly reported on
resume and the fan runs at full speed upon resume.
Here's a very simple way to check if such a machine is affected :
# cat /sys/class/thermal/thermal_zone0/temp
55000
( now suspend, wait one second and resume )
0
(and after ~15 seconds the fan starts to spin)
Let's apply the same quirk as commit cbc00c13 (ACPI: save NVS memory
for Lenovo G50-45) and reuse the function it provides. Note that this
commit was already backported to 4.9.x but not 4.4.x.
Cc: 3.17+ <stable@vger.kernel.org> # 3.17+: requires cbc00c13
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit 7bab01ecc6c43da882333c6db39741cb43677004 upstream.
The device exposes AT, NMEA and DIAG ports in both USB configurations.
The patch explicitly ignores interfaces 0 and 1, as they're bound to
other drivers already; and also interface 6, which is a GNSS interface
for which we don't have a driver yet.
T: Bus=01 Lev=03 Prnt=04 Port=00 Cnt=01 Dev#= 18 Spd=480 MxCh= 0
D: Ver= 2.10 Cls=ef(misc ) Sub=02 Prot=01 MxPS=64 #Cfgs= 2
P: Vendor=413c ProdID=81d7 Rev=03.18
S: Manufacturer=DELL
S: Product=DW5821e Snapdragon X20 LTE
S: SerialNumber=0123456789ABCDEF
C: #Ifs= 7 Cfg#= 2 Atr=a0 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=02(commc) Sub=0e Prot=00 Driver=cdc_mbim
I: If#= 1 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=02 Driver=cdc_mbim
I: If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#= 4 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#= 5 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
I: If#= 6 Alt= 0 #EPs= 1 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
T: Bus=01 Lev=03 Prnt=04 Port=00 Cnt=01 Dev#= 16 Spd=480 MxCh= 0
C: #Ifs= 6 Cfg#= 1 Atr=a0 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan
I: If#= 1 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid
Signed-off-by: Aleksander Morgado <aleksander@aleksander.es>
commit e60870012e5a35b1506d7b376fddfb30e9da0b27 upstream.
The portdata spinlock can be taken in interrupt context (via
sierra_outdat_callback()).
Disable interrupts when taking the portdata spinlock when discarding
deferred URBs during close to prevent a possible deadlock.
Fixes: 014333f77c0b ("USB: sierra: fix urb and memory leak on disconnect")
Signed-off-by: John Ogness <john.ogness@linutronix.de>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
[ johan: amend commit message and add fixes and stable tags ]
Signed-off-by: Johan Hovold <johan@kernel.org>
[ Upstream commit a51c76b4dfb30496dc65396a957ef0f06af7fb22 ]
Fix tcf_unbind_filter missing in cls_matchall as this will trigger
WARN_ON() in cbq_destroy_class().
Fixes: fd62d9f5c575f ("net/sched: matchall: Fix configuration race")
Reported-by: Li Shuang <shuali@redhat.com>
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit 5e22002aa8809e2efab2da95855f73f63e14a36c ]
It was possible to directly leak the kernel address where the isdn_dev
structure pointer was stored. This is a kernel ASLR bypass for anyone
with access to the ioctl. The code had been present since the beginning
of git history, though this shouldn't ever be needed for normal operation,
therefore remove it.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Karsten Keil <isdn@linux-pingi.de>
commit 3acd3e3bab95ec3622ff98da313290ee823a0f68 upstream.
The endian conversions used in vxp_dma_read() and vxp_dma_write() are
superfluous and even wrong on big-endian machines, as inw() and outw()
already do conversions. Kill them.
Cc: <stable@vger.kernel.org>
commit dfef01e150824b0e6da750cacda8958188d29aea upstream.
snd_dma_alloc_pages_fallback() tries to allocate pages again when the
allocation fails with reduced size. But the first try actually
*increases* the size to power-of-two, which may give back a larger
chunk than the requested size. This confuses the callers, e.g. sgbuf
assumes that the size is equal or less, and it may result in a bad
loop due to the underflow and eventually lead to Oops.
The code of this function seems incorrectly assuming the usage of
get_order(). We need to decrease at first, then align to
power-of-two.
Reported-and-tested-by: he, bo <bo.he@intel.com>
Reported-by: zhang jun <jun.zhang@intel.com>
commit 8e82a728792bf66b9f0a29c9d4c4b0630f7b9c79 upstream.
I added the subsys product-id for the HDMI HDA device rather then for
the PCH one, this commit fixes this.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1525104
Cc: stable@vger.kernel.org
commit 69756930f2de0457d51db7d505a1e4f40e9fd116 upstream.
One place in cs5535audio_build_dma_packets() does an extra conversion
via cpu_to_le32(); namely jmpprd_addr is passed to setup_prd() ops,
which writes the value via cs_writel(). That is, the callback does
the conversion by itself, and we don't need to convert beforehand.
This patch fixes that bogus conversion.
commit 50e9ffb1996a5d11ff5040a266585bad4ceeca0a upstream.
The virmidi output trigger tries to parse the all available bytes and
process sequencer events as much as possible. In a normal situation,
this is supposed to be relatively short, but a program may give a huge
buffer and it'll take a long time in a single spin lock, which may
eventually lead to a soft lockup.
This patch simply adds a workaround, a cond_resched() call in the loop
if applicable. A better solution would be to move the event processor
into a work, but let's put a duct-tape quickly at first.
Reported-and-tested-by: Dae R. Jeong <threeearcat@gmail.com>
Reported-by: syzbot+619d9f40141d826b097e@syzkaller.appspotmail.com
commit fff71a4c050ba46e305d910c837b99ba1728135e upstream.
The endian conversions used in vx2_dma_read() and vx2_dma_write() are
superfluous and even wrong on big-endian machines, as inl() and outl()
Spotted by sparse, a warning like:
sound/pci/vx222/vx222_ops.c:278:30: warning: incorrect type in argument 1 (different base types)
commit d77a4b4a5b0b2ebcbc9840995d91311ef28302ab upstream.
As an equivalent codec with CX20724,
CX8200 is also subject to the reboot bug.
Late 2017 and 2018 LG Gram and some HP Spectre laptops are known victims
to this issue, causing extremely loud noises upon reboot.
Now that we know that this bug is subject to multiple codecs,
fix the comment as well.
Signed-off-by: Park Ju Hyung <qkrwngud825@gmail.com>
commit f59cf9a0551dd954ad8b752461cf19d9789f4b1d upstream.
On rare occasions, we are still noticing that the internal speaker
spitting out spurious noises even after adding the problematic codec
to the list.
Adding a 10ms artificial delay before rebooting fixes the issue entirely.
Patch for Realtek codecs also adds the same amount of delay after
entering D3.
[ Upstream commit 2df8bee5654bb2b7312662ca6810d4dc16b0b67f ]
Li Shuang reported the following crash:
[ 71.267724] BUG: unable to handle kernel NULL pointer dereference at 0000000000000004
[ 71.276456] PGD 800000085d9bd067 P4D 800000085d9bd067 PUD 859a0b067 PMD 0
[ 71.284127] Oops: 0000 [#1] SMP PTI
[ 71.288015] CPU: 12 PID: 2386 Comm: tc Not tainted 4.18.0-rc8.latest+ #131
[ 71.295686] Hardware name: Dell Inc. PowerEdge R730/0WCJNT, BIOS 2.1.5 04/11/2016
[ 71.304037] RIP: 0010:tcindex_delete+0x72/0x280 [cls_tcindex]
[ 71.310446] Code: 00 31 f6 48 87 75 20 48 85 f6 74 11 48 8b 47 18 48 8b 40 08 48 8b 40 50 e8 fb a6 f8 fc 48 85 db 0f 84 dc 00 00 00 48 8b 73 18 <8b> 56 04 48 8d 7e 04 85 d2 0f 84 7b 01 00
[ 71.331517] RSP: 0018:ffffb45207b3f898 EFLAGS: 00010282
[ 71.337345] RAX: ffff8ad3d72d6360 RBX: ffff8acc84393680 RCX: 000000000000002e
[ 71.345306] RDX: ffff8ad3d72c8570 RSI: 0000000000000000 RDI: ffff8ad847a45800
[ 71.353277] RBP: ffff8acc84393688 R08: ffff8ad3d72c8400 R09: 0000000000000000
[ 71.361238] R10: ffff8ad3de786e00 R11: 0000000000000000 R12: ffffb45207b3f8c7
[ 71.369199] R13: ffff8ad3d93bd2a0 R14: 000000000000002e R15: ffff8ad3d72c9600
[ 71.377161] FS: 00007f9d3ec3e740(0000) GS:ffff8ad3df980000(0000) knlGS:0000000000000000
[ 71.386188] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 71.392597] CR2: 0000000000000004 CR3: 0000000852f06003 CR4: 00000000001606e0
[ 71.400558] Call Trace:
[ 71.403299] tcindex_destroy_element+0x25/0x40 [cls_tcindex]
[ 71.409611] tcindex_walk+0xbb/0x110 [cls_tcindex]
[ 71.414953] tcindex_destroy+0x44/0x90 [cls_tcindex]
[ 71.420492] ? tcindex_delete+0x280/0x280 [cls_tcindex]
[ 71.426323] tcf_proto_destroy+0x16/0x40
[ 71.430696] tcf_chain_flush+0x51/0x70
[ 71.434876] tcf_block_put_ext.part.30+0x8f/0x1b0
[ 71.440122] tcf_block_put+0x4d/0x70
[ 71.444108] cbq_destroy+0x4d/0xd0 [sch_cbq]
[ 71.448869] qdisc_destroy+0x62/0x130
[ 71.452951] dsmark_destroy+0x2a/0x70 [sch_dsmark]
[ 71.458300] qdisc_destroy+0x62/0x130
[ 71.462373] qdisc_graft+0x3ba/0x470
[ 71.466359] tc_get_qdisc+0x2a6/0x2c0
[ 71.470443] ? cred_has_capability+0x7d/0x130
[ 71.475307] rtnetlink_rcv_msg+0x263/0x2d0
[ 71.479875] ? rtnl_calcit.isra.30+0x110/0x110
[ 71.484832] netlink_rcv_skb+0x4d/0x130
[ 71.489109] netlink_unicast+0x1a3/0x250
[ 71.493482] netlink_sendmsg+0x2ae/0x3a0
[ 71.497859] sock_sendmsg+0x36/0x40
[ 71.501748] ___sys_sendmsg+0x26f/0x2d0
[ 71.506029] ? handle_pte_fault+0x586/0xdf0
[ 71.510694] ? __handle_mm_fault+0x389/0x500
[ 71.515457] ? __sys_sendmsg+0x5e/0xa0
[ 71.519636] __sys_sendmsg+0x5e/0xa0
[ 71.523626] do_syscall_64+0x5b/0x180
[ 71.527711] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 71.533345] RIP: 0033:0x7f9d3e257f10
[ 71.537331] Code: c3 48 8b 05 82 6f 2c 00 f7 db 64 89 18 48 83 cb ff eb dd 0f 1f 80 00 00 00 00 83 3d 8d d0 2c 00 00 75 10 b8 2e 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8
[ 71.558401] RSP: 002b:00007fff6f893398 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
[ 71.566848] RAX: ffffffffffffffda RBX: 000000005b71274d RCX: 00007f9d3e257f10
[ 71.574810] RDX: 0000000000000000 RSI: 00007fff6f8933e0 RDI: 0000000000000003
[ 71.582770] RBP: 00007fff6f8933e0 R08: 000000000000ffff R09: 0000000000000003
[ 71.590729] R10: 00007fff6f892e20 R11: 0000000000000246 R12: 0000000000000000
[ 71.598689] R13: 0000000000662ee0 R14: 0000000000000000 R15: 0000000000000000
[ 71.606651] Modules linked in: sch_cbq cls_tcindex sch_dsmark xt_CHECKSUM iptable_mangle ipt_MASQUERADE iptable_nat nf_nat_ipv4 nf_nat nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_coni
[ 71.685425] libahci i2c_algo_bit i2c_core i40e libata dca mdio megaraid_sas dm_mirror dm_region_hash dm_log dm_mod
[ 71.697075] CR2: 0000000000000004
[ 71.700792] ---[ end trace f604eb1acacd978b ]---
Reproducer:
tc qdisc add dev lo handle 1:0 root dsmark indices 64 set_tc_index
tc filter add dev lo parent 1:0 protocol ip prio 1 tcindex mask 0xfc shift 2
tc qdisc add dev lo parent 1:0 handle 2:0 cbq bandwidth 10Mbit cell 8 avpkt 1000 mpu 64
tc class add dev lo parent 2:0 classid 2:1 cbq bandwidth 10Mbit rate 1500Kbit avpkt 1000 prio 1 bounded isolated allot 1514 weight 1 maxburst 10
tc filter add dev lo parent 2:0 protocol ip prio 1 handle 0x2e tcindex classid 2:1 pass_on
tc qdisc add dev lo parent 2:1 pfifo limit 5
tc qdisc del dev lo root
This is because in tcindex_set_parms, when there is no old_r, we set new
exts to cr.exts. And we didn't set it to filter when r == &new_filter_result.
Then in tcindex_delete() -> tcf_exts_get_net(), we will get NULL pointer
dereference as we didn't init exts.
Fix it by moving tcf_exts_change() after "if (old_r && old_r != r)" check.
Then we don't need "cr" as there is no errout after that.
Fixes: bf63ac73b3e13 ("net_sched: fix an oops in tcindex filter")
[ Upstream commit 008369dcc5f7bfba526c98054f8525322acf0ea3 ]
Li Shuang reported the following warn:
[ 733.484610] WARNING: CPU: 6 PID: 21123 at net/sched/sch_cbq.c:1418 cbq_destroy_class+0x5d/0x70 [sch_cbq]
[ 733.495190] Modules linked in: sch_cbq cls_tcindex sch_dsmark rpcsec_gss_krb5 auth_rpcgss nfsv4 dns_resolver nfs lockd grace fscache xt_CHECKSUM iptable_mangle ipt_MASQUERADE iptable_nat l
[ 733.574155] syscopyarea sysfillrect sysimgblt fb_sys_fops ttm drm igb ixgbe ahci libahci i2c_algo_bit libata i40e i2c_core dca mdio megaraid_sas dm_mirror dm_region_hash dm_log dm_mod
[ 733.592500] CPU: 6 PID: 21123 Comm: tc Not tainted 4.18.0-rc8.latest+ #131
[ 733.600169] Hardware name: Dell Inc. PowerEdge R730/0WCJNT, BIOS 2.1.5 04/11/2016
[ 733.608518] RIP: 0010:cbq_destroy_class+0x5d/0x70 [sch_cbq]
[ 733.614734] Code: e7 d9 d2 48 8b 7b 48 e8 61 05 da d2 48 8d bb f8 00 00 00 e8 75 ae d5 d2 48 39 eb 74 0a 48 89 df 5b 5d e9 16 6c 94 d2 5b 5d c3 <0f> 0b eb b6 0f 1f 44 00 00 66 2e 0f 1f 84
[ 733.635798] RSP: 0018:ffffbfbb066bb9d8 EFLAGS: 00010202
[ 733.641627] RAX: 0000000000000001 RBX: ffff9cdd17392800 RCX: 000000008010000f
[ 733.649588] RDX: ffff9cdd1df547e0 RSI: ffff9cdd17392800 RDI: ffff9cdd0f84c800
[ 733.657547] RBP: ffff9cdd0f84c800 R08: 0000000000000001 R09: 0000000000000000
[ 733.665508] R10: ffff9cdd0f84d000 R11: 0000000000000001 R12: 0000000000000001
[ 733.673469] R13: 0000000000000000 R14: 0000000000000001 R15: ffff9cdd17392200
[ 733.681430] FS: 00007f911890a740(0000) GS:ffff9cdd1f8c0000(0000) knlGS:0000000000000000
[ 733.690456] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 733.696864] CR2: 0000000000b5544c CR3: 0000000859374002 CR4: 00000000001606e0
[ 733.704826] Call Trace:
[ 733.707554] cbq_destroy+0xa1/0xd0 [sch_cbq]
[ 733.712318] qdisc_destroy+0x62/0x130
[ 733.716401] dsmark_destroy+0x2a/0x70 [sch_dsmark]
[ 733.721745] qdisc_destroy+0x62/0x130
[ 733.725829] qdisc_graft+0x3ba/0x470
[ 733.729817] tc_get_qdisc+0x2a6/0x2c0
[ 733.733901] ? cred_has_capability+0x7d/0x130
[ 733.738761] rtnetlink_rcv_msg+0x263/0x2d0
[ 733.743330] ? rtnl_calcit.isra.30+0x110/0x110
[ 733.748287] netlink_rcv_skb+0x4d/0x130
[ 733.752576] netlink_unicast+0x1a3/0x250
[ 733.756949] netlink_sendmsg+0x2ae/0x3a0
[ 733.761324] sock_sendmsg+0x36/0x40
[ 733.765213] ___sys_sendmsg+0x26f/0x2d0
[ 733.769493] ? handle_pte_fault+0x586/0xdf0
[ 733.774158] ? __handle_mm_fault+0x389/0x500
[ 733.778919] ? __sys_sendmsg+0x5e/0xa0
[ 733.783099] __sys_sendmsg+0x5e/0xa0
[ 733.787087] do_syscall_64+0x5b/0x180
[ 733.791171] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 733.796805] RIP: 0033:0x7f9117f23f10
[ 733.800791] Code: c3 48 8b 05 82 6f 2c 00 f7 db 64 89 18 48 83 cb ff eb dd 0f 1f 80 00 00 00 00 83 3d 8d d0 2c 00 00 75 10 b8 2e 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8
[ 733.821873] RSP: 002b:00007ffe96818398 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
[ 733.830319] RAX: ffffffffffffffda RBX: 000000005b71244c RCX: 00007f9117f23f10
[ 733.838280] RDX: 0000000000000000 RSI: 00007ffe968183e0 RDI: 0000000000000003
[ 733.846241] RBP: 00007ffe968183e0 R08: 000000000000ffff R09: 0000000000000003
[ 733.854202] R10: 00007ffe96817e20 R11: 0000000000000246 R12: 0000000000000000
[ 733.862161] R13: 0000000000662ee0 R14: 0000000000000000 R15: 0000000000000000
[ 733.870121] ---[ end trace 28edd4aad712ddca ]---
This is because we didn't update f->result.res when create new filter. Then in
tcindex_delete() -> tcf_unbind_filter(), we will failed to find out the res
and unbind filter, which will trigger the WARN_ON() in cbq_destroy_class().
Fix it by updating f->result.res when create new filter.
Fixes: 6e0565697a106 ("net_sched: fix another crash in cls_tcindex")
[ Upstream commit 82a40777de12728dedf4075453b694f0d1baee80 ]
According to RFC791, 68 bytes is the minimum size of IPv4 datagram every
device must be able to forward without further fragmentation while 576
bytes is the minimum size of IPv4 datagram every device has to be able
to receive, so in ip6_tnl_xmit(), 68(IPV4_MIN_MTU) should be the right
value for the ipv4 min mtu check in ip6_tnl_xmit.
While at it, change to use max() instead of if statement.
Fixes: c9fefa08190f ("ip6_tunnel: get the min mtu properly in ip6_tnl_xmit")
Reported-by: Sabrina Dubroca <sd@queasysnail.net>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit 455f05ecd2b219e9a216050796d30c830d9bc393 ]
syzbot reported that we reinitialize an active delayed
work in vsock_stream_connect():
ODEBUG: init active (active state 0) object type: timer_list hint:
delayed_work_timer_fn+0x0/0x90 kernel/workqueue.c:1414
WARNING: CPU: 1 PID: 11518 at lib/debugobjects.c:329
debug_print_object+0x16a/0x210 lib/debugobjects.c:326
The pattern is apparently wrong, we should only initialize
the dealyed work once and could repeatly schedule it. So we
have to move out the initializations to allocation side.
And to avoid confusion, we can split the shared dwork
into two, instead of re-using the same one.
Fixes: d021c344051a ("VSOCK: Introduce VM Sockets")
Reported-by: <syzbot+8a9b1bd330476a4f3db6@syzkaller.appspotmail.com>
Cc: Andy king <acking@vmware.com>
Cc: Stefan Hajnoczi <stefanha@redhat.com>
Cc: Jorgen Hansen <jhansen@vmware.com>
[ Upstream commit 0dcb82254d65f72333aa50ad626d1e9665ad093b ]
llc_sap_put() decreases the refcnt before deleting sap
from the global list. Therefore, there is a chance
llc_sap_find() could find a sap with zero refcnt
in this global list.
Close this race condition by checking if refcnt is zero
or not in llc_sap_find(), if it is zero then it is being
removed so we can just treat it as gone.
Reported-by: <syzbot+278893f3f7803871f7ce@syzkaller.appspotmail.com>
[ Upstream commit 6d37fa49da1e8db8fb1995be22ac837ca41ac8a8 ]
In l2tp code, if it is a L2TP_UDP_ENCAP tunnel, tunnel->sk points to a
UDP socket. User could call sendmsg() on both this tunnel and the UDP
socket itself concurrently. As l2tp_xmit_skb() holds socket lock and call
__sk_dst_check() to refresh sk->sk_dst_cache, while udpv6_sendmsg() is
lockless and call sk_dst_check() to refresh sk->sk_dst_cache, there
could be a race and cause the dst cache to be freed multiple times.
So we fix l2tp side code to always call sk_dst_check() to garantee
xchg() is called when refreshing sk->sk_dst_cache to avoid race
conditions.
Syzkaller reported stack trace:
BUG: KASAN: use-after-free in atomic_read include/asm-generic/atomic-instrumented.h:21 [inline]
BUG: KASAN: use-after-free in atomic_fetch_add_unless include/linux/atomic.h:575 [inline]
BUG: KASAN: use-after-free in atomic_add_unless include/linux/atomic.h:597 [inline]
BUG: KASAN: use-after-free in dst_hold_safe include/net/dst.h:308 [inline]
BUG: KASAN: use-after-free in ip6_hold_safe+0xe6/0x670 net/ipv6/route.c:1029
Read of size 4 at addr ffff8801aea9a880 by task syz-executor129/4829
CPU: 0 PID: 4829 Comm: syz-executor129 Not tainted 4.18.0-rc7-next-20180802+ #30
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x1c9/0x2b4 lib/dump_stack.c:113
print_address_description+0x6c/0x20b mm/kasan/report.c:256
kasan_report_error mm/kasan/report.c:354 [inline]
kasan_report.cold.7+0x242/0x30d mm/kasan/report.c:412
check_memory_region_inline mm/kasan/kasan.c:260 [inline]
check_memory_region+0x13e/0x1b0 mm/kasan/kasan.c:267
kasan_check_read+0x11/0x20 mm/kasan/kasan.c:272
rt6_get_pcpu_route net/ipv6/route.c:1249 [inline]
ip6_pol_route+0x354/0xd20 net/ipv6/route.c:1922
ip6_pol_route_output+0x54/0x70 net/ipv6/route.c:2098
fib6_rule_lookup+0x283/0x890 net/ipv6/fib6_rules.c:122
ip6_route_output_flags+0x2c5/0x350 net/ipv6/route.c:2126
ip6_dst_lookup_tail+0x1278/0x1da0 net/ipv6/ip6_output.c:978
ip6_dst_lookup_flow+0xc8/0x270 net/ipv6/ip6_output.c:1079
ip6_sk_dst_lookup_flow+0x5ed/0xc50 net/ipv6/ip6_output.c:1117
udpv6_sendmsg+0x2163/0x36b0 net/ipv6/udp.c:1354
inet_sendmsg+0x1a1/0x690 net/ipv4/af_inet.c:798
sock_sendmsg_nosec net/socket.c:622 [inline]
sock_sendmsg+0xd5/0x120 net/socket.c:632
___sys_sendmsg+0x51d/0x930 net/socket.c:2115
__sys_sendmmsg+0x240/0x6f0 net/socket.c:2210
__do_sys_sendmmsg net/socket.c:2239 [inline]
__se_sys_sendmmsg net/socket.c:2236 [inline]
__x64_sys_sendmmsg+0x9d/0x100 net/socket.c:2236
do_syscall_64+0x1b9/0x820 arch/x86/entry/common.c:290
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x446a29
Code: e8 ac b8 02 00 48 83 c4 18 c3 0f 1f 80 00 00 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 eb 08 fc ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f4de5532db8 EFLAGS: 00000246 ORIG_RAX: 0000000000000133
RAX: ffffffffffffffda RBX: 00000000006dcc38 RCX: 0000000000446a29
RDX: 00000000000000b8 RSI: 0000000020001b00 RDI: 0000000000000003
RBP: 00000000006dcc30 R08: 00007f4de5533700 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00000000006dcc3c
R13: 00007ffe2b830fdf R14: 00007f4de55339c0 R15: 0000000000000001
Fixes: 71b1391a4128 ("l2tp: ensure sk->dst is still valid")
Reported-by: syzbot+05f840f3b04f211bad55@syzkaller.appspotmail.com
Signed-off-by: Wei Wang <weiwan@google.com>
Signed-off-by: Martin KaFai Lau <kafai@fb.com>
Cc: Guillaume Nault <g.nault@alphalink.fr>
Cc: David Ahern <dsahern@gmail.com>
Cc: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit 61ef4b07fcdc30535889990cf4229766502561cf ]
The shift of 'cwnd' with '(now - hc->tx_lsndtime) / hc->tx_rto' value
can lead to undefined behavior [1].
In order to fix this use a gradual shift of the window with a 'while'
loop, similar to what tcp_cwnd_restart() is doing.
When comparing delta and RTO there is a minor difference between TCP
and DCCP, the last one also invokes dccp_cwnd_restart() and reduces
'cwnd' if delta equals RTO. That case is preserved in this change.
[1]:
[40850.963623] UBSAN: Undefined behaviour in net/dccp/ccids/ccid2.c:237:7
[40851.043858] shift exponent 67 is too large for 32-bit type 'unsigned int'
[40851.127163] CPU: 3 PID: 15940 Comm: netstress Tainted: G W E 4.18.0-rc7.x86_64 #1
[40851.377176] Call Trace:
[40851.408503] dump_stack+0xf1/0x17b
[40851.451331] ? show_regs_print_info+0x5/0x5
[40851.503555] ubsan_epilogue+0x9/0x7c
[40851.548363] __ubsan_handle_shift_out_of_bounds+0x25b/0x2b4
[40851.617109] ? __ubsan_handle_load_invalid_value+0x18f/0x18f
[40851.686796] ? xfrm4_output_finish+0x80/0x80
[40851.739827] ? lock_downgrade+0x6d0/0x6d0
[40851.789744] ? xfrm4_prepare_output+0x160/0x160
[40851.845912] ? ip_queue_xmit+0x810/0x1db0
[40851.895845] ? ccid2_hc_tx_packet_sent+0xd36/0x10a0 [dccp]
[40851.963530] ccid2_hc_tx_packet_sent+0xd36/0x10a0 [dccp]
[40852.029063] dccp_xmit_packet+0x1d3/0x720 [dccp]
[40852.086254] dccp_write_xmit+0x116/0x1d0 [dccp]
[40852.142412] dccp_sendmsg+0x428/0xb20 [dccp]
[40852.195454] ? inet_dccp_listen+0x200/0x200 [dccp]
[40852.254833] ? sched_clock+0x5/0x10
[40852.298508] ? sched_clock+0x5/0x10
[40852.342194] ? inet_create+0xdf0/0xdf0
[40852.388988] sock_sendmsg+0xd9/0x160
Fixes: 113ced1f52e5 ("dccp ccid-2: Perform congestion-window validation")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
commit f19f5c49bbc3ffcc9126cc245fc1b24cc29f4a37 upstream.
It turns out that we should *not* invert all not-present mappings,
because the all zeroes case is obviously special.
clear_page() does not undergo the XOR logic to invert the address bits,
i.e. PTE, PMD and PUD entries that have not been individually written
will have val=0 and so will trigger __pte_needs_invert(). As a result,
{pte,pmd,pud}_pfn() will return the wrong PFN value, i.e. all ones
(adjusted by the max PFN mask) instead of zero. A zeroed entry is ok
because the page at physical address 0 is reserved early in boot
specifically to mitigate L1TF, so explicitly exempt them from the
inversion when reading the PFN.
Manifested as an unexpected mprotect(..., PROT_NONE) failure when called
on a VMA that has VM_PFNMAP and was mmap'd to as something other than
PROT_NONE but never used. mprotect() sends the PROT_NONE request down
prot_none_walk(), which walks the PTEs to check the PFNs.
prot_none_pte_entry() gets the bogus PFN from pte_pfn() and returns
-EACCES because it thinks mprotect() is trying to adjust a high MMIO
address.
[ This is a very modified version of Sean's original patch, but all
credit goes to Sean for doing this and also pointing out that
sometimes the __pte_needs_invert() function only gets the protection
bits, not the full eventual pte. But zero remains special even in
just protection bits, so that's ok. - Linus ]
Fixes: f22cc87f6c1f ("x86/speculation/l1tf: Invert all not present mappings")
Signed-off-by: Sean Christopherson <sean.j.christopherson@intel.com>
Acked-by: Andi Kleen <ak@linux.intel.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Michal Hocko <mhocko@suse.com>
commit 5e0fb5df2ee871b841f96f9cb6a7f2784e96aa4e upstream.
ioremap() calls pud_free_pmd_page() / pmd_free_pte_page() when it creates
a pud / pmd map. The following preconditions are met at their entry.
- All pte entries for a target pud/pmd address range have been cleared.
- System-wide TLB purges have been peformed for a target pud/pmd address
range.
The preconditions assure that there is no stale TLB entry for the range.
Speculation may not cache TLB entries since it requires all levels of page
entries, including ptes, to have P & A-bits set for an associated address.
However, speculation may cache pud/pmd entries (paging-structure caches)
when they have P-bit set.
Add a system-wide TLB purge (INVLPG) to a single page after clearing
pud/pmd entry's P-bit.
SDM 4.10.4.1, Operation that Invalidate TLBs and Paging-Structure Caches,
states that:
INVLPG invalidates all paging-structure caches associated with the
current PCID regardless of the liner addresses to which they correspond.
Fixes: 28ee90fe6048 ("x86/mm: implement free pmd/pte page interfaces")
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: mhocko@suse.com
Cc: akpm@linux-foundation.org
Cc: hpa@zytor.com
Cc: cpandya@codeaurora.org
Cc: Joerg Roedel <joro@8bytes.org>
Link: https://lkml.kernel.org/r/20180627141348.21777-4-toshi.kani@hpe.com
commit 785a19f9d1dd8a4ab2d0633be4656653bd3de1fc upstream.
The following kernel panic was observed on ARM64 platform due to a stale
TLB entry.
1. ioremap with 4K size, a valid pte page table is set.
2. iounmap it, its pte entry is set to 0.
3. ioremap the same address with 2M size, update its pmd entry with
a new value.
4. CPU may hit an exception because the old pmd entry is still in TLB,
which leads to a kernel panic.
Commit b6bdb7517c3d ("mm/vmalloc: add interfaces to free unmapped page
table") has addressed this panic by falling to pte mappings in the above
case on ARM64.
To support pmd mappings in all cases, TLB purge needs to be performed
in this case on ARM64.
Add a new arg, 'addr', to pud_free_pmd_page() and pmd_free_pte_page()
so that TLB purge can be added later in seprate patches.
[toshi.kani@hpe.com: merge changes, rewrite patch description]
Signed-off-by: Chintan Pandya <cpandya@codeaurora.org>
Cc: mhocko@suse.com
Cc: hpa@zytor.com
Link: https://lkml.kernel.org/r/20180627141348.21777-3-toshi.kani@hpe.com
commit 7992c18810e568b95c869b227137a2215702a805 upstream.
CVE-2018-9363
The buffer length is unsigned at all layers, but gets cast to int and
checked in hidp_process_report and can lead to a buffer overflow.
Switch len parameter to unsigned int to resolve issue.
This affects 3.18 and newer kernels.
Signed-off-by: Mark Salyzyn <salyzyn@android.com>
Fixes: a4b1b5877b514b276f0f31efe02388a9c2836728 ("HID: Bluetooth: hidp: make sure input buffers are big enough")
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Cc: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Cc: linux-bluetooth@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: security@kernel.org
Cc: kernel-team@android.com
commit 3bbda5a38601f7675a214be2044e41d7749e6c7b upstream.
If the ts3a227e audio accessory detection hardware is present and its
driver probed, the jack needs to be created before enabling jack
detection in the ts3a227e driver. With this patch, the jack is
instantiated in the max98090 headset init function if the ts3a227e is
present. This fixes a null pointer dereference as the jack detection
enabling function in the ts3a driver was called before the jack is
created.
[minor correction to keep error handling on jack creation the same
as before by Pierre Bossart]
Signed-off-by: Thierry Escande <thierry.escande@collabora.com>
Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Acked-By: Vinod Koul <vinod.koul@intel.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit 318abdfbe708aaaa652c79fb500e9bd60521f9dc upstream.
Like the skcipher_walk and blkcipher_walk cases:
scatterwalk_done() is only meant to be called after a nonzero number of
bytes have been processed, since scatterwalk_pagedone() will flush the
dcache of the *previous* page. But in the error case of
ablkcipher_walk_done(), e.g. if the input wasn't an integer number of
blocks, scatterwalk_done() was actually called after advancing 0 bytes.
This caused a crash ("BUG: unable to handle kernel paging request")
during '!PageSlab(page)' on architectures like arm and arm64 that define
ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE, provided that the input was
page-aligned as in that case walk->offset == 0.
Fix it by reorganizing ablkcipher_walk_done() to skip the
scatterwalk_advance() and scatterwalk_done() if an error has occurred.
Reported-by: Liu Chao <liuchao741@huawei.com>
Fixes: bf06099db18a ("crypto: skcipher - Add ablkcipher_walk interfaces")
Cc: <stable@vger.kernel.org> # v2.6.35+
commit 0868def3e4100591e7a1fdbf3eed1439cc8f7ca3 upstream.
Like the skcipher_walk case:
Fix it by reorganizing blkcipher_walk_done() to skip the
This bug was found by syzkaller fuzzing.
Reproducer, assuming ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE:
#include <linux/if_alg.h>
#include <sys/socket.h>
#include <unistd.h>
int main()
struct sockaddr_alg addr = {
.salg_type = "skcipher",
.salg_name = "ecb(aes-generic)",
char buffer[4096] __attribute__((aligned(4096))) = { 0 };
int fd;
fd = socket(AF_ALG, SOCK_SEQPACKET, 0);
bind(fd, (void *)&addr, sizeof(addr));
setsockopt(fd, SOL_ALG, ALG_SET_KEY, buffer, 16);
fd = accept(fd, NULL, NULL);
write(fd, buffer, 15);
read(fd, buffer, 15);
Fixes: 5cde0af2a982 ("[CRYPTO] cipher: Added block cipher type")
Cc: <stable@vger.kernel.org> # v2.6.19+
commit bb29648102335586e9a66289a1d98a0cb392b6e5 upstream.
syzbot reported a crash in vmac_final() when multiple threads
concurrently use the same "vmac(aes)" transform through AF_ALG. The bug
is pretty fundamental: the VMAC template doesn't separate per-request
state from per-tfm (per-key) state like the other hash algorithms do,
but rather stores it all in the tfm context. That's wrong.
Also, vmac_final() incorrectly zeroes most of the state including the
derived keys and cached pseudorandom pad. Therefore, only the first
VMAC invocation with a given key calculates the correct digest.
Fix these bugs by splitting the per-tfm state from the per-request state
and using the proper init/update/final sequencing for requests.
Reproducer for the crash:
#include <unistd.h>
int main()
int fd;
.salg_type = "hash",
.salg_name = "vmac(aes)",
char buf[256] = { 0 };
setsockopt(fd, SOL_ALG, ALG_SET_KEY, buf, 16);
fork();
for (;;)
write(fd, buf, 256);
The immediate cause of the crash is that vmac_ctx_t.partial_size exceeds
VMAC_NHBYTES, causing vmac_final() to memset() a negative length.
Reported-by: syzbot+264bca3a6e8d645550d3@syzkaller.appspotmail.com
Fixes: f1939f7c5645 ("crypto: vmac - New hash algorithm for intel_txt support")
Cc: <stable@vger.kernel.org> # v2.6.32+
commit 73bf20ef3df262026c3470241ae4ac8196943ffa upstream.
The VMAC template assumes the block cipher has a 128-bit block size, but
it failed to check for that. Thus it was possible to instantiate it
using a 64-bit block size cipher, e.g. "vmac(cast5)", causing
uninitialized memory to be used.
Add the needed check when instantiating the template.
commit af839b4e546613aed1fbd64def73956aa98631e7 upstream.
There is a copy-paste error where sha256_mb_mgr_get_comp_job_avx2()
copies the SHA-256 digest state from sha256_mb_mgr::args::digest to
job_sha256::result_digest. Consequently, the sha256_mb algorithm
sometimes calculates the wrong digest. Fix it.
Reproducer using AF_ALG:
#include <assert.h>
#include <stdio.h>
#include <string.h>
#include <unistd.h>
static const __u8 expected[32] =
"\xad\x7f\xac\xb2\x58\x6f\xc6\xe9\x66\xc0\x04\xd7\xd1\xd1\x6b\x02"
"\x4f\x58\x05\xff\x7c\xb4\x7c\x7a\x85\xda\xbd\x8b\x48\x89\x2c\xa7";
int main()
int fd;
.salg_name = "sha256_mb",
__u8 data[4096] = { 0 };
__u8 digest[32];
int ret;
int i;
fork();
fd = accept(fd, 0, 0);
do {
ret = write(fd, data, 4096);
assert(ret == 4096);
ret = read(fd, digest, 32);
assert(ret == 32);
} while (memcmp(digest, expected, 32) == 0);
printf("wrong digest: ");
for (i = 0; i < 32; i++)
printf("%02x", digest[i]);
printf("\n");
Output was:
wrong digest: ad7facb2000000000000000000000000ffffffef7cb47c7a85dabd8b48892ca7
Fixes: 172b1d6b5a93 ("crypto: sha256-mb - fix ctx pointer and digest copy")
Cc: <stable@vger.kernel.org> # v4.8+
commit 934193a654c1f4d0643ddbf4b2529b508cae926e upstream.
Verify that 'depmod' ($DEPMOD) is installed.
This is a partial revert of commit 620c231c7a7f
("kbuild: do not check for ancient modutils tools").
Also update Documentation/process/changes.rst to refer to
kmod instead of module-init-tools.
Fixes kernel bugzilla #198965:
https://bugzilla.kernel.org/show_bug.cgi?id=198965
Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi>
Cc: Lucas De Marchi <lucas.de.marchi@gmail.com>
Cc: Michal Marek <michal.lkml@markovi.net>
Cc: Jessica Yu <jeyu@kernel.org>
Cc: Chih-Wei Huang <cwhuang@linux.org.tw>
Cc: stable@vger.kernel.org # any kernel since 2012
commit 17e83549e199d89aace7788a9f11c108671eecf5 upstream.
Fix the following kernel bug:
kernel BUG at drivers/iommu/intel-iommu.c:3260!
invalid opcode: 0000 [#5] PREEMPT SMP
Hardware name: Intel Corp. Harcuvar/Server, BIOS HAVLCRB0.X64.0013.D39.1608311820 08/31/2016
task: ffff880175389950 ti: ffff880176bec000 task.ti: ffff880176bec000
RIP: 0010:[<ffffffff8150a83b>] [<ffffffff8150a83b>] intel_unmap+0x25b/0x260
RSP: 0018:ffff880176bef5e8 EFLAGS: 00010296
RAX: 0000000000000024 RBX: ffff8800773c7c88 RCX: 000000000000ce04
RDX: 0000000080000000 RSI: 0000000000000000 RDI: 0000000000000009
RBP: ffff880176bef638 R08: 0000000000000010 R09: 0000000000000004
R10: ffff880175389c78 R11: 0000000000000a4f R12: ffff8800773c7868
R13: 00000000ffffac88 R14: ffff8800773c7818 R15: 0000000000000001
FS: 00007fef21258700(0000) GS:ffff88017b5c0000(0000) knlGS:0000000000000000
CR2: 000000000066d6d8 CR3: 000000007118c000 CR4: 00000000003406e0
Stack:
00000000ffffac88 ffffffff8199867f ffff880176bef5f8 ffff880100000030
ffff880176bef668 ffff8800773c7c88 ffff880178288098 ffff8800772c0010
ffff8800773c7818 0000000000000001 ffff880176bef648 ffffffff8150a86e
Call Trace:
[<ffffffff8199867f>] ? printk+0x46/0x48
[<ffffffff8150a86e>] intel_unmap_page+0xe/0x10
[<ffffffffa039d99b>] ismt_access+0x27b/0x8fa [i2c_ismt]
[<ffffffff81554420>] ? __pm_runtime_suspend+0xa0/0xa0
[<ffffffff815544a0>] ? pm_suspend_timer_fn+0x80/0x80
[<ffffffff8143dfd0>] ? pci_bus_read_dev_vendor_id+0xf0/0xf0
[<ffffffff8172b36c>] i2c_smbus_xfer+0xec/0x4b0
[<ffffffff810aa4d5>] ? vprintk_emit+0x345/0x530
[<ffffffffa038936b>] i2cdev_ioctl_smbus+0x12b/0x240 [i2c_dev]
[<ffffffff810aa829>] ? vprintk_default+0x29/0x40
[<ffffffffa0389b33>] i2cdev_ioctl+0x63/0x1ec [i2c_dev]
[<ffffffff811b04c8>] do_vfs_ioctl+0x328/0x5d0
[<ffffffff8119d8ec>] ? vfs_write+0x11c/0x190
[<ffffffff8109d449>] ? rt_up_read+0x19/0x20
[<ffffffff811b07f1>] SyS_ioctl+0x81/0xa0
[<ffffffff819a351b>] system_call_fastpath+0x16/0x6e
This happen When run "i2cdetect -y 0" detect SMBus iSMT adapter.
After finished I2C block read/write, when unmap the data buffer,
a wrong device address was pass to dma_unmap_single().
To fix this, give dma_unmap_single() the "dev" parameter, just like
what dma_map_single() does, then unmap can find the right devices.
Fixes: 13f35ac14cd0 ("i2c: Adding support for Intel iSMT SMBus 2.0 host controller")
Signed-off-by: Liwei Song <liwei.song@windriver.com>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit 0e410e158e5baa1300bdf678cea4f4e0cf9d8b94 upstream.
With KASAN enabled the kernel has two different memset() functions, one
with KASAN checks (memset) and one without (__memset). KASAN uses some
macro tricks to use the proper version where required. For example
memset() calls in mm/slub.c are without KASAN checks, since they operate
on poisoned slab object metadata.
The issue is that clang emits memset() calls even when there is no
memset() in the source code. They get linked with improper memset()
implementation and the kernel fails to boot due to a huge amount of KASAN
reports during early boot stages.
The solution is to add -fno-builtin flag for files with KASAN_SANITIZE :=
n marker.
Link: http://lkml.kernel.org/r/8ffecfffe04088c52c42b92739c2bd8a0bcb3f5e.1516384594.git.andreyknvl@google.com
Signed-off-by: Andrey Konovalov <andreyknvl@google.com>
Acked-by: Nick Desaulniers <ndesaulniers@google.com>
[ Sami: Backported to 4.9 avoiding c5caf21ab0cf8 and e7c52b84fb ]
Signed-off-by: Sami Tolvanen <samitolvanen@google.com>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
commit f967db0b9ed44ec3057a28f3b28efc51df51b835 upstream.
ioremap() supports pmd mappings on x86-PAE. However, kernel's pmd
tables are not shared among processes on x86-PAE. Therefore, any
update to sync'd pmd entries need re-syncing. Freeing a pte page
also leads to a vmalloc fault and hits the BUG_ON in vmalloc_sync_one().
Disable free page handling on x86-PAE. pud_free_pmd_page() and
pmd_free_pte_page() simply return 0 if a given pud/pmd entry is present.
This assures that ioremap() does not update sync'd pmd entries at the
cost of falling back to pte mappings.
Reported-by: Joerg Roedel <joro@8bytes.org>
Cc: mhocko@suse.com
Cc: hpa@zytor.com
Link: https://lkml.kernel.org/r/20180627141348.21777-2-toshi.kani@hpe.com
commit 0a957467c5fd46142bc9c52758ffc552d4c5e2f7 upstream.
i8259.h uses inb/outb and thus needs to include asm/io.h to avoid the
following build error, as seen with x86_64:defconfig and CONFIG_SMP=n.
In file included from drivers/rtc/rtc-cmos.c:45:0:
arch/x86/include/asm/i8259.h: In function 'inb_pic':
arch/x86/include/asm/i8259.h:32:24: error:
implicit declaration of function 'inb'
arch/x86/include/asm/i8259.h: In function 'outb_pic':
arch/x86/include/asm/i8259.h:45:2: error:
implicit declaration of function 'outb'
Reported-by: Sebastian Gottschall <s.gottschall@dd-wrt.com>
Suggested-by: Sebastian Gottschall <s.gottschall@dd-wrt.com>
Fixes: 447ae3166702 ("x86: Don't include linux/irq.h from asm/hardirq.h")
commit 1eb46908b35dfbac0ec1848d4b1e39667e0187e9 upstream.
allmodconfig+CONFIG_INTEL_KVM=n results in the following build error.
ERROR: "l1tf_vmx_mitigation" [arch/x86/kvm/kvm.ko] undefined!
Fixes: 5b76a3cff011 ("KVM: VMX: Tell the nested hypervisor to skip L1D flush on vmentry")
Reported-by: Meelis Roos <mroos@linux.ee>
Cc: Meelis Roos <mroos@linux.ee>
commit f8b64d08dde2714c62751d18ba77f4aeceb161d3 upstream.
Move smp_num_siblings and cpu_llc_id to cpu/common.c so that they're
always present as symbols and not only in the CONFIG_SMP case. Then,
other code using them doesn't need ugly ifdeffery anymore. Get rid of
some ifdeffery.
Signed-off-by: Borislav Petkov <bpetkov@suse.de>
Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
Link: http://lkml.kernel.org/r/1524864877-111962-2-git-send-email-suravee.suthikulpanit@amd.com
commit b89b41d0b8414690ec0030c134b8bde209e6d06c upstream.
Current cpu_core_id fixup causes downcored F17h configurations to be
incorrect:
NODE: 0
processor 0 core id : 0
processor 1 core id : 1
processor 2 core id : 2
processor 3 core id : 4
processor 4 core id : 5
processor 5 core id : 0
NODE: 1
processor 6 core id : 2
processor 7 core id : 3
processor 8 core id : 4
processor 9 core id : 0
processor 10 core id : 1
processor 11 core id : 2
Code that relies on the cpu_core_id, like match_smt(), for example,
which builds the thread siblings masks used by the scheduler, is
mislead.
So, limit the fixup to pre-F17h machines. The new value for cpu_core_id
for F17h and later will represent the CPUID_Fn8000001E_EBX[CoreId],
which is guaranteed to be unique for each core within a socket.
This way we have:
NODE: 0
processor 5 core id : 6
NODE: 1
processor 6 core id : 8
processor 7 core id : 9
processor 8 core id : 10
processor 9 core id : 12
processor 10 core id : 13
processor 11 core id : 14
[ Heavily massaged. ]
Cc: Yazen Ghannam <Yazen.Ghannam@amd.com>
Link: http://lkml.kernel.org/r/20170731085159.9455-2-bp@alien8.de
commit 6c26fcd2abfe0a56bbd95271fce02df2896cfd24 upstream.
pfn_modify_allowed() and arch_has_pfn_modify_check() are outside of the
!__ASSEMBLY__ section in include/asm-generic/pgtable.h, which confuses
assembler on archs that don't have __HAVE_ARCH_PFN_MODIFY_ALLOWED (e.g.
ia64) and breaks build:
include/asm-generic/pgtable.h: Assembler messages:
include/asm-generic/pgtable.h:538: Error: Unknown opcode `static inline bool pfn_modify_allowed(unsigned long pfn,pgprot_t prot)'
include/asm-generic/pgtable.h:540: Error: Unknown opcode `return true'
include/asm-generic/pgtable.h:543: Error: Unknown opcode `static inline bool arch_has_pfn_modify_check(void)'
include/asm-generic/pgtable.h:545: Error: Unknown opcode `return false'
arch/ia64/kernel/entry.S:69: Error: `mov' does not fit into bundle
Move those two static inlines into the !__ASSEMBLY__ section so that they
don't confuse the asm build pass.
Fixes: 42e4089c7890 ("x86/speculation/l1tf: Disallow non privileged high MMIO PROT_NONE mappings")
[groeck: Context changes]
commit 792adb90fa724ce07c0171cbc96b9215af4b1045 upstream.
The introduction of generic_max_swapfile_size and arch-specific versions has
broken linking on x86 with CONFIG_SWAP=n due to undefined reference to
'generic_max_swapfile_size'. Fix it by compiling the x86-specific
max_swapfile_size() only with CONFIG_SWAP=y.
Reported-by: Tomas Pruzina <pruzinat@gmail.com>
Fixes: 377eeaa8e11f ("x86/speculation/l1tf: Limit swap file size to MAX_PA/2")
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
commit 269777aa530f3438ec1781586cdac0b5fe47b061 upstream.
Commit 0cc3cd21657b ("cpu/hotplug: Boot HT siblings at least once")
breaks non-SMP builds.
[ I suspect the 'bool' fields should just be made to be bitfields and be
exposed regardless of configuration, but that's a separate cleanup
that I'll leave to the owners of this file for later. - Linus ]
Fixes: 0cc3cd21657b ("cpu/hotplug: Boot HT siblings at least once")
Signed-off-by: Abel Vesa <abelvesa@linux.com>
