The x86 copy of cpufeatures.h is now out of sync, so fix that.
commit 9dbc8a0328efa485a6f5b68b867f9f523a3fbeff upstream.
Fixes: 8043bb1ae03cb ("crypto: omap-sham - convert driver logic to use sgs for data xmit")
The memory pages freed in omap_sham_finish_req() were less than those
allocated in omap_sham_copy_sgs().
Cc: stable@vger.kernel.org
Signed-off-by: Bin Liu <b-liu@ti.com>
Acked-by: Tero Kristo <t-kristo@ti.com>
commit 1411b5218adbcf1d45ddb260db5553c52e8d917c upstream.
In the vmx AES init routines we do a printk(KERN_INFO ...) to report
the fallback implementation we're using.
However with a slow console this can significantly affect the speed of
crypto operations. Using 'cryptsetup benchmark' the removal of the
printk() leads to a ~5x speedup for aes-cbc decryption.
So remove them.
Fixes: 8676590a1593 ("crypto: vmx - Adding AES routines for VMX module")
Fixes: 8c755ace357c ("crypto: vmx - Adding CBC routines for VMX module")
Fixes: 4f7f60d312b3 ("crypto: vmx - Adding CTR routines for VMX module")
Fixes: cc333cd68dfa ("crypto: vmx - Adding GHASH routines for VMX module")
Cc: stable@vger.kernel.org # v4.1+
commit e6e7e9cd8eed0e18217c899843bffbe8c7dae564 upstream.
Add ELAN0612 to the list of supported touchpads; this ID is used in Lenovo
v330 14IKB devices.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=199253
Signed-off-by: Johannes Wienke <languitar@semipol.de>
commit 5ca4d1ae9bad0f59bd6f851c39b19f5366953666 upstream.
GPD Win 2 Website: http://www.gpd.hk/gpdwin2.asp
Tested on a unit from the first production run sent to Indiegogo backers
Signed-off-by: Ethan Lee <flibitijibibo@gmail.com>
commit 3c9fa24ca7c9c47605672916491f79e8ccacb9e6 upstream.
The functions that were used in the emulation of fxrstor, fxsave, sgdt and
sidt were originally meant for task switching, and as such they did not
check privilege levels. This is very bad when the same functions are used
in the emulation of unprivileged instructions. This is CVE-2018-10853.
The obvious fix is to add a new argument to ops->read_std and ops->write_std,
which decides whether the access is a "system" access or should use the
processor's CPL.
Fixes: 129a72a0d3c8 ("KVM: x86: Introduce segmented_write_std", 2017-01-12)
commit 4a7e625ce50412a7711efa0f2ef0b96ce3826759 upstream.
Commit 9b96fbacda34 ("serial: PL011: clear pending interrupts")
clears the RX and receive timeout interrupts on pl011 startup, to
avoid a screaming-interrupt scenario that can occur when the
firmware or bootloader leaves these interrupts asserted.
This has been noted as an issue when running Linux on qemu [1].
Unfortunately, the above fix seems to lead to potential
misbehaviour if the RX FIFO interrupt is asserted _non_ spuriously
on driver startup, if the RX FIFO is also already full to the
trigger level.
Clearing the RX FIFO interrupt does not change the FIFO fill level.
In this scenario, because the interrupt is now clear and because
the FIFO is already full to the trigger level, no new assertion of
the RX FIFO interrupt can occur unless the FIFO is drained back
below the trigger level. This never occurs because the pl011
driver is waiting for an RX FIFO interrupt to tell it that there is
something to read, and does not read the FIFO at all until that
interrupt occurs.
Thus, simply clearing "spurious" interrupts on startup may be
misguided, since there is no way to be sure that the interrupts are
truly spurious, and things can go wrong if they are not.
This patch instead clears the interrupt condition by draining the
RX FIFO during UART startup, after clearing any potentially
spurious interrupt. This should ensure that an interrupt will
definitely be asserted if the RX FIFO subsequently becomes
sufficiently full.
The drain is done at the point of enabling interrupts only. This
means that it will occur any time the UART is newly opened through
the tty layer. It will not apply to polled-mode use of the UART by
kgdboc: since that scenario cannot use interrupts by design, this
should not matter. kgdboc will interact badly with "normal" use of
the UART in any case: this patch makes no attempt to paper over
such issues.
This patch does not attempt to address the case where the RX FIFO
fills faster than it can be drained: that is a pathological
hardware design problem that is beyond the scope of the driver to
work around. As a failsafe, the number of poll iterations for
draining the FIFO is limited to twice the FIFO size. This will
ensure that the kernel at least boots even if it is impossible to
drain the FIFO for some reason.
[1] [Qemu-devel] [Qemu-arm] [PATCH] pl011: do not put into fifo
before enabled the interruption
https://lists.gnu.org/archive/html/qemu-devel/2018-01/msg06446.html
Reported-by: Wei Xu <xuwei5@hisilicon.com>
Cc: Russell King <linux@armlinux.org.uk>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Peter Maydell <peter.maydell@linaro.org>
Fixes: 9b96fbacda34 ("serial: PL011: clear pending interrupts")
Signed-off-by: Dave Martin <Dave.Martin@arm.com>
Cc: stable <stable@vger.kernel.org>
Tested-by: Wei Xu <xuwei5@hisilicon.com>
commit b23220fe054e92f616b82450fae8cd3ab176cc60 upstream.
The balloon.page field is used for two different purposes if batching is
on or off. If batching is on, the field point to the page which is used
to communicate with with the hypervisor. If it is off, balloon.page
points to the page that is about to be (un)locked.
Unfortunately, this dual-purpose of the field introduced a bug: when the
balloon is popped (e.g., when the machine is reset or the balloon driver
is explicitly removed), the balloon driver frees, unconditionally, the
page that is held in balloon.page. As a result, if batching is
disabled, this leads to double freeing the last page that is sent to the
hypervisor.
The following error occurs during rmmod when kernel checkers are on, and
the balloon is not empty:
[ 42.307653] ------------[ cut here ]------------
[ 42.307657] Kernel BUG at ffffffffba1e4b28 [verbose debug info unavailable]
[ 42.307720] invalid opcode: 0000 [#1] SMP DEBUG_PAGEALLOC
[ 42.312512] Modules linked in: vmw_vsock_vmci_transport vsock ppdev joydev vmw_balloon(-) input_leds serio_raw vmw_vmci parport_pc shpchp parport i2c_piix4 nfit mac_hid autofs4 vmwgfx drm_kms_helper hid_generic syscopyarea sysfillrect usbhid sysimgblt fb_sys_fops hid ttm mptspi scsi_transport_spi ahci mptscsih drm psmouse vmxnet3 libahci mptbase pata_acpi
[ 42.312766] CPU: 10 PID: 1527 Comm: rmmod Not tainted 4.12.0+ #5
[ 42.312803] Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 09/30/2016
[ 42.313042] task: ffff9bf9680f8000 task.stack: ffffbfefc1638000
[ 42.313290] RIP: 0010:__free_pages+0x38/0x40
[ 42.313510] RSP: 0018:ffffbfefc163be98 EFLAGS: 00010246
[ 42.313731] RAX: 000000000000003e RBX: ffffffffc02b9720 RCX: 0000000000000006
[ 42.313972] RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff9bf97e08e0a0
[ 42.314201] RBP: ffffbfefc163be98 R08: 0000000000000000 R09: 0000000000000000
[ 42.314435] R10: 0000000000000000 R11: 0000000000000000 R12: ffffffffc02b97e4
[ 42.314505] R13: ffffffffc02b9748 R14: ffffffffc02b9728 R15: 0000000000000200
[ 42.314550] FS: 00007f3af5fec700(0000) GS:ffff9bf97e080000(0000) knlGS:0000000000000000
[ 42.314599] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 42.314635] CR2: 00007f44f6f4ab24 CR3: 00000003a7d12000 CR4: 00000000000006e0
[ 42.314864] Call Trace:
[ 42.315774] vmballoon_pop+0x102/0x130 [vmw_balloon]
[ 42.315816] vmballoon_exit+0x42/0xd64 [vmw_balloon]
[ 42.315853] SyS_delete_module+0x1e2/0x250
[ 42.315891] entry_SYSCALL_64_fastpath+0x23/0xc2
[ 42.315924] RIP: 0033:0x7f3af5b0e8e7
[ 42.315949] RSP: 002b:00007fffe6ce0148 EFLAGS: 00000206 ORIG_RAX: 00000000000000b0
[ 42.315996] RAX: ffffffffffffffda RBX: 000055be676401e0 RCX: 00007f3af5b0e8e7
[ 42.316951] RDX: 000000000000000a RSI: 0000000000000800 RDI: 000055be67640248
[ 42.317887] RBP: 0000000000000003 R08: 0000000000000000 R09: 1999999999999999
[ 42.318845] R10: 0000000000000883 R11: 0000000000000206 R12: 00007fffe6cdf130
[ 42.319755] R13: 0000000000000000 R14: 0000000000000000 R15: 000055be676401e0
[ 42.320606] Code: c0 74 1c f0 ff 4f 1c 74 02 5d c3 85 f6 74 07 e8 0f d8 ff ff 5d c3 31 f6 e8 c6 fb ff ff 5d c3 48 c7 c6 c8 0f c5 ba e8 58 be 02 00 <0f> 0b 66 0f 1f 44 00 00 66 66 66 66 90 48 85 ff 75 01 c3 55 48
[ 42.323462] RIP: __free_pages+0x38/0x40 RSP: ffffbfefc163be98
[ 42.325735] ---[ end trace 872e008e33f81508 ]---
To solve the bug, we eliminate the dual purpose of balloon.page.
Fixes: f220a80f0c2e ("VMware balloon: add batching to the vmw_balloon.")
Reported-by: Oleksandr Natalenko <onatalen@redhat.com>
Signed-off-by: Gil Kupfer <gilkup@gmail.com>
Signed-off-by: Nadav Amit <namit@vmware.com>
Reviewed-by: Xavier Deguillard <xdeguillard@vmware.com>
Tested-by: Oleksandr Natalenko <oleksandr@redhat.com>
commit 13dc04d0e5fdc25c8f713ad23fdce51cf2bf96ba upstream.
I noticed that unused UARTs won't necessarily idle properly always
unless at least one byte tx transfer is done first.
After some debugging I narrowed down the problem to the scr register
dma configuration bits that need to be set before softreset for the
clocks to idle. Unless we do this, the module clkctrl idlest bits
may be set to 1 instead of 3 meaning the clock will never idle and
is blocking deeper idle states for the whole domain.
This might be related to the configuration done by the bootloader
or kexec booting where certain configurations cause the 8250 or
the clkctrl clock to jam in a way where setting of the scr bits
and reset is needed to clear it. I've tried diffing the 8250
registers for the various modes, but did not see anything specific.
So far I've only seen this on omap4 but I'm suspecting this might
also happen on the other clkctrl using SoCs considering they
already have a quirk enabled for UART_ERRATA_CLOCK_DISABLE.
Let's fix the issue by configuring scr before reset for basic dma
even if we don't use it. The scr register will be reset when we do
softreset few lines after, and we restore scr on resume. We should
do this for all the SoCs with UART_ERRATA_CLOCK_DISABLE quirk flag
set since the ones with UART_ERRATA_CLOCK_DISABLE are all based
using clkctrl similar to omap4.
Looks like both OMAP_UART_SCR_DMAMODE_1 | OMAP_UART_SCR_DMAMODE_CTL
bits are needed for the clkctrl to idle after a softreset.
And we need to add omap4 to also use the UART_ERRATA_CLOCK_DISABLE
for the related workaround to be enabled. This same compatible
value will also be used for omap5.
Fixes: cdb929e4452a ("serial: 8250_omap: workaround errata around idling UART after using DMA")
Cc: Keerthy <j-keerthy@ti.com>
Cc: Matthijs van Duin <matthijsvanduin@gmail.com>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Tero Kristo <t-kristo@ti.com>
commit aa2f80e752c75e593b3820f42c416ed9458fa73e upstream.
The best granularity of residue that DMA engine can report is in the BURST
units, so the serial driver must use MAXBURST = 1 and DMA_SLAVE_BUSWIDTH_1_BYTE
if it relies on exact number of bytes transferred by DMA engine.
Fixes: 62c37eedb74c ("serial: samsung: add dma reqest/release functions")
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
commit 9594b5be7ec110ed11acec58fa94f3f293668c85 upstream.
I was puzzled while looking at /proc/interrupts and random things showed
up between reboots. This occurred more often but I realised it later. The
"correct" output should be:
|38: 11861 atmel-aic5 2 Level ttyS0
but I saw sometimes
|38: 6426 atmel-aic5 2 Level tty1
and accounted it wrongly as correct. This is use after free and the
former example randomly got the "old" pointer which pointed to the same
content. With SLAB_FREELIST_RANDOM and HARDENED I even got
|38: 7067 atmel-aic5 2 Level E=Started User Manager for UID 0
or other nonsense.
As it turns out the tty, pointer that is accessed in atmel_startup(), is
freed() before atmel_shutdown(). It seems to happen quite often that the
tty for ttyS0 is allocated and freed while ->shutdown is not invoked. I
don't do anything special - just a systemd boot :)
Use dev_name(&pdev->dev) as the IRQ name for request_irq(). This exists
as long as the driver is loaded so no use-after-free here.
Fixes: 761ed4a94582 ("tty: serial_core: convert uart_close to use tty_port_close")
Acked-by: Richard Genoud <richard.genoud@gmail.com>
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
commit d63c16f8e1ab761775275adcf54f4bef7c330295 upstream.
Printk format "%pCr" will be removed soon, as clk_get_rate() must not be
called in atomic context.
Replace it by open-coding the operation. This is safe here, as the code
runs in task context.
Link: http://lkml.kernel.org/r/1527845302-12159-4-git-send-email-geert+renesas@glider.be
To: Jia-Ju Bai <baijiaju1990@gmail.com>
To: Jonathan Corbet <corbet@lwn.net>
To: Michael Turquette <mturquette@baylibre.com>
To: Stephen Boyd <sboyd@kernel.org>
To: Zhang Rui <rui.zhang@intel.com>
To: Eduardo Valentin <edubezval@gmail.com>
To: Eric Anholt <eric@anholt.net>
To: Stefan Wahren <stefan.wahren@i2se.com>
To: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
Cc: Petr Mladek <pmladek@suse.com>
Cc: linux-doc@vger.kernel.org
Cc: linux-clk@vger.kernel.org
Cc: linux-pm@vger.kernel.org
Cc: linux-serial@vger.kernel.org
Cc: linux-renesas-soc@vger.kernel.org
Cc: Geert Uytterhoeven <geert+renesas@glider.be>
Cc: stable@vger.kernel.org # 4.5+
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Petr Mladek <pmladek@suse.com>
commit bd6bce004d78b867ba0c6d3712f1c5b50398af9a upstream.
This patch fixes an issue that reconnection is possible to fail
because unexpected state handling happens by the irqs. To fix the issue,
the driver disables the controller's irqs when disconnected.
Fixes: 746bfe63bba3 ("usb: gadget: renesas_usb3: add support for Renesas USB3.0 peripheral controller")
Cc: <stable@vger.kernel.org> # v4.5+
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit ca7d9515d0e6825351ce106066cea1f60e40b1c8 upstream.
The "G-Drive" (sold by G-Technology) external USB 3.0 drive
hangs on write access under UAS and usb-storage:
[ 136.079121] sd 15:0:0:0: [sdi] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 136.079144] sd 15:0:0:0: [sdi] tag#0 Sense Key : Illegal Request [current]
[ 136.079152] sd 15:0:0:0: [sdi] tag#0 Add. Sense: Invalid field in cdb
[ 136.079176] sd 15:0:0:0: [sdi] tag#0 CDB: Write(16) 8a 08 00 00 00 00 00 00 00 00 00 00 00 08 00 00
[ 136.079180] print_req_error: critical target error, dev sdi, sector 0
[ 136.079183] Buffer I/O error on dev sdi, logical block 0, lost sync page write
[ 136.173148] EXT4-fs (sdi): mounted filesystem with ordered data mode. Opts: (null)
[ 140.583998] sd 15:0:0:0: [sdi] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 140.584010] sd 15:0:0:0: [sdi] tag#0 Sense Key : Illegal Request [current]
[ 140.584016] sd 15:0:0:0: [sdi] tag#0 Add. Sense: Invalid field in cdb
[ 140.584022] sd 15:0:0:0: [sdi] tag#0 CDB: Write(16) 8a 08 00 00 00 00 e8 c4 00 18 00 00 00 08 00 00
[ 140.584025] print_req_error: critical target error, dev sdi, sector 3905159192
[ 140.584044] print_req_error: critical target error, dev sdi, sector 3905159192
[ 140.584052] Aborting journal on device sdi-8.
The proposed patch adds compatibility quirks. Because the drive requires two
quirks (one to work with UAS, and another to work with usb-storage), adding this
under unusual_devs.h and not just unusual_uas.h so kernels compiled without UAS
receive the quirk. With the patch, the drive works reliably on UAS and usb-
storage.
(tested on NEC Corporation uPD720200 USB 3.0 host controller).
Signed-off-by: Alexander Kappner <agk@godking.net>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 8c4e97ddfe73a0958bb0abf7e6a3bc4cc3e04936 upstream.
The ALWAYS_SYNC flag is currently honored by the usb-storage driver but not UAS
and is required to work around devices that become unstable upon being
queried for cache. This code is taken straight from:
drivers/usb/storage/scsiglue.c:284
Acked-by: Oliver Neukum <oneukum@suse.com>
commit a0d6ec88090d7b1b008429c44532a388e29bb1bd upstream.
pdev_nr and rhport can be controlled by user-space, hence leading to
a potential exploitation of the Spectre variant 1 vulnerability.
This issue was detected with the help of Smatch:
drivers/usb/usbip/vhci_sysfs.c:238 detach_store() warn: potential spectre issue 'vhcis'
drivers/usb/usbip/vhci_sysfs.c:328 attach_store() warn: potential spectre issue 'vhcis'
drivers/usb/usbip/vhci_sysfs.c:338 attach_store() warn: potential spectre issue 'vhci->vhci_hcd_ss->vdev'
drivers/usb/usbip/vhci_sysfs.c:340 attach_store() warn: potential spectre issue 'vhci->vhci_hcd_hs->vdev'
Fix this by sanitizing pdev_nr and rhport before using them to index
vhcis and vhci->vhci_hcd_ss->vdev respectively.
Notice that given that speculation windows are large, the policy is
to kill the speculation on the first load and not worry if it can be
completed with a dependent load/store [1].
[1] https://marc.info/?l=linux-kernel&m=152449131114778&w=2
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Acked-by: Shuah Khan (Samsung OSG) <shuah@kernel.org>
commit 45ad559a29629cb1c64ee636563c69b71524f077 upstream.
Syzbot reported yet another warning with Ion:
WARNING: CPU: 0 PID: 1467 at drivers/staging/android/ion/ion.c:122
ion_buffer_destroy+0xd4/0x190 drivers/staging/android/ion/ion.c:122
Kernel panic - not syncing: panic_on_warn set ...
This is catching that a buffer was freed with an existing kernel mapping
still present. This can be easily be triggered from userspace by calling
DMA_BUF_SYNC_START without calling DMA_BUF_SYNC_END. Switch to a single
pr_warn_once to indicate the error without being disruptive.
Reported-by: syzbot+cd8bcd40cb049efa2770@syzkaller.appspotmail.com
Reported-by: syzbot <syzkaller@googlegroups.com>
Signed-off-by: Laura Abbott <labbott@redhat.com>
commit ce14e868a54edeb2e30cb7a7b104a2fc4b9d76ca upstream.
Int the next patch the emulator's .read_std and .write_std callbacks will
grow another argument, which is not needed in kvm_read_guest_virt and
kvm_write_guest_virt_system's callers. Since we have to make separate
functions, let's give the currently existing names a nicer interface, too.
commit 79367a65743975e5cac8d24d08eccc7fdae832b0 upstream.
Wrap the common invocation of ctxt->ops->read_std and ctxt->ops->write_std, so
as to have a smaller patch when the functions grow another argument.
commit 7d18f0a14aa6a0d6bad39111c1fb655f07f71d59 upstream.
Sometimes a GPIO is fetched with NULL as parent device, and
that is just fine. So under these circumstances, avoid using
dev_name() to provide a name for the GPIO line.
Cc: Daniel Rosenberg <drosen@google.com>
commit 42819eb7a0957cc340ad4ed8bba736bab5ebc464 upstream.
The merged version of my patch "nvmet: don't report 0-bytes in serial
number" fails to remove two lines which should have been replaced,
so that the space-padded strings are overwritten again with 0-bytes.
Fix it.
Fixes: 42de82a8b544 nvmet: don't report 0-bytes in serial number
Signed-off-by: Martin Wilck <mwilck@suse.com>
Reviewed-by: Sagi Grimberg <sagi@grimbeg.me>
commit 42de82a8b544fa55670feef7d6f85085fba48fc0 upstream.
The NVME standard mandates that the SN, MN, and FR fields of the Identify
Controller Data Structure be "ASCII strings". That means that they may
not contain 0-bytes, not even string terminators.
Reviewed-by: Hannes Reinecke <hare@suse.de>
[hch: fixed for the move of the serial field, updated description]
commit 2e7f5d2af2155084c6f7c86328d36e698cd84954 upstream.
The NVMe specification defines the serial number as:
"Serial Number (SN): Contains the serial number for the NVM subsystem
that is assigned by the vendor as an ASCII string. Refer to section
7.10 for unique identifier requirements. Refer to section 1.5 for ASCII
string requirements"
So move it from the controller to the subsystem, where it belongs.
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
commit 02f39b2379fb81557ae864ec8f85421c0250c954 upstream.
The crypto code was checking both use_eager_fpu() and
defined(X86_FEATURE_EAGER_FPU). The latter was nonsensical, so
remove it. This will avoid breakage when we remove
X86_FEATURE_EAGER_FPU.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Cc: pbonzini@redhat.com
Link: http://lkml.kernel.org/r/1475627678-20788-2-git-send-email-riel@redhat.com
commit 4b66af2d6356a00e94bcdea3e7fea324e8b5c6f4 upstream.
Key extensions (struct sadb_key) include a user-specified number of key
bits. The kernel uses that number to determine how much key data to copy
out of the message in pfkey_msg2xfrm_state().
The length of the sadb_key message must be verified to be long enough,
even in the case of SADB_X_AALG_NULL. Furthermore, the sadb_key_len value
must be long enough to include both the key data and the struct sadb_key
itself.
Introduce a helper function verify_key_len(), and call it from
parse_exthdrs() where other exthdr types are similarly checked for
correctness.
Signed-off-by: Kevin Easton <kevin@guarana.org>
Reported-by: syzbot+5022a34ca5a3d49b84223653fab632dfb7b4cf37@syzkaller.appspotmail.com
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Cc: Zubin Mithra <zsm@chromium.org>
commit 161b8be2bd6abad250d4b3f674bdd5480f15beeb upstream.
A spurious interrupt before the nvme driver has initialized the completion
queue may inadvertently cause the driver to believe it has a completion
to process. This may result in a NULL dereference since the nvmeq's tags
are not set at this point.
The patch initializes the host's CQ memory so that a spurious interrupt
isn't mistaken for a real completion.
Signed-off-by: Keith Busch <keith.busch@intel.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
commit ad729bc9acfb7c47112964b4877ef5404578ed13 upstream.
The patch c4adfc822bf5 ("bonding: make speed, duplex setting consistent
with link state") puts the link state to down if
bond_update_speed_duplex() cannot retrieve speed and duplex settings.
Assumably the patch was written with 802.3ad mode in mind which relies
on link speed/duplex settings. For other modes like active-backup these
settings are not required. Thus, only for these other modes, this patch
reintroduces support for slaves that do not support reporting speed or
duplex such as wireless devices. This fixes the regression reported in
bug 196547 (https://bugzilla.kernel.org/show_bug.cgi?id=196547).
Fixes: c4adfc822bf5 ("bonding: make speed, duplex setting consistent
with link state")
Signed-off-by: Andreas Born <futur.andy@googlemail.com>
Acked-by: Mahesh Bandewar <maheshb@google.com>
Cc: Nate Clark <nate@neworld.us>
commit 3f3c278c94dd994fe0d9f21679ae19b9c0a55292 upstream.
Earlier patch c4adfc822bf5 ("bonding: make speed, duplex setting
consistent with link state") made an attempt to keep slave state
consistent with speed and duplex settings. Unfortunately link-state
transition is used to change the active link especially when used
in conjunction with mii-mon. The above mentioned patch broke that
logic. Also when speed and duplex settings for a link are updated
during a link-event, the link-status should not be changed to
invoke correct transition logic.
This patch fixes this issue by moving the link-state update outside
of the bond_update_speed_duplex() fn and to the places where this fn
is called and update link-state selectively.
with link state")
Signed-off-by: Mahesh Bandewar <maheshb@google.com>
Reviewed-by: Andy Gospodarek <andy@greyhouse.net>
commit b5bf0f5b16b9c316c34df9f31d4be8729eb86845 upstream.
bond_miimon_commit() marks the link UP after attempting to get the speed
and duplex settings for the link. There is a possibility that
bond_update_speed_duplex() could fail. This is another place where it
could result into an inconsistent bonding link state.
With this patch the link will be marked UP only if the speed and duplex
values retrieved have sane values and processed further.
commit ca6938a1cd8a1c5e861a99b67f84ac166fc2b9e7 upstream.
Since commit:
58122bf1d856 ("x86/fpu: Default eagerfpu=on on all CPUs")
... in Linux 4.6, eager FPU mode has been the default on all x86
systems, and no one has reported any regressions.
This patch removes the ability to enable lazy mode: use_eager_fpu()
becomes "return true" and all of the FPU mode selection machinery is
removed.
Link: http://lkml.kernel.org/r/1475627678-20788-3-git-send-email-riel@redhat.com
objtool ports introduced in v4.9.106 were not totally complete. Therefore
they resulted in issues like:
module: overflow in relocation type 10 val XXXXXXXXXXX
‘usbcore’ likely not compiled with -mcmodel=kernel
‘scsi_mod’ likely not compiled with -mcmodel=kernel
Missing part was the complete backport of commit e390f9a.
Original notes by Josh Poimboeuf:
The '__unreachable' and '__func_stack_frame_non_standard' sections are
only used at compile time. They're discarded for vmlinux but they
should also be discarded for modules.
Since this is a recurring pattern, prefix the section names with
".discard.". It's a nice convention and vmlinux.lds.h already discards
such sections.
Also remove the 'a' (allocatable) flag from the __unreachable section
since it doesn't make sense for a discarded section.
Signed-off-by: Philip Müller <philm@manjaro.org>
Fixes: d1091c7fa3d5 ("objtool: Improve detection of BUG() and other dead ends")
Link: https://gitlab.manjaro.org/packages/core/linux49/issues/2
commit 867ac9d737094e46a6c33213f16dd1ec9e8bd5d5 upstream.
Objtool tries to silence 'unreachable instruction' warnings when it
detects gcov is enabled, because gcov produces a lot of unreachable
instructions and they don't really matter.
However, the 0-day bot is still reporting some unreachable instruction
warnings with CONFIG_GCOV_KERNEL=y on GCC 4.6.4.
As it turns out, objtool's gcov detection doesn't work with older
versions of GCC because they don't create a bunch of symbols with the
'gcov.' prefix like newer versions of GCC do.
Move the gcov check out of objtool and instead just create a new
'--no-unreachable' flag which can be passed in by the kernel Makefile
when CONFIG_GCOV_KERNEL is defined.
Also rename the 'nofp' variable to 'no_fp' for consistency with the new
'no_unreachable' variable.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Fixes: 9cfffb116887 ("objtool: Skip all "unreachable instruction" warnings for gcov kernels")
Link: http://lkml.kernel.org/r/c243dc78eb2ffdabb6e927844dea39b6033cd395.1500939244.git.jpoimboe@redhat.com
[just Makefile.build as the other parts of this patch already applied - gregkh]
commit 590347e4000356f55eb10b03ced2686bd74dab40 upstream.
gcc-6.3 and earlier show a new warning after a seemingly unrelated
change to the arm64 PAGE_KERNEL definition:
In file included from drivers/md/dm-bufio.c:14:0:
drivers/md/dm-bufio.c: In function 'alloc_buffer':
include/linux/sched/mm.h:182:56: warning: 'noio_flag' may be used uninitialized in this function [-Wmaybe-uninitialized]
current->flags = (current->flags & ~PF_MEMALLOC_NOIO) | flags;
The same warning happened earlier on linux-3.18 for MIPS and I did a
workaround for that, but now it's come back.
gcc-7 and newer are apparently smart enough to figure this out, and
other architectures don't show it, so the best I could come up with is
to rework the caller slightly in a way that makes it obvious enough to
all arm64 compilers what is happening here.
Fixes: 41acec624087 ("arm64: kpti: Make use of nG dependent on arm64_kernel_unmapped_at_el0()")
Link: https://patchwork.kernel.org/patch/9692829/
[snitzer: moved declarations inside conditional, altered vmalloc return]
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
[nc: Backport to 4.9, adjust context for lack of 19809c2da28a]
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Fix an additional misuse of X86_FEATURE_SSBD in
guest_cpuid_has_spec_ctrl(). This function was introduced in the
backport of SSBD support to 4.9 and is not present upstream, so it was
not fixed by commit 43462d908821 "KVM: VMX: Expose SSBD properly to
guests."
Fixes: 52817587e706 ("x86/cpufeatures: Disentangle SSBD enumeration")
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: David Woodhouse <dwmw@amazon.co.uk>
Cc: kvm@vger.kernel.org
[ Upstream commit 5b5e7a0de2bbf2a1afcd9f49e940010e9fb80d53 ]
Before using nla_get_u32(), better make sure the attribute
is of the proper size.
Code recently was changed, but bug has been there from beginning
of git.
BUG: KMSAN: uninit-value in rtnetlink_put_metrics+0x553/0x960 net/core/rtnetlink.c:746
CPU: 1 PID: 14139 Comm: syz-executor6 Not tainted 4.17.0-rc5+ #103
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x185/0x1d0 lib/dump_stack.c:113
kmsan_report+0x149/0x260 mm/kmsan/kmsan.c:1084
__msan_warning_32+0x6e/0xc0 mm/kmsan/kmsan_instr.c:686
fib_dump_info+0xc42/0x2190 net/ipv4/fib_semantics.c:1361
rtmsg_fib+0x65f/0x8c0 net/ipv4/fib_semantics.c:419
fib_table_insert+0x2314/0x2b50 net/ipv4/fib_trie.c:1287
inet_rtm_newroute+0x210/0x340 net/ipv4/fib_frontend.c:779
rtnetlink_rcv_msg+0xa32/0x1560 net/core/rtnetlink.c:4646
netlink_rcv_skb+0x378/0x600 net/netlink/af_netlink.c:2448
rtnetlink_rcv+0x50/0x60 net/core/rtnetlink.c:4664
netlink_unicast_kernel net/netlink/af_netlink.c:1310 [inline]
netlink_unicast+0x1678/0x1750 net/netlink/af_netlink.c:1336
netlink_sendmsg+0x104f/0x1350 net/netlink/af_netlink.c:1901
sock_sendmsg_nosec net/socket.c:629 [inline]
sock_sendmsg net/socket.c:639 [inline]
___sys_sendmsg+0xec0/0x1310 net/socket.c:2117
__sys_sendmsg net/socket.c:2155 [inline]
__do_sys_sendmsg net/socket.c:2164 [inline]
__se_sys_sendmsg net/socket.c:2162 [inline]
__x64_sys_sendmsg+0x331/0x460 net/socket.c:2162
do_syscall_64+0x152/0x230 arch/x86/entry/common.c:287
entry_SYSCALL_64_after_hwframe+0x44/0xa9
RIP: 0033:0x455a09
RSP: 002b:00007faae5fd8c68 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
RAX: ffffffffffffffda RBX: 00007faae5fd96d4 RCX: 0000000000455a09
RDX: 0000000000000000 RSI: 0000000020000000 RDI: 0000000000000013
RBP: 000000000072bea0 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00000000ffffffff
R13: 00000000000005d0 R14: 00000000006fdc20 R15: 0000000000000000
Uninit was stored to memory at:
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:279 [inline]
kmsan_save_stack mm/kmsan/kmsan.c:294 [inline]
kmsan_internal_chain_origin+0x12b/0x210 mm/kmsan/kmsan.c:685
__msan_chain_origin+0x69/0xc0 mm/kmsan/kmsan_instr.c:529
fib_convert_metrics net/ipv4/fib_semantics.c:1056 [inline]
fib_create_info+0x2d46/0x9dc0 net/ipv4/fib_semantics.c:1150
fib_table_insert+0x3e4/0x2b50 net/ipv4/fib_trie.c:1146
Uninit was created at:
kmsan_internal_poison_shadow+0xb8/0x1b0 mm/kmsan/kmsan.c:189
kmsan_kmalloc+0x94/0x100 mm/kmsan/kmsan.c:315
kmsan_slab_alloc+0x10/0x20 mm/kmsan/kmsan.c:322
slab_post_alloc_hook mm/slab.h:446 [inline]
slab_alloc_node mm/slub.c:2753 [inline]
__kmalloc_node_track_caller+0xb32/0x11b0 mm/slub.c:4395
__kmalloc_reserve net/core/skbuff.c:138 [inline]
__alloc_skb+0x2cb/0x9e0 net/core/skbuff.c:206
alloc_skb include/linux/skbuff.h:988 [inline]
netlink_alloc_large_skb net/netlink/af_netlink.c:1182 [inline]
netlink_sendmsg+0x76e/0x1350 net/netlink/af_netlink.c:1876
Fixes: a919525ad832 ("net: Move fib_convert_metrics to metrics file")
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Cc: David Ahern <dsahern@gmail.com>
[ Upstream commit 79fb218d97980d4fee9a64f4c8ff05289364ba25 ]
On newer PHYs, we need to select the expansion register to write with
setting bits [11:8] to 0xf. This was done correctly by bcm7xxx.c prior
to being migrated to generic code under bcm-phy-lib.c which
unfortunately used the older implementation from the BCM54xx days.
Fix this by creating an inline stub: bcm_write_exp_sel() which adds the
correct value (MII_BCM54XX_EXP_SEL_ER) and update both the Cygnus PHY
and BCM7xxx PHY drivers which require setting these bits.
broadcom.c is unchanged because some PHYs even use a different selector
method, so let them specify it directly (e.g: SerDes secondary selector).
Fixes: a1cba5613edf ("net: phy: Add Broadcom phy library for common interfaces")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 644c7eebbfd59e72982d11ec6cc7d39af12450ae ]
It seems that rtnl_group_changelink() can call do_setlink
while a prior call to validate_linkmsg(dev = NULL, ...) could
not validate IFLA_ADDRESS / IFLA_BROADCAST
Make sure do_setlink() calls validate_linkmsg() instead
of letting its callers having this responsibility.
With help from Dmitry Vyukov, thanks a lot !
BUG: KMSAN: uninit-value in is_valid_ether_addr include/linux/etherdevice.h:199 [inline]
BUG: KMSAN: uninit-value in eth_prepare_mac_addr_change net/ethernet/eth.c:275 [inline]
BUG: KMSAN: uninit-value in eth_mac_addr+0x203/0x2b0 net/ethernet/eth.c:308
CPU: 1 PID: 8695 Comm: syz-executor3 Not tainted 4.17.0-rc5+ #103
Call Trace:
dev_set_mac_address+0x261/0x530 net/core/dev.c:7157
do_setlink+0xbc3/0x5fc0 net/core/rtnetlink.c:2317
rtnl_group_changelink net/core/rtnetlink.c:2824 [inline]
rtnl_newlink+0x1fe9/0x37a0 net/core/rtnetlink.c:2976
RIP: 0033:0x455a09
RSP: 002b:00007fc07480ec68 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
RAX: ffffffffffffffda RBX: 00007fc07480f6d4 RCX: 0000000000455a09
RDX: 0000000000000000 RSI: 00000000200003c0 RDI: 0000000000000014
kmsan_memcpy_origins+0x11d/0x170 mm/kmsan/kmsan.c:527
__msan_memcpy+0x109/0x160 mm/kmsan/kmsan_instr.c:478
do_setlink+0xb84/0x5fc0 net/core/rtnetlink.c:2315
Fixes: e7ed828f10bd ("netlink: support setting devgroup parameters")
Cc: Dmitry Vyukov <dvyukov@google.com>
[ Upstream commit d546b67cda015fb92bfee93d5dc0ceadb91deaee ]
spin_lock/unlock was used instead of spin_un/lock_irq
in a procedure used in process space, on a spinlock
which can be grabbed in an interrupt.
This caused the stack trace below to be displayed (on kernel
4.17.0-rc1 compiled with Lock Debugging enabled):
[ 154.661474] WARNING: SOFTIRQ-safe -> SOFTIRQ-unsafe lock order detected
[ 154.668909] 4.17.0-rc1-rdma_rc_mlx+ #3 Tainted: G I
[ 154.675856] -----------------------------------------------------
[ 154.682706] modprobe/10159 [HC0[0]:SC0[0]:HE0:SE1] is trying to acquire:
[ 154.690254] 00000000f3b0e495 (&(&qp_table->lock)->rlock){+.+.}, at: mlx4_qp_remove+0x20/0x50 [mlx4_core]
[ 154.700927]
and this task is already holding:
[ 154.707461] 0000000094373b5d (&(&cq->lock)->rlock/1){....}, at: destroy_qp_common+0x111/0x560 [mlx4_ib]
[ 154.718028] which would create a new lock dependency:
[ 154.723705] (&(&cq->lock)->rlock/1){....} -> (&(&qp_table->lock)->rlock){+.+.}
[ 154.731922]
but this new dependency connects a SOFTIRQ-irq-safe lock:
[ 154.740798] (&(&cq->lock)->rlock){..-.}
[ 154.740800]
... which became SOFTIRQ-irq-safe at:
[ 154.752163] _raw_spin_lock_irqsave+0x3e/0x50
[ 154.757163] mlx4_ib_poll_cq+0x36/0x900 [mlx4_ib]
[ 154.762554] ipoib_tx_poll+0x4a/0xf0 [ib_ipoib]
to a SOFTIRQ-irq-unsafe lock:
[ 154.815603] (&(&qp_table->lock)->rlock){+.+.}
[ 154.815604]
... which became SOFTIRQ-irq-unsafe at:
[ 154.827718] ...
[ 154.827720] _raw_spin_lock+0x35/0x50
[ 154.833912] mlx4_qp_lookup+0x1e/0x50 [mlx4_core]
[ 154.839302] mlx4_flow_attach+0x3f/0x3d0 [mlx4_core]
Since mlx4_qp_lookup() is called only in process space, we can
simply replace the spin_un/lock calls with spin_un/lock_irq calls.
Fixes: 6dc06c08bef1 ("net/mlx4: Fix the check in attaching steering rules")
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Tariq Toukan <tariqt@mellanox.com>
[ Upstream commit 2f17becfbea5e9a0529b51da7345783e96e69516 ]
Use the right device to determine if redirect should be sent especially
when using vrf. Same as well as when sending the redirect.
Signed-off-by: Stephen Suryaputra <ssuryaextr@gmail.com>
Acked-by: David Ahern <dsahern@gmail.com>
[ Upstream commit 1b15ad683ab42a203f98b67045b40720e99d0e9a ]
DaeRyong Jeong reports a race between vhost_dev_cleanup() and
vhost_process_iotlb_msg():
Thread interleaving:
CPU0 (vhost_process_iotlb_msg) CPU1 (vhost_dev_cleanup)
(In the case of both VHOST_IOTLB_UPDATE and
VHOST_IOTLB_INVALIDATE)
vhost_umem_clean(dev->iotlb);
if (!dev->iotlb) {
ret = -EFAULT;
break;
dev->iotlb = NULL;
The reason is we don't synchronize between them, fixing by protecting
vhost_process_iotlb_msg() with dev mutex.
Reported-by: DaeRyong Jeong <threeearcat@gmail.com>
Fixes: 6b1e6cc7855b0 ("vhost: new device IOTLB API")
Signed-off-by: Jason Wang <jasowang@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit 25ea66544bfd1d9df1b7e1502f8717e85fa1e6e6 ]
This code was introduced in 2011 around the same time that we made
netdev_features_t a u64 type. These days a u32 is not big enough to
hold all the potential features.
Acked-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit 1d88ba1ebb2763aa86172cd7ca05dedbeccc0d35 ]
syzbot reported a rcu_sched self-detected stall on CPU which is caused
by too small value set on rto_min with SCTP_RTOINFO sockopt. With this
value, hb_timer will get stuck there, as in its timer handler it starts
this timer again with this value, then goes to the timer handler again.
This problem is there since very beginning, and thanks to Eric for the
reproducer shared from a syzbot mail.
This patch fixes it by not allowing sctp_transport_timeout to return a
smaller value than HZ/5 for hb_timer, which is based on TCP's min rto.
Note that it doesn't fix this issue by limiting rto_min, as some users
are still using small rto and no proper value was found for it yet.
Reported-by: syzbot+3dcd59a1f907245f891f@syzkaller.appspotmail.com
Suggested-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit fdd13dd350dda1826579eb5c333d76b14513b812 ]
ILT entry requires 12 bit right shifted physical address.
Existing mask for ILT entry of physical address i.e.
ILT_ENTRY_PHY_ADDR_MASK is not sufficient to handle 64bit
address because upper 8 bits of 64 bit address were getting
masked which resulted in completer abort error on
PCIe bus due to invalid address.
Fix that mask to handle 64bit physical address.
Fixes: fe56b9e6a8d9 ("qed: Add module with basic common support")
Signed-off-by: Shahed Shaikh <shahed.shaikh@cavium.com>
Signed-off-by: Ariel Elior <ariel.elior@cavium.com>
[ Upstream commit 9aad13b087ab0a588cd68259de618f100053360e ]
Commit b84bbaf7a6c8 ("packet: in packet_snd start writing at link
layer allocation") ensures that packet_snd always starts writing
the link layer header in reserved headroom allocated for this
purpose.
This is needed because packets may be shorter than hard_header_len,
in which case the space up to hard_header_len may be zeroed. But
that necessary padding is not accounted for in skb->len.
The fix, however, is buggy. It calls skb_push, which grows skb->len
when moving skb->data back. But in this case packet length should not
change.
Instead, call skb_reserve, which moves both skb->data and skb->tail
back, without changing length.
Fixes: b84bbaf7a6c8 ("packet: in packet_snd start writing at link layer allocation")
Reported-by: Tariq Toukan <tariqt@mellanox.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
[ Upstream commit 9f7c728332e8966084242fcd951aa46583bc308c ]
Testing Telit LM940 with ICMP packets > 14552 bytes revealed that
the modem needs FLAG_SEND_ZLP to properly work, otherwise the cdc
mbim data interface won't be anymore responsive.
Signed-off-by: Daniele Palmas <dnlplm@gmail.com>
Acked-by: Bjørn Mork <bjorn@mork.no>
[ Upstream commit eb73190f4fbeedf762394e92d6a4ec9ace684c88 ]
syzbot was able to trick af_packet again [1]
Various commits tried to address the problem in the past,
but failed to take into account V3 header size.
[1]
tpacket_rcv: packet too big, clamped from 72 to 4294967224. macoff=96
BUG: KASAN: use-after-free in prb_run_all_ft_ops net/packet/af_packet.c:1016 [inline]
BUG: KASAN: use-after-free in prb_fill_curr_block.isra.59+0x4e5/0x5c0 net/packet/af_packet.c:1039
Write of size 2 at addr ffff8801cb62000e by task kworker/1:2/2106
CPU: 1 PID: 2106 Comm: kworker/1:2 Not tainted 4.17.0-rc7+ #77
Workqueue: ipv6_addrconf addrconf_dad_work
Call Trace:
dump_stack+0x1b9/0x294 lib/dump_stack.c:113
print_address_description+0x6c/0x20b mm/kasan/report.c:256
kasan_report_error mm/kasan/report.c:354 [inline]
kasan_report.cold.7+0x242/0x2fe mm/kasan/report.c:412
__asan_report_store2_noabort+0x17/0x20 mm/kasan/report.c:436
__packet_lookup_frame_in_block net/packet/af_packet.c:1094 [inline]
packet_current_rx_frame net/packet/af_packet.c:1117 [inline]
tpacket_rcv+0x1866/0x3340 net/packet/af_packet.c:2282
dev_queue_xmit_nit+0x891/0xb90 net/core/dev.c:2018
xmit_one net/core/dev.c:3049 [inline]
dev_hard_start_xmit+0x16b/0xc10 net/core/dev.c:3069
__dev_queue_xmit+0x2724/0x34c0 net/core/dev.c:3584
dev_queue_xmit+0x17/0x20 net/core/dev.c:3617
neigh_resolve_output+0x679/0xad0 net/core/neighbour.c:1358
neigh_output include/net/neighbour.h:482 [inline]
ip6_finish_output2+0xc9c/0x2810 net/ipv6/ip6_output.c:120
ip6_finish_output+0x5fe/0xbc0 net/ipv6/ip6_output.c:154
NF_HOOK_COND include/linux/netfilter.h:277 [inline]
ip6_output+0x227/0x9b0 net/ipv6/ip6_output.c:171
dst_output include/net/dst.h:444 [inline]
NF_HOOK include/linux/netfilter.h:288 [inline]
ndisc_send_skb+0x100d/0x1570 net/ipv6/ndisc.c:491
ndisc_send_ns+0x3c1/0x8d0 net/ipv6/ndisc.c:633
addrconf_dad_work+0xbef/0x1340 net/ipv6/addrconf.c:4033
process_one_work+0xc1e/0x1b50 kernel/workqueue.c:2145
worker_thread+0x1cc/0x1440 kernel/workqueue.c:2279
kthread+0x345/0x410 kernel/kthread.c:240
ret_from_fork+0x3a/0x50 arch/x86/entry/entry_64.S:412
The buggy address belongs to the page:
page:ffffea00072d8800 count:0 mapcount:-127 mapping:0000000000000000 index:0xffff8801cb620e80
flags: 0x2fffc0000000000()
raw: 02fffc0000000000 0000000000000000 ffff8801cb620e80 00000000ffffff80
raw: ffffea00072e3820 ffffea0007132d20 0000000000000002 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8801cb61ff00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffff8801cb61ff80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
>ffff8801cb620000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ffff8801cb620080: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ffff8801cb620100: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Fixes: 2b6867c2ce76 ("net/packet: fix overflow in check for priv area size")
Fixes: dc808110bb62 ("packet: handle too big packets for PACKET_V3")
Fixes: f6fb8f100b80 ("af-packet: TPACKET_V3 flexible buffer implementation.")
[ Upstream commit 75d4e704fa8d2cf33ff295e5b441317603d7f9fd ]
Per discussion with David at netconf 2018, let's clarify
DaveM's position of handling stable backports in netdev-FAQ.
This is important for people relying on upstream -stable
releases.
[ Upstream commit eb7f54b90bd8f469834c5e86dcf72ebf9a629811 ]
(resend for properly queueing in patchwork)
kcm_clone() creates kernel socket, which does not take net counter.
Thus, the net may die before the socket is completely destructed,
i.e. kcm_exit_net() is executed before kcm_done().
Reported-by: syzbot+5f1a04e374a635efc426@syzkaller.appspotmail.com
Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com>
