commit 013ad043906b2befd4a9bfb06219ed9fedd92716 upstream.
sector_div() is only viable for use with sector_t.
dm_block_t is typedef'd to uint64_t -- so use div_u64() instead.
Fixes: 3ab918281 ("dm thin metadata: try to avoid ever aborting transactions")
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Cc: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit cbe355f57c8074bc4f452e5b6e35509044c6fa23 upstream.
In dlm_init_lockres() we access and modify res->tracking and
dlm->tracking_list without holding dlm->track_lock. This can cause list
corruptions and can end up in kernel panic.
Fix this by locking res->tracking and dlm->tracking_list with
dlm->track_lock instead of dlm->spinlock.
Link: http://lkml.kernel.org/r/1529951192-4686-1-git-send-email-ashish.samant@oracle.com
Signed-off-by: Ashish Samant <ashish.samant@oracle.com>
Reviewed-by: Changwei Ge <ge.changwei@h3c.com>
Acked-by: Joseph Qi <jiangqi903@gmail.com>
Acked-by: Jun Piao <piaojun@huawei.com>
Cc: Mark Fasheh <mark@fasheh.com>
Cc: Junxiao Bi <junxiao.bi@oracle.com>
Cc: Changwei Ge <ge.changwei@h3c.com>
Cc: <stable@vger.kernel.org>
commit f8a00cef17206ecd1b30d3d9f99e10d9fa707aa7 upstream.
Currently, you can use /proc/self/task/*/stack to cause a stack walk on
a task you control while it is running on another CPU. That means that
the stack can change under the stack walker. The stack walker does
have guards against going completely off the rails and into random
kernel memory, but it can interpret random data from your kernel stack
as instruction pointers and stack pointers. This can cause exposure of
kernel stack contents to userspace.
Restrict the ability to inspect kernel stacks of arbitrary tasks to root
in order to prevent a local attacker from exploiting racy stack unwinding
to leak kernel task stack contents. See the added comment for a longer
rationale.
There don't seem to be any users of this userspace API that can't
gracefully bail out if reading from the file fails. Therefore, I believe
that this change is unlikely to break things. In the case that this patch
does end up needing a revert, the next-best solution might be to fake a
single-entry stack based on wchan.
Link: http://lkml.kernel.org/r/20180927153316.200286-1-jannh@google.com
Fixes: 2ec220e27f50 ("proc: add /proc/*/stack")
Signed-off-by: Jann Horn <jannh@google.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Ken Chen <kenchen@google.com>
Cc: Laura Abbott <labbott@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: "H . Peter Anvin" <hpa@zytor.com>
commit 19a4fbffc94e41abaa2a623a25ce2641d69eccf0 upstream.
The current code only frees N-1 gpios if an error occurs during
gpiod_set_transitory, gpiod_direction_output or gpiod_direction_input.
Leading to gpios that cannot be used by userspace nor other drivers.
Cc: Timur Tabi <timur@codeaurora.org>
Cc: stable@vger.kernel.org
Fixes: ab3dbcf78f60f46d ("gpioib: do not free unrequested descriptors)
Reported-by: Jan Lorenzen <jl@newtec.dk>
Reported-by: Jim Paris <jim@jtan.com>
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
commit d80771c08363ad7fbf0f56f5301e7ca65065c582 upstream.
When compiling with CONFIG_DEBUG_ATOMIC_SLEEP=y the mxs-dcp driver
prints warnings such as:
WARNING: CPU: 0 PID: 120 at kernel/sched/core.c:7736 __might_sleep+0x98/0x9c
do not call blocking ops when !TASK_RUNNING; state=1 set at [<8081978c>] dcp_chan_thread_sha+0x3c/0x2ec
The problem is that blocking ops will manipulate current->state
themselves so it is not allowed to call them between
set_current_state(TASK_INTERRUPTIBLE) and schedule().
Fix this by converting the per-chan mutex to a spinlock (it only
protects tiny list ops anyway) and rearranging the wait logic so that
callbacks are called current->state as TASK_RUNNING. Those callbacks
will indeed call blocking ops themselves so this is required.
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
commit ba439a6cbfa2936a6713f64cb499de7943673fe3 upstream.
The following KASAN warning was printed when booting a 64-bit kernel
on some systems with Intel CPUs:
[ 44.512826] ==================================================================
[ 44.520165] BUG: KASAN: stack-out-of-bounds in find_first_bit+0xb0/0xc0
[ 44.526786] Read of size 8 at addr ffff88041e02fc50 by task kworker/0:2/124
[ 44.535253] CPU: 0 PID: 124 Comm: kworker/0:2 Tainted: G X --------- --- 4.18.0-12.el8.x86_64+debug #1
[ 44.545858] Hardware name: Intel Corporation PURLEY/PURLEY, BIOS BKVDTRL1.86B.0005.D08.1712070559 12/07/2017
[ 44.555682] Workqueue: events work_for_cpu_fn
[ 44.560043] Call Trace:
[ 44.562502] dump_stack+0x9a/0xe9
[ 44.565832] print_address_description+0x65/0x22e
[ 44.570683] ? find_first_bit+0xb0/0xc0
[ 44.570689] kasan_report.cold.6+0x92/0x19f
[ 44.578726] find_first_bit+0xb0/0xc0
[ 44.578737] adf_probe+0x9eb/0x19a0 [qat_c62x]
[ 44.578751] ? adf_remove+0x110/0x110 [qat_c62x]
[ 44.591490] ? mark_held_locks+0xc8/0x140
[ 44.591498] ? _raw_spin_unlock+0x30/0x30
[ 44.591505] ? trace_hardirqs_on_caller+0x381/0x570
[ 44.604418] ? adf_remove+0x110/0x110 [qat_c62x]
[ 44.604427] local_pci_probe+0xd4/0x180
[ 44.604432] ? pci_device_shutdown+0x110/0x110
[ 44.617386] work_for_cpu_fn+0x51/0xa0
[ 44.621145] process_one_work+0x8fe/0x16e0
[ 44.625263] ? pwq_dec_nr_in_flight+0x2d0/0x2d0
[ 44.629799] ? lock_acquire+0x14c/0x400
[ 44.633645] ? move_linked_works+0x12e/0x2a0
[ 44.637928] worker_thread+0x536/0xb50
[ 44.641690] ? __kthread_parkme+0xb6/0x180
[ 44.645796] ? process_one_work+0x16e0/0x16e0
[ 44.650160] kthread+0x30c/0x3d0
[ 44.653400] ? kthread_create_worker_on_cpu+0xc0/0xc0
[ 44.658457] ret_from_fork+0x3a/0x50
[ 44.663557] The buggy address belongs to the page:
[ 44.668350] page:ffffea0010780bc0 count:0 mapcount:0 mapping:0000000000000000 index:0x0
[ 44.676356] flags: 0x17ffffc0000000()
[ 44.680023] raw: 0017ffffc0000000 ffffea0010780bc8 ffffea0010780bc8 0000000000000000
[ 44.687769] raw: 0000000000000000 0000000000000000 00000000ffffffff 0000000000000000
[ 44.695510] page dumped because: kasan: bad access detected
[ 44.702578] Memory state around the buggy address:
[ 44.707372] ffff88041e02fb00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 44.714593] ffff88041e02fb80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 44.721810] >ffff88041e02fc00: 00 00 00 00 00 00 f1 f1 f1 f1 04 f2 f2 f2 f2 f2
[ 44.729028] ^
[ 44.734864] ffff88041e02fc80: f2 f2 00 00 00 00 f3 f3 f3 f3 00 00 00 00 00 00
[ 44.742082] ffff88041e02fd00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 44.749299] ==================================================================
Looking into the code:
int ret, bar_mask;
for_each_set_bit(bar_nr, (const unsigned long *)&bar_mask,
It is casting a 32-bit integer pointer to a 64-bit unsigned long
pointer. There are two problems here. First, the 32-bit pointer address
may not be 64-bit aligned. Secondly, it is accessing an extra 4 bytes.
This is fixed by changing the bar_mask type to unsigned long.
Signed-off-by: Waiman Long <longman@redhat.com>
commit 709ae62e8e6d9ac4df7dadb3b8ae432675c45ef9 upstream.
The issue is the same as commit dd9aa335c880 ("ALSA: hda/realtek - Can't
adjust speaker's volume on a Dell AIO"), the output requires to connect
to a node with Amp-out capability.
Applying the same fixup ALC298_FIXUP_SPK_VOLUME can fix the issue.
BugLink: https://bugs.launchpad.net/bugs/1775068
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
commit 0595751f267994c3c7027377058e4185b3a28e75 upstream.
When mounting a Windows share that is the root of a drive (eg. C$)
the server does not return . and .. directory entries. This results in
the smb2 code path erroneously skipping the 2 first entries.
Pseudo-code of the readdir() code path:
cifs_readdir(struct file, struct dir_context)
initiate_cifs_search <-- if no reponse cached yet
server->ops->query_dir_first
dir_emit_dots
dir_emit <-- adds "." and ".." if we're at pos=0
find_cifs_entry
initiate_cifs_search <-- if pos < start of current response
(restart search)
server->ops->query_dir_next <-- if pos > end of current response
(fetch next search res)
for(...) <-- loops over cur response entries
starting at pos
cifs_filldir <-- skip . and .., emit entry
cifs_fill_dirent
dir_emit
pos++
A) dir_emit_dots() always adds . & ..
and sets the current dir pos to 2 (0 and 1 are done).
Therefore we always want the index_to_find to be 2 regardless of if
the response has . and ..
B) smb1 code initializes index_of_last_entry with a +2 offset
in cifssmb.c CIFSFindFirst():
psrch_inf->index_of_last_entry = 2 /* skip . and .. */ +
psrch_inf->entries_in_buffer;
Later in find_cifs_entry() we want to find the next dir entry at pos=2
as a result of (A)
first_entry_in_buffer = cfile->srch_inf.index_of_last_entry -
cfile->srch_inf.entries_in_buffer;
This var is the dir pos that the first entry in the buffer will
have therefore it must be 2 in the first call.
If we don't offset index_of_last_entry by 2 (like in (B)),
first_entry_in_buffer=0 but we were instructed to get pos=2 so this
code in find_cifs_entry() skips the 2 first which is ok for non-root
shares, as it skips . and .. from the response but is not ok for root
shares where the 2 first are actual files
pos_in_buf = index_to_find - first_entry_in_buffer;
// pos_in_buf=2
// we skip 2 first response entries :(
for (i = 0; (i < (pos_in_buf)) && (cur_ent != NULL); i++) {
/* go entry by entry figuring out which is first */
cur_ent = nxt_dir_entry(cur_ent, end_of_smb,
cfile->srch_inf.info_level);
C) cifs_filldir() skips . and .. so we can safely ignore them for now.
Sample program:
int main(int argc, char **argv)
const char *path = argc >= 2 ? argv[1] : ".";
DIR *dh;
struct dirent *de;
printf("listing path <%s>\n", path);
dh = opendir(path);
if (!dh) {
printf("opendir error %d\n", errno);
return 1;
while (1) {
de = readdir(dh);
if (!de) {
if (errno) {
printf("readdir error %d\n", errno);
return 1;
printf("end of listing\n");
break;
printf("off=%lu <%s>\n", de->d_off, de->d_name);
return 0;
Before the fix with SMB1 on root shares:
<.> off=1
<..> off=2
<$Recycle.Bin> off=3
<bootmgr> off=4
and on non-root shares:
<.> off=1
<..> off=4 <-- after adding .., the offsets jumps to +2 because
<2536> off=5 we skipped . and .. from response buffer (C)
<411> off=6 but still incremented pos
<file> off=7
<fsx> off=8
Therefore the fix for smb2 is to mimic smb1 behaviour and offset the
index_of_last_entry by 2.
Test results comparing smb1 and smb2 before/after the fix on root
share, non-root shares and on large directories (ie. multi-response
dir listing):
PRE FIX
pre-1-root VS pre-2-root:
ERR pre-2-root is missing [bootmgr, $Recycle.Bin]
pre-1-nonroot VS pre-2-nonroot:
OK~ same files, same order, different offsets
pre-1-nonroot-large VS pre-2-nonroot-large:
POST FIX
post-1-root VS post-2-root:
OK same files, same order, same offsets
post-1-nonroot VS post-2-nonroot:
post-1-nonroot-large VS post-2-nonroot-large:
REGRESSION?
pre-1-root VS post-1-root:
pre-1-nonroot VS post-1-nonroot:
BugLink: https://bugzilla.samba.org/show_bug.cgi?id=13107
Signed-off-by: Aurelien Aptel <aaptel@suse.com>
Signed-off-by: Paulo Alcantara <palcantara@suse.deR>
Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com>
Signed-off-by: Steve French <stfrench@microsoft.com>
CC: Stable <stable@vger.kernel.org>
commit ffc4c92227db5699493e43eb140b4cb5904c30ff upstream.
Commit 786534b92f3c introduced a regression that caused listxattr to
return the POSIX ACL attribute names even though sysfs doesn't support
POSIX ACLs. This happens because simple_xattr_list checks for NULL
i_acl / i_default_acl, but inode_init_always initializes those fields
to ACL_NOT_CACHED ((void *)-1). For example:
$ getfattr -m- -d /sys
/sys: system.posix_acl_access: Operation not supported
/sys: system.posix_acl_default: Operation not supported
Fix this in simple_xattr_list by checking if the filesystem supports POSIX ACLs.
Fixes: 786534b92f3c ("tmpfs: listxattr should include POSIX ACL xattrs")
Reported-by: Marc Aurèle La France <tsi@tuyoix.net>
Tested-by: Marc Aurèle La France <tsi@tuyoix.net>
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
Cc: stable@vger.kernel.org # v4.5+
[ Upstream commit 4dca864b59dd150a221730775e2f21f49779c135 ]
This patch removes duplicate macro useage in events_base.c.
It also fixes gcc warning:
variable ‘col’ set but not used [-Wunused-but-set-variable]
Signed-off-by: Joshua Abraham <j.abraham1776@gmail.com>
Reviewed-by: Juergen Gross <jgross@suse.com>
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
[ Upstream commit 3366cdb6d350d95466ee430ac50f3c8415ca8f46 ]
The command 'xl vcpu-set 0 0', issued in dom0, will crash dom0:
BUG: unable to handle kernel NULL pointer dereference at 00000000000002d8
PGD 0 P4D 0
Oops: 0000 [#1] PREEMPT SMP NOPTI
CPU: 7 PID: 65 Comm: xenwatch Not tainted 4.19.0-rc2-1.ga9462db-default #1 openSUSE Tumbleweed (unreleased)
Hardware name: Intel Corporation S5520UR/S5520UR, BIOS S5500.86B.01.00.0050.050620101605 05/06/2010
RIP: e030:device_offline+0x9/0xb0
Code: 77 24 00 e9 ce fe ff ff 48 8b 13 e9 68 ff ff ff 48 8b 13 e9 29 ff ff ff 48 8b 13 e9 ea fe ff ff 90 66 66 66 66 90 41 54 55 53 <f6> 87 d8 02 00 00 01 0f 85 88 00 00 00 48 c7 c2 20 09 60 81 31 f6
RSP: e02b:ffffc90040f27e80 EFLAGS: 00010203
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000
RDX: ffff8801f3800000 RSI: ffffc90040f27e70 RDI: 0000000000000000
RBP: 0000000000000000 R08: ffffffff820e47b3 R09: 0000000000000000
R10: 0000000000007ff0 R11: 0000000000000000 R12: ffffffff822e6d30
R13: dead000000000200 R14: dead000000000100 R15: ffffffff8158b4e0
FS: 00007ffa595158c0(0000) GS:ffff8801f39c0000(0000) knlGS:0000000000000000
CS: e033 DS: 0000 ES: 0000 CR0: 0000000080050033
CR2: 00000000000002d8 CR3: 00000001d9602000 CR4: 0000000000002660
Call Trace:
handle_vcpu_hotplug_event+0xb5/0xc0
xenwatch_thread+0x80/0x140
? wait_woken+0x80/0x80
kthread+0x112/0x130
? kthread_create_worker_on_cpu+0x40/0x40
This happens because handle_vcpu_hotplug_event is called twice. In the
first iteration cpu_present is still true, in the second iteration
cpu_present is false which causes get_cpu_device to return NULL.
In case of cpu#0, cpu_online is apparently always true.
Fix this crash by checking if the cpu can be hotplugged, which is false
for a cpu that was just removed.
Also check if the cpu was actually offlined by device_remove, otherwise
leave the cpu_present state as it is.
Rearrange to code to do all work with device_hotplug_lock held.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
[ Upstream commit 87dffe86d406bee8782cac2db035acb9a28620a7 ]
When guest receives a sysrq request from the host it acknowledges it by
writing '\0' to control/sysrq xenstore node. This, however, make xenstore
watch fire again but xenbus_scanf() fails to parse empty value with "%c"
format string:
sysrq: SysRq : Emergency Sync
Emergency Sync complete
xen:manage: Error -34 reading sysrq code in control/sysrq
Ignore -ERANGE the same way we already ignore -ENOENT, empty value in
control/sysrq is totally legal.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Reviewed-by: Wei Liu <wei.liu2@citrix.com>
[ Upstream commit 097f5863b1a0c9901f180bbd56ae7d630655faaa ]
We need to verify that the "data_offset" is within bounds.
Reported-by: Dr Silvio Cesare of InfoSect <silvio.cesare@gmail.com>
Reviewed-by: Aurelien Aptel <aaptel@suse.com>
[ Upstream commit 0ac1487c4b2de383b91ecad1be561b8f7a2c15f4 ]
For inbound data with an unsupported HW header format, only dump the
actual HW header. We have no idea how much payload follows it, and what
it contains. Worst case, we dump past the end of the Inbound Buffer and
access whatever is located next in memory.
Signed-off-by: Julian Wiedmann <jwi@linux.ibm.com>
[ Upstream commit aec45e857c5538664edb76a60dd452e3265f37d1 ]
qeth_query_oat_command() currently allocates the kernel buffer for
the SIOC_QETH_QUERY_OAT ioctl with kzalloc. So on systems with
fragmented memory, large allocations may fail (eg. the qethqoat tool by
default uses 132KB).
Solve this issue by using vzalloc, backing the allocation with
non-contiguous memory.
Signed-off-by: Wenjia Zhang <wenjia@linux.ibm.com>
Reviewed-by: Julian Wiedmann <jwi@linux.ibm.com>
[ Upstream commit 6ad569019999300afd8e614d296fdc356550b77f ]
After system suspend, sometimes the r8169 doesn't work when ethernet
cable gets pluggued.
This issue happens because rtl_reset_work() doesn't get called from
rtl8169_runtime_resume(), after system suspend.
In rtl_task(), RTL_FLAG_TASK_* only gets cleared if this condition is
met:
if (!netif_running(dev) ||
!test_bit(RTL_FLAG_TASK_ENABLED, tp->wk.flags))
If RTL_FLAG_TASK_ENABLED was cleared during system suspend while
RTL_FLAG_TASK_RESET_PENDING was set, the next rtl_schedule_task() won't
schedule task as the flag is still there.
So in addition to clearing RTL_FLAG_TASK_ENABLED, also clears other
flags.
Cc: Heiner Kallweit <hkallweit1@gmail.com>
[ Upstream commit 13aceef06adfaf93d52e01e28a8bc8a0ad471d83 ]
All other uses of "asm goto" go through asm_volatile_goto, which avoids
a miscompile when using GCC < 4.8.2. Replace our open-coded "asm goto"
statements with the asm_volatile_goto macro to avoid issues with older
toolchains.
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Signed-off-by: Miguel Ojeda <miguel.ojeda.sandonis@gmail.com>
[ Upstream commit 5c41aaad409c097cf1ef74f2c649fed994744ef5 ]
Building drivers/mtd/nand/raw/nandsim.c on arch/hexagon/ produces a
printk format build warning. This is due to hexagon's ffs() being
coded as returning long instead of int.
Fix the printk format warning by changing all of hexagon's ffs() and
fls() functions to return int instead of long. The variables that
they return are already int instead of long. This return type
matches the return type in <asm-generic/bitops/>.
../drivers/mtd/nand/raw/nandsim.c: In function 'init_nandsim':
../drivers/mtd/nand/raw/nandsim.c:760:2: warning: format '%u' expects argument of type 'unsigned int', but argument 2 has type 'long int' [-Wformat]
There are no ffs() or fls() allmodconfig build errors after making this
change.
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: linux-hexagon@vger.kernel.org
Patch-mainline: linux-kernel @ 07/22/2018, 16:03
Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
[ Upstream commit 200f351e27f014fcbf69b544b0b4b72aeaf45fd3 ]
Fix build warning in arch/hexagon/kernel/dma.c by casting a void *
to unsigned long to match the function parameter type.
../arch/hexagon/kernel/dma.c: In function 'arch_dma_alloc':
../arch/hexagon/kernel/dma.c:51:5: warning: passing argument 2 of 'gen_pool_add' makes integer from pointer without a cast [enabled by default]
../include/linux/genalloc.h:112:19: note: expected 'long unsigned int' but argument is of type 'void *'
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Rich Felker <dalias@libc.org>
Cc: linux-sh@vger.kernel.org
Patch-mainline: linux-kernel @ 07/20/2018, 20:17
[rkuo@codeaurora.org: fixed architecture name]
[ Upstream commit 3ab91828166895600efd9cdc3a0eb32001f7204a ]
Committing a transaction can consume some metadata of it's own, we now
reserve a small amount of metadata to cover this. Free metadata
reported by the kernel will not include this reserve.
If any of the reserve has been used after a commit we enter a new
internal state PM_OUT_OF_METADATA_SPACE. This is reported as
PM_READ_ONLY, so no userland changes are needed. If the metadata
device is resized the pool will move back to PM_WRITE.
These changes mean we never need to abort and rollback a transaction due
to running out of metadata space. This is particularly important
because there have been a handful of reports of data corruption against
DM thin-provisioning that can all be attributed to the thin-pool having
ran out of metadata space.
Signed-off-by: Joe Thornber <ejt@redhat.com>
[ Upstream commit 16160c1946b702dcfa95ef63389a56deb2f1c7cb ]
Problem: perf did not show branch predicted/mispredicted bit in brstack.
Output of perf -F brstack for profile collected
Before:
0x4fdbcd/0x4fdc03/-/-/-/0
0x45f4c1/0x4fdba0/-/-/-/0
0x45f544/0x45f4bb/-/-/-/0
0x45f555/0x45f53c/-/-/-/0
0x7f66901cc24b/0x45f555/-/-/-/0
0x7f66901cc22e/0x7f66901cc23d/-/-/-/0
0x7f66901cc1ff/0x7f66901cc20f/-/-/-/0
0x7f66901cc1e8/0x7f66901cc1fc/-/-/-/0
After:
0x4fdbcd/0x4fdc03/P/-/-/0
0x45f4c1/0x4fdba0/P/-/-/0
0x45f544/0x45f4bb/P/-/-/0
0x45f555/0x45f53c/P/-/-/0
0x7f66901cc24b/0x45f555/P/-/-/0
0x7f66901cc22e/0x7f66901cc23d/P/-/-/0
0x7f66901cc1ff/0x7f66901cc20f/P/-/-/0
0x7f66901cc1e8/0x7f66901cc1fc/P/-/-/0
Cause:
As mentioned in Software Development Manual vol 3, 17.4.8.1,
IA32_PERF_CAPABILITIES[5:0] indicates the format of the address that is
stored in the LBR stack. Knights Landing reports 1 (LBR_FORMAT_LIP) as
its format. Despite that, registers containing FROM address of the branch,
do have MISPREDICT bit but because of the format indicated in
IA32_PERF_CAPABILITIES[5:0], LBR did not read MISPREDICT bit.
Solution:
Teach LBR about above Knights Landing quirk and make it read MISPREDICT bit.
Signed-off-by: Jacek Tomaka <jacek.tomaka@poczta.fm>
Link: http://lkml.kernel.org/r/20180802013830.10600-1-jacekt@dugeo.com
[ Upstream commit ef5b0771d247379c90c8bf1332ff32f7f74bff7f ]
The buffer length field in the ena rx descriptor is 16 bit, and the
current driver passes a full page in each ena rx descriptor.
When PAGE_SIZE equals 64kB or more, the buffer length field becomes
zero.
To solve this issue, limit the ena Rx descriptor to use 16kB even
when allocating 64kB kernel pages. This change would not impact ena
device functionality, as 16kB is still larger than maximum MTU.
Signed-off-by: Netanel Belgazal <netanel@amazon.com>
[ Upstream commit bcfb84a996f6fa90b5e6e2954b2accb7a4711097 ]
A powerpc build of cifs with gcc v8.2.0 produces this warning:
fs/cifs/cifssmb.c: In function ‘CIFSSMBNegotiate’:
fs/cifs/cifssmb.c:605:3: warning: ‘strncpy’ writing 16 bytes into a region of size 1 overflows the destination [-Wstringop-overflow=]
strncpy(pSMB->DialectsArray+count, protocols[i].name, 16);
Since we are already doing a strlen() on the source, change the strncpy
to a memcpy().
[ Upstream commit c44a5ee803d2b7ed8c2e6ce24a5c4dd60778886e ]
Update superblock when particular devices are requested via rebuild
(e.g. lvconvert --replace ...) to avoid spurious failure with the "New
device injected into existing raid set without 'delta_disks' or
'rebuild' parameter specified" error message.
Signed-off-by: Heinz Mauelshagen <heinzm@redhat.com>
[ Upstream commit 0a6986c6595e9afd20ff7280dab36431c1e467f8 ]
This Falcon application doesn't appear to be present on some newer
systems, so let's not fail init if we can't find it.
TBD: is there a way to determine whether it *should* be there?
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
[ Upstream commit df7ddb2396cd162e64aaff9401be05e31e438961 ]
The PCI BDF is not unique. PCI domain must also be considered when
searching for the next physical device during lag setup. Example below:
mlx5_core 0000:01:00.0: MLX5E: StrdRq(1) RqSz(8) StrdSz(128) RxCqeCmprss(0)
mlx5_core 0000:01:00.1: MLX5E: StrdRq(1) RqSz(8) StrdSz(128) RxCqeCmprss(0)
mlx5_core 0001:01:00.0: MLX5E: StrdRq(1) RqSz(8) StrdSz(128) RxCqeCmprss(0)
mlx5_core 0001:01:00.1: MLX5E: StrdRq(1) RqSz(8) StrdSz(128) RxCqeCmprss(0)
Signed-off-by: Daniel Jurgens <danielj@mellanox.com>
Reviewed-by: Aviv Heller <avivh@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
[ Upstream commit 8407879c4e0d7731f6e7e905893cecf61a7762c7 ]
Currently we always repost the recv buffer before we send a response
capsule back to the host. Since ordering is not guaranteed for send
and recv completions, it is posible that we will receive a new request
from the host before we got a send completion for the response capsule.
Today, we pre-allocate 2x rsps the length of the queue, but in reality,
under heavy load there is nothing that is really preventing the gap to
expand until we exhaust all our rsps.
To fix this, if we don't have any pre-allocated rsps left, we dynamically
allocate a rsp and make sure to free it when we are done. If under memory
pressure we fail to allocate a rsp, we silently drop the command and
wait for the host to retry.
Reported-by: Steve Wise <swise@opengridcomputing.com>
Tested-by: Steve Wise <swise@opengridcomputing.com>
Signed-off-by: Sagi Grimberg <sagi@grimberg.me>
[hch: dropped a superflous assignment]
[ Upstream commit 14427b86837a4baf1c121934c6599bdb67dfa9fc ]
snprintf() always returns the full length of the string it could have
printed, even if it was truncated because the buffer was too small.
So in case the counter value is truncated, we will over-read from
in_buffer and over-write to the caller's buffer.
I don't think it's actually possible for this to happen, but in case
truncation occurs, WARN and return -EIO.
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
[ Upstream commit 0d23ba6034b9cf48b8918404367506da3e4b3ee5 ]
The current code grabs the private_data of whatever file descriptor
userspace has supplied and implicitly casts it to a `struct ucma_file *`,
potentially causing a type confusion.
This is probably fine in practice because the pointer is only used for
comparisons, it is never actually dereferenced; and even in the
comparisons, it is unlikely that a file from another filesystem would have
a ->private_data pointer that happens to also be valid in this context.
But ->private_data is not always guaranteed to be a valid pointer to an
object owned by the file's filesystem; for example, some filesystems just
cram numbers in there.
Check the type of the supplied file descriptor to be safe, analogous to how
other places in the kernel do it.
Fixes: 88314e4dda1e ("RDMA/cma: add support for rdma_migrate_id()")
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
[ Upstream commit fa694160cca6dbba17c57dc7efec5f93feaf8795 ]
This makes sure that the SyS symbols are ignored for any powerpc system,
not just the big endian ones.
Reported-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Signed-off-by: Sandipan Das <sandipan@linux.ibm.com>
Reviewed-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Acked-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Ravi Bangoria <ravi.bangoria@linux.ibm.com>
Fixes: fb6d59423115 ("perf probe ppc: Use the right prefix when ignoring SyS symbols on ppc")
Link: http://lkml.kernel.org/r/20180828090848.1914-1-sandipan@linux.ibm.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit fd8d2702791a970c751f8b526a17d8e725a05b46 ]
If evsel is NULL, we should return NULL to avoid a NULL pointer
dereference a bit later in the code.
Signed-off-by: Hisao Tanabe <xtanabe@gmail.com>
Acked-by: Namhyung Kim <namhyung@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Fixes: 03e0a7df3efd ("perf tools: Introduce bpf-output event")
LPU-Reference: 20180824154556.23428-1-xtanabe@gmail.com
Link: https://lkml.kernel.org/n/tip-e5plzjhx6595a5yjaf22jss3@git.kernel.org
[ Upstream commit 43822c98f2ebb2cbd5e467ab72bbcdae7f0caa22 ]
Signed-off-by: Harry Mallon <hjmallon@gmail.com>
[ Upstream commit c37bd52836296ecc9a0fc8060b819089aebdbcde ]
There is no deallocation of fotg210->ep[i] elements, allocated at
fotg210_udc_probe.
The patch adds deallocation of fotg210->ep array elements and simplifies
error path of fotg210_udc_probe().
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Anton Vasilyev <vasilyev@ispras.ru>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
[ Upstream commit ee345492437043a79db058a3d4f029ebcb52089a ]
USB device
Vendor 05ac (Apple)
Device 026c (Magic Keyboard with Numeric Keypad)
Bluetooth devices
Vendor 004c (Apple)
Device 0267 (Magic Keyboard)
Support already exists for the Magic Keyboard over USB connection.
Add support for the Magic Keyboard over Bluetooth connection, and for
the Magic Keyboard with Numeric Keypad over Bluetooth and USB
connection.
Signed-off-by: Sean O'Brien <seobrien@chromium.org>
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit d41aa5252394c065d1f04d1ceea885b70d00c9c6 upstream.
Reproducer, assuming 2M of hugetlbfs available:
Hugetlbfs mounted, size=2M and option user=testuser
# mount | grep ^hugetlbfs
hugetlbfs on /dev/hugepages type hugetlbfs (rw,pagesize=2M,user=dan)
# sysctl vm.nr_hugepages=1
vm.nr_hugepages = 1
# grep Huge /proc/meminfo
AnonHugePages: 0 kB
ShmemHugePages: 0 kB
HugePages_Total: 1
HugePages_Free: 1
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
Hugetlb: 2048 kB
Code:
#include <sys/mman.h>
#include <stddef.h>
#define SIZE 2*1024*1024
int main()
void *ptr;
ptr = mmap(NULL, SIZE, PROT_READ | PROT_WRITE, MAP_PRIVATE | MAP_HUGETLB | MAP_ANONYMOUS, -1, 0);
madvise(ptr, SIZE, MADV_DONTDUMP);
madvise(ptr, SIZE, MADV_DODUMP);
Compile and strace:
mmap(NULL, 2097152, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_HUGETLB, -1, 0) = 0x7ff7c9200000
madvise(0x7ff7c9200000, 2097152, MADV_DONTDUMP) = 0
madvise(0x7ff7c9200000, 2097152, MADV_DODUMP) = -1 EINVAL (Invalid argument)
hugetlbfs pages have VM_DONTEXPAND in the VmFlags driver pages based on
author testing with analysis from Florian Weimer[1].
The inclusion of VM_DONTEXPAND into the VM_SPECIAL defination was a
consequence of the large useage of VM_DONTEXPAND in device drivers.
A consequence of [2] is that VM_DONTEXPAND marked pages are unable to be
marked DODUMP.
A user could quite legitimately madvise(MADV_DONTDUMP) their hugetlbfs
memory for a while and later request that madvise(MADV_DODUMP) on the same
memory. We correct this omission by allowing madvice(MADV_DODUMP) on
hugetlbfs pages.
[1] https://stackoverflow.com/questions/52548260/madvisedodump-on-the-same-ptr-size-as-a-successful-madvisedontdump-fails-wit
[2] commit 0103bd16fb90 ("mm: prepare VM_DONTDUMP for using in drivers")
Link: http://lkml.kernel.org/r/20180930054629.29150-1-daniel@linux.ibm.com
Link: https://lists.launchpad.net/maria-discuss/msg05245.html
Fixes: 0103bd16fb90 ("mm: prepare VM_DONTDUMP for using in drivers")
Reported-by: Kenneth Penza <kpenza@gmail.com>
Signed-off-by: Daniel Black <daniel@linux.ibm.com>
Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Konstantin Khlebnikov <khlebnikov@openvz.org>
[ Upstream commit 7ab660f8baecfe26c1c267fa8e64d2073feae2bb ]
debugfs_known_mountpoints[] is not used any more, so let's remove it.
Link: http://lkml.kernel.org/r/1535102651-19418-1-git-send-email-n-horiguchi@ah.jp.nec.com
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Matthew Wilcox <willy@infradead.org>
[ Upstream commit 904506562e0856f2535d876407d087c9459d345b ]
Currently we get the following compiler warning:
slabinfo.c:854:22: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (s->object_size < min_objsize)
due to the mismatch of signed/unsigned comparison. ->object_size and
->slab_size are never expected to be negative, so let's define them as
unsigned int.
[n-horiguchi@ah.jp.nec.com: convert everything - none of these can be negative]
Link: http://lkml.kernel.org/r/20180826234947.GA9787@hori1.linux.bs1.fc.nec.co.jp
Link: http://lkml.kernel.org/r/1535103134-20239-1-git-send-email-n-horiguchi@ah.jp.nec.com
[ Upstream commit c6e57b3896fc76299913b8cfd82d853bee8a2c84 ]
When tracing is enabled, all the debug messages are recorded and must
not exceed MAX_MSG_LEN (100) columns. Longer debug messages grant the
user with:
WARNING: CPU: 3 PID: 32642 at /tmp/wifi-core-20180806094828/src/iwlwifi-stack-dev/net/mac80211/./trace_msg.h:32 trace_event_raw_event_mac80211_msg_event+0xab/0xc0 [mac80211]
Workqueue: phy1 ieee80211_iface_work [mac80211]
RIP: 0010:trace_event_raw_event_mac80211_msg_event+0xab/0xc0 [mac80211]
Call Trace:
__sdata_dbg+0xbd/0x120 [mac80211]
ieee80211_ibss_rx_queued_mgmt+0x15f/0x510 [mac80211]
ieee80211_iface_work+0x21d/0x320 [mac80211]
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
[ Upstream commit 6c18b27d6e5c6a7206364eae2b47bc8d8b2fa68f ]
If the driver fails to properly prepare for the channel
switch, mac80211 will disconnect. If the CSA IE had mode
set to 1, it means that the clients are not allowed to send
any Tx on the current channel, and that includes the
deauthentication frame.
Make sure that we don't send the deauthentication frame in
this case.
In iwlwifi, this caused a failure to flush queues since the
firmware already closed the queues after having parsed the
CSA IE. Then mac80211 would wait until the deauthentication
frame would go out (drv_flush(drop=false)) and that would
never happen.
[ Upstream commit 0007e94355fdb71a1cf5dba0754155cba08f0666 ]
When performing a channel switch flow for a managed interface, the
flow did not update the bandwidth of the AP station and the rate
scale algorithm. In case of a channel width downgrade, this would
result with the rate scale algorithm using a bandwidth that does not
match the interface channel configuration.
Fix this by updating the AP station bandwidth and rate scaling algorithm
before the actual channel change in case of a bandwidth downgrade, or
after the actual channel change in case of a bandwidth upgrade.
Signed-off-by: Ilan Peer <ilan.peer@intel.com>
[ Upstream commit f3ffb6c3a28963657eb8b02a795d75f2ebbd5ef4 ]
We hit a problem with iwlwifi that was caused by a bug in
mac80211. A bug in iwlwifi caused the firwmare to crash in
certain cases in channel switch. Because of that bug,
drv_pre_channel_switch would fail and trigger the restart
flow.
Now we had the hw restart worker which runs on the system's
workqueue and the csa_connection_drop_work worker that runs
on mac80211's workqueue that can run together. This is
obviously problematic since the restart work wants to
reconfigure the connection, while the csa_connection_drop_work
worker does the exact opposite: it tries to disconnect.
Fix this by cancelling the csa_connection_drop_work worker
in the restart worker.
Note that this can sound racy: we could have:
driver iface_work CSA_work restart_work
<--drv_cs ---|
<FW CRASH!>
-CS FAILED-->
| cancel_work(CSA)
schedule |
CSA work |
Race between those 2
But this is not possible because we flush the workqueue
in the restart worker before we cancel the CSA worker.
That would be bullet proof if we could guarantee that
we schedule the CSA worker only from the iface_work
which runs on the workqueue (and not on the system's
workqueue), but unfortunately we do have an instance
in which we schedule the CSA work outside the context
of the workqueue (ieee80211_chswitch_done).
Note also that we should probably cancel other workers
like beacon_connection_loss_work and possibly others
for different types of interfaces, at the very least,
IBSS should suffer from the exact same problem, but for
now, do the minimum to fix the actual bug that was actually
experienced and reproduced.
[ Upstream commit 8442938c3a2177ba16043b3a935f2c78266ad399 ]
The "chandef->center_freq1" variable is a u32 but "freq" is a u16 so we
are truncating away the high bits. I noticed this bug because in commit
9cf0a0b4b64a ("cfg80211: Add support for 60GHz band channels 5 and 6")
we made "freq <= 56160 + 2160 * 6" a valid requency when before it was
only "freq <= 56160 + 2160 * 4" that was valid. It introduces a static
checker warning:
net/wireless/util.c:1571 ieee80211_chandef_to_operating_class()
warn: always true condition '(freq <= 56160 + 2160 * 6) => (0-u16max <= 69120)'
But really we probably shouldn't have been truncating the high bits
away to begin with.
[ Upstream commit c15e3f19a6d5c89b1209dc94b40e568177cb0921 ]
When a Mac client saves an item containing a backslash to a file server
the backslash is represented in the CIFS/SMB protocol as as U+F026.
Before this change, listing a directory containing an item with a
backslash in its name will return that item with the backslash
represented with a true backslash character (U+005C) because
convert_sfm_character mapped U+F026 to U+005C when interpretting the
CIFS/SMB protocol response. However, attempting to open or stat the
path using a true backslash will result in an error because
convert_to_sfm_char does not map U+005C back to U+F026 causing the
CIFS/SMB request to be made with the backslash represented as U+005C.
This change simply prevents the U+F026 to U+005C conversion from
happenning. This is analogous to how the code does not do any
translation of UNI_SLASH (U+F000).
Signed-off-by: Jon Kuhn <jkuhn@barracuda.com>
[ Upstream commit 16fe10cf92783ed9ceb182d6ea2b8adf5e8ec1b8 ]
The kernel module may sleep with holding a spinlock.
The function call paths (from bottom to top) in Linux-4.16 are:
[FUNC] usleep_range
drivers/net/ethernet/cadence/macb_main.c, 648:
usleep_range in macb_halt_tx
drivers/net/ethernet/cadence/macb_main.c, 730:
macb_halt_tx in macb_tx_error_task
drivers/net/ethernet/cadence/macb_main.c, 721:
_raw_spin_lock_irqsave in macb_tx_error_task
To fix this bug, usleep_range() is replaced with udelay().
This bug is found by my static analysis tool DSAC.
Signed-off-by: Jia-Ju Bai <baijiaju1990@gmail.com>
[ Upstream commit 4c85609b08c4761eca0a40fd7beb06bc650f252d ]
This driver currently emits a STOP if the next message is not
I2C_MD_RD. It should not do it because it disturbs the I2C_RDWR
ioctl, where read/write transactions are combined without STOP
between.
Issue STOP only when the message is the last one _or_ flagged with
I2C_M_STOP.
Fixes: 6a62974b667f ("i2c: uniphier_f: add UniPhier FIFO-builtin I2C driver")
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
[ Upstream commit 38f5d8d8cbb2ffa2b54315118185332329ec891c ]
between.
I2C_M_STOP.
Fixes: dd6fd4a32793 ("i2c: uniphier: add UniPhier FIFO-less I2C driver")
[ Upstream commit 1d0ffd264204eba1861865560f1f7f7a92919384 ]
In raid10 reshape_request it gets max_sectors in read_balance. If the underlayer disks
have bad blocks, the max_sectors is less than last. It will call goto read_more many
times. It calls raise_barrier(conf, sectors_done != 0) every time. In this condition
sectors_done is not 0. So the value passed to the argument force of raise_barrier is
true.
In raise_barrier it checks conf->barrier when force is true. If force is true and
conf->barrier is 0, it panic. In this case reshape_request submits bio to under layer
disks. And in the callback function of the bio it calls lower_barrier. If the bio
finishes before calling raise_barrier again, it can trigger the BUG_ON.
Add one pair of raise_barrier/lower_barrier to fix this bug.
Signed-off-by: Xiao Ni <xni@redhat.com>
Suggested-by: Neil Brown <neilb@suse.com>
Signed-off-by: Shaohua Li <shli@fb.com>
[ Upstream commit 3fcbb8260a87efb691d837e8cd24e81f65b3eb70 ]
In 4.19-rc1, Eugeniy reported weird boot and IO errors on ARC HSDK
| INFO: task syslogd:77 blocked for more than 10 seconds.
| Not tainted 4.19.0-rc1-00007-gf213acea4e88 #40
| "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this
| message.
| syslogd D 0 77 76 0x00000000
| Stack Trace:
| __switch_to+0x0/0xac
| __schedule+0x1b2/0x730
| io_schedule+0x5c/0xc0
| __lock_page+0x98/0xdc
| find_lock_entry+0x38/0x100
| shmem_getpage_gfp.isra.3+0x82/0xbfc
| shmem_fault+0x46/0x138
| handle_mm_fault+0x5bc/0x924
| do_page_fault+0x100/0x2b8
| ret_from_exception+0x0/0x8
He bisected to 84c6591103db ("locking/atomics,
asm-generic/bitops/lock.h: Rewrite using atomic_fetch_*()")
This commit however only unmasked the real issue introduced by commit
4aef66c8ae9 ("locking/atomic, arch/arc: Fix build") which missed the
retry-if-scond-failed branch in atomic_fetch_##op() macros.
The bisected commit started using atomic_fetch_##op() macros for building
the rest of atomics.
Fixes: 4aef66c8ae9 ("locking/atomic, arch/arc: Fix build")
Reported-by: Eugeniy Paltsev <paltsev@synopsys.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
[vgupta: wrote changelog]
[ Upstream commit d49b48f088c323dbacae44dfbe56d9c985c8a2a1 ]
gpiochip_add_data_with_key() adds the gpiochip to the gpio_devices list
before of_gpiochip_add() is called, but it's only the latter which sets
the ->of_xlate function pointer. gpiochip_find() can be called by
someone else between these two actions, and it can find the chip and
call of_gpiochip_match_node_and_xlate() which leads to the following
crash due to a NULL ->of_xlate().
Unhandled prefetch abort: page domain fault (0x01b) at 0x00000000
Modules linked in: leds_gpio(+) gpio_generic(+)
CPU: 0 PID: 830 Comm: insmod Not tainted 4.18.0+ #43
Hardware name: ARM-Versatile Express
PC is at (null)
LR is at of_gpiochip_match_node_and_xlate+0x2c/0x38
Process insmod (pid: 830, stack limit = 0x(ptrval))
(of_gpiochip_match_node_and_xlate) from (gpiochip_find+0x48/0x84)
(gpiochip_find) from (of_get_named_gpiod_flags+0xa8/0x238)
(of_get_named_gpiod_flags) from (gpiod_get_from_of_node+0x2c/0xc8)
(gpiod_get_from_of_node) from (devm_fwnode_get_index_gpiod_from_child+0xb8/0x144)
(devm_fwnode_get_index_gpiod_from_child) from (gpio_led_probe+0x208/0x3c4 [leds_gpio])
(gpio_led_probe [leds_gpio]) from (platform_drv_probe+0x48/0x9c)
(platform_drv_probe) from (really_probe+0x1d0/0x3d4)
(really_probe) from (driver_probe_device+0x78/0x1c0)
(driver_probe_device) from (__driver_attach+0x120/0x13c)
(__driver_attach) from (bus_for_each_dev+0x68/0xb4)
(bus_for_each_dev) from (bus_add_driver+0x1a8/0x268)
(bus_add_driver) from (driver_register+0x78/0x10c)
(driver_register) from (do_one_initcall+0x54/0x1fc)
(do_one_initcall) from (do_init_module+0x64/0x1f4)
(do_init_module) from (load_module+0x2198/0x26ac)
(load_module) from (sys_finit_module+0xe0/0x110)
(sys_finit_module) from (ret_fast_syscall+0x0/0x54)
One way to fix this would be to rework the hairy registration sequence
in gpiochip_add_data_with_key(), but since I'd probably introduce a
couple of new bugs if I attempted that, simply add a check for a
non-NULL of_xlate function pointer in
of_gpiochip_match_node_and_xlate(). This works since the driver looking
for the gpio will simply fail to find the gpio and defer its probe and
be reprobed when the driver which is registering the gpiochip has fully
completed its probe.
Signed-off-by: Vincent Whitchurch <vincent.whitchurch@axis.com>
