commit 6fdc6dd90272ce7e75d744f71535cfbd8d77da81 upstream.
The vsyscall32 sysctl can racy against a concurrent fork when it switches
from disabled to enabled:
arch_setup_additional_pages()
if (vdso32_enabled)
--> No mapping
sysctl.vsysscall32()
--> vdso32_enabled = true
create_elf_tables()
ARCH_DLINFO_IA32
if (vdso32_enabled) {
--> Add VDSO entry with NULL pointer
Make ARCH_DLINFO_IA32 check whether the VDSO mapping has been set up for
the newly forked process or not.
Acked-by: Andy Lutomirski <luto@amacapital.net>
Cc: Mathias Krause <minipli@googlemail.com>
Link: http://lkml.kernel.org/r/20170410151723.602367196@linutronix.de
commit c06989da39cdb10604d572c8c7ea8c8c97f3c483 upstream.
vdso_enabled can be set to arbitrary integer values via the kernel command
line 'vdso32=' parameter or via 'sysctl abi.vsyscall32'.
load_vdso32() only maps VDSO if vdso_enabled == 1, but ARCH_DLINFO_IA32
merily checks for vdso_enabled != 0. As a consequence the AT_SYSINFO_EHDR
auxiliary vector for the VDSO_ENTRY is emitted with a NULL pointer which
causes a segfault when the application tries to use the VDSO.
Restrict the valid arguments on the command line and the sysctl to 0 and 1.
Fixes: b0b49f2673f0 ("x86, vdso: Remove compat vdso support")
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Roland McGrath <roland@redhat.com>
Link: http://lkml.kernel.org/r/1491424561-7187-1-git-send-email-minipli@googlemail.com
Link: http://lkml.kernel.org/r/20170410151723.518412863@linutronix.de
commit 11e63f6d920d6f2dfd3cd421e939a4aec9a58dcd upstream.
Before we rework the "pmem api" to stop abusing __copy_user_nocache()
for memcpy_to_pmem() we need to fix cases where we may strand dirty data
in the cpu cache. The problem occurs when copy_from_iter_pmem() is used
for arbitrary data transfers from userspace. There is no guarantee that
these transfers, performed by dax_iomap_actor(), will have aligned
destinations or aligned transfer lengths. Backstop the usage
__copy_user_nocache() with explicit cache management in these unaligned
cases.
Yes, copy_from_iter_pmem() is now too big for an inline, but addressing
that is saved for a later patch that moves the entirety of the "pmem
api" into the pmem driver directly.
Fixes: 5de490daec8b ("pmem: add copy_from_iter_pmem() and clear_pmem()")
Cc: <x86@kernel.org>
Cc: Jan Kara <jack@suse.cz>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
commit cfac6dfa42bddfa9711b20d486e521d1a41ab09f upstream.
Put the right values from the original siginfo into the
userspace compat-siginfo.
This fixes the 32-bit MPX "tabletest" testcase on 64-bit kernels.
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Acked-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Dmitry Safonov <0x7f454c46@gmail.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Fixes: a4455082dc6f0 ('x86/signals: Add missing signal_compat code for x86 features')
Link: http://lkml.kernel.org/r/1491322501-5054-1-git-send-email-joro@8bytes.org
commit 6f6266a561306e206e0e31a5038f029b6a7b1d89 upstream.
Reserving a runtime region results in splitting the EFI memory
descriptors for the runtime region. This results in runtime region
descriptors with bogus memory mappings, leading to interesting crashes
like the following during a kexec:
general protection fault: 0000 [#1] SMP
Modules linked in:
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.11.0-rc1 #53
Hardware name: Wiwynn Leopard-Orv2/Leopard-DDR BW, BIOS LBM05 09/30/2016
RIP: 0010:virt_efi_set_variable()
Call Trace:
efi_delete_dummy_variable()
efi_enter_virtual_mode()
start_kernel()
? set_init_arg()
x86_64_start_reservations()
x86_64_start_kernel()
start_cpu()
Kernel panic - not syncing: Fatal exception
Runtime regions will not be freed and do not need to be reserved, so
skip the memmap modification in this case.
Signed-off-by: Omar Sandoval <osandov@fb.com>
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Dave Young <dyoung@redhat.com>
Cc: Peter Jones <pjones@redhat.com>
Cc: linux-efi@vger.kernel.org
Fixes: 8e80632fb23f ("efi/esrt: Use efi_mem_reserve() and avoid a kmalloc()")
Link: http://lkml.kernel.org/r/20170412152719.9779-2-matt@codeblueprint.co.uk
commit f2200ac311302fcdca6556fd0c5127eab6c65a3e upstream.
When the perf_branch_entry::{in_tx,abort,cycles} fields were added,
intel_pmu_lbr_read_32() wasn't updated to initialize them.
Fixes: 135c5612c460 ("perf/x86/intel: Support Haswell/v4 LBR format")
commit 5376366886251e2f8f248704adb620a4bc4c0937 upstream.
Signed-off-by: Cameron Gutman <aicommander@gmail.com>
commit 1fa839b4986d648b907d117275869a0e46c324b9 upstream.
This fixes Continuous Availability when errors during
file reopen are encountered.
cifs_user_readv and cifs_user_writev would wait for ever if
results of cifs_reopen_file are not stored and for later inspection.
In fact, results are checked and, in case of errors, a chain
of function calls leading to reads and writes to be scheduled in
a separate thread is skipped.
These threads will wake up the corresponding waiters once reads
and writes are done.
However, given the return value is not stored, when rc is checked
for errors a previous one (always zero) is inspected instead.
This leads to pending reads/writes added to the list, making
cifs_user_readv and cifs_user_writev wait for ever.
Signed-off-by: Germano Percossi <germano.percossi@citrix.com>
Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 18ea43113f5b74a97dd4be9bddbac10d68b1a6ce upstream.
In case of error, smb2_reconnect_server reschedule itself
with a delay, to avoid being too aggressive.
commit 45abdf35cf82e4270328c7237e7812de960ac560 upstream.
Add the missing unlock before return from function etnaviv_gpu_submit()
in the error handling case.
lst: fixed label name.
Fixes: f3cd1b064f11 ("drm/etnaviv: (re-)protect fence allocation with GPU mutex")
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
commit f94773b9f5ecd1df7c88c2e921924dd41d2020cc upstream.
The NV4A (aka NV44A) is an oddity in the family. It only comes in AGP
and PCI varieties, rather than a core PCIE chip with a bridge for
AGP/PCI as necessary. As a result, it appears that the MMU is also
non-functional. For AGP cards, the vast majority of the NV4A lineup,
this worked out since we force AGP cards to use the nv04 mmu. However
for PCI variants, this did not work.
Switching to the NV04 MMU makes it work like a charm. Thanks to mwk for
the suggestion. This should be a no-op for NV4A AGP boards, as they were
using it already.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=70388
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
commit 83bce9c2baa51e439480a713119a73d3c8b61083 upstream.
Fixes: 590801c1a3 ("drm/nouveau/mpeg: remove dependence on namedb/engctx lookup")
commit 1ec1688c5360e14dde4094d6acbf7516bf6db37e upstream.
Otherwise lockdep says:
[ 1337.483798] ================================================
[ 1337.483999] [ BUG: lock held when returning to user space! ]
[ 1337.484252] 4.11.0-rc6 #19 Not tainted
[ 1337.484423] ------------------------------------------------
[ 1337.484626] mount/14766 is leaving the kernel with locks still held!
[ 1337.484841] 1 lock held by mount/14766:
[ 1337.485017] #0: (&type->s_umount_key#33/1){+.+.+.}, at: [<ffffffff8124171f>] sget_userns+0x2af/0x520
Caught by xfstests generic/413 which tried to mount with the unsupported
mount option dax. Then xfstests generic/422 ran sync which deadlocks.
Signed-off-by: Martin Brandenburg <martin@omnibond.com>
Acked-by: Mike Marshall <hubcap@omnibond.com>
commit 85d492f28d056c40629fc25d79f54da618a29dc4 upstream.
Now 64K page system, zsamlloc has 257 classes so 8 class bit is not
enough. With that, it corrupts the system when zsmalloc stores
65536byte data(ie, index number 256) so that this patch increases class
bit for simple fix for stable backport. We should clean up this mess
soon.
index size
0 32
1 288
204 52256
256 65536
Fixes: 3783689a1 ("zsmalloc: introduce zspage structure")
Link: http://lkml.kernel.org/r/1492042622-12074-3-git-send-email-minchan@kernel.org
Signed-off-by: Minchan Kim <minchan@kernel.org>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
commit 5b7abeae3af8c08c577e599dd0578b9e3ee6687b upstream.
Yet another instance of the same race.
Fix is identical to change_huge_pmd().
See "thp: fix MADV_DONTNEED vs. numa balancing race" for more details.
Link: http://lkml.kernel.org/r/20170302151034.27829-5-kirill.shutemov@linux.intel.com
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
commit 58ceeb6bec86d9140f9d91d71a710e963523d063 upstream.
Both MADV_DONTNEED and MADV_FREE handled with down_read(mmap_sem).
It's critical to not clear pmd intermittently while handling MADV_FREE
to avoid race with MADV_DONTNEED:
CPU0: CPU1:
madvise_free_huge_pmd()
pmdp_huge_get_and_clear_full()
madvise_dontneed()
zap_pmd_range()
pmd_trans_huge(*pmd) == 0 (without ptl)
// skip the pmd
set_pmd_at();
// pmd is re-established
It results in MADV_DONTNEED skipping the pmd, leaving it not cleared.
It violates MADV_DONTNEED interface and can result is userspace
misbehaviour.
Basically it's the same race as with numa balancing in
change_huge_pmd(), but a bit simpler to mitigate: we don't need to
preserve dirty/young flags here due to MADV_FREE functionality.
[kirill.shutemov@linux.intel.com: Urgh... Power is special again]
Link: http://lkml.kernel.org/r/20170303102636.bhd2zhtpds4mt62a@black.fi.intel.com
Link: http://lkml.kernel.org/r/20170302151034.27829-4-kirill.shutemov@linux.intel.com
Acked-by: Minchan Kim <minchan@kernel.org>
Cc: Minchan Kim <minchan@kernel.org>
commit a5d68ba85801a78c892a0eb8efb711e293ed314b upstream.
For the bidirectional case, the Data-Out buffer blocks will always at
the head of the tcmu_cmd's bitmap, and before gathering the Data-In
buffer, first of all it should skip the Data-Out ones, or the device
supporting BIDI commands won't work.
Fixed: 26418649eead ("target/user: Introduce data_bitmap, replace
data_length/data_head/data_tail")
Reported-by: Ilias Tsitsimpis <iliastsi@arrikto.com>
Tested-by: Ilias Tsitsimpis <iliastsi@arrikto.com>
Signed-off-by: Xiubo Li <lixiubo@cmss.chinamobile.com>
commit abe342a5b4b5aa579f6bf40ba73447c699e6b579 upstream.
The t_data_nents and t_bidi_data_nents are the numbers of the
segments, but it couldn't be sure the block size equals to size
of the segment.
For the worst case, all the blocks are discontiguous and there
will need the same number of iovecs, that's to say: blocks == iovs.
So here just set the number of iovs to block count needed by tcmu
cmd.
Reviewed-by: Mike Christie <mchristi@redhat.com>
commit ab22d2604c86ceb01bb2725c9860b88a7dd383bb upstream.
If there has BIDI data, its first iov[] will overwrite the last
iov[] for se_cmd->t_data_sg.
To fix this, we can just increase the iov pointer, but this may
introuduce a new memory leakage bug: If the se_cmd->data_length
and se_cmd->t_bidi_data_sg->length are all not aligned up to the
DATA_BLOCK_SIZE, the actual length needed maybe larger than just
sum of them.
So, this could be avoided by rounding all the data lengthes up
to DATA_BLOCK_SIZE.
Reviewed-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com>
non-root cgroups
commit 77f88796cee819b9c4562b0b6b44691b3b7755b1 upstream.
Creation of a kthread goes through a couple interlocked stages between
the kthread itself and its creator. Once the new kthread starts
running, it initializes itself and wakes up the creator. The creator
then can further configure the kthread and then let it start doing its
job by waking it up.
In this configuration-by-creator stage, the creator is the only one
that can wake it up but the kthread is visible to userland. When
altering the kthread's attributes from userland is allowed, this is
fine; however, for cases where CPU affinity is critical,
kthread_bind() is used to first disable affinity changes from userland
and then set the affinity. This also prevents the kthread from being
migrated into non-root cgroups as that can affect the CPU affinity and
many other things.
Unfortunately, the cgroup side of protection is racy. While the
PF_NO_SETAFFINITY flag prevents further migrations, userland can win
the race before the creator sets the flag with kthread_bind() and put
the kthread in a non-root cgroup, which can lead to all sorts of
problems including incorrect CPU affinity and starvation.
This bug got triggered by userland which periodically tries to migrate
all processes in the root cpuset cgroup to a non-root one. Per-cpu
workqueue workers got caught while being created and ended up with
incorrected CPU affinity breaking concurrency management and sometimes
stalling workqueue execution.
This patch adds task->no_cgroup_migration which disallows the task to
be migrated by userland. kthreadd starts with the flag set making
every child kthread start in the root cgroup with migration
disallowed. The flag is cleared after the kthread finishes
initialization by which time PF_NO_SETAFFINITY is set if the kthread
should stay in the root cgroup.
It'd be better to wait for the initialization instead of failing but I
couldn't think of a way of implementing that without adding either a
new PF flag, or sleeping and retrying from waiting side. Even if
userland depends on changing cgroup membership of a kthread, it either
has to be synchronized with kthread_create() or periodically repeat,
so it's unlikely that this would break anything.
v2: Switch to a simpler implementation using a new task_struct bit
field suggested by Oleg.
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Reported-and-debugged-by: Chris Mason <clm@fb.com>
commit 888022c0473d079bff9b47fb50434b1f20f8f37f upstream.
Add compat ioctl support to dma-buf. This lets one to use DMA_BUF_IOCTL_SYNC
ioctl from 32bit application on 64bit kernel. Data structures for both 32
and 64bit modes are same, so there is no need for additional translation
layer.
Reviewed-by: Christian König <christian.koenig@amd.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
Link: http://patchwork.freedesktop.org/patch/msgid/1487683261-2655-1-git-send-email-m.szyprowski@samsung.com
transitions
commit 7c3945bc2073554bb2ecf983e073dee686679c53 upstream.
Save the qp context flags byte containing the flag disabling vlan stripping
in the RESET to INIT qp transition, rather than in the INIT to RTR
transition. Per the firmware spec, the flags in this byte are active
in the RESET to INIT transition.
As a result of saving the flags in the incorrect qp transition, when
switching dynamically from VGT to VST and back to VGT, the vlan
remained stripped (as is required for VST) and did not return to
not-stripped (as is required for VGT).
Fixes: f0f829bf42cd ("net/mlx4_core: Add immediate activate for VGT->VST->VGT")
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Tariq Toukan <tariqt@mellanox.com>
commit 291c566a28910614ce42d0ffe82196eddd6346f4 upstream.
In function mlx4_cq_completion() and mlx4_cq_event(), the
radix_tree_lookup requires a rcu_read_lock.
This is mandatory: if another core frees the CQ, it could
run the radix_tree_node_rcu_free() call_rcu() callback while
its being used by the radix tree lookup function.
Additionally, in function mlx4_cq_event(), since we are adding
the rcu lock around the radix-tree lookup, we no longer need to take
the spinlock. Also, the synchronize_irq() call for the async event
eliminates the need for incrementing the cq reference count in
mlx4_cq_event().
Other changes:
1. In function mlx4_cq_free(), replace spin_lock_irq with spin_lock:
we no longer take this spinlock in the interrupt context.
The spinlock here, therefore, simply protects against different
threads simultaneously invoking mlx4_cq_free() for different cq's.
2. In function mlx4_cq_free(), we move the radix tree delete to before
the synchronize_irq() calls. This guarantees that we will not
access this cq during any subsequent interrupts, and therefore can
safely free the CQ after the synchronize_irq calls. The rcu_read_lock
in the interrupt handlers only needs to protect against corrupting the
radix tree; the interrupt handlers may access the cq outside the
rcu_read_lock due to the synchronize_irq calls which protect against
premature freeing of the cq.
3. In function mlx4_cq_event(), we change the mlx_warn message to mlx4_dbg.
4. We leave the cq reference count mechanism in place, because it is
still needed for the cq completion tasklet mechanism.
Fixes: 6d90aa5cf17b ("net/mlx4_core: Make sure there are no pending async events when freeing CQ")
Fixes: 225c7b1feef1 ("IB/mlx4: Add a driver Mellanox ConnectX InfiniBand adapters")
Signed-off-by: Matan Barak <matanb@mellanox.com>
commit 6496bbf0ec481966ef9ffe5b6660d8d1b55c60cc upstream.
Single send WQE in RX buffer should be stamped with software
ownership in order to prevent the flow of QP in error in FW
once UPDATE_QP is called.
Fixes: 9f519f68cfff ('mlx4_en: Not using Shared Receive Queues')
Signed-off-by: Eugenia Emantayev <eugenia@mellanox.com>
commit 22547c4cc4fe20698a6a85a55b8788859134b8e4 upstream.
On a system with a defective USB device connected to an USB hub,
an endless sequence of port connect events was observed. The sequence
of events as observed is as follows:
- Port reports connected event (port status=USB_PORT_STAT_CONNECTION).
- Event handler debounces port and resets it by calling hub_port_reset().
- hub_port_reset() calls hub_port_wait_reset() to wait for the reset
to complete.
- The reset completes, but USB_PORT_STAT_CONNECTION is not immediately
set in the port status register.
- hub_port_wait_reset() returns -ENOTCONN.
- Port initialization sequence is aborted.
- A few milliseconds later, the port again reports a connected event,
and the sequence repeats.
This continues either forever or, randomly, stops if the connection
is already re-established when the port status is read. It results in
a high rate of udev events. This in turn destabilizes userspace since
the above sequence holds the device mutex pretty much continuously
and prevents userspace from actually reading the device status.
To prevent the problem from happening, let's wait for the connection
to be re-established after a port reset. If the device was actually
disconnected, the code will still return an error, but it will do so
only after the long reset timeout.
Cc: Douglas Anderson <dianders@chromium.org>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 36e1f3d107867b25c616c2fd294f5a1c9d4e5d09 upstream.
While stressing memory and IO at the same time we changed SMT settings,
we were able to consistently trigger deadlocks in the mm system, which
froze the entire machine.
I think that under memory stress conditions, the large allocations
performed by blk_mq_init_rq_map may trigger a reclaim, which stalls
waiting on the block layer remmaping completion, thus deadlocking the
system. The trace below was collected after the machine stalled,
waiting for the hotplug event completion.
The simplest fix for this is to make allocations in this path
non-reclaimable, with GFP_NOIO. With this patch, We couldn't hit the
issue anymore.
This should apply on top of Jens's for-next branch cleanly.
Changes since v1:
- Use GFP_NOIO instead of GFP_NOWAIT.
Call Trace:
[c000000f0160aaf0] [c000000f0160ab50] 0xc000000f0160ab50 (unreliable)
[c000000f0160acc0] [c000000000016624] __switch_to+0x2e4/0x430
[c000000f0160ad20] [c000000000b1a880] __schedule+0x310/0x9b0
[c000000f0160ae00] [c000000000b1af68] schedule+0x48/0xc0
[c000000f0160ae30] [c000000000b1b4b0] schedule_preempt_disabled+0x20/0x30
[c000000f0160ae50] [c000000000b1d4fc] __mutex_lock_slowpath+0xec/0x1f0
[c000000f0160aed0] [c000000000b1d678] mutex_lock+0x78/0xa0
[c000000f0160af00] [d000000019413cac] xfs_reclaim_inodes_ag+0x33c/0x380 [xfs]
[c000000f0160b0b0] [d000000019415164] xfs_reclaim_inodes_nr+0x54/0x70 [xfs]
[c000000f0160b0f0] [d0000000194297f8] xfs_fs_free_cached_objects+0x38/0x60 [xfs]
[c000000f0160b120] [c0000000003172c8] super_cache_scan+0x1f8/0x210
[c000000f0160b190] [c00000000026301c] shrink_slab.part.13+0x21c/0x4c0
[c000000f0160b2d0] [c000000000268088] shrink_zone+0x2d8/0x3c0
[c000000f0160b380] [c00000000026834c] do_try_to_free_pages+0x1dc/0x520
[c000000f0160b450] [c00000000026876c] try_to_free_pages+0xdc/0x250
[c000000f0160b4e0] [c000000000251978] __alloc_pages_nodemask+0x868/0x10d0
[c000000f0160b6f0] [c000000000567030] blk_mq_init_rq_map+0x160/0x380
[c000000f0160b7a0] [c00000000056758c] blk_mq_map_swqueue+0x33c/0x360
[c000000f0160b820] [c000000000567904] blk_mq_queue_reinit+0x64/0xb0
[c000000f0160b850] [c00000000056a16c] blk_mq_queue_reinit_notify+0x19c/0x250
[c000000f0160b8a0] [c0000000000f5d38] notifier_call_chain+0x98/0x100
[c000000f0160b8f0] [c0000000000c5fb0] __cpu_notify+0x70/0xe0
[c000000f0160b930] [c0000000000c63c4] notify_prepare+0x44/0xb0
[c000000f0160b9b0] [c0000000000c52f4] cpuhp_invoke_callback+0x84/0x250
[c000000f0160ba10] [c0000000000c570c] cpuhp_up_callbacks+0x5c/0x120
[c000000f0160ba60] [c0000000000c7cb8] _cpu_up+0xf8/0x1d0
[c000000f0160bac0] [c0000000000c7eb0] do_cpu_up+0x120/0x150
[c000000f0160bb40] [c0000000006fe024] cpu_subsys_online+0x64/0xe0
[c000000f0160bb90] [c0000000006f5124] device_online+0xb4/0x120
[c000000f0160bbd0] [c0000000006f5244] online_store+0xb4/0xc0
[c000000f0160bc20] [c0000000006f0a68] dev_attr_store+0x68/0xa0
[c000000f0160bc60] [c0000000003ccc30] sysfs_kf_write+0x80/0xb0
[c000000f0160bca0] [c0000000003cbabc] kernfs_fop_write+0x17c/0x250
[c000000f0160bcf0] [c00000000030fe6c] __vfs_write+0x6c/0x1e0
[c000000f0160bd90] [c000000000311490] vfs_write+0xd0/0x270
[c000000f0160bde0] [c0000000003131fc] SyS_write+0x6c/0x110
[c000000f0160be30] [c000000000009204] system_call+0x38/0xec
Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com>
Cc: Brian King <brking@linux.vnet.ibm.com>
Cc: Douglas Miller <dougmill@linux.vnet.ibm.com>
Cc: linux-block@vger.kernel.org
Cc: linux-scsi@vger.kernel.org
Signed-off-by: Jens Axboe <axboe@fb.com>
commit 2b6867c2ce76c596676bec7d2d525af525fdc6e2 upstream.
Subtracting tp_sizeof_priv from tp_block_size and casting to int
to check whether one is less then the other doesn't always work
(both of them are unsigned ints).
Compare them as is instead.
Also cast tp_sizeof_priv to u64 before using BLK_PLUS_PRIV, as
it can overflow inside BLK_PLUS_PRIV otherwise.
Signed-off-by: Andrey Konovalov <andreyknvl@google.com>
This reverts commit f2a0409a08502d64fbe3990354dff5902b08d2fb which is
commit bafb2f7d4755bf1571bd5e9a03b97f3fc4fe69ae upstream.
It was reported to have problems.
Cc: Jani Nikula <jani.nikula@linux.intel.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Cc: Eric Blau <eblau1@gmail.com>
Signed-off-by: Greg Kroah-Hartman gregkh@linuxfoundation.org
commit 33fa46d7b310e06d2cb2ab5417c100af120bfb65 upstream.
In case caam_jr_alloc() fails, ctx->dev carries the error code,
thus accessing it with dev_err() is incorrect.
Fixes: 8c419778ab57e ("crypto: caam - add support for RSA algorithm")
Signed-off-by: Horia Geantă <horia.geanta@nxp.com>
commit 40c98cb57cdbc377456116ad4582c89e329721b0 upstream.
RNG instantiation was previously fixed by
commit 62743a4145bb9 ("crypto: caam - fix RNG init descriptor ret. code checking")
while deinstantiation was not addressed.
Since the descriptors used are similar, in the sense that they both end
with a JUMP HALT command, checking for errors should be similar too,
i.e. status code 7000_0000h should be considered successful.
Fixes: 1005bccd7a4a6 ("crypto: caam - enable instantiation of all RNG4 state handles")
commit c25f8064c1d5731a2ce5664def890140dcdd3e5c upstream.
Commit dda45f701c9d ("MIPS: Switch to the irq_stack in interrupts")
changed both the normal and vectored interrupt handlers. Unfortunately
the vectored version, "except_vec_vi_handler", was incorrectly modified
to unconditionally jal to plat_irq_dispatch, rather than doing a jalr to
the vectored handler that has been set up. This is ok for many platforms
which set the vectored handler to plat_irq_dispatch anyway, but will
cause problems with platforms that use other handlers.
Fixes: dda45f701c9d ("MIPS: Switch to the irq_stack in interrupts")
Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/15110/
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit 3cc3434fd6307d06b53b98ce83e76bf9807689b9 upstream.
Since do_IRQ is now invoked on a separate IRQ stack, we select
HAVE_IRQ_EXIT_ON_IRQ_STACK so that softirq's may be invoked directly
from irq_exit(), rather than requiring do_softirq_own_stack.
Acked-by: Jason A. Donenfeld <jason@zx2c4.com>
Patchwork: https://patchwork.linux-mips.org/patch/14744/
commit dda45f701c9d7ad4ac0bb446e3a96f6df9a468d9 upstream.
When enterring interrupt context via handle_int or except_vec_vi, switch
to the irq_stack of the current CPU if it is not already in use.
The current stack pointer is masked with the thread size and compared to
the base or the irq stack. If it does not match then the stack pointer
is set to the top of that stack, otherwise this is a nested irq being
handled on the irq stack so the stack pointer should be left as it was.
The in-use stack pointer is placed in the callee saved register s1. It
will be saved to the stack when plat_irq_dispatch is invoked and can be
restored once control returns here.
Cc: James Hogan <james.hogan@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14743/
commit 510d86362a27577f5ee23f46cfb354ad49731e61 upstream.
The SAVE_SOME macro is used to save the execution context on all
exceptions.
If an exception occurs while executing user code, the stack is switched
to the kernel's stack for the current task, and register $28 is switched
to point to the current_thread_info, which is at the bottom of the stack
region.
If the exception occurs while executing kernel code, the stack is left,
and this change ensures that register $28 is not updated. This is the
correct behaviour when the kernel can be executing on the separate irq
stack, because the thread_info will not be at the base of it.
With this change, register $28 is only switched to it's kernel
conventional usage of the currrent thread info pointer at the point at
which execution enters kernel space. Doing it on every exception was
redundant, but OK without an IRQ stack, but will be erroneous once that
is introduced.
Patchwork: https://patchwork.linux-mips.org/patch/14742/
commit d42d8d106b0275b027c1e8992c42aecf933436ea upstream.
Within unwind stack, check if the stack pointer being unwound is within
the CPU's irq_stack and if so use that page rather than the task's stack
page.
Cc: Adam Buchbinder <adam.buchbinder@gmail.com>
Cc: Maciej W. Rozycki <macro@imgtec.com>
Cc: Marcin Nowakowski <marcin.nowakowski@imgtec.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Patchwork: https://patchwork.linux-mips.org/patch/14741/
commit fe8bd18ffea5327344d4ec2bf11f47951212abd0 upstream.
Allocate a per-cpu irq stack for use within interrupt handlers.
Also add a utility function on_irq_stack to determine if a given stack
pointer is within the irq stack for that cpu.
Cc: Petr Mladek <pmladek@suse.com>
Cc: Aaron Tomlin <atomlin@redhat.com>
Patchwork: https://patchwork.linux-mips.org/patch/14740/
commit bd5d21310133921021d78995ad6346f908483124 upstream.
After parsing TRX we should skip to the first block placed behind it.
Our code was working only with TRX with length not aligned to the
blocksize. In other cases (length aligned) it was missing the block
places right after TRX.
This fixes calculation and simplifies the comment.
Signed-off-by: Rafał Miłecki <rafal@milecki.pl>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
commit a083c8fd277b4122c804f18ec8c84165f345c71c upstream.
In device removal routine, usage of "#ifdef CONFIG_RT2X00_LIB_USB"
will not cover the case when it is configured as module. This will
omit the entire if-block which does cleanup of URBs and cancellation
of pending work. Changing the #ifdef to #if IS_ENABLED() to fix it.
Signed-off-by: Vishal Thanki <vishalthanki@gmail.com>
Acked-by: Stanislaw Gruszka <sgruszka@redhat.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 93c7018ec16bb83399dd4db61c361a6d6aba0d5a upstream.
We might kill TX or RX urb during rt2x00usb_flush_entry(), what can
cause anchor list corruption like shown below:
[ 2074.035633] WARNING: CPU: 2 PID: 14480 at lib/list_debug.c:33 __list_add+0xac/0xc0
[ 2074.035634] list_add corruption. prev->next should be next (ffff88020f362c28), but was dead000000000100. (prev=ffff8801d161bb70).
<snip>
[ 2074.035670] Call Trace:
[ 2074.035672] [<ffffffff813bde47>] dump_stack+0x63/0x8c
[ 2074.035674] [<ffffffff810a2231>] __warn+0xd1/0xf0
[ 2074.035676] [<ffffffff810a22af>] warn_slowpath_fmt+0x5f/0x80
[ 2074.035678] [<ffffffffa073855d>] ? rt2x00usb_register_write_lock+0x3d/0x60 [rt2800usb]
[ 2074.035679] [<ffffffff813dbe4c>] __list_add+0xac/0xc0
[ 2074.035681] [<ffffffff81591c6c>] usb_anchor_urb+0x4c/0xa0
[ 2074.035683] [<ffffffffa07322af>] rt2x00usb_kick_rx_entry+0xaf/0x100 [rt2x00usb]
[ 2074.035684] [<ffffffffa0732322>] rt2x00usb_clear_entry+0x22/0x30 [rt2x00usb]
To fix do not anchor TX and RX urb's, it is not needed as during
shutdown we kill those urbs in rt2x00usb_free_entries().
Cc: Vishal Thanki <vishalthanki@gmail.com>
Fixes: 8b4c0009313f ("rt2x00usb: Use usb anchor to manage URB")
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit 0488a6121dfe6cbd44de15ea3627913b7549a1e9 upstream.
If device fail to initialize we can OOPS in rt2x00lib_remove_dev(), due
to using uninitialized usb_anchor structure:
[ 855.435820] ieee80211 phy3: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1000 with error -19
[ 855.435826] ieee80211 phy3: rt2800_probe_rt: Error - Invalid RT chipset 0x0000, rev 0000 detected
[ 855.435829] ieee80211 phy3: rt2x00lib_probe_dev: Error - Failed to allocate device
[ 855.435845] BUG: unable to handle kernel NULL pointer dereference at 0000000000000028
[ 855.435900] IP: _raw_spin_lock_irq+0xd/0x30
[ 855.435926] PGD 0
[ 855.435953] Oops: 0002 [#1] SMP
<snip>
[ 855.437011] Call Trace:
[ 855.437029] ? usb_kill_anchored_urbs+0x27/0xc0
[ 855.437061] rt2x00lib_remove_dev+0x190/0x1c0 [rt2x00lib]
[ 855.437097] rt2x00lib_probe_dev+0x246/0x7a0 [rt2x00lib]
[ 855.437149] ? ieee80211_roc_setup+0x9e/0xd0 [mac80211]
[ 855.437183] ? __kmalloc+0x1af/0x1f0
[ 855.437207] ? rt2x00usb_probe+0x13d/0xc50 [rt2x00usb]
[ 855.437240] rt2x00usb_probe+0x155/0xc50 [rt2x00usb]
[ 855.437273] rt2800usb_probe+0x15/0x20 [rt2800usb]
[ 855.437304] usb_probe_interface+0x159/0x2d0
[ 855.437333] driver_probe_device+0x2bb/0x460
Patch changes initialization sequence to fix the problem.
Cc: Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit e2474541032db65d02bf88b6a8c2f954654b443f upstream.
Writing messages larger than the FIFO size results in a hang, rendering
the machine unusable. This is because the RXD status flag is set on the
first interrupt which results in bcm2835_drain_rxfifo() stealing bytes
from the buffer. The controller continues to trigger interrupts waiting
for the missing bytes, but bcm2835_fill_txfifo() has none to give.
In this situation wait_for_completion_timeout() apparently is unable to
stop the madness.
The BCM2835 ARM Peripherals datasheet has this to say about the flags:
TXD: is set when the FIFO has space for at least one byte of data.
RXD: is set when the FIFO contains at least one byte of data.
TXW: is set during a write transfer and the FIFO is less than full.
RXR: is set during a read transfer and the FIFO is or more full.
Implementing the logic from the downstream i2c-bcm2708 driver solved
the hang problem.
Signed-off-by: Noralf Trønnes <noralf@tronnes.org>
Reviewed-by: Eric Anholt <eric@anholt.net>
Reviewed-by: Martin Sperl <kernel@martin.sperl.org>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit eb68d0324dc4d88ab0d6159bdcd98c247a3a8954 upstream.
The deamon through which the kernel module communicates with the userspace
part of Orangefs, the "client-core", sends initialization data to the
kernel module with ioctl. The initialization data was built by the
client-core in a 2k buffer and copy_from_user'd into a 1k buffer
in the kernel module. When more than 1k of initialization data needed
to be sent, some was lost, reducing the usability of the control by which
debug levels are set. This patch sets the kernel side buffer to 2K to
match the userspace side...
Signed-off-by: Mike Marshall <hubcap@omnibond.com>
commit 05973c2efb40122f2a9ecde2d065f7ea5068d024 upstream.
This patch is simlar to one Dan Carpenter sent me, cleans
up some return codes and whitespace errors. There was one
place where he thought inserting an error message into
the ring buffer might be too chatty, I hope I convinced him
othewise. As a consolation <g> I changed a truly chatty
error message in another location into a debug message,
system-admins had already yelled at me about that one...
commit 4defb5f912a0ba60e07e91a4b62634814cd99b7f upstream.
allocates string 'new' is not free'd on the exit path when
cdm_element_count <= 0. Fix this by kfree'ing it.
Fixes CoverityScan CID#1375923 "Resource Leak"
commit 3d3d18f086cdda72ee18a454db70ca72c6e3246c upstream.
The rcu_barrier() takes the cpu_hotplug mutex which itself is not
reclaim-safe, and so rcu_barrier() is illegal from inside the shrinker.
[ 309.661373] =========================================================
[ 309.661376] [ INFO: possible irq lock inversion dependency detected ]
[ 309.661380] 4.11.0-rc1-CI-CI_DRM_2333+ #1 Tainted: G W
[ 309.661383] ---------------------------------------------------------
[ 309.661386] gem_exec_gttfil/6435 just changed the state of lock:
[ 309.661389] (rcu_preempt_state.barrier_mutex){+.+.-.}, at: [<ffffffff81100731>] _rcu_barrier+0x31/0x160
[ 309.661399] but this lock took another, RECLAIM_FS-unsafe lock in the past:
[ 309.661402] (cpu_hotplug.lock){+.+.+.}
[ 309.661404]
and interrupts could create inverse lock ordering between them.
[ 309.661410]
[ 309.661414] Possible interrupt unsafe locking scenario:
[ 309.661417] CPU0 CPU1
[ 309.661419] ---- ----
[ 309.661421] lock(cpu_hotplug.lock);
[ 309.661425] local_irq_disable();
[ 309.661432] lock(rcu_preempt_state.barrier_mutex);
[ 309.661441] lock(cpu_hotplug.lock);
[ 309.661446] <Interrupt>
[ 309.661448] lock(rcu_preempt_state.barrier_mutex);
[ 309.661453]
*** DEADLOCK ***
[ 309.661460] 4 locks held by gem_exec_gttfil/6435:
[ 309.661464] #0: (sb_writers#10){.+.+.+}, at: [<ffffffff8120d83d>] vfs_write+0x17d/0x1f0
[ 309.661475] #1: (debugfs_srcu){......}, at: [<ffffffff81320491>] debugfs_use_file_start+0x41/0xa0
[ 309.661486] #2: (&attr->mutex){+.+.+.}, at: [<ffffffff8123a3e7>] simple_attr_write+0x37/0xe0
[ 309.661495] #3: (&dev->struct_mutex){+.+.+.}, at: [<ffffffffa0091b4a>] i915_drop_caches_set+0x3a/0x150 [i915]
[ 309.661540]
the shortest dependencies between 2nd lock and 1st lock:
[ 309.661547] -> (cpu_hotplug.lock){+.+.+.} ops: 829 {
[ 309.661553] HARDIRQ-ON-W at:
[ 309.661560] __lock_acquire+0x5e5/0x1b50
[ 309.661565] lock_acquire+0xc9/0x220
[ 309.661572] __mutex_lock+0x6e/0x990
[ 309.661576] mutex_lock_nested+0x16/0x20
[ 309.661583] get_online_cpus+0x61/0x80
[ 309.661590] kmem_cache_create+0x25/0x1d0
[ 309.661596] debug_objects_mem_init+0x30/0x249
[ 309.661602] start_kernel+0x341/0x3fe
[ 309.661607] x86_64_start_reservations+0x2a/0x2c
[ 309.661612] x86_64_start_kernel+0x173/0x186
[ 309.661619] verify_cpu+0x0/0xfc
[ 309.661622] SOFTIRQ-ON-W at:
[ 309.661627] __lock_acquire+0x611/0x1b50
[ 309.661632] lock_acquire+0xc9/0x220
[ 309.661636] __mutex_lock+0x6e/0x990
[ 309.661641] mutex_lock_nested+0x16/0x20
[ 309.661646] get_online_cpus+0x61/0x80
[ 309.661650] kmem_cache_create+0x25/0x1d0
[ 309.661655] debug_objects_mem_init+0x30/0x249
[ 309.661660] start_kernel+0x341/0x3fe
[ 309.661664] x86_64_start_reservations+0x2a/0x2c
[ 309.661669] x86_64_start_kernel+0x173/0x186
[ 309.661674] verify_cpu+0x0/0xfc
[ 309.661677] RECLAIM_FS-ON-W at:
[ 309.661682] mark_held_locks+0x6f/0xa0
[ 309.661687] lockdep_trace_alloc+0xb3/0x100
[ 309.661693] kmem_cache_alloc_trace+0x31/0x2e0
[ 309.661699] __smpboot_create_thread.part.1+0x27/0xe0
[ 309.661704] smpboot_create_threads+0x61/0x90
[ 309.661709] cpuhp_invoke_callback+0x9c/0x8a0
[ 309.661713] cpuhp_up_callbacks+0x31/0xb0
[ 309.661718] _cpu_up+0x7a/0xc0
[ 309.661723] do_cpu_up+0x5f/0x80
[ 309.661727] cpu_up+0xe/0x10
[ 309.661734] smp_init+0x71/0xb3
[ 309.661738] kernel_init_freeable+0x94/0x19e
[ 309.661743] kernel_init+0x9/0xf0
[ 309.661748] ret_from_fork+0x2e/0x40
[ 309.661752] INITIAL USE at:
[ 309.661757] __lock_acquire+0x234/0x1b50
[ 309.661761] lock_acquire+0xc9/0x220
[ 309.661766] __mutex_lock+0x6e/0x990
[ 309.661771] mutex_lock_nested+0x16/0x20
[ 309.661775] get_online_cpus+0x61/0x80
[ 309.661780] __cpuhp_setup_state+0x44/0x170
[ 309.661785] page_alloc_init+0x23/0x3a
[ 309.661790] start_kernel+0x124/0x3fe
[ 309.661794] x86_64_start_reservations+0x2a/0x2c
[ 309.661799] x86_64_start_kernel+0x173/0x186
[ 309.661804] verify_cpu+0x0/0xfc
[ 309.661807] }
[ 309.661813] ... key at: [<ffffffff81e37690>] cpu_hotplug+0xb0/0x100
[ 309.661817] ... acquired at:
[ 309.661821] lock_acquire+0xc9/0x220
[ 309.661825] __mutex_lock+0x6e/0x990
[ 309.661829] mutex_lock_nested+0x16/0x20
[ 309.661833] get_online_cpus+0x61/0x80
[ 309.661837] _rcu_barrier+0x9f/0x160
[ 309.661841] rcu_barrier+0x10/0x20
[ 309.661847] netdev_run_todo+0x5f/0x310
[ 309.661852] rtnl_unlock+0x9/0x10
[ 309.661856] default_device_exit_batch+0x133/0x150
[ 309.661862] ops_exit_list.isra.0+0x4d/0x60
[ 309.661866] cleanup_net+0x1d8/0x2c0
[ 309.661872] process_one_work+0x1f4/0x6d0
[ 309.661876] worker_thread+0x49/0x4a0
[ 309.661881] kthread+0x107/0x140
[ 309.661884] ret_from_fork+0x2e/0x40
[ 309.661890] -> (rcu_preempt_state.barrier_mutex){+.+.-.} ops: 179 {
[ 309.661896] HARDIRQ-ON-W at:
[ 309.661901] __lock_acquire+0x5e5/0x1b50
[ 309.661905] lock_acquire+0xc9/0x220
[ 309.661910] __mutex_lock+0x6e/0x990
[ 309.661914] mutex_lock_nested+0x16/0x20
[ 309.661919] _rcu_barrier+0x31/0x160
[ 309.661923] rcu_barrier+0x10/0x20
[ 309.661928] netdev_run_todo+0x5f/0x310
[ 309.661932] rtnl_unlock+0x9/0x10
[ 309.661936] default_device_exit_batch+0x133/0x150
[ 309.661941] ops_exit_list.isra.0+0x4d/0x60
[ 309.661946] cleanup_net+0x1d8/0x2c0
[ 309.661951] process_one_work+0x1f4/0x6d0
[ 309.661955] worker_thread+0x49/0x4a0
[ 309.661960] kthread+0x107/0x140
[ 309.661964] ret_from_fork+0x2e/0x40
[ 309.661968] SOFTIRQ-ON-W at:
[ 309.661972] __lock_acquire+0x611/0x1b50
[ 309.661977] lock_acquire+0xc9/0x220
[ 309.661981] __mutex_lock+0x6e/0x990
[ 309.661986] mutex_lock_nested+0x16/0x20
[ 309.661990] _rcu_barrier+0x31/0x160
[ 309.661995] rcu_barrier+0x10/0x20
[ 309.661999] netdev_run_todo+0x5f/0x310
[ 309.662003] rtnl_unlock+0x9/0x10
[ 309.662008] default_device_exit_batch+0x133/0x150
[ 309.662013] ops_exit_list.isra.0+0x4d/0x60
[ 309.662017] cleanup_net+0x1d8/0x2c0
[ 309.662022] process_one_work+0x1f4/0x6d0
[ 309.662027] worker_thread+0x49/0x4a0
[ 309.662031] kthread+0x107/0x140
[ 309.662035] ret_from_fork+0x2e/0x40
[ 309.662039] IN-RECLAIM_FS-W at:
[ 309.662043] __lock_acquire+0x638/0x1b50
[ 309.662048] lock_acquire+0xc9/0x220
[ 309.662053] __mutex_lock+0x6e/0x990
[ 309.662058] mutex_lock_nested+0x16/0x20
[ 309.662062] _rcu_barrier+0x31/0x160
[ 309.662067] rcu_barrier+0x10/0x20
[ 309.662089] i915_gem_shrink_all+0x33/0x40 [i915]
[ 309.662109] i915_drop_caches_set+0x141/0x150 [i915]
[ 309.662114] simple_attr_write+0xc7/0xe0
[ 309.662119] full_proxy_write+0x4f/0x70
[ 309.662124] __vfs_write+0x23/0x120
[ 309.662128] vfs_write+0xc6/0x1f0
[ 309.662133] SyS_write+0x44/0xb0
[ 309.662138] entry_SYSCALL_64_fastpath+0x1c/0xb1
[ 309.662142] INITIAL USE at:
[ 309.662147] __lock_acquire+0x234/0x1b50
[ 309.662151] lock_acquire+0xc9/0x220
[ 309.662156] __mutex_lock+0x6e/0x990
[ 309.662160] mutex_lock_nested+0x16/0x20
[ 309.662165] _rcu_barrier+0x31/0x160
[ 309.662169] rcu_barrier+0x10/0x20
[ 309.662174] netdev_run_todo+0x5f/0x310
[ 309.662178] rtnl_unlock+0x9/0x10
[ 309.662183] default_device_exit_batch+0x133/0x150
[ 309.662188] ops_exit_list.isra.0+0x4d/0x60
[ 309.662192] cleanup_net+0x1d8/0x2c0
[ 309.662197] process_one_work+0x1f4/0x6d0
[ 309.662202] worker_thread+0x49/0x4a0
[ 309.662206] kthread+0x107/0x140
[ 309.662210] ret_from_fork+0x2e/0x40
[ 309.662214] }
[ 309.662220] ... key at: [<ffffffff81e4e1c8>] rcu_preempt_state+0x508/0x780
[ 309.662225] ... acquired at:
[ 309.662229] check_usage_forwards+0x12b/0x130
[ 309.662233] mark_lock+0x360/0x6f0
[ 309.662237] __lock_acquire+0x638/0x1b50
[ 309.662241] lock_acquire+0xc9/0x220
[ 309.662245] __mutex_lock+0x6e/0x990
[ 309.662249] mutex_lock_nested+0x16/0x20
[ 309.662253] _rcu_barrier+0x31/0x160
[ 309.662257] rcu_barrier+0x10/0x20
[ 309.662279] i915_gem_shrink_all+0x33/0x40 [i915]
[ 309.662298] i915_drop_caches_set+0x141/0x150 [i915]
[ 309.662303] simple_attr_write+0xc7/0xe0
[ 309.662307] full_proxy_write+0x4f/0x70
[ 309.662311] __vfs_write+0x23/0x120
[ 309.662315] vfs_write+0xc6/0x1f0
[ 309.662319] SyS_write+0x44/0xb0
[ 309.662323] entry_SYSCALL_64_fastpath+0x1c/0xb1
[ 309.662329]
stack backtrace:
[ 309.662335] CPU: 1 PID: 6435 Comm: gem_exec_gttfil Tainted: G W 4.11.0-rc1-CI-CI_DRM_2333+ #1
[ 309.662342] Hardware name: Hewlett-Packard HP Compaq 8100 Elite SFF PC/304Ah, BIOS 786H1 v01.13 07/14/2011
[ 309.662348] Call Trace:
[ 309.662354] dump_stack+0x67/0x92
[ 309.662359] print_irq_inversion_bug.part.19+0x1a4/0x1b0
[ 309.662365] check_usage_forwards+0x12b/0x130
[ 309.662369] mark_lock+0x360/0x6f0
[ 309.662374] ? print_shortest_lock_dependencies+0x1a0/0x1a0
[ 309.662379] __lock_acquire+0x638/0x1b50
[ 309.662383] ? __mutex_unlock_slowpath+0x3e/0x2e0
[ 309.662388] ? trace_hardirqs_on+0xd/0x10
[ 309.662392] ? _rcu_barrier+0x31/0x160
[ 309.662396] lock_acquire+0xc9/0x220
[ 309.662400] ? _rcu_barrier+0x31/0x160
[ 309.662404] ? _rcu_barrier+0x31/0x160
[ 309.662409] __mutex_lock+0x6e/0x990
[ 309.662412] ? _rcu_barrier+0x31/0x160
[ 309.662416] ? _rcu_barrier+0x31/0x160
[ 309.662421] ? synchronize_rcu_expedited+0x35/0xb0
[ 309.662426] ? _raw_spin_unlock_irqrestore+0x52/0x60
[ 309.662434] mutex_lock_nested+0x16/0x20
[ 309.662438] _rcu_barrier+0x31/0x160
[ 309.662442] rcu_barrier+0x10/0x20
[ 309.662464] i915_gem_shrink_all+0x33/0x40 [i915]
[ 309.662484] i915_drop_caches_set+0x141/0x150 [i915]
[ 309.662489] simple_attr_write+0xc7/0xe0
[ 309.662494] full_proxy_write+0x4f/0x70
[ 309.662498] __vfs_write+0x23/0x120
[ 309.662503] ? rcu_read_lock_sched_held+0x75/0x80
[ 309.662507] ? rcu_sync_lockdep_assert+0x2a/0x50
[ 309.662512] ? __sb_start_write+0x102/0x210
[ 309.662516] ? vfs_write+0x17d/0x1f0
[ 309.662520] vfs_write+0xc6/0x1f0
[ 309.662524] ? trace_hardirqs_on_caller+0xe7/0x200
[ 309.662529] SyS_write+0x44/0xb0
[ 309.662533] entry_SYSCALL_64_fastpath+0x1c/0xb1
[ 309.662537] RIP: 0033:0x7f507eac24a0
[ 309.662541] RSP: 002b:00007fffda8720e8 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[ 309.662548] RAX: ffffffffffffffda RBX: ffffffff81482bd3 RCX: 00007f507eac24a0
[ 309.662552] RDX: 0000000000000005 RSI: 00007fffda8720f0 RDI: 0000000000000005
[ 309.662557] RBP: ffffc9000048bf88 R08: 0000000000000000 R09: 000000000000002c
[ 309.662561] R10: 0000000000000014 R11: 0000000000000246 R12: 00007fffda872230
[ 309.662566] R13: 00007fffda872228 R14: 0000000000000201 R15: 00007fffda8720f0
[ 309.662572] ? __this_cpu_preempt_check+0x13/0x20
Fixes: 0eafec6d3244 ("drm/i915: Enable lockless lookup of request tracking via RCU")
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=100192
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: http://patchwork.freedesktop.org/patch/msgid/20170314115019.18127-1-chris@chris-wilson.co.uk
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
(cherry picked from commit bd784b7cc41af7a19cfb705fa6d800e511c4ab02)
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20170321144531.12344-1-chris@chris-wilson.co.uk
commit 8f68d591d4765b2e1ce9d916ac7bc5583285c4ad upstream.
On Baytrail, we manually calculate busyness over the evaluation interval
to avoid issues with miscaluations with RC6 enabled. However, it turns
out that the DOWN_EI interrupt generator is completely bust - it
operates in two modes, continuous or never. Neither of which are
conducive to good behaviour. Stop unmask the DOWN_EI interrupt and just
compute everything from the UP_EI which does seem to correspond to the
desired interval.
v2: Fixup gen6_rps_pm_mask() as well
v3: Inline vlv_c0_above() to combine the now identical elapsed
calculation for up/down and simplify the threshold testing
Fixes: 43cf3bf084ba ("drm/i915: Improved w/a for rps on Baytrail")
Cc: Mika Kuoppala <mika.kuoppala@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20170309211232.28878-1-chris@chris-wilson.co.uk
Reviewed-by: Mika Kuoppala <mika.kuoppala@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20170313170617.31564-1-chris@chris-wilson.co.uk
(cherry picked from commit e0e8c7cb6eb68e9256de2d8cbeb481d3701c05ac)
commit 0f5418e564ac6452b9086295646e602a9addc4bf upstream.
This patch makes the I915_PARAM_HAS_EXEC_CONSTANTS getparam return 0
(indicating the optional feature is not supported), and makes execbuf
always return -EINVAL if the flags are used.
Apparently, no userspace ever shipped which used this optional feature:
I checked the git history of Mesa, xf86-video-intel, libva, and Beignet,
and there were zero commits showing a use of these flags. Kernel commit
72bfa19c8deb4 apparently introduced the feature prematurely. According
to Chris, the intention was to use this in cairo-drm, but "the use was
broken for gen6", so I don't think it ever happened.
'relative_constants_mode' has always been tracked per-device, but this
has actually been wrong ever since hardware contexts were introduced, as
the INSTPM register is saved (and automatically restored) as part of the
render ring context. The software per-device value could therefore get
out of sync with the hardware per-context value. This meant that using
them is actually unsafe: a client which tried to use them could damage
the state of other clients, causing the GPU to interpret their BO
offsets as absolute pointers, leading to bogus memory reads.
These flags were also never ported to execlist mode, making them no-ops
on Gen9+ (which requires execlists), and Gen8 in the default mode.
On Gen8+, userspace can write these registers directly, achieving the
same effect. On Gen6-7.5, it likely makes sense to extend the command
parser to support them. I don't think anyone wants this on Gen4-5.
Based on a patch by Dave Gordon.
v3: Return -ENODEV for the getparam, as this is what we do for other
obsolete features. Suggested by Chris Wilson.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=92448
Signed-off-by: Kenneth Graunke <kenneth@whitecape.org>
Reviewed-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Link: http://patchwork.freedesktop.org/patch/msgid/20170215093446.21291-1-kenneth@whitecape.org
Link: http://patchwork.freedesktop.org/patch/msgid/20170313170433.26843-1-chris@chris-wilson.co.uk
(cherry picked from commit ef0f411f51475f4eebf9fc1b19a85be698af19ff)
commit 35a3abfd198e6c69a6644784bb09a2d951fc6b21 upstream.
In order to prevent accessing the hpd registers outside of the display
power wells, we should refrain from writing to the registers before the
display interrupts are enabled.
[ 4.740136] WARNING: CPU: 1 PID: 221 at drivers/gpu/drm/i915/intel_uncore.c:795 __unclaimed_reg_debug+0x44/0x50 [i915]
[ 4.740155] Unclaimed read from register 0x1e1110
[ 4.740168] Modules linked in: i915(+) intel_gtt drm_kms_helper prime_numbers
[ 4.740190] CPU: 1 PID: 221 Comm: systemd-udevd Not tainted 4.10.0-rc6+ #384
[ 4.740203] Hardware name: / , BIOS PYBSWCEL.86A.0027.2015.0507.1758 05/07/2015
[ 4.740220] Call Trace:
[ 4.740236] dump_stack+0x4d/0x6f
[ 4.740251] __warn+0xc1/0xe0
[ 4.740265] warn_slowpath_fmt+0x4a/0x50
[ 4.740281] ? insert_work+0x77/0xc0
[ 4.740355] ? fwtable_write32+0x90/0x130 [i915]
[ 4.740431] __unclaimed_reg_debug+0x44/0x50 [i915]
[ 4.740507] fwtable_read32+0xd8/0x130 [i915]
[ 4.740575] i915_hpd_irq_setup+0xa5/0x100 [i915]
[ 4.740649] intel_hpd_init+0x68/0x80 [i915]
[ 4.740716] i915_driver_load+0xe19/0x1380 [i915]
[ 4.740784] i915_pci_probe+0x32/0x90 [i915]
[ 4.740799] pci_device_probe+0x8b/0xf0
[ 4.740815] driver_probe_device+0x2b6/0x450
[ 4.740828] __driver_attach+0xda/0xe0
[ 4.740841] ? driver_probe_device+0x450/0x450
[ 4.740853] bus_for_each_dev+0x5b/0x90
[ 4.740865] driver_attach+0x19/0x20
[ 4.740878] bus_add_driver+0x166/0x260
[ 4.740892] driver_register+0x5b/0xd0
[ 4.740906] ? 0xffffffffa0166000
[ 4.740920] __pci_register_driver+0x47/0x50
[ 4.740985] i915_init+0x5c/0x5e [i915]
[ 4.740999] do_one_initcall+0x3e/0x160
[ 4.741015] ? __vunmap+0x7c/0xc0
[ 4.741029] ? kmem_cache_alloc+0xcf/0x120
[ 4.741045] do_init_module+0x55/0x1c4
[ 4.741060] load_module+0x1f3f/0x25b0
[ 4.741073] ? __symbol_put+0x40/0x40
[ 4.741086] ? kernel_read_file+0x100/0x190
[ 4.741100] SYSC_finit_module+0xbc/0xf0
[ 4.741112] SyS_finit_module+0x9/0x10
[ 4.741125] entry_SYSCALL_64_fastpath+0x17/0x98
[ 4.741135] RIP: 0033:0x7f8559a140f9
[ 4.741145] RSP: 002b:00007fff7509a3e8 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
[ 4.741161] RAX: ffffffffffffffda RBX: 00007f855aba02d1 RCX: 00007f8559a140f9
[ 4.741172] RDX: 0000000000000000 RSI: 000055b6db0914f0 RDI: 0000000000000011
[ 4.741183] RBP: 0000000000020000 R08: 0000000000000000 R09: 000000000000000e
[ 4.741193] R10: 0000000000000011 R11: 0000000000000246 R12: 000055b6db0854d0
[ 4.741204] R13: 000055b6db091150 R14: 0000000000000000 R15: 000055b6db035924
v2: Set dev_priv->display_irqs_enabled to true for all platforms other
than vlv/chv that manually control the display power domain.
Fixes: 19625e85c6ec ("drm/i915: Enable polling when we don't have hpd")
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=97798
Suggested-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Lyude <cpaul@redhat.com>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Hans de Goede <jwrdegoede@fedoraproject.org>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20170215131547.5064-1-chris@chris-wilson.co.uk
Link: http://patchwork.freedesktop.org/patch/msgid/20170313170231.18633-1-chris@chris-wilson.co.uk
(cherry picked from commit 262fd485ac6b476479f41f00bb104f6a1766ae66)
commit 34dc8993eef63681b062871413a9484008a2a78f upstream.
Certain Baytrails, namely the 4 cpu core variants, have been
plaqued by spurious system hangs, mostly occurring with light loads.
Multiple bisects by various people point to a commit which changes the
reclocking strategy for Baytrail to follow its bigger brethen:
commit 8fb55197e64d ("drm/i915: Agressive downclocking on Baytrail")
There is also a review comment attached to this commit from Deepak S
on avoiding punit access on Cherryview and thus it was excluded on
common reclocking path. By taking the same approach and omitting
the punit access by not tweaking the thresholds when the hardware
has been asked to move into different frequency, considerable gains
in stability have been observed.
With J1900 box, light render/video load would end up in system hang
in usually less than 12 hours. With this patch applied, the cumulative
uptime has now been 34 days without issues. To provoke system hang,
light loads on both render and bsd engines in parallel have been used:
glxgears >/dev/null 2>/dev/null &
mpv --vo=vaapi --hwdec=vaapi --loop=inf vid.mp4
So far, author has not witnessed system hang with above load
and this patch applied. Reports from the tenacious people at
kernel bugzilla are also promising.
Considering that the punit access frequency with this patch is
considerably less, there is a possibility that this will push
the, still unknown, root cause past the triggering point on most loads.
But as we now can reliably reproduce the hang independently,
we can reduce the pain that users are having and use a
static thresholds until a root cause is found.
v3: don't break debugfs and simplification (Chris Wilson)
References: https://bugzilla.kernel.org/show_bug.cgi?id=109051
Cc: Len Brown <len.brown@intel.com>
Cc: Jani Nikula <jani.nikula@intel.com>
Cc: fritsch@xbmc.org
Cc: miku@iki.fi
Cc: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
CC: Michal Feix <michal@feix.cz>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Deepak S <deepak.s@linux.intel.com>
Cc: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Acked-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Mika Kuoppala <mika.kuoppala@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1487166779-26945-1-git-send-email-mika.kuoppala@intel.com
(cherry picked from commit 6067a27d1f0184596d51decbac1c1fdc4acb012f)
