commit 56350fb8978bbf4aafe08f21234e161dd128b417 upstream.
The hardware always writes one or two bytes in the index portion of
an indexed transfer. Make sure the message we send as the index
doesn't have a zero length.
Cc: Daniel Kurtz <djkurtz@chromium.org>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Sean Paul <seanpaul@chromium.org>
Fixes: 56f9eac05489 ("drm/i915/intel_i2c: use INDEX cycles for i2c read transactions")
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20171123194157.25367-3-ville.syrjala@linux.intel.com
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
(cherry picked from commit bb9e0d4bca50f429152e74a459160b41f3d60fb2)
Signed-off-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
commit ae5c631e605a452a5a0e73205a92810c01ed954b upstream.
We can only specify the one slave address to indexed reads/writes.
Make sure the messages we check are destined to the same slave
address before deciding to do an indexed transfer.
Link: https://patchwork.freedesktop.org/patch/msgid/20171123194157.25367-2-ville.syrjala@linux.intel.com
(cherry picked from commit c4deb62d7821672265b87952bcd1c808f3bf3e8f)
commit b688741cb06695312f18b730653d6611e1bad28d upstream.
For correct close-to-open semantics, NFS must validate
the change attribute of a directory (or file) on open.
Since commit ecf3d1f1aa74 ("vfs: kill FS_REVAL_DOT by adding a
d_weak_revalidate dentry op"), open() of "." or a path ending ".." is
not revalidated reliably (except when that direct is a mount point).
Prior to that commit, "." was revalidated using nfs_lookup_revalidate()
which checks the LOOKUP_OPEN flag and forces revalidation if the flag is
set.
Since that commit, nfs_weak_revalidate() is used for NFSv3 (which
ignores the flags) and nothing is used for NFSv4.
This is fixed by using nfs_lookup_verify_inode() in
nfs_weak_revalidate(). This does the revalidation exactly when needed.
Also, add a definition of .d_weak_revalidate for NFSv4.
The incorrect behavior is easily demonstrated by running "echo *" in
some non-mountpoint NFS directory while watching network traffic.
Without this patch, "echo *" sometimes doesn't produce any traffic.
With the patch it always does.
Fixes: ecf3d1f1aa74 ("vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op")
cc: stable@vger.kernel.org (3.9+)
Signed-off-by: NeilBrown <neilb@suse.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
This reverts commit 0d794d0d018f23fb09c50f6ae26868bd6ae343d6 which is
commit 0d794d0d018f23fb09c50f6ae26868bd6ae343d6 upstream.
Andy writes:
I think the thing to do is to revert the patch from -stable.
The bug it fixes is very minor, and the regression is that it
made a pre-existing bug in some nearly-undebuggable core resume
code much easier to hit. I don't feel comfortable with a
backport of the latter fix until it has a good long soak in
Linus' tree.
Reported-by: Andy Lutomirski <luto@kernel.org>
Cc: Borislav Petkov <bpetkov@suse.de>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
commit 8d8258bdab735d9f3c4b78e091ecfbb2b2b1f2ca upstream.
resulted in unexpected data truncation
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Rex Zhu <Rex.Zhu@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 4d98e5ee6084f6d7bc578c5d5f86de7156aaa4cb upstream.
When the mutex is locked just in the moment we copy it we end up with a
warning that we release a locked mutex.
Fix this by properly reinitializing the mutex.
Signed-off-by: Christian König <christian.koenig@amd.com>
commit a2f042430784d86eb2b7a6d2a869f552da30edba upstream.
This patch fixes the following soft lockup:
BUG: soft lockup - CPU#0 stuck for 23s! [weston:307]
On weston idle-timeout the IP is powered down and reset
asserted. On weston resume we get a massive vblank
IRQ storm due to the LDI registers having lost some state.
This state loss is caused by ade_crtc_atomic_begin() not
calling ade_ldi_set_mode(). With this patch applied
resuming from Weston idle-timeout works well.
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
Tested-by: John Stultz <john.stultz@linaro.org>
Reviewed-by: Xinliang Liu <xinliang.liu@linaro.org>
Signed-off-by: Xinliang Liu <xinliang.liu@linaro.org>
commit f3621a8eb59a913612c8e6e37d81f16b649f8b6c upstream.
During panel removal or system shutdown panel_simple_disable() is called
which disables the panel backlight but the panel is still powered due to
missing calls to panel_simple_unprepare().
Fixes: d02fd93e2cd8 ("drm/panel: simple - Disable panel on shutdown")
Signed-off-by: Jonathan Liu <net147@gmail.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20170807115545.27747-1-net147@gmail.com
commit 4f626a4ac8f57ddabf06d03870adab91e463217f upstream.
The function for byteswapping the data send to/from atombios was buggy for
num_bytes not divisible by four. The function must be aware of the fact
that after byte-swapping the u32 units, valid bytes might end up after the
num_bytes boundary.
This patch was tested on kernel 3.12 and allowed us to sucesfully use
DisplayPort on and Radeon SI card. Namely it fixed the link training and
EDID readout.
The function is patched both in radeon and amd drivers, since the functions
and the fixes are identical.
Signed-off-by: Roman Kapl <rka@sysgo.com>
commit 78aa02c713fcf19e9bc8511ab61a5fd6c877cc01 upstream.
After commit ea09729c9302 ("drm/amdgpu: rework page directory filling
v2") then it becomes a lot harder to verify that "r" is initialized. My
static checker complains and so I've reviewed the code. It does look
like it might be buggy... Anyway, it doesn't hurt to set "r" to zero
at the start.
Reviewed-by: Christian König <christian.koenig@amd.com>
commit 40a9960b046290939b56ce8e51f365258f27f264 upstream.
We shifted some code around in commit 9cca0b8e5df0 ("drm/amdgpu: move
amdgpu_cs_sysvm_access_required into find_mapping") and now my static
checker complains that "r" might not be initialized at the end of the
function. I've reviewed the code, and that seems possible, but it's
also possible I may have missed something.
commit 18c437caa5b18a235dd65cec224eab54bebcee65 upstream.
Fixes distorted colors on some cards on resume from suspend.
This reverts commit b9729b17a414f99c61f4db9ac9f9ed987fa0cbfe.
Bug: https://bugs.freedesktop.org/show_bug.cgi?id=98832
Bug: https://bugs.freedesktop.org/show_bug.cgi?id=99163
Bug: https://bugzilla.kernel.org/show_bug.cgi?id=107001
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
commit 8c97eeccf0ad8783c057830119467b877bdfced7 upstream.
And increase the existing delay to cover this device as well.
Signed-off-by: Jeff Lien <jeff.lien@wdc.com>
commit 68615eb01f82256c19e41967bfb3eef902f77033 upstream.
With a nxp,se97 chip on an atmel sama5d31 board, the I2C adapter driver
is not always capable of avoiding the 25-35 ms timeout as specified by
the SMBUS protocol. This may cause silent corruption of the last bit of
any transfer, e.g. a one is read instead of a zero if the sensor chip
times out. This also affects the eeprom half of the nxp-se97 chip, where
this silent corruption was originally noticed. Other I2C adapters probably
suffer similar issues, e.g. bit-banging comes to mind as risky...
The SMBUS register in the nxp chip is not a standard Jedec register, but
it is not special to the nxp chips either, at least the atmel chips
have the same mechanism. Therefore, do not special case this on the
manufacturer, it is opt-in via the device property anyway.
Signed-off-by: Peter Rosin <peda@axentia.se>
Acked-by: Rob Herring <robh@kernel.org>
commit cf33c1ee5254c6a430bc1538232b49c3ea13e613 upstream.
This patch try to fix the building error on MIPS. The reason is MIPS
has already defined the PTR macro, which conflicts with the PTR macro
in include/uapi/linux/bcache.h.
[fixed by mlyle: corrected a line-length issue]
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Reviewed-by: Michael Lyle <mlyle@lyle.org>
Signed-off-by: Michael Lyle <mlyle@lyle.org>
commit 6e0c9507bf51e1517a80ad0ac171e5402528fcef upstream.
On Apollo Lake devices the BIOS does not set up IRQ routing for the i801
SMBUS controller IRQ, so we end up with dev->irq set to IRQ_NOTCONNECTED.
Detect this and do not try to use the irq in this case silencing:
i801_smbus 0000:00:1f.1: Failed to allocate irq -2147483648: -107
BugLink: https://communities.intel.com/thread/114759
Reviewed-by: Jean Delvare <jdelvare@suse.de>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit d9bcd462daf34aebb8de9ad7f76de0198bb5a0f0 upstream.
So far we completely rely on the caller to provide valid arguments.
To be on the safe side perform an own sanity check.
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
Signed-off-by: Bartosz Golaszewski <brgl@bgdev.pl>
commit 5478e478eee3b096b8d998d4ed445da30da2dfbc upstream.
There's an ilog2() expansion in AT24_DEVICE_MAGIC() which rounds down
the actual size of EUI-48 byte array in at24mac402 eeproms to 4 from 6,
making it impossible to read it all.
Fix it by manually adjusting the value in probe().
This patch contains a temporary fix that is suitable for stable
branches. Eventually we'll probably remove the call to ilog2() while
converting the magic values to actual structs.
Fixes: 0b813658c115 ("eeprom: at24: add support for at24mac series")
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
commit 644a1f19c6c8393d0c4168a5adf79056da6822eb upstream.
Chip datasheet mentions that word addresses other than the actual
start position of the MAC delivers undefined results. So fix this.
Current implementation doesn't work due to this wrong offset.
commit c892b0d81705c566f575e489efc3c50762db1bde upstream.
The sysfs entry "ocr" was missing the 0x prefix to identify it as hex
formatted.
Fixes: 5fb06af7a33b ("mmc: core: Extend sysfs with OCR register")
Signed-off-by: Bastian Stender <bst@pengutronix.de>
[Ulf: Amended change to also cover SD-cards]
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit ebe7dd45cf49e3b49cacbaace17f9f878f21fbea upstream.
The block driver must be resumed if the mmc bus fails to suspend the card.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
commit 12806ba937382fdfdbad62a399aa2dce65c10fcd upstream.
In x2apic mode the LDR is fixed based on the ID rather
than separately loadable like it was before x2.
When kvm_apic_set_state is called, the base is set, and if
it has the X2APIC_ENABLE flag set then the LDR is calculated;
however that value gets overwritten by the memcpy a few lines
below overwriting it with the value that came from userland.
The symptom is a lack of EOI after loading the state
(e.g. after a QEMU migration) and is due to the EOI bitmap
being wrong due to the incorrect LDR. This was seen with
a Win2016 guest under Qemu with irqchip=split whose USB mouse
didn't work after a VM migration.
This corresponds to RH bug:
https://bugzilla.redhat.com/show_bug.cgi?id=1502591
Reported-by: Yiqian Wei <yiwei@redhat.com>
Signed-off-by: Dr. David Alan Gilbert <dgilbert@redhat.com>
[Applied fixup from Liran Alon. - Paolo]
commit e872fa94662d0644057c7c80b3071bdb9249e5ab upstream.
Split out the ldr calculation from kvm_apic_set_x2apic_id
since we're about to reuse it in the following patch.
commit 6ea6e84309ca7e0e850b3083e6b09344ee15c290 upstream.
Sometimes, a processor might execute an instruction while another
processor is updating the page tables for that instruction's code page,
but before the TLB shootdown completes. The interesting case happens
if the page is in the TLB.
In general, the processor will succeed in executing the instruction and
nothing bad happens. However, what if the instruction is an MMIO access?
If *that* happens, KVM invokes the emulator, and the emulator gets the
updated page tables. If the update side had marked the code page as non
present, the page table walk then will fail and so will x86_decode_insn.
Unfortunately, even though kvm_fetch_guest_virt is correctly returning
X86EMUL_PROPAGATE_FAULT, x86_decode_insn's caller treats the failure as
a fatal error if the instruction cannot simply be reexecuted (as is the
case for MMIO). And this in fact happened sometimes when rebooting
Windows 2012r2 guests. Just checking ctxt->have_exception and injecting
the exception if true is enough to fix the case.
Thanks to Eduardo Habkost for helping in the debugging of this issue.
Reported-by: Yanan Fu <yfu@redhat.com>
Cc: Eduardo Habkost <ehabkost@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit 61cb57c9ed631c95b54f8e9090c89d18b3695b3c upstream.
Instruction emulation after trapping a #UD exception can result in an
MMIO access, for example when emulating a MOVBE on a processor that
doesn't support the instruction. In this case, the #UD vmexit handler
must exit to user mode, but there wasn't any code to do so. Add it for
both VMX and SVM.
Signed-off-by: Liran Alon <liran.alon@oracle.com>
Reviewed-by: Nikita Leshenko <nikita.leshchenko@oracle.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: Wanpeng Li <wanpeng.li@hotmail.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
commit 51c4b8bba674cfd2260d173602c4dac08e4c3a99 upstream.
When guest passes KVM it's pvclock-page GPA via WRMSR to
MSR_KVM_SYSTEM_TIME / MSR_KVM_SYSTEM_TIME_NEW, KVM don't initialize
pvclock-page to some start-values. It just requests a clock-update which
will happen before entering to guest.
The clock-update logic will call kvm_setup_pvclock_page() to update the
pvclock-page with info. However, kvm_setup_pvclock_page() *wrongly*
assumes that the version-field is initialized to an even number. This is
wrong because at first-time write, field could be any-value.
Fix simply makes sure that if first-time version-field is odd, increment
it once more to make it even and only then start standard logic.
This follows same logic as done in other pvclock shared-pages (See
kvm_write_wall_clock() and record_steal_time()).
commit a3ac350793d90d1da631c8beeee9352387974ed5 upstream.
Commit 485fa1261f78 ("ARM: OMAP2+: LogicPD Torpedo + Wireless: Add Bluetooth")
set the wrong baud rate for the UART. The Baud rate was 300,000 and it should
be 3,000,000 for WL1283.
commit ad48ed0c5763dc08931407e455dff5acdbe96e81 upstream.
At least two different omap3630/3730 boards booting from MMC1
fail to reboot if the "ti,twl4030-power-idle-osc-off" or
"ti,twl4030-power-idle" compatible flags are set. This patch will
keep the vmmc1 powered up during reboot allowing the bootloader
to load.
Signed-off-by: Lee Jones <lee.jones@linaro.org>
commit 64ebe12494fd5d193f014ce38e1fd83cc57883c8 upstream.
From kernel 4.9, my two nfsv4 servers sometimes suffer from
"panic: unable to handle kernel page request"
in posix_unblock_lock() called from nfs4_laundromat().
These panics diseappear if we revert the commit "nfsd: add a LRU list
for blocked locks".
The cause appears to be a typo in nfs4_laundromat(), which is also
present in nfs4_state_shutdown_net().
Fixes: 7919d0a27f1e "nfsd: add a LRU list for blocked locks"
Cc: jlayton@redhat.com
Reveiwed-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit d8a1a000555ecd1b824ac1ed6df8fe364dfbbbb0 upstream.
If nfsd4_process_open2() is initialising a new stateid, and yet the
call to nfs4_get_vfs_file() fails for some reason, then we must
declare the stateid closed, and unhash it before dropping the mutex.
Right now, we unhash the stateid after dropping the mutex, and without
changing the stateid type, meaning that another OPEN could theoretically
look it up and attempt to use it.
Reported-by: Andrew W Elble <aweits@rit.edu>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 15ca08d3299682dc49bad73251677b2c5017ef08 upstream.
Open file stateids can linger on the nfs4_file list of stateids even
after they have been closed. In order to avoid reusing such a
stateid, and confusing the client, we need to recheck the
nfs4_stid's type after taking the mutex.
Otherwise, we risk reusing an old stateid that was already closed,
which will confuse clients that expect new stateids to conform to
RFC7530 Sections 9.1.4.2 and 16.2.5 or RFC5661 Sections 8.2.2 and 18.2.4.
commit 8e138e0d92c6c9d3d481674fb14e3439b495be37 upstream.
We discovered a box that had double allocations, and suspected the space
cache may be to blame. While auditing the write out path I noticed that
if we've already setup the space cache we will just carry on. This
means that any error we hit after cache_save_setup before we go to
actually write the cache out we won't reset the inode generation, so
whatever was already written will be considered correct, except it'll be
stale. Fix this by _always_ resetting the generation on the block group
inode, this way we only ever have valid or invalid cache.
With this patch I was no longer able to reproduce cache corruption with
dm-log-writes and my bpf error injection tool.
Signed-off-by: Josef Bacik <jbacik@fb.com>
Signed-off-by: David Sterba <dsterba@suse.com>
commit 6ea8d958a2c95a1d514015d4e29ba21a8c0a1a91 upstream.
MADVISE_WILLNEED has always been a noop for DAX (formerly XIP) mappings.
Unfortunately madvise_willneed() doesn't communicate this information
properly to the generic madvise syscall implementation. The calling
convention is quite subtle there. madvise_vma() is supposed to either
return an error or update &prev otherwise the main loop will never
advance to the next vma and it will keep looping for ever without a way
to get out of the kernel.
It seems this has been broken since introduction. Nobody has noticed
because nobody seems to be using MADVISE_WILLNEED on these DAX mappings.
[mhocko@suse.com: rewrite changelog]
Link: http://lkml.kernel.org/r/20171127115318.911-1-guoxuenan@huawei.com
Fixes: fe77ba6f4f97 ("[PATCH] xip: madvice/fadvice: execute in place")
Signed-off-by: chenjie <chenjie6@huawei.com>
Signed-off-by: guoxuenan <guoxuenan@huawei.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: zhangyi (F) <yi.zhang@huawei.com>
Cc: Miao Xie <miaoxie@huawei.com>
Cc: Mike Rapoport <rppt@linux.vnet.ibm.com>
Cc: Shaohua Li <shli@fb.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com>
Cc: Carsten Otte <cotte@de.ibm.com>
Cc: Dan Williams <dan.j.williams@intel.com>
commit 31383c6865a578834dd953d9dbc88e6b19fe3997 upstream.
Patch series "device-dax: fix unaligned munmap handling"
When device-dax is operating in huge-page mode we want it to behave like
hugetlbfs and fail attempts to split vmas into unaligned ranges. It
would be messy to teach the munmap path about device-dax alignment
constraints in the same (hstate) way that hugetlbfs communicates this
constraint. Instead, these patches introduce a new ->split() vm
operation.
This patch (of 2):
The device-dax interface has similar constraints as hugetlbfs in that it
requires the munmap path to unmap in huge page aligned units. Rather
than add more custom vma handling code in __split_vma() introduce a new
vm operation to perform this vma specific check.
Link: http://lkml.kernel.org/r/151130418135.4029.6783191281930729710.stgit@dwillia2-desk3.amr.corp.intel.com
Fixes: dee410792419 ("/dev/dax, core: file operations and dax-mmap")
Cc: Jeff Moyer <jmoyer@redhat.com>
commit 63cd448908b5eb51d84c52f02b31b9b4ccd1cb5a upstream.
If the call __alloc_contig_migrate_range() in alloc_contig_range returns
-EBUSY, processing continues so that test_pages_isolated() is called
where there is a tracepoint to identify the busy pages. However, it is
possible for busy pages to become available between the calls to these
two routines. In this case, the range of pages may be allocated.
Unfortunately, the original return code (ret == -EBUSY) is still set and
returned to the caller. Therefore, the caller believes the pages were
not allocated and they are leaked.
Update the comment to indicate that allocation is still possible even if
__alloc_contig_migrate_range returns -EBUSY. Also, clear return code in
this case so that it is not accidentally used or returned to caller.
Link: http://lkml.kernel.org/r/20171122185214.25285-1-mike.kravetz@oracle.com
Fixes: 8ef5849fa8a2 ("mm/cma: always check which page caused allocation failure")
Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Laura Abbott <labbott@redhat.com>
Cc: Michal Hocko <mhocko@suse.com>
commit a8f97366452ed491d13cf1e44241bc0b5740b1f0 upstream.
Currently, we unconditionally make page table dirty in touch_pmd().
It may result in false-positive can_follow_write_pmd().
We may avoid the situation, if we would only make the page table entry
dirty if caller asks for write access -- FOLL_WRITE.
The patch also changes touch_pud() in the same way.
[Salvatore Bonaccorso: backport for 4.9:
- Adjust context
- Drop specific part for PUD-sized transparent hugepages. Support
for PUD-sized transparent hugepages was added in v4.11-rc1
commit b7ace5ed8867ca54503727988adec6b20af54eeb upstream.
Fixes commit 687c27676151 ("ARM: dts: Add minimal support for LogicPD
Torpedo DM3730 devkit")
This patch corrects an issue where the cd-gpios was improperly setup
using IRQ_TYPE_LEVEL_LOW instead of GPIO_ACTIVE_LOW.
commit 56322e123235370f1449c7444e311cce857d12f5 upstream.
Fix commit 05c4ffc3a266 ("ARM: dts: LogicPD Torpedo: Add MT9P031 Support")
In the previous commit, I indicated that the only testing was done by
showing the camera showed up when probing. This patch fixes an incorrect
pin muxing on cam_d0, cam_d1 and cam_d2.
[ Upstream commit 639b08810d6ad74ded2c5f6e233c4fcb9d147168 ]
When accessing Xenstore in a transaction the user is specifying a
transaction id which he normally obtained from Xenstore when starting
the transaction. Xenstore is validating a transaction id against all
known transaction ids of the connection the request came in. As all
requests of a domain not being the one where Xenstore lives share
one connection, validation of transaction ids of different users of
Xenstore in that domain should be done by the kernel of that domain
being the multiplexer between the Xenstore users in that domain and
Xenstore.
In order to prohibit one Xenstore user "hijacking" a transaction from
another user the xenbus driver has to verify a given transaction id
against all known transaction ids of the user before forwarding it to
Xenstore.
Signed-off-by: Juergen Gross <jgross@suse.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
[ Upstream commit 6c73f949300f17851f53fa80c9d1611ccd6909d3 ]
The Set Features implementation for Keep Alive Timer was using the wrong
structure when retrieving the KATO value; it was treating the Set
Features command as a Property Set command.
The NVMe spec defines the Keep Alive Timer feature as having one input
in CDW11 (4 bytes at offset 44 in the command) whereas the code was
reading 8 bytes at offset 48.
Since the Linux NVMe over Fabrics host never sets this feature, this
code has presumably never been tested.
Signed-off-by: Daniel Verkamp <daniel.verkamp@intel.com>
[ Upstream commit 7af26f889eb67db272021a939f7d4a57e96dd961 ]
The loop that sets the unused logical addresses to INVALID should be
done before 'configured' is set to true. This ensures that cec_log_addrs
is consistent before it will be used.
Signed-off-by: Hans Verkuil <hansverk@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
[ Upstream commit a24f56d47930492c94ef6875bf45adf7607ca1a4 ]
This is a 2.0 only message, so it should return Feature Abort if the
adapter is configured for CEC version 1.4.
Right now it does nothing, which means that the sender will time out.
[ Upstream commit 120476123646ba3619c90db7bcbc6f8eea53c990 ]
When a pending message was canceled (e.g. due to a timeout), then the
old tx_status info was overwritten instead of ORed. The same happened
with the tx_error_cnt field. So just modify them instead of overwriting
them.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
[ Upstream commit cabab3f9f5ca077535080b3252e6168935b914af ]
s390 version of commit 334bb7738764 ("x86/kbuild: enable modversions
for symbols exported from asm") so we get also rid of all these
warnings:
WARNING: EXPORT symbol "_mcount" [vmlinux] version generation failed, symbol will not be versioned.
WARNING: EXPORT symbol "memcpy" [vmlinux] version generation failed, symbol will not be versioned.
WARNING: EXPORT symbol "memmove" [vmlinux] version generation failed, symbol will not be versioned.
WARNING: EXPORT symbol "memset" [vmlinux] version generation failed, symbol will not be versioned.
WARNING: EXPORT symbol "save_fpu_regs" [vmlinux] version generation failed, symbol will not be versioned.
WARNING: EXPORT symbol "sie64a" [vmlinux] version generation failed, symbol will not be versioned.
WARNING: EXPORT symbol "sie_exit" [vmlinux] version generation failed, symbol will not be versioned.
[ Upstream commit 1cab2a84f470e15ecc8e5143bfe9398c6e888032 ]
Protect against corrupt firmware files by ensuring that the length we
get for the data in a region actually lies within the available firmware
file data buffer.
Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit 73ba39ab9307340dc98ec3622891314bbc09cc2e ]
In function btrfs_uuid_tree_iterate(), errno is assigned to variable ret
on errors. However, it directly returns 0. It may be better to return
ret. This patch also removes the warning, because the caller already
prints a warning.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=188731
Signed-off-by: Pan Bian <bianpan2016@163.com>
Reviewed-by: Omar Sandoval <osandov@fb.com>
[ edited subject ]
[ Upstream commit 8759fec4af222f338d08f8f1a7ad6a77ca6cb301 ]
Currently, inner IV/DIGEST data are only copied once into the hash
engines and not set explicitly before launching a request that is not a
first frag. This is an issue especially when multiple ahash reqs are
computed in parallel or chained with cipher request, as the state of the
request being computed is not updated into the hash engine. It leads to
non-deterministic corrupted digest results.
Fixes: commit 2786cee8e50b ("crypto: marvell - Move SRAM I/O operations to step functions")
Signed-off-by: Romain Perier <romain.perier@free-electrons.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Cc: <stable@vger.kernel.org>
[ Upstream commit 0ea617a298dcdc2251b4e10f83ac3f3e627b66e3 ]
On an error, snd_ctl_add already free's kctrl, so calling snd_ctl_free_one
to free it again leads to a double free error. Fix this by removing
the extraneous snd_ctl_free_one call.
Issue found using static analysis with CoverityScan, CID 1372908
Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
