commit c8e4e5bdb62a5ac6f860ebcaaf7b467b62f453f1 upstream.
Corrected the register to check the 64-bit pointer
capability state. 64-bit pointer implementation capability
was checking in wrong register, which causes the BDC
enumeration failure in 64-bit memory address.
Fixes: efed421a94e6 ("usb: gadget: Add UDC driver for
Broadcom USB3.0 device controller IP BDC")
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Signed-off-by: Srinath Mannam <srinath.mannam@broadcom.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit b16ea8b9492e99e03b1269fe93ebdbf8e4eabf8a upstream.
The FIFO/Queue type values are incorrect. Correct them according to
DWC_usb3 programming guide section 1.2.27 (or DWC_usb31 section 1.2.25).
Additionally, this patch includes ProtocolStatusQ and AuxEventQ types.
Fixes: cf6d867d3b57 ("usb: dwc3: core: add fifo space helper")
Signed-off-by: Thinh Nguyen <thinhn@synopsys.com>
commit 8874ae5f15f3feef3b4a415b9aed51edcf449aa1 upstream.
Add the missing platform_device_put() before return from bdc_pci_probe()
in the platform_device_add_resources() error handling case.
Fixes: efed421a94e6 ("usb: gadget: Add UDC driver for Broadcom USB3.0 device controller IP BDC")
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
commit 4cd3b6ebff8510b2139d64024411207090cfe0a9 upstream.
Hung task timeouts can result if a qlogic board breaks unexpectedly
while running I/O. These tasks become hung because command srb reference
counts are not going to zero, hence the affected srbs and commands do
not get freed. This fix accounts for this extra reference in the srbs in
the case of a board failure.
Fixes: a465537ad1a4 ("qla2xxx: Disable the adapter and skip error recovery in case of register disconnect")
Signed-off-by: Bill Kuzeja <william.kuzeja@stratus.com>
Acked-by: Himanshu Madhani <himanshu.madhani@cavium.com>
commit fd649f10c3d21ee9d7542c609f29978bdf73ab94 upstream.
Commit 4fde46f0cc71 ("Btrfs: free the stale device") introduced
btrfs_free_stale_device which iterates the device lists for all
registered btrfs filesystems and deletes those devices which aren't
mounted. In a btrfs_devices structure has only 1 device attached to it
and it is unused then btrfs_free_stale_devices will proceed to also free
the btrfs_fs_devices struct itself. Currently this leads to a use after
free since list_for_each_entry will try to perform a check on the
already freed memory to see if it has to terminate the loop.
The fix is to use 'break' when we know we are freeing the current
fs_devs.
Fixes: 4fde46f0cc71 ("Btrfs: free the stale device")
Signed-off-by: Nikolay Borisov <nborisov@suse.com>
Reviewed-by: Anand Jain <anand.jain@oracle.com>
Signed-off-by: David Sterba <dsterba@suse.com>
commit 92e222df7b8f05c565009c7383321b593eca488b upstream.
In case of using DUP, we search for enough unallocated disk space on a
device to hold two stripes.
The devices_info[ndevs-1].max_avail that holds the amount of unallocated
space found is directly assigned to stripe_size, while it's actually
twice the stripe size.
Later on in the code, an unconditional division of stripe_size by
dev_stripes corrects the value, but in the meantime there's a check to
see if the stripe_size does not exceed max_chunk_size. Since during this
check stripe_size is twice the amount as intended, the check will reduce
the stripe_size to max_chunk_size if the actual correct to be used
stripe_size is more than half the amount of max_chunk_size.
The unconditional division later tries to correct stripe_size, but will
actually make sure we can't allocate more than half the max_chunk_size.
Fix this by moving the division by dev_stripes before the max chunk size
check, so it always contains the right value, instead of putting a duct
tape division in further on to get it fixed again.
Since in all other cases than DUP, dev_stripes is 1, this change only
affects DUP.
Other attempts in the past were made to fix this:
* 37db63a400 "Btrfs: fix max chunk size check in chunk allocator" tried
to fix the same problem, but still resulted in part of the code acting
on a wrongly doubled stripe_size value.
* 86db25785a "Btrfs: fix max chunk size on raid5/6" unintentionally
broke this fix again.
The real problem was already introduced with the rest of the code in
73c5de0051.
The user visible result however will be that the max chunk size for DUP
will suddenly double, while it's actually acting according to the limits
in the code again like it was 5 years ago.
Reported-by: Naohiro Aota <naohiro.aota@wdc.com>
Link: https://www.spinics.net/lists/linux-btrfs/msg69752.html
Fixes: 73c5de0051 ("btrfs: quasi-round-robin for chunk allocation")
Fixes: 86db25785a ("Btrfs: fix max chunk size on raid5/6")
Signed-off-by: Hans van Kranenburg <hans.van.kranenburg@mendix.com>
Reviewed-by: David Sterba <dsterba@suse.com>
[ update comment ]
commit f930c7043663188429cd9b254e9d761edfc101ce upstream.
Don't make any assumptions on the sg_io_hdr_t::dxfer_direction or the
sg_io_hdr_t::dxferp in order to determine if it is a valid request. The
only way we can check for bad requests is by checking if the length
exceeds 256M.
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
Fixes: 28676d869bbb (scsi: sg: check for valid direction before starting the request)
Reported-by: Jason L Tibbitts III <tibbs@math.uh.edu>
Tested-by: Jason L Tibbitts III <tibbs@math.uh.edu>
Suggested-by: Doug Gilbert <dgilbert@interlog.com>
Cc: Doug Gilbert <dgilbert@interlog.com>
Cc: <stable@vger.kernel.org>
Reviewed-by: Hannes Reinecke <hare@suse.com>
commit 14074aba4bcda3764c9a702b276308b89901d5b6 upstream.
dxfer_len is an unsigned int and we always assign a value > 0 to it, so
it doesn't make any sense to check if it is < 0. We can't really check
dxferp as well as we have both NULL and not NULL cases in the possible
call paths.
So just return true for SG_DXFER_FROM_DEV transfer in
sg_is_valid_dxfer().
Reported-by: Colin Ian King <colin.king@canonical.com>
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Douglas Gilbert <dgilbert@interlog.com>
commit 68c59fcea1f2c6a54c62aa896cc623c1b5bc9b47 upstream.
SG_DXFER_FROM_DEV transfers do not necessarily have a dxferp as we set
it to NULL for the old sg_io read/write interface, but must have a
length bigger than 0. This fixes a regression introduced by commit
28676d869bbb ("scsi: sg: check for valid direction before starting the
request")
Fixes: 28676d869bbb ("scsi: sg: check for valid direction before starting the request")
Reported-by: Chris Clayton <chris2553@googlemail.com>
Tested-by: Chris Clayton <chris2553@googlemail.com>
Acked-by: Douglas Gilbert <dgilbert@interlog.com>
Cc: Cristian Crinteanu <crinteanu.cristian@gmail.com>
commit 4f2c7583e33eb08dc09dd2e25574b80175ba7d93 upstream.
When struct its_device instances are created, the nr_ites member
will be set to a power of 2 that equals or exceeds the requested
number of MSIs passed to the msi_prepare() callback. At the same
time, the LPI map is allocated to be some multiple of 32 in size,
where the allocated size may be less than the requested size
depending on whether a contiguous range of sufficient size is
available in the global LPI bitmap.
This may result in the situation where the nr_ites < nr_lpis, and
since nr_ites is what we program into the hardware when we map the
device, the additional LPIs will be non-functional.
For bog standard hardware, this does not really matter. However,
in cases where ITS device IDs are shared between different PCIe
devices, we may end up allocating these additional LPIs without
taking into account that they don't actually work.
So let's make nr_ites at least 32. This ensures that all allocated
LPIs are 'live', and that its_alloc_device_irq() will fail when
attempts are made to allocate MSIs beyond what was allocated in
the first place.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
[maz: updated comment]
[ardb: trivial tweak of unrelated context]
commit d0264c01e7587001a8c4608a5d1818dba9a4c11a upstream.
While converting ioctx index from a list to a table, db446a08c23d
("aio: convert the ioctx list to table lookup v3") missed tagging
kioctx_table->table[] as an array of RCU pointers and using the
appropriate RCU accessors. This introduces a small window in the
lookup path where init and access may race.
Mark kioctx_table->table[] with __rcu and use the approriate RCU
accessors when using the field.
Reported-by: Jann Horn <jannh@google.com>
Fixes: db446a08c23d ("aio: convert the ioctx list to table lookup v3")
Cc: Benjamin LaHaise <bcrl@kvack.org>
Cc: stable@vger.kernel.org # v3.12+
commit a6d7cff472eea87d96899a20fa718d2bab7109f3 upstream.
While fixing refcounting, e34ecee2ae79 ("aio: Fix a trinity splat")
incorrectly removed explicit RCU grace period before freeing kioctx.
The intention seems to be depending on the internal RCU grace periods
of percpu_ref; however, percpu_ref uses a different flavor of RCU,
sched-RCU. This can lead to kioctx being freed while RCU read
protected dereferences are still in progress.
Fix it by updating free_ioctx() to go through call_rcu() explicitly.
v2: Comment added to explain double bouncing.
Fixes: e34ecee2ae79 ("aio: Fix a trinity splat")
Cc: Kent Overstreet <kent.overstreet@gmail.com>
Cc: stable@vger.kernel.org # v3.13+
commit 3b821409632ab778d46e807516b457dfa72736ed upstream.
In case when dentry passed to lock_parent() is protected from freeing only
by the fact that it's on a shrink list and trylock of parent fails, we
could get hit by __dentry_kill() (and subsequent dentry_kill(parent))
between unlocking dentry and locking presumed parent. We need to recheck
that dentry is alive once we lock both it and parent *and* postpone
rcu_read_unlock() until after that point. Otherwise we could return
a pointer to struct dentry that already is rcu-scheduled for freeing, with
->d_lock held on it; caller's subsequent attempt to unlock it can end
up with memory corruption.
Cc: stable@vger.kernel.org # 3.12+, counting backports
commit 95dd77580ccd66a0da96e6d4696945b8cea39431 upstream.
On nfsv2 and nfsv3 the nfs server can export subsets of the same
filesystem and report the same filesystem identifier, so that the nfs
client can know they are the same filesystem. The subsets can be from
disjoint directory trees. The nfsv2 and nfsv3 filesystems provides no
way to find the common root of all directory trees exported form the
server with the same filesystem identifier.
The practical result is that in struct super s_root for nfs s_root is
not necessarily the root of the filesystem. The nfs mount code sets
s_root to the root of the first subset of the nfs filesystem that the
kernel mounts.
This effects the dcache invalidation code in generic_shutdown_super
currently called shrunk_dcache_for_umount and that code for years
has gone through an additional list of dentries that might be dentry
trees that need to be freed to accomodate nfs.
When I wrote path_connected I did not realize nfs was so special, and
it's hueristic for avoiding calling is_subdir can fail.
The practical case where this fails is when there is a move of a
directory from the subtree exposed by one nfs mount to the subtree
exposed by another nfs mount. This move can happen either locally or
remotely. With the remote case requiring that the move directory be cached
before the move and that after the move someone walks the path
to where the move directory now exists and in so doing causes the
already cached directory to be moved in the dcache through the magic
of d_splice_alias.
If someone whose working directory is in the move directory or a
subdirectory and now starts calling .. from the initial mount of nfs
(where s_root == mnt_root), then path_connected as a heuristic will
not bother with the is_subdir check. As s_root really is not the root
of the nfs filesystem this heuristic is wrong, and the path may
actually not be connected and path_connected can fail.
The is_subdir function might be cheap enough that we can call it
unconditionally. Verifying that will take some benchmarking and
the result may not be the same on all kernels this fix needs
to be backported to. So I am avoiding that for now.
Filesystems with snapshots such as nilfs and btrfs do something
similar. But as the directory tree of the snapshots are disjoint
from one another and from the main directory tree rename won't move
things between them and this problem will not occur.
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Fixes: 397d425dc26d ("vfs: Test for and handle paths that are unreachable from their mnt_root")
commit 7d617264eb22b18d979eac6e85877a141253034e upstream.
Turning off the sink in this case causes various issues, because
userspace expects it to stay on until it turns it off explicitly.
Instead, turn the sink off and back on when a display is connected
again. This dance seems necessary for link training to work correctly.
Bugzilla: https://bugs.freedesktop.org/105308
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Michel Dänzer <michel.daenzer@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 342038d92403b3efa1138a8599666b9f026279d6 upstream.
We unmapped imported DMA-bufs when the GEM handle was dropped, not when the
hardware was done with the buffere.
Signed-off-by: Christian König <christian.koenig@amd.com>
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
CC: stable@vger.kernel.org
commit a2ff19f7b70118ced291a28d5313469914de451b upstream.
When releasing a client, we need to clear the clienttab[] entry at
first, then call snd_seq_queue_client_leave(). Otherwise, the
in-flight cell in the queue might be picked up by the timer interrupt
via snd_seq_check_queue() before calling snd_seq_queue_client_leave(),
and it's delivered to another queue while the client is clearing
queues. This may eventually result in an uncleared cell remaining in
a queue, and the later snd_seq_pool_delete() may need to wait for a
long time until the event gets really processed.
By moving the clienttab[] clearance at the beginning of release, any
event delivery of a cell belonging to this client will fail at a later
point, since snd_seq_client_ptr() returns NULL. Thus the cell that
was picked up by the timer interrupt will be returned immediately
without further delivery, and the long stall of snd_seq_delete_pool()
can be avoided, too.
commit d0f833065221cbfcbadf19fd4102bcfa9330006a upstream.
Although we've covered the races between concurrent write() and
ioctl() in the previous patch series, there is still a possible UAF in
the following scenario:
A: user client closed B: timer irq
-> snd_seq_release() -> snd_seq_timer_interrupt()
-> snd_seq_free_client() -> snd_seq_check_queue()
-> cell = snd_seq_prioq_cell_peek()
-> snd_seq_prioq_leave()
.... removing all cells
-> snd_seq_pool_done()
.... vfree()
-> snd_seq_compare_tick_time(cell)
... Oops
So the problem is that a cell is peeked and accessed without any
protection until it's retrieved from the queue again via
snd_seq_prioq_cell_out().
This patch tries to address it, also cleans up the code by a slight
refactoring. snd_seq_prioq_cell_out() now receives an extra pointer
argument. When it's non-NULL, the function checks the event timestamp
with the given pointer. The caller needs to pass the right reference
either to snd_seq_tick or snd_seq_realtime depending on the event
timestamp type.
A good news is that the above change allows us to remove the
snd_seq_prioq_cell_peek(), too, thus the patch actually reduces the
code size.
Reviewed-by: Nicolai Stange <nstange@suse.de>
commit 40088dc4e1ead7df31728c73f5b51d71da18831d upstream.
With the commit 1ba8f9d30817 ("ALSA: hda: Add a power_save
blacklist"), we changed the default value of power_save option to -1
for processing the power-save blacklist.
Unfortunately, this seems breaking user-space applications that
actually read the power_save parameter value via sysfs and judge /
adjust the power-saving status. They see the value -1 as if the
power-save is turned off, although the actual value is taken from
CONFIG_SND_HDA_POWER_SAVE_DEFAULT and it can be a positive.
So, overall, passing -1 there was no good idea. Let's partially
revert it -- at least for power_save option default value is restored
again to CONFIG_SND_HDA_POWER_SAVE_DEFAULT. Meanwhile, in this patch,
we keep the blacklist behavior and make is adjustable via the new
option, pm_blacklist.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=199073
Fixes: 1ba8f9d30817 ("ALSA: hda: Add a power_save blacklist")
Acked-by: Hans de Goede <hdegoede@redhat.com>
commit 01c0b4265cc16bc1f43f475c5944c55c10d5768f upstream.
snd_pcm_oss_get_formats() has an obvious use-after-free around
snd_mask_test() calls, as spotted by syzbot. The passed format_mask
argument is a pointer to the hw_params object that is freed before the
loop. What a surprise that it has been present since the original
code of decades ago...
Reported-by: syzbot+4090700a4f13fccaf648@syzkaller.appspotmail.com
commit 9ef0f88fe5466c2ca1d2975549ba6be502c464c1 upstream.
Just when I had decided that flush_cache_range() was always called with
a valid context, Helge reported two cases where the
"BUG_ON(!vma->vm_mm->context);" was hit on the phantom buildd:
kernel BUG at /mnt/sdb6/linux/linux-4.15.4/arch/parisc/kernel/cache.c:587!
CPU: 1 PID: 3254 Comm: kworker/1:2 Tainted: G D 4.15.0-1-parisc64-smp #1 Debian 4.15.4-1+b1
Workqueue: events free_ioctx
IAOQ[0]: flush_cache_range+0x164/0x168
IAOQ[1]: flush_cache_page+0x0/0x1c8
RP(r2): unmap_page_range+0xae8/0xb88
Backtrace:
[<00000000404a6980>] unmap_page_range+0xae8/0xb88
[<00000000404a6ae0>] unmap_single_vma+0xc0/0x188
[<00000000404a6cdc>] zap_page_range_single+0x134/0x1f8
[<00000000404a702c>] unmap_mapping_range+0x1cc/0x208
[<0000000040461518>] truncate_pagecache+0x98/0x108
[<0000000040461624>] truncate_setsize+0x9c/0xb8
[<00000000405d7f30>] put_aio_ring_file+0x80/0x100
[<00000000405d803c>] aio_free_ring+0x8c/0x290
[<00000000405d82c0>] free_ioctx+0x80/0x180
[<0000000040284e6c>] process_one_work+0x21c/0x668
[<00000000402854c4>] worker_thread+0x20c/0x778
[<0000000040291d44>] kthread+0x2d4/0x2e0
[<0000000040204020>] end_fault_vector+0x20/0xc0
This indicates that we need to handle the no context case in
flush_cache_range() as we do in flush_cache_mm().
In thinking about this, I realized that we don't need to flush the TLB
when there is no context. So, I added context checks to the large flush
cases in flush_cache_mm() and flush_cache_range(). The large flush case
occurs frequently in flush_cache_mm() and the change should improve fork
performance.
The v2 version of this change removes the BUG_ON from flush_cache_page()
by skipping the TLB flush when there is no context. I also added code
to flush the TLB in flush_cache_mm() and flush_cache_range() when we
have a context that's not current. Now all three routines handle TLB
flushes in a similar manner.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Cc: stable@vger.kernel.org # 4.9+
Signed-off-by: Helge Deller <deller@gmx.de>
commit 18a955219bf7d9008ce480d4451b6b8bf4483a22 upstream.
Gratian Crisan reported that vmalloc_fault() crashes when CONFIG_HUGETLBFS
is not set since the function inadvertently uses pXn_huge(), which always
return 0 in this case. ioremap() does not depend on CONFIG_HUGETLBFS.
Fix vmalloc_fault() to call pXd_large() instead.
Fixes: f4eafd8bcd52 ("x86/mm: Fix vmalloc_fault() to handle large pages properly")
Reported-by: Gratian Crisan <gratian.crisan@ni.com>
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: linux-mm@kvack.org
Link: https://lkml.kernel.org/r/20180313170347.3829-2-toshi.kani@hpe.com
commit e3b3121fa8da94cb20f9e0c64ab7981ae47fd085 upstream.
In accordance with Intel's microcode revision guidance from March 6 MCU
rev 0xc2 is cleared on both Skylake H/S and Skylake Xeon E3 processors
that share CPUID 506E3.
Signed-off-by: Alexander Sergeyev <sergeev917@gmail.com>
Cc: Jia Zhang <qianyue.zj@alibaba-inc.com>
Cc: Kyle Huey <me@kylehuey.com>
Cc: David Woodhouse <dwmw@amazon.co.uk>
Link: https://lkml.kernel.org/r/20180313193856.GA8580@localhost.localdomain
32-bit kernels
commit a14bff131108faf50cc0cf864589fd71ee216c96 upstream.
In the following commit:
9e0e3c5130e9 ("x86/speculation, objtool: Annotate indirect calls/jumps for objtool")
... we added annotations for CALL_NOSPEC/JMP_NOSPEC on 64-bit x86 kernels,
but we did not annotate the 32-bit path.
Annotate it similarly.
Signed-off-by: Andy Whitcroft <apw@canonical.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/20180314112427.22351-1-apw@canonical.com
commit b5069782453459f6ec1fdeb495d9901a4545fcb5 upstream.
POPF would trap if VIP was set regardless of whether IF was set. Fix it.
Suggested-by: Stas Sergeev <stsp@list.ru>
Reported-by: Bart Oldeman <bartoldeman@gmail.com>
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Fixes: 5ed92a8ab71f ("x86/vm86: Use the normal pt_regs area for vm86")
Link: http://lkml.kernel.org/r/ce95f40556e7b2178b6bc06ee9557827ff94bd28.1521003603.git.luto@kernel.org
commit 78393fdde2a456cafa414b171c90f26a3df98b20 upstream.
POPF is currently broken -- add tests to catch the error. This
results in:
[RUN] POPF with VIP set and IF clear from vm86 mode
[INFO] Exited vm86 mode due to STI
[FAIL] Incorrect return reason (started at eip = 0xd, ended at eip = 0xf)
because POPF currently fails to check IF before reporting a pending
interrupt.
This patch also makes the FAIL message a bit more informative.
Cc: Stas Sergeev <stsp@list.ru>
Link: http://lkml.kernel.org/r/a16270b5cfe7832d6d00c479d0f871066cbdb52b.1521003603.git.luto@kernel.org
commit a9e017d5619eb371460c8e516f4684def62bef3a upstream.
The STR and SLDT instructions are not valid when running on virtual-8086
mode and generate an invalid operand exception. These two instructions are
protected by the Intel User-Mode Instruction Prevention (UMIP) security
feature. In protected mode, if UMIP is enabled, these instructions generate
a general protection fault if called from CPL > 0. Linux traps the general
protection fault and emulates the instructions sgdt, sidt and smsw; but not
str and sldt.
These tests are added to verify that the emulation code does not emulate
these two instructions but the expected invalid operand exception is
seen.
Tests fallback to exit with INT3 in case emulation does happen.
Signed-off-by: Ricardo Neri <ricardo.neri-calderon@linux.intel.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Chen Yucong <slaoub@gmail.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Huang Rui <ray.huang@amd.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Ravi V. Shankar <ravi.v.shankar@intel.com>
Cc: Shuah Khan <shuah@kernel.org>
Cc: ricardo.neri@intel.com
Link: http://lkml.kernel.org/r/1509935277-22138-13-git-send-email-ricardo.neri-calderon@linux.intel.com
commit 9390afebe1d3f5a0be18b1afdd0ce09d67cebf9e upstream.
Certain user space programs that run on virtual-8086 mode may utilize
instructions protected by the User-Mode Instruction Prevention (UMIP)
security feature present in new Intel processors: SGDT, SIDT and SMSW. In
such a case, a general protection fault is issued if UMIP is enabled. When
such a fault happens, the kernel traps it and emulates the results of
these instructions with dummy values. The purpose of this new
test is to verify whether the impacted instructions can be executed
without causing such #GP. If no #GP exceptions occur, we expect to exit
virtual-8086 mode from INT3.
The instructions protected by UMIP are executed in representative use
cases:
a) displacement-only memory addressing
b) register-indirect memory addressing
c) results stored directly in operands
Unfortunately, it is not possible to check the results against a set of
expected values because no emulation will occur in systems that do not
have the UMIP feature. Instead, results are printed for verification. A
simple verification is done to ensure that results of all tests are
identical.
Link: http://lkml.kernel.org/r/1509935277-22138-12-git-send-email-ricardo.neri-calderon@linux.intel.com
commit 327d53d005ca47b10eae940616ed11c569f75a9b upstream.
Fix a logic error that caused the test to exit with 0 even if test
cases failed.
Cc: bartoldeman@gmail.com
Link: http://lkml.kernel.org/r/b1cc37144038958a469c8f70a5f47a6a5638636a.1521003603.git.luto@kernel.org
commit 7958b2246fadf54b7ff820a2a5a2c5ca1554716f upstream.
CPUID.0x7.0x0:EDX[18] indicates whether Intel CPU support PCONFIG instruction.
Cc: Kai Huang <kai.huang@linux.intel.com>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Link: http://lkml.kernel.org/r/20180305162610.37510-4-kirill.shutemov@linux.intel.com
commit d2b6dc61a8dd3c429609b993778cb54e75a5c5f0 upstream.
This partially reverts commit:
23b2a4ddebdd17f ("x86/boot/32: Defer resyncing initial_page_table until per-cpu is set up")
That commit had one definite bug and one potential bug. The
definite bug is that setup_per_cpu_areas() uses a differnet generic
implementation on UP kernels, so initial_page_table never got
resynced. This was fine for access to percpu data (it's in the
identity map on UP), but it breaks other users of
initial_page_table. The potential bug is that helpers like
efi_init() would be called before the tables were synced.
Avoid both problems by just syncing the page tables in setup_arch()
*and* setup_per_cpu_areas().
Reported-by: Jan Kiszka <jan.kiszka@siemens.com>
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Thomas Garnier <thgarnie@google.com>
Cc: linux-efi@vger.kernel.org
commit b4957ab0826f6f7efdfdc648521e1c4c3fc6ceda upstream.
This patch fixes some checkpatch.pl script caught errors and
warnings during the compilation time.
[ backported to 4.9.y to fix build warnings caused by the backporting of
64ec10dc2ab8 ("net: hns: Correct HNS RSS key set function") by Sasha
- gregkh]
Signed-off-by: Salil Mehta <salil.mehta@huawei.com>
Cc: Sasha Levin <alexander.levin@microsoft.com>
[ Upstream commit b7e27bc1d42e8e0cc58b602b529c25cd0071b336 ]
Custom policies can require file signatures based on LSM labels. These
files are normally created and only afterwards labeled, requiring them
to be signed.
Instead of requiring file signatures based on LSM labels, entire
filesystems could require file signatures. In this case, we need the
ability of writing new files without requiring file signatures.
The definition of a "new" file was originally defined as any file with
a length of zero. Subsequent patches redefined a "new" file to be based
on the FILE_CREATE open flag. By combining the open flag with a file
size of zero, this patch relaxes the file signature requirement.
Fixes: 1ac202e978e1 ima: accept previously set IMA_NEW_FILE
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
[ Upstream commit 2ce77d16db4240dd2e422fc0a5c26d3e2ec03446 ]
Things can explode for locktorture if the user does combinations
of nwriters_stress=0 nreaders_stress=0. Fix this by not assuming
we always want to torture writer threads.
Reported-by: Jeremy Linton <jeremy.linton@arm.com>
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Reviewed-by: Jeremy Linton <jeremy.linton@arm.com>
Tested-by: Jeremy Linton <jeremy.linton@arm.com>
[ Upstream commit 2adfa4210f8f35cdfb4e08318cc06b99752964c2 ]
The 'configinit.sh' script checks the format of optional argument for the
build directory, printing an error message if the format is not valid.
However, the error message uses the wrong variable, indicating an empty
string even though the user entered a non-empty (but erroneous) string.
This commit fixes the script to use the correct variable.
Fixes: c87b9c601ac8 ("rcutorture: Add KVM-based test framework")
Signed-off-by: SeongJae Park <sj38.park@gmail.com>
[ Upstream commit 92ff42645028fa6f9b8aa767718457b9264316b4 ]
Packets that don't have dest mac as the mac of the master device should
not be entertained by the IPvlan rx-handler. This is mostly true as the
packet path mostly takes care of that, except when the master device is
a virtual device. As demonstrated in the following case -
ip netns add ns1
ip link add ve1 type veth peer name ve2
ip link add link ve2 name iv1 type ipvlan mode l2
ip link set dev iv1 netns ns1
ip link set ve1 up
ip link set ve2 up
ip -n ns1 link set iv1 up
ip addr add 192.168.10.1/24 dev ve1
ip -n ns1 addr 192.168.10.2/24 dev iv1
ping -c2 192.168.10.2
<Works!>
ip neigh show dev ve1
ip neigh show 192.168.10.2 lladdr <random> dev ve1
<Still works! Wrong!!>
This patch adds that missing check in the IPvlan rx-handler.
Reported-by: Amit Sikka <amit.sikka@ericsson.com>
Signed-off-by: Mahesh Bandewar <maheshb@google.com>
[ Upstream commit 65a12b3aafed5fc59f4ce41b22b752b1729e6701 ]
We should be finishing the loop with timeout set to zero but because
this is a post-op we finish with timeout == -1.
Fixes: 1082e2703a2d ("ASoC: NUC900/audio: add nuc900 audio driver support")
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit c7976f5272486e4ff406014c4b43e2fa3b70b052 ]
In the ieee80211_setup_sdata() we check if the interface type is valid
and, if not, call BUG(). This should never happen, but if there is
something wrong with the code, it will not be caught until the bug
happens when an interface is being set up. Calling BUG() is too
extreme for this and a WARN_ON() would be better used instead. Change
that.
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
[ Upstream commit e16ea4bb516bc21ea2202f2107718b29218bea59 ]
Enforce using PS_MANUAL_POLL in ps hwsim debugfs to trigger a poll,
only if PS_ENABLED was set before.
This is required due to commit c9491367b759 ("mac80211: always update the
PM state of a peer on MGMT / DATA frames") that enforces the ap to
check only mgmt/data frames ps bit, and then update station's power save
accordingly.
When sending only ps-poll (control frame) the ap will not be aware that
the station entered power save.
Setting ps enable before triggering ps_poll, will send NDP with PM bit
enabled first.
Signed-off-by: Adiel Aloni <adiel.aloni@intel.com>
[ Upstream commit 8516673a996870ea0ceb337ee4f83c33c5ec3111 ]
Before accessing the GGTT we must flush the PTE writes and make them
visible to the chipset, or else the indirect access may end up in the
wrong page. In commit 3497971a71d8 ("agp/intel: Flush chipset writes
after updating a single PTE"), we noticed corruption of the uploads for
pwrite and for capturing GPU error states, but it was presumed that the
explicit calls to intel_gtt_chipset_flush() were sufficient for the
execbuffer path. However, we have not been flushing the chipset between
the PTE writes and access via the GTT itself.
For simplicity, do the flush after any PTE update rather than try and
batch the flushes on a just-in-time basis.
References: 3497971a71d8 ("agp/intel: Flush chipset writes after updating a single PTE")
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
Cc: Mika Kuoppala <mika.kuoppala@intel.com>
Cc: drm-intel-fixes@lists.freedesktop.org
Reviewed-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20171208214616.30147-1-chris@chris-wilson.co.uk
[ Upstream commit b9eab08d012fa093947b230f9a87257c27fb829b ]
When attempting to load a livepatch module, I got the following error:
module_64: patch_module: Expect noop after relocate, got 3c820000
The error was triggered by the following code in
unregister_netdevice_queue():
14c: 00 00 00 48 b 14c <unregister_netdevice_queue+0x14c>
14c: R_PPC64_REL24 net_set_todo
150: 00 00 82 3c addis r4,r2,0
GCC didn't insert a nop after the branch to net_set_todo() because it's
a sibling call, so it never returns. The nop isn't needed after the
branch in that case.
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Acked-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Reviewed-and-tested-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
[ Upstream commit 5108d768408abc80e4e8d99f5b406a73cb04056b ]
Kobject created using kobject_create_and_add() can be freed using
kobject_put() when there is no referenece any more. However,
kobject memory allocated with kzalloc() has to set up a release
callback in order to free it when the counter decreases to 0.
Otherwise it causes memory leak.
Signed-off-by: Yong Zhao <yong.zhao@amd.com>
Signed-off-by: Felix Kuehling <Felix.Kuehling@amd.com>
Reviewed-by: Oded Gabbay <oded.gabbay@gmail.com>
Signed-off-by: Oded Gabbay <oded.gabbay@gmail.com>
[ Upstream commit 72d24955b44a4039db54a1c252b5031969eeaac3 ]
When new veth is created, and GSO values have been configured
on one device, clone those values to the peer.
For example:
# ip link add dev vm1 gso_max_size 65530 type veth peer name vm2
This should create vm1 <--> vm2 with both having GSO maximum
size set to 65530.
Signed-off-by: Stephen Hemminger <sthemmin@microsoft.com>
[ Upstream commit d5ac225c7d64c9c3ef821239edc035634e594ec9 ]
The cam->buffers[] array has cam->num_frames elements so the > needs to
be changed to >= to avoid going beyond the end of the array. The
->buffers[] array is allocated in cpia2_allocate_buffers() if you want
to confirm.
Fixes: ab33d5071de7 ("V4L/DVB (3376): Add cpia2 camera support")
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
[ Upstream commit a17d2d6cd9985ca09a9e384f1bc71d710f7e5203 ]
When used as part of a display pipeline, the VSP is stopped and
restarted explicitly by the DU from its suspend and resume handlers.
There is thus no need to stop or restart pipelines in the VSP suspend
and resume handlers, and doing so would cause the hardware to be
left in a misconfigured state.
Ensure that the VSP suspend and resume handlers do not affect DRM-based
pipelines.
Signed-off-by: Kieran Bingham <kieran.bingham+renesas@ideasonboard.com>
Reviewed-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
[ Upstream commit 4b3aec2bbbce1c35f50e7475a9fd78d24b9ea4ea ]
Add IBM 3542 and 3552, arrays: FAStT200 and FAStT500.
Add full STK OPENstorage family, arrays: 9176, D173, D178, D210, D220,
D240 and D280.
Add STK BladeCtlr family, arrays: B210, B220, B240 and B280.
These changes were done in multipath-tools time ago.
Cc: NetApp RDAC team <ng-eseries-upstream-maintainers@netapp.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Christophe Varoqui <christophe.varoqui@opensvc.com>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Cc: James E.J. Bottomley <jejb@linux.vnet.ibm.com>
Cc: SCSI ML <linux-scsi@vger.kernel.org>
Cc: device-mapper development <dm-devel@redhat.com>
Signed-off-by: Xose Vazquez Perez <xose.vazquez@gmail.com>
[ Upstream commit b369a0471503130cfc74f9f62071db97f48948c3 ]
Commit 56f3d383f37b ("scsi: scsi_devinfo: Add TRY_VPD_PAGES to HITACHI
OPEN-V blacklist entry") modified some Hitachi entries:
HITACHI is always supporting VPD pages, even though it's claiming to
support SCSI Revision 3 only.
The same should have been done also for HP-rebranded.
[mkp: checkpatch and tweaked commit message]
Cc: Takahiro Yasui <takahiro.yasui@hds.com>
Cc: Matthias Rudolph <Matthias.Rudolph@hitachivantara.com>
[ Upstream commit a44c9d36509c83cf64f33b93f6ab2e63822c01eb ]
Since scsi_get_device_flags_keyed() callers do not check whether or not
the returned value is an error code, change that function such that it
returns a flags value even if the 'key' argument is invalid. Note:
since commit 28a0bc4120d3 ("scsi: sd: Implement blacklist option for
WRITE SAME w/ UNMAP") bit 31 is a valid device information flag so
checking whether bit 31 is set in the return value is not sufficient to
tell the difference between an error code and a flags value.
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Cc: Hannes Reinecke <hare@suse.com>
Cc: Johannes Thumshirn <jthumshirn@suse.de>
[ Upstream commit a8168b6cee6e9334dfebb4b9108e8d73794f6088 ]
On some dual port NICs, the 2 ports have to be configured with compatible
link speeds. Under some conditions, a port's configured speed may no
longer be supported. The firmware will send a message to the driver
when this happens.
Improve this logic that prints out the warning by only printing it if
we can determine the link speed that is no longer supported. If the
speed is unknown or it is in autoneg mode, skip the warning message.
Reported-by: Thomas Bogendoerfer <tbogendoerfer@suse.de>
Signed-off-by: Michael Chan <michael.chan@broadcom.com>
Tested-by: Thomas Bogendoerfer <tbogendoerfer@suse.de>
