commit f73b3cc39c84220e6dccd463b5c8279b03514646 upstream.
If the build user has the CFLAGS variable set in their environment,
objtool blindly appends to it, which can cause unexpected behavior.
Clobber CFLAGS to ensure consistent objtool compilation behavior.
Reported-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Tested-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Link: https://lkml.kernel.org/r/83a276df209962e6058fcb6c615eef9d401c21bc.1567121311.git.jpoimboe@redhat.com
CC: Nathan Chancellor <natechancellor@gmail.com>
commit 24a8d78a9affb63e5ced313ccde6888fe96edc6e upstream.
When naming the new devices, instead of using the ACPI ID in
the name as base, using the parent device's name. That makes
it possible to support multiple multi-instance i2c devices
of the same type in the same system.
This fixes an issue seen on some Intel Kaby Lake based
boards:
sysfs: cannot create duplicate filename '/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-INT3515-tps6598x.0'
Fixes: 2336dfadfb1e ("platform/x86: i2c-multi-instantiate: Allow to have same slaves")
Cc: stable@vger.kernel.org
Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
commit d2c63b7dfd06788a466d5ec8a850491f084c5fc2 upstream.
It's reported that the garbled sound on HP Envy x360 13z-ag000 (Ryzen
Laptop) is fixed by the same workaround applied to other AMD chips.
Update the driver_data entry for Raven (1022:15e3) to use the newly
introduced preset, AZX_DCAPS_PRESET_AMD_SB. Since it already contains
AZX_DCAPS_PM_RUNTIME, we can drop that bit, too.
Reported-and-tested-by: Dennis Padiernos <depadiernos@gmail.com>
Cc: <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/20190920073040.31764-1-tiwai@suse.de
commit 7b485d175631be676424aedb8cd2f66d0c93da78 upstream.
The same fixup to enable laptop imic is needed for ASUS M9V with AD1986A
codec like another HP machine.
Signed-off-by: Shih-Yuan Lee (FourDollars) <fourdollars@debian.org>
Link: https://lore.kernel.org/r/20190920134052.GA8035@localhost
commit 3a9236e97207f2469254b4098995159b80174d95 upstream.
At higher sampling rate (e.g. 192.0 kHz), Alesis iO26 transfers 4 data
channels per data block in CIP.
Both iO14 and iO26 have the same contents in their configuration ROM.
For this reason, ALSA Dice driver attempts to distinguish them according
to the value of TX0_AUDIO register at probe callback. Although the way is
valid at lower and middle sampling rate, it's lastly invalid at higher
sampling rate because because the two models returns the same value for
read transaction to the register.
In the most cases, users just plug-in the device and ALSA dice driver
detects it. In the case, the device runs at lower sampling rate and
the driver detects expectedly. For this reason, this commit leaves the
way to detect as is.
Fixes: 28b208f600a3 ("ALSA: dice: add parameters of stream formats for models produced by Alesis")
Cc: <stable@vger.kernel.org> # v4.18+
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
Link: https://lore.kernel.org/r/20190916101851.30409-1-o-takashi@sakamocchi.jp
commit f41f900568d9ffd896cc941db7021eb14bd55910 upstream.
EVGA NU Audio is actually a USB audio device on a PCIexpress card,
with it's own USB controller. It supports both PCM and DSD.
Signed-off-by: Jussi Laako <jussi@sonarnerd.net>
Link: https://lore.kernel.org/r/20190924071143.30911-1-jussi@sonarnerd.net
commit 029d2c0fd61eac74700fb4ffff36fc63bfff7e5e upstream.
This patch adds quirk VID ID for Hiby portable players family with
native DSD playback support.
Signed-off-by: Ilya Pshonkin <sudokamikaze@protonmail.com>
Link: https://lore.kernel.org/r/20190917074937.157802-1-ilya.pshonkin@netforce.ua
commit 6e73fd25e2c7510b7dfadbaf701f31d4bff9c75b upstream.
With the original commit applied, z3fold_zpool_destroy() may get blocked
on wait_event() for indefinite time. Revert this commit for the time
being to get rid of this problem since the issue the original commit
addresses is less severe.
Link: http://lkml.kernel.org/r/20190910123142.7a9c8d2de4d0acbc0977c602@gmail.com
Fixes: d776aaa9895eb6eb77 ("mm/z3fold.c: fix race between migration and destruction")
Reported-by: Agustín Dall'Alba <agustin@dallalba.com.ar>
Signed-off-by: Vitaly Wool <vitalywool@gmail.com>
Cc: Vitaly Wool <vitalywool@gmail.com>
Cc: Shakeel Butt <shakeelb@google.com>
Cc: Jonathan Adams <jwadams@google.com>
Cc: Henry Burns <henrywolfeburns@gmail.com>
commit 053a4ffe298836bb973d2cba59f82fff60c7db5b upstream.
The AUDIO PLL max support 650M, so the original clk settings violate
spec. This patch makes the output 786432000 -> 393216000,
and 722534400 -> 361267200 to aligned with NXP vendor kernel without any
impact on audio functionality and go within 650MHz PLL limit.
Fixes: ba5625c3e272 ("clk: imx: Add clock driver support for imx8mm")
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Acked-by: Abel Vesa <abel.vesa@nxp.com>
commit 5fc194ea6d34dfad9833d3043ce41d6c52aff39a upstream.
Add missing break statement in order to prevent the code from falling
through to case CRYPTO_ALG_TYPE_AHASH.
Fixes: aeb4c132f33d ("crypto: talitos - Convert to new AEAD interface")
Reported-by: kbuild test robot <lkp@intel.com>
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Reviewed-by: Christophe Leroy <christophe.leroy@c-s.fr>
commit 37c673ade35c707d50583b5b25091ff8ebdeafd7 upstream.
As reported by the OpenWRT team, write requests sometimes fail on some
platforms.
Currently to check the state chip_ready() is used correctly as described by
the flash memory S29GL256P11TFI01 datasheet.
Also chip_good() is used to check if the write is succeeded and it was
implemented by the commit fb4a90bfcd6d8 ("[MTD] CFI-0002 - Improve error
checking").
But actually the write failure is caused on some platforms and also it can
be fixed by using chip_good() to check the state and retry instead.
Also it seems that it is caused after repeated about 1,000 times to retry
the write one word with the reset command.
By using chip_good() to check the state to be done it can be reduced the
retry with reset.
It is depended on the actual flash chip behavior so the root cause is
unknown.
Cc: Chris Packham <chris.packham@alliedtelesis.co.nz>
Cc: Joakim Tjernlund <Joakim.Tjernlund@infinera.com>
Cc: linux-mtd@lists.infradead.org
Reported-by: Fabio Bettoni <fbettoni@gmail.com>
Signed-off-by: Felix Fietkau <nbd@nbd.name>
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Signed-off-by: Tokunori Ikegami <ikegami.t@gmail.com>
[vigneshr@ti.com: Fix a checkpatch warning]
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
commit 2acf40f0454d41b8d51c95d317283c20c931164d upstream.
The PixArt OEM mice are known for disconnecting every minute in
runlevel 1 or 3 if they are not always polled. So add quirk
ALWAYS_POLL for this one as well.
Ville Viinikka (viinikv) reported and tested the quirk.
Link: https://github.com/sriemer/fix-linux-mouse issue 15
Signed-off-by: Sebastian Parschauer <s.parschauer@gmx.de>
CC: stable@vger.kernel.org # v4.16+
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit 416dacb819f59180e4d86a5550052033ebb6d72c upstream.
The syzbot fuzzer has reported a pair of problems in the
hidraw_ioctl() function: slab-out-of-bounds read and use-after-free
read. An example of the first:
BUG: KASAN: slab-out-of-bounds in strlen+0x79/0x90 lib/string.c:525
Read of size 1 at addr ffff8881c8035f38 by task syz-executor.4/2833
CPU: 1 PID: 2833 Comm: syz-executor.4 Not tainted 5.3.0-rc2+ #1
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS
Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0xca/0x13e lib/dump_stack.c:113
print_address_description+0x6a/0x32c mm/kasan/report.c:351
__kasan_report.cold+0x1a/0x33 mm/kasan/report.c:482
kasan_report+0xe/0x12 mm/kasan/common.c:612
strlen include/linux/string.h:281 [inline]
hidraw_ioctl+0x245/0xae0 drivers/hid/hidraw.c:446
vfs_ioctl fs/ioctl.c:46 [inline]
file_ioctl fs/ioctl.c:509 [inline]
do_vfs_ioctl+0xd2d/0x1330 fs/ioctl.c:696
ksys_ioctl+0x9b/0xc0 fs/ioctl.c:713
__do_sys_ioctl fs/ioctl.c:720 [inline]
__se_sys_ioctl fs/ioctl.c:718 [inline]
__x64_sys_ioctl+0x6f/0xb0 fs/ioctl.c:718
do_syscall_64+0xb7/0x580 arch/x86/entry/common.c:296
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x459829
Code: fd b7 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7
48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff
ff 0f 83 cb b7 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f7a68f6dc78 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 0000000000459829
RDX: 0000000000000000 RSI: 0000000080404805 RDI: 0000000000000004
RBP: 000000000075bf20 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00007f7a68f6e6d4
R13: 00000000004c21de R14: 00000000004d5620 R15: 00000000ffffffff
The two problems have the same cause: hidraw_ioctl() fails to test
whether the device has been removed. This patch adds the missing test.
Reported-and-tested-by: syzbot+5a6c4ec678a0c6ee84ba@syzkaller.appspotmail.com
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: <stable@vger.kernel.org>
commit 8ccff2843fb4e6d9d26e5ae9ffe9840b38b92638 upstream.
Before this commit dj_probe would exit with an error if the initial
logi_dj_recv_query_paired_devices fails. The initial call may fail
when the receiver is connected through a kvm and the focus is away.
When the call fails this causes 2 problems:
1) dj_probe calls logi_dj_recv_query_paired_devices after calling
hid_device_io_start() so a HID report may have been received in between
and our delayedwork_callback may be running. It seems that the initial
logi_dj_recv_query_paired_devices failure happening with some KVMs triggers
this exact scenario, causing the work-queue to run on free-ed memory,
leading to:
BUG: unable to handle page fault for address: 0000000000001e88
#PF: supervisor read access in kernel mode
#PF: error_code(0x0000) - not-present page
PGD 0 P4D 0
Oops: 0000 [#1] SMP PTI
CPU: 3 PID: 257 Comm: kworker/3:3 Tainted: G OE 5.3.0-rc5+ #100
Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./B150M Pro4S/D3, BIOS P7.10 12/06/2016
Workqueue: events 0xffffffffc02ba200
RIP: 0010:0xffffffffc02ba1bd
Code: e8 e8 13 00 d8 48 89 c5 48 85 c0 74 4c 48 8b 7b 10 48 89 ea b9 07 00 00 00 41 b9 09 00 00 00 41 b8 01 00 00 00 be 10 00 00 00 <48> 8b 87 88 1e 00 00 48 8b 40 40 e8 b3 6b b4 d8 48 89 ef 41 89 c4
RSP: 0018:ffffb760c046bdb8 EFLAGS: 00010286
RAX: ffff935038ea4550 RBX: ffff935046778000 RCX: 0000000000000007
RDX: ffff935038ea4550 RSI: 0000000000000010 RDI: 0000000000000000
RBP: ffff935038ea4550 R08: 0000000000000001 R09: 0000000000000009
R10: 000000000000e011 R11: 0000000000000001 R12: ffff9350467780e8
R13: ffff935046778000 R14: 0000000000000000 R15: ffff935046778070
FS: 0000000000000000(0000) GS:ffff935054e00000(0000) knlGS:0000000000000000
CR2: 0000000000001e88 CR3: 000000075a612002 CR4: 00000000003606e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
0xffffffffc02ba2f7
? process_one_work+0x1b1/0x560
process_one_work+0x234/0x560
worker_thread+0x50/0x3b0
kthread+0x10a/0x140
? process_one_work+0x560/0x560
? kthread_park+0x80/0x80
ret_from_fork+0x3a/0x50
Modules linked in: vboxpci(O) vboxnetadp(O) vboxnetflt(O) vboxdrv(O) bnep vfat fat btusb btrtl btbcm btintel bluetooth intel_rapl_msr ecdh_generic rfkill ecc snd_usb_audio snd_usbmidi_lib intel_rapl_common snd_rawmidi mc x86_pkg_temp_thermal intel_powerclamp coretemp iTCO_wdt iTCO_vendor_support mei_wdt mei_hdcp ppdev kvm_intel kvm irqbypass crct10dif_pclmul crc32_generic crc32_pclmul snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio ghash_clmulni_intel intel_cstate snd_hda_intel snd_hda_codec intel_uncore snd_hda_core snd_hwdep intel_rapl_perf snd_seq snd_seq_device snd_pcm snd_timer intel_wmi_thunderbolt snd e1000e soundcore mxm_wmi i2c_i801 bfq mei_me mei intel_pch_thermal parport_pc parport acpi_pad binfmt_misc hid_lg_g15(E) hid_logitech_dj(E) i915 crc32c_intel i2c_algo_bit drm_kms_helper nvme nvme_core drm wmi video uas usb_storage i2c_dev
---[ end trace 1d3f8afdcfcbd842 ]---
2) Even if we were to fix 1. by making sure the work is stopped before
failing probe, failing probe is the wrong thing to do, we have
logi_dj_recv_queue_unknown_work to deal with the initial
logi_dj_recv_query_paired_devices failure.
Rather then error-ing out of the probe, causing the receiver to not work at
all we should rely on this, so that the attached devices will get properly
enumerated once the KVM focus is switched back.
Fixes: 74808f9115ce ("HID: logitech-dj: add support for non unifying receivers")
commit 5f9242775bb61f390f0885f23fc16397262c7538 upstream.
The syzbot fuzzer found a general protection fault in the HID subsystem:
kasan: CONFIG_KASAN_INLINE enabled
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] SMP KASAN
CPU: 0 PID: 3715 Comm: syz-executor.3 Not tainted 5.2.0-rc6+ #15
Google 01/01/2011
RIP: 0010:__pm_runtime_resume+0x49/0x180 drivers/base/power/runtime.c:1069
Code: ed 74 d5 fe 45 85 ed 0f 85 9a 00 00 00 e8 6f 73 d5 fe 48 8d bd c1 02
00 00 48 b8 00 00 00 00 00 fc ff df 48 89 fa 48 c1 ea 03 <0f> b6 04 02 48
89 fa 83 e2 07 38 d0 7f 08 84 c0 0f 85 fe 00 00 00
RSP: 0018:ffff8881d99d78e0 EFLAGS: 00010202
RAX: dffffc0000000000 RBX: 0000000000000020 RCX: ffffc90003f3f000
RDX: 0000000416d8686d RSI: ffffffff82676841 RDI: 00000020b6c3436a
RBP: 00000020b6c340a9 R08: ffff8881c6d64800 R09: fffffbfff0e84c25
R10: ffff8881d99d7940 R11: ffffffff87426127 R12: 0000000000000004
R13: 0000000000000000 R14: ffff8881d9b94000 R15: ffffffff897f9048
FS: 00007f047f542700(0000) GS:ffff8881db200000(0000) knlGS:0000000000000000
CR2: 0000001b30f21000 CR3: 00000001ca032000 CR4: 00000000001406f0
Call Trace:
pm_runtime_get_sync include/linux/pm_runtime.h:226 [inline]
usb_autopm_get_interface+0x1b/0x50 drivers/usb/core/driver.c:1707
usbhid_power+0x7c/0xe0 drivers/hid/usbhid/hid-core.c:1234
hid_hw_power include/linux/hid.h:1038 [inline]
hidraw_open+0x20d/0x740 drivers/hid/hidraw.c:282
chrdev_open+0x219/0x5c0 fs/char_dev.c:413
do_dentry_open+0x497/0x1040 fs/open.c:778
do_last fs/namei.c:3416 [inline]
path_openat+0x1430/0x3ff0 fs/namei.c:3533
do_filp_open+0x1a1/0x280 fs/namei.c:3563
do_sys_open+0x3c0/0x580 fs/open.c:1070
do_syscall_64+0xb7/0x560 arch/x86/entry/common.c:301
It turns out the fault was caused by a bug in the HID Logitech driver,
which violates the requirement that every pathway calling
hid_hw_start() must also call hid_hw_stop(). This patch fixes the bug
by making sure the requirement is met.
Reported-and-tested-by: syzbot+3cbe5cd105d2ad56a1df@syzkaller.appspotmail.com
commit 2bcdacb70327013ca2066bfcf2af1009eff01f1d upstream.
The sony driver is not properly cleaning up from potential failures in
sony_input_configured. Currently it calls hid_hw_stop, while hid_connect
is still running. This is not a good idea, instead hid_hw_stop should
be moved to sony_probe. Similar changes were recently made to Logitech
drivers, which were also doing improper cleanup.
Signed-off-by: Roderick Colenbrander <roderick.colenbrander@sony.com>
commit 98375b86c79137416e9fd354177b85e768c16e56 upstream.
The syzbot fuzzer provoked a general protection fault in the
hid-prodikeys driver:
CPU: 0 PID: 12 Comm: kworker/0:1 Not tainted 5.3.0-rc5+ #28
Google 01/01/2011
Workqueue: usb_hub_wq hub_event
RIP: 0010:pcmidi_submit_output_report drivers/hid/hid-prodikeys.c:300 [inline]
RIP: 0010:pcmidi_set_operational drivers/hid/hid-prodikeys.c:558 [inline]
RIP: 0010:pcmidi_snd_initialise drivers/hid/hid-prodikeys.c:686 [inline]
RIP: 0010:pk_probe+0xb51/0xfd0 drivers/hid/hid-prodikeys.c:836
Code: 0f 85 50 04 00 00 48 8b 04 24 4c 89 7d 10 48 8b 58 08 e8 b2 53 e4 fc
48 8b 54 24 20 48 b8 00 00 00 00 00 fc ff df 48 c1 ea 03 <80> 3c 02 00 0f
85 13 04 00 00 48 ba 00 00 00 00 00 fc ff df 49 8b
The problem is caused by the fact that pcmidi_get_output_report() will
return an error if the HID device doesn't provide the right sort of
output report, but pcmidi_set_operational() doesn't bother to check
the return code and assumes the function call always succeeds.
This patch adds the missing check and aborts the probe operation if
necessary.
Reported-and-tested-by: syzbot+1088533649dafa1c9004@syzkaller.appspotmail.com
commit 6ccb4ac2bf8a35c694ead92f8ac5530a16e8f2c8 upstream.
There's a bug in skiboot that causes the OPAL_XIVE_ALLOCATE_IRQ call
to return the 32-bit value 0xffffffff when OPAL has run out of IRQs.
Unfortunatelty, OPAL return values are signed 64-bit entities and
errors are supposed to be negative. If that happens, the linux code
confusingly treats 0xffffffff as a valid IRQ number and panics at some
point.
A fix was recently merged in skiboot:
e97391ae2bb5 ("xive: fix return value of opal_xive_allocate_irq()")
but we need a workaround anyway to support older skiboots already
in the field.
Internally convert 0xffffffff to OPAL_RESOURCE which is the usual error
returned upon resource exhaustion.
Cc: stable@vger.kernel.org # v4.12+
Signed-off-by: Greg Kurz <groug@kaod.org>
Reviewed-by: Cédric Le Goater <clg@kaod.org>
Link: https://lore.kernel.org/r/156821713818.1985334.14123187368108582810.stgit@bahia.lan
undefined SW FP routines
commit 0f0727d971f6fdf8f1077180d495ddb9928f0c8b upstream.
arch/x86/Makefile disables SSE and SSE2 for the whole kernel. The
AMDGPU drivers modified in this patch re-enable SSE but not SSE2. Turn
on SSE2 to support emitting double precision floating point instructions
rather than calls to non-existent (usually available from gcc_s or
compiler_rt) floating point helper routines for Clang.
This was originally landed in:
commit 10117450735c ("drm/amd/display: add -msse2 to prevent Clang from emitting libcalls to undefined SW FP routines")
but reverted in:
commit 193392ed9f69 ("Revert "drm/amd/display: add -msse2 to prevent Clang from emitting libcalls to undefined SW FP routines"")
due to bugreports from GCC builds. Add guards to only do so for Clang.
Link: https://bugs.freedesktop.org/show_bug.cgi?id=109487
Link: https://github.com/ClangBuiltLinux/linux/issues/327
Suggested-by: Sedat Dilek <sedat.dilek@gmail.com>
Suggested-by: Sami Tolvanen <samitolvanen@google.com>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit bd200d190f45b62c006d1ad0a63eeffd87db7a47 upstream.
[Why]
DRM private objects have no hw_done/flip_done fencing mechanism on their
own and cannot be used to sequence commits accordingly.
When issuing commits that don't touch the same set of hardware resources
like page-flips on different CRTCs we can run into the issue below
because of this:
1. Client requests non-blocking Commit #1, has a new dc_state #1,
state is swapped, commit tail is deferred to work queue
2. Client requests non-blocking Commit #2, has a new dc_state #2,
3. Commit #2 work starts, commit tail finishes,
atomic state is cleared, dc_state #1 is freed
4. Commit #1 work starts,
commit tail encounters null pointer deref on dc_state #1
In order to change the DC state as in the private object we need to
ensure that we wait for all outstanding commits to finish and that
any other pending commits must wait for the current one to finish as
well.
We do this for MEDIUM and FULL updates. But not for FAST updates, nor
would we want to since it would cause stuttering from the delays.
FAST updates that go through dm_determine_update_type_for_commit always
create a new dc_state and lock the DRM private object if there are
any changed planes.
We need the old state to validate, but we don't actually need the new
state here.
[How]
If the commit isn't a full update then the use after free can be
resolved by simply discarding the new state entirely and retaining
the existing one instead.
With this change the sequence above can be reexamined. Commit #2 will
still free Commit #1's reference, but before this happens we actually
added an additional reference as part of Commit #2.
If an update comes in during this that needs to change the dc_state
it will need to wait on Commit #1 and Commit #2 to finish. Then it'll
swap the state, finish the work in commit tail and drop the last
reference on Commit #2's dc_state.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=204181
Fixes: 004b3938e637 ("drm/amd/display: Check scaling info when determing update type")
Signed-off-by: Nicholas Kazlauskas <nicholas.kazlauskas@amd.com>
Acked-by: Alex Deucher <alexander.deucher@amd.com>
Reviewed-by: David Francis <david.francis@amd.com>
commit 43d10d30df156f7834fa91aecb69614fefc8bb0a upstream.
[Why]
By passing through the dm_determine_update_type_for_commit for atomic
commits that can be done asynchronously we are incurring a
performance penalty by locking access to the global private object
and holding that access until the end of the programming sequence.
This is also allocating a new large dc_state on every access in addition
to retaining all the references on each stream and plane until the end
[How]
Shift the determination for async update before validation. Return early
if it's going to be an async update.
commit e16e37efb4c9eb7bcb9dab756c975040c5257e98 upstream.
[Why]
We previously allowed framebuffer swaps as async updates for cursor
planes but had to disable them due to a bug in DRM with async update
handling and incorrect ref counting. The check to block framebuffer
swaps has been added to DRM for a while now, so this check is redundant.
The real fix that allows this to properly in DRM has also finally been
merged and is getting backported into stable branches, so dropping
this now seems to be the right time to do so.
[How]
Drop the redundant check for old_fb != new_fb.
With the proper fix in DRM, this should also fix some cursor stuttering
issues with xf86-video-amdgpu since it double buffers the cursor.
IGT tests that swap framebuffers (-varying-size for example) should
also pass again.
commit 14e019df1e64c8b19ce8e0b3da25b6f40c8716be upstream.
Deferred probe is an expected return value on many platforms and so
there's no need to output a warning that may potentially confuse users.
Signed-off-by: Jon Hunter <jonathanh@nvidia.com>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
commit 763719771e84b8c8c2f53af668cdc905faa608de upstream.
Deferred probe is an expected return value for clk_get() on many
platforms. The driver deals with it properly, so there's no need
commit 47e640af2e492cc28778dd6f894d50313f7fba75 upstream.
nf_tables.h defines an API comprising several inline functions and
macros that depend on the nft member of struct net. However, this is
only defined is CONFIG_NF_TABLES is enabled. Added preprocessor checks
to ensure that nf_tables.h will compile if CONFIG_NF_TABLES is disabled.
Signed-off-by: Jeremy Sowden <jeremy@azazel.net>
Link: https://lore.kernel.org/netfilter-devel/20190920094925.aw7actk4tdnk3rke@salvia/T/
Fixes: 3c171f496ef5 ("netfilter: bridge: add connection tracking system")
Reported-by: Adam Borowski <kilobyte@angband.pl>
commit 0c4df39e504bf925ab666132ac3c98d6cbbe380b upstream.
Ensure we do not access the buffer beyond the end if no 0xff byte
is encountered.
Reported-by: syzbot+eaaaf38a95427be88f4b@syzkaller.appspotmail.com
Signed-off-by: Sean Young <sean@mess.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
commit 52f6f9d74f31078964ca1574f7bb612da7877ac8 upstream.
As sparse points out, these two copy_from_user() should actually be
copy_to_user().
Fixes: 229b53c9bf4e ("take floppy compat ioctls to sodding floppy.c")
Acked-by: Alexander Popov <alex.popov@linux.com>
Reviewed-by: Mukesh Ojha <mojha@codeaurora.org>
Signed-off-by: Jann Horn <jannh@google.com>
commit 14ced7e3a1ae9bed7051df3718c8c7b583854a5c upstream.
Despite extensive testing of commit 885bd765963b ("phy: qcom-qmp: Correct
READY_STATUS poll break condition") I failed to conclude that the
PHYSTATUS bit of the PCS_STATUS register used in PCIe and USB3 falls as
the PHY gets ready. Similar to the prior bug with UFS the code will
generally get past the check before the transition and thereby
"succeed".
Correct the name of the register used PCIe and USB3 PHYs, replace
mask_pcs_ready with a constant expression depending on the type of the
PHY and check for the appropriate ready state.
Cc: Vivek Gautam <vivek.gautam@codeaurora.org>
Cc: Evan Green <evgreen@chromium.org>
Cc: Niklas Cassel <niklas.cassel@linaro.org>
Reported-by: Marc Gonzalez <marc.w.gonzalez@free.fr>
Fixes: 885bd765963b ("phy: qcom-qmp: Correct READY_STATUS poll break condition")
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Tested-by: Marc Gonzalez <marc.w.gonzalez@free.fr>
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
commit 0be0bfd2de9dfdd2098a9c5b14bdd8f739c9165d upstream.
Once upon a time, commit 2cac0c00a6cd ("ovl: get exclusive ownership on
upper/work dirs") in v4.13 added some sanity checks on overlayfs layers.
This change caused a docker regression. The root cause was mount leaks
by docker, which as far as I know, still exist.
To mitigate the regression, commit 85fdee1eef1a ("ovl: fix regression
caused by exclusive upper/work dir protection") in v4.14 turned the
mount errors into warnings for the default index=off configuration.
Recently, commit 146d62e5a586 ("ovl: detect overlapping layers") in
v5.2, re-introduced exclusive upper/work dir checks regardless of
This changes the status quo and mount leak related bug reports have
started to re-surface. Restore the status quo to fix the regressions.
To clarify, index=off does NOT relax overlapping layers check for this
ovelayfs mount. index=off only relaxes exclusive upper/work dir checks
with another overlayfs mount.
To cover the part of overlapping layers detection that used the
exclusive upper/work dir checks to detect overlap with self upper/work
dir, add a trap also on the work base dir.
Link: https://github.com/moby/moby/issues/34672
Link: https://lore.kernel.org/linux-fsdevel/20171006121405.GA32700@veci.piliscsaba.szeredi.hu/
Link: https://github.com/containers/libpod/issues/3540
Fixes: 146d62e5a586 ("ovl: detect overlapping layers")
Cc: <stable@vger.kernel.org> # v4.19+
Signed-off-by: Amir Goldstein <amir73il@gmail.com>
Tested-by: Colin Walters <walters@verbum.org>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
commit d0b7a302d58abe24ed0f32a0672dd4c356bb73db upstream.
This reverts commit 24fe1b0efad4fcdd32ce46cffeab297f22581707.
Commit 24fe1b0efad4fcdd ("arm64: Remove unnecessary ISBs from
set_{pte,pmd,pud}") removed ISB instructions immediately following updates
to the page table, on the grounds that they are not required by the
architecture and a DSB alone is sufficient to ensure that subsequent data
accesses use the new translation:
DDI0487E_a, B2-128:
| ... no instruction that appears in program order after the DSB
| instruction can alter any state of the system or perform any part of
| its functionality until the DSB completes other than:
| * Being fetched from memory and decoded
| * Reading the general-purpose, SIMD and floating-point,
| Special-purpose, or System registers that are directly or indirectly
| read without causing side-effects.
However, the same document also states the following:
DDI0487E_a, B2-125:
| DMB and DSB instructions affect reads and writes to the memory system
| generated by Load/Store instructions and data or unified cache
| maintenance instructions being executed by the PE. Instruction fetches
| or accesses caused by a hardware translation table access are not
| explicit accesses.
which appears to claim that the DSB alone is insufficient. Unfortunately,
some CPU designers have followed the second clause above, whereas in Linux
we've been relying on the first. This means that our mapping sequence:
MOV X0, <valid pte>
STR X0, [Xptep] // Store new PTE to page table
DSB ISHST
LDR X1, [X2] // Translates using the new PTE
can actually raise a translation fault on the load instruction because the
translation can be performed speculatively before the page table update and
then marked as "faulting" by the CPU. For user PTEs, this is ok because we
can handle the spurious fault, but for kernel PTEs and intermediate table
entries this results in a panic().
Revert the offending commit to reintroduce the missing barriers.
Fixes: 24fe1b0efad4fcdd ("arm64: Remove unnecessary ISBs from set_{pte,pmd,pud}")
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Will Deacon <will@kernel.org>
commit 4b2c5a14cd8005a900075f7dfec87473c6ee66fb upstream.
commit 1222a1601488 ("nl80211: Fix possible Spectre-v1 for CQM
RSSI thresholds") was incomplete and requires one more fix to
prevent accessing to rssi_thresholds[n] because user can control
rssi_thresholds[i] values to make i reach to n. For example,
rssi_thresholds = {-400, -300, -200, -100} when last is -34.
Fixes: 1222a1601488 ("nl80211: Fix possible Spectre-v1 for CQM RSSI thresholds")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Masashi Honma <masashi.honma@gmail.com>
Link: https://lore.kernel.org/r/20190908005653.17433-1-masashi.honma@gmail.com
commit d2ace81bf902a9f11d52e59e5d232d2255a0e353 upstream.
When half-duplex RS485 communication is used, after RX is started, TX
tasklet still needs to be scheduled tasklet. This avoids console freezing
when more data is to be transmitted, if the serial communication is not
closed.
Fixes: 69646d7a3689 ("tty/serial: atmel: RS485 HD w/DMA: enable RX after TX is stopped")
Signed-off-by: Razvan Stefanescu <razvan.stefanescu@microchip.com>
Cc: stable <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/20190813074025.16218-1-razvan.stefanescu@microchip.com
commit 9c801e313195addaf11c16e155f50789d6ebfd19 upstream.
The sequence of arguments which was passed to handle_lsr_errors() didn't
match the parameters defined in that function, &lsr was passed to flag
and &flag was passed to lsr, this patch fixed that.
Fixes: b7396a38fb28 ("tty/serial: Add Spreadtrum sc9836-uart driver support")
Signed-off-by: Chunyan Zhang <chunyan.zhang@unisoc.com>
Signed-off-by: Chunyan Zhang <zhang.lyra@gmail.com>
Link: https://lore.kernel.org/r/20190905074151.5268-1-zhang.lyra@gmail.com
commit 4b708b7b1a2c09fbdfff6b942ebe3a160213aacd upstream.
The VPD implementation from Chromium Vital Product Data project used to
parse data from untrusted input without checking if the meta data is
invalid or corrupted. For example, the size from decoded content may
be negative value, or larger than whole input buffer. Such invalid data
may cause buffer overflow.
To fix that, the size parameters passed to vpd_decode functions should
be changed to unsigned integer (u32) type, and the parsing of entry
header should be refactored so every size field is correctly verified
before starting to decode.
Fixes: ad2ac9d5c5e0 ("firmware: Google VPD: import lib_vpd source files")
Signed-off-by: Hung-Te Lin <hungte@chromium.org>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Reviewed-by: Stephen Boyd <swboyd@chromium.org>
Link: https://lore.kernel.org/r/20190830022402.214442-1-hungte@chromium.org
commit 11fec009d97e5bd2329ef7d52d71e9f6763f1048 upstream.
In Python, like in C, when a comma is omitted in a list of strings, the
two strings around the missing comma are concatenated.
Cc: stable@vger.kernel.org # v5.2 only
Signed-off-by: Jonathan Neuschäfer <j.neuschaefer@gmx.net>
Reviewed-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
commit b60fe990c6b07ef6d4df67bc0530c7c90a62623a upstream.
The first/last indexes are typically shared with a user app.
The app can change the 'last' index that the kernel uses
to store the next result. This change sanity checks the index
before using it for writing to a potentially arbitrary address.
This fixes CVE-2019-14821.
Fixes: 5f94c1741bdc ("KVM: Add coalesced MMIO support (common part)")
Signed-off-by: Matt Delco <delco@chromium.org>
Signed-off-by: Jim Mattson <jmattson@google.com>
Reported-by: syzbot+983c866c3dd6efa3662a@syzkaller.appspotmail.com
[Use READ_ONCE. - Paolo]
[ Upstream commit 19e13cb27b998ff49f07e399b5871bfe5ba7e3f0 ]
We need to hold rnl lock in suspend and resume callbacks because phylink
requires it. Otherwise we will get a WARN() in suspend and resume.
Also, move phylink start and stop callbacks to inside device's internal
lock so that we prevent concurrent HW accesses.
Fixes: 74371272f97f ("net: stmmac: Convert to phylink and remove phylib logic")
Reported-by: Christophe ROULLIER <christophe.roullier@st.com>
Tested-by: Christophe ROULLIER <christophe.roullier@st.com>
Signed-off-by: Jose Abreu <joabreu@synopsys.com>
[ Upstream commit 23426a25e55a417dc104df08781b6eff95e65f3f ]
The DSA core, DSA taggers and DSA drivers all make use of
module_init(). Hence they get initialised at device_initcall() time.
The ordering is non-deterministic. It can be a DSA driver is bound to
a device before the needed tag driver has been initialised, resulting
in the message:
No tagger for this switch
Rather than have this be fatal, return -EPROBE_DEFER so that it is
tried again later once all the needed drivers have been loaded.
Fixes: d3b8c04988ca ("dsa: Add boilerplate helper to register DSA tag driver modules")
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
[ Upstream commit 00b368502d18f790ab715e055869fd4bb7484a9b ]
When skb_shinfo(skb) is not able to cache extra fragment (that is,
skb_shinfo(skb)->nr_frags >= MAX_SKB_FRAGS), xennet_fill_frags() assumes
the sk_buff_head list is already empty. As a result, cons is increased only
by 1 and returns to error handling path in xennet_poll().
However, if the sk_buff_head list is not empty, queue->rx.rsp_cons may be
set incorrectly. That is, queue->rx.rsp_cons would point to the rx ring
buffer entries whose queue->rx_skbs[i] and queue->grant_rx_ref[i] are
already cleared to NULL. This leads to NULL pointer access in the next
iteration to process rx ring buffer entries.
Below is how xennet_poll() does error handling. All remaining entries in
tmpq are accounted to queue->rx.rsp_cons without assuming how many
outstanding skbs are remained in the list.
985 static int xennet_poll(struct napi_struct *napi, int budget)
1032 if (unlikely(xennet_set_skb_gso(skb, gso))) {
1033 __skb_queue_head(&tmpq, skb);
1034 queue->rx.rsp_cons += skb_queue_len(&tmpq);
1035 goto err;
1036 }
It is better to always have the error handling in the same way.
Fixes: ad4f15dc2c70 ("xen/netfront: don't bug in case of too many frags")
Signed-off-by: Dongli Zhang <dongli.zhang@oracle.com>
[ Upstream commit acdcecc61285faed359f1a3568c32089cc3a8329 ]
UDP reuseport groups can hold a mix unconnected and connected sockets.
Ensure that connections only receive all traffic to their 4-tuple.
Fast reuseport returns on the first reuseport match on the assumption
that all matches are equal. Only if connections are present, return to
the previous behavior of scoring all sockets.
Record if connections are present and if so (1) treat such connected
sockets as an independent match from the group, (2) only return
2-tuple matches from reuseport and (3) do not return on the first
2-tuple reuseport match to allow for a higher scoring match later.
New field has_conns is set without locks. No other fields in the
bitmap are modified at runtime and the field is only ever set
unconditionally, so an RMW cannot miss a change.
Fixes: e32ea7e74727 ("soreuseport: fast reuseport UDP socket selection")
Link: http://lkml.kernel.org/r/CA+FuTSfRP09aJNYRt04SS6qj22ViiOEWaWmLAwX0psk8-PGNxw@mail.gmail.com
Signed-off-by: Willem de Bruijn <willemb@google.com>
Acked-by: Paolo Abeni <pabeni@redhat.com>
Acked-by: Craig Gallek <kraig@google.com>
[ Upstream commit 6efb971ba8edfbd80b666f29de12882852f095ae ]
When tcf_block_get() fails in sfb_init(), q->qdisc is still a NULL
pointer which leads to a crash in sfb_destroy(). Similar for
sch_dsmark.
Instead of fixing each separately, Linus suggested to just accept
NULL pointer in qdisc_put(), which would make callers easier.
(For sch_dsmark, the bug probably exists long before commit
6529eaba33f0.)
Fixes: 6529eaba33f0 ("net: sched: introduce tcf block infractructure")
Reported-by: syzbot+d5870a903591faaca4ae@syzkaller.appspotmail.com
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Cc: Jiri Pirko <jiri@resnulli.us>
Acked-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit d518d2ed8640c1cbbbb6f63939e3e65471817367 ]
The test implemented by some_qdisc_is_busy() is somewhat loosy for
NOLOCK qdisc, as we may hit the following scenario:
CPU1 CPU2
// in net_tx_action()
clear_bit(__QDISC_STATE_SCHED...);
// in some_qdisc_is_busy()
val = (qdisc_is_running(q) ||
test_bit(__QDISC_STATE_SCHED,
&q->state));
// here val is 0 but...
qdisc_run(q)
// ... CPU1 is going to run the qdisc next
As a conseguence qdisc_run() in net_tx_action() can race with qdisc_reset()
in dev_qdisc_reset(). Such race is not possible for !NOLOCK qdisc as
both the above bit operations are under the root qdisc lock().
After commit 021a17ed796b ("pfifo_fast: drop unneeded additional lock on dequeue")
the race can cause use after free and/or null ptr dereference, but the root
cause is likely older.
This patch addresses the issue explicitly checking for deactivation under
the seqlock for NOLOCK qdisc, so that the qdisc_run() in the critical
scenario becomes a no-op.
Note that the enqueue() op can still execute concurrently with dev_qdisc_reset(),
but that is safe due to the skb_array() locking, and we can't avoid that
for NOLOCK qdiscs.
Fixes: 021a17ed796b ("pfifo_fast: drop unneeded additional lock on dequeue")
Reported-by: Li Shuang <shuali@redhat.com>
Reported-and-tested-by: Davide Caratti <dcaratti@redhat.com>
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
[ Upstream commit 28e486037747c2180470b77c290d4090ad42f259 ]
In ip6erspan_tunnel_xmit(), if the skb will not be sent out, it has to
be freed on the tx_err path. Otherwise when deleting a netns, it would
cause dst/dev to leak, and dmesg shows:
unregister_netdevice: waiting for lo to become free. Usage count = 1
Fixes: ef7baf5e083c ("ip6_gre: add ip6 erspan collect_md mode")
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Acked-by: William Tu <u9012063@gmail.com>
commit e6839c31a608e79f2057fab987dd814f5d3477e6 upstream.
The hardware manual should be revised, but the initial value of
VBCTRL.OCCLREN is set to 1 actually. If the bit is set, the hardware
clears VBCTRL.VBOUT and ADPCTRL.DRVVBUS registers automatically
when the hardware detects over-current signal from a USB power switch.
However, since the hardware doesn't have any registers which
indicates over-current, the driver cannot handle it at all. So, if
"is_otg_channel" hardware detects over-current, since ADPCTRL.DRVVBUS
register is cleared automatically, the channel cannot be used after
that.
To resolve this behavior, this patch sets the VBCTRL.OCCLREN to 0
to keep ADPCTRL.DRVVBUS even if the "is_otg_channel" hardware
detects over-current. (We assume a USB power switch itself protects
over-current and turns the VBUS off.)
This patch is inspired by a BSP patch from Kazuya Mizuguchi.
Fixes: 1114e2d31731 ("phy: rcar-gen3-usb2: change the mode to OTG on the combined channel")
Cc: <stable@vger.kernel.org> # v4.5+
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
commit 699bf94114151aae4dceb2d9dbf1a6312839dcae upstream.
The usb_bulk_urb will kfree'd on disconnect, so ensure the pointer is set
to NULL after each free.
stop stream
urb killing
urb buffer free
tm6000: got start feed request tm6000_start_feed
tm6000: got start stream request tm6000_start_stream
tm6000: pipe reset
tm6000: IR URB failure: status: -71, length 0
xhci_hcd 0000:00:14.0: ERROR unknown event type 37
tm6000: error tm6000_urb_received
usb 1-2: USB disconnect, device number 5
tm6000: disconnecting tm6000 #0
BUG: KASAN: use-after-free in dvb_fini+0x75/0x140 [tm6000_dvb]
Read of size 8 at addr ffff888241044060 by task kworker/2:0/22
CPU: 2 PID: 22 Comm: kworker/2:0 Tainted: G W 5.3.0-rc4+ #1
Hardware name: LENOVO 20KHCTO1WW/20KHCTO1WW, BIOS N23ET65W (1.40 ) 07/02/2019
Call Trace:
dump_stack+0x9a/0xf0
print_address_description.cold+0xae/0x34f
__kasan_report.cold+0x75/0x93
? tm6000_fillbuf+0x390/0x3c0 [tm6000_alsa]
? dvb_fini+0x75/0x140 [tm6000_dvb]
tm6000_close_extension+0x51/0x80 [tm6000]
tm6000_usb_disconnect.cold+0xd4/0x105 [tm6000]
usb_unbind_interface+0xe4/0x390
device_release_driver_internal+0x121/0x250
bus_remove_device+0x197/0x260
device_del+0x268/0x550
? __device_links_no_driver+0xd0/0xd0
? usb_remove_ep_devs+0x30/0x3b
usb_disable_device+0x122/0x400
usb_disconnect+0x153/0x430
hub_event+0x800/0x1e40
? trace_hardirqs_on_thunk+0x1a/0x20
? hub_port_debounce+0x1f0/0x1f0
? retint_kernel+0x10/0x10
? lock_is_held_type+0xf1/0x130
? process_one_work+0x4ae/0xa00
process_one_work+0x4ba/0xa00
? pwq_dec_nr_in_flight+0x160/0x160
? do_raw_spin_lock+0x10a/0x1d0
worker_thread+0x7a/0x5c0
? process_one_work+0xa00/0xa00
kthread+0x1d5/0x200
? kthread_create_worker_on_cpu+0xd0/0xd0
Allocated by task 2682:
save_stack+0x1b/0x80
__kasan_kmalloc.constprop.0+0xc2/0xd0
usb_alloc_urb+0x28/0x60
tm6000_start_feed+0x10a/0x300 [tm6000_dvb]
dmx_ts_feed_start_filtering+0x86/0x120 [dvb_core]
dvb_dmxdev_start_feed+0x121/0x180 [dvb_core]
dvb_dmxdev_filter_start+0xcb/0x540 [dvb_core]
dvb_demux_do_ioctl+0x7ed/0x890 [dvb_core]
dvb_usercopy+0x97/0x1f0 [dvb_core]
dvb_demux_ioctl+0x11/0x20 [dvb_core]
do_vfs_ioctl+0x5d8/0x9d0
ksys_ioctl+0x5e/0x90
__x64_sys_ioctl+0x3d/0x50
do_syscall_64+0x74/0xe0
Freed by task 22:
__kasan_slab_free+0x12c/0x170
kfree+0xfd/0x3a0
xhci_giveback_urb_in_irq+0xfe/0x230
xhci_td_cleanup+0x276/0x340
xhci_irq+0x1129/0x3720
__handle_irq_event_percpu+0x6e/0x420
handle_irq_event_percpu+0x6f/0x100
handle_irq_event+0x55/0x84
handle_edge_irq+0x108/0x3b0
handle_irq+0x2e/0x40
do_IRQ+0x83/0x1a0
commit 3dd550a2d36596a1b0ee7955da3b611c031d3873 upstream.
The syzbot fuzzer provoked a slab-out-of-bounds error in the USB core:
BUG: KASAN: slab-out-of-bounds in memcmp+0xa6/0xb0 lib/string.c:904
Read of size 1 at addr ffff8881d175bed6 by task kworker/0:3/2746
CPU: 0 PID: 2746 Comm: kworker/0:3 Not tainted 5.3.0-rc5+ #28
Google 01/01/2011
Call Trace:
memcmp include/linux/string.h:400 [inline]
descriptors_changed drivers/usb/core/hub.c:5579 [inline]
usb_reset_and_verify_device+0x564/0x1300 drivers/usb/core/hub.c:5729
usb_reset_device+0x4c1/0x920 drivers/usb/core/hub.c:5898
rt2x00usb_probe+0x53/0x7af
drivers/net/wireless/ralink/rt2x00/rt2x00usb.c:806
The error occurs when the descriptors_changed() routine (called during
a device reset) attempts to compare the old and new BOS and capability
descriptors. The length it uses for the comparison is the
wTotalLength value stored in BOS descriptor, but this value is not
necessarily the same as the length actually allocated for the
descriptors. If it is larger the routine will call memcmp() with a
length that is too big, thus reading beyond the end of the allocated
region and leading to this fault.
The kernel reads the BOS descriptor twice: first to get the total
length of all the capability descriptors, and second to read it along
with all those other descriptors. A malicious (or very faulty) device
may send different values for the BOS descriptor fields each time.
The memory area will be allocated using the wTotalLength value read
the first time, but stored within it will be the value read the second
time.
To prevent this possibility from causing any errors, this patch
modifies the BOS descriptor after it has been read the second time:
It sets the wTotalLength field to the actual length of the descriptors
that were read in and validated. Then the memcpy() call, or any other
code using these descriptors, will be able to rely on wTotalLength
being valid.
Reported-and-tested-by: syzbot+35f4d916c623118d576e@syzkaller.appspotmail.com
Link: https://lore.kernel.org/r/Pine.LNX.4.44L0.1909041154260.1722-100000@iolanthe.rowland.org
This reverts commit b03755ad6f33b7b8cd7312a3596a2dbf496de6e7.
This is sad, and done for all the wrong reasons. Because that commit is
good, and does exactly what it says: avoids a lot of small disk requests
for the inode table read-ahead.
However, it turns out that it causes an entirely unrelated problem: the
getrandom() system call was introduced back in 2014 by commit
c6e9d6f38894 ("random: introduce getrandom(2) system call"), and people
use it as a convenient source of good random numbers.
But part of the current semantics for getrandom() is that it waits for
the entropy pool to fill at least partially (unlike /dev/urandom). And
at least ArchLinux apparently has a systemd that uses getrandom() at
boot time, and the improvements in IO patterns means that existing
installations suddenly start hanging, waiting for entropy that will
never happen.
It seems to be an unlucky combination of not _quite_ enough entropy,
together with a particular systemd version and configuration. Lennart
says that the systemd-random-seed process (which is what does this early
access) is supposed to not block any other boot activity, but sadly that
doesn't actually seem to be the case (possibly due bogus dependencies on
cryptsetup for encrypted swapspace).
The correct fix is to fix getrandom() to not block when it's not
appropriate, but that fix is going to take a lot more discussion. Do we
just make it act like /dev/urandom by default, and add a new flag for
"wait for entropy"? Do we add a boot-time option? Or do we just limit
the amount of time it will wait for entropy?
So in the meantime, we do the revert to give us time to discuss the
eventual fix for the fundamental problem, at which point we can re-apply
the ext4 inode table access optimization.
Reported-by: Ahmed S. Darwish <darwish.07@gmail.com>
Cc: Ted Ts'o <tytso@mit.edu>
Cc: Willy Tarreau <w@1wt.eu>
Cc: Alexander E. Patrakov <patrakov@gmail.com>
Cc: Lennart Poettering <mzxreary@0pointer.de>
