path: root/CREDITS
2013-09-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "The usual trivial updates all over the tree -- mostly typo fixes and documentation updates" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (52 commits) doc: Documentation/cputopology.txt fix typo treewide: Convert retrun typos to return Fix comment typo for init_cma_reserved_pageblock Documentation/trace: Correcting and extending tracepoint documentation mm/hotplug: fix a typo in Documentation/memory-hotplug.txt power: Documentation: Update s2ram link doc: fix a typo in Documentation/00-INDEX Documentation/printk-formats.txt: No casts needed for u64/s64 doc: Fix typo "is is" in Documentations treewide: Fix printks with 0x%# zram: doc fixes Documentation/kmemcheck: update kmemcheck documentation doc: documentation/hwspinlock.txt fix typo PM / Hibernate: add section for resume options doc: filesystems : Fix typo in Documentations/filesystems scsi/megaraid fixed several typos in comments ppc: init_32: Fix error typo "CONFIG_START_KERNEL" treewide: Add __GFP_NOWARN to k.alloc calls with v.alloc fallbacks page_isolation: Fix a comment typo in test_pages_isolated() doc: fix a typo about irq affinity ...
2013-08-20MAINTAINERS: Remove Jeremy from the Xen subsystem.Konrad Rzeszutek Wilk
Jeremy has been a key person in making Linux work with Xen. He has been enjoying the last year working on something different so reflect that in the maintainers file. CC: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org>
2013-08-05credits: update contact information for Chris CheneyChris Cheney
Small clean-up for my CREDITS entry. Signed-off-by: Chris Cheney <chris.cheney@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-04-29MAINTAINERS: i8k driver is orphanJean Delvare
Massimo Dal Zotto stopped maintaining the i8k driver several years ago, so move his name from MAINTAINERS to CREDITS. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Massimo Dal Zotto <dz@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-18MAINTAINERS: Remove Mark M. HoffmanJean Delvare
Mark M. Hoffman stopped working on the Linux kernel several years ago, so he should no longer be listed as a driver maintainer. I'm not even sure if his e-mail address still works. I can take over 3 drivers he was responsible for, the 4th one will fall down to the subsystem maintainer. Also give Mark credit for all the good work he did. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Acked-by: Guenter Roeck <linux@roeck-us.net> Cc: Wolfram Sang <wolfram@the-dreams.de>
2013-03-08Randy has movedRandy Dunlap
Update email address and CREDITS info. xenotime.net is defunct. Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Cc: Harry Wei <harryxiyou@gmail.com> Cc: Keiichi KII <k-keiichi@bx.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-13CREDITS: update email and address of Harald HoyerHarald Hoyer
Signed-off-by: Harald Hoyer <harald@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-20KVM: Retire as maintainerAvi Kivity
After six and a half years of writing and maintaining KVM, it is time to move to new things. Update my MAINTAINERS entry to reflect that. Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-28Email/web address changeJonathan Woithe
This patch updates Jonathan Woithe's contact details across the kernel tree. Signed-off-by: Jonathan Woithe <jwoithe@just42.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-01-14Merge branch 'for-3.3' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-3.3' of git://linux-nfs.org/~bfields/linux: (31 commits) nfsd4: nfsd4_create_clid_dir return value is unused NFSD: Change name of extended attribute containing junction svcrpc: don't revert to SVC_POOL_DEFAULT on nfsd shutdown svcrpc: fix double-free on shutdown of nfsd after changing pool mode nfsd4: be forgiving in the absence of the recovery directory nfsd4: fix spurious 4.1 post-reboot failures NFSD: forget_delegations should use list_for_each_entry_safe NFSD: Only reinitilize the recall_lru list under the recall lock nfsd4: initialize special stateid's at compile time NFSd: use network-namespace-aware cache registering routines SUNRPC: create svc_xprt in proper network namespace svcrpc: update outdated BKL comment nfsd41: allow non-reclaim open-by-fh's in 4.1 svcrpc: avoid memory-corruption on pool shutdown svcrpc: destroy server sockets all at once svcrpc: make svc_delete_xprt static nfsd: Fix oops when parsing a 0 length export nfsd4: Use kmemdup rather than duplicating its implementation nfsd4: add a separate (lockowner, inode) lookup nfsd4: fix CONFIG_NFSD_FAULT_INJECTION compile error ...
2011-12-09CREDITS: update Kees's expired fingerprint and fix detailsKees Cook
Small clean-up for my CREDITS entry; the GPG fingerprint was not up to date, so I fixed other details at the same time too. Signed-off-by: Kees Cook <kees@outflux.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-07Update NFSD MAINTAINERNeilBrown
Neil hasn't really been at all active as a maintainer for some years now. So move his maintainership to CREDITS Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-29cpupowerutils: use COPYING, CREDITS from top-level directoryDominik Brodowski
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-06-30CREDITS: Fix typoHenrik Ahlgren
David Brownell's CREDITS entry should have N: (name) instead of M: (email). Signed-off-by: Henrik Ahlgren <pablo@seestieto.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-07MAINTAINERS: Saying goodbye to David BrownellGrant Likely
We had to say goodbye when David passed away recently. David had a huge impact on our community, both personally in the lives of the people he worked with, and technically in the design and maintenance of several subsystems. He is greatly missed. He also leaves behind a number of much loved subsystems now orphaned. This patch updates the MAINTAINERS file for the areas that David was responsible for and adds an entry for him to the CREDITS file. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Harry Wei <harryxiyou@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25Merge branch 'kconfig-for-40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig-for-40' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: xconfig: merge code path to conf_write() kconfig: do not record timestamp in .config gconfig: Hide unused left treeview when start up the interface gconfig: enable rules hint for main treeviews MAINTAINERS: Update KCONFIG entry kconfig-language: add to hints kconfig: Document the new "visible if" syntax kconfig: quiet commands when V=0 kconfig: change update-po-config to reflect new layout of arch/um kconfig: make update-po-config work in KBUILD_OUTPUT kconfig: rearrange clean-files kconfig: change gconf to modify hostprogs-y like nconf and mconf kconfig: change qconf to modify hostprogs-y like nconf and mconf kconfig: only build kxgettext when needed nconfig: Silence unused return values from wattrset kconfig: Do not record timestamp in auto.conf and autoconf.h kconfig: get rid of unused flags kconfig: allow multiple inclusion of the same file kconfig: Avoid buffer underrun in choice input
2011-05-25MAINTAINERS: orphan DMFE, move Tobias Ringstrom to CREDITSJoe Perches
Tobias's email bounces and he hasn't submitted or acked a patch in git history. Signed-off-by: Joe Perches <joe@perches.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-04MAINTAINERS: Update KCONFIG entryMichal Marek
Roman Zippel hasn't been active for several years. Add myself as kconfig maintainer, but change the mode to "Odd Fixes" to not set expectations too high. Also, remove the patchwork link, since it is not used for kbuild/kconfig. Signed-off-by: Michal Marek <mmarek@suse.cz> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-03-31CREDITS: update Johannes Berg's gpg keyJohannes Berg
I've had a new key for almost two years and revoked the old one, but forgot to update it here. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-13CREDITS: update Stelian's entryStelian Pop
Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-19perf tools: Change my maintainer addressArnaldo Carvalho de Melo
Also remove old snail mail address from CREDITS, moved years ago. LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-10-01MAINTAINERS: update matroxfb & ncpfs statusPetr Vandrovec
I moved couple years ago, so let's update my email and snail mail. And I do not have any access to Matrox hardware anymore, and I'm quite unresponsive to matroxfb bug reports (sorry Alan), so saying that I'm maintainer is a bit far fetched. For ncpfs I do not use ncpfs in my daily life either, but at least I can test that one, so I can stay listed here for odd fixes. Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-15Nicolas Pitre has a new email addressNicolas Pitre
Due to problems at cam.org, my nico@cam.org email address is no longer valid. FRom now on, nico@fluxnic.net should be used instead. Signed-off-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29MAINTAINERS: Remove CS461x sound card sectionJoe Perches
Thomas Woller's email address bounces Nils Faerber isn't active Added Thomas Woller to CREDITS, Nils already has an entry Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29MAINTAINERS: Move ARPD to CREDITSJoe Perches
Jonathan Layes is hard to find. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-17Update Andreas Koensgen's email addressRalf Baechle
The kernel has used a stale email address of Andreas for a few years. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-18can: Update MAINTAINERS and CREDITS fileWolfgang Grandegger
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (28 commits) trivial: Update my email address trivial: NULL noise: drivers/mtd/tests/mtd_*test.c trivial: NULL noise: drivers/media/dvb/frontends/drx397xD_fw.h trivial: Fix misspelling of "Celsius". trivial: remove unused variable 'path' in alloc_file() trivial: fix a pdlfush -> pdflush typo in comment trivial: jbd header comment typo fix for JBD_PARANOID_IOFAIL trivial: wusb: Storage class should be before const qualifier trivial: drivers/char/bsr.c: Storage class should be before const qualifier trivial: h8300: Storage class should be before const qualifier trivial: fix where cgroup documentation is not correctly referred to trivial: Give the right path in Documentation example trivial: MTD: remove EOL from MODULE_DESCRIPTION trivial: Fix typo in bio_split()'s documentation trivial: PWM: fix of #endif comment trivial: fix typos/grammar errors in Kconfig texts trivial: Fix misspelling of firmware trivial: cgroups: documentation typo and spelling corrections trivial: Update contact info for Jochen Hein trivial: fix typo "resgister" -> "register" ...
2009-03-31MAINTAINERS: move old ide-{floppy,tape} entries to CREDITS (take 2)Bartlomiej Zolnierkiewicz
Ben Hutchings noticed that MAINTAINERS somehow still contain old ide-{floppy,tape} entries. Fix it by moving them to CREDITS (kudos to Gadi and Paul for all the early hard work on ide-{floppy,tape}). v2: Rename IDE/ATAPI CDROM DRIVER entry to IDE/ATAPI DRIVERS one. Cc: Gadi Oxman <gadio@netvision.net.il> Cc: Paul Bristow <paul@paulbristow.net> Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-30trivial: Update my email addressRiku Voipio
Update my email address. Signed-off-by: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-30trivial: Update contact info for Jochen HeinJochen Hein
I've moved again - so update my address again. Signed-off-by: Jochen Hein <jochen@jochen.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-22Update my email addressGertjan van Wingerde
Update all previous incarnations of my email address to the correct one. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-18Pavel has movedPavel Machek
My @suse.cz address will stop working some day, so put working one into MAINTAINERS/CREDITS. It would be cool to get this to 2.6.29... it should not really break anything. Signed-off-by: Pavel Machek <pavel@ucw.cz> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15CREDITS address update for dwmw2.David Woodhouse
Update employer's care-of address in CREDITS file, and remove references to some _very_ old stuff I'd forgotten I'd ever done. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (123 commits) wimax/i2400m: add CREDITS and MAINTAINERS entries wimax: export linux/wimax.h and linux/wimax/i2400m.h with headers_install i2400m: Makefile and Kconfig i2400m/SDIO: TX and RX path backends i2400m/SDIO: firmware upload backend i2400m/SDIO: probe/disconnect, dev init/shutdown and reset backends i2400m/SDIO: header for the SDIO subdriver i2400m/USB: TX and RX path backends i2400m/USB: firmware upload backend i2400m/USB: probe/disconnect, dev init/shutdown and reset backends i2400m/USB: header for the USB bus driver i2400m: debugfs controls i2400m: various functions for device management i2400m: RX and TX data/control paths i2400m: firmware loading and bootrom initialization i2400m: linkage to the networking stack i2400m: Generic probe/disconnect, reset and message passing i2400m: host/device procotol and core driver definitions i2400m: documentation and instructions for usage wimax: Makefile, Kconfig and docbook linkage for the stack ...
2009-01-07wimax/i2400m: add CREDITS and MAINTAINERS entriesInaky Perez-Gonzalez
This patch adds entries for the original developers of the i2400m drivers and up-to-date maintainer entries. Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06trivial: update Jesper Juhl CREDITS entry with new emailJesper Juhl
Old email no longer exists, this updates CREDITS with my new one. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-03Updated contact info for CREDITS fileHugh Blemings
This updates some personal info in the CREDITS file. I'm no longer actively involved in Keyspan driver work so shouldn't really be listed as a Maintainer here. I do however field the occasional question on them and as I'm dropping the misc.nu domain, want to ensure people can find me should they need to. Signed-off-by: Hugh Blemings <hugh@blemings.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23Merge branch 'for-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb * 'for-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb: (47 commits) uwb: wrong sizeof argument in mac address compare uwb: don't use printk_ratelimit() so often uwb: use kcalloc where appropriate uwb: use time_after() when purging stale beacons uwb: add credits for the original developers of the UWB/WUSB/WLP subsystems uwb: add entries in the MAINTAINERS file uwb: depend on EXPERIMENTAL wusb: wusb-cbaf (CBA driver) sysfs ABI simplification uwb: document UWB and WUSB sysfs files uwb: add symlinks in sysfs between radio controllers and PALs uwb: dont tranmit identification IEs uwb: i1480/GUWA100U: fix firmware download issues uwb: i1480: remove MAC/PHY information checking function uwb: add Intel i1480 HWA to the UWB RC quirk table uwb: disable command/event filtering for D-Link DUB-1210 uwb: initialize the debug sub-system uwb: Fix handling IEs with empty IE data in uwb_est_get_size() wusb: fix bmRequestType for Abort RPipe request wusb: fix error path for wusb_set_dev_addr() wusb: add HWA host controller driver ...
2008-10-20Update email addresses.Dave Jones
Update assorted email addresses and related info to point to a single current, valid address. additionally - trivial CREDITS entry updates. (Not that this file means much any more) - remove arjans dead redhat.com address from powernow driver Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-17uwb: add credits for the original developers of the UWB/WUSB/WLP subsystemsInaky Perez-Gonzalez
Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-07-24remove the OSS trident driverAdrian Bunk
SOUND_TRIDENT was the last PCI OSS driver, and since there's already an ALSA driver for the same hardware we can remove it. [muli@il.ibm.com: update CREDITS] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21Don't list my old OSDL mailing address in CREDITS fileLinus Torvalds
.. it may or may be forwarded, but it's not like I want people to send stuff without knowing or checking first anyway, so delete the address entirely. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-04Miguel Ojeda has movedMiguel Ojeda
Signed-off-by: Miguel Ojeda <miguel.ojeda.sandonis@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24pcsp - Don't build pcspkr when snd-pcsp is enabledStas Sergeev
- Update CREDITS with the pc-speaker driver authors. - Prevent pcspkr from being built together with snd-pcsp. Both pcspkr and snd-pcsp use the same platform driver name "pcspkr". Signed-off-by: Stas Sergeev <stsp@aknet.ru>
2008-02-03MAINTAINERS: remove Adam Fritzler, remove his email address in other sourcesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03remove obsolete contact information from CREDITSAdrian Bunk
2008-01-28[CAN]: Add maintainer entriesOliver Hartkopp
This patch adds entries in the CREDITS and MAINTAINERS file for CAN. Signed-off-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de> Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
