path: root/CREDITS
2007-02-11[PATCH] drivers: add LCD supportMiguel Ojeda Sandonis
Add support for auxiliary displays, the ks0108 LCD controller, the cfag12864b LCD and adds a framebuffer device: cfag12864bfb. - Add a "auxdisplay/" folder in "drivers/" for auxiliary display drivers. - Add support for the ks0108 LCD Controller as a device driver. (uses parport interface) - Add support for the cfag12864b LCD as a device driver. (uses ks0108 LCD Controller driver) - Add a framebuffer device called cfag12864bfb. (uses cfag12864b LCD driver) - Add the usual Documentation, includes, Makefiles, Kconfigs, MAINTAINERS, CREDITS... - Miguel Ojeda will maintain all the stuff above. [rdunlap@xenotime.net: workqueue fixups] [akpm@osdl.org: kconfig fix] Signed-off-by: Miguel Ojeda Sandonis <maxextreme@gmail.com> Cc: Greg KH <greg@kroah.com> Acked-by: Paulo Marques <pmarques@grupopie.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-23Change Linus' email address tooLinus Torvalds
This changes a few mentions of my email address to point to the new one, leaving things like old copyright messages alone. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-30[PATCH] Update CREDITS and MAINTAINERS entries for Lennert BuytenhekLennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Generic HID layer - buildJiri Kosina
This modifies Makefiles and Kconfigs to properly reflect the creation of generic HID layer. It also removes the dependency of BROKEN, which was introduced by the first patch in series (see the comment). Also updates credits. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-02[TCP]: MD5 Signature Option (RFC2385) support.YOSHIFUJI Hideaki
Based on implementation by Rick Payne. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-17[PATCH] Update my CREDITS entryDavid Weinehall
I moved from Sweden to Finland 2.5 years ago, thought it might be time to update my CREDITS entry (simply removing the address completely seemed the sanest option). Signed-off-by: David Weinehall <tao@kernel.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-08[PATCH] Tigran has movedTigran Aivazian
2006-10-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6: (292 commits) [GFS2] Fix endian bug for de_type [GFS2] Initialize SELinux extended attributes at inode creation time. [GFS2] Move logging code into log.c (mostly) [GFS2] Mark nlink cleared so VFS sees it happen [GFS2] Two redundant casts removed [GFS2] Remove uneeded endian conversion [GFS2] Remove duplicate sb reading code [GFS2] Mark metadata reads for blktrace [GFS2] Remove iflags.h, use FS_ [GFS2] Fix code style/indent in ops_file.c [GFS2] streamline-generic_file_-interfaces-and-filemap gfs fix [GFS2] Remove readv/writev methods and use aio_read/aio_write instead (gfs bits) [GFS2] inode-diet: Eliminate i_blksize from the inode structure [GFS2] inode_diet: Replace inode.u.generic_ip with inode.i_private (gfs) [GFS2] Fix typo in last patch [GFS2] Fix direct i/o logic in filemap.c [GFS2] Fix bug in Makefiles for lock modules [GFS2] Remove (extra) fs_subsys declaration [GFS2/DLM] Fix trailing whitespace [GFS2] Tidy up meta_io code ...
2006-10-04[PATCH] RCU: CREDITS and MAINTAINERSJosh Triplett
Add MAINTAINERS entry for Read-Copy Update (RCU), listing Dipankar Sarma as maintainer, and giving the URL for Paul McKenney's RCU site. Add MAINTAINERS entry for rcutorture, listing myself as maintainer. Add CREDITS entries for developers of RCU, RCU variants, and rcutorture. Use Paul McKenney's preferred email address in include/linux/rcupdate.h . Signed-off-by: Josh Triplett <josh@freedesktop.org> Cc: Paul McKenney <paulmck@us.ibm.com> Cc: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Add missing maintainer countries in CREDITSSamuel Tardieu
Add missing maintainer countries. Signed-off-by: Samuel Tardieu <sam@rfc1149.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Michal Wronski: update contact infoMichal Wronski
My email has changed. Signed-Off-By: Michal Wronski <michal.wronski@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03[PATCH] Add Pekka to CREDITSPekka Enberg
Whomever said... "When you meet someone now who is writing a compiler or hacking a Unix kernel, at least you know they're not just doing it to pick up chicks." ...has obviously never met a _Linux_ kernel hacker. Anyway, sometimes people confuse my email addresses, which is why I really should add the proper one to CREDITS ;-). Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02Merge branch 'master' into gfs2Steven Whitehouse
2006-09-29[PATCH] /sys/modules: allow full length section namesIan S. Nelson
I've been using systemtap for some debugging and I noticed that it can't probe a lot of modules. Turns out it's kind of silly, the sections section of /sys/module is limited to 32byte filenames and many of the actual sections are a a bit longer than that. [akpm@osdl.org: rewrite to use dymanic allocation] Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Small update to CREDITSJesper Juhl
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25[GFS2] Fix up merge of Linus' kernel into GFS2Steven Whitehouse
This fixes up a couple of conflicts when merging up with Linus' latest kernel. This will hopefully allow GFS2 to be more easily merged into forthcoming -mm and FC kernels due to the "one line per header" format now used for the kernel headers. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Conflicts: include/linux/Kbuild include/linux/kernel.h
2006-09-22[NetLabel]: documentationPaul Moore
Documentation for the NetLabel system, this includes a basic overview of how NetLabel works, how LSM developers can integrate it into their favorite LSM, as well as documentation on the CIPSO related sysctl variables. Also, due to the difficulty of finding expired IETF drafts, I am including the IETF CIPSO draft that is the basis of the NetLabel CIPSO implementation. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-29Merge branch 'master' into gfs2Steven Whitehouse
2006-08-26[DCCP]: Update contact details and copyrightIan McDonald
Just updating copyright and contacts Signed off by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-17Merge branch 'master'Steven Whitehouse
2006-07-10[PATCH] Updates CREDITS fileLuiz Fernando N. Capitulino
Updates my personal entry in the CREDITS file. Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03Merge rsync://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6Steven Whitehouse
Conflicts: include/linux/kernel.h
2006-06-29Merge master.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6: (23 commits) [PARISC] Move os_id_to_string() inside #ifndef __ASSEMBLY__ [PARISC] Fix do_gettimeofday() hang [PARISC] Fix PCREL22F relocation problem for most modules [PARISC] Refactor show_regs in traps.c [PARISC] Add os_id_to_string helper [PARISC] OS_ID_LINUX == 0x0006 [PARISC] Ensure Space ID hashing is turned off [PARISC] Match show_cache_info with reality [PARISC] Remove unused macro fixup_branch in syscall.S [PARISC] Add is_compat_task() helper [PARISC] Update Thibaut Varene's CREDITS entry [PARISC] Reduce data footprint in pdc_stable.c [PARISC] pdc_stable version 0.30 [PARISC] Work around machines which do not support chassis warnings [PARISC] PDC_CHASSIS is implemented on all machines [PARISC] Remove unconditional #define PIC in syscall macros [PARISC] Use MFIA in current_text_addr on pa2.0 processors [PARISC] Remove dead function pc_in_user_space [PARISC] Test ioc_needs_fdc variable instead of open coding [PARISC] Fix gcc 4.1 warnings in sba_iommu.c ...
2006-06-27[PARISC] Update Thibaut Varene's CREDITS entryThibaut Varene
Signed-off-by: Thibaut VARENE <varenet@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-06-26move acknowledgment for Mark Adler to CREDITSAdrian Bunk
The place in the documentation of the Linux kernel to acknowledge contributions is the CREDITS file. Give Mark Adler an entry there instead of including a string in the kernel image. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-25[PATCH] Update contact information in CREDITSNiels Kristian Bech Jensen
Update my contact information in CREDITS. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-25Merge branch 'master'Steven Whitehouse
2006-05-15[PATCH] Marcelo has movedMarcelo Tosatti
Signed-off-by: Marcelo Tosatti <marcelo@kvack.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-12Merge branch 'master'Steven Whitehouse
2006-05-04CREDITS file update (Tristan Greaves)Linus Torvalds
By request from Tristan. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-28[GFS2] Update my Credits file entrySteven Whitehouse
2006-04-11[PATCH] Update contact info for Geert UytterhoevenGeert Uytterhoeven
Update contact info for Geert Uytterhoeven Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Philip Gladstone has movedPhilip Gladstone
I noticed that my email address is four jobs ago. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] RTC subsystem: classAlessandro Zummo
Add the basic RTC subsystem infrastructure to the kernel. rtc/class.c - registration facilities for RTC drivers rtc/interface.c - kernel/rtc interface functions rtc/hctosys.c - snippet of code that copies hw clock to sw clock at bootup, if configured to do so. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] Remova long-incorrect address for Jamie LokierJamie Lokier
Nice place isn't it? I've lived in 7 other houses since then. Signed-off-by: Jamie Lokier <jamie@shareable.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20[PATCH] USB: CREDITS: Add credits about the ZC0301 and ET61X[12]51 USB driversLuca Risolia
This patch adds credits about the ZC0301 and ET61X[12]51 USB drivers which have been included in the mainline kernel recently. Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-19[PATCH] Remove obsolete CREDITS addressAndrea Arcangeli
This address is going to be obsolete, so I should update it.
2006-03-11[PATCH] update email addressChris Wright
Update email address. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-05[PATCH] MAINTAINERS/CREDITS: Update SELinux contact infoStephen Smalley
Update my contact info. Please apply. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] CREDITS update: Eugene SuroveginEugene Surovegin
Add EMAC to my CREDITS entry. Signed-off-by: Eugene Surovegin <ebs@ebshome.net Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[ALSA] Add support for the CS5535 Audio deviceJaya Kumar
Add support for the CS5535 Audio device. I've fixed up some errors as per Takashi's advice from the thread: http://lkml.org/lkml/2005/9/15/119 From: Alan Cox <alan@lxorguk.ukuu.org.uk> cs5535 is a 32bit x86 only device using weird CPU features Signed-off-by: Jaya Kumar <jayakumar.alsa@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-18[PARISC] Update CREDITS entriesKyle McMartin
Update Randolph Chung's location, and add Thibaut Varene. Signed-off-by: Randolph Chung <tausq@parisc-linux.org> Signed-off-by: Thibaut Varene <varenet@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-13[PATCH] Update email address for KumarKumar Gala
Changed jobs and the Freescale address is no longer valid. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-06Update Michal Wronski contact infoMichal Wronski
2005-10-21[PARISC] Update MAINTAINERS and CREDITSKyle McMartin
Add Kyle McMartin and Thibaut Varene as maintainers for ALSA ad1889 driver. Add myself to CREDITS. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-09-17[DCCP]: Add MAINTAINERS and CREDITS entriesArnaldo Carvalho de Melo
Also remove the SPX entry in MAINTAINERS, forgot to do that when I removed it. Signed-off-by: Ian McDonald <iam4@cs.waikato.ac.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-18[PATCH] Update email addresses for ZwaneZwane Mwaikambo
Some folks have been emailing me and having trouble due to these stale addresses; Signed-off-by: Zwane Mwaikambo <zwane@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-08[PATCH] Update contact info for James MorrisJames Morris
2005-07-27[PATCH] Update CREDITS entry and listings in source files for Jesper JuhlJesper Juhl
a) update entry in CREDITS for Jesper Juhl b) remove email address from source files so it's only listed in credits. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-22[PATCH] Update my credits entryJames Morris
