path: root/CREDITS
2009-02-18Pavel has movedPavel Machek
My @suse.cz address will stop working some day, so put working one into MAINTAINERS/CREDITS. It would be cool to get this to 2.6.29... it should not really break anything. Signed-off-by: Pavel Machek <pavel@ucw.cz> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15CREDITS address update for dwmw2.David Woodhouse
Update employer's care-of address in CREDITS file, and remove references to some _very_ old stuff I'd forgotten I'd ever done. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (123 commits) wimax/i2400m: add CREDITS and MAINTAINERS entries wimax: export linux/wimax.h and linux/wimax/i2400m.h with headers_install i2400m: Makefile and Kconfig i2400m/SDIO: TX and RX path backends i2400m/SDIO: firmware upload backend i2400m/SDIO: probe/disconnect, dev init/shutdown and reset backends i2400m/SDIO: header for the SDIO subdriver i2400m/USB: TX and RX path backends i2400m/USB: firmware upload backend i2400m/USB: probe/disconnect, dev init/shutdown and reset backends i2400m/USB: header for the USB bus driver i2400m: debugfs controls i2400m: various functions for device management i2400m: RX and TX data/control paths i2400m: firmware loading and bootrom initialization i2400m: linkage to the networking stack i2400m: Generic probe/disconnect, reset and message passing i2400m: host/device procotol and core driver definitions i2400m: documentation and instructions for usage wimax: Makefile, Kconfig and docbook linkage for the stack ...
2009-01-07wimax/i2400m: add CREDITS and MAINTAINERS entriesInaky Perez-Gonzalez
This patch adds entries for the original developers of the i2400m drivers and up-to-date maintainer entries. Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06trivial: update Jesper Juhl CREDITS entry with new emailJesper Juhl
Old email no longer exists, this updates CREDITS with my new one. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-03Updated contact info for CREDITS fileHugh Blemings
This updates some personal info in the CREDITS file. I'm no longer actively involved in Keyspan driver work so shouldn't really be listed as a Maintainer here. I do however field the occasional question on them and as I'm dropping the misc.nu domain, want to ensure people can find me should they need to. Signed-off-by: Hugh Blemings <hugh@blemings.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23Merge branch 'for-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb * 'for-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb: (47 commits) uwb: wrong sizeof argument in mac address compare uwb: don't use printk_ratelimit() so often uwb: use kcalloc where appropriate uwb: use time_after() when purging stale beacons uwb: add credits for the original developers of the UWB/WUSB/WLP subsystems uwb: add entries in the MAINTAINERS file uwb: depend on EXPERIMENTAL wusb: wusb-cbaf (CBA driver) sysfs ABI simplification uwb: document UWB and WUSB sysfs files uwb: add symlinks in sysfs between radio controllers and PALs uwb: dont tranmit identification IEs uwb: i1480/GUWA100U: fix firmware download issues uwb: i1480: remove MAC/PHY information checking function uwb: add Intel i1480 HWA to the UWB RC quirk table uwb: disable command/event filtering for D-Link DUB-1210 uwb: initialize the debug sub-system uwb: Fix handling IEs with empty IE data in uwb_est_get_size() wusb: fix bmRequestType for Abort RPipe request wusb: fix error path for wusb_set_dev_addr() wusb: add HWA host controller driver ...
2008-10-20Update email addresses.Dave Jones
Update assorted email addresses and related info to point to a single current, valid address. additionally - trivial CREDITS entry updates. (Not that this file means much any more) - remove arjans dead redhat.com address from powernow driver Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-17uwb: add credits for the original developers of the UWB/WUSB/WLP subsystemsInaky Perez-Gonzalez
Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-07-24remove the OSS trident driverAdrian Bunk
SOUND_TRIDENT was the last PCI OSS driver, and since there's already an ALSA driver for the same hardware we can remove it. [muli@il.ibm.com: update CREDITS] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21Don't list my old OSDL mailing address in CREDITS fileLinus Torvalds
.. it may or may be forwarded, but it's not like I want people to send stuff without knowing or checking first anyway, so delete the address entirely. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-04Miguel Ojeda has movedMiguel Ojeda
Signed-off-by: Miguel Ojeda <miguel.ojeda.sandonis@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24pcsp - Don't build pcspkr when snd-pcsp is enabledStas Sergeev
- Update CREDITS with the pc-speaker driver authors. - Prevent pcspkr from being built together with snd-pcsp. Both pcspkr and snd-pcsp use the same platform driver name "pcspkr". Signed-off-by: Stas Sergeev <stsp@aknet.ru>
2008-02-03MAINTAINERS: remove Adam Fritzler, remove his email address in other sourcesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03remove obsolete contact information from CREDITSAdrian Bunk
2008-01-28[CAN]: Add maintainer entriesOliver Hartkopp
This patch adds entries in the CREDITS and MAINTAINERS file for CAN. Signed-off-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de> Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (40 commits) kbuild: introduce ccflags-y, asflags-y and ldflags-y kbuild: enable 'make CPPFLAGS=...' to add additional options to CPP kbuild: enable use of AFLAGS and CFLAGS on commandline kbuild: enable 'make AFLAGS=...' to add additional options to AS kbuild: fix AFLAGS use in h8300 and m68knommu kbuild: check for wrong use of CFLAGS kbuild: enable 'make CFLAGS=...' to add additional options to CC kbuild: fix up CFLAGS usage kbuild: make modpost detect unterminated device id lists kbuild: call export_report from the Makefile kbuild: move Kai Germaschewski to CREDITS kconfig/menuconfig: distinguish between selected-by-another options and comments kconfig: tristate choices with mixed tristate and boolean values include/linux/Kbuild: remove duplicate entries kbuild: kill backward compatibility checks kbuild: kill EXTRA_ARFLAGS kbuild: fix documentation in makefiles.txt kbuild: call make once for all targets when O=.. is used kbuild: pass -g to assembler under CONFIG_DEBUG_INFO kbuild: update _shipped files for kconfig syntax cleanup ... Fix up conflicts in arch/um/sys-{x86_64,i386}/Makefile manually.
2007-10-16Merge branch 'linus' of master.kernel.org:/pub/scm/linux/kernel/git/perex/alsaLinus Torvalds
* 'linus' of master.kernel.org:/pub/scm/linux/kernel/git/perex/alsa: (264 commits) [ALSA] version 1.0.15 [ALSA] Fix thinko in cs4231 mce down check [ALSA] sun-cs4231: improved waiting after MCE down [ALSA] sun-cs4231: use cs4231-regs.h [ALSA] This simplifies and fixes waiting loops of the mce_down() [ALSA] This patch adds support for a wavetable chip on [ALSA] This patch removes open_mutex from the ad1848-lib as [ALSA] fix bootup crash in snd_gus_interrupt() [ALSA] hda-codec - Fix SKU ID function for realtek codecs [ALSA] Support ASUS P701 eeepc [0x1043 0x82a1] support [ALSA] hda-codec - Add array terminator for dmic in STAC codec [ALSA] hdsp - Fix zero division [ALSA] usb-audio - Fix double comment [ALSA] hda-codec - Fix STAC922x volume knob control [ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.cz [ALSA] hda-codec - Fix for Fujitsu Lifebook C1410 [ALSA] mpu-401: remove MPU401_INFO_UART_ONLY flag [ALSA] mpu-401: do not require an ACK byte for the ENTER_UART command [ALSA] via82xx - Add DXS quirk for Shuttle AK31v2 [ALSA] hda-codec - Fix input_mux numbers for vaio stac92xx ...
2007-10-16CREDITS: correct Mikael Pettersson's URLMikael Pettersson
New URL due to local reorganization.
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-12kbuild: move Kai Germaschewski to CREDITSSam Ravnborg
Kai is not active in kernel development these days so give him credit for his major kbuild contribution and ISDN work. Acked-by: Kai Germaschewski <kai@germaschewski.name> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-10[RT2x00]: add driver for Ralink wireless hardwareIvo van Doorn
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-26Slab maintainer & Credits updateChristoph Lameter
Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20[ALSA] Update Claudio's CREDITS informationClaudio Matsuoka
Signed-off-by: Claudio Matsuoka <cmatsuoka@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-06-20Fix up CREDIT entry orderingLi Yang
Reorder my CREDIT entry to make it in alphabetic order by last name. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11further UTF-8 fixes and name correctionDavid Woodhouse
> -** Copyright 1994 by Bj<94>rn Brauel > +** Copyright 1994 by Bj”rn Brauel I think these were cp437, and it should read 'Björn'. (asm-m68k/atari*.h) Also note that Arnaldo just put more legacy noise into CREDITS... Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09Convert the toplevel files CREDITS and MAINTAINERS to UTF-8.John Anthony Kazos Jr
Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08Add webpages' URL and summarize 3 lines.Miguel Ojeda
CREDITS: - Summarize 3 lines into one. - Add webpage. MAINTAINERS: - Add auxdisplay drivers/tree webpages. Signed-off-by: Miguel Ojeda Sandonis <maxextreme@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08proc: maps protectionKees Cook
The /proc/pid/ "maps", "smaps", and "numa_maps" files contain sensitive information about the memory location and usage of processes. Issues: - maps should not be world-readable, especially if programs expect any kind of ASLR protection from local attackers. - maps cannot just be 0400 because "-D_FORTIFY_SOURCE=2 -O2" makes glibc check the maps when %n is in a *printf call, and a setuid(getuid()) process wouldn't be able to read its own maps file. (For reference see http://lkml.org/lkml/2006/1/22/150) - a system-wide toggle is needed to allow prior behavior in the case of non-root applications that depend on access to the maps contents. This change implements a check using "ptrace_may_attach" before allowing access to read the maps contents. To control this protection, the new knob /proc/sys/kernel/maps_protect has been added, with corresponding updates to the procfs documentation. [akpm@linux-foundation.org: build fixes] [akpm@linux-foundation.org: New sysctl numbers are old hat] Signed-off-by: Kees Cook <kees@outflux.net> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[PATCH] x86-64: Change my email addressAndi Kleen
Signed-off-by: Andi Kleen <ak@suse.de>
2007-04-27USB: update MAINAINERS and CREDITS for Freescale USB driverLi Yang
Add MAINAINERS and CREDITS entry for Freescale Highspeed USB device driver. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-25[WIRELESS] cfg80211: New wireless config infrastructure.Johannes Berg
This patch creates the core cfg80211 code along with some sysfs bits. This is a stripped down version to allow mac80211 to function, but doesn't include any configuration yet except for creating and removing virtual interfaces. This patch includes the nl80211 header file but it only contains the interface types which the cfg80211 interface for creating virtual interfaces relies on. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[CREDITS]: Update Arnaldo entryArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-02-26[PATCH] CREDITS: update my email addressMikael Pettersson
Update my email address in CREDITS to one that works. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] drivers: add LCD supportMiguel Ojeda Sandonis
Add support for auxiliary displays, the ks0108 LCD controller, the cfag12864b LCD and adds a framebuffer device: cfag12864bfb. - Add a "auxdisplay/" folder in "drivers/" for auxiliary display drivers. - Add support for the ks0108 LCD Controller as a device driver. (uses parport interface) - Add support for the cfag12864b LCD as a device driver. (uses ks0108 LCD Controller driver) - Add a framebuffer device called cfag12864bfb. (uses cfag12864b LCD driver) - Add the usual Documentation, includes, Makefiles, Kconfigs, MAINTAINERS, CREDITS... - Miguel Ojeda will maintain all the stuff above. [rdunlap@xenotime.net: workqueue fixups] [akpm@osdl.org: kconfig fix] Signed-off-by: Miguel Ojeda Sandonis <maxextreme@gmail.com> Cc: Greg KH <greg@kroah.com> Acked-by: Paulo Marques <pmarques@grupopie.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-23Change Linus' email address tooLinus Torvalds
This changes a few mentions of my email address to point to the new one, leaving things like old copyright messages alone. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-30[PATCH] Update CREDITS and MAINTAINERS entries for Lennert BuytenhekLennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Generic HID layer - buildJiri Kosina
This modifies Makefiles and Kconfigs to properly reflect the creation of generic HID layer. It also removes the dependency of BROKEN, which was introduced by the first patch in series (see the comment). Also updates credits. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-02[TCP]: MD5 Signature Option (RFC2385) support.YOSHIFUJI Hideaki
Based on implementation by Rick Payne. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-17[PATCH] Update my CREDITS entryDavid Weinehall
I moved from Sweden to Finland 2.5 years ago, thought it might be time to update my CREDITS entry (simply removing the address completely seemed the sanest option). Signed-off-by: David Weinehall <tao@kernel.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-08[PATCH] Tigran has movedTigran Aivazian
2006-10-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6: (292 commits) [GFS2] Fix endian bug for de_type [GFS2] Initialize SELinux extended attributes at inode creation time. [GFS2] Move logging code into log.c (mostly) [GFS2] Mark nlink cleared so VFS sees it happen [GFS2] Two redundant casts removed [GFS2] Remove uneeded endian conversion [GFS2] Remove duplicate sb reading code [GFS2] Mark metadata reads for blktrace [GFS2] Remove iflags.h, use FS_ [GFS2] Fix code style/indent in ops_file.c [GFS2] streamline-generic_file_-interfaces-and-filemap gfs fix [GFS2] Remove readv/writev methods and use aio_read/aio_write instead (gfs bits) [GFS2] inode-diet: Eliminate i_blksize from the inode structure [GFS2] inode_diet: Replace inode.u.generic_ip with inode.i_private (gfs) [GFS2] Fix typo in last patch [GFS2] Fix direct i/o logic in filemap.c [GFS2] Fix bug in Makefiles for lock modules [GFS2] Remove (extra) fs_subsys declaration [GFS2/DLM] Fix trailing whitespace [GFS2] Tidy up meta_io code ...
2006-10-04[PATCH] RCU: CREDITS and MAINTAINERSJosh Triplett
Add MAINTAINERS entry for Read-Copy Update (RCU), listing Dipankar Sarma as maintainer, and giving the URL for Paul McKenney's RCU site. Add MAINTAINERS entry for rcutorture, listing myself as maintainer. Add CREDITS entries for developers of RCU, RCU variants, and rcutorture. Use Paul McKenney's preferred email address in include/linux/rcupdate.h . Signed-off-by: Josh Triplett <josh@freedesktop.org> Cc: Paul McKenney <paulmck@us.ibm.com> Cc: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Add missing maintainer countries in CREDITSSamuel Tardieu
Add missing maintainer countries. Signed-off-by: Samuel Tardieu <sam@rfc1149.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Michal Wronski: update contact infoMichal Wronski
My email has changed. Signed-Off-By: Michal Wronski <michal.wronski@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03[PATCH] Add Pekka to CREDITSPekka Enberg
Whomever said... "When you meet someone now who is writing a compiler or hacking a Unix kernel, at least you know they're not just doing it to pick up chicks." ...has obviously never met a _Linux_ kernel hacker. Anyway, sometimes people confuse my email addresses, which is why I really should add the proper one to CREDITS ;-). Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02Merge branch 'master' into gfs2Steven Whitehouse
2006-09-29[PATCH] /sys/modules: allow full length section namesIan S. Nelson
I've been using systemtap for some debugging and I noticed that it can't probe a lot of modules. Turns out it's kind of silly, the sections section of /sys/module is limited to 32byte filenames and many of the actual sections are a a bit longer than that. [akpm@osdl.org: rewrite to use dymanic allocation] Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Small update to CREDITSJesper Juhl
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
