path: root/CREDITS
2011-06-30CREDITS: Fix typoHenrik Ahlgren
David Brownell's CREDITS entry should have N: (name) instead of M: (email). Signed-off-by: Henrik Ahlgren <pablo@seestieto.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-07MAINTAINERS: Saying goodbye to David BrownellGrant Likely
We had to say goodbye when David passed away recently. David had a huge impact on our community, both personally in the lives of the people he worked with, and technically in the design and maintenance of several subsystems. He is greatly missed. He also leaves behind a number of much loved subsystems now orphaned. This patch updates the MAINTAINERS file for the areas that David was responsible for and adds an entry for him to the CREDITS file. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Harry Wei <harryxiyou@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25Merge branch 'kconfig-for-40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig-for-40' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: xconfig: merge code path to conf_write() kconfig: do not record timestamp in .config gconfig: Hide unused left treeview when start up the interface gconfig: enable rules hint for main treeviews MAINTAINERS: Update KCONFIG entry kconfig-language: add to hints kconfig: Document the new "visible if" syntax kconfig: quiet commands when V=0 kconfig: change update-po-config to reflect new layout of arch/um kconfig: make update-po-config work in KBUILD_OUTPUT kconfig: rearrange clean-files kconfig: change gconf to modify hostprogs-y like nconf and mconf kconfig: change qconf to modify hostprogs-y like nconf and mconf kconfig: only build kxgettext when needed nconfig: Silence unused return values from wattrset kconfig: Do not record timestamp in auto.conf and autoconf.h kconfig: get rid of unused flags kconfig: allow multiple inclusion of the same file kconfig: Avoid buffer underrun in choice input
2011-05-25MAINTAINERS: orphan DMFE, move Tobias Ringstrom to CREDITSJoe Perches
Tobias's email bounces and he hasn't submitted or acked a patch in git history. Signed-off-by: Joe Perches <joe@perches.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-04MAINTAINERS: Update KCONFIG entryMichal Marek
Roman Zippel hasn't been active for several years. Add myself as kconfig maintainer, but change the mode to "Odd Fixes" to not set expectations too high. Also, remove the patchwork link, since it is not used for kbuild/kconfig. Signed-off-by: Michal Marek <mmarek@suse.cz> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-03-31CREDITS: update Johannes Berg's gpg keyJohannes Berg
I've had a new key for almost two years and revoked the old one, but forgot to update it here. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-13CREDITS: update Stelian's entryStelian Pop
Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-19perf tools: Change my maintainer addressArnaldo Carvalho de Melo
Also remove old snail mail address from CREDITS, moved years ago. LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-10-01MAINTAINERS: update matroxfb & ncpfs statusPetr Vandrovec
I moved couple years ago, so let's update my email and snail mail. And I do not have any access to Matrox hardware anymore, and I'm quite unresponsive to matroxfb bug reports (sorry Alan), so saying that I'm maintainer is a bit far fetched. For ncpfs I do not use ncpfs in my daily life either, but at least I can test that one, so I can stay listed here for odd fixes. Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-15Nicolas Pitre has a new email addressNicolas Pitre
Due to problems at cam.org, my nico@cam.org email address is no longer valid. FRom now on, nico@fluxnic.net should be used instead. Signed-off-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29MAINTAINERS: Remove CS461x sound card sectionJoe Perches
Thomas Woller's email address bounces Nils Faerber isn't active Added Thomas Woller to CREDITS, Nils already has an entry Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29MAINTAINERS: Move ARPD to CREDITSJoe Perches
Jonathan Layes is hard to find. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-17Update Andreas Koensgen's email addressRalf Baechle
The kernel has used a stale email address of Andreas for a few years. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-18can: Update MAINTAINERS and CREDITS fileWolfgang Grandegger
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (28 commits) trivial: Update my email address trivial: NULL noise: drivers/mtd/tests/mtd_*test.c trivial: NULL noise: drivers/media/dvb/frontends/drx397xD_fw.h trivial: Fix misspelling of "Celsius". trivial: remove unused variable 'path' in alloc_file() trivial: fix a pdlfush -> pdflush typo in comment trivial: jbd header comment typo fix for JBD_PARANOID_IOFAIL trivial: wusb: Storage class should be before const qualifier trivial: drivers/char/bsr.c: Storage class should be before const qualifier trivial: h8300: Storage class should be before const qualifier trivial: fix where cgroup documentation is not correctly referred to trivial: Give the right path in Documentation example trivial: MTD: remove EOL from MODULE_DESCRIPTION trivial: Fix typo in bio_split()'s documentation trivial: PWM: fix of #endif comment trivial: fix typos/grammar errors in Kconfig texts trivial: Fix misspelling of firmware trivial: cgroups: documentation typo and spelling corrections trivial: Update contact info for Jochen Hein trivial: fix typo "resgister" -> "register" ...
2009-03-31MAINTAINERS: move old ide-{floppy,tape} entries to CREDITS (take 2)Bartlomiej Zolnierkiewicz
Ben Hutchings noticed that MAINTAINERS somehow still contain old ide-{floppy,tape} entries. Fix it by moving them to CREDITS (kudos to Gadi and Paul for all the early hard work on ide-{floppy,tape}). v2: Rename IDE/ATAPI CDROM DRIVER entry to IDE/ATAPI DRIVERS one. Cc: Gadi Oxman <gadio@netvision.net.il> Cc: Paul Bristow <paul@paulbristow.net> Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-30trivial: Update my email addressRiku Voipio
Update my email address. Signed-off-by: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-30trivial: Update contact info for Jochen HeinJochen Hein
I've moved again - so update my address again. Signed-off-by: Jochen Hein <jochen@jochen.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-22Update my email addressGertjan van Wingerde
Update all previous incarnations of my email address to the correct one. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-18Pavel has movedPavel Machek
My @suse.cz address will stop working some day, so put working one into MAINTAINERS/CREDITS. It would be cool to get this to 2.6.29... it should not really break anything. Signed-off-by: Pavel Machek <pavel@ucw.cz> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15CREDITS address update for dwmw2.David Woodhouse
Update employer's care-of address in CREDITS file, and remove references to some _very_ old stuff I'd forgotten I'd ever done. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (123 commits) wimax/i2400m: add CREDITS and MAINTAINERS entries wimax: export linux/wimax.h and linux/wimax/i2400m.h with headers_install i2400m: Makefile and Kconfig i2400m/SDIO: TX and RX path backends i2400m/SDIO: firmware upload backend i2400m/SDIO: probe/disconnect, dev init/shutdown and reset backends i2400m/SDIO: header for the SDIO subdriver i2400m/USB: TX and RX path backends i2400m/USB: firmware upload backend i2400m/USB: probe/disconnect, dev init/shutdown and reset backends i2400m/USB: header for the USB bus driver i2400m: debugfs controls i2400m: various functions for device management i2400m: RX and TX data/control paths i2400m: firmware loading and bootrom initialization i2400m: linkage to the networking stack i2400m: Generic probe/disconnect, reset and message passing i2400m: host/device procotol and core driver definitions i2400m: documentation and instructions for usage wimax: Makefile, Kconfig and docbook linkage for the stack ...
2009-01-07wimax/i2400m: add CREDITS and MAINTAINERS entriesInaky Perez-Gonzalez
This patch adds entries for the original developers of the i2400m drivers and up-to-date maintainer entries. Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06trivial: update Jesper Juhl CREDITS entry with new emailJesper Juhl
Old email no longer exists, this updates CREDITS with my new one. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-03Updated contact info for CREDITS fileHugh Blemings
This updates some personal info in the CREDITS file. I'm no longer actively involved in Keyspan driver work so shouldn't really be listed as a Maintainer here. I do however field the occasional question on them and as I'm dropping the misc.nu domain, want to ensure people can find me should they need to. Signed-off-by: Hugh Blemings <hugh@blemings.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23Merge branch 'for-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb * 'for-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb: (47 commits) uwb: wrong sizeof argument in mac address compare uwb: don't use printk_ratelimit() so often uwb: use kcalloc where appropriate uwb: use time_after() when purging stale beacons uwb: add credits for the original developers of the UWB/WUSB/WLP subsystems uwb: add entries in the MAINTAINERS file uwb: depend on EXPERIMENTAL wusb: wusb-cbaf (CBA driver) sysfs ABI simplification uwb: document UWB and WUSB sysfs files uwb: add symlinks in sysfs between radio controllers and PALs uwb: dont tranmit identification IEs uwb: i1480/GUWA100U: fix firmware download issues uwb: i1480: remove MAC/PHY information checking function uwb: add Intel i1480 HWA to the UWB RC quirk table uwb: disable command/event filtering for D-Link DUB-1210 uwb: initialize the debug sub-system uwb: Fix handling IEs with empty IE data in uwb_est_get_size() wusb: fix bmRequestType for Abort RPipe request wusb: fix error path for wusb_set_dev_addr() wusb: add HWA host controller driver ...
2008-10-20Update email addresses.Dave Jones
Update assorted email addresses and related info to point to a single current, valid address. additionally - trivial CREDITS entry updates. (Not that this file means much any more) - remove arjans dead redhat.com address from powernow driver Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-17uwb: add credits for the original developers of the UWB/WUSB/WLP subsystemsInaky Perez-Gonzalez
Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-07-24remove the OSS trident driverAdrian Bunk
SOUND_TRIDENT was the last PCI OSS driver, and since there's already an ALSA driver for the same hardware we can remove it. [muli@il.ibm.com: update CREDITS] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21Don't list my old OSDL mailing address in CREDITS fileLinus Torvalds
.. it may or may be forwarded, but it's not like I want people to send stuff without knowing or checking first anyway, so delete the address entirely. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-04Miguel Ojeda has movedMiguel Ojeda
Signed-off-by: Miguel Ojeda <miguel.ojeda.sandonis@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24pcsp - Don't build pcspkr when snd-pcsp is enabledStas Sergeev
- Update CREDITS with the pc-speaker driver authors. - Prevent pcspkr from being built together with snd-pcsp. Both pcspkr and snd-pcsp use the same platform driver name "pcspkr". Signed-off-by: Stas Sergeev <stsp@aknet.ru>
2008-02-03MAINTAINERS: remove Adam Fritzler, remove his email address in other sourcesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03remove obsolete contact information from CREDITSAdrian Bunk
2008-01-28[CAN]: Add maintainer entriesOliver Hartkopp
This patch adds entries in the CREDITS and MAINTAINERS file for CAN. Signed-off-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de> Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (40 commits) kbuild: introduce ccflags-y, asflags-y and ldflags-y kbuild: enable 'make CPPFLAGS=...' to add additional options to CPP kbuild: enable use of AFLAGS and CFLAGS on commandline kbuild: enable 'make AFLAGS=...' to add additional options to AS kbuild: fix AFLAGS use in h8300 and m68knommu kbuild: check for wrong use of CFLAGS kbuild: enable 'make CFLAGS=...' to add additional options to CC kbuild: fix up CFLAGS usage kbuild: make modpost detect unterminated device id lists kbuild: call export_report from the Makefile kbuild: move Kai Germaschewski to CREDITS kconfig/menuconfig: distinguish between selected-by-another options and comments kconfig: tristate choices with mixed tristate and boolean values include/linux/Kbuild: remove duplicate entries kbuild: kill backward compatibility checks kbuild: kill EXTRA_ARFLAGS kbuild: fix documentation in makefiles.txt kbuild: call make once for all targets when O=.. is used kbuild: pass -g to assembler under CONFIG_DEBUG_INFO kbuild: update _shipped files for kconfig syntax cleanup ... Fix up conflicts in arch/um/sys-{x86_64,i386}/Makefile manually.
2007-10-16Merge branch 'linus' of master.kernel.org:/pub/scm/linux/kernel/git/perex/alsaLinus Torvalds
* 'linus' of master.kernel.org:/pub/scm/linux/kernel/git/perex/alsa: (264 commits) [ALSA] version 1.0.15 [ALSA] Fix thinko in cs4231 mce down check [ALSA] sun-cs4231: improved waiting after MCE down [ALSA] sun-cs4231: use cs4231-regs.h [ALSA] This simplifies and fixes waiting loops of the mce_down() [ALSA] This patch adds support for a wavetable chip on [ALSA] This patch removes open_mutex from the ad1848-lib as [ALSA] fix bootup crash in snd_gus_interrupt() [ALSA] hda-codec - Fix SKU ID function for realtek codecs [ALSA] Support ASUS P701 eeepc [0x1043 0x82a1] support [ALSA] hda-codec - Add array terminator for dmic in STAC codec [ALSA] hdsp - Fix zero division [ALSA] usb-audio - Fix double comment [ALSA] hda-codec - Fix STAC922x volume knob control [ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.cz [ALSA] hda-codec - Fix for Fujitsu Lifebook C1410 [ALSA] mpu-401: remove MPU401_INFO_UART_ONLY flag [ALSA] mpu-401: do not require an ACK byte for the ENTER_UART command [ALSA] via82xx - Add DXS quirk for Shuttle AK31v2 [ALSA] hda-codec - Fix input_mux numbers for vaio stac92xx ...
2007-10-16CREDITS: correct Mikael Pettersson's URLMikael Pettersson
New URL due to local reorganization.
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-12kbuild: move Kai Germaschewski to CREDITSSam Ravnborg
Kai is not active in kernel development these days so give him credit for his major kbuild contribution and ISDN work. Acked-by: Kai Germaschewski <kai@germaschewski.name> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-10[RT2x00]: add driver for Ralink wireless hardwareIvo van Doorn
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-26Slab maintainer & Credits updateChristoph Lameter
Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20[ALSA] Update Claudio's CREDITS informationClaudio Matsuoka
Signed-off-by: Claudio Matsuoka <cmatsuoka@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-06-20Fix up CREDIT entry orderingLi Yang
Reorder my CREDIT entry to make it in alphabetic order by last name. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11further UTF-8 fixes and name correctionDavid Woodhouse
> -** Copyright 1994 by Bj<94>rn Brauel > +** Copyright 1994 by Bj”rn Brauel I think these were cp437, and it should read 'Björn'. (asm-m68k/atari*.h) Also note that Arnaldo just put more legacy noise into CREDITS... Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09Convert the toplevel files CREDITS and MAINTAINERS to UTF-8.John Anthony Kazos Jr
Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08Add webpages' URL and summarize 3 lines.Miguel Ojeda
CREDITS: - Summarize 3 lines into one. - Add webpage. MAINTAINERS: - Add auxdisplay drivers/tree webpages. Signed-off-by: Miguel Ojeda Sandonis <maxextreme@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
