path: root/CREDITS
2016-10-27CREDITS: update credit information for Martin KepplingerMartin Kepplinger
Content and employer changed. Link: http://lkml.kernel.org/r/1477304102-28830-1-git-send-email-martin.kepplinger@ginzinger.com Signed-off-by: Martin Kepplinger <martink@posteo.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07CREDITS: update Pavel's information, add GPG key, remove snail mail addressPavel Machek
Link: http://lkml.kernel.org/r/20161003082312.GA20634@amd Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-06Merge tag 'for-v4.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply Pull power supply and reset updates from Sebastian Reichel: - move power supply drivers to drivers/power/supply - unify location of power supply DT documentation - tps65217-charger: IRQ support - act8945a-charger: misc. cleanups & improvements - sbs-battery cleanup - fix users of deprecated create_singlethread_workqueue() - misc fixes. * tag 'for-v4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply: (46 commits) power: supply: bq27xxx_battery: allow kernel poll_interval parameter runtime update power: supply: sbs-battery: Cleanup removal of chip->pdata power: reset: st: Remove obsolete platforms from dt doc power: reset: st-poweroff: Remove obsolete platforms. power: reset: zx-reboot: Unmap region obtained by of_iomap power: reset: xgene-reboot: Unmap region obtained by of_iomap power: supply: ab8500: cleanup with list_first_entry_or_null() power: reset: add in missing white space in error message text sbs-battery: make writes to ManufacturerAccess optional power: bq24257: Fix use of uninitialized pointer bq->charger power: supply: sbs-battery: simplify DT parsing power: supply: bq24735-charger: Request status GPIO with initial input setup power: supply: sbs-battery: Use gpio_desc and sleeping calls for battery detect power: supply: act8945a_charger: Add max current property power: supply: act8945a_charger: Add capacity level property doc: bindings: power: act8945a-charger: Update properties. power: supply: act8945a_charger: Fix the power supply type power: supply: act8945a_charger: Add status change update support power: supply: act8945a_charger: Improve state handling power: supply: act8945a_charger: Remove "battery_temperature" ...
2016-10-04Merge tag 'edac_for_4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bpLinus Torvalds
Pull EDAC updates from Borislav Petkov: "A lot of movement in the EDAC tree this time around, coarse summary below: - Altera Arria10 enablement of NAND, DMA, USB, QSPI and SD-MMC FIFO buffers (Thor Thayer) - split the memory controller part out of mpc85xx and share it with a new Freescale ARM Layerscape driver (York Sun) - amd64_edac fixes (Yazen Ghannam) - misc cleanups, refactoring and fixes all over the place" * tag 'edac_for_4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: (37 commits) EDAC, altera: Add IRQ Flags to disable IRQ while handling EDAC, altera: Correct EDAC IRQ error message EDAC, amd64: Autoload module using x86_cpu_id EDAC, sb_edac: Remove NULL pointer check on array pci_tad EDAC: Remove NO_IRQ from powerpc-only drivers EDAC, fsl_ddr: Fix error return code in fsl_mc_err_probe() EDAC, fsl_ddr: Add entry to MAINTAINERS EDAC: Move Doug Thompson to CREDITS EDAC, I3000: Orphan driver EDAC, fsl_ddr: Replace simple_strtoul() with kstrtoul() EDAC, layerscape: Add Layerscape EDAC support EDAC, fsl_ddr: Fix IRQ dispose warning when module is removed EDAC, fsl_ddr: Add support for little endian EDAC, fsl_ddr: Add missing DDR DRAM types EDAC, fsl_ddr: Rename macros and names EDAC, fsl-ddr: Separate FSL DDR driver from MPC85xx EDAC, mpc85xx: Replace printk() with pr_* format EDAC, mpc85xx: Drop setting/clearing RFXE bit in HID1 EDAC, altera: Rename MC trigger to common name EDAC, altera: Rename device trigger to common name ...
2016-10-03Merge tag 'char-misc-4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here's the "big" char and misc driver update for 4.9-rc1. Lots of little things here, all over the driver tree for subsystems that flow through me. Nothing major that I can discern, full details are in the shortlog. All have been in the linux-next tree with no reported issues" * tag 'char-misc-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (144 commits) drivers/misc/hpilo: Changes to support new security states in iLO5 FW at25: fix debug and error messaging misc/genwqe: ensure zero initialization vme: fake: remove unexpected unlock in fake_master_set() vme: fake: mark symbols static where possible spmi: pmic-arb: Return an error code if sanity check fails Drivers: hv: get rid of id in struct vmbus_channel Drivers: hv: make VMBus bus ids persistent mcb: Add a dma_device to mcb_device mcb: Enable PCI bus mastering by default mei: stop the stall timer worker if not needed clk: probe common clock drivers earlier vme: fake: fix build for 64-bit dma_addr_t ttyprintk: Neaten and simplify printing mei: me: add kaby point device ids coresight: tmc: mark symbols static where possible coresight: perf: deal with error condition properly Drivers: hv: hv_util: Avoid dynamic allocation in time synch fpga manager: Add hardware dependency to Zynq driver Drivers: hv: utils: Support TimeSync version 4.0 protocol samples. ...
2016-09-19CREDITS: Update fingerprint for Geert UytterhoevenGeert Uytterhoeven
My old key was revoked in 2007. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2016-09-09EDAC: Move Doug Thompson to CREDITSBorislav Petkov
Doug hasn't been active as a maintainer for a long time now. Move him to CREDITS. Thanks for all the hard work, Doug! Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Doug Thompson <norsk5@yahoo.com> Cc: Doug Thompson <dougthompson@xmission.com>
2016-09-01EDAC, I3000: Orphan driverBorislav Petkov
Apparently there's no hw left at Intel for testing patches and Jason is not going to maintain it anymore. Signed-off-by: Borislav Petkov <bp@suse.de>
2016-08-31MAINTAINERS: Remove power-supply co-maintainersSebastian Reichel
This documents the status quo and keeps everyones cc/to-list a bit shorter. Signed-off-by: Sebastian Reichel <sre@kernel.org>
2016-08-31MAINTAINERS: Saying goodbye to Hans J. KochBenedikt Spranger
We had to say goodbye when Hans passed away recently. Hans was a free-software enthusiast and an active contributor. He was the main author and maintainer of the UIO subsystem and contributed in various ways to the Linux kernel as a professional and hobbyist. He is greatly missed. Signed-off-by: Benedikt Spranger <b.spranger@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-15Update my main e-mails at the Kernel treeMauro Carvalho Chehab
For the third time in three years, I'm changing my e-mail at Samsung. That's bad, as it may stop communications with me for a while. So, this time, I'll also add the mchehab@kernel.org e-mail, as it remains stable since ever. Cc: stable@vger.kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-29Documentation: update the devices.txt documentationLinus Walleij
Alan is no longer maintaining this list through the Linux assigned numbers authority. Make it a collective document by referring to "the maintainers" in plural throughout, and naming the chardev and block layer maintainers in particular as parties of involvement. Cut down and remove some sections that pertained to the process of maintaining the list at lanana.org and contacting Alan directly. Make it clear that this document, in the kernel, is the master document. Also move paragraphs around so as to emphasize dynamic major number allocation. Remove paragraph on 2.6 deprecation, that tag no longer appears anywhere in the file. Cc: Jonathan Corbet <corbet@lwn.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Alan Cox <alan@linux.intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-01Merge tag 'iio-for-4.6a' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next Jonathan writes: First round of new IIO device support, features and cleanups for the 4.6 cycle. Device Support * ad5761 - new driver * at91_sama5d2 ADC. - new driver and MAINTAINERS entry. - minor cleanups followed. * atlas pH-SM - new driver (this has possibly the prettiest data sheet I've ever seen) * mcp3422 - mcp3425 ADC added. * mcp4725 - mcp4726 DAC added. * mma8452 - mma8451q accelerometer added. * mpl115 - mpl115a1 added (a lot bigger than it seems as this is an SPI part whereas previous parts were i2c). * si7005 - Hoperf th02 (seems to be a repackaged part) * si7020 - Hoperf th06 (seems to be a repackaged part) New features * Core - IIO_PH type. Does what it says on the tin. * max30100 - LED current configuration support. * mcp320x - more differential measurement combinations. * mma8452 - free fall deteciton - opt3001 - enable operation without a IRQ line. - device tree docs. Somehow the original docs have disappeared down a rabbit hole, so here is a new set. * st-sensors - Support active-low interrupts. Cleanups and minor / not so minor reworks * Documentation - drop some defunct ABI from the docs in staging. * presure / Kconfig - white space cleanup. * ad7150 - BIT macro usage - Alignment fixes * ad7192 - false indent fixed. * ak8975 - constify the ak_def structures * axp288 - drop a redundant double const. * dht11 - substantial reliability improvements by being more tolerant of missing start bits. - simplify the decoding algorithm * mma8452 - whitespace cleanup * mpl115 - don't bother setting i2c_client_data as nothing uses it. * mpu6050 - drop unused function parameter. * opt3001 - extract integration time as constants. - trivial refactoring.
2016-01-24iio: add ad5761 DAC driverRicardo Ribalda Delgado
ad5761 is a 1-channel DAC with configurable output range. The driver uses the regulator interface for its voltage ref. It shares its register layout with ad5761r, ad5721 and ad5721r. Differences: ad5761* are 16 bit, ad5721* are 12 bits. ad57*1r have an internal reference. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2016-01-20./CREDITS: add credit information for Martin KepplingerMartin Kepplinger
2016-01-15Merge tag 'md/4.5' of git://neil.brown.name/mdLinus Torvalds
Pull md updates from Neil Brown: "Mostly clustered-raid1 and raid5 journal updates. one Y2038 fix and other minor stuff. One patch removes me from the MAINTAINERS file and adds a record of my md maintainership to Credits" Many thanks to Neil, who has been around for a _looong_ time. * tag 'md/4.5' of git://neil.brown.name/md: (26 commits) md/raid: only permit hot-add of compatible integrity profiles Remove myself as MD Maintainer, and add to Credits. raid5-cache: handle journal hotadd in quiesce MD: add journal with array suspended md: set MD_HAS_JOURNAL in correct places md: Remove 'ready' field from mddev. md: remove unnecesary md_new_event_inintr raid5: allow r5l_io_unit allocations to fail raid5-cache: use a mempool for the metadata block raid5-cache: use a bio_set raid5-cache: add journal hot add/remove support drivers: md: use ktime_get_real_seconds() md: avoid warning for 32-bit sector_t raid5-cache: free meta_page earlier raid5-cache: simplify r5l_move_io_unit_list md: update comment for md_allow_write md-cluster: update comments for MD_CLUSTER_SEND_LOCKED_ALREADY md-cluster: Protect communication with mutexes md-cluster: Defer MD reloading to mddev->thread md-cluster: update the documentation ...
2016-01-14Remove myself as MD Maintainer, and add to Credits.NeilBrown
Signed-off-by: NeilBrown <neilb@suse.com>
2015-12-18MAINTAINERS: change the maintainer of fam15h_power driverHuang Rui
Andreas Herrmann won't take the maintainer of fam15h_power driver. I will take it and appreciate him for the great contributions on this driver. Signed-off-by: Huang Rui <ray.huang@amd.com> Acked-by: Andreas Herrmann <herrmann.der.user@googlemail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Aravind Gopalakrishnan <Aravind.Gopalakrishnan@amd.com> [groeck: Fixed typo in CREDITS] Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-09-10MAINTAINERS/CREDITS: mark MaxRAID as Orphan, move Anil Ravindranath to CREDITSJoe Perches
Anil's email address bounces and he hasn't had a signoff in over 5 years. Signed-off-by: Joe Perches <joe@perches.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04Merge tag 'pinctrl-v4.3-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control updates from Linus Walleij: "This is the bulk of pin control changes for the v4.3 development cycle. Like with GPIO it's a lot of stuff. If my subsystems are any sign of the overall tempo of the kernel v4.3 will be a gigantic diff. [ It looks like 4.3 is calmer than 4.2 in most other subsystems, but we'll see - Linus ] Core changes: - It is possible configure groups in debugfs. - Consolidation of chained IRQ handler install/remove replacing all call sites where irq_set_handler_data() and irq_set_chained_handler() were done in succession with a combined call to irq_set_chained_handler_and_data(). This series was created by Thomas Gleixner after the problem was observed by Russell King. - Tglx also made another series of patches switching __irq_set_handler_locked() for irq_set_handler_locked() which is way cleaner. - Tglx also wrote a good bunch of patches to make use of irq_desc_get_xxx() accessors and avoid looking up irq_descs from IRQ numbers. The goal is to get rid of the irq number from the handlers in the IRQ flow which is nice. Driver feature enhancements: - Power management support for the SiRF SoC Atlas 7. - Power down support for the Qualcomm driver. - Intel Cherryview and Baytrail: switch drivers to use raw spinlocks in IRQ handlers to play nice with the realtime patch set. - Rework and new modes handling for Qualcomm SPMI-MPP. - Pinconf power source config for SH PFC. New drivers and subdrivers: - A new driver for Conexant Digicolor CX92755. - A new driver for UniPhier PH1-LD4, PH1-Pro4, PH1-sLD8, PH1-Pro5, ProXtream2 and PH1-LD6b SoC pin control support. - Reverse-egineered the S/PDIF settings for the Allwinner sun4i driver. - Support for Qualcomm Technologies QDF2xxx ARM64 SoCs - A new Freescale i.mx6ul subdriver. Cleanup: - Remove platform data support in a number of SH PFC subdrivers" * tag 'pinctrl-v4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (95 commits) pinctrl: at91: fix null pointer dereference pinctrl: mediatek: Implement wake handler and suspend resume pinctrl: mediatek: Fix multiple registration issue. pinctrl: sh-pfc: r8a7794: add USB pin groups pinctrl: at91: Use generic irq_{request,release}_resources() pinctrl: cherryview: Use raw_spinlock for locking pinctrl: baytrail: Use raw_spinlock for locking pinctrl: imx6ul: Remove .owner field pinctrl: zynq: Fix typos in smc0_nand_grp and smc0_nor_grp pinctrl: sh-pfc: Implement pinconf power-source param for voltage switching clk: rockchip: add pclk_pd_pmu to the list of rk3288 critical clocks pinctrl: sun4i: add spdif to pin description. pinctrl: atlas7: clear ugly branch statements for pull and drivestrength pinctrl: baytrail: Serialize all register access pinctrl: baytrail: Drop FSF mailing address pinctrl: rockchip: only enable gpio clock when it setting pinctrl/mediatek: fix spelling mistake in dev_err error message pinctrl: cherryview: Serialize all register access pinctrl: UniPhier: PH1-Pro5: add I2C ch6 pin-mux setting pinctrl: nomadik: reflect current input value ...
2015-07-28MAINTAINERS: pinctrl: Move Thomas Abraham to CREDITSKrzysztof Kozlowski
Thomas Abraham's Linaro email address bounces for several months. Also there were no replies for several emails sent on LKML to his Samsung address. Move his name to CREDITS. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Cc: Tomasz Figa <tomasz.figa@gmail.com> Cc: Thomas Abraham <thomas.ab@samsung.com> Cc: Linus Walleij <linus.walleij@linaro.org> Link: http://lkml.org/lkml/2015/6/15/15 Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-14cgroup: implement the PIDs subsystemAleksa Sarai
Adds a new single-purpose PIDs subsystem to limit the number of tasks that can be forked inside a cgroup. Essentially this is an implementation of RLIMIT_NPROC that applies to a cgroup rather than a process tree. However, it should be noted that organisational operations (adding and removing tasks from a PIDs hierarchy) will *not* be prevented. Rather, the number of tasks in the hierarchy cannot exceed the limit through forking. This is due to the fact that, in the unified hierarchy, attach cannot fail (and it is not possible for a task to overcome its PIDs cgroup policy limit by attaching to a child cgroup -- even if migrating mid-fork it must be able to fork in the parent first). PIDs are fundamentally a global resource, and it is possible to reach PID exhaustion inside a cgroup without hitting any reasonable kmemcg policy. Once you've hit PID exhaustion, you're only in a marginally better state than OOM. This subsystem allows PID exhaustion inside a cgroup to be prevented. Signed-off-by: Aleksa Sarai <cyphar@cyphar.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-06-30MAINTAINERS: move Jens Osterkamp to CREDITSJoe Perches
Jens' email address bounces, so move his name and entry to CREDITS. Signed-off-by: Joe Perches <joe@perches.com> Cc: Ishizaki Kou <kou.ishizaki@toshiba.co.jp> Cc: Jens Osterkamp <jens@linux.vnet.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-23MAINTAINERS: Add H8/300 entryYoshinori Sato
Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp>
2015-05-07MAINTAINERS: replace an AT91 maintainerNicolas Ferre
As some help is needed from an active maintainer, replace Andrew Victor by Alexandre Belloni in the ARM/Atmel MAINTAINERS' entry (aka AT91). Add an entry to the CREDITS file. Thanks Andrew for the great role you played during the early days of this product family. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-04-22Merge tag 'pci-v4.1-fixes-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI fixes from Bjorn Helgaas: "These fix an ia64 regression caused by tighter resource checking we merged during the merge window and remove an invalid email address from MAINTAINERS. Resource management: - ia64: Treat all Address Space Descriptors as windows (Bjorn Helgaas) Miscellaneous: - MAINTAINERS: Remove Mohit Kumar (email bounces) (Bjorn Helgaas)" * tag 'pci-v4.1-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: ia64/PCI: Treat all host bridge Address Space Descriptors (even consumers) as windows MAINTAINERS: Remove Mohit Kumar (email bounces)
2015-04-21MAINTAINERS: Remove Mohit Kumar (email bounces)Bjorn Helgaas
Email to Mohit Kumar <mohit.kumar@st.com> has been bouncing, so remove the address from MAINTAINERS and add an entry in CREDITS. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2015-04-15MAINTAINERS: CREDITS: remove Stefano Brivio from B43Joe Perches
This email address isn't working anymore Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15CREDITS: add Ricardo Ribalda DelgadoRicardo Ribalda Delgado
Add personal details to CREDITS file. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-23MAINTAINERS: mmc: Cleanup MMC/SD/SDIO section and SDHCI driver sectionUlf Hansson
As Chris Ball has moved on to other assignments, he's no longer able to help me maintain MMC. Let's remove him from the MMC sections in MAINTAINERS and add him to CREDIT file. This also affects the SDHCI DRIVER section, since its state now becomes orphan. Cc: Chris Ball <chris@printf.net> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Chris Ball <chris@printf.net>
2014-12-19Update/Remove soon-to-be-dead email addressDave Jones
I'm leaving Red Hat at the end of December 2014, so remove all references to my soon-to-be-dead address. (There are some references left in the tree, that need additional changes, I'll send those through the AGP maintainers). Signed-off-by: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-15Update MAINTAINERS and CREDITS files with amdkfd infoOded Gabbay
v6: Update entries to reflect new name & location of driver Signed-off-by: Oded Gabbay <oded.gabbay@amd.com>
2014-08-08MAINTAINERS: update IBM ServeRAID RAID infoMichael Opdenacker
- Invalid maintainer e-mail address: Mail server reply: Recipient address rejected: User unknown in virtual alias table - Remove no longer working webpage URL - Remove obsolete "Person" field - Move status to "Orphan" - Add Dave Jeffery and Jack Hammer to the CREDITS file Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Reviewed-by: Jean Delvare <jdelvare@suse.de> Cc: David Jeffery <dhjeffery@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Paul Bolle <pebolle@tiscali.nl> Reviewed-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-30Josh has movedJosh Triplett
My IBM email addresses haven't worked for years; also map some old-but-functional forwarding addresses to my canonical address. Update my GPG key fingerprint; I moved to 4096R a long time ago. Update description. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-23MAINTAINERS: SLAB maintainer updateChristoph Lameter
As discussed in various threads on the side: Remove one inactive maintainer, add two new ones and update my email address. Plus add Andrew. And fix the glob to include files like mm/slab_common.c Signed-off-by: Christoph Lameter <cl@linux.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-04Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "The main set of series of patches for media subsystem, including: - document RC sysfs class - added an API to setup scancode to allow waking up systems using the Remote Controller - add API for SDR devices. Drivers are still on staging - some API improvements for getting EDID data from media inputs/outputs - new DVB frontend driver for drx-j (ATSC) - one driver (it913x/it9137) got removed, in favor of an improvement on another driver (af9035) - added a skeleton V4L2 PCI driver at documentation - added a dual flash driver (lm3646) - added a new IR driver (img-ir) - added an IR scancode decoder for the Sharp protocol - some improvements at the usbtv driver, to allow its core to be reused. - added a new SDR driver (rtl2832u_sdr) - added a new tuner driver (msi001) - several improvements at em28xx driver to fix PM support, device removal and to split the V4L2 specific bits into a separate sub-driver - one driver got converted to videobuf2 (s2255drv) - the e4000 tuner driver now follows an improved binding model - some fixes at V4L2 compat32 code - several fixes and enhancements at videobuf2 code - some cleanups at V4L2 API documentation - usual driver enhancements, new board additions and misc fixups" [ NOTE! This merge effective drops commit 4329b93b283c ("of: Reduce indentation in of_graph_get_next_endpoint"). The of_graph_get_next_endpoint() function was moved and renamed by commit fd9fdb78a9bf ("[media] of: move graph helpers from drivers/media/v4l2-core to drivers/of"). It was originally called v4l2_of_get_next_endpoint() and lived in the file drivers/media/v4l2-core/v4l2-of.c. In that original location, it was then fixed to support empty port nodes by commit b9db140c1e46 ("[media] v4l: of: Support empty port nodes"), and that commit clashes badly with the dropped "Reduce intendation" commit. I had to choose one or the other, and decided that the "Support empty port nodes" commit was more important ] * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (426 commits) [media] em28xx-dvb: fix PCTV 461e tuner I2C binding Revert "[media] em28xx-dvb: fix PCTV 461e tuner I2C binding" [media] em28xx: fix PCTV 290e LNA oops [media] em28xx-dvb: fix PCTV 461e tuner I2C binding [media] m88ds3103: fix bug on .set_tone() [media] saa7134: fix WARN_ON during resume [media] v4l2-dv-timings: add module name, description, license [media] videodev2.h: add parenthesis around macro arguments [media] saa6752hs: depends on CRC32 [media] si4713: fix Kconfig dependencies [media] Sensoray 2255 uses videobuf2 [media] adv7180: free an interrupt on failure paths in init_device() [media] e4000: make VIDEO_V4L2 dependency optional [media] af9033: Don't export functions for the hardware filter [media] af9035: use af9033 PID filters [media] af9033: implement PID filter [media] rtl2832_sdr: do not use dynamic stack allocation [media] e4000: fix 32-bit build error [media] em28xx-audio: make sure audio is unmuted on open() [media] DocBook media: v4l2_format_sdr was renamed to v4l2_sdr_format ...
2014-04-03MAINTAINERS: remove Venkatesh from HPET, move to CREDITSJoe Perches
Seems he's gone off to bigger/better things. So long, etc... Signed-off-by: Joe Perches <joe@perches.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03MAINTAINERS: mark SuperH orphanGeert Uytterhoeven
Paul Mundt's email address bounces regularly, and he hasn't taken any SuperH patches for about one year. Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org> Suggested-by: Paul Bolle <pebolle@tiscali.nl> Cc: Paul Mundt <paul.mundt@gmail.com> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Cc: Laurent Pinchart <Laurent.pinchart@ideasonboard.com> Cc: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-20Merge branch 'master' into for-nextJiri Kosina
2014-02-19CREDITS: fix formattingGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-02-07[media, edac] Change my email addressMauro Carvalho Chehab
There are several left overs with my old email address. Remove their occurrences and add myself at CREDITS, to allow people to be able to reach me on my new addresses. Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-29Update Jean Delvare's e-mail addressJean Delvare
2013-11-27MAINTAINERS: add HSI subsystemSebastian Reichel
This adds me as maintainer for the HSI subsystem and Carlos Chinea (original author) to the CREDITS file. Signed-off-by: Sebastian Reichel <sre@debian.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13MAINTAINERS: update Zwane Mwaikambo's e-mail addressJean Delvare
Zwane Mwaikambo's @arm.linux.org.uk address no longer works. In February 2013 he asked for his gmail address to be used instead [1] so let's just do that. [1] http://marc.info/?l=linux-kernel&m=136079068903214&w=2 Signed-off-by: Jean Delvare <jdelvare@suse.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Zwane Mwaikambo <zwanem@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13MAINTAINERS: remove Richard Purdie as backlight maintainerJingoo Han
Remove Richard Purdie as backlight subsystem maintainer, akpm: Richard is still responsive and is reviewing some of the patches, but appears to agree that listing him as the maintainer is no longer appropriate. [akpm@linux-foundation.org: s/USA/UK/] Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-12Merge tag 'h8300-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull h8300 platform removal from Guenter Roeck: "The patch series has been in -next for more than one relase cycle. I did get a number of Acks, and no objections. H8/300 has been dead for several years, the kernel for it has not compiled for ages, and recent versions of gcc for it are broken. Remove support for it" * tag 'h8300-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: CREDITS: Add Yoshinori Sato for h8300 fs/minix: Drop dependency on H8300 Drop remaining references to H8/300 architecture Drop MAINTAINERS entry for H8/300 watchdog: Drop references to H8300 architecture net/ethernet: Drop H8/300 Ethernet driver net/ethernet: smsc9194: Drop conditional code for H8/300 ide: Drop H8/300 driver Drop support for Renesas H8/300 (h8300) architecture
2013-11-04CREDITS: Add Yoshinori Sato for h8300Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2013-09-25update contact information for Mikael PetterssonMikael Pettersson
My old @it.uu.se email address is going away, so update relevant files to point to my @gmail.com address instead. In sata_promise.c just delete the address, people can get it from MAINTAINERS. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "The usual trivial updates all over the tree -- mostly typo fixes and documentation updates" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (52 commits) doc: Documentation/cputopology.txt fix typo treewide: Convert retrun typos to return Fix comment typo for init_cma_reserved_pageblock Documentation/trace: Correcting and extending tracepoint documentation mm/hotplug: fix a typo in Documentation/memory-hotplug.txt power: Documentation: Update s2ram link doc: fix a typo in Documentation/00-INDEX Documentation/printk-formats.txt: No casts needed for u64/s64 doc: Fix typo "is is" in Documentations treewide: Fix printks with 0x%# zram: doc fixes Documentation/kmemcheck: update kmemcheck documentation doc: documentation/hwspinlock.txt fix typo PM / Hibernate: add section for resume options doc: filesystems : Fix typo in Documentations/filesystems scsi/megaraid fixed several typos in comments ppc: init_32: Fix error typo "CONFIG_START_KERNEL" treewide: Add __GFP_NOWARN to k.alloc calls with v.alloc fallbacks page_isolation: Fix a comment typo in test_pages_isolated() doc: fix a typo about irq affinity ...
2013-08-20MAINTAINERS: Remove Jeremy from the Xen subsystem.Konrad Rzeszutek Wilk
Jeremy has been a key person in making Linux work with Xen. He has been enjoying the last year working on something different so reflect that in the maintainers file. CC: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org>
