path: root/Documentation/ABI/testing/sysfs-class-bdi
2008-05-24fuse: fix bdi naming conflictMiklos Szeredi
Fuse allocates a separate bdi for each filesystem, and registers them in sysfs with "MAJOR:MINOR" of sb->s_dev (st_dev). This works fine for anon devices normally used by fuse, but can conflict with an already registered BDI for "fuseblk" filesystems, where sb->s_dev represents a real block device. In particularl this happens if a non-partitioned device is being mounted. Fix by registering with a different name for "fuseblk" filesystems. Thanks to Ioan Ionita for the bug report. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Reported-by: Ioan Ionita <opslynx@gmail.com> Tested-by: Ioan Ionita <opslynx@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30mm: bdi: move statistics to debugfsMiklos Szeredi
Move BDI statistics to debugfs: /sys/kernel/debug/bdi/<bdi>/stats Use postcore_initcall() to initialize the sysfs class and debugfs, because debugfs is initialized in core_initcall(). Update descriptions in ABI documentation. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30mm: bdi: allow setting a maximum for the bdi dirty limitPeter Zijlstra
Add "max_ratio" to /sys/class/bdi. This indicates the maximum percentage of the global dirty threshold allocated to this bdi. [mszeredi@suse.cz] - fix parsing in max_ratio_store(). - export bdi_set_max_ratio() to modules - limit bdi_dirty with bdi->max_ratio - document new sysfs attribute Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30mm: bdi: allow setting a minimum for the bdi dirty limitPeter Zijlstra
Under normal circumstances each device is given a part of the total write-back cache that relates to its current avg writeout speed in relation to the other devices. min_ratio - allows one to assign a minimum portion of the write-back cache to a particular device. This is useful in situations where you might want to provide a minimum QoS. (One request for this feature came from flash based storage people who wanted to avoid writing out at all costs - they of course needed some pdflush hacks as well) max_ratio - allows one to assign a maximum portion of the dirty limit to a particular device. This is useful in situations where you want to avoid one device taking all or most of the write-back cache. Eg. an NFS mount that is prone to get stuck, or a FUSE mount which you don't trust to play fair. Add "min_ratio" to /sys/class/bdi. This indicates the minimum percentage of the global dirty threshold allocated to this bdi. [mszeredi@suse.cz] - fix parsing in min_ratio_store() - document new sysfs attribute Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30mm: bdi: export BDI attributes in sysfsPeter Zijlstra
Provide a place in sysfs (/sys/class/bdi) for the backing_dev_info object. This allows us to see and set the various BDI specific variables. In particular this properly exposes the read-ahead window for all relevant users and /sys/block/<block>/queue/read_ahead_kb should be deprecated. With patient help from Kay Sievers and Greg KH [mszeredi@suse.cz] - split off NFS and FUSE changes into separate patches - document new sysfs attributes under Documentation/ABI - do bdi_class_init as a core_initcall, otherwise the "default" BDI won't be initialized - remove bdi_init_fmt macro, it's not used very much [akpm@linux-foundation.org: fix ia64 warning] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Greg KH <greg@kroah.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
