path: root/Documentation/ABI
2009-02-18Bernhard has movedBernhard Walle
Since I don't work for SUSE any more and the bwalle@suse.de address is invalid, correct it in the copyright headers and documentation. Signed-off-by: Bernhard Walle <bernhard.walle@gmx.de> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08regulator: sysfs attribute reduction (v2)David Brownell
Clean up the sysfs interface to regulators by only exposing the attributes that can be properly displayed. For example: when a particular regulator method is needed to display the value, only create that attribute when that method exists. This cleaned-up interface is much more comprehensible. Most regulators only support a subset of the possible methods, so often more than half the attributes would be meaningless. Many "not defined" values are no longer necessary. (But handling of out-of-range values still looks a bit iffy.) Documentation is updated to reflect that few of the attributes are *always* present, and to briefly explain why a regulator may not have a given attribute. This adds object code, about a dozen bytes more than was removed by the preceding patch, but saves a bunch of per-regulator data associated with the now-removed attributes. So there's a net reduction in memory footprint. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-01-06mm: show node to memory section relationship with symlinks in sysfsGary Hade
Show node to memory section relationship with symlinks in sysfs Add /sys/devices/system/node/nodeX/memoryY symlinks for all the memory sections located on nodeX. For example: /sys/devices/system/node/node1/memory135 -> ../../memory/memory135 indicates that memory section 135 resides on node1. Also revises documentation to cover this change as well as updating Documentation/ABI/testing/sysfs-devices-memory to include descriptions of memory hotremove files 'phys_device', 'phys_index', and 'state' that were previously not described there. In addition to it always being a good policy to provide users with the maximum possible amount of physical location information for resources that can be hot-added and/or hot-removed, the following are some (but likely not all) of the user benefits provided by this change. Immediate: - Provides information needed to determine the specific node on which a defective DIMM is located. This will reduce system downtime when the node or defective DIMM is swapped out. - Prevents unintended onlining of a memory section that was previously offlined due to a defective DIMM. This could happen during node hot-add when the user or node hot-add assist script onlines _all_ offlined sections due to user or script inability to identify the specific memory sections located on the hot-added node. The consequences of reintroducing the defective memory could be ugly. - Provides information needed to vary the amount and distribution of memory on specific nodes for testing or debugging purposes. Future: - Will provide information needed to identify the memory sections that need to be offlined prior to physical removal of a specific node. Symlink creation during boot was tested on 2-node x86_64, 2-node ppc64, and 2-node ia64 systems. Symlink creation during physical memory hot-add tested on a 2-node x86_64 system. Signed-off-by: Gary Hade <garyhade@us.ibm.com> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-19Merge branch 'master' of ↵David Vrabel
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-upstream
2008-11-19uwb: add basic radio managerDavid Vrabel
The UWB radio manager coordinates the use of the radio between the PALs that may be using it. PALs request use of the radio with uwb_radio_start() and the radio manager will start beaconing if its not already doing so. When the last PAL has called uwb_radio_stop() beaconing will be stopped. In the future, the radio manager will have a more sophisticated channel selection algorithm, probably following the Channel Selection Policy from the WiMedia Alliance when it is finalized. For now, channel 9 (BG1, TFC1) is selected. The user may override the channel selected by the radio manager and may force the radio to stop beaconing. The WUSB Host Controller PAL makes use of this and there are two new debug PAL commands that can be used for testing. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-11-12Add c2 port supportRodolfo Giometti
C2port implements a two wire serial communication protocol (bit banging) designed to enable in-system programming, debugging, and boundary-scan testing on low pin-count Silicon Labs devices. Currently this code supports only flash programming through sysfs interface but extensions shoud be easy to add. Signed-off-by: Rodolfo Giometti <giometti@linux.it> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-28ACPI: bugfix reporting of event handler statusZhang Rui
Introduce a new flag showing whether the event has an event handler/method. For all the GPEs and Fixed Events, 1. ACPI_EVENT_FLAG_HANDLE is cleared, it's an "invalid" ACPI event. 2. Both ACPI_EVENT_FLAG_HANDLE and ACPI_EVENT_FLAG_DISABLE are set, it's "disabled". 3. Both ACPI_EVENT_FLAG_HANDLE and ACPI_EVENT_FLAG_ENABLE are set, it's "enabled". 4. Both ACPI_EVENT_FLAG_HANDLE and ACPI_EVENT_FLAG_WAKE_ENABLE are set, it's "wake_enabled". Among other things, this prevents incorrect reporting of ACPI events as being "invalid" when it's really just (temporarily) "disabled". Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-20Merge branch 'master' into for-upstreamDavid Vrabel
Conflicts: Documentation/ABI/testing/sysfs-bus-usb drivers/Makefile
2008-10-17USB: Export if an interface driver supports autosuspend.Sarah Sharp
Create a new sysfs file per interface named supports_autosuspend. This file returns true if an interface driver's .supports_autosuspend flag is set. It also returns true if the interface is unclaimed (since the USB core will autosuspend a device if an interface is not claimed). This new sysfs file will be useful for user space scripts to test whether a USB device correctly auto-suspends. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: add USB test and measurement class driverGreg Kroah-Hartman
This driver was originaly written by Stefan Kopp, but massively reworked by Greg for submission. Thanks to Felipe Balbi <me@felipebalbi.com> for lots of work in cleaning up this driver. Thanks to Oliver Neukum <oliver@neukum.org> for reviewing previous versions and pointing out problems. Cc: Stefan Kopp <stefan_kopp@agilent.com> Cc: Marcel Janssen <korgull@home.nl> Cc: Felipe Balbi <me@felipebalbi.com> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: Added driver for a Delcom USB 7-segment LED DisplayHarrison Metzger
Added basic support for a Delcom USB 7-segment LED Display Signed-off by: Harrison Metzger <harrisonmetz@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16profiling: dynamically enable readprofile at runtimeDave Hansen
Way too often, I have a machine that exhibits some kind of crappy behavior. The CPU looks wedged in the kernel or it is spending way too much system time and I wonder what is responsible. I try to run readprofile. But, of course, Ubuntu doesn't enable it by default. Dang! The reason we boot-time enable it is that it takes a big bufffer that we generally can only bootmem alloc. But, does it hurt to at least try and runtime-alloc it? To use: echo 2 > /sys/kernel/profile Then run readprofile like normal. This should fix the compile issue with allmodconfig. I've compile-tested on a bunch more configs now including a few more architectures. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13regulator: Export regulator name via sysfsMark Brown
Provide a new file 'name' in the regulator sysfs class with a human readable name for the regulator for use in applications. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2008-10-13regulator: update email address for Liam GirdwoodLiam Girdwood
Additionally added another web resource for voltage regulators. Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2008-09-17uwb: document UWB and WUSB sysfs filesDavid Vrabel
Add some brief documentation on the UWB and WUSB related sysfs files. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-09-13Documentation/ABI: /sys/class/gpioDavid Brownell
Provide summary ABI docs about the /sys/class/gpio files. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-02sysfs: document files in /sys/firmware/sgi_uv/Russ Anderson
Document files in /sys/firmware/sgi_uv/. Signed-off-by: Russ Anderson <rja@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30regulator: documentation - ABILiam Girdwood
This adds documentation describing the sysfs ABI used by the regulator framework. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com>
2008-07-24memory-hotplug: add sysfs removable attribute for hotplug memory removeBadari Pulavarty
Memory may be hot-removed on a per-memory-block basis, particularly on POWER where the SPARSEMEM section size often matches the memory-block size. A user-level agent must be able to identify which sections of memory are likely to be removable before attempting the potentially expensive operation. This patch adds a file called "removable" to the memory directory in sysfs to help such an agent. In this patch, a memory block is considered removable if; o It contains only MOVABLE pageblocks o It contains only pageblocks with free pages regardless of pageblock type On the other hand, a memory block starting with a PageReserved() page will never be considered removable. Without this patch, the user-agent is forced to choose a memory block to remove randomly. Sample output of the sysfs files: ./memory/memory0/removable: 0 ./memory/memory1/removable: 0 ./memory/memory2/removable: 0 ./memory/memory3/removable: 0 ./memory/memory4/removable: 0 ./memory/memory5/removable: 0 ./memory/memory6/removable: 0 ./memory/memory7/removable: 1 ./memory/memory8/removable: 0 ./memory/memory9/removable: 0 ./memory/memory10/removable: 0 ./memory/memory11/removable: 0 ./memory/memory12/removable: 0 ./memory/memory13/removable: 0 ./memory/memory14/removable: 0 ./memory/memory15/removable: 0 ./memory/memory16/removable: 0 ./memory/memory17/removable: 1 ./memory/memory18/removable: 1 ./memory/memory19/removable: 1 ./memory/memory20/removable: 1 ./memory/memory21/removable: 1 ./memory/memory22/removable: 1 Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24hugetlb: new sysfs interfaceNishanth Aravamudan
Provide new hugepages user APIs that are more suited to multiple hstates in sysfs. There is a new directory, /sys/kernel/hugepages. Underneath that directory there will be a directory per-supported hugepage size, e.g.: /sys/kernel/hugepages/hugepages-64kB /sys/kernel/hugepages/hugepages-16384kB /sys/kernel/hugepages/hugepages-16777216kB corresponding to 64k, 16m and 16g respectively. Within each hugepages-size directory there are a number of files, corresponding to the tracked counters in the hstate, e.g.: /sys/kernel/hugepages/hugepages-64/nr_hugepages /sys/kernel/hugepages/hugepages-64/nr_overcommit_hugepages /sys/kernel/hugepages/hugepages-64/free_hugepages /sys/kernel/hugepages/hugepages-64/resv_hugepages /sys/kernel/hugepages/hugepages-64/surplus_hugepages Of these files, the first two are read-write and the latter three are read-only. The size of the hugepage being manipulated is trivially deducible from the enclosing directory and is always expressed in kB (to match meminfo). [dave@linux.vnet.ibm.com: fix build] [nacc@us.ibm.com: hugetlb: hang off of /sys/kernel/mm rather than /sys/kernel] [nacc@us.ibm.com: hugetlb: remove CONFIG_SYSFS dependency] Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: create /sys/kernel/mmNishanth Aravamudan
Add a kobject to create /sys/kernel/mm when sysfs is mounted. The kobject will exist regardless. This will allow for the hugepage related sysfs directories to exist under the mm "subsystem" directory. Add an ABI file appropriately. [kosaki.motohiro@jp.fujitsu.com: fix build] Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21sysfs: add /sys/dev/{char,block} to lookup sysfs path by major:minorDan Williams
Why?: There are occasions where userspace would like to access sysfs attributes for a device but it may not know how sysfs has named the device or the path. For example what is the sysfs path for /dev/disk/by-id/ata-ST3160827AS_5MT004CK? With this change a call to stat(2) returns the major:minor then userspace can see that /sys/dev/block/8:32 links to /sys/block/sdc. What are the alternatives?: 1/ Add an ioctl to return the path: Doable, but sysfs is meant to reduce the need to proliferate ioctl interfaces into the kernel, so this seems counter productive. 2/ Use udev to create these symlinks: Also doable, but it adds a udev dependency to utilities that might be running in a limited environment like an initramfs. 3/ Do a full-tree search of sysfs. [kay.sievers@vrfy.org: fix duplicate registrations] [kay.sievers@vrfy.org: cleanup suggestions] Cc: Neil Brown <neilb@suse.de> Cc: Tejun Heo <htejun@gmail.com> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Reviewed-by: SL Baur <steve@xemacs.org> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Mark Lord <lkml@rtr.ca> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-16ACPI: Enhance /sys/firmware/interrupts to allow enable/disable/clear from ↵Zhang Rui
user-space Allow users to enable/disable/clear a specific & valid GPE/Fixed Event in user space. This is useful for debugging, especially for some interrupt storm issues. All wakeup GPEs are disabled and they can not be enabled at runtime, and we mark them as invalid. All GPEs that don't have a _Lxx/_Exx method are marked as invalid. All Fixed Events that don't have an event handler are marked as invalid and they can't be enabled until an event handler is registered. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Ling Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-14Merge branch 'x86/for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (821 commits) x86: make 64bit hpet_set_mapping to use ioremap too, v2 x86: get x86_phys_bits early x86: max_low_pfn_mapped fix #4 x86: change _node_to_cpumask_ptr to return const ptr x86: I/O APIC: remove an IRQ2-mask hack x86: fix numaq_tsc_disable calling x86, e820: remove end_user_pfn x86: max_low_pfn_mapped fix, #3 x86: max_low_pfn_mapped fix, #2 x86: max_low_pfn_mapped fix, #1 x86_64: fix delayed signals x86: remove conflicting nx6325 and nx6125 quirks x86: Recover timer_ack lost in the merge of the NMI watchdog x86: I/O APIC: Never configure IRQ2 x86: L-APIC: Always fully configure IRQ0 x86: L-APIC: Set IRQ0 as edge-triggered x86: merge dwarf2 headers x86: use AS_CFI instead of UNWIND_INFO x86: use ignore macro instead of hash comment x86: use matching CFI_ENDPROC ...
2008-07-14Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: (71 commits) [S390] sclp_tty: Fix scheduling while atomic bug. [S390] sclp_tty: remove ioctl interface. [S390] Remove P390 support. [S390] Cleanup vmcp printk messages. [S390] Cleanup lcs printk messages. [S390] Cleanup kprobes printk messages. [S390] Cleanup vmwatch printk messages. [S390] Cleanup dcssblk printk messages. [S390] Cleanup zfcp dumper printk messages. [S390] Cleanup vmlogrdr printk messages. [S390] Cleanup s390 debug feature print messages. [S390] Cleanup monreader printk messages. [S390] Cleanup appldata printk messages. [S390] Cleanup smsgiucv printk messages. [S390] Cleanup cpacf printk messages. [S390] Cleanup qeth print messages. [S390] Cleanup netiucv printk messages. [S390] Cleanup iucv printk messages. [S390] Cleanup sclp printk messages. [S390] Cleanup zcrypt printk messages. ...
2008-07-14[S390] cio: Introduce modalias for css bus.Cornelia Huck
Add modalias and subchannel type attributes for all subchannels. I/O subchannel specific attributes are now created in io_subchannel_probe(). modalias and subchannel type are also added to the uevent for the css bus. Also make the css modalias known. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-07-08sysfs: add /sys/firmware/memmapBernhard Walle
This patch adds /sys/firmware/memmap interface that represents the BIOS (or Firmware) provided memory map. The tree looks like: /sys/firmware/memmap/0/start (hex number) end (hex number) type (string) ... /1/start end type With the following shell snippet one can print the memory map in the same form the kernel prints itself when booting on x86 (the E820 map). --------- 8< -------------------------- #!/bin/sh cd /sys/firmware/memmap for dir in * ; do start=$(cat $dir/start) end=$(cat $dir/end) type=$(cat $dir/type) printf "%016x-%016x (%s)\n" $start $[ $end +1] "$type" done --------- >8 -------------------------- That patch only provides the needed interface: 1. The sysfs interface. 2. The structure and enumeration definition. 3. The function firmware_map_add() and firmware_map_add_early() that should be called from architecture code (E820/EFI, for example) to add the contents to the interface. If the kernel is compiled without CONFIG_FIRMWARE_MEMMAP, the interface does nothing without cluttering the architecture-specific code with #ifdef's. The purpose of the new interface is kexec: While /proc/iomem represents the *used* memory map (e.g. modified via kernel parameters like 'memmap' and 'mem'), the /sys/firmware/memmap tree represents the unmodified memory map provided via the firmware. So kexec can: - use the original memory map for rebooting, - use the /proc/iomem for setting up the ELF core headers for kdump case that should only represent the memory of the system. The patch has been tested on i386 and x86_64. Signed-off-by: Bernhard Walle <bwalle@suse.de> Acked-by: Greg KH <gregkh@suse.de> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: kexec@lists.infradead.org Cc: yhlu.kernel@gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-03block: Data integrity infrastructure documentationMartin K. Petersen
Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-24fuse: fix bdi naming conflictMiklos Szeredi
Fuse allocates a separate bdi for each filesystem, and registers them in sysfs with "MAJOR:MINOR" of sb->s_dev (st_dev). This works fine for anon devices normally used by fuse, but can conflict with an already registered BDI for "fuseblk" filesystems, where sb->s_dev represents a real block device. In particularl this happens if a non-partitioned device is being mounted. Fix by registering with a different name for "fuseblk" filesystems. Thanks to Ioan Ionita for the bug report. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Reported-by: Ioan Ionita <opslynx@gmail.com> Tested-by: Ioan Ionita <opslynx@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30mm: bdi: move statistics to debugfsMiklos Szeredi
Move BDI statistics to debugfs: /sys/kernel/debug/bdi/<bdi>/stats Use postcore_initcall() to initialize the sysfs class and debugfs, because debugfs is initialized in core_initcall(). Update descriptions in ABI documentation. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30mm: bdi: allow setting a maximum for the bdi dirty limitPeter Zijlstra
Add "max_ratio" to /sys/class/bdi. This indicates the maximum percentage of the global dirty threshold allocated to this bdi. [mszeredi@suse.cz] - fix parsing in max_ratio_store(). - export bdi_set_max_ratio() to modules - limit bdi_dirty with bdi->max_ratio - document new sysfs attribute Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30mm: bdi: allow setting a minimum for the bdi dirty limitPeter Zijlstra
Under normal circumstances each device is given a part of the total write-back cache that relates to its current avg writeout speed in relation to the other devices. min_ratio - allows one to assign a minimum portion of the write-back cache to a particular device. This is useful in situations where you might want to provide a minimum QoS. (One request for this feature came from flash based storage people who wanted to avoid writing out at all costs - they of course needed some pdflush hacks as well) max_ratio - allows one to assign a maximum portion of the dirty limit to a particular device. This is useful in situations where you want to avoid one device taking all or most of the write-back cache. Eg. an NFS mount that is prone to get stuck, or a FUSE mount which you don't trust to play fair. Add "min_ratio" to /sys/class/bdi. This indicates the minimum percentage of the global dirty threshold allocated to this bdi. [mszeredi@suse.cz] - fix parsing in min_ratio_store() - document new sysfs attribute Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30mm: bdi: export BDI attributes in sysfsPeter Zijlstra
Provide a place in sysfs (/sys/class/bdi) for the backing_dev_info object. This allows us to see and set the various BDI specific variables. In particular this properly exposes the read-ahead window for all relevant users and /sys/block/<block>/queue/read_ahead_kb should be deprecated. With patient help from Kay Sievers and Greg KH [mszeredi@suse.cz] - split off NFS and FUSE changes into separate patches - document new sysfs attributes under Documentation/ABI - do bdi_class_init as a core_initcall, otherwise the "default" BDI won't be initialized - remove bdi_init_fmt macro, it's not used very much [akpm@linux-foundation.org: fix ia64 warning] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Greg KH <greg@kroah.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-23Merge git://git.infradead.org/~dedekind/ubi-2.6David Woodhouse
2008-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/pci-2.6: (42 commits) PCI: Change PCI subsystem MAINTAINER PCI: pci-iommu-iotlb-flushing-speedup PCI: pci_setup_bridge() mustn't be __devinit PCI: pci_bus_size_cardbus() mustn't be __devinit PCI: pci_scan_device() mustn't be __devinit PCI: pci_alloc_child_bus() mustn't be __devinit PCI: replace remaining __FUNCTION__ occurrences PCI: Hotplug: fakephp: Return success, not ENODEV, when bus rescan is triggered PCI: Hotplug: Fix leaks in IBM Hot Plug Controller Driver - ibmphp_init_devno() PCI: clean up resource alignment management PCI: aerdrv_acpi.c: remove unneeded NULL check PCI: Update VIA CX700 quirk PCI: Expose PCI VPD through sysfs PCI: iommu: iotlb flushing PCI: simplify quirk debug output PCI: iova RB tree setup tweak PCI: parisc: use generic pci_enable_resources() PCI: ppc: use generic pci_enable_resources() PCI: powerpc: use generic pci_enable_resources() PCI: ia64: use generic pci_enable_resources() ...
2008-04-20PCI: Expose PCI VPD through sysfsBen Hutchings
Vital Product Data (VPD) may be exposed by PCI devices in several ways. It is generally unsafe to read this information through the existing interfaces to user-land because of stateful interfaces. This adds: - abstract operations for VPD access (struct pci_vpd_ops) - VPD state information in struct pci_dev (struct pci_vpd) - an implementation of the VPD access method specified in PCI 2.2 (in access.c) - a 'vpd' binary file in sysfs directories for PCI devices with VPD operations defined It adds a probe for PCI 2.2 VPD in pci_scan_device() and release of VPD state in pci_release_dev(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19Firmware: add iSCSI iBFT SupportKonrad Rzeszutek
Add /sysfs/firmware/ibft/[initiator|targetX|ethernetX] directories along with text properties which export the the iSCSI Boot Firmware Table (iBFT) structure. What is iSCSI Boot Firmware Table? It is a mechanism for the iSCSI tools to extract from the machine NICs the iSCSI connection information so that they can automagically mount the iSCSI share/target. Currently the iSCSI information is hard-coded in the initrd. The /sysfs entries are read-only one-name-and-value fields. The usual set of data exposed is: # for a in `find /sys/firmware/ibft/ -type f -print`; do echo -n "$a: "; cat $a; done /sys/firmware/ibft/target0/target-name: iqn.2007.com.intel-sbx44:storage-10gb /sys/firmware/ibft/target0/nic-assoc: 0 /sys/firmware/ibft/target0/chap-type: 0 /sys/firmware/ibft/target0/lun: 00000000 /sys/firmware/ibft/target0/port: 3260 /sys/firmware/ibft/target0/ip-addr: 192.168.79.116 /sys/firmware/ibft/target0/flags: 3 /sys/firmware/ibft/target0/index: 0 /sys/firmware/ibft/ethernet0/mac: 00:11:25:9d:8b:01 /sys/firmware/ibft/ethernet0/vlan: 0 /sys/firmware/ibft/ethernet0/gateway: 192.168.79.254 /sys/firmware/ibft/ethernet0/origin: 0 /sys/firmware/ibft/ethernet0/subnet-mask: 255.255.252.0 /sys/firmware/ibft/ethernet0/ip-addr: 192.168.77.41 /sys/firmware/ibft/ethernet0/flags: 7 /sys/firmware/ibft/ethernet0/index: 0 /sys/firmware/ibft/initiator/initiator-name: iqn.2007-07.com:konrad.initiator /sys/firmware/ibft/initiator/flags: 3 /sys/firmware/ibft/initiator/index: 0 For full details of the IBFT structure please take a look at: ftp://ftp.software.ibm.com/systems/support/system_x_pdf/ibm_iscsi_boot_firmware_table_v1.02.pdf [akpm@linux-foundation.org: fix build] Signed-off-by: Konrad Rzeszutek <konradr@linux.vnet.ibm.com> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: Peter Jones <pjones@redhat.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-18ocfs2: Move /sys/o2cb to /sys/fs/o2cbMark Fasheh
/sys/fs is where we really want file system specific sysfs objects. Ocfs2-tools has been updated to look in /sys/fs/o2cb. We can maintain backwards compatibility with old ocfs2-tools by using a sysfs symlink. After some time (2 years), the symlink can be safely removed. This patch also adds documentation to make it easier for people to figure out what /sys/fs/o2cb is used for. Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-04-18ocfs2: Document /sys/fs/ocfs2Joel Becker
Add ABI documentation for these files: /sys/fs/ocfs2/max_locking_protocol /sys/fs/ocfs2/loaded_cluster_plugins /sys/fs/ocfs2/active_cluster_plugin /sys/fs/ocfs2/cluster_stack Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-04-17Documentation: add UBI sysfs ABI docsArtem Bityutskiy
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Acked-by: Greg KH <greg@kroah.com>
2008-02-08Enhanced partition statistics: documentation updateJerome Marchand
Update the documentation to reflect the change in userspace interface. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-07Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (112 commits) ACPI: fix build warning Revert "cpuidle: build fix for non-x86" ACPI: update intrd DSDT override console messages ACPI: update DSDT override documentation ACPI: Add "acpi_no_initrd_override" kernel parameter ACPI: its a directory not a folder.... ACPI: misc cleanups ACPI: add missing prink prefix strings ACPI: cleanup acpi.h ACPICA: fix CONFIG_ACPI_DEBUG_FUNC_TRACE build ACPI: video: Ignore ACPI video devices that aren't present in hardware ACPI: video: reset brightness on resume ACPI: video: call ACPI notifier chain for ACPI video notifications ACPI: create notifier chain to get hotkey events to graphics driver ACPI: video: delete unused display switch on hotkey event code ACPI: video: create "brightness_switch_enabled" modparam cpuidle: Add a poll_idle method ACPI: cpuidle: Support C1 idle time accounting ACPI: enable MWAIT for C1 idle ACPI: idle: Fix acpi_safe_halt usages and interrupt enabling/disabling ...
2008-02-07Documentation: create new scheduler/ subdirectoryJ. Bruce Fields
The top-level Documentation/ directory is unmanageably large, so we should take any obvious opportunities to move stuff into subdirectories. These sched-*.txt files seem an obvious easy case. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06ACPI: create /sys/firmware/acpi/interruptsLen Brown
See Documentation/ABI/testing/sysfs-firmware-acpi Based-on-original-patch-by: Luming Yu <luming.yu@intel.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01USB: Add documentation for USB suspend statistics.Sarah Sharp
This documents two newly created files: /sys/bus/usb/device/.../power/connected_duration /sys/bus/usb/device/.../power/active_duration Documentation was placed in Documentation/ABI/testing, since that's where the documentation is for the other USB sysfs power files. Signed-off-by: Sarah Sharp <sarah.a.sharp@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-12-17Add Documentation for FAIR_USER_SCHED sysfs filesDhaval Giani
This patch adds documentation about /sys/kernel/uids/<uid>/cpu_share to Documentation/ABI. Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: add power/persist device attributeAlan Stern
This patch (as920) adds an extra level of protection to the USB-Persist facility. Now it will apply by default only to hubs; for all other devices the user must enable it explicitly by setting the power/persist device attribute. The disconnect_all_children() routine in hub.c has been removed and its code placed inline. This is the way it was originally as part of hub_pre_reset(); the revised usage in hub_reset_resume() is sufficiently different that the code can no longer be shared. Likewise, mark_children_for_reset() is now inline as part of hub_reset_resume(). The end result looks much cleaner than before. The sysfs interface is updated to add the new attribute file, and there are corresponding documentation updates. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-10ieee1394: remove old isochronous ABIStefan Richter
Based on patch "the scheduled removal of RAW1394_REQ_ISO_{SEND,LISTEN}" from Adrian Bunk, November 20 2006. This patch also removes the underlying facilities in ohci1394 and disables them in pcilynx. That is, hpsb_host_driver.devctl() and hpsb_host_driver.transmit_packet() are no longer used for iso reception and transmission. Since video1394 and dv1394 only work with ohci1394 and raw1394's rawiso interface has never been implemented in pcilynx, pcilynx is now no longer useful for isochronous applications. raw1394 will still handle the request types but will complete the requests with errors that indicate API version conflicts. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-27USB: add power/level sysfs attributeAlan Stern
This patch (as874) adds another piece to the user-visible part of the USB autosuspend interface. The new power/level sysfs attribute allows users to force the device on (with autosuspend off), force the device to sleep (with autoresume off), or return to normal automatic operation. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
