This is the 4.14.164 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6q.c
arch/arm/mach-imx/cpuidle-imx6sx.c
arch/arm64/kernel/cpu_errata.c
arch/arm64/kvm/hyp/tlb.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/gpio/gpio-vf610.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/input/keyboard/imx_keypad.c
drivers/input/keyboard/snvs_pwrkey.c
drivers/mmc/core/block.c
drivers/mmc/core/queue.h
drivers/mmc/host/sdhci-esdhc-imx.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/ethernet/freescale/fec_main.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
include/net/tcp.h
sound/soc/fsl/Kconfig
sound/soc/fsl/fsl_esai.c
commit db4d30fbb71b47e4ecb11c4efa5d8aad4b03dfae upstream.
Some processors may incur a machine check error possibly resulting in an
unrecoverable CPU lockup when an instruction fetch encounters a TLB
multi-hit in the instruction TLB. This can occur when the page size is
changed along with either the physical address or cache type. The relevant
erratum can be found here:
https://bugzilla.kernel.org/show_bug.cgi?id=205195
There are other processors affected for which the erratum does not fully
disclose the impact.
This issue affects both bare-metal x86 page tables and EPT.
It can be mitigated by either eliminating the use of large pages or by
using careful TLB invalidations when changing the page size in the page
tables.
Just like Spectre, Meltdown, L1TF and MDS, a new bit has been allocated in
MSR_IA32_ARCH_CAPABILITIES (PSCHANGE_MC_NO) and will be set on CPUs which
are mitigated against this issue.
Signed-off-by: Vineela Tummalapalli <vineela.tummalapalli@intel.com>
Co-developed-by: Pawan Gupta <pawan.kumar.gupta@linux.intel.com>
Signed-off-by: Pawan Gupta <pawan.kumar.gupta@linux.intel.com>
commit a7a248c593e4fd7a67c50b5f5318fe42a0db335e upstream.
Add the documenation for TSX Async Abort. Include the description of
the issue, how to check the mitigation state, control the mitigation,
guidance for system administrators.
[ bp: Add proper SPDX tags, touch ups by Josh and me. ]
Co-developed-by: Antonio Gomez Iglesias <antonio.gomez.iglesias@intel.com>
Signed-off-by: Antonio Gomez Iglesias <antonio.gomez.iglesias@intel.com>
Reviewed-by: Mark Gross <mgross@linux.intel.com>
Reviewed-by: Tony Luck <tony.luck@intel.com>
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
[ Upstream commit 36815b416fa48766ac5a98e4b2dc3ebc5887222e ]
Permit mux_id values up to 254 to be used in qmimux_register_device()
for compatibility with ip(8) and the rmnet driver.
Fixes: c6adf77953bc ("net: usb: qmi_wwan: add qmap mux protocol support")
Cc: Daniele Palmas <dnlplm@gmail.com>
Signed-off-by: Reinhard Speyerer <rspmn@arcor.de>
commit 5999bbe7a6ea3c62029532ec84dc06003a1fa258 upstream
Add the initial MDS vulnerability documentation.
Reviewed-by: Jon Masters <jcm@redhat.com>
commit 65fd4cb65b2dad97feb8330b6690445910b56d6a upstream
Move L!TF to a separate directory so the MDS stuff can be added at the
side. Otherwise the all hardware vulnerabilites have their own top level
entry. Should have done that right away.
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit 8a4b06d391b0a42a373808979b5028f5c84d9c6a upstream
Add the sysfs reporting file for MDS. It exposes the vulnerability and
mitigation state similar to the existing files for the other speculative
hardware vulnerabilities.
Reviewed-by: Borislav Petkov <bp@suse.de>
Tested-by: Jon Masters <jcm@redhat.com>
It is an experimental feature, and tested by internal team for
Carplay feature.
Signed-off-by: Peter Chen <peter.chen@nxp.com>
commit d90a7a0ec83fb86622cd7dae23255d3c50a99ec8 upstream
Introduce the 'l1tf=' kernel command line option to allow for boot-time
switching of mitigation that is used on processors affected by L1TF.
The possible values are:
full
Provides all available mitigations for the L1TF vulnerability. Disables
SMT and enables all mitigations in the hypervisors. SMT control via
/sys/devices/system/cpu/smt/control is still possible after boot.
Hypervisors will issue a warning when the first VM is started in
a potentially insecure configuration, i.e. SMT enabled or L1D flush
disabled.
full,force
Same as 'full', but disables SMT control. Implies the 'nosmt=force'
command line option. sysfs control of SMT and the hypervisor flush
control is disabled.
flush
Leaves SMT enabled and enables the conditional hypervisor mitigation.
Hypervisors will issue a warning when the first VM is started in a
disabled.
flush,nosmt
Disables SMT and enables the conditional hypervisor mitigation. SMT
control via /sys/devices/system/cpu/smt/control is still possible
after boot. If SMT is reenabled or flushing disabled at runtime
hypervisors will issue a warning.
flush,nowarn
Same as 'flush', but hypervisors will not warn when
a VM is started in a potentially insecure configuration.
off
Disables hypervisor mitigations and doesn't emit any warnings.
Default is 'flush'.
Let KVM adhere to these semantics, which means:
- 'lt1f=full,force' : Performe L1D flushes. No runtime control
possible.
- 'l1tf=full'
- 'l1tf-flush'
- 'l1tf=flush,nosmt' : Perform L1D flushes and warn on VM start if
SMT has been runtime enabled or L1D flushing
has been run-time enabled
- 'l1tf=flush,nowarn' : Perform L1D flushes and no warnings are emitted.
- 'l1tf=off' : L1D flushes are not performed and no warnings
are emitted.
KVM can always override the L1D flushing behavior using its 'vmentry_l1d_flush'
module parameter except when lt1f=full,force is set.
This makes KVM's private 'nosmt' option redundant, and as it is a bit
non-systematic anyway (this is something to control globally, not on
hypervisor level), remove that option.
Add the missing Documentation entry for the l1tf vulnerability sysfs file
while at it.
Tested-by: Jiri Kosina <jkosina@suse.cz>
Link: https://lkml.kernel.org/r/20180713142323.202758176@linutronix.de
commit 05736e4ac13c08a4a9b1ef2de26dd31a32cbee57 upstream
Provide a command line and a sysfs knob to control SMT.
The command line options are:
'nosmt': Enumerate secondary threads, but do not online them
'nosmt=force': Ignore secondary threads completely during enumeration
via MP table and ACPI/MADT.
The sysfs control file has the following states (read/write):
'on': SMT is enabled. Secondary threads can be freely onlined
'off': SMT is disabled. Secondary threads, even if enumerated
cannot be onlined
'forceoff': SMT is permanentely disabled. Writes to the control
file are rejected.
'notsupported': SMT is not supported by the CPU
The command line option 'nosmt' sets the sysfs control to 'off'. This
can be changed to 'on' to reenable SMT during runtime.
The command line option 'nosmt=force' sets the sysfs control to
'forceoff'. This cannot be changed during runtime.
When SMT is 'on' and the control file is changed to 'off' then all online
secondary threads are offlined and attempts to online a secondary thread
later on are rejected.
When SMT is 'off' and the control file is changed to 'on' then secondary
threads can be onlined again. The 'off' -> 'on' transition does not
automatically online the secondary threads.
When the control file is set to 'forceoff', the behaviour is the same as
setting it to 'off', but the operation is irreversible and later writes to
the control file are rejected.
When the control status is 'notsupported' then writes to the control file
are rejected.
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
commit b6c84ba22ff3a198eb8d5552cf9b8fda1d792e54 upstream.
Currently we see a kernel-oops reported on Power-9 while attaching a
context to an AFU, with radix-mode and sysfs attr 'prefault_mode' set
to anything other than 'none'. The backtrace of the oops is of this
form:
Unable to handle kernel paging request for data at address 0x00000080
Faulting instruction address: 0xc00800000bcf3b20
cpu 0x1: Vector: 300 (Data Access) at [c00000037f003800]
pc: c00800000bcf3b20: cxl_load_segment+0x178/0x290 [cxl]
lr: c00800000bcf39f0: cxl_load_segment+0x48/0x290 [cxl]
sp: c00000037f003a80
msr: 9000000000009033
dar: 80
dsisr: 40000000
current = 0xc00000037f280000
paca = 0xc0000003ffffe600 softe: 3 irq_happened: 0x01
pid = 3529, comm = afp_no_int
<snip>
cxl_prefault+0xfc/0x248 [cxl]
process_element_entry_psl9+0xd8/0x1a0 [cxl]
cxl_attach_dedicated_process_psl9+0x44/0x130 [cxl]
native_attach_process+0xc0/0x130 [cxl]
afu_ioctl+0x3f4/0x5e0 [cxl]
do_vfs_ioctl+0xdc/0x890
ksys_ioctl+0x68/0xf0
sys_ioctl+0x40/0xa0
system_call+0x58/0x6c
The issue is caused as on Power-8 the AFU attr 'prefault_mode' was
used to improve initial storage fault performance by prefaulting
process segments. However on Power-9 with radix mode we don't have
Storage-Segments that we can prefault. Also prefaulting process Pages
will be too costly and fine-grained.
Hence, since the prefaulting mechanism doesn't makes sense of
radix-mode, this patch updates prefault_mode_store() to not allow any
other value apart from CXL_PREFAULT_NONE when radix mode is enabled.
Fixes: f24be42aab37 ("cxl: Add psl9 specific code")
Cc: stable@vger.kernel.org # v4.12+
Signed-off-by: Vaibhav Jain <vaibhav@linux.ibm.com>
Acked-by: Frederic Barrat <fbarrat@linux.vnet.ibm.com>
Acked-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
commit c456442cd3a59eeb1d60293c26cbe2ff2c4e42cf upstream
Add the sysfs file for the new vulerability. It does not do much except
show the words 'Vulnerable' for recent x86 cores.
Intel cores prior to family 6 are known not to be vulnerable, and so are
some Atoms and some Xeon Phi.
It assumes that older Cyrix, Centaur, etc. cores are immune.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: Ingo Molnar <mingo@kernel.org>
commit b9a3589332c2a25fb7edad25a26fcaada3209126 upstream.
The name of the file is "current_timetamp_clock" not
"timestamp_clock".
Fixes: bc2b7dab629a ("iio:core: timestamping clock selection support")
Cc: Gregor Boirie <gregor.boirie@parrot.com>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
commit 9ecccfaa7cb5249bd31bdceb93fcf5bedb8a24d8 upstream.
Fixes: 87590ce6e ("sysfs/cpu: Add vulnerability folder")
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
commit 87590ce6e373d1a5401f6539f0c59ef92dd924a9 upstream.
As the meltdown/spectre problem affects several CPU architectures, it makes
sense to have common way to express whether a system is affected by a
particular vulnerability or not. If affected the way to express the
mitigation should be common as well.
Create /sys/devices/system/cpu/vulnerabilities folder and files for
meltdown, spectre_v1 and spectre_v2.
Allow architectures to override the show function.
Cc: Linus Torvalds <torvalds@linuxfoundation.org>
Cc: David Woodhouse <dwmw@amazon.co.uk>
Link: https://lkml.kernel.org/r/20180107214913.096657732@linutronix.de
MIPS will soon not be a part of Imagination Technologies, and as such
many @imgtec.com email addresses will no longer be valid. This patch
updates the addresses for those who:
- Have 10 or more patches in mainline authored using an @imgtec.com
email address, or any patches dated within the past year.
- Are still with Imagination but leaving as part of the MIPS business
unit, as determined from an internal email address list.
- Haven't already updated their email address (ie. JamesH) or expressed
a desire to be excluded (ie. Maciej).
- Acked v2 or earlier of this patch, which leaves Deng-Cheng, Matt &
myself.
New addresses are of the form firstname.lastname@mips.com, and all
verified against an internal email address list. An entry is added to
.mailmap for each person such that get_maintainer.pl will report the new
addresses rather than @imgtec.com addresses which will soon be dead.
Instances of the affected addresses throughout the tree are then
mechanically replaced with the new @mips.com address.
Signed-off-by: Paul Burton <paul.burton@mips.com>
Cc: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com>
Cc: Deng-Cheng Zhu <dengcheng.zhu@mips.com>
Acked-by: Dengcheng Zhu <dengcheng.zhu@mips.com>
Cc: Matt Redfearn <matt.redfearn@imgtec.com>
Cc: Matt Redfearn <matt.redfearn@mips.com>
Acked-by: Matt Redfearn <matt.redfearn@mips.com>
Cc: linux-mips@linux-mips.org
Cc: trivial@kernel.org
This reverts commit 0cc2b4e5a020 (PM / QoS: Fix device resume latency PM
QoS) as it introduced regressions on multiple systems and the fix-up
in commit 2a9a86d5c813 (PM / QoS: Fix default runtime_pm device resume
latency) does not address all of them.
The original problem that commit 0cc2b4e5a020 was attempting to fix
will be addressed later.
Fixes: 0cc2b4e5a020 (PM / QoS: Fix device resume latency PM QoS)
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
The special value of 0 for device resume latency PM QoS means
"no restriction", but there are two problems with that.
First, device resume latency PM QoS requests with 0 as the
value are always put in front of requests with positive
values in the priority lists used internally by the PM QoS
framework, causing 0 to be chosen as an effective constraint
value. However, that 0 is then interpreted as "no restriction"
effectively overriding the other requests with specific
restrictions which is incorrect.
Second, the users of device resume latency PM QoS have no
way to specify that *any* resume latency at all should be
avoided, which is an artificial limitation in general.
To address these issues, modify device resume latency PM QoS to
use S32_MAX as the "no constraint" value and 0 as the "no
latency at all" one and rework its users (the cpuidle menu
governor, the genpd QoS governor and the runtime PM framework)
to follow these changes.
Also add a special "n/a" value to the corresponding user space I/F
to allow user space to indicate that it cannot accept any resume
latencies at all for the given device.
Fixes: 85dc0b8a4019 (PM / QoS: Make it possible to expose PM QoS latency constraints)
Link: https://bugzilla.kernel.org/show_bug.cgi?id=197323
Reported-by: Reinette Chatre <reinette.chatre@intel.com>
Tested-by: Reinette Chatre <reinette.chatre@intel.com>
Acked-by: Alex Shi <alex.shi@linaro.org>
Cc: All applicable <stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging and IIO fixes from Greg KH:
"Here are a small number of patches to resolve some reported IIO and a
staging driver problem. Nothing major here, full details are in the
shortlog below.
All have been in linux-next with no reported issues"
* tag 'staging-4.14-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: bcm2835-audio: Fix memory corruption
iio: adc: at91-sama5d2_adc: fix probe error on missing trigger property
iio: adc: dln2-adc: fix build error
iio: dummy: events: Add missing break
staging: iio: ade7759: fix signed extension bug on shift of a u8
iio: pressure: zpa2326: Remove always-true check which confuses gcc
iio: proximity: as3935: noise detection + threshold changes
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus
Jonathan writes:
Second set of IIO fixes for the 4.14 cycle.
* ade7759
- Fix a signed extension bug.
* as3935
- The default noise and watch dog settings were such that the device
was unusuable in most applications. Add device tree parameters to
allow it to be configured to something that will actually work.
* at91-sama5d2 adc
- Fix handling of legacy device trees that don't provide the new
trigger edge property.
* dln2-adc
- Fix a missing Kconfig dependency on IIO_TRIGGERED_BUFFER.
* dummy driver
- Add a missing break so that writing in_voltage0_thresh_rising_en
doesn't always result in an error.
* zpa2326
- Drop a test for an always true condition so that gcc won't spit out
and unused variable warning.
When the VMA based swap readahead was introduced, a new knob
/sys/kernel/mm/swap/vma_ra_max_order
was added as the max window of VMA swap readahead. This is to make it
possible to use different max window for VMA based readahead and
original physical readahead. But Minchan Kim pointed out that this will
cause a regression because setting page-cluster sysctl to zero cannot
disable swap readahead with the change.
To fix the regression, the page-cluster sysctl is used as the max window
of both the VMA based swap readahead and original physical swap
readahead. If more fine grained control is needed in the future, more
knobs can be added as the subordinate knobs of the page-cluster sysctl.
The vma_ra_max_order knob is deleted. Because the knob was introduced
in v4.14-rc1, and this patch is targeting being merged before v4.14
releasing, there should be no existing users of this newly added ABI.
Link: http://lkml.kernel.org/r/20171011070847.16003-1-ying.huang@intel.com
Fixes: ec560175c0b6fce ("mm, swap: VMA based swap readahead")
Signed-off-by: "Huang, Ying" <ying.huang@intel.com>
Reported-by: Minchan Kim <minchan@kernel.org>
Acked-by: Minchan Kim <minchan@kernel.org>
Cc: Shaohua Li <shli@kernel.org>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Tim Chen <tim.c.chen@intel.com>
Update my imgtec.com and personal email address to my kernel.org one in
a few places as MIPS will soon no longer be part of Imagination
Technologies, and add mappings in .mailcap so get_maintainer.pl reports
the right address.
Signed-off-by: James Hogan <jhogan@kernel.org>
Most applications are too noisy to allow the default noise and
watchdog settings, and thus need to be configurable via DT
properties.
Also default settings to POR defaults on a reset, and register
distuber interrupts as noise since it prevents proper usage.
Cc: devicetree@vger.kernel.org
Signed-off-by: Matt Ranostay <matt.ranostay@konsulko.com>
Acked-by: Rob Herring <robh@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs
Pull f2fs updates from Jaegeuk Kim:
"In this round, we've mostly tuned f2fs to provide better user
experience for Android. Especially, we've worked on atomic write
feature again with SQLite community in order to support it officially.
And we added or modified several facilities to analyze and enhance IO
behaviors.
Major changes include:
- add app/fs io stat
- add inode checksum feature
- support project/journalled quota
- enhance atomic write with new ioctl() which exposes feature set
- enhance background gc/discard/fstrim flows with new gc_urgent mode
- add F2FS_IOC_FS{GET,SET}XATTR
- fix some quota flows"
* tag 'f2fs-for-4.14' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (63 commits)
f2fs: hurry up to issue discard after io interruption
f2fs: fix to show correct discard_granularity in sysfs
f2fs: detect dirty inode in evict_inode
f2fs: clear radix tree dirty tag of pages whose dirty flag is cleared
f2fs: speed up gc_urgent mode with SSR
f2fs: better to wait for fstrim completion
f2fs: avoid race in between read xattr & write xattr
f2fs: make get_lock_data_page to handle encrypted inode
f2fs: use generic terms used for encrypted block management
f2fs: introduce f2fs_encrypted_file for clean-up
Revert "f2fs: add a new function get_ssr_cost"
f2fs: constify super_operations
f2fs: fix to wake up all sleeping flusher
f2fs: avoid race in between atomic_read & atomic_inc
f2fs: remove unneeded parameter of change_curseg
f2fs: update i_flags correctly
f2fs: don't check inode's checksum if it was dirtied or writebacked
f2fs: don't need to update inode checksum for recovery
f2fs: trigger fdatasync for non-atomic_write file
f2fs: fix to avoid race in between aio and gc
Pull dmaengine updates from Vinod Koul:
"This one features the usual updates to the drivers and one good part
of removing DA_SG from core as it has no users.
Summary:
- Remove DMA_SG support as we have no users for this feature
- New driver for Altera / Intel mSGDMA IP core
- Support for memset in dmatest and qcom_hidma driver
- Update for non cyclic mode in k3dma, bunch of update in bam_dma,
bcm sba-raid
- Constify device ids across drivers"
* tag 'dmaengine-4.14-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (52 commits)
dmaengine: sun6i: support V3s SoC variant
dmaengine: sun6i: make gate bit in sun8i's DMA engines a common quirk
dmaengine: rcar-dmac: document R8A77970 bindings
dmaengine: xilinx_dma: Fix error code format specifier
dmaengine: altera: Use macros instead of structs to describe the registers
dmaengine: ti-dma-crossbar: Fix dra7 reserve function
dmaengine: pl330: constify amba_id
dmaengine: pl08x: constify amba_id
dmaengine: bcm-sba-raid: Remove redundant SBA_REQUEST_STATE_COMPLETED
dmaengine: bcm-sba-raid: Explicitly ACK mailbox message after sending
dmaengine: bcm-sba-raid: Add debugfs support
dmaengine: bcm-sba-raid: Remove redundant SBA_REQUEST_STATE_RECEIVED
dmaengine: bcm-sba-raid: Re-factor sba_process_deferred_requests()
dmaengine: bcm-sba-raid: Pre-ack async tx descriptor
dmaengine: bcm-sba-raid: Peek mbox when we have no free requests
dmaengine: bcm-sba-raid: Alloc resources before registering DMA device
dmaengine: bcm-sba-raid: Improve sba_issue_pending() run duration
dmaengine: bcm-sba-raid: Increase number of free sba_request
dmaengine: bcm-sba-raid: Allow arbitrary number free sba_request
dmaengine: bcm-sba-raid: Remove reqs_free_count from sba_device
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD updates from Lee Jones:
"New Drivers
- RK805 Power Management IC (PMIC)
- ROHM BD9571MWV-M MFD Power Management IC (PMIC)
- Texas Instruments TPS68470 Power Management IC (PMIC) & LEDs
New Device Support:
- Add support for HiSilicon Hi6421v530 to hi6421-pmic-core
- Add support for X-Powers AXP806 to axp20x
- Add support for X-Powers AXP813 to axp20x
- Add support for Intel Sunrise Point LPSS to intel-lpss-pci
New Functionality:
- Amend API to provide register layout; atmel-smc
Fix-ups:
- DT re-work; omap, nokia
- Header file location change {I2C => MFD}; dm355evm_msp, tps65010
- Fix chip ID formatting issue(s); rk808
- Optionally register touchscreen devices; da9052-core
- Documentation improvements; twl-core
- Constification; rtsx_pcr, ab8500-core, da9055-i2c, da9052-spi
- Drop unnecessary static declaration; max8925-i2c
- Kconfig changes (missing deps and remove module support)
- Slim down oversized licence statement; hi6421-pmic-core
- Use managed resources (devm_*); lp87565
- Supply proper error checking/handling; t7l66xb
Bug Fixes:
- Fix counter duplication issue; da9052-core
- Fix potential NULL deference issue; max8998
- Leave SPI-NOR write-protection bit alone; lpc_ich
- Ensure device is put into reset during suspend; intel-lpss
- Correct register offset variable size; omap-usb-tll"
* tag 'mfd-next-4.14' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (61 commits)
mfd: intel_soc_pmic: Differentiate between Bay and Cherry Trail CRC variants
mfd: intel_soc_pmic: Export separate mfd-cell configs for BYT and CHT
dt-bindings: mfd: Add bindings for ZII RAVE devices
mfd: omap-usb-tll: Fix register offsets
mfd: da9052: Constify spi_device_id
mfd: intel-lpss: Put I2C and SPI controllers into reset state on suspend
mfd: da9055: Constify i2c_device_id
mfd: intel-lpss: Add missing PCI ID for Intel Sunrise Point LPSS devices
mfd: t7l66xb: Handle return value of clk_prepare_enable
mfd: Add ROHM BD9571MWV-M PMIC DT bindings
mfd: intel_soc_pmic_chtwc: Turn Kconfig option into a bool
mfd: lp87565: Convert to use devm_mfd_add_devices()
mfd: Add support for TPS68470 device
mfd: lpc_ich: Do not touch SPI-NOR write protection bit on Haswell/Broadwell
mfd: syscon: atmel-smc: Add helper to retrieve register layout
mfd: axp20x: Use correct platform device ID for many PEK
dt-bindings: mfd: axp20x: Introduce bindings for AXP813
mfd: axp20x: Add support for AXP813 PMIC
dt-bindings: mfd: axp20x: Add AXP806 to supported list of chips
mfd: Add ROHM BD9571MWV-M MFD PMIC driver
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc updates from Michael Ellerman:
"Nothing really major this release, despite quite a lot of activity.
Just lots of things all over the place.
Some things of note include:
- Access via perf to a new type of PMU (IMC) on Power9, which can
count both core events as well as nest unit events (Memory
controller etc).
- Optimisations to the radix MMU TLB flushing, mostly to avoid
unnecessary Page Walk Cache (PWC) flushes when the structure of the
tree is not changing.
- Reworks/cleanups of do_page_fault() to modernise it and bring it
closer to other architectures where possible.
- Rework of our page table walking so that THP updates only need to
send IPIs to CPUs where the affected mm has run, rather than all
CPUs.
- The size of our vmalloc area is increased to 56T on 64-bit hash MMU
systems. This avoids problems with the percpu allocator on systems
with very sparse NUMA layouts.
- STRICT_KERNEL_RWX support on PPC32.
- A new sched domain topology for Power9, to capture the fact that
pairs of cores may share an L2 cache.
- Power9 support for VAS, which is a new mechanism for accessing
coprocessors, and initial support for using it with the NX
compression accelerator.
- Major work on the instruction emulation support, adding support for
many new instructions, and reworking it so it can be used to
implement the emulation needed to fixup alignment faults.
- Support for guests under PowerVM to use the Power9 XIVE interrupt
controller.
And probably that many things again that are almost as interesting,
but I had to keep the list short. Plus the usual fixes and cleanups as
always.
Thanks to: Alexey Kardashevskiy, Alistair Popple, Andreas Schwab,
Aneesh Kumar K.V, Anju T Sudhakar, Arvind Yadav, Balbir Singh,
Benjamin Herrenschmidt, Bhumika Goyal, Breno Leitao, Bryant G. Ly,
Christophe Leroy, Cédric Le Goater, Dan Carpenter, Dou Liyang,
Frederic Barrat, Gautham R. Shenoy, Geliang Tang, Geoff Levand, Hannes
Reinecke, Haren Myneni, Ivan Mikhaylov, John Allen, Julia Lawall,
LABBE Corentin, Laurentiu Tudor, Madhavan Srinivasan, Markus Elfring,
Masahiro Yamada, Matt Brown, Michael Neuling, Murilo Opsfelder Araujo,
Nathan Fontenot, Naveen N. Rao, Nicholas Piggin, Oliver O'Halloran,
Paul Mackerras, Rashmica Gupta, Rob Herring, Rui Teng, Sam Bobroff,
Santosh Sivaraj, Scott Wood, Shilpasri G Bhat, Sukadev Bhattiprolu,
Suraj Jitindar Singh, Tobin C. Harding, Victor Aoqui"
* tag 'powerpc-4.14-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (321 commits)
powerpc/xive: Fix section __init warning
powerpc: Fix kernel crash in emulation of vector loads and stores
powerpc/xive: improve debugging macros
powerpc/xive: add XIVE Exploitation Mode to CAS
powerpc/xive: introduce H_INT_ESB hcall
powerpc/xive: add the HW IRQ number under xive_irq_data
powerpc/xive: introduce xive_esb_write()
powerpc/xive: rename xive_poke_esb() in xive_esb_read()
powerpc/xive: guest exploitation of the XIVE interrupt controller
powerpc/xive: introduce a common routine xive_queue_page_alloc()
powerpc/sstep: Avoid used uninitialized error
axonram: Return directly after a failed kzalloc() in axon_ram_probe()
axonram: Improve a size determination in axon_ram_probe()
axonram: Delete an error message for a failed memory allocation in axon_ram_probe()
powerpc/powernv/npu: Move tlb flush before launching ATSD
powerpc/macintosh: constify wf_sensor_ops structures
powerpc/iommu: Use permission-specific DEVICE_ATTR variants
powerpc/eeh: Delete an error out of memory message at init time
powerpc/mm: Use seq_putc() in two functions
macintosh: Convert to using %pOF instead of full_name
/proc/pid/smaps_rollup is a new proc file that improves the performance
of user programs that determine aggregate memory statistics (e.g., total
PSS) of a process.
Android regularly "samples" the memory usage of various processes in
order to balance its memory pool sizes. This sampling process involves
opening /proc/pid/smaps and summing certain fields. For very large
processes, sampling memory use this way can take several hundred
milliseconds, due mostly to the overhead of the seq_printf calls in
task_mmu.c.
smaps_rollup improves the situation. It contains most of the fields of
/proc/pid/smaps, but instead of a set of fields for each VMA,
smaps_rollup instead contains one synthetic smaps-format entry
representing the whole process. In the single smaps_rollup synthetic
entry, each field is the summation of the corresponding field in all of
the real-smaps VMAs. Using a common format for smaps_rollup and smaps
allows userspace parsers to repurpose parsers meant for use with
non-rollup smaps for smaps_rollup, and it allows userspace to switch
between smaps_rollup and smaps at runtime (say, based on the
availability of smaps_rollup in a given kernel) with minimal fuss.
By using smaps_rollup instead of smaps, a caller can avoid the
significant overhead of formatting, reading, and parsing each of a large
process's potentially very numerous memory mappings. For sampling
system_server's PSS in Android, we measured a 12x speedup, representing
a savings of several hundred milliseconds.
One alternative to a new per-process proc file would have been including
PSS information in /proc/pid/status. We considered this option but
thought that PSS would be too expensive (by a few orders of magnitude)
to collect relative to what's already emitted as part of
/proc/pid/status, and slowing every user of /proc/pid/status for the
sake of readers that happen to want PSS feels wrong.
The code itself works by reusing the existing VMA-walking framework we
use for regular smaps generation and keeping the mem_size_stats
structure around between VMA walks instead of using a fresh one for each
VMA. In this way, summation happens automatically. We let seq_file
walk over the VMAs just as it does for regular smaps and just emit
nothing to the seq_file until we hit the last VMA.
Benchmarks:
using smaps:
iterations:1000 pid:1163 pss:220023808
0m29.46s real 0m08.28s user 0m20.98s system
using smaps_rollup:
iterations:1000 pid:1163 pss:220702720
0m04.39s real 0m00.03s user 0m04.31s system
We're using the PSS samples we collect asynchronously for
system-management tasks like fine-tuning oom_adj_score, memory use
tracking for debugging, application-level memory-use attribution, and
deciding whether we want to kill large processes during system idle
maintenance windows. Android has been using PSS for these purposes for
a long time; as the average process VMA count has increased and and
devices become more efficiency-conscious, PSS-collection inefficiency
has started to matter more. IMHO, it'd be a lot safer to optimize the
existing PSS-collection model, which has been fine-tuned over the years,
instead of changing the memory tracking approach entirely to work around
smaps-generation inefficiency.
Tim said:
: There are two main reasons why Android gathers PSS information:
: 1. Android devices can show the user the amount of memory used per
: application via the settings app. This is a less important use case.
: 2. We log PSS to help identify leaks in applications. We have found
: an enormous number of bugs (in the Android platform, in Google's own
: apps, and in third-party applications) using this data.
: To do this, system_server (the main process in Android userspace) will
: sample the PSS of a process three seconds after it changes state (for
: example, app is launched and becomes the foreground application) and about
: every ten minutes after that. The net result is that PSS collection is
: regularly running on at least one process in the system (usually a few
: times a minute while the screen is on, less when screen is off due to
: suspend). PSS of a process is an incredibly useful stat to track, and we
: aren't going to get rid of it. We've looked at some very hacky approaches
: using RSS ("take the RSS of the target process, subtract the RSS of the
: zygote process that is the parent of all Android apps") to reduce the
: accounting time, but it regularly overestimated the memory used by 20+
: percent. Accordingly, I don't think that there's a good alternative to
: using PSS.
: We started looking into PSS collection performance after we noticed random
: frequency spikes while a phone's screen was off; occasionally, one of the
: CPU clusters would ramp to a high frequency because there was 200-300ms of
: constant CPU work from a single thread in the main Android userspace
: process. The work causing the spike (which is reasonable governor
: behavior given the amount of CPU time needed) was always PSS collection.
: As a result, Android is burning more power than we should be on PSS
: collection.
: The other issue (and why I'm less sure about improving smaps as a
: long-term solution) is that the number of VMAs per process has increased
: significantly from release to release. After trying to figure out why we
: were seeing these 200-300ms PSS collection times on Android O but had not
: noticed it in previous versions, we found that the number of VMAs in the
: main system process increased by 50% from Android N to Android O (from
: ~1800 to ~2700) and varying increases in every userspace process. Android
: M to N also had an increase in the number of VMAs, although not as much.
: I'm not sure why this is increasing so much over time, but thinking about
: ASLR and ways to make ASLR better, I expect that this will continue to
: increase going forward. I would not be surprised if we hit 5000 VMAs on
: the main Android process (system_server) by 2020.
: If we assume that the number of VMAs is going to increase over time, then
: doing anything we can do to reduce the overhead of each VMA during PSS
: collection seems like the right way to go, and that means outputting an
: aggregate statistic (to avoid whatever overhead there is per line in
: writing smaps and in reading each line from userspace).
Link: http://lkml.kernel.org/r/20170812022148.178293-1-dancol@google.com
Signed-off-by: Daniel Colascione <dancol@google.com>
Cc: Tim Murray <timmurray@google.com>
Cc: Joel Fernandes <joelaf@google.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Sonny Rao <sonnyrao@chromium.org>
The sysfs interface to control the VMA based swap readahead is added as
follow,
/sys/kernel/mm/swap/vma_ra_enabled
Enable the VMA based swap readahead algorithm, or use the original
global swap readahead algorithm.
Set the max order of the readahead window size for the VMA based swap
The corresponding ABI documentation is added too.
Link: http://lkml.kernel.org/r/20170807054038.1843-5-ying.huang@intel.com
This patch adds document and kconfig for using of writeback feature.
Link: http://lkml.kernel.org/r/1498459987-24562-10-git-send-email-minchan@kernel.org
Signed-off-by: Minchan Kim <minchan@kernel.org>
Cc: Juneho Choi <juno.choi@lge.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Pull power management updates from Rafael Wysocki:
"This time (again) cpufreq gets the majority of changes which mostly
are driver updates (including a major consolidation of intel_pstate),
some schedutil governor modifications and core cleanups.
There also are some changes in the system suspend area, mostly related
to diagnostics and debug messages plus some renames of things related
to suspend-to-idle. One major change here is that suspend-to-idle is
now going to be preferred over S3 on systems where the ACPI tables
indicate to do so and provide requsite support (the Low Power Idle S0
_DSM in particular). The system sleep documentation and the tools
related to it are updated too.
The rest is a few cpuidle changes (nothing major), devfreq updates,
generic power domains (genpd) framework updates and a few assorted
modifications elsewhere.
Specifics:
- Drop the P-state selection algorithm based on a PID controller from
intel_pstate and make it use the same P-state selection method
(based on the CPU load) for all types of systems in the active mode
(Rafael Wysocki, Srinivas Pandruvada).
- Rework the cpufreq core and governors to make it possible to take
cross-CPU utilization updates into account and modify the schedutil
governor to actually do so (Viresh Kumar).
- Clean up the handling of transition latency information in the
cpufreq core and untangle it from the information on which drivers
cannot do dynamic frequency switching (Viresh Kumar).
- Add support for new SoCs (MT2701/MT7623 and MT7622) to the mediatek
cpufreq driver and update its DT bindings (Sean Wang).
- Modify the cpufreq dt-platdev driver to autimatically create
cpufreq devices for the new (v2) Operating Performance Points (OPP)
DT bindings and update its whitelist of supported systems (Viresh
Kumar, Shubhrajyoti Datta, Marc Gonzalez, Khiem Nguyen, Finley
Xiao).
- Add support for Ux500 to the cpufreq-dt driver and drop the
obsolete dbx500 cpufreq driver (Linus Walleij, Arnd Bergmann).
- Add new SoC (R8A7795) support to the cpufreq rcar driver (Khiem
Nguyen).
- Fix and clean up assorted issues in the cpufreq drivers and core
(Arvind Yadav, Christophe Jaillet, Colin Ian King, Gustavo Silva,
Julia Lawall, Leonard Crestez, Rob Herring, Sudeep Holla).
- Update the IO-wait boost handling in the schedutil governor to make
it less aggressive (Joel Fernandes).
- Rework system suspend diagnostics to make it print fewer messages
to the kernel log by default, add a sysfs knob to allow more
suspend-related messages to be printed and add Low Power S0 Idle
constraints checks to the ACPI suspend-to-idle code (Rafael
- Prefer suspend-to-idle over S3 on ACPI-based systems with the
ACPI_FADT_LOW_POWER_S0 flag set and the Low Power Idle S0 _DSM
interface present in the ACPI tables (Rafael Wysocki).
- Update documentation related to system sleep and rename a number of
items in the code to make it cleare that they are related to
suspend-to-idle (Rafael Wysocki).
- Export a variable allowing device drivers to check the target
system sleep state from the core system suspend code (Florian
Fainelli).
- Clean up the cpuidle subsystem to handle the polling state on x86
in a more straightforward way and to use %pOF instead of full_name
(Rafael Wysocki, Rob Herring).
- Update the devfreq framework to fix and clean up a few minor issues
(Chanwoo Choi, Rob Herring).
- Extend diagnostics in the generic power domains (genpd) framework
and clean it up slightly (Thara Gopinath, Rob Herring).
- Fix and clean up a couple of issues in the operating performance
points (OPP) framework (Viresh Kumar, Waldemar Rymarkiewicz).
- Add support for RV1108 to the rockchip-io Adaptive Voltage Scaling
(AVS) driver (David Wu).
- Fix the usage of notifiers in CPU power management on some
platforms (Alex Shi).
- Update the pm-graph system suspend/hibernation and boot profiling
utility (Todd Brandt).
- Make it possible to run the cpupower utility without CPU0 (Prarit
Bhargava)"
* tag 'pm-4.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (87 commits)
cpuidle: Make drivers initialize polling state
cpuidle: Move polling state initialization code to separate file
cpuidle: Eliminate the CPUIDLE_DRIVER_STATE_START symbol
cpufreq: imx6q: Fix imx6sx low frequency support
cpufreq: speedstep-lib: make several arrays static, makes code smaller
PM: docs: Delete the obsolete states.txt document
PM: docs: Describe high-level PM strategies and sleep states
PM / devfreq: Fix memory leak when fail to register device
PM / devfreq: Add dependency on PM_OPP
PM / devfreq: Move private devfreq_update_stats() into devfreq
PM / devfreq: Convert to using %pOF instead of full_name
PM / AVS: rockchip-io: add io selectors and supplies for RV1108
cpufreq: ti: Fix 'of_node_put' being called twice in error handling path
cpufreq: dt-platdev: Drop few entries from whitelist
cpufreq: dt-platdev: Automatically create cpufreq device with OPP v2
ARM: ux500: don't select CPUFREQ_DT
cpuidle: Convert to using %pOF instead of full_name
cpufreq: Convert to using %pOF instead of full_name
PM / Domains: Convert to using %pOF instead of full_name
cpufreq: Cap the default transition delay value to 10 ms
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here is the big char/misc driver update for 4.14-rc1.
Lots of different stuff in here, it's been an active development cycle
for some reason. Highlights are:
- updated binder driver, this brings binder up to date with what
shipped in the Android O release, plus some more changes that
happened since then that are in the Android development trees.
- coresight updates and fixes
- mux driver file renames to be a bit "nicer"
- intel_th driver updates
- normal set of hyper-v updates and changes
- small fpga subsystem and driver updates
- lots of const code changes all over the driver trees
- extcon driver updates
- fmc driver subsystem upadates
- w1 subsystem minor reworks and new features and drivers added
- spmi driver updates
Plus a smattering of other minor driver updates and fixes.
All of these have been in linux-next with no reported issues for a
while"
* tag 'char-misc-4.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (244 commits)
ANDROID: binder: don't queue async transactions to thread.
ANDROID: binder: don't enqueue death notifications to thread todo.
ANDROID: binder: Don't BUG_ON(!spin_is_locked()).
ANDROID: binder: Add BINDER_GET_NODE_DEBUG_INFO ioctl
ANDROID: binder: push new transactions to waiting threads.
ANDROID: binder: remove proc waitqueue
android: binder: Add page usage in binder stats
android: binder: fixup crash introduced by moving buffer hdr
drivers: w1: add hwmon temp support for w1_therm
drivers: w1: refactor w1_slave_show to make the temp reading functionality separate
drivers: w1: add hwmon support structures
eeprom: idt_89hpesx: Support both ACPI and OF probing
mcb: Fix an error handling path in 'chameleon_parse_cells()'
MCB: add support for SC31 to mcb-lpc
mux: make device_type const
char: virtio: constify attribute_group structures.
Documentation/ABI: document the nvmem sysfs files
lkdtm: fix spelling mistake: "incremeted" -> "incremented"
perf: cs-etm: Fix ETMv4 CONFIGR entry in perf.data file
nvmem: include linux/err.h from header
Pull staging/IIO driver updates from Greg KH:
"Here is the big staging and IIO driver update for 4.14-rc1.
Lots of staging driver fixes and cleanups, including some reorginizing
of the lustre header files to try to impose some sanity on what is,
and what is not, the uapi for that filesystem.
There are some tty core changes in here as well, as the speakup
drivers need them, and that's ok with me, they are sane and the
speakup code is getting nicer because of it.
There is also the addition of the obiligatory new wifi driver, just
because it has been a release or two since we added our last one...
Other than that, lots and lots of small coding style fixes, as usual.
All of these have been in linux-next for a while with no reported
issues"
* tag 'staging-4.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (612 commits)
staging:rtl8188eu:core Fix remove unneccessary else block
staging: typec: fusb302: make structure fusb302_psy_desc static
staging: unisys: visorbus: make two functions static
staging: fsl-dpaa2/eth: fix off-by-one FD ctrl bitmaks
staging: r8822be: Simplify deinit_priv()
staging: r8822be: Remove some dead code
staging: vboxvideo: Use CONFIG_DRM_KMS_FB_HELPER to check for fbdefio availability
staging:rtl8188eu Fix comparison to NULL
staging: rts5208: rename mmc_ddr_tunning_rx_cmd to mmc_ddr_tuning_rx_cmd
Staging: Pi433: style fix - tabs and spaces
staging: pi433: fix spelling mistake: "preample" -> "preamble"
staging:rtl8188eu:core Fix Code Indent
staging: typec: fusb302: Export current-limit through a power_supply class dev
staging: typec: fusb302: Add support for USB2 charger detection through extcon
staging: typec: fusb302: Use client->irq as irq if set
staging: typec: fusb302: Get max snk mv/ma/mw from device-properties
staging: typec: fusb302: Set max supply voltage to 5V
staging: typec: tcpm: Add get_current_limit tcpc_dev callback
staging:rtl8188eu Use __func__ instead of function name
staging: lustre: coding style fixes found by checkpatch.pl
Add support for STM32 Low-Power Timer, that can be used as counter
or quadrature encoder.
Signed-off-by: Fabrice Gasnier <fabrice.gasnier@st.com>
Reviewed-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
NVMEM has been in kernel since v4.2 but the ABI document was missing
since then. userspace interface did not change since then and seems
stable, so this patch documents the nvmem ABI.
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
If secure authentication of a devices fails, either because the device
already has another key uploaded, or there is some other error sending
challenge to the device, and the user only wants to approve the device
just once (without a new key being uploaded to the device) the current
implementation does not allow this because the key cannot be cleared
once set even if we allow it to be changed.
Make this scenario possible and allow clearing the key by writing
empty string to the key sysfs file.
Signed-off-by: Yehezkel Bernat <yehezkel.bernat@intel.com>
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
CONFIG_PPC_MEMTRACE must be set to use this feature. This can only be
used on powernv platforms.
Signed-off-by: Rashmica Gupta <rashmica.g@gmail.com>
[mpe: Update dates and kernel versions, mention size is in bytes]
Add support for the SuperSpeed Link Layer test case TD.7.34
which requires the operator to place the port into compliance
mode, and to subsequently bring it out via reset. Historically
according to the (now deprecated) USB 3.0 specification a
SuperSpeed host downstream port would automatically transition
to Compliance mode from the Polling state if LFPS polling times
out. However the language in USB 3.1 as well as xHCI 1.1 states
it may be required to explicitly enable this transition. For
such hosts this is done by sending a SET_FEATURE(PORT_LINK_STATE)
with the state set to Compliance to the root hub port.
Similar to the other supported commands, to do this via sysfs:
echo > /sys/bus/usb/devices/2-0\:1.0/enable_compliance
According to xHCI 1.1 section 4.19.1.2.4.1, this enables the
transition to compliance mode upon LFPS timeout. Note that this
can only be issued when the port is in disconnected state. And
in order to disable this behavior on subsequent transitions, a
warm reset should be issued. So add another entry to do that:
echo > /sys/bus/usb/devices/2-0\:1.0/warm_reset
In general these attributes can also be useful for other USB
SuperSpeed compliance tests such as electrical and eye diagram
testing which require CPn patterns to be transmitted.
Signed-off-by: Jack Pham <jackp@codeaurora.org>
Commit d618ebaf0aa8 ("f2fs: enable small discard by default") enables
f2fs to issue 4K size discard in real-time discard mode. However, issuing
smaller discard may cost more lifetime but releasing less free space in
flash device. Since f2fs has ability of separating hot/cold data and
garbage collection, we can expect that small-sized invalid region would
expand soon with OPU, deletion or garbage collection on valid datas, so
it's better to delay or skip issuing smaller size discards, it could help
to reduce overmuch consumption of IO bandwidth and lifetime of flash
storage.
This patch makes f2fs selectng 64K size as its default minimal
granularity, and issue discard with the size which is not smaller than
minimal granularity. Also it exposes discard granularity as sysfs entry
for configuration in different scenario.
Jaegeuk Kim:
We must issue all the accumulated discard commands when fstrim is called.
So, I've added pend_list_tag[] to indicate whether we should issue the
commands or not. If tag sets P_ACTIVE or P_TRIM, we have to issue them.
P_TRIM is set once at a time, given fstrim trigger.
In addition, issue_discard_thread is calling too much due to the number of
discard commands remaining in the pending list. I added a timer to control
it likewise gc_thread.
Signed-off-by: Chao Yu <yuchao0@huawei.com>
Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
ABI document added to describe all sysfs variables
for dma
Signed-off-by: Ujjal Singh <ujjal.singh@intel.com>
Acked-by: Dave Jiang <dave.jiang@intel.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
This patch adds a sysfs entry to control urgent mode for background GC.
If this is set, background GC thread conducts GC with gc_urgent_sleep_time
all the time.
Reviewed-by: Chao Yu <yuchao0@huawei.com>
This adds 3 new options to the RNDIS gadget function configs. It allows
overriding the default USB interface class/subclass/protocol.
The motivation for this is that if you set the values to "ef" (Misc),
"04" (RNDIS), "01" (Ethernet) respectively, then the device will be
recognized by the rndiscmp.inf file in Windows Vista and newer and will
cause Windows to load the correct RNDIS driver without the need for a
custom (signed) .inf file.
Signed-off-by: David Lechner <david@lechnology.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
This patch adds support to set power-shifting-ratio which hints the
firmware how to distribute/throttle power between different entities
in a system (e.g CPU v/s GPU). This ratio is used by OCC for power
capping algorithm.
Signed-off-by: Shilpasri G Bhat <shilpa.bhat@linux.vnet.ibm.com>
Adds a generic powercap framework to change the system powercap
inband through OPAL-OCC command/response interface.
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next
Jonathan writes:
First round of IIO new device support, features and cleanups for the 4.14 cycle.
4 completely new drivers in this set and plenty of other stuff.
One ABI change due to a silly mistake a long time back. Hopefully no
one will notice. It effects the numerical order of consumer device
channels which was the reverse of the obvious. It's going the slow
way to allow us some margin to spot if we have broken userspace or
not (seems unlikely)
New Device Support
* ccs811
- new driver for the Volatile Organic Compounds (VOC) sensor.
* dln2 adc
- new driver for the ADC on this flexible usb board.
* EP93xx
- new driver for this Cirrus logic SoC ADC.
* ltc2471
- new ADC driver support the ltc2471 and ltc2473
* st_accel
- add trivial table entries to support H3LIS331DL, LIS331DL, LIS3LV02DL.
* st_gyro
- add L3GD20H support (again) having fixed the various things that were
broken in the first try. Includes devicetree binding.
* stm32 dac
- add support for the DACs in the STM32F4 series
Features
* Documentation
- add missing power attribute documentation to the ABI docs.
* at91-sama5d2
- add hardware trigger and buffered capture support with bindings.
- suspend and resume functionality.
* bmc150
- support for the BOSC0200 ACPI device id seen on some tablets.
* hdc100x
- devicetree bindings
- document supported devices
- match table and device ids.
* hts221
- support active low interrupts (with bindings)
- open drain mode with bindings.
* htu21
- OF match table and bindings.
* lsm6dsx
* ltc2497
- add support for board file based consumer mapping.
* ms5367
* mt7622
- binding document and OF match table.
- suspend and resume support.
* rpr0521
- triggered buffer support.
* tsys01
Cleanups and minor fixes
* core
- fix ordering of IIO channels to entry numbers when using
iio_map_array_register rather than reversing them.
- use the new %pOF format specifier rather than full name for the
device tree nodes.
* ad7280a
- fix potential issue with macro argument reuse.
* ad7766
- drop a pointless NULL value check as it's done in the gpiod code.
* adis16400
- unsigned -> unsigned int.
* at91 adc
- make some init data static to reduce code size.
* at91-sama5d2 ADC
* da311
* hid-sensor-rotation
- drop an unnecessary static.
* hts221
- refactor the write_with_mask code.
- move the BDU configuration to probe time as there is no reason for it
to change.
- avoid overwriting reserved data during power-down. This is a fix, but
the infrastructure need was too invasive to send it to mainline except
in a merge window. It's not a regression as it was always wrong.
- avoid reconfigure the sampling frequency multiple times by just
doing it in the write_raw function directly.
- refactor the power_on/off calls into a set_enable.
- move the dry-enable logic into trig_set_state as that is the only
place it was used.
* ina219
- fix polling of ina226 conversion ready flag.
* imx7d
- add vendor name in kconfig for consistency with similar parts.
* mcp3422
- Change initial channel to 0 as it feels more logical.
- Check for some errors in probe.
* meson-saradc
- add a check of of_match_device return value.
* mpu3050
- allow open drain for any interrupt type.
* rockchip adc
- add check on of_match_device return value.
* sca3000
- drop a trailing whitespace.
* stm32 adc
- make array stm32h7_adc_ckmodes_spec static.
* stm32 dac
- fix an error message.
* stm32 timers
- fix clock name in docs to match reality after changes.
* st_accel
- explicit OF table (spi).
- add missing entries to OF table (i2c).
- rename of_device_id table to drop the part name.
- adding missing lis3l02dq entry to bindings.
- rename H3LIS331DL_DRIVER_NAME to line up with similar entries in driver.
* st_gyro
* st_magn
- enable multiread for lis3mdl.
* st_pressure
* st_sensors common.
- move st_sensors_of_i2c_probe and rename to make it available for spi
drivers.
* tsc3472
- don't write an extra byte when writing the ATIME register.
- add a link to the datasheet.
* tsl2x7x - continued staging cleanups
- add of_match_table.
- drop redundant power_state sysfs attribute.
- drop wrapper tsl2x7x_i2c_read.
- clean up i2c calls made in tsl2x7x_als_calibrate.
- refactor the read and write _event_value callbacks to handle additional
elements.
- use usleep_range instead of mdelay.
- check return value from tsl2x7x_invoke_change.
* zpa2326
- add some newline to the end of logging macros.
Debug messages from the system suspend/hibernation infrastructure can
fill up the entire kernel log buffer in some cases and anyway they
are only useful for debugging. They depend on CONFIG_PM_DEBUG, but
that is set as a rule as some generally useful diagnostic facilities
depend on it too.
For this reason, avoid printing those messages by default, but make
it possible to turn them on as needed with the help of a new sysfs
attribute under /sys/power/.
Commit c43a102e67db ("iio: ina2xx: add support for TI INA2xx Power Monitors")
introduced the in_powerY_raw attribute, but omitted the corresponding
documentation.
The description is correct for the INA2xx and the MAX9611 IIO drivers.
Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
Add FPGA manager driver for loading Arria-V/Cyclone-V/Stratix-V
and Arria-10 FPGAs via CvP.
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Signed-off-by: Alan Tull <atull@kernel.org>
Pull MTD updates from Brian Norris:
"General updates:
- Cleanups and additional flash support for "dataflash" driver
- new driver for mchp23k256 SPI SRAM device
- improve handling of MTDs without eraseblocks (i.e., MTD_NO_ERASE)
- refactor and improve "sub-partition" handling with TRX partition
parser; partitions can now be created as sub-partitions of another
partition
SPINOR updates, from Cyrille Pitchen and Marek Vasut:
- introduce support to the SPI 1-2-2 and 1-4-4 protocols.
- introduce support to the Double Data Rate (DDR) mode.
- introduce support to the Octo SPI protocols.
- add support to new memory parts for Spansion, Macronix and Winbond.
- add fixes for the Aspeed, STM32 and Cadence QSPI controler drivers.
- clean up the st_spi_fsm driver.
NAND updates, from Boris Brezillon:
- addition of on-die ECC support to Micron driver
- addition of helpers to help drivers choose most appropriate ECC
settings
- deletion of dead-code (cached programming and ->errstat() hook)
- make sure drivers that do not support the SET/GET FEATURES command
return ENOTSUPP use a dummy ->set/get_features implementation
returning -ENOTSUPP (required for Micron on-die ECC)
- change the semantic of ecc->write_page() for drivers setting the
NAND_ECC_CUSTOM_PAGE_ACCESS flag
- support exiting 'GET STATUS' command in default ->cmdfunc()
implementations
- change the prototype of ->setup_data_interface()
A bunch of driver related changes:
- various cleanup, fixes and improvements of the MTK driver
- OMAP DT bindings fixes
- support for ->setup_data_interface() in the fsmc driver
- support for imx7 in the gpmi driver
- finalization of the denali driver rework (thanks to Masahiro for
the work he's done on this driver)
- fix "bitflips in erased pages" handling in the ifc driver
- addition of PM ops and dynamic timing configuration to the atmel
driver"
* tag 'for-linus-20170713' of git://git.infradead.org/linux-mtd: (118 commits)
Documentation: ABI: mtd: describe "offset" more precisely
mtd: Fix check in mtd_unpoint()
mtd: nand: mtk: release lock on error path
mtd: st_spi_fsm: remove SPINOR_OP_RDSR2 and use SPINOR_OP_RDCR instead
mtd: spi-nor: cqspi: remove duplicate const
mtd: spi-nor: Add support for Spansion S25FL064L
mtd: spi-nor: Add support for mx66u51235f
mtd: nand: mtk: add ->setup_data_interface() hook
mtd: nand: mtk: remove unneeded mtk_ecc_hw_init from mtk_ecc_resume
mtd: nand: mtk: remove unneeded mtk_nfc_hw_init from mtk_nfc_resume
mtd: nand: mtk: disable ecc irq when writing page with hwecc
mtd: nand: mtk: fix incorrect register setting order about ecc irq
mtd: partitions: fixup some allocate_partition() whitespace
mtd: parsers: trx: fix pr_err format for printing offset
MAINTAINERS: Update SPI NOR subsystem git repositories
mtd: extract TRX parser out of bcm47xxpart into a separated module
mtd: partitions: add support for partition parsers
mtd: partitions: add support for subpartitions
mtd: partitions: rename "master" to the "parent" where appropriate
mtd: partitions: remove sysfs files when deleting all master's partitions
So far Linux supported only two levels of MTD devices so we didn't need
a very precise description for this sysfs file. With commit
97519dc52b44a ("mtd: partitions: add support for subpartitions") there
is support for a tree structure so we should have more precise
description. Using "parent" and "flash device" makes it more accurate.
Signed-off-by: Rafał Miłecki <rafal@milecki.pl>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
