commit 9ecccfaa7cb5249bd31bdceb93fcf5bedb8a24d8 upstream.
Fixes: 87590ce6e ("sysfs/cpu: Add vulnerability folder")
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
commit 87590ce6e373d1a5401f6539f0c59ef92dd924a9 upstream.
As the meltdown/spectre problem affects several CPU architectures, it makes
sense to have common way to express whether a system is affected by a
particular vulnerability or not. If affected the way to express the
mitigation should be common as well.
Create /sys/devices/system/cpu/vulnerabilities folder and files for
meltdown, spectre_v1 and spectre_v2.
Allow architectures to override the show function.
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Linus Torvalds <torvalds@linuxfoundation.org>
Cc: David Woodhouse <dwmw@amazon.co.uk>
Link: https://lkml.kernel.org/r/20180107214913.096657732@linutronix.de
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86
Pull x86 platform driver fixes from Darren Hart:
"Minor doc fix, a DMI match for ideapad and a fix to toshiba-wmi to
avoid loading on non-toshiba systems.
Documentation/ABI:
- ibm_rtl: The "What:" fields are incomplete
toshiba-wmi:
- Fix loading the driver on non Toshiba laptops
ideapad-laptop:
- Add another DMI entry for Yoga 900"
* tag 'platform-drivers-x86-v4.9-3' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86:
Documentation/ABI: ibm_rtl: The "What:" fields are incomplete
toshiba-wmi: Fix loading the driver on non Toshiba laptops
ideapad-laptop: Add another DMI entry for Yoga 900
The "What:" field at the ABI should describe the location of
the ABI, e. g. the position under a mounted sysfs. However,
this file has only the basename without the path.
Fix it.
Cc: Vernon Mauery <vernux@us.ibm.com>
Cc: platform-driver-x86@vger.kernel.org
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
This patch prevents resetting the cxl adapter via sysfs in presence of
one or more active cxl_context on it. This protects against an
unrecoverable error caused by PSL owning a dirty cache line even after
reset and host tries to touch the same cache line. In case a force reset
of the card is required irrespective of any active contexts, the int
value -1 can be stored in the 'reset' sysfs attribute of the card.
The patch introduces a new atomic_t member named contexts_num inside
struct cxl that holds the number of active context attached to the card
, which is checked against '0' before proceeding with the reset. To
prevent against a race condition where a context is activated just after
reset check is performed, the contexts_num is atomically set to '-1'
after reset-check to indicate that no more contexts can be activated on
the card anymore.
Before activating a context we atomically test if contexts_num is
non-negative and if so, increment its value by one. In case the value of
contexts_num is negative then it indicates that the card is about to be
reset and context activation is error-ed out at that point.
Fixes: 62fa19d4b4fd ("cxl: Add ability to reset the card")
Cc: stable@vger.kernel.org # v4.0+
Acked-by: Frederic Barrat <fbarrat@linux.vnet.ibm.com>
Reviewed-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
Signed-off-by: Vaibhav Jain <vaibhav@linux.vnet.ibm.com>
Pull Ceph updates from Ilya Dryomov:
"The big ticket item here is support for rbd exclusive-lock feature,
with maintenance operations offloaded to userspace (Douglas Fuller,
Mike Christie and myself). Another block device bullet is a series
fixing up layering error paths (myself).
On the filesystem side, we've got patches that improve our handling of
buffered vs dio write races (Neil Brown) and a few assorted fixes from
Zheng. Also included a couple of random cleanups and a minor CRUSH
update"
* tag 'ceph-for-4.9-rc1' of git://github.com/ceph/ceph-client: (39 commits)
crush: remove redundant local variable
crush: don't normalize input of crush_ln iteratively
libceph: ceph_build_auth() doesn't need ceph_auth_build_hello()
libceph: use CEPH_AUTH_UNKNOWN in ceph_auth_build_hello()
ceph: fix description for rsize and rasize mount options
rbd: use kmalloc_array() in rbd_header_from_disk()
ceph: use list_move instead of list_del/list_add
ceph: handle CEPH_SESSION_REJECT message
ceph: avoid accessing / when mounting a subpath
ceph: fix mandatory flock check
ceph: remove warning when ceph_releasepage() is called on dirty page
ceph: ignore error from invalidate_inode_pages2_range() in direct write
ceph: fix error handling of start_read()
rbd: add rbd_obj_request_error() helper
rbd: img_data requests don't own their page array
rbd: don't call rbd_osd_req_format_read() for !img_data requests
rbd: rework rbd_img_obj_exists_submit() error paths
rbd: don't crash or leak on errors in rbd_img_obj_parent_read_full_callback()
rbd: move bumping img_request refcount into rbd_obj_request_submit()
rbd: mark the original request as done if stat request fails
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID updates from Jiri Kosina:
- Integrated Sensor Hub support (Cherrytrail+) from Srinivas Pandruvada
- Big cleanup of Wacom driver; namely it's now using devres, and the
standardized LED API so that libinput doesn't need to have root
access any more, with substantial amount of other cleanups
piggy-backing on top. All this from Benjamin Tissoires
- Report descriptor parsing would now ignore and out-of-range System
controls in case of the application actually being System Control.
This fixes quite some issues with several devices, and allows us to
remove a few ->report_fixup callbacks. From Benjamin Tissoires
- ... a lot of other assorted small fixes and device ID additions
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (76 commits)
HID: add missing \n to end of dev_warn messages
HID: alps: fix multitouch cursor issue
HID: hid-logitech: Documentation updates/corrections
HID: hid-logitech: Improve Wingman Formula Force GP support
HID: hid-logitech: Rewrite of descriptor for all DF wheels
HID: hid-logitech: Compute combined pedals value
HID: hid-logitech: Add combined pedal support Logitech wheels
HID: hid-logitech: Introduce control for combined pedals feature
HID: sony: Update copyright and add Dualshock 4 rate control note
HID: sony: Defer the initial USB Sixaxis output report
HID: sony: Relax duplicate checking for USB-only devices
Revert "HID: microsoft: fix invalid rdesc for 3k kbd"
HID: alps: fix error return code in alps_input_configured()
HID: alps: fix stick device not working after resume
HID: support for keyboard - Corsair STRAFE
HID: alps: Fix memory leak
HID: uclogic: Add support for UC-Logic TWHA60 v3
HID: uclogic: Override constant descriptors
HID: uclogic: Support UGTizer GP0610 partially
HID: uclogic: Add support for several more tablets
'for-4.9/hid-input', 'for-4.9/intel-ish', 'for-4.9/kye-uclogic-waltop-fixes', 'for-4.9/logitech', 'for-4.9/sony', 'for-4.9/upstream' and 'for-4.9/wacom' into for-linus
git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply
Pull power supply and reset updates from Sebastian Reichel:
- move power supply drivers to drivers/power/supply
- unify location of power supply DT documentation
- tps65217-charger: IRQ support
- act8945a-charger: misc. cleanups & improvements
- sbs-battery cleanup
- fix users of deprecated create_singlethread_workqueue()
- misc fixes.
* tag 'for-v4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply: (46 commits)
power: supply: bq27xxx_battery: allow kernel poll_interval parameter runtime update
power: supply: sbs-battery: Cleanup removal of chip->pdata
power: reset: st: Remove obsolete platforms from dt doc
power: reset: st-poweroff: Remove obsolete platforms.
power: reset: zx-reboot: Unmap region obtained by of_iomap
power: reset: xgene-reboot: Unmap region obtained by of_iomap
power: supply: ab8500: cleanup with list_first_entry_or_null()
power: reset: add in missing white space in error message text
sbs-battery: make writes to ManufacturerAccess optional
power: bq24257: Fix use of uninitialized pointer bq->charger
power: supply: sbs-battery: simplify DT parsing
power: supply: bq24735-charger: Request status GPIO with initial input setup
power: supply: sbs-battery: Use gpio_desc and sleeping calls for battery detect
power: supply: act8945a_charger: Add max current property
power: supply: act8945a_charger: Add capacity level property
doc: bindings: power: act8945a-charger: Update properties.
power: supply: act8945a_charger: Fix the power supply type
power: supply: act8945a_charger: Add status change update support
power: supply: act8945a_charger: Improve state handling
power: supply: act8945a_charger: Remove "battery_temperature"
git://git.kernel.org/pub/scm/linux/kernel/git/j.anaszewski/linux-leds
Pull LED driver updates from Jacek Anaszewski:
"Three new LED class drivers and some minor fixes and improvementes to
the leds-gpio driver, LED Trigger core and documentation"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/j.anaszewski/linux-leds:
leds: triggers: Check return value of kobject_uevent_env()
leds: triggers: Return from led_trigger_set() if there is nothing to do
leds: gpio: fix and simplify error handling in gpio_leds_create
leds: gpio: switch to managed version of led_classdev_register
leds: gpio: fix and simplify reading property "label"
leds: gpio: simplify gpio_leds_create
leds: gpio: add helper cdev_to_gpio_led_data
leds: gpio: fix an unhandled error case in create_gpio_led
leds: gpio: introduce gpio_blink_set_t
leds: add driver for Mellanox systems LEDs
Documentation: move oneshot trigger attributes documentation to ABI
leds: centralize definition of "default-state" property
leds: add PM8058 LEDs driver
leds: pm8058: add device tree bindings
leds: do not overflow sysfs buffer in led_trigger_show
leds: make triggers explicitly non-modular
DT: leds: Add bindings for ISSI is31fl319x
leds: is31fl319x: 1/3/6/9-channel light effect led driver
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull usb/phy/extcon updates from Greg KH:
"Here is the big USB, and PHY, and extcon, patchsets for 4.9-rc1.
Full details are in the shortlog, but generally a lot of new hardware
support, usb gadget updates, and Wolfram's great cleanup of USB error
message handling, making the kernel image a tad bit smaller.
All of this has been in linux-next with no reported issues"
* tag 'usb-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (343 commits)
Revert "usbtmc: convert to devm_kzalloc"
USB: serial: cp210x: Add ID for a Juniper console
usb: Kconfig: using select for USB_COMMON dependency
bluetooth: bcm203x: don't print error when allocating urb fails
mmc: host: vub300: don't print error when allocating urb fails
usb: hub: change CLEAR_FEATURE to SET_FEATURE
usb: core: Introduce a USB port LED trigger
USB: bcma: drop Northstar PHY 2.0 initialization code
usb: core: hcd: add missing header dependencies
usb: musb: da8xx: fix error handling message in probe
usb: musb: Fix session based PM for first invalid VBUS
usb: musb: Fix PM runtime for disconnect after unconfigure
musb: Export musb_root_disconnect for use in modules
usb: misc: legousbtower: Fix NULL pointer deference
cdc-acm: hardening against malicious devices
Revert "usb: gadget: NCM: Protect dev->port_usb using dev->lock"
include: extcon: Fix compilation error caused because of incomplete merge
MAINTAINERS: add tree entry for USB Serial
phy-twl4030-usb: initialize charging-related stuff via pm_runtime
phy-twl4030-usb: better handle musb_mailbox() failure
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here's the "big" char and misc driver update for 4.9-rc1.
Lots of little things here, all over the driver tree for subsystems
that flow through me. Nothing major that I can discern, full details
are in the shortlog.
All have been in the linux-next tree with no reported issues"
* tag 'char-misc-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (144 commits)
drivers/misc/hpilo: Changes to support new security states in iLO5 FW
at25: fix debug and error messaging
misc/genwqe: ensure zero initialization
vme: fake: remove unexpected unlock in fake_master_set()
vme: fake: mark symbols static where possible
spmi: pmic-arb: Return an error code if sanity check fails
Drivers: hv: get rid of id in struct vmbus_channel
Drivers: hv: make VMBus bus ids persistent
mcb: Add a dma_device to mcb_device
mcb: Enable PCI bus mastering by default
mei: stop the stall timer worker if not needed
clk: probe common clock drivers earlier
vme: fake: fix build for 64-bit dma_addr_t
ttyprintk: Neaten and simplify printing
mei: me: add kaby point device ids
coresight: tmc: mark symbols static where possible
coresight: perf: deal with error condition properly
Drivers: hv: hv_util: Avoid dynamic allocation in time synch
fpga manager: Add hardware dependency to Zynq driver
Drivers: hv: utils: Support TimeSync version 4.0 protocol samples.
This commit adds a new trigger responsible for turning on LED when USB
device gets connected to the selected USB port. This can can useful for
various home routers that have USB port(s) and a proper LED telling user
a device is connected.
The trigger gets its documentation file but basically it just requires
enabling it and selecting USB ports (e.g. echo 1 > ports/usb1-1).
There was a long discussion on design of this driver. Its current state
is a result of picking them most adjustable solution as others couldn't
handle all cases.
1) It wasn't possible for the driver to register separated trigger for
each USB port. Some physical USB ports are handled by more than one
controller and so by more than one USB port. E.g. USB 2.0 physical
port may be handled by OHCI's port and EHCI's port.
It's also not possible to assign more than 1 trigger to a single LED
and implementing such feature would be tricky due to syncing triggers
and sysfs conflicts with old triggers.
2) Another idea was to register trigger per USB hub. This wouldn't allow
handling devices with multiple USB LEDs and controllers (hubs)
controlling more than 1 physical port. It's common for hubs to have
few ports and each may have its own LED.
This final trigger is highly flexible. It allows selecting any USB ports
for any LED. It was also modified (comparing to the initial version) to
allow choosing ports rather than having user /guess/ proper names. It
was successfully tested on SmartRG SR400ac which has 3 USB LEDs,
2 physical ports and 3 controllers.
It was noted USB subsystem already has usb-gadget and usb-host triggers
but they are pretty trivial ones. They indicate activity only and can't
have ports specified.
In future it may be good idea to consider adding activity support to
usbport as well. This should allow switching to this more generic driver
and maybe marking old ones as obsolete.
This can be implemented with another sysfs file for setting mode. The
default mode wouldn't change so there won't be ABI breakage and so such
feature can be safely implemented later.
There was also an idea of supporting other devices (PCI, SDIO, etc.) but
as this driver already contains some USB specific code (and will get
more) these should be probably separated drivers (triggers).
Signed-off-by: Rafał Miłecki <rafal@milecki.pl>
Signed-off-by: Simon Wood <simon@mungewell.org>
Introduce a dev_attr which can be used to combine the accelerator
and brake pedals into a single axis. This is useful for older games
which can not handle seperate accelerator and brake.
git://git.kernel.org/pub/scm/linux/kernel/git/maz/arm-platforms into irq/core
Merge the first drop of irqchip updates for 4.9 from Marc Zyngier:
- ACPI IORT core code
- IORT support for the GICv3 ITS
- A few of GIC cleanups
Information about interrupts is exposed via /proc/interrupts, but the
format of that file has changed over kernel versions and differs across
architectures. It also has varying column numbers depending on hardware.
That all makes it hard for tools to parse.
To solve this, expose the information through sysfs so each irq attribute
is in a separate file in a consistent, machine parsable way.
This feature is only available when both CONFIG_SPARSE_IRQ and
CONFIG_SYSFS are enabled.
Examples:
/sys/kernel/irq/18/actions: i801_smbus,ehci_hcd:usb1,uhci_hcd:usb7
/sys/kernel/irq/18/chip_name: IR-IO-APIC
/sys/kernel/irq/18/hwirq: 18
/sys/kernel/irq/18/name: fasteoi
/sys/kernel/irq/18/per_cpu_count: 0,0
/sys/kernel/irq/18/type: level
/sys/kernel/irq/25/actions: ahci0
/sys/kernel/irq/25/chip_name: IR-PCI-MSI
/sys/kernel/irq/25/hwirq: 512000
/sys/kernel/irq/25/name: edge
/sys/kernel/irq/25/per_cpu_count: 29036,0
/sys/kernel/irq/25/type: edge
[ tglx: Moved kobject_del() under sparse_irq_lock, massaged code comments
and changelog ]
Signed-off-by: Craig Gallek <kraig@google.com>
Cc: David Decotigny <decot@google.com>
Link: http://lkml.kernel.org/r/1473783291-122873-1-git-send-email-kraigatgoog@gmail.com
We want the fixes in here for merging and testing.
commit 5590f3196b29 ("drivers/core/of: Add symlink to device-tree from
devices with an OF node") added a symlink called "of_node" to sysfs
however the documentation describes it as "of_path".
Fix the documentation to match what the code actually does.
Signed-off-by: Martin Fuzzey <mfuzzey@parkeon.com>
Acked-by: Rob Herring <robh@kernel.org>
Patches merged to the IIO BMP085 driver makes it fully compliant
with all features found in this old misc driver. Retire this old
driver in favor of the new one in the proper subsystem.
Cc: Jonathan Cameron <jic23@cam.ac.uk>
Cc: Marek Belisko <marek@goldelico.com>
Acked-by: H. Nikolaus Schaller <hns@goldelico.com>
v3.20 doesn't exist. heartbeat_enable was actually added in v4.4.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Documentation of sysfs interface should be in ABI in the first place.
This moves relevant part of documentation and mentions where to look for
it.
Fix trivial typos whilst we are at it.
Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
This adds a force close option, so we can force the unmapping
of a rbd device that is open. If a path/device is blacklisted, apps
like multipathd can map a new device and then unmap the old one.
The unmapping cleanup would then be handled by the generic hotunplug
code paths in multipahd like is done for iSCSI, FC/FCOE, SAS, etc.
Signed-off-by: Mike Christie <mchristi@redhat.com>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Export the info used to setup the rbd image, so it can be used to remap
the image.
[idryomov@gmail.com: do_rbd_add() EH]
Export snap id in sysfs, so tools like multipathd can use it in a uuid.
Export the cluster fsid, so tools like udev and multipath-tools can use
it for part of the uuid.
Export client addr/nonce, so userspace can check if a image is being
blacklisted.
[idryomov@gmail.com: ceph_client_addr(), endianess fix]
Change my email address to kernel.org instead of Samsung one for the
purpose of any future contact. The copyrights remain untouched and are
attributed to Samsung.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Sebastian Reichel <sre@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm
Pull pwm updates from Thierry Reding:
"This set of changes improve some aspects of the atomic API as well as
make use of this new API in the regulator framework to allow properly
dealing with critical regulators controlled by a PWM.
Aside from that there's a bunch of updates and cleanups for existing
drivers, as well as the addition of new drivers for the Broadcom
iProc, STMPE and ChromeOS EC controllers"
* tag 'pwm/for-4.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: (44 commits)
regulator: pwm: Document pwm-dutycycle-unit and pwm-dutycycle-range
regulator: pwm: Support extra continuous mode cases
pwm: Add ChromeOS EC PWM driver
dt-bindings: pwm: Add binding for ChromeOS EC PWM
mfd: cros_ec: Add EC_PWM function definitions
mfd: cros_ec: Add cros_ec_cmd_xfer_status() helper
pwm: atmel: Use of_device_get_match_data()
pwm: atmel: Fix checkpatch warnings
pwm: atmel: Fix disabling of PWM channels
dt-bindings: pwm: Add R-Car H3 device tree bindings
pwm: rcar: Use ARCH_RENESAS
pwm: tegra: Add support for Tegra186
dt-bindings: pwm: tegra: Add compatible string for Tegra186
pwm: tegra: Avoid overflow when calculating duty cycle
pwm: tegra: Allow 100 % duty cycle
pwm: tegra: Add support for reset control
pwm: tegra: Rename mmio_base to regs
pwm: tegra: Remove useless padding
pwm: tegra: Drop NUM_PWM macro
pwm: lpc32xx: Set PWM_PIN_LEVEL bit to default value
The now obsolete sysfs files for LEDs and EKRemote are kept for backward
compatibility.
Both the EKR (read-only) and the regular Cintiqs and Intuos are now
sharing the same led API.
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Acked-by: Ping Cheng <pingc@wacom.com>
Pull networking updates from David Miller:
1) Unified UDP encapsulation offload methods for drivers, from
Alexander Duyck.
2) Make DSA binding more sane, from Andrew Lunn.
3) Support QCA9888 chips in ath10k, from Anilkumar Kolli.
4) Several workqueue usage cleanups, from Bhaktipriya Shridhar.
5) Add XDP (eXpress Data Path), essentially running BPF programs on RX
packets as soon as the device sees them, with the option to mirror
the packet on TX via the same interface. From Brenden Blanco and
others.
6) Allow qdisc/class stats dumps to run lockless, from Eric Dumazet.
7) Add VLAN support to b53 and bcm_sf2, from Florian Fainelli.
8) Simplify netlink conntrack entry layout, from Florian Westphal.
9) Add ipv4 forwarding support to mlxsw spectrum driver, from Ido
Schimmel, Yotam Gigi, and Jiri Pirko.
10) Add SKB array infrastructure and convert tun and macvtap over to it.
From Michael S Tsirkin and Jason Wang.
11) Support qdisc packet injection in pktgen, from John Fastabend.
12) Add neighbour monitoring framework to TIPC, from Jon Paul Maloy.
13) Add NV congestion control support to TCP, from Lawrence Brakmo.
14) Add GSO support to SCTP, from Marcelo Ricardo Leitner.
15) Allow GRO and RPS to function on macsec devices, from Paolo Abeni.
16) Support MPLS over IPV4, from Simon Horman.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1622 commits)
xgene: Fix build warning with ACPI disabled.
be2net: perform temperature query in adapter regardless of its interface state
l2tp: Correctly return -EBADF from pppol2tp_getname.
net/mlx5_core/health: Remove deprecated create_singlethread_workqueue
net: ipmr/ip6mr: update lastuse on entry change
macsec: ensure rx_sa is set when validation is disabled
tipc: dump monitor attributes
tipc: add a function to get the bearer name
tipc: get monitor threshold for the cluster
tipc: make cluster size threshold for monitoring configurable
tipc: introduce constants for tipc address validation
net: neigh: disallow transition to NUD_STALE if lladdr is unchanged in neigh_update()
MAINTAINERS: xgene: Add driver and documentation path
Documentation: dtb: xgene: Add MDIO node
drivers: net: xgene: ethtool: Use phy_ethtool_gset and sset
drivers: net: xgene: Use exported functions
drivers: net: xgene: Enable MDIO driver
drivers: net: xgene: Add backward compatibility
drivers: net: phy: xgene: Add MDIO driver
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Catalin Marinas:
- Kexec support for arm64
- Kprobes support
- Expose MIDR_EL1 and REVIDR_EL1 CPU identification registers to sysfs
- Trapping of user space cache maintenance operations and emulation in
the kernel (CPU errata workaround)
- Clean-up of the early page tables creation (kernel linear mapping,
EFI run-time maps) to avoid splitting larger blocks (e.g. pmds) into
smaller ones (e.g. ptes)
- VDSO support for CLOCK_MONOTONIC_RAW in clock_gettime()
- ARCH_HAS_KCOV enabled for arm64
- Optimise IP checksum helpers
- SWIOTLB optimisation to only allocate/initialise the buffer if the
available RAM is beyond the 32-bit mask
- Properly handle the "nosmp" command line argument
- Fix for the initialisation of the CPU debug state during early boot
- vdso-offsets.h build dependency workaround
- Build fix when RANDOMIZE_BASE is enabled with MODULES off
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (64 commits)
arm64: arm: Fix-up the removal of the arm64 regs_query_register_name() prototype
arm64: Only select ARM64_MODULE_PLTS if MODULES=y
arm64: mm: run pgtable_page_ctor() on non-swapper translation table pages
arm64: mm: make create_mapping_late() non-allocating
arm64: Honor nosmp kernel command line option
arm64: Fix incorrect per-cpu usage for boot CPU
arm64: kprobes: Add KASAN instrumentation around stack accesses
arm64: kprobes: Cleanup jprobe_return
arm64: kprobes: Fix overflow when saving stack
arm64: kprobes: WARN if attempting to step with PSTATE.D=1
arm64: debug: remove unused local_dbg_{enable, disable} macros
arm64: debug: remove redundant spsr manipulation
arm64: debug: unmask PSTATE.D earlier
arm64: localise Image objcopy flags
arm64: ptrace: remove extra define for CPSR's E bit
kprobes: Add arm64 case in kprobe example module
arm64: Add kernel return probes support (kretprobes)
arm64: Add trampoline code for kretprobes
arm64: kprobes instruction simulation support
arm64: Treat all entry code as non-kprobe-able
Pull ACPI updates from Rafael Wysocki:
"The new feaures here are the support for ACPI overlays (allowing ACPI
tables to be loaded at any time from EFI variables or via configfs)
and the LPI (Low-Power Idle) support. Also notable is the ACPI-based
NUMA support for ARM64.
Apart from that we have two new drivers, for the DPTF (Dynamic Power
and Thermal Framework) power participant device and for the Intel
Broxton WhiskeyCove PMIC, some more PMIC-related changes, support for
the Boot Error Record Table (BERT) in APEI and support for
platform-initiated graceful shutdown.
Plus two new pieces of documentation and usual assorted fixes and
cleanups in quite a few places.
Specifics:
- Support for ACPI SSDT overlays allowing Secondary System
Description Tables (SSDTs) to be loaded at any time from EFI
variables or via configfs (Octavian Purdila, Mika Westerberg).
- Support for the ACPI LPI (Low-Power Idle) feature introduced in
ACPI 6.0 and allowing processor idle states to be represented in
ACPI tables in a hierarchical way (with the help of Processor
Container objects) and support for ACPI idle states management on
ARM64, based on LPI (Sudeep Holla).
- General improvements of ACPI support for NUMA and ARM64 support for
ACPI-based NUMA (Hanjun Guo, David Daney, Robert Richter).
- General improvements of the ACPI table upgrade mechanism and ARM64
support for that feature (Aleksey Makarov, Jon Masters).
- Support for the Boot Error Record Table (BERT) in APEI and
improvements of kernel messages printed by the error injection code
(Huang Ying, Borislav Petkov).
- New driver for the Intel Broxton WhiskeyCove PMIC operation region
and support for the REGS operation region on Broxton, PMIC code
cleanups (Bin Gao, Felipe Balbi, Paul Gortmaker).
- New driver for the power participant device which is part of the
Dynamic Power and Thermal Framework (DPTF) and DPTF-related code
reorganization (Srinivas Pandruvada).
- Support for the platform-initiated graceful shutdown feature
introduced in ACPI 6.1 (Prashanth Prakash).
- ACPI button driver update related to lid input events generated
automatically on initialization and system resume that have been
problematic for some time (Lv Zheng).
- ACPI EC driver cleanups (Lv Zheng).
- Documentation of the ACPICA release automation process and the
in-kernel ACPI AML debugger (Lv Zheng).
- New blacklist entry and two fixes for the ACPI backlight driver
(Alex Hung, Arvind Yadav, Ralf Gerbig).
- Cleanups of the ACPI pci_slot driver (Joe Perches, Paul Gortmaker).
- ACPI CPPC code changes to make it more robust against possible
defects in ACPI tables and new symbol definitions for PCC (Hoan
Tran).
- System reboot code modification to execute the ACPI _PTS (Prepare
To Sleep) method in addition to _TTS (Ocean He).
- ACPICA-related change to carry out lock ordering checks in ACPICA
if ACPICA debug is enabled in the kernel (Lv Zheng).
- Assorted minor fixes and cleanups (Andy Shevchenko, Baoquan He,
Bhaktipriya Shridhar, Paul Gortmaker, Rafael Wysocki)"
* tag 'acpi-4.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (71 commits)
ACPI: enable ACPI_PROCESSOR_IDLE on ARM64
arm64: add support for ACPI Low Power Idle(LPI)
drivers: firmware: psci: initialise idle states using ACPI LPI
cpuidle: introduce CPU_PM_CPU_IDLE_ENTER macro for ARM{32, 64}
arm64: cpuidle: drop __init section marker to arm_cpuidle_init
ACPI / processor_idle: Add support for Low Power Idle(LPI) states
ACPI / processor_idle: introduce ACPI_PROCESSOR_CSTATE
ACPI / DPTF: move int340x_thermal.c to the DPTF folder
ACPI / DPTF: Add DPTF power participant driver
ACPI / lpat: make it explicitly non-modular
ACPI / dock: make dock explicitly non-modular
ACPI / PCI: make pci_slot explicitly non-modular
ACPI / PMIC: remove modular references from non-modular code
ACPICA: Linux: Enable ACPI_MUTEX_DEBUG for Linux kernel
ACPI: Rename configfs.c to acpi_configfs.c to prevent link error
ACPI / debugger: Add AML debugger documentation
ACPI: Add documentation describing ACPICA release automation
ACPI: add support for loading SSDTs via configfs
ACPI: add support for configfs
efi / ACPI: load SSTDs from EFI variables
It can be useful for JIT software to be aware of MIDR_EL1 and
REVIDR_EL1 to ascertain the presence of any core errata that could
affect code generation.
This patch exposes these registers through sysfs:
/sys/devices/system/cpu/cpu$ID/regs/identification/midr_el1
/sys/devices/system/cpu/cpu$ID/regs/identification/revidr_el1
where $ID is the cpu number. For big.LITTLE systems, one can have a
mixture of cores (e.g. Cortex A53 and Cortex A57), thus all CPUs need
to be enumerated.
If the kernel does not have valid information to populate these entries
with, an empty string is returned to userspace.
Cc: Mark Rutland <mark.rutland@arm.com>
Reviewed-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Steve Capper <steve.capper@linaro.org>
[suzuki.poulose@arm.com: ABI documentation updates, hotplug notifiers, kobject changes]
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
New tables can be loaded by creating directories under /config/table/
and writing the AML code into the aml table attribute. Various table
attributes will be readable once the table is successfully loaded.
Unloading tables is not supported at the moment, but it can be easily
implemented once ACPI loading functions provide a table handle to be
used for unloading.
Signed-off-by: Octavian Purdila <octavian.purdila@intel.com>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Register the ACPI subsystem with configfs.
git://git.open-mesh.org/linux-merge
Simon Wunderlich says:
This feature patchset includes the following changes:
- two patches with minimal clean up work by Antonio Quartulli and
Simon Wunderlich
- eight patches of B.A.T.M.A.N. V, API and documentation clean
up work, by Antonio Quartulli and Marek Lindner
- Andrew Lunn fixed the skb priority adoption when forwarding
fragmented packets (two patches)
- Multicast optimization support is now enabled for bridges which
comes with some protocol updates, by Linus Luessing
Adds a new per-device sysfs attribute "current_timestamp_clock" to allow
userspace to select a particular POSIX clock for buffered samples and
events timestamping.
Following clocks, as listed in clock_gettime(2), are supported:
CLOCK_REALTIME, CLOCK_MONOTONIC, CLOCK_MONOTONIC_RAW,
CLOCK_REALTIME_COARSE, CLOCK_MONOTONIC_COARSE, CLOCK_BOOTTIME and
CLOCK_TAI.
Signed-off-by: Gregor Boirie <gregor.boirie@parrot.com>
Acked-by: Sanchayan Maity <maitysanchayan@gmail.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
Acked-by: Antonio Quartulli <a@unstable.cc>
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
Also update obsolete email address.
We want the fixes in here, and we can resolve a merge issue in
drivers/iio/industrialio-trigger.c
Pull USB fixes from Greg KH:
"Here are a bunch (65) of USB fixes for 4.7-rc4. Sorry about the
quantity, I've been slow in getting these out.
The majority are the "normal" gadget, musb, and xhci fixes, that we
all are used to. There are also a few other tiny fixes resolving a
number of reported issues that showed up in 4.7-rc1.
All of these have been in linux-next"
* tag 'usb-4.7-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (65 commits)
usbip: rate limit get_frame_number message
usb: musb: sunxi: Remove bogus "Frees glue" comment
usb: musb: sunxi: Fix NULL ptr deref when gadget is registered before musb
usb: echi-hcd: Add ehci_setup check before echi_shutdown
usb: host: ehci-msm: Conditionally call ehci suspend/resume
MAINTAINERS: Add file patterns for usb device tree bindings
usb: host: ehci-tegra: Avoid getting the same reset twice
usb: host: ehci-tegra: Grab the correct UTMI pads reset
USB: mos7720: delete parport
USB: OHCI: Don't mark EDs as ED_OPER if scheduling fails
phy: ti-pipe3: Program the DPLL even if it was already locked
usb: musb: Stop bulk endpoint while queue is rotated
usb: musb: Ensure rx reinit occurs for shared_fifo endpoints
usb: musb: host: correct cppi dma channel for isoch transfer
usb: musb: only restore devctl when session was set in backup
usb: phy: Check initial state for twl6030
usb: musb: Use normal module_init for 2430 glue
usb: musb: Remove pm_runtime_set_irq_safe
usb: musb: Remove extra PM runtime calls from 2430 glue layer
usb: musb: Return error value from musb_mailbox
Allow a user to read PWM capture results from sysfs. To start a capture
and read the result, simply read the file:
$ cat $PWMCHIP/capture
The output format is "<period> <duty cycle>".
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next
Jonathan writes:
First round of IIO new device support, features and cleanups for the 4.8 cycle.
New device support
* ads1015
- add ads1115 support
* bma220 accelerometer
- new driver
- triggered buffer support.
* bmc150
- add bmm150 support.
* bmp280
- bme280 support with addition of humidity channel.
* max5487 potentiometer
- new driver
* MMA7660FC accelerometer.
- New driver
* st-pressure
- support for the lps22hb
* loop trigger.
- This one is *nasty* but we have real applications (parrot drones) where
it is useful. The trigger basically spins as hard as it can firing off
a new trigger each time all triggered devices come back to say they are
done. It doesn't hang a machine even when doing it on a dummy driver.
A lot nicer than having this implemented within lots of device drivers
anyway.
Core stuff
* Add support to create IIO devices via configfs (similar to we did for
triggers a while back) + docs.
* New channel types
- IIO_ELECTRICAL_CONDUCTIVITY
* Couple of MAINTAINERS patches to list the device tree bindings.
* Make trigger ops structure non optional (comment fix). It hasn't been for
an awful long time, but that's not what the description said.
New features
* ak8975
- support adapters that are limited to byte data only by allowing the
emulated block read i2c function that was recently introduced.
* atlas-ph
- support atlas-ec (electrical conductivity sensor)
* bmi160
- add available frequency and scale attributes to make the driver
more user friendly (and avoid having to read the datasheet to know
what will work).
* dummy
- move creation to configfs interface. It's not real hardware so we
are not that worried about the ABI breakage ;)
* mma8452
- oversampling ration support
* nau7802
- expose available gains to make life easier for userspace.
* st-sensors
- allow use of emulation for SMBus block reads as all the st parts support
it.
* ti-ads1015
- list datasheet names to allow their use by inkernel consumers.
* Various module alias additions to help auto probing. Drop one redundant one
as well.
Cleanups
* ad7266, ad7476, ad7887, ad7923, ad799x
- use direct mode claim function rather than open coding it during sensor
read (prevents switching on buffers mid read).
* ad7793, ad7791
- use direct mode claim to prevent frequency changes when buffers running.
* afe440x - These are ABI breaking but the driver requires custom userspace
code to do anything useful anyway and that is still being written and under
control of TI. Ultimately we may have other libraries to do pulse
oximetry with these devices but we aren't aware of any yet.
- kernel-doc format fixes
- drop ifdef fun around of_match_ptr - it's not worth the mess to save
a tiny amount of space.
- drop some unnecessary register initializations.
- drop the weird locked gain modes as they gain us nothing (can just set
all gains separately).
- remove handling of offset attributes seeing as no channels actually have
them (oops)
- Drop the LED3 input channel as it's an alias for ALED2.
- *big one* remove channel names - an experiment that turned out to not
make sense - see patch for details.
- use regmap fields to clean up code.
- tie the tia gain stages to appropriate channels in the ABI as that is
what they really effect. Same with the LED currents.
- cleanout some unused defines and fix a missnamed one.
* atlas-ph
- reorganise to allow support of other similar parts.
* bmc150
- document supported chips in kconfig help.
* jsa1212
- drop an unneeded i2c functionality check for functionality the driver
doesn't use.
* mxs-lradc
- simply touch screen registration code.
- remove the touch screen unregister as all devm based now.
- disable only those channels that are masked in hardware stop (others
are already dealt with elsewhere)
* st-sensors
- unexport st_sensors_get_buffer_element as nothing outside the st-sensors
core driver uses it.
- fix handling of failure to start up regulators.
* tpl0102
- drop an i2c functionality test for features that aren't needed.
* ti-am335x
- use variable name rather than type in sizeof for clarity.
- use SIMPLE_DEV_PM_OPS helper macro to tidy up a bit.
Tools
* Add install / uninstall to makefile. Someone cares, so presumably
some people will find it useful!
* generic_buffer
- rename to iio_generic_buffer to line up with other tools.
- handle cleanup when receiving signals
- Add a --device-num option and a --trigger-num option rather than
relying on naming which doesn't work if you have two of the same part.
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus
Jonathan writes:
First round of iio fixes for the 4.7 cycle.
A slightly bumper set due to travel delaying the pull request and a fair few
issues with the recent merge window patches. Patches all over the place.
The st-sensors one is probably the most involved, but definitly solves the
issues seen. Note there are some other issues around that handler
(and the fact that a lot of boards tie a level interrupt chip to an
edge interrupt only irq chip). These are not regressions however, so
will turn up the slow route.
* core
- iio_trigger_attach_pollfunc had some really badly wrong error handling.
Another nasty triggered whilst chasing down issues with the st sensors
rework below.
* ad5592r
- fix an off by one error when allocating channels.
* am2315
- a stray mutex unlock before we ever take the lock.
* apds9960
- missing a parent in the driver model (which should be the i2c device).
Result is it doesn't turn up under /sys/bus/i2c/devices which some
userspace code uses for repeatable device identification.
* as3935
- ABI usage bug which meant a processed value was reported as raw. Now
reporting scale as well to ensure userspace has the info it needs.
- Don't return processed value via the buffer - it doesn't conform to
the ABI and will overflow in some cases.
- Fix a wrongly sized buffer which would overflow trashing part of the
stack. Also move it onto the heap as part of the fix.
* bh1780
- a missing return after write in debugfs lead to an incorrect read and
a null pointer dereference.
- dereferencing the wrong pointer in suspend and resume leading to
unpredictable results.
- assign a static name to avoid accidentally ending up with no name if
loaded via device tree.
* bmi160
- output data rate for the accelerometer was incorrectly reported. Fix it.
- writing the output data rate was also wrong due to reverse parameters.
* bmp280
- error message for wrong chip ID gave the wrong expected value.
* hdc100x
- mask for writing the integration time was wrong allowin g us to get
'stuck' in a particular value with no way back.
- temperature reported in celsius rather than millicelsius as per the
ABI.
- Get rid of some incorrect data shifting which lead to readings being
rather incorrect.
* max44000
- drop scale attribute for proximity as it is an unscaled value (depends
on what is in range rather than anything knowable at the detector).
* st-pressure
- ABI compliance fixes - units were wrong.
* st-sensors
- We introduced some nasty issues with the recent switch over to a
a somewhat threaded handler in that we broke using a software trigger
with these devices. Now do it properly. It's a larger patch than ideal
for a fix, but the logic is straight forward.
- Make sure the trigger is initialized before requesting the interrupt.
This matters now the interrupt can be shared. Before it was ugly and wrong
but short of flakey hardware could not be triggered.
- Hammer down the dataready pin at boot - otherwise with really
unlucky timing things could get interestingly wedged requiring a hard power
down of the chip.
v3.20 doesn't exist, it is actually v4.0.
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Signed-off-by: Matt Ranostay <mranostay@gmail.com>
Pull UBI/UBIFS updates from Richard Weinberger:
"This contains mostly cleanups and minor improvements of UBI and UBIFS"
* tag 'upstream-4.7-rc1' of git://git.infradead.org/linux-ubifs:
ubifs: ubifs_dump_inode: Fix dumping field bulk_read
UBI: Fix static volume checks when Fastmap is used
UBI: Set free_count to zero before walking through erase list
UBI: Silence an unintialized variable warning
UBI: Clean up return in ubi_remove_volume()
UBI: Modify wrong comment in ubi_leb_map function.
UBI: Don't read back all data in ubi_eba_copy_leb()
UBI: Add ro-mode sysfs attribute
On serious situations, UBI may detect serious device corruption,
and switch to read-only mode to protect the data and allow debugging.
This commit exposes this ro-mode on sysfs, so it can be obtained
by userspace tools.
Signed-off-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
Signed-off-by: Richard Weinberger <richard@nod.at>
IIO_CHAN_INFO_RAW was returning processed data which was incorrect.
This also adds the IIO_CHAN_INFO_SCALE value to convert to a processed value.
Cc: <Stable@vger.kernel.org>
