commit 4bc58eb16bb2352854b9c664cc36c1c68d2bfbb7 upstream.
Fix the name of attribute
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 8cd50626823c00ca7472b2f61cb8c0eb9798ddc0 upstream.
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus
Jonathan writes:
First set of IIO fixes for the 4.2 cycle.
* Fix a regression in hid sensors suspend time as a result of adding runtime
pm. The normal flow of waking up devices in order to go into suspend
(given the devices are normally suspended when not reading) to a regression
in suspend time on some laptops (reports of an additional 8 seconds).
Fix this by checking to see if a user action resulting in the wake up, and
make it a null operation if it didn't. Note that for hid sensors, there is
nothing useful to be done when moving into a full suspend from a runtime
suspend so they might as well be left alone.
* rochip_saradc: fix some missing MODULE_* data including the licence so that
the driver does not taint the kernel incorrectly and can build as a module.
* twl4030 - mark irq as oneshot as it always should have been.
* inv-mpu - write formats for attributes not specified, leading to miss
interpretation of the gyro scale channel when written.
* Proximity ABI clarification. This had snuck through as a mess. Some
drivers thought proximity went in one direction, some the other. We went
with the most common option, documented it and fixed up the drivers going
the other way. Fix for sx9500 included in this set.
* ad624r - fix a wrong shift in the output data.
* at91_adc - remove a false limit on the value of the STARTUP register
applied by too small a type for the device tree parameter.
* cm3323 - clear the bits when setting the integration time (otherwise
we can only ever set more bits in the relevant field).
* bmc150-accel - multiple triggers are registered, but on error were not being
unwound in the opposite order leading to removal of triggers that had not
yet successfully been registered (count down instead of up when unwinding).
* tcs3414 - ensure right part of val / val2 pair read so that the integration
time is not always 0.
* cc10001_adc - bug in kconfig dependency. Use of OR when AND was intended.
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86
Pull x86 platform driver updates from Darren Hart:
"Fairly routine update for platform-drivers-x86.
Mostly fixes and cleanups, with a significant refactoring of toshiba*
drivers. Includes the addition of the dell-rbtn driver.
Details:
asus-wmi:
- fan control
dell*:
- add Dell airplane mode switch driver
ideapad-laptop:
- platform rfkill fixes, and regression fix
pvpanic:
- handle missing _STA correctly
toshiba*:
- rafactor bluetooth support
- haps documentation
- driver cleanup
other:
- Use acpi_video_unregister_backlight instead of
acpi_video_unregister in serveral drivers.
- Orphan msi-wmi.
* tag 'platform-drivers-x86-v4.2-1' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: (24 commits)
MAINTAINERS: Orphan x86 driver msi-wmi
ideapad: fix software rfkill setting
dell-laptop: Use dell-rbtn instead i8042 filter when possible
dell-rbtn: Export notifier for other kernel modules
dell-rbtn: Dell Airplane Mode Switch driver
samsung-laptop: Use acpi_video_unregister_backlight instead of acpi_video_unregister
asus-wmi: Use acpi_video_unregister_backlight instead of acpi_video_unregister
apple_gmux: Use acpi_video_unregister_backlight instead of acpi_video_unregister
pvpanic: handle missing _STA correctly
ideapad_laptop: Lenovo G50-30 fix rfkill reports wireless blocked
asus-wmi: add fan control
Documentation/ABI: Add file describing the sysfs entries for toshiba_haps
toshiba_haps: Make use of DEVICE_ATTR_{RW, WO} macros
toshiba_haps: Replace sscanf with kstrtoint
toshiba_acpi: Bump driver version to 0.22
toshiba_acpi: Remove TOS_FAILURE check from some functions
toshiba_acpi: Comments cleanup
toshiba_acpi: Rename hci_{read, write}1 functions
toshiba_acpi: Remove no longer needed hci_{read, write}2 functions
toshiba_bluetooth: Change BT status message to debug
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"The main change in this kernel is Casey's generalized LSM stacking
work, which removes the hard-coding of Capabilities and Yama stacking,
allowing multiple arbitrary "small" LSMs to be stacked with a default
monolithic module (e.g. SELinux, Smack, AppArmor).
See
https://lwn.net/Articles/636056/
This will allow smaller, simpler LSMs to be incorporated into the
mainline kernel and arbitrarily stacked by users. Also, this is a
useful cleanup of the LSM code in its own right"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (38 commits)
tpm, tpm_crb: fix le64_to_cpu conversions in crb_acpi_add()
vTPM: set virtual device before passing to ibmvtpm_reset_crq
tpm_ibmvtpm: remove unneccessary message level.
ima: update builtin policies
ima: extend "mask" policy matching support
ima: add support for new "euid" policy condition
ima: fix ima_show_template_data_ascii()
Smack: freeing an error pointer in smk_write_revoke_subj()
selinux: fix setting of security labels on NFS
selinux: Remove unused permission definitions
selinux: enable genfscon labeling for sysfs and pstore files
selinux: enable per-file labeling for debugfs files.
selinux: update netlink socket classes
signals: don't abuse __flush_signals() in selinux_bprm_committed_creds()
selinux: Print 'sclass' as string when unrecognized netlink message occurs
Smack: allow multiple labels in onlycap
Smack: fix seq operations in smackfs
ima: pass iint to ima_add_violation()
ima: wrap event related data to the new ima_event_data structure
integrity: add validity checks for 'path' parameter
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB updates from Greg KH:
"Here's the big USB patchset for 4.2-rc1. As is normal these days, the
majority of changes are in the gadget drivers, with a bunch of other
small driver changes.
All of these have been in linux-next with no reported issues"
* tag 'usb-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (175 commits)
usb: dwc3: Use ASCII space in Kconfig
usb: chipidea: add work-around for Marvell HSIC PHY startup
usb: chipidea: allow multiple instances to use default ci_default_pdata
dt-bindings: Consolidate ChipIdea USB ci13xxx bindings
phy: add Marvell HSIC 28nm PHY
phy: Add Marvell USB 2.0 OTG 28nm PHY
dt-bindings: Add Marvell PXA1928 USB and HSIC PHY bindings
USB: ssb: use devm_kzalloc
USB: ssb: fix error handling in ssb_hcd_create_pdev()
usb: isp1760: check for null return from kzalloc
cdc-acm: Add support of ATOL FPrint fiscal printers
usb: chipidea: usbmisc_imx: Remove unneeded semicolon
USB: usbtmc: add device quirk for Rigol DS6104
USB: serial: mos7840: Use setup_timer
phy: twl4030-usb: add ABI documentation
phy: twl4030-usb: remove incorrect pm_runtime_get_sync() in probe function.
phy: twl4030-usb: remove pointless 'suspended' test in 'suspend' callback.
phy: twl4030-usb: make runtime pm more reliable.
drivers:usb:fsl: Fix compilation error for fsl ehci drv
usb: renesas_usbhs: Don't disable the pipe if Control write status stage
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver updates from Greg KH:
"Here's the big, really big, staging tree patches for 4.2-rc1.
Loads of stuff in here, almost all just coding style fixes / churn,
and a few new drivers as well, one of which I just disabled from the
build a few minutes ago due to way too many build warnings.
Other than the one "disable this driver" patch, all of these have been
in linux-next for quite a while with no reported issues"
* tag 'staging-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1163 commits)
staging: wilc1000: disable driver due to build warnings
Staging: rts5208: fix CHANGE_LINK_STATE value
Staging: sm750fb: ddk750_swi2c.c: Insert spaces before parenthesis
Staging: sm750fb: ddk750_swi2c.c: Place braces on correct lines
Staging: sm750fb: ddk750_swi2c.c: Insert spaces around operators
Staging: sm750fb: ddk750_swi2c.c: Replace spaces with tabs
Staging: sm750fb: ddk750_swi2c.h: Shorten lines to under 80 characters
Staging: sm750fb: ddk750_swi2c.h: Replace spaces with tabs
Staging: sm750fb: modedb.h: Shorten lines to under 80 characters
Staging: sm750fb: modedb.h: Replace spaces with tabs
staging: comedi: addi_apci_3120: rename 'this_board' variables
staging: comedi: addi_apci_1516: rename 'this_board' variables
staging: comedi: ni_atmio: cleanup ni_getboardtype()
staging: comedi: vmk80xx: sanity check context used to get the boardinfo
staging: comedi: vmk80xx: rename 'boardinfo' variables
staging: comedi: dt3000: rename 'this_board' variables
staging: comedi: adv_pci_dio: rename 'this_board' variables
staging: comedi: cb_pcidas64: rename 'thisboard' variables
staging: comedi: cb_pcidas: rename 'thisboard' variables
staging: comedi: me4000: rename 'thisboard' variables
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg KH:
"Here is the driver core / firmware changes for 4.2-rc1.
A number of small changes all over the place in the driver core, and
in the firmware subsystem. Nothing really major, full details in the
shortlog. Some of it is a bit of churn, given that the platform
driver probing changes was found to not work well, so they were
reverted.
All of these have been in linux-next for a while with no reported
issues"
* tag 'driver-core-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (31 commits)
Revert "base/platform: Only insert MEM and IO resources"
Revert "base/platform: Continue on insert_resource() error"
Revert "of/platform: Use platform_device interface"
Revert "base/platform: Remove code duplication"
firmware: add missing kfree for work on async call
fs: sysfs: don't pass count == 0 to bin file readers
base:dd - Fix for typo in comment to function driver_deferred_probe_trigger().
firmware: use const for remaining firmware names
firmware: fix possible use after free on name on asynchronous request
firmware: check for file truncation on direct firmware loading
firmware: fix __getname() missing failure check
drivers: of/base: move of_init to driver_init
drivers/base: cacheinfo: fix annoying typo when DT nodes are absent
sysfs: disambiguate between "error code" and "failure" in comments
driver-core: fix build for !CONFIG_MODULES
driver-core: make __device_attach() static
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here's the big char/misc driver pull request for 4.2-rc1.
Lots of mei, extcon, coresight, uio, mic, and other driver updates in
here. Full details in the shortlog. All of these have been in
linux-next for some time with no reported problems"
* tag 'char-misc-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (176 commits)
mei: me: wait for power gating exit confirmation
mei: reset flow control on the last client disconnection
MAINTAINERS: mei: add mei_cl_bus.h to maintained file list
misc: sram: sort and clean up included headers
misc: sram: move reserved block logic out of probe function
misc: sram: add private struct device and virt_base members
misc: sram: report correct SRAM pool size
misc: sram: bump error message level on unclean driver unbinding
misc: sram: fix device node reference leak on error
misc: sram: fix enabled clock leak on error path
misc: mic: Fix reported static checker warning
misc: mic: Fix randconfig build error by including errno.h
uio: pruss: Drop depends on ARCH_DAVINCI_DA850 from config
uio: pruss: Add CONFIG_HAS_IOMEM dependence
uio: pruss: Include <linux/sizes.h>
extcon: Redefine the unique id of supported external connectors without 'enum extcon' type
char:xilinx_hwicap:buffer_icap - change 1/0 to true/false for bool type variable in function buffer_icap_set_configuration().
Drivers: hv: vmbus: Allocate ring buffer memory in NUMA aware fashion
parport: check exclusive access before register
w1: use correct lock on error in w1_seq_show()
Merge second patchbomb from Andrew Morton:
- most of the rest of MM
- lots of misc things
- procfs updates
- printk feature work
- updates to get_maintainer, MAINTAINERS, checkpatch
- lib/ updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (96 commits)
exit,stats: /* obey this comment */
coredump: add __printf attribute to cn_*printf functions
coredump: use from_kuid/kgid when formatting corename
fs/reiserfs: remove unneeded cast
NILFS2: support NFSv2 export
fs/befs/btree.c: remove unneeded initializations
fs/minix: remove unneeded cast
init/do_mounts.c: add create_dev() failure log
kasan: remove duplicate definition of the macro KASAN_FREE_PAGE
fs/efs: femove unneeded cast
checkpatch: emit "NOTE: <types>" message only once after multiple files
checkpatch: emit an error when there's a diff in a changelog
checkpatch: validate MODULE_LICENSE content
checkpatch: add multi-line handling for PREFER_ETHER_ADDR_COPY
checkpatch: suggest using eth_zero_addr() and eth_broadcast_addr()
checkpatch: fix processing of MEMSET issues
checkpatch: suggest using ether_addr_equal*()
checkpatch: avoid NOT_UNIFIED_DIFF errors on cover-letter.patch files
checkpatch: remove local from codespell path
checkpatch: add --showfile to allow input via pipe to show filenames
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
Pull DMI updates from Jean Delvare:
"The most important change is the new sysfs interface to the DMI table,
which will let user-space tools (such as dmidecode) access the table
without relying on /dev/mem"
* 'dmi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
firmware: dmi: struct dmi_header should be packed
firmware: dmi_scan: Coding style cleanups
Documentation: ABI: sysfs-firmware-dmi: add -entries suffix to file name
firmware: dmi_scan: add SBMIOS entry and DMI tables
firmware: dmi_scan: Trim DMI table length before exporting it
firmware: dmi_scan: Rename dmi_table to dmi_decode_table
firmware: dmi: List my quilt tree
firmware: dmi_scan: Only honor end-of-table for 64-bit tables
printk log_buf keeps various metadata for each message including its
sequence number and timestamp. The metadata is currently available only
through /dev/kmsg and stripped out before passed onto console drivers. We
want this metadata to be available to console drivers too so that console
consumers can get full information including the metadata and dictionary,
which among other things can be used to detect whether messages got lost
in transit.
This patch implements support for extended console drivers. Consoles can
indicate that they want extended messages by setting the new CON_EXTENDED
flag and they'll be fed messages formatted the same way as /dev/kmsg.
"<level>,<sequnum>,<timestamp>,<contflag>;<message text>\n"
If extended consoles exist, in-kernel fragment assembly is disabled. This
ensures that all messages emitted to consoles have full metadata including
sequence number. The contflag carries enough information to reassemble
the fragments from the reader side trivially. Note that this only affects
/dev/kmsg. Regular console and /proc/kmsg outputs are not affected by
this change.
* Extended message formatting for console drivers is enabled iff there
are registered extended consoles.
* Comment describing /dev/kmsg message format updated to add missing
contflag field and help distinguishing variable from verbatim terms.
Cc: Kay Sievers <kay@vrfy.org>
Reviewed-by: Petr Mladek <pmladek@suse.cz>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
pratyush.anand@st.com email-id doesn't exist anymore as I have left the
company. Replace ST's id with pratyush.anand@gmail.com.
Signed-off-by: Pratyush Anand <pratyush.anand@gmail.com>
We currently don't support on-demand device creation. The one and only
way to have N zram devices is to specify num_devices module parameter
(default value: 1). IOW if, for some reason, at some point, user wants
to have N + 1 devies he/she must umount all the existing devices, unload
the module, load the module passing num_devices equals to N + 1. And do
this again, if needed.
This patch introduces zram control sysfs class, which has two sysfs
attrs:
- hot_add -- add a new zram device
- hot_remove -- remove a specific (device_id) zram device
hot_add sysfs attr is read-only and has only automatic device id
assignment mode (as requested by Minchan Kim). read operation performed
on this attr creates a new zram device and returns back its device_id or
error status.
Usage example:
# add a new specific zram device
cat /sys/class/zram-control/hot_add
2
# remove a specific zram device
echo 4 > /sys/class/zram-control/hot_remove
Returning zram_add() error code back to user (-ENOMEM in this case)
cat: /sys/class/zram-control/hot_add: Cannot allocate memory
NOTE, there might be users who already depend on the fact that at least
zram0 device gets always created by zram_init(). Preserve this behavior.
[minchan@kernel.org: use zram->claim to avoid lockdep splat]
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Minchan Kim <minchan@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata updates from Tejun Heo:
- a number of libata core changes to better support NCQ TRIM.
- ahci now supports MSI-X in single IRQ mode to support a new
controller which doesn't implement MSI or INTX.
- ahci now supports edge-triggered IRQ mode to support a new controller
which for some odd reason did edge-triggered IRQ.
- the usual controller support additions and changes.
* 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (27 commits)
libata: Do not blacklist Micron M500DC
ata: ahci_mvebu: add suspend/resume support
ahci, msix: Fix build error for !PCI_MSI
ahci: Add support for Cavium's ThunderX host controller
ahci: Add generic MSI-X support for single interrupts to SATA PCI driver
libata: finally use __initconst in ata_parse_force_one()
drivers: ata: add support for Ceva sata host controller
devicetree:bindings: add devicetree bindings for ceva ahci
ahci: added support for Freescale AHCI sata
ahci: Store irq number in struct ahci_host_priv
ahci: Move interrupt enablement code to a separate function
Doc: libata: Fix spelling typo found in libata.xml
ata:sata_nv - Change 1 to true for bool type variable.
ata: add Broadcom AHCI SATA3 driver for STB chips
Documentation: devicetree: add Broadcom SATA binding
libata: Fix regression when the NCQ Send and Receive log page is absent
ata: hpt366: fix constant cast warning
ata: ahci_xgene: potential NULL dereference in probe
ata: ahci_xgene: Add AHCI Support for 2nd HW version of APM X-Gene SoC AHCI SATA Host controller.
libahci: Add support to handle HOST_IRQ_STAT as edge trigger latch.
The dmi-sysfs module adds DMI table structures entries under
/sys/firmware/dmi/entries only, so rename documentation file to
sysfs-firmware-dmi-entries as more appropriate. Without renaming it's
confusing to differ this from sysfs-firmware-dmi-tables that adds raw
DMI table and actually adds "dmi" kobject.
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@globallogic.com>
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Some utils, like dmidecode and smbios, need to access SMBIOS entry
table area in order to get information like SMBIOS version, size, etc.
Currently it's done via /dev/mem. But for situation when /dev/mem
usage is disabled, the utils have to use dmi sysfs instead, which
doesn't represent SMBIOS entry and adds code/delay redundancy when direct
access for table is needed.
So this patch creates dmi/tables and adds SMBIOS entry point to allow
utils in question to work correctly without /dev/mem. Also patch adds
raw dmi table to simplify dmi table processing in user space, as
proposed by Jean Delvare.
Tested-by: Roy Franz <roy.franz@linaro.org>
Pull documentation updates from Jonathan Corbet:
"The main thing here is Ingo's big subdirectory documenting feature
support for each architecture. Beyond that, it's the usual pile of
fixes, tweaks, and small additions"
* tag 'docs-for-linus' of git://git.lwn.net/linux-2.6: (79 commits)
doc:md: fix typo in md.txt.
Documentation/mic/mpssd: don't build x86 userspace when cross compiling
Documentation/prctl: don't build tsc tests when cross compiling
Documentation/vDSO: don't build tests when cross compiling
Doc:ABI/testing: Fix typo in sysfs-bus-fcoe
Doc: Docbook: Change wikipedia's URL from http to https in scsi.tmpl
Doc: Change wikipedia's URL from http to https
Documentation/kernel-parameters: add missing pciserial to the earlyprintk
Doc:pps: Fix typo in pps.txt
kbuild : Fix documentation of INSTALL_HDR_PATH
Documentation: filesystems: updated struct file_operations documentation in vfs.txt
kbuild: edit explanation of clean-files variable
Doc: ja_JP: Fix typo in HOWTO
Move freefall program from Documentation/ to tools/
Documentation: ARM: EXYNOS: Describe boot loaders interface
Doc:nfc: Fix typo in nfc-hci.txt
vfs: Minor documentation fix
Doc: networking: txtimestamp: fix printf format warning
Documentation, intel_pstate: Improve legacy mode internal governors description
Documentation: extend use case for EXPORT_SYMBOL_GPL()
Pull networking updates from David Miller:
1) Add TX fast path in mac80211, from Johannes Berg.
2) Add TSO/GRO support to ibmveth, from Thomas Falcon
3) Move away from cached routes in ipv6, just like ipv4, from Martin
KaFai Lau.
4) Lots of new rhashtable tests, from Thomas Graf.
5) Run ingress qdisc lockless, from Alexei Starovoitov.
6) Allow servers to fetch TCP packet headers for SYN packets of new
connections, for fingerprinting. From Eric Dumazet.
7) Add mode parameter to pktgen, for testing receive. From Alexei
Starovoitov.
8) Cache access optimizations via simplifications of build_skb(), from
Alexander Duyck.
9) Move page frag allocator under mm/, also from Alexander.
10) Add xmit_more support to hv_netvsc, from KY Srinivasan.
11) Add a counter guard in case we try to perform endless reclassify
loops in the packet scheduler.
12) Extern flow dissector to be programmable and use it in new "Flower"
classifier. From Jiri Pirko.
13) AF_PACKET fanout rollover fixes, performance improvements, and new
statistics. From Willem de Bruijn.
14) Add netdev driver for GENEVE tunnels, from John W Linville.
15) Add ingress netfilter hooks and filtering, from Pablo Neira Ayuso.
16) Fix handling of epoll edge triggers in TCP, from Eric Dumazet.
17) Add an ECN retry fallback for the initial TCP handshake, from Daniel
Borkmann.
18) Add tail call support to BPF, from Alexei Starovoitov.
19) Add several pktgen helper scripts, from Jesper Dangaard Brouer.
20) Add zerocopy support to AF_UNIX, from Hannes Frederic Sowa.
21) Favor even port numbers for allocation to connect() requests, and
odd port numbers for bind(0), in an effort to help avoid
ip_local_port_range exhaustion. From Eric Dumazet.
22) Add Cavium ThunderX driver, from Sunil Goutham.
23) Allow bpf programs to access skb_iif and dev->ifindex SKB metadata,
24) Add support for T6 chips in cxgb4vf driver, from Hariprasad Shenai.
25) Double TCP Small Queues default to 256K to accomodate situations
like the XEN driver and wireless aggregation. From Wei Liu.
26) Add more entropy inputs to flow dissector, from Tom Herbert.
27) Add CDG congestion control algorithm to TCP, from Kenneth Klette
Jonassen.
28) Convert ipset over to RCU locking, from Jozsef Kadlecsik.
29) Track and act upon link status of ipv4 route nexthops, from Andy
Gospodarek.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1670 commits)
bridge: vlan: flush the dynamically learned entries on port vlan delete
bridge: multicast: add a comment to br_port_state_selection about blocking state
net: inet_diag: export IPV6_V6ONLY sockopt
stmmac: troubleshoot unexpected bits in des0 & des1
net: ipv4 sysctl option to ignore routes when nexthop link is down
net: track link-status of ipv4 nexthops
net: switchdev: ignore unsupported bridge flags
net: Cavium: Fix MAC address setting in shutdown state
drivers: net: xgene: fix for ACPI support without ACPI
ip: report the original address of ICMP messages
net/mlx5e: Prefetch skb data on RX
net/mlx5e: Pop cq outside mlx5e_get_cqe
net/mlx5e: Remove mlx5e_cq.sqrq back-pointer
net/mlx5e: Remove extra spaces
net/mlx5e: Avoid TX CQE generation if more xmit packets expected
net/mlx5e: Avoid redundant dev_kfree_skb() upon NOP completion
net/mlx5e: Remove re-assignment of wq type in mlx5e_enable_rq()
net/mlx5e: Use skb_shinfo(skb)->gso_segs rather than counting them
net/mlx5e: Static mapping of netdev priv resources to/from netdev TX queues
net/mlx4_en: Use HW counters for rx/tx bytes/packets in PF device
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux
Pull powerpc updates from Michael Ellerman:
- disable the 32-bit vdso when building LE, so we can build with a
64-bit only toolchain.
- EEH fixes from Gavin & Richard.
- enable the sys_kcmp syscall from Laurent.
- sysfs control for fastsleep workaround from Shreyas.
- expose OPAL events as an irq chip by Alistair.
- MSI ops moved to pci_controller_ops by Daniel.
- fix for kernel to userspace backtraces for perf from Anton.
- merge pseries and pseries_le defconfigs from Cyril.
- CXL in-kernel API from Mikey.
- OPAL prd driver from Jeremy.
- fix for DSCR handling & tests from Anshuman.
- Powernv flash mtd driver from Cyril.
- dynamic DMA Window support on powernv from Alexey.
- LLVM clang fixes & workarounds from Anton.
- reworked version of the patch to abort syscalls when transactional.
- fix the swap encoding to support 4TB, from Aneesh.
- various fixes as usual.
- Freescale updates from Scott: Highlights include more 8xx
optimizations, an e6500 hugetlb optimization, QMan device tree nodes,
t1024/t1023 support, and various fixes and cleanup.
* tag 'powerpc-4.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: (180 commits)
cxl: Fix typo in debug print
cxl: Add CXL_KERNEL_API config option
powerpc/powernv: Fix wrong IOMMU table in pnv_ioda_setup_bus_dma()
powerpc/mm: Change the swap encoding in pte.
powerpc/mm: PTE_RPN_MAX is not used, remove the same
powerpc/tm: Abort syscalls in active transactions
powerpc/iommu/ioda2: Enable compile with IOV=on and IOMMU_API=off
powerpc/include: Add opal-prd to installed uapi headers
powerpc/powernv: fix construction of opal PRD messages
powerpc/powernv: Increase opal-irqchip initcall priority
powerpc: Make doorbell check preemption safe
powerpc/powernv: pnv_init_idle_states() should only run on powernv
macintosh/nvram: Remove as unused
powerpc: Don't use gcc specific options on clang
powerpc: Don't use -mno-strict-align on clang
powerpc: Only use -mtraceback=no, -mno-string and -msoft-float if toolchain supports it
powerpc: Only use -mabi=altivec if toolchain supports it
powerpc: Fix duplicate const clang warning in user access code
vfio: powerpc/spapr: Support Dynamic DMA windows
vfio: powerpc/spapr: Register memory and define IOMMU v2
Pull SCSI updates from James Bottomley:
"This is the usual grab bag of driver updates (lpfc, hpsa,
megaraid_sas, cxgbi, be2iscsi) plus an assortment of minor updates.
There is also one new driver: the Cisco snic. The advansys driver has
been rewritten to get rid of the warning about converting it to the
DMA API, the tape statistics patch got in and finally, there's a
resuffle of SCSI header files to separate more cleanly initiator from
target mode (and better share the common definitions)"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (156 commits)
snic: driver for Cisco SCSI HBA
qla2xxx: Fix indentation
qla2xxx: Comment out unreachable code
fusion: remove dead MTRR code
advansys: fix compilation errors and warnings when CONFIG_PCI is not set
mptsas: fix depth param in scsi_track_queue_full
megaraid: fix irq setup process regression
lpfc: Update version to 10.7.0.0 for upstream patch set.
lpfc: Fix to drop PLOGIs from fabric node till LOGO processing completes
lpfc: Fix scsi task management error message.
lpfc: Fix cq_id masking problem.
lpfc: Fix scsi prep dma buf error.
lpfc: Add support for using block multi-queue
lpfc: Devices are not discovered during takeaway/giveback testing
lpfc: Fix vport deletion failure.
lpfc: Check for active portpeerbeacon.
lpfc: Update driver version for upstream patch set 10.6.0.1.
lpfc: Change buffer pool empty message to miscellaneous category
lpfc: Fix incorrect log message reported for empty FCF record.
lpfc: Fix rport leak.
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID updates from Jiri Kosina:
- spurious power/wakeup sysfs files removal for I2C-HID devices, from
Andrew Duggan
- Logitech M560 support, from Goffredo Baroncelli
- a lot of housekeeping cleanups to hid-lg4ff driver, from Michal Maly
- improved support for Plantronics devices, from Terry Junge
- Sony Motion Controller and Navigation Controller support and
subsequent cleanups of hid-sony driver, from Frank Praznik and Simon
Wood
- HW support improvements to the Wacom driver, from Jason Gerecke and
Ping Cheng
- assorted small cleanups and device ID additions all over the place
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (69 commits)
HID: cypress: use swap() in cp_report_fixup()
HID: microsoft: Add Surface Power Cover
HID: hid-sony: Fix report descriptor for Navigation Controller
HID: hid-sony: Navigation controller only has 1 LED and no rumble
HID: hid-sony: Add BT support for Navigation Controller
HID: wacom: Introduce new 'touch_input' device
HID: wacom: Split apart 'wacom_setup_pentouch_input_capabilites'
HID: wacom: Introduce a new WACOM_DEVICETYPE_PAD device_type
HID: wacom: Treat features->device_type values as flags
HID: wacom: Simplify 'wacom_update_name'
HID: rmi: Disable populating F30 when the touchpad has physical buttons
HID: plantronics: Update to map volume up/down controls
HID: sony: PS Move fix report descriptor
HID: sony: PS3 Move enable LEDs and Rumble via BT
HID: sony: Add support PS3 Move Battery via BT
HID: sony: Add quirk for MOTION_CONTROLLER_BT
HID: sony: Support PS3 Move Controller when connected via Bluetooth
HID: i2c-hid: Do not set the ACPI companion field in the HID device
usb, HID: Remove Vernier devices from lsusb and hid_ignore_list
HID: hidpp: Add driver for mouse logitech M560
This patch fix some spelling typo in sysfs-bus-fcoe
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
'for-4.2/rmi', 'for-4.2/sensor-hub', 'for-4.2/sjoy', 'for-4.2/sony' and 'for-4.2/wacom' into for-linus
drivers/hid/wacom_wac.c
The current "mask" policy option matches files opened as MAY_READ,
MAY_WRITE, MAY_APPEND or MAY_EXEC. This patch extends the "mask"
option to match files opened containing one of these modes. For
example, "mask=^MAY_READ" would match files opened read-write.
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Signed-off-by: Dr. Greg Wettstein <gw@idfusion.org>
Cc: stable@vger.kernel.org
The new "euid" policy condition measures files with the specified
effective uid (euid). In addition, for CAP_SETUID files it measures
files with the specified uid or suid.
Changelog:
- fixed checkpatch.pl warnings
- fixed avc denied {setuid} messages - based on Roberto's feedback
Current description for proximity measurement is ambiguous. While
the first part says that proximity is measured by observing
reflectivity, the second part incorrectly infers that reported values
should behave like a distance.
This is because of AS3935 lightning sensor which uses the proximity
API, while not being a true proximity sensor.
Note this is marked for stable as it accompanies a fix in ABI usage
to the sx9500 driver which would otherwise appear to be correct.
Fixes: 614e8842ddf ("iio: ABI: add clarification for proximity")
Signed-off-by: Daniel Baluta <daniel.baluta@intel.com>
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next
Jonathan writes:
Third round of new IIO drivers, cleanups and functionality for the 4.2 cycle.
Given Linus announced a 4.8rc coming up, hopefully time for one more
lot of IIO patches this cycle. Some of these are actually
improvements / fixes for patches earlier in the cycle.
New device support
* st_accel driver - support devices with 8 bit channels.
Cleanup
* A general cleanup of the iio tools under /tools/ from Hartmut.
I'm more than a little embarassed by how bad some of these were! Are well,
much more refined and less bug prone now.
These cover lots of stuff like unhandled error returns, memory leaks as
well as general refactoring to tidy the code up.
* iio_simple_dummy - fix memory leaks in the init functions, drop some
pointless error returns from functions that never generate errors and
make the module parameter explicitly unsigned.
* More buffer handling reworks from Lars-Peter, this time targetting hardware
buffers (a little used corner that looks likely to get more use in the near
future). Specifically:
- Always compute the masklength as inkernel buffer users may need it.
- Add a means of labeling which buffer modes a given buffer implementation
supports.
- In the case of hardware buffers, require strict scan matching rather than
matching to a superset. Currently the demux is bypassed by these drivers
(this may well not change for efficiency reasons) so allowing a superset
of channels to be selected would otherwise lead to more data than requested
confusing userspace.
Driver funcationality improvments
* mmc35240 - adds a compensation to the raw values as borrowed form Memsic's
own input driver.
* mma8452
- event support
- event debouncing
- high pass filter configuration
- triggers
* vf610 - allow conversion mode to be adjusted
Fixlets
* mmc35240
- Off by one error that by coincidence had no real effect.
- i2c_device_name should be lowercase.
- Lack of null terminator at end of attributes array.
- Avoid computing the fractional part of the magnetic field by moving
the scaling into userspace where floating point is available to simplify
the maths.
- Use a smaller sleep before assuming the measurement is done. This is
safe and improves the possible polling rate.
- Fix sensitivity on z-axis - datasheet disagrees with Memsic's releasedd
code and the value used in the code seems to be correct.
* stk3310 - make a local variable signed to ensure error handling works.
* twl4030
- fix calculation of the temperature sense current - bug unlikely
to have ever been noticed as the difference is small.
- Fix errors in descriptions.
This resolves a merge issue in musb_core.c and we want the fixes that
were in Linus's tree in this branch as well for testing.
We want the staging tree fixes in here too to help with testing and
merge issues.
We want the fixes in this branch as well for testing and merge
resolution.
Support configurable conversion mode through sysfs. So far, the
mode used was low-power, which is enabled by default now. Beside
that, the modes normal and high-speed are selectable as well.
Use the new device tree property which specifies the maximum ADC
conversion clock frequencies. Depending on the mode used, the
available resulting conversion frequency are calculated
dynamically.
Acked-by: Fugang Duan <B38611@freescale.com>
Signed-off-by: Stefan Agner <stefan@agner.ch>
Now that libcxl is public, let's document it.
Signed-off-by: Michael Neuling <mikey@neuling.org>
Acked-by: Ian Munsie <imunsie@au1.ibm.com>
Export the "AFU Error Buffer" via sysfs attribute (afu_err_buf). AFU
error buffer is used by the AFU to report application specific
errors. The contents of this buffer are AFU specific and are intended to
be interpreted by the application interacting with the afu.
Suggested-by: Michael Neuling <mikey@neuling.org>
Signed-off-by: Vaibhav Jain <vaibhav@linux.vnet.ibm.com>
This patch implements tape statistics in the st module via
sysfs. Current no statistics are available for tape I/O and there
is no easy way to reuse the block layer statistics for tape
as tape is a character device and does not have perform I/O in
sector sized chunks (the size of the data written to tape
can change). For tapes we also need extra stats related to
things like tape movement (via other I/O).
There have been multiple end users requesting statistics
including AT&T (and some HP customers who have not given
permission to be named). It is impossible for them
to investigate any issues related to tape performance
in a non-invasive way.
[jejb: eliminate PRId64]
Signed-off-by: Shane Seymour <shane.seymour@hp.com>
Tested-by: Shane Seymour <shane.seymour@hp.com>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mfleming/efi into x86/efi
Pull EFI changes from Matt Fleming:
- Use idiomatic negative error values in efivar_create_sysfs_entry()
instead of returning '1' to indicate error. (Dan Carpenter)
- Implement new support to expose the EFI System Resource Tables in sysfs,
which provides information for performing firmware updates. (Peter Jones)
- Documentation cleanup in the EFI handover protocol section which
falsely claimed that 'cmdline_size' needed to be filled out by the
boot loader. (Alex Smith)
- Align the order of SMBIOS tables in /sys/firmware/efi/systab to match
the way that we do things for ACPI and add documentation to
Documentation/ABI. (Jean Delvare)
drivers/net/phy/amd-xgbe-phy.c
drivers/net/wireless/iwlwifi/Kconfig
include/net/mac80211.h
iwlwifi/Kconfig and mac80211.h were both trivial overlapping
changes.
The drivers/net/phy/amd-xgbe-phy.c file got removed in 'net-next' and
the bug fix that happened on the 'net' side is already integrated
into the rest of the amd-xgbe driver.
This driver device one local attribute: vbus.
Describe that in Documentation/ABI/testing/sysfs-platform/twl4030-usb.
Signed-off-by: NeilBrown <neil@brown.name>
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
It's not clear right now that the order in which entries are displayed
in /sys/firmware/efi/systab actually forms an ABI that userspace tools
rely upon.
Document the ABI along with the userspace tool that cares.
Suggested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Reviewed-by: Jean Delvare <jdelvare@suse.de>
Cc: Leif Lindholm <leif.lindholm@linaro.org>
Cc: Ivan Khoronzhuk <ivan.khoronzhuk@globallogic.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
s/hierarcy/hierarchy/
Maybe the typo will annoy people enough so that they add the missing
nodes to their device-tree files, but I still think this is better off
fixed.
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
This patch provides support for the DS28EA00 digital thermometer.
The DS28EA00 provides an additional two pins for implementing a sequence
detection algorithm. This feature allows you to determine the physical
location of the chip in the 1-wire bus without needing pre-existing
knowledge of the bus ordering. Support is provided through the sysfs
w1_seq file. The file will contain a single line with an integer value
representing the device index in the bus starting at 0.
Signed-off-by: Matt Campbell <mattrcampbell@gmail.com>
Acked-by: Evgeniy Polyakov <zbr@ioremap.net>
Some of 1-Wire devices commonly associated with physical access control
systems are attached/generate presence for as short as 100 ms - hence
the tens-to-hundreds milliseconds scan intervals are required.
Signed-off-by: Dmitry Khromov <dk@icelogic.net>
Export name and uuid via sysfs and uevent
Cc: linux-api@vger.kernel.org
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
In order to automate modules matching add device uuid
which is reported in client enumeration, keep also
the name that is needed in for nfc distinguishing radio vendor
Report mei:name:uuid
Cc: Samuel Ortiz <sameo@linux.intel.com>
ETM ID registers contain valuable information about the capabilities
of the implementation and are very useful when configuring the device for
various trace scenarios.
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Having access to the ETMv4 management registers is very useful as they
give meaningful information on how the IP block has been configured at
synthesis time.
Adding sysfs entries to access and configure specifics about the
virtual machine ID comparator functions.
Signed-off-by: Pratik Patel <pratikp@codeaurora.org>
context ID comparator functions.
Adding sysfs entries to control the selection of the resources the
trace unit will use as triggers to perform a trace run.
Adding sysfs entries related to the counter functionality, more
specifically to set, control and reload the counters.
