path: root/Documentation/ABI
2010-06-11Revert "PCI: create function symlinks in /sys/bus/pci/slots/N/"Jesse Barnes
This reverts commit 75568f8094eb0333e9c2109b23cbc8b82d318a3c. Since they're just a convenience anyway, remove these symlinks since they're causing duplicate filename errors in the wild. Acked-by: Alex Chiang <achiang@canonical.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-05-27Merge branch 'sfi-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6 * 'sfi-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6: SFI: add sysfs interface for SFI tables. SFI: add support for v0.81 spec
2010-05-27SFI: add sysfs interface for SFI tables.Feng Tang
Analogous to ACPI's /sys/firmware/acpi/tables/... create /sys/firmware/sfi/tables/ The tables are primariy for the kernel, but sometimes it is useful for user-space to be able to read them. Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-25mm: compaction: add /sys trigger for per-node memory compactionMel Gorman
Add a per-node sysfs file called compact. When the file is written to, each zone in that node is compacted. The intention that this would be used by something like a job scheduler in a batch system before a job starts so that the job can allocate the maximum number of hugepages without significant start-up cost. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-24Merge git://git.infradead.org/battery-2.6Linus Torvalds
* git://git.infradead.org/battery-2.6: ds2760_battery: Document ABI change ds2760_battery: Make charge_now and charge_full writeable power_supply: Add support for writeable properties power_supply: Use attribute groups power_supply: Add test_power driver tosa_battery: Fix build error due to direct driver_data usage wm97xx_battery: Quieten sparse warning (bat_set_pdata not declared) ds2782_battery: Get rid of magic numbers in driver_data ds2782_battery: Add support for ds2786 battery gas gauge pda_power: Add function callbacks for suspend and resume wm831x_power: Use genirq Driver for Zipit Z2 battery chip ds2782_battery: Fix clientdata on removal
2010-05-21Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (36 commits) PCI: hotplug: pciehp: Removed check for hotplug of display devices PCI: read memory ranges out of Broadcom CNB20LE host bridge PCI: Allow manual resource allocation for PCI hotplug bridges x86/PCI: make ACPI MCFG reserved error messages ACPI specific PCI hotplug: Use kmemdup PM/PCI: Update PCI power management documentation PCI: output FW warning in pci_read/write_vpd PCI: fix typos pci_device_dis/enable to pci_dis/enable_device in comments PCI quirks: disable msi on AMD rs4xx internal gfx bridges PCI: Disable MSI for MCP55 on P5N32-E SLI x86/PCI: irq and pci_ids patch for additional Intel Cougar Point DeviceIDs PCI: aerdrv: trivial cleanup for aerdrv_core.c PCI: aerdrv: trivial cleanup for aerdrv.c PCI: aerdrv: introduce default_downstream_reset_link PCI: aerdrv: rework find_aer_service PCI: aerdrv: remove is_downstream PCI: aerdrv: remove magical ROOT_ERR_STATUS_MASKS PCI: aerdrv: redefine PCI_ERR_ROOT_*_SRC PCI: aerdrv: rework do_recovery PCI: aerdrv: rework get_e_source() ...
2010-05-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (59 commits) HID: fix up 'EMBEDDED' mess in Kconfig HID: roccat: cleanup preprocessor macros HID: roccat: refactor special event handling HID: roccat: fix special button support HID: roccat: Correctly mark init and exit functions HID: hidraw: Use Interrupt Endpoint for OUT Transfers if Available HID: hid-samsung: remove redundant key mappings HID: add omitted hid-zydacron.c file HID: hid-samsung: add support for Creative Desktop Wireless 6000 HID: picolcd: Eliminate use after free HID: Zydacron Remote Control driver HID: Use kmemdup HID: magicmouse: fix input registration HID: make Prodikeys driver standalone config option HID: Prodikeys PC-MIDI HID Driver HID: hidraw: fix indentation HID: ntrig: add filtering module parameters HID: ntrig: add sysfs access to filter parameters HID: ntrig: add sensitivity and responsiveness support HID: add multi-input quirk for eGalax Touchcontroller ...
2010-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (229 commits) USB: remove unused usb_buffer_alloc and usb_buffer_free macros usb: musb: update gfp/slab.h includes USB: ftdi_sio: fix legacy SIO-device header USB: kl5usb105: reimplement using generic framework USB: kl5usb105: minor clean ups USB: kl5usb105: fix memory leak USB: io_ti: use kfifo to implement write buffering USB: io_ti: remove unsused private counter USB: ti_usb: use kfifo to implement write buffering USB: ir-usb: fix incorrect write-buffer length USB: aircable: fix incorrect write-buffer length USB: safe_serial: straighten out read processing USB: safe_serial: reimplement read using generic framework USB: safe_serial: reimplement write using generic framework usb-storage: always print quirks USB: usb-storage: trivial debug improvements USB: oti6858: use port write fifo USB: oti6858: use kfifo to implement write buffering USB: cypress_m8: use kfifo to implement write buffering USB: cypress_m8: remove unused drain define ... Fix up conflicts (due to usb_buffer_alloc/free renaming) in drivers/input/tablet/acecad.c drivers/input/tablet/kbtab.c drivers/input/tablet/wacom_sys.c drivers/media/video/gspca/gspca.c sound/usb/usbaudio.c
2010-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1674 commits) qlcnic: adding co maintainer ixgbe: add support for active DA cables ixgbe: dcb, do not tag tc_prio_control frames ixgbe: fix ixgbe_tx_is_paused logic ixgbe: always enable vlan strip/insert when DCB is enabled ixgbe: remove some redundant code in setting FCoE FIP filter ixgbe: fix wrong offset to fc_frame_header in ixgbe_fcoe_ddp ixgbe: fix header len when unsplit packet overflows to data buffer ipv6: Never schedule DAD timer on dead address ipv6: Use POSTDAD state ipv6: Use state_lock to protect ifa state ipv6: Replace inet6_ifaddr->dead with state cxgb4: notify upper drivers if the device is already up when they load cxgb4: keep interrupts available when the ports are brought down cxgb4: fix initial addition of MAC address cnic: Return SPQ credit to bnx2x after ring setup and shutdown. cnic: Convert cnic_local_flags to atomic ops. can: Fix SJA1000 command register writes on SMP systems bridge: fix build for CONFIG_SYSFS disabled ARCNET: Limit com20020 PCI ID matches for SOHARD cards ... Fix up various conflicts with pcmcia tree drivers/net/ {pcmcia/3c589_cs.c, wireless/orinoco/orinoco_cs.c and wireless/orinoco/spectrum_cs.c} and feature removal (Documentation/feature-removal-schedule.txt). Also fix a non-content conflict due to pm_qos_requirement getting renamed in the PM tree (now pm_qos_request) in net/mac80211/scan.c
2010-05-20USB: Composite framework: Add suspended sysfs entryFabien Chouteau
This patch adds a sysfs entry (/sys/devices/platform/_UDC_/gadget/suspended) to show the suspend state of an USB composite gadget. Signed-off-by: Fabien Chouteau <fabien.chouteau@barco.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: deprecate the power/level sysfs attributeAlan Stern
This patch (as1367) deprecates USB's power/level sysfs attribute in favor of the power/control attribute provided by the runtime PM core. The two attributes do the same thing. It would be nice to replace power/level with a symlink to power/control, but at the moment sysfs doesn't offer any way to do so. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-19Merge branches 'ntrig', 'picolcd', 'prodikeys' and 'roccat-kone' into for-linusJiri Kosina
Conflicts: drivers/hid/Makefile
2010-05-19Merge branch 'upstream' into for-linusJiri Kosina
Conflicts: drivers/hid/hid-wacom.c
2010-05-19ds2760_battery: Document ABI changeDaniel Mack
Add some documentation for the newly added writeable properties. Suggested-by: Greg KH <gregkh@suse.de> Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-05-12HID: Prodikeys PC-MIDI HID DriverDon Prince
A specialised HID driver for the Creative Prodikeys PC-MIDI USB Keyboard. The Prodikeys PC-MIDI is a multifunction keyboard comprising a qwerty keyboard, multimedia keys and a touch sensitive musical keyboard. The specialised HID driver adds full support for the musical keyboard and extra multimedia keys which are not currently handled by the default HID driver. The specialised HID driver interfaces with ALSA, and presents the midi keyboard as a rawmidi device. Sustain duration, octave shifting and the midi output channel can be read/written form userspace via sysfs. Signed-off-by: Don Prince <dhprince-devel@yahoo.co.uk> ALSA parts: Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-11PCI: create function symlinks in /sys/bus/pci/slots/N/Alex Chiang
Create convenience symlinks in sysfs, linking slots to device functions, and vice versa. These links make it easier for users to figure out which devices actually live in what slots. For example: sapphire:/sys/bus/pci/slots # ls 1 10 2 3 4 5 6 7 8 9 sapphire:/sys/bus/pci/slots # ls -l 3 total 0 -r--r--r-- 1 root root 65536 Aug 18 14:10 address lrwxrwxrwx 1 root root 0 Aug 18 14:10 function0 -> ../../../../devices/pci0000:23/0000:23:01.0 lrwxrwxrwx 1 root root 0 Aug 18 14:10 function1 -> ../../../../devices/pci0000:23/0000:23:01.1 sapphire:/sys/bus/pci/slots # ls -l 3/function0/slot lrwxrwxrwx 1 root root 0 Aug 18 14:13 3/function0/slot -> ../../../bus/pci/slots/3 The original form of this patch was written by Matthew Wilcox, and was enhanced to include links from the sysfs slots/ directory pointing back at the device functions. Cc: willy@linux.intel.com Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-05-03Merge branch 'hid-suspend' into picolcdJiri Kosina
2010-04-27HID: split picolcd's operation_mode sysfs attributeBruno Prémont
Original operation_mode sysfs attribute accepts the operation mode as main value with an option delay as second value to change the start-up delay on mode change. As it is preferred to have exactly one value per sysfs attribute, extract this delay into a separate sysfs attribute called operation_mode_delay. Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-04-23HID: wacom: add ABI doc entry for speed attributePrzemo Firszt
Signed-off-by: Przemo Firszt <przemo@firszt.eu> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-04-23Documentation/: it's -> its where appropriateFrancis Galiegue
Fix obvious cases of "it's" being used when "its" was meant. Signed-off-by: Francis Galiegue <fgaliegue@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-04-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bonding/bond_main.c drivers/net/via-velocity.c drivers/net/wireless/iwlwifi/iwl-agn.c
2010-03-31HID: add framebuffer support to PicoLCD deviceBruno Prémont
Add framebuffer support to PicoLCD device with use of deferred-io. Only changed areas of framebuffer get sent to device in order to save USB bandwidth and especially resources on PicoLCD device or allow higher refresh rate for a small area. Changed tiles are determined while updating shadow framebuffer. Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-31HID: new driver for PicoLCD deviceBruno Prémont
Add basic driver for PicoLCD graphics device. Initially support keypad with input device and provide support for debugging communication via events file from debugfs. Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-22Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wireless/ath/ath5k/phy.c
2010-03-22HID: add driver for Roccat Kone gaming mouseStefan Achatz
This Patch adds support for Kone gaming mouse from Roccat. It provides access to profiles, settings, firmware, weight, actual settings etc. through sysfs attributes. Event handling of this mouse differs from standard hid behaviour in that tilt button press is reported in each move event which results in strange behaviour if not handled by the driver. This is a heavily reworked version of the previously introduced driver. The changes include most of the previously raised concerns, memory leak and other fixes, code cleanups, adoption of additional achieved knowlege about the hardware and is (IMHO) a much better version than before even when I exchanged reduced USB-IO with a bigger memory consumption. I refused to implement one mentioned point: Removing the 'just-because-we-can' attributes. Motivation: Reading the clipped in weight: I'm no gamer and can't determine the usefulness of this feature but if the manufacturer implements such a feature it might make sense to someone and I would unwillingly limit the functionality besides its such a small feature. Reading the actual profile and dpi settings: Here I can testify that one can get lost of the actual settings when switching back and forth. The manufacturers windows driver has the ability for on-screen-display of the values and there is a mouse in the market that has an lcd on the underside of it to show these values. So I think this feature makes sense not only for me and shouldn't be removed. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-19rename new rfkill sysfs knobsflorian@mickler.org
This patch renames the (never officially released) sysfs-knobs "blocked_hw" and "blocked_sw" to "hard" and "soft", as the hardware vs software conotation is misleading. It also gets rid of not needed locks around u32-read-access. Signed-off-by: Florian Mickler <florian@mickler.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-19USB: Fix documentation for avoid_reset_quirkOliver Neukum
The name used in the documentation doesn't match reality. Signed-off-by: Oliver Neukum <neukum@b1-systems.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-10enhance sysfs rfkill interfaceflorian@mickler.org
This commit introduces two new sysfs knobs. /sys/class/rfkill/rfkill[0-9]+/blocked_hw: (ro) hardblock kill state /sys/class/rfkill/rfkill[0-9]+/blocked_sw: (rw) softblock kill state Signed-off-by: Florian Mickler <florian@mickler.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10Document the rfkill sysfs ABIflorian@mickler.org
This moves sysfs ABI info from Documentation/rfkill.txt to the ABI subfolder and reformats it. This also schedules the deprecated sysfs parts to be removed in 2012 (claim file) and 2014 (state file). Signed-off-by: Florian Mickler <florian@mickler.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-06mm: document /sys/devices/system/node/nodeXMel Gorman
Add a bare description of what /sys/devices/system/node/nodeX is. Others will follow in time but right now, none of that tree is documented. The existence of this file might at least encourage people to document new entries. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (220 commits) USB: backlight, appledisplay: fix incomplete registration failure handling USB: pl2303: remove unnecessary reset of usb_device in urbs USB: ftdi_sio: remove obsolete check in unthrottle USB: ftdi_sio: remove unused tx_bytes counter USB: qcaux: driver for auxiliary serial ports on Qualcomm devices USB: pl2303: initial TIOCGSERIAL support USB: option: add Longcheer/Longsung vendor ID USB: fix I2C API usage in ohci-pnx4008. USB: usbmon: mask seconds properly in text API USB: sisusbvga: no unnecessary GFP_ATOMIC USB: storage: onetouch: unnecessary GFP_ATOMIC USB: serial: ftdi: add CONTEC vendor and product id USB: remove references to port->port.count from the serial drivers USB: tty: Prune uses of tty_request_room in the USB layer USB: tty: Add a function to insert a string of characters with the same flag USB: don't read past config->interface[] if usb_control_msg() fails in usb_reset_configuration() USB: tty: kill request_room for USB ACM class USB: tty: sort out the request_room handling for whiteheat USB: storage: fix misplaced parenthesis USB: vstusb.c: removal of driver for Vernier Software & Technology, Inc., devices and spectrometers ...
2010-03-03Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86: (45 commits) compal-laptop: Make it depend on CONFIG_RFKILL classmate-laptop: Added some keys present in other devices MAINTAINERS: Add git tree to x86 Platform Drivers asus-acpi: remove duplicate comparison of asus_model strings toshiba-acpi: fix multimedia keys on some machines dell-laptop: Fix errors on failure and exit paths dell-laptop: Fix build error by making buffer_mutex static asus-laptop: fix style problems reported by checkpath.pl asus-laptop: use device_create_file() instead of platform_group asus-laptop: clean led code asus-laptop: add gps rfkill asus-laptop: set initial lcd state asus-laptop: leds, remove dead code and fix asus_led_exit()/asus_led_init() asus-laptop: add backlight changes notifications asus-laptop: add bluetooth keys found on M9V asus-laptop: switch to sparse keymap library asus-laptop: rename wireless_status to wlan_status to avoid confusion asus-laptop: add error check for write_acpi_int calls asus-laptop: stop using ASUS_HANDLE and use relative methods instead asus-laptop: rename function talking directly to acpi with asus_xxx scheme ...
2010-03-02USB: Export QUIRK_RESET_MORPHS through sysfsOliver Neukum
Some devices which use mode switching revert to their primary mode as they are reset. They must not be reset for error handling. As user spaces makes the switch it also has to tell the kernel that a device is quirky. Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-01Merge branch 'for-2.6.34' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.34' of git://git.kernel.dk/linux-2.6-block: (38 commits) block: don't access jiffies when initialising io_context cfq: remove 8 bytes of padding from cfq_rb_root on 64 bit builds block: fix for "Consolidate phys_segment and hw_segment limits" cfq-iosched: quantum check tweak blktrace: perform cleanup after setup error blkdev: fix merge_bvec_fn return value checks cfq-iosched: requests "in flight" vs "in driver" clarification cciss: Fix problem with scatter gather elements in the scsi half of the driver cciss: eliminate unnecessary pointer use in cciss scsi code cciss: do not use void pointer for scsi hba data cciss: factor out scatter gather chain block mapping code cciss: fix scatter gather chain block dma direction kludge cciss: simplify scatter gather code cciss: factor out scatter gather chain block allocation and freeing cciss: detect bad alignment of scsi commands at build time cciss: clarify command list padding calculation cfq-iosched: rethink seeky detection for SSDs cfq-iosched: rework seeky detection block: remove padding from io_context on 64bit builds block: Consolidate phys_segment and hw_segment limits ...
2010-03-01Merge git://git.iksaif.net/acpi4asus into x86-platformMatthew Garrett
2010-02-28Merge branch 'eeepc-laptop' into acpi4asusCorentin Chary
2010-02-28asus-laptop: set the right paths in the documentationCorentin Chary
Signed-off-by: Corentin Chary <corentincj@iksaif.net>
2010-02-28eeepc-laptop: set the right paths in the documentationCorentin Chary
2010-02-26PM: Add facility for advanced testing of async suspend/resumeRafael J. Wysocki
Add configuration switch CONFIG_PM_ADVANCED_DEBUG for compiling in extra PM debugging/testing code allowing one to access some PM-related attributes of devices from the user space via sysfs. If CONFIG_PM_ADVANCED_DEBUG is set, add sysfs attribute power/async for every device allowing the user space to access the device's power.async_suspend flag and modify it, if desired. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-02-26PM: Add a switch for disabling/enabling asynchronous suspend/resumeRafael J. Wysocki
Add sysfs attribute /sys/power/pm_async allowing the user space to disable/enable asynchronous suspend/resume of devices. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-02-26PM: Document device power attributes in sysfsRafael J. Wysocki
There are sysfs attributes in /sys/devices/.../power/ that haven't been documented yet in Documentation/ABI/. Document them as appropriate. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-02-22Merge branch 'master' into for-2.6.34Jens Axboe
2010-02-07ima: rename PATH_CHECK to FILE_CHECKMimi Zohar
With the movement of the ima hooks functions were renamed from *path* to *file* since they always deal with struct file. This patch renames some of the ima internal flags to make them consistent with the rest of the code. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-01-29block: Added in stricter no merge semantics for block I/OAlan D. Brunelle
Updated 'nomerges' tunable to accept a value of '2' - indicating that _no_ merges at all are to be attempted (not even the simple one-hit cache). The following table illustrates the additional benefit - 5 minute runs of a random I/O load were applied to a dozen devices on a 16-way x86_64 system. nomerges Throughput %System Improvement (tput / %sys) -------- ------------ ----------- ------------------------- 0 12.45 MB/sec 0.669365609 1 12.50 MB/sec 0.641519199 0.40% / 2.71% 2 12.52 MB/sec 0.639849750 0.56% / 2.96% Signed-off-by: Alan D. Brunelle <alan.brunelle@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-23USB: power management documentation updateAlan Stern
This patch (as1313) updates the documentation concerning USB power management. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-16HWPOISON: Add soft page offline supportAndi Kleen
This is a simpler, gentler variant of memory_failure() for soft page offlining controlled from user space. It doesn't kill anything, just tries to invalidate and if that doesn't work migrate the page away. This is useful for predictive failure analysis, where a page has a high rate of corrected errors, but hasn't gone bad yet. Instead it can be offlined early and avoided. The offlining is controlled from sysfs, including a new generic entry point for hard page offlining for symmetry too. We use the page isolate facility to prevent re-allocation race. Normally this is only used by memory hotplug. To avoid races with memory allocation I am using lock_system_sleep(). This avoids the situation where memory hotplug is about to isolate a page range and then hwpoison undoes that work. This is a big hammer currently, but the simplest solution currently. When the page is not free or LRU we try to free pages from slab and other caches. The slab freeing is currently quite dumb and does not try to focus on the specific slab cache which might own the page. This could be potentially improved later. Thanks to Fengguang Wu and Haicheng Li for some fixes. [Added fix from Andrew Morton to adapt to new migrate_pages prototype] Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-15Documentation: ABI: /sys/devices/system/cpu/cpu#/nodeAlex Chiang
Describe NUMA node symlink created for CPUs when CONFIG_NUMA is set. Signed-off-by: Alex Chiang <achiang@hp.com> Cc: Greg KH <greg@kroah.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Gary Hade <garyhade@us.ibm.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mm: add numa node symlink for memory section in sysfsAlex Chiang
Commit c04fc586c (mm: show node to memory section relationship with symlinks in sysfs) created symlinks from nodes to memory sections, e.g. /sys/devices/system/node/node1/memory135 -> ../../memory/memory135 If you're examining the memory section though and are wondering what node it might belong to, you can find it by grovelling around in sysfs, but it's a little cumbersome. Add a reverse symlink for each memory section that points back to the node to which it belongs. Signed-off-by: Alex Chiang <achiang@hp.com> Cc: Gary Hade <garyhade@us.ibm.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: David Rientjes <rientjes@google.com> Cc: Greg KH <greg@kroah.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-12Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (151 commits) powerpc: Fix usage of 64-bit instruction in 32-bit altivec code MAINTAINERS: Add PowerPC patterns powerpc/pseries: Track previous CPPR values to correctly EOI interrupts powerpc/pseries: Correct pseries/dlpar.c build break without CONFIG_SMP powerpc: Make "intspec" pointers in irq_host->xlate() const powerpc/8xx: DTLB Miss cleanup powerpc/8xx: Remove DIRTY pte handling in DTLB Error. powerpc/8xx: Start using dcbX instructions in various copy routines powerpc/8xx: Restore _PAGE_WRITETHRU powerpc/8xx: Add missing Guarded setting in DTLB Error. powerpc/8xx: Fixup DAR from buggy dcbX instructions. powerpc/8xx: Tag DAR with 0x00f0 to catch buggy instructions. powerpc/8xx: Update TLB asm so it behaves as linux mm expects. powerpc/8xx: Invalidate non present TLBs powerpc/pseries: Serialize cpu hotplug operations during deactivate Vs deallocate pseries/pseries: Add code to online/offline CPUs of a DLPAR node powerpc: stop_this_cpu: remove the cpu from the online map. powerpc/pseries: Add kernel based CPU DLPAR handling sysfs/cpu: Add probe/release files powerpc/pseries: Kernel DLPAR Infrastructure ...
2009-12-12Merge branches 'slab/fixes', 'slab/kmemleak', 'slub/perf' and 'slub/stats' ↵Pekka Enberg
into for-linus
