Current documentation over use case for EXPORT_SYMBOL_GPL()
only acknowledges functions which are "an internal implementation
issue, and not really an interface". In practice these days
though we have some maintainers taking on preferences to require
all new functionality go in with EXPORT_SYMBOL_GPL().
A maintainer asking developers to use EXPORT_SYMBOL_GPL()
for new functionality tends to be a well accepted and understood
position that maintainers can take and typically requires the
maintainers educating contributing developers on their own
positions and requirements.
Developers who submit code to maintainers not familiar with
these preferences as optional for new functionality need explicit
guidence though as existing documentation does not acknowledge
this as a valid possibility. Without this being documented some
maintainers are reluctant to accept new functionality with
This extends the use case documentation for EXPORT_SYMBOL_GPL()
to acknowledge acceptance for new functionality.
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
[jc: wording tweaked with permission]
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Merge second patch-bomb from Andrew Morton:
- the rest of MM
- zram updates
- zswap updates
- exit
- procfs
- exec
- wait
- crash dump
- lib/idr
- rapidio
- adfs, affs, bfs, ufs
- cris
- Kconfig things
- initramfs
- small amount of IPC material
- percpu enhancements
- early ioremap support
- various other misc things
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (156 commits)
MAINTAINERS: update Intel C600 SAS driver maintainers
fs/ufs: remove unused ufs_super_block_third pointer
fs/ufs: remove unused ufs_super_block_second pointer
fs/ufs: remove unused ufs_super_block_first pointer
fs/ufs/super.c: add __init to init_inodecache()
doc/kernel-parameters.txt: add early_ioremap_debug
arm64: add early_ioremap support
arm64: initialize pgprot info earlier in boot
x86: use generic early_ioremap
mm: create generic early_ioremap() support
x86/mm: sparse warning fix for early_memremap
lglock: map to spinlock when !CONFIG_SMP
percpu: add preemption checks to __this_cpu ops
vmstat: use raw_cpu_ops to avoid false positives on preemption checks
slub: use raw_cpu_inc for incrementing statistics
net: replace __this_cpu_inc in route.c with raw_cpu_inc
modules: use raw_cpu_write for initialization of per cpu refcount.
mm: use raw_cpu ops for determining current NUMA node
percpu: add raw_cpu_ops
slub: fix leak of 'name' in sysfs_slab_add
Clean asm/system.h from docs as nothing should refer to that header anymore.
This is the final piece in the puzzle, as all patches to remove the
last users of \(interruptible_\|\)sleep_on\(_timeout\|\) have made it
into the 3.15 merge window. The work was long overdue, and this
interface in particular should not have survived the BKL removal
that was done a couple of years ago.
Citing Jon Corbet from http://lwn.net/2001/0201/kernel.php3":
"[...] it was suggested that the janitors look for and fix all code
that calls sleep_on() [...] since (1) almost all such code is
incorrect, and (2) Linus has agreed that those functions should
be removed in the 2.5 development series".
We haven't quite made it for 2.5, but maybe we can merge this for 3.15.
Pull trivial tree from Jiri Kosina:
"Assorted tiny fixes queued in trivial tree"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (22 commits)
DocBook: update EXPORT_SYMBOL entry to point at export.h
Documentation: update top level 00-INDEX file with new additions
ARM: at91/ide: remove unsused at91-ide Kconfig entry
percpu_counter.h: comment code for better readability
x86, efi: fix comment typo in head_32.S
IB: cxgb3: delay freeing mem untill entirely done with it
net: mvneta: remove unneeded version.h include
time: x86: report_lost_ticks doesn't exist any more
pcmcia: avoid static analysis complaint about use-after-free
fs/jfs: Fix typo in comment : 'how may' -> 'how many'
of: add missing documentation for of_platform_populate()
btrfs: remove unnecessary cur_trans set before goto loop in join_transaction
sound: soc: Fix typo in sound/codecs
treewide: Fix typo in various drivers
btrfs: fix comment typos
Update ibmvscsi module name in Kconfig.
powerpc: fix typo (utilties -> utilities)
of: fix spelling mistake in comment
h8300: Fix home page URL in h8300/README
xtensa: Fix home page URL in Kconfig
Previously we used to get EXPORT_SYMBOL and friends from
module.h but we moved away from that since module.h largely
includes the entire header space one way or another.
As most users just wanted the simple export related macros,
they were spun off into a separate new header -- export.h
Update the docs to reflect that.
Suggested-by: Borislav Petkov <bp@alien8.de>
Acked-by: Rob Landley <rob@landley.net>
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a
while now and is almost always enabled by default. As agreed during the
Linux kernel summit, remove it from any "depends on" lines in Kconfigs.
CC: Rob Landley <rob@landley.net>
CC: Jiri Kosina <jkosina@suse.cz>
CC: Masanari Iida <standby24x7@gmail.com>
CC: Jason Wessel <jason.wessel@windriver.com>
CC: Richard L Maliszewski <richard.l.maliszewski@intel.com>
CC: Gang Wei <gang.wei@intel.com>
CC: Shane Wang <shane.wang@intel.com>
CC: Harry Wei <harryxiyou@gmail.com>
Acked-by: Jason Wessel <jason.wessel@windriver.com>
Correct multiple spelling typo in Documentation.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Reported-by: Anders Larsen <al@alarsen.net>
The sleeping inside spinlock detection is actually used
for more general sleeping inside atomic sections
debugging: preemption disabled, rcu read side critical
sections, interrupts, interrupt disabled, etc...
Change the name of the config and its help section to
reflect its more general role.
Since signal_pending() takes a task_struct pointer as an argument, update
the example to pass in 'current'.
Signed-off-by: Shawn Bohrer <shawn.bohrer@gmail.com>
Use the %pI4 format string instead of %d.%d.%d.%d and NIPQUAD.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Fix docbook fatal errors (file location changed):
docproc: lin2628-rc1/include/asm-x86/io_32.h: No such file or directory
make[1]: *** [Documentation/DocBook/deviceiobook.xml] Error 1
docproc: lin2628-rc1/include/asm-x86/atomic_32.h: No such file or directory
make[1]: *** [Documentation/DocBook/kernel-api.xml] Error 1
docproc: lin2628-rc1/include/asm-x86/mca_dma.h: No such file or directory
make[1]: *** [Documentation/DocBook/mcabook.xml] Error 1
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Fix docbook templates for modified x86 path/filenames.
__FUNCTION__ is the prefered kernel idiom, __func__ is not supported by gcc
2.95 (we actually map __FUNCTION__ to __func__ for more recent compilers,
but it should never be used directly)
Update the hacking guide, before CONFIG_PREEMPT_RT goes in and it needs
rewriting again.
Changes include modernization of quotes, removal of most references to
bottom halves (some mention required because we still use bh in places to
mean softirq).
It would be nice to have a discussion of sparse and various annotations.
Please send patches straight to akpm.
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (authored)
infrastructure for it.
Let it rip!
